NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #751 of 5106 Old 11-15-2009, 03:13 PM
DigitalfreakNYC's Avatar
Quoted: 127 Post(s)
Good Night & Good Luck (UK) (Lion's Gate)
Code:
        Total   Video
00000.MPLS                                                      AVC     1:32:48 21,762,797,568  23,172,263,661  31.27   24.01   DTS-HD Master 5.1 3734Kbps (48kHz/24-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     GOOD NIGHT AND GOOD LUCK
Disc Size:      23,172,263,661 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:32:48 (h:m:s)
Total Bitrate:          31.27 Mbps
VIDEO:
MPEG-4 AVC Video        24005 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3734 kbps       5.1 / 48 kHz / 3734 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         73.771 kbps
Presentation Graphics           English         80.571 kbps
FILES:
00000.M2TS      0:00:00.000     1:32:47.270     21,759,873,024  31,268
00042.M2TS      1:32:47.270     0:00:01.000     2,924,544       23,373
CHAPTERS:
1               0:00:00.000     0:05:23.156     23,627 kbps     42,071 kbps     00:02:19.389    37,326 kbps     00:02:17.262    36,146 kbps     00:02:17.804    123,165 bytes   399,014 bytes   00:03:46.976
2               0:05:23.156     0:06:47.198     26,169 kbps     40,692 kbps     00:06:25.968    38,392 kbps     00:05:57.023    37,278 kbps     00:05:53.853    136,431 bytes   508,876 bytes   00:05:57.190
3               0:12:10.354     0:12:23.367     23,866 kbps     41,380 kbps     00:17:07.943    35,556 kbps     00:17:15.909    35,423 kbps     00:17:10.654    124,424 bytes   418,566 bytes   00:23:58.478
4               0:24:33.722     0:06:24.467     24,538 kbps     38,991 kbps     00:29:26.473    34,917 kbps     00:29:39.068    32,562 kbps     00:29:36.816    127,929 bytes   463,541 bytes   00:30:40.588
5               0:30:58.189     0:06:58.668     24,097 kbps     38,387 kbps     00:36:04.245    35,280 kbps     00:36:03.786    32,510 kbps     00:36:02.785    125,633 bytes   397,382 bytes   00:31:25.466
6               0:37:56.857     0:08:02.982     24,103 kbps     37,877 kbps     00:41:01.959    30,181 kbps     00:42:04.772    29,128 kbps     00:38:36.063    125,660 bytes   424,739 bytes   00:41:54.929
7               0:45:59.840     0:05:58.441     27,040 kbps     41,042 kbps     00:47:45.821    36,036 kbps     00:47:44.444    34,139 kbps     00:47:43.902    140,975 bytes   416,643 bytes   00:49:24.920
8               0:51:58.281     0:06:22.882     24,734 kbps     39,691 kbps     00:53:21.448    35,164 kbps     00:53:03.889    34,810 kbps     00:53:03.889    128,951 bytes   410,995 bytes   00:58:21.164
9               0:58:21.164     0:09:15.972     25,840 kbps     42,424 kbps     01:06:14.303    40,239 kbps     01:06:10.341    39,578 kbps     01:06:12.468    134,718 bytes   502,830 bytes   01:06:14.011
10              1:07:37.136     0:08:21.542     25,135 kbps     45,524 kbps     01:07:46.771    41,713 kbps     01:07:45.603    39,154 kbps     01:07:40.598    131,045 bytes   479,708 bytes   01:11:25.531
11              1:15:58.679     0:08:33.763     22,948 kbps     39,956 kbps     01:18:23.240    33,804 kbps     01:18:20.404    31,406 kbps     01:18:15.440    119,638 bytes   405,871 bytes   01:19:43.069
12              1:24:32.442     0:08:15.828     17,236 kbps     38,926 kbps     01:25:30.166    37,801 kbps     01:25:29.124    37,180 kbps     01:25:27.372    89,870 bytes    599,698 bytes   01:25:28.498
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5567.145                24,006                  16,705,610,569  90,869,407
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5567.145                3,735                   2,599,011,868   14,993,416
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           5567.145                1,542                   1,073,369,656   6,680,724
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5567.145                74                      51,346,925      288,015
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5567.145                81                      56,080,404      314,564
00042.M2TS      4113 (0x1011)   0x1B            AVC                                     0.876                   25,517                  2,793,680       15,194
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #752 of 5106 Old 11-15-2009, 03:31 PM - Thread Starter
Cinema Squid's Avatar
Originally Posted by Stephen Dawson View Post
Mr Squid does it differently by manipulating PowerDVD's setup conditions, but here's how I do it.
I use AnyDVD HD. In the Video Blu-ray section I have 'Remove Blu-ray Region Code' ticked, and 'Always ask for region code of inserted disc' selected.
I load the disc and after a while AnyDVD HD asks me to select a region. I select 'C'. AnyDVD HD finishes its disc scan. I then play the disc in PowerDVD. If it plays okay I know that it works in Region C.
I eject the disc, then re-load it. Since I am in Region B, the next time I select 'A' as the region. If it works in PowerDVD then I know that it is okay for Region A as well. For locally acquired discs I assume that they will work in Region B.
I have to check both A and C because I have some discs that are locked to A & B, barring C, and some that are locked to B & C, barring A.
Shortcut: in perhaps 10% of cases AnyDVD HD can make a positive region code determination on its own, so if it says 'Disc is Region Free', or 'Disc Region B', then I rely on that. Normally, though, it says that it can't tell what the region code of the disc is.
Honestly, the way Stephen is doing it is much easier, but of course I like to make life difficult for myself, so here's a description of how I check:
https://www.avsforum.com/avs-vb/showp...6&postcount=51
There is also a utility put together by msgohan that automates this process that you could try out:
https://www.avsforum.com/avs-vb/showthread.php?t=1027837
Cinema Squid is offline
post #753 of 5106 Old 11-15-2009, 03:48 PM
Quoted: 127 Post(s)
Stephen/Squid,
Thanks for the info. I'm done updating from all my titles. If you want to update the first post, feel free
post #754 of 5106 Old 11-16-2009, 10:47 AM
Kuros's Avatar
Code:
        Total   Video
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
VIDEO:
AUDIO:
SUBTITLES:
FILES:
CHAPTERS:
STREAM DIAGNOSTICS:
OMG! DigitalfreakNYC I love you!!
I've been desperately trying to find some info on this title because the US one from Warner Bros is meant to be pretty crap and there are NO reviews of this Lions Gate release that I can find! Thank You! Thank You!
Have you watched it yet btw? How do you rate the picture and sound and do you know how it compares to the US version?
Could you also tell me what extras are on the disc and if it is region free? Cheers!
P.S Icon are releasing this in Australia soon . I wonder how the Aussie version will compare? I'm sure our very own, resident Aussie superstar will let us know soon enough!
Kuros is offline
post #755 of 5106 Old 11-16-2009, 11:44 AM
Kuros's Avatar
I just wanted to say that this thread is easily the best thing on the internet!
Thank you for creating the greatest tool in the history of the universe Mr Squid!
I hope to participate once I upgrade my pooter with a BD drive.
We totally need more scans of non-US titles though, especially UK ones as there are very few reviews of UK Blus online in particular.
Some UK BDs that I'd love to see BDInfoed include:
Knowing
Martyrs
Indiana Jones and the Kingdom of The Crystal Skull
The Nightmare Before Christmas
National Treasure 1 & 2
Chicago
Tin Man
Lost Seasons One to Five (Three and Five in particular)
The X-Files: I want to Believe
Twilight
Freddy Vs Jason
Texas Chainsaw Massacre (2003)
The New World
Milk
Sex and the City
The Mist
Pretty Woman
Enchanted
Fast & Furious
Wolverine
Rogue
28 Weeks Later
Drag Me to Hell
Dirty Dancing
I'm sure there are loads more that I can't remember!
Keep up the excellent work guys.
P.S. Does the BDInfo tool tell you what regions a BD is compatible with? I can't see any mention of Blu-ray region in the logs?
Kuros is offline
post #756 of 5106 Old 11-16-2009, 12:17 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
I have a good number of UK discs that I haven't bothered to scan and post because I fully expect them to be more or less identical to the US ones, and I think that's the case for a majority of the big studio releases.
Though I guess it could be useful if the language options differ.
paku is offline
post #757 of 5106 Old 11-16-2009, 01:23 PM
Kuros's Avatar
Kewl! Do you have any of the UK titles from my list?
A fair few of those BDs on my list have different distributors in the UK. Even the ones with the same distributor can have different specs compared to the US versions.
Disney/Buena Vista for example, used to encode the audio on all their European Blu-rays in 16 bits (as opposed to 24bits like on their US releases). I don't think they do this anymore but I'm not always sure.
Another example of same distributor but different specs in different regions: The scan log of the Czech version of Indiana Jones and the Kingdom of the Crystal Skull (the only non-US version listed here) says the English Dolby TrueHD is only 16 bits (it's 24 bit on the US disc), I was wondering if the Dolby TrueHD on the UK BD is 16 or 24 bits?
Oh and another annoying Disney Anomaly: The French, German and US versions of Snow White include the original English mono track on the Blu-ray. The tards at Disney didn't include the mono track on the version released in the UK though.
So if you have any UK discs please do scan them because they're not always the same!
Kuros is offline
post #758 of 5106 Old 11-16-2009, 01:52 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
The Nightmare Before Christmas - 1993 - UK - Disney - Region B
Code:
        Total   Video
00001.MPLS                                                      AVC     1:16:39 26,567,491,584  45,792,699,296  46.21   29.25   Dolby TrueHD 7.1 4867Kbps (48kHz/24-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     NIGHTMAREBEFOREXMAS_GBR
Disc Size:      45,792,699,296 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:16:39 (h:m:s)
Total Bitrate:          46.21 Mbps
VIDEO:
MPEG-4 AVC Video        29245 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         4867 kbps       7.1 / 48 kHz / 4867 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
DTS Audio                       French          1509 kbps       5.1 / 48 kHz / 1509 kbps / 24-bit
DTS Audio                       German          1509 kbps       5.1 / 48 kHz / 1509 kbps / 24-bit
DTS Audio                       Italian         1509 kbps       5.1 / 48 kHz / 1509 kbps / 24-bit
DTS Audio                       Spanish         1509 kbps       5.1 / 48 kHz / 1509 kbps / 24-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         22.995 kbps
Presentation Graphics           English         26.253 kbps
Presentation Graphics           Danish          19.005 kbps
Presentation Graphics           Danish          33.201 kbps
Presentation Graphics           Dutch           17.778 kbps
Presentation Graphics           Dutch           32.526 kbps
Presentation Graphics           Finnish         20.879 kbps
Presentation Graphics           Finnish         36.496 kbps
Presentation Graphics           French          19.500 kbps
Presentation Graphics           French          43.920 kbps
Presentation Graphics           French          0.193 kbps
Presentation Graphics           German          24.805 kbps
Presentation Graphics           German          41.930 kbps
Presentation Graphics           German          0.176 kbps
Presentation Graphics           Icelandic       21.771 kbps
Presentation Graphics           Icelandic       42.766 kbps
Presentation Graphics           Italian         21.427 kbps
Presentation Graphics           Italian         39.106 kbps
Presentation Graphics           Italian         0.243 kbps
Presentation Graphics           Norwegian       19.527 kbps
Presentation Graphics           Norwegian       42.405 kbps
Presentation Graphics           Spanish         22.455 kbps
Presentation Graphics           Spanish         39.527 kbps
Presentation Graphics           Spanish         0.360 kbps
Presentation Graphics           Swedish         19.728 kbps
Presentation Graphics           Swedish         37.915 kbps
FILES:
00001.M2TS      0:00:00.000     1:16:39.845     26,567,491,584  46,206
CHAPTERS:
1               0:00:00.000     0:01:19.579     23,909 kbps     51,342 kbps     00:00:01.501    35,357 kbps     00:00:13.388    32,813 kbps     00:00:13.388    124,588 bytes   678,256 bytes   00:00:54.387
2               0:01:19.579     0:05:02.719     30,123 kbps     50,299 kbps     00:02:20.557    35,179 kbps     00:04:47.662    32,801 kbps     00:03:03.933    157,046 bytes   723,147 bytes   00:02:20.598
3               0:06:22.298     0:07:47.633     30,196 kbps     39,497 kbps     00:07:06.300    34,689 kbps     00:13:10.372    32,831 kbps     00:09:19.559    157,428 bytes   653,911 bytes   00:13:27.389
4               0:14:09.932     0:06:43.277     30,218 kbps     40,599 kbps     00:17:16.869    35,275 kbps     00:15:36.602    32,794 kbps     00:20:12.711    157,545 bytes   581,447 bytes   00:16:19.395
5               0:20:53.210     0:05:23.114     30,189 kbps     45,427 kbps     00:23:14.101    34,800 kbps     00:20:58.840    32,758 kbps     00:22:38.982    157,391 bytes   724,599 bytes   00:25:54.177
6               0:26:16.324     0:04:28.017     30,210 kbps     44,637 kbps     00:30:27.200    34,569 kbps     00:28:25.995    32,771 kbps     00:27:07.292    157,499 bytes   797,718 bytes   00:30:06.805
7               0:30:44.342     0:04:50.707     29,817 kbps     44,157 kbps     00:33:23.751    34,942 kbps     00:34:12.925    32,163 kbps     00:33:22.625    155,451 bytes   618,879 bytes   00:34:37.200
8               0:35:35.049     0:03:10.481     30,154 kbps     48,295 kbps     00:37:04.388    35,567 kbps     00:37:40.967    32,624 kbps     00:36:43.910    157,207 bytes   637,946 bytes   00:38:19.380
9               0:38:45.531     0:02:35.947     30,214 kbps     39,805 kbps     00:40:53.200    35,312 kbps     00:40:53.200    32,498 kbps     00:40:52.950    157,523 bytes   688,612 bytes   00:41:09.800
10              0:41:21.478     0:04:21.636     30,091 kbps     53,031 kbps     00:43:39.742    35,460 kbps     00:44:01.805    32,672 kbps     00:45:04.326    156,879 bytes   651,872 bytes   00:41:22.396
11              0:45:43.115     0:02:53.256     30,106 kbps     44,529 kbps     00:48:06.800    34,952 kbps     00:48:10.554    32,330 kbps     00:46:57.105    156,961 bytes   658,057 bytes   00:48:07.551
12              0:48:36.371     0:02:33.570     30,194 kbps     42,123 kbps     00:50:18.932    35,418 kbps     00:49:43.021    32,750 kbps     00:49:57.953    157,420 bytes   527,046 bytes   00:50:06.628
13              0:51:09.941     0:02:18.805     30,005 kbps     39,336 kbps     00:51:23.163    34,953 kbps     00:51:52.776    32,761 kbps     00:52:07.249    156,434 bytes   514,541 bytes   00:51:13.862
14              0:53:28.747     0:01:44.479     30,205 kbps     46,506 kbps     00:54:25.679    35,022 kbps     00:54:25.136    32,681 kbps     00:53:52.270    157,473 bytes   574,142 bytes   00:53:56.191
15              0:55:13.226     0:05:00.925     30,206 kbps     45,352 kbps     00:59:38.700    34,876 kbps     00:57:08.716    32,887 kbps     00:57:20.979    157,481 bytes   631,375 bytes   00:57:17.225
16              1:00:14.152     0:01:48.775     30,209 kbps     46,617 kbps     01:00:48.144    33,710 kbps     01:01:27.809    32,145 kbps     01:01:43.157    157,496 bytes   481,657 bytes   01:00:58.780
17              1:02:02.927     0:03:02.515     30,146 kbps     40,783 kbps     01:04:22.900    34,439 kbps     01:04:56.309    32,883 kbps     01:04:13.975    157,166 bytes   546,901 bytes   01:02:45.011
18              1:05:05.443     0:04:11.167     30,215 kbps     51,463 kbps     01:08:22.264    35,520 kbps     01:07:24.206    32,885 kbps     01:08:21.388    157,528 bytes   660,368 bytes   01:08:43.327
19              1:09:16.610     0:02:36.197     28,713 kbps     43,259 kbps     01:10:15.127    34,660 kbps     01:10:13.000    32,473 kbps     01:11:26.448    149,697 bytes   657,605 bytes   01:10:56.585
20              1:11:52.808     0:04:46.035     18,255 kbps     52,007 kbps     01:16:30.961    30,997 kbps     01:16:30.836    29,383 kbps     01:15:36.323    95,175 bytes    625,468 bytes   01:16:36.508
21              1:16:38.844     0:00:01.001     97 kbps         0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    529 bytes       751 bytes       01:16:39.011
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     4599.720                29,246                  16,815,425,554  91,452,403
00001.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           4599.720                5,508                   3,166,621,392   20,087,722
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           4599.720                640                     367,989,760     2,156,190
00001.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           4599.720                192                     110,396,928     718,730
00001.M2TS      4355 (0x1103)   0x82            DTS             fra (French)            4599.720                1,509                   867,646,832     5,174,832
00001.M2TS      4356 (0x1104)   0x82            DTS             ita (Italian)           4599.720                1,509                   867,646,832     5,174,832
00001.M2TS      4357 (0x1105)   0x82            DTS             deu (German)            4599.720                1,509                   867,646,832     5,174,832
00001.M2TS      4358 (0x1106)   0x82            DTS             spa (Spanish)           4599.720                1,509                   867,646,832     5,174,832
00001.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           4599.720                192                     110,396,928     718,730
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4599.720                23                      13,221,536      78,515
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           4599.720                26                      15,095,244      88,851
00001.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            4599.720                20                      11,211,997      67,647
00001.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           4599.720                21                      12,320,303      73,506
00001.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            4599.720                25                      14,262,282      84,350
00001.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           4599.720                22                      12,911,453      77,016
00001.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             4599.720                18                      10,221,824      60,704
00001.M2TS      4615 (0x1207)   0x90            PGS             swe (Swedish)           4599.720                20                      11,343,497      67,187
00001.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         4599.720                20                      11,227,538      67,784
00001.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            4599.720                19                      10,927,689      64,871
00001.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           4599.720                21                      12,005,135      72,086
00001.M2TS      4619 (0x120B)   0x90            PGS             isl (Icelandic)         4599.720                22                      12,517,684      74,775
00001.M2TS      4620 (0x120C)   0x90            PGS             fra (French)            4599.720                44                      25,253,295      147,252
00001.M2TS      4621 (0x120D)   0x90            PGS             ita (Italian)           4599.720                39                      22,485,162      132,221
00001.M2TS      4622 (0x120E)   0x90            PGS             deu (German)            4599.720                42                      24,109,010      141,043
00001.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           4599.720                40                      22,727,476      133,548
00001.M2TS      4624 (0x1210)   0x90            PGS             nld (Dutch)             4599.720                33                      18,701,888      109,790
00001.M2TS      4625 (0x1211)   0x90            PGS             swe (Swedish)           4599.720                38                      21,800,158      128,433
00001.M2TS      4626 (0x1212)   0x90            PGS             nor (Norwegian)         4599.720                42                      24,381,829      142,519
00001.M2TS      4627 (0x1213)   0x90            PGS             dan (Danish)            4599.720                33                      19,089,820      113,706
00001.M2TS      4628 (0x1214)   0x90            PGS             fin (Finnish)           4599.720                36                      20,984,210      122,901
00001.M2TS      4629 (0x1215)   0x90            PGS             isl (Icelandic)         4599.720                43                      24,589,820      143,644
00001.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            4599.720                0                       110,918         663
00001.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           4599.720                0                       139,752         836
00001.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            4599.720                0                       101,241         619
00001.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           4599.720                0                       207,197         1,275
paku is offline
post #759 of 5106 Old 11-16-2009, 02:55 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Changeling - 2008 - UK - Universal - Region ABC
Two playlists for some reason, seems related to the PiP track.
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:21:54 35,870,060,544  40,139,796,497  33.70   22.57   DTS-HD Master 5.1 3440Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     CHANGELING_G51
Disc Size:      40,139,796,497 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:21:54 (h:m:s)
Total Bitrate:          33.70 Mbps
VIDEO:
VC-1 Video              22572 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              714 kbps            480p / 23.976 fps / 16:9 / Advanced Profile 2
VC-1 Video              211 kbps            480p / 23.976 fps / 16:9 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3440 kbps       5.1 / 48 kHz / 3440 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       German          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Italian         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Japanese        768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Express                     English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         18.571 kbps
Presentation Graphics           English         46.665 kbps
Presentation Graphics           Chinese         26.926 kbps
Presentation Graphics           Danish          35.545 kbps
Presentation Graphics           Dutch           32.778 kbps
Presentation Graphics           Finnish         28.584 kbps
Presentation Graphics           French          46.666 kbps
Presentation Graphics           French          18.160 kbps
Presentation Graphics           French          0.447 kbps
Presentation Graphics           German          49.064 kbps
Presentation Graphics           German          17.856 kbps
Presentation Graphics           German          0.497 kbps
Presentation Graphics           Italian         42.944 kbps
Presentation Graphics           Italian         16.601 kbps
Presentation Graphics           Italian         0.481 kbps
Presentation Graphics           Japanese        26.992 kbps
Presentation Graphics           Japanese        15.403 kbps
Presentation Graphics           Japanese        0.426 kbps
Presentation Graphics           Korean          20.428 kbps
Presentation Graphics           Norwegian       37.061 kbps
Presentation Graphics           Portuguese      36.073 kbps
Presentation Graphics           Spanish         43.371 kbps
Presentation Graphics           Spanish         16.833 kbps
Presentation Graphics           Spanish         0.503 kbps
Presentation Graphics           Swedish         38.255 kbps
FILES:
00009.M2TS      0:00:00.000     2:21:54.506     35,870,060,544  33,703
CHAPTERS:
1               0:00:00.000     0:06:30.056     20,417 kbps     36,291 kbps     00:02:09.045    31,037 kbps     00:05:17.775    29,428 kbps     00:05:32.915    107,745 bytes   734,983 bytes   00:06:30.056
2               0:06:30.056     0:07:26.946     24,440 kbps     38,510 kbps     00:09:08.881    33,345 kbps     00:09:05.086    30,035 kbps     00:09:00.998    127,417 bytes   505,527 bytes   00:13:40.569
3               0:13:57.002     0:04:40.613     22,962 kbps     33,097 kbps     00:13:57.002    28,678 kbps     00:13:57.002    27,040 kbps     00:15:02.651    119,714 bytes   598,079 bytes   00:17:02.646
4               0:18:37.616     0:08:24.962     25,081 kbps     37,164 kbps     00:25:42.791    31,294 kbps     00:21:52.644    30,170 kbps     00:21:51.226    130,760 bytes   451,581 bytes   00:25:16.306
5               0:27:02.579     0:09:49.505     23,221 kbps     37,432 kbps     00:31:17.333    31,238 kbps     00:27:32.025    29,765 kbps     00:27:28.563    121,063 bytes   508,219 bytes   00:27:16.426
6               0:36:52.084     0:06:28.387     23,541 kbps     38,678 kbps     00:39:49.303    32,701 kbps     00:38:26.762    29,963 kbps     00:38:26.804    122,733 bytes   476,301 bytes   00:40:18.791
7               0:43:20.472     0:07:30.575     26,483 kbps     37,093 kbps     00:50:43.665    31,446 kbps     00:47:01.151    30,400 kbps     00:46:59.233    138,070 bytes   451,052 bytes   00:44:49.228
8               0:50:51.047     0:06:27.303     25,170 kbps     44,186 kbps     00:52:37.153    30,540 kbps     00:51:04.394    28,951 kbps     00:52:01.493    131,226 bytes   717,213 bytes   00:52:41.825
9               0:57:18.351     0:08:47.235     21,161 kbps     36,809 kbps     01:02:30.663    30,840 kbps     01:02:29.495    28,866 kbps     01:02:24.574    110,326 bytes   455,069 bytes   01:02:34.500
10              1:06:05.586     0:08:21.000     18,372 kbps     39,853 kbps     01:11:06.553    31,397 kbps     01:06:13.135    28,903 kbps     01:06:10.216    95,782 bytes    627,959 bytes   01:09:53.230
11              1:14:26.587     0:07:14.851     23,488 kbps     36,526 kbps     01:18:55.230    29,878 kbps     01:18:55.230    28,701 kbps     01:19:18.879    122,454 bytes   434,774 bytes   01:18:39.339
12              1:21:41.438     0:06:43.820     26,159 kbps     37,957 kbps     01:24:28.855    29,858 kbps     01:21:45.483    28,790 kbps     01:26:13.293    136,379 bytes   532,092 bytes   01:26:48.745
13              1:28:25.258     0:04:01.908     18,940 kbps     33,153 kbps     01:30:12.073    27,979 kbps     01:30:35.680    26,866 kbps     01:30:32.802    98,744 bytes    363,522 bytes   01:30:12.115
14              1:32:27.166     0:06:03.321     22,226 kbps     35,849 kbps     01:37:32.638    30,390 kbps     01:34:10.102    28,923 kbps     01:33:20.595    115,878 bytes   416,229 bytes   01:34:01.052
15              1:38:30.487     0:08:11.240     20,435 kbps     36,591 kbps     01:39:38.180    29,423 kbps     01:38:51.091    28,301 kbps     01:39:36.804    106,538 bytes   399,298 bytes   01:42:38.569
16              1:46:41.728     0:08:30.426     22,408 kbps     33,856 kbps     01:48:05.729    31,097 kbps     01:50:06.391    29,361 kbps     01:47:31.319    116,824 bytes   430,881 bytes   01:52:58.229
17              1:55:12.155     0:06:24.050     20,052 kbps     36,764 kbps     01:55:37.680    30,086 kbps     02:01:16.435    28,983 kbps     01:55:35.678    104,544 bytes   477,910 bytes   01:59:57.857
18              2:01:36.205     0:06:37.897     24,921 kbps     36,336 kbps     02:05:06.582    31,165 kbps     02:01:36.205    29,574 kbps     02:02:11.657    129,928 bytes   465,552 bytes   02:06:02.012
19              2:08:14.103     0:06:25.551     21,342 kbps     37,873 kbps     02:14:03.952    30,287 kbps     02:13:50.647    29,816 kbps     02:13:45.726    111,269 bytes   443,121 bytes   02:14:10.333
20              2:14:39.654     0:07:14.851     19,699 kbps     35,232 kbps     02:18:24.004    31,069 kbps     02:15:21.822    29,388 kbps     02:15:23.156    103,395 bytes   435,396 bytes   02:16:07.993
STREAM DIAGNOSTICS:
00009.M2TS      4113 (0x1011)   0xEA            VC-1                                    8514.423                22,572                  24,023,926,615  130,688,049
00009.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          8514.423                768                     817,392,640     4,789,410
00009.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           8514.423                3,440                   3,660,786,704   21,222,325
00009.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            8514.423                768                     817,392,640     4,789,410
00009.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           8514.423                768                     817,392,640     4,789,410
00009.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            8514.423                768                     817,392,640     4,789,410
00009.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           8514.423                768                     817,392,640     4,789,410
00009.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          8514.423                27                      28,727,479      167,627
00009.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8514.423                47                      49,665,882      284,941
00009.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8514.423                47                      49,667,044      283,711
00009.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           8514.423                43                      45,705,879      262,220
00009.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            8514.423                49                      52,219,953      297,582
00009.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           8514.423                43                      46,159,824      264,653
00009.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             8514.423                33                      34,886,177      200,140
00009.M2TS      4615 (0x1207)   0x90            PGS             dan (Danish)            8514.423                36                      37,830,794      218,010
00009.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           8514.423                29                      30,421,939      178,265
00009.M2TS      4617 (0x1209)   0x90            PGS             kor (Korean)            8514.423                20                      21,741,799      131,216
00009.M2TS      4618 (0x120A)   0x90            PGS             nor (Norwegian)         8514.423                37                      39,444,326      228,190
00009.M2TS      4619 (0x120B)   0x90            PGS             por (Portuguese)        8514.423                36                      38,393,381      220,833
00009.M2TS      4620 (0x120C)   0x90            PGS             swe (Swedish)           8514.423                38                      40,715,586      234,194
00009.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           8514.423                27                      28,657,306      168,150
00009.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          8514.423                15                      16,393,732      92,476
00009.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           8514.423                19                      19,764,960      111,496
00009.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            8514.423                18                      19,327,445      109,408
00009.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           8514.423                17                      17,668,610      100,386
00009.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            8514.423                18                      19,004,122      107,620
00009.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           8514.423                17                      17,915,477      101,729
00009.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          8514.423                0                       453,522         2,591
00009.M2TS      4629 (0x1215)   0x90            PGS             fra (French)            8514.423                0                       475,598         2,739
00009.M2TS      4630 (0x1216)   0x90            PGS             ita (Italian)           8514.423                0                       511,481         2,935
00009.M2TS      4631 (0x1217)   0x90            PGS             deu (German)            8514.423                0                       528,433         3,028
00009.M2TS      4632 (0x1218)   0x90            PGS             spa (Spanish)           8514.423                1                       535,602         3,068
00009.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           8514.423                192                     204,349,440     1,197,360
00009.M2TS      6912 (0x1B00)   0xEA            VC-1                                    8514.423                714                     760,077,252     4,262,219
00009.M2TS      6913 (0x1B01)   0xEA            VC-1                                    8514.423                211                     224,648,427     1,353,175
Code:
        Total   Video
00001.MPLS                                                      VC-1    2:21:54 35,870,060,544  40,139,796,497  33.70   22.57   DTS-HD Master 5.1 3440Kbps (48kHz/24-bit)
Code:
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
(*) Indicates included stream hidden by this playlist.
VIDEO:
* VC-1 Video            714 kbps            480p / 23.976 fps / 16:9 / Advanced Profile 2
* VC-1 Video            211 kbps            480p / 23.976 fps / 16:9 / Advanced Profile 2
AUDIO:
* DTS Express                   English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
FILES:
CHAPTERS:
1               0:00:00.000     2:21:54.506     22,572 kbps     44,186 kbps     00:52:37.153    33,345 kbps     00:09:05.086    30,400 kbps     00:46:59.233    117,787 bytes   734,983 bytes   00:06:30.056
STREAM DIAGNOSTICS:
paku is offline
post #760 of 5106 Old 11-16-2009, 04:26 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Apocalypto - 2006 - UK - Icon - Region B
Seems to be the same as AU version, but with slightly different subtitle bitrate, and Region B locked instead of AB.
Code:
        Total   Video
00001.MPLS                                                      AVC     2:18:21 34,638,587,904  39,692,543,628  33.38   23.87   LPCM 5.1 6912Kbps (48kHz/24-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     APL1EUE1
Disc Size:      39,692,543,628 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:18:21 (h:m:s)
Total Bitrate:          33.38 Mbps
VIDEO:
MPEG-4 AVC Video        23873 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      Mayan languages 6912 kbps       5.1 / 48 kHz / 6912 kbps / 24-bit
Dolby Digital Audio             Mayan languages 640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         4.325 kbps
Presentation Graphics           English         5.750 kbps
Presentation Graphics           English         37.816 kbps
Presentation Graphics           French          4.360 kbps
Presentation Graphics           Spanish         4.499 kbps
FILES:
00001.M2TS      0:00:00.000     2:18:21.334     34,638,587,904  33,381
CHAPTERS:
1               0:00:00.000     0:08:19.332     27,702 kbps     49,345 kbps     00:02:08.711    38,868 kbps     00:05:47.889    35,952 kbps     00:05:43.468    144,414 bytes   530,585 bytes   00:07:32.535
2               0:08:19.332     0:04:44.409     30,365 kbps     48,492 kbps     00:08:35.640    39,418 kbps     00:11:03.871    35,064 kbps     00:11:03.245    158,308 bytes   556,694 bytes   00:09:41.664
3               0:13:03.741     0:06:13.539     24,233 kbps     45,455 kbps     00:19:06.436    34,250 kbps     00:18:48.585    32,523 kbps     00:18:47.042    126,338 bytes   545,623 bytes   00:13:12.625
4               0:19:17.281     0:03:52.440     25,534 kbps     41,027 kbps     00:23:00.629    33,538 kbps     00:21:12.896    31,609 kbps     00:21:11.228    133,121 bytes   460,817 bytes   00:22:33.226
5               0:23:09.721     0:09:24.522     25,054 kbps     50,941 kbps     00:26:25.083    35,741 kbps     00:26:23.123    33,381 kbps     00:23:53.390    130,618 bytes   549,855 bytes   00:30:13.937
6               0:32:34.243     0:05:10.935     24,034 kbps     49,124 kbps     00:34:55.802    31,825 kbps     00:33:48.901    29,825 kbps     00:33:48.735    125,300 bytes   515,413 bytes   00:34:00.705
7               0:37:45.179     0:10:43.476     23,632 kbps     42,509 kbps     00:46:33.832    34,687 kbps     00:43:14.341    33,396 kbps     00:43:13.841    123,204 bytes   532,584 bytes   00:41:50.424
8               0:48:28.655     0:08:10.490     24,499 kbps     49,258 kbps     00:56:29.886    33,150 kbps     00:48:43.962    30,823 kbps     00:49:30.425    127,725 bytes   528,071 bytes   00:50:25.981
9               0:56:39.145     0:04:14.629     22,050 kbps     41,350 kbps     00:57:13.513    34,564 kbps     00:56:43.983    32,394 kbps     00:56:42.857    114,958 bytes   535,260 bytes   00:59:54.799
10              1:00:53.775     0:08:21.334     25,602 kbps     40,218 kbps     01:05:34.055    32,553 kbps     01:05:40.269    31,373 kbps     01:05:34.055    133,476 bytes   522,509 bytes   01:05:34.096
11              1:09:15.109     0:08:57.828     24,622 kbps     43,353 kbps     01:15:23.602    34,796 kbps     01:11:40.587    32,801 kbps     01:11:40.671    128,370 bytes   537,698 bytes   01:16:33.380
12              1:18:12.938     0:05:02.844     21,103 kbps     46,445 kbps     01:21:48.194    30,752 kbps     01:22:01.333    27,381 kbps     01:22:02.334    110,020 bytes   498,056 bytes   01:22:16.640
13              1:23:15.782     0:08:56.494     22,625 kbps     44,673 kbps     01:25:36.089    35,234 kbps     01:31:16.387    33,691 kbps     01:31:11.382    117,958 bytes   545,721 bytes   01:30:59.745
14              1:32:12.276     0:10:55.446     25,744 kbps     51,716 kbps     01:42:10.165    36,206 kbps     01:34:55.231    34,377 kbps     01:34:49.433    134,220 bytes   556,722 bytes   01:36:07.386
15              1:43:07.723     0:07:07.260     25,094 kbps     67,432 kbps     01:43:12.019    36,903 kbps     01:49:56.631    33,107 kbps     01:43:12.019    130,827 bytes   591,741 bytes   01:43:12.060
16              1:50:14.983     0:07:30.700     26,285 kbps     41,001 kbps     01:55:32.133    34,628 kbps     01:52:39.043    33,379 kbps     01:52:39.043    137,040 bytes   555,572 bytes   01:51:34.354
17              1:57:45.683     0:10:20.786     27,216 kbps     47,768 kbps     02:03:35.324    34,612 kbps     02:03:38.202    32,690 kbps     02:02:32.845    141,894 bytes   530,690 bytes   02:00:25.176
18              2:08:06.470     0:01:42.769     22,474 kbps     39,762 kbps     02:09:44.568    31,850 kbps     02:08:13.769    29,862 kbps     02:08:11.350    117,167 bytes   511,670 bytes   02:09:45.194
19              2:09:49.239     0:08:32.094     5,893 kbps      33,843 kbps     02:18:05.819    24,272 kbps     02:18:05.235    15,072 kbps     02:18:04.734    30,726 bytes    394,561 bytes   02:18:07.529
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     8301.210                23,874                  24,772,633,884  134,750,652
00001.M2TS      4352 (0x1100)   0x80            LPCM            myn (Mayan languages)   8301.210                6,919                   7,178,994,508   39,846,408
00001.M2TS      4353 (0x1101)   0x81            AC3             myn (Mayan languages)   8301.210                640                     664,107,520     3,891,255
00001.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           8301.210                192                     199,232,256     1,297,085
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8301.210                4                       4,488,183       27,503
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8301.210                6                       5,966,812       36,633
00001.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8301.210                4                       4,524,367       27,702
00001.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           8301.210                4                       4,668,529       28,502
00001.M2TS      4612 (0x1204)   0x90            PGS             eng (English)           8301.210                38                      39,240,908      225,437
paku is offline
post #761 of 5106 Old 11-16-2009, 05:10 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Waltz with Bashir - 2008 - US - Sony - Region ABC
Full scan for this movie, though the English dub is listed as Main Track for some reason.
Code:
        Total   Video
00001.MPLS                                                      AVC     1:30:22 24,104,140,800  30,780,872,837  35.56   27.93   Dolby TrueHD 5.1 1540Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     WALTZ_WITH_BASHIR
Disc Size:      30,780,872,837 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:30:22 (h:m:s)
Total Bitrate:          35.56 Mbps
VIDEO:
MPEG-4 AVC Video        27928 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1540 kbps       5.1 / 48 kHz / 1540 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps)
Dolby TrueHD Audio              Hebrew          1573 kbps       5.1 / 48 kHz / 1573 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps)
SUBTITLES:
Presentation Graphics           English         27.487 kbps
Presentation Graphics           English         20.780 kbps
FILES:
00011.M2TS      0:00:00.000     1:30:22.417     24,104,140,800  35,562
CHAPTERS:
1               0:00:00.000     0:04:23.012     27,414 kbps     43,391 kbps     00:00:40.623    33,758 kbps     00:02:15.009    32,716 kbps     00:02:09.921    142,901 bytes   636,191 bytes   00:00:07.465
2               0:04:23.012     0:05:35.168     28,270 kbps     40,207 kbps     00:08:34.889    33,473 kbps     00:04:23.012    33,335 kbps     00:04:23.012    147,385 bytes   690,660 bytes   00:07:55.516
3               0:09:58.180     0:05:10.310     27,900 kbps     39,110 kbps     00:10:39.639    32,638 kbps     00:12:31.917    32,602 kbps     00:12:26.912    145,457 bytes   625,609 bytes   00:14:37.751
4               0:15:08.490     0:04:20.551     28,463 kbps     41,710 kbps     00:19:10.732    34,014 kbps     00:19:07.521    33,336 kbps     00:19:04.184    148,394 bytes   612,254 bytes   00:17:34.845
5               0:19:29.042     0:02:45.874     27,576 kbps     37,870 kbps     00:21:04.179    30,942 kbps     00:21:23.740    29,790 kbps     00:21:18.819    143,770 bytes   687,551 bytes   00:21:04.388
6               0:22:14.916     0:08:37.600     27,857 kbps     39,738 kbps     00:23:56.601    33,306 kbps     00:24:50.864    32,734 kbps     00:24:47.444    145,236 bytes   649,443 bytes   00:25:50.757
7               0:30:52.517     0:04:07.997     27,216 kbps     44,952 kbps     00:31:20.712    33,578 kbps     00:34:28.566    32,583 kbps     00:32:05.715    141,892 bytes   703,731 bytes   00:31:45.111
8               0:35:00.515     0:06:09.952     27,793 kbps     39,307 kbps     00:35:31.254    33,463 kbps     00:35:31.254    33,106 kbps     00:35:31.254    144,901 bytes   652,272 bytes   00:37:10.561
9               0:41:10.468     0:05:47.930     28,800 kbps     38,527 kbps     00:42:39.974    33,899 kbps     00:41:54.887    32,883 kbps     00:41:50.049    150,150 bytes   606,208 bytes   00:41:29.945
10              0:46:58.398     0:05:17.650     27,810 kbps     53,988 kbps     00:50:47.711    33,783 kbps     00:50:47.377    31,714 kbps     00:50:47.377    144,989 bytes   638,269 bytes   00:47:15.040
11              0:52:16.049     0:05:52.477     27,875 kbps     45,325 kbps     00:55:08.972    32,582 kbps     00:56:27.300    31,254 kbps     00:56:22.295    145,328 bytes   590,578 bytes   00:53:21.573
12              0:58:08.526     0:03:44.057     28,539 kbps     46,064 kbps     01:00:54.567    33,262 kbps     01:00:50.647    31,692 kbps     01:00:45.642    148,792 bytes   757,358 bytes   01:00:54.776
13              1:01:52.583     0:02:21.975     27,632 kbps     39,437 kbps     01:02:27.034    33,056 kbps     01:03:46.030    32,307 kbps     01:03:41.025    144,061 bytes   689,781 bytes   01:02:58.483
14              1:04:14.559     0:06:24.175     28,066 kbps     42,609 kbps     01:04:15.518    34,233 kbps     01:04:15.351    32,128 kbps     01:10:01.989    146,323 bytes   655,386 bytes   01:04:29.907
15              1:10:38.734     0:06:26.344     27,730 kbps     38,372 kbps     01:11:27.449    33,434 kbps     01:13:06.507    32,725 kbps     01:13:01.502    144,569 bytes   683,843 bytes   01:11:12.268
16              1:17:05.078     0:13:17.338     27,794 kbps     48,016 kbps     01:29:10.011    34,638 kbps     01:30:04.273    33,292 kbps     01:22:23.897    144,921 bytes   779,582 bytes   01:29:10.345
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     5422.334                27,929                  18,929,721,625  102,955,248
00011.M2TS      4352 (0x1100)   0x83            TrueHD          heb (Hebrew)            5422.334                2,021                   1,369,722,824   10,860,351
00011.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           5422.334                1,988                   1,347,747,886   10,509,086
00011.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5422.334                192                     130,138,368     847,255
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5422.334                27                      18,630,469      106,418
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5422.334                21                      14,085,019      82,357
paku is offline
post #762 of 5106 Old 11-16-2009, 05:49 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Dog Day Afternoon - 1975 - US - Warner - Region ABC
Another full scan that was missing from the list.
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:04:39 18,723,514,368  22,828,079,584  20.03   17.98   DD AC3 1.0 192Kbps                        DD AC3 1.0 192Kbps
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID
Disc Size:      22,828,079,584 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:04:39 (h:m:s)
Total Bitrate:          20.03 Mbps
VIDEO:
VC-1 Video              17981 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             French          192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Spanish         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         59.014 kbps
Presentation Graphics           English         64.347 kbps
Presentation Graphics           French          40.890 kbps
Presentation Graphics           Spanish         48.096 kbps
FILES:
00000.M2TS      0:00:00.000     2:04:39.513     18,723,514,368  20,026
CHAPTERS:
1               0:00:00.000     0:03:22.368     17,218 kbps     32,824 kbps     00:00:26.484    26,583 kbps     00:00:31.823    25,584 kbps     00:00:26.484    90,080 bytes    538,465 bytes   00:00:26.526
2               0:03:22.368     0:05:15.648     18,123 kbps     28,567 kbps     00:03:48.311    20,963 kbps     00:05:55.229    19,773 kbps     00:04:25.306    94,486 bytes    383,135 bytes   00:03:31.753
3               0:08:38.017     0:04:25.265     18,292 kbps     26,872 kbps     00:12:11.272    21,446 kbps     00:12:10.938    19,879 kbps     00:09:26.899    95,366 bytes    367,415 bytes   00:12:11.647
4               0:13:03.282     0:03:30.043     18,195 kbps     31,203 kbps     00:14:13.018    21,472 kbps     00:14:12.643    20,271 kbps     00:13:56.669    94,861 bytes    473,965 bytes   00:14:36.750
5               0:16:33.325     0:04:05.411     18,309 kbps     33,060 kbps     00:17:18.412    22,198 kbps     00:18:45.666    20,147 kbps     00:17:26.295    95,455 bytes    369,625 bytes   00:17:27.546
6               0:20:38.737     0:04:32.105     18,408 kbps     35,552 kbps     00:21:13.438    20,942 kbps     00:23:43.713    19,873 kbps     00:24:18.123    95,973 bytes    437,753 bytes   00:21:13.689
7               0:25:10.842     0:02:35.321     18,301 kbps     26,252 kbps     00:27:27.103    20,970 kbps     00:27:25.518    19,876 kbps     00:27:25.602    95,415 bytes    393,390 bytes   00:26:57.032
8               0:27:46.164     0:03:33.546     18,265 kbps     28,993 kbps     00:29:52.165    21,276 kbps     00:30:25.114    19,747 kbps     00:29:57.754    95,228 bytes    364,240 bytes   00:28:17.487
9               0:31:19.711     0:04:53.459     18,313 kbps     25,219 kbps     00:33:07.610    21,032 kbps     00:33:07.610    19,804 kbps     00:35:14.904    95,475 bytes    351,460 bytes   00:34:49.962
10              0:36:13.171     0:05:06.305     18,195 kbps     25,440 kbps     00:40:27.633    21,273 kbps     00:40:27.591    20,053 kbps     00:40:08.364    94,862 bytes    338,337 bytes   00:36:53.961
11              0:41:19.477     0:07:19.939     18,139 kbps     27,013 kbps     00:42:10.653    21,151 kbps     00:43:20.723    19,669 kbps     00:45:38.610    94,570 bytes    375,516 bytes   00:45:19.299
12              0:48:39.416     0:01:32.258     18,036 kbps     24,520 kbps     00:48:43.295    20,688 kbps     00:50:02.708    19,188 kbps     00:49:13.158    94,030 bytes    310,217 bytes   00:49:16.703
13              0:50:11.675     0:08:52.031     18,070 kbps     31,231 kbps     00:55:19.858    21,047 kbps     00:53:41.760    19,845 kbps     00:50:33.739    94,211 bytes    520,617 bytes   00:55:20.025
14              0:59:03.706     0:02:55.175     18,063 kbps     27,132 kbps     01:00:51.522    20,702 kbps     01:00:40.887    19,700 kbps     01:00:51.230    94,173 bytes    364,217 bytes   01:01:58.715
15              1:01:58.881     0:01:55.281     17,955 kbps     26,200 kbps     01:02:28.453    20,390 kbps     01:03:43.861    19,316 kbps     01:02:11.018    93,609 bytes    334,963 bytes   01:02:29.162
16              1:03:54.163     0:07:17.770     17,950 kbps     28,844 kbps     01:04:39.375    21,341 kbps     01:04:37.665    19,903 kbps     01:04:02.213    93,585 bytes    432,056 bytes   01:09:51.312
17              1:11:11.934     0:03:11.691     18,017 kbps     31,555 kbps     01:11:48.220    20,855 kbps     01:12:16.457    19,293 kbps     01:11:29.868    93,933 bytes    448,837 bytes   01:11:48.262
18              1:14:23.625     0:07:00.420     17,846 kbps     32,317 kbps     01:18:15.816    25,266 kbps     01:19:53.413    23,037 kbps     01:19:54.581    93,039 bytes    448,265 bytes   01:18:15.899
19              1:21:24.045     0:01:50.276     17,950 kbps     25,725 kbps     01:21:33.179    20,465 kbps     01:21:58.955    19,226 kbps     01:22:17.057    93,585 bytes    351,124 bytes   01:21:59.122
20              1:23:14.322     0:08:18.664     17,835 kbps     25,174 kbps     01:31:31.986    21,457 kbps     01:26:46.075    19,450 kbps     01:30:10.530    92,985 bytes    404,434 bytes   01:25:09.521
21              1:31:32.987     0:04:41.447     17,808 kbps     29,029 kbps     01:32:11.901    21,654 kbps     01:34:25.618    19,454 kbps     01:32:20.743    92,845 bytes    338,094 bytes   01:32:11.943
22              1:36:14.435     0:01:53.446     17,819 kbps     30,055 kbps     01:36:58.687    20,982 kbps     01:36:58.103    19,553 kbps     01:36:44.673    92,902 bytes    320,737 bytes   01:36:58.729
23              1:38:07.882     0:02:59.846     17,932 kbps     25,456 kbps     01:38:28.068    20,956 kbps     01:40:27.229    19,434 kbps     01:38:38.078    93,488 bytes    392,726 bytes   01:38:20.352
24              1:41:07.728     0:04:35.275     17,756 kbps     23,758 kbps     01:42:20.801    20,342 kbps     01:45:33.827    19,087 kbps     01:45:29.156    92,570 bytes    302,319 bytes   01:42:51.582
25              1:45:43.003     0:05:31.330     17,766 kbps     28,598 kbps     01:48:49.981    20,502 kbps     01:46:41.269    19,161 kbps     01:47:00.455    92,625 bytes    368,408 bytes   01:49:10.126
26              1:51:14.334     0:04:29.269     17,815 kbps     27,670 kbps     01:54:20.728    20,925 kbps     01:54:32.407    19,646 kbps     01:54:18.601    92,879 bytes    358,545 bytes   01:52:20.900
27              1:55:43.603     0:03:14.194     17,779 kbps     25,567 kbps     01:58:30.478    20,664 kbps     01:58:48.871    19,017 kbps     01:56:07.961    92,691 bytes    295,167 bytes   01:58:51.249
28              1:58:57.797     0:01:42.602     17,695 kbps     24,734 kbps     02:00:16.209    19,582 kbps     02:00:22.256    18,869 kbps     02:00:15.917    92,255 bytes    276,673 bytes   02:00:00.651
29              2:00:40.399     0:02:26.646     17,870 kbps     27,462 kbps     02:02:54.784    21,189 kbps     02:02:54.784    19,484 kbps     02:02:35.806    93,167 bytes    314,040 bytes   02:02:54.867
30              2:03:07.046     0:01:32.467     16,460 kbps     23,477 kbps     02:03:07.129    19,816 kbps     02:03:55.886    18,735 kbps     02:04:06.480    86,874 bytes    314,224 bytes   02:03:56.595
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    7479.430                17,982                  16,811,562,405  91,474,759
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           7479.430                192                     179,508,480     1,168,675
00000.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7479.430                192                     179,508,480     1,168,675
00000.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7479.430                192                     179,508,480     1,168,675
00000.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7479.430                192                     179,508,480     1,168,675
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7479.430                59                      55,174,654      309,955
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7479.430                64                      60,160,267      337,962
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7479.430                41                      38,229,525      216,661
00000.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7479.430                48                      44,967,186      253,687
paku is offline
post #763 of 5106 Old 11-16-2009, 06:11 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
US version, Region ABC
Code:
        Total   Video
Monsters, Inc. (English render)                                 AVC     1:32:15 21,977,174,016  39,068,603,530  31.76   24.12   DTS-HD Master 5.1-ES 4060Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:
Disc Size:      39,068,603,530 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:32:15 (h:m:s)
Total Bitrate:          31.76 Mbps
VIDEO:
MPEG-4 AVC Video        24124 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4060 kbps       5.1-ES / 48 kHz / 4060 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital EX Audio          French          640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Spanish         640 kbps        5.1-EX / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         40.155 kbps
Presentation Graphics           French          34.703 kbps
Presentation Graphics           Spanish         33.283 kbps
Presentation Graphics           English         84.117 kbps
Presentation Graphics           French          69.496 kbps
Presentation Graphics           Spanish         65.253 kbps
FILES:
00138.M2TS      0:00:00.000     0:00:30.238     126,978,048     33,594
00139.M2TS      0:00:30.238     0:01:02.562     244,242,432     31,232
00140.M2TS      0:01:32.801     0:04:42.031     1,134,796,800   32,189
00141.M2TS      0:06:14.832     0:00:45.462     177,899,520     31,305
00142.M2TS      0:07:00.294     0:00:56.556     222,683,136     31,499
00143.M2TS      0:07:56.851     0:00:35.702     141,993,984     31,817
00144.M2TS      0:08:32.553     0:00:28.403     112,490,496     31,684
00145.M2TS      0:09:00.957     0:00:55.180     219,506,688     31,824
00146.M2TS      0:09:56.137     0:03:15.403     773,818,368     31,681
00147.M2TS      0:13:11.540     0:00:25.233     98,875,392      31,347
00148.M2TS      0:13:36.774     0:00:41.791     165,857,280     31,749
00149.M2TS      0:14:18.565     0:02:47.458     673,910,784     32,195
00150.M2TS      0:17:06.024     0:00:39.998     160,813,056     32,164
00151.M2TS      0:17:46.023     0:00:18.893     75,583,488      32,003
00152.M2TS      0:18:04.917     0:01:00.101     251,424,768     33,467
00153.M2TS      0:19:05.018     0:00:30.196     117,848,064     31,221
00154.M2TS      0:19:35.215     0:00:33.783     130,977,792     31,016
01155.M2TS      0:20:08.999     0:00:20.854     83,410,944      31,998
00156.M2TS      0:20:29.853     0:05:18.568     1,255,034,880   31,517
00157.M2TS      0:25:48.421     0:00:17.851     72,781,824      32,617
00158.M2TS      0:26:06.272     0:01:33.426     371,546,112     31,815
00159.M2TS      0:27:39.699     0:01:25.460     349,673,472     32,733
00160.M2TS      0:29:05.159     0:04:34.732     1,144,737,792   33,334
00161.M2TS      0:33:39.892     0:00:26.443     108,306,432     32,767
01162.M2TS      0:34:06.335     0:05:40.590     1,354,856,448   31,824
00163.M2TS      0:39:46.925     0:00:23.440     92,737,536      31,651
00164.M2TS      0:40:10.366     0:03:16.321     773,505,024     31,520
00165.M2TS      0:43:26.687     0:00:32.198     126,738,432     31,489
00166.M2TS      0:43:58.885     0:38:38.691     9,470,631,936   32,676
00167.M2TS      1:22:37.577     0:00:15.640     68,272,128      34,920
01168.M2TS      1:22:53.217     0:00:13.680     64,659,456      37,812
00169.M2TS      1:23:06.898     0:00:16.433     68,038,656      33,123
00170.M2TS      1:23:23.331     0:00:15.015     66,115,584      35,226
00171.M2TS      1:23:38.346     0:00:29.612     116,201,472     31,392
00172.M2TS      1:24:07.959     0:08:07.862     1,560,225,792   25,585
CHAPTERS:
1               0:00:00.000     0:01:33.092     24,256 kbps     41,985 kbps     00:01:26.544    31,700 kbps     00:00:06.423    31,211 kbps     00:00:01.459    126,401 bytes   643,478 bytes   00:01:27.212
2               0:01:33.092     0:01:34.511     22,894 kbps     33,752 kbps     00:03:05.727    26,666 kbps     00:03:02.599    26,198 kbps     00:02:57.594    119,357 bytes   634,717 bytes   00:01:50.860
3               0:03:07.604     0:01:43.520     26,437 kbps     33,529 kbps     00:04:17.090    30,240 kbps     00:04:16.381    30,157 kbps     00:04:25.556    137,831 bytes   645,478 bytes   00:04:51.124
4               0:04:51.124     0:02:25.812     24,164 kbps     33,163 kbps     00:06:41.067    30,212 kbps     00:04:58.506    29,984 kbps     00:04:55.586    125,980 bytes   661,139 bytes   00:07:11.305
5               0:07:16.936     0:01:54.572     23,922 kbps     32,940 kbps     00:09:06.253    30,247 kbps     00:08:08.696    29,576 kbps     00:07:46.257    124,720 bytes   617,646 bytes   00:07:29.323
6               0:09:11.509     0:01:32.091     24,430 kbps     34,953 kbps     00:09:27.692    30,211 kbps     00:09:23.688    28,999 kbps     00:09:18.683    127,367 bytes   785,801 bytes   00:09:28.693
7               0:10:43.601     0:01:10.195     24,234 kbps     32,961 kbps     00:11:15.674    27,111 kbps     00:11:38.948    26,733 kbps     00:11:34.610    126,345 bytes   583,793 bytes   00:11:19.470
8               0:11:53.796     0:05:31.998     23,981 kbps     32,393 kbps     00:14:27.533    29,870 kbps     00:16:07.382    28,836 kbps     00:16:02.377    125,027 bytes   641,551 bytes   00:12:07.643
9               0:17:25.794     0:02:40.285     24,490 kbps     34,348 kbps     00:18:06.376    30,480 kbps     00:18:26.188    29,991 kbps     00:18:22.976    127,678 bytes   831,179 bytes   00:19:05.018
10              0:20:06.079     0:01:57.700     23,943 kbps     32,995 kbps     00:20:49.206    30,343 kbps     00:20:23.930    27,702 kbps     00:20:55.504    124,828 bytes   663,616 bytes   00:21:26.701
11              0:22:03.780     0:03:44.641     24,120 kbps     39,588 kbps     00:24:26.256    30,464 kbps     00:23:01.922    29,511 kbps     00:23:04.549    125,750 bytes   747,839 bytes   00:23:16.269
12              0:25:48.421     0:02:46.541     25,031 kbps     33,138 kbps     00:28:02.138    30,311 kbps     00:28:29.040    29,002 kbps     00:27:38.865    130,498 bytes   540,763 bytes   00:28:32.168
13              0:28:34.963     0:02:31.526     25,223 kbps     33,931 kbps     00:30:26.699    30,096 kbps     00:30:24.238    29,625 kbps     00:30:19.776    131,501 bytes   687,312 bytes   00:29:40.987
14              0:31:06.489     0:03:43.473     25,286 kbps     33,710 kbps     00:33:51.570    30,230 kbps     00:31:23.714    29,594 kbps     00:32:04.630    131,828 bytes   630,439 bytes   00:34:00.371
15              0:34:49.962     0:02:05.667     26,072 kbps     35,175 kbps     00:36:54.253    30,409 kbps     00:35:42.598    30,146 kbps     00:34:50.963    135,927 bytes   689,952 bytes   00:36:37.278
16              0:36:55.629     0:01:54.656     23,166 kbps     33,807 kbps     00:38:02.655    30,688 kbps     00:38:00.569    30,256 kbps     00:37:55.522    120,775 bytes   752,888 bytes   00:38:06.533
17              0:38:50.286     0:01:37.597     22,638 kbps     32,287 kbps     00:39:21.233    28,665 kbps     00:38:55.374    26,792 kbps     00:38:57.334    118,027 bytes   592,753 bytes   00:40:08.322
18              0:40:27.883     0:03:06.394     24,135 kbps     33,483 kbps     00:40:36.809    30,547 kbps     00:40:32.805    29,014 kbps     00:42:13.489    125,831 bytes   684,012 bytes   00:42:36.470
19              0:43:34.278     0:01:55.448     23,352 kbps     33,489 kbps     00:45:23.512    29,558 kbps     00:45:01.782    28,677 kbps     00:45:01.615    121,749 bytes   674,805 bytes   00:43:39.992
20              0:45:29.726     0:02:37.699     25,251 kbps     35,061 kbps     00:46:57.731    30,511 kbps     00:47:17.459    29,708 kbps     00:47:15.165    131,649 bytes   813,452 bytes   00:46:59.316
21              0:48:07.425     0:02:29.732     24,986 kbps     39,973 kbps     00:50:03.792    30,251 kbps     00:50:09.381    29,128 kbps     00:48:26.903    130,265 bytes   673,241 bytes   00:50:18.390
22              0:50:37.158     0:04:04.118     23,384 kbps     34,895 kbps     00:54:34.103    30,314 kbps     00:54:30.099    29,849 kbps     00:52:27.185    121,915 bytes   581,575 bytes   00:54:25.637
23              0:54:41.277     0:02:48.168     24,072 kbps     35,847 kbps     00:57:15.139    30,045 kbps     00:55:04.467    29,347 kbps     00:55:07.136    125,499 bytes   629,123 bytes   00:56:37.435
24              0:57:29.445     0:06:12.580     25,589 kbps     36,202 kbps     00:58:21.873    31,004 kbps     00:58:17.869    30,079 kbps     00:58:12.905    133,411 bytes   801,813 bytes   01:02:25.825
25              1:03:42.026     0:02:42.996     22,143 kbps     35,706 kbps     01:03:55.789    28,871 kbps     01:04:30.449    25,522 kbps     01:04:29.156    115,443 bytes   530,736 bytes   01:04:12.932
26              1:06:25.022     0:01:01.352     26,808 kbps     34,839 kbps     01:06:29.193    30,528 kbps     01:06:25.230    29,572 kbps     01:06:38.994    139,763 bytes   530,658 bytes   01:07:00.140
27              1:07:26.375     0:06:25.760     27,124 kbps     35,235 kbps     01:12:38.520    30,815 kbps     01:08:06.331    30,041 kbps     01:07:30.337    141,411 bytes   717,189 bytes   01:09:26.662
28              1:13:52.135     0:03:57.445     24,698 kbps     35,612 kbps     01:15:00.162    30,562 kbps     01:16:43.598    29,830 kbps     01:16:40.470    128,765 bytes   628,011 bytes   01:14:00.227
29              1:17:49.581     0:03:35.340     25,967 kbps     33,873 kbps     01:21:23.127    30,570 kbps     01:21:19.123    30,227 kbps     01:21:14.118    135,378 bytes   722,660 bytes   01:20:48.134
30              1:21:24.921     0:02:43.037     24,467 kbps     33,276 kbps     01:22:40.913    30,563 kbps     01:23:01.893    30,211 kbps     01:22:56.888    127,560 bytes   704,800 bytes   01:22:43.583
31              1:24:07.959     0:00:58.266     24,857 kbps     33,551 kbps     01:24:22.390    30,175 kbps     01:24:28.688    29,211 kbps     01:24:08.042    129,593 bytes   622,928 bytes   01:24:23.266
32              1:25:06.225     0:07:09.595     17,334 kbps     33,427 kbps     01:31:36.615    31,308 kbps     01:31:36.490    30,881 kbps     01:31:35.447    90,382 bytes    576,600 bytes   01:30:47.566
STREAM DIAGNOSTICS:
00138.M2TS      4113 (0x1011)   0x1B            AVC                                     30.113                  26,109                  98,280,528      534,566
00138.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           30.113                  4,071                   15,324,256      87,961
00138.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            30.113                  643                     2,419,200       14,175
00138.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           30.113                  643                     2,419,200       14,175
00138.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           30.113                  193                     725,760         4,725
00138.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           30.113                  7                       25,797          155
00138.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            30.113                  0                       70              7
00138.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           30.113                  0                       70              7
00138.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           30.113                  81                      303,045         1,707
00138.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            30.113                  68                      254,302         1,440
00138.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           30.113                  64                      242,437         1,377
00139.M2TS      4113 (0x1011)   0x1B            AVC                                     62.479                  23,421                  182,916,983     994,992
00139.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           62.479                  4,382                   34,219,740      195,665
00139.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            62.479                  641                     5,007,360       29,340
00139.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           62.479                  641                     5,007,360       29,340
00139.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           62.479                  192                     1,502,208       9,780
00139.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           62.479                  4                       27,461          163
00139.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            62.479                  0                       70              7
00139.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           62.479                  0                       70              7
00139.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           62.479                  84                      658,839         3,735
00139.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            62.479                  78                      608,322         3,459
00139.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           62.479                  79                      618,514         3,511
00140.M2TS      4113 (0x1011)   0x1B            AVC                                     281.948                 24,703                  870,628,171     4,735,617
00140.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           281.948                 3,850                   135,700,708     781,429
00140.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            281.948                 640                     22,563,840      132,210
00140.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           281.948                 640                     22,563,840      132,210
00140.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           281.948                 192                     6,769,152       44,070
00140.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           281.948                 50                      1,767,853       10,163
00140.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            281.948                 43                      1,505,868       8,581
00140.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           281.948                 41                      1,461,596       8,337
00140.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           281.948                 92                      3,254,629       18,386
00140.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            281.948                 77                      2,719,209       15,431
00140.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           281.948                 72                      2,546,527       14,492
00141.M2TS      4113 (0x1011)   0x1B            AVC                                     45.295                  24,024                  136,020,284     739,863
00141.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           45.295                  3,697                   20,933,980      120,884
00141.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            45.295                  642                     3,637,760       21,315
00141.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           45.295                  642                     3,637,760       21,315
00141.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           45.295                  193                     1,091,328       7,105
00141.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           45.295                  81                      459,118         2,627
00141.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            45.295                  77                      436,288         2,483
00141.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           45.295                  73                      413,379         2,359
00141.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           45.295                  82                      463,260         2,613
00141.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            45.295                  74                      418,282         2,361
00141.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           45.295                  65                      367,203         2,084
00142.M2TS      4113 (0x1011)   0x1B            AVC                                     56.473                  23,930                  168,924,807     918,865
00142.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           56.473                  3,989                   28,158,316      161,825
00142.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            56.473                  641                     4,526,080       26,520
00142.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           56.473                  641                     4,526,080       26,520
00142.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           56.473                  192                     1,357,824       8,840
00142.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           56.473                  57                      404,107         2,324
00142.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            56.473                  52                      368,421         2,114
00142.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           56.473                  49                      345,856         1,992
00142.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           56.473                  83                      586,776         3,315
00142.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            56.473                  73                      514,933         2,917
00142.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           56.473                  67                      469,747         2,672
00143.M2TS      4113 (0x1011)   0x1B            AVC                                     35.536                  24,036                  106,767,502     580,751
00143.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           35.536                  4,279                   19,005,296      108,855
00143.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            35.536                  643                     2,856,960       16,740
00143.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           35.536                  643                     2,856,960       16,740
00143.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           35.536                  193                     857,088         5,580
00143.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           35.536                  71                      315,028         1,792
00143.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            35.536                  52                      232,695         1,332
00143.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           35.536                  57                      252,127         1,438
00143.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           35.536                  76                      336,717         1,908
00143.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            35.536                  68                      302,866         1,715
00143.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           35.536                  58                      259,098         1,478
00144.M2TS      4113 (0x1011)   0x1B            AVC                                     28.320                  23,993                  84,934,478      462,009
00144.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           28.320                  4,186                   14,819,540      84,960
00144.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            28.320                  642                     2,273,280       13,320
00144.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           28.320                  642                     2,273,280       13,320
00144.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           28.320                  193                     681,984         4,440
00144.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           28.320                  48                      171,398         1,001
00144.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            28.320                  40                      142,146         828
00144.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           28.320                  35                      125,243         736
00144.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           28.320                  79                      278,807         1,582
00144.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            28.320                  68                      241,459         1,371
00144.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           28.320                  68                      240,705         1,367
00145.M2TS      4113 (0x1011)   0x1B            AVC                                     55.013                  24,003                  165,059,497     897,847
00145.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           55.013                  4,230                   29,090,352      166,763
00145.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            55.013                  642                     4,416,000       25,875
00145.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           55.013                  642                     4,416,000       25,875
00145.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           55.013                  193                     1,324,800       8,625
00145.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           55.013                  66                      450,841         2,583
00145.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            55.013                  57                      389,976         2,240
00145.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           55.013                  64                      439,896         2,511
00145.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           55.013                  90                      621,187         3,524
00145.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            55.013                  73                      502,733         2,871
00145.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           55.013                  68                      470,326         2,693
00146.M2TS      4113 (0x1011)   0x1B            AVC                                     195.237                 23,967                  584,904,783     3,181,596
00146.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           195.237                 4,136                   100,941,932     579,042
00146.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            195.237                 641                     15,633,920      91,605
00146.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           195.237                 641                     15,633,920      91,605
00146.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           195.237                 192                     4,690,176       30,535
00146.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           195.237                 49                      1,205,521       6,897
00146.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            195.237                 46                      1,133,458       6,471
00146.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           195.237                 43                      1,041,572       5,971
00146.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           195.237                 82                      2,012,672       11,372
00146.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            195.237                 69                      1,687,426       9,567
00146.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           195.237                 66                      1,599,818       9,090
00147.M2TS      4113 (0x1011)   0x1B            AVC                                     25.067                  23,824                  74,648,710      406,058
00147.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           25.067                  4,124                   12,922,780      74,115
00147.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            25.067                  645                     2,019,840       11,835
00147.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           25.067                  645                     2,019,840       11,835
00147.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           25.067                  193                     605,952         3,945
00147.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           25.067                  31                      98,124          568
00147.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            25.067                  13                      40,100          232
00147.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           25.067                  15                      48,201          276
00147.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           25.067                  118                     368,502         2,069
00147.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            25.067                  98                      305,803         1,729
00147.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           25.067                  82                      257,714         1,467
00148.M2TS      4113 (0x1011)   0x1B            AVC                                     41.708                  23,981                  125,025,405     680,064
00148.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           41.708                  4,322                   22,534,304      129,002
00148.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            41.708                  641                     3,343,360       19,590
00148.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           41.708                  641                     3,343,360       19,590
00148.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           41.708                  192                     1,003,008       6,530
00148.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           41.708                  6                       33,807          205
00148.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            41.708                  3                       13,213          79
00148.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           41.708                  2                       11,430          69
00148.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           41.708                  98                      510,952         2,884
00148.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            41.708                  74                      383,907         2,190
00148.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           41.708                  74                      387,046         2,207
00149.M2TS      4113 (0x1011)   0x1B            AVC                                     167.292                 24,178                  505,603,239     2,750,147
00149.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           167.292                 4,475                   93,578,228      534,705
00149.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            167.292                 641                     13,399,040      78,510
00149.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           167.292                 641                     13,399,040      78,510
00149.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           167.292                 192                     4,019,712       26,170
00149.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           167.292                 43                      907,709         5,317
00149.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            167.292                 29                      604,032         3,502
00149.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           167.292                 26                      553,541         3,225
00149.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           167.292                 75                      1,574,840       8,921
00149.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            167.292                 68                      1,428,992       8,115
00149.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           167.292                 60                      1,261,082       7,208
00150.M2TS      4113 (0x1011)   0x1B            AVC                                     39.915                  24,422                  121,848,050     662,783
00150.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           39.915                  4,132                   20,614,036      118,258
00150.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            39.915                  641                     3,200,000       18,750
00150.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           39.915                  641                     3,200,000       18,750
00150.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           39.915                  192                     960,000         6,250
00150.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           39.915                  72                      358,388         2,057
00150.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            39.915                  63                      315,039         1,801
00150.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           39.915                  64                      319,716         1,826
00150.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           39.915                  75                      373,220         2,106
00150.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            39.915                  64                      318,275         1,806
00150.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           39.915                  64                      321,590         1,823
00151.M2TS      4113 (0x1011)   0x1B            AVC                                     18.810                  23,914                  56,230,254      305,871
00151.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           18.810                  4,530                   10,652,344      60,847
00151.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            18.810                  643                     1,512,960       8,865
00151.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           18.810                  643                     1,512,960       8,865
00151.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           18.810                  193                     453,888         2,955
00151.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           18.810                  61                      144,421         835
00151.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            18.810                  44                      102,487         593
00151.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           18.810                  41                      95,917          555
00151.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           18.810                  110                     259,349         1,462
00151.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            18.810                  84                      198,611         1,131
00151.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           18.810                  78                      183,464         1,050
00152.M2TS      4113 (0x1011)   0x1B            AVC                                     59.935                  25,543                  191,366,348     1,040,884
00152.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           59.935                  4,377                   32,788,404      187,605
00152.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            59.935                  642                     4,810,240       28,185
00152.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           59.935                  642                     4,810,240       28,185
00152.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           59.935                  193                     1,443,072       9,395
00152.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           59.935                  47                      353,870         2,042
00152.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            59.935                  24                      182,250         1,039
00152.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           59.935                  20                      152,366         876
00152.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           59.935                  83                      619,847         3,502
00152.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            59.935                  69                      520,299         2,952
00152.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           59.935                  66                      494,501         2,811
00153.M2TS      4113 (0x1011)   0x1B            AVC                                     30.030                  24,055                  90,294,909      491,154
00153.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           30.030                  3,676                   13,798,376      79,742
00153.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            30.030                  644                     2,416,640       14,160
00153.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           30.030                  644                     2,416,640       14,160
00153.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           30.030                  193                     724,992         4,720
00153.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           30.030                  66                      246,327         1,399
00153.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            30.030                  67                      253,158         1,437
00153.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           30.030                  65                      243,574         1,385
00153.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           30.030                  80                      300,366         1,699
00153.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            30.030                  69                      258,795         1,475
00153.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           30.030                  67                      249,716         1,424
00154.M2TS      4113 (0x1011)   0x1B            AVC                                     33.617                  24,004                  100,869,330     548,681
00154.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           33.617                  3,592                   15,092,960      87,283
00154.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            33.617                  643                     2,703,360       15,840
00154.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           33.617                  643                     2,703,360       15,840
00154.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           33.617                  193                     811,008         5,280
00154.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           33.617                  56                      235,103         1,342
00154.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            33.617                  51                      213,828         1,219
00154.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           33.617                  51                      213,824         1,218
00154.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           33.617                  70                      292,529         1,646
00154.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            33.617                  56                      237,417         1,347
00154.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           33.617                  56                      234,811         1,333
01155.M2TS      4113 (0x1011)   0x1B            AVC                                     20.771                  24,233                  62,916,744      342,235
01155.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           20.771                  4,261                   11,062,016      63,336
01155.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            20.771                  643                     1,669,120       9,780
01155.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           20.771                  643                     1,669,120       9,780
01155.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           20.771                  193                     500,736         3,260
01155.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           20.771                  53                      138,316         791
01155.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            20.771                  46                      120,581         690
01155.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           20.771                  47                      123,117         704
01155.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           20.771                  81                      210,527         1,190
01155.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            20.771                  65                      168,750         964
01155.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           20.771                  66                      171,346         977
00156.M2TS      4113 (0x1011)   0x1B            AVC                                     318.401                 24,110                  959,597,203     5,219,685
00156.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           318.401                 3,883                   154,562,596     889,854
00156.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            318.401                 640                     25,487,360      149,340
00156.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           318.401                 640                     25,487,360      149,340
00156.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           318.401                 192                     7,646,208       49,780
00156.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           318.401                 32                      1,277,514       7,446
00156.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            318.401                 22                      891,681         5,147
00156.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           318.401                 22                      863,296         4,989
00156.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           318.401                 86                      3,419,027       19,332
00156.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            318.401                 70                      2,770,683       15,735
00156.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           318.401                 68                      2,693,006       15,314
00157.M2TS      4113 (0x1011)   0x1B            AVC                                     17.684                  25,282                  55,886,260      303,979
00157.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           17.684                  4,074                   9,005,808       51,747
00157.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            17.684                  646                     1,428,480       8,370
00157.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           17.684                  646                     1,428,480       8,370
00157.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           17.684                  194                     428,544         2,790
00157.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           17.684                  16                      34,935          205
00157.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            17.684                  3                       6,668           43
00157.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           17.684                  2                       5,094           35
00157.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           17.684                  81                      179,930         1,027
00157.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            17.684                  76                      167,555         960
00157.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           17.684                  75                      165,395         947
00158.M2TS      4113 (0x1011)   0x1B            AVC                                     93.260                  24,247                  282,654,383     1,537,457
00158.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           93.260                  3,948                   46,021,596      264,707
00158.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            93.260                  641                     7,475,200       43,800
00158.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           93.260                  641                     7,475,200       43,800
00158.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           93.260                  192                     2,242,560       14,600
00158.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           93.260                  64                      746,407         4,293
00158.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            93.260                  55                      646,030         3,715
00158.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           93.260                  53                      620,466         3,576
00158.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           93.260                  94                      1,090,148       6,176
00158.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            93.260                  74                      867,727         4,951
00158.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           93.260                  74                      859,660         4,907
00159.M2TS      4113 (0x1011)   0x1B            AVC                                     85.294                  24,961                  266,131,302     1,447,548
00159.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           85.294                  4,150                   44,241,172      253,739
00159.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            85.294                  641                     6,837,760       40,065
00159.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           85.294                  641                     6,837,760       40,065
00159.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           85.294                  192                     2,051,328       13,355
00159.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           85.294                  54                      570,446         3,265
00159.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            85.294                  49                      523,056         2,988
00159.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           85.294                  47                      506,375         2,896
00159.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           85.294                  89                      952,650         5,393
00159.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            85.294                  76                      813,613         4,628
00159.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           85.294                  72                      768,622         4,387
00160.M2TS      4113 (0x1011)   0x1B            AVC                                     274.566                 25,746                  883,608,597     4,806,081
00160.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           274.566                 3,958                   135,825,700     781,025
00160.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            274.566                 640                     21,980,160      128,790
00160.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           274.566                 640                     21,980,160      128,790
00160.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           274.566                 192                     6,594,048       42,930
00160.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           274.566                 41                      1,402,107       8,134
00160.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            274.566                 37                      1,266,125       7,301
00160.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           274.566                 35                      1,208,866       6,992
00160.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           274.566                 84                      2,884,761       16,260
00160.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            274.566                 70                      2,407,321       13,651
00160.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           274.566                 67                      2,289,643       13,013
00161.M2TS      4113 (0x1011)   0x1B            AVC                                     26.276                  25,794                  84,720,849      460,811
00161.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           26.276                  3,654                   12,002,192      69,283
00161.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            26.276                  645                     2,117,120       12,405
00161.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           26.276                  645                     2,117,120       12,405
00161.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           26.276                  193                     635,136         4,135
00161.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           26.276                  13                      41,247          246
00161.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            26.276                  4                       14,747          87
00161.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           26.276                  2                       6,414           41
00161.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           26.276                  74                      243,741         1,367
00161.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            26.276                  69                      226,791         1,275
00161.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           26.276                  62                      202,295         1,141
01162.M2TS      4113 (0x1011)   0x1B            AVC                                     340.423                 24,332                  1,035,394,638   5,631,925
01162.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           340.423                 3,887                   165,387,780     951,955
01162.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            340.423                 640                     27,248,640      159,660
01162.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           340.423                 640                     27,248,640      159,660
01162.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           340.423                 192                     8,174,592       53,220
01162.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           340.423                 52                      2,226,514       12,824
01162.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            340.423                 46                      1,964,183       11,294
01162.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           340.423                 45                      1,897,460       10,925
01162.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           340.423                 86                      3,680,156       20,765
01162.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            340.423                 69                      2,952,104       16,753
01162.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           340.423                 67                      2,841,219       16,145
00163.M2TS      4113 (0x1011)   0x1B            AVC                                     23.273                  24,064                  70,007,150      380,800
00163.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           23.273                  4,128                   12,008,288      68,895
00163.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            23.273                  645                     1,876,480       10,995
00163.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           23.273                  645                     1,876,480       10,995
00163.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           23.273                  194                     562,944         3,665
00163.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           23.273                  75                      216,967         1,224
00163.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            23.273                  71                      207,002         1,171
00163.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           23.273                  74                      215,231         1,217
00163.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           23.273                  83                      242,467         1,363
00163.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            23.273                  61                      178,388         1,008
00163.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           23.273                  52                      152,381         867
00164.M2TS      4113 (0x1011)   0x1B            AVC                                     196.154                 23,883                  585,606,271     3,185,390
00164.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           196.154                 4,000                   98,086,720      563,668
00164.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            196.154                 641                     15,708,160      92,040
00164.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           196.154                 641                     15,708,160      92,040
00164.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           196.154                 192                     4,712,448       30,680
00164.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           196.154                 68                      1,674,279       9,561
00164.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            196.154                 62                      1,522,784       8,713
00164.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           196.154                 59                      1,446,883       8,300
00164.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           196.154                 90                      2,208,906       12,469
00164.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            196.154                 71                      1,739,411       9,861
00164.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           196.154                 67                      1,651,553       9,374
00165.M2TS      4113 (0x1011)   0x1B            AVC                                     32.115                  23,985                  96,284,540      523,732
00165.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           32.115                  4,042                   16,227,780      93,198
00165.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            32.115                  642                     2,577,920       15,105
00165.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           32.115                  642                     2,577,920       15,105
00165.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           32.115                  193                     773,376         5,035
00165.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           32.115                  33                      131,707         772
00165.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            32.115                  32                      127,963         745
00165.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           32.115                  31                      125,702         732
00165.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           32.115                  78                      313,288         1,773
00165.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            32.115                  63                      252,219         1,431
00165.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           32.115                  60                      242,452         1,379
00166.M2TS      4113 (0x1011)   0x1B            AVC                                     2318.525                24,974                  7,237,870,707   39,368,763
00166.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2318.525                4,092                   1,185,810,792   6,806,215
00166.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            2318.525                640                     185,497,600     1,086,900
00166.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           2318.525                640                     185,497,600     1,086,900
00166.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           2318.525                192                     55,649,280      362,300
00166.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2318.525                40                      11,491,951      66,359
00166.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            2318.525                35                      10,198,400      58,837
00166.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2318.525                34                      9,765,045       56,477
00166.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           2318.525                84                      24,218,275      136,949
00166.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            2318.525                68                      19,843,464      113,011
00166.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           2318.525                64                      18,520,645      105,816
00167.M2TS      4113 (0x1011)   0x1B            AVC                                     15.474                  27,242                  52,691,949      286,584
00167.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           15.474                  4,141                   8,009,328       45,969
00167.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            15.474                  647                     1,251,840       7,335
00167.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           15.474                  647                     1,251,840       7,335
00167.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           15.474                  194                     375,552         2,445
00167.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           15.474                  85                      164,785         931
00167.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            15.474                  85                      164,809         931
00167.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           15.474                  76                      147,004         834
00167.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           15.474                  92                      178,005         1,002
00167.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            15.474                  82                      159,410         902
00167.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           15.474                  71                      137,216         780
01168.M2TS      4113 (0x1011)   0x1B            AVC                                     13.597                  30,200                  51,328,771      279,146
01168.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           13.597                  4,051                   6,885,376       39,568
01168.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            13.597                  645                     1,095,680       6,420
01168.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           13.597                  645                     1,095,680       6,420
01168.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           13.597                  193                     328,704         2,140
01168.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           13.597                  53                      89,559          520
01168.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            13.597                  37                      62,978          368
01168.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           13.597                  38                      64,901          378
01168.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           13.597                  56                      95,703          538
01168.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            13.597                  44                      74,394          423
01168.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           13.597                  40                      67,666          386
00169.M2TS      4113 (0x1011)   0x1B            AVC                                     16.350                  25,514                  52,143,336      283,623
00169.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           16.350                  4,011                   8,197,364       47,107
00169.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            16.350                  644                     1,315,840       7,710
00169.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           16.350                  644                     1,315,840       7,710
00169.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           16.350                  193                     394,752         2,570
00169.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           16.350                  48                      98,013          574
00169.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            16.350                  57                      115,913         671
00169.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           16.350                  48                      97,105          570
00169.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           16.350                  104                     212,694         1,195
00169.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            16.350                  91                      186,263         1,052
00169.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           16.350                  88                      180,171         1,018
00170.M2TS      4113 (0x1011)   0x1B            AVC                                     14.848                  27,748                  51,500,656      280,113
00170.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           14.848                  4,205                   7,804,016       44,747
00170.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            14.848                  648                     1,203,200       7,050
00170.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           14.848                  648                     1,203,200       7,050
00170.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           14.848                  194                     360,960         2,350
00170.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           14.848                  10                      19,344          118
00170.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            14.848                  5                       8,914           56
00170.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           14.848                  4                       6,629           43
00170.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           14.848                  83                      154,924         884
00170.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            14.848                  66                      122,005         695
00170.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           14.848                  69                      128,319         730
00171.M2TS      4113 (0x1011)   0x1B            AVC                                     29.488                  24,023                  88,546,700      481,648
00171.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           29.488                  4,005                   14,762,936      84,806
00171.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            29.488                  643                     2,370,560       13,890
00171.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           29.488                  643                     2,370,560       13,890
00171.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           29.488                  193                     711,168         4,630
00171.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           29.488                  28                      101,375         587
00171.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            29.488                  20                      74,544          439
00171.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           29.488                  18                      67,202          399
00171.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           29.488                  73                      269,235         1,519
00171.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            29.488                  58                      214,146         1,219
00171.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           29.488                  57                      208,824         1,192
00172.M2TS      4113 (0x1011)   0x1B            AVC                                     487.696                 18,243                  1,112,124,758   6,050,866
00172.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           487.696                 4,152                   253,100,404     1,451,168
00172.M2TS      4353 (0x1101)   0x81            AC3-EX          fra (French)            487.696                 640                     39,029,760      228,690
00172.M2TS      4354 (0x1102)   0x81            AC3-EX          spa (Spanish)           487.696                 640                     39,029,760      228,690
00172.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           487.696                 192                     11,708,928      76,230
00172.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           487.696                 3                       156,242         931
00172.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            487.696                 3                       164,393         968
00172.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           487.696                 2                       145,956         870
00172.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           487.696                 79                      4,837,171       27,378
00172.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            487.696                 66                      4,043,622       23,032
00172.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           487.696                 60                      3,669,122       20,987
eric.exe is online now
post #764 of 5106 Old 11-16-2009, 06:34 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Memento - 2000 - US - Sony - Region ABC
And another full scan for the list, gotta link 'em all!
Code:
        Total   Video
00013.MPLS                                                      MPEG-2  1:53:26 21,143,543,808  24,127,704,986  24.85   17.54   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Size:      24,127,704,986 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:53:26 (h:m:s)
Total Bitrate:          24.85 Mbps
VIDEO:
MPEG-2 Video            17535 kbps          1080p / 23.976 fps / 16:9
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         56.572 kbps
Presentation Graphics           English         58.597 kbps
FILES:
00015.M2TS      0:00:00.000     1:53:26.800     21,143,543,808  24,850
CHAPTERS:
1               0:00:00.000     0:06:25.385     15,752 kbps     28,051 kbps     00:02:32.569    20,593 kbps     00:02:28.648    19,704 kbps     00:04:13.294    82,114 bytes    490,450 bytes   00:04:44.575
2               0:06:25.385     0:04:41.281     16,765 kbps     26,037 kbps     00:06:36.854    21,670 kbps     00:06:32.850    19,838 kbps     00:06:27.845    87,403 bytes    469,215 bytes   00:06:33.684
3               0:11:06.666     0:05:06.639     17,706 kbps     29,749 kbps     00:12:35.421    25,694 kbps     00:12:33.753    25,133 kbps     00:12:07.643    92,312 bytes    497,632 bytes   00:12:33.169
4               0:16:13.305     0:06:04.739     18,326 kbps     27,153 kbps     00:20:30.437    23,162 kbps     00:20:22.262    21,971 kbps     00:20:15.214    95,543 bytes    465,118 bytes   00:17:38.599
5               0:22:18.045     0:06:12.747     17,558 kbps     29,121 kbps     00:28:18.196    25,991 kbps     00:28:18.196    25,377 kbps     00:28:17.821    91,540 bytes    532,031 bytes   00:27:39.449
6               0:28:30.792     0:10:56.238     16,527 kbps     27,198 kbps     00:28:40.552    23,426 kbps     00:28:37.674    21,820 kbps     00:28:33.336    86,167 bytes    500,038 bytes   00:28:40.719
7               0:39:27.031     0:09:29.944     18,298 kbps     26,856 kbps     00:40:18.999    24,263 kbps     00:39:39.960    23,530 kbps     00:39:39.502    95,400 bytes    497,056 bytes   00:48:05.757
8               0:48:56.975     0:13:44.907     18,154 kbps     30,441 kbps     00:56:54.244    25,026 kbps     00:57:18.017    24,227 kbps     00:49:32.552    94,644 bytes    523,163 bytes   00:52:39.156
9               1:02:41.883     0:07:15.643     18,197 kbps     28,493 kbps     01:09:37.590    24,262 kbps     01:02:55.521    23,931 kbps     01:09:28.622    94,869 bytes    481,691 bytes   01:03:11.204
10              1:09:57.526     0:07:20.731     17,162 kbps     27,156 kbps     01:16:04.184    23,038 kbps     01:13:36.161    21,749 kbps     01:13:36.161    89,474 bytes    488,046 bytes   01:13:40.833
11              1:17:18.258     0:04:26.224     17,599 kbps     27,365 kbps     01:19:25.135    22,477 kbps     01:19:24.718    21,531 kbps     01:17:52.209    91,752 bytes    482,807 bytes   01:17:55.962
12              1:21:44.482     0:04:49.080     17,484 kbps     24,561 kbps     01:26:00.405    21,748 kbps     01:26:13.543    20,641 kbps     01:26:14.961    91,155 bytes    468,052 bytes   01:22:58.765
13              1:26:33.563     0:07:25.611     18,079 kbps     28,325 kbps     01:29:57.392    26,046 kbps     01:29:53.262    24,160 kbps     01:29:36.621    94,254 bytes    527,717 bytes   01:33:26.267
14              1:33:59.175     0:06:49.700     20,171 kbps     32,248 kbps     01:37:28.801    29,591 kbps     01:37:32.137    27,905 kbps     01:36:26.989    105,165 bytes   479,588 bytes   01:37:41.146
15              1:40:48.876     0:08:30.134     17,166 kbps     30,239 kbps     01:48:26.333    24,642 kbps     01:47:06.711    22,593 kbps     01:49:09.000    89,494 bytes    519,677 bytes   01:48:56.571
16              1:49:19.010     0:04:07.789     13,548 kbps     25,994 kbps     01:49:54.462    21,100 kbps     01:49:27.769    20,422 kbps     01:49:22.764    70,643 bytes    463,014 bytes   01:50:19.154
STREAM DIAGNOSTICS:
00015.M2TS      4113 (0x1011)   0x02            MPEG-2                                  6806.675                17,536                  14,919,902,821  81,181,442
00015.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6806.675                640                     544,545,280     3,190,695
00015.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6806.675                4,614                   3,926,162,240   21,781,760
00015.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6806.675                192                     163,363,584     1,063,565
00015.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6806.675                192                     163,363,584     1,063,565
00015.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           6806.675                192                     163,363,584     1,063,565
00015.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6806.675                57                      48,133,875      269,971
00015.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6806.675                59                      49,857,099      280,013
paku is offline
post #765 of 5106 Old 11-16-2009, 07:19 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Tekkonkinkreet - 2006 - UK - Sony - Region ABC
Code:
        Total   Video
00001.MPLS                                                      AVC     1:50:36 30,942,449,664  39,216,248,585  37.30   25.71   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     TEKKONKINKREET
Disc Size:      39,216,248,585 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:50:36 (h:m:s)
Total Bitrate:          37.30 Mbps
VIDEO:
MPEG-4 AVC Video        25715 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      Japanese        4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -2dB
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -1dB
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -5dB
Dolby Digital Audio             Italian         640 kbps        5.1 / 48 kHz / 640 kbps / DN -2dB
Dolby Digital Audio             Japanese        640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         21.038 kbps
Presentation Graphics           English         17.320 kbps
Presentation Graphics           English         57.929 kbps
Presentation Graphics           Arabic          11.949 kbps
Presentation Graphics           Bulgarian       20.288 kbps
Presentation Graphics           Croatian        19.888 kbps
Presentation Graphics           Danish          21.199 kbps
Presentation Graphics           Dutch           22.462 kbps
Presentation Graphics           Dutch           44.513 kbps
Presentation Graphics           Finnish         21.971 kbps
Presentation Graphics           French          22.975 kbps
Presentation Graphics           French          49.650 kbps
Presentation Graphics           German          25.918 kbps
Presentation Graphics           German          52.827 kbps
Presentation Graphics           Greek           21.918 kbps
Presentation Graphics           Hebrew          16.564 kbps
Presentation Graphics           Hindi           21.644 kbps
Presentation Graphics           Hungarian       21.338 kbps
Presentation Graphics           Icelandic       23.760 kbps
Presentation Graphics           Italian         22.008 kbps
Presentation Graphics           Italian         53.226 kbps
Presentation Graphics           Norwegian       21.274 kbps
Presentation Graphics           Polish          21.242 kbps
Presentation Graphics           Portuguese      22.225 kbps
Presentation Graphics           Romanian        20.906 kbps
Presentation Graphics           Slovenian       19.280 kbps
Presentation Graphics           Spanish         22.479 kbps
Presentation Graphics           Spanish         49.960 kbps
Presentation Graphics           Swedish         21.328 kbps
Presentation Graphics           Turkish         21.390 kbps
FILES:
00011.M2TS      0:00:00.000     1:50:36.630     30,942,449,664  37,299
CHAPTERS:
1               0:00:00.000     0:06:38.981     25,037 kbps     56,326 kbps     00:01:33.635    35,573 kbps     00:04:17.048    33,165 kbps     00:02:33.528    130,516 bytes   783,472 bytes   00:04:50.164
2               0:06:38.981     0:07:34.120     26,436 kbps     50,183 kbps     00:08:37.850    35,998 kbps     00:10:07.815    33,549 kbps     00:10:27.752    137,823 bytes   783,193 bytes   00:11:38.572
3               0:14:13.102     0:07:39.667     25,834 kbps     47,572 kbps     00:19:27.332    33,351 kbps     00:20:29.061    31,781 kbps     00:20:07.915    134,685 bytes   783,266 bytes   00:18:29.900
4               0:21:52.769     0:05:59.025     25,084 kbps     43,083 kbps     00:25:13.553    33,564 kbps     00:27:11.588    32,386 kbps     00:26:22.831    130,778 bytes   783,557 bytes   00:25:30.362
5               0:27:51.795     0:08:59.330     25,632 kbps     46,733 kbps     00:29:51.956    35,677 kbps     00:35:23.871    33,209 kbps     00:35:23.246    133,636 bytes   783,589 bytes   00:32:21.856
6               0:36:51.125     0:04:57.922     25,949 kbps     43,993 kbps     00:41:43.125    36,656 kbps     00:40:07.530    34,082 kbps     00:40:07.446    135,288 bytes   782,363 bytes   00:40:24.338
7               0:41:49.048     0:06:50.952     25,693 kbps     42,239 kbps     00:46:01.925    35,193 kbps     00:42:03.854    33,875 kbps     00:41:56.555    133,949 bytes   781,181 bytes   00:44:05.934
8               0:48:40.000     0:06:36.270     26,215 kbps     44,266 kbps     00:50:12.342    34,738 kbps     00:52:09.459    33,108 kbps     00:51:56.113    136,673 bytes   783,137 bytes   00:54:46.408
9               0:55:16.271     0:07:17.520     26,125 kbps     46,647 kbps     00:59:34.946    35,349 kbps     00:56:07.155    33,699 kbps     00:58:01.519    136,204 bytes   783,403 bytes   00:56:02.525
10              1:02:33.791     0:07:51.345     25,811 kbps     51,042 kbps     01:09:41.552    34,719 kbps     01:09:41.552    32,639 kbps     01:06:11.926    134,566 bytes   783,412 bytes   01:08:34.401
11              1:10:25.137     0:04:32.313     25,426 kbps     57,960 kbps     01:11:37.209    34,593 kbps     01:13:21.438    32,044 kbps     01:12:27.843    132,561 bytes   783,436 bytes   01:12:02.067
12              1:14:57.451     0:05:04.762     26,237 kbps     44,045 kbps     01:19:58.001    35,693 kbps     01:15:28.732    33,952 kbps     01:15:24.811    136,787 bytes   782,734 bytes   01:16:11.316
13              1:20:02.214     0:04:37.860     25,838 kbps     39,375 kbps     01:21:54.492    33,658 kbps     01:22:14.888    32,593 kbps     01:21:55.243    134,710 bytes   783,030 bytes   01:20:53.348
14              1:24:40.075     0:05:43.676     25,841 kbps     45,548 kbps     01:29:01.961    33,098 kbps     01:25:57.485    30,085 kbps     01:25:56.860    134,725 bytes   782,013 bytes   01:28:41.190
15              1:30:23.751     0:09:12.843     26,464 kbps     42,713 kbps     01:37:48.737    32,129 kbps     01:33:41.490    31,345 kbps     01:32:23.704    137,973 bytes   780,569 bytes   01:34:45.638
16              1:39:36.595     0:11:00.034     24,356 kbps     49,327 kbps     01:40:04.081    33,140 kbps     01:47:30.861    31,739 kbps     01:47:24.896    127,000 bytes   783,556 bytes   01:43:30.162
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6636.547                25,715                  21,332,529,518  116,030,843
00011.M2TS      4352 (0x1100)   0x80            LPCM            jpn (Japanese)          6636.547                4,614                   3,828,008,184   21,237,216
00011.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          6636.547                640                     530,931,200     3,110,925
00011.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6636.547                640                     530,931,200     3,110,925
00011.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            6636.547                640                     530,931,200     3,110,925
00011.M2TS      4356 (0x1104)   0x81            AC3             deu (German)            6636.547                640                     530,931,200     3,110,925
00011.M2TS      4357 (0x1105)   0x81            AC3             ita (Italian)           6636.547                640                     530,931,200     3,110,925
00011.M2TS      4358 (0x1106)   0x81            AC3             spa (Spanish)           6636.547                640                     530,931,200     3,110,925
00011.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           6636.547                192                     159,279,360     1,036,975
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6636.547                21                      17,452,302      101,901
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6636.547                17                      14,368,552      86,546
00011.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6636.547                23                      19,059,242      110,673
00011.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            6636.547                26                      21,500,786      123,976
00011.M2TS      4612 (0x1204)   0x90            PGS             ita (Italian)           6636.547                22                      18,257,602      106,313
00011.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           6636.547                22                      18,648,466      108,463
00011.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             6636.547                22                      18,634,042      108,306
00011.M2TS      4615 (0x1207)   0x90            PGS             ara (Arabic)            6636.547                12                      9,912,741       60,927
00011.M2TS      4616 (0x1208)   0x90            PGS             bul (Bulgarian)         6636.547                20                      16,830,543      98,553
00011.M2TS      4617 (0x1209)   0x90            PGS             hrv (Croatian)          6636.547                20                      16,498,458      96,742
00011.M2TS      4618 (0x120A)   0x90            PGS             dan (Danish)            6636.547                21                      17,586,021      102,646
00011.M2TS      4619 (0x120B)   0x90            PGS             fin (Finnish)           6636.547                22                      18,226,946      105,153
00011.M2TS      4620 (0x120C)   0x90            PGS             ell (Greek)             6636.547                22                      18,182,927      105,858
00011.M2TS      4621 (0x120D)   0x90            PGS             heb (Hebrew)            6636.547                17                      13,740,902      81,767
00011.M2TS      4622 (0x120E)   0x90            PGS             hin (Hindi)             6636.547                22                      17,955,340      104,664
00011.M2TS      4623 (0x120F)   0x90            PGS             hun (Hungarian)         6636.547                21                      17,701,628      103,299
00011.M2TS      4624 (0x1210)   0x90            PGS             isl (Icelandic)         6636.547                24                      19,710,737      114,239
00011.M2TS      4625 (0x1211)   0x90            PGS             nor (Norwegian)         6636.547                21                      17,648,318      103,009
00011.M2TS      4626 (0x1212)   0x90            PGS             pol (Polish)            6636.547                21                      17,622,131      102,860
00011.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        6636.547                22                      18,437,115      107,319
00011.M2TS      4628 (0x1214)   0x90            PGS             ron (Romanian)          6636.547                21                      17,342,817      101,310
00011.M2TS      4629 (0x1215)   0x90            PGS             slv (Slovenian)         6636.547                19                      15,994,617      93,970
00011.M2TS      4630 (0x1216)   0x90            PGS             swe (Swedish)           6636.547                21                      17,693,662      103,270
00011.M2TS      4631 (0x1217)   0x90            PGS             tur (Turkish)           6636.547                21                      17,745,043      103,460
00011.M2TS      4632 (0x1218)   0x90            PGS             eng (English)           6636.547                58                      48,056,745      273,254
00011.M2TS      4633 (0x1219)   0x90            PGS             fra (French)            6636.547                50                      41,188,985      235,884
00011.M2TS      4634 (0x121A)   0x90            PGS             deu (German)            6636.547                53                      43,824,433      250,479
00011.M2TS      4635 (0x121B)   0x90            PGS             ita (Italian)           6636.547                53                      44,155,277      252,051
00011.M2TS      4636 (0x121C)   0x90            PGS             spa (Spanish)           6636.547                50                      41,445,602      237,496
00011.M2TS      4637 (0x121D)   0x90            PGS             nld (Dutch)             6636.547                45                      36,926,861      210,653
paku is offline
post #766 of 5106 Old 11-16-2009, 07:41 PM
Stephen Dawson's Avatar
Amelie - 2001 - Australian version
(Original title: Le fabuleux destin d'Amélie Poulain)
Distributed by Icon Film Distribution Pty Ltd
Region free, confirmed with AnyDVD HD. Note: disc opens with a number of trailers in 576i50 format, and three of the extras are in 1080i50 format.
The audio referred to as 'English' is actually the original French. The subtitles referred to as 'English' are actually English. There is no 'Languages' menu to turn the subtitles on or off. They default on. But you can use the subtitle key on your player's remote control.
Finally, video is 24fps, rather than 23.976.
Code:
        Total   Video
00000.MPLS                                                      AVC     2:02:14 29,115,230,208  34,610,747,082  31.76   25.98   DTS-HD Master 5.1 4125Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     AMELIE
Disc Size:      34,610,747,082 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:02:14 (h:m:s)
VIDEO:
MPEG-4 AVC Video        25981 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4125 kbps       5.1 / 48 kHz / 4125 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         28.893 kbps
FILES:
00000.M2TS      0:00:00.000     2:02:14.041     29,115,230,208  31,759
CHAPTERS:
1               0:00:00.000     0:04:45.375     25,819 kbps     46,537 kbps     00:01:34.124    39,399 kbps     00:02:59.708    36,213 kbps     00:02:57.333    134,452 bytes   466,936 bytes   00:01:44.791
2               0:04:45.375     0:04:42.208     27,656 kbps     47,826 kbps     00:06:33.416    43,092 kbps     00:06:33.000    36,805 kbps     00:06:32.999    144,041 bytes   381,733 bytes   00:06:30.833
3               0:09:27.583     0:04:32.375     27,719 kbps     46,551 kbps     00:09:59.708    42,946 kbps     00:12:28.833    39,053 kbps     00:12:28.625    144,372 bytes   391,714 bytes   00:10:25.208
4               0:13:59.958     0:07:15.458     26,583 kbps     45,013 kbps     00:17:27.375    35,698 kbps     00:17:25.083    32,095 kbps     00:14:48.708    138,452 bytes   354,924 bytes   00:14:18.916
5               0:21:15.416     0:09:09.416     26,746 kbps     49,213 kbps     00:26:18.583    42,367 kbps     00:26:14.583    37,106 kbps     00:23:56.666    139,302 bytes   360,230 bytes   00:24:03.541
6               0:30:24.833     0:04:14.750     26,805 kbps     45,601 kbps     00:32:10.583    36,178 kbps     00:32:07.333    32,076 kbps     00:30:33.041    139,608 bytes   337,730 bytes   00:33:58.125
7               0:34:39.583     0:04:10.958     30,751 kbps     45,610 kbps     00:35:17.166    41,740 kbps     00:35:16.750    39,753 kbps     00:38:12.833    160,161 bytes   355,121 bytes   00:36:29.250
8               0:38:50.541     0:12:33.791     26,401 kbps     46,653 kbps     00:40:35.041    42,783 kbps     00:40:13.916    37,793 kbps     00:40:13.833    137,507 bytes   377,791 bytes   00:42:02.000
9               0:51:24.333     0:06:28.208     24,931 kbps     47,467 kbps     00:51:28.291    42,958 kbps     00:51:24.333    37,365 kbps     00:51:24.541    129,849 bytes   358,531 bytes   00:52:26.625
10              0:57:52.541     0:06:53.833     26,886 kbps     41,279 kbps     01:04:13.625    34,978 kbps     01:04:09.666    31,678 kbps     01:02:13.708    140,031 bytes   348,593 bytes   01:00:04.208
11              1:04:46.375     0:06:17.875     26,360 kbps     44,211 kbps     01:05:33.875    38,503 kbps     01:10:04.958    34,251 kbps     01:09:59.416    137,292 bytes   404,751 bytes   01:08:48.166
12              1:11:04.250     0:09:11.291     26,027 kbps     48,043 kbps     01:13:43.541    38,400 kbps     01:13:52.333    34,560 kbps     01:13:43.541    135,557 bytes   355,461 bytes   01:16:41.125
13              1:20:15.541     0:12:50.000     25,706 kbps     45,611 kbps     01:25:52.416    36,101 kbps     01:25:48.416    31,799 kbps     01:26:14.291    133,885 bytes   360,751 bytes   01:25:32.333
14              1:33:05.541     0:02:42.083     27,958 kbps     48,204 kbps     01:34:48.208    42,101 kbps     01:34:45.125    37,256 kbps     01:35:13.958    145,617 bytes   362,165 bytes   01:34:49.791
15              1:35:47.625     0:09:03.583     27,609 kbps     46,129 kbps     01:44:05.916    37,054 kbps     01:43:42.958    33,380 kbps     01:41:18.791    143,795 bytes   381,048 bytes   01:42:01.083
16              1:44:51.208     0:03:52.750     26,189 kbps     37,269 kbps     01:48:21.333    30,305 kbps     01:48:19.833    29,830 kbps     01:47:29.250    136,400 bytes   371,206 bytes   01:46:39.375
17              1:48:43.958     0:05:39.791     26,361 kbps     43,710 kbps     01:52:12.708    33,436 kbps     01:52:08.833    31,039 kbps     01:52:07.375    137,297 bytes   368,120 bytes   01:49:43.791
18              1:54:23.750     0:02:49.041     28,803 kbps     44,997 kbps     01:56:34.208    42,526 kbps     01:56:34.208    40,554 kbps     01:56:32.791    150,017 bytes   377,338 bytes   01:56:01.833
19              1:57:12.791     0:05:00.000     9,117 kbps      41,381 kbps     01:57:53.791    35,020 kbps     01:57:14.541    34,360 kbps     01:57:13.291    47,485 bytes    375,923 bytes   01:57:51.791
20              2:02:12.791     0:00:01.250     72 kbps         76 kbps         02:02:12.958    0 kbps          00:00:00.000    0 kbps          00:00:00.000    387 bytes       2,432 bytes     02:02:13.541
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     7333.917                25,981                  23,817,939,686  129,547,909
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7333.917                4,125                   3,781,929,648   21,696,635
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7333.917                29                      26,488,094      151,547
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #767 of 5106 Old 11-16-2009, 07:42 PM - Thread Starter
Cinema Squid's Avatar
[UK] Spider-Man (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Sony
Release Date: 2007-10-15
EAN: 5050629650075 (Trilogy Box)
Aspect Ratio: 1.85:1
English DD 5.1 is a descriptive audio track. As far as the TrueHD track goes, the eac3to analyze bit depth finds the maximum bit depth to be 24, but average and most common as 16. I'm calling this 16-bit.
Code:
        Total   Video
[UK] Spider-Man                                                 AVC     2:01:12 31,049,551,872  32,980,349,090  34.16   26.09   Dolby TrueHD 5.1 1712Kbps (48kHz/16-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     SPIDER_MAN
Disc Size:      32,980,349,090 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:01:12 (h:m:s)
Total Bitrate:          34.16 Mbps
VIDEO:
MPEG-4 AVC Video        26089 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1712 kbps       5.1 / 48 kHz / 1712 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -6dB
Dolby Digital Audio             Czech           640 kbps        5.1 / 48 kHz / 640 kbps / DN -1dB
Dolby Digital Audio             Hungarian       640 kbps        5.1 / 48 kHz / 640 kbps / DN -3dB
Dolby Digital Audio             Russian         640 kbps        5.1 / 48 kHz / 640 kbps / DN -2dB
SUBTITLES:
Presentation Graphics           English         25.893 kbps
Presentation Graphics           English         20.789 kbps
Presentation Graphics           Arabic          14.825 kbps
Presentation Graphics           Bulgarian       23.202 kbps
Presentation Graphics           Croatian        20.788 kbps
Presentation Graphics           Czech           20.983 kbps
Presentation Graphics           Danish          21.122 kbps
Presentation Graphics           Dutch           18.933 kbps
Presentation Graphics           Finnish         22.489 kbps
Presentation Graphics           Greek           25.706 kbps
Presentation Graphics           Hebrew          19.623 kbps
Presentation Graphics           Hindi           24.348 kbps
Presentation Graphics           Hungarian       22.965 kbps
Presentation Graphics           Icelandic       21.347 kbps
Presentation Graphics           Norwegian       21.689 kbps
Presentation Graphics           Polish          18.017 kbps
Presentation Graphics           Romanian        24.450 kbps
Presentation Graphics           Russian         0.000 kbps
Presentation Graphics           Slovenian       21.134 kbps
Presentation Graphics           Swedish         22.834 kbps
Presentation Graphics           Turkish         24.537 kbps
FILES:
00011.M2TS      0:00:00.000     2:01:12.265     31,049,551,872  34,157
CHAPTERS:
1               0:00:00.000     0:06:29.472     24,665 kbps     39,154 kbps     00:00:22.772    31,987 kbps     00:00:22.522    29,739 kbps     00:05:43.509    128,579 bytes   481,173 bytes   00:05:13.313
2               0:06:29.472     0:02:53.423     28,379 kbps     35,143 kbps     00:08:49.237    30,516 kbps     00:07:52.597    29,826 kbps     00:07:52.597    147,957 bytes   444,273 bytes   00:06:33.601
3               0:09:22.895     0:05:33.291     25,738 kbps     40,444 kbps     00:14:45.384    32,142 kbps     00:10:26.917    30,733 kbps     00:10:25.875    134,187 bytes   528,675 bytes   00:10:26.959
4               0:14:56.186     0:02:54.465     28,085 kbps     39,465 kbps     00:17:44.104    33,910 kbps     00:17:40.184    32,252 kbps     00:17:02.438    146,423 bytes   389,399 bytes   00:17:05.774
5               0:17:50.652     0:04:02.951     25,520 kbps     36,069 kbps     00:21:21.446    30,836 kbps     00:20:34.316    29,841 kbps     00:20:36.818    133,050 bytes   563,936 bytes   00:19:45.267
6               0:21:53.603     0:01:35.011     26,188 kbps     34,477 kbps     00:23:19.815    29,213 kbps     00:23:16.645    28,222 kbps     00:23:13.141    136,534 bytes   420,067 bytes   00:23:14.851
7               0:23:28.615     0:01:50.151     27,927 kbps     38,989 kbps     00:24:40.187    32,090 kbps     00:24:39.644    30,755 kbps     00:24:39.936    145,600 bytes   480,139 bytes   00:25:12.469
8               0:25:18.767     0:09:16.347     26,251 kbps     43,925 kbps     00:27:50.293    34,580 kbps     00:27:47.290    31,835 kbps     00:27:47.290    136,862 bytes   493,834 bytes   00:26:35.176
9               0:34:35.114     0:05:47.055     26,577 kbps     41,448 kbps     00:39:54.809    33,511 kbps     00:39:54.809    31,706 kbps     00:39:50.638    138,560 bytes   490,475 bytes   00:36:40.364
10              0:40:22.169     0:01:21.956     29,075 kbps     40,017 kbps     00:40:55.035    31,881 kbps     00:40:36.225    31,011 kbps     00:40:36.642    151,581 bytes   433,219 bytes   00:41:40.414
11              0:41:44.126     0:01:29.756     26,190 kbps     31,680 kbps     00:42:38.347    27,543 kbps     00:42:38.347    26,999 kbps     00:42:38.472    136,543 bytes   398,357 bytes   00:42:07.566
12              0:43:13.882     0:01:26.127     26,082 kbps     30,439 kbps     00:43:25.436    27,718 kbps     00:43:18.804    27,102 kbps     00:43:13.882    135,978 bytes   351,782 bytes   00:44:40.010
13              0:44:40.010     0:09:52.967     25,225 kbps     43,035 kbps     00:49:50.487    30,621 kbps     00:50:56.261    30,146 kbps     00:49:15.535    131,514 bytes   588,847 bytes   00:49:50.696
14              0:54:32.978     0:01:19.579     26,923 kbps     43,503 kbps     00:54:45.240    29,706 kbps     00:54:42.904    28,362 kbps     00:55:39.794    140,364 bytes   516,734 bytes   00:54:46.992
15              0:55:52.557     0:04:56.379     26,017 kbps     33,132 kbps     00:57:09.092    28,755 kbps     00:59:04.332    27,993 kbps     00:58:59.285    135,640 bytes   518,568 bytes   00:59:16.177
16              1:00:48.936     0:03:31.836     23,779 kbps     38,790 kbps     01:02:45.803    28,333 kbps     01:02:45.803    26,515 kbps     01:02:43.634    123,975 bytes   540,909 bytes   01:04:20.773
17              1:04:20.773     0:01:36.262     26,634 kbps     36,458 kbps     01:04:39.542    30,683 kbps     01:04:36.872    29,453 kbps     01:04:33.452    138,858 bytes   560,942 bytes   01:04:28.239
18              1:05:57.036     0:06:15.333     27,050 kbps     40,378 kbps     01:08:40.950    32,697 kbps     01:08:26.685    30,751 kbps     01:08:03.245    141,025 bytes   578,685 bytes   01:10:41.237
19              1:12:12.369     0:02:06.501     27,009 kbps     53,294 kbps     01:12:12.703    33,738 kbps     01:12:12.661    30,599 kbps     01:12:12.661    140,815 bytes   637,646 bytes   01:12:12.911
20              1:14:18.871     0:01:29.798     28,053 kbps     44,550 kbps     01:15:02.748    32,664 kbps     01:15:02.706    30,412 kbps     01:14:58.368    146,256 bytes   451,916 bytes   01:14:22.207
21              1:15:48.669     0:03:46.851     24,575 kbps     39,098 kbps     01:17:34.399    34,104 kbps     01:17:46.912    30,503 kbps     01:17:34.024    128,122 bytes   478,976 bytes   01:17:38.028
22              1:19:35.520     0:02:30.942     25,825 kbps     41,627 kbps     01:20:19.606    33,491 kbps     01:20:17.312    32,140 kbps     01:20:13.183    134,641 bytes   415,363 bytes   01:20:25.111
23              1:22:06.463     0:03:07.145     27,838 kbps     40,083 kbps     01:24:26.394    30,658 kbps     01:24:09.377    30,217 kbps     01:24:26.269    145,134 bytes   435,918 bytes   01:22:34.699
24              1:25:13.608     0:05:25.616     25,326 kbps     33,111 kbps     01:26:18.256    27,458 kbps     01:26:14.252    26,923 kbps     01:26:14.127    132,036 bytes   437,550 bytes   01:25:52.730
25              1:30:39.225     0:08:57.453     26,578 kbps     34,548 kbps     01:39:08.817    30,442 kbps     01:31:23.478    29,485 kbps     01:31:18.514    138,563 bytes   427,861 bytes   01:30:44.230
26              1:39:36.679     0:05:31.706     25,790 kbps     45,413 kbps     01:39:37.805    32,014 kbps     01:40:30.899    30,749 kbps     01:39:37.721    134,457 bytes   644,694 bytes   01:40:09.128
27              1:45:08.385     0:05:19.444     26,342 kbps     39,068 kbps     01:45:25.736    31,529 kbps     01:50:22.115    28,660 kbps     01:50:17.777    137,334 bytes   543,823 bytes   01:45:18.186
28              1:50:27.829     0:10:44.435     25,543 kbps     38,307 kbps     01:55:38.681    31,648 kbps     02:00:51.702    30,940 kbps     01:57:25.621    133,185 bytes   631,341 bytes   01:54:57.849
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     7272.182                26,089                  23,715,460,427  128,990,753
00011.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           7272.182                2,352                   2,138,329,272   16,469,626
00011.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           7272.182                640                     581,783,040     3,408,885
00011.M2TS      4354 (0x1102)   0x81            AC3             ces (Czech)             7272.182                640                     581,783,040     3,408,885
00011.M2TS      4355 (0x1103)   0x81            AC3             hun (Hungarian)         7272.182                640                     581,783,040     3,408,885
00011.M2TS      4356 (0x1104)   0x81            AC3             rus (Russian)           7272.182                640                     581,783,040     3,408,885
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7272.182                26                      23,537,441      135,681
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7272.182                21                      18,897,937      111,530
00011.M2TS      4610 (0x1202)   0x90            PGS             nld (Dutch)             7272.182                19                      17,210,615      99,676
00011.M2TS      4611 (0x1203)   0x90            PGS             ara (Arabic)            7272.182                15                      13,476,563      80,945
00011.M2TS      4612 (0x1204)   0x90            PGS             bul (Bulgarian)         7272.182                23                      21,091,691      122,374
00011.M2TS      4613 (0x1205)   0x90            PGS             hrv (Croatian)          7272.182                21                      18,896,604      110,352
00011.M2TS      4614 (0x1206)   0x90            PGS             ces (Czech)             7272.182                21                      19,074,421      111,238
00011.M2TS      4615 (0x1207)   0x90            PGS             dan (Danish)            7272.182                21                      19,200,918      110,136
00011.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           7272.182                22                      20,443,469      117,788
00011.M2TS      4617 (0x1209)   0x90            PGS             ell (Greek)             7272.182                26                      23,367,905      134,574
00011.M2TS      4618 (0x120A)   0x90            PGS             heb (Hebrew)            7272.182                20                      17,838,302      104,678
00011.M2TS      4619 (0x120B)   0x90            PGS             hin (Hindi)             7272.182                24                      22,133,222      128,053
00011.M2TS      4620 (0x120C)   0x90            PGS             hun (Hungarian)         7272.182                23                      20,875,908      121,071
00011.M2TS      4621 (0x120D)   0x90            PGS             isl (Icelandic)         7272.182                21                      19,405,455      112,840
00011.M2TS      4622 (0x120E)   0x90            PGS             nor (Norwegian)         7272.182                22                      19,716,260      114,699
00011.M2TS      4623 (0x120F)   0x90            PGS             pol (Polish)            7272.182                18                      16,378,466      96,258
00011.M2TS      4624 (0x1210)   0x90            PGS             ron (Romanian)          7272.182                24                      22,225,489      128,467
00011.M2TS      4625 (0x1211)   0x90            PGS             slv (Slovenian)         7272.182                21                      19,211,705      111,133
00011.M2TS      4626 (0x1212)   0x90            PGS             swe (Swedish)           7272.182                23                      20,756,620      119,116
00011.M2TS      4627 (0x1213)   0x90            PGS             tur (Turkish)           7272.182                25                      22,304,800      128,849
00011.M2TS      4628 (0x1214)   0x90            PGS             rus (Russian)           7272.182                0                       70              7
Cinema Squid is offline
post #768 of 5106 Old 11-16-2009, 07:43 PM - Thread Starter
[UK] Spider-Man 2 (Additional Details)
Studio: Sony
Aspect Ratio: 2.40:1
The Spider-Man 2 and Spider-Man 2.1 playlists are seamlessly branched. Interestingly, the main English TrueHD and Czech/Polish DD dubs are duplicated with a different version of each being used in each playlist. There is an additional English DD 2.0 track which is a descriptive audio track and is only available on the theatrical cut.
Code:
        Total   Video
Spider-Man                                                      AVC     2:07:28 37,269,983,232  49,838,875,847  38.98   24.14   Dolby TrueHD 5.1 3694Kbps (48kHz/24-bit)
   Spider-Man 2.1                                               AVC     2:15:48 39,587,856,384  49,838,875,847  38.87   24.06   Dolby TrueHD 5.1 3675Kbps (48kHz/24-bit)
Spider-Man 2
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID
Disc Size:      49,838,875,847 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:07:28 (h:m:s)
Total Bitrate:          38.98 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        24140 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
* Dolby TrueHD Audio            English         3684 kbps       5.1 / 48 kHz / 3684 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              English         3694 kbps       5.1 / 48 kHz / 3694 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
* Dolby Digital Audio           Czech           448 kbps        5.1 / 48 kHz / 448 kbps / DN -1dB
* Dolby Digital Audio           Polish          448 kbps        5.1 / 48 kHz / 448 kbps / DN -3dB
Dolby Digital Audio             Polish          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -1dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         20.625 kbps
Presentation Graphics           English         17.063 kbps
Presentation Graphics           Arabic          10.795 kbps
Presentation Graphics           Bulgarian       18.549 kbps
Presentation Graphics           Croatian        17.739 kbps
Presentation Graphics           Czech           18.215 kbps
Presentation Graphics           Greek           20.831 kbps
Presentation Graphics           Hebrew          16.028 kbps
Presentation Graphics           Hindi           18.051 kbps
Presentation Graphics           Icelandic       20.443 kbps
Presentation Graphics           Polish          18.192 kbps
Presentation Graphics           Romanian        18.453 kbps
Presentation Graphics           Slovenian       17.389 kbps
Presentation Graphics           Turkish         21.791 kbps
FILES:
00001.M2TS      0:00:00.000     0:06:57.625     2,084,038,656   39,922
00005.M2TS      0:06:57.625     0:04:50.206     1,390,252,032   38,324
00007.M2TS      0:11:47.832     0:00:38.580     177,991,680     36,908
00008.M2TS      0:12:26.412     0:02:15.885     639,344,640     37,640
00010.M2TS      0:14:42.298     0:07:30.199     2,124,367,872   37,750
00016.M2TS      0:22:12.497     0:03:36.549     1,056,878,592   39,044
00038.M2TS      0:25:49.047     0:01:17.327     358,723,584     37,112
00055.M2TS      0:27:06.374     0:02:28.690     730,785,792     39,319
00054.M2TS      0:29:35.064     0:01:45.271     489,191,424     37,175
00022.M2TS      0:31:20.336     0:09:24.897     2,784,086,016   39,428
00041.M2TS      0:40:45.234     0:01:00.560     300,828,672     39,739
00024.M2TS      0:41:45.794     0:09:13.052     2,716,968,960   39,301
00042.M2TS      0:50:58.847     0:00:29.404     146,061,312     39,739
00026.M2TS      0:51:28.251     0:08:16.871     2,497,830,912   40,217
00043.M2TS      0:59:45.123     0:04:49.872     1,388,537,856   38,321
00030.M2TS      1:04:34.995     0:04:47.036     1,358,757,888   37,870
00045.M2TS      1:09:22.032     0:00:55.722     290,549,760     41,714
00032.M2TS      1:10:17.755     0:25:06.171     7,237,607,424   38,442
00046.M2TS      1:35:23.926     0:01:17.118     386,347,008     40,078
00057.M2TS      1:36:41.045     0:01:39.891     498,364,416     39,912
00058.M2TS      1:38:20.936     0:03:32.503     1,049,106,432   39,495
00050.M2TS      1:41:53.440     0:25:34.699     7,563,362,304   39,426
CHAPTERS:
1               0:00:00.000     0:03:27.457     24,859 kbps     56,385 kbps     00:00:23.148    34,638 kbps     00:00:37.245    32,895 kbps     00:00:36.536    129,578 bytes   749,961 bytes   00:00:23.273
2               0:03:27.457     0:03:57.445     24,014 kbps     38,409 kbps     00:05:18.109    30,741 kbps     00:03:28.041    30,011 kbps     00:03:28.082    125,198 bytes   583,753 bytes   00:05:29.120
3               0:07:24.902     0:01:27.921     23,495 kbps     33,814 kbps     00:08:11.240    25,888 kbps     00:08:11.240    25,008 kbps     00:08:11.240    122,492 bytes   463,733 bytes   00:08:52.823
4               0:08:52.823     0:01:13.490     26,404 kbps     37,326 kbps     00:09:06.671    29,551 kbps     00:09:04.168    28,511 kbps     00:08:57.745    137,658 bytes   591,183 bytes   00:10:06.314
5               0:10:06.314     0:04:22.637     23,939 kbps     36,571 kbps     00:10:06.314    31,617 kbps     00:10:06.314    30,375 kbps     00:10:06.314    124,806 bytes   549,998 bytes   00:10:07.106
6               0:14:28.951     0:02:38.491     23,553 kbps     32,113 kbps     00:14:48.929    27,978 kbps     00:14:44.258    27,082 kbps     00:16:47.381    122,796 bytes   474,396 bytes   00:17:07.443
7               0:17:07.443     0:01:48.107     24,022 kbps     34,840 kbps     00:18:08.295    30,615 kbps     00:18:07.836    30,267 kbps     00:18:07.753    125,240 bytes   525,128 bytes   00:17:38.724
8               0:18:55.551     0:03:16.946     23,652 kbps     32,634 kbps     00:20:09.041    28,749 kbps     00:20:24.056    28,311 kbps     00:20:17.925    123,311 bytes   519,025 bytes   00:19:34.590
9               0:22:12.497     0:00:38.038     26,859 kbps     31,234 kbps     00:22:42.527    29,027 kbps     00:22:41.818    27,963 kbps     00:22:25.260    140,031 bytes   465,095 bytes   00:22:14.958
10              0:22:50.535     0:01:33.176     24,348 kbps     34,206 kbps     00:23:25.487    29,871 kbps     00:23:23.568    27,268 kbps     00:23:23.819    126,940 bytes   493,160 bytes   00:23:04.633
11              0:24:23.712     0:01:58.409     23,058 kbps     34,000 kbps     00:25:03.919    27,189 kbps     00:25:03.501    26,349 kbps     00:26:04.521    120,214 bytes   472,357 bytes   00:25:54.928
12              0:26:22.122     0:02:05.458     23,557 kbps     36,023 kbps     00:28:24.661    29,638 kbps     00:27:25.852    26,114 kbps     00:27:25.810    122,817 bytes   543,682 bytes   00:28:27.580
13              0:28:27.580     0:01:07.484     24,048 kbps     38,176 kbps     00:29:18.590    29,179 kbps     00:28:59.904    27,866 kbps     00:28:59.279    125,376 bytes   461,056 bytes   00:28:28.373
14              0:29:35.064     0:01:28.588     23,601 kbps     32,963 kbps     00:30:56.020    30,308 kbps     00:30:56.020    27,661 kbps     00:30:52.976    123,047 bytes   535,900 bytes   00:30:58.523
15              0:31:03.653     0:02:06.209     25,386 kbps     30,009 kbps     00:31:38.521    27,941 kbps     00:31:37.020    27,289 kbps     00:31:08.366    132,350 bytes   472,592 bytes   00:33:09.862
16              0:33:09.862     0:06:40.650     23,518 kbps     46,927 kbps     00:39:07.678    31,756 kbps     00:38:55.416    28,900 kbps     00:38:50.244    122,611 bytes   682,090 bytes   00:39:02.173
17              0:39:50.513     0:02:00.245     25,522 kbps     39,309 kbps     00:41:02.126    31,502 kbps     00:39:55.017    30,445 kbps     00:39:50.721    133,058 bytes   472,608 bytes   00:39:54.308
18              0:41:50.758     0:01:18.369     24,543 kbps     36,969 kbps     00:42:40.224    31,263 kbps     00:42:57.241    29,089 kbps     00:42:49.733    127,955 bytes   545,394 bytes   00:42:58.367
19              0:43:09.128     0:01:31.090     22,746 kbps     28,107 kbps     00:43:24.435    25,157 kbps     00:43:23.767    24,581 kbps     00:43:18.595    118,588 bytes   480,923 bytes   00:43:11.588
20              0:44:40.219     0:02:17.011     22,218 kbps     34,200 kbps     00:46:56.146    25,389 kbps     00:46:22.112    25,164 kbps     00:46:15.731    115,836 bytes   535,569 bytes   00:46:57.147
21              0:46:57.230     0:03:03.933     25,841 kbps     39,571 kbps     00:49:33.428    29,973 kbps     00:49:29.925    29,214 kbps     00:49:46.858    134,724 bytes   517,317 bytes   00:49:40.310
22              0:50:01.164     0:03:01.097     26,501 kbps     37,903 kbps     00:52:23.056    33,127 kbps     00:52:31.398    30,309 kbps     00:52:32.232    138,166 bytes   580,724 bytes   00:50:15.011
23              0:53:02.262     0:05:02.510     24,894 kbps     36,106 kbps     00:56:11.492    31,134 kbps     00:56:01.941    30,706 kbps     00:55:56.811    129,788 bytes   505,642 bytes   00:54:17.504
24              0:58:04.772     0:01:31.508     23,121 kbps     50,023 kbps     00:58:05.064    31,228 kbps     00:59:24.769    30,367 kbps     00:59:24.769    120,543 bytes   616,366 bytes   00:58:05.189
25              0:59:36.280     0:00:25.191     23,995 kbps     36,766 kbps     00:59:36.739    28,103 kbps     00:59:36.614    26,097 kbps     00:59:36.823    125,098 bytes   501,065 bytes   00:59:37.448
26              1:00:01.472     0:01:29.798     26,358 kbps     42,307 kbps     01:00:02.181    31,437 kbps     01:00:02.181    30,144 kbps     01:00:02.098    137,417 bytes   448,901 bytes   01:00:28.624
27              1:01:31.270     0:02:09.128     21,629 kbps     35,391 kbps     01:02:59.775    25,922 kbps     01:02:51.434    25,233 kbps     01:01:53.543    112,763 bytes   405,734 bytes   01:01:32.188
28              1:03:40.399     0:01:44.020     26,400 kbps     46,500 kbps     01:03:43.235    33,601 kbps     01:03:53.788    33,210 kbps     01:03:47.865    137,639 bytes   501,955 bytes   01:03:44.111
29              1:05:24.420     0:02:50.003     22,991 kbps     34,813 kbps     01:05:25.129    30,149 kbps     01:05:36.932    27,768 kbps     01:05:36.891    119,865 bytes   557,496 bytes   01:05:25.671
30              1:08:14.423     0:01:26.252     23,859 kbps     31,719 kbps     01:08:29.104    27,263 kbps     01:08:25.059    26,593 kbps     01:08:20.054    124,390 bytes   456,911 bytes   01:08:42.618
31              1:09:40.676     0:04:07.747     24,373 kbps     41,541 kbps     01:10:06.869    32,506 kbps     01:10:19.173    31,338 kbps     01:10:14.126    127,070 bytes   746,241 bytes   01:10:17.755
32              1:13:48.423     0:02:53.923     21,914 kbps     44,557 kbps     01:15:37.574    33,681 kbps     01:15:36.948    31,167 kbps     01:15:33.737    114,252 bytes   610,845 bytes   01:15:38.408
33              1:16:42.347     0:02:33.820     24,320 kbps     42,074 kbps     01:17:29.853    31,213 kbps     01:17:27.434    30,211 kbps     01:17:26.600    126,795 bytes   478,594 bytes   01:16:53.024
34              1:19:16.167     0:02:09.796     24,141 kbps     29,856 kbps     01:19:47.866    27,720 kbps     01:19:47.824    27,601 kbps     01:19:47.824    125,859 bytes   480,214 bytes   01:20:04.674
35              1:21:25.964     0:03:50.229     24,593 kbps     32,373 kbps     01:22:55.929    27,720 kbps     01:21:39.978    26,868 kbps     01:21:35.807    128,216 bytes   526,653 bytes   01:21:48.987
36              1:25:16.194     0:01:33.176     24,509 kbps     34,959 kbps     01:25:59.195    30,333 kbps     01:26:14.377    28,339 kbps     01:25:56.901    127,781 bytes   543,278 bytes   01:26:08.287
37              1:26:49.370     0:01:21.915     25,435 kbps     29,062 kbps     01:27:23.446    27,022 kbps     01:26:50.997    26,855 kbps     01:27:23.446    132,605 bytes   419,685 bytes   01:28:11.285
38              1:28:11.285     0:02:28.857     23,232 kbps     30,235 kbps     01:28:18.584    26,864 kbps     01:28:14.539    26,676 kbps     01:28:13.704    121,121 bytes   462,673 bytes   01:28:13.746
39              1:30:40.142     0:02:25.019     24,762 kbps     40,305 kbps     01:31:34.071    29,169 kbps     01:31:16.971    27,830 kbps     01:31:16.929    129,097 bytes   472,212 bytes   01:31:09.880
40              1:33:05.162     0:01:07.609     23,915 kbps     36,816 kbps     01:34:10.561    29,458 kbps     01:34:00.217    28,330 kbps     01:34:01.385    124,683 bytes   394,151 bytes   01:33:30.354
41              1:34:12.771     0:00:58.099     25,804 kbps     36,093 kbps     01:35:08.118    29,025 kbps     01:34:42.968    28,280 kbps     01:34:40.090    134,528 bytes   491,196 bytes   01:35:09.119
42              1:35:10.871     0:02:01.496     23,972 kbps     33,983 kbps     01:35:30.099    28,116 kbps     01:35:27.388    26,513 kbps     01:36:22.109    124,980 bytes   425,032 bytes   01:36:29.575
43              1:37:12.368     0:02:44.080     25,587 kbps     40,863 kbps     01:39:14.364    32,889 kbps     01:39:51.443    30,107 kbps     01:39:46.438    133,401 bytes   501,127 bytes   01:39:56.323
44              1:39:56.448     0:02:42.162     22,364 kbps     35,449 kbps     01:42:36.692    29,982 kbps     01:40:04.039    27,030 kbps     01:42:28.517    116,595 bytes   448,849 bytes   01:39:58.075
45              1:42:38.610     0:02:14.217     24,802 kbps     33,996 kbps     01:43:16.565    26,923 kbps     01:44:08.909    26,366 kbps     01:44:08.909    129,305 bytes   425,253 bytes   01:43:50.390
46              1:44:52.828     0:03:10.815     24,331 kbps     40,361 kbps     01:46:20.373    30,067 kbps     01:46:17.537    27,555 kbps     01:46:12.490    126,853 bytes   512,546 bytes   01:47:19.599
47              1:48:03.643     0:05:03.970     23,876 kbps     34,992 kbps     01:52:21.859    29,094 kbps     01:52:17.855    27,627 kbps     01:52:12.850    124,480 bytes   547,243 bytes   01:53:07.613
48              1:53:07.613     0:02:22.559     24,549 kbps     35,937 kbps     01:54:54.220    31,265 kbps     01:55:17.869    30,678 kbps     01:55:12.905    127,986 bytes   428,217 bytes   01:54:59.225
49              1:55:30.173     0:02:26.729     23,918 kbps     34,266 kbps     01:57:49.979    30,667 kbps     01:57:50.146    27,952 kbps     01:57:45.474    124,697 bytes   466,493 bytes   01:57:50.980
50              1:57:56.902     0:03:57.570     24,982 kbps     41,520 kbps     01:57:58.321    30,375 kbps     01:57:57.778    28,448 kbps     01:57:57.945    130,243 bytes   649,292 bytes   01:57:59.322
51              2:01:54.473     0:00:49.674     23,931 kbps     35,181 kbps     02:02:01.814    30,089 kbps     02:02:33.846    27,266 kbps     02:02:29.300    124,766 bytes   434,165 bytes   02:02:26.630
52              2:02:44.148     0:04:43.992     22,427 kbps     35,044 kbps     02:02:48.319    29,159 kbps     02:02:47.568    26,306 kbps     02:02:47.568    116,943 bytes   486,253 bytes   02:05:45.037
Spider-Man 2.1
Code:
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:15:48 (h:m:s)
Total Bitrate:          38.87 Mbps
VIDEO:
MPEG-4 AVC Video        24057 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3675 kbps       5.1 / 48 kHz / 3675 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
* Dolby TrueHD Audio            English         3685 kbps       5.1 / 48 kHz / 3685 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
* Dolby Digital Audio           Polish          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -1dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         21.499 kbps
Presentation Graphics           English         17.657 kbps
Presentation Graphics           Arabic          11.380 kbps
Presentation Graphics           Bulgarian       19.528 kbps
Presentation Graphics           Croatian        18.439 kbps
Presentation Graphics           Czech           19.193 kbps
Presentation Graphics           Greek           21.529 kbps
Presentation Graphics           Hebrew          16.778 kbps
Presentation Graphics           Hindi           19.193 kbps
Presentation Graphics           Icelandic       21.494 kbps
Presentation Graphics           Polish          19.146 kbps
Presentation Graphics           Romanian        19.402 kbps
Presentation Graphics           Slovenian       18.255 kbps
Presentation Graphics           Turkish         22.417 kbps
FILES:
00000.M2TS      0:00:00.000     0:07:46.257     2,293,807,104   39,357
00005.M2TS      0:07:46.257     0:04:50.206     1,390,252,032   38,324
00006.M2TS      0:12:36.464     0:01:31.883     429,729,792     37,415
00008.M2TS      0:14:08.347     0:02:15.885     639,344,640     37,640
00009.M2TS      0:16:24.233     0:08:41.395     2,466,459,648   37,844
00016.M2TS      0:25:05.629     0:03:36.549     1,056,878,592   39,044
00017.M2TS      0:28:42.178     0:01:36.262     444,739,584     36,960
00055.M2TS      0:30:18.441     0:02:28.690     730,785,792     39,319
00056.M2TS      0:32:47.131     0:02:50.461     794,929,152     37,307
00022.M2TS      0:35:37.593     0:09:24.897     2,784,086,016   39,428
00023.M2TS      0:45:02.491     0:01:03.688     316,372,992     39,740
00024.M2TS      0:46:06.180     0:09:13.052     2,716,968,960   39,301
00025.M2TS      0:55:19.232     0:00:48.673     242,239,488     39,814
00026.M2TS      0:56:07.906     0:08:16.871     2,497,830,912   40,217
00027.M2TS      1:04:24.777     0:07:19.230     2,067,265,536   37,652
00030.M2TS      1:11:44.007     0:04:47.036     1,358,757,888   37,870
00031.M2TS      1:16:31.044     0:01:20.080     395,630,592     39,524
00032.M2TS      1:17:51.124     0:25:06.171     7,237,607,424   38,442
00033.M2TS      1:42:57.295     0:02:04.290     616,298,496     39,668
00057.M2TS      1:45:01.586     0:01:39.891     498,364,416     39,912
00103.M2TS      1:46:41.478     0:03:31.961     1,046,145,024   39,484
00050.M2TS      1:50:13.439     0:25:34.699     7,563,362,304   39,426
CHAPTERS:
1               0:00:00.000     0:03:27.457     23,415 kbps     47,698 kbps     00:00:23.148    35,653 kbps     00:00:23.148    27,482 kbps     00:00:17.767    122,053 bytes   776,681 bytes   00:01:49.734
2               0:03:27.457     0:04:46.077     23,861 kbps     38,409 kbps     00:05:31.456    28,626 kbps     00:03:28.249    27,837 kbps     00:03:28.082    124,399 bytes   583,753 bytes   00:05:42.467
3               0:08:13.534     0:01:27.921     23,495 kbps     33,814 kbps     00:08:59.872    25,888 kbps     00:08:59.872    25,008 kbps     00:08:59.872    122,492 bytes   463,733 bytes   00:09:41.455
4               0:09:41.455     0:01:13.490     26,404 kbps     37,326 kbps     00:09:55.303    29,551 kbps     00:09:52.800    28,511 kbps     00:09:46.377    137,658 bytes   591,183 bytes   00:10:54.945
5               0:10:54.945     0:05:15.898     23,908 kbps     40,256 kbps     00:14:03.717    31,617 kbps     00:10:54.945    30,375 kbps     00:10:54.945    124,644 bytes   549,998 bytes   00:10:55.738
6               0:16:10.844     0:03:13.818     23,620 kbps     33,282 kbps     00:16:40.833    31,168 kbps     00:16:39.873    30,274 kbps     00:16:36.537    123,142 bytes   478,042 bytes   00:17:34.720
7               0:19:24.663     0:01:55.073     24,023 kbps     36,115 kbps     00:20:44.660    33,556 kbps     00:20:44.451    30,199 kbps     00:20:39.488    125,244 bytes   525,128 bytes   00:19:55.944
8               0:21:19.736     0:03:45.892     23,716 kbps     33,250 kbps     00:22:33.226    29,841 kbps     00:22:54.873    29,141 kbps     00:22:54.664    123,643 bytes   531,993 bytes   00:23:03.381
9               0:25:05.629     0:00:38.038     26,859 kbps     31,234 kbps     00:25:35.659    29,027 kbps     00:25:34.950    27,963 kbps     00:25:18.391    140,031 bytes   465,095 bytes   00:25:08.089
10              0:25:43.667     0:01:33.176     24,348 kbps     34,206 kbps     00:26:18.618    29,871 kbps     00:26:16.700    27,268 kbps     00:26:16.950    126,940 bytes   493,160 bytes   00:25:57.764
11              0:27:16.843     0:02:00.954     23,081 kbps     34,000 kbps     00:27:57.050    27,189 kbps     00:27:56.633    26,349 kbps     00:29:00.196    120,332 bytes   472,357 bytes   00:28:50.603
12              0:29:17.797     0:02:21.850     23,606 kbps     36,023 kbps     00:31:36.728    29,638 kbps     00:30:37.919    26,257 kbps     00:30:06.262    123,070 bytes   543,682 bytes   00:31:39.647
13              0:31:39.647     0:01:07.484     24,040 kbps     38,176 kbps     00:32:30.656    29,179 kbps     00:32:11.971    27,866 kbps     00:32:11.346    125,334 bytes   461,056 bytes   00:31:40.440
14              0:32:47.131     0:02:33.778     23,927 kbps     39,022 kbps     00:34:51.839    32,558 kbps     00:35:08.606    31,550 kbps     00:35:06.395    124,743 bytes   483,637 bytes   00:32:53.096
15              0:35:20.910     0:02:06.209     24,903 kbps     30,009 kbps     00:35:55.778    27,941 kbps     00:35:54.277    26,923 kbps     00:35:49.230    129,832 bytes   472,592 bytes   00:37:27.119
16              0:37:27.119     0:06:40.650     23,518 kbps     46,927 kbps     00:43:24.935    31,756 kbps     00:43:12.673    28,900 kbps     00:43:07.501    122,611 bytes   682,090 bytes   00:43:19.430
17              0:44:07.770     0:02:03.373     25,435 kbps     39,729 kbps     00:45:20.634    31,502 kbps     00:44:12.274    30,445 kbps     00:44:07.978    132,606 bytes   472,608 bytes   00:44:11.565
18              0:46:11.143     0:01:18.411     24,546 kbps     36,969 kbps     00:47:00.609    31,263 kbps     00:47:17.626    29,089 kbps     00:47:10.118    127,971 bytes   545,394 bytes   00:47:18.752
19              0:47:29.554     0:01:31.591     22,721 kbps     28,107 kbps     00:47:44.820    25,157 kbps     00:47:44.152    24,581 kbps     00:47:38.981    118,454 bytes   480,923 bytes   00:47:31.974
20              0:49:01.146     0:02:16.302     22,205 kbps     32,726 kbps     00:51:16.239    25,389 kbps     00:50:42.497    25,164 kbps     00:50:36.116    115,769 bytes   511,380 bytes   00:51:16.740
21              0:51:17.449     0:03:04.267     25,862 kbps     39,571 kbps     00:53:53.813    29,973 kbps     00:53:50.310    29,214 kbps     00:54:07.243    134,831 bytes   535,569 bytes   00:51:17.532
22              0:54:21.716     0:03:20.450     26,242 kbps     37,903 kbps     00:57:02.710    33,127 kbps     00:57:11.052    30,309 kbps     00:57:11.886    136,812 bytes   580,724 bytes   00:54:35.397
23              0:57:42.166     0:05:02.176     24,906 kbps     36,106 kbps     01:00:51.147    31,134 kbps     01:00:41.596    30,706 kbps     01:00:36.466    129,849 bytes   505,642 bytes   00:58:57.158
24              1:02:44.343     0:01:31.549     23,113 kbps     50,023 kbps     01:02:44.719    31,228 kbps     01:04:04.423    30,367 kbps     01:04:04.423    120,501 bytes   616,366 bytes   01:02:44.844
25              1:04:15.893     0:01:52.403     25,559 kbps     36,766 kbps     01:04:16.394    29,990 kbps     01:06:02.625    28,609 kbps     01:05:55.868    133,254 bytes   601,337 bytes   01:06:05.002
26              1:06:08.297     0:02:17.971     24,940 kbps     30,400 kbps     01:06:57.930    27,614 kbps     01:07:10.568    27,403 kbps     01:07:05.563    130,024 bytes   425,047 bytes   01:07:56.071
27              1:08:26.268     0:02:23.309     20,569 kbps     32,729 kbps     01:10:08.912    25,045 kbps     01:10:38.317    23,798 kbps     01:09:03.639    107,236 bytes   404,659 bytes   01:08:27.144
28              1:10:49.578     0:01:44.020     26,383 kbps     46,500 kbps     01:10:52.247    33,601 kbps     01:11:02.800    33,210 kbps     01:10:56.877    137,551 bytes   501,955 bytes   01:10:53.123
29              1:12:33.599     0:02:49.836     23,012 kbps     34,813 kbps     01:12:34.141    30,149 kbps     01:12:45.944    27,768 kbps     01:12:45.903    119,975 bytes   557,496 bytes   01:12:34.683
30              1:15:23.435     0:01:47.857     23,938 kbps     35,427 kbps     01:16:31.586    27,587 kbps     01:16:30.961    26,593 kbps     01:15:29.066    124,801 bytes   456,911 bytes   01:15:51.630
31              1:17:11.293     0:04:10.500     23,942 kbps     39,248 kbps     01:17:50.999    32,506 kbps     01:17:52.542    30,766 kbps     01:17:47.537    124,825 bytes   746,241 bytes   01:17:51.124
32              1:21:21.793     0:02:53.923     21,914 kbps     44,557 kbps     01:23:10.944    33,681 kbps     01:23:10.318    31,167 kbps     01:23:07.106    114,252 bytes   610,845 bytes   01:23:11.778
33              1:24:15.717     0:02:33.820     24,320 kbps     42,074 kbps     01:25:03.222    31,213 kbps     01:25:00.803    30,211 kbps     01:24:59.969    126,795 bytes   478,594 bytes   01:24:26.394
34              1:26:49.537     0:02:09.796     24,141 kbps     29,856 kbps     01:27:21.235    27,720 kbps     01:27:21.194    27,601 kbps     01:27:21.194    125,859 bytes   480,214 bytes   01:27:38.044
35              1:28:59.333     0:03:49.812     24,590 kbps     32,373 kbps     01:30:29.298    27,720 kbps     01:29:13.347    26,868 kbps     01:29:09.177    128,202 bytes   526,653 bytes   01:29:22.356
36              1:32:49.146     0:01:33.593     24,516 kbps     34,959 kbps     01:33:32.565    30,333 kbps     01:33:47.746    28,339 kbps     01:33:30.271    127,817 bytes   543,278 bytes   01:33:41.657
37              1:34:22.740     0:01:21.915     25,435 kbps     29,062 kbps     01:34:56.815    27,022 kbps     01:34:24.366    26,855 kbps     01:34:56.815    132,605 bytes   419,685 bytes   01:35:44.655
38              1:35:44.655     0:02:28.857     23,232 kbps     30,235 kbps     01:35:51.954    26,864 kbps     01:35:47.908    26,676 kbps     01:35:47.074    121,121 bytes   462,673 bytes   01:35:47.116
39              1:38:13.512     0:02:26.771     24,728 kbps     40,305 kbps     01:39:07.441    29,169 kbps     01:38:50.340    27,830 kbps     01:38:50.299    128,919 bytes   472,212 bytes   01:38:43.250
40              1:40:40.284     0:01:06.191     23,961 kbps     36,816 kbps     01:41:43.931    29,458 kbps     01:41:33.587    28,330 kbps     01:41:34.755    124,920 bytes   394,151 bytes   01:41:03.724
41              1:41:46.475     0:00:57.766     25,823 kbps     36,093 kbps     01:42:41.488    29,025 kbps     01:42:16.338    28,280 kbps     01:42:13.460    134,631 bytes   491,196 bytes   01:42:42.489
42              1:42:44.241     0:02:48.668     23,868 kbps     33,639 kbps     01:43:03.468    27,224 kbps     01:44:57.457    26,578 kbps     01:44:16.166    124,438 bytes   401,602 bytes   01:44:08.700
43              1:45:32.909     0:02:43.538     25,607 kbps     40,435 kbps     01:47:34.906    33,234 kbps     01:48:09.232    31,185 kbps     01:48:06.438    133,504 bytes   460,141 bytes   01:46:11.573
44              1:48:16.448     0:02:42.203     22,361 kbps     35,449 kbps     01:50:56.691    28,359 kbps     01:50:53.354    27,030 kbps     01:50:48.516    116,582 bytes   489,834 bytes   01:48:18.867
45              1:50:58.651     0:02:14.217     24,798 kbps     33,996 kbps     01:51:36.564    26,923 kbps     01:52:28.908    26,366 kbps     01:52:28.908    129,285 bytes   425,253 bytes   01:52:10.390
46              1:53:12.869     0:03:10.773     24,333 kbps     40,361 kbps     01:54:40.373    30,067 kbps     01:54:37.537    27,555 kbps     01:54:32.490    126,859 bytes   512,546 bytes   01:55:39.599
47              1:56:23.643     0:05:03.970     23,876 kbps     34,992 kbps     02:00:41.859    29,094 kbps     02:00:37.855    27,627 kbps     02:00:32.850    124,480 bytes   547,243 bytes   02:01:27.613
48              2:01:27.613     0:02:22.851     24,554 kbps     35,937 kbps     02:03:14.219    31,265 kbps     02:03:37.868    30,678 kbps     02:03:32.905    128,014 bytes   428,217 bytes   02:03:19.224
49              2:03:50.464     0:02:26.855     23,847 kbps     34,266 kbps     02:06:09.978    30,667 kbps     02:06:10.145    27,952 kbps     02:06:05.474    124,326 bytes   466,493 bytes   02:06:10.979
50              2:06:17.319     0:03:57.153     25,024 kbps     41,520 kbps     02:06:18.320    30,375 kbps     02:06:17.778    28,448 kbps     02:06:17.945    130,461 bytes   649,292 bytes   02:06:19.321
51              2:10:14.473     0:00:49.215     24,007 kbps     35,181 kbps     02:10:21.813    30,089 kbps     02:10:53.845    27,266 kbps     02:10:49.299    125,159 bytes   434,165 bytes   02:10:46.630
52              2:11:03.688     0:04:44.450     22,417 kbps     35,044 kbps     02:11:08.318    29,159 kbps     02:11:07.567    26,306 kbps     02:11:07.567    116,887 bytes   486,253 bytes   02:14:05.036
post #769 of 5106 Old 11-16-2009, 07:44 PM - Thread Starter
[UK] Spider-Man 3 (Additional Details)
Studio: Sony
EAN: 5050629650075 (Trilogy Box) / 5050629495416 (Stand-Alone)
There are two DD 2.0 commentary tracks (each with English and Dutch subs) along with a DD 5.1 descriptive audio track to supplement the main audio and dubs.
Code:
        Total   Video
[UK] Spider-Man 3                                               AVC     2:19:11 44,073,861,120  48,019,355,309  42.22   26.06   LPCM 5.1 4608Kbps (48kHz/16-bit)          Dolby TrueHD 5.1 3424Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     SPIDER_MAN_3
Disc Size:      48,019,355,309 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:19:11 (h:m:s)
Total Bitrate:          42.22 Mbps
VIDEO:
MPEG-4 AVC Video        26060 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3424 kbps       5.1 / 48 kHz / 3424 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -1dB)
Dolby Digital Audio             Hungarian       640 kbps        5.1 / 48 kHz / 640 kbps / DN -1dB
Dolby Digital Audio             Polish          640 kbps        5.1 / 48 kHz / 640 kbps / DN -3dB
SUBTITLES:
Presentation Graphics           English         19.762 kbps
Presentation Graphics           English         16.921 kbps
Presentation Graphics           English         59.509 kbps
Presentation Graphics           English         61.427 kbps
Presentation Graphics           Arabic          10.517 kbps
Presentation Graphics           Bulgarian       17.186 kbps
Presentation Graphics           Croatian        18.347 kbps
Presentation Graphics           Czech           17.303 kbps
Presentation Graphics           Danish          18.246 kbps
Presentation Graphics           Dutch           18.494 kbps
Presentation Graphics           Dutch           50.658 kbps
Presentation Graphics           Dutch           49.839 kbps
Presentation Graphics           Estonian        17.555 kbps
Presentation Graphics           Finnish         17.643 kbps
Presentation Graphics           Greek           19.348 kbps
Presentation Graphics           Hebrew          15.405 kbps
Presentation Graphics           Hindi           18.498 kbps
Presentation Graphics           Hungarian       16.757 kbps
Presentation Graphics           Icelandic       18.835 kbps
Presentation Graphics           Lithuanian      18.599 kbps
Presentation Graphics           Norwegian       16.226 kbps
Presentation Graphics           Polish          16.553 kbps
Presentation Graphics           Romanian        20.184 kbps
Presentation Graphics           Slovenian       16.863 kbps
Presentation Graphics           Swedish         18.907 kbps
Presentation Graphics           Turkish         20.587 kbps
FILES:
00011.M2TS      0:00:00.000     2:19:11.301     44,073,861,120  42,220
CHAPTERS:
1               0:00:00.000     0:03:11.524     26,519 kbps     51,688 kbps     00:00:23.898    32,766 kbps     00:00:34.826    32,051 kbps     00:00:34.617    138,227 bytes   650,706 bytes   00:00:17.308
2               0:03:11.524     0:01:28.213     27,195 kbps     35,937 kbps     00:03:16.154    29,874 kbps     00:03:15.820    28,941 kbps     00:03:11.774    141,782 bytes   499,400 bytes   00:04:39.737
3               0:04:39.737     0:03:20.033     25,995 kbps     35,620 kbps     00:07:28.573    28,483 kbps     00:07:28.573    27,470 kbps     00:07:21.232    135,525 bytes   557,557 bytes   00:04:45.535
4               0:07:59.770     0:00:33.908     26,901 kbps     31,828 kbps     00:08:08.070    27,985 kbps     00:08:12.909    27,266 kbps     00:08:21.375    140,248 bytes   480,633 bytes   00:08:13.117
5               0:08:33.679     0:01:56.574     25,696 kbps     34,602 kbps     00:09:37.702    28,714 kbps     00:09:35.908    27,399 kbps     00:09:30.945    133,967 bytes   675,171 bytes   00:10:28.753
6               0:10:30.254     0:03:24.454     25,684 kbps     38,867 kbps     00:10:49.607    29,371 kbps     00:10:49.357    27,426 kbps     00:10:49.357    133,905 bytes   499,806 bytes   00:11:02.119
7               0:13:54.708     0:03:00.305     26,683 kbps     31,283 kbps     00:14:14.520    28,376 kbps     00:14:34.999    28,033 kbps     00:14:32.955    139,112 bytes   516,501 bytes   00:14:03.092
8               0:16:55.013     0:05:29.287     25,666 kbps     43,636 kbps     00:18:58.345    30,044 kbps     00:20:13.587    28,988 kbps     00:20:13.170    133,809 bytes   566,868 bytes   00:21:43.176
9               0:22:24.301     0:02:20.640     26,319 kbps     42,111 kbps     00:24:12.159    32,757 kbps     00:24:12.242    30,749 kbps     00:22:40.650    137,216 bytes   681,485 bytes   00:24:44.941
10              0:24:44.941     0:02:26.604     25,031 kbps     37,606 kbps     00:24:44.941    27,519 kbps     00:24:44.941    25,974 kbps     00:24:44.941    130,501 bytes   649,035 bytes   00:24:45.650
11              0:27:11.546     0:03:01.097     27,544 kbps     37,104 kbps     00:27:33.193    32,958 kbps     00:27:29.606    31,562 kbps     00:27:24.559    143,601 bytes   577,528 bytes   00:29:34.564
12              0:30:12.644     0:02:18.596     25,563 kbps     31,471 kbps     00:31:41.608    27,316 kbps     00:32:14.974    27,075 kbps     00:32:09.886    133,276 bytes   503,252 bytes   00:30:24.948
13              0:32:31.240     0:03:39.093     26,156 kbps     38,096 kbps     00:35:21.786    30,436 kbps     00:35:18.991    28,961 kbps     00:35:59.699    136,365 bytes   586,034 bytes   00:35:19.033
14              0:36:10.334     0:03:33.630     25,439 kbps     34,555 kbps     00:37:45.179    28,296 kbps     00:36:35.860    27,993 kbps     00:36:29.896    132,629 bytes   560,439 bytes   00:36:13.045
15              0:39:43.964     0:00:24.524     28,351 kbps     35,611 kbps     00:39:48.928    31,270 kbps     00:39:44.673    30,241 kbps     00:39:43.964    147,810 bytes   569,932 bytes   00:40:08.489
16              0:40:08.489     0:01:34.719     24,245 kbps     33,372 kbps     00:40:10.116    27,539 kbps     00:40:08.489    26,530 kbps     00:40:26.757    126,404 bytes   526,310 bytes   00:40:10.950
17              0:41:43.209     0:01:36.805     24,366 kbps     34,379 kbps     00:43:05.165    28,129 kbps     00:42:59.577    27,303 kbps     00:42:56.240    127,031 bytes   504,965 bytes   00:43:06.125
18              0:43:20.014     0:01:23.458     27,878 kbps     35,456 kbps     00:44:15.944    31,654 kbps     00:43:28.856    30,569 kbps     00:43:26.687    145,346 bytes   567,923 bytes   00:44:41.303
19              0:44:43.472     0:01:55.532     27,777 kbps     36,817 kbps     00:44:59.697    33,535 kbps     00:44:59.738    31,783 kbps     00:44:54.817    144,816 bytes   562,905 bytes   00:45:42.698
20              0:46:39.004     0:02:45.540     28,051 kbps     44,102 kbps     00:48:35.245    33,455 kbps     00:48:16.643    32,009 kbps     00:48:27.988    146,245 bytes   613,266 bytes   00:47:52.870
21              0:49:24.544     0:02:28.606     27,083 kbps     39,058 kbps     00:51:31.338    32,314 kbps     00:50:41.037    31,541 kbps     00:50:36.533    141,197 bytes   568,440 bytes   00:51:49.439
22              0:51:53.151     0:07:34.579     25,216 kbps     39,066 kbps     00:58:41.351    33,496 kbps     00:59:12.507    31,954 kbps     00:59:10.880    131,463 bytes   555,780 bytes   00:58:58.785
23              0:59:27.730     0:04:02.742     27,420 kbps     38,952 kbps     01:00:14.611    31,983 kbps     01:00:24.287    30,903 kbps     01:00:31.085    142,957 bytes   581,976 bytes   01:01:52.959
24              1:03:30.473     0:03:04.058     25,893 kbps     52,033 kbps     01:04:41.460    31,417 kbps     01:04:29.824    30,114 kbps     01:05:26.339    134,993 bytes   631,295 bytes   01:04:45.423
25              1:06:34.532     0:01:32.884     26,164 kbps     39,414 kbps     01:07:47.813    31,049 kbps     01:07:32.006    30,212 kbps     01:07:27.460    136,406 bytes   625,320 bytes   01:07:46.604
26              1:08:07.416     0:02:38.408     25,196 kbps     47,413 kbps     01:10:26.430    33,451 kbps     01:10:22.635    30,896 kbps     01:10:22.968    131,362 bytes   590,904 bytes   01:10:26.555
27              1:10:45.824     0:03:04.767     25,777 kbps     41,632 kbps     01:12:14.538    28,376 kbps     01:12:51.909    28,213 kbps     01:12:52.701    134,390 bytes   513,145 bytes   01:11:05.594
28              1:13:50.592     0:01:32.801     27,186 kbps     35,752 kbps     01:14:33.177    29,685 kbps     01:14:33.177    29,006 kbps     01:14:11.989    141,736 bytes   616,108 bytes   01:14:33.218
29              1:15:23.393     0:01:18.870     25,894 kbps     33,859 kbps     01:16:20.576    28,160 kbps     01:16:07.854    27,028 kbps     01:16:06.728    134,999 bytes   463,074 bytes   01:16:24.037
30              1:16:42.264     0:02:39.450     25,948 kbps     34,465 kbps     01:16:56.361    29,372 kbps     01:16:42.264    28,324 kbps     01:17:41.239    135,281 bytes   469,961 bytes   01:19:07.075
31              1:19:21.715     0:02:54.966     25,662 kbps     38,184 kbps     01:19:33.059    29,136 kbps     01:19:22.549    27,795 kbps     01:20:19.731    133,788 bytes   554,670 bytes   01:21:33.972
32              1:22:16.681     0:02:04.666     26,778 kbps     34,686 kbps     01:22:23.813    29,140 kbps     01:22:23.313    28,257 kbps     01:22:18.183    139,606 bytes   633,560 bytes   01:24:00.702
33              1:24:21.347     0:02:47.000     25,202 kbps     32,950 kbps     01:24:23.058    28,429 kbps     01:24:21.347    26,703 kbps     01:24:21.347    131,392 bytes   533,196 bytes   01:24:21.431
34              1:27:08.348     0:03:09.439     25,834 kbps     47,038 kbps     01:29:18.603    30,929 kbps     01:29:16.434    30,018 kbps     01:29:16.142    134,685 bytes   720,844 bytes   01:27:08.431
35              1:30:17.787     0:02:25.687     26,440 kbps     40,856 kbps     01:30:18.204    32,096 kbps     01:30:18.204    29,683 kbps     01:30:18.162    137,847 bytes   511,391 bytes   01:31:53.090
36              1:32:43.474     0:02:30.900     26,929 kbps     37,470 kbps     01:34:02.553    30,550 kbps     01:34:02.470    30,100 kbps     01:34:02.553    140,394 bytes   580,334 bytes   01:34:54.563
37              1:35:14.375     0:00:39.122     25,683 kbps     38,203 kbps     01:35:24.427    30,566 kbps     01:35:22.883    28,587 kbps     01:35:18.129    133,897 bytes   477,942 bytes   01:35:53.372
38              1:35:53.497     0:04:52.834     26,129 kbps     41,179 kbps     01:38:55.512    29,162 kbps     01:38:00.749    28,638 kbps     01:37:56.078    136,226 bytes   491,536 bytes   01:36:01.714
39              1:40:46.331     0:03:29.292     26,109 kbps     44,304 kbps     01:41:03.682    33,009 kbps     01:41:03.515    31,128 kbps     01:41:12.608    136,123 bytes   607,642 bytes   01:42:23.220
40              1:44:15.624     0:03:04.601     27,138 kbps     35,250 kbps     01:44:57.124    30,025 kbps     01:45:08.468    29,520 kbps     01:45:03.463    141,485 bytes   516,708 bytes   01:47:20.225
41              1:47:20.225     0:01:50.568     25,811 kbps     39,218 kbps     01:49:09.668    29,760 kbps     01:49:05.664    28,775 kbps     01:49:00.659    134,566 bytes   524,857 bytes   01:49:09.709
42              1:49:10.794     0:03:41.930     25,794 kbps     39,372 kbps     01:50:45.221    32,810 kbps     01:50:28.747    32,249 kbps     01:50:27.996    134,479 bytes   580,049 bytes   01:51:43.363
43              1:52:52.724     0:03:41.846     25,670 kbps     38,225 kbps     01:53:12.160    30,217 kbps     01:53:35.141    29,430 kbps     01:53:03.151    133,831 bytes   547,658 bytes   01:52:56.352
44              1:56:34.570     0:03:22.535     26,256 kbps     41,131 kbps     01:58:05.620    32,915 kbps     01:56:45.832    31,799 kbps     01:56:37.907    136,886 bytes   618,421 bytes   01:58:43.199
45              1:59:57.106     0:00:31.239     25,605 kbps     33,990 kbps     02:00:13.748    28,172 kbps     02:00:12.997    26,854 kbps     02:00:09.744    133,494 bytes   431,463 bytes   02:00:19.462
46              2:00:28.346     0:01:58.409     26,679 kbps     48,000 kbps     02:01:37.832    32,604 kbps     02:02:05.735    29,628 kbps     02:01:32.243    139,093 bytes   558,079 bytes   02:01:38.332
47              2:02:26.756     0:02:02.622     24,960 kbps     37,846 kbps     02:03:52.508    33,124 kbps     02:04:24.373    31,420 kbps     02:04:18.993    130,128 bytes   518,088 bytes   02:04:19.034
48              2:04:29.378     0:01:41.935     27,245 kbps     49,424 kbps     02:04:38.220    33,104 kbps     02:04:47.229    32,200 kbps     02:04:47.229    142,043 bytes   538,688 bytes   02:04:33.674
49              2:06:11.313     0:03:22.160     27,226 kbps     35,617 kbps     02:09:17.791    31,035 kbps     02:07:21.675    30,443 kbps     02:07:37.608    141,942 bytes   580,675 bytes   02:08:30.160
50              2:09:33.474     0:02:23.017     27,033 kbps     37,444 kbps     02:11:04.523    32,023 kbps     02:11:02.855    30,643 kbps     02:11:02.855    140,937 bytes   563,551 bytes   02:11:11.405
51              2:11:56.491     0:02:02.705     26,464 kbps     49,580 kbps     02:11:58.952    30,789 kbps     02:11:59.202    30,412 kbps     02:11:58.952    137,972 bytes   696,299 bytes   02:11:59.828
52              2:13:59.197     0:05:12.103     22,948 kbps     38,327 kbps     02:16:49.618    32,954 kbps     02:16:48.950    31,458 kbps     02:16:48.950    119,673 bytes   702,393 bytes   02:16:58.168
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     8351.218                26,060                  27,204,603,108  147,968,591
00011.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           8351.218                4,614                   4,817,032,724   26,724,176
00011.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           8351.218                4,064                   4,242,153,866   28,630,914
00011.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           8351.218                640                     668,106,240     3,914,685
00011.M2TS      4355 (0x1103)   0x81            AC3             ces (Czech)             8351.218                640                     668,106,240     3,914,685
00011.M2TS      4356 (0x1104)   0x81            AC3             hun (Hungarian)         8351.218                640                     668,106,240     3,914,685
00011.M2TS      4357 (0x1105)   0x81            AC3             rus (Russian)           8351.218                640                     668,106,240     3,914,685
00011.M2TS      4358 (0x1106)   0x81            AC3             pol (Polish)            8351.218                640                     668,106,240     3,914,685
00011.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           8351.218                192                     200,431,872     1,304,895
00011.M2TS      4360 (0x1108)   0x81            AC3             eng (English)           8351.218                192                     200,431,872     1,304,895
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8351.218                20                      20,629,523      119,438
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8351.218                17                      17,664,411      105,362
00011.M2TS      4610 (0x1202)   0x90            PGS             ara (Arabic)            8351.218                11                      10,978,866      67,139
00011.M2TS      4611 (0x1203)   0x90            PGS             bul (Bulgarian)         8351.218                17                      17,941,187      104,265
00011.M2TS      4612 (0x1204)   0x90            PGS             hrv (Croatian)          8351.218                18                      19,152,286      111,576
00011.M2TS      4613 (0x1205)   0x90            PGS             ces (Czech)             8351.218                17                      18,063,189      105,537
00011.M2TS      4614 (0x1206)   0x90            PGS             dan (Danish)            8351.218                18                      19,047,743      109,773
00011.M2TS      4615 (0x1207)   0x90            PGS             nld (Dutch)             8351.218                18                      19,306,642      110,516
00011.M2TS      4616 (0x1208)   0x90            PGS             est (Estonian)          8351.218                18                      18,325,393      104,901
00011.M2TS      4617 (0x1209)   0x90            PGS             fin (Finnish)           8351.218                18                      18,417,644      107,577
00011.M2TS      4618 (0x120A)   0x90            PGS             ell (Greek)             8351.218                19                      20,197,672      117,172
00011.M2TS      4619 (0x120B)   0x90            PGS             heb (Hebrew)            8351.218                15                      16,081,711      95,306
00011.M2TS      4620 (0x120C)   0x90            PGS             hin (Hindi)             8351.218                18                      19,310,461      112,463
00011.M2TS      4621 (0x120D)   0x90            PGS             hun (Hungarian)         8351.218                17                      17,493,086      102,455
00011.M2TS      4622 (0x120E)   0x90            PGS             isl (Icelandic)         8351.218                19                      19,661,745      113,504
00011.M2TS      4623 (0x120F)   0x90            PGS             lit (Lithuanian)        8351.218                19                      19,415,237      113,277
00011.M2TS      4624 (0x1210)   0x90            PGS             nor (Norwegian)         8351.218                16                      16,938,665      98,571
00011.M2TS      4625 (0x1211)   0x90            PGS             pol (Polish)            8351.218                17                      17,279,454      101,388
00011.M2TS      4626 (0x1212)   0x90            PGS             ron (Romanian)          8351.218                20                      21,070,368      121,197
00011.M2TS      4627 (0x1213)   0x90            PGS             slv (Slovenian)         8351.218                17                      17,603,249      103,132
00011.M2TS      4628 (0x1214)   0x90            PGS             swe (Swedish)           8351.218                19                      19,737,432      113,473
00011.M2TS      4629 (0x1215)   0x90            PGS             tur (Turkish)           8351.218                21                      21,490,814      124,181
00011.M2TS      4630 (0x1216)   0x90            PGS             eng (English)           8351.218                60                      62,122,332      352,791
00011.M2TS      4631 (0x1217)   0x90            PGS             eng (English)           8351.218                61                      64,124,127      362,536
00011.M2TS      4632 (0x1218)   0x90            PGS             nld (Dutch)             8351.218                51                      52,882,749      302,103
00011.M2TS      4633 (0x1219)   0x90            PGS             nld (Dutch)             8351.218                50                      52,027,957      296,166
00011.M2TS      4634 (0x121A)   0x90            PGS             rus (Russian)           8351.218                0                       70              7
Disc 2: Extras
Code:
Disc Size:      24,016,791,523 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
EDIT: One more thing, the barcode of this trilogy boxset edition of SM3 matches the stand-alone version EAN so should be identical. SM1 & 2 do not have barcodes and in the place where it would be says "NOT FOR INDIVIDUAL RESALE - PART OF PACK". I have no idea why Sony hasn't issued these individually by now (over two years after the boxset release), but 1 & 2 have zero features other than previews for Ghost Rider, Spider-Man 3 and Surf's Up so perhaps it's a matter of putting together a non-embarassing supplements package for these.
post #770 of 5106 Old 11-16-2009, 08:14 PM - Thread Starter
Originally Posted by benes View Post
This one was upconverted from a 16bit master and encoded at 24bit, according to paidgeek way back when.
Thanks for the clarification, benes. I do see now that Patsfan123 did an analyze on the US disc and saw the same thing I did on the UK edition:
https://www.avsforum.com/avs-vb/showp...&postcount=634
post #771 of 5106 Old 11-16-2009, 08:27 PM - Thread Starter
[US] Near Dark (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Lionsgate
Release Date: 2009-11-10
UPC: 012236106517
DTS-MA 5.1 and LPCM 2.0 are main audio, while the DD 2.0 track is a commentary by writer/director Kathryn Bigelow.
Code:
        Total   Video
[US] Near Dark                                                  AVC     1:34:13 19,473,048,000  22,724,222,780  27.56   21.97   DTS-HD Master 5.1 1548Kbps (48kHz/16-bit) LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     Near Dark
Disc Size:      22,724,222,780 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:34:13 (h:m:s)
Total Bitrate:          27.56 Mbps
VIDEO:
MPEG-4 AVC Video        21974 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1548 kbps       5.1 / 48 kHz / 1548 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 16-bit)
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         25.156 kbps
Presentation Graphics           English         32.738 kbps
Presentation Graphics           Spanish         25.305 kbps
FILES:
00000.M2TS      0:00:00.000     1:34:13.272     19,473,048,000  27,556
CHAPTERS:
1               0:00:00.000     0:12:43.012     20,538 kbps     42,264 kbps     00:09:31.862    30,041 kbps     00:09:31.529    27,016 kbps     00:09:31.529    107,070 bytes   370,644 bytes   00:00:46.421
2               0:12:43.012     0:07:35.371     22,481 kbps     43,865 kbps     00:13:30.643    38,425 kbps     00:13:30.017    35,401 kbps     00:13:29.642    117,208 bytes   396,835 bytes   00:13:35.981
3               0:20:18.383     0:09:06.963     22,339 kbps     43,595 kbps     00:26:43.435    40,598 kbps     00:26:41.933    35,504 kbps     00:20:18.383    116,466 bytes   367,794 bytes   00:29:25.305
4               0:29:25.346     0:10:33.841     20,819 kbps     44,587 kbps     00:30:45.718    36,402 kbps     00:30:45.385    32,228 kbps     00:30:41.714    108,539 bytes   363,924 bytes   00:31:48.948
5               0:39:59.188     0:12:38.883     22,619 kbps     42,052 kbps     00:45:25.055    31,175 kbps     00:52:03.662    29,266 kbps     00:48:46.798    117,925 bytes   375,214 bytes   00:52:17.050
6               0:52:38.071     0:08:52.782     23,785 kbps     45,161 kbps     00:59:52.755    35,784 kbps     01:00:55.735    33,715 kbps     00:59:51.838    124,004 bytes   389,619 bytes   00:59:22.058
7               1:01:30.853     0:03:43.223     22,823 kbps     41,282 kbps     01:02:04.303    33,935 kbps     01:02:03.052    30,862 kbps     01:01:57.880    118,988 bytes   368,616 bytes   01:02:30.455
8               1:05:14.076     0:06:32.934     24,654 kbps     44,814 kbps     01:07:28.252    36,332 kbps     01:07:24.665    33,858 kbps     01:10:23.802    128,535 bytes   417,210 bytes   01:07:29.253
9               1:11:47.011     0:06:47.156     20,879 kbps     38,902 kbps     01:13:34.827    27,513 kbps     01:16:31.795    26,305 kbps     01:16:31.837    108,852 bytes   376,813 bytes   01:13:59.309
10              1:18:34.167     0:05:33.624     22,721 kbps     44,637 kbps     01:20:16.937    35,028 kbps     01:23:07.774    32,491 kbps     01:22:48.672    118,456 bytes   396,140 bytes   01:23:26.960
11              1:24:07.792     0:06:44.237     25,107 kbps     44,275 kbps     01:27:44.300    36,926 kbps     01:29:03.629    33,317 kbps     01:28:55.747    130,894 bytes   390,784 bytes   01:28:33.891
12              1:30:52.029     0:03:21.242     10,197 kbps     18,072 kbps     01:33:34.609    15,866 kbps     01:33:33.274    14,553 kbps     01:33:30.813    53,182 bytes    259,731 bytes   01:33:35.151
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5653.189                21,974                  15,528,016,501  84,471,995
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5653.189                1,548                   1,093,703,904   6,490,092
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           5653.189                2,310                   1,632,665,820   9,045,240
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5653.189                193                     136,382,976     887,910
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5653.189                25                      17,776,710      101,758
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5653.189                33                      23,134,650      132,364
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           5653.189                25                      17,882,210      102,401
post #772 of 5106 Old 11-16-2009, 08:31 PM - Thread Starter
[US] Wild Things (Additional Details)
Studio: Sony
Release Date: 2007-07-17
UPC: 043396208704
Code:
        Total   Video
[US] Wild Things: Unrated                                       AVC     1:54:46 23,963,510,784  24,455,261,408  27.84   20.40   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     WILDTHING
Disc Size:      24,455,261,408 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:54:46 (h:m:s)
Total Bitrate:          27.84 Mbps
VIDEO:
MPEG-4 AVC Video        20395 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         28.206 kbps
Presentation Graphics           English         21.904 kbps
Presentation Graphics           Arabic          14.133 kbps
Presentation Graphics           Dutch           22.309 kbps
Presentation Graphics           French          27.062 kbps
FILES:
00001.M2TS      0:00:00.000     1:54:46.880     23,963,510,784  27,837
CHAPTERS:
1               0:00:00.000     0:03:55.318     20,667 kbps     42,788 kbps     00:01:21.289    33,549 kbps     00:01:20.789    32,159 kbps     00:01:21.206    107,727 bytes   505,944 bytes   00:01:45.230
2               0:03:55.318     0:09:39.704     20,746 kbps     39,674 kbps     00:09:23.187    32,055 kbps     00:09:23.229    31,429 kbps     00:09:23.187    108,163 bytes   669,286 bytes   00:11:38.030
3               0:13:35.022     0:06:11.329     20,019 kbps     36,716 kbps     00:17:41.143    31,431 kbps     00:17:34.386    30,712 kbps     00:17:32.134    104,369 bytes   565,500 bytes   00:14:33.622
4               0:19:46.351     0:06:22.298     20,103 kbps     28,742 kbps     00:24:15.704    24,498 kbps     00:22:46.907    23,885 kbps     00:22:42.402    104,810 bytes   525,846 bytes   00:25:54.886
5               0:26:08.650     0:06:25.134     18,878 kbps     32,084 kbps     00:29:27.849    26,784 kbps     00:29:14.210    25,733 kbps     00:29:11.124    98,423 bytes    557,301 bytes   00:29:11.207
6               0:32:33.785     0:08:19.540     19,731 kbps     36,845 kbps     00:35:05.603    27,635 kbps     00:39:23.652    26,977 kbps     00:39:25.154    102,867 bytes   583,936 bytes   00:34:48.878
7               0:40:53.325     0:10:40.973     19,761 kbps     35,312 kbps     00:47:20.212    30,376 kbps     00:47:20.170    27,870 kbps     00:50:27.441    103,023 bytes   744,374 bytes   00:50:27.482
8               0:51:34.299     0:08:25.671     22,483 kbps     42,215 kbps     00:56:01.983    34,758 kbps     00:58:53.321    33,164 kbps     00:55:55.310    117,217 bytes   581,157 bytes   00:57:52.260
9               0:59:59.971     0:06:33.393     22,590 kbps     37,319 kbps     01:00:05.351    34,106 kbps     01:01:25.682    32,890 kbps     01:01:23.262    117,772 bytes   758,119 bytes   01:00:05.393
10              1:06:33.364     0:07:05.591     21,838 kbps     38,781 kbps     01:07:30.379    35,860 kbps     01:09:48.601    33,387 kbps     01:09:46.932    113,853 bytes   553,493 bytes   01:07:30.421
11              1:13:38.956     0:06:30.348     18,318 kbps     45,993 kbps     01:15:30.984    32,230 kbps     01:15:30.651    28,460 kbps     01:15:29.483    95,503 bytes    749,974 bytes   01:17:47.079
12              1:20:09.304     0:08:11.949     20,929 kbps     36,007 kbps     01:26:03.283    32,572 kbps     01:26:03.199    31,439 kbps     01:26:03.158    109,113 bytes   582,434 bytes   01:21:37.183
13              1:28:21.254     0:03:27.582     20,571 kbps     30,519 kbps     01:31:47.835    24,081 kbps     01:29:46.923    23,204 kbps     01:30:39.434    107,247 bytes   518,143 bytes   01:29:33.618
14              1:31:48.836     0:02:56.092     21,255 kbps     37,528 kbps     01:32:19.367    30,932 kbps     01:32:15.738    28,773 kbps     01:32:11.067    110,815 bytes   497,655 bytes   01:32:20.284
15              1:34:44.929     0:07:24.861     20,413 kbps     37,583 kbps     01:37:13.494    28,760 kbps     01:35:00.403    28,023 kbps     01:34:55.398    106,424 bytes   441,614 bytes   01:34:53.354
16              1:42:09.790     0:12:37.089     19,243 kbps     39,707 kbps     01:42:11.667    34,012 kbps     01:45:51.678    31,942 kbps     01:45:46.673    100,334 bytes   704,333 bytes   01:42:11.792
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     6886.797                20,396                  17,557,587,280  95,518,542
00001.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6886.797                640                     550,950,400     3,228,225
00001.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6886.797                4,614                   3,972,352,384   22,038,016
00001.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6886.797                640                     550,950,400     3,228,225
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6886.797                28                      24,281,545      139,408
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6886.797                22                      18,855,939      110,856
00001.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6886.797                27                      23,296,658      133,890
00001.M2TS      4611 (0x1203)   0x90            PGS             nld (Dutch)             6886.797                22                      19,205,060      109,871
00001.M2TS      4612 (0x1204)   0x90            PGS             ara (Arabic)            6886.797                14                      12,166,595      72,187
post #773 of 5106 Old 11-16-2009, 08:36 PM - Thread Starter
[US] Forrest Gump (Additional Details)
Studio: Paramount
Release Date: 2009-11-03
UPC: 097360715941
Aspect Ratio: 2.35:1
The two DD 2.0 tracks are commentaries.
Code:
        Total   Video
[US] Forrest Gump                                               AVC     2:22:09 36,673,142,784  42,375,583,809  34.40   26.56   DTS-HD Master 5.1 4094Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     FORREST_GUMP_D1_AC
Disc Size:      42,375,583,809 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:22:09 (h:m:s)
Total Bitrate:          34.40 Mbps
VIDEO:
MPEG-4 AVC Video        26560 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4094 kbps       5.1 / 48 kHz / 4094 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit / DN -4dB)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         35.858 kbps
Presentation Graphics           English         37.408 kbps
Presentation Graphics           French          31.159 kbps
Presentation Graphics           Portuguese      29.825 kbps
Presentation Graphics           Spanish         28.739 kbps
FILES:
00004.M2TS      0:00:00.000     2:22:09.395     36,673,142,784  34,397
CHAPTERS:
1               0:00:00.000     0:06:43.569     26,263 kbps     35,789 kbps     00:05:26.659    34,738 kbps     00:05:26.659    33,354 kbps     00:05:56.356    136,908 bytes   351,828 bytes   00:03:21.743
2               0:06:43.569     0:05:41.007     25,941 kbps     32,841 kbps     00:07:10.304    32,387 kbps     00:07:01.421    31,983 kbps     00:07:01.421    135,247 bytes   377,446 bytes   00:07:01.587
3               0:12:24.577     0:07:32.368     26,896 kbps     37,538 kbps     00:18:53.757    35,675 kbps     00:18:51.713    35,463 kbps     00:19:07.729    140,226 bytes   503,367 bytes   00:18:56.718
4               0:19:56.945     0:11:16.759     26,738 kbps     36,797 kbps     00:21:55.605    35,428 kbps     00:22:07.993    34,666 kbps     00:21:48.682    139,397 bytes   414,839 bytes   00:29:28.683
5               0:31:13.705     0:09:26.482     25,929 kbps     35,433 kbps     00:38:00.319    33,818 kbps     00:37:54.480    33,148 kbps     00:37:53.062    135,183 bytes   300,492 bytes   00:31:26.593
6               0:40:40.187     0:03:37.926     25,358 kbps     35,436 kbps     00:43:25.853    34,704 kbps     00:40:59.415    34,378 kbps     00:40:58.330    132,203 bytes   330,397 bytes   00:41:51.175
7               0:44:18.113     0:12:16.360     27,731 kbps     38,171 kbps     00:52:15.382    35,637 kbps     00:55:17.063    35,359 kbps     00:49:19.748    144,579 bytes   446,447 bytes   00:51:14.988
8               0:56:34.474     0:06:57.792     25,944 kbps     37,024 kbps     01:02:26.159    34,937 kbps     00:58:11.696    34,405 kbps     00:58:07.609    135,260 bytes   313,937 bytes   01:03:32.266
9               1:03:32.266     0:10:01.809     26,471 kbps     35,958 kbps     01:04:06.801    34,177 kbps     01:04:03.464    32,157 kbps     01:09:35.796    138,007 bytes   394,617 bytes   01:06:30.069
10              1:13:34.076     0:03:28.750     26,184 kbps     34,885 kbps     01:16:21.118    32,739 kbps     01:16:18.699    32,340 kbps     01:16:14.361    136,509 bytes   294,500 bytes   01:14:13.407
11              1:17:02.826     0:06:49.450     24,678 kbps     36,245 kbps     01:21:28.300    35,409 kbps     01:21:20.959    35,340 kbps     01:21:17.330    128,660 bytes   278,791 bytes   01:21:29.593
12              1:23:52.277     0:11:07.667     27,932 kbps     36,780 kbps     01:32:16.948    35,560 kbps     01:26:55.335    35,369 kbps     01:24:14.924    145,626 bytes   435,932 bytes   01:27:55.687
13              1:34:59.944     0:03:55.652     25,886 kbps     37,501 kbps     01:36:20.649    34,299 kbps     01:38:14.805    33,349 kbps     01:38:12.303    134,956 bytes   360,358 bytes   01:36:23.152
14              1:38:55.596     0:04:57.296     27,130 kbps     33,704 kbps     01:42:38.569    31,540 kbps     01:42:34.565    31,074 kbps     01:39:30.923    141,443 bytes   359,046 bytes   01:42:39.027
15              1:43:52.893     0:07:35.413     25,950 kbps     36,097 kbps     01:48:11.735    35,329 kbps     01:48:05.270    34,919 kbps     01:48:04.269    135,291 bytes   415,172 bytes   01:44:49.908
16              1:51:28.306     0:07:26.404     26,688 kbps     35,751 kbps     01:54:44.085    35,398 kbps     01:54:44.085    34,619 kbps     01:54:11.386    139,139 bytes   380,456 bytes   01:52:33.288
17              1:58:54.710     0:05:53.853     26,982 kbps     32,643 kbps     02:00:46.989    31,107 kbps     02:00:42.568    30,765 kbps     02:00:38.522    140,671 bytes   328,046 bytes   02:03:50.798
18              2:04:48.564     0:10:36.636     27,545 kbps     36,686 kbps     02:14:55.337    35,670 kbps     02:15:07.182    35,411 kbps     02:15:01.426    143,609 bytes   726,068 bytes   02:15:22.656
19              2:15:25.200     0:06:44.195     25,299 kbps     48,389 kbps     02:22:05.058    35,379 kbps     02:20:03.812    35,267 kbps     02:19:58.807    131,910 bytes   413,989 bytes   02:22:05.600
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     8529.229                26,560                  28,317,271,327  154,017,475
00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           8529.229                4,094                   4,364,458,556   25,050,958
00004.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           8529.229                640                     682,352,640     3,998,160
00004.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            8529.229                640                     682,352,640     3,998,160
00004.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           8529.229                224                     238,823,424     1,332,720
00004.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           8529.229                224                     238,823,424     1,332,720
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8529.229                36                      38,231,148      218,032
00004.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            8529.229                31                      33,220,651      188,881
00004.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           8529.229                29                      30,640,736      174,898
00004.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        8529.229                30                      31,798,319      180,822
00004.M2TS      4612 (0x1204)   0x90            PGS             eng (English)           8529.229                37                      39,883,248      227,361
Disc 2: Extras
Code:
Disc Title:     FORREST_GUMP_D2_AC
Disc Size:      47,710,591,750 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
post #774 of 5106 Old 11-16-2009, 08:36 PM
Stephen Dawson's Avatar
Scream - 1996 - Australian version
Distributed by Icon Film Distribution Pty Ltd
Region Free, confirmed with AnyDVD HD (no 50 hertz material on disc)
Bare bones: only extra is English subtitles.
Code:
        Total   Video
00001.MPLS                                                      AVC     1:51:00 19,462,023,168  19,961,638,836  23.38   20.00   DTS-HD Master 5.1 2047Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     SCREAM
Disc Size:      19,961,638,836 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:51:00 (h:m:s)
Total Bitrate:          23.38 Mbps
VIDEO:
MPEG-4 AVC Video        19998 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2047 kbps       5.1 / 48 kHz / 2047 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         53.386 kbps
FILES:
00001.M2TS      0:00:00.000     1:51:00.654     19,462,023,168  23,376
CHAPTERS:
1               0:00:00.000     0:09:54.844     20,481 kbps     36,719 kbps     00:08:58.663    29,145 kbps     00:08:58.454    26,984 kbps     00:08:54.742    106,769 bytes   264,490 bytes   00:06:02.779
2               0:09:54.844     0:03:04.267     21,811 kbps     38,680 kbps     00:11:49.125    29,211 kbps     00:10:33.299    26,370 kbps     00:10:29.462    113,714 bytes   280,872 bytes   00:12:55.399
3               0:12:59.111     0:04:15.171     21,766 kbps     33,596 kbps     00:14:09.056    26,600 kbps     00:15:58.582    25,164 kbps     00:14:19.233    113,478 bytes   262,388 bytes   00:16:00.960
4               0:17:14.283     0:04:30.895     21,067 kbps     39,978 kbps     00:17:53.947    32,462 kbps     00:17:52.362    27,365 kbps     00:17:46.732    109,836 bytes   270,232 bytes   00:17:27.296
5               0:21:45.178     0:08:02.190     21,470 kbps     38,148 kbps     00:29:12.834    30,797 kbps     00:29:08.788    28,611 kbps     00:29:03.825    111,935 bytes   271,033 bytes   00:24:22.002
6               0:29:47.368     0:04:32.271     23,580 kbps     38,418 kbps     00:32:04.422    32,623 kbps     00:31:12.787    30,362 kbps     00:31:07.782    122,937 bytes   281,239 bytes   00:31:27.093
7               0:34:19.640     0:05:05.346     22,609 kbps     39,287 kbps     00:38:26.345    34,273 kbps     00:36:07.623    32,231 kbps     00:36:02.577    117,872 bytes   266,019 bytes   00:38:27.263
8               0:39:24.987     0:06:01.360     20,671 kbps     34,259 kbps     00:39:44.965    29,245 kbps     00:39:43.464    27,094 kbps     00:39:43.464    107,768 bytes   246,268 bytes   00:40:09.156
9               0:45:26.348     0:05:51.142     21,259 kbps     34,414 kbps     00:50:28.442    30,377 kbps     00:50:39.995    28,202 kbps     00:50:35.032    110,837 bytes   239,788 bytes   00:48:40.626
10              0:51:17.491     0:03:27.248     19,736 kbps     30,794 kbps     00:54:13.208    26,780 kbps     00:54:16.670    25,941 kbps     00:54:12.624    102,897 bytes   233,254 bytes   00:54:44.155
11              0:54:44.739     0:05:58.858     20,041 kbps     34,798 kbps     00:57:43.293    29,836 kbps     00:57:42.167    25,528 kbps     00:59:23.518    104,483 bytes   242,237 bytes   00:57:45.753
12              1:00:43.598     0:03:45.892     20,210 kbps     30,978 kbps     01:00:43.848    24,346 kbps     01:03:59.710    23,164 kbps     01:03:55.832    105,365 bytes   241,057 bytes   01:01:19.717
13              1:04:29.490     0:04:49.956     20,860 kbps     34,881 kbps     01:07:30.463    27,291 kbps     01:06:41.539    25,582 kbps     01:06:37.076    108,754 bytes   241,141 bytes   01:07:41.265
14              1:09:19.446     0:09:34.073     19,580 kbps     34,322 kbps     01:18:40.173    28,298 kbps     01:18:39.673    25,222 kbps     01:18:37.003    102,081 bytes   259,258 bytes   01:18:42.509
15              1:18:53.520     0:10:35.009     22,123 kbps     37,405 kbps     01:24:14.674    32,468 kbps     01:24:11.087    30,257 kbps     01:24:10.003    115,340 bytes   265,522 bytes   01:28:37.186
16              1:29:28.529     0:04:04.535     19,593 kbps     32,673 kbps     01:29:57.433    26,929 kbps     01:29:53.721    24,351 kbps     01:29:49.300    102,147 bytes   226,536 bytes   01:29:47.048
17              1:33:33.065     0:02:03.706     19,100 kbps     27,879 kbps     01:34:21.656    22,822 kbps     01:33:38.237    21,480 kbps     01:33:35.401    99,578 bytes    204,066 bytes   01:34:47.264
18              1:35:36.772     0:07:23.776     21,081 kbps     35,502 kbps     01:37:23.420    32,272 kbps     01:40:48.125    28,356 kbps     01:40:43.120    109,908 bytes   239,317 bytes   01:37:38.769
19              1:43:00.549     0:00:54.971     17,777 kbps     35,483 kbps     01:43:02.426    26,279 kbps     01:43:00.591    23,416 kbps     01:43:00.549    92,682 bytes    238,536 bytes   01:43:51.516
20              1:43:55.520     0:07:05.133     5,770 kbps      17,198 kbps     01:45:02.796    13,223 kbps     01:45:02.713    12,355 kbps     01:45:02.587    30,085 bytes    223,962 bytes   01:43:57.147
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     6660.571                19,998                  16,649,806,602  90,581,501
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6660.571                2,047                   1,704,295,940   10,303,971
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6660.571                53                      44,448,470      255,909
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #775 of 5106 Old 11-16-2009, 08:46 PM - Thread Starter
Cinema Squid's Avatar
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
A   [CA] 2001   15 Minutes                                                       AVC     1080p24 2.35:1  15.00   2:00:39 19,123,673,088  19,200,834,832  21.13   DTS-MA  5.1    48/24  4005  / AC3     5.1    48     448
ABC [--] 1992   AC/DC: Live at Donington                                        AVC     1080p24 1.78:1  29.98   1:58:05 37,330,151,424  45,186,096,671  42.15   LPCM    5.1    48/24  6912  / AC3     5.1    48     640   / LPCM    2.0    48/24  2304
ABC [UK] 1997   Air Force One                                                    AVC     1080p24 2.40:1  23.92   2:04:35 33,864,517,632  34,650,384,768  36.24   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
A   [US] 2009   Aliens in the Attic                                             AVC     1080p24 1.85:1  22.28   2:02:49 18,462,517,248  32,068,115,582  20.04   DTS-MA  5.1    48/24  3656
ABC [AU] 2001   Amelie                                                           AVC     1080p24*2.35:1  25.98   2:02:14 29,115,230,208  34,610,747,082  31.76   DTS-MA  5.1    48/24  4125
ABC [US] 2009   The Answer Man                                                   VC-1    1080p24 1.78:1  23.52   1:37:03 21,074,282,496  24,951,716,822  28.95   DTS-MA  5.1    48/24  3595
 B  [UK] 2006   Apocalypto                                                       AVC     1080p24 1.85:1  23.87   2:18:21 34,638,587,904  39,692,543,628  33.38   LPCM    5.1    48/24  6912  / AC3     5.1    48     640
ABC [US] 2008   Ballast                                                         AVC     1080p24 2.35:1  19.99   1:36:14 16,865,064,960  23,196,786,160  23.37   TrueHD  5.1    48/16  926
ABC [US] 2009   Battlestar Galactica: The Plan                                   VC-1    1080p24 1.78:1  30.99   1:51:22 30,804,099,072  41,495,648,963  36.88   DTS-MA  5.1    48/24  3718
ABC [US] 2003   The Blind Swordsman: Zatoichi                                    AVC     1080p24 1.85:1  36.69   1:56:06 38,201,985,024  44,755,421,574  43.87   AC3     5.1    48     640
ABC [US] 1968   Bullitt                                                          VC-1    1080p24 1.78:1  17.13   1:53:45 16,239,169,536  29,681,616,306  19.03   AC3     2.0    48     192
ABC [UK] 2008   Changeling                                                       VC-1    1080p24 2.40:1  22.57   2:21:54 35,870,060,544  40,139,796,497  33.70   DTS-MA  5.1    48/24  3440
ABC [US] 1951   A Christmas Carol                                               MPEG-2  1080p24 1.33:1  24.99   1:26:31 17,645,524,992  19,128,775,884  27.19   AC3     5.1    48     448   / AC3     2.0    48     192
ABC [US] 1997   Contact                                                          VC-1    1080p24 2.40:1  23.20   2:29:40 37,252,349,952  39,638,834,297  33.19   TrueHD  5.1    48/16  1457
AB  [DE] 1978   The Deer Hunter                                                 VC-1    1080p24 2.35:1  14.99   3:03:31 34,798,430,208  41,798,014,150  25.28   DTS-MA  5.1    48/16  2146  / DTS-MA  2.0    48/16  903
ABC [US] 1975   Dog Day Afternoon                                                VC-1    1080p24 1.85:1  17.98   2:04:39 18,723,514,368  22,828,079,584  20.03   AC3     1.0    48     192
ABC [US] 1969   Easy Rider                                                       AVC     1080p24 1.85:1  27.81   1:35:33 29,458,575,360  36,530,438,643  41.11   TrueHD  5.1    48/20  2464  / AC3     2.0    48     192
AB  [DE] 1980   The Elephant Man                                                AVC     1080p24*2.35:1  24.99   2:03:40 33,895,176,192  47,445,247,463  36.54   DTS-MA  5.1    48/16  1838
ABC [US] 2008   Eric Clapton and Steve Winwood: Live From Madison Square Garden  AVC     1080p24 1.78:1  24.89   2:19:06 31,565,420,544  43,819,221,252  30.26   DTS     5.1    48     1509  / LPCM    2.0    48/24  2304
ABC [US] 1999   Fight Club                                                      AVC     1080p24 2.40:1  23.45   2:19:08 34,166,661,120  46,278,055,124  32.74   DTS-MA  5.1    48/24  3266  / AC3     2.0    48     224
ABC [AU] 2006   Firewall                                                 VC-1    1080p24 2.40:1  13.72   1:44:52 13,430,900,736  15,004,427,546  17.08   AC3     5.1    48     640
ABC [UK] 2006   Flags of Our Fathers                                             VC-1    1080p24 2.40:1  18.70   2:11:53 28,482,220,032  41,211,330,866  28.80   LPCM    5.1    48/24  6912  / AC3     5.1    48     640
ABC [US] 2008   Food, Inc.                                                       VC-1    1080p24 1.78:1  22.07   1:33:44 19,130,898,432  24,328,934,602  27.21   DTS-MA  5.1    48/24  3552
A   [US] 1978   Force 10 from Navarone                                           AVC     1080p24 2.40:1  19.89   2:05:51 23,092,740,096  24,707,408,272  24.47   DTS-MA  5.1    48/24  2855  / AC3     2.0    48     224
ABC [US] 1994   Forrest Gump                                                     AVC     1080p24 2.35:1  26.56   2:22:09 36,673,142,784  42,375,583,809  34.40   DTS-MA  5.1    48/24  4094
 B  [AU] 2008   Four Christmases                                         VC-1    1080p24 1.85:1  19.00   1:28:31 15,732,639,744  20,301,884,568  23.70   TrueHD  5.1    48/16  1488  / AC3     5.1    48     640
ABC [US] 1926   The General                                                     AVC     1080p24 1.33:1  29.95   1:18:52 21,170,878,464  31,913,531,212  35.79   DTS-MA  5.1    48/16  1816  / LPCM    2.0    48/16  1536  / AC3     2.0    48     224
ABC [AU] 2004   Ghost in the Shell 2: Innocence                                  AVC     1080p24 1.85:1  27.89   1:39:53 28,376,619,456  35,382,384,904  37.88   DTS-MA  5.1    48/16  1821
 B  [AU] 2008   Ghost in the Shell 2.0                                           AVC     1080p24 1.78:1  22.90   1:23:07 22,825,662,912  40,804,998,956  36.62   DTS-MA  6.1    48/24  4134  / LPCM    2.0    48/16  1536
                                   Original Version                              AVC     1080p24 1.78:1  17.00   1:22:37 13,354,782,720                  21.55   LPCM    2.0    48/16  1536
ABC [AU] 2000   Gladiator: Extended (seamless)                                   AVC     1080p24 2.35:1  18.31   2:50:56 39,987,800,064  49,913,698,444  31.19   DTS-MA  5.1    48/24  4408
                           Theatrical (seamless)                         AVC     1080p24 2.35:1  18.17   2:34:58 36,127,475,712                  31.08   DTS-MA  5.1    48/24  4436
ABC [US] 1998   Godzilla                                                 AVC     1080p24 2.40:1  24.31   2:18:43 39,010,837,440  46,955,811,596  37.50   DTS-MA  5.1    48/24  3772
A   [US] 2008   Gomorrah                                                        AVC     1080p24 2.35:1  20.98   2:27:24 26,965,432,320  48,169,901,374  24.39   DTS-MA  5.1    48/24  3761
ABC [US] 1939   Gone with the Wind                                              VC-1    1080p24 1.37:1  18.39                           44,959,920,915          TrueHD  5.1    48/16  1251  / AC3     1.0    48     192
    [UK] 2005   Good Night, and Good Luck                                        AVC     1080p24 1.85:1  24.01   1:32:48 21,762,797,568  23,172,263,661  31.27   DTS-MA  5.1    48/24  3734
ABC [US] 1990   Hardware                                                 AVC     1080p24 1.85:1  23.99   1:33:53 18,404,370,432  42,981,054,123  26.14   AC3     5.1    48     448   / AC3     2.0    48     256
ABC [AU] 2009   Harry Potter and the Half-Blood Prince                           VC-1    1080p24 2.40:1  17.93   2:33:30 32,092,581,888  36,044,123,840  27.88   TrueHD  5.1    48/16  1523
ABC [US] 1992   Home Alone 2: Lost in New York                                   AVC     1080p24 1.85:1  18.64   2:00:01 22,034,847,744  22,799,164,805  24.48   DTS-MA  5.1    48/24  3707  / AC3     2.0    48     224
A   [US] 2009   Ice Age: Dawn of the Dinosaurs                                  AVC     1080p24 1.85:1  35.68   2:02:49 31,413,712,896  46,175,017,296  34.10   DTS-MA  7.1    48/24  4674
    [US] 2006   Inside Man                                                       VC-1    1080p24 2.35:1  30.83   2:08:43 41,773,694,976  44,854,314,991  43.27   DTS-MA  5.1    48/24  4124
ABC [UK] 2005   The Island                                                       VC-1    1080p24 2.40:1  17.42   2:15:59 23,163,469,824  24,281,435,860  22.71   AC3     5.1    48     640
ABC [DE] 2003   The Italian Job                                                  VC-1    1080p24 2.35:1  15.99   1:50:30 18,732,183,552  22,158,579,251  22.60   DTS-MA  5.1    48/16  2287
 BC [CZ] 2008   Jumper                                                          AVC     1080p24 2.35:1  28.13   1:28:21 26,122,788,864  42,400,978,866  39.42   DTS-MA  5.1    48/24  3860
ABC [AU] 2006   The Lake House                                                   VC-1    1080p24 2.40:1  14.41   1:38:33 13,160,515,584  13,750,881,640  17.81   AC3     5.1    48     640
ABC [US] 2009   Land of the Lost                                         AVC     1080p24 1.85:1  29.10   1:41:40 28,174,743,552  48,980,686,878  36.95   DTS-MA  5.1    48/24  3768
ABC [AU] 1962   The Longest Day                                                  AVC     1080p24 2.20:1  25.49   2:58:20 44,028,198,912  44,648,472,965  32.92   DTS-MA  5.1    48/24  3090
ABC [US] 2003   Love Actually                                                    VC-1    1080p24 2.35:1  29.48   2:14:49 40,993,763,328  44,070,966,924  40.54   DTS-MA  5.1    48/24  4128
ABC [UK] 2007   Mad Detective                                                    AVC     1080p24 2.35:1  18.91   1:29:24 20,723,392,512  24,517,540,436  30.91   DTS-MA  5.1    48/24  4218  / TrueHD  5.1    48/24  3826  / AC3     2.0    48     224
ABC [US] 2000   Memento                                                          MPEG-2  1080p24 2.35:1  17.54   1:53:26 21,143,543,808  24,127,704,986  24.85   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
AB  [DE] 1963   Le Mépris                                                       AVC     1080p24 2.35:1  31.58   1:43:15 29,169,106,944                  37.67   DTS-MA  2.0    48/16  933
ABC [US] 2001   Monsters, Inc.                                                   AVC     1080p24 1.85:1  24.12   1:32:15 21,977,174,016  39,068,603,530  31.76   DTS-MA  5.1-ES 48/24  4060
ABC [US] 1992   My Cousin Vinny                                                  AVC     1080p24 1.85:1  18.99   1:59:18 22,349,278,464  22,945,135,235  24.98   DTS-MA  5.1    48/24  3540  / AC3     2.0    48     224
A   [US] 2009   My Life in Ruins                                         AVC     1080p24 1.85:1  32.65   1:35:15 27,892,819,968  29,999,147,888  39.05   DTS-MA  5.1    48/24  3853
A   [US] 1990   Navy Seals                                                       MPEG-2  1080p24 1.85:1  17.82   1:53:35 20,128,776,192  21,930,639,430  23.63   DTS-MA  5.1    48/24  3729  / AC3     2.0    48     224
A   [US] 1987   Near Dark                                                        AVC     1080p24 1.85:1  21.97   1:34:13 19,473,048,000  22,724,222,780  27.56   DTS-MA  5.1    48/16  1548  / LPCM    2.0    48/24  2304
ABC [US] 2007   Next                                                             AVC     1080p24 2.35:1  31.93   1:36:10 30,727,809,024  39,473,700,963  42.60   LPCM    5.1    48/24  6912  / AC3     5.1    48     640
 B  [UK] 1993   The Nightmare Before Christmas                                   AVC     1080p24 1.66:1  29.25   1:16:39 26,567,491,584  45,792,699,296  46.21   TrueHD  7.1    48/24  4867  / AC3     5.1    48     640
ABC [AU] 2007   No Reservations                                                  VC-1    1080p24 2.40:1  17.53   1:44:18 17,818,447,872  22,434,959,812  22.78   AC3     5.1    48     640
ABC [US] 2009   Orphan                                                           VC-1    1080p24 1.78:1  19.43   2:02:55 23,565,361,152  25,904,634,661  25.56   TrueHD  5.1    48/16  1435
A   [US] 1965   Pierrot le Fou                                                   AVC     1080p24 2.35:1  29.99   1:50:19 28,021,315,584  48,268,916,216  33.87   LPCM    1.0    48/24  1152
A   [US] 1990   Predator 2                                                       AVC     1080p24 1.85:1  34.87   1:48:00 35,525,738,496  41,381,164,699  43.86   DTS-MA  5.1    48/24  4404  / AC3     2.0    48     224
A   [US] 2007   Rush Hour 3                                                      VC-1    1080p24 2.40:1  15.86   1:30:47 15,472,195,584  28,077,311,094  22.72   DTS-MA  7.1    48/24  5234
                             Secondary PiP Encode                                VC-1    1080p24 2.40:1  15.90   1:30:47 11,545,509,888                  16.96   DTS     2.0    48     255
A   [US] 1989   Say Anything...                                                  AVC     1080p24 1.85:1  26.57   1:40:20 24,000,135,168  35,522,009,508  31.89   DTS-MA  5.1    48/24  2489  / AC3     2.0    48     224
ABC [AU] 1996   Scream                                                           AVC     1080p24 2.35:1  20.00   1:51:00 19,462,023,168  19,961,638,836  23.38   DTS-MA  5.1    48/16  2047
A   [US] 2006   The Sentinel                                                     MPEG-2  1080p24 2.40:1  16.06   1:48:00 18,704,486,400  24,481,489,982  23.09   DTS-MA  5.1    48/24  4092
ABC [US] 1989   Sex, Lies, and Videotape                                        AVC     1080p24 1.85:1  27.73   1:39:59 29,131,259,904  33,201,395,680  38.85   TrueHD  5.1    96/16  5120
ABC [US] 2007   Shooter                                                          MPEG-2  1080p24 2.40:1  28.36   2:05:41 30,405,734,400  39,067,656,128  32.26   AC3     5.1    48     640
ABC [UK] 2000   Snatch                                                           AVC     1080p24 1.85:1  29.96   1:42:46 31,774,138,368  39,400,309,731  41.22   DTS-MA  5.1    48/24  4070
ABC [AU] 2000   Space Cowboys                                                    MPEG-2  1080p24 2.40:1  16.29   2:10:26 19,108,780,032  22,255,303,046  19.53   AC3     5.1           640
ABC [UK] 2002   Spider-Man                                                       AVC     1080p24 1.85:1  26.09   2:01:12 31,049,551,872  32,980,349,090  34.16   TrueHD  5.1    48/16  1712
ABC [UK] 2004   Spider-Man 2 (seamless)                                          AVC     1080p24 2.40:1  24.14   2:07:28 37,269,983,232  49,838,875,847  38.99   TrueHD  5.1    48/24  3694
                   Spider-Man 2.1 (seamless)                                     AVC     1080p24 2.40:1  24.06   2:15:48 39,587,856,384                  38.87   TrueHD  5.1    48/24  3675
ABC [UK] 2007   Spider-Man 3                                                     AVC     1080p24 2.40:1  26.06   2:19:11 44,073,861,120  48,019,355,309  42.22   LPCM    5.1    48/16  4608  / TrueHD  5.1    48/24  3424
ABC [US] 2009   Star Trek                                                       AVC     1080p24 2.40:1  32.69   2:06:50 39,570,505,728  41,537,681,136  41.60   TrueHD  5.1    48/24  3603
    [US] 2008   Star Wars: The Clone Wars: Season 1: Disc 1: Episodes 1-7        VC-1    1080p24 2.35:1  10.21   2:40:28 18,425,088,000                  15.31   AC3     5.1    48     640
ABC [US] 1994   Stargate: 15th Anniversary: Extended (seamless)                  VC-1    1080p24 2.40:1  22.89   2:09:41 30,655,444,800  40,630,330,646  31.52   DTS-MA  7.1    48/24  5137
                                            Theatrical (seamless)                VC-1    1080p24 2.40:1  22.87   2:00:49 28,500,805,440                  31.45   DTS-MA  7.1    48/24  5112
ABC [CZ] 2008   Starship Troopers 3: Marauder                                   AVC     1080p24 1.85:1  29.63   1:44:54 33,588,940,800  41,924,654,929  42.69   TrueHD  5.1    48/16  1629
ABC [US] 2009   State of Play                                                    VC-1    1080p24 2.40:1  22.48   2:07:08 29,373,247,488  32,937,699,441  30.81   DTS-MA  5.1    48/24  3603
A   [US] 2008   Street Kings                                                     AVC     1080p24 2.35:1  33.49   1:48:48 33,872,019,456  43,653,832,730  41.51   DTS-MA  5.1    48/24  3782
ABC [US] 1989   Tango and Cash                                                   VC-1    1080p24 2.40:1  18.69   1:43:46 22,187,907,072  22,758,172,159  28.51   TrueHD  5.1    48/16  1787  / AC3     5.1    48     640
ABC [UK] 2006   Tekkonkinkreet                                                   AVC     1080p24 2.35:1  25.72   1:50:36 30,942,449,664  39,216,248,585  37.30   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
    [US] 2009   Tinker Bell and the Lost Treasure                                AVC     1080p24 1.78:1  31.77   1:20:14 23,403,866,112  33,089,522,488  38.89   DTS-MA  5.1    48/24  3727
ABC [US] 2009   Transformers: Revenge of the Fallen                                AVC     1080p24 2.40:1  31.29   2:29:53 44,644,544,448  45,008,234,560  39.71   DTS-MA  5.1    48/24  4658
ABC [AU] 2009   Transformers: Revenge of the Fallen                              AVC     1080p24 2.40:1  31.29   2:29:53 44,644,798,464  45,008,217,243  39.72   DTS-MA  5.1    48/24  4658
ABC [AU] 1999   Two Hands                                                        AVC     1080i50 1.85:1  30.00   1:29:33 22,376,300,544  23,774,170,024  33.32   DTS-MA  2.0    48/16  1580
A   [US] 2002   Unfaithful                                                       AVC     1080p24 1.85:1  33.87   2:03:38 37,587,253,248  48,050,920,909  40.54   DTS-MA  5.1    48/24  3083
A   [US] 2009   Up                                                               AVC     1080p24 1.78:1  24.04   1:36:07 25,535,932,416  44,564,197,747  35.42   DTS-MA  5.1-ES 48/24  4034  / DTS-MA  2.0    48/24  2064
ABC [AU] 1971   Wake in Fright                                                   AVC     1080p24*1.85:1  21.99   1:48:54 19,194,605,568  23,363,692,368  23.50   AC3     2.0    48     224
ABC [US] 2008   Waltz with Bashir                                                AVC     1080p24 1.78:1  27.93   1:30:22 24,104,140,800  30,780,889,447  35.56   TrueHD  5.1    48/16  1573
ABC [US] 1995   Waterworld                                                       AVC     1080p24 1.85:1  30.68   2:15:11 43,701,190,656  44,887,550,467  43.10   DTS-MA  5.1    48/24  4181
ABC [US] 2000   The Way of the Gun                                              AVC     1080p24 1.78:1  17.99   2:00:05 22,150,287,360  23,362,614,581  24.59   DTS-MA  7.1    48/24  4737
ABC [US] 2009   Whatever Works                                                  AVC     1080p24 1.78:1  21.99   1:31:26 17,853,075,456  18,035,371,975  26.03   DTS-MA  5.1    48/24  2478
ABC [US] 1998   Wild Things                                                      AVC     1080p24 2.40:1  20.40   1:54:46 23,963,510,784  24,455,261,408  27.84   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
ABC [AU] 1939   The Wizard of Oz                                         VC-1    1080p24 1.37:1  22.96   1:41:47 22,708,051,968  41,146,450,143  29.75   TrueHD  5.1    48/16  1308  / AC3     1.0    48     192
A   [US] 2009   X-Men Origins: Wolverine: Rental Edition                 AVC     1080p24 2.35:1  22.07   1:47:21 23,668,660,224  25,890,185,462  29.40   DTS-MA  5.1    48/24  3892
Cinema Squid is offline
post #776 of 5106 Old 11-16-2009, 10:33 PM
Mary and Max - 2009 - Australian version
Region Free, confirmed with AnyDVD HD, but lots of 576i50 extras.
Main feature is 24fps rather than 23.976.
Code:
        Total   Video
00000.MPLS                                                      AVC     1:32:10 16,724,621,760  20,258,242,073  24.19   20.00   DTS-HD Master 5.1 2298Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     MARY AND MAX
Disc Size:      20,258,242,073 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:32:10 (h:m:s)
Total Bitrate:          24.19 Mbps
VIDEO:
MPEG-4 AVC Video        19996 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2298 kbps       5.1 / 48 kHz / 2298 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             English         256 kbps        2.0 / 48 kHz / 256 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         37.398 kbps
FILES:
00000.M2TS      0:00:00.000     1:32:10.500     16,724,621,760  24,192
CHAPTERS:
1               0:00:00.000     0:08:27.375     19,632 kbps     39,794 kbps     00:01:29.250    33,447 kbps     00:07:42.291    29,486 kbps     00:07:37.666    102,242 bytes   528,351 bytes   00:07:04.500
2               0:08:27.375     0:07:24.416     20,876 kbps     39,983 kbps     00:12:20.166    31,527 kbps     00:08:59.041    30,164 kbps     00:08:55.500    108,730 bytes   587,932 bytes   00:15:07.666
3               0:15:51.791     0:09:54.625     19,502 kbps     41,914 kbps     00:23:16.250    32,219 kbps     00:16:06.666    29,723 kbps     00:16:06.625    101,572 bytes   621,637 bytes   00:22:15.916
4               0:25:46.416     0:05:51.875     20,714 kbps     40,704 kbps     00:26:56.000    35,369 kbps     00:26:52.083    31,216 kbps     00:26:48.416    107,886 bytes   558,722 bytes   00:27:47.208
5               0:31:38.291     0:06:23.125     19,421 kbps     37,778 kbps     00:32:01.416    30,462 kbps     00:32:00.708    26,668 kbps     00:31:59.208    101,150 bytes   458,189 bytes   00:37:04.250
6               0:38:01.416     0:05:15.750     19,451 kbps     37,261 kbps     00:38:12.416    25,985 kbps     00:39:21.458    23,783 kbps     00:39:18.416    101,310 bytes   580,101 bytes   00:40:00.666
7               0:43:17.166     0:07:48.333     20,274 kbps     44,170 kbps     00:48:07.458    29,317 kbps     00:50:32.583    25,847 kbps     00:49:27.541    105,596 bytes   550,833 bytes   00:46:41.583
8               0:51:05.500     0:07:30.500     20,993 kbps     38,167 kbps     00:53:18.666    29,147 kbps     00:51:48.000    26,484 kbps     00:51:46.750    109,338 bytes   510,693 bytes   00:54:39.208
9               0:58:36.000     0:06:55.250     20,202 kbps     40,934 kbps     01:00:41.000    28,504 kbps     01:01:50.583    26,313 kbps     01:01:47.083    105,218 bytes   503,870 bytes   00:59:32.083
10              1:05:31.250     0:09:04.250     20,743 kbps     39,960 kbps     01:06:15.583    31,519 kbps     01:09:23.291    27,936 kbps     01:09:20.833    108,038 bytes   591,755 bytes   01:09:48.750
11              1:14:35.500     0:03:57.000     21,190 kbps     39,705 kbps     01:16:20.083    32,867 kbps     01:16:17.958    27,960 kbps     01:16:18.333    110,367 bytes   452,421 bytes   01:15:47.250
12              1:18:32.500     0:06:16.500     20,586 kbps     41,352 kbps     01:21:14.708    37,620 kbps     01:21:10.583    35,496 kbps     01:21:09.749    107,221 bytes   586,435 bytes   01:18:40.791
13              1:24:49.000     0:04:10.458     19,705 kbps     36,383 kbps     01:25:11.124    24,688 kbps     01:25:10.916    24,069 kbps     01:26:26.083    102,628 bytes   497,904 bytes   01:25:46.375
14              1:28:59.458     0:03:11.041     13,316 kbps     33,091 kbps     01:31:24.083    30,451 kbps     01:31:22.625    27,876 kbps     01:31:20.083    69,386 bytes    348,081 bytes   01:31:25.125
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5530.417                19,996                  13,823,597,699  75,206,962
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5530.417                2,298                   1,588,536,404   9,494,663
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5530.417                256                     176,976,896     1,036,974
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5530.417                256                     176,972,800     1,036,950
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5530.417                37                      25,853,705      146,575
Stephen Dawson
hifi-writer.com
post #777 of 5106 Old 11-16-2009, 11:22 PM
Becoming Jane - 2007 - Australian version
Region free, confirmed with AnyDVD HD, but feature uses 1080i50.
Code:
        Total   Video
00000.MPLS                                                      AVC     1:55:34 22,446,888,960  22,689,166,726  25.90   22.00   DTS-HD Master 5.1 2478Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     BECOMING_JANE
Disc Size:      22,689,166,726 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:55:34 (h:m:s)
Total Bitrate:          25.90 Mbps
VIDEO:
MPEG-4 AVC Video        21999 kbps          1080i / 25 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2478 kbps       5.1 / 48 kHz / 2478 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         39.002 kbps
FILES:
00000.M2TS      0:00:00.000     1:55:34.000     22,446,888,960  25,898
CHAPTERS:
1               0:00:00.000     0:07:56.319     21,227 kbps     35,542 kbps     00:04:56.839    29,500 kbps     00:04:54.799    26,931 kbps     00:07:36.040    106,128 bytes   356,966 bytes   00:01:14.519
2               0:07:56.319     0:11:18.319     23,681 kbps     37,574 kbps     00:14:11.319    31,896 kbps     00:13:49.040    30,033 kbps     00:08:00.759    118,404 bytes   295,302 bytes   00:12:59.519
3               0:19:14.639     0:08:14.040     23,212 kbps     38,417 kbps     00:19:32.040    30,608 kbps     00:20:47.000    28,515 kbps     00:25:32.559    116,060 bytes   407,607 bytes   00:19:52.040
4               0:27:28.680     0:10:38.519     21,641 kbps     42,134 kbps     00:31:25.479    35,059 kbps     00:31:39.879    32,450 kbps     00:31:34.239    108,203 bytes   311,099 bytes   00:32:08.159
5               0:38:07.199     0:11:42.120     22,855 kbps     38,527 kbps     00:42:47.239    33,185 kbps     00:42:45.120    30,133 kbps     00:39:37.400    114,275 bytes   322,109 bytes   00:43:42.159
6               0:49:49.319     0:11:40.680     23,895 kbps     33,487 kbps     00:58:37.799    29,120 kbps     00:51:28.000    28,151 kbps     00:51:26.879    119,473 bytes   256,209 bytes   01:00:12.919
7               1:01:30.000     0:07:57.879     22,778 kbps     36,790 kbps     01:01:30.239    30,051 kbps     01:01:35.120    27,704 kbps     01:01:30.080    113,888 bytes   276,017 bytes   01:01:31.799
8               1:09:27.879     0:08:46.360     21,136 kbps     37,993 kbps     01:09:30.839    29,478 kbps     01:17:08.320    26,700 kbps     01:09:46.640    105,679 bytes   307,825 bytes   01:16:43.599
9               1:18:14.239     0:06:33.000     21,190 kbps     38,896 kbps     01:18:23.959    33,122 kbps     01:18:23.120    31,123 kbps     01:18:23.479    105,950 bytes   300,889 bytes   01:23:36.440
10              1:24:47.239     0:04:36.000     21,948 kbps     35,340 kbps     01:24:54.720    31,338 kbps     01:29:08.080    29,066 kbps     01:29:08.080    109,742 bytes   319,988 bytes   01:25:07.639
11              1:29:23.239     0:08:34.480     22,895 kbps     43,904 kbps     01:31:00.080    39,950 kbps     01:30:59.519    33,594 kbps     01:30:54.519    114,475 bytes   360,683 bytes   01:37:57.120
12              1:37:57.720     0:06:57.799     21,100 kbps     36,170 kbps     01:44:27.519    33,628 kbps     01:37:57.799    31,459 kbps     01:37:57.720    105,502 bytes   329,564 bytes   01:38:02.519
13              1:44:55.519     0:05:18.080     20,902 kbps     29,465 kbps     01:47:28.720    25,897 kbps     01:47:23.080    24,925 kbps     01:47:19.799    104,511 bytes   260,394 bytes   01:45:02.720
14              1:50:13.599     0:05:20.400     14,512 kbps     20,268 kbps     01:51:17.559    18,324 kbps     01:51:46.559    17,757 kbps     01:51:44.759    72,570 bytes    268,985 bytes   01:55:05.199
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6933.880                21,999                  19,067,227,843  103,727,692
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6933.880                2,478                   2,148,074,876   12,758,353
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6933.880                39                      33,804,805      192,519
Stephen Dawson
hifi-writer.com
post #778 of 5106 Old 11-17-2009, 07:50 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Kill Bill: Volume 1 - 2003 - UK - Disney - Region ABC
Code:
        Total   Video
00001.MPLS                                                      AVC     1:50:43 37,005,232,128  41,556,466,060  44.56   30.06   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     KILLBILL1_GBR
Disc Size:      41,556,466,060 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:50:43 (h:m:s)
Total Bitrate:          44.56 Mbps
VIDEO:
MPEG-4 AVC Video        30057 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS Audio                       German          1509 kbps       5.1 / 48 kHz / 1509 kbps / 24-bit
DTS Audio                       Italian         1509 kbps       5.1 / 48 kHz / 1509 kbps / 16-bit
DTS Audio                       Spanish         1509 kbps       5.1 / 48 kHz / 1509 kbps / 16-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Italian         640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         11.293 kbps
Presentation Graphics           English         13.516 kbps
Presentation Graphics           English         3.422 kbps
Presentation Graphics           German          12.673 kbps
Presentation Graphics           German          3.155 kbps
Presentation Graphics           Italian         10.110 kbps
Presentation Graphics           Italian         2.768 kbps
Presentation Graphics           Spanish         10.566 kbps
Presentation Graphics           Spanish         2.567 kbps
FILES:
00001.M2TS      0:00:00.000     1:50:43.637     37,005,232,128  44,560
CHAPTERS:
1               0:00:00.000     0:02:27.856     27,132 kbps     51,078 kbps     00:00:02.377    37,765 kbps     00:00:22.564    35,247 kbps     00:01:18.453    141,412 bytes   602,377 bytes   00:00:13.430
2               0:02:27.856     0:02:40.285     5,696 kbps      21,573 kbps     00:04:54.502    19,236 kbps     00:04:54.377    17,657 kbps     00:04:53.084    29,694 bytes    268,622 bytes   00:04:58.172
3               0:05:08.141     0:04:42.073     31,644 kbps     44,627 kbps     00:05:48.556    38,071 kbps     00:05:48.556    34,912 kbps     00:06:00.610    164,975 bytes   596,501 bytes   00:05:20.069
4               0:09:50.214     0:06:18.377     32,894 kbps     43,146 kbps     00:12:59.653    38,159 kbps     00:15:43.400    35,725 kbps     00:15:18.083    171,495 bytes   610,116 bytes   00:15:25.257
5               0:16:08.592     0:03:43.431     32,025 kbps     44,693 kbps     00:18:56.218    38,174 kbps     00:16:52.511    35,596 kbps     00:16:52.094    166,964 bytes   642,199 bytes   00:16:22.523
6               0:19:52.024     0:05:20.111     32,907 kbps     43,090 kbps     00:23:26.071    37,748 kbps     00:22:48.241    35,697 kbps     00:23:48.009    171,563 bytes   824,083 bytes   00:22:03.405
7               0:25:12.135     0:07:06.926     32,076 kbps     50,431 kbps     00:25:57.722    38,026 kbps     00:27:22.349    35,453 kbps     00:25:29.653    167,232 bytes   669,282 bytes   00:25:46.545
8               0:32:19.062     0:03:38.593     32,843 kbps     50,482 kbps     00:32:50.593    36,908 kbps     00:32:50.259    35,490 kbps     00:35:08.356    171,228 bytes   664,529 bytes   00:35:56.696
9               0:35:57.655     0:09:04.752     31,593 kbps     49,151 kbps     00:41:36.118    38,077 kbps     00:42:10.778    35,448 kbps     00:42:10.778    164,711 bytes   772,291 bytes   00:43:08.335
10              0:45:02.407     0:05:28.453     31,746 kbps     48,420 kbps     00:45:23.721    37,232 kbps     00:50:00.998    35,176 kbps     00:48:39.416    165,507 bytes   588,123 bytes   00:45:25.889
11              0:50:30.861     0:08:08.863     32,237 kbps     43,836 kbps     00:56:32.263    37,990 kbps     00:55:57.228    35,651 kbps     00:56:27.634    168,067 bytes   558,312 bytes   00:54:08.578
12              0:58:39.724     0:05:55.396     29,041 kbps     48,615 kbps     00:59:17.220    38,073 kbps     00:59:50.962    35,668 kbps     01:02:54.312    151,407 bytes   629,400 bytes   00:59:35.280
13              1:04:35.121     0:08:37.099     31,046 kbps     54,935 kbps     01:10:05.159    38,422 kbps     01:05:42.104    35,784 kbps     01:06:02.166    161,859 bytes   706,113 bytes   01:11:37.876
14              1:13:12.221     0:08:27.215     32,681 kbps     50,174 kbps     01:13:12.721    38,156 kbps     01:14:44.730    35,682 kbps     01:15:23.769    170,385 bytes   656,132 bytes   01:13:47.965
15              1:21:39.436     0:08:26.297     32,745 kbps     50,255 kbps     01:28:57.498    38,287 kbps     01:27:50.390    35,706 kbps     01:28:42.150    170,718 bytes   616,438 bytes   01:29:36.579
16              1:30:05.733     0:08:31.344     31,743 kbps     55,824 kbps     01:32:41.013    38,428 kbps     01:31:53.925    35,642 kbps     01:35:24.677    165,493 bytes   676,295 bytes   01:32:41.055
17              1:38:37.077     0:03:09.022     28,039 kbps     53,601 kbps     01:38:39.204    36,786 kbps     01:40:05.082    34,101 kbps     01:40:05.082    146,182 bytes   599,237 bytes   01:39:13.656
18              1:41:46.099     0:01:33.301     30,391 kbps     45,183 kbps     01:41:48.060    37,430 kbps     01:42:54.126    35,274 kbps     01:42:51.331    158,442 bytes   608,181 bytes   01:41:48.102
19              1:43:19.401     0:07:23.234     17,005 kbps     30,608 kbps     01:49:15.590    30,210 kbps     01:49:15.090    29,556 kbps     01:49:12.504    88,659 bytes    501,745 bytes   01:49:17.259
20              1:50:42.635     0:00:01.001     97 kbps         0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    527 bytes       749 bytes       01:50:42.802
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     6643.512                30,058                  24,961,355,357  135,752,498
00001.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           6643.512                4,614                   3,832,051,552   21,259,648
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6643.512                640                     531,491,840     3,114,210
00001.M2TS      4354 (0x1102)   0x82            DTS             ita (Italian)           6643.512                1,509                   1,253,156,092   7,474,092
00001.M2TS      4355 (0x1103)   0x81            AC3             ita (Italian)           6643.512                640                     531,491,840     3,114,210
00001.M2TS      4356 (0x1104)   0x82            DTS             spa (Spanish)           6643.512                1,509                   1,253,155,908   7,474,091
00001.M2TS      4357 (0x1105)   0x81            AC3             spa (Spanish)           6643.512                640                     531,491,840     3,114,210
00001.M2TS      4358 (0x1106)   0x82            DTS             deu (German)            6643.512                1,509                   1,253,156,092   7,474,092
00001.M2TS      4359 (0x1107)   0x81            AC3             deu (German)            6643.512                640                     531,491,840     3,114,210
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6643.512                11                      9,378,707       56,539
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6643.512                14                      11,224,181      68,001
00001.M2TS      4610 (0x1202)   0x90            PGS             ita (Italian)           6643.512                10                      8,396,251       50,384
00001.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6643.512                11                      8,774,222       52,431
00001.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            6643.512                13                      10,524,292      62,039
00001.M2TS      4613 (0x1205)   0x90            PGS             eng (English)           6643.512                3                       2,841,551       16,743
00001.M2TS      4614 (0x1206)   0x90            PGS             ita (Italian)           6643.512                3                       2,298,353       13,812
00001.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           6643.512                3                       2,131,438       12,783
00001.M2TS      4616 (0x1208)   0x90            PGS             deu (German)            6643.512                3                       2,620,236       15,498
paku is offline
post #779 of 5106 Old 11-17-2009, 08:49 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Kill Bill: Volume 2 - 2004 - UK - Disney - Region ABC
Code:
        Total   Video
00001.MPLS                                                      AVC     2:16:57 42,803,675,136  47,278,908,653  41.67   27.26   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     KILLBILL2_GBR
Disc Size:      47,278,908,653 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:16:57 (h:m:s)
Total Bitrate:          41.67 Mbps
VIDEO:
MPEG-4 AVC Video        27261 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS Audio                       Italian         1509 kbps       5.1 / 48 kHz / 1509 kbps / 24-bit
DTS Audio                       Spanish         1509 kbps       5.1 / 48 kHz / 1509 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         17.562 kbps
Presentation Graphics           English         20.425 kbps
Presentation Graphics           English         1.497 kbps
Presentation Graphics           German          18.063 kbps
Presentation Graphics           German          1.373 kbps
Presentation Graphics           Italian         15.513 kbps
Presentation Graphics           Italian         1.155 kbps
Presentation Graphics           Spanish         16.157 kbps
Presentation Graphics           Spanish         1.294 kbps
FILES:
00001.M2TS      0:00:00.000     2:16:57.834     42,803,675,136  41,669
CHAPTERS:
1               0:00:00.000     0:02:01.121     18,698 kbps     44,520 kbps     00:00:02.669    36,585 kbps     00:01:39.682    34,800 kbps     00:01:35.303    97,450 bytes    564,156 bytes   00:00:36.036
2               0:02:01.121     0:03:27.290     30,679 kbps     41,481 kbps     00:04:58.631    37,141 kbps     00:04:18.841    35,624 kbps     00:04:39.153    159,948 bytes   623,831 bytes   00:02:13.049
3               0:05:28.411     0:09:22.478     28,822 kbps     42,852 kbps     00:14:42.882    37,302 kbps     00:11:54.422    35,677 kbps     00:12:42.052    150,266 bytes   810,567 bytes   00:14:50.890
4               0:14:50.889     0:03:17.530     24,668 kbps     38,114 kbps     00:14:58.272    36,066 kbps     00:14:56.770    34,312 kbps     00:14:52.766    128,606 bytes   770,825 bytes   00:14:54.810
5               0:18:08.420     0:04:44.492     32,467 kbps     42,194 kbps     00:20:54.544    37,713 kbps     00:22:16.418    35,748 kbps     00:20:03.535    169,269 bytes   708,127 bytes   00:21:38.797
6               0:22:52.913     0:08:02.690     26,409 kbps     46,667 kbps     00:23:22.484    37,914 kbps     00:26:00.141    35,145 kbps     00:29:08.329    137,685 bytes   642,321 bytes   00:27:20.847
7               0:30:55.603     0:08:18.581     17,594 kbps     52,836 kbps     00:35:50.022    37,933 kbps     00:35:39.637    35,465 kbps     00:35:34.257    91,726 bytes    590,505 bytes   00:33:55.366
8               0:39:14.185     0:18:19.598     32,231 kbps     44,905 kbps     00:56:33.473    37,960 kbps     00:55:50.847    35,873 kbps     00:55:20.775    168,036 bytes   645,859 bytes   00:57:33.783
9               0:57:33.783     0:05:33.124     31,031 kbps     47,355 kbps     00:59:06.668    37,891 kbps     00:59:19.264    35,611 kbps     00:59:19.264    161,780 bytes   669,328 bytes   01:02:34.792
10              1:03:06.908     0:11:35.152     30,692 kbps     55,474 kbps     01:09:38.757    37,867 kbps     01:14:18.203    35,579 kbps     01:13:39.456    160,012 bytes   808,846 bytes   01:09:38.799
11              1:14:42.060     0:06:31.891     31,562 kbps     52,600 kbps     01:17:16.465    38,057 kbps     01:19:52.454    35,562 kbps     01:20:13.558    164,552 bytes   745,327 bytes   01:21:09.155
12              1:21:13.952     0:06:34.394     32,450 kbps     44,286 kbps     01:22:53.843    38,074 kbps     01:21:55.994    35,642 kbps     01:22:49.464    169,178 bytes   777,581 bytes   01:21:39.185
13              1:27:48.346     0:04:26.808     24,444 kbps     42,941 kbps     01:28:51.117    31,323 kbps     01:30:21.082    30,221 kbps     01:31:19.432    127,440 bytes   655,365 bytes   01:28:51.159
14              1:32:15.154     0:07:52.889     25,797 kbps     40,855 kbps     01:36:25.863    36,352 kbps     01:36:21.859    35,423 kbps     01:36:19.523    134,492 bytes   542,163 bytes   01:36:35.206
15              1:40:08.043     0:09:27.942     26,519 kbps     52,626 kbps     01:42:03.534    37,561 kbps     01:42:13.794    33,524 kbps     01:41:00.429    138,257 bytes   587,185 bytes   01:41:00.471
16              1:49:35.985     0:05:36.586     23,002 kbps     41,600 kbps     01:50:59.736    34,020 kbps     01:50:58.401    30,326 kbps     01:54:38.329    119,922 bytes   504,351 bytes   01:54:45.295
17              1:55:12.572     0:06:56.332     20,950 kbps     46,276 kbps     01:58:28.684    37,128 kbps     01:58:25.848    34,320 kbps     01:58:23.805    109,221 bytes   497,975 bytes   01:55:16.409
18              2:02:08.904     0:01:54.280     27,517 kbps     38,565 kbps     02:03:48.170    36,901 kbps     02:03:46.335    35,798 kbps     02:03:42.331    143,459 bytes   549,885 bytes   02:02:25.379
19              2:04:03.185     0:12:53.647     23,128 kbps     54,954 kbps     02:05:13.714    38,010 kbps     02:05:10.002    35,712 kbps     02:05:12.796    120,581 bytes   757,945 bytes   02:06:08.352
20              2:16:56.833     0:00:01.001     107 kbps        0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    582 bytes       932 bytes       02:16:57.000
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     8217.710                27,262                  28,003,646,622  152,308,800
00001.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           8217.710                4,614                   4,740,047,228   26,297,072
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           8217.710                640                     657,428,480     3,852,120
00001.M2TS      4354 (0x1102)   0x82            DTS             ita (Italian)           8217.710                1,509                   1,550,089,064   9,245,064
00001.M2TS      4355 (0x1103)   0x81            AC3             ita (Italian)           8217.710                640                     657,428,480     3,852,120
00001.M2TS      4356 (0x1104)   0x82            DTS             spa (Spanish)           8217.710                1,509                   1,550,089,064   9,245,064
00001.M2TS      4357 (0x1105)   0x81            AC3             spa (Spanish)           8217.710                640                     657,428,480     3,852,120
00001.M2TS      4358 (0x1106)   0x82            DTS             deu (German)            8217.710                1,509                   1,550,089,064   9,245,064
00001.M2TS      4359 (0x1107)   0x81            AC3             deu (German)            8217.710                640                     657,428,480     3,852,120
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8217.710                18                      18,039,987      107,766
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8217.710                20                      20,980,948      125,526
00001.M2TS      4610 (0x1202)   0x90            PGS             ita (Italian)           8217.710                16                      15,935,257      96,299
00001.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           8217.710                16                      16,597,222      99,894
00001.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            8217.710                18                      18,554,446      110,496
00001.M2TS      4613 (0x1205)   0x90            PGS             eng (English)           8217.710                1                       1,537,405       9,023
00001.M2TS      4614 (0x1206)   0x90            PGS             ita (Italian)           8217.710                1                       1,185,966       7,205
00001.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           8217.710                1                       1,329,127       8,001
00001.M2TS      4616 (0x1208)   0x90            PGS             deu (German)            8217.710                1                       1,410,699       8,425
paku is offline
post #780 of 5106 Old 11-17-2009, 09:52 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
American Gangster - 2007 - UK - Universal - Region ABC
Significantly lower video bitrate compared to the US version, probably to make room for all the DTS dubs. First playlist is theatrical cut, second extended. There are actually two playlists for each of them but they seemed to be more or less the same.
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:36:50 31,644,487,680  49,500,968,583  26.90   14.86   DTS-HD Master 5.1 4012Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     AMER_GANG_G51
Disc Size:      49,500,968,583 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:36:50 (h:m:s)
Total Bitrate:          26.90 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
VC-1 Video              14858 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
* VC-1 Video            1021 kbps           480p / 23.976 fps / 16:9 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         4012 kbps       5.1 / 48 kHz / 4012 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       German          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Italian         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Japanese        768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* DTS Express                   English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         67.597 kbps
Presentation Graphics           English         45.516 kbps
* Presentation Graphics         English         17.818 kbps
Presentation Graphics           Chinese         25.147 kbps
Presentation Graphics           Danish          32.374 kbps
Presentation Graphics           Dutch           27.930 kbps
Presentation Graphics           Finnish         28.404 kbps
Presentation Graphics           French          44.422 kbps
Presentation Graphics           French          60.259 kbps
* Presentation Graphics         French          16.040 kbps
Presentation Graphics           French          0.545 kbps
Presentation Graphics           German          44.656 kbps
Presentation Graphics           German          67.533 kbps
* Presentation Graphics         German          18.702 kbps
Presentation Graphics           German          0.599 kbps
Presentation Graphics           Italian         41.831 kbps
Presentation Graphics           Italian         60.117 kbps
* Presentation Graphics         Italian         16.213 kbps
Presentation Graphics           Italian         0.615 kbps
Presentation Graphics           Japanese        23.529 kbps
Presentation Graphics           Japanese        40.020 kbps
* Presentation Graphics         Japanese        11.806 kbps
Presentation Graphics           Japanese        0.667 kbps
Presentation Graphics           Korean          18.015 kbps
Presentation Graphics           Norwegian       28.047 kbps
Presentation Graphics           Portuguese      32.917 kbps
Presentation Graphics           Spanish         42.826 kbps
Presentation Graphics           Spanish         58.998 kbps
* Presentation Graphics         Spanish         16.076 kbps
Presentation Graphics           Spanish         0.749 kbps
Presentation Graphics           Swedish         32.399 kbps
FILES:
00235.M2TS      0:00:00.000     0:19:49.396     3,979,481,088   26,766
00222.M2TS      0:19:49.396     0:00:26.026     85,757,952      26,361
00236.M2TS      0:20:15.422     0:23:26.571     4,788,185,088   27,233
00223.M2TS      0:43:41.994     0:00:20.854     66,711,552      25,592
00237.M2TS      0:44:02.848     0:07:29.574     1,527,545,856   27,182
00224.M2TS      0:51:32.422     0:00:19.185     79,650,816      33,212
00238.M2TS      0:51:51.608     0:05:33.249     1,182,222,336   28,380
00225.M2TS      0:57:24.858     0:01:43.144     331,517,952     25,713
00239.M2TS      0:59:08.002     0:00:43.877     143,929,344     26,242
00226.M2TS      0:59:51.879     0:00:35.035     113,897,472     26,008
00240.M2TS      1:00:26.914     0:01:34.594     319,838,208     27,049
00227.M2TS      1:02:01.509     0:00:06.673     21,540,864      25,823
00241.M2TS      1:02:08.182     0:02:02.080     435,879,936     28,563
00228.M2TS      1:04:10.262     0:00:50.925     164,278,272     25,807
00242.M2TS      1:05:01.188     0:23:31.410     4,862,312,448   27,560
00229.M2TS      1:28:32.598     0:00:30.488     98,009,088      25,717
00243.M2TS      1:29:03.087     0:02:56.009     573,069,312     26,047
00230.M2TS      1:31:59.096     0:00:22.897     73,826,304      25,793
00244.M2TS      1:32:21.994     0:00:16.850     54,054,912      25,664
00231.M2TS      1:32:38.844     0:01:57.408     387,895,296     26,430
00245.M2TS      1:34:36.253     0:02:03.665     405,245,952     26,216
00232.M2TS      1:36:39.918     0:00:35.368     113,541,120     25,682
00246.M2TS      1:37:15.287     0:07:13.433     1,437,462,528   26,532
00233.M2TS      1:44:28.720     0:00:30.697     97,873,920      25,507
00247.M2TS      1:44:59.417     0:43:43.287     9,154,762,752   27,918
00234.M2TS      2:28:42.705     0:00:54.345     160,659,456     23,650
00248.M2TS      2:29:37.051     0:07:13.349     985,337,856     18,190
CHAPTERS:
1               0:00:00.000     0:06:48.950     14,170 kbps     22,360 kbps     00:02:20.515    20,362 kbps     00:02:16.511    20,062 kbps     00:02:11.506    74,728 bytes    262,708 bytes   00:02:21.432
2               0:06:48.950     0:07:18.646     15,893 kbps     25,365 kbps     00:13:35.940    24,992 kbps     00:13:32.770    24,741 kbps     00:13:27.515    82,856 bytes    222,973 bytes   00:08:51.155
3               0:14:07.596     0:10:08.399     15,650 kbps     26,846 kbps     00:21:40.424    25,214 kbps     00:14:14.603    24,661 kbps     00:14:14.061    81,594 bytes    237,443 bytes   00:21:43.427
4               0:24:15.996     0:06:37.105     14,275 kbps     19,942 kbps     00:30:34.791    18,604 kbps     00:27:27.228    17,666 kbps     00:30:28.076    74,425 bytes    218,851 bytes   00:24:22.002
5               0:30:53.101     0:05:13.646     16,014 kbps     25,448 kbps     00:33:40.977    23,848 kbps     00:33:35.346    23,662 kbps     00:33:32.677    83,488 bytes    245,454 bytes   00:33:46.691
6               0:36:06.747     0:06:15.291     16,312 kbps     29,914 kbps     00:39:44.048    27,312 kbps     00:39:42.171    25,932 kbps     00:39:42.213    85,042 bytes    217,302 bytes   00:39:44.090
7               0:42:22.039     0:06:07.825     14,710 kbps     22,816 kbps     00:42:29.713    18,991 kbps     00:42:27.920    17,910 kbps     00:47:26.885    76,692 bytes    242,930 bytes   00:45:34.940
8               0:48:29.865     0:05:37.462     15,199 kbps     29,384 kbps     00:51:33.340    26,415 kbps     00:51:33.256    24,802 kbps     00:51:32.380    79,242 bytes    257,614 bytes   00:51:40.889
9               0:54:07.327     0:10:43.267     15,228 kbps     23,417 kbps     00:54:39.025    20,383 kbps     00:54:35.105    19,502 kbps     00:54:19.881    79,394 bytes    198,217 bytes   01:02:11.185
10              1:04:50.594     0:04:39.195     14,944 kbps     27,377 kbps     01:07:28.127    19,692 kbps     01:07:28.210    19,134 kbps     01:07:25.166    77,909 bytes    253,544 bytes   01:07:32.214
11              1:09:29.790     0:08:07.862     14,433 kbps     20,600 kbps     01:12:36.810    19,432 kbps     01:12:36.727    18,946 kbps     01:12:34.057    75,248 bytes    201,809 bytes   01:14:08.569
12              1:17:37.652     0:08:20.917     16,617 kbps     37,505 kbps     01:25:29.999    31,026 kbps     01:23:22.539    28,879 kbps     01:23:21.371    86,632 bytes    264,293 bytes   01:23:23.206
13              1:25:58.569     0:06:04.572     15,007 kbps     25,641 kbps     01:29:24.400    24,698 kbps     01:29:23.649    19,816 kbps     01:29:18.769    78,237 bytes    241,614 bytes   01:29:26.694
14              1:32:03.142     0:08:43.773     14,863 kbps     26,032 kbps     01:32:30.669    19,218 kbps     01:32:30.669    17,919 kbps     01:40:25.644    77,488 bytes    256,003 bytes   01:32:30.878
15              1:40:46.915     0:08:06.110     15,629 kbps     23,227 kbps     01:47:22.936    22,475 kbps     01:47:19.808    21,830 kbps     01:47:14.844    81,483 bytes    212,442 bytes   01:48:51.566
16              1:48:53.026     0:08:01.522     14,527 kbps     20,301 kbps     01:55:16.701    19,297 kbps     01:55:15.241    18,876 kbps     01:55:12.864    75,738 bytes    212,162 bytes   01:55:12.905
17              1:56:54.549     0:07:07.885     15,310 kbps     20,400 kbps     01:59:21.737    18,489 kbps     01:59:20.486    17,659 kbps     01:59:05.596    79,817 bytes    213,369 bytes   02:00:38.606
18              2:04:02.434     0:11:44.078     15,400 kbps     21,944 kbps     02:15:30.789    19,670 kbps     02:15:29.287    19,277 kbps     02:15:23.365    80,287 bytes    184,133 bytes   02:10:21.063
19              2:15:46.513     0:13:19.799     15,097 kbps     33,370 kbps     02:29:05.227    28,681 kbps     02:29:01.223    26,571 kbps     02:28:44.665    78,709 bytes    372,879 bytes   02:29:06.103
20              2:29:06.312     0:07:44.088     7,603 kbps      34,398 kbps     02:36:44.478    22,827 kbps     02:36:40.724    18,177 kbps     02:35:38.829    40,274 bytes    472,552 bytes   02:35:44.418
STREAM DIAGNOSTICS:
00235.M2TS      4113 (0x1011)   0xEA            VC-1                                    1189.271                15,382                  2,286,633,303   12,444,556
00235.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          1189.271                768                     114,182,144     669,036
00235.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1189.271                3,934                   584,884,416     3,364,063
00235.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            1189.271                768                     114,182,144     669,036
00235.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           1189.271                768                     114,182,144     669,036
00235.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            1189.271                768                     114,182,144     669,036
00235.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           1189.271                768                     114,182,144     669,036
00235.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           1189.271                192                     28,545,792      185,845
00235.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1189.271                23                      3,375,806       19,833
00235.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1189.271                42                      6,312,104       36,155
00235.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1189.271                41                      6,138,066       35,130
00235.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           1189.271                39                      5,847,444       33,479
00235.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            1189.271                42                      6,292,516       35,883
00235.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1189.271                40                      5,926,447       33,927
00235.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             1189.271                25                      3,738,649       21,814
00235.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            1189.271                17                      2,507,748       15,203
00235.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           1189.271                31                      4,558,963       26,369
00235.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            1189.271                31                      4,625,657       26,766
00235.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           1189.271                27                      4,027,651       23,460
00235.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         1189.271                27                      3,968,405       23,165
00235.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        1189.271                31                      4,534,596       26,192
00235.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           1189.271                23                      3,416,460       20,160
00235.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          1189.271                43                      6,407,647       36,247
00235.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           1189.271                72                      10,639,065      60,397
00235.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            1189.271                63                      9,414,339       53,771
00235.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           1189.271                63                      9,293,384       53,106
00235.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            1189.271                70                      10,430,180      59,274
00235.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           1189.271                63                      9,326,166       53,288
00235.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          1189.271                6                       921,035         5,313
00235.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           1189.271                9                       1,358,694       7,794
00235.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            1189.271                9                       1,273,732       7,356
00235.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           1189.271                9                       1,320,930       7,614
00235.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            1189.271                9                       1,392,722       7,992
00235.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           1189.271                9                       1,264,386       7,293
00235.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          1189.271                0                       57,430          350
00235.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            1189.271                0                       36,476          213
00235.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           1189.271                0                       40,862          243
00235.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            1189.271                0                       37,185          215
00235.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           1189.271                0                       71,384          423
00235.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           1189.271                192                     28,547,072      167,268
00235.M2TS      6912 (0x1B00)   0xEA            VC-1                                    1189.271                505                     75,127,222      428,570
00222.M2TS      4113 (0x1011)   0xEA            VC-1                                    25.901                  15,042                  48,699,002      265,042
00222.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          25.901                  772                     2,498,560       14,640
00222.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           25.901                  3,899                   12,622,880      72,662
00222.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            25.901                  772                     2,498,560       14,640
00222.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           25.901                  772                     2,498,560       14,640
00222.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            25.901                  772                     2,498,560       14,640
00222.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           25.901                  772                     2,498,560       14,640
00222.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           25.901                  193                     625,152         4,070
00222.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          25.901                  42                      137,529         786
00222.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           25.901                  79                      255,780         1,438
00222.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            25.901                  85                      276,521         1,556
00222.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           25.901                  75                      241,429         1,363
00222.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            25.901                  83                      267,826         1,505
00222.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           25.901                  91                      295,215         1,665
00222.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             25.901                  60                      193,604         1,102
00222.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            25.901                  33                      106,043         626
00222.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           25.901                  68                      220,551         1,247
00222.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            25.901                  59                      192,294         1,094
00222.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           25.901                  54                      173,786         993
00222.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         25.901                  55                      179,357         1,024
00222.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        25.901                  64                      208,005         1,180
00222.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           25.901                  29                      92,853          532
00222.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          25.901                  53                      171,373         969
00222.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           25.901                  96                      310,200         1,774
00222.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            25.901                  89                      287,585         1,652
00222.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           25.901                  83                      268,281         1,550
00222.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            25.901                  99                      319,763         1,828
00222.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           25.901                  95                      307,966         1,764
00222.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          25.901                  0                       70              7
00222.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           25.901                  0                       70              7
00222.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            25.901                  0                       70              7
00222.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           25.901                  0                       70              7
00222.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            25.901                  0                       70              7
00222.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           25.901                  0                       70              7
00222.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          25.901                  0                       70              7
00222.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            25.901                  0                       70              7
00222.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           25.901                  0                       70              7
00222.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            25.901                  0                       70              7
00222.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           25.901                  0                       70              7
00222.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           25.901                  193                     624,640         3,660
00222.M2TS      6912 (0x1B00)   0xEA            VC-1                                    25.901                  39                      126,073         1,143
00236.M2TS      4113 (0x1011)   0xEA            VC-1                                    1406.447                15,347                  2,698,166,877   14,684,338
00236.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          1406.447                768                     135,031,808     791,202
00236.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1406.447                4,101                   720,913,612     4,137,266
00236.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            1406.447                768                     135,031,808     791,202
00236.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           1406.447                768                     135,031,808     791,202
00236.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            1406.447                768                     135,031,808     791,202
00236.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           1406.447                768                     135,031,808     791,202
00236.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           1406.447                192                     33,758,208      219,780
00236.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1406.447                22                      3,877,293       22,784
00236.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1406.447                42                      7,315,104       41,965
00236.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1406.447                41                      7,289,070       41,719
00236.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           1406.447                38                      6,677,665       38,379
00236.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            1406.447                41                      7,152,997       40,916
00236.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1406.447                39                      6,787,685       38,985
00236.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             1406.447                26                      4,523,919       26,417
00236.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            1406.447                17                      2,987,755       18,123
00236.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           1406.447                29                      5,117,727       29,646
00236.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            1406.447                30                      5,281,195       30,623
00236.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           1406.447                26                      4,484,270       26,264
00236.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         1406.447                25                      4,419,390       25,878
00236.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        1406.447                30                      5,231,806       30,281
00236.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           1406.447                23                      4,046,088       23,886
00236.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          1406.447                43                      7,485,904       42,402
00236.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           1406.447                69                      12,196,766      69,016
00236.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            1406.447                62                      10,976,241      62,412
00236.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           1406.447                63                      11,120,220      63,173
00236.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            1406.447                70                      12,280,018      69,474
00236.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           1406.447                60                      10,572,028      60,207
00236.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          1406.447                9                       1,630,644       9,409
00236.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           1406.447                12                      2,057,409       11,802
00236.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            1406.447                11                      1,921,611       11,099
00236.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           1406.447                11                      1,921,453       11,102
00236.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            1406.447                12                      2,172,662       12,465
00236.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           1406.447                11                      1,871,518       10,814
00236.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          1406.447                1                       175,174         1,050
00236.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            1406.447                0                       85,220          505
00236.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           1406.447                1                       122,791         731
00236.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            1406.447                1                       129,715         769
00236.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           1406.447                1                       146,905         876
00236.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           1406.447                192                     33,759,232      197,808
00236.M2TS      6912 (0x1B00)   0xEA            VC-1                                    1406.447                821                     144,352,389     807,983
00223.M2TS      4113 (0x1011)   0xEA            VC-1                                    20.729                  15,035                  38,958,839      212,034
00223.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          20.729                  773                     2,002,944       11,736
00223.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           20.729                  4,017                   10,408,344      59,805
00223.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            20.729                  773                     2,002,944       11,736
00223.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           20.729                  773                     2,002,944       11,736
00223.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            20.729                  773                     2,002,944       11,736
00223.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           20.729                  773                     2,002,944       11,736
00223.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           20.729                  193                     500,736         3,260
00223.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          20.729                  0                       70              7
00223.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           20.729                  18                      47,141          278
00223.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            20.729                  13                      33,930          198
00223.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           20.729                  10                      26,027          155
00223.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            20.729                  11                      28,828          171
00223.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           20.729                  10                      26,872          159
00223.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             20.729                  7                       18,754          116
00223.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            20.729                  4                       10,026          68
00223.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           20.729                  6                       16,207          102
00223.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            20.729                  8                       20,362          125
00223.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           20.729                  7                       19,247          117
00223.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         20.729                  7                       18,017          112
00223.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        20.729                  0                       70              7
00223.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           20.729                  5                       12,423          81
00223.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          20.729                  57                      148,576         837
00223.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           20.729                  86                      223,697         1,261
00223.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            20.729                  90                      232,401         1,309
00223.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           20.729                  83                      214,933         1,215
00223.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            20.729                  87                      226,451         1,277
00223.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           20.729                  83                      214,082         1,211
00223.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          20.729                  0                       70              7
00223.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           20.729                  0                       70              7
00223.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            20.729                  0                       70              7
00223.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           20.729                  0                       70              7
00223.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            20.729                  0                       70              7
00223.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           20.729                  0                       70              7
00223.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          20.729                  0                       70              7
00223.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            20.729                  0                       70              7
00223.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           20.729                  0                       70              7
00223.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            20.729                  0                       70              7
00223.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           20.729                  0                       70              7
00223.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           20.729                  194                     501,760         2,940
00223.M2TS      6912 (0x1B00)   0xEA            VC-1                                    20.729                  39                      101,228         917
00237.M2TS      4113 (0x1011)   0xEA            VC-1                                    449.449                 15,007                  843,129,674     4,588,690
00237.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          449.449                 768                     43,159,552      252,888
00237.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           449.449                 3,919                   220,174,536     1,266,627
00237.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            449.449                 768                     43,159,552      252,888
00237.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           449.449                 768                     43,159,552      252,888
00237.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            449.449                 768                     43,159,552      252,888
00237.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           449.449                 768                     43,159,552      252,888
00237.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           449.449                 192                     10,790,400      70,250
00237.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          449.449                 30                      1,672,961       9,783
00237.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           449.449                 57                      3,185,523       18,299
00237.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            449.449                 54                      3,018,960       17,324
00237.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           449.449                 49                      2,745,929       15,832
00237.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            449.449                 54                      3,026,456       17,365
00237.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           449.449                 50                      2,823,712       16,243
00237.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             449.449                 33                      1,872,217       10,972
00237.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            449.449                 21                      1,196,130       7,280
00237.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           449.449                 38                      2,134,195       12,401
00237.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            449.449                 37                      2,103,275       12,230
00237.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           449.449                 32                      1,772,821       10,401
00237.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         449.449                 33                      1,854,562       10,874
00237.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        449.449                 37                      2,058,346       11,964
00237.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           449.449                 31                      1,754,923       10,329
00237.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          449.449                 41                      2,294,386       13,005
00237.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           449.449                 72                      4,057,652       22,929
00237.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            449.449                 66                      3,717,956       21,093
00237.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           449.449                 64                      3,582,507       20,357
00237.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            449.449                 72                      4,067,237       22,987
00237.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           449.449                 65                      3,638,938       20,669
00237.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          449.449                 15                      865,868         5,001
00237.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           449.449                 22                      1,216,246       6,917
00237.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            449.449                 20                      1,144,071       6,536
00237.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           449.449                 20                      1,098,127       6,293
00237.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            449.449                 23                      1,272,381       7,227
00237.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           449.449                 20                      1,100,523       6,290
00237.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          449.449                 1                       30,030          176
00237.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            449.449                 0                       19,040          110
00237.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           449.449                 1                       28,409          168
00237.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            449.449                 0                       26,231          157
00237.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           449.449                 0                       27,746          164
00237.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           449.449                 192                     10,790,912      63,228
00237.M2TS      6912 (0x1B00)   0xEA            VC-1                                    449.449                 1,094                   61,486,177      341,502
00224.M2TS      4113 (0x1011)   0xEA            VC-1                                    19.061                  22,435                  53,453,489      290,795
00224.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          19.061                  773                     1,842,176       10,794
00224.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           19.061                  4,184                   9,968,708       57,175
00224.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            19.061                  773                     1,842,176       10,794
00224.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           19.061                  773                     1,842,176       10,794
00224.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            19.061                  773                     1,842,176       10,794
00224.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           19.061                  773                     1,842,176       10,794
00224.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           19.061                  193                     460,800         3,000
00224.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          19.061                  9                       22,050          130
00224.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           19.061                  7                       15,670          92
00224.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            19.061                  6                       15,460          91
00224.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           19.061                  7                       16,643          97
00224.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            19.061                  9                       20,516          119
00224.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           19.061                  6                       13,773          82
00224.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             19.061                  3                       8,072           50
00224.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            19.061                  7                       17,654          110
00224.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           19.061                  6                       14,935          88
00224.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            19.061                  5                       12,024          72
00224.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           19.061                  10                      23,203          140
00224.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         19.061                  6                       14,287          85
00224.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        19.061                  6                       15,409          91
00224.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           19.061                  11                      25,191          151
00224.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          19.061                  41                      96,626          544
00224.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           19.061                  50                      120,186         679
00224.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            19.061                  59                      141,099         793
00224.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           19.061                  53                      126,957         716
00224.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            19.061                  45                      107,081         607
00224.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           19.061                  47                      110,887         629
00224.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          19.061                  0                       70              7
00224.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           19.061                  0                       70              7
00224.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            19.061                  0                       70              7
00224.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           19.061                  0                       70              7
00224.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            19.061                  0                       70              7
00224.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           19.061                  0                       70              7
00224.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          19.061                  4                       10,152          59
00224.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            19.061                  0                       70              7
00224.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           19.061                  0                       70              7
00224.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            19.061                  0                       70              7
00224.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           19.061                  0                       70              7
00224.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           19.061                  193                     460,800         2,700
00224.M2TS      6912 (0x1B00)   0xEA            VC-1                                    19.061                  40                      94,169          849
00238.M2TS      4113 (0x1011)   0xEA            VC-1                                    333.166                 14,998                  624,582,526     3,399,318
00238.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          333.166                 768                     31,992,832      187,458
00238.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           333.166                 4,123                   171,704,756     985,311
00238.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            333.166                 768                     31,992,832      187,458
00238.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           333.166                 768                     31,992,832      187,458
00238.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            333.166                 768                     31,992,832      187,458
00238.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           333.166                 768                     31,992,832      187,458
00238.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           333.166                 192                     7,998,720       52,075
00238.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          333.166                 23                      966,731         5,686
00238.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           333.166                 55                      2,297,351       13,120
00238.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            333.166                 51                      2,123,673       12,157
00238.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           333.166                 49                      2,032,768       11,628
00238.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            333.166                 51                      2,136,413       12,202
00238.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           333.166                 48                      1,988,521       11,391
00238.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             333.166                 29                      1,195,920       6,998
00238.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            333.166                 19                      777,084         4,723
00238.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           333.166                 35                      1,465,091       8,460
00238.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            333.166                 35                      1,456,208       8,421
00238.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           333.166                 29                      1,212,307       7,080
00238.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         333.166                 31                      1,297,135       7,574
00238.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        333.166                 35                      1,451,622       8,391
00238.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           333.166                 28                      1,148,384       6,750
00238.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          333.166                 44                      1,833,861       10,378
00238.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           333.166                 71                      2,973,763       16,798
00238.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            333.166                 65                      2,696,536       15,295
00238.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           333.166                 62                      2,565,658       14,584
00238.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            333.166                 72                      3,008,267       16,986
00238.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           333.166                 63                      2,628,587       14,923
00238.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          333.166                 22                      936,434         5,454
00238.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           333.166                 38                      1,565,256       8,959
00238.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            333.166                 32                      1,334,533       7,706
00238.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           333.166                 33                      1,369,861       7,906
00238.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            333.166                 39                      1,618,110       9,252
00238.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           333.166                 33                      1,364,274       7,866
00238.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          333.166                 0                       7,031           45
00238.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            333.166                 0                       70              7
00238.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           333.166                 0                       70              7
00238.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            333.166                 0                       70              7
00238.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           333.166                 0                       70              7
00238.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           333.166                 192                     7,999,488       46,872
00238.M2TS      6912 (0x1B00)   0xEA            VC-1                                    333.166                 2,016                   83,944,241      461,054
00225.M2TS      4113 (0x1011)   0xEA            VC-1                                    103.061                 14,968                  192,825,473     1,049,472
00225.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          103.061                 769                     9,902,080       58,020
00225.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           103.061                 3,986                   51,346,468      295,156
00225.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            103.061                 769                     9,902,080       58,020
00225.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           103.061                 769                     9,902,080       58,020
00225.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            103.061                 769                     9,902,080       58,020
00225.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           103.061                 769                     9,902,080       58,020
00225.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           103.061                 192                     2,476,032       16,120
00225.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          103.061                 19                      238,966         1,458
00225.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           103.061                 45                      579,858         3,377
00225.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            103.061                 33                      428,443         2,524
00225.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           103.061                 33                      428,118         2,507
00225.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            103.061                 37                      470,869         2,754
00225.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           103.061                 34                      439,184         2,575
00225.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             103.061                 23                      301,114         1,791
00225.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            103.061                 17                      213,145         1,324
00225.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           103.061                 29                      378,584         2,226
00225.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            103.061                 27                      347,096         2,056
00225.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           103.061                 25                      321,828         1,907
00225.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         103.061                 32                      409,277         2,421
00225.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        103.061                 28                      360,255         2,121
00225.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           103.061                 25                      327,179         1,943
00225.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          103.061                 33                      421,897         2,395
00225.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           103.061                 55                      709,852         4,020
00225.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            103.061                 48                      619,279         3,530
00225.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           103.061                 54                      695,986         3,946
00225.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            103.061                 53                      677,496         3,843
00225.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           103.061                 46                      595,638         3,399
00225.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          103.061                 0                       70              7
00225.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           103.061                 0                       70              7
00225.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            103.061                 0                       70              7
00225.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           103.061                 0                       70              7
00225.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            103.061                 0                       70              7
00225.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           103.061                 0                       70              7
00225.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          103.061                 0                       70              7
00225.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            103.061                 0                       70              7
00225.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           103.061                 0                       70              7
00225.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            103.061                 0                       70              7
00225.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           103.061                 0                       70              7
00225.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           103.061                 192                     2,476,032       14,508
00225.M2TS      6912 (0x1B00)   0xEA            VC-1                                    103.061                 39                      501,780         4,540
00239.M2TS      4113 (0x1011)   0xEA            VC-1                                    43.752                  15,017                  82,128,302      446,985
00239.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          43.752                  770                     4,212,736       24,684
00239.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           43.752                  3,798                   20,772,400      119,794
00239.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            43.752                  770                     4,212,736       24,684
00239.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           43.752                  770                     4,212,736       24,684
00239.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            43.752                  770                     4,212,736       24,684
00239.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           43.752                  770                     4,212,736       24,684
00239.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           43.752                  193                     1,053,696       6,860
00239.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          43.752                  27                      145,270         832
00239.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           43.752                  114                     625,027         3,544
00239.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            43.752                  94                      515,595         2,946
00239.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           43.752                  93                      510,499         2,918
00239.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            43.752                  96                      523,526         2,990
00239.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           43.752                  99                      540,946         3,091
00239.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             43.752                  56                      307,260         1,802
00239.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            43.752                  35                      189,652         1,158
00239.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           43.752                  54                      296,584         1,729
00239.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            43.752                  58                      317,343         1,854
00239.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           43.752                  58                      314,843         1,839
00239.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         43.752                  54                      298,037         1,743
00239.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        43.752                  58                      317,004         1,826
00239.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           43.752                  55                      299,573         1,759
00239.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          43.752                  53                      290,239         1,631
00239.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           43.752                  76                      414,879         2,343
00239.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            43.752                  60                      329,925         1,882
00239.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           43.752                  64                      351,664         2,000
00239.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            43.752                  80                      440,197         2,482
00239.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           43.752                  60                      328,478         1,874
00239.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          43.752                  0                       70              7
00239.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           43.752                  0                       70              7
00239.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            43.752                  0                       70              7
00239.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           43.752                  0                       70              7
00239.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            43.752                  0                       70              7
00239.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           43.752                  0                       70              7
00239.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          43.752                  7                       36,730          206
00239.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            43.752                  0                       70              7
00239.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           43.752                  0                       70              7
00239.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            43.752                  0                       70              7
00239.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           43.752                  0                       70              7
00239.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           43.752                  193                     1,054,720       6,180
00239.M2TS      6912 (0x1B00)   0xEA            VC-1                                    43.752                  39                      212,985         1,929
00226.M2TS      4113 (0x1011)   0xEA            VC-1                                    34.910                  15,016                  65,527,835      356,647
00226.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          34.910                  771                     3,363,840       19,710
00226.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           34.910                  3,724                   16,250,636      93,756
00226.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            34.910                  771                     3,363,840       19,710
00226.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           34.910                  771                     3,363,840       19,710
00226.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            34.910                  771                     3,363,840       19,710
00226.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           34.910                  771                     3,363,840       19,710
00226.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           34.910                  193                     840,960         5,475
00226.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          34.910                  41                      178,295         1,024
00226.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           34.910                  77                      336,991         1,897
00226.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            34.910                  75                      326,439         1,849
00226.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           34.910                  72                      315,938         1,785
00226.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            34.910                  81                      355,517         1,998
00226.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           34.910                  73                      320,532         1,811
00226.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             34.910                  46                      202,175         1,160
00226.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            34.910                  29                      127,051         751
00226.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           34.910                  61                      266,578         1,508
00226.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            34.910                  54                      236,934         1,350
00226.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           34.910                  47                      206,490         1,182
00226.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         34.910                  52                      228,564         1,309
00226.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        34.910                  58                      252,799         1,435
00226.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           34.910                  38                      167,891         972
00226.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          34.910                  52                      226,040         1,277
00226.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           34.910                  83                      363,436         2,042
00226.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            34.910                  78                      339,726         1,913
00226.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           34.910                  68                      294,693         1,667
00226.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            34.910                  83                      363,725         2,044
00226.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           34.910                  69                      301,888         1,707
00226.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          34.910                  0                       70              7
00226.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           34.910                  0                       70              7
00226.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            34.910                  0                       70              7
00226.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           34.910                  0                       70              7
00226.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            34.910                  0                       70              7
00226.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           34.910                  0                       70              7
00226.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          34.910                  0                       70              7
00226.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            34.910                  0                       70              7
00226.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           34.910                  0                       70              7
00226.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            34.910                  0                       70              7
00226.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           34.910                  0                       70              7
00226.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           34.910                  193                     841,728         4,932
00226.M2TS      6912 (0x1B00)   0xEA            VC-1                                    34.910                  39                      169,804         1,539
00240.M2TS      4113 (0x1011)   0xEA            VC-1                                    94.469                  15,010                  177,253,977     964,703
00240.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          94.469                  769                     9,081,856       53,214
00240.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           94.469                  4,470                   52,781,464      301,587
00240.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            94.469                  769                     9,081,856       53,214
00240.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           94.469                  769                     9,081,856       53,214
00240.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            94.469                  769                     9,081,856       53,214
00240.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           94.469                  769                     9,081,856       53,214
00240.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           94.469                  192                     2,270,976       14,785
00240.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          94.469                  18                      211,236         1,300
00240.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           94.469                  46                      548,132         3,154
00240.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            94.469                  35                      417,757         2,428
00240.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           94.469                  39                      455,171         2,630
00240.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            94.469                  39                      465,207         2,680
00240.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           94.469                  38                      446,700         2,576
00240.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             94.469                  26                      301,267         1,774
00240.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            94.469                  15                      172,273         1,075
00240.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           94.469                  28                      324,866         1,905
00240.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            94.469                  29                      343,830         2,021
00240.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           94.469                  25                      290,572         1,717
00240.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         94.469                  22                      264,939         1,576
00240.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        94.469                  29                      338,699         1,982
00240.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           94.469                  22                      259,900         1,560
00240.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          94.469                  43                      508,347         2,877
00240.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           94.469                  77                      909,441         5,142
00240.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            94.469                  68                      806,651         4,585
00240.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           94.469                  64                      754,838         4,305
00240.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            94.469                  75                      883,527         5,002
00240.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           94.469                  67                      794,319         4,520
00240.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          94.469                  6                       76,437          440
00240.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           94.469                  13                      156,618         879
00240.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            94.469                  10                      123,601         699
00240.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           94.469                  10                      116,454         661
00240.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            94.469                  11                      127,952         724
00240.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           94.469                  12                      137,018         772
00240.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          94.469                  0                       70              7
00240.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            94.469                  0                       70              7
00240.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           94.469                  0                       70              7
00240.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            94.469                  0                       70              7
00240.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           94.469                  0                       70              7
00240.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           94.469                  192                     2,271,232       13,308
00240.M2TS      6912 (0x1B00)   0xEA            VC-1                                    94.469                  632                     7,463,376       42,163
00227.M2TS      4113 (0x1011)   0xEA            VC-1                                    6.548                   15,152                  12,402,618      67,496
00227.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          6.548                   783                     641,024         3,756
00227.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           6.548                   4,683                   3,833,252       21,875
00227.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            6.548                   783                     641,024         3,756
00227.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           6.548                   783                     641,024         3,756
00227.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            6.548                   783                     641,024         3,756
00227.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           6.548                   783                     641,024         3,756
00227.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           6.548                   196                     160,512         1,045
00227.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          6.548                   0                       70              7
00227.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6.548                   13                      10,603          65
00227.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6.548                   8                       6,698           43
00227.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           6.548                   8                       6,851           44
00227.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            6.548                   10                      8,516           53
00227.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           6.548                   0                       70              7
00227.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             6.548                   0                       70              7
00227.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            6.548                   0                       70              7
00227.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           6.548                   0                       70              7
00227.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            6.548                   0                       70              7
00227.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           6.548                   0                       70              7
00227.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         6.548                   0                       70              7
00227.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        6.548                   0                       70              7
00227.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           6.548                   0                       70              7
00227.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          6.548                   27                      22,490          126
00227.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           6.548                   43                      35,362          203
00227.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            6.548                   36                      29,601          173
00227.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           6.548                   41                      33,232          191
00227.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            6.548                   47                      38,439          220
00227.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           6.548                   42                      34,000          197
00227.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          6.548                   0                       70              7
00227.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           6.548                   0                       70              7
00227.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            6.548                   0                       70              7
00227.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           6.548                   0                       70              7
00227.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            6.548                   0                       70              7
00227.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           6.548                   0                       70              7
00227.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          6.548                   0                       70              7
00227.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            6.548                   0                       70              7
00227.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           6.548                   0                       70              7
00227.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            6.548                   0                       70              7
00227.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           6.548                   0                       70              7
00227.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           6.548                   198                     161,792         948
00227.M2TS      6912 (0x1B00)   0xEA            VC-1                                    6.548                   40                      32,652          295
00241.M2TS      4113 (0x1011)   0xEA            VC-1                                    121.955                 15,023                  229,024,104     1,246,474
00241.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          121.955                 769                     11,720,704      68,676
00241.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           121.955                 4,273                   65,134,908      373,071
00241.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            121.955                 769                     11,720,704      68,676
00241.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           121.955                 769                     11,720,704      68,676
00241.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            121.955                 769                     11,720,704      68,676
00241.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           121.955                 769                     11,720,704      68,676
00241.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           121.955                 192                     2,930,688       19,080
00241.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          121.955                 21                      325,632         1,915
00241.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           121.955                 48                      724,482         4,141
00241.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            121.955                 41                      628,351         3,618
00241.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           121.955                 41                      628,074         3,617
00241.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            121.955                 39                      594,211         3,402
00241.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           121.955                 42                      639,402         3,670
00241.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             121.955                 26                      400,965         2,347
00241.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            121.955                 17                      260,891         1,589
00241.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           121.955                 28                      430,162         2,507
00241.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            121.955                 30                      455,386         2,654
00241.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           121.955                 25                      386,984         2,270
00241.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         121.955                 25                      387,089         2,270
00241.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        121.955                 28                      425,088         2,488
00241.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           121.955                 22                      332,501         1,977
00241.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          121.955                 43                      662,067         3,746
00241.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           121.955                 76                      1,158,205       6,524
00241.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            121.955                 68                      1,036,201       5,864
00241.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           121.955                 65                      998,381         5,654
00241.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            121.955                 77                      1,177,456       6,628
00241.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           121.955                 64                      976,011         5,533
00241.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          121.955                 39                      597,807         3,447
00241.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           121.955                 48                      727,927         4,166
00241.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            121.955                 46                      695,214         3,987
00241.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           121.955                 45                      684,262         3,928
00241.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            121.955                 51                      774,921         4,423
00241.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           121.955                 46                      697,986         4,001
00241.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          121.955                 0                       70              7
00241.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            121.955                 0                       70              7
00241.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           121.955                 0                       70              7
00241.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            121.955                 0                       70              7
00241.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           121.955                 0                       70              7
00241.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           121.955                 192                     2,930,688       17,172
00241.M2TS      6912 (0x1B00)   0xEA            VC-1                                    121.955                 2,021                   30,815,060      169,230
00228.M2TS      4113 (0x1011)   0xEA            VC-1                                    50.801                  15,024                  95,405,504      519,244
00228.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          50.801                  770                     4,889,600       28,650
00228.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           50.801                  3,928                   24,941,640      143,330
00228.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            50.801                  770                     4,889,600       28,650
00228.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           50.801                  770                     4,889,600       28,650
00228.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            50.801                  770                     4,889,600       28,650
00228.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           50.801                  770                     4,889,600       28,650
00228.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           50.801                  193                     1,222,656       7,960
00228.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          50.801                  23                      143,600         838
00228.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           50.801                  39                      248,879         1,430
00228.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            50.801                  37                      235,455         1,357
00228.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           50.801                  41                      257,757         1,477
00228.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            50.801                  41                      262,143         1,503
00228.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           50.801                  39                      249,012         1,430
00228.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             50.801                  28                      178,125         1,037
00228.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            50.801                  15                      97,196          597
00228.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           50.801                  29                      184,257         1,072
00228.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            50.801                  30                      188,366         1,093
00228.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           50.801                  25                      161,041         943
00228.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         50.801                  25                      156,213         919
00228.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        50.801                  30                      193,463         1,122
00228.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           50.801                  20                      124,965         748
00228.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          50.801                  51                      324,797         1,831
00228.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           50.801                  78                      495,184         2,776
00228.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            50.801                  66                      420,398         2,371
00228.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           50.801                  65                      412,123         2,327
00228.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            50.801                  78                      496,313         2,782
00228.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           50.801                  68                      432,309         2,436
00228.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          50.801                  0                       70              7
00228.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           50.801                  0                       70              7
00228.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            50.801                  0                       70              7
00228.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           50.801                  0                       70              7
00228.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            50.801                  0                       70              7
00228.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           50.801                  0                       70              7
00228.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          50.801                  0                       70              7
00228.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            50.801                  0                       70              7
00228.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           50.801                  0                       70              7
00228.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            50.801                  0                       70              7
00228.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           50.801                  0                       70              7
00228.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           50.801                  193                     1,222,656       7,164
00228.M2TS      6912 (0x1B00)   0xEA            VC-1                                    50.801                  39                      248,562         2,246
00242.M2TS      4113 (0x1011)   0xEA            VC-1                                    1411.285                15,353                  2,708,492,820   14,740,441
00242.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          1411.285                768                     135,495,680     793,920
00242.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1411.285                3,952                   697,109,628     4,008,593
00242.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            1411.285                768                     135,495,680     793,920
00242.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           1411.285                768                     135,495,680     793,920
00242.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            1411.285                768                     135,495,680     793,920
00242.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           1411.285                768                     135,495,680     793,920
00242.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           1411.285                192                     33,874,176      220,535
00242.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1411.285                28                      5,009,815       29,292
00242.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1411.285                55                      9,691,004       55,349
00242.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1411.285                54                      9,532,630       54,480
00242.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           1411.285                52                      9,158,531       52,351
00242.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            1411.285                54                      9,567,862       54,550
00242.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1411.285                53                      9,396,001       53,695
00242.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             1411.285                35                      6,123,702       35,619
00242.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            1411.285                22                      3,925,746       23,718
00242.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           1411.285                40                      7,066,113       40,798
00242.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            1411.285                40                      7,091,752       40,945
00242.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           1411.285                35                      6,261,294       36,422
00242.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         1411.285                34                      6,062,639       35,315
00242.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        1411.285                41                      7,245,566       41,747
00242.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           1411.285                31                      5,459,481       32,057
00242.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          1411.285                42                      7,361,758       41,715
00242.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           1411.285                70                      12,384,026      69,674
00242.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            1411.285                63                      11,142,703      62,946
00242.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           1411.285                62                      10,855,797      61,395
00242.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            1411.285                70                      12,393,891      69,745
00242.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           1411.285                61                      10,737,696      60,744
00242.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          1411.285                14                      2,443,632       14,098
00242.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           1411.285                19                      3,284,780       18,773
00242.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            1411.285                17                      2,986,729       17,188
00242.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           1411.285                17                      3,067,152       17,623
00242.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            1411.285                20                      3,492,393       19,923
00242.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           1411.285                17                      2,962,749       17,045
00242.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          1411.285                1                       93,481          547
00242.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            1411.285                0                       68,357          399
00242.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           1411.285                0                       53,956          313
00242.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            1411.285                0                       40,170          231
00242.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           1411.285                1                       105,458         608
00242.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           1411.285                192                     33,873,920      198,480
00242.M2TS      6912 (0x1B00)   0xEA            VC-1                                    1411.285                1,087                   191,767,189     1,065,290
00229.M2TS      4113 (0x1011)   0xEA            VC-1                                    30.364                  15,030                  57,046,401      310,481
00229.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          30.364                  771                     2,927,616       17,154
00229.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           30.364                  3,756                   14,254,392      82,238
00229.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            30.364                  771                     2,927,616       17,154
00229.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           30.364                  771                     2,927,616       17,154
00229.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            30.364                  771                     2,927,616       17,154
00229.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           30.364                  771                     2,927,616       17,154
00229.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           30.364                  193                     731,904         4,765
00229.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          30.364                  30                      115,348         652
00229.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           30.364                  65                      245,796         1,399
00229.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            30.364                  61                      230,451         1,314
00229.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           30.364                  60                      227,891         1,287
00229.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            30.364                  58                      219,973         1,245
00229.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           30.364                  57                      218,080         1,242
00229.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             30.364                  40                      152,613         871
00229.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            30.364                  23                      86,307          513
00229.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           30.364                  40                      151,925         868
00229.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            30.364                  44                      168,773         960
00229.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           30.364                  36                      137,731         791
00229.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         30.364                  39                      149,030         853
00229.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        30.364                  43                      162,450         925
00229.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           30.364                  33                      126,318         735
00229.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          30.364                  35                      131,437         747
00229.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           30.364                  54                      204,463         1,154
00229.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            30.364                  48                      181,885         1,031
00229.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           30.364                  56                      212,987         1,200
00229.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            30.364                  62                      234,371         1,316
00229.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           30.364                  48                      183,335         1,039
00229.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          30.364                  0                       70              7
00229.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           30.364                  0                       70              7
00229.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            30.364                  0                       70              7
00229.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           30.364                  0                       70              7
00229.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            30.364                  0                       70              7
00229.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           30.364                  0                       70              7
00229.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          30.364                  0                       70              7
00229.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            30.364                  0                       70              7
00229.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           30.364                  0                       70              7
00229.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            30.364                  0                       70              7
00229.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           30.364                  0                       70              7
00229.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           30.364                  193                     733,184         4,296
00229.M2TS      6912 (0x1B00)   0xEA            VC-1                                    30.364                  39                      148,713         1,344
00243.M2TS      4113 (0x1011)   0xEA            VC-1                                    175.884                 15,228                  334,792,257     1,822,046
00243.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          175.884                 769                     16,897,024      99,006
00243.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           175.884                 3,972                   87,322,128      502,179
00243.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            175.884                 769                     16,897,024      99,006
00243.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           175.884                 769                     16,897,024      99,006
00243.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            175.884                 769                     16,897,024      99,006
00243.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           175.884                 769                     16,897,024      99,006
00243.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           175.884                 192                     4,224,768       27,505
00243.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          175.884                 20                      430,618         2,545
00243.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           175.884                 42                      917,120         5,277
00243.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            175.884                 36                      799,509         4,605
00243.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           175.884                 34                      756,043         4,367
00243.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            175.884                 38                      837,602         4,813
00243.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           175.884                 34                      738,977         4,274
00243.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             175.884                 24                      527,939         3,115
00243.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            175.884                 15                      323,396         1,995
00243.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           175.884                 26                      576,871         3,384
00243.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            175.884                 28                      622,060         3,643
00243.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           175.884                 24                      535,488         3,163
00243.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         175.884                 22                      492,825         2,917
00243.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        175.884                 25                      550,250         3,224
00243.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           175.884                 21                      468,061         2,782
00243.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          175.884                 42                      925,594         5,240
00243.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           175.884                 72                      1,587,312       8,912
00243.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            175.884                 68                      1,500,088       8,439
00243.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           175.884                 65                      1,426,307       8,040
00243.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            175.884                 72                      1,591,720       8,934
00243.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           175.884                 64                      1,414,035       7,969
00243.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          175.884                 0                       70              7
00243.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           175.884                 0                       70              7
00243.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            175.884                 0                       70              7
00243.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           175.884                 0                       70              7
00243.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            175.884                 0                       70              7
00243.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           175.884                 0                       70              7
00243.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          175.884                 0                       70              7
00243.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            175.884                 0                       70              7
00243.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           175.884                 0                       70              7
00243.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            175.884                 0                       70              7
00243.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           175.884                 0                       70              7
00243.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           175.884                 192                     4,225,024       24,756
00243.M2TS      6912 (0x1B00)   0xEA            VC-1                                    175.884                 39                      854,373         7,737
00230.M2TS      4113 (0x1011)   0xEA            VC-1                                    22.814                  14,961                  42,666,247      232,224
00230.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          22.814                  771                     2,198,528       12,882
00230.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           22.814                  4,374                   12,475,196      71,370
00230.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            22.814                  771                     2,198,528       12,882
00230.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           22.814                  771                     2,198,528       12,882
00230.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            22.814                  771                     2,198,528       12,882
00230.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           22.814                  771                     2,198,528       12,882
00230.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           22.814                  193                     549,888         3,580
00230.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          22.814                  0                       70              7
00230.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           22.814                  6                       18,154          106
00230.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            22.814                  0                       70              7
00230.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           22.814                  0                       70              7
00230.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            22.814                  0                       70              7
00230.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           22.814                  0                       70              7
00230.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             22.814                  0                       70              7
00230.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            22.814                  0                       70              7
00230.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           22.814                  0                       70              7
00230.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            22.814                  0                       70              7
00230.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           22.814                  0                       70              7
00230.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         22.814                  0                       70              7
00230.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        22.814                  0                       70              7
00230.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           22.814                  0                       70              7
00230.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          22.814                  50                      141,319         796
00230.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           22.814                  89                      254,835         1,420
00230.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            22.814                  79                      225,482         1,263
00230.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           22.814                  75                      214,887         1,204
00230.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            22.814                  91                      258,224         1,441
00230.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           22.814                  79                      224,548         1,257
00230.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          22.814                  0                       70              7
00230.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           22.814                  0                       70              7
00230.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            22.814                  0                       70              7
00230.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           22.814                  0                       70              7
00230.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            22.814                  0                       70              7
00230.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           22.814                  0                       70              7
00230.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          22.814                  0                       70              7
00230.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            22.814                  0                       70              7
00230.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           22.814                  0                       70              7
00230.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            22.814                  0                       70              7
00230.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           22.814                  0                       70              7
00230.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           22.814                  193                     550,912         3,228
00230.M2TS      6912 (0x1B00)   0xEA            VC-1                                    22.814                  39                      112,510         1,014
00244.M2TS      4113 (0x1011)   0xEA            VC-1                                    16.725                  14,609                  30,541,673      166,244
00244.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          16.725                  774                     1,617,920       9,480
00244.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           16.725                  4,527                   9,464,032       54,071
00244.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            16.725                  774                     1,617,920       9,480
00244.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           16.725                  774                     1,617,920       9,480
00244.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            16.725                  774                     1,617,920       9,480
00244.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           16.725                  774                     1,617,920       9,480
00244.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           16.725                  194                     404,736         2,635
00244.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          16.725                  7                       15,023          101
00244.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           16.725                  31                      65,496          381
00244.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            16.725                  12                      26,035          153
00244.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           16.725                  15                      32,089          185
00244.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            16.725                  18                      36,888          211
00244.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           16.725                  17                      34,546          198
00244.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             16.725                  9                       19,427          116
00244.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            16.725                  9                       18,272          110
00244.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           16.725                  10                      20,886          125
00244.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            16.725                  17                      36,034          207
00244.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           16.725                  15                      31,220          181
00244.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         16.725                  10                      21,457          128
00244.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        16.725                  16                      33,045          191
00244.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           16.725                  14                      29,167          170
00244.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          16.725                  40                      82,893          469
00244.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           16.725                  79                      165,330         923
00244.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            16.725                  75                      156,469         877
00244.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           16.725                  76                      158,369         886
00244.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            16.725                  69                      144,139         808
00244.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           16.725                  70                      146,275         821
00244.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          16.725                  0                       70              7
00244.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           16.725                  0                       70              7
00244.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            16.725                  0                       70              7
00244.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           16.725                  0                       70              7
00244.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            16.725                  0                       70              7
00244.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           16.725                  0                       70              7
00244.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          16.725                  0                       70              7
00244.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            16.725                  0                       70              7
00244.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           16.725                  0                       70              7
00244.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            16.725                  0                       70              7
00244.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           16.725                  0                       70              7
00244.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           16.725                  194                     405,504         2,376
00244.M2TS      6912 (0x1B00)   0xEA            VC-1                                    16.725                  39                      81,792          741
00231.M2TS      4113 (0x1011)   0xEA            VC-1                                    117.284                 14,979                  219,593,545     1,195,151
00231.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          117.284                 769                     11,272,192      66,048
00231.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           117.284                 4,191                   61,440,608      352,227
00231.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            117.284                 769                     11,272,192      66,048
00231.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           117.284                 769                     11,272,192      66,048
00231.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            117.284                 769                     11,272,192      66,048
00231.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           117.284                 769                     11,272,192      66,048
00231.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           117.284                 192                     2,818,560       18,350
00231.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          117.284                 41                      597,627         3,470
00231.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           117.284                 82                      1,204,356       6,834
00231.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            117.284                 86                      1,257,168       7,120
00231.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           117.284                 75                      1,101,753       6,275
00231.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            117.284                 84                      1,234,729       6,993
00231.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           117.284                 79                      1,155,725       6,561
00231.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             117.284                 48                      699,874         4,077
00231.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            117.284                 30                      437,732         2,636
00231.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           117.284                 58                      857,251         4,937
00231.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            117.284                 57                      835,630         4,819
00231.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           117.284                 48                      703,964         4,094
00231.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         117.284                 50                      733,280         4,249
00231.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        117.284                 60                      882,464         5,077
00231.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           117.284                 44                      646,599         3,780
00231.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          117.284                 37                      545,781         3,087
00231.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           117.284                 60                      879,377         4,947
00231.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            117.284                 54                      792,896         4,477
00231.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           117.284                 55                      807,697         4,556
00231.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            117.284                 63                      916,512         5,149
00231.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           117.284                 51                      747,280         4,232
00231.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          117.284                 0                       70              7
00231.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           117.284                 0                       70              7
00231.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            117.284                 0                       70              7
00231.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           117.284                 0                       70              7
00231.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            117.284                 0                       70              7
00231.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           117.284                 0                       70              7
00231.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          117.284                 0                       70              7
00231.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            117.284                 0                       70              7
00231.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           117.284                 0                       70              7
00231.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            117.284                 0                       70              7
00231.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           117.284                 0                       70              7
00231.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           117.284                 192                     2,818,048       16,512
00231.M2TS      6912 (0x1B00)   0xEA            VC-1                                    117.284                 39                      570,896         5,166
00245.M2TS      4113 (0x1011)   0xEA            VC-1                                    123.540                 15,009                  231,769,039     1,261,407
00245.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          123.540                 769                     11,872,256      69,564
00245.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           123.540                 4,130                   63,775,672      365,846
00245.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            123.540                 769                     11,872,256      69,564
00245.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           123.540                 769                     11,872,256      69,564
00245.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            123.540                 769                     11,872,256      69,564
00245.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           123.540                 769                     11,872,256      69,564
00245.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           123.540                 192                     2,968,320       19,325
00245.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          123.540                 24                      368,505         2,189
00245.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           123.540                 51                      791,335         4,529
00245.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            123.540                 43                      659,775         3,802
00245.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           123.540                 45                      700,583         4,022
00245.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            123.540                 49                      755,851         4,322
00245.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           123.540                 47                      728,577         4,173
00245.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             123.540                 28                      429,315         2,537
00245.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            123.540                 19                      291,663         1,784
00245.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           123.540                 33                      505,723         2,949
00245.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            123.540                 35                      534,525         3,098
00245.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           123.540                 30                      459,728         2,700
00245.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         123.540                 29                      445,929         2,624
00245.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        123.540                 35                      543,559         3,153
00245.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           123.540                 26                      398,465         2,373
00245.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          123.540                 38                      585,032         3,306
00245.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           123.540                 65                      1,004,275       5,645
00245.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            123.540                 59                      908,965         5,128
00245.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           123.540                 58                      895,809         5,055
00245.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            123.540                 67                      1,038,262       5,827
00245.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           123.540                 60                      930,882         5,248
00245.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          123.540                 0                       70              7
00245.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           123.540                 0                       70              7
00245.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            123.540                 0                       70              7
00245.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           123.540                 0                       70              7
00245.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            123.540                 0                       70              7
00245.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           123.540                 0                       70              7
00245.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          123.540                 0                       70              7
00245.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            123.540                 0                       70              7
00245.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           123.540                 0                       70              7
00245.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            123.540                 0                       70              7
00245.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           123.540                 0                       70              7
00245.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           123.540                 192                     2,969,600       17,400
00245.M2TS      6912 (0x1B00)   0xEA            VC-1                                    123.540                 199                     3,071,239       18,850
00232.M2TS      4113 (0x1011)   0xEA            VC-1                                    35.244                  15,008                  66,114,774      359,836
00232.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          35.244                  771                     3,395,584       19,896
00232.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           35.244                  3,805                   16,761,284      96,580
00232.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            35.244                  771                     3,395,584       19,896
00232.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           35.244                  771                     3,395,584       19,896
00232.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            35.244                  771                     3,395,584       19,896
00232.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           35.244                  771                     3,395,584       19,896
00232.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           35.244                  193                     849,408         5,530
00232.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          35.244                  26                      114,794         669
00232.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           35.244                  45                      197,999         1,118
00232.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            35.244                  51                      222,614         1,260
00232.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           35.244                  46                      201,522         1,137
00232.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            35.244                  43                      188,613         1,067
00232.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           35.244                  47                      206,243         1,170
00232.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             35.244                  40                      175,565         996
00232.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            35.244                  20                      88,764          523
00232.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           35.244                  36                      157,782         900
00232.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            35.244                  40                      174,849         993
00232.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           35.244                  36                      157,973         902
00232.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         35.244                  33                      146,360         837
00232.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        35.244                  44                      193,042         1,101
00232.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           35.244                  29                      129,676         740
00232.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          35.244                  40                      174,617         994
00232.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           35.244                  64                      281,551         1,590
00232.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            35.244                  52                      229,271         1,307
00232.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           35.244                  51                      226,647         1,293
00232.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            35.244                  71                      312,603         1,759
00232.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           35.244                  55                      242,341         1,377
00232.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          35.244                  0                       70              7
00232.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           35.244                  0                       70              7
00232.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            35.244                  0                       70              7
00232.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           35.244                  0                       70              7
00232.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            35.244                  0                       70              7
00232.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           35.244                  0                       70              7
00232.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          35.244                  0                       70              7
00232.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            35.244                  0                       70              7
00232.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           35.244                  0                       70              7
00232.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            35.244                  0                       70              7
00232.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           35.244                  0                       70              7
00232.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           35.244                  193                     849,920         4,980
00232.M2TS      6912 (0x1B00)   0xEA            VC-1                                    35.244                  39                      172,463         1,559
00246.M2TS      4113 (0x1011)   0xEA            VC-1                                    433.308                 15,005                  812,742,318     4,423,379
00246.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          433.308                 768                     41,610,240      243,810
00246.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           433.308                 3,620                   196,083,896     1,133,274
00246.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            433.308                 768                     41,610,240      243,810
00246.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           433.308                 768                     41,610,240      243,810
00246.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            433.308                 768                     41,610,240      243,810
00246.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           433.308                 768                     41,610,240      243,810
00246.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           433.308                 192                     10,402,560      67,725
00246.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          433.308                 29                      1,551,930       9,038
00246.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           433.308                 46                      2,510,048       14,381
00246.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            433.308                 48                      2,583,255       14,764
00246.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           433.308                 45                      2,419,980       13,889
00246.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            433.308                 48                      2,575,734       14,717
00246.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           433.308                 45                      2,420,234       13,881
00246.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             433.308                 33                      1,813,061       10,530
00246.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            433.308                 21                      1,128,115       6,781
00246.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           433.308                 37                      1,979,589       11,435
00246.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            433.308                 38                      2,083,602       12,004
00246.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           433.308                 34                      1,820,739       10,565
00246.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         433.308                 33                      1,779,485       10,334
00246.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        433.308                 39                      2,127,603       12,249
00246.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           433.308                 29                      1,597,551       9,346
00246.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          433.308                 38                      2,067,701       11,702
00246.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           433.308                 63                      3,395,912       19,090
00246.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            433.308                 56                      3,041,860       17,171
00246.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           433.308                 59                      3,172,079       17,877
00246.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            433.308                 63                      3,398,790       19,108
00246.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           433.308                 54                      2,912,481       16,469
00246.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          433.308                 14                      747,965         4,298
00246.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           433.308                 20                      1,100,439       6,252
00246.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            433.308                 19                      1,043,188       5,944
00246.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           433.308                 20                      1,079,036       6,138
00246.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            433.308                 22                      1,203,852       6,818
00246.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           433.308                 20                      1,087,118       6,181
00246.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          433.308                 0                       7,899           49
00246.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            433.308                 0                       70              7
00246.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           433.308                 0                       21,847          126
00246.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            433.308                 0                       70              7
00246.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           433.308                 0                       24,725          141
00246.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           433.308                 192                     10,403,840      60,960
00246.M2TS      6912 (0x1B00)   0xEA            VC-1                                    433.308                 865                     46,874,710      261,977
00233.M2TS      4113 (0x1011)   0xEA            VC-1                                    30.572                  14,962                  57,176,846      311,191
00233.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          30.572                  771                     2,947,072       17,268
00233.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           30.572                  3,843                   14,687,992      84,578
00233.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            30.572                  771                     2,947,072       17,268
00233.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           30.572                  771                     2,947,072       17,268
00233.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            30.572                  771                     2,947,072       17,268
00233.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           30.572                  771                     2,947,072       17,268
00233.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           30.572                  193                     737,280         4,800
00233.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          30.572                  19                      74,386          461
00233.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           30.572                  39                      148,786         871
00233.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            30.572                  30                      113,590         673
00233.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           30.572                  30                      116,116         686
00233.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            30.572                  40                      151,515         879
00233.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           30.572                  35                      134,747         789
00233.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             30.572                  26                      97,835          586
00233.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            30.572                  18                      70,374          436
00233.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           30.572                  33                      125,427         738
00233.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            30.572                  31                      118,191         697
00233.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           30.572                  27                      104,355         621
00233.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         30.572                  28                      107,773         641
00233.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        30.572                  27                      103,594         620
00233.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           30.572                  24                      93,480          565
00233.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          30.572                  34                      128,427         734
00233.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           30.572                  56                      212,169         1,191
00233.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            30.572                  46                      174,859         989
00233.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           30.572                  58                      220,003         1,234
00233.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            30.572                  51                      194,671         1,098
00233.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           30.572                  57                      217,368         1,222
00233.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          30.572                  0                       70              7
00233.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           30.572                  0                       70              7
00233.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            30.572                  0                       70              7
00233.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           30.572                  0                       70              7
00233.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            30.572                  0                       70              7
00233.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           30.572                  0                       70              7
00233.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          30.572                  0                       70              7
00233.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            30.572                  0                       70              7
00233.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           30.572                  0                       70              7
00233.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            30.572                  0                       70              7
00233.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           30.572                  0                       70              7
00233.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           30.572                  193                     737,280         4,320
00233.M2TS      6912 (0x1B00)   0xEA            VC-1                                    30.572                  39                      149,268         1,351
00247.M2TS      4113 (0x1011)   0xEA            VC-1                                    2623.162                15,094                  4,949,409,737   26,936,798
00247.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          2623.162                768                     251,836,416     1,475,604
00247.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           2623.162                3,999                   1,311,378,528   7,536,556
00247.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            2623.162                768                     251,836,416     1,475,604
00247.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           2623.162                768                     251,836,416     1,475,604
00247.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            2623.162                768                     251,836,416     1,475,604
00247.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           2623.162                768                     251,836,416     1,475,604
00247.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           2623.162                192                     62,959,104      409,890
00247.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          2623.162                25                      8,103,251       47,349
00247.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2623.162                47                      15,247,362      87,275
00247.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            2623.162                47                      15,374,052      87,842
00247.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           2623.162                44                      14,300,769      81,934
00247.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            2623.162                47                      15,354,437      87,567
00247.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           2623.162                45                      14,844,575      84,842
00247.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             2623.162                29                      9,572,711       55,733
00247.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            2623.162                19                      6,146,601       37,231
00247.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           2623.162                34                      11,260,123      65,092
00247.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            2623.162                33                      10,835,322      62,785
00247.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           2623.162                30                      9,803,894       57,182
00247.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         2623.162                29                      9,556,909       55,792
00247.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        2623.162                35                      11,473,492      66,162
00247.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           2623.162                26                      8,623,548       50,700
00247.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          2623.162                40                      13,033,509      73,978
00247.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           2623.162                70                      23,010,580      129,749
00247.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            2623.162                61                      20,053,422      113,691
00247.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           2623.162                62                      20,313,531      115,117
00247.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            2623.162                70                      22,853,580      128,902
00247.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           2623.162                61                      20,019,482      113,525
00247.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          2623.162                17                      5,666,523       32,817
00247.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           2623.162                29                      9,490,224       54,113
00247.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            2623.162                25                      8,343,589       47,928
00247.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           2623.162                26                      8,412,406       48,306
00247.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            2623.162                30                      9,942,533       56,605
00247.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           2623.162                26                      8,423,766       48,339
00247.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          2623.162                1                       365,759         2,104
00247.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            2623.162                1                       430,102         2,442
00247.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           2623.162                1                       453,829         2,580
00247.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            2623.162                1                       470,049         2,666
00247.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           2623.162                2                       503,545         2,856
00247.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           2623.162                192                     62,959,616      368,904
00247.M2TS      6912 (0x1B00)   0xEA            VC-1                                    2623.162                1,678                   550,276,440     3,031,881
00234.M2TS      4113 (0x1011)   0xEA            VC-1                                    54.221                  12,509                  84,783,758      461,597
00234.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          54.221                  770                     5,217,280       30,570
00234.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           54.221                  4,831                   32,741,044      186,392
00234.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            54.221                  770                     5,217,280       30,570
00234.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           54.221                  770                     5,217,280       30,570
00234.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            54.221                  770                     5,217,280       30,570
00234.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           54.221                  770                     5,217,280       30,570
00234.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           54.221                  193                     1,304,832       8,495
00234.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          54.221                  0                       70              7
00234.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           54.221                  0                       70              7
00234.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            54.221                  0                       70              7
00234.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           54.221                  0                       70              7
00234.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            54.221                  0                       70              7
00234.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           54.221                  0                       70              7
00234.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             54.221                  0                       70              7
00234.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            54.221                  0                       70              7
00234.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           54.221                  0                       70              7
00234.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            54.221                  0                       70              7
00234.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           54.221                  0                       70              7
00234.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         54.221                  0                       70              7
00234.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        54.221                  0                       70              7
00234.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           54.221                  0                       70              7
00234.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          54.221                  47                      321,860         1,830
00234.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           54.221                  70                      473,866         2,678
00234.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            54.221                  66                      450,461         2,552
00234.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           54.221                  68                      460,679         2,606
00234.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            54.221                  75                      506,016         2,852
00234.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           54.221                  60                      405,558         2,306
00234.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          54.221                  0                       70              7
00234.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           54.221                  0                       70              7
00234.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            54.221                  0                       70              7
00234.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           54.221                  0                       70              7
00234.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            54.221                  0                       70              7
00234.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           54.221                  0                       70              7
00234.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          54.221                  0                       70              7
00234.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            54.221                  0                       70              7
00234.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           54.221                  0                       70              7
00234.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            54.221                  0                       70              7
00234.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           54.221                  0                       70              7
00234.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           54.221                  192                     1,304,576       7,644
00234.M2TS      6912 (0x1B00)   0xEA            VC-1                                    54.221                  39                      264,514         2,393
00248.M2TS      4113 (0x1011)   0xEA            VC-1                                    433.224                 8,014                   433,984,222     2,364,925
00248.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          433.224                 768                     41,602,048      243,762
00248.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           433.224                 4,352                   235,653,452     1,348,301
00248.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            433.224                 768                     41,602,048      243,762
00248.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           433.224                 768                     41,602,048      243,762
00248.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            433.224                 768                     41,602,048      243,762
00248.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           433.224                 768                     41,602,048      243,762
00248.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           433.224                 192                     10,401,024      67,715
00248.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          433.224                 0                       70              7
00248.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           433.224                 0                       70              7
00248.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            433.224                 0                       70              7
00248.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           433.224                 0                       70              7
00248.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            433.224                 0                       70              7
00248.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           433.224                 0                       70              7
00248.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             433.224                 0                       70              7
00248.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            433.224                 0                       11,470          70
00248.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           433.224                 0                       70              7
00248.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            433.224                 0                       70              7
00248.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           433.224                 0                       70              7
00248.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         433.224                 0                       70              7
00248.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        433.224                 0                       17,819          104
00248.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           433.224                 0                       70              7
00248.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          433.224                 13                      681,405         3,882
00248.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           433.224                 19                      1,053,522       5,951
00248.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            433.224                 18                      975,907         5,529
00248.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           433.224                 19                      1,038,462       5,868
00248.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            433.224                 20                      1,080,356       6,098
00248.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           433.224                 18                      957,232         5,430
00248.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          433.224                 0                       70              7
00248.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           433.224                 0                       70              7
00248.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            433.224                 0                       70              7
00248.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           433.224                 0                       70              7
00248.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            433.224                 0                       70              7
00248.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           433.224                 0                       70              7
00248.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          433.224                 0                       70              7
00248.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            433.224                 0                       70              7
00248.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           433.224                 0                       70              7
00248.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            433.224                 0                       70              7
00248.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           433.224                 0                       70              7
00248.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           433.224                 192                     10,401,792      60,948
00248.M2TS      6912 (0x1B00)   0xEA            VC-1                                    433.224                 39                      2,103,411       19,048
Code:
        Total   Video
00001.MPLS                                                      VC-1    2:55:45 35,042,353,152  49,500,968,583  26.58   14.62   DTS-HD Master 5.1 3996Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     AMER_GANG_G51
Disc Size:      49,500,968,583 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:55:45 (h:m:s)
Total Bitrate:          26.58 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
VC-1 Video              14617 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              1035 kbps           480p / 23.976 fps / 16:9 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3996 kbps       5.1 / 48 kHz / 3996 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
* DTS Audio                     French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* DTS Audio                     German          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* DTS Audio                     Italian         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* DTS Audio                     Japanese        768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* DTS Audio                     Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
DTS Express                     English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
* Presentation Graphics         English         56.857 kbps
Presentation Graphics           English         44.405 kbps
Presentation Graphics           English         18.186 kbps
Presentation Graphics           Chinese         25.072 kbps
Presentation Graphics           Danish          31.953 kbps
Presentation Graphics           Dutch           28.306 kbps
Presentation Graphics           Finnish         28.816 kbps
Presentation Graphics           French          42.898 kbps
* Presentation Graphics         French          50.642 kbps
Presentation Graphics           French          16.392 kbps
* Presentation Graphics         French          0.486 kbps
Presentation Graphics           German          43.788 kbps
* Presentation Graphics         German          56.734 kbps
Presentation Graphics           German          18.896 kbps
* Presentation Graphics         German          0.535 kbps
Presentation Graphics           Italian         40.594 kbps
* Presentation Graphics         Italian         50.467 kbps
Presentation Graphics           Italian         16.450 kbps
* Presentation Graphics         Italian         0.549 kbps
Presentation Graphics           Japanese        23.057 kbps
* Presentation Graphics         Japanese        33.546 kbps
Presentation Graphics           Japanese        11.763 kbps
* Presentation Graphics         Japanese        0.588 kbps
Presentation Graphics           Korean          18.448 kbps
Presentation Graphics           Norwegian       28.112 kbps
Presentation Graphics           Portuguese      33.074 kbps
Presentation Graphics           Spanish         41.789 kbps
* Presentation Graphics         Spanish         49.599 kbps
Presentation Graphics           Spanish         16.497 kbps
* Presentation Graphics         Spanish         0.668 kbps
Presentation Graphics           Swedish         32.257 kbps
FILES:
00235.M2TS      0:00:00.000     0:19:49.396     3,979,481,088   26,766
00249.M2TS      0:19:49.396     0:01:53.196     363,626,496     25,699
00236.M2TS      0:21:42.592     0:23:26.571     4,788,185,088   27,233
00250.M2TS      0:45:09.164     0:01:49.943     315,002,880     22,921
00237.M2TS      0:46:59.107     0:07:29.574     1,527,545,856   27,182
00251.M2TS      0:54:28.682     0:00:37.454     117,239,808     25,042
00238.M2TS      0:55:06.136     0:05:33.249     1,182,222,336   28,380
00252.M2TS      1:00:39.385     0:02:16.886     441,219,072     25,786
00239.M2TS      1:02:56.272     0:00:43.877     143,929,344     26,242
00253.M2TS      1:03:40.149     0:04:22.553     767,244,288     23,378
00240.M2TS      1:08:02.703     0:01:34.594     319,838,208     27,049
00254.M2TS      1:09:37.298     0:02:22.433     462,120,960     25,956
00241.M2TS      1:11:59.731     0:02:02.080     435,879,936     28,563
00255.M2TS      1:14:01.812     0:02:23.309     431,118,336     24,066
00242.M2TS      1:16:25.122     0:23:31.410     4,862,312,448   27,560
00256.M2TS      1:39:56.532     0:01:05.398     216,158,208     26,442
00243.M2TS      1:41:01.930     0:02:56.009     573,069,312     26,047
00257.M2TS      1:43:57.939     0:01:05.106     189,130,752     23,239
00244.M2TS      1:45:03.046     0:00:16.850     54,054,912      25,664
00258.M2TS      1:45:19.896     0:02:25.103     457,918,464     25,246
00245.M2TS      1:47:45.000     0:02:03.665     405,245,952     26,216
00259.M2TS      1:49:48.665     0:02:13.925     449,820,672     26,870
00246.M2TS      1:52:02.590     0:07:13.433     1,437,462,528   26,532
00260.M2TS      1:59:16.023     0:01:49.818     316,403,712     23,049
00247.M2TS      2:01:05.841     0:43:43.287     9,154,762,752   27,918
00261.M2TS      2:44:49.129     0:03:43.431     666,021,888     23,847
00248.M2TS      2:48:32.560     0:07:13.349     985,337,856     18,190
CHAPTERS:
1               0:00:00.000     0:06:48.950     14,170 kbps     22,360 kbps     00:02:20.515    20,362 kbps     00:02:16.511    20,062 kbps     00:02:11.506    74,728 bytes    262,708 bytes   00:02:21.432
2               0:06:48.950     0:07:18.646     15,893 kbps     25,365 kbps     00:13:35.940    24,992 kbps     00:13:32.770    24,741 kbps     00:13:27.515    82,856 bytes    222,973 bytes   00:08:51.155
3               0:14:07.596     0:11:35.569     15,244 kbps     26,846 kbps     00:23:07.594    25,214 kbps     00:14:14.603    24,661 kbps     00:14:14.061    79,473 bytes    237,443 bytes   00:23:10.597
4               0:25:43.166     0:06:37.105     14,275 kbps     19,942 kbps     00:32:01.961    18,604 kbps     00:28:54.399    17,666 kbps     00:31:55.246    74,425 bytes    218,851 bytes   00:25:49.172
5               0:32:20.271     0:05:13.646     16,014 kbps     25,448 kbps     00:35:08.147    23,848 kbps     00:35:02.517    23,662 kbps     00:34:59.847    83,488 bytes    245,454 bytes   00:35:13.861
6               0:37:33.918     0:06:15.291     16,312 kbps     29,914 kbps     00:41:11.218    27,312 kbps     00:41:09.341    25,932 kbps     00:41:09.383    85,042 bytes    217,302 bytes   00:41:11.260
7               0:43:49.209     0:07:36.914     14,286 kbps     22,816 kbps     00:43:56.884    18,991 kbps     00:43:55.090    17,910 kbps     00:50:23.145    74,480 bytes    242,930 bytes   00:48:31.199
8               0:51:26.124     0:05:55.730     14,582 kbps     21,355 kbps     00:56:29.010    17,536 kbps     00:54:03.114    16,984 kbps     00:53:27.996    76,024 bytes    196,364 bytes   00:56:01.149
9               0:57:21.855     0:18:09.338     13,926 kbps     23,417 kbps     00:57:53.553    20,383 kbps     00:57:49.632    19,502 kbps     00:57:34.409    72,603 bytes    274,284 bytes   01:06:24.522
10              1:15:31.193     0:05:22.530     14,805 kbps     27,377 kbps     01:18:52.060    19,692 kbps     01:18:52.143    19,134 kbps     01:18:49.099    77,185 bytes    253,544 bytes   01:18:56.147
11              1:20:53.723     0:08:07.862     14,433 kbps     20,600 kbps     01:24:00.743    19,432 kbps     01:24:00.660    18,946 kbps     01:23:57.991    75,248 bytes    201,809 bytes   01:25:32.502
12              1:29:01.586     0:08:20.917     16,617 kbps     37,505 kbps     01:36:53.932    31,026 kbps     01:34:46.472    28,879 kbps     01:34:45.304    86,632 bytes    264,293 bytes   01:34:47.139
13              1:37:22.503     0:06:39.482     15,178 kbps     29,924 kbps     01:40:29.022    28,459 kbps     01:40:28.605    28,405 kbps     01:40:28.605    79,129 bytes    254,996 bytes   01:40:45.455
14              1:44:01.985     0:11:32.233     14,580 kbps     26,032 kbps     01:45:11.721    25,147 kbps     01:45:27.654    24,741 kbps     01:45:26.069    76,016 bytes    256,003 bytes   01:45:11.930
15              1:55:34.218     0:09:25.231     15,157 kbps     23,227 kbps     02:03:29.360    22,475 kbps     02:03:26.231    21,830 kbps     02:03:21.268    79,023 bytes    212,442 bytes   02:04:57.990
16              2:04:59.450     0:08:01.522     14,527 kbps     20,301 kbps     02:11:23.125    19,297 kbps     02:11:21.665    18,876 kbps     02:11:19.287    75,738 bytes    212,162 bytes   02:11:19.329
17              2:13:00.972     0:07:07.885     15,310 kbps     20,400 kbps     02:15:28.161    18,489 kbps     02:15:26.910    17,659 kbps     02:15:12.020    79,817 bytes    213,369 bytes   02:16:45.029
18              2:20:08.858     0:11:44.078     15,400 kbps     21,944 kbps     02:31:37.212    19,670 kbps     02:31:35.711    19,277 kbps     02:31:29.788    80,287 bytes    184,133 bytes   02:26:27.486
19              2:31:52.936     0:16:08.884     14,786 kbps     21,273 kbps     02:45:20.577    20,070 kbps     02:45:19.325    17,853 kbps     02:45:18.324    77,088 bytes    253,043 bytes   02:45:30.378
20              2:48:01.821     0:07:44.088     7,560 kbps      34,398 kbps     02:55:39.987    22,827 kbps     02:55:36.233    18,177 kbps     02:54:34.338    40,068 bytes    472,552 bytes   02:54:39.927
STREAM DIAGNOSTICS:
00235.M2TS      4113 (0x1011)   0xEA            VC-1                                    1189.271                15,382                  2,286,633,303   12,444,556
00235.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          1189.271                768                     114,182,144     669,036
00235.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1189.271                3,934                   584,884,416     3,364,063
00235.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            1189.271                768                     114,182,144     669,036
00235.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           1189.271                768                     114,182,144     669,036
00235.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            1189.271                768                     114,182,144     669,036
00235.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           1189.271                768                     114,182,144     669,036
00235.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           1189.271                192                     28,545,792      185,845
00235.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1189.271                23                      3,375,806       19,833
00235.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1189.271                42                      6,312,104       36,155
00235.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1189.271                41                      6,138,066       35,130
00235.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           1189.271                39                      5,847,444       33,479
00235.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            1189.271                42                      6,292,516       35,883
00235.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1189.271                40                      5,926,447       33,927
00235.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             1189.271                25                      3,738,649       21,814
00235.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            1189.271                17                      2,507,748       15,203
00235.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           1189.271                31                      4,558,963       26,369
00235.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            1189.271                31                      4,625,657       26,766
00235.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           1189.271                27                      4,027,651       23,460
00235.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         1189.271                27                      3,968,405       23,165
00235.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        1189.271                31                      4,534,596       26,192
00235.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           1189.271                23                      3,416,460       20,160
00235.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          1189.271                43                      6,407,647       36,247
00235.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           1189.271                72                      10,639,065      60,397
00235.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            1189.271                63                      9,414,339       53,771
00235.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           1189.271                63                      9,293,384       53,106
00235.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            1189.271                70                      10,430,180      59,274
00235.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           1189.271                63                      9,326,166       53,288
00235.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          1189.271                6                       921,035         5,313
00235.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           1189.271                9                       1,358,694       7,794
00235.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            1189.271                9                       1,273,732       7,356
00235.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           1189.271                9                       1,320,930       7,614
00235.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            1189.271                9                       1,392,722       7,992
00235.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           1189.271                9                       1,264,386       7,293
00235.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          1189.271                0                       57,430          350
00235.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            1189.271                0                       36,476          213
00235.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           1189.271                0                       40,862          243
00235.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            1189.271                0                       37,185          215
00235.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           1189.271                0                       71,384          423
00235.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           1189.271                192                     28,547,072      167,268
00235.M2TS      6912 (0x1B00)   0xEA            VC-1                                    1189.271                505                     75,127,222      428,570
00249.M2TS      4113 (0x1011)   0xEA            VC-1                                    113.071                 13,009                  183,863,923     1,000,921
00249.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          113.071                 769                     10,867,712      63,678
00249.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           113.071                 3,959                   55,955,676      321,734
00249.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            113.071                 769                     10,867,712      63,678
00249.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           113.071                 769                     10,867,712      63,678
00249.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            113.071                 769                     10,867,712      63,678
00249.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           113.071                 769                     10,867,712      63,678
00249.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           113.071                 192                     2,717,184       17,690
00249.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          113.071                 27                      375,461         2,170
00249.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           113.071                 41                      584,250         3,331
00249.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            113.071                 48                      672,202         3,812
00249.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           113.071                 40                      559,119         3,195
00249.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            113.071                 45                      631,658         3,588
00249.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           113.071                 46                      646,869         3,673
00249.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             113.071                 35                      494,583         2,844
00249.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            113.071                 24                      342,849         2,017
00249.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           113.071                 37                      529,386         3,032
00249.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            113.071                 37                      517,824         2,970
00249.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           113.071                 34                      483,916         2,784
00249.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         113.071                 35                      494,568         2,844
00249.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        113.071                 39                      544,191         3,111
00249.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           113.071                 25                      348,099         2,024
00249.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          113.071                 0                       70              7
00249.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           113.071                 0                       70              7
00249.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            113.071                 0                       70              7
00249.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           113.071                 0                       70              7
00249.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            113.071                 0                       70              7
00249.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           113.071                 0                       70              7
00249.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          113.071                 21                      301,557         1,791
00249.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           113.071                 36                      514,560         2,988
00249.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            113.071                 30                      428,055         2,512
00249.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           113.071                 32                      445,759         2,607
00249.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            113.071                 32                      451,606         2,644
00249.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           113.071                 34                      484,891         2,823
00249.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          113.071                 0                       70              7
00249.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            113.071                 0                       70              7
00249.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           113.071                 0                       70              7
00249.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            113.071                 0                       70              7
00249.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           113.071                 0                       70              7
00249.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           113.071                 192                     2,717,696       15,924
00249.M2TS      6912 (0x1B00)   0xEA            VC-1                                    113.071                 2,027                   28,643,492      157,382
00236.M2TS      4113 (0x1011)   0xEA            VC-1                                    1406.447                15,347                  2,698,166,877   14,684,338
00236.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          1406.447                768                     135,031,808     791,202
00236.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1406.447                4,101                   720,913,612     4,137,266
00236.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            1406.447                768                     135,031,808     791,202
00236.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           1406.447                768                     135,031,808     791,202
00236.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            1406.447                768                     135,031,808     791,202
00236.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           1406.447                768                     135,031,808     791,202
00236.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           1406.447                192                     33,758,208      219,780
00236.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          1406.447                22                      3,877,293       22,784
00236.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1406.447                42                      7,315,104       41,965
00236.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            1406.447                41                      7,289,070       41,719
00236.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           1406.447                38                      6,677,665       38,379
00236.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            1406.447                41                      7,152,997       40,916
00236.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1406.447                39                      6,787,685       38,985
00236.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             1406.447                26                      4,523,919       26,417
00236.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            1406.447                17                      2,987,755       18,123
00236.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           1406.447                29                      5,117,727       29,646
00236.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            1406.447                30                      5,281,195       30,623
00236.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           1406.447                26                      4,484,270       26,264
00236.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         1406.447                25                      4,419,390       25,878
00236.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        1406.447                30                      5,231,806       30,281
00236.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           1406.447                23                      4,046,088       23,886
00236.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          1406.447                43                      7,485,904       42,402
00236.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           1406.447                69                      12,196,766      69,016
00236.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            1406.447                62                      10,976,241      62,412
00236.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           1406.447                63                      11,120,220      63,173
00236.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            1406.447                70                      12,280,018      69,474
00236.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           1406.447                60                      10,572,028      60,207
00236.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          1406.447                9                       1,630,644       9,409
00236.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           1406.447                12                      2,057,409       11,802
00236.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            1406.447                11                      1,921,611       11,099
00236.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           1406.447                11                      1,921,453       11,102
00236.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            1406.447                12                      2,172,662       12,465
00236.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           1406.447                11                      1,871,518       10,814
00236.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          1406.447                1                       175,174         1,050
00236.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            1406.447                0                       85,220          505
00236.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           1406.447                1                       122,791         731
00236.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            1406.447                1                       129,715         769
00236.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           1406.447                1                       146,905         876
00236.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           1406.447                192                     33,759,232      197,808
00236.M2TS      6912 (0x1B00)   0xEA            VC-1                                    1406.447                821                     144,352,389     807,983
00250.M2TS      4113 (0x1011)   0xEA            VC-1                                    109.818                 13,007                  178,545,186     971,966
00250.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          109.818                 769                     10,555,392      61,848
00250.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           109.818                 3,627                   49,789,612      287,633
00250.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            109.818                 769                     10,555,392      61,848
00250.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           109.818                 769                     10,555,392      61,848
00250.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            109.818                 769                     10,555,392      61,848
00250.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           109.818                 769                     10,555,392      61,848
00250.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           109.818                 192                     2,638,848       17,180
00250.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          109.818                 17                      239,571         1,407
00250.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           109.818                 33                      456,615         2,624
00250.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            109.818                 29                      401,211         2,307
00250.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           109.818                 27                      371,008         2,141
00250.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            109.818                 34                      460,705         2,629
00250.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           109.818                 28                      386,788         2,228
00250.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             109.818                 28                      381,889         2,202
00250.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            109.818                 19                      263,791         1,559
00250.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           109.818                 28                      379,224         2,188
00250.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            109.818                 26                      350,822         2,035
00250.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           109.818                 25                      343,714         1,995
00250.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         109.818                 26                      355,710         2,059
00250.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        109.818                 30                      411,133         2,363
00250.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           109.818                 20                      270,287         1,595
00250.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          109.818                 0                       70              7
00250.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           109.818                 0                       70              7
00250.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            109.818                 0                       70              7
00250.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           109.818                 0                       70              7
00250.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            109.818                 0                       70              7
00250.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           109.818                 0                       70              7
00250.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          109.818                 0                       70              7
00250.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           109.818                 0                       70              7
00250.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            109.818                 0                       70              7
00250.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           109.818                 0                       70              7
00250.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            109.818                 0                       70              7
00250.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           109.818                 0                       70              7
00250.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          109.818                 0                       70              7
00250.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            109.818                 0                       70              7
00250.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           109.818                 0                       70              7
00250.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            109.818                 0                       70              7
00250.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           109.818                 0                       70              7
00250.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           109.818                 192                     2,639,872       15,468
00250.M2TS      6912 (0x1B00)   0xEA            VC-1                                    109.818                 39                      533,679         4,833
00237.M2TS      4113 (0x1011)   0xEA            VC-1                                    449.449                 15,007                  843,129,674     4,588,690
00237.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          449.449                 768                     43,159,552      252,888
00237.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           449.449                 3,919                   220,174,536     1,266,627
00237.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            449.449                 768                     43,159,552      252,888
00237.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           449.449                 768                     43,159,552      252,888
00237.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            449.449                 768                     43,159,552      252,888
00237.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           449.449                 768                     43,159,552      252,888
00237.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           449.449                 192                     10,790,400      70,250
00237.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          449.449                 30                      1,672,961       9,783
00237.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           449.449                 57                      3,185,523       18,299
00237.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            449.449                 54                      3,018,960       17,324
00237.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           449.449                 49                      2,745,929       15,832
00237.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            449.449                 54                      3,026,456       17,365
00237.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           449.449                 50                      2,823,712       16,243
00237.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             449.449                 33                      1,872,217       10,972
00237.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            449.449                 21                      1,196,130       7,280
00237.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           449.449                 38                      2,134,195       12,401
00237.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            449.449                 37                      2,103,275       12,230
00237.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           449.449                 32                      1,772,821       10,401
00237.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         449.449                 33                      1,854,562       10,874
00237.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        449.449                 37                      2,058,346       11,964
00237.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           449.449                 31                      1,754,923       10,329
00237.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          449.449                 41                      2,294,386       13,005
00237.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           449.449                 72                      4,057,652       22,929
00237.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            449.449                 66                      3,717,956       21,093
00237.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           449.449                 64                      3,582,507       20,357
00237.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            449.449                 72                      4,067,237       22,987
00237.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           449.449                 65                      3,638,938       20,669
00237.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          449.449                 15                      865,868         5,001
00237.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           449.449                 22                      1,216,246       6,917
00237.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            449.449                 20                      1,144,071       6,536
00237.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           449.449                 20                      1,098,127       6,293
00237.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            449.449                 23                      1,272,381       7,227
00237.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           449.449                 20                      1,100,523       6,290
00237.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          449.449                 1                       30,030          176
00237.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            449.449                 0                       19,040          110
00237.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           449.449                 1                       28,409          168
00237.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            449.449                 0                       26,231          157
00237.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           449.449                 0                       27,746          164
00237.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           449.449                 192                     10,790,912      63,228
00237.M2TS      6912 (0x1B00)   0xEA            VC-1                                    449.449                 1,094                   61,486,177      341,502
00251.M2TS      4113 (0x1011)   0xEA            VC-1                                    37.329                  13,013                  60,718,697      330,539
00251.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          37.329                  771                     3,596,288       21,072
00251.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           37.329                  3,696                   17,245,772      99,562
00251.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            37.329                  771                     3,596,288       21,072
00251.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           37.329                  771                     3,596,288       21,072
00251.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            37.329                  771                     3,596,288       21,072
00251.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           37.329                  771                     3,596,288       21,072
00251.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           37.329                  193                     899,328         5,855
00251.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          37.329                  10                      48,891          301
00251.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           37.329                  18                      83,054          494
00251.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            37.329                  12                      57,098          346
00251.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           37.329                  12                      53,998          327
00251.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            37.329                  16                      72,379          429
00251.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           37.329                  15                      71,330          430
00251.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             37.329                  13                      62,445          381
00251.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            37.329                  10                      47,854          302
00251.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           37.329                  13                      58,786          354
00251.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            37.329                  14                      63,392          380
00251.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           37.329                  15                      69,861          423
00251.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         37.329                  11                      53,616          327
00251.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        37.329                  15                      70,662          426
00251.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           37.329                  13                      62,702          381
00251.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          37.329                  0                       70              7
00251.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           37.329                  0                       70              7
00251.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            37.329                  0                       70              7
00251.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           37.329                  0                       70              7
00251.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            37.329                  0                       70              7
00251.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           37.329                  0                       70              7
00251.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          37.329                  22                      104,284         604
00251.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           37.329                  35                      164,281         928
00251.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            37.329                  34                      158,970         900
00251.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           37.329                  30                      137,858         784
00251.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            37.329                  36                      169,031         954
00251.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           37.329                  35                      162,905         920
00251.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          37.329                  0                       70              7
00251.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            37.329                  0                       70              7
00251.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           37.329                  0                       70              7
00251.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            37.329                  0                       70              7
00251.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           37.329                  0                       70              7
00251.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           37.329                  193                     899,072         5,268
00251.M2TS      6912 (0x1B00)   0xEA            VC-1                                    37.329                  2,025                   9,449,649       51,905
00238.M2TS      4113 (0x1011)   0xEA            VC-1                                    333.166                 14,998                  624,582,526     3,399,318
00238.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          333.166                 768                     31,992,832      187,458
00238.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           333.166                 4,123                   171,704,756     985,311
00238.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            333.166                 768                     31,992,832      187,458
00238.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           333.166                 768                     31,992,832      187,458
00238.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            333.166                 768                     31,992,832      187,458
00238.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           333.166                 768                     31,992,832      187,458
00238.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           333.166                 192                     7,998,720       52,075
00238.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          333.166                 23                      966,731         5,686
00238.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           333.166                 55                      2,297,351       13,120
00238.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            333.166                 51                      2,123,673       12,157
00238.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           333.166                 49                      2,032,768       11,628
00238.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            333.166                 51                      2,136,413       12,202
00238.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           333.166                 48                      1,988,521       11,391
00238.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             333.166                 29                      1,195,920       6,998
00238.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            333.166                 19                      777,084         4,723
00238.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           333.166                 35                      1,465,091       8,460
00238.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            333.166                 35                      1,456,208       8,421
00238.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           333.166                 29                      1,212,307       7,080
00238.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         333.166                 31                      1,297,135       7,574
00238.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        333.166                 35                      1,451,622       8,391
00238.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           333.166                 28                      1,148,384       6,750
00238.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          333.166                 44                      1,833,861       10,378
00238.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           333.166                 71                      2,973,763       16,798
00238.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            333.166                 65                      2,696,536       15,295
00238.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           333.166                 62                      2,565,658       14,584
00238.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            333.166                 72                      3,008,267       16,986
00238.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           333.166                 63                      2,628,587       14,923
00238.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          333.166                 22                      936,434         5,454
00238.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           333.166                 38                      1,565,256       8,959
00238.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            333.166                 32                      1,334,533       7,706
00238.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           333.166                 33                      1,369,861       7,906
00238.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            333.166                 39                      1,618,110       9,252
00238.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           333.166                 33                      1,364,274       7,866
00238.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          333.166                 0                       7,031           45
00238.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            333.166                 0                       70              7
00238.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           333.166                 0                       70              7
00238.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            333.166                 0                       70              7
00238.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           333.166                 0                       70              7
00238.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           333.166                 192                     7,999,488       46,872
00238.M2TS      6912 (0x1B00)   0xEA            VC-1                                    333.166                 2,016                   83,944,241      461,054
00252.M2TS      4113 (0x1011)   0xEA            VC-1                                    136.762                 13,005                  222,322,985     1,210,264
00252.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          136.762                 769                     13,142,016      77,004
00252.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           136.762                 3,963                   67,747,548      389,528
00252.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            136.762                 769                     13,142,016      77,004
00252.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           136.762                 769                     13,142,016      77,004
00252.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            136.762                 769                     13,142,016      77,004
00252.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           136.762                 769                     13,142,016      77,004
00252.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           136.762                 192                     3,285,504       21,390
00252.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          136.762                 23                      398,396         2,395
00252.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           136.762                 49                      845,513         4,904
00252.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            136.762                 42                      723,435         4,237
00252.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           136.762                 45                      764,129         4,460
00252.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            136.762                 50                      851,450         4,936
00252.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           136.762                 45                      768,839         4,484
00252.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             136.762                 38                      652,800         3,835
00252.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            136.762                 23                      396,801         2,414
00252.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           136.762                 41                      703,413         4,131
00252.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            136.762                 39                      667,041         3,932
00252.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           136.762                 39                      658,173         3,879
00252.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         136.762                 40                      675,502         3,981
00252.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        136.762                 44                      759,466         4,433
00252.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           136.762                 30                      506,080         2,999
00252.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          136.762                 0                       70              7
00252.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           136.762                 0                       70              7
00252.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            136.762                 0                       70              7
00252.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           136.762                 0                       70              7
00252.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            136.762                 0                       70              7
00252.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           136.762                 0                       70              7
00252.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          136.762                 24                      413,939         2,501
00252.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           136.762                 41                      697,875         4,063
00252.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            136.762                 44                      755,544         4,376
00252.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           136.762                 38                      655,152         3,833
00252.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            136.762                 41                      694,549         4,047
00252.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           136.762                 40                      676,959         3,951
00252.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          136.762                 0                       70              7
00252.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            136.762                 0                       70              7
00252.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           136.762                 0                       70              7
00252.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            136.762                 0                       70              7
00252.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           136.762                 0                       70              7
00252.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           136.762                 192                     3,287,040       19,260
00252.M2TS      6912 (0x1B00)   0xEA            VC-1                                    136.762                 2,009                   34,339,391      188,644
00239.M2TS      4113 (0x1011)   0xEA            VC-1                                    43.752                  15,017                  82,128,302      446,985
00239.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          43.752                  770                     4,212,736       24,684
00239.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           43.752                  3,798                   20,772,400      119,794
00239.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            43.752                  770                     4,212,736       24,684
00239.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           43.752                  770                     4,212,736       24,684
00239.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            43.752                  770                     4,212,736       24,684
00239.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           43.752                  770                     4,212,736       24,684
00239.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           43.752                  193                     1,053,696       6,860
00239.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          43.752                  27                      145,270         832
00239.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           43.752                  114                     625,027         3,544
00239.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            43.752                  94                      515,595         2,946
00239.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           43.752                  93                      510,499         2,918
00239.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            43.752                  96                      523,526         2,990
00239.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           43.752                  99                      540,946         3,091
00239.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             43.752                  56                      307,260         1,802
00239.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            43.752                  35                      189,652         1,158
00239.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           43.752                  54                      296,584         1,729
00239.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            43.752                  58                      317,343         1,854
00239.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           43.752                  58                      314,843         1,839
00239.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         43.752                  54                      298,037         1,743
00239.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        43.752                  58                      317,004         1,826
00239.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           43.752                  55                      299,573         1,759
00239.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          43.752                  53                      290,239         1,631
00239.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           43.752                  76                      414,879         2,343
00239.M2TS      4624 (0x1210)   0x90            PGS             fra (French)            43.752                  60                      329,925         1,882
00239.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           43.752                  64                      351,664         2,000
00239.M2TS      4626 (0x1212)   0x90            PGS             deu (German)            43.752                  80                      440,197         2,482
00239.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           43.752                  60                      328,478         1,874
00239.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          43.752                  0                       70              7
00239.M2TS      4629 (0x1215)   0x90            PGS             eng (English)           43.752                  0                       70              7
00239.M2TS      4630 (0x1216)   0x90            PGS             fra (French)            43.752                  0                       70              7
00239.M2TS      4631 (0x1217)   0x90            PGS             ita (Italian)           43.752                  0                       70              7
00239.M2TS      4632 (0x1218)   0x90            PGS             deu (German)            43.752                  0                       70              7
00239.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           43.752                  0                       70              7
00239.M2TS      4634 (0x121A)   0x90            PGS             jpn (Japanese)          43.752                  7                       36,730          206
00239.M2TS      4635 (0x121B)   0x90            PGS             fra (French)            43.752                  0                       70              7
00239.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           43.752                  0                       70              7
00239.M2TS      4637 (0x121D)   0x90            PGS             deu (German)            43.752                  0                       70              7
00239.M2TS      4638 (0x121E)   0x90            PGS             spa (Spanish)           43.752                  0                       70              7
00239.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           43.752                  193                     1,054,720       6,180
00239.M2TS      6912 (0x1B00)   0xEA            VC-1                                    43.752                  39                      212,985         1,929
00253.M2TS      4113 (0x1011)   0xEA            VC-1                                    262.429                 13,007                  426,686,798     2,322,729
00253.M2TS      4352 (0x1100)   0x82            DTS             jpn (Japanese)          262.429                 768                     25,205,760      147,690
00253.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           262.429                 4,204                   137,900,100     790,272
00253.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            262.429                 768                     25,205,760      147,690
00253.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           262.429                 768                     25,205,760      147,690
00253.M2TS      4356 (0x1104)   0x82            DTS             deu (German)            262.429                 768                     25,205,760      147,690
00253.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           262.429                 768                     25,205,760      147,690
00253.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           262.429                 192                     6,301,440       41,025
00253.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          262.429                 11                      357,215         2,107
00253.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           262.429                 21                      686,208         3,879
00253.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            262.429                 19                      619,194         3,525
00253.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           262.429                 18                      598,905         3,413
00253.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            262.429                 23                      738,924         4,174
00253.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           262.429                 19                      633,303         3,603
00253.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             262.429                 16
