NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #691 of 5106 Old 11-05-2009, 07:28 PM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
That's a disappointing AVBR on Harry Potter 6. Very poor disc utilization. Hope its not filtered.
Blu-ray : 340
lgans316 is offline
post #692 of 5106 Old 11-05-2009, 07:53 PM
Stephen Dawson's Avatar
Well, at 17.92Mbps this one has the second highest average video bitrate so far of the Harry Potters, exceeded only by Azkaban (19.3), and far in excess of Goblet (12.87) and Phoenix (13.79).
From the highdefdigest review of this last:
Warner has certainly delivered the goods, and even with the startling number of reference-quality high-def titles I've reviewed in recent weeks, 'Harry Potter and the Order of the Phoenix' easily stands tall, boasting yet another a five-star video presentation.
I've often used the term "picture window effect" in my reviews, but right from the film's opening sequence, 'Order of the Phoenix' boasts some of the most three-dimensional images I've yet seen on a next-gen title. This continues throughout the film, with the level of detail and depth to this Blu-ray disc truly fantastic. Sharp, resplendent in fine texture and perfectly balanced in terms of balance and contrast, 'Order of the Phoenix' is absolutely top tier.
Meanwhile the same place's review of Goblet (remember, just 12.87Mbps) claims that 'it looks a hair better than 'Prisoner of Azkaban,"' (which got 19.3Mbps).
Of course, all that was written when the format was still new.
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #693 of 5106 Old 11-05-2009, 11:35 PM - Thread Starter
Cinema Squid's Avatar
Originally Posted by Stephen Dawson View Post
Mr Squid: I note that the PIP stream and associated audio is asterisked as being unavailable in this playlist. As there are no other playlists for the movie content, do you think I would be correct in assuming that in BonusView playback, the whole show is managed by BD-Java rather than playlists
That is probably so. I don't know that it is particularly important that the BonusView tracks be in the MPLS playlist since it is probably managed by BD-J in any case as you propose. It does seem that certain titles have setup multiple playlists with BonusView hidden/shown, or in the case of seamlessly branching titles, regular audio and subtitle tracks hidden/shown that are are only valid for one cut (as well as mysterious multiple playlist which seem to serve no purpose whatsoever). A given track's presence in the playlist may be required for the playback device to correctly construct its OSD menu for toggling tracks.
By the way, I did see your request to correct the "Include Stream Diagnostics" options some pages back. I was hoping to come up with a few more changes at least, but in lieu of that I will likely patch another quick release with this fix and a fix for the folder name reporting problem when scanning a folder structure from hard drive - hopefully this weekend.
Cinema Squid is offline
post #694 of 5106 Old 11-06-2009, 12:04 AM
Ah, if you're going to be fiddling code, and if you get a chance, the thing I would love above all else is a graph for the audio streams, just like the video ones. That would be truly a thing of beauty.
Also, totally unimportant, but one tiny bug fix: when you generate a graph, the cursor location is shown at the bottom left in the status bar. The x axis is expressed as time, first as minutes decimal, then in parentheses as hours:minutes:seconds.decimal seconds. The decimal minutes expression is labelled 'secs', which I confess had me confused a little intially!
But that one isn't important. Even the Streams option doesn't really matter (hard drive space is, for all practical purposes, totally free these days).
It's the Audio streams graph that I'd like to see.
Stephen Dawson
hifi-writer.com
post #695 of 5106 Old 11-06-2009, 02:41 AM
patrick99's Avatar
+1
I will get this disc, but in general, when a BD is released by Warner my reaction is to assume the worst and not to buy it unless I really want to see the movie, as in this case. The fact that the last movie in the series got a favorable PQ review from one of the most "unreliable" reviewers to be found certainly has no effect on my thinking.
patrick99 is offline
post #696 of 5106 Old 11-06-2009, 03:05 AM
Ghost in the Shell/Ghost in the Shell 2.0 - 1995/2008 - Australian version
Distributed by Madman Entertainment Pty Ltd
Locked to Region B, confirmed with AnyDVD HD
For those as clueless as me, GitS 2.0 is a 2008 reanimation and re-recording with 6.1 channel sound of the original GitS, so it's technically neither a sequel nor a remake.
This one is for the GitS 2.0 version:
Code:
        Total   Video
00000.MPLS                                                      AVC     1:23:07 22,825,662,912  40,804,998,956  36.61   22.90   DTS-HD Master 6.1 4122Kbps (48kHz/24-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     GHOST IN THE SHELL 2
Disc Size:      40,804,998,956 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:23:07 (h:m:s)
Total Bitrate:          36.61 Mbps
VIDEO:
MPEG-4 AVC Video        22900 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4122 kbps       6.1 / 48 kHz / 4122 kbps / 24-bit (DTS Core: 6.1-ES / 48 kHz / 768 kbps / 24-bit)
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
DTS-HD Master Audio             Japanese        4134 kbps       6.1 / 48 kHz / 4134 kbps / 24-bit (DTS Core: 6.1-ES / 48 kHz / 768 kbps / 24-bit)
LPCM Audio                      Japanese        1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         41.530 kbps
FILES:
00000.M2TS      0:00:00.000     1:23:07.440     22,825,662,912  36,613
CHAPTERS:
1               0:00:00.000     0:04:28.142     19,362 kbps     32,546 kbps     00:04:13.962    27,369 kbps     00:04:13.670    25,639 kbps     00:04:08.081    100,930 bytes   377,376 bytes   00:04:21.636
2               0:04:28.142     0:06:56.791     23,603 kbps     43,329 kbps     00:04:31.229    37,641 kbps     00:04:28.184    30,040 kbps     00:04:28.142    123,058 bytes   371,890 bytes   00:06:48.491
3               0:11:24.934     0:06:34.102     24,093 kbps     39,109 kbps     00:15:57.998    31,891 kbps     00:15:45.235    28,516 kbps     00:15:44.568    125,612 bytes   538,878 bytes   00:16:02.962
4               0:17:59.036     0:08:07.778     25,413 kbps     43,742 kbps     00:19:05.185    36,444 kbps     00:20:32.356    32,264 kbps     00:20:32.356    132,490 bytes   404,536 bytes   00:19:06.395
5               0:26:06.815     0:09:59.849     24,259 kbps     42,407 kbps     00:27:52.045    31,413 kbps     00:27:48.792    29,550 kbps     00:28:09.062    126,476 bytes   408,458 bytes   00:32:01.628
6               0:36:06.664     0:07:01.587     23,497 kbps     38,175 kbps     00:36:32.356    31,950 kbps     00:39:07.428    31,396 kbps     00:39:05.760    122,502 bytes   516,286 bytes   00:36:38.696
7               0:43:08.252     0:06:51.661     23,800 kbps     40,177 kbps     00:44:09.605    33,693 kbps     00:45:49.329    30,668 kbps     00:47:14.498    124,083 bytes   361,989 bytes   00:44:07.478
8               0:49:59.913     0:05:22.530     25,596 kbps     41,876 kbps     00:52:22.931    38,773 kbps     00:52:22.097    35,705 kbps     00:52:22.097    133,446 bytes   404,882 bytes   00:55:20.400
9               0:55:22.444     0:04:58.798     25,673 kbps     40,553 kbps     00:55:38.543    37,972 kbps     00:55:37.876    35,416 kbps     00:55:37.876    133,848 bytes   385,816 bytes   00:57:35.952
10              1:00:21.242     0:06:22.131     25,227 kbps     42,493 kbps     01:03:37.688    34,209 kbps     01:04:02.463    29,960 kbps     01:06:25.731    131,524 bytes   348,045 bytes   01:06:20.101
11              1:06:43.374     0:07:11.264     25,448 kbps     39,547 kbps     01:07:28.878    33,136 kbps     01:07:27.835    31,704 kbps     01:07:23.914    132,675 bytes   588,643 bytes   01:13:48.382
12              1:13:54.638     0:09:12.802     11,752 kbps     32,362 kbps     01:13:56.515    27,090 kbps     01:14:20.455    25,973 kbps     01:14:18.912    61,280 bytes    385,221 bytes   01:17:33.732
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     4987.357                22,901                  14,276,791,064  77,662,254
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4987.357                4,122                   2,569,639,348   14,447,939
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           4987.357                1,542                   961,579,396     5,984,934
00000.M2TS      4354 (0x1102)   0x86            DTS-HD MA       jpn (Japanese)          4987.357                4,134                   2,577,314,188   14,490,107
00000.M2TS      4355 (0x1103)   0x80            LPCM            jpn (Japanese)          4987.357                1,542                   961,579,396     5,984,934
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4987.357                42                      25,891,570      146,390
And this is for the original 1995 version:
Code:
        Total   Video
00011.MPLS                                                      AVC     1:22:37 13,354,782,720  40,804,998,956  21.55   17.00   LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:22:37 (h:m:s)
Total Bitrate:          21.55 Mbps
VIDEO:
MPEG-4 AVC Video        16999 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
SUBTITLES:
Presentation Graphics           English         42.264 kbps
FILES:
00014.M2TS      0:00:00.000     1:22:37.886     13,354,782,720  21,549
CHAPTERS:
1               0:00:00.000     0:04:05.378     17,251 kbps     34,626 kbps     00:00:26.793    27,442 kbps     00:00:26.226    26,482 kbps     00:00:26.226    71,942 bytes    293,917 bytes   00:00:29.229
2               0:04:05.378     0:07:04.524     17,178 kbps     44,318 kbps     00:04:57.096    33,698 kbps     00:04:53.292    27,272 kbps     00:05:59.792    71,647 bytes    437,772 bytes   00:08:16.062
3               0:11:09.902     0:04:16.489     16,081 kbps     29,023 kbps     00:13:51.630    23,540 kbps     00:14:28.367    20,805 kbps     00:14:27.499    67,069 bytes    279,260 bytes   00:14:40.379
4               0:15:26.392     0:10:37.603     18,993 kbps     34,678 kbps     00:20:42.407    32,258 kbps     00:20:29.261    30,150 kbps     00:20:30.495    79,218 bytes    335,356 bytes   00:15:47.646
5               0:26:03.995     0:10:18.618     16,501 kbps     28,237 kbps     00:27:48.767    23,370 kbps     00:33:42.353    21,692 kbps     00:35:47.478    68,822 bytes    296,894 bytes   00:35:57.221
6               0:36:22.613     0:07:02.789     17,559 kbps     33,921 kbps     00:37:22.940    26,413 kbps     00:38:43.521    25,169 kbps     00:39:18.022    73,235 bytes    311,707 bytes   00:36:46.938
7               0:43:25.402     0:06:50.977     16,999 kbps     33,503 kbps     00:46:03.260    31,282 kbps     00:45:59.356    26,797 kbps     00:45:55.119    70,900 bytes    302,090 bytes   00:49:57.961
8               0:50:16.380     0:05:09.742     17,207 kbps     31,590 kbps     00:55:20.116    29,745 kbps     00:55:16.112    25,560 kbps     00:55:16.112    71,770 bytes    319,551 bytes   00:52:15.265
9               0:55:26.122     0:05:08.241     18,188 kbps     31,744 kbps     00:58:52.462    26,594 kbps     00:55:41.538    25,231 kbps     00:55:41.538    75,859 bytes    274,023 bytes   00:55:35.665
10              1:00:34.364     0:06:24.550     17,558 kbps     35,806 kbps     01:03:49.225    30,301 kbps     01:06:38.127    24,798 kbps     01:03:55.565    73,233 bytes    303,271 bytes   01:06:42.999
11              1:06:58.914     0:07:09.829     16,582 kbps     34,661 kbps     01:07:41.824    27,956 kbps     01:07:39.388    22,434 kbps     01:07:38.587    69,163 bytes    327,008 bytes   01:13:55.898
12              1:14:08.744     0:08:29.141     13,920 kbps     24,898 kbps     01:17:47.696    23,336 kbps     01:17:43.692    22,974 kbps     01:17:30.679    58,063 bytes    286,803 bytes   01:17:48.664
STREAM DIAGNOSTICS:
00014.M2TS      4113 (0x1011)   0x1B            AVC                                     4957.753                17,000                  10,535,135,191  57,342,986
00014.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           4957.753                1,542                   955,881,192     5,949,468
00014.M2TS      4353 (0x1101)   0x80            LPCM            jpn (Japanese)          4957.753                1,542                   955,888,904     5,949,516
00014.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4957.753                42                      26,192,573      148,087
Stephen Dawson
hifi-writer.com
post #697 of 5106 Old 11-06-2009, 05:01 AM
Ghost in the Shell 2: Innocence - 2004 - Australian version
Region Free, confirmed with AnyDVD HD. Note: the two substantial extras -- a 16 minute 'Making Of' featurette and a 24 minute interview with the director -- are in 1080i50 format, and so may be incompatible with some equipment.
Code:
        Total   Video
00000.MPLS                                                      AVC     1:39:53 28,376,619,456  35,382,384,904  37.87   27.89   DTS-HD Master 5.1 1922Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     GHOST IN THE SHELL INNOCENCE
Disc Size:      35,382,384,904 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:39:53 (h:m:s)
Total Bitrate:          37.87 Mbps
VIDEO:
MPEG-4 AVC Video        27885 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1922 kbps       5.1 / 48 kHz / 1922 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 16-bit)
DTS-HD Master Audio             Japanese        1821 kbps       5.1 / 48 kHz / 1821 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 16-bit)
DTS-HD Master Audio             Spanish         1883 kbps       5.1 / 48 kHz / 1883 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 16-bit)
LPCM Audio                      Catalan         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
Dolby Digital Audio             Japanese        256 kbps        2.0 / 48 kHz / 256 kbps
SUBTITLES:
Presentation Graphics           English         31.303 kbps
Presentation Graphics           Spanish         41.210 kbps
Presentation Graphics           English         80.230 kbps
Presentation Graphics           Spanish         85.173 kbps
FILES:
00000.M2TS      0:00:00.000     1:39:53.779     28,376,619,456  37,874
CHAPTERS:
1               0:00:00.000     0:09:04.669     20,985 kbps     46,764 kbps     00:08:04.525    40,019 kbps     00:03:56.653    36,155 kbps     00:03:55.276    109,397 bytes   498,656 bytes   00:05:16.733
2               0:09:04.669     0:04:50.623     26,068 kbps     37,702 kbps     00:09:27.024    35,153 kbps     00:11:26.185    32,574 kbps     00:11:21.180    135,908 bytes   433,198 bytes   00:13:55.251
3               0:13:55.292     0:07:06.426     29,720 kbps     43,881 kbps     00:14:09.348    40,532 kbps     00:14:06.220    37,722 kbps     00:14:05.928    154,945 bytes   516,663 bytes   00:17:12.698
4               0:21:01.718     0:03:45.350     28,176 kbps     34,865 kbps     00:22:49.659    30,967 kbps     00:22:47.491    30,350 kbps     00:23:01.088    146,898 bytes   425,198 bytes   00:21:53.729
5               0:24:47.068     0:07:45.923     29,243 kbps     45,109 kbps     00:25:05.504    38,785 kbps     00:25:36.368    35,463 kbps     00:25:31.404    152,459 bytes   470,766 bytes   00:31:26.885
6               0:32:32.992     0:06:41.526     30,019 kbps     47,720 kbps     00:35:16.781    41,431 kbps     00:35:15.530    37,691 kbps     00:35:15.988    156,507 bytes   452,378 bytes   00:36:18.551
7               0:39:14.518     0:04:14.879     30,049 kbps     45,993 kbps     00:39:49.678    40,165 kbps     00:39:48.260    37,138 kbps     00:39:46.342    156,661 bytes   434,948 bytes   00:39:46.384
8               0:43:29.398     0:07:05.633     31,879 kbps     44,998 kbps     00:47:17.709    40,547 kbps     00:49:33.220    38,432 kbps     00:47:17.584    166,202 bytes   492,662 bytes   00:49:48.819
9               0:50:35.032     0:06:31.182     30,793 kbps     44,895 kbps     00:55:23.570    40,501 kbps     00:55:20.567    38,338 kbps     00:55:18.273    160,543 bytes   476,893 bytes   00:51:52.692
10              0:57:06.214     0:05:17.984     27,908 kbps     46,764 kbps     00:57:47.839    41,659 kbps     00:59:05.375    34,715 kbps     00:59:01.371    145,499 bytes   450,291 bytes   00:58:12.530
11              1:02:24.198     0:06:35.228     29,521 kbps     46,074 kbps     01:05:16.829    39,550 kbps     01:08:28.479    37,409 kbps     01:02:54.896    153,911 bytes   426,869 bytes   01:05:10.948
12              1:08:59.426     0:06:48.157     28,842 kbps     45,953 kbps     01:10:41.779    41,444 kbps     01:10:40.611    34,639 kbps     01:10:41.028    150,368 bytes   421,448 bytes   01:12:39.438
13              1:15:47.584     0:05:25.074     32,106 kbps     47,469 kbps     01:18:47.222    39,910 kbps     01:18:47.180    36,146 kbps     01:18:43.802    167,388 bytes   462,079 bytes   01:18:12.896
14              1:21:12.659     0:06:47.365     32,590 kbps     49,066 kbps     01:25:14.234    39,485 kbps     01:24:43.953    37,308 kbps     01:24:43.787    169,908 bytes   496,292 bytes   01:24:46.164
15              1:28:00.024     0:06:44.028     32,050 kbps     44,740 kbps     01:33:08.416    37,595 kbps     01:33:04.370    36,156 kbps     01:33:02.451    167,093 bytes   467,970 bytes   01:33:25.933
16              1:34:44.053     0:05:09.726     3,820 kbps      9,360 kbps      01:37:15.454    8,735 kbps      01:37:13.285    7,945 kbps      01:37:10.741    19,921 bytes    159,459 bytes   01:37:15.996
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5993.696                27,886                  20,892,451,624  113,631,634
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5993.696                1,922                   1,440,350,128   8,406,160
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       jpn (Japanese)          5993.696                1,821                   1,364,219,108   7,995,150
00000.M2TS      4354 (0x1102)   0x86            DTS-HD MA       spa (Spanish)           5993.696                1,883                   1,410,526,776   8,243,155
00000.M2TS      4355 (0x1103)   0x80            LPCM            cat (Catalan)           5993.696                1,543                   1,155,737,672   7,193,388
00000.M2TS      4356 (0x1104)   0x81            AC3             jpn (Japanese)          5993.696                256                     191,800,320     1,123,830
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5993.696                31                      23,452,898      132,375
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5993.696                41                      30,875,398      172,252
00000.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           5993.696                80                      60,110,621      338,333
00000.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           5993.696                85                      63,814,217      357,746
Stephen Dawson
hifi-writer.com
post #698 of 5106 Old 11-06-2009, 10:25 AM
Phloyd's Avatar
Hey Stephen,
Are you getting any of those Icon releases like Amelie, Once Were Warriors or Eagle vs. Shark? I am very curious to see what those are like...
Phloyd is offline
post #699 of 5106 Old 11-06-2009, 06:50 PM - Thread Starter
Code:
DISC INFO:
Disc Title:     NETFLIX INSTANT STREAMING DISC
Disc Size:      189,959,798 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
How'd they fit so many movies and television shows onto such an under-utilized disc?!?
post #700 of 5106 Old 11-07-2009, 01:49 AM
CRT Dude's Avatar
Its a shame AACS LA gets paid to copy protect a jar file.
CRT Dude is offline
post #701 of 5106 Old 11-07-2009, 05:07 AM
Originally Posted by Phloyd View Post
Hey Stephen,
I'm hoping to, but I rarely know for sure until they turn up in the mail. There are some excellent titles coming up from them.
Stephen Dawson
hifi-writer.com
post #702 of 5106 Old 11-07-2009, 05:30 AM
Harry Potter and the Half-Blood Prince - Disc 2
We don't normally talk much here about special extras, but there were a couple of oddities on Disc 2 of this release, and when others get their hands on a copy, I'd be keen to see if one of them is confirmed.
The first oddity is the organisation of the 'Making Of' featurettes. There are eight of these under the title of 'Close-Up with the Cast of Harry Potter'. They are delivered in a more inventive way than usual, with a cast member 'interviewing' someone responsible for some aspect of production (eg. 'Editing With Daniel Radcliffe'). All are presented in 1080p24 VC1.
There is a 'Play All' to go with these. Normally a set of clips with a 'Play All' has a separate *.m2ts file for each clip, and the 'Play All' runs through all the files. Rarely, but occasionally, all the clips are in one *.m2ts file, which the 'Play All' runs, and the individual clip playlists hook into this file at various points.
This disc has an individual *.m2ts file for each clip, plus a separate *.m2ts file for the 'Play All'. So it blows about 3GB of disc space, but it doesn't really matter since the entire disc only comes to about 16GB.
The other oddity -- the one that I'd be interested in others confirming -- concerns the major doco on the disc: 'J.K.Rowling: A Year in the Life'. This 50 minute piece is also presented in 1080p24, but at the start it actually looks like 1080i60, with a deinterlacing failure, showing visible combing. The problems only seem to be in the first minute or so. When it gets to video of the book coming off the production line, there's a weird set of dots flashing up over the picture, and then on the second appearance after this of Rowling's face there are a couple of major flashes of macro blocking. All most unusual.
I haven't watched this doco, so the stuff may appear later (I just jumped to a dozen different spots randomly throughout and didn't see anything amiss).
Stephen Dawson
hifi-writer.com
post #703 of 5106 Old 11-07-2009, 07:38 AM
sschen's Avatar
Quoted: 47 Post(s)
Code:
        Total   Video
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
VIDEO:
AUDIO:
SUBTITLES:
FILES:
CHAPTERS:
STREAM DIAGNOSTICS:
I am a bit confused by this, how come it is 1080i even though it is 30fps? I thought 1080i is only when the frame rate is 25fps?
sschen is offline
post #704 of 5106 Old 11-07-2009, 12:43 PM
Blu-ray supports both 1080i50 and 1080i60 (which, when their content is progressive, are 25 and 30fps respectively). 1080i60 is actually more common than 1080i50.
Stephen Dawson
hifi-writer.com
post #705 of 5106 Old 11-09-2009, 12:37 PM
Phloyd's Avatar
Yeah, I am seriously tempted to just order them from Amazon.
Got plenty to watch right now though so probably best to save my $$$ for a bit...
Phloyd is offline
post #706 of 5106 Old 11-09-2009, 12:39 PM
Phloyd's Avatar
My Life In Ruins [USA]
UPC: 24543602446
Studio: Fox Home Entertainment
Release Date: 2009-10-06
Aspect Ratio: 1.85:1
Region Code: A
Note that this is a RENTAL VERSION! Anyone with the retail version - please post for comparison.
My Life In Ruins Blu-ray Screen Caps Here
Code:
        Total   Video
My Life in Ruins                                                AVC     1:35:15 27,892,819,968  29,999,147,888  39.04   32.65   DTS-HD Master 5.1 3853Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     MYLIFEINRUINS_RENTAL
Disc Size:      29,999,147,888 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:35:15 (h:m:s)
Total Bitrate:          39.04 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        32654 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3853 kbps       5.1 / 48 kHz / 3853 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps
SUBTITLES:
Presentation Graphics           English         46.125 kbps
Presentation Graphics           English         0.515 kbps
Presentation Graphics           French          0.635 kbps
Presentation Graphics           Spanish         37.319 kbps
FILES:
00218.M2TS      0:00:00.000     1:35:15.584     27,892,819,968  39,041
CHAPTERS:
1               0:00:00.000     0:05:56.731     31,723 kbps     37,733 kbps     00:04:19.342    35,317 kbps     00:04:15.338    35,050 kbps     00:04:10.333    165,369 bytes   628,016 bytes   00:01:14.991
2               0:05:56.731     0:03:45.308     34,604 kbps     36,744 kbps     00:07:54.474    35,214 kbps     00:06:35.395    35,026 kbps     00:06:30.390    180,411 bytes   419,363 bytes   00:06:01.527
3               0:09:42.039     0:03:44.140     34,303 kbps     36,391 kbps     00:11:02.286    35,154 kbps     00:11:02.286    34,962 kbps     00:10:06.731    178,839 bytes   459,710 bytes   00:11:07.166
4               0:13:26.180     0:03:42.347     32,654 kbps     36,952 kbps     00:16:00.584    35,094 kbps     00:13:42.738    34,978 kbps     00:13:37.733    170,244 bytes   478,096 bytes   00:17:07.359
5               0:17:08.527     0:04:37.235     32,901 kbps     36,644 kbps     00:19:42.014    35,187 kbps     00:20:38.987    35,000 kbps     00:20:33.982    171,533 bytes   430,146 bytes   00:20:24.306
6               0:21:45.762     0:04:02.951     33,209 kbps     37,874 kbps     00:23:25.195    35,409 kbps     00:23:21.191    35,033 kbps     00:21:54.229    173,136 bytes   409,616 bytes   00:21:50.767
7               0:25:48.713     0:03:27.457     31,955 kbps     36,651 kbps     00:27:28.647    35,053 kbps     00:28:45.265    34,945 kbps     00:28:12.899    166,596 bytes   425,222 bytes   00:27:30.398
8               0:29:16.171     0:03:43.765     32,020 kbps     36,223 kbps     00:30:15.355    35,019 kbps     00:30:16.272    34,865 kbps     00:29:17.630    166,938 bytes   434,888 bytes   00:29:35.648
9               0:32:59.936     0:03:37.800     33,220 kbps     37,727 kbps     00:33:28.631    35,182 kbps     00:33:24.627    34,752 kbps     00:33:49.444    173,192 bytes   396,049 bytes   00:35:39.387
10              0:36:37.737     0:04:38.778     33,941 kbps     36,494 kbps     00:37:18.861    35,080 kbps     00:39:59.814    34,873 kbps     00:40:57.705    176,954 bytes   445,306 bytes   00:40:03.025
11              0:41:16.515     0:04:21.678     34,463 kbps     37,255 kbps     00:43:22.808    35,358 kbps     00:43:35.613    35,068 kbps     00:43:30.733    179,677 bytes   496,882 bytes   00:43:23.726
12              0:45:38.193     0:04:55.712     31,482 kbps     36,612 kbps     00:45:41.780    34,949 kbps     00:49:49.403    34,851 kbps     00:49:07.235    164,135 bytes   406,590 bytes   00:45:41.196
13              0:50:33.905     0:04:38.486     33,408 kbps     36,537 kbps     00:52:24.015    35,198 kbps     00:52:24.099    34,993 kbps     00:52:23.932    174,174 bytes   445,386 bytes   00:52:32.941
14              0:55:12.392     0:03:51.856     32,192 kbps     37,075 kbps     00:57:02.252    35,225 kbps     00:55:59.689    35,044 kbps     00:55:54.726    167,833 bytes   459,121 bytes   00:56:06.696
15              0:59:04.249     0:04:46.119     34,442 kbps     37,811 kbps     00:59:31.234    35,339 kbps     00:59:55.341    35,080 kbps     01:00:16.654    179,565 bytes   502,338 bytes   01:00:03.308
16              1:03:50.368     0:03:05.185     34,519 kbps     37,875 kbps     01:04:17.687    35,420 kbps     01:04:13.683    35,121 kbps     01:04:08.678    179,966 bytes   399,207 bytes   01:04:18.479
17              1:06:55.553     0:04:09.415     30,535 kbps     36,046 kbps     01:09:16.277    35,049 kbps     01:09:12.273    34,905 kbps     01:09:07.268    159,193 bytes   325,691 bytes   01:10:50.246
18              1:11:04.969     0:04:46.286     33,898 kbps     36,432 kbps     01:13:00.667    35,133 kbps     01:13:35.160    34,931 kbps     01:13:33.492    176,730 bytes   380,872 bytes   01:12:59.708
19              1:15:51.255     0:02:02.163     34,526 kbps     38,051 kbps     01:16:22.494    35,268 kbps     01:16:18.448    34,983 kbps     01:17:42.741    180,001 bytes   428,740 bytes   01:16:24.955
20              1:17:53.418     0:02:47.709     30,329 kbps     36,314 kbps     01:20:04.633    34,966 kbps     01:19:56.750    34,585 kbps     01:17:56.380    158,124 bytes   360,973 bytes   01:20:41.127
21              1:20:41.127     0:03:18.615     34,560 kbps     37,370 kbps     01:22:10.550    35,269 kbps     01:22:10.592    35,006 kbps     01:21:31.803    180,177 bytes   492,569 bytes   01:21:25.839
22              1:23:59.743     0:01:14.282     34,629 kbps     36,477 kbps     01:25:11.689    35,274 kbps     01:25:07.602    35,016 kbps     01:25:02.680    180,538 bytes   318,181 bytes   01:25:12.357
23              1:25:14.025     0:04:58.673     31,357 kbps     36,563 kbps     01:29:44.712    35,163 kbps     01:29:40.708    34,742 kbps     01:25:37.257    163,483 bytes   434,011 bytes   01:29:42.752
24              1:30:12.698     0:05:02.885     26,815 kbps     37,174 kbps     01:30:49.235    34,798 kbps     01:34:30.873    34,663 kbps     01:34:28.871    139,819 bytes   532,467 bytes   01:30:29.715
STREAM DIAGNOSTICS:
00218.M2TS      4113 (0x1011)   0x1B            AVC                                     5715.460                32,654                  23,329,310,138  126,870,356
00218.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5715.460                3,854                   2,753,073,752   15,853,429
00218.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            5715.460                448                     320,074,496     1,786,130
00218.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5715.460                46                      32,953,643      190,417
00218.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5715.460                37                      26,662,278      153,864
00218.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5715.460                1                       453,782         2,591
00218.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           5715.460                1                       368,003         2,112
Phloyd is offline
post #707 of 5106 Old 11-09-2009, 12:41 PM
Phloyd's Avatar
Full report for Next.
Next [USA]
UPC: 97361312545
Studio: Paramount Home Entertainment
Release Date: 2008-06-03
Aspect Ratio: 2.35:1
Region Code: A,B,C
Next Blu-ray Screen Caps Here
Code:
        Total   Video
Next                                                            AVC     1:36:10 30,727,809,024  39,473,700,963  42.60   31.93   LPCM 5.1 6912Kbps (48kHz/24-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     NEXT
Disc Size:      39,473,700,963 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:36:10 (h:m:s)
Total Bitrate:          42.60 Mbps
VIDEO:
MPEG-4 AVC Video        31927 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         6912 kbps       5.1 / 48 kHz / 6912 kbps / 24-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             French          192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         30.186 kbps
Presentation Graphics           English         31.550 kbps
Presentation Graphics           French          29.298 kbps
Presentation Graphics           Portuguese      25.726 kbps
Presentation Graphics           Spanish         25.565 kbps
FILES:
00000.M2TS      0:00:00.000     1:36:10.765     30,727,809,024  42,598
CHAPTERS:
1               0:00:00.000     0:02:28.773     27,178 kbps     54,386 kbps     00:01:10.320    39,979 kbps     00:01:14.616    37,348 kbps     00:00:01.918    141,656 bytes   755,958 bytes   00:02:26.813
2               0:02:28.773     0:07:37.540     35,219 kbps     50,269 kbps     00:03:07.020    39,310 kbps     00:03:03.308    37,504 kbps     00:02:58.303    183,616 bytes   723,616 bytes   00:02:52.380
3               0:10:06.314     0:01:39.641     30,103 kbps     54,037 kbps     00:10:08.649    37,680 kbps     00:10:06.314    35,761 kbps     00:10:06.314    156,944 bytes   764,384 bytes   00:11:45.955
4               0:11:45.955     0:04:29.018     32,868 kbps     44,641 kbps     00:12:56.942    37,776 kbps     00:12:52.396    36,925 kbps     00:12:47.349    171,357 bytes   700,474 bytes   00:13:44.657
5               0:16:14.974     0:03:59.447     34,454 kbps     47,407 kbps     00:20:08.540    38,378 kbps     00:16:49.133    37,868 kbps     00:17:00.144    179,627 bytes   696,981 bytes   00:17:22.666
6               0:20:14.421     0:00:48.256     30,939 kbps     43,896 kbps     00:20:34.441    34,791 kbps     00:20:46.620    33,709 kbps     00:20:47.162    161,304 bytes   659,462 bytes   00:20:18.550
7               0:21:02.678     0:06:52.203     33,478 kbps     48,065 kbps     00:24:56.703    40,080 kbps     00:25:06.213    38,009 kbps     00:25:06.213    174,537 bytes   749,767 bytes   00:22:35.145
8               0:27:54.881     0:02:22.642     30,497 kbps     40,767 kbps     00:29:10.957    35,750 kbps     00:28:51.312    34,846 kbps     00:29:09.956    158,999 bytes   676,977 bytes   00:28:51.396
9               0:30:17.524     0:06:01.110     33,054 kbps     43,753 kbps     00:33:44.897    39,405 kbps     00:33:09.445    38,252 kbps     00:33:44.105    172,327 bytes   769,546 bytes   00:33:18.997
10              0:36:18.634     0:05:53.978     32,903 kbps     54,773 kbps     00:38:34.186    39,507 kbps     00:39:28.157    38,512 kbps     00:37:42.218    171,544 bytes   770,233 bytes   00:38:34.395
11              0:42:12.613     0:06:08.159     31,853 kbps     44,525 kbps     00:43:03.122    38,468 kbps     00:42:15.449    36,995 kbps     00:42:15.449    166,067 bytes   769,488 bytes   00:45:44.658
12              0:48:20.772     0:07:49.844     34,386 kbps     46,534 kbps     00:53:22.365    39,721 kbps     00:54:12.624    37,513 kbps     00:53:22.365    179,272 bytes   781,055 bytes   00:50:44.666
13              0:56:10.617     0:05:50.475     32,211 kbps     47,487 kbps     00:58:26.503    38,286 kbps     00:58:40.850    37,586 kbps     01:00:16.279    167,931 bytes   762,498 bytes   01:00:21.159
14              1:02:01.092     0:09:03.834     32,714 kbps     51,374 kbps     01:05:48.527    39,024 kbps     01:07:17.491    38,321 kbps     01:07:12.236    170,558 bytes   782,014 bytes   01:09:24.702
15              1:11:04.927     0:08:11.949     33,188 kbps     49,734 kbps     01:11:30.577    38,835 kbps     01:18:03.095    38,200 kbps     01:17:58.840    173,026 bytes   772,001 bytes   01:11:25.864
16              1:19:16.877     0:06:50.201     33,373 kbps     44,479 kbps     01:23:25.542    38,352 kbps     01:23:30.547    38,137 kbps     01:23:25.542    173,990 bytes   760,903 bytes   01:24:32.817
17              1:26:07.078     0:04:29.602     32,393 kbps     45,110 kbps     01:26:54.626    35,714 kbps     01:26:50.788    34,440 kbps     01:29:51.219    168,880 bytes   691,225 bytes   01:30:25.753
18              1:30:36.681     0:05:34.083     15,128 kbps     54,544 kbps     01:36:04.592    27,366 kbps     01:36:04.216    19,952 kbps     01:32:52.066    78,891 bytes    644,928 bytes   01:36:05.509
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5770.682                31,927                  23,030,194,291  125,245,493
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5770.682                640                     461,662,720     2,705,055
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           5770.682                6,919                   4,990,557,572   27,699,672
00000.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            5770.682                192                     138,498,816     901,685
00000.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           5770.682                640                     461,662,720     2,705,055
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5770.682                30                      21,774,249      124,831
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5770.682                32                      22,758,716      130,426
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5770.682                29                      21,133,973      121,383
00000.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           5770.682                26                      18,440,876      106,395
00000.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        5770.682                26                      18,557,106      107,310
Phloyd is offline
post #708 of 5106 Old 11-09-2009, 06:42 PM - Thread Starter
[US] Predator 2 (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Fox
Release Date: 2009-06-09
UPC: 024543589112
DD 2.0 w/ Dolby Surround encoding is an original audio track - the other two are commentaries. Besides the different language options, the video and main audio seem identical to the UK release, reported here:
https://www.avsforum.com/avs-vb/showp...postcount=1196
Code:
        Total   Video
[US] Predator 2                                                 AVC     1:48:00 35,525,738,496  41,381,164,699  43.86   34.87   DTS-HD Master 5.1 4404Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     PREDATOR2
Disc Size:      41,381,164,699 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:48:00 (h:m:s)
Total Bitrate:          43.86 Mbps
VIDEO:
MPEG-4 AVC Video        34871 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4404 kbps       5.1 / 48 kHz / 4404 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         27.167 kbps
Presentation Graphics           French          0.109 kbps
Presentation Graphics           Spanish         23.088 kbps
Presentation Graphics           Spanish         0.015 kbps
FILES:
00074.M2TS      0:00:00.000     1:48:00.015     35,525,738,496  43,859
CHAPTERS:
1               0:00:00.000     0:03:11.816     33,604 kbps     44,241 kbps     00:02:11.131    36,906 kbps     00:01:52.570    36,067 kbps     00:01:25.251    175,158 bytes   459,766 bytes   00:01:57.534
2               0:03:11.816     0:04:14.504     35,298 kbps     37,596 kbps     00:05:29.078    35,923 kbps     00:04:55.003    35,750 kbps     00:04:17.632    184,027 bytes   304,223 bytes   00:07:23.568
3               0:07:26.320     0:04:14.087     34,935 kbps     40,083 kbps     00:09:09.757    35,938 kbps     00:10:02.393    35,776 kbps     00:10:14.405    182,134 bytes   325,138 bytes   00:09:10.633
4               0:11:40.408     0:02:24.978     35,280 kbps     37,435 kbps     00:13:40.528    35,998 kbps     00:13:42.446    35,808 kbps     00:13:41.237    183,933 bytes   356,222 bytes   00:13:41.487
5               0:14:05.386     0:01:57.951     35,467 kbps     37,023 kbps     00:15:02.902    35,929 kbps     00:14:08.806    35,772 kbps     00:15:43.233    184,911 bytes   300,187 bytes   00:16:03.337
6               0:16:03.337     0:02:54.632     34,567 kbps     37,169 kbps     00:18:28.315    35,905 kbps     00:18:24.102    35,698 kbps     00:17:11.572    180,215 bytes   308,277 bytes   00:18:11.632
7               0:18:57.970     0:03:23.453     34,550 kbps     38,648 kbps     00:19:38.385    35,825 kbps     00:20:51.917    35,728 kbps     00:20:46.912    180,129 bytes   285,364 bytes   00:20:34.274
8               0:22:21.423     0:03:27.332     35,132 kbps     40,257 kbps     00:25:47.295    35,988 kbps     00:25:43.291    35,791 kbps     00:23:37.874    183,161 bytes   357,071 bytes   00:25:48.046
9               0:25:48.755     0:03:15.111     34,654 kbps     36,830 kbps     00:26:36.094    35,915 kbps     00:26:32.090    35,813 kbps     00:26:27.085    180,672 bytes   295,108 bytes   00:26:04.771
10              0:29:03.867     0:01:16.326     35,409 kbps     36,712 kbps     00:29:40.195    35,848 kbps     00:29:30.685    35,726 kbps     00:29:27.515    184,605 bytes   296,116 bytes   00:29:41.112
11              0:30:20.193     0:02:21.015     35,516 kbps     37,148 kbps     00:31:32.307    35,844 kbps     00:31:28.094    35,739 kbps     00:31:41.024    185,163 bytes   275,318 bytes   00:31:32.849
12              0:32:41.209     0:03:58.655     33,958 kbps     37,064 kbps     00:36:16.757    35,891 kbps     00:33:31.092    35,754 kbps     00:32:52.512    177,041 bytes   311,325 bytes   00:36:17.717
13              0:36:39.864     0:04:22.136     35,255 kbps     36,906 kbps     00:36:40.615    35,886 kbps     00:38:17.378    35,763 kbps     00:39:53.099    183,802 bytes   315,766 bytes   00:36:40.865
14              0:41:02.001     0:01:58.409     35,494 kbps     36,885 kbps     00:42:43.769    35,908 kbps     00:42:39.765    35,769 kbps     00:42:34.760    185,050 bytes   296,354 bytes   00:42:46.480
15              0:43:00.411     0:04:17.465     34,808 kbps     37,706 kbps     00:43:30.691    36,050 kbps     00:43:21.890    35,846 kbps     00:43:21.682    181,473 bytes   293,297 bytes   00:43:53.797
16              0:47:17.876     0:03:55.944     34,778 kbps     40,448 kbps     00:50:04.584    36,160 kbps     00:50:00.580    35,982 kbps     00:49:55.617    181,315 bytes   315,602 bytes   00:50:05.377
17              0:51:13.820     0:02:29.232     35,532 kbps     38,600 kbps     00:52:54.671    36,130 kbps     00:53:04.431    35,918 kbps     00:52:45.662    185,248 bytes   324,627 bytes   00:51:56.571
18              0:53:43.053     0:04:31.354     34,136 kbps     40,354 kbps     00:55:15.145    36,246 kbps     00:55:13.977    35,700 kbps     00:54:23.802    177,968 bytes   390,845 bytes   00:56:26.049
19              0:58:14.407     0:03:04.309     34,796 kbps     38,295 kbps     00:58:25.501    35,844 kbps     00:58:42.310    35,693 kbps     00:58:37.305    181,411 bytes   273,535 bytes   01:00:43.014
20              1:01:18.716     0:03:27.874     34,662 kbps     37,550 kbps     01:04:42.128    35,820 kbps     01:01:47.161    35,731 kbps     01:01:40.947    180,709 bytes   319,129 bytes   01:04:44.630
21              1:04:46.591     0:02:49.669     34,883 kbps     41,065 kbps     01:05:13.576    36,256 kbps     01:05:12.199    35,678 kbps     01:05:11.741    181,861 bytes   412,393 bytes   01:05:35.431
22              1:07:36.260     0:08:05.610     34,757 kbps     43,386 kbps     01:14:11.405    36,118 kbps     01:10:06.410    35,829 kbps     01:10:01.363    181,207 bytes   299,733 bytes   01:14:11.947
23              1:15:41.870     0:01:07.650     35,167 kbps     37,991 kbps     01:16:40.429    35,885 kbps     01:15:58.178    35,772 kbps     01:15:53.131    183,346 bytes   289,736 bytes   01:16:49.521
24              1:16:49.521     0:02:33.695     35,093 kbps     39,207 kbps     01:18:22.781    36,435 kbps     01:18:18.777    35,867 kbps     01:18:13.772    182,958 bytes   324,338 bytes   01:18:23.699
25              1:19:23.216     0:02:38.575     35,430 kbps     37,900 kbps     01:21:32.470    35,886 kbps     01:19:30.599    35,776 kbps     01:19:30.849    184,714 bytes   324,912 bytes   01:20:23.568
26              1:22:01.791     0:04:09.123     34,216 kbps     40,008 kbps     01:25:45.431    36,044 kbps     01:25:44.931    35,809 kbps     01:24:37.739    178,387 bytes   302,991 bytes   01:25:46.182
27              1:26:10.915     0:05:21.279     35,304 kbps     37,173 kbps     01:27:59.357    35,931 kbps     01:27:55.353    35,746 kbps     01:30:27.880    184,061 bytes   308,312 bytes   01:27:05.220
28              1:31:32.195     0:02:06.126     35,158 kbps     37,548 kbps     01:32:19.242    36,007 kbps     01:32:15.238    35,734 kbps     01:33:09.667    183,299 bytes   297,675 bytes   01:32:07.813
29              1:33:38.321     0:02:41.119     35,515 kbps     37,359 kbps     01:35:15.459    35,862 kbps     01:35:22.299    35,763 kbps     01:36:09.430    185,157 bytes   276,279 bytes   01:36:19.440
30              1:36:19.440     0:01:35.136     35,492 kbps     37,180 kbps     01:37:22.002    35,885 kbps     01:36:25.988    35,710 kbps     01:36:39.210    185,039 bytes   270,472 bytes   01:37:25.714
31              1:37:54.577     0:03:54.025     34,788 kbps     38,123 kbps     01:38:49.173    35,841 kbps     01:41:19.281    35,741 kbps     01:38:59.850    181,370 bytes   249,516 bytes   01:38:50.758
32              1:41:48.602     0:06:11.412     34,751 kbps     38,844 kbps     01:42:39.027    36,035 kbps     01:44:06.365    35,742 kbps     01:44:54.204    181,197 bytes   317,946 bytes   01:46:44.898
STREAM DIAGNOSTICS:
00074.M2TS      4113 (0x1011)   0x1B            AVC                                     6479.890                34,871                  28,245,247,124  153,598,316
00074.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6479.890                4,404                   3,567,191,620   20,397,308
00074.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6479.890                224                     181,440,896     1,012,505
00074.M2TS      4354 (0x1102)   0x82            DTS             spa (Spanish)           6479.890                768                     622,082,048     3,645,012
00074.M2TS      4355 (0x1103)   0x82            DTS             fra (French)            6479.890                768                     622,082,048     3,645,012
00074.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           6479.890                224                     181,440,896     1,012,505
00074.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           6479.890                224                     181,440,896     1,012,505
00074.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6479.890                27                      22,005,541      126,993
00074.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6479.890                23                      18,701,498      107,318
00074.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6479.890                0                       12,012          72
00074.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            6479.890                0                       88,057          505
post #709 of 5106 Old 11-09-2009, 06:47 PM
jd213's Avatar
Funny how the UK release was region free yet the US release was region locked. Seems pointless considering the UK release came out months beforehand and got cheap on Amazon.co.uk real fast so I don't see importing the US release to the UK/Europe as being particularly tempting.
jd213 is offline
post #710 of 5106 Old 11-09-2009, 06:57 PM - Thread Starter
UPC: 24543602446
Region Code: A
Does this seem to be missing any of the features listed in the reviews? Not that it really has many features in the first place, so a rental-exclusive crippled version hardly seems worth the effort...
I have a few scans of stripped-down rental versions myself that I've yet to post, although in those cases the full version was already posted by someone else so it didn't seem pressing.
post #711 of 5106 Old 11-09-2009, 07:46 PM
Patsfan123's Avatar
Quoted: 470 Post(s)
Liked: 309
I'd be interested in seeing those Squid..
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #712 of 5106 Old 11-09-2009, 08:26 PM
Phloyd's Avatar
TBH I haven't even looked at it yet... just processed it
Phloyd is offline
post #713 of 5106 Old 11-09-2009, 11:46 PM
Phloyd's Avatar
Full details for Shooter:
Shooter [USA]
UPC: 97361300702
Release Date: 2007-07-31
Region Code: A,B,C
Shooter Blu-ray Screen Caps Here
Code:
        Total   Video
Shooter                                                         MPEG-2  2:05:41 30,405,734,400  39,058,040,880  32.25   28.36   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     SHOOTER
Disc Size:      39,058,040,880 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:05:41 (h:m:s)
Total Bitrate:          32.25 Mbps
VIDEO:
MPEG-2 Video            28364 kbps          1080p / 23.976 fps / 16:9
AUDIO:
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         34.949 kbps
Presentation Graphics           English         36.980 kbps
Presentation Graphics           French          35.443 kbps
Presentation Graphics           Portuguese      30.291 kbps
Presentation Graphics           Spanish         29.491 kbps
FILES:
00003.M2TS      0:00:00.000     2:05:41.534     30,405,734,400  32,254
CHAPTERS:
1               0:00:00.000     0:08:13.117     29,707 kbps     36,763 kbps     00:07:07.260    33,681 kbps     00:01:56.991    32,940 kbps     00:06:00.735    154,864 bytes   680,276 bytes   00:02:38.074
2               0:08:13.117     0:08:09.572     27,169 kbps     35,455 kbps     00:08:58.162    32,679 kbps     00:08:57.954    31,180 kbps     00:08:38.768    141,646 bytes   680,276 bytes   00:11:33.734
3               0:16:22.690     0:06:50.618     28,256 kbps     35,718 kbps     00:20:34.858    32,627 kbps     00:20:30.854    31,483 kbps     00:20:29.603    147,315 bytes   680,274 bytes   00:18:07.628
4               0:23:13.308     0:08:23.836     29,163 kbps     36,617 kbps     00:28:06.017    32,653 kbps     00:27:57.384    32,034 kbps     00:27:54.714    152,045 bytes   680,276 bytes   00:26:42.642
5               0:31:37.145     0:07:25.486     29,218 kbps     37,058 kbps     00:34:36.491    33,866 kbps     00:34:32.487    33,443 kbps     00:34:27.482    152,330 bytes   680,276 bytes   00:38:30.766
6               0:39:02.631     0:05:22.613     27,977 kbps     35,737 kbps     00:40:04.902    31,325 kbps     00:39:23.277    30,077 kbps     00:39:20.816    145,861 bytes   680,273 bytes   00:40:09.240
7               0:44:25.245     0:07:02.046     27,675 kbps     36,021 kbps     00:45:46.743    31,038 kbps     00:51:13.528    29,599 kbps     00:51:11.902    144,283 bytes   680,273 bytes   00:45:27.933
8               0:51:27.292     0:06:25.134     27,509 kbps     35,923 kbps     00:53:31.917    30,775 kbps     00:55:32.704    30,039 kbps     00:55:32.620    143,420 bytes   680,274 bytes   00:57:23.690
9               0:57:52.427     0:07:17.311     28,226 kbps     35,278 kbps     01:02:42.008    31,457 kbps     01:03:27.637    30,871 kbps     01:04:46.257    147,159 bytes   680,273 bytes   01:04:28.739
10              1:05:09.739     0:06:34.852     28,636 kbps     35,673 kbps     01:09:39.508    31,975 kbps     01:07:35.468    30,775 kbps     01:08:00.367    149,294 bytes   680,275 bytes   01:08:47.623
11              1:11:44.591     0:06:16.209     27,148 kbps     34,404 kbps     01:12:18.917    31,802 kbps     01:13:55.139    31,233 kbps     01:13:52.261    141,535 bytes   680,276 bytes   01:12:42.483
12              1:18:00.801     0:05:31.497     28,446 kbps     36,860 kbps     01:22:59.808    32,698 kbps     01:21:36.224    32,072 kbps     01:21:36.224    148,304 bytes   680,275 bytes   01:23:12.612
13              1:23:32.298     0:06:24.592     29,212 kbps     37,361 kbps     01:27:30.078    33,024 kbps     01:24:23.933    32,623 kbps     01:29:22.190    152,298 bytes   680,276 bytes   01:25:17.737
14              1:29:56.891     0:06:03.696     29,895 kbps     37,490 kbps     01:32:21.869    33,562 kbps     01:31:54.050    32,566 kbps     01:31:49.045    155,857 bytes   680,275 bytes   01:30:10.154
15              1:36:00.588     0:03:56.069     28,264 kbps     34,329 kbps     01:37:22.419    31,838 kbps     01:37:38.018    31,221 kbps     01:37:33.472    147,355 bytes   680,275 bytes   01:36:53.432
16              1:39:56.657     0:10:11.986     27,689 kbps     35,654 kbps     01:45:50.218    31,607 kbps     01:50:03.638    30,997 kbps     01:44:41.650    144,359 bytes   680,275 bytes   01:49:41.575
17              1:50:08.643     0:05:22.697     26,791 kbps     33,274 kbps     01:50:35.629    30,475 kbps     01:50:09.060    29,802 kbps     01:50:11.771    139,677 bytes   680,276 bytes   01:51:50.578
18              1:55:31.341     0:04:57.588     28,109 kbps     36,512 kbps     01:57:06.978    31,781 kbps     01:59:33.541    30,820 kbps     01:59:32.623    146,550 bytes   680,271 bytes   01:55:36.804
19              2:00:28.930     0:05:12.603     29,795 kbps     34,913 kbps     02:00:39.023    32,019 kbps     02:04:07.523    31,789 kbps     02:04:02.226    155,358 bytes   680,275 bytes   02:05:37.279
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x02            MPEG-2                                  7541.367                28,364                  26,738,271,958  145,422,307
00003.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           7541.367                640                     603,322,880     3,535,095
00003.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7541.367                640                     603,322,880     3,535,095
00003.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7541.367                640                     603,322,880     3,535,095
00003.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7541.367                192                     180,996,864     1,178,365
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7541.367                35                      32,945,988      188,633
00003.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7541.367                37                      34,860,853      199,661
00003.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7541.367                35                      33,412,109      191,314
00003.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7541.367                29                      27,801,322      160,300
00003.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        7541.367                30                      28,555,277      164,663
Phloyd is offline
post #714 of 5106 Old 11-10-2009, 07:58 PM - Thread Starter
[US] Hardware (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Severin
Release Date: 2009-10-13
UPC: 891635001698
There seem to be some severely specs-busting instantaneous bitrate spikes in this video stream - of course audio is low-bitrate and lossy, so there may be extra wiggle room. DD 5.1 @ 448 kbps and DD 2.0 @ 256 kbps are original audio, while DD 2.0 @ 192 kbps is a commentary track. No subs.
Code:
        Total   Video
[US] Hardware                                                   AVC     1:33:53 18,404,370,432  42,981,054,123  26.14   23.99   DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     Hardware
Disc Size:      42,981,054,123 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:33:53 (h:m:s)
Total Bitrate:          26.14 Mbps
VIDEO:
MPEG-4 AVC Video        23994 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             English         256 kbps        2.0 / 48 kHz / 256 kbps / DN -4dB
FILES:
00003.M2TS      0:00:00.000     1:33:53.461     18,404,370,432  26,136
CHAPTERS:
1               0:00:00.000     0:05:24.073     22,291 kbps     35,679 kbps     00:04:06.454    33,139 kbps     00:03:56.069    31,511 kbps     00:03:51.022    116,200 bytes   534,875 bytes   00:05:04.345
2               0:05:24.073     0:05:22.780     22,966 kbps     41,647 kbps     00:06:23.174    37,448 kbps     00:06:20.838    35,562 kbps     00:06:20.171    119,736 bytes   400,733 bytes   00:06:09.660
3               0:10:46.854     0:03:09.522     25,174 kbps     60,947 kbps     00:12:22.199    35,584 kbps     00:11:35.486    35,020 kbps     00:11:37.947    131,248 bytes   849,960 bytes   00:11:38.030
4               0:13:56.377     0:04:28.685     26,375 kbps     42,284 kbps     00:17:43.270    38,362 kbps     00:14:32.872    37,214 kbps     00:14:29.952    137,505 bytes   563,643 bytes   00:14:32.913
5               0:18:25.062     0:07:39.542     23,962 kbps     56,658 kbps     00:21:30.455    42,706 kbps     00:21:29.788    39,671 kbps     00:21:29.955    124,927 bytes   751,565 bytes   00:18:26.230
6               0:26:04.604     0:08:55.326     21,964 kbps     53,481 kbps     00:29:08.747    38,925 kbps     00:28:56.735    34,817 kbps     00:27:20.221    114,510 bytes   702,655 bytes   00:29:57.253
7               0:34:59.931     0:02:57.385     24,685 kbps     45,809 kbps     00:36:39.113    41,583 kbps     00:36:36.319    36,737 kbps     00:36:31.355    128,698 bytes   537,985 bytes   00:36:36.944
8               0:37:57.316     0:04:48.329     23,701 kbps     48,209 kbps     00:42:09.527    40,046 kbps     00:39:50.679    37,777 kbps     00:39:49.345    123,565 bytes   660,718 bytes   00:39:50.721
9               0:42:45.646     0:08:21.209     25,885 kbps     59,334 kbps     00:46:05.220    42,634 kbps     00:46:59.024    40,175 kbps     00:46:56.480    134,955 bytes   759,642 bytes   00:42:47.022
10              0:51:06.855     0:08:00.646     22,592 kbps     41,124 kbps     00:58:57.825    32,012 kbps     00:58:53.821    28,624 kbps     00:57:03.294    117,783 bytes   645,645 bytes   00:58:56.908
11              0:59:07.502     0:07:01.462     26,264 kbps     56,730 kbps     01:03:39.774    38,510 kbps     01:03:35.812    36,284 kbps     01:02:36.335    136,926 bytes   688,017 bytes   01:02:00.717
12              1:06:08.965     0:03:15.862     24,973 kbps     53,537 kbps     01:07:29.128    40,657 kbps     01:06:20.476    37,052 kbps     01:06:13.427    130,195 bytes   881,310 bytes   01:07:29.170
13              1:09:24.827     0:04:10.041     23,023 kbps     31,263 kbps     01:12:13.037    27,579 kbps     01:11:54.310    26,223 kbps     01:11:55.477    120,030 bytes   481,620 bytes   01:11:36.292
14              1:13:34.868     0:08:58.037     23,834 kbps     49,726 kbps     01:18:29.496    43,644 kbps     01:18:28.328    37,858 kbps     01:18:26.451    124,258 bytes   855,822 bytes   01:14:42.561
15              1:22:32.906     0:07:42.545     29,288 kbps     52,864 kbps     01:23:55.030    43,528 kbps     01:23:24.332    40,280 kbps     01:25:45.807    152,696 bytes   827,310 bytes   01:24:17.510
16              1:30:15.451     0:03:38.009     12,705 kbps     37,922 kbps     01:30:25.795    37,540 kbps     01:30:25.795    36,730 kbps     01:30:25.753    66,253 bytes    391,467 bytes   01:30:47.358
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     5633.378                23,994                  16,895,844,334  91,903,621
00003.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5633.378                449                     316,287,816     1,765,008
00003.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5633.378                256                     180,271,104     1,056,276
00003.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5633.378                192                     135,201,024     880,215
post #715 of 5106 Old 11-11-2009, 10:16 AM
Phloyd's Avatar
So I probably missed discussion on this since I was insanely busy when 0.5.3 came out... but we no longer get the Disc Volume automagically inserted into the Disc Title field?
At first I thought it was a Win7 thing (since I upgraded both at the same time) but I see the same behaviour on my old XP box as well.
Not a complaint, just want to know if it will stay that way so I can update my automation
Cheers!
Phloyd is offline
post #716 of 5106 Old 11-11-2009, 11:20 AM - Thread Starter
It's a bug. The name doesn't show up when you scan a folder, but it will put in the volume label if you scan a drive (physical or virtual).
post #717 of 5106 Old 11-11-2009, 04:42 PM
Patsfan123's Avatar
Quoted: 470 Post(s)
Liked: 309
Since we're bringing up bugs, I've got one.. Or just strange behavior.
When you have the program autosave the .txt reports, it will save it in the directory of the program (how it is supposed to work). If you have it set on your Blu-ray drive, and then switch to a new disc and simply hit the rescan button, it now will save that .txt report in the folder which I save the bit-rate graphs. I lost a few reports in that folder until I realized that was happening. This is how it works with older versions of the program as well.
post #718 of 5106 Old 11-11-2009, 05:18 PM
Patsfan123's Avatar
Quoted: 470 Post(s)
Liked: 309
Star Wars: The Clone Wars: Season One [Disc 1]
Code:
        Total   Video
USER.001                                                        VC-1    2:40:28 18,425,088,000  27,140,427,990  15.31   10.21   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     STAR_WARS_CLONE_WARS_S1_BOX
Disc Size:      27,140,427,990 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:40:28 (h:m:s)
Total Bitrate:          15.31 Mbps
VIDEO:
VC-1 Video              10206 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Japanese        640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           Japanese        26.576 kbps
Presentation Graphics           English         42.607 kbps
Presentation Graphics           French          44.065 kbps
Presentation Graphics           German          48.348 kbps
Presentation Graphics           Spanish         38.237 kbps
Presentation Graphics           Spanish         39.299 kbps
FILES:
00095.M2TS      0:00:00.000     0:22:37.147     2,646,466,560   15,600
00097.M2TS      0:22:37.147     0:24:21.418     3,024,635,904   16,557
00098.M2TS      0:46:58.565     0:23:20.899     2,712,827,904   15,492
00099.M2TS      1:10:19.465     0:22:39.274     2,603,993,088   15,326
00101.M2TS      1:32:58.739     0:23:33.745     2,455,732,224   13,896
00102.M2TS      1:56:32.485     0:21:26.034     2,347,757,568   14,605
00103.M2TS      2:17:58.520     0:22:29.765     2,633,674,752   15,610
CHAPTERS:
1               0:00:00.000     0:22:37.147     10,505 kbps     33,874 kbps     00:04:24.639    25,600 kbps     00:04:20.635    22,557 kbps     00:04:29.435    54,832 bytes    435,899 bytes   00:04:20.468
2               0:22:37.147     0:24:21.418     11,361 kbps     48,557 kbps     00:44:29.875    24,590 kbps     00:44:35.130    23,369 kbps     00:44:29.833    59,280 bytes    480,439 bytes   00:44:29.917
3               0:46:58.565     0:23:20.899     10,354 kbps     41,630 kbps     00:47:27.636    25,913 kbps     01:06:24.313    23,878 kbps     01:06:24.313    54,028 bytes    518,830 bytes   00:47:27.803
4               1:10:19.465     0:22:39.274     10,220 kbps     36,682 kbps     01:17:04.995    22,055 kbps     01:20:07.969    19,746 kbps     01:15:20.557    53,329 bytes    444,546 bytes   01:31:51.464
5               1:32:58.739     0:23:33.745     8,848 kbps      47,255 kbps     01:36:53.098    22,910 kbps     01:54:20.103    19,496 kbps     01:36:51.263    46,159 bytes    589,981 bytes   01:36:53.140
6               1:56:32.485     0:21:26.034     9,542 kbps      36,046 kbps     02:00:26.886    21,594 kbps     02:00:25.134    17,519 kbps     02:10:04.671    49,794 bytes    383,055 bytes   02:11:55.991
7               2:17:58.520     0:22:29.765     10,543 kbps     37,013 kbps     02:19:07.297    25,505 kbps     02:18:58.580    22,799 kbps     02:18:59.080    55,019 bytes    637,129 bytes   02:19:07.464
STREAM DIAGNOSTICS:
00095.M2TS      4113 (0x1011)   0xEA            VC-1                                    1357.022                10,506                  1,782,095,035   9,704,778
00095.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1357.022                641                     108,654,080     636,645
00095.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1357.022                641                     108,654,080     636,645
00095.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1357.022                641                     108,654,080     636,645
00095.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1357.022                641                     108,654,080     636,645
00095.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1357.022                641                     108,654,080     636,645
00095.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1357.022                641                     108,654,080     636,645
00095.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1357.022                26                      4,450,420       25,795
00095.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1357.022                37                      6,334,822       36,263
00095.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1357.022                41                      7,023,589       39,932
00095.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1357.022                45                      7,553,895       42,901
00095.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1357.022                35                      5,878,894       33,616
00095.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1357.022                36                      6,130,560       34,991
00097.M2TS      4113 (0x1011)   0xEA            VC-1                                    1461.251                11,362                  2,075,408,345   11,300,325
00097.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1461.251                640                     116,986,880     685,470
00097.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1461.251                640                     116,986,880     685,470
00097.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1461.251                640                     116,986,880     685,470
00097.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1461.251                640                     116,986,880     685,470
00097.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1461.251                640                     116,986,880     685,470
00097.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1461.251                640                     116,986,880     685,470
00097.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1461.251                31                      5,602,171       32,531
00097.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1461.251                49                      8,998,316       51,439
00097.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1461.251                51                      9,400,371       53,472
00097.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1461.251                57                      10,329,457      58,681
00097.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1461.251                45                      8,175,788       46,701
00097.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1461.251                46                      8,469,681       48,315
00098.M2TS      4113 (0x1011)   0xEA            VC-1                                    1400.774                10,355                  1,813,123,587   9,874,162
00098.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1400.774                641                     112,156,160     657,165
00098.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1400.774                641                     112,156,160     657,165
00098.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1400.774                641                     112,156,160     657,165
00098.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1400.774                641                     112,156,160     657,165
00098.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1400.774                641                     112,156,160     657,165
00098.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1400.774                641                     112,156,160     657,165
00098.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1400.774                30                      5,242,860       30,343
00098.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1400.774                46                      8,004,997       45,747
00098.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1400.774                50                      8,678,869       49,436
00098.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1400.774                53                      9,286,541       52,718
00098.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1400.774                43                      7,514,076       42,922
00098.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1400.774                44                      7,708,726       43,992
00099.M2TS      4113 (0x1011)   0xEA            VC-1                                    1359.149                10,221                  1,736,429,951   9,456,667
00099.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1359.149                640                     108,812,800     637,575
00099.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1359.149                640                     108,812,800     637,575
00099.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1359.149                640                     108,812,800     637,575
00099.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1359.149                640                     108,812,800     637,575
00099.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1359.149                640                     108,812,800     637,575
00099.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1359.149                640                     108,812,800     637,575
00099.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1359.149                28                      4,833,946       28,133
00099.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1359.149                42                      7,133,787       40,846
00099.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1359.149                45                      7,638,856       43,558
00099.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1359.149                48                      8,096,905       46,078
00099.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1359.149                38                      6,510,014       37,234
00099.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1359.149                40                      6,806,251       38,879
00101.M2TS      4113 (0x1011)   0xEA            VC-1                                    1413.579                8,849                   1,563,548,263   8,517,797
00101.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1413.579                641                     113,180,160     663,165
00101.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1413.579                641                     113,180,160     663,165
00101.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1413.579                641                     113,180,160     663,165
00101.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1413.579                641                     113,180,160     663,165
00101.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1413.579                641                     113,180,160     663,165
00101.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1413.579                641                     113,180,160     663,165
00101.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1413.579                24                      4,246,788       24,949
00101.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1413.579                44                      7,820,679       44,758
00101.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1413.579                45                      7,935,777       45,144
00101.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1413.579                49                      8,627,950       49,152
00101.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1413.579                41                      7,173,462       40,993
00101.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1413.579                41                      7,183,441       41,062
00102.M2TS      4113 (0x1011)   0xEA            VC-1                                    1285.951                9,543                   1,533,912,897   8,354,977
00102.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1285.951                641                     102,963,200     603,300
00102.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1285.951                641                     102,963,200     603,300
00102.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1285.951                641                     102,963,200     603,300
00102.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1285.951                641                     102,963,200     603,300
00102.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1285.951                641                     102,963,200     603,300
00102.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1285.951                641                     102,963,200     603,300
00102.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1285.951                24                      3,908,776       22,737
00102.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1285.951                42                      6,779,247       38,974
00102.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1285.951                42                      6,800,986       38,686
00102.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1285.951                47                      7,512,035       42,979
00102.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1285.951                36                      5,715,314       32,665
00102.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1285.951                37                      5,944,174       33,918
00103.M2TS      4113 (0x1011)   0xEA            VC-1                                    1349.682                10,544                  1,778,898,596   9,687,301
00103.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1349.682                640                     108,055,040     633,135
00103.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1349.682                640                     108,055,040     633,135
00103.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1349.682                640                     108,055,040     633,135
00103.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1349.682                640                     108,055,040     633,135
00103.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1349.682                640                     108,055,040     633,135
00103.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1349.682                640                     108,055,040     633,135
00103.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1349.682                22                      3,699,890       21,462
00103.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1349.682                37                      6,207,068       35,853
00103.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1349.682                33                      5,554,864       31,594
00103.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1349.682                40                      6,781,438       38,978
00103.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1349.682                30                      5,052,168       28,872
00103.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1349.682                30                      5,055,314       28,897
No doubt, far from Warner's best effort. Tons of wasted space and abysmally low bitrate.. I wish we could get some of Warner's tech people in this thread so they could answer to this. It being animated, it still looks good, but this is pretty disappointing.
I am netflixing this, so anyone feel free to add the other discs.
Here is the original playlist with copyright screens inserted after each episode.
Spoiler
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:41:03 18,592,303,104  27,140,427,990  15.39   10.17   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:41:03 (h:m:s)
Total Bitrate:          15.39 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
VC-1 Video              10170 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
* Dolby Digital Audio           Japanese        640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
* Presentation Graphics         Japanese        26.492 kbps
Presentation Graphics           English         42.465 kbps
Presentation Graphics           French          43.918 kbps
Presentation Graphics           German          48.185 kbps
Presentation Graphics           Spanish         38.111 kbps
Presentation Graphics           Spanish         39.170 kbps
FILES:
00096.M2TS      0:22:37.147     0:00:05.004     23,887,872      38,182
00097.M2TS      0:22:42.152     0:24:21.418     3,024,635,904   16,557
00096.M2TS      0:47:03.570     0:00:05.004     23,887,872      38,182
00098.M2TS      0:47:08.575     0:23:20.899     2,712,827,904   15,492
00096.M2TS      1:10:29.475     0:00:05.004     23,887,872      38,182
00099.M2TS      1:10:34.480     0:22:39.274     2,603,993,088   15,326
00096.M2TS      1:33:13.754     0:00:05.004     23,887,872      38,182
00101.M2TS      1:33:18.759     0:23:33.745     2,455,732,224   13,896
00096.M2TS      1:56:52.505     0:00:05.004     23,887,872      38,182
00102.M2TS      1:56:57.510     0:21:26.034     2,347,757,568   14,605
00096.M2TS      2:18:23.545     0:00:05.004     23,887,872      38,182
00103.M2TS      2:18:28.550     0:22:29.765     2,633,674,752   15,610
00096.M2TS      2:40:58.315     0:00:05.004     23,887,872      38,182
CHAPTERS:
1               0:00:00.000     0:07:08.469     11,454 kbps     33,874 kbps     00:04:24.639    25,600 kbps     00:04:20.635    22,557 kbps     00:04:29.435    59,796 bytes    435,899 bytes   00:04:20.468
2               0:07:08.469     0:07:58.728     10,616 kbps     28,829 kbps     00:10:09.608    22,389 kbps     00:10:08.524    20,209 kbps     00:10:02.977    55,393 bytes    414,442 bytes   00:09:03.584
3               0:15:07.197     0:06:49.992     10,137 kbps     23,454 kbps     00:18:10.923    16,014 kbps     00:17:46.356    15,421 kbps     00:19:32.796    52,850 bytes    319,396 bytes   00:21:05.055
4               0:21:57.190     0:00:39.956     2,787 kbps      5,739 kbps      00:22:23.258    4,332 kbps      00:22:29.139    3,859 kbps      00:22:15.751    14,744 bytes    271,613 bytes   00:22:17.169
5               0:22:37.147     0:00:05.005     345 kbps        376 kbps        00:22:41.109    345 kbps        00:22:37.147    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    00:22:38.148
6               0:22:42.152     0:07:23.151     11,874 kbps     35,610 kbps     00:25:44.084    24,578 kbps     00:25:36.034    22,106 kbps     00:25:38.453    61,992 bytes    417,695 bytes   00:25:44.626
7               0:30:05.303     0:08:39.810     11,284 kbps     36,001 kbps     00:37:19.820    22,972 kbps     00:37:16.525    21,589 kbps     00:37:18.611    58,832 bytes    433,578 bytes   00:35:21.911
8               0:38:45.114     0:07:23.317     11,901 kbps     48,557 kbps     00:44:34.880    24,590 kbps     00:44:40.135    23,369 kbps     00:44:34.838    62,046 bytes    480,439 bytes   00:44:34.922
9               0:46:08.432     0:00:55.138     3,625 kbps      12,331 kbps     00:46:58.023    11,224 kbps     00:46:56.313    7,314 kbps      00:46:51.433    19,099 bytes    279,870 bytes   00:46:40.464
10              0:47:03.570     0:00:05.005     345 kbps        376 kbps        00:47:07.533    345 kbps        00:47:03.570    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    00:47:04.571
11              0:47:08.575     0:07:28.448     10,194 kbps     41,630 kbps     00:47:37.646    23,780 kbps     00:47:34.977    19,233 kbps     00:47:31.473    53,223 bytes    518,830 bytes   00:47:37.813
12              0:54:37.023     0:07:22.275     9,514 kbps      21,837 kbps     00:58:27.754    19,388 kbps     00:55:52.932    16,855 kbps     00:58:22.332    49,603 bytes    415,950 bytes   00:54:38.024
13              1:01:59.298     0:07:34.745     12,170 kbps     37,780 kbps     01:02:49.348    25,913 kbps     01:06:34.323    23,878 kbps     01:06:34.323    63,448 bytes    424,266 bytes   01:07:18.659
14              1:09:34.044     0:00:55.430     3,453 kbps      10,999 kbps     01:10:24.053    9,633 kbps      01:10:22.426    7,306 kbps      01:10:17.504    18,192 bytes    285,662 bytes   01:10:06.285
15              1:10:29.475     0:00:05.005     345 kbps        376 kbps        01:10:33.437    345 kbps        01:10:29.475    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    01:10:30.476
16              1:10:34.480     0:07:06.801     10,930 kbps     36,682 kbps     01:17:20.010    21,799 kbps     01:15:40.410    19,746 kbps     01:15:35.572    57,069 bytes    376,464 bytes   01:13:45.879
17              1:17:41.281     0:07:01.796     9,903 kbps      28,373 kbps     01:20:24.903    22,055 kbps     01:20:22.984    16,677 kbps     01:20:20.482    51,627 bytes    367,696 bytes   01:22:37.077
18              1:24:43.077     0:07:50.595     10,491 kbps     25,517 kbps     01:29:39.248    18,329 kbps     01:25:32.877    15,854 kbps     01:25:29.749    54,696 bytes    444,546 bytes   01:32:06.479
19              1:32:33.673     0:00:40.081     2,810 kbps      5,693 kbps      01:33:09.292    4,317 kbps      01:33:05.621    3,790 kbps      01:32:52.233    14,869 bytes    266,382 bytes   01:32:57.655
20              1:33:13.754     0:00:05.005     345 kbps        376 kbps        01:33:17.717    345 kbps        01:33:13.754    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    01:33:14.755
21              1:33:18.759     0:07:22.108     9,539 kbps      47,255 kbps     01:37:13.118    22,894 kbps     01:34:09.310    19,496 kbps     01:37:11.283    49,801 bytes    589,981 bytes   01:37:13.160
22              1:40:40.868     0:05:09.350     8,085 kbps      24,504 kbps     01:43:40.797    19,209 kbps     01:43:37.044    14,359 kbps     01:43:31.955    42,152 bytes    439,155 bytes   01:45:21.231
23              1:45:50.218     0:09:16.055     9,383 kbps      46,550 kbps     01:54:41.207    22,910 kbps     01:54:40.123    19,031 kbps     01:53:48.363    48,920 bytes    561,073 bytes   01:47:55.635
24              1:55:06.274     0:01:46.231     5,390 kbps      13,689 kbps     01:55:50.652    11,119 kbps     01:55:50.151    9,483 kbps      01:55:09.861    28,192 bytes    279,063 bytes   01:55:51.653
25              1:56:52.505     0:00:05.005     345 kbps        376 kbps        01:56:56.467    345 kbps        01:56:52.505    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    01:56:53.506
26              1:56:57.510     0:06:02.904     10,625 kbps     36,046 kbps     02:00:51.911    21,594 kbps     02:00:50.159    16,606 kbps     02:00:49.992    55,490 bytes    369,356 bytes   02:00:52.203
27              2:03:00.414     0:08:05.735     9,105 kbps      23,735 kbps     02:08:42.464    18,719 kbps     02:10:34.701    17,519 kbps     02:10:29.696    47,468 bytes    303,936 bytes   02:10:25.526
28              2:11:06.149     0:06:29.597     9,757 kbps      32,660 kbps     02:16:50.911    21,549 kbps     02:14:41.323    16,492 kbps     02:16:46.281    50,866 bytes    383,055 bytes   02:12:21.016
29              2:17:35.747     0:00:47.797     4,016 kbps      14,374 kbps     02:17:39.668    11,112 kbps     02:17:35.747    9,215 kbps      02:17:35.747    21,197 bytes    248,597 bytes   02:18:11.074
30              2:18:23.545     0:00:05.004     345 kbps        376 kbps        02:18:27.507    345 kbps        02:18:23.545    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    02:18:24.546
31              2:18:28.550     0:06:35.228     9,826 kbps      37,013 kbps     02:19:37.327    25,505 kbps     02:19:28.610    22,799 kbps     02:19:29.110    51,309 bytes    637,129 bytes   02:19:37.494
32              2:25:03.778     0:08:09.322     11,298 kbps     35,725 kbps     02:25:31.264    22,402 kbps     02:26:41.918    18,181 kbps     02:26:02.336    58,905 bytes    473,054 bytes   02:26:43.419
33              2:33:13.100     0:07:01.295     10,907 kbps     33,131 kbps     02:36:28.962    21,797 kbps     02:39:55.585    18,478 kbps     02:39:39.027    56,862 bytes    335,885 bytes   02:36:30.130
34              2:40:14.396     0:00:43.918     5,108 kbps      11,023 kbps     02:40:14.771    8,227 kbps      02:40:14.396    6,165 kbps      02:40:36.877    26,991 bytes    304,680 bytes   02:40:45.427
35              2:40:58.315     0:00:05.004     330 kbps        376 kbps        02:41:02.277    0 kbps          00:00:00.000    0 kbps          00:00:00.000    1,737 bytes     26,895 bytes    02:40:59.316
STREAM DIAGNOSTICS:
00096.M2TS      4113 (0x1011)   0xEA            VC-1                                    4.880                   383                     233,553         1,327
00096.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           4.880                   3,948                   2,407,936       18,812
00096.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            4.880                   3,948                   2,407,936       18,812
00096.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            4.880                   3,948                   2,407,936       18,812
00096.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           4.880                   3,948                   2,407,936       18,812
00096.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           4.880                   3,948                   2,407,936       18,812
00096.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          4.880                   3,948                   2,407,936       18,812
00096.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          4.880                   4                       2,208           19
00096.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           4.880                   4                       2,208           19
00096.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            4.880                   4                       2,208           19
00096.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            4.880                   4                       2,208           19
00096.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           4.880                   4                       2,208           19
00096.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           4.880                   4                       2,208           19
Disc 2
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:39:42 18,595,559,424  26,218,250,404  15.52   10.32   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Size:      26,218,250,404 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:39:42 (h:m:s)
Total Bitrate:          15.52 Mbps
VIDEO:
VC-1 Video              10315 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
SUBTITLES:
* Presentation Graphics         Japanese        25.222 kbps
Presentation Graphics           English         38.464 kbps
Presentation Graphics           French          41.085 kbps
Presentation Graphics           German          44.318 kbps
Presentation Graphics           Spanish         35.016 kbps
Presentation Graphics           Spanish         36.197 kbps
FILES:
00088.M2TS      0:00:00.000     0:22:34.561     2,738,982,912   16,176
00098.M2TS      0:22:34.561     0:00:05.004     23,887,872      38,182
00089.M2TS      0:22:39.566     0:22:34.686     2,561,495,040   15,127
00098.M2TS      0:45:14.253     0:00:05.004     23,887,872      38,182
00090.M2TS      0:45:19.258     0:23:27.406     2,410,616,832   13,702
00098.M2TS      1:08:46.664     0:00:05.004     23,887,872      38,182
00091.M2TS      1:08:51.669     0:22:38.106     2,382,360,576   14,033
00096.M2TS      1:31:29.775     0:00:05.004     23,887,872      38,182
00092.M2TS      1:31:34.780     0:22:38.899     2,684,442,624   15,804
00096.M2TS      1:54:13.680     0:00:05.004     23,887,872      38,182
00093.M2TS      1:54:18.685     0:22:38.857     2,807,857,152   16,531
00096.M2TS      2:16:57.542     0:00:05.004     23,887,872      38,182
00094.M2TS      2:17:02.547     0:22:35.062     2,842,589,184   16,782
00096.M2TS      2:39:37.609     0:00:05.004     23,887,872      38,182
CHAPTERS:
1               0:00:00.000     0:07:58.060     11,406 kbps     36,719 kbps     00:00:19.269    25,230 kbps     00:02:52.213    24,068 kbps     00:02:47.125    59,537 bytes    624,152 bytes   00:03:57.654
2               0:07:58.060     0:06:25.510     9,704 kbps      32,695 kbps     00:11:37.697    25,107 kbps     00:11:36.529    22,489 kbps     00:11:31.524    50,594 bytes    493,114 bytes   00:11:57.133
3               0:14:23.571     0:07:30.825     12,439 kbps     38,483 kbps     00:16:44.420    26,182 kbps     00:16:40.416    21,547 kbps     00:16:54.555    64,850 bytes    670,581 bytes   00:15:39.438
4               0:21:54.396     0:00:40.165     2,682 kbps      5,670 kbps      00:22:30.140    4,383 kbps      00:22:26.511    3,548 kbps      00:22:13.123    14,206 bytes    244,378 bytes   00:22:21.548
5               0:22:34.561     0:00:05.005     345 kbps        376 kbps        00:22:38.523    345 kbps        00:22:34.561    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    00:22:35.562
6               0:22:39.566     0:06:47.365     10,323 kbps     27,981 kbps     00:28:03.139    23,806 kbps     00:27:49.292    21,102 kbps     00:26:10.068    53,900 bytes    411,939 bytes   00:23:06.134
7               0:29:26.931     0:05:28.953     10,795 kbps     37,200 kbps     00:32:31.199    22,387 kbps     00:30:21.611    19,161 kbps     00:30:16.606    56,279 bytes    422,061 bytes   00:32:31.449
8               0:34:55.885     0:08:16.829     9,874 kbps      35,911 kbps     00:37:27.161    19,842 kbps     00:38:08.494    17,286 kbps     00:38:06.742    51,476 bytes    396,684 bytes   00:40:44.692
9               0:43:12.715     0:02:01.538     8,049 kbps      23,382 kbps     00:43:18.178    21,443 kbps     00:43:14.425    16,471 kbps     00:43:12.715    42,124 bytes    413,784 bytes   00:43:18.887
10              0:45:14.253     0:00:05.005     345 kbps        376 kbps        00:45:18.215    345 kbps        00:45:14.253    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    00:45:15.254
11              0:45:19.258     0:07:59.437     8,115 kbps      21,485 kbps     00:49:19.331    19,929 kbps     00:49:15.369    18,688 kbps     00:49:16.912    42,362 bytes    319,050 bytes   00:45:46.493
12              0:53:18.695     0:08:17.163     9,591 kbps      46,917 kbps     00:57:18.601    20,870 kbps     00:57:26.109    16,577 kbps     00:58:19.746    50,003 bytes    560,060 bytes   00:57:18.643
13              1:01:35.858     0:06:11.162     9,201 kbps      24,713 kbps     01:03:51.744    16,396 kbps     01:05:31.469    14,221 kbps     01:06:10.174    47,970 bytes    324,550 bytes   01:07:28.294
14              1:07:47.021     0:00:59.642     3,016 kbps      9,425 kbps      01:07:48.898    5,491 kbps      01:07:47.021    4,630 kbps      01:08:34.527    15,824 bytes    255,362 bytes   01:08:22.932
15              1:08:46.664     0:00:05.005     345 kbps        376 kbps        01:08:50.626    345 kbps        01:08:46.664    0 kbps          00:00:00.000    1,799 bytes     26,895 bytes    01:08:47.665
16              1:08:51.669     0:06:41.651     10,177 kbps     28,296 kbps     01:11:03.592    22,719 kbps     01:11:57.563    17,839 kbps     01:14:51.778    53,143 bytes    370,811 bytes   01:12:51.075
17              1:15:33.320     0:07:45.631     8,346 kbps      24,467 kbps     01:15:55.008    20,696 kbps     01:17:49.915    19,929 kbps     01:17:50.290    43,515 bytes    338,501 bytes   01:20:21.733
18              1:23:18.952     0:07:30.825     9,160 kbps      21,520 kbps     01:29:22.690    18,839 kbps     01:29:18.686    17,704 kbps     01:29:13.681    47,758 bytes    390,574 bytes   01:27:50.556
19              1:30:49.777     0:00:39.998     2,656 kbps      6,096 kbps      01:31:21.559    4,278 kbps      01:31:12.133    3,854 kbps      01:31:08.379    14,052 bytes    263,811 bytes   01:31:13.801
20              1:31:29.775     0:00:05.005     345 kbps        376 kbps        01:31:33.738    345 kbps        01:31:29.775    0 kbps          00:00:00.000    1,799 bytes     26,883 bytes    01:31:30.776
21              1:31:34.780     0:07:18.729     10,313 kbps     29,568 kbps     01:38:50.674    26,846 kbps     01:38:48.505    20,598 kbps     01:38:43.500    53,845 bytes    385,062 bytes   01:37:47.152
22              1:38:53.510     0:07:07.301     11,745 kbps     36,978 kbps     01:44:28.637    28,749 kbps     01:44:25.300    23,595 kbps     01:44:20.420    61,233 bytes    392,947 bytes   01:43:24.698
23              1:46:00.812     0:07:29.866     10,546 kbps     39,033 kbps     01:47:49.004    25,418 kbps     01:50:21.364    20,956 kbps     01:50:20.238    54,982 bytes    512,485 bytes   01:50:22.615
24              1:53:30.678     0:00:43.001     4,859 kbps      8,483 kbps      01:53:56.663    6,904 kbps      01:53:52.992    6,758 kbps      01:53:52.867    25,607 bytes    358,701 bytes   01:53:57.664
25              1:54:13.680     0:00:05.005     345 kbps        376 kbps        01:54:17.642    345 kbps        01:54:13.680    0 kbps          00:00:00.000    1,799 bytes     26,883 bytes    01:54:14.681
26              1:54:18.685     0:07:12.473     13,064 kbps     30,473 kbps     01:54:39.664    23,059 kbps     01:54:38.496    21,244 kbps     01:54:39.664    68,207 bytes    378,679 bytes   01:55:30.506
27              2:01:31.158     0:08:21.167     10,071 kbps     25,677 kbps     02:01:36.497    24,083 kbps     02:07:42.780    22,318 kbps     02:07:40.110    52,504 bytes    344,048 bytes   02:09:52.326
28              2:09:52.326     0:06:25.218     11,871 kbps     33,903 kbps     02:12:25.312    25,496 kbps     02:12:22.059    22,800 kbps     02:13:18.740    61,891 bytes    442,790 bytes   02:12:27.814
29              2:16:17.544     0:00:39.998     6,726 kbps      11,862 kbps     02:16:40.525    9,462 kbps      02:16:40.525    9,205 kbps      02:16:37.022    35,623 bytes    422,383 bytes   02:16:41.526
30              2:16:57.542     0:00:05.004     345 kbps        376 kbps        02:17:01.504    345 kbps        02:16:57.542    0 kbps          00:00:00.000    1,799 bytes     26,883 bytes    02:16:58.543
31              2:17:02.547     0:07:34.370     12,530 kbps     42,862 kbps     02:18:04.067    26,514 kbps     02:24:24.739    23,533 kbps     02:23:36.941    65,416 bytes    519,511 bytes   02:18:13.576
32              2:24:36.918     0:06:32.100     10,706 kbps     39,148 kbps     02:25:13.412    26,941 kbps     02:24:45.551    21,656 kbps     02:25:04.403    55,817 bytes    554,710 bytes   02:26:20.897
33              2:31:09.018     0:07:45.339     12,340 kbps     45,664 kbps     02:35:37.786    24,967 kbps     02:35:37.786    22,140 kbps     02:35:20.978    64,333 bytes    598,836 bytes   02:35:37.870
34              2:38:54.358     0:00:43.251     3,593 kbps      11,523 kbps     02:38:56.443    7,643 kbps      02:38:54.441    4,681 kbps      02:38:54.441    18,987 bytes    328,181 bytes   02:38:56.360
35              2:39:37.609     0:00:05.004     330 kbps        376 kbps        02:39:41.571    0 kbps          00:00:00.000    0 kbps          00:00:00.000    1,736 bytes     26,883 bytes    02:39:38.610
STREAM DIAGNOSTICS:
00088.M2TS      4113 (0x1011)   0xEA            VC-1                                    1354.478                11,007                  1,863,624,705   10,147,822
00088.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1354.478                641                     108,451,840     635,460
00088.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1354.478                641                     108,451,840     635,460
00088.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1354.478                641                     108,451,840     635,460
00088.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1354.478                641                     108,451,840     635,460
00088.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1354.478                641                     108,451,840     635,460
00088.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1354.478                641                     108,451,840     635,460
00088.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1354.478                30                      5,023,229       29,250
00088.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1354.478                48                      8,168,892       46,872
00088.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1354.478                48                      8,198,311       46,607
00088.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1354.478                55                      9,324,639       53,177
00088.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1354.478                43                      7,199,152       41,173
00088.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1354.478                44                      7,427,515       42,427
00098.M2TS      4113 (0x1011)   0xEA            VC-1                                    4.880                   383                     233,553         1,327
00098.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           4.880                   3,948                   2,407,936       18,812
00098.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            4.880                   3,948                   2,407,936       18,812
00098.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            4.880                   3,948                   2,407,936       18,812
00098.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           4.880                   3,948                   2,407,936       18,812
00098.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           4.880                   3,948                   2,407,936       18,812
00098.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          4.880                   3,948                   2,407,936       18,812
00098.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          4.880                   4                       2,208           19
00098.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           4.880                   4                       2,208           19
00098.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            4.880                   4                       2,208           19
00098.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            4.880                   4                       2,208           19
00098.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           4.880                   4                       2,208           19
00098.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           4.880                   4                       2,208           19
00089.M2TS      4113 (0x1011)   0xEA            VC-1                                    1354.520                10,070                  1,704,962,629   9,285,600
00089.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1354.520                641                     108,456,960     635,490
00089.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1354.520                641                     108,456,960     635,490
00089.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1354.520                641                     108,456,960     635,490
00089.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1354.520                641                     108,456,960     635,490
00089.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1354.520                641                     108,456,960     635,490
00089.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1354.520                641                     108,456,960     635,490
00089.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1354.520                25                      4,185,619       24,263
00089.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1354.520                35                      5,974,975       34,236
00089.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1354.520                37                      6,343,523       35,931
00089.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1354.520                41                      6,946,494       39,530
00089.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1354.520                32                      5,447,881       31,069
00089.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1354.520                33                      5,637,340       32,108
00090.M2TS      4113 (0x1011)   0xEA            VC-1                                    1407.239                8,708                   1,531,696,197   8,344,710
00090.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1407.239                641                     112,673,280     660,195
00090.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1407.239                641                     112,673,280     660,195
00090.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1407.239                641                     112,673,280     660,195
00090.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1407.239                641                     112,673,280     660,195
00090.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1407.239                641                     112,673,280     660,195
00090.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1407.239                641                     112,673,280     660,195
00090.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1407.239                22                      3,841,600       22,374
00090.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1407.239                36                      6,404,813       36,928
00090.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1407.239                36                      6,366,206       36,253
00090.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1407.239                41                      7,274,283       41,669
00090.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1407.239                32                      5,577,498       31,962
00090.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1407.239                33                      5,768,703       33,014
00091.M2TS      4113 (0x1011)   0xEA            VC-1                                    1358.023                8,991                   1,526,244,306   8,314,304
00091.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1358.023                641                     108,728,320     637,080
00091.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1358.023                641                     108,728,320     637,080
00091.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1358.023                641                     108,728,320     637,080
00091.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1358.023                641                     108,728,320     637,080
00091.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1358.023                641                     108,728,320     637,080
00091.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1358.023                641                     108,728,320     637,080
00091.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1358.023                27                      4,594,476       26,530
00091.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1358.023                40                      6,783,767       38,807
00091.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1358.023                44                      7,475,387       42,372
00091.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1358.023                47                      7,944,454       45,143
00091.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1358.023                37                      6,267,005       35,805
00091.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1358.023                38                      6,505,280       37,113
00096.M2TS      4113 (0x1011)   0xEA            VC-1                                    4.880                   383                     233,503         1,327
00092.M2TS      4113 (0x1011)   0xEA            VC-1                                    1358.732                10,669                  1,812,062,881   9,867,658
00092.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1358.732                641                     108,789,760     637,440
00092.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1358.732                641                     108,789,760     637,440
00092.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1358.732                641                     108,789,760     637,440
00092.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1358.732                641                     108,789,760     637,440
00092.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1358.732                641                     108,789,760     637,440
00092.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1358.732                641                     108,789,760     637,440
00092.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1358.732                30                      5,163,042       29,969
00092.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1358.732                43                      7,324,964       41,859
00092.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1358.732                47                      7,966,432       45,166
00092.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1358.732                50                      8,490,786       48,226
00092.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1358.732                40                      6,832,599       39,000
00092.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1358.732                41                      6,899,740       39,370
00093.M2TS      4113 (0x1011)   0xEA            VC-1                                    1358.774                11,436                  1,942,340,298   10,575,821
00093.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1358.774                641                     108,792,320     637,455
00093.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1358.774                641                     108,792,320     637,455
00093.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1358.774                641                     108,792,320     637,455
00093.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1358.774                641                     108,792,320     637,455
00093.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1358.774                641                     108,792,320     637,455
00093.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1358.774                641                     108,792,320     637,455
00093.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1358.774                21                      3,536,072       20,558
00093.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1358.774                31                      5,326,781       30,495
00093.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1358.774                35                      5,981,128       33,922
00093.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1358.774                36                      6,085,468       34,629
00093.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1358.774                30                      5,062,602       28,933
00093.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1358.774                30                      5,179,438       29,581
00094.M2TS      4113 (0x1011)   0xEA            VC-1                                    1354.979                11,652                  1,973,570,357   10,745,415
00094.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1354.979                640                     108,482,560     635,640
00094.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1354.979                640                     108,482,560     635,640
00094.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            1354.979                640                     108,428,800     635,325
00094.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           1354.979                640                     108,428,800     635,325
00094.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           1354.979                640                     108,482,560     635,640
00094.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          1354.979                640                     108,428,800     635,325
00094.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1354.979                23                      3,851,697       22,292
00094.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1354.979                36                      6,073,609       34,762
00094.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1354.979                41                      6,866,674       38,937
00094.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            1354.979                41                      7,003,829       39,838
00094.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           1354.979                33                      5,540,709       31,725
00094.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1354.979                35                      5,923,888       33,816
post #719 of 5106 Old 11-11-2009, 09:17 PM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
An Insider mentioned that the authoring staffs at Warner are overworked and underpaid. The AVBR justifies that.
Blu-ray : 340
lgans316 is offline
post #720 of 5106 Old 11-12-2009, 06:58 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Snatch - 2000 - UK - Sony - Region ABC
Code:
        Total   Video
00001.MPLS                                                      AVC     1:42:46 31,774,138,368  39,400,309,731  41.22   29.96   DTS-HD Master 5.1 4070Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     SNATCH
Disc Size:      39,400,309,731 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:42:46 (h:m:s)
Total Bitrate:          41.22 Mbps
VIDEO:
MPEG-4 AVC Video        29962 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4070 kbps       5.1 / 48 kHz / 4070 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          1969 kbps       5.1 / 48 kHz / 1969 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             German          1939 kbps       5.1 / 48 kHz / 1939 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         36.282 kbps
Presentation Graphics           English         29.542 kbps
Presentation Graphics           English         1.993 kbps
Presentation Graphics           English         53.332 kbps
Presentation Graphics           Arabic          19.443 kbps
Presentation Graphics           Danish          28.952 kbps
Presentation Graphics           Dutch           31.565 kbps
Presentation Graphics           Dutch           42.388 kbps
Presentation Graphics           Finnish         31.969 kbps
Presentation Graphics           French          34.133 kbps
Presentation Graphics           French          46.088 kbps
Presentation Graphics           German          35.853 kbps
Presentation Graphics           German          42.013 kbps
Presentation Graphics           Hindi           31.718 kbps
Presentation Graphics           Norwegian       27.569 kbps
Presentation Graphics           Swedish         27.531 kbps
Presentation Graphics           Turkish         30.457 kbps
FILES:
00262.M2TS      0:00:00.000     1:42:46.201     31,774,138,368  41,224
CHAPTERS:
1               0:00:00.000     0:06:58.292     29,249 kbps     40,392 kbps     00:00:20.478    32,774 kbps     00:00:16.558    31,735 kbps     00:00:11.553    152,476 bytes   459,009 bytes   00:05:58.649
2               0:06:58.292     0:04:55.253     30,575 kbps     34,412 kbps     00:10:11.736    31,531 kbps     00:11:00.201    31,093 kbps     00:10:46.354    159,403 bytes   337,517 bytes   00:09:07.922
3               0:11:53.546     0:04:38.194     30,726 kbps     33,775 kbps     00:16:03.087    31,308 kbps     00:15:59.249    31,104 kbps     00:15:54.244    160,190 bytes   410,234 bytes   00:16:30.739
4               0:16:31.740     0:06:16.167     29,992 kbps     44,823 kbps     00:22:39.149    33,432 kbps     00:22:35.145    31,980 kbps     00:22:30.140    156,365 bytes   504,800 bytes   00:22:39.816
5               0:22:47.908     0:07:15.309     30,719 kbps     32,861 kbps     00:30:01.341    31,263 kbps     00:29:57.504    31,039 kbps     00:22:52.871    160,154 bytes   351,304 bytes   00:30:02.217
6               0:30:03.218     0:06:24.717     30,632 kbps     33,220 kbps     00:30:57.480    31,233 kbps     00:30:20.360    31,072 kbps     00:30:21.986    159,702 bytes   359,594 bytes   00:34:39.911
7               0:36:27.935     0:05:11.477     30,673 kbps     32,895 kbps     00:37:00.718    31,172 kbps     00:40:39.270    30,994 kbps     00:40:33.931    159,914 bytes   353,920 bytes   00:39:10.473
8               0:41:39.413     0:06:36.979     30,737 kbps     33,891 kbps     00:48:14.516    31,264 kbps     00:43:05.582    31,082 kbps     00:48:05.549    160,248 bytes   423,737 bytes   00:48:15.392
9               0:48:16.393     0:04:57.213     30,774 kbps     33,258 kbps     00:50:45.083    31,403 kbps     00:50:41.037    31,090 kbps     00:48:28.030    160,442 bytes   434,581 bytes   00:48:18.395
10              0:53:13.607     0:05:52.685     30,687 kbps     33,067 kbps     00:53:41.009    31,218 kbps     00:53:36.963    31,009 kbps     00:57:13.304    159,986 bytes   336,749 bytes   00:58:23.875
11              0:59:06.292     0:08:40.811     30,708 kbps     33,361 kbps     01:05:07.486    31,408 kbps     01:05:03.566    31,052 kbps     01:04:58.603    160,098 bytes   391,773 bytes   01:05:08.446
12              1:07:47.104     0:05:37.420     30,278 kbps     42,924 kbps     01:11:05.261    32,913 kbps     01:11:01.215    31,532 kbps     01:10:56.210    157,856 bytes   483,409 bytes   01:11:05.761
13              1:13:24.525     0:05:45.011     30,416 kbps     35,273 kbps     01:18:27.744    31,698 kbps     01:18:23.740    31,260 kbps     01:18:18.735    158,576 bytes   358,986 bytes   01:19:08.535
14              1:19:09.536     0:09:03.042     30,469 kbps     33,386 kbps     01:20:16.394    31,360 kbps     01:22:11.343    31,098 kbps     01:22:06.254    158,850 bytes   375,222 bytes   01:21:21.793
15              1:28:12.578     0:05:45.762     30,587 kbps     34,297 kbps     01:33:16.549    31,549 kbps     01:33:12.545    31,008 kbps     01:33:21.470    159,468 bytes   300,993 bytes   01:31:54.467
16              1:33:58.341     0:08:47.860     24,538 kbps     39,539 kbps     01:36:16.145    32,537 kbps     01:36:12.224    31,637 kbps     01:36:07.136    127,938 bytes   392,574 bytes   01:37:09.198
STREAM DIAGNOSTICS:
00262.M2TS      4113 (0x1011)   0x1B            AVC                                     6166.035                29,963                  23,093,929,982  125,596,643
00262.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6166.035                4,070                   3,136,853,236   18,007,179
00262.M2TS      4353 (0x1101)   0x86            DTS-HD MA       fra (French)            6166.035                1,969                   1,517,276,240   9,200,966
00262.M2TS      4354 (0x1102)   0x86            DTS-HD MA       deu (German)            6166.035                1,939                   1,494,554,204   9,079,845
00262.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6166.035                192                     147,988,992     963,470
00262.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6166.035                36                      27,965,379      160,704
00262.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6166.035                30                      22,770,464      133,739
00262.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6166.035                34                      26,308,682      151,735
00262.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            6166.035                36                      27,634,312      158,903
00262.M2TS      4612 (0x1204)   0x90            PGS             ara (Arabic)            6166.035                19                      14,985,909      90,287
00262.M2TS      4613 (0x1205)   0x90            PGS             dan (Danish)            6166.035                29                      22,315,140      127,286
00262.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             6166.035                32                      24,329,148      138,423
00262.M2TS      4615 (0x1207)   0x90            PGS             fin (Finnish)           6166.035                32                      24,641,125      140,673
00262.M2TS      4616 (0x1208)   0x90            PGS             hin (Hindi)             6166.035                32                      24,447,326      141,736
00262.M2TS      4617 (0x1209)   0x90            PGS             nor (Norwegian)         6166.035                28                      21,249,448      121,424
00262.M2TS      4618 (0x120A)   0x90            PGS             swe (Swedish)           6166.035                28                      21,220,115      121,275
00262.M2TS      4619 (0x120B)   0x90            PGS             tur (Turkish)           6166.035                30                      23,475,372      136,397
00262.M2TS      4620 (0x120C)   0x90            PGS             eng (English)           6166.035                53                      41,106,734      232,735
00262.M2TS      4621 (0x120D)   0x90            PGS             fra (French)            6166.035                46                      35,523,495      201,921
00262.M2TS      4622 (0x120E)   0x90            PGS             deu (German)            6166.035                42                      32,382,444      183,926
00262.M2TS      4623 (0x120F)   0x90            PGS             nld (Dutch)             6166.035                42                      32,671,512      185,619
00262.M2TS      4624 (0x1210)   0x90            PGS             eng (English)           6166.035                2                       1,535,797       8,819
paku is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
