NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 29 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #841 of 5106 Old 11-20-2009, 10:58 AM
DigitalfreakNYC's Avatar
Quoted: 127 Post(s)
How can you scan a disc without Anydvd? It won't let you.
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #842 of 5106 Old 11-20-2009, 12:53 PM
Stephen Dawson's Avatar
If you were referring to my figures above, you can't. The only non-AnyDVD 'scan' I did was a 'DIR /S' in a command window, for which you don't need AnyDVD of course.
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #843 of 5106 Old 11-20-2009, 02:02 PM - Thread Starter
Cinema Squid's Avatar
Well actually you sort of can in theory as of 0.5.3.
BDInfo should be able to at least pull up a disc when AnyDVD is disabled. It will complain that it can't read a stream file because it is copy-protected or corrupted while it's in the initial "Please wait while I scan the disc..." mode. However, if you click "No" when it asks if you want to continue scanning, it should at least show the playlists with some basic information including the disc size (but the full bitrate scan will not work).
Originally Posted by Phloyd View Post
These sorts of questions remind me of my 'idea' to create some kind of hash code that is derived from the non-AACS files on a disc (and possibly their creation date) so that each disc can have a unique identifier that is consistent with AnyDVD enabled or not.
This kind of thing, while unlikely to be foolproof, should allow us to see if a disc has authoring differences from another, assuming that a re-encode would also require changes in non-AACS protected files.
I definitely like the idea, I just haven't thought about it much since you mentioned it before.
SlySoft's "Bumblebee" program for collecting disc data for their internal disc database apparently generates some kind of disc hash code. I wonder how they are doing it?
Cinema Squid is offline
post #844 of 5106 Old 11-20-2009, 02:09 PM
Phloyd's Avatar
It may be worth finding out - it is easiest (sometimes) to not reinvent the wheel...
Phloyd is offline
post #845 of 5106 Old 11-20-2009, 10:27 PM - Thread Starter
[US] Aliens in the Attic: Rental Edition (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Fox
Release Date: 2009-11-03
Aspect Ratio: 1.85:1
Seemingly identical in main playlist to the retail release, but utterly lacking in special features other than a half-dozen previews. Here is Phloyd's post of the retail for reference:
https://www.avsforum.com/avs-vb/showp...&postcount=809
However, since they managed to shrink this one down to a BD-25 for the rental edition by stripping out the features, I'd call that a win!
Code:
        Total   Video
[US] Aliens in the Attic: Rental Edition                        AVC     1:25:48 18,462,517,248  21,094,154,509  28.69   22.29   DTS-HD Master 5.1 3656Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     ALIENS_IN_THE_ATTIC
Disc Size:      21,094,154,509 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:25:48 (h:m:s)
Total Bitrate:          28.69 Mbps
VIDEO:
MPEG-4 AVC Video        22285 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3656 kbps       5.1 / 48 kHz / 3656 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         62.693 kbps
Presentation Graphics           Chinese         54.622 kbps
Presentation Graphics           French          0.316 kbps
Presentation Graphics           Portuguese      47.055 kbps
Presentation Graphics           Spanish         52.108 kbps
Presentation Graphics           Thai            46.582 kbps
FILES:
00002.M2TS      0:00:00.000     1:25:48.143     18,462,517,248  28,690
CHAPTERS:
1               0:00:00.000     0:03:27.373     22,072 kbps     36,741 kbps     00:00:01.918    27,376 kbps     00:00:01.918    25,961 kbps     00:01:08.276    115,051 bytes   683,459 bytes   00:00:21.730
2               0:03:27.373     0:04:46.577     22,928 kbps     34,750 kbps     00:06:26.302    28,364 kbps     00:06:25.968    26,590 kbps     00:06:26.052    119,537 bytes   666,596 bytes   00:07:11.806
3               0:08:13.951     0:01:49.275     21,535 kbps     35,659 kbps     00:08:47.902    25,065 kbps     00:08:44.607    23,251 kbps     00:08:39.977    112,274 bytes   601,802 bytes   00:08:19.499
4               0:10:03.227     0:03:20.825     22,642 kbps     34,079 kbps     00:12:16.694    28,377 kbps     00:12:06.100    27,250 kbps     00:12:03.139    118,047 bytes   654,917 bytes   00:11:29.605
5               0:13:24.053     0:02:35.363     21,020 kbps     35,859 kbps     00:15:51.533    25,608 kbps     00:15:47.529    24,520 kbps     00:15:42.691    109,590 bytes   556,727 bytes   00:15:45.903
6               0:15:59.416     0:02:43.913     22,601 kbps     37,178 kbps     00:18:34.863    27,135 kbps     00:18:30.400    25,926 kbps     00:18:28.065    117,833 bytes   627,178 bytes   00:18:37.866
7               0:18:43.330     0:01:58.326     22,843 kbps     36,873 kbps     00:19:24.621    28,153 kbps     00:19:24.621    25,630 kbps     00:19:24.621    119,091 bytes   530,226 bytes   00:19:34.715
8               0:20:41.657     0:02:11.297     21,116 kbps     29,924 kbps     00:22:41.985    25,314 kbps     00:22:41.985    24,091 kbps     00:22:41.943    110,091 bytes   467,333 bytes   00:21:15.649
9               0:22:52.954     0:03:45.350     21,824 kbps     31,548 kbps     00:24:29.926    25,035 kbps     00:24:05.944    23,981 kbps     00:24:50.739    113,781 bytes   507,081 bytes   00:23:11.098
10              0:26:38.305     0:03:37.300     22,119 kbps     34,051 kbps     00:28:03.181    27,592 kbps     00:27:31.107    26,541 kbps     00:27:54.089    115,320 bytes   696,692 bytes   00:28:04.057
11              0:30:15.605     0:02:51.129     22,617 kbps     41,827 kbps     00:32:50.927    27,391 kbps     00:32:50.927    25,472 kbps     00:31:29.178    117,912 bytes   600,818 bytes   00:32:51.052
12              0:33:06.734     0:02:23.393     23,276 kbps     36,512 kbps     00:33:49.944    28,181 kbps     00:33:23.543    26,789 kbps     00:33:17.996    121,349 bytes   676,406 bytes   00:33:45.857
13              0:35:30.127     0:06:51.661     21,993 kbps     32,353 kbps     00:39:01.589    27,558 kbps     00:39:05.051    26,524 kbps     00:39:00.838    114,663 bytes   575,948 bytes   00:42:21.789
14              0:42:21.789     0:04:31.813     21,242 kbps     31,993 kbps     00:45:31.854    25,381 kbps     00:44:40.010    24,587 kbps     00:45:31.854    110,748 bytes   576,603 bytes   00:42:22.581
15              0:46:53.602     0:02:40.535     22,965 kbps     33,418 kbps     00:48:18.604    28,609 kbps     00:48:18.604    26,796 kbps     00:48:18.437    119,729 bytes   639,196 bytes   00:48:18.645
16              0:49:34.137     0:04:57.005     21,487 kbps     35,985 kbps     00:49:48.860    28,567 kbps     00:50:01.206    26,405 kbps     00:50:01.081    112,026 bytes   735,353 bytes   00:53:16.109
17              0:54:31.142     0:05:26.701     23,229 kbps     38,196 kbps     00:56:16.539    28,208 kbps     00:57:10.426    26,348 kbps     00:58:55.990    121,105 bytes   694,490 bytes   00:55:23.445
18              0:59:57.844     0:03:52.273     22,138 kbps     36,875 kbps     01:01:50.206    26,752 kbps     01:00:57.653    25,707 kbps     01:00:53.483    115,416 bytes   570,902 bytes   01:01:16.422
19              1:03:50.117     0:04:34.816     22,653 kbps     31,943 kbps     01:05:13.826    26,912 kbps     01:05:34.013    25,878 kbps     01:05:33.846    118,104 bytes   514,772 bytes   01:06:01.832
20              1:08:24.934     0:05:00.675     23,320 kbps     44,339 kbps     01:09:32.001    28,084 kbps     01:10:07.286    26,931 kbps     01:10:07.328    121,581 bytes   682,354 bytes   01:09:32.501
21              1:13:25.609     0:04:33.898     22,284 kbps     37,434 kbps     01:16:12.234    26,656 kbps     01:14:40.184    25,272 kbps     01:14:41.477    116,179 bytes   691,418 bytes   01:16:12.526
22              1:17:59.508     0:01:17.202     21,552 kbps     32,173 kbps     01:18:52.269    26,746 kbps     01:18:55.105    25,959 kbps     01:18:52.060    112,362 bytes   534,041 bytes   01:19:16.668
23              1:19:16.710     0:01:16.618     23,422 kbps     31,242 kbps     01:19:18.754    25,710 kbps     01:19:21.423    25,528 kbps     01:19:16.710    122,110 bytes   506,384 bytes   01:19:45.781
24              1:20:33.328     0:05:14.814     21,840 kbps     31,230 kbps     01:23:19.077    27,348 kbps     01:23:16.825    26,756 kbps     01:23:16.741    113,892 bytes   568,268 bytes   01:23:42.642
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     5148.060                22,286                  14,341,078,234  78,013,042
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5148.060                3,656                   2,352,652,764   13,589,358
00002.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            5148.060                448                     288,296,960     1,608,800
00002.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           5148.060                448                     288,296,960     1,608,800
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5148.060                63                      40,344,345      228,406
00002.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5148.060                52                      33,532,193      190,440
00002.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        5148.060                47                      30,280,620      172,904
00002.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           5148.060                55                      35,149,999      199,642
00002.M2TS      4612 (0x1204)   0x90            PGS             tha (Thai)              5148.060                47                      29,976,392      171,523
00002.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            5148.060                0                       203,615         1,158
post #846 of 5106 Old 11-20-2009, 10:39 PM - Thread Starter
[US] Ice Age: Dawn of the Dinosaurs: Rental Edition (Additional Details)
Studio: Fox
Release Date: 2009-10-27
Another barebones rental edition which is only graced by the presence of some previews. If I were the special features producer for this home video release, I might be upset that my hard work is only going to be appreciated by a fraction of the audience. However, since I am only a poor consumer who watches the movie once and then meekly slips it back into its rental sleeve a mere 10 seconds or so after completion - perhaps even before the credits have even finished rolling, I will sleep well tonight.
Not quite the same as the playlist posted by Phloyd (linked below) because they chopped off the audio commentary track:
https://www.avsforum.com/avs-vb/showp...&postcount=806
Code:
        Total   Video
Ice Age: Dawn of the Dinosaurs: Rental Edition                  AVC     1:34:03 31,075,117,056  33,371,171,772  44.05   35.68   DTS-HD Master 7.1 4674Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     ICE_AGE_3_RENTAL
Disc Size:      33,371,171,772 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:34:03 (h:m:s)
Total Bitrate:          44.05 Mbps
VIDEO:
MPEG-4 AVC Video        35681 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4674 kbps       7.1 / 48 kHz / 4674 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Portuguese      448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         34.938 kbps
Presentation Graphics           Chinese         15.746 kbps
Presentation Graphics           Chinese         17.839 kbps
Presentation Graphics           Portuguese      24.072 kbps
Presentation Graphics           Spanish         22.762 kbps
FILES:
00317.M2TS      0:00:00.000     1:34:03.304     31,075,117,056  44,052
CHAPTERS:
1               0:00:00.000     0:03:10.815     33,617 kbps     43,152 kbps     00:00:25.483    39,376 kbps     00:00:12.512    38,981 kbps     00:00:11.011    175,223 bytes   826,709 bytes   00:00:26.359
2               0:03:10.815     0:07:28.030     36,860 kbps     47,267 kbps     00:03:28.041    40,292 kbps     00:03:24.037    39,228 kbps     00:09:58.723    192,171 bytes   936,192 bytes   00:08:06.194
3               0:10:38.846     0:05:26.784     35,566 kbps     44,650 kbps     00:12:44.180    39,931 kbps     00:12:20.656    39,306 kbps     00:10:40.973    185,425 bytes   936,268 bytes   00:12:47.141
4               0:16:05.631     0:03:54.817     35,971 kbps     43,445 kbps     00:19:49.730    39,361 kbps     00:19:45.726    39,099 kbps     00:19:40.721    187,534 bytes   864,688 bytes   00:19:59.573
5               0:20:00.449     0:04:07.205     35,555 kbps     46,053 kbps     00:22:21.840    39,570 kbps     00:21:18.652    39,096 kbps     00:22:43.904    185,366 bytes   935,916 bytes   00:23:02.255
6               0:24:07.654     0:03:21.993     36,072 kbps     45,111 kbps     00:25:54.010    39,707 kbps     00:25:40.914    38,830 kbps     00:26:45.520    188,064 bytes   936,854 bytes   00:25:54.844
7               0:27:29.648     0:04:17.924     35,807 kbps     46,343 kbps     00:31:32.849    40,309 kbps     00:31:28.845    39,028 kbps     00:29:55.835    186,683 bytes   880,563 bytes   00:28:17.445
8               0:31:47.572     0:04:23.096     34,784 kbps     45,053 kbps     00:34:03.708    39,450 kbps     00:32:52.261    39,150 kbps     00:31:50.283    181,349 bytes   934,978 bytes   00:32:00.960
9               0:36:10.668     0:05:00.925     36,480 kbps     55,274 kbps     00:39:03.424    39,638 kbps     00:40:19.500    39,241 kbps     00:37:54.146    190,192 bytes   936,466 bytes   00:40:58.831
10              0:41:11.594     0:07:17.478     35,371 kbps     44,264 kbps     00:42:21.372    39,746 kbps     00:43:34.612    39,305 kbps     00:43:29.607    184,408 bytes   882,404 bytes   00:42:50.859
11              0:48:29.072     0:02:17.262     34,094 kbps     43,758 kbps     00:50:06.420    39,544 kbps     00:49:14.284    38,958 kbps     00:48:30.699    177,751 bytes   936,037 bytes   00:49:11.740
12              0:50:46.334     0:06:16.667     35,909 kbps     47,931 kbps     00:53:15.192    40,352 kbps     00:53:11.062    39,614 kbps     00:53:06.224    187,214 bytes   935,817 bytes   00:51:16.239
13              0:57:03.002     0:01:03.146     36,589 kbps     41,667 kbps     00:57:49.465    39,339 kbps     00:57:57.182    38,926 kbps     00:57:14.180    190,759 bytes   636,512 bytes   00:57:07.757
14              0:58:06.149     0:05:05.138     36,352 kbps     54,287 kbps     00:58:17.619    41,806 kbps     00:58:13.615    40,066 kbps     00:58:08.610    189,523 bytes   790,828 bytes   01:00:09.814
15              1:03:11.287     0:04:53.751     35,435 kbps     42,429 kbps     01:05:33.054    39,198 kbps     01:04:28.072    38,995 kbps     01:04:27.071    184,741 bytes   663,076 bytes   01:07:36.052
16              1:08:05.039     0:03:32.003     36,608 kbps     45,909 kbps     01:09:43.095    39,716 kbps     01:08:25.518    39,082 kbps     01:10:09.371    190,855 bytes   679,160 bytes   01:09:11.689
17              1:11:37.042     0:04:23.262     35,716 kbps     42,966 kbps     01:11:52.182    39,439 kbps     01:14:04.648    38,994 kbps     01:12:53.535    186,208 bytes   670,328 bytes   01:14:38.974
18              1:16:00.305     0:05:04.762     35,622 kbps     45,834 kbps     01:18:06.598    39,655 kbps     01:18:08.850    39,217 kbps     01:20:18.939    185,717 bytes   937,284 bytes   01:18:53.645
19              1:21:05.068     0:05:45.053     35,518 kbps     44,281 kbps     01:25:25.453    39,482 kbps     01:25:13.525    39,034 kbps     01:25:08.520    185,173 bytes   928,354 bytes   01:26:33.897
20              1:26:50.121     0:07:13.182     34,987 kbps     39,681 kbps     01:33:49.707    39,061 kbps     01:33:02.410    38,976 kbps     01:31:48.294    182,421 bytes   911,385 bytes   01:27:43.800
STREAM DIAGNOSTICS:
00317.M2TS      4113 (0x1011)   0x1B            AVC                                     5643.179                35,682                  25,170,170,052  136,873,889
00317.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5643.179                4,674                   3,297,350,200   18,800,110
00317.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            5643.179                448                     316,026,368     1,763,540
00317.M2TS      4354 (0x1102)   0x81            AC3             por (Portuguese)        5643.179                448                     316,026,368     1,763,540
00317.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           5643.179                448                     316,026,368     1,763,540
00317.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5643.179                35                      24,645,927      143,228
00317.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5643.179                23                      16,056,818      92,972
00317.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        5643.179                24                      16,980,897      97,986
00317.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           5643.179                16                      11,107,783      66,066
00317.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           5643.179                18                      12,583,667      73,755
post #847 of 5106 Old 11-20-2009, 11:00 PM - Thread Starter
[US] Fight Club (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Fox
UPC: 024543617907
Release Date: 2009-11-17
Aspect Ratio: 2.40:1
OK, you caught me red-handed - sometimes I actually buy movies. Not sure if the rental edition of this is gimped, but recent trends would suggest so.
There are four DD 2.0 commentaries with the fifth DD 2.0 (w/ Dolby Surround) being an original audio track. Clearly a bunch of subs - not quite sure what the difference between the two Chinese tracks is since unusually Fox put these in the menus in Chinese characters instead of saying "Cantonese" / "Mandarin" like they usually do. My guess would be traditional Chinese characters with and without Cantonese slang as per usual.
As far as other subs go, additional tracks are commentary subs. English and French have full coverage over all four commentaries, but Danish, Dutch, Finnish, Norwegian and Swedish only have subs for the solo Fincher and Fincher/Pitt/Norton/Carter commentaries.
Code:
        Total   Video
[US] Fight Club                                                 AVC     2:19:08 34,166,661,120  46,456,080,536  32.74   23.45   DTS-HD Master 5.1 3266Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     FIGHT_CLUB
Disc Size:      46,456,080,536 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:19:08 (h:m:s)
Total Bitrate:          32.74 Mbps
VIDEO:
MPEG-4 AVC Video        23453 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3266 kbps       5.1 / 48 kHz / 3266 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         44.262 kbps
Presentation Graphics           English         49.407 kbps
Presentation Graphics           English         34.927 kbps
Presentation Graphics           English         53.857 kbps
Presentation Graphics           English         65.773 kbps
Presentation Graphics           Chinese         33.239 kbps
Presentation Graphics           Chinese         33.913 kbps
Presentation Graphics           Danish          40.255 kbps
Presentation Graphics           Danish          49.298 kbps
Presentation Graphics           Danish          53.204 kbps
Presentation Graphics           Dutch           41.248 kbps
Presentation Graphics           Dutch           51.027 kbps
Presentation Graphics           Dutch           55.589 kbps
Presentation Graphics           Finnish         45.164 kbps
Presentation Graphics           Finnish         49.829 kbps
Presentation Graphics           Finnish         52.609 kbps
Presentation Graphics           French          41.687 kbps
Presentation Graphics           French          52.237 kbps
Presentation Graphics           French          47.943 kbps
Presentation Graphics           French          30.883 kbps
Presentation Graphics           French          46.190 kbps
Presentation Graphics           Norwegian       39.489 kbps
Presentation Graphics           Norwegian       51.012 kbps
Presentation Graphics           Norwegian       54.659 kbps
Presentation Graphics           Portuguese      40.858 kbps
Presentation Graphics           Spanish         41.625 kbps
Presentation Graphics           Swedish         42.597 kbps
Presentation Graphics           Swedish         48.456 kbps
Presentation Graphics           Swedish         51.863 kbps
FILES:
00349.M2TS      0:00:00.000     2:19:08.381     34,166,661,120  32,741
CHAPTERS:
1               0:00:00.000     0:02:08.378     15,141 kbps     25,392 kbps     00:01:54.155    22,420 kbps     00:01:50.068    21,560 kbps     00:00:02.127    78,912 bytes    381,482 bytes   00:01:31.090
2               0:02:08.378     0:01:46.439     23,397 kbps     32,077 kbps     00:03:26.623    30,239 kbps     00:03:23.536    27,446 kbps     00:03:04.142    121,980 bytes   336,048 bytes   00:02:39.826
3               0:03:54.817     0:00:51.509     23,500 kbps     28,925 kbps     00:04:40.530    27,961 kbps     00:04:36.526    27,203 kbps     00:04:31.562    122,516 bytes   248,910 bytes   00:04:36.067
4               0:04:46.327     0:01:35.595     30,157 kbps     35,765 kbps     00:04:52.417    33,946 kbps     00:04:49.289    33,224 kbps     00:04:48.121    157,226 bytes   289,164 bytes   00:05:16.733
5               0:06:21.923     0:04:00.281     25,415 kbps     35,859 kbps     00:10:01.142    31,963 kbps     00:09:43.040    31,025 kbps     00:09:39.704    132,503 bytes   380,158 bytes   00:09:39.745
6               0:10:22.204     0:01:12.697     24,241 kbps     30,924 kbps     00:10:54.779    30,077 kbps     00:10:50.941    29,230 kbps     00:10:48.105    126,384 bytes   254,868 bytes   00:10:57.448
7               0:11:34.902     0:07:38.666     23,206 kbps     32,809 kbps     00:15:11.035    31,144 kbps     00:15:11.035    30,352 kbps     00:15:09.283    120,987 bytes   288,524 bytes   00:17:25.711
8               0:19:13.569     0:02:27.605     22,814 kbps     35,901 kbps     00:20:01.450    33,074 kbps     00:19:57.613    31,307 kbps     00:19:56.612    118,944 bytes   390,289 bytes   00:19:58.655
9               0:21:41.174     0:04:06.829     25,489 kbps     34,479 kbps     00:22:06.491    31,370 kbps     00:24:32.387    30,620 kbps     00:24:31.845    132,890 bytes   308,159 bytes   00:22:48.784
10              0:25:48.004     0:03:21.326     23,509 kbps     34,081 kbps     00:26:58.408    30,728 kbps     00:26:39.431    29,650 kbps     00:26:37.512    122,563 bytes   335,426 bytes   00:26:53.153
11              0:29:09.330     0:03:17.864     21,908 kbps     26,535 kbps     00:31:12.370    25,338 kbps     00:30:59.440    25,225 kbps     00:30:54.435    114,216 bytes   274,777 bytes   00:32:26.235
12              0:32:27.195     0:01:43.269     24,770 kbps     35,205 kbps     00:32:35.411    31,772 kbps     00:33:45.940    31,454 kbps     00:33:40.935    129,139 bytes   304,378 bytes   00:32:35.703
13              0:34:10.465     0:01:47.482     21,723 kbps     24,879 kbps     00:35:49.063    23,753 kbps     00:35:48.020    23,493 kbps     00:35:47.478    113,255 bytes   256,751 bytes   00:35:22.245
14              0:35:57.947     0:05:39.047     23,699 kbps     35,553 kbps     00:40:22.378    34,944 kbps     00:40:18.374    34,576 kbps     00:40:13.619    123,557 bytes   316,430 bytes   00:37:35.586
15              0:41:36.994     0:05:41.966     22,352 kbps     36,100 kbps     00:41:50.382    31,890 kbps     00:41:46.795    29,843 kbps     00:41:43.209    116,534 bytes   290,972 bytes   00:46:26.742
16              0:47:18.961     0:01:18.912     28,019 kbps     34,685 kbps     00:48:17.894    32,964 kbps     00:47:36.353    32,234 kbps     00:47:35.060    146,077 bytes   295,367 bytes   00:48:21.398
17              0:48:37.873     0:11:40.408     23,622 kbps     35,880 kbps     00:55:01.339    34,221 kbps     00:54:58.753    31,251 kbps     00:54:57.794    123,153 bytes   366,275 bytes   00:54:59.838
18              1:00:18.281     0:01:37.972     21,215 kbps     31,125 kbps     01:01:30.269    28,055 kbps     01:01:28.267    27,892 kbps     01:01:29.185    110,607 bytes   261,180 bytes   01:01:14.504
19              1:01:56.254     0:07:52.180     24,320 kbps     33,725 kbps     01:03:09.327    30,268 kbps     01:07:05.980    29,143 kbps     01:07:06.397    126,794 bytes   429,835 bytes   01:02:33.332
20              1:09:48.434     0:05:09.517     19,110 kbps     25,872 kbps     01:10:52.414    25,399 kbps     01:11:00.005    25,323 kbps     01:10:52.331    99,628 bytes    287,036 bytes   01:14:57.951
21              1:14:57.951     0:00:49.674     25,635 kbps     35,537 kbps     01:15:23.227    29,157 kbps     01:15:22.392    27,615 kbps     01:15:17.304    133,651 bytes   345,583 bytes   01:15:23.685
22              1:15:47.626     0:03:48.228     28,844 kbps     35,701 kbps     01:16:13.193    34,759 kbps     01:18:18.276    33,955 kbps     01:18:13.939    150,379 bytes   343,930 bytes   01:17:55.921
23              1:19:35.854     0:01:53.613     23,691 kbps     35,265 kbps     01:21:14.077    30,297 kbps     01:21:11.616    29,106 kbps     01:21:09.114    123,512 bytes   369,616 bytes   01:21:07.737
24              1:21:29.467     0:06:09.077     23,118 kbps     34,589 kbps     01:24:55.507    29,889 kbps     01:24:53.755    27,961 kbps     01:24:53.755    120,527 bytes   534,661 bytes   01:24:55.799
25              1:27:38.544     0:07:58.436     25,115 kbps     37,161 kbps     01:34:12.855    34,992 kbps     01:34:17.234    34,677 kbps     01:34:58.943    130,938 bytes   426,361 bytes   01:28:04.404
26              1:35:36.981     0:02:11.089     21,118 kbps     35,431 kbps     01:37:46.068    33,647 kbps     01:37:42.982    30,490 kbps     01:37:38.018    110,098 bytes   265,724 bytes   01:37:44.608
27              1:37:48.070     0:03:38.718     20,510 kbps     35,824 kbps     01:39:21.830    29,438 kbps     01:39:18.577    27,684 kbps     01:39:17.034    106,929 bytes   259,661 bytes   01:40:45.164
28              1:41:26.789     0:03:40.678     21,457 kbps     33,139 kbps     01:42:49.788    31,974 kbps     01:43:02.092    31,612 kbps     01:43:01.049    111,867 bytes   415,672 bytes   01:42:27.266
29              1:45:07.467     0:02:50.712     22,970 kbps     35,464 kbps     01:45:42.044    28,706 kbps     01:45:34.703    27,599 kbps     01:45:33.702    119,754 bytes   316,288 bytes   01:45:55.515
30              1:47:58.180     0:02:36.698     27,038 kbps     36,568 kbps     01:48:17.032    33,225 kbps     01:48:27.584    31,851 kbps     01:49:38.280    140,964 bytes   536,358 bytes   01:48:17.741
31              1:50:34.878     0:06:18.294     24,745 kbps     34,740 kbps     01:55:32.508    31,493 kbps     01:51:56.042    30,116 kbps     01:51:55.250    129,007 bytes   362,967 bytes   01:55:42.936
32              1:56:53.172     0:03:43.640     21,352 kbps     33,750 kbps     02:00:32.850    31,090 kbps     02:00:31.807    28,416 kbps     02:00:26.802    111,319 bytes   382,777 bytes   02:00:31.224
33              2:00:36.812     0:05:18.901     26,220 kbps     35,969 kbps     02:00:52.245    34,477 kbps     02:05:35.069    32,826 kbps     02:05:35.069    136,699 bytes   451,145 bytes   02:00:56.958
34              2:05:55.714     0:03:42.639     21,183 kbps     35,346 kbps     02:09:17.875    28,464 kbps     02:09:22.796    28,032 kbps     02:09:16.874    110,439 bytes   307,874 bytes   02:09:08.824
35              2:09:38.353     0:06:15.625     23,001 kbps     31,207 kbps     02:15:42.592    28,370 kbps     02:15:41.216    27,401 kbps     02:11:43.812    119,915 bytes   335,684 bytes   02:10:42.084
36              2:15:53.979     0:03:14.402     21,211 kbps     35,543 kbps     02:18:56.119    31,331 kbps     02:17:10.347    29,883 kbps     02:17:10.096    110,607 bytes   524,989 bytes   02:18:55.410
STREAM DIAGNOSTICS:
00349.M2TS      4113 (0x1011)   0x1B            AVC                                     8348.257                23,453                  24,474,005,226  133,128,432
00349.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           8348.257                3,266                   3,408,495,100   19,825,023
00349.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           8348.257                224                     233,754,752     1,304,435
00349.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           8348.257                448                     467,509,504     2,608,870
00349.M2TS      4355 (0x1103)   0x82            DTS             fra (French)            8348.257                768                     801,444,864     4,695,966
00349.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        8348.257                448                     467,509,504     2,608,870
00349.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           8348.257                224                     233,754,752     1,304,435
00349.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           8348.257                224                     233,754,752     1,304,435
00349.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           8348.257                224                     233,754,752     1,304,435
00349.M2TS      4360 (0x1108)   0x81            AC3             eng (English)           8348.257                224                     233,754,752     1,304,435
00349.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8348.257                44                      46,189,862      263,899
00349.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           8348.257                42                      43,437,640      248,254
00349.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8348.257                42                      43,502,728      248,610
00349.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        8348.257                41                      42,637,078      244,385
00349.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            8348.257                40                      42,008,101      240,787
00349.M2TS      4613 (0x1205)   0x90            PGS             fin (Finnish)           8348.257                45                      47,131,168      268,792
00349.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             8348.257                41                      43,044,583      246,044
00349.M2TS      4615 (0x1207)   0x90            PGS             nor (Norwegian)         8348.257                39                      41,208,682      236,533
00349.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           8348.257                43                      44,452,091      254,153
00349.M2TS      4617 (0x1209)   0x90            PGS             zho (Chinese)           8348.257                33                      34,686,480      200,598
00349.M2TS      4618 (0x120A)   0x90            PGS             zho (Chinese)           8348.257                34                      35,389,356      204,808
00349.M2TS      4619 (0x120B)   0x90            PGS             eng (English)           8348.257                54                      56,202,506      315,885
00349.M2TS      4620 (0x120C)   0x90            PGS             fra (French)            8348.257                52                      54,511,825      306,830
00349.M2TS      4621 (0x120D)   0x90            PGS             dan (Danish)            8348.257                49                      51,444,784      290,137
00349.M2TS      4622 (0x120E)   0x90            PGS             fin (Finnish)           8348.257                50                      51,998,435      293,174
00349.M2TS      4623 (0x120F)   0x90            PGS             nld (Dutch)             8348.257                51                      53,249,519      299,966
00349.M2TS      4624 (0x1210)   0x90            PGS             nor (Norwegian)         8348.257                51                      53,233,368      299,858
00349.M2TS      4625 (0x1211)   0x90            PGS             swe (Swedish)           8348.257                48                      50,565,650      285,387
00349.M2TS      4626 (0x1212)   0x90            PGS             eng (English)           8348.257                66                      68,636,992      386,501
00349.M2TS      4627 (0x1213)   0x90            PGS             fra (French)            8348.257                48                      50,030,503      284,264
00349.M2TS      4628 (0x1214)   0x90            PGS             dan (Danish)            8348.257                53                      55,521,093      314,934
00349.M2TS      4629 (0x1215)   0x90            PGS             fin (Finnish)           8348.257                53                      54,900,275      311,605
00349.M2TS      4630 (0x1216)   0x90            PGS             nld (Dutch)             8348.257                56                      58,010,239      328,384
00349.M2TS      4631 (0x1217)   0x90            PGS             nor (Norwegian)         8348.257                55                      57,039,544      323,190
00349.M2TS      4632 (0x1218)   0x90            PGS             swe (Swedish)           8348.257                52                      54,121,549      307,326
00349.M2TS      4633 (0x1219)   0x90            PGS             eng (English)           8348.257                35                      36,447,742      205,239
00349.M2TS      4634 (0x121A)   0x90            PGS             fra (French)            8348.257                31                      32,228,138      182,311
00349.M2TS      4635 (0x121B)   0x90            PGS             eng (English)           8348.257                49                      51,558,229      290,330
00349.M2TS      4636 (0x121C)   0x90            PGS             fra (French)            8348.257                46                      48,201,053      271,952
Bonus "jacket" META/DL graphic (are there any other players besides the PS3 that display these?):
post #848 of 5106 Old 11-20-2009, 11:24 PM - Thread Starter
[US] Angel Heart (Additional Details)
Studio: Lionsgate
UPC: 012236105886
Release Date: 2009-11-24
A rental, but presumably the same as this coming Tuesday's retail release since it actually has a half-handful of features. English DD 2.0 is a commentary by director Alan Parker.
Why are all these as yet unreleased movies available for rent nowadays? Mysteries of the universe...
Code:
        Total   Video
[US] Angel Heart                                                AVC     1:52:59 20,954,757,120  23,509,459,782  24.73   19.00   DTS-HD Master 5.1 3810Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     ANGEL_HEART
Disc Size:      23,509,459,782 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:52:59 (h:m:s)
Total Bitrate:          24.73 Mbps
VIDEO:
MPEG-4 AVC Video        18998 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3810 kbps       5.1 / 48 kHz / 3810 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit / DN -4dB)
Dolby Digital Audio             French          224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         39.927 kbps
Presentation Graphics           English         46.698 kbps
Presentation Graphics           Spanish         37.998 kbps
FILES:
00313.M2TS      0:00:00.000     1:52:59.606     20,954,757,120  24,727
CHAPTERS:
1               0:00:00.000     0:06:21.756     16,335 kbps     27,280 kbps     00:04:43.866    25,969 kbps     00:03:37.508    25,670 kbps     00:04:36.985    85,156 bytes    224,642 bytes   00:04:39.028
2               0:06:21.756     0:04:55.128     20,497 kbps     24,285 kbps     00:08:58.913    23,422 kbps     00:09:09.465    23,079 kbps     00:09:07.838    106,861 bytes   206,943 bytes   00:07:23.568
3               0:11:16.884     0:09:06.671     20,200 kbps     30,871 kbps     00:11:39.198    30,045 kbps     00:11:35.194    29,144 kbps     00:11:34.360    105,316 bytes   301,361 bytes   00:11:55.131
4               0:20:23.555     0:04:55.795     17,796 kbps     25,013 kbps     00:24:02.274    23,283 kbps     00:23:58.061    22,947 kbps     00:23:56.560    92,778 bytes    267,398 bytes   00:24:55.869
5               0:25:19.351     0:07:10.888     21,908 kbps     28,978 kbps     00:32:23.232    25,894 kbps     00:32:21.314    25,469 kbps     00:26:37.971    114,220 bytes   304,892 bytes   00:30:43.633
6               0:32:30.239     0:04:56.879     17,056 kbps     26,241 kbps     00:36:03.077    25,835 kbps     00:35:59.073    25,770 kbps     00:35:54.068    88,920 bytes    247,719 bytes   00:37:22.156
7               0:37:27.119     0:05:53.978     24,346 kbps     34,607 kbps     00:38:43.446    33,713 kbps     00:38:43.446    33,455 kbps     00:38:42.320    126,930 bytes   288,024 bytes   00:37:33.251
8               0:43:21.098     0:07:09.637     17,049 kbps     23,528 kbps     00:45:03.742    22,661 kbps     00:43:40.576    22,513 kbps     00:43:39.491    88,888 bytes    219,838 bytes   00:50:23.979
9               0:50:30.736     0:04:53.167     22,891 kbps     28,910 kbps     00:52:07.123    27,270 kbps     00:54:53.248    26,250 kbps     00:54:48.285    119,344 bytes   313,967 bytes   00:51:06.104
10              0:55:23.903     0:08:41.145     15,811 kbps     26,579 kbps     01:02:45.470    24,058 kbps     01:02:43.468    22,130 kbps     01:02:38.504    82,430 bytes    190,298 bytes   01:02:46.012
11              1:04:05.049     0:05:39.839     17,614 kbps     27,940 kbps     01:07:53.861    25,870 kbps     01:07:28.252    24,630 kbps     01:06:39.745    91,833 bytes    206,875 bytes   01:07:46.103
12              1:09:44.889     0:08:14.035     19,577 kbps     31,419 kbps     01:14:48.692    30,031 kbps     01:13:19.353    26,949 kbps     01:14:48.692    102,065 bytes   286,877 bytes   01:13:49.341
13              1:17:58.924     0:05:11.185     21,615 kbps     26,483 kbps     01:18:28.745    25,553 kbps     01:23:04.896    24,873 kbps     01:22:39.871    112,693 bytes   239,726 bytes   01:18:41.425
14              1:23:10.110     0:06:57.875     16,848 kbps     25,793 kbps     01:28:50.992    23,111 kbps     01:28:32.598    21,586 kbps     01:28:31.681    87,837 bytes    191,575 bytes   01:28:26.175
15              1:30:07.985     0:11:10.127     20,782 kbps     27,034 kbps     01:40:04.123    25,069 kbps     01:33:40.239    24,715 kbps     01:33:17.508    108,350 bytes   308,819 bytes   01:41:17.488
16              1:41:18.113     0:11:41.492     16,329 kbps     27,219 kbps     01:42:19.299    26,575 kbps     01:42:19.633    25,667 kbps     01:42:16.296    85,140 bytes    222,315 bytes   01:47:17.556
STREAM DIAGNOSTICS:
00313.M2TS      4113 (0x1011)   0x1B            AVC                                     6779.439                18,998                  16,099,494,951  87,592,118
00313.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6779.439                3,810                   3,228,486,252   18,605,376
00313.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            6779.439                224                     189,829,248     1,059,315
00313.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6779.439                224                     189,829,248     1,059,315
00313.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6779.439                40                      33,835,891      190,770
00313.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6779.439                47                      39,574,657      223,458
00313.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6779.439                38                      32,201,393      181,855
post #849 of 5106 Old 11-21-2009, 12:01 AM - Thread Starter
[US] Brüno (Additional Details)
Studio: Universal
UPC: 025195052597
The "enhanced commentary" is provided as a separate seamlessly branched playlist that adds about 26.5 minutes to the runtime. This includes a DD 2.0 commentary track which is disabled for the main feature but is the only track selectable on the commentary playlist. There is an additional English DD 2.0 descriptive audio track for the visually impaired on the theatrical playlist.
This descriptive audio track is somewhat horrifying in its own way actually:
Spoiler
"Brüno flails a huge black dildo. Danny demonstrates a counter-attack. He blocks Brüno with his knee [...] Brüno wears a strap-on dildo. Danny boots it [...] Now Brüno attacks with all three dildos. Danny twists his arm and forces him down - then kicks him."
Code:
        Total   Video
[US] Bruno                                                      AVC     1:21:26 19,328,581,632  41,564,260,059  31.64   24.08   DTS-HD Master 5.1 3476Kbps (48kHz/24-bit)
         Enhanced Commentary                                    AVC     1:48:09 25,910,347,776  41,564,260,059  31.94   24.10   DTS-HD Master 5.1 3741Kbps (48kHz/24-bit)
Brüno
Code:
DISC INFO:
Disc Title:     BRUNO
Disc Size:      41,564,260,059 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:21:26 (h:m:s)
Total Bitrate:          31.64 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        24077 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3476 kbps       5.1 / 48 kHz / 3476 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         52.877 kbps
* Presentation Graphics         English         71.981 kbps
Presentation Graphics           French          47.845 kbps
* Presentation Graphics         French          58.637 kbps
Presentation Graphics           French          4.689 kbps
Presentation Graphics           Spanish         45.201 kbps
* Presentation Graphics         Spanish         55.306 kbps
Presentation Graphics           Spanish         3.232 kbps
FILES:
00104.M2TS      0:00:00.000     0:00:22.522     91,631,616      32,548
00098.M2TS      0:00:22.522     0:04:04.410     979,525,632     32,062
00112.M2TS      0:04:26.933     0:00:35.535     146,558,976     32,994
00099.M2TS      0:05:02.468     0:01:13.364     296,085,504     32,286
00113.M2TS      0:06:15.833     0:01:07.233     273,070,080     32,492
00100.M2TS      0:07:23.067     0:03:08.229     759,355,392     32,274
00114.M2TS      0:10:31.297     0:01:18.286     309,755,904     31,654
00101.M2TS      0:11:49.583     0:03:38.384     873,369,600     31,994
00115.M2TS      0:15:27.968     0:01:15.658     296,878,080     31,391
00097.M2TS      0:16:43.627     0:03:09.314     751,958,016     31,776
00116.M2TS      0:19:52.941     0:01:03.104     248,758,272     31,536
00102.M2TS      0:20:56.046     0:02:12.715     525,711,360     31,689
00117.M2TS      0:23:08.762     0:01:10.820     276,178,944     31,198
00103.M2TS      0:24:19.582     0:01:46.523     418,996,224     31,467
00118.M2TS      0:26:06.106     0:01:01.561     243,480,576     31,641
00105.M2TS      0:27:07.667     0:01:18.536     311,556,096     31,736
00119.M2TS      0:28:26.204     0:00:49.591     203,046,912     32,755
00106.M2TS      0:29:15.795     0:17:23.208     4,169,736,192   31,976
00120.M2TS      0:46:39.004     0:01:25.960     345,335,808     32,139
00107.M2TS      0:48:04.965     0:07:54.432     1,892,493,312   31,912
00122.M2TS      0:55:59.397     0:03:04.184     729,206,784     31,673
00108.M2TS      0:59:03.581     0:02:33.945     616,857,600     32,056
00125.M2TS      1:01:37.526     0:01:09.903     280,098,816     32,056
00109.M2TS      1:02:47.430     0:04:53.251     1,160,681,472   31,664
00124.M2TS      1:07:40.681     0:02:24.978     583,206,912     32,182
00110.M2TS      1:10:05.659     0:04:45.910     1,179,021,312   32,990
00121.M2TS      1:14:51.570     0:01:08.860     271,755,264     31,572
00111.M2TS      1:16:00.430     0:05:19.444     1,076,742,144   26,965
00123.M2TS      1:21:19.874     0:00:07.048     17,528,832      19,895
CHAPTERS:
1               0:00:00.000     0:04:58.965     23,854 kbps     39,739 kbps     00:04:12.377    34,097 kbps     00:01:22.540    33,690 kbps     00:03:18.907    124,345 bytes   687,422 bytes   00:01:30.882
2               0:04:58.965     0:04:00.281     24,544 kbps     35,111 kbps     00:07:22.316    34,121 kbps     00:07:22.108    33,920 kbps     00:07:21.858    127,962 bytes   460,428 bytes   00:05:03.469
3               0:08:59.246     0:03:45.266     25,325 kbps     31,622 kbps     00:12:03.806    30,678 kbps     00:12:03.848    30,578 kbps     00:12:03.806    132,032 bytes   471,297 bytes   00:09:05.878
4               0:12:44.513     0:01:58.034     24,413 kbps     34,696 kbps     00:13:00.529    30,143 kbps     00:12:59.695    27,321 kbps     00:12:59.695    127,279 bytes   380,574 bytes   00:14:42.548
5               0:14:42.548     0:02:40.076     21,692 kbps     34,768 kbps     00:16:27.111    33,388 kbps     00:16:25.651    29,998 kbps     00:16:23.982    113,092 bytes   416,757 bytes   00:14:45.551
6               0:17:22.624     0:04:56.295     25,780 kbps     34,962 kbps     00:21:24.699    33,325 kbps     00:21:40.257    32,327 kbps     00:20:56.004    134,406 bytes   332,113 bytes   00:22:16.710
7               0:22:18.920     0:02:04.165     23,499 kbps     34,935 kbps     00:24:07.237    33,997 kbps     00:24:14.619    33,843 kbps     00:24:09.614    122,511 bytes   316,066 bytes   00:24:08.238
8               0:24:23.086     0:03:56.319     24,180 kbps     30,583 kbps     00:25:42.540    28,907 kbps     00:27:18.928    28,821 kbps     00:27:14.007    126,063 bytes   314,835 bytes   00:27:13.089
9               0:28:19.405     0:05:18.026     23,435 kbps     36,651 kbps     00:28:34.754    33,597 kbps     00:28:20.323    28,842 kbps     00:28:33.795    122,181 bytes   588,937 bytes   00:28:28.164
10              0:33:37.431     0:04:02.992     25,082 kbps     35,082 kbps     00:34:41.871    33,928 kbps     00:37:34.752    33,852 kbps     00:37:29.747    130,768 bytes   482,927 bytes   00:33:46.148
11              0:37:40.424     0:06:10.995     23,736 kbps     34,576 kbps     00:38:14.416    32,735 kbps     00:38:12.915    31,281 kbps     00:38:12.915    123,748 bytes   625,036 bytes   00:42:10.235
12              0:43:51.420     0:03:58.905     26,919 kbps     36,192 kbps     00:47:22.297    34,286 kbps     00:47:28.637    33,969 kbps     00:45:20.467    140,345 bytes   409,767 bytes   00:47:23.256
13              0:47:50.325     0:04:09.666     25,318 kbps     35,521 kbps     00:50:24.145    34,235 kbps     00:50:20.183    34,048 kbps     00:50:15.178    131,997 bytes   441,932 bytes   00:50:29.818
14              0:51:59.991     0:03:06.561     22,999 kbps     35,638 kbps     00:54:42.153    31,421 kbps     00:54:55.333    28,935 kbps     00:54:42.070    119,905 bytes   468,180 bytes   00:54:43.071
15              0:55:06.553     0:03:35.340     24,446 kbps     35,270 kbps     00:57:41.791    31,966 kbps     00:55:07.262    29,198 kbps     00:55:06.886    127,452 bytes   467,285 bytes   00:55:11.224
16              0:58:41.893     0:05:20.778     25,312 kbps     35,640 kbps     00:59:50.294    34,086 kbps     01:02:41.632    33,262 kbps     00:59:42.203    131,964 bytes   412,847 bytes   00:58:47.899
17              1:04:02.671     0:05:08.933     23,751 kbps     33,982 kbps     01:04:09.053    29,939 kbps     01:04:09.053    29,449 kbps     01:08:59.802    123,827 bytes   296,358 bytes   01:04:51.387
18              1:09:11.605     0:05:17.066     25,223 kbps     41,316 kbps     01:12:20.585    34,042 kbps     01:14:12.155    32,020 kbps     01:09:21.573    131,502 bytes   620,655 bytes   01:09:28.789
19              1:14:28.672     0:03:58.947     29,239 kbps     39,757 kbps     01:16:24.621    35,058 kbps     01:16:20.659    34,385 kbps     01:16:15.654    152,440 bytes   614,442 bytes   01:15:40.702
20              1:18:27.619     0:02:59.304     6,712 kbps      24,292 kbps     01:21:22.001    20,089 kbps     01:21:19.791    12,464 kbps     01:21:14.702    35,004 bytes    677,924 bytes   01:21:22.877
Brüno: Enhanced Commentary
Code:
        Total   Video
01097.MPLS                                                      AVC     1:48:09 25,910,347,776  41,564,260,059  31.94   24.10   DTS-HD Master 5.1 3741Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BRUNO
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:48:09 (h:m:s)
Total Bitrate:          31.94 Mbps
VIDEO:
MPEG-4 AVC Video        24100 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
* DTS-HD Master Audio           English         3741 kbps       5.1 / 48 kHz / 3741 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
* DTS Audio                     French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* DTS Audio                     Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
* Presentation Graphics         English         30.658 kbps
Presentation Graphics           English         96.146 kbps
* Presentation Graphics         French          28.068 kbps
Presentation Graphics           French          77.552 kbps
* Presentation Graphics         French          3.088 kbps
* Presentation Graphics         Spanish         26.430 kbps
Presentation Graphics           Spanish         73.790 kbps
* Presentation Graphics         Spanish         2.130 kbps
FILES:
00010.M2TS      0:00:00.000     0:00:22.522     89,229,312      31,694
00083.M2TS      0:04:26.933     0:01:35.261     390,021,120     32,754
00099.M2TS      0:06:02.195     0:01:13.364     296,085,504     32,286
00084.M2TS      0:07:15.560     0:06:00.193     1,455,280,128   32,322
00100.M2TS      0:13:15.753     0:03:08.229     759,355,392     32,274
00085.M2TS      0:16:23.982     0:01:37.806     401,338,368     32,827
00101.M2TS      0:18:01.788     0:03:38.384     873,369,600     31,994
00086.M2TS      0:21:40.173     0:02:11.756     540,168,192     32,798
00097.M2TS      0:23:51.930     0:03:09.314     751,958,016     31,776
00087.M2TS      0:27:01.244     0:03:05.727     757,585,920     32,632
00102.M2TS      0:30:06.971     0:02:12.715     525,711,360     31,689
00088.M2TS      0:32:19.687     0:02:55.216     714,221,568     32,610
00103.M2TS      0:35:14.904     0:01:46.523     418,996,224     31,467
00094.M2TS      0:37:01.427     0:01:35.970     394,149,888     32,856
00105.M2TS      0:38:37.398     0:01:18.536     311,556,096     31,736
00089.M2TS      0:39:55.935     0:06:02.320     1,478,393,856   32,643
00106.M2TS      0:45:58.255     0:17:23.208     4,169,736,192   31,976
00090.M2TS      1:03:21.464     0:03:46.559     917,520,384     32,398
00107.M2TS      1:07:08.023     0:07:54.432     1,892,493,312   31,912
00091.M2TS      1:15:02.456     0:05:08.850     1,260,355,584   32,646
00108.M2TS      1:20:11.306     0:02:33.945     616,857,600     32,056
00092.M2TS      1:22:45.251     0:01:54.614     470,335,488     32,829
00109.M2TS      1:24:39.866     0:04:53.251     1,160,681,472   31,664
00096.M2TS      1:29:33.117     0:05:44.093     1,407,959,040   32,734
00110.M2TS      1:35:17.211     0:04:45.910     1,179,021,312   32,990
00093.M2TS      1:40:03.121     0:02:25.562     594,745,344     32,687
00111.M2TS      1:42:28.683     0:05:19.444     1,076,742,144   26,965
00095.M2TS      1:47:48.128     0:00:21.396     26,953,728      10,078
CHAPTERS:
1               0:00:00.000     0:05:58.691     23,926 kbps     39,739 kbps     00:04:12.377    34,097 kbps     00:01:22.540    33,690 kbps     00:03:18.907    124,723 bytes   797,427 bytes   00:04:56.379
2               0:05:58.691     0:08:53.241     24,302 kbps     45,762 kbps     00:07:15.935    34,336 kbps     00:10:44.769    34,059 kbps     00:10:39.764    126,701 bytes   875,633 bytes   00:11:10.044
3               0:14:51.932     0:04:04.786     25,257 kbps     34,308 kbps     00:17:37.556    33,722 kbps     00:17:36.221    33,337 kbps     00:17:33.302    131,680 bytes   577,647 bytes   00:17:05.649
4               0:18:56.718     0:01:58.034     24,413 kbps     34,696 kbps     00:19:12.734    30,143 kbps     00:19:11.900    27,321 kbps     00:19:11.900    127,279 bytes   380,574 bytes   00:20:54.753
5               0:20:54.753     0:03:36.174     22,415 kbps     35,908 kbps     00:22:02.112    33,948 kbps     00:23:04.382    33,611 kbps     00:22:59.836    116,862 bytes   563,668 bytes   00:22:03.321
6               0:24:30.927     0:06:58.918     25,395 kbps     38,496 kbps     00:27:24.934    34,776 kbps     00:27:20.930    34,306 kbps     00:27:15.800    132,397 bytes   845,698 bytes   00:27:38.156
7               0:31:29.846     0:03:48.561     23,936 kbps     35,165 kbps     00:32:54.764    33,991 kbps     00:35:09.941    33,839 kbps     00:35:04.936    124,793 bytes   438,679 bytes   00:34:12.466
8               0:35:18.407     0:04:30.728     24,220 kbps     35,876 kbps     00:37:32.458    34,247 kbps     00:37:28.454    33,954 kbps     00:37:14.565    126,273 bytes   840,087 bytes   00:37:46.430
9               0:39:49.136     0:10:30.755     23,951 kbps     50,788 kbps     00:41:12.261    37,296 kbps     00:41:08.257    35,284 kbps     00:41:03.252    124,869 bytes   821,459 bytes   00:42:45.145
10              0:50:19.891     0:04:02.992     25,082 kbps     35,082 kbps     00:51:24.331    33,928 kbps     00:54:17.212    33,852 kbps     00:54:12.207    130,768 bytes   482,927 bytes   00:50:28.608
11              0:54:22.884     0:06:10.995     23,736 kbps     34,576 kbps     00:54:56.876    32,735 kbps     00:54:55.375    31,281 kbps     00:54:55.375    123,748 bytes   625,036 bytes   00:58:52.695
12              1:00:33.880     0:06:19.504     25,479 kbps     44,217 kbps     01:03:33.809    35,902 kbps     01:03:29.805    34,944 kbps     01:03:24.800    132,835 bytes   936,228 bytes   01:05:51.071
13              1:06:53.384     0:04:09.666     26,023 kbps     35,521 kbps     01:09:27.204    34,235 kbps     01:09:23.242    34,048 kbps     01:09:18.237    135,674 bytes   441,932 bytes   01:09:32.876
14              1:11:03.050     0:03:06.561     22,999 kbps     35,638 kbps     01:13:45.212    31,421 kbps     01:13:58.392    28,935 kbps     01:13:45.128    119,905 bytes   468,180 bytes   01:13:46.129
15              1:14:09.611     0:05:40.006     24,065 kbps     38,330 kbps     01:18:57.273    34,891 kbps     01:18:53.311    33,935 kbps     01:17:12.586    125,462 bytes   547,091 bytes   01:19:13.832
16              1:19:49.617     0:06:05.490     25,589 kbps     35,700 kbps     01:24:34.485    34,141 kbps     01:24:34.068    33,405 kbps     01:19:51.578    133,407 bytes   499,967 bytes   01:23:54.320
17              1:25:55.108     0:05:08.808     26,404 kbps     37,679 kbps     01:31:00.121    34,590 kbps     01:30:56.117    34,157 kbps     01:30:51.112    137,658 bytes   419,257 bytes   01:31:01.080
18              1:31:03.916     0:08:36.307     23,396 kbps     48,698 kbps     01:31:48.294    36,698 kbps     01:31:44.248    35,208 kbps     01:31:39.285    121,977 bytes   805,052 bytes   01:31:59.096
19              1:39:40.223     0:05:15.481     28,104 kbps     39,757 kbps     01:42:52.874    35,058 kbps     01:42:48.912    34,385 kbps     01:42:43.907    146,521 bytes   538,919 bytes   01:40:37.614
20              1:44:55.705     0:03:13.818     6,096 kbps      17,383 kbps     01:47:16.388    12,989 kbps     01:47:16.388    11,861 kbps     01:47:12.384    31,791 bytes    485,285 bytes   01:47:17.013
post #850 of 5106 Old 11-21-2009, 09:21 PM
Eagle Eye - 2008 - Australian version
Distributed by Paramount Home Entertainment (Australasia) Pty Ltd
Region free, confirmed with AnyDVD HD
Main title seems much the same as the US version showin on front page, except that this one has the western European language package.
Code:
        Total   Video
00000.MPLS                                                      AVC     1:57:35 35,211,491,328  45,702,444,692  39.93   29.62   Dolby TrueHD 5.1 3578Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     EAGLE_EYE_EU
Disc Size:      45,702,444,692 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:57:35 (h:m:s)
Total Bitrate:          39.93 Mbps
VIDEO:
MPEG-4 AVC Video        29622 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3578 kbps       5.1 / 48 kHz / 3578 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Italian         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           Danish          32.607 kbps
Presentation Graphics           German          43.382 kbps
Presentation Graphics           English         43.229 kbps
Presentation Graphics           Spanish         35.850 kbps
Presentation Graphics           French          29.736 kbps
Presentation Graphics           Italian         41.979 kbps
Presentation Graphics           Dutch           27.838 kbps
Presentation Graphics           Norwegian       27.807 kbps
Presentation Graphics           Finnish         30.222 kbps
Presentation Graphics           Swedish         33.532 kbps
Presentation Graphics           German          1.415 kbps
Presentation Graphics           Spanish         1.407 kbps
Presentation Graphics           French          0.775 kbps
Presentation Graphics           Italian         1.956 kbps
Presentation Graphics           English         46.957 kbps
FILES:
00000.M2TS      0:00:00.000     1:57:35.089     35,211,491,328  39,927
CHAPTERS:
1               0:00:00.000     0:05:49.140     30,416 kbps     41,131 kbps     00:01:19.329    35,569 kbps     00:00:53.386    34,715 kbps     00:00:48.381    158,554 bytes   389,108 bytes   00:00:51.926
2               0:05:49.140     0:04:50.415     30,409 kbps     38,048 kbps     00:08:49.445    34,811 kbps     00:08:45.441    34,466 kbps     00:08:40.520    158,538 bytes   389,622 bytes   00:09:08.172
3               0:10:39.555     0:05:47.347     31,085 kbps     38,573 kbps     00:15:07.531    35,039 kbps     00:15:03.611    34,293 kbps     00:14:30.536    162,064 bytes   370,852 bytes   00:14:35.958
4               0:16:26.902     0:03:07.061     30,161 kbps     37,701 kbps     00:18:02.039    34,382 kbps     00:16:32.324    34,135 kbps     00:16:39.248    157,247 bytes   327,786 bytes   00:19:18.866
5               0:19:33.964     0:04:07.789     29,206 kbps     34,609 kbps     00:22:20.714    33,951 kbps     00:21:34.668    33,031 kbps     00:21:28.745    152,265 bytes   270,908 bytes   00:23:38.959
6               0:23:41.753     0:02:41.077     31,718 kbps     37,277 kbps     00:24:49.404    34,538 kbps     00:25:21.895    34,310 kbps     00:25:16.932    165,363 bytes   325,544 bytes   00:24:21.334
7               0:26:22.831     0:05:19.569     30,699 kbps     37,843 kbps     00:28:41.886    34,393 kbps     00:27:01.077    33,977 kbps     00:29:07.328    160,051 bytes   339,331 bytes   00:28:01.137
8               0:31:42.400     0:06:24.092     29,165 kbps     39,677 kbps     00:34:58.429    34,196 kbps     00:37:49.976    33,832 kbps     00:35:23.079    152,051 bytes   335,747 bytes   00:36:54.170
9               0:38:06.492     0:05:16.649     31,088 kbps     39,513 kbps     00:41:54.386    34,437 kbps     00:38:09.704    34,324 kbps     00:38:38.065    162,078 bytes   474,300 bytes   00:41:55.221
10              0:43:23.142     0:03:06.811     31,957 kbps     36,761 kbps     00:45:47.661    34,477 kbps     00:43:36.864    34,254 kbps     00:43:37.489    166,607 bytes   386,132 bytes   00:45:37.234
11              0:46:29.953     0:05:31.289     29,685 kbps     35,618 kbps     00:49:36.848    34,294 kbps     00:47:15.040    34,213 kbps     00:47:06.615    154,762 bytes   365,204 bytes   00:49:39.935
12              0:52:01.243     0:04:02.325     30,871 kbps     37,940 kbps     00:55:10.557    34,350 kbps     00:54:04.491    34,173 kbps     00:54:00.487    160,949 bytes   426,543 bytes   00:52:11.253
13              0:56:03.568     0:04:36.776     30,577 kbps     37,315 kbps     00:58:51.653    34,343 kbps     00:57:35.410    34,169 kbps     00:56:07.280    159,415 bytes   279,049 bytes   00:59:24.561
14              1:00:40.345     0:03:46.309     30,143 kbps     36,893 kbps     01:02:05.972    34,616 kbps     01:01:23.471    34,121 kbps     01:00:50.063    157,154 bytes   498,014 bytes   01:00:49.103
15              1:04:26.654     0:04:41.322     30,495 kbps     37,651 kbps     01:05:44.398    34,889 kbps     01:05:40.394    34,491 kbps     01:05:35.473    158,987 bytes   329,514 bytes   01:05:49.862
16              1:09:07.977     0:06:25.176     30,759 kbps     39,079 kbps     01:14:17.703    34,440 kbps     01:12:27.426    34,112 kbps     01:10:10.414    160,361 bytes   290,626 bytes   01:09:16.819
17              1:15:33.153     0:05:25.616     30,259 kbps     40,717 kbps     01:20:05.884    35,054 kbps     01:20:01.838    34,504 kbps     01:19:56.875    157,757 bytes   327,023 bytes   01:20:21.316
18              1:20:58.770     0:04:44.409     30,498 kbps     36,657 kbps     01:21:47.402    34,500 kbps     01:21:43.481    34,016 kbps     01:21:44.274    159,004 bytes   322,368 bytes   01:24:55.590
19              1:25:43.179     0:07:08.928     30,742 kbps     40,032 kbps     01:30:12.740    34,598 kbps     01:28:16.249    34,192 kbps     01:32:30.795    160,276 bytes   441,186 bytes   01:26:24.137
20              1:32:52.108     0:06:56.290     29,776 kbps     44,909 kbps     01:39:08.025    34,868 kbps     01:39:04.021    34,182 kbps     01:33:06.247    155,237 bytes   422,812 bytes   01:39:08.984
21              1:39:48.399     0:04:46.661     30,205 kbps     38,282 kbps     01:44:33.684    34,823 kbps     01:43:44.009    33,935 kbps     01:43:05.512    157,474 bytes   354,803 bytes   01:44:30.222
22              1:44:35.060     0:03:41.846     31,004 kbps     38,074 kbps     01:44:55.747    34,591 kbps     01:48:10.192    34,326 kbps     01:45:35.579    161,639 bytes   387,567 bytes   01:45:21.273
23              1:48:16.907     0:02:31.484     30,079 kbps     35,255 kbps     01:48:38.929    34,398 kbps     01:48:34.508    34,177 kbps     01:48:32.589    156,819 bytes   401,214 bytes   01:48:31.213
24              1:50:48.391     0:06:46.697     16,468 kbps     35,708 kbps     01:53:28.802    34,117 kbps     01:54:07.507    33,355 kbps     01:54:06.047    85,867 bytes    552,760 bytes   01:53:27.550
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     7054.923                29,623                  26,123,423,965  142,073,713
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           7054.923                4,218                   3,719,559,316   25,762,361
00000.M2TS      4353 (0x1101)   0x81            AC3             deu (German)            7054.923                640                     564,408,320     3,307,080
00000.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7054.923                640                     564,408,320     3,307,080
00000.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            7054.923                640                     564,408,320     3,307,080
00000.M2TS      4356 (0x1104)   0x81            AC3             ita (Italian)           7054.923                640                     564,408,320     3,307,080
00000.M2TS      4608 (0x1200)   0x90            PGS             dan (Danish)            7054.923                33                      28,756,053      165,253
00000.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            7054.923                43                      38,257,649      218,782
00000.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           7054.923                43                      38,123,415      216,831
00000.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7054.923                36                      31,615,906      181,623
00000.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            7054.923                30                      26,224,103      151,943
00000.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           7054.923                42                      37,020,370      212,074
00000.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             7054.923                28                      24,550,169      141,218
00000.M2TS      4615 (0x1207)   0x90            PGS             nor (Norwegian)         7054.923                28                      24,522,656      142,297
00000.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           7054.923                30                      26,652,240      152,554
00000.M2TS      4617 (0x1209)   0x90            PGS             swe (Swedish)           7054.923                34                      29,570,975      169,950
00000.M2TS      4618 (0x120A)   0x90            PGS             deu (German)            7054.923                1                       1,247,461       7,176
00000.M2TS      4619 (0x120B)   0x90            PGS             spa (Spanish)           7054.923                1                       1,240,430       7,143
00000.M2TS      4620 (0x120C)   0x90            PGS             fra (French)            7054.923                1                       683,069         3,991
00000.M2TS      4621 (0x120D)   0x90            PGS             ita (Italian)           7054.923                2                       1,724,648       9,896
00000.M2TS      4622 (0x120E)   0x90            PGS             eng (English)           7054.923                47                      41,410,971      236,621
Stephen Dawson
hifi-writer.com
post #851 of 5106 Old 11-22-2009, 06:29 AM
From Hell - 2001 - Australian version
Distributed by Twentieth Century Fox Home Entertainment South Pacific Pty Ltd
Locked to Region B, confirmed with AnyDVD HD
This is an older Fox title, so it is menu-less. At the end of the movie, after running through some copyright text panels, it goes back to the start and plays again.
Code:
        Total   Video
00001.MPLS                                                      AVC     2:02:13 25,093,152,768  29,695,146,658  27.37   18.98   DTS-HD Master 5.1 4045Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     FROMHELL_F1
Disc Size:      29,695,146,658 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:02:13 (h:m:s)
Total Bitrate:          27.37 Mbps
VIDEO:
MPEG-4 AVC Video        18981 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4045 kbps       5.1 / 48 kHz / 4045 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       German          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         34.694 kbps
Presentation Graphics           French          25.272 kbps
Presentation Graphics           French          0.185 kbps
Presentation Graphics           German          36.384 kbps
Presentation Graphics           German          0.341 kbps
Presentation Graphics           Swedish         27.568 kbps
Presentation Graphics           Danish          28.812 kbps
Presentation Graphics           Finnish         30.111 kbps
Presentation Graphics           Norwegian       27.793 kbps
Presentation Graphics           Dutch           30.055 kbps
Presentation Graphics           English         66.997 kbps
Presentation Graphics           French          59.861 kbps
Presentation Graphics           German          68.167 kbps
Presentation Graphics           Swedish         60.771 kbps
Presentation Graphics           Danish          60.132 kbps
Presentation Graphics           Finnish         59.106 kbps
Presentation Graphics           Norwegian       60.767 kbps
Presentation Graphics           Dutch           64.045 kbps
Presentation Graphics           English         26.840 kbps
Presentation Graphics           French          26.866 kbps
Presentation Graphics           German          27.359 kbps
Presentation Graphics           Swedish         27.044 kbps
Presentation Graphics           Danish          26.866 kbps
Presentation Graphics           Finnish         26.905 kbps
Presentation Graphics           Norwegian       26.940 kbps
Presentation Graphics           Dutch           26.832 kbps
FILES:
00001.M2TS      0:00:00.000     2:02:12.325     25,093,128,192  27,378
00002.M2TS      2:02:12.325     0:00:01.000     24,576          196
CHAPTERS:
1               0:00:00.000     0:02:00.745     18,224 kbps     51,319 kbps     00:00:01.960    39,918 kbps     00:00:01.918    36,922 kbps     00:00:01.918    94,980 bytes    437,198 bytes   00:00:06.881
2               0:02:00.745     0:05:19.068     27,304 kbps     48,372 kbps     00:05:29.704    42,014 kbps     00:04:54.877    39,412 kbps     00:04:37.777    142,351 bytes   499,549 bytes   00:05:29.746
3               0:07:19.814     0:02:57.260     23,518 kbps     45,629 kbps     00:08:41.812    39,963 kbps     00:08:41.395    36,096 kbps     00:08:36.390    122,614 bytes   319,919 bytes   00:08:45.858
4               0:10:17.074     0:04:59.590     24,124 kbps     53,051 kbps     00:11:59.802    42,145 kbps     00:11:57.550    41,212 kbps     00:11:59.176    125,774 bytes   382,643 bytes   00:11:04.080
5               0:15:16.665     0:03:04.225     23,036 kbps     43,005 kbps     00:16:02.962    33,029 kbps     00:16:02.962    28,162 kbps     00:18:08.670    120,098 bytes   336,408 bytes   00:15:19.585
6               0:18:20.891     0:03:02.640     15,986 kbps     30,187 kbps     00:18:43.789    28,861 kbps     00:18:42.412    26,995 kbps     00:18:41.787    83,346 bytes    260,310 bytes   00:20:38.528
7               0:21:23.532     0:04:26.266     20,038 kbps     35,900 kbps     00:22:29.306    33,588 kbps     00:22:28.555    29,115 kbps     00:22:25.594    104,470 bytes   332,116 bytes   00:23:42.796
8               0:25:49.798     0:06:01.444     23,942 kbps     53,502 kbps     00:31:32.932    43,124 kbps     00:28:29.624    36,140 kbps     00:30:51.850    124,824 bytes   467,365 bytes   00:31:51.242
9               0:31:51.242     0:04:44.325     21,368 kbps     47,038 kbps     00:31:52.952    31,432 kbps     00:31:51.242    30,724 kbps     00:31:51.242    111,405 bytes   468,470 bytes   00:31:57.373
10              0:36:35.568     0:04:39.404     20,628 kbps     43,302 kbps     00:39:49.637    38,975 kbps     00:39:47.551    36,965 kbps     00:39:47.760    107,545 bytes   404,190 bytes   00:41:08.174
11              0:41:14.972     0:04:08.665     19,709 kbps     36,474 kbps     00:41:38.662    28,678 kbps     00:44:14.652    27,409 kbps     00:44:14.652    102,756 bytes   323,317 bytes   00:41:38.704
12              0:45:23.637     0:02:29.148     19,754 kbps     30,454 kbps     00:46:28.744    25,374 kbps     00:46:01.508    24,249 kbps     00:45:57.838    102,991 bytes   313,890 bytes   00:46:00.883
13              0:47:52.786     0:05:12.562     19,910 kbps     38,714 kbps     00:52:30.981    36,986 kbps     00:52:28.562    34,797 kbps     00:52:27.185    103,800 bytes   354,581 bytes   00:53:05.348
14              0:53:05.348     0:03:10.440     17,365 kbps     31,365 kbps     00:54:07.619    27,699 kbps     00:53:06.224    25,563 kbps     00:53:59.569    90,531 bytes    387,986 bytes   00:53:08.268
15              0:56:15.789     0:03:17.614     17,143 kbps     25,940 kbps     00:59:23.142    24,025 kbps     00:59:23.142    22,691 kbps     00:59:18.304    89,376 bytes    321,552 bytes   00:59:33.403
16              0:59:33.403     0:03:29.584     23,857 kbps     45,817 kbps     01:02:10.727    38,270 kbps     01:02:16.399    35,463 kbps     01:02:04.137    124,381 bytes   349,225 bytes   01:02:10.810
17              1:03:02.987     0:04:33.189     19,937 kbps     34,572 kbps     01:06:15.429    31,657 kbps     01:06:15.304    30,753 kbps     01:06:13.219    103,944 bytes   446,340 bytes   01:06:19.225
18              1:07:36.177     0:03:53.399     22,577 kbps     31,630 kbps     01:07:43.601    29,324 kbps     01:07:41.557    29,091 kbps     01:07:41.849    117,704 bytes   356,358 bytes   01:07:44.310
19              1:11:29.576     0:04:48.246     20,409 kbps     40,668 kbps     01:15:31.735    34,986 kbps     01:15:15.177    33,858 kbps     01:15:15.010    106,402 bytes   355,143 bytes   01:11:34.498
20              1:16:17.823     0:03:11.774     13,990 kbps     25,385 kbps     01:19:08.744    21,322 kbps     01:19:06.867    19,265 kbps     01:19:06.867    72,935 bytes    238,338 bytes   01:19:06.908
21              1:19:29.598     0:01:23.875     19,324 kbps     29,398 kbps     01:19:45.989    24,937 kbps     01:19:44.196    21,930 kbps     01:19:39.483    100,749 bytes   235,612 bytes   01:19:30.515
22              1:20:53.473     0:04:28.434     18,742 kbps     34,275 kbps     01:24:16.926    30,844 kbps     01:24:13.339    30,005 kbps     01:23:55.572    97,712 bytes    333,374 bytes   01:24:30.648
23              1:25:21.908     0:01:09.277     15,019 kbps     36,678 kbps     01:25:25.370    24,057 kbps     01:25:21.950    20,915 kbps     01:25:24.536    78,301 bytes    295,642 bytes   01:25:25.495
24              1:26:31.185     0:06:12.080     21,055 kbps     46,485 kbps     01:31:29.108    43,872 kbps     01:31:36.199    39,769 kbps     01:31:31.694    109,769 bytes   339,925 bytes   01:31:39.160
25              1:32:43.265     0:01:50.568     20,022 kbps     46,861 kbps     01:32:59.865    43,296 kbps     01:32:58.864    39,466 kbps     01:32:56.028    104,387 bytes   384,929 bytes   01:33:00.533
26              1:34:33.834     0:04:25.098     16,852 kbps     52,331 kbps     01:38:27.693    38,165 kbps     01:38:23.981    34,274 kbps     01:38:23.564    87,859 bytes    363,138 bytes   01:38:28.193
27              1:38:58.932     0:01:28.213     16,028 kbps     28,352 kbps     01:40:21.390    21,115 kbps     01:40:11.463    19,093 kbps     01:40:06.458    83,563 bytes    231,469 bytes   01:39:00.851
28              1:40:27.145     0:05:29.871     14,080 kbps     49,497 kbps     01:45:10.762    33,523 kbps     01:45:01.628    29,743 kbps     01:45:02.796    73,406 bytes    336,639 bytes   01:45:11.013
29              1:45:57.017     0:03:43.097     13,135 kbps     20,016 kbps     01:48:50.440    18,254 kbps     01:49:16.675    17,867 kbps     01:49:12.921    68,481 bytes    432,180 bytes   01:49:40.115
30              1:49:40.115     0:02:08.878     16,587 kbps     32,400 kbps     01:49:40.115    25,933 kbps     01:49:40.115    21,254 kbps     01:49:40.115    86,479 bytes    433,847 bytes   01:49:41.032
31              1:51:48.993     0:03:49.562     17,145 kbps     42,327 kbps     01:53:09.115    38,497 kbps     01:53:17.040    36,744 kbps     01:53:13.912    89,387 bytes    389,061 bytes   01:53:20.919
32              1:55:38.556     0:06:33.768     4,011 kbps      7,023 kbps      02:00:37.980    6,250 kbps      02:00:21.339    6,047 kbps      02:00:17.335    20,915 bytes    153,202 bytes   01:59:26.117
33              2:02:12.325     0:00:01.001     64 kbps         0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    346 bytes       449 bytes       02:02:12.408
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     7332.242                18,984                  17,399,647,737  94,665,831
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7332.242                4,046                   3,707,823,188   21,296,078
00001.M2TS      4353 (0x1101)   0x82            DTS             fra (French)            7332.242                755                     691,531,442     4,124,442
00001.M2TS      4354 (0x1102)   0x82            DTS             deu (German)            7332.242                755                     691,531,442     4,124,442
00001.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7332.242                224                     205,305,856     1,145,680
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7332.242                35                      31,803,011      181,240
00001.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7332.242                25                      23,165,736      133,442
00001.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7332.242                0                       169,304         983
00001.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            7332.242                36                      33,351,640      188,468
00001.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            7332.242                0                       312,702         1,807
00001.M2TS      4613 (0x1205)   0x90            PGS             swe (Swedish)           7332.242                28                      25,270,654      144,614
00001.M2TS      4614 (0x1206)   0x90            PGS             dan (Danish)            7332.242                29                      26,410,589      150,754
00001.M2TS      4615 (0x1207)   0x90            PGS             fin (Finnish)           7332.242                30                      27,601,380      157,289
00001.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         7332.242                28                      25,476,894      145,762
00001.M2TS      4617 (0x1209)   0x90            PGS             nld (Dutch)             7332.242                30                      27,550,787      156,989
00001.M2TS      4618 (0x120A)   0x90            PGS             eng (English)           7332.242                67                      61,413,471      343,005
00001.M2TS      4619 (0x120B)   0x90            PGS             fra (French)            7332.242                60                      54,872,319      307,236
00001.M2TS      4620 (0x120C)   0x90            PGS             deu (German)            7332.242                68                      62,486,034      348,681
00001.M2TS      4621 (0x120D)   0x90            PGS             swe (Swedish)           7332.242                61                      55,706,246      311,808
00001.M2TS      4622 (0x120E)   0x90            PGS             dan (Danish)            7332.242                60                      55,121,225      308,637
00001.M2TS      4623 (0x120F)   0x90            PGS             fin (Finnish)           7332.242                59                      54,180,188      303,522
00001.M2TS      4624 (0x1210)   0x90            PGS             nor (Norwegian)         7332.242                61                      55,702,654      311,794
00001.M2TS      4625 (0x1211)   0x90            PGS             nld (Dutch)             7332.242                64                      58,707,676      328,104
00001.M2TS      4626 (0x1212)   0x90            PGS             eng (English)           7332.242                27                      24,603,337      134,799
00001.M2TS      4627 (0x1213)   0x90            PGS             fra (French)            7332.242                27                      24,626,732      134,929
00001.M2TS      4628 (0x1214)   0x90            PGS             deu (German)            7332.242                27                      25,079,122      137,391
00001.M2TS      4629 (0x1215)   0x90            PGS             swe (Swedish)           7332.242                27                      24,790,670      135,818
00001.M2TS      4630 (0x1216)   0x90            PGS             dan (Danish)            7332.242                27                      24,626,858      134,929
00001.M2TS      4631 (0x1217)   0x90            PGS             fin (Finnish)           7332.242                27                      24,663,311      135,124
00001.M2TS      4632 (0x1218)   0x90            PGS             nor (Norwegian)         7332.242                27                      24,695,089      135,298
00001.M2TS      4633 (0x1219)   0x90            PGS             nld (Dutch)             7332.242                27                      24,595,783      134,760
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     0.876                   86                      9,404           61
Stephen Dawson
hifi-writer.com
post #852 of 5106 Old 11-22-2009, 06:57 AM
MarekM's Avatar
any chance to get info for BRAVEHEART UK edition ?
my friend bought one in Hungary, and they have indetical specs to UK edtition, but only DTS HR track, no DTS HD MASTER as printed on cover hmm
thanx for info.
Marek
MarekM is offline
post #853 of 5106 Old 11-22-2009, 07:29 AM
DigitalfreakNYC's Avatar
Quoted: 127 Post(s)
A Charlie Brown Christmas (US)
Code:
        Total   Video
00002.MPLS                                                      VC-1    0:25:28 4,936,267,776   10,404,132,056  25.83   23.23   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     CHARLIE_BROWN_XMAS
Disc Size:      10,404,132,056 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 0:25:28 (h:m:s)
Total Bitrate:          25.83 Mbps
VIDEO:
VC-1 Video              23228 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Japanese        640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         40.880 kbps
Presentation Graphics           Japanese        29.249 kbps
Presentation Graphics           Japanese        0.303 kbps
FILES:
00002.M2TS      0:00:00.000     0:25:28.860     4,936,267,776   25,830
CHAPTERS:
1               0:00:00.000     0:02:14.342     26,651 kbps     36,795 kbps     00:02:11.256    34,531 kbps     00:02:08.920    30,186 kbps     00:02:03.957    139,900 bytes   293,532 bytes   00:02:13.466
2               0:02:14.342     0:06:13.790     22,754 kbps     32,023 kbps     00:03:00.513    31,348 kbps     00:02:58.553    30,231 kbps     00:02:56.634    118,658 bytes   273,924 bytes   00:03:00.555
3               0:08:28.132     0:08:49.528     23,223 kbps     33,209 kbps     00:09:03.084    30,944 kbps     00:09:00.831    29,937 kbps     00:09:00.122    121,075 bytes   329,558 bytes   00:16:24.483
4               0:17:17.661     0:05:41.716     22,280 kbps     30,178 kbps     00:20:16.548    28,559 kbps     00:20:12.711    28,138 kbps     00:20:14.546    116,171 bytes   306,522 bytes   00:22:15.042
5               0:22:59.378     0:02:29.482     23,526 kbps     30,060 kbps     00:23:36.623    27,882 kbps     00:23:34.329    27,172 kbps     00:24:16.371    123,135 bytes   321,021 bytes   00:24:18.415
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0xEA            VC-1                                    1528.777                23,230                  4,439,140,445   24,147,922
00002.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           1528.777                640                     122,309,120     716,655
00002.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1528.777                640                     122,309,120     716,655
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1528.777                41                      7,812,483       44,446
00002.M2TS      4609 (0x1201)   0x90            PGS             jpn (Japanese)          1528.777                29                      5,589,619       32,408
00002.M2TS      4610 (0x1202)   0x90            PGS             jpn (Japanese)          1528.777                0                       57,853          387
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #854 of 5106 Old 11-22-2009, 12:43 PM
Quoted: 127 Post(s)
Keane- Live (US)
Code:
        Total   Video
00000.MPLS                                                      AVC     1:35:23 22,274,322,432  43,799,157,906  31.13   18.00   DTS-HD Master 5.1 3111Kbps (48kHz/24-bit) LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     KEANE
Disc Size:      43,799,157,906 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:35:23 (h:m:s)
Total Bitrate:          31.13 Mbps
VIDEO:
MPEG-4 AVC Video        17995 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        6000 kbps           480i / 29.970 fps / 4:3 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3111 kbps       5.1 / 48 kHz / 3111 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
FILES:
00002.M2TS      0:00:00.000     1:35:23.684     22,274,322,432  31,133
CHAPTERS:
1               0:00:00.000     0:02:25.845     14,205 kbps     30,084 kbps     00:01:32.392    27,054 kbps     00:00:22.722    24,073 kbps     00:01:20.280    59,235 bytes    291,526 bytes   00:00:27.027
2               0:02:25.845     0:04:09.148     21,625 kbps     31,232 kbps     00:03:37.750    30,302 kbps     00:03:34.280    28,658 kbps     00:04:36.609    90,192 bytes    294,654 bytes   00:04:21.160
3               0:06:34.994     0:03:53.199     20,384 kbps     31,362 kbps     00:08:55.234    29,409 kbps     00:08:51.297    26,250 kbps     00:08:46.826    85,020 bytes    294,222 bytes   00:10:02.802
4               0:10:28.194     0:04:39.178     12,780 kbps     30,261 kbps     00:14:03.609    24,818 kbps     00:13:56.902    24,003 kbps     00:13:56.402    53,305 bytes    287,909 bytes   00:12:37.923
5               0:15:07.373     0:03:10.657     14,804 kbps     31,143 kbps     00:17:04.690    28,537 kbps     00:17:00.853    25,550 kbps     00:16:10.836    61,745 bytes    284,245 bytes   00:17:05.090
6               0:18:18.030     0:03:52.632     17,626 kbps     31,450 kbps     00:21:09.134    25,310 kbps     00:21:05.998    24,145 kbps     00:21:05.998    73,515 bytes    295,138 bytes   00:20:29.561
7               0:22:10.662     0:04:07.480     16,207 kbps     31,389 kbps     00:24:30.569    29,900 kbps     00:24:05.944    27,975 kbps     00:24:01.406    67,596 bytes    287,148 bytes   00:24:01.773
8               0:26:18.143     0:01:57.684     20,987 kbps     30,970 kbps     00:26:43.868    30,414 kbps     00:26:42.667    30,091 kbps     00:26:37.929    87,535 bytes    295,525 bytes   00:26:47.572
9               0:28:15.827     0:04:31.204     13,382 kbps     29,592 kbps     00:29:49.721    25,549 kbps     00:30:26.658    21,987 kbps     00:30:22.754    55,814 bytes    280,335 bytes   00:32:33.484
10              0:32:47.031     0:01:21.748     19,649 kbps     31,039 kbps     00:33:12.056    30,426 kbps     00:33:10.922    29,591 kbps     00:33:09.821    81,951 bytes    292,672 bytes   00:33:17.061
11              0:34:08.780     0:03:01.714     14,757 kbps     25,919 kbps     00:35:26.524    23,779 kbps     00:34:09.180    19,563 kbps     00:34:08.780    61,548 bytes    234,554 bytes   00:36:17.909
12              0:37:10.494     0:04:15.255     12,965 kbps     30,420 kbps     00:40:58.489    28,853 kbps     00:40:58.522    24,668 kbps     00:40:58.322    54,076 bytes    288,050 bytes   00:40:59.323
13              0:41:25.749     0:01:55.248     15,560 kbps     27,152 kbps     00:42:56.307    23,449 kbps     00:42:13.597    20,640 kbps     00:42:35.819    64,897 bytes    272,623 bytes   00:43:11.455
14              0:43:20.998     0:04:53.893     14,242 kbps     30,482 kbps     00:47:01.351    29,025 kbps     00:46:58.315    22,929 kbps     00:47:36.086    59,403 bytes    290,987 bytes   00:47:01.418
15              0:48:14.892     0:01:33.426     14,198 kbps     27,049 kbps     00:49:34.071    23,522 kbps     00:49:33.370    19,800 kbps     00:49:33.170    59,218 bytes    223,655 bytes   00:49:35.372
16              0:49:48.318     0:04:26.666     21,486 kbps     31,169 kbps     00:52:29.579    28,939 kbps     00:52:38.088    28,023 kbps     00:52:38.488    89,615 bytes    297,959 bytes   00:52:49.699
17              0:54:14.985     0:05:21.454     22,611 kbps     31,789 kbps     00:54:54.457    30,701 kbps     00:58:31.941    30,463 kbps     00:58:30.006    94,306 bytes    299,193 bytes   00:55:44.474
18              0:59:36.439     0:01:13.940     14,119 kbps     28,106 kbps     01:00:10.640    22,140 kbps     01:00:08.438    20,549 kbps     01:00:16.379    58,888 bytes    278,270 bytes   01:00:11.274
19              1:00:50.380     0:05:49.949     21,956 kbps     31,513 kbps     01:03:19.095    30,623 kbps     01:05:43.339    30,216 kbps     01:05:43.673    91,573 bytes    298,165 bytes   01:01:16.205
20              1:06:40.329     0:04:08.448     19,996 kbps     31,472 kbps     01:08:34.243    30,179 kbps     01:09:19.288    27,764 kbps     01:07:27.476    83,401 bytes    297,756 bytes   01:10:27.957
21              1:10:48.777     0:04:54.894     21,848 kbps     31,479 kbps     01:11:50.239    29,819 kbps     01:14:11.146    29,479 kbps     01:13:48.891    91,124 bytes    295,844 bytes   01:14:12.381
22              1:15:43.672     0:03:35.415     16,867 kbps     31,730 kbps     01:16:48.203    28,552 kbps     01:18:23.298    23,546 kbps     01:19:05.674    70,351 bytes    296,295 bytes   01:18:24.633
23              1:19:19.087     0:03:58.905     15,158 kbps     31,686 kbps     01:20:18.246    28,248 kbps     01:20:16.077    24,662 kbps     01:20:55.984    63,221 bytes    294,679 bytes   01:20:19.748
24              1:23:17.993     0:06:01.561     23,532 kbps     31,765 kbps     01:27:53.568    30,899 kbps     01:27:37.885    29,871 kbps     01:28:33.074    98,148 bytes    298,930 bytes   01:28:32.106
25              1:29:19.554     0:04:42.081     18,741 kbps     31,490 kbps     01:30:37.965    30,050 kbps     01:30:35.730    27,905 kbps     01:30:36.130    78,166 bytes    297,455 bytes   01:30:49.644
26              1:34:01.636     0:01:22.048     13,376 kbps     31,101 kbps     01:34:07.842    29,960 kbps     01:34:07.541    29,288 kbps     01:34:07.408    55,811 bytes    292,813 bytes   01:34:08.843
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     5723.618                17,996                  12,874,991,687  70,158,257
00002.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           5723.618                2,310                   1,653,000,228   9,157,896
00002.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           5723.618                3,111                   2,226,107,196   12,991,235
00002.M2TS      6912 (0x1B00)   0x1B            AVC                                     5723.618                6,000                   4,292,542,400   23,512,918
Secondary Encode
Code:
DISC INFO:
Disc Title:     KEANE
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:34:33 (h:m:s)
Total Bitrate:          22.79 Mbps
VIDEO:
MPEG-4 AVC Video        15999 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3139 kbps       5.1 / 48 kHz / 3139 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
FILES:
00003.M2TS      0:00:00.000     1:34:33.200     16,164,538,368  22,794
CHAPTERS:
1               0:00:00.000     0:02:25.845     15,618 kbps     32,174 kbps     00:00:01.167    31,548 kbps     00:00:01.167    24,286 kbps     00:00:59.926    65,125 bytes    293,552 bytes   00:00:01.801
2               0:02:25.845     0:04:09.148     14,334 kbps     31,649 kbps     00:02:44.063    29,997 kbps     00:02:41.294    24,567 kbps     00:02:41.060    59,785 bytes    287,777 bytes   00:02:44.464
3               0:06:34.994     0:03:53.199     13,735 kbps     24,378 kbps     00:09:42.181    23,183 kbps     00:09:22.428    22,177 kbps     00:09:18.758    57,286 bytes    209,566 bytes   00:10:19.018
4               0:10:28.194     0:04:39.178     16,394 kbps     29,535 kbps     00:13:41.821    24,843 kbps     00:14:06.612    24,073 kbps     00:14:16.722    68,375 bytes    240,776 bytes   00:14:17.022
5               0:15:07.373     0:03:10.657     19,158 kbps     31,331 kbps     00:15:58.791    30,539 kbps     00:15:55.988    29,912 kbps     00:15:51.183    79,906 bytes    275,148 bytes   00:15:58.424
6               0:18:18.030     0:03:52.632     17,397 kbps     31,449 kbps     00:18:23.168    29,434 kbps     00:18:19.164    25,732 kbps     00:18:18.030    72,559 bytes    287,395 bytes   00:21:53.645
7               0:22:10.662     0:04:07.480     15,279 kbps     26,951 kbps     00:23:40.952    24,144 kbps     00:23:40.952    23,808 kbps     00:23:40.952    63,728 bytes    195,817 bytes   00:23:53.965
8               0:26:18.143     0:01:57.684     14,934 kbps     23,362 kbps     00:27:38.423    22,452 kbps     00:27:38.423    21,571 kbps     00:27:38.423    62,285 bytes    220,792 bytes   00:27:43.428
9               0:28:15.827     0:04:31.204     12,182 kbps     23,625 kbps     00:28:19.764    20,751 kbps     00:28:16.828    18,731 kbps     00:28:15.827    50,811 bytes    193,907 bytes   00:31:29.821
10              0:32:47.031     0:01:21.748     14,630 kbps     20,474 kbps     00:33:34.946    19,753 kbps     00:33:30.842    18,964 kbps     00:33:26.004    61,020 bytes    183,465 bytes   00:34:00.304
11              0:34:08.780     0:03:01.714     14,357 kbps     25,871 kbps     00:36:15.840    19,383 kbps     00:36:15.840    18,255 kbps     00:36:15.840    59,881 bytes    172,157 bytes   00:36:43.467
12              0:37:10.494     0:04:15.255     13,723 kbps     29,143 kbps     00:37:21.239    27,554 kbps     00:37:17.802    22,288 kbps     00:40:37.902    57,237 bytes    206,785 bytes   00:39:41.245
13              0:41:25.749     0:01:55.248     12,791 kbps     21,509 kbps     00:41:36.560    19,688 kbps     00:41:36.560    18,729 kbps     00:41:36.560    53,348 bytes    194,902 bytes   00:41:45.569
14              0:43:20.998     0:04:53.893     12,925 kbps     25,458 kbps     00:44:27.631    24,622 kbps     00:44:24.328    20,545 kbps     00:44:22.559    53,906 bytes    194,556 bytes   00:43:43.821
15              0:48:14.892     0:01:33.426     15,745 kbps     25,760 kbps     00:49:45.949    25,168 kbps     00:49:43.146    21,356 kbps     00:49:38.175    65,670 bytes    196,605 bytes   00:48:31.108
16              0:49:48.318     0:04:26.666     17,036 kbps     31,360 kbps     00:50:04.501    29,250 kbps     00:50:08.538    27,161 kbps     00:50:04.301    71,055 bytes    283,321 bytes   00:50:06.336
17              0:54:14.985     0:05:21.454     17,529 kbps     31,426 kbps     00:58:06.549    29,000 kbps     00:54:45.582    26,692 kbps     00:57:58.708    73,111 bytes    277,966 bytes   00:57:54.804
18              0:59:36.439     0:01:13.940     10,622 kbps     31,719 kbps     00:59:41.210    30,207 kbps     00:59:37.607    23,708 kbps     00:59:36.439    44,303 bytes    289,151 bytes   00:59:41.244
19              1:00:50.380     0:05:49.949     17,892 kbps     32,099 kbps     01:02:01.517    31,277 kbps     01:02:01.084    30,821 kbps     01:00:58.721    74,626 bytes    294,362 bytes   01:04:00.770
20              1:06:40.329     0:04:08.448     18,594 kbps     31,606 kbps     01:07:28.944    30,775 kbps     01:07:28.811    28,261 kbps     01:06:54.443    77,553 bytes    296,614 bytes   01:07:30.780
21              1:10:48.777     0:04:54.894     16,872 kbps     30,699 kbps     01:11:19.975    29,220 kbps     01:11:16.238    28,075 kbps     01:11:11.367    70,372 bytes    253,355 bytes   01:14:34.603
22              1:15:43.672     0:03:35.415     11,710 kbps     17,929 kbps     01:19:01.069    16,927 kbps     01:18:57.032    15,621 kbps     01:16:31.586    48,841 bytes    165,764 bytes   01:18:57.065
23              1:19:19.087     0:03:58.905     19,646 kbps     32,428 kbps     01:21:55.777    31,173 kbps     01:20:23.185    30,097 kbps     01:20:22.384    81,941 bytes    297,303 bytes   01:22:39.087
24              1:23:17.993     0:06:01.561     20,222 kbps     31,839 kbps     01:23:33.508    31,063 kbps     01:27:49.264    30,782 kbps     01:27:44.926    84,345 bytes    283,898 bytes   01:29:13.548
25              1:29:19.554     0:04:42.081     16,580 kbps     30,384 kbps     01:33:09.951    25,591 kbps     01:31:53.741    24,431 kbps     01:31:53.674    69,152 bytes    285,465 bytes   01:31:10.064
26              1:34:01.636     0:00:31.564     16,505 kbps     29,830 kbps     01:34:17.652    27,055 kbps     01:34:17.418    23,929 kbps     01:34:17.351    68,913 bytes    208,514 bytes   01:34:12.046
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     5673.067                16,000                  11,346,016,746  61,849,382
00003.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           5673.067                2,331                   1,653,000,228   9,157,896
00003.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           5673.067                3,139                   2,226,107,196   12,991,235
post #855 of 5106 Old 11-22-2009, 02:57 PM
MarekM's Avatar
http://www.dvdtimes.co.uk/content/id...salvation.html
but there still remains around 2hrs:38mins worth of 1080p footage on this disc. Combine this with the fact there are two high bitrate DTS-HD tracks accompanying all this footage (Original English and an Italian dub) and the end result is that all the Fulll-HD, AVC footage has an average video bitrate of just a touch under 20Mbps. This is low, and you can feel the strain frequently throughout the film (regardless of which version you're watching) in the form of compression artefacts like banding and most gratingly: obvious blocking. Just watch the early sequence where John Connor is navigating the dark tunnels of the Skynet human observation lab (where we first see Marcus Wright's body) and you'll see annoying compression problems.
I hope that US version will have MUCH bigger bitrate to aviod this....
Marek
MarekM is offline
post #856 of 5106 Old 11-22-2009, 04:12 PM
Quoted: 127 Post(s)
Rob Thomas Live At Red Rocks (US)
Code:
        Total   Video
00033.MPLS                                                      AVC     1:26:36 22,751,299,584  23,802,417,280  35.02   29.88   DTS-HD Master 5.1 2663Kbps (48kHz/16-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     ROB_THOMAS
Disc Size:      23,802,417,280 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:26:36 (h:m:s)
Total Bitrate:          35.02 Mbps
VIDEO:
MPEG-4 AVC Video        29885 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2663 kbps       5.1 / 48 kHz / 2663 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps
FILES:
00029.M2TS      0:00:00.000     1:26:36.791     22,751,299,584  35,024
CHAPTERS:
1               0:00:00.000     0:04:32.005     30,009 kbps     42,023 kbps     00:03:55.501    34,599 kbps     00:03:55.001    33,119 kbps     00:03:51.264    125,149 bytes   437,001 bytes   00:03:30.977
2               0:04:32.005     0:05:05.972     29,925 kbps     43,138 kbps     00:09:17.290    35,144 kbps     00:09:13.519    33,926 kbps     00:09:13.519    124,811 bytes   437,063 bytes   00:06:02.695
3               0:09:37.977     0:04:44.017     30,035 kbps     40,151 kbps     00:14:14.153    34,630 kbps     00:14:13.018    32,976 kbps     00:14:10.583    125,272 bytes   423,291 bytes   00:09:38.144
4               0:14:21.994     0:03:07.987     29,437 kbps     35,822 kbps     00:16:14.673    33,501 kbps     00:14:35.441    32,608 kbps     00:14:35.608    122,776 bytes   392,668 bytes   00:17:28.213
5               0:17:29.982     0:04:17.056     30,032 kbps     43,538 kbps     00:20:08.373    35,456 kbps     00:19:53.926    33,765 kbps     00:19:53.192    125,256 bytes   432,911 bytes   00:19:57.996
6               0:21:47.039     0:03:34.948     29,733 kbps     39,420 kbps     00:25:08.507    34,861 kbps     00:25:00.565    33,203 kbps     00:25:00.599    124,009 bytes   445,331 bytes   00:25:00.699
7               0:25:21.987     0:07:54.006     29,997 kbps     39,834 kbps     00:29:21.326    34,061 kbps     00:32:43.861    33,099 kbps     00:33:00.345    125,114 bytes   415,316 bytes   00:27:56.508
8               0:33:15.994     0:05:21.988     29,860 kbps     39,447 kbps     00:34:12.250    34,809 kbps     00:34:11.783    33,068 kbps     00:33:20.665    124,542 bytes   406,827 bytes   00:38:06.183
9               0:38:37.982     0:03:48.027     30,019 kbps     43,569 kbps     00:42:13.998    35,481 kbps     00:42:13.764    34,197 kbps     00:42:13.597    125,206 bytes   459,239 bytes   00:38:41.585
10              0:42:26.010     0:04:45.952     29,887 kbps     39,230 kbps     00:47:08.358    34,599 kbps     00:46:37.394    33,729 kbps     00:46:31.989    124,652 bytes   404,911 bytes   00:46:32.022
11              0:47:11.962     0:03:56.035     29,356 kbps     41,089 kbps     00:49:11.081    33,963 kbps     00:47:37.821    32,471 kbps     00:48:23.734    122,441 bytes   401,087 bytes   00:48:23.834
12              0:51:07.998     0:05:22.989     30,400 kbps     44,060 kbps     00:52:19.336    35,386 kbps     00:54:29.966    33,216 kbps     00:54:12.115    126,795 bytes   414,694 bytes   00:53:40.617
13              0:56:30.987     0:03:40.019     29,688 kbps     46,131 kbps     00:57:30.280    34,899 kbps     00:58:11.454    31,524 kbps     00:58:06.483    123,825 bytes   524,888 bytes   00:58:12.622
14              1:00:11.007     0:06:39.932     29,935 kbps     47,144 kbps     01:02:31.747    34,198 kbps     01:02:29.011    33,196 kbps     01:02:39.388    124,856 bytes   557,038 bytes   01:00:30.326
15              1:06:50.940     0:06:09.102     29,647 kbps     38,267 kbps     01:11:14.303    33,292 kbps     01:12:20.869    31,486 kbps     01:12:22.071    123,651 bytes   433,524 bytes   01:12:59.508
16              1:13:00.042     0:05:08.908     29,728 kbps     40,099 kbps     01:13:15.724    35,154 kbps     01:13:12.354    34,168 kbps     01:13:07.149    123,992 bytes   395,175 bytes   01:16:28.050
17              1:18:08.950     0:03:41.087     30,149 kbps     39,759 kbps     01:18:12.654    34,664 kbps     01:18:22.964    33,606 kbps     01:18:10.919    125,745 bytes   422,056 bytes   01:18:23.065
18              1:21:50.038     0:04:46.753     29,791 kbps     44,925 kbps     01:23:23.965    35,210 kbps     01:25:33.294    33,439 kbps     01:23:14.956    124,266 bytes   460,501 bytes   01:23:25.934
STREAM DIAGNOSTICS:
00029.M2TS      4113 (0x1011)   0x1B            AVC                                     5196.692                29,885                  19,413,177,568  105,675,339
00029.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5196.692                2,663                   1,729,875,464   10,210,874
00029.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5196.692                192                     124,723,200     812,000
00029.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5196.692                448                     291,020,800     1,624,000
post #857 of 5106 Old 11-22-2009, 04:30 PM - Thread Starter
Cinema Squid's Avatar
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
ABC [DE] 1995   12 Monkeys                                                      VC-1    1080p24 1.85:1  19.97   2:09:24 24,602,277,888  24,666,135,864  25.35   DTS     5.1    48     1509
ABC [UK] 1968   2001: A Space Odyssey                                            VC-1    1080p24 2.20:1  13.39   2:28:51 24,937,451,520  37,429,719,180  22.34   LPCM    5.1    48/16  4608  / AC3     5.1    48     448
ABC [US] 2007   3:10 to Yuma                                                     VC-1    1080p24 2.40:1  23.94   2:02:30 29,979,684,864  47,940,898,854  32.63   LPCM    7.1    48/16  6144  / AC3     5.1-EX 48     640
A   [US] 2009   Aliens in the Attic                                              AVC     1080p24 1.85:1  22.29   1:25:48 18,462,517,248  31,744,495,684  28.69   DTS-MA  5.1    48/24  3656
A   [US] 2009   Aliens in the Attic: Rental Edition                              AVC     1080p24 1.85:1  22.29   1:25:48 18,462,517,248  21,094,154,509  28.69   DTS-MA  5.1    48/24  3656
ABC [UK] 2007   American Gangster: Extended (seamless)                           VC-1    1080p24 1.85:1  14.62   2:55:45 35,042,353,152  49,500,968,583  26.59   DTS-MA  5.1    48/24  3996
                                   Theatrical (seamless)                 VC-1    1080p24 1.85:1  14.86   2:36:50 31,644,487,680                  26.90   DTS-MA  5.1    48/24  4012
ABC [US] 1987   Angel Heart                                                      AVC     1080p24 1.85:1  19.00   1:52:59 20,954,757,120  23,509,459,782  24.73   DTS-MA  5.1    48/24  3810
ABC [US] 2009   Angels and Demons: Extended (seamless)                          AVC     1080p24 2.40:1  24.14   2:26:15 35,209,445,376                  32.10   DTS-MA  5.1    48/24  3774
                                   Theatrical (seamless)                        AVC     1080p24 2.40:1  24.14   2:18:37 33,299,324,928                  32.03   DTS-MA  5.1    48/24  3774
ABC [AU] 2007   Becoming Jane                                                    AVC     1080i50 2.35:1  22.00   1:55:34 22,446,888,960  22,689,166,726  25.90   DTS-MA  5.1    48/16  2478
ABC [US] 2009   Brüno (seamless)                                         AVC     1080p24 1.85:1  24.08   1:21:26 19,328,581,632  41,564,260,059  31.65   DTS-MA  5.1    48/24  3476
                       Enhanced Commentary (seamless)                            AVC     1080p24 1.85:1  24.10   1:48:09 25,910,347,776                  31.94   AC3     2.0    48     192
ABC [UK] 2006   Cars                                                             AVC     1080p24 2.40:1  23.19   1:56:35 27,809,046,528  39,236,865,612  31.80   TrueHD  5.1    48/24  3679  / AC3     5.1-EX 48     640
ABC [US] 1965   A Charlie Brown Christmas                                        VC-1    1080p24 1.33:1  23.23   0:25:28 4,936,267,776   10,404,132,056  25.84   AC3     5.1    48     640
ABC [US] 1997   Chasing Amy                                                      VC-1    1080p24 1.85:1  20.23   1:53:08 24,606,240,768  42,796,245,949  29.00   DTS-MA  5.1    48/24  3584
A   [US] 2008   A Christmas Tale                                                AVC     1080p24 2.35:1  22.99   2:32:11 32,220,690,432  48,388,234,227  28.23   DTS-MA  5.1    48/24  3722
ABC [US] 1994   Clerks: Theatrical                                               AVC     1080p24 1.85:1  22.03   1:31:47 20,184,932,352  43,828,722,238  29.32   DTS-MA  5.1    48/24  3867
 B  [UK] 1955   The Dam Busters                                                 AVC     1080p24 1.33:1  20.99   2:05:27 22,999,733,952  23,122,777,896  24.45   LPCM    2.0    48/24  2304
ABC [UK] 2006   Day Watch                                                        AVC     1080p24 2.35:1  29.47   2:25:48 44,533,014,528  46,537,441,336  40.73   TrueHD  5.1    48/24  3617  / DTS     5.1    48     768
ABC [UK] 1988   Die Hard                                                 AVC     1080p24 2.40:1  25.90   2:12:07 32,553,762,816  37,529,945,017  32.85   DTS-MA  5.1    48/24  2282
ABC [US] 1971   Dirty Harry                                                     VC-1    1080p24 2.40:1  23.62   1:42:29 23,751,659,520  39,028,323,532  30.90   TrueHD  5.1    48/16  1514  / AC3     5.1    48     640
ABC [UK] 1971   Dirty Harry                                                      VC-1    1080p24 2.40:1  23.62   1:42:29 23,751,659,520  39,028,323,532  30.90   TrueHD  5.1    48/16  1514  / AC3     5.1    48     640
ABC [AU] 2008   Eagle Eye                                                        AVC     1080p24 2.40:1  29.62   1:57:35 35,211,491,328  45,702,444,692  39.93   TrueHD  5.1    48/24  3578
A   [US] 2007   Enchanted (seamless)                                             AVC     1080p24 2.35:1  21.90   1:47:28 25,003,229,184  45,602,820,932  31.02   TrueHD  5.1    48/24  3419  / AC3     5.1    48     640
                           The D-Files (seamless)                                AVC     1080p24 2.35:1  21.89   1:48:24 25,096,151,040                  30.87   AC3     5.1    48     448
ABC [US] 1999   Fight Club                                                       AVC     1080p24 2.40:1  23.45   2:19:08 34,166,661,120  46,456,080,536  32.74   DTS-MA  5.1    48/24  3266  / AC3     2.0    48     224
 B  [UK] 1986   The Fly                                                          AVC     1080p24 1.85:1  26.44   1:35:38 25,060,171,776  49,590,896,224  34.94   DTS-MA  5.1    48/24  4067
 B  [AU] 2001   From Hell                                                        AVC     1080p24 2.35:1  18.98   2:02:13 25,093,152,768  29,695,146,658  27.38   DTS-MA  5.1    48/24  4045
ABC [AU] 2009   G.I. Joe: The Rise of Cobra                                      AVC     1080p24 2.40:1  30.62   1:57:59 37,218,772,992  45,576,248,103  42.06   DTS-MA  5.1    48/24  4910  / AC3     5.1    48     640
ABC [US] 1999   Galaxy Quest                                                     AVC     1080p24 2.35:1  33.78   1:42:08 31,998,498,816  37,890,989,811  41.77   TrueHD  5.1    48/24  3486
ABC [UK] 1972   The Godfather                                                    AVC     1080p24 1.78:1  27.00   2:57:09 48,781,590,528  49,326,206,203  36.72   TrueHD  5.1    48/24  3557  / AC3     2.0    48     192
ABC [AU] 1972   The Godfather                                                    AVC     1080p24 1.78:1  27.00   2:57:09 48,781,590,528  49,326,206,530  36.72   TrueHD  5.1    48/24  3557  / AC3     2.0    48     192
ABC [UK] 1974   The Godfather: Part II                                           AVC     1080p24 1.78:1  22.42   3:22:06 48,295,163,904  48,692,967,662  31.86   TrueHD  5.1    48/24  3592
ABC [AU] 1974   The Godfather: Part II                                           AVC     1080p24 1.78:1  22.42   3:22:06 48,295,163,904  48,692,968,245  31.86   TrueHD  5.1    48/24  3592
ABC [UK] 1990   The Godfather: Part III                                          AVC     1080p24 1.78:1  28.93   2:50:15 48,078,206,976  48,078,206,976  37.65   TrueHD  5.1    48/16  3309
ABC [AU] 1990   The Godfather: Part III                                          AVC     1080p24 1.78:1  28.93   2:50:15 48,078,206,976  48,078,206,976  37.65   TrueHD  5.1    48/16  3309
ABC [UK] 2004   Hellboy                                                          AVC     1080p24 1.85:1  26.01   2:12:28 38,793,381,888  48,855,607,402  39.05   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
ABC [UK] 2008   Hellboy II: The Golden Army                                      AVC     1080p24 1.85:1  20.99   1:59:40 30,685,544,448  46,529,472,390  34.19   DTS-MA  7.1    48/24  5288
ABC [UK] 2007   Hot Fuzz                                                 VC-1    1080p24 2.40:1  21.20   2:00:46 31,566,759,936  45,601,536,136  34.85   DTS-MA  5.1    48/24  4148
ABC [US] 1966   How the Grinch Stole Christmas                                   VC-1    1080p24 1.33:1  21.76   0:25:45 4,497,678,336   6,927,438,925   23.29   AC3     2.0    48     192
A   [US] 2009   I Love You, Beth Cooper                                          AVC     1080p24 1.85:1  34.96   1:41:48 32,140,425,216  42,941,558,165  42.10   DTS-MA  5.1    48/24  3518
A   [US] 2002   Ice Age                                                          AVC     1080p24 1.85:1  16.18   1:21:05 13,896,222,720  17,968,121,934  22.85   DTS-MA  5.1    48/24  4066
A   [US] 2006   Ice Age: The Meltdown                                            MPEG-2  1080p24 1.85:1  17.90   1:30:36 16,927,604,736  24,315,595,866  24.91   DTS-MA  5.1    48/24  3928
A   [US] 2009   Ice Age: Dawn of the Dinosaurs                                   AVC     1080p24 1.85:1  35.68   2:02:49 31,413,712,896  46,175,017,296  34.10   DTS-MA  7.1    48/24  4674
A   [US] 2009   Ice Age: Dawn of the Dinosaurs: Rental Edition                   AVC     1080p24 1.85:1  35.68   1:34:03 31,075,117,056  33,371,171,772  44.05   DTS-MA  5.1    48/24  4674
    [US] 2009   Inglourious Basterds                                             AVC     1080p24 2.40:1  25.67   2:32:59 37,429,143,552  47,786,518,356  32.62   DTS-MA  5.1    48/24  3516
A   [US] 2001   Jay and Silent Bob Strike Back                                   MPEG-2  1080p24 2.35:1  18.06   1:44:27 19,931,897,856  20,221,544,086  25.44   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
    [US] 2007   Keane: Live at the O2                                            AVC     1080i60 1.78:1  18.00   1:35:23 22,274,322,432  43,799,157,906  31.14   DTS-MA  5.1    48/24  3111  / LPCM    2.0    48/24  2304
                                       Secondary PiP Encode                      AVC     1080i60 1.78:1  16.00   1:34:33 16,164,538,368                  22.80   DTS-MA  5.1    48/24  3139  / LPCM    2.0    48/24  2304
ABC [UK] 2003   Kill Bill: Volume 1                                              AVC     1080p24 2.40:1  30.06   1:50:43 37,005,232,128  41,556,466,060  44.56   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
ABC [UK] 2004   Kill Bill: Volume 2                                              AVC     1080p24 2.40:1  27.26   2:16:57 42,803,675,136  47,278,908,653  41.67   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
ABC [AU] 2004   Layer Cake                                                       MPEG-2  1080p24 2.40:1  26.57   1:45:23 32,666,449,920  37,537,764,608  41.33   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
AB  [DE] 1995   Leaving Las Vegas                                                VC-1    1080p24 1.85:1  20.64   1:51:25 23,471,628,288  27,433,066,573  28.09   DTS-MA  2.0    48/16  924
ABC [US] 1994   Léon: The Professional: International Cut (seamless)             AVC     1080p24 2.35:1  25.55   2:12:52 39,050,803,200  48,351,000,229  39.19   DTS-MA  5.1    96/24  5829
                                        Theatrical (seamless)                    AVC     1080p24 2.35:1  25.61   1:49:27 32,276,189,184                  39.32   DTS-MA  5.1    96/24  5943
ABC [AU] 2009   Mary and Max                                                     AVC     1080p24*1.85:1  20.00   1:32:10 16,724,621,760  20,258,242,073  24.19   DTS-MA  5.1    48/16  2298  / AC3     2.0    48     256
ABC [US] 2009   My Bloody Valentine: 2-D Rental Edition                          AVC     1080p24 1.85:1  16.00   1:41:00 17,736,375,168  20,210,885,356  23.41   DTS-MA  7.1    48/24  5068
    [DE] 2007   My Name Is Bruce                                                VC-1    1080p24 1.85:1  24.98   1:24:07 20,282,769,408  22,121,941,500  32.15   DTS-MA  5.1    48/16
ABC [UK] 2004   National Treasure                                                AVC     1080p24 2.40:1  22.41   2:11:04 34,800,076,800  48,752,596,130  35.40   TrueHD  5.1    48/16  1650
ABC [UK] 2004   Night Watch                                                      AVC     1080p24 1.85:1  32.95   1:54:21 37,754,382,336  43,949,394,764  44.02   TrueHD  5.1    48/24  3803  / DTS     5.1    48     768
    [DE] 2008   Nights in Rodanthe                                              VC-1    1080p24 2.40:1  17.47   1:37:06 16,238,161,920  22,905,160,020  22.30   AC3     5.1    48     640
ABC [US] 2004   The Passion of the Christ: Theatrical (seamless)         AVC     1080p24 2.35:1  22.39   2:06:32 28,268,316,672  41,566,110,029  29.79   DTS-MA  5.1    48/24  3959
                                           Edited (seamless)                     AVC     1080p24 2.35:1  22.37   2:01:51 26,899,064,832                  29.43   DTS-MA  5.1    48/24  3901
ABC [US] 2003   Pirates of the Caribbean: The Curse of the Black Pearl           AVC     1080p24 2.40:1  20.05   2:23:15 33,850,466,304  45,581,824,827  31.51   LPCM    5.1    48/24  6912  / AC3     5.1-EX 48     640
ABC [US] 2006   Pirates of the Caribbean: Dead Man's Chest                       AVC     1080p24 2.40:1  18.99   2:30:40 33,637,705,728  42,818,592,246  29.77   LPCM    5.1    48/24  6912  / AC3     5.1    48     640
A   [US] 2007   Pirates of the Caribbean: At World's End                 AVC     1080p24 2.40:1  22.14   2:48:31 41,492,570,112  45,035,768,044  32.83   LPCM    5.1    48/24  6912  / AC3     5.1    48     640
    [US] 2006   Rob Thomas: Something to Be Tour: Live at Red Rocks              AVC     1080i60 1.78:1  29.89   1:26:36 22,751,299,584  23,802,417,280  35.03   DTS-MA  5.1    48/16  2663  / AC3     5.1    48     448   / AC3     2.0    48     224
A   [US] 1970   The Rolling Stones: Gimme Shelter                               AVC     1080p24 1.33:1  34.98   1:31:44 29,860,915,200  36,952,558,557  43.40   DTS-MA  5.1    48/24  3804  / DTS-MA  2.0    48/24  1990
 B  [UK] 1959   Sleeping Beauty                                                  AVC     1080p24 2.55:1  24.06   1:15:10 20,355,717,120  36,779,614,017  36.11   DTS-MA  7.1    48/16  2591  / AC3     2.0    48     192
ABC [UK] 2008   Soul Power                                                      AVC     1080p24 1.78:1  29.99   1:32:20 26,331,469,824  28,971,921,180  38.02   DTS-MA  5.1    48/16  2205  / TrueHD  5.1    48/16  1576  / AC3     2.0    48     640
 B  [UK] 2007   Sunshine                                                 AVC     1080p24 2.35:1  24.65   1:47:27 27,332,990,976  34,614,667,486  33.92   DTS-MA  5.1    48/24  4009  / AC3     5.1    48     384
ABC [US] 2001   Swordfish                                                        VC-1    1080p24 2.40:1  20.02   1:39:15 17,242,951,680  20,348,598,040  23.16   AC3     5.1    48     640
ABC [AU] 2009   Terminator Salvation: Director's Cut (seamless)                  AVC     1080p24 2.40:1  19.95   1:57:40 27,402,006,528  45,026,260,616  31.05   DTS-MA  5.1    48/24  2660
                                      Maximum Movie Mode (seamless)              AVC     1080p24 2.40:1  19.78   2:01:58 28,058,185,728                  30.67   DTS-MA  5.1    48/24  2512
                                      Theatrical (seamless)                      AVC     1080p24 2.40:1  19.67   1:54:46 26,688,724,992                  31.01   DTS-MA  5.1    48/24  2720
ABC [UK] 2008   The Tudors: Season 2: Disc 1: Episodes 1-4                       AVC     1080p24 1.78:1  24.89   3:35:08 46,846,937,088  47,385,637,581  29.03   TrueHD  5.1    48/16  1421
                                      Disc 2: Episodes 5-7                       AVC     1080p24 1.78:1  31.98   2:38:09 43,217,805,312  43,756,165,980  36.44   TrueHD  5.1    48/16  1424
                                      Disc 3: Episodes 8-10                      AVC     1080p24 1.78:1  32.00   2:31:56 41,506,418,688  46,647,971,955  36.43   TrueHD  5.1    48/16  1406
 B  [AU] 2005   Wedding Crashers: Unrated                                        VC-1    1080p24 2.40:1  14.09   2:07:00 18,189,182,976  38,608,878,116  19.10   TrueHD  5.1    48/16  1487  / AC3     5.1    48     640
                                  Theatrical                                     VC-1    1080p24 2.40:1  15.57   1:59:03 18,427,484,160                  20.64   TrueHD  5.1    48/16  1476  / AC3     5.1    48     640
A   [US] 1987   Wings of Desire                                                  AVC     1080p24 1.66:1  23.98   2:07:44 26,440,255,488  49,824,683,398  27.60   DTS-MA  5.1    48/16  1911
Cinema Squid is offline
post #858 of 5106 Old 11-22-2009, 06:03 PM
Quoted: 127 Post(s)
Tori Amos: Live at Montreux (US)
Show 1
Code:
        Total   Video
00001.MPLS                                                      AVC     0:49:13 11,615,311,872  23,364,171,692  31.46   23.00   DTS-HD Master 5.1 4600Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     EVBRD333229
Disc Size:      23,364,171,692 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 0:49:13 (h:m:s)
Total Bitrate:          31.46 Mbps
VIDEO:
MPEG-4 AVC Video        22999 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4600 kbps       5.1 / 48 kHz / 4600 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
FILES:
00001.M2TS      0:00:00.000     0:49:13.417     11,615,311,872  31,463
CHAPTERS:
1               0:00:00.000     0:06:53.045     23,443 kbps     34,999 kbps     00:05:15.315    33,728 kbps     00:03:23.036    33,138 kbps     00:05:09.409    97,767 bytes    347,569 bytes   00:05:09.442
2               0:06:53.045     0:06:28.788     22,775 kbps     34,914 kbps     00:10:40.673    33,389 kbps     00:10:34.533    32,866 kbps     00:10:31.931    94,991 bytes    342,815 bytes   00:10:26.892
3               0:13:21.834     0:04:53.559     21,538 kbps     31,724 kbps     00:17:01.954    28,979 kbps     00:16:52.544    28,708 kbps     00:16:52.945    89,833 bytes    308,326 bytes   00:16:53.846
4               0:18:15.394     0:05:26.759     24,200 kbps     31,723 kbps     00:23:15.026    30,111 kbps     00:20:00.532    29,072 kbps     00:19:55.594    100,934 bytes   303,164 bytes   00:23:09.321
5               0:23:42.154     0:04:15.054     24,698 kbps     34,993 kbps     00:26:26.685    34,002 kbps     00:26:25.250    31,576 kbps     00:26:21.913    103,012 bytes   340,685 bytes   00:27:57.208
6               0:27:57.208     0:04:14.954     25,015 kbps     33,826 kbps     00:29:11.416    31,222 kbps     00:30:11.643    30,914 kbps     00:30:06.171    104,331 bytes   337,144 bytes   00:30:09.274
7               0:32:12.163     0:05:08.107     24,146 kbps     34,994 kbps     00:33:00.478    32,864 kbps     00:36:02.693    32,189 kbps     00:36:01.559    100,708 bytes   348,525 bytes   00:32:46.397
8               0:37:20.271     0:07:10.396     22,124 kbps     34,948 kbps     00:39:40.544    32,068 kbps     00:39:37.074    31,518 kbps     00:39:31.535    92,274 bytes    345,686 bytes   00:37:23.774
9               0:44:30.668     0:04:41.614     19,593 kbps     34,839 kbps     00:45:25.622    30,226 kbps     00:47:46.029    29,810 kbps     00:46:18.375    81,721 bytes    316,351 bytes   00:46:27.184
10              0:49:12.282     0:00:01.134     95 kbps         99 kbps         00:49:12.382    0 kbps          00:00:00.000    0 kbps          00:00:00.000    410 bytes       1,466 bytes     00:49:12.883
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     2953.284                23,000                  8,490,521,855   46,240,039
00001.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           2953.284                1,542                   569,419,376     3,544,104
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2953.284                448                     165,392,640     922,950
00001.M2TS      4354 (0x1102)   0x86            DTS-HD MA       eng (English)           2953.284                4,601                   1,698,389,692   9,690,347
Show #2
Code:
        Total   Video
00000.MPLS                                                      AVC     0:45:24 10,700,470,272  23,364,171,692  31.42   23.00   DTS-HD Master 5.1 4558Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 0:45:24 (h:m:s)
Total Bitrate:          31.42 Mbps
VIDEO:
AUDIO:
DTS-HD Master Audio             English         4558 kbps       5.1 / 48 kHz / 4558 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
FILES:
00000.M2TS      0:00:00.000     0:45:24.555     10,700,470,272  31,419
CHAPTERS:
1               0:00:00.000     0:04:35.775     21,851 kbps     31,417 kbps     00:01:26.786    29,624 kbps     00:01:25.819    29,351 kbps     00:03:13.793    91,127 bytes    292,738 bytes   00:01:30.790
2               0:04:35.775     0:04:40.013     23,995 kbps     34,926 kbps     00:06:34.794    32,106 kbps     00:06:31.190    31,754 kbps     00:06:25.785    100,078 bytes   304,799 bytes   00:06:32.425
3               0:09:15.788     0:05:20.353     23,597 kbps     34,989 kbps     00:12:12.932    34,058 kbps     00:12:11.931    33,174 kbps     00:12:09.328    98,420 bytes    347,274 bytes   00:14:28.934
4               0:14:36.141     0:06:26.819     21,293 kbps     34,999 kbps     00:19:07.212    33,722 kbps     00:15:42.174    33,239 kbps     00:15:42.174    88,810 bytes    348,102 bytes   00:19:10.616
5               0:21:02.961     0:03:22.302     21,262 kbps     34,995 kbps     00:21:52.044    32,200 kbps     00:21:41.967    31,350 kbps     00:21:43.735    88,679 bytes    342,949 bytes   00:21:43.802
6               0:24:25.263     0:01:31.891     26,931 kbps     34,989 kbps     00:24:45.317    33,505 kbps     00:24:46.852    32,573 kbps     00:24:45.650    112,324 bytes   348,760 bytes   00:24:48.086
7               0:25:57.155     0:04:35.675     20,598 kbps     34,995 kbps     00:27:57.976    32,320 kbps     00:30:21.252    30,721 kbps     00:27:55.974    85,911 bytes    299,101 bytes   00:28:05.083
8               0:30:32.831     0:03:45.858     25,020 kbps     34,993 kbps     00:32:32.550    32,597 kbps     00:31:09.300    32,055 kbps     00:31:09.234    104,355 bytes   342,172 bytes   00:32:00.451
9               0:34:18.689     0:06:34.994     26,116 kbps     34,999 kbps     00:38:55.433    34,230 kbps     00:36:08.799    33,680 kbps     00:35:53.384    108,924 bytes   348,038 bytes   00:39:03.974
10              0:40:53.684     0:04:29.569     21,142 kbps     34,992 kbps     00:42:52.202    32,764 kbps     00:42:49.500    32,434 kbps     00:41:52.409    88,178 bytes    346,589 bytes   00:44:19.056
11              0:45:23.253     0:00:01.301     102 kbps        108 kbps        00:45:23.520    0 kbps          00:00:00.000    0 kbps          00:00:00.000    435 bytes       1,468 bytes     00:45:23.854
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     2724.455                23,000                  7,832,641,205   42,657,146
00000.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           2724.455                1,542                   525,295,168     3,269,472
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2724.455                448                     152,576,256     851,430
00000.M2TS      4354 (0x1102)   0x86            DTS-HD MA       eng (English)           2724.455                4,558                   1,552,412,348   8,862,241
post #859 of 5106 Old 11-22-2009, 09:13 PM
CRT Dude's Avatar
Warner using a higher bitrate than Sony. Good luck with that one. It will probably have Warner's famous filtering so you'll be trading sharpness for less artifacts.
CRT Dude is offline
post #860 of 5106 Old 11-23-2009, 12:19 AM
MarekM's Avatar
hopefully we will get some pics, so we can compate those two.
Marek
MarekM is offline
post #861 of 5106 Old 11-23-2009, 06:38 AM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
This is an excellent opportunity for Warner to do a better encoding job than Sony. I hope they did that. I think Warner may use BD-50 for the disc with Maximum Movie Mode feature and BD-25 for the cut without BonusView.
If the differences are noticeable like Watchmen, then I have no qualms in buying the Warner BD.
Blu-ray : 340
lgans316 is offline
post #862 of 5106 Old 11-23-2009, 10:08 AM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
[US] Hannibal                                                   MPEG-2  2:11:32 23,624,140,800  24,570,455,062  23.94   17.63   DTS-HD Master 5.1 4022Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     79441102_HANNIBAL
Disc Size:      24,570,455,062 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:11:32 (h:m:s)
Total Bitrate:          23.94 Mbps
VIDEO:
MPEG-2 Video            17633 kbps          1080p / 23.976 fps / 16:9
AUDIO:
DTS-HD Master Audio             English         4022 kbps       5.1 / 48 kHz / 4022 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         36.679 kbps
Presentation Graphics           Spanish         32.412 kbps
Presentation Graphics           French          0.561 kbps
Presentation Graphics           Spanish         0.233 kbps
FILES:
00002.M2TS      0:00:00.000     2:11:32.801     23,624,140,800  23,945
CHAPTERS:
1               0:00:00.000     0:03:01.055     14,563 kbps     21,815 kbps     00:00:19.936    19,537 kbps     00:00:17.434    18,072 kbps     00:00:16.433    75,906 bytes    640,518 bytes   00:03:01.055
2               0:03:01.055     0:02:04.749     21,780 kbps     44,297 kbps     00:03:37.884    31,356 kbps     00:04:26.766    27,480 kbps     00:03:59.864    113,549 bytes   703,083 bytes   00:03:07.103
3               0:05:05.805     0:05:35.460     18,075 kbps     40,891 kbps     00:10:36.761    37,103 kbps     00:10:36.260    27,877 kbps     00:10:31.255    94,233 bytes    698,573 bytes   00:10:36.802
4               0:10:41.265     0:03:22.869     16,781 kbps     36,168 kbps     00:11:31.399    31,099 kbps     00:11:30.481    25,142 kbps     00:11:29.438    87,488 bytes    652,104 bytes   00:11:35.361
5               0:14:04.134     0:02:47.917     17,407 kbps     26,542 kbps     00:15:11.410    22,074 kbps     00:15:07.448    20,897 kbps     00:16:25.901    90,752 bytes    579,906 bytes   00:14:46.343
6               0:16:52.052     0:06:02.528     17,491 kbps     41,449 kbps     00:20:46.411    32,956 kbps     00:20:46.411    28,675 kbps     00:20:46.411    91,188 bytes    633,907 bytes   00:22:54.581
7               0:22:54.581     0:01:22.957     18,848 kbps     38,009 kbps     00:24:09.197    25,301 kbps     00:24:05.235    24,670 kbps     00:24:00.230    98,264 bytes    664,803 bytes   00:24:17.539
8               0:24:17.539     0:04:39.988     17,700 kbps     39,920 kbps     00:27:32.901    38,247 kbps     00:27:36.196    35,324 kbps     00:27:31.358    92,281 bytes    703,081 bytes   00:27:35.236
9               0:28:57.527     0:07:09.595     17,567 kbps     36,839 kbps     00:30:17.023    35,011 kbps     00:30:13.228    33,529 kbps     00:30:13.520    91,584 bytes    703,085 bytes   00:34:42.413
10              0:36:07.123     0:02:27.897     17,317 kbps     37,406 kbps     00:36:58.466    29,343 kbps     00:36:54.754    23,872 kbps     00:36:50.124    90,281 bytes    627,437 bytes   00:38:35.021
11              0:38:35.021     0:05:03.720     18,335 kbps     35,474 kbps     00:41:55.763    25,333 kbps     00:43:04.331    23,667 kbps     00:42:57.283    95,589 bytes    682,588 bytes   00:43:38.741
12              0:43:38.741     0:03:51.689     17,166 kbps     29,302 kbps     00:43:38.741    23,066 kbps     00:43:38.741    21,964 kbps     00:43:38.741    89,495 bytes    541,042 bytes   00:44:36.131
13              0:47:30.430     0:03:04.183     17,333 kbps     25,394 kbps     00:48:21.106    22,368 kbps     00:50:03.083    21,759 kbps     00:50:01.373    90,367 bytes    555,250 bytes   00:50:27.524
14              0:50:34.614     0:04:06.621     16,693 kbps     34,443 kbps     00:53:26.411    32,844 kbps     00:53:26.411    24,901 kbps     00:53:23.783    87,031 bytes    703,081 bytes   00:53:26.578
15              0:54:41.236     0:05:07.974     18,218 kbps     31,937 kbps     00:56:16.331    22,787 kbps     00:56:14.621    20,706 kbps     00:56:11.117    94,982 bytes    617,163 bytes   00:59:49.085
16              0:59:49.210     0:02:42.287     18,371 kbps     38,846 kbps     01:01:06.120    31,538 kbps     01:01:02.533    24,810 kbps     01:01:03.701    95,778 bytes    703,081 bytes   01:00:15.361
17              1:02:31.497     0:04:10.792     17,504 kbps     24,439 kbps     01:03:39.774    21,992 kbps     01:03:36.270    19,879 kbps     01:03:36.229    91,259 bytes    704,462 bytes   01:06:42.289
18              1:06:42.289     0:03:32.837     18,643 kbps     34,030 kbps     01:06:45.001    30,729 kbps     01:07:08.149    27,643 kbps     01:07:03.144    97,194 bytes    783,024 bytes   01:07:12.945
19              1:10:15.127     0:05:19.027     17,091 kbps     26,377 kbps     01:14:42.978    21,025 kbps     01:15:29.149    20,028 kbps     01:15:24.144    89,105 bytes    639,250 bytes   01:10:33.646
20              1:15:34.154     0:06:07.158     16,869 kbps     37,086 kbps     01:20:21.107    23,120 kbps     01:20:20.190    20,215 kbps     01:20:20.190    87,948 bytes    703,081 bytes   01:19:35.437
21              1:21:41.313     0:05:03.469     18,887 kbps     34,460 kbps     01:23:04.854    33,048 kbps     01:22:31.821    32,682 kbps     01:22:27.442    98,468 bytes    703,081 bytes   01:22:35.742
22              1:26:44.782     0:03:29.083     17,250 kbps     31,911 kbps     01:26:59.088    24,046 kbps     01:26:57.420    21,411 kbps     01:26:52.373    89,935 bytes    588,762 bytes   01:28:10.201
23              1:30:13.866     0:03:32.712     16,215 kbps     27,200 kbps     01:30:51.154    20,271 kbps     01:33:30.438    19,387 kbps     01:33:29.353    84,540 bytes    638,010 bytes   01:32:14.153
24              1:33:46.579     0:05:16.441     19,333 kbps     35,250 kbps     01:38:11.969    30,235 kbps     01:37:50.072    27,046 kbps     01:37:47.736    100,793 bytes   490,298 bytes   01:36:09.513
25              1:39:03.020     0:03:22.410     17,451 kbps     29,682 kbps     01:39:52.987    25,300 kbps     01:39:51.527    23,835 kbps     01:39:46.146    90,983 bytes    439,564 bytes   01:39:31.715
26              1:42:25.430     0:03:33.421     17,249 kbps     28,902 kbps     01:45:42.294    27,872 kbps     01:45:39.624    23,886 kbps     01:45:36.413    89,928 bytes    451,378 bytes   01:44:37.145
27              1:45:58.852     0:04:27.100     18,346 kbps     37,228 kbps     01:48:44.851    24,497 kbps     01:48:43.183    22,105 kbps     01:50:10.061    95,648 bytes    539,543 bytes   01:49:35.860
28              1:50:25.952     0:01:50.485     19,089 kbps     36,167 kbps     01:51:57.752    32,439 kbps     01:51:56.126    29,729 kbps     01:51:55.208    99,521 bytes    639,959 bytes   01:51:57.877
29              1:52:16.438     0:09:23.271     16,994 kbps     34,198 kbps     01:53:40.939    30,817 kbps     01:52:24.279    30,410 kbps     01:52:20.275    88,599 bytes    630,616 bytes   02:01:39.709
30              2:01:39.709     0:03:40.762     18,313 kbps     33,499 kbps     02:04:03.060    27,316 kbps     02:04:13.279    24,809 kbps     02:04:12.945    95,477 bytes    703,081 bytes   02:04:04.854
31              2:05:20.471     0:01:48.858     16,613 kbps     32,547 kbps     02:07:02.364    23,763 kbps     02:07:00.154    20,014 kbps     02:06:55.649    86,614 bytes    703,088 bytes   02:07:07.661
32              2:07:09.330     0:04:23.471     16,917 kbps     24,893 kbps     02:10:43.710    23,306 kbps     02:10:42.709    22,173 kbps     02:10:40.207    88,211 bytes    454,100 bytes   02:10:44.461
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x02            MPEG-2                                  7892.718                17,633                  17,396,547,673  94,656,619
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7892.718                4,022                   3,968,109,332   22,793,853
00002.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           7892.718                448                     441,998,592     2,466,510
00002.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            7892.718                448                     441,998,592     2,466,510
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7892.718                37                      36,187,991      207,003
00002.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           7892.718                32                      31,977,621      183,031
00002.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7892.718                1                       553,152         3,137
00002.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7892.718                0                       229,521         1,306
eric.exe is offline
post #863 of 5106 Old 11-25-2009, 05:49 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Gone with the Wind - 1939 - UK - Warner - Region ABC
A bit disappointing that the 'Overture', 'Intermission', and 'Exit Music' titles (clearly visible on the bitrate chart) are freeze-framed. It's unnerving, and just looks very odd and artificial compared to the rest of the movie.
Code:
        Total   Video
00000.MPLS                                                      VC-1    3:53:14 44,401,987,584  44,970,009,511  25.38   18.40   Dolby TrueHD 5.1 1251Kbps (48kHz/16-bit)  DD AC3 1.0 192Kbps
Code:
DISC INFO:
Disc Title:     GONE_WITH_THE_WIND
Disc Size:      44,970,009,511 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 3:53:14 (h:m:s)
Total Bitrate:          25.38 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
VC-1 Video              18399 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         1251 kbps       5.1 / 48 kHz / 1251 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             French          384 kbps        5.1 / 48 kHz / 384 kbps / DN -4dB
Dolby Digital Audio             German          384 kbps        5.1 / 48 kHz / 384 kbps / DN -4dB
Dolby Digital Audio             Italian         384 kbps        5.1 / 48 kHz / 384 kbps / DN -4dB
Dolby Digital Audio             Spanish         384 kbps        5.1 / 48 kHz / 384 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
* Dolby Digital Audio           Japanese        192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Portuguese      192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Spanish         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         39.090 kbps
Presentation Graphics           Danish          28.308 kbps
Presentation Graphics           Dutch           29.566 kbps
Presentation Graphics           Finnish         27.165 kbps
Presentation Graphics           French          26.327 kbps
Presentation Graphics           German          40.542 kbps
Presentation Graphics           Italian         34.809 kbps
Presentation Graphics           Italian         36.298 kbps
* Presentation Graphics         Japanese        36.787 kbps
* Presentation Graphics         Japanese        0.421 kbps
* Presentation Graphics         Japanese        41.460 kbps
Presentation Graphics           Norwegian       27.032 kbps
Presentation Graphics           Portuguese      31.965 kbps
Presentation Graphics           Spanish         31.877 kbps
Presentation Graphics           Spanish         31.615 kbps
Presentation Graphics           Swedish         27.430 kbps
FILES:
00000.M2TS      0:00:00.000     3:53:14.271     44,401,987,584  25,383
CHAPTERS:
1               0:00:00.000     0:02:35.780     2,993 kbps      10,932 kbps     00:02:32.110    7,568 kbps      00:02:29.107    6,549 kbps      00:02:24.102    15,851 bytes    235,547 bytes   00:02:31.150
2               0:02:35.780     0:04:11.125     29,376 kbps     55,563 kbps     00:06:26.928    41,234 kbps     00:02:58.136    39,675 kbps     00:05:37.003    154,848 bytes   519,321 bytes   00:04:03.243
3               0:06:46.906     0:02:52.088     23,976 kbps     47,489 kbps     00:07:04.006    41,748 kbps     00:07:00.002    38,766 kbps     00:08:53.616    125,031 bytes   435,695 bytes   00:06:49.992
4               0:09:38.995     0:05:46.429     22,074 kbps     41,364 kbps     00:12:08.853    39,669 kbps     00:12:08.227    38,716 kbps     00:12:04.932    115,084 bytes   450,397 bytes   00:10:17.074
5               0:15:25.424     0:02:28.231     31,776 kbps     45,131 kbps     00:16:18.352    40,084 kbps     00:16:14.223    39,735 kbps     00:16:09.051    165,664 bytes   434,917 bytes   00:17:28.589
6               0:17:53.655     0:03:48.519     19,298 kbps     29,358 kbps     00:20:05.746    28,678 kbps     00:20:05.704    25,326 kbps     00:20:05.287    100,609 bytes   399,342 bytes   00:19:07.145
7               0:21:42.175     0:04:04.702     21,017 kbps     33,505 kbps     00:21:49.766    31,911 kbps     00:21:47.764    31,611 kbps     00:23:09.346    109,573 bytes   467,091 bytes   00:23:03.173
8               0:25:46.878     0:02:48.126     17,007 kbps     26,515 kbps     00:26:05.689    25,624 kbps     00:26:05.647    23,595 kbps     00:26:20.120    88,669 bytes    355,682 bytes   00:28:01.846
9               0:28:35.004     0:04:00.031     24,047 kbps     38,191 kbps     00:29:55.710    37,231 kbps     00:29:51.706    34,580 kbps     00:29:46.701    125,368 bytes   400,725 bytes   00:32:25.944
10              0:32:35.036     0:03:04.309     20,007 kbps     28,678 kbps     00:34:38.493    27,516 kbps     00:34:37.784    26,867 kbps     00:34:32.862    104,306 bytes   299,885 bytes   00:33:02.146
11              0:35:39.345     0:02:30.316     19,086 kbps     27,589 kbps     00:36:42.325    25,485 kbps     00:36:10.376    24,944 kbps     00:36:04.996    99,508 bytes    285,553 bytes   00:36:37.445
12              0:38:09.662     0:04:12.585     15,258 kbps     30,491 kbps     00:40:10.866    24,532 kbps     00:40:00.106    23,634 kbps     00:40:03.109    79,547 bytes    303,202 bytes   00:39:58.145
13              0:42:22.248     0:03:40.303     18,551 kbps     32,933 kbps     00:45:59.923    25,925 kbps     00:44:55.401    24,206 kbps     00:42:22.456    96,715 bytes    363,246 bytes   00:45:59.965
14              0:46:02.551     0:02:44.539     16,270 kbps     27,047 kbps     00:46:03.677    26,056 kbps     00:46:02.634    23,541 kbps     00:46:02.551    84,826 bytes    287,534 bytes   00:46:41.465
15              0:48:47.090     0:03:15.069     14,967 kbps     28,653 kbps     00:49:24.544    27,839 kbps     00:49:24.544    26,071 kbps     00:49:23.210    78,065 bytes    462,419 bytes   00:49:18.080
16              0:52:02.160     0:03:24.245     15,959 kbps     27,834 kbps     00:53:28.914    25,439 kbps     00:53:28.163    23,026 kbps     00:53:23.158    83,203 bytes    296,645 bytes   00:52:15.799
17              0:55:26.406     0:03:16.362     18,942 kbps     28,858 kbps     00:57:07.215    26,642 kbps     00:57:07.215    26,204 kbps     00:57:07.215    98,754 bytes    253,398 bytes   00:58:22.123
18              0:58:42.769     0:02:59.679     14,958 kbps     23,482 kbps     01:01:40.279    21,676 kbps     01:01:36.275    20,529 kbps     01:01:31.312    77,984 bytes    263,085 bytes   01:01:11.834
19              1:01:42.448     0:03:03.349     16,447 kbps     28,060 kbps     01:01:43.449    24,516 kbps     01:01:43.199    21,887 kbps     01:01:43.199    85,766 bytes    484,112 bytes   01:02:14.856
20              1:04:45.798     0:05:56.064     24,438 kbps     50,454 kbps     01:05:29.508    41,441 kbps     01:05:25.504    36,683 kbps     01:05:20.499    127,408 bytes   452,984 bytes   01:07:00.725
21              1:10:41.862     0:04:08.623     17,758 kbps     45,002 kbps     01:14:48.150    35,172 kbps     01:14:44.271    29,446 kbps     01:14:40.476    92,585 bytes    401,995 bytes   01:14:48.442
22              1:14:50.486     0:02:16.427     19,530 kbps     41,608 kbps     01:14:55.407    35,178 kbps     01:14:53.614    32,128 kbps     01:14:50.819    101,822 bytes   458,778 bytes   01:15:55.592
23              1:17:06.913     0:01:47.065     20,536 kbps     35,810 kbps     01:17:43.283    31,191 kbps     01:17:39.279    29,487 kbps     01:18:07.891    107,067 bytes   321,594 bytes   01:17:44.284
24              1:18:53.979     0:04:12.752     15,563 kbps     24,864 kbps     01:19:39.733    22,960 kbps     01:23:01.476    21,828 kbps     01:22:56.596    81,136 bytes    284,348 bytes   01:19:39.775
25              1:23:06.731     0:04:32.981     25,400 kbps     47,256 kbps     01:26:06.953    41,982 kbps     01:25:20.657    38,855 kbps     01:25:21.157    132,423 bytes   360,772 bytes   01:25:34.629
26              1:27:39.712     0:04:07.580     32,341 kbps     46,147 kbps     01:31:15.303    42,294 kbps     01:31:13.634    39,537 kbps     01:30:50.069    168,613 bytes   402,346 bytes   01:31:46.042
27              1:31:47.293     0:03:10.940     20,547 kbps     34,804 kbps     01:32:03.518    31,573 kbps     01:32:00.264    29,598 kbps     01:31:57.345    107,120 bytes   475,096 bytes   01:32:36.968
28              1:34:58.234     0:03:05.143     19,538 kbps     27,112 kbps     01:35:52.955    25,764 kbps     01:35:44.572    25,232 kbps     01:35:44.613    101,860 bytes   220,217 bytes   01:35:52.997
29              1:38:03.377     0:03:55.735     15,896 kbps     24,509 kbps     01:38:08.257    22,638 kbps     01:38:26.150    22,480 kbps     01:38:22.521    82,876 bytes    219,302 bytes   01:38:56.639
30              1:41:59.112     0:02:13.842     22,092 kbps     37,381 kbps     01:44:06.198    30,754 kbps     01:42:43.365    29,987 kbps     01:42:37.651    116,668 bytes   289,974 bytes   01:44:06.240
31              1:44:12.955     0:03:59.530     5,790 kbps      12,985 kbps     01:48:07.522    7,800 kbps      01:44:14.414    6,811 kbps      01:44:14.414    30,310 bytes    280,715 bytes   01:46:22.376
32              1:48:12.486     0:01:30.465     4,211 kbps      21,044 kbps     01:48:13.945    8,300 kbps      01:48:12.903    6,036 kbps      01:48:12.903    21,954 bytes    224,434 bytes   01:49:08.959
33              1:49:42.951     0:02:58.553     22,970 kbps     41,221 kbps     01:51:20.632    36,037 kbps     01:50:16.026    35,295 kbps     01:50:03.722    120,599 bytes   630,410 bytes   01:50:54.564
34              1:52:41.504     0:04:49.914     18,746 kbps     30,511 kbps     01:54:27.068    27,771 kbps     01:54:23.940    26,068 kbps     01:54:21.020    97,747 bytes    358,412 bytes   01:53:03.610
35              1:57:31.419     0:04:11.751     17,442 kbps     32,373 kbps     01:57:33.087    27,390 kbps     01:57:33.004    25,224 kbps     01:58:55.419    91,012 bytes    504,199 bytes   01:58:29.310
36              2:01:43.170     0:02:04.165     17,200 kbps     30,688 kbps     02:02:38.976    27,613 kbps     02:02:38.934    24,103 kbps     02:02:38.934    89,945 bytes    543,567 bytes   02:02:42.355
37              2:03:47.336     0:05:32.582     14,930 kbps     26,415 kbps     02:09:18.917    25,581 kbps     02:09:12.578    23,742 kbps     02:09:09.908    77,837 bytes    415,866 bytes   02:09:15.330
38              2:09:19.918     0:02:01.287     24,264 kbps     45,436 kbps     02:11:00.060    41,817 kbps     02:10:56.849    35,743 kbps     02:10:51.718    126,503 bytes   620,618 bytes   02:10:58.475
39              2:11:21.206     0:03:03.182     19,819 kbps     33,918 kbps     02:13:00.430    30,345 kbps     02:12:56.593    29,805 kbps     02:12:51.338    103,445 bytes   398,048 bytes   02:12:53.006
40              2:14:24.389     0:05:15.481     19,496 kbps     31,931 kbps     02:18:33.722    30,293 kbps     02:18:30.760    26,549 kbps     02:18:43.189    101,643 bytes   465,918 bytes   02:18:30.802
41              2:19:39.871     0:05:38.629     16,812 kbps     32,257 kbps     02:19:58.848    30,050 kbps     02:19:57.806    28,429 kbps     02:19:52.801    87,652 bytes    492,668 bytes   02:19:59.307
42              2:25:18.501     0:04:35.900     19,285 kbps     31,065 kbps     02:28:05.209    27,649 kbps     02:25:28.636    26,991 kbps     02:27:57.285    100,545 bytes   380,871 bytes   02:27:56.450
43              2:29:54.402     0:02:48.668     13,323 kbps     26,348 kbps     02:30:29.228    23,517 kbps     02:32:16.043    23,255 kbps     02:32:10.538    69,459 bytes    248,967 bytes   02:30:17.174
44              2:32:43.070     0:04:43.616     17,732 kbps     33,081 kbps     02:37:06.959    30,152 kbps     02:37:03.247    26,426 kbps     02:36:58.242    92,448 bytes    270,786 bytes   02:34:24.046
45              2:37:26.687     0:05:20.778     19,120 kbps     24,592 kbps     02:41:27.302    22,996 kbps     02:41:12.537    22,727 kbps     02:41:12.412    99,684 bytes    276,022 bytes   02:40:56.813
46              2:42:47.466     0:03:13.067     22,179 kbps     27,678 kbps     02:45:28.168    25,778 kbps     02:45:21.453    25,077 kbps     02:45:19.451    115,630 bytes   315,385 bytes   02:45:59.115
47              2:46:00.533     0:07:11.681     19,073 kbps     25,320 kbps     02:53:11.214    23,459 kbps     02:52:11.529    22,806 kbps     02:52:52.904    99,437 bytes    386,490 bytes   02:47:45.764
48              2:53:12.215     0:04:01.032     21,890 kbps     29,279 kbps     02:54:57.028    27,821 kbps     02:54:57.028    27,633 kbps     02:54:57.028    114,125 bytes   388,968 bytes   02:57:12.663
49              2:57:13.247     0:03:12.233     16,579 kbps     30,724 kbps     02:58:13.391    24,861 kbps     02:58:09.387    23,389 kbps     02:58:07.593    86,435 bytes    390,849 bytes   02:57:14.665
50              3:00:25.481     0:04:43.366     14,674 kbps     26,781 kbps     03:05:02.216    25,830 kbps     03:04:58.921    24,626 kbps     03:04:57.795    76,502 bytes    312,674 bytes   03:02:12.588
51              3:05:08.847     0:03:38.092     14,578 kbps     29,111 kbps     03:07:38.205    27,918 kbps     03:07:36.411    27,110 kbps     03:07:31.406    76,003 bytes    416,128 bytes   03:06:42.316
52              3:08:46.940     0:03:30.752     16,378 kbps     25,129 kbps     03:10:10.232    24,152 kbps     03:10:10.273    23,972 kbps     03:10:05.602    85,388 bytes    342,679 bytes   03:10:10.649
53              3:12:17.692     0:01:50.944     19,520 kbps     27,763 kbps     03:14:07.636    22,930 kbps     03:14:03.632    22,085 kbps     03:13:58.627    101,770 bytes   263,449 bytes   03:12:22.697
54              3:14:08.637     0:04:44.242     16,295 kbps     26,863 kbps     03:16:04.794    23,897 kbps     03:16:04.794    23,396 kbps     03:16:04.753    84,957 bytes    257,020 bytes   03:16:04.878
55              3:18:52.879     0:05:21.237     21,056 kbps     31,225 kbps     03:19:45.682    29,119 kbps     03:19:43.054    28,317 kbps     03:19:45.556    109,778 bytes   388,492 bytes   03:19:44.973
56              3:24:14.116     0:05:41.466     11,667 kbps     42,088 kbps     03:26:23.537    30,077 kbps     03:26:20.701    23,587 kbps     03:26:15.738    60,827 bytes    325,506 bytes   03:26:25.456
57              3:29:55.582     0:02:30.817     14,351 kbps     33,887 kbps     03:32:16.682    28,953 kbps     03:32:13.303    25,577 kbps     03:32:10.801    74,820 bytes    494,899 bytes   03:32:13.345
58              3:32:26.400     0:03:03.308     20,700 kbps     30,369 kbps     03:35:11.732    26,549 kbps     03:35:07.978    26,055 kbps     03:35:02.973    107,920 bytes   214,779 bytes   03:32:35.409
59              3:35:29.708     0:03:59.822     20,270 kbps     29,988 kbps     03:35:57.402    28,619 kbps     03:35:57.402    28,166 kbps     03:35:57.069    105,678 bytes   253,282 bytes   03:39:29.531
60              3:39:29.531     0:02:14.050     17,777 kbps     21,793 kbps     03:39:52.971    20,346 kbps     03:39:50.218    19,550 kbps     03:41:33.571    92,679 bytes    250,825 bytes   03:41:27.232
61              3:41:43.581     0:04:59.799     16,571 kbps     27,836 kbps     03:44:04.347    25,724 kbps     03:44:01.052    25,145 kbps     03:43:59.384    86,391 bytes    335,863 bytes   03:41:57.220
62              3:46:43.381     0:02:13.550     15,285 kbps     24,019 kbps     03:47:17.707    23,121 kbps     03:47:16.372    22,252 kbps     03:47:14.495    80,242 bytes    236,275 bytes   03:48:45.753
63              3:48:56.931     0:04:17.340     6,294 kbps      13,919 kbps     03:48:58.224    9,765 kbps      03:48:57.932    8,062 kbps      03:48:57.932    33,078 bytes    261,439 bytes   03:49:01.936
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    13994.147               18,399                  32,184,311,210  175,115,709
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           13994.147               1,891                   3,307,104,240   23,923,838
00000.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            13994.147               384                     671,725,056     3,935,889
00000.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            13994.147               384                     671,725,056     3,935,889
00000.M2TS      4355 (0x1103)   0x81            AC3             ita (Italian)           13994.147               384                     671,725,056     3,935,889
00000.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           13994.147               384                     671,725,056     3,935,889
00000.M2TS      4357 (0x1105)   0x81            AC3             spa (Spanish)           13994.147               192                     335,862,528     2,186,605
00000.M2TS      4358 (0x1106)   0x81            AC3             por (Portuguese)        13994.147               192                     335,862,528     2,186,605
00000.M2TS      4359 (0x1107)   0x81            AC3             jpn (Japanese)          13994.147               192                     335,862,528     2,186,605
00000.M2TS      4360 (0x1108)   0x81            AC3             eng (English)           13994.147               192                     335,862,528     2,186,605
00000.M2TS      4361 (0x1109)   0x81            AC3             eng (English)           13994.147               192                     335,862,528     2,186,605
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           13994.147               39                      68,379,621      391,849
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            13994.147               26                      46,053,946      268,007
00000.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            13994.147               41                      70,919,032      405,877
00000.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           13994.147               35                      60,890,003      350,340
00000.M2TS      4612 (0x1204)   0x90            PGS             ita (Italian)           13994.147               36                      63,496,119      365,449
00000.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           13994.147               32                      55,762,508      322,499
00000.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             13994.147               30                      51,718,465      294,871
00000.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           13994.147               32                      55,303,127      320,055
00000.M2TS      4616 (0x1208)   0x90            PGS             por (Portuguese)        13994.147               32                      55,915,578      320,303
00000.M2TS      4617 (0x1209)   0x90            PGS             nor (Norwegian)         13994.147               27                      47,287,438      269,832
00000.M2TS      4618 (0x120A)   0x90            PGS             dan (Danish)            13994.147               28                      49,517,995      281,937
00000.M2TS      4619 (0x120B)   0x90            PGS             fin (Finnish)           13994.147               27                      47,518,858      271,283
00000.M2TS      4620 (0x120C)   0x90            PGS             swe (Swedish)           13994.147               27                      47,982,712      276,727
00000.M2TS      4621 (0x120D)   0x90            PGS             jpn (Japanese)          13994.147               37                      64,351,696      369,703
00000.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          13994.147               0                       736,754         4,811
00000.M2TS      4623 (0x120F)   0x90            PGS             jpn (Japanese)          13994.147               41                      72,525,659      412,929
paku is offline
post #864 of 5106 Old 11-25-2009, 06:55 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
North by Northwest - 1959 - UK - Warner - Region ABC
Code:
        Total   Video
00001.MPLS                                                      VC-1    2:16:25 34,328,414,208  46,256,498,694  33.55   26.73   Dolby TrueHD 5.1 1326Kbps (48kHz/16-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     NORTH_BY_NORTHWEST
Disc Size:      46,256,498,694 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:16:25 (h:m:s)
Total Bitrate:          33.55 Mbps
VIDEO:
VC-1 Video              26734 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         1326 kbps       5.1 / 48 kHz / 1326 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             French          192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             German          192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Italian         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         33.827 kbps
Presentation Graphics           Danish          23.507 kbps
Presentation Graphics           Finnish         21.599 kbps
Presentation Graphics           French          21.561 kbps
Presentation Graphics           German          32.200 kbps
Presentation Graphics           Italian         26.747 kbps
Presentation Graphics           Italian         28.232 kbps
* Presentation Graphics         Japanese        24.371 kbps
* Presentation Graphics         Japanese        30.165 kbps
* Presentation Graphics         Japanese        10.140 kbps
Presentation Graphics           Norwegian       26.554 kbps
Presentation Graphics           Portuguese      25.191 kbps
Presentation Graphics           Spanish         30.646 kbps
Presentation Graphics           Spanish         29.893 kbps
Presentation Graphics           Swedish         21.514 kbps
FILES:
00001.M2TS      0:00:00.000     2:16:25.218     34,328,414,208  33,552
CHAPTERS:
1               0:00:00.000     0:02:15.593     23,998 kbps     38,225 kbps     00:01:59.828    35,393 kbps     00:01:58.493    34,069 kbps     00:01:53.530    126,634 bytes   491,204 bytes   00:00:43.501
2               0:02:15.593     0:02:22.350     28,144 kbps     38,540 kbps     00:03:46.476    33,007 kbps     00:02:52.422    32,382 kbps     00:02:44.831    146,728 bytes   299,099 bytes   00:04:37.944
3               0:04:37.944     0:02:34.445     26,303 kbps     46,738 kbps     00:05:41.549    35,932 kbps     00:05:40.423    33,909 kbps     00:05:40.423    137,132 bytes   404,964 bytes   00:05:41.591
4               0:07:12.390     0:04:05.536     27,173 kbps     52,640 kbps     00:09:21.894    36,616 kbps     00:09:17.890    34,466 kbps     00:09:54.760    141,669 bytes   428,402 bytes   00:07:27.405
5               0:11:17.927     0:03:08.521     24,907 kbps     51,665 kbps     00:13:38.859    36,217 kbps     00:13:03.991    33,065 kbps     00:14:03.801    129,853 bytes   406,355 bytes   00:13:39.860
6               0:14:26.448     0:03:26.748     22,434 kbps     36,783 kbps     00:16:31.699    32,157 kbps     00:16:30.197    29,605 kbps     00:16:28.195    116,963 bytes   245,245 bytes   00:16:50.300
7               0:17:53.197     0:04:54.335     26,648 kbps     42,543 kbps     00:21:58.233    37,200 kbps     00:18:41.995    31,548 kbps     00:18:41.995    138,929 bytes   362,181 bytes   00:21:44.469
8               0:22:47.532     0:03:56.861     26,067 kbps     46,357 kbps     00:24:23.670    36,698 kbps     00:25:42.541    32,551 kbps     00:24:23.336    135,902 bytes   401,046 bytes   00:26:19.202
9               0:26:44.394     0:02:53.423     26,622 kbps     39,264 kbps     00:27:11.087    36,774 kbps     00:27:09.252    34,185 kbps     00:27:05.373    138,792 bytes   410,335 bytes   00:27:08.460
10              0:29:37.817     0:02:45.623     26,633 kbps     49,976 kbps     00:31:38.021    33,970 kbps     00:31:38.021    32,382 kbps     00:30:37.460    138,853 bytes   381,728 bytes   00:31:38.062
11              0:32:23.441     0:02:24.394     27,090 kbps     41,547 kbps     00:34:00.872    36,516 kbps     00:33:48.192    33,134 kbps     00:33:48.192    141,235 bytes   347,475 bytes   00:34:45.124
12              0:34:47.835     0:01:57.992     26,096 kbps     36,680 kbps     00:35:47.019    34,156 kbps     00:35:45.184    32,348 kbps     00:35:10.942    136,051 bytes   369,270 bytes   00:35:43.516
13              0:36:45.828     0:01:43.561     28,471 kbps     48,942 kbps     00:38:03.239    37,203 kbps     00:38:03.239    33,871 kbps     00:38:01.237    148,435 bytes   388,342 bytes   00:38:26.637
14              0:38:29.390     0:03:00.179     26,580 kbps     40,493 kbps     00:39:36.832    35,318 kbps     00:39:33.496    33,320 kbps     00:40:08.447    138,574 bytes   423,527 bytes   00:38:33.394
15              0:41:29.570     0:02:42.328     27,182 kbps     39,015 kbps     00:42:44.520    36,014 kbps     00:44:06.894    33,470 kbps     00:42:57.491    141,714 bytes   348,344 bytes   00:43:31.942
16              0:44:11.899     0:02:12.173     28,975 kbps     49,656 kbps     00:45:02.241    34,187 kbps     00:45:00.364    32,982 kbps     00:44:41.679    151,060 bytes   379,157 bytes   00:45:03.075
17              0:46:24.072     0:05:00.800     28,173 kbps     48,890 kbps     00:49:30.884    34,972 kbps     00:47:01.860    33,727 kbps     00:50:07.963    146,883 bytes   363,189 bytes   00:46:40.756
18              0:51:24.873     0:03:29.500     28,398 kbps     47,398 kbps     00:52:52.794    34,224 kbps     00:52:56.882    33,554 kbps     00:52:52.377    148,054 bytes   363,844 bytes   00:52:53.420
19              0:54:54.374     0:02:44.539     28,133 kbps     40,338 kbps     00:56:36.184    37,224 kbps     00:56:05.320    34,427 kbps     00:56:00.690    146,670 bytes   294,378 bytes   00:55:17.314
20              0:57:38.913     0:02:38.950     27,591 kbps     39,291 kbps     00:58:24.959    32,754 kbps     00:59:27.230    32,102 kbps     00:59:22.475    144,300 bytes   317,584 bytes   00:58:25.919
21              1:00:17.864     0:02:35.071     28,941 kbps     50,218 kbps     01:00:53.066    36,303 kbps     01:00:35.465    33,663 kbps     01:02:42.925    150,965 bytes   387,828 bytes   01:00:53.608
22              1:02:52.935     0:03:17.614     25,733 kbps     39,650 kbps     01:06:08.631    35,518 kbps     01:06:04.835    32,667 kbps     01:06:00.539    134,158 bytes   377,391 bytes   01:06:03.876
23              1:06:10.549     0:02:56.217     28,765 kbps     44,389 kbps     01:08:40.574    35,003 kbps     01:08:39.323    34,280 kbps     01:08:39.323    149,970 bytes   483,408 bytes   01:06:39.578
24              1:09:06.767     0:02:34.195     24,493 kbps     45,627 kbps     01:09:43.804    36,290 kbps     01:11:13.644    31,279 kbps     01:09:22.741    127,693 bytes   477,709 bytes   01:10:19.256
25              1:11:40.963     0:02:42.579     28,112 kbps     53,831 kbps     01:12:00.399    35,976 kbps     01:13:25.484    33,121 kbps     01:14:04.231    146,563 bytes   479,953 bytes   01:13:40.707
26              1:14:23.542     0:01:16.409     28,502 kbps     39,800 kbps     01:14:58.619    35,259 kbps     01:14:55.699    34,119 kbps     01:14:58.118    148,598 bytes   492,271 bytes   01:14:35.971
27              1:15:39.952     0:03:21.868     24,784 kbps     45,998 kbps     01:15:43.205    35,995 kbps     01:17:26.350    34,080 kbps     01:17:14.338    129,212 bytes   366,734 bytes   01:15:43.247
28              1:19:01.820     0:04:12.168     24,099 kbps     51,662 kbps     01:22:22.270    35,037 kbps     01:22:21.728    31,226 kbps     01:22:16.723    125,641 bytes   387,536 bytes   01:22:22.312
29              1:23:13.988     0:02:11.631     25,618 kbps     43,615 kbps     01:24:55.131    32,690 kbps     01:24:53.421    30,920 kbps     01:25:15.485    133,559 bytes   372,035 bytes   01:24:54.422
30              1:25:25.620     0:02:42.579     25,880 kbps     44,305 kbps     01:27:39.003    36,374 kbps     01:27:30.286    34,367 kbps     01:27:30.787    134,925 bytes   333,172 bytes   01:27:40.004
31              1:28:08.199     0:01:45.605     26,076 kbps     43,195 kbps     01:29:30.823    36,574 kbps     01:29:40.583    31,440 kbps     01:29:35.578    135,948 bytes   358,089 bytes   01:29:31.449
32              1:29:53.805     0:04:03.243     27,612 kbps     46,754 kbps     01:32:24.330    36,188 kbps     01:30:12.198    33,364 kbps     01:31:08.838    143,954 bytes   397,713 bytes   01:32:24.372
33              1:33:57.048     0:02:01.287     28,787 kbps     32,646 kbps     01:34:44.428    30,864 kbps     01:34:40.424    30,197 kbps     01:34:35.461    150,083 bytes   274,539 bytes   01:34:21.155
34              1:35:58.335     0:04:38.945     23,009 kbps     33,977 kbps     01:36:42.713    30,829 kbps     01:36:41.712    29,960 kbps     01:36:37.208    119,958 bytes   305,863 bytes   01:36:42.755
35              1:40:37.281     0:05:15.148     28,700 kbps     40,207 kbps     01:40:43.620    37,370 kbps     01:41:24.411    34,119 kbps     01:41:35.798    149,627 bytes   452,211 bytes   01:41:56.652
36              1:45:52.429     0:05:37.920     29,147 kbps     38,257 kbps     01:49:55.005    33,911 kbps     01:49:03.328    32,366 kbps     01:46:37.933    151,960 bytes   465,486 bytes   01:47:03.500
37              1:51:30.350     0:03:36.799     24,191 kbps     43,918 kbps     01:51:39.859    34,974 kbps     01:51:37.857    32,086 kbps     01:51:33.144    126,122 bytes   662,642 bytes   01:54:50.466
38              1:55:07.150     0:03:16.696     23,894 kbps     40,361 kbps     01:57:29.876    35,302 kbps     01:57:18.114    34,225 kbps     01:57:13.109    124,574 bytes   318,057 bytes   01:57:29.917
39              1:58:23.846     0:03:57.904     29,122 kbps     50,323 kbps     01:59:09.642    36,530 kbps     01:59:37.128    34,099 kbps     02:00:11.996    151,831 bytes   340,893 bytes   01:59:10.434
40              2:02:21.751     0:04:36.276     27,585 kbps     49,749 kbps     02:05:21.847    36,943 kbps     02:04:34.133    34,649 kbps     02:06:25.661    143,816 bytes   436,968 bytes   02:04:38.262
41              2:06:58.027     0:01:50.610     29,323 kbps     34,294 kbps     02:08:46.677    32,927 kbps     02:07:35.105    32,479 kbps     02:08:38.419    152,878 bytes   289,894 bytes   02:07:37.107
42              2:08:48.637     0:01:39.933     26,108 kbps     36,438 kbps     02:09:02.901    33,103 kbps     02:09:01.650    30,853 kbps     02:08:56.645    136,116 bytes   344,185 bytes   02:09:35.184
43              2:10:28.570     0:01:25.168     27,251 kbps     40,657 kbps     02:10:29.363    35,435 kbps     02:10:28.570    32,926 kbps     02:11:43.729    142,072 bytes   359,967 bytes   02:11:53.739
44              2:11:53.739     0:02:38.491     26,918 kbps     41,540 kbps     02:12:45.207    37,120 kbps     02:13:52.899    33,862 kbps     02:14:20.260    140,336 bytes   359,220 bytes   02:12:45.248
45              2:14:32.230     0:01:07.358     27,599 kbps     39,028 kbps     02:14:35.609    34,556 kbps     02:14:37.569    34,271 kbps     02:14:32.564    143,890 bytes   289,792 bytes   02:14:38.612
46              2:15:39.589     0:00:43.877     26,118 kbps     38,270 kbps     02:16:15.417    36,217 kbps     02:16:13.123    31,924 kbps     02:16:08.410    140,579 bytes   357,285 bytes   02:16:16.418
47              2:16:23.466     0:00:01.751     192 kbps        236 kbps        02:16:24.176    0 kbps          00:00:00.000    0 kbps          00:00:00.000    1,914 bytes     9,236 bytes     02:16:24.426
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0xEA            VC-1                                    8185.094                26,734                  27,352,805,532  148,774,923
00001.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           8185.094                1,966                   2,011,427,438   14,588,916
00001.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            8185.094                192                     196,468,992     1,279,095
00001.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            8185.094                192                     196,468,992     1,279,095
00001.M2TS      4355 (0x1103)   0x81            AC3             ita (Italian)           8185.094                192                     196,468,992     1,279,095
00001.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           8185.094                192                     196,468,992     1,279,095
00001.M2TS      4357 (0x1105)   0x81            AC3             por (Portuguese)        8185.094                192                     196,468,992     1,279,095
00001.M2TS      4358 (0x1106)   0x81            AC3             jpn (Japanese)          8185.094                192                     196,468,992     1,279,095
00001.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           8185.094                192                     196,468,992     1,279,095
00001.M2TS      4360 (0x1108)   0x81            AC3             eng (English)           8185.094                640                     654,896,640     3,837,285
00001.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          8185.094                24                      24,935,338      145,450
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8185.094                34                      34,610,626      198,322
00001.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8185.094                22                      22,059,896      128,512
00001.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            8185.094                32                      32,945,364      189,294
00001.M2TS      4612 (0x1204)   0x90            PGS             ita (Italian)           8185.094                27                      27,366,170      158,224
00001.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           8185.094                28                      28,885,682      166,941
00001.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           8185.094                31                      31,355,583      180,509
00001.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           8185.094                30                      30,585,145      176,088
00001.M2TS      4616 (0x1208)   0x90            PGS             por (Portuguese)        8185.094                25                      25,774,171      147,371
00001.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            8185.094                24                      24,051,527      137,645
00001.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           8185.094                22                      22,098,818      127,786
00001.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         8185.094                27                      27,168,441      157,452
00001.M2TS      4620 (0x120C)   0x90            PGS             swe (Swedish)           8185.094                22                      22,012,491      125,326
00001.M2TS      4621 (0x120D)   0x90            PGS             jpn (Japanese)          8185.094                30                      30,863,214      178,148
00001.M2TS      4622 (0x120E)   0x90            PGS             jpn (Japanese)          8185.094                10                      10,374,503      60,596
paku is offline
post #865 of 5106 Old 11-25-2009, 07:54 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Heat - 1995 - UK - Warner - Region ABC
Code:
        Total   Video
00003.MPLS                                                      VC-1    2:50:27 37,431,152,640  41,621,652,225  29.28   22.38   Dolby TrueHD 5.1 1440Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     HEAT
Disc Size:      41,621,652,225 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:50:27 (h:m:s)
Total Bitrate:          29.28 Mbps
VIDEO:
VC-1 Video              22384 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         1440 kbps       5.1 / 48 kHz / 1440 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Portuguese      192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         26.747 kbps
Presentation Graphics           Danish          19.242 kbps
Presentation Graphics           Dutch           19.858 kbps
Presentation Graphics           Finnish         19.386 kbps
Presentation Graphics           French          16.571 kbps
Presentation Graphics           German          26.390 kbps
Presentation Graphics           Norwegian       18.531 kbps
Presentation Graphics           Portuguese      20.229 kbps
Presentation Graphics           Spanish         23.036 kbps
Presentation Graphics           Spanish         21.051 kbps
Presentation Graphics           Swedish         18.695 kbps
FILES:
00003.M2TS      0:00:00.000     2:50:27.383     37,431,152,640  29,279
CHAPTERS:
1               0:00:00.000     0:04:22.512     20,125 kbps     38,271 kbps     00:03:00.513    31,846 kbps     00:02:58.595    29,684 kbps     00:01:53.780    106,997 bytes   524,877 bytes   00:03:31.794
2               0:04:22.512     0:02:41.494     23,061 kbps     44,104 kbps     00:05:29.787    33,980 kbps     00:05:29.912    32,140 kbps     00:06:53.329    120,228 bytes   473,970 bytes   00:05:30.538
3               0:07:04.006     0:03:03.600     20,876 kbps     33,362 kbps     00:10:00.182    30,724 kbps     00:10:00.099    29,042 kbps     00:09:57.430    108,839 bytes   438,078 bytes   00:10:01.267
4               0:10:07.607     0:03:27.624     22,609 kbps     42,940 kbps     00:10:33.799    33,646 kbps     00:10:54.403    31,909 kbps     00:10:49.190    117,873 bytes   385,902 bytes   00:12:47.391
5               0:13:35.231     0:01:16.993     22,500 kbps     26,159 kbps     00:14:37.376    24,395 kbps     00:14:47.219    23,641 kbps     00:13:35.314    117,307 bytes   240,180 bytes   00:14:37.418
6               0:14:52.224     0:03:28.833     25,195 kbps     37,531 kbps     00:14:56.020    33,979 kbps     00:14:53.851    32,222 kbps     00:14:53.851    131,355 bytes   371,122 bytes   00:17:19.955
7               0:18:21.058     0:02:42.453     22,697 kbps     36,978 kbps     00:19:10.107    28,534 kbps     00:20:11.126    26,657 kbps     00:19:04.476    118,330 bytes   411,412 bytes   00:20:40.280
8               0:21:03.512     0:04:20.426     24,047 kbps     50,142 kbps     00:21:37.254    31,820 kbps     00:21:04.429    31,245 kbps     00:21:11.979    125,371 bytes   427,537 bytes   00:21:37.963
9               0:25:23.939     0:06:35.561     20,852 kbps     43,754 kbps     00:31:41.316    34,026 kbps     00:31:40.481    30,755 kbps     00:31:35.476    108,712 bytes   327,700 bytes   00:31:42.317
10              0:31:59.500     0:02:56.801     19,126 kbps     30,724 kbps     00:32:28.780    25,633 kbps     00:32:28.780    23,138 kbps     00:32:28.780    99,716 bytes    318,684 bytes   00:32:28.905
11              0:34:56.302     0:02:58.970     16,589 kbps     28,101 kbps     00:36:50.249    26,002 kbps     00:36:46.662    22,562 kbps     00:36:41.657    86,486 bytes    294,449 bytes   00:36:50.791
12              0:37:55.273     0:02:52.755     18,725 kbps     32,538 kbps     00:38:32.059    28,412 kbps     00:38:28.848    24,332 kbps     00:38:26.262    97,622 bytes    403,872 bytes   00:38:33.019
13              0:40:48.028     0:03:46.059     20,437 kbps     35,679 kbps     00:43:25.894    31,946 kbps     00:43:25.603    30,699 kbps     00:43:24.685    106,548 bytes   313,801 bytes   00:43:21.724
14              0:44:34.088     0:04:47.829     22,279 kbps     40,226 kbps     00:45:42.823    34,998 kbps     00:45:39.820    29,432 kbps     00:45:39.737    116,155 bytes   337,879 bytes   00:45:48.746
15              0:49:21.917     0:02:40.201     22,831 kbps     46,283 kbps     00:51:08.190    34,609 kbps     00:51:40.430    32,368 kbps     00:51:12.360    119,031 bytes   465,556 bytes   00:51:30.295
16              0:52:02.118     0:00:54.804     22,532 kbps     34,552 kbps     00:52:52.502    30,750 kbps     00:52:49.499    26,781 kbps     00:52:46.913    117,469 bytes   292,124 bytes   00:52:24.641
17              0:52:56.923     0:03:06.644     22,793 kbps     37,878 kbps     00:53:49.267    30,720 kbps     00:53:45.305    28,548 kbps     00:54:38.942    118,832 bytes   363,062 bytes   00:54:19.172
18              0:56:03.568     0:02:06.751     23,294 kbps     33,015 kbps     00:57:22.605    30,472 kbps     00:57:24.774    29,790 kbps     00:57:22.605    121,445 bytes   338,869 bytes   00:57:23.314
19              0:58:10.320     0:03:31.377     22,851 kbps     41,365 kbps     00:59:03.915    31,766 kbps     00:58:56.658    31,325 kbps     00:58:45.188    119,137 bytes   416,914 bytes   01:01:14.253
20              1:01:41.698     0:02:48.042     17,174 kbps     33,389 kbps     01:01:41.739    31,183 kbps     01:01:41.739    27,508 kbps     01:01:41.698    89,539 bytes    402,103 bytes   01:01:41.864
21              1:04:29.740     0:03:57.445     20,435 kbps     37,327 kbps     01:05:15.453    32,212 kbps     01:05:13.910    30,564 kbps     01:05:13.951    106,540 bytes   445,454 bytes   01:04:33.286
22              1:08:27.186     0:06:22.673     26,443 kbps     42,266 kbps     01:14:33.135    34,795 kbps     01:08:49.875    32,170 kbps     01:08:48.082    137,863 bytes   451,506 bytes   01:14:12.281
23              1:14:49.860     0:02:25.562     20,575 kbps     29,924 kbps     01:15:19.806    28,142 kbps     01:15:38.116    27,691 kbps     01:15:38.408    107,271 bytes   318,286 bytes   01:15:20.807
24              1:17:15.422     0:04:42.156     21,793 kbps     44,899 kbps     01:17:23.221    31,554 kbps     01:17:20.135    31,111 kbps     01:17:35.359    113,618 bytes   426,105 bytes   01:17:24.222
25              1:21:57.579     0:03:24.787     24,044 kbps     36,558 kbps     01:23:34.426    32,139 kbps     01:23:32.257    31,181 kbps     01:23:32.298    125,355 bytes   330,346 bytes   01:22:10.550
26              1:25:22.367     0:03:28.249     27,433 kbps     44,303 kbps     01:27:52.850    33,525 kbps     01:27:31.329    32,381 kbps     01:27:05.094    143,025 bytes   424,756 bytes   01:27:46.719
27              1:28:50.616     0:06:17.919     20,250 kbps     28,557 kbps     01:28:54.078    27,605 kbps     01:28:52.035    26,108 kbps     01:28:50.616    105,577 bytes   290,936 bytes   01:28:54.912
28              1:35:08.536     0:01:50.735     22,538 kbps     30,529 kbps     01:35:09.495    28,502 kbps     01:35:31.726    28,020 kbps     01:35:21.298    117,504 bytes   264,888 bytes   01:36:40.628
29              1:36:59.271     0:04:20.009     19,782 kbps     34,745 kbps     01:37:48.571    30,947 kbps     01:37:48.863    28,515 kbps     01:37:45.943    103,137 bytes   357,195 bytes   01:37:53.284
30              1:41:19.281     0:03:46.100     22,130 kbps     32,786 kbps     01:41:49.561    30,862 kbps     01:41:45.766    29,860 kbps     01:41:41.428    115,373 bytes   387,580 bytes   01:42:29.810
31              1:45:05.382     0:01:33.676     20,836 kbps     32,924 kbps     01:46:18.455    27,728 kbps     01:45:06.967    26,305 kbps     01:45:06.717    108,629 bytes   342,524 bytes   01:46:18.914
32              1:46:39.059     0:05:56.022     25,888 kbps     44,491 kbps     01:49:52.335    35,058 kbps     01:52:13.059    32,420 kbps     01:52:13.059    134,966 bytes   389,611 bytes   01:51:33.478
33              1:52:35.081     0:01:20.997     26,349 kbps     40,920 kbps     01:53:33.515    33,775 kbps     01:53:29.511    32,220 kbps     01:53:08.698    137,374 bytes   344,948 bytes   01:53:34.432
34              1:53:56.079     0:02:53.172     23,614 kbps     32,700 kbps     01:54:30.989    29,761 kbps     01:56:38.074    29,054 kbps     01:54:14.347    123,113 bytes   375,708 bytes   01:54:31.114
35              1:56:49.252     0:02:29.691     21,324 kbps     39,369 kbps     01:59:11.853    32,197 kbps     01:57:13.568    29,174 kbps     01:57:14.068    111,173 bytes   343,644 bytes   01:59:12.562
36              1:59:18.943     0:03:32.086     25,416 kbps     41,903 kbps     02:02:34.472    35,340 kbps     02:02:34.347    32,456 kbps     02:02:33.054    132,506 bytes   380,290 bytes   02:01:39.625
37              2:02:51.030     0:04:33.189     25,406 kbps     34,555 kbps     02:04:55.196    31,761 kbps     02:03:36.617    30,535 kbps     02:04:58.282    132,456 bytes   408,037 bytes   02:03:01.082
38              2:07:24.219     0:02:41.369     22,782 kbps     39,088 kbps     02:07:30.976    30,111 kbps     02:08:15.479    28,988 kbps     02:08:25.155    118,775 bytes   368,933 bytes   02:08:19.483
39              2:10:05.589     0:02:03.039     20,622 kbps     34,632 kbps     02:10:46.380    30,185 kbps     02:10:43.168    25,741 kbps     02:10:42.835    107,516 bytes   327,096 bytes   02:10:55.639
40              2:12:08.629     0:02:36.823     25,330 kbps     36,669 kbps     02:14:37.402    32,864 kbps     02:14:36.401    32,079 kbps     02:14:34.941    132,061 bytes   358,107 bytes   02:13:07.437
41              2:14:45.452     0:04:40.863     24,362 kbps     37,981 kbps     02:15:33.542    33,441 kbps     02:15:23.573    32,145 kbps     02:15:16.942    127,011 bytes   410,179 bytes   02:15:52.102
42              2:19:26.316     0:02:17.929     23,713 kbps     35,714 kbps     02:20:10.360    33,288 kbps     02:20:10.402    31,814 kbps     02:20:05.438    123,631 bytes   325,731 bytes   02:21:26.811
43              2:21:44.245     0:03:49.103     22,714 kbps     34,447 kbps     02:23:18.965    32,087 kbps     02:23:27.890    30,690 kbps     02:23:23.970    118,420 bytes   248,373 bytes   02:24:26.908
44              2:25:33.349     0:02:28.648     23,030 kbps     34,444 kbps     02:27:13.324    29,788 kbps     02:27:09.904    27,803 kbps     02:25:35.476    120,070 bytes   284,525 bytes   02:27:12.824
45              2:28:01.998     0:02:43.413     21,280 kbps     32,210 kbps     02:28:53.174    30,946 kbps     02:28:57.178    30,583 kbps     02:28:52.173    110,945 bytes   353,224 bytes   02:28:54.467
46              2:30:45.411     0:02:18.221     22,979 kbps     32,735 kbps     02:32:57.418    32,491 kbps     02:32:54.081    31,664 kbps     02:32:53.622    119,804 bytes   225,662 bytes   02:32:50.870
47              2:33:03.632     0:02:02.163     22,114 kbps     39,665 kbps     02:34:02.983    28,030 kbps     02:34:02.942    26,138 kbps     02:33:59.688    115,292 bytes   306,149 bytes   02:34:03.984
48              2:35:05.796     0:03:14.652     25,628 kbps     39,645 kbps     02:37:14.800    34,768 kbps     02:36:33.008    32,215 kbps     02:36:31.757    133,610 bytes   425,694 bytes   02:36:45.979
49              2:38:20.449     0:02:05.208     24,701 kbps     40,205 kbps     02:39:36.942    30,550 kbps     02:39:06.411    29,002 kbps     02:40:15.606    128,781 bytes   346,681 bytes   02:39:37.109
50              2:40:25.657     0:03:25.663     24,515 kbps     40,385 kbps     02:41:12.871    33,947 kbps     02:41:55.163    31,488 kbps     02:43:38.225    127,810 bytes   392,820 bytes   02:40:42.716
51              2:43:51.321     0:01:56.616     25,093 kbps     33,747 kbps     02:45:26.124    32,315 kbps     02:45:12.444    31,587 kbps     02:45:13.361    133,111 bytes   327,175 bytes   02:45:24.414
52              2:45:47.938     0:04:39.445     12,455 kbps     22,888 kbps     02:50:11.576    21,029 kbps     02:50:09.073    18,792 kbps     02:50:07.155    65,151 bytes    366,361 bytes   02:49:26.156
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0xEA            VC-1                                    10227.259               22,385                  28,616,822,994  155,674,355
00003.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           10227.259               2,080                   2,659,080,262   19,546,121
00003.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            10227.259               640                     818,191,360     4,794,090
00003.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            10227.259               640                     818,191,360     4,794,090
00003.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           10227.259               640                     818,191,360     4,794,090
00003.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        10227.259               192                     245,457,408     1,598,030
00003.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           10227.259               192                     245,457,408     1,598,030
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           10227.259               27                      34,194,173      195,915
00003.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            10227.259               17                      21,184,736      124,233
00003.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            10227.259               26                      33,737,673      194,614
00003.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           10227.259               23                      29,449,734      170,874
00003.M2TS      4612 (0x1204)   0x90            PGS             nld (Dutch)             10227.259               20                      25,386,467      147,555
00003.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           10227.259               21                      26,912,371      156,615
00003.M2TS      4614 (0x1206)   0x90            PGS             por (Portuguese)        10227.259               20                      25,861,181      150,940
00003.M2TS      4615 (0x1207)   0x90            PGS             dan (Danish)            10227.259               19                      24,599,999      142,489
00003.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           10227.259               19                      24,784,132      143,807
00003.M2TS      4617 (0x1209)   0x90            PGS             nor (Norwegian)         10227.259               19                      23,691,006      137,893
00003.M2TS      4618 (0x120A)   0x90            PGS             swe (Swedish)           10227.259               19                      23,900,293      138,729
paku is offline
post #866 of 5106 Old 11-25-2009, 01:37 PM
mitanidani's Avatar
[HK] District 9
Studio: Sony Pictures Home Entertainment
Code:
        Total   Video
00001.MPLS                                                      AVC     1:52:15 26.505.363.456  43.042.617.796  31,48   19,70   DTS-HD Master 5.1 3958Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:
Disc Size:      43.042.617.796 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:52:15 (h:m:s)
Total Bitrate:          31,48 Mbps
VIDEO:
MPEG-4 AVC Video        19697 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3958 kbps       5.1 / 48 kHz / 3958 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             Portuguese      3165 kbps       5.1 / 48 kHz / 3165 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Russian         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Ukrainian       640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         37,325 kbps
* Presentation Graphics         English         37,341 kbps
Presentation Graphics           English         65,776 kbps
Presentation Graphics           Chinese         32,192 kbps
Presentation Graphics           Chinese         33,597 kbps
Presentation Graphics           Estonian        33,495 kbps
Presentation Graphics           Korean          17,977 kbps
Presentation Graphics           Lithuanian      33,412 kbps
Presentation Graphics           Portuguese      25,252 kbps
Presentation Graphics           Portuguese      59,165 kbps
Presentation Graphics           Russian         5,989 kbps
Presentation Graphics           Spanish         33,550 kbps
Presentation Graphics           Spanish         57,193 kbps
Presentation Graphics           Ukrainian       4,712 kbps
FILES:
00011.M2TS      0:00:00.000     1:52:15.729     26.505.363.456  31.480
CHAPTERS:
1               0:00:00.000     0:06:22.340     19.569 kbps     34.809 kbps     00:03:54.108    30.931 kbps     00:04:23.638    28.062 kbps     00:04:23.638    102.014 bytes   691.975 bytes   00:03:22.952
2               0:06:22.340     0:07:03.005     19.661 kbps     34.607 kbps     00:11:46.038    31.032 kbps     00:11:44.495    30.312 kbps     00:11:41.992    102.506 bytes   674.396 bytes   00:06:47.198
3               0:13:25.346     0:07:08.010     20.340 kbps     35.007 kbps     00:14:08.472    30.661 kbps     00:13:49.787    28.566 kbps     00:13:47.952    106.042 bytes   494.861 bytes   00:15:15.414
4               0:20:33.357     0:06:35.395     19.492 kbps     40.320 kbps     00:25:42.499    28.077 kbps     00:23:43.380    27.163 kbps     00:23:38.125    101.624 bytes   645.743 bytes   00:26:05.105
5               0:27:08.752     0:07:04.966     20.030 kbps     36.426 kbps     00:29:48.286    30.083 kbps     00:29:46.743    28.753 kbps     00:28:53.314    104.426 bytes   596.112 bytes   00:29:49.120
6               0:34:13.718     0:07:44.213     19.654 kbps     37.782 kbps     00:38:34.312    33.636 kbps     00:38:30.308    28.999 kbps     00:38:16.210    102.466 bytes   553.996 bytes   00:34:35.573
7               0:41:57.932     0:05:04.012     20.280 kbps     44.778 kbps     00:44:09.396    31.457 kbps     00:44:29.291    30.390 kbps     00:42:40.975    105.729 bytes   598.681 bytes   00:45:50.038
8               0:47:01.944     0:07:06.008     19.074 kbps     31.323 kbps     00:53:58.652    24.601 kbps     00:47:57.374    23.178 kbps     00:47:53.829    99.446 bytes    718.489 bytes   00:51:51.316
9               0:54:07.953     0:05:52.643     19.025 kbps     37.105 kbps     00:54:24.844    30.331 kbps     00:54:24.844    25.853 kbps     00:54:22.842    99.189 bytes    577.925 bytes   00:54:53.498
10              1:00:00.597     0:08:25.379     20.276 kbps     32.061 kbps     01:01:02.158    26.161 kbps     01:00:29.584    25.547 kbps     01:02:20.862    105.708 bytes   468.947 bytes   01:08:25.976
11              1:08:25.976     0:05:11.894     19.964 kbps     38.065 kbps     01:08:44.745    29.467 kbps     01:08:43.953    24.957 kbps     01:08:42.576    104.082 bytes   666.147 bytes   01:08:45.663
12              1:13:37.871     0:07:24.318     20.584 kbps     42.999 kbps     01:20:28.240    31.792 kbps     01:14:48.525    29.309 kbps     01:20:28.240    107.314 bytes   659.260 bytes   01:14:13.740
13              1:21:02.190     0:05:38.171     19.935 kbps     32.172 kbps     01:21:11.199    28.812 kbps     01:21:10.198    28.073 kbps     01:21:07.112    103.932 bytes   585.365 bytes   01:25:10.480
14              1:26:40.361     0:07:01.003     19.570 kbps     33.997 kbps     01:28:14.872    28.752 kbps     01:28:12.078    24.582 kbps     01:28:12.078    102.027 bytes   556.348 bytes   01:28:12.453
15              1:33:41.365     0:05:03.136     19.901 kbps     38.050 kbps     01:35:09.370    31.598 kbps     01:35:09.370    29.127 kbps     01:35:05.991    103.754 bytes   686.379 bytes   01:35:09.412
16              1:38:44.501     0:13:31.227     18.729 kbps     37.670 kbps     01:41:22.576    32.717 kbps     01:40:03.455    30.673 kbps     01:41:20.449    97.656 bytes    679.467 bytes   01:41:30.250
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6735,646                19.697                  16.584.215.434  90.226.623
00011.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6735,646                3.958                   3.332.332.316   19.160.253
00011.M2TS      4353 (0x1101)   0x86            DTS-HD MA       por (Portuguese)        6735,646                3.166                   2.665.221.276   15.534.444
00011.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6735,646                640                     538.859.520     3.157.380
00011.M2TS      4355 (0x1103)   0x81            AC3             rus (Russian)           6735,646                640                     538.859.520     3.157.380
00011.M2TS      4356 (0x1104)   0x81            AC3             ukr (Ukrainian)         6735,646                640                     538.859.520     3.157.380
00011.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           6735,646                192                     161.657.856     1.052.460
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6735,646                37                      31.426.004      180.016
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6735,646                37                      31.440.173      180.087
00011.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        6735,646                25                      21.261.220      124.139
00011.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6735,646                34                      28.247.642      163.102
00011.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           6735,646                32                      27.104.555      156.876
00011.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           6735,646                34                      28.287.807      163.322
00011.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            6735,646                18                      15.136.333      90.749
00011.M2TS      4615 (0x1207)   0x90            PGS             est (Estonian)          6735,646                33                      28.201.949      161.643
00011.M2TS      4616 (0x1208)   0x90            PGS             lit (Lithuanian)        6735,646                33                      28.132.177      161.657
00011.M2TS      4617 (0x1209)   0x90            PGS             rus (Russian)           6735,646                6                       5.042.859       29.206
00011.M2TS      4618 (0x120A)   0x90            PGS             ukr (Ukrainian)         6735,646                5                       3.967.735       23.267
00011.M2TS      4619 (0x120B)   0x90            PGS             eng (English)           6735,646                66                      55.380.979      313.645
00011.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           6735,646                57                      48.154.538      274.533
00011.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        6735,646                59                      49.814.692      283.271
mitanidani is offline
post #867 of 5106 Old 11-25-2009, 04:00 PM
Stephen Dawson's Avatar
The Sisterhood of the Traveling Pants 2 - 2008 - Australian version
Distributed by Warner Bros Entertainment Australia Pty Ltd
Region Free, confirmed with AnyDVD HD
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:59:34 21,102,434,304  22,969,191,610  23.53   16.90   DD AC3 5.1 640Kbps                        Dolby TrueHD 5.1 1329Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     SISTERHOOD_2_BD01
Disc Size:      22,969,191,610 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:59:34 (h:m:s)
Total Bitrate:          23.53 Mbps
VIDEO:
VC-1 Video              16902 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby TrueHD Audio              English         1329 kbps       5.1 / 48 kHz / 1329 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             Portuguese      640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         34.087 kbps
Presentation Graphics           French          30.175 kbps
Presentation Graphics           Spanish         30.831 kbps
Presentation Graphics           Portuguese      29.920 kbps
Presentation Graphics           French          0.202 kbps
Presentation Graphics           Spanish         0.239 kbps
Presentation Graphics           Portuguese      0.206 kbps
FILES:
00000.M2TS      0:00:00.000     1:59:34.208     21,102,434,304  23,531
CHAPTERS:
1               0:00:00.000     0:04:02.617     16,043 kbps     32,893 kbps     00:03:00.763    25,742 kbps     00:00:04.295    23,169 kbps     00:03:27.207    83,929 bytes    417,479 bytes   00:03:01.431
2               0:04:02.617     0:05:12.770     18,511 kbps     27,856 kbps     00:06:51.953    25,436 kbps     00:06:50.701    24,508 kbps     00:06:32.475    96,505 bytes    282,807 bytes   00:05:57.398
3               0:09:15.388     0:05:27.618     18,867 kbps     28,057 kbps     00:12:59.361    25,460 kbps     00:10:29.253    24,540 kbps     00:10:24.915    98,365 bytes    278,991 bytes   00:10:16.324
4               0:14:43.007     0:05:12.478     15,595 kbps     24,734 kbps     00:14:45.092    20,779 kbps     00:14:43.424    19,927 kbps     00:14:43.507    81,305 bytes    357,778 bytes   00:14:58.772
5               0:19:55.485     0:06:15.708     18,346 kbps     28,473 kbps     00:23:04.841    25,467 kbps     00:23:04.841    24,749 kbps     00:23:02.672    95,646 bytes    342,698 bytes   00:20:05.454
6               0:26:11.194     0:04:15.630     19,430 kbps     27,757 kbps     00:28:45.640    26,385 kbps     00:28:55.108    25,891 kbps     00:28:55.108    101,298 bytes   361,265 bytes   00:27:36.321
7               0:30:26.825     0:05:45.928     20,034 kbps     29,582 kbps     00:34:12.050    23,255 kbps     00:30:37.544    22,441 kbps     00:30:34.040    104,446 bytes   382,675 bytes   00:30:51.724
8               0:36:12.753     0:02:57.427     19,575 kbps     26,380 kbps     00:37:14.565    24,178 kbps     00:37:49.684    24,041 kbps     00:37:49.684    102,056 bytes   310,078 bytes   00:36:15.089
9               0:39:10.181     0:05:46.054     16,228 kbps     23,811 kbps     00:39:39.668    21,680 kbps     00:40:51.782    21,384 kbps     00:41:24.690    84,605 bytes    289,534 bytes   00:44:50.646
10              0:44:56.235     0:03:59.948     15,419 kbps     25,144 kbps     00:46:51.850    22,736 kbps     00:46:50.349    21,620 kbps     00:46:45.385    80,388 bytes    288,531 bytes   00:47:16.583
11              0:48:56.183     0:04:07.121     18,753 kbps     25,275 kbps     00:49:00.020    23,916 kbps     00:48:57.142    22,414 kbps     00:51:51.399    97,768 bytes    315,596 bytes   00:50:22.436
12              0:53:03.305     0:04:06.120     17,359 kbps     29,552 kbps     00:56:51.991    23,402 kbps     00:56:51.908    21,557 kbps     00:53:42.552    90,501 bytes    292,382 bytes   00:53:42.594
13              0:57:09.426     0:05:19.902     17,344 kbps     24,391 kbps     00:58:47.148    23,155 kbps     00:58:24.792    21,924 kbps     00:59:07.627    90,421 bytes    297,532 bytes   01:01:49.956
14              1:02:29.328     0:04:38.945     15,698 kbps     25,128 kbps     01:02:48.931    23,551 kbps     01:02:47.263    22,612 kbps     01:02:46.220    81,844 bytes    291,285 bytes   01:05:15.745
15              1:07:08.274     0:03:07.270     16,125 kbps     24,176 kbps     01:07:36.844    22,310 kbps     01:07:36.844    21,864 kbps     01:07:36.844    84,067 bytes    270,811 bytes   01:07:16.449
16              1:10:15.544     0:03:54.150     16,370 kbps     26,789 kbps     01:11:13.143    21,742 kbps     01:10:15.628    20,663 kbps     01:10:15.586    85,348 bytes    255,150 bytes   01:14:09.653
17              1:14:09.695     0:02:59.137     19,104 kbps     29,246 kbps     01:15:21.892    24,570 kbps     01:15:27.397    24,320 kbps     01:15:27.981    99,602 bytes    288,588 bytes   01:14:14.116
18              1:17:08.832     0:05:14.105     17,410 kbps     26,267 kbps     01:19:46.281    22,403 kbps     01:20:26.071    21,617 kbps     01:19:22.507    90,766 bytes    408,739 bytes   01:19:46.531
19              1:22:22.938     0:04:49.038     19,248 kbps     24,378 kbps     01:22:48.463    23,109 kbps     01:22:47.879    22,019 kbps     01:23:45.478    100,349 bytes   338,514 bytes   01:27:11.935
20              1:27:11.976     0:02:51.296     13,599 kbps     22,725 kbps     01:27:38.962    18,744 kbps     01:27:37.210    16,361 kbps     01:27:37.418    70,901 bytes    386,849 bytes   01:29:49.926
21              1:30:03.272     0:05:51.768     18,078 kbps     35,649 kbps     01:32:01.891    23,690 kbps     01:33:00.575    22,494 kbps     01:33:10.084    94,250 bytes    282,279 bytes   01:33:06.747
22              1:35:55.040     0:04:06.871     17,684 kbps     45,331 kbps     01:35:58.544    29,456 kbps     01:35:55.166    22,291 kbps     01:39:23.916    92,195 bytes    430,913 bytes   01:38:17.558
23              1:40:01.912     0:05:23.281     15,298 kbps     24,057 kbps     01:41:51.438    21,564 kbps     01:40:31.442    19,602 kbps     01:40:26.562    79,759 bytes    409,656 bytes   01:40:30.983
24              1:45:25.193     0:04:24.514     19,341 kbps     28,821 kbps     01:49:19.302    24,788 kbps     01:48:15.155    24,591 kbps     01:48:15.280    100,834 bytes   300,237 bytes   01:47:03.583
25              1:49:49.708     0:02:36.656     19,994 kbps     50,170 kbps     01:51:18.421    39,926 kbps     01:51:27.931    36,261 kbps     01:51:27.347    104,237 bytes   399,794 bytes   01:51:23.760
26              1:52:26.364     0:07:07.844     5,980 kbps      23,352 kbps     01:54:59.893    10,416 kbps     01:54:56.389    9,611 kbps      01:58:35.316    31,252 bytes    257,650 bytes   01:54:59.934
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    7174.084                16,903                  15,157,721,014  82,482,671
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           7174.084                640                     573,939,200     3,362,925
00000.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           7174.084                1,969                   1,765,578,198   13,084,515
00000.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            7174.084                640                     573,939,200     3,362,925
00000.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           7174.084                640                     573,939,200     3,362,925
00000.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        7174.084                640                     573,939,200     3,362,925
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7174.084                34                      30,568,223      175,647
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7174.084                30                      27,060,553      155,930
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           7174.084                31                      27,648,483      159,359
00000.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        7174.084                30                      26,831,373      154,952
00000.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            7174.084                0                       180,866         1,048
00000.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           7174.084                0                       214,167         1,248
00000.M2TS      4614 (0x1206)   0x90            PGS             por (Portuguese)        7174.084                0                       185,102         1,085
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #868 of 5106 Old 11-25-2009, 04:02 PM
d.f.h's Avatar
RE https://www.avsforum.com/avs-vb/showp...&postcount=850
Sorry for OT. I have noticed you have the BDinfo information of the Fight Club Blu-ray disc (US version). I have the EU version and during the BDinfo bitrate scan the process stops at 236 050 752 measured bytes from 34 642 753 636 estimated bytes (00010.MPLS, 00349.M2TS, see below). BDinfo is the 0.5.3 version, AnyDVD HD is 6.6.0.3, the disc is not Testmold. Do you have any idea where the problem could be? Do you need some more information from me?
Code:
        Total   Video
00010.MPLS                                                      AVC     2:19:08 236*050*752     46*839*447*743  0,23    15,06   DTS-HD Master 5.1 3739Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     FIGHT_CLUB
Disc Size:      46*839*447*743 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:19:08 (h:m:s)
Total Bitrate:          0,23 Mbps
VIDEO:
MPEG-4 AVC Video        15062 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3739 kbps       5.1 / 48 kHz / 3739 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       Russian         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             Czech           448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
Dolby Digital Audio             Hungarian       224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
Dolby Digital Audio             Polish          224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         0,000 kbps
Presentation Graphics           Arabic          0,000 kbps
Presentation Graphics           Bulgarian       0,000 kbps
Presentation Graphics           Croatian        0,000 kbps
Presentation Graphics           Czech           0,000 kbps
Presentation Graphics           Estonian        0,000 kbps
Presentation Graphics           Greek           0,000 kbps
Presentation Graphics           Hebrew          0,648 kbps
Presentation Graphics           Hungarian       0,000 kbps
Presentation Graphics           Icelandic       0,000 kbps
Presentation Graphics           Kazakh          0,000 kbps
Presentation Graphics           Latin           0,000 kbps
Presentation Graphics           Lithuanian      0,000 kbps
Presentation Graphics           Polish          0,000 kbps
Presentation Graphics           Portuguese      0,000 kbps
Presentation Graphics           Romanian        0,946 kbps
Presentation Graphics           Russian         0,000 kbps
Presentation Graphics           Russian         55,235 kbps
Presentation Graphics           Russian         44,928 kbps
Presentation Graphics           Serbian         0,000 kbps
Presentation Graphics           Slovenian       0,000 kbps
Presentation Graphics           Spanish         0,000 kbps
Presentation Graphics           Spanish         50,338 kbps
Presentation Graphics           Spanish         39,724 kbps
Presentation Graphics           Spanish         37,949 kbps
Presentation Graphics           Spanish         58,282 kbps
Presentation Graphics           Turkish         0,000 kbps
Presentation Graphics           Ukrainian       0,000 kbps
FILES:
00349.M2TS      0:00:00.000     2:19:08.381     236*050*752     23*930
CHAPTERS:
1               0:00:00.000     0:02:08.378     9*258 kbps      23*061 kbps     00:00:05.046    22*178 kbps     00:00:02.127    21*560 kbps     00:00:02.127    78*527 bytes    250*361 bytes   00:00:07.007
2               0:02:08.378     0:01:46.439     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
3               0:03:54.817     0:00:51.509     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
4               0:04:46.327     0:01:35.595     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
5               0:06:21.923     0:04:00.281     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
6               0:10:22.204     0:01:12.697     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
7               0:11:34.902     0:07:38.666     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
8               0:19:13.569     0:02:27.605     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
9               0:21:41.174     0:04:06.829     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
10              0:25:48.004     0:03:21.326     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
11              0:29:09.330     0:03:17.864     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
12              0:32:27.195     0:01:43.269     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
13              0:34:10.465     0:01:47.482     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
14              0:35:57.947     0:05:39.047     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
15              0:41:36.994     0:05:41.966     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
16              0:47:18.961     0:01:18.912     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
17              0:48:37.873     0:11:40.408     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
18              1:00:18.281     0:01:37.972     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
19              1:01:56.254     0:07:52.180     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
20              1:09:48.434     0:05:09.517     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
21              1:14:57.951     0:00:49.674     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
22              1:15:47.626     0:03:48.228     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
23              1:19:35.854     0:01:53.613     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
24              1:21:29.467     0:06:09.077     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
25              1:27:38.544     0:07:58.436     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
26              1:35:36.981     0:02:11.089     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
27              1:37:48.070     0:03:38.718     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
28              1:41:26.789     0:03:40.678     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
29              1:45:07.467     0:02:50.712     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
30              1:47:58.180     0:02:36.698     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
31              1:50:34.878     0:06:18.294     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
32              1:56:53.172     0:03:43.640     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
33              2:00:36.812     0:05:18.901     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
34              2:05:55.714     0:03:42.639     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
35              2:09:38.353     0:06:15.625     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
36              2:15:53.979     0:03:14.402     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
STREAM DIAGNOSTICS:
00349.M2TS      4113 (0x1011)   0x1B            AVC                                     78,870                  15*070                  148*573*578     808*580
00349.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           78,870                  3*741                   36*880*159      212*659
00349.M2TS      4353 (0x1101)   0x82            DTS             rus (Russian)           78,870                  764                     7*528*615       44*113
00349.M2TS      4354 (0x1102)   0x82            DTS             spa (Spanish)           78,870                  764                     7*527*591       44*112
00349.M2TS      4355 (0x1103)   0x81            AC3             ces (Czech)             78,870                  445                     4*384*701       24*468
00349.M2TS      4356 (0x1104)   0x81            AC3             hun (Hungarian)         78,870                  223                     2*201*823       12*287
00349.M2TS      4357 (0x1105)   0x81            AC3             pol (Polish)            78,870                  223                     2*201*823       12*287
00349.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           78,870                  223                     2*201*823       12*287
00349.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           78,870                  223                     2*201*823       12*287
00349.M2TS      4360 (0x1108)   0x81            AC3             eng (English)           78,870                  223                     2*201*823       12*287
00349.M2TS      4361 (0x1109)   0x81            AC3             eng (English)           78,870                  223                     2*200*927       12*286
00349.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           78,870                  0                       0               0
00349.M2TS      4609 (0x1201)   0x90            PGS             rus (Russian)           78,870                  0                       0               0
00349.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           78,870                  0                       0               0
00349.M2TS      4611 (0x1203)   0x90            PGS             est (Estonian)          78,870                  0                       0               0
00349.M2TS      4612 (0x1204)   0x90            PGS             lat (Latin)             78,870                  0                       0               0
00349.M2TS      4613 (0x1205)   0x90            PGS             lit (Lithuanian)        78,870                  0                       0               0
00349.M2TS      4614 (0x1206)   0x90            PGS             bul (Bulgarian)         78,870                  0                       0               0
00349.M2TS      4615 (0x1207)   0x90            PGS             hrv (Croatian)          78,870                  0                       0               0
00349.M2TS      4616 (0x1208)   0x90            PGS             ces (Czech)             78,870                  0                       0               0
00349.M2TS      4617 (0x1209)   0x90            PGS             ara (Arabic)            78,870                  0                       0               0
00349.M2TS      4618 (0x120A)   0x90            PGS             ell (Greek)             78,870                  0                       0               0
00349.M2TS      4619 (0x120B)   0x90            PGS             hun (Hungarian)         78,870                  0                       0               0
00349.M2TS      4620 (0x120C)   0x90            PGS             isl (Icelandic)         78,870                  0                       0               0
00349.M2TS      4621 (0x120D)   0x90            PGS             heb (Hebrew)            78,870                  1                       6*389           41
00349.M2TS      4622 (0x120E)   0x90            PGS             kaz (Kazakh)            78,870                  0                       0               0
00349.M2TS      4623 (0x120F)   0x90            PGS             pol (Polish)            78,870                  0                       0               0
00349.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        78,870                  0                       0               0
00349.M2TS      4625 (0x1211)   0x90            PGS             ron (Romanian)          78,870                  1                       9*330           58
00349.M2TS      4626 (0x1212)   0x90            PGS             srp (Serbian)           78,870                  0                       0               0
00349.M2TS      4627 (0x1213)   0x90            PGS             slv (Slovenian)         78,870                  0                       0               0
00349.M2TS      4628 (0x1214)   0x90            PGS             tur (Turkish)           78,870                  0                       0               0
00349.M2TS      4629 (0x1215)   0x90            PGS             ukr (Ukrainian)         78,870                  0                       0               0
00349.M2TS      4630 (0x1216)   0x90            PGS             rus (Russian)           78,870                  55                      544*839         3*056
00349.M2TS      4631 (0x1217)   0x90            PGS             spa (Spanish)           78,870                  50                      496*536         2*796
00349.M2TS      4632 (0x1218)   0x90            PGS             rus (Russian)           78,870                  45                      443*168         2*491
00349.M2TS      4633 (0x1219)   0x90            PGS             spa (Spanish)           78,870                  40                      391*842         2*214
00349.M2TS      4634 (0x121A)   0x90            PGS             spa (Spanish)           78,870                  38                      374*329         2*111
00349.M2TS      4635 (0x121B)   0x90            PGS             spa (Spanish)           78,870                  58                      574*892         3*248
d.f.h is offline
post #869 of 5106 Old 11-25-2009, 04:50 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
[US] Angels & Demons
Code:
        Total   Video
Angels & Demons (Theatrical)                                    AVC     2:18:37 33,299,324,928  46,896,047,158  32.03   24.12   DTS-HD Master 5.1 3723Kbps (48kHz/24-bit)
Angels & Demons (Extended)                                      AVC     2:26:15 35,209,445,376  46,896,047,158  32.10   24.14   DTS-HD Master 5.1 3774Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     ANGELS_AND_DEMONS
Disc Size:      46,896,047,158 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:18:37 (h:m:s)
Total Bitrate:          32.03 Mbps
VIDEO:
MPEG-4 AVC Video        24124 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3723 kbps       5.1 / 48 kHz / 3723 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          2228 kbps       5.1 / 48 kHz / 2228 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         28.186 kbps
Presentation Graphics           English         21.568 kbps
Presentation Graphics           French          23.620 kbps
Presentation Graphics           French          1.819 kbps
* Presentation Graphics         English         0.002 kbps
FILES:
00505.M2TS      0:00:00.000     0:09:06.671     2,252,562,432   32,964
00506.M2TS      0:09:06.671     0:02:00.870     493,154,304     32,640
00509.M2TS      0:11:07.541     0:01:11.071     288,276,480     32,449
00511.M2TS      0:12:18.612     0:02:29.941     604,821,504     32,270
00512.M2TS      0:14:48.554     0:01:22.081     338,184,192     32,961
00514.M2TS      0:16:10.636     0:15:20.461     3,709,231,104   32,238
00515.M2TS      0:31:31.097     0:01:07.609     277,002,240     32,777
00517.M2TS      0:32:38.706     0:00:24.607     99,858,432      32,464
00518.M2TS      0:33:03.314     0:00:34.200     138,688,512     32,441
00520.M2TS      0:33:37.515     0:11:28.938     2,812,944,384   32,664
00521.M2TS      0:45:06.453     0:00:59.434     241,133,568     32,457
00523.M2TS      0:46:05.888     0:01:35.178     385,591,296     32,410
00524.M2TS      0:47:41.066     0:00:36.036     149,551,104     33,200
00526.M2TS      0:48:17.102     0:14:42.214     3,622,526,976   32,849
00527.M2TS      1:02:59.317     0:09:06.546     2,201,260,032   32,221
00530.M2TS      1:12:05.863     0:00:17.392     69,709,824      32,065
00532.M2TS      1:12:23.255     0:01:21.456     332,285,952     32,634
00533.M2TS      1:13:44.711     0:00:40.790     169,734,144     33,289
00535.M2TS      1:14:25.502     0:01:56.116     471,164,928     32,462
00536.M2TS      1:16:21.618     0:00:57.807     234,430,464     32,443
00538.M2TS      1:17:19.426     0:01:19.662     337,041,408     33,847
00539.M2TS      1:18:39.089     0:01:08.693     293,007,360     34,123
00542.M2TS      1:19:47.782     0:00:42.834     176,498,688     32,964
00545.M2TS      1:20:30.617     0:03:59.280     961,400,832     32,143
00548.M2TS      1:24:29.897     0:04:26.516     1,066,801,152   32,022
00550.M2TS      1:28:56.414     0:11:22.014     2,815,629,312   33,027
00551.M2TS      1:40:18.428     0:00:20.228     81,371,136      32,181
00553.M2TS      1:40:38.657     0:04:36.901     1,127,731,200   32,581
00554.M2TS      1:45:15.559     0:00:46.546     192,485,376     33,083
00556.M2TS      1:46:02.105     0:19:54.359     4,922,800,128   32,974
00557.M2TS      2:05:56.465     0:00:32.991     139,229,184     33,761
00559.M2TS      2:06:29.456     0:12:07.852     2,293,217,280   25,205
CHAPTERS:
1               0:00:00.000     0:09:30.945     24,576 kbps     44,325 kbps     00:06:47.990    34,171 kbps     00:06:47.156    31,274 kbps     00:06:47.407    128,117 bytes   645,686 bytes   00:03:09.898
2               0:09:30.945     0:08:02.064     25,338 kbps     42,975 kbps     00:09:51.590    33,343 kbps     00:11:20.971    31,137 kbps     00:16:11.804    132,099 bytes   591,126 bytes   00:11:22.098
3               0:17:33.010     0:08:07.987     24,762 kbps     35,281 kbps     00:23:31.827    29,750 kbps     00:22:28.013    28,511 kbps     00:23:31.618    129,100 bytes   570,686 bytes   00:23:57.936
4               0:25:40.997     0:06:41.275     24,270 kbps     35,150 kbps     00:32:11.554    30,702 kbps     00:27:45.163    29,509 kbps     00:27:45.163    126,532 bytes   509,397 bytes   00:27:45.997
5               0:32:22.273     0:11:14.590     24,597 kbps     43,898 kbps     00:35:29.877    31,781 kbps     00:39:12.975    30,772 kbps     00:39:09.430    128,237 bytes   577,848 bytes   00:39:21.484
6               0:43:36.864     0:08:15.745     25,533 kbps     39,705 kbps     00:43:54.923    32,031 kbps     00:44:14.193    30,285 kbps     00:49:30.425    133,116 bytes   552,970 bytes   00:47:35.227
7               0:51:52.609     0:09:19.308     24,264 kbps     42,540 kbps     00:53:52.687    32,544 kbps     00:53:52.687    29,863 kbps     00:53:52.437    126,499 bytes   521,540 bytes   00:53:15.191
8               1:01:11.918     0:09:35.658     24,876 kbps     39,195 kbps     01:02:40.756    31,922 kbps     01:02:37.169    30,359 kbps     01:05:45.941    129,694 bytes   613,189 bytes   01:06:08.255
9               1:10:47.576     0:06:26.385     24,726 kbps     38,826 kbps     01:14:00.519    31,992 kbps     01:14:00.102    29,228 kbps     01:14:00.018    128,908 bytes   577,981 bytes   01:11:31.745
10              1:17:13.962     0:09:07.546     24,693 kbps     43,967 kbps     01:19:17.210    32,189 kbps     01:22:43.082    29,265 kbps     01:22:40.997    128,740 bytes   568,256 bytes   01:22:50.840
11              1:26:21.509     0:11:18.052     24,759 kbps     45,244 kbps     01:34:48.807    32,615 kbps     01:26:49.704    29,630 kbps     01:30:16.118    129,084 bytes   699,529 bytes   01:37:30.302
12              1:37:39.561     0:10:01.851     24,256 kbps     44,283 kbps     01:45:50.135    32,640 kbps     01:41:50.562    31,148 kbps     01:41:45.724    126,461 bytes   612,955 bytes   01:45:50.427
13              1:47:41.413     0:10:20.953     25,546 kbps     46,392 kbps     01:50:59.444    31,835 kbps     01:51:07.702    30,845 kbps     01:50:59.444    133,183 bytes   737,465 bytes   01:50:50.518
14              1:58:02.366     0:05:00.967     24,306 kbps     34,677 kbps     01:59:21.987    28,206 kbps     01:59:14.814    26,285 kbps     01:59:48.848    126,722 bytes   455,779 bytes   02:02:30.009
15              2:03:03.334     0:04:24.806     25,244 kbps     38,644 kbps     02:06:26.161    31,160 kbps     02:06:34.419    29,381 kbps     02:06:29.414    131,610 bytes   548,631 bytes   02:06:59.987
16              2:07:28.140     0:11:09.168     16,610 kbps     37,671 kbps     02:08:08.347    30,380 kbps     02:08:04.217    29,405 kbps     02:07:59.671    86,609 bytes    658,127 bytes   02:10:30.489
STREAM DIAGNOSTICS:
SKIPPED
Code:
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:26:15 (h:m:s)
Total Bitrate:          32.10 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        24144 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3774 kbps       5.1 / 48 kHz / 3774 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          2225 kbps       5.1 / 48 kHz / 2225 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         27.791 kbps
Presentation Graphics           English         21.207 kbps
Presentation Graphics           French          23.433 kbps
Presentation Graphics           French          1.724 kbps
FILES:
00507.M2TS      0:09:06.671     0:02:00.870     495,888,384     32,821
00510.M2TS      0:11:07.541     0:01:13.782     302,665,728     32,817
00511.M2TS      0:12:21.323     0:02:29.941     604,821,504     32,270
00513.M2TS      0:14:51.265     0:02:54.716     716,433,408     32,804
00514.M2TS      0:17:45.981     0:15:20.461     3,709,231,104   32,238
00516.M2TS      0:33:06.442     0:01:32.884     378,753,024     32,621
00517.M2TS      0:34:39.327     0:00:24.607     99,858,432      32,464
00519.M2TS      0:35:03.935     0:01:11.362     291,919,872     32,725
00520.M2TS      0:36:15.298     0:11:28.938     2,812,944,384   32,664
00522.M2TS      0:47:44.236     0:01:43.895     417,816,576     32,172
00523.M2TS      0:49:28.131     0:01:35.178     385,591,296     32,410
00525.M2TS      0:51:03.310     0:00:38.121     159,381,504     33,447
00526.M2TS      0:51:41.431     0:14:42.214     3,622,526,976   32,849
00528.M2TS      1:06:23.646     0:09:46.586     2,376,609,792   32,413
00531.M2TS      1:16:10.232     0:00:55.972     226,510,848     32,375
00532.M2TS      1:17:06.204     0:01:21.456     332,285,952     32,634
00534.M2TS      1:18:27.661     0:01:25.794     354,908,160     33,094
00535.M2TS      1:19:53.455     0:01:56.116     471,164,928     32,462
00537.M2TS      1:21:49.571     0:01:06.900     272,406,528     32,575
00538.M2TS      1:22:56.471     0:01:19.662     337,041,408     33,847
00540.M2TS      1:24:16.134     0:01:30.090     383,533,056     34,058
00543.M2TS      1:25:46.224     0:00:56.765     234,147,840     32,999
00546.M2TS      1:26:42.989     0:04:19.133     1,050,243,072   32,423
00549.M2TS      1:31:02.123     0:04:26.516     1,073,707,008   32,229
00550.M2TS      1:35:28.639     0:11:22.014     2,815,629,312   33,027
00552.M2TS      1:46:50.654     0:01:12.197     293,203,968     32,489
00553.M2TS      1:48:02.851     0:04:36.901     1,127,731,200   32,581
00555.M2TS      1:52:39.752     0:00:57.766     240,832,512     33,353
00556.M2TS      1:53:37.518     0:19:54.359     4,922,800,128   32,974
00558.M2TS      2:13:31.878     0:00:35.952     153,077,760     34,062
00559.M2TS      2:14:07.831     0:12:07.852     2,293,217,280   25,205
CHAPTERS:
1               0:00:00.000     0:09:30.861     24,577 kbps     44,325 kbps     00:06:47.990    34,171 kbps     00:06:47.156    31,274 kbps     00:06:47.407    128,126 bytes   645,686 bytes   00:03:09.898
2               0:09:30.861     0:09:37.493     25,205 kbps     42,975 kbps     00:09:51.590    32,279 kbps     00:09:42.498    31,137 kbps     00:17:47.149    131,409 bytes   604,286 bytes   00:14:55.936
3               0:19:08.355     0:08:07.904     24,763 kbps     35,281 kbps     00:25:07.172    29,750 kbps     00:24:03.358    28,511 kbps     00:25:06.963    129,102 bytes   570,686 bytes   00:25:33.281
4               0:27:16.259     0:07:06.551     24,215 kbps     35,052 kbps     00:33:06.401    30,767 kbps     00:33:06.401    29,509 kbps     00:29:20.508    126,247 bytes   509,397 bytes   00:29:21.342
5               0:34:22.810     0:11:51.794     24,606 kbps     43,898 kbps     00:38:07.660    31,781 kbps     00:41:50.758    30,772 kbps     00:41:47.212    128,285 bytes   577,848 bytes   00:41:59.266
6               0:46:14.605     0:09:02.249     25,389 kbps     40,489 kbps     00:51:08.607    32,031 kbps     00:46:51.975    30,285 kbps     00:52:54.754    132,365 bytes   552,970 bytes   00:50:57.470
7               0:55:16.855     0:09:19.350     24,263 kbps     42,540 kbps     00:57:17.016    32,544 kbps     00:57:17.016    29,863 kbps     00:57:16.766    126,497 bytes   521,540 bytes   00:56:39.520
8               1:04:36.205     0:10:15.698     24,859 kbps     39,195 kbps     01:06:05.085    31,922 kbps     01:06:01.499    30,359 kbps     01:09:50.310    129,606 bytes   613,189 bytes   01:10:12.624
9               1:14:51.903     0:07:59.061     24,708 kbps     43,558 kbps     01:18:43.468    33,080 kbps     01:18:43.051    30,551 kbps     01:18:42.968    128,814 bytes   577,981 bytes   01:15:36.114
10              1:22:50.965     0:10:02.727     24,674 kbps     39,217 kbps     01:24:56.632    32,189 kbps     01:28:55.454    29,265 kbps     01:28:53.369    128,639 bytes   568,256 bytes   01:29:03.212
11              1:32:53.692     0:11:17.968     24,761 kbps     45,244 kbps     01:41:21.033    32,615 kbps     01:33:21.929    29,630 kbps     01:36:48.343    129,092 bytes   699,529 bytes   01:44:02.527
12              1:44:11.661     0:11:05.164     24,310 kbps     44,754 kbps     01:52:41.838    32,640 kbps     01:49:14.756    31,148 kbps     01:49:09.918    126,741 bytes   571,048 bytes   01:53:25.840
13              1:55:16.826     0:10:20.911     25,545 kbps     46,392 kbps     01:58:34.857    31,835 kbps     01:58:43.115    30,845 kbps     01:58:34.857    133,182 bytes   737,465 bytes   01:58:25.931
14              2:05:37.738     0:05:00.842     24,308 kbps     34,677 kbps     02:06:57.401    28,206 kbps     02:06:50.227    26,285 kbps     02:07:24.261    126,731 bytes   455,779 bytes   02:10:05.422
15              2:10:38.580     0:04:27.850     25,253 kbps     38,595 kbps     02:14:04.536    31,160 kbps     02:14:12.794    29,381 kbps     02:14:07.789    131,657 bytes   548,631 bytes   02:14:38.361
16              2:15:06.431     0:11:09.251     16,611 kbps     37,671 kbps     02:15:46.721    30,380 kbps     02:15:42.592    29,405 kbps     02:15:38.046    86,613 bytes    658,127 bytes   02:18:08.863
STREAM DIAGNOSTICS:
SKIPPED
Theatrical:
Extended:
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #870 of 5106 Old 11-25-2009, 06:39 PM - Thread Starter
Cinema Squid's Avatar
Hmm, that is indeed odd. Have you any problems playing the disc using a software player from the same BD drive or from a stand-alone player?
Cinema Squid is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
