NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 35 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #1021 of 5106 Old 01-01-2010, 11:56 PM - Thread Starter
Cinema Squid's Avatar
Originally Posted by DJ Matt View Post
Thanks for the answer. So, in most cases there would be more than 1 audio stream included such as English and Spanish for instance. If the movie only file size is 28,566,454,678 for instance then its quite possible the file size for the movie and just 1 lone audio stream is a few GB less than that.
Yes, that's correct. If you scroll down to the bottom of any of the reports that include the stream diagnostics, the measured size of each individual raw stream is given in bytes. However, this figure represents the stream stripped of M2TS container overhead for the purposes of calculating codec bitrate, so perhaps a more accurate number if you are considering remuxing and space is a concern would be the packet count multiplied by 192 bytes per packet.
Cinema Squid is offline
post #1022 of 5106 Old 01-02-2010, 03:40 PM
DJ Matt's Avatar
Quoted: 27 Post(s)
Makes sense now. I have backed up some of my Blu-rays that I own andin most cases there is more than 1 audio stream, but I select the main video stream and 1 audio stream and is considerably less than what the movie file size is of course. Thanks for the explanation.
DJ Matt is offline
post #1023 of 5106 Old 01-02-2010, 03:41 PM
Burrito's Avatar
No region code (Source: DVD Profiler database)
Studio: Warner
UPC: 7321983000409
Release Date: 2007-12-07
Aspect Ratio: 2.20:1
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:28:51 24.937.451.520  37.429.719.180  22,34   13,39   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     2001_SPACE_ODYSSEY
Disc Size:      37.429.719.180 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:28:51 (h:m:s)
Total Bitrate:          22,34 Mbps
VIDEO:
VC-1 Video              13392 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             German          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             Italian         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         13,326 kbps
Presentation Graphics           English         13,792 kbps
Presentation Graphics           Chinese         11,429 kbps
Presentation Graphics           Danish          9,515 kbps
Presentation Graphics           Dutch           10,310 kbps
Presentation Graphics           Finnish         9,233 kbps
Presentation Graphics           French          11,286 kbps
Presentation Graphics           German          14,680 kbps
Presentation Graphics           German          15,434 kbps
Presentation Graphics           Italian         13,535 kbps
Presentation Graphics           Italian         14,305 kbps
Presentation Graphics           Korean          9,633 kbps
Presentation Graphics           Norwegian       9,428 kbps
Presentation Graphics           Portuguese      12,717 kbps
Presentation Graphics           Portuguese      13,744 kbps
Presentation Graphics           Spanish         12,661 kbps
Presentation Graphics           Spanish         11,416 kbps
Presentation Graphics           Swedish         8,586 kbps
FILES:
00000.M2TS      0:00:00.000     2:28:51.672     24.937.451.520  22.336
CHAPTERS:
1               0:00:00.000     0:02:57.177     309 kbps        413 kbps        00:00:01.584    340 kbps        00:00:01.584    328 kbps        00:00:01.918    2.256 bytes     10.257 bytes    00:00:00.000
2               0:02:57.177     0:01:41.935     14.088 kbps     24.671 kbps     00:04:10.041    24.230 kbps     00:04:20.885    24.091 kbps     00:04:15.088    76.810 bytes    261.401 bytes   00:03:04.350
3               0:04:39.112     0:07:00.920     15.492 kbps     30.567 kbps     00:06:09.494    23.462 kbps     00:06:09.577    22.201 kbps     00:05:49.640    81.699 bytes    580.722 bytes   00:06:14.207
4               0:11:40.032     0:05:17.984     14.095 kbps     25.045 kbps     00:11:50.209    20.195 kbps     00:16:44.628    19.454 kbps     00:14:50.264    73.901 bytes    513.837 bytes   00:14:40.504
5               0:16:58.017     0:02:55.008     16.719 kbps     29.612 kbps     00:19:48.270    24.141 kbps     00:19:46.018    21.828 kbps     00:19:43.015    87.166 bytes    414.534 bytes   00:17:33.093
6               0:19:53.025     0:05:36.002     14.717 kbps     24.154 kbps     00:20:26.600    21.469 kbps     00:22:48.742    20.024 kbps     00:25:12.886    76.727 bytes    432.895 bytes   00:20:26.683
7               0:25:29.027     0:02:09.128     16.004 kbps     22.389 kbps     00:27:19.012    20.701 kbps     00:27:16.760    19.683 kbps     00:27:13.423    83.435 bytes    285.796 bytes   00:26:16.825
8               0:27:38.156     0:01:51.444     16.356 kbps     19.983 kbps     00:29:23.678    18.842 kbps     00:27:39.699    18.412 kbps     00:27:38.615    85.273 bytes    237.259 bytes   00:29:29.601
9               0:29:29.601     0:04:16.422     16.852 kbps     26.232 kbps     00:33:43.479    19.269 kbps     00:29:35.732    18.317 kbps     00:33:01.980    87.902 bytes    280.991 bytes   00:33:22.333
10              0:33:46.024     0:07:22.608     14.258 kbps     26.965 kbps     00:40:00.731    21.143 kbps     00:34:01.664    19.280 kbps     00:37:08.851    74.398 bytes    439.287 bytes   00:39:22.276
11              0:41:08.632     0:04:28.935     15.515 kbps     21.836 kbps     00:45:01.490    19.248 kbps     00:44:21.200    17.986 kbps     00:44:17.696    80.887 bytes    264.191 bytes   00:43:28.105
12              0:45:37.568     0:05:18.985     16.173 kbps     28.812 kbps     00:50:19.391    24.798 kbps     00:50:22.769    24.255 kbps     00:50:18.265    84.319 bytes    383.304 bytes   00:49:38.558
13              0:50:56.553     0:03:46.392     15.215 kbps     20.987 kbps     00:51:10.817    18.965 kbps     00:53:19.738    18.596 kbps     00:53:16.109    79.322 bytes    271.475 bytes   00:54:41.611
14              0:54:42.946     0:03:50.730     16.496 kbps     30.832 kbps     00:56:11.493    23.111 kbps     00:56:11.493    22.040 kbps     00:56:49.697    86.002 bytes    374.977 bytes   00:56:21.127
15              0:58:33.676     0:05:22.321     13.851 kbps     24.139 kbps     01:02:04.178    21.442 kbps     01:02:03.386    19.025 kbps     01:02:03.386    72.212 bytes    409.018 bytes   01:00:45.558
16              1:03:55.998     0:02:09.295     15.511 kbps     24.154 kbps     01:05:09.238    19.116 kbps     01:04:55.308    16.459 kbps     01:04:50.303    80.865 bytes    408.764 bytes   01:05:34.013
17              1:06:05.294     0:06:05.364     14.703 kbps     23.213 kbps     01:07:19.827    20.787 kbps     01:10:00.487    19.602 kbps     01:09:55.482    76.656 bytes    321.851 bytes   01:10:11.916
18              1:12:10.659     0:06:41.234     15.412 kbps     24.769 kbps     01:18:25.617    20.054 kbps     01:16:50.689    19.726 kbps     01:16:50.355    80.353 bytes    329.147 bytes   01:18:25.659
19              1:18:51.893     0:04:09.582     15.480 kbps     23.902 kbps     01:20:24.110    21.428 kbps     01:22:29.903    19.264 kbps     01:19:11.329    80.704 bytes    402.538 bytes   01:20:24.277
20              1:23:01.476     0:04:00.740     19.335 kbps     29.338 kbps     01:23:57.365    24.400 kbps     01:24:26.603    24.294 kbps     01:25:16.778    100.802 bytes   346.345 bytes   01:23:34.676
21              1:27:02.217     0:00:47.046     7.740 kbps      23.035 kbps     01:27:14.354    18.920 kbps     01:27:10.225    18.456 kbps     01:27:06.137    40.753 bytes    166.947 bytes   01:27:05.637
22              1:27:49.264     0:02:18.471     308 kbps        385 kbps        01:30:06.734    326 kbps        01:30:02.730    313 kbps        01:27:49.681    2.245 bytes     9.236 bytes     01:27:49.764
23              1:30:07.735     0:02:43.163     14.972 kbps     27.996 kbps     01:30:08.820    22.995 kbps     01:30:08.820    21.763 kbps     01:30:08.820    78.215 bytes    386.430 bytes   01:30:42.895
24              1:32:50.898     0:05:44.677     16.817 kbps     27.013 kbps     01:35:24.927    23.334 kbps     01:36:34.830    22.402 kbps     01:36:34.830    87.675 bytes    317.858 bytes   01:36:03.883
25              1:38:35.576     0:02:11.506     15.130 kbps     23.797 kbps     01:39:31.715    21.677 kbps     01:38:36.327    20.170 kbps     01:40:30.482    78.881 bytes    389.334 bytes   01:40:24.852
26              1:40:47.082     0:04:48.413     12.608 kbps     28.651 kbps     01:45:19.521    23.132 kbps     01:45:19.396    20.735 kbps     01:43:10.017    65.734 bytes    340.329 bytes   01:41:33.712
27              1:45:35.495     0:04:06.079     13.835 kbps     21.901 kbps     01:49:40.407    17.831 kbps     01:46:58.078    17.253 kbps     01:48:34.966    72.130 bytes    240.762 bytes   01:47:01.623
28              1:49:41.575     0:05:38.171     13.270 kbps     27.663 kbps     01:54:24.065    20.942 kbps     01:54:20.478    20.765 kbps     01:54:20.562    69.184 bytes    382.776 bytes   01:51:27.013
29              1:55:19.746     0:01:46.439     16.124 kbps     23.668 kbps     01:56:22.600    21.564 kbps     01:56:53.047    21.244 kbps     01:56:46.916    84.759 bytes    281.326 bytes   01:55:55.490
30              1:57:06.185     0:04:22.095     5.426 kbps      17.405 kbps     02:00:12.914    16.939 kbps     02:00:10.578    16.615 kbps     02:00:07.033    28.301 bytes    154.225 bytes   02:00:55.248
31              2:01:28.281     0:10:05.104     14.282 kbps     30.973 kbps     02:07:19.131    23.163 kbps     02:07:19.131    22.120 kbps     02:10:56.306    74.462 bytes    660.965 bytes   02:10:37.621
32              2:11:33.385     0:06:24.217     13.893 kbps     23.087 kbps     02:15:38.964    17.456 kbps     02:12:48.418    16.572 kbps     02:12:47.376    72.432 bytes    368.686 bytes   02:12:13.008
33              2:17:57.602     0:02:35.822     12.296 kbps     23.582 kbps     02:19:03.251    21.063 kbps     02:20:05.730    18.881 kbps     02:20:00.683    64.522 bytes    288.783 bytes   02:19:03.293
34              2:20:33.425     0:08:18.247     802 kbps        4.773 kbps      02:23:33.146    4.333 kbps      02:23:33.146    3.834 kbps      02:23:33.146    5.384 bytes     118.830 bytes   02:23:39.027
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    8931,589                13.392                  14.951.281.519  81.391.692
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           8931,589                448                     500.174.080     2.791.150
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           8931,589                4.614                   5.151.790.140   28.581.360
00000.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            8931,589                448                     500.174.080     2.791.150
00000.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           8931,589                448                     500.174.080     2.791.150
00000.M2TS      4356 (0x1104)   0x81            AC3             deu (German)            8931,589                448                     500.174.080     2.791.150
00000.M2TS      4357 (0x1105)   0x81            AC3             ita (Italian)           8931,589                448                     500.174.080     2.791.150
00000.M2TS      4358 (0x1106)   0x81            AC3             spa (Spanish)           8931,589                448                     500.174.080     2.791.150
00000.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           8931,589                192                     214.360.320     1.395.575
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8931,589                13                      14.878.413      85.015
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8931,589                14                      15.398.332      87.894
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8931,589                11                      12.600.843      72.551
00000.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            8931,589                15                      16.390.161      93.248
00000.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            8931,589                15                      17.231.475      97.913
00000.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           8931,589                14                      15.111.303      86.399
00000.M2TS      4614 (0x1206)   0x90            PGS             ita (Italian)           8931,589                14                      15.971.145      91.137
00000.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           8931,589                13                      14.134.968      80.995
00000.M2TS      4616 (0x1208)   0x90            PGS             nld (Dutch)             8931,589                10                      11.510.164      65.469
00000.M2TS      4617 (0x1209)   0x90            PGS             zho (Chinese)           8931,589                11                      12.760.281      73.711
00000.M2TS      4618 (0x120A)   0x90            PGS             dan (Danish)            8931,589                10                      10.623.303      60.250
00000.M2TS      4619 (0x120B)   0x90            PGS             fin (Finnish)           8931,589                9                       10.308.491      58.450
00000.M2TS      4620 (0x120C)   0x90            PGS             kor (Korean)            8931,589                10                      10.755.109      62.740
00000.M2TS      4621 (0x120D)   0x90            PGS             nor (Norwegian)         8931,589                9                       10.525.806      60.075
00000.M2TS      4622 (0x120E)   0x90            PGS             por (Portuguese)        8931,589                13                      14.197.575      81.388
00000.M2TS      4623 (0x120F)   0x90            PGS             por (Portuguese)        8931,589                14                      15.345.138      87.584
00000.M2TS      4624 (0x1210)   0x90            PGS             spa (Spanish)           8931,589                11                      12.745.238      73.379
00000.M2TS      4625 (0x1211)   0x90            PGS             swe (Swedish)           8931,589                9                       9.586.298       54.563
Burrito is offline
post #1024 of 5106 Old 01-02-2010, 09:50 PM
Burrito's Avatar
Studio: Columbia Pictures
UPC: 4030521713420
Release Date: 2008-09-19
Aspect Ratio: 2.40:1
Code:
        Total   Video
00001.MPLS                                                      AVC     2:02:41 34.663.766.016  42.313.110.767  37,67   25,76   Dolby TrueHD 5.1 1591Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     21
Disc Size:      42.313.110.767 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:02:41 (h:m:s)
Total Bitrate:          37,67 Mbps
VIDEO:
MPEG-4 AVC Video        25764 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1591 kbps       5.1 / 48 kHz / 1591 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby TrueHD Audio              French          1570 kbps       5.1 / 48 kHz / 1570 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -2dB)
Dolby TrueHD Audio              German          1563 kbps       5.1 / 48 kHz / 1563 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
SUBTITLES:
Presentation Graphics           English         37,880 kbps
Presentation Graphics           Arabic          17,351 kbps
Presentation Graphics           Dutch           33,631 kbps
Presentation Graphics           Dutch           75,102 kbps
Presentation Graphics           French          28,115 kbps
Presentation Graphics           French          64,786 kbps
Presentation Graphics           German          32,067 kbps
Presentation Graphics           German          81,876 kbps
Presentation Graphics           Turkish         34,112 kbps
FILES:
00133.M2TS      0:00:00.000     2:02:41.354     34.663.766.016  37.671
CHAPTERS:
1               0:00:00.000     0:08:00.271     25.798 kbps     48.305 kbps     00:00:22.564    32.583 kbps     00:03:59.155    32.079 kbps     00:03:59.155    134.487 bytes   632.545 bytes   00:07:53.973
2               0:08:00.271     0:08:36.641     26.821 kbps     41.012 kbps     00:11:20.304    32.663 kbps     00:11:16.300    31.339 kbps     00:11:11.295    139.831 bytes   559.287 bytes   00:11:19.637
3               0:16:36.912     0:07:00.044     24.843 kbps     35.571 kbps     00:17:25.377    29.754 kbps     00:16:42.209    29.214 kbps     00:16:37.204    129.519 bytes   692.586 bytes   00:22:43.236
4               0:23:36.957     0:05:40.006     25.962 kbps     38.433 kbps     00:27:37.781    31.434 kbps     00:26:19.035    31.123 kbps     00:26:19.035    135.354 bytes   736.013 bytes   00:28:37.048
5               0:29:16.963     0:02:47.000     25.153 kbps     33.821 kbps     00:30:04.969    30.987 kbps     00:30:04.219    28.956 kbps     00:30:04.219    131.137 bytes   599.983 bytes   00:30:05.929
6               0:32:03.963     0:08:47.652     25.748 kbps     41.753 kbps     00:34:30.902    31.689 kbps     00:32:30.490    31.072 kbps     00:32:48.633    134.238 bytes   602.424 bytes   00:34:31.027
7               0:40:51.615     0:07:22.275     27.131 kbps     54.055 kbps     00:41:29.278    32.937 kbps     00:41:28.944    31.349 kbps     00:47:19.461    141.447 bytes   616.078 bytes   00:43:36.238
8               0:48:13.890     0:07:30.867     26.060 kbps     45.522 kbps     00:48:14.141    30.590 kbps     00:54:39.734    29.237 kbps     00:54:00.528    135.867 bytes   702.921 bytes   00:55:44.758
9               0:55:44.758     0:08:35.598     25.799 kbps     41.516 kbps     01:03:39.065    32.948 kbps     01:03:38.773    32.226 kbps     01:03:38.606    134.507 bytes   775.122 bytes   00:55:45.550
10              1:04:20.356     0:08:30.259     25.976 kbps     40.049 kbps     01:07:36.927    31.283 kbps     01:05:48.152    30.534 kbps     01:05:47.735    135.426 bytes   654.203 bytes   01:07:01.225
11              1:12:50.616     0:09:25.064     25.925 kbps     38.423 kbps     01:16:56.987    33.584 kbps     01:16:59.615    32.524 kbps     01:16:56.987    135.163 bytes   610.374 bytes   01:20:20.941
12              1:22:15.680     0:07:49.594     25.398 kbps     40.906 kbps     01:22:21.978    33.064 kbps     01:22:21.394    31.295 kbps     01:22:17.265    132.413 bytes   559.607 bytes   01:25:33.336
13              1:30:05.274     0:08:04.609     26.712 kbps     43.980 kbps     01:30:53.156    32.396 kbps     01:30:19.414    31.721 kbps     01:31:12.800    139.263 bytes   636.144 bytes   01:38:09.884
14              1:38:09.884     0:07:08.261     25.009 kbps     41.963 kbps     01:38:17.725    32.792 kbps     01:38:13.888    30.986 kbps     01:38:10.175    130.388 bytes   690.814 bytes   01:38:10.676
15              1:45:18.145     0:03:40.845     25.842 kbps     42.860 kbps     01:48:23.663    30.440 kbps     01:45:36.079    30.060 kbps     01:45:29.656    134.731 bytes   590.165 bytes   01:45:22.274
16              1:48:58.990     0:13:42.363     24.467 kbps     43.641 kbps     01:50:04.180    33.000 kbps     01:51:08.370    32.206 kbps     01:51:08.119    127.574 bytes   599.514 bytes   01:57:28.708
STREAM DIAGNOSTICS:
00133.M2TS      4113 (0x1011)   0x1B            AVC                                     7361,271                25.765                  23.707.616.843  128.949.655
00133.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           7361,271                2.231                   2.052.574.336   16.123.120
00133.M2TS      4353 (0x1101)   0x83            TrueHD          fra (French)            7361,271                2.210                   2.033.987.684   15.986.113
00133.M2TS      4354 (0x1102)   0x83            TrueHD          deu (German)            7361,271                2.203                   2.026.920.524   15.947.786
00133.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7361,271                192                     176.673.024     1.150.215
00133.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7361,271                38                      34.856.432      199.470
00133.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7361,271                28                      25.870.336      150.609
00133.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            7361,271                32                      29.507.298      171.509
00133.M2TS      4611 (0x1203)   0x90            PGS             nld (Dutch)             7361,271                34                      30.945.859      178.308
00133.M2TS      4612 (0x1204)   0x90            PGS             ara (Arabic)            7361,271                17                      15.966.101      98.262
00133.M2TS      4613 (0x1205)   0x90            PGS             tur (Turkish)           7361,271                34                      31.389.172      180.624
00133.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            7361,271                65                      59.613.643      340.431
00133.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            7361,271                82                      75.339.988      425.782
00133.M2TS      4616 (0x1208)   0x90            PGS             nld (Dutch)             7361,271                75                      69.106.366      391.940
Burrito is offline
post #1025 of 5106 Old 01-02-2010, 11:45 PM
DJ Matt's Avatar
Quoted: 27 Post(s)
The Marine 2
US Release
Code:
        Total   Video
00638.MPLS                                                      AVC     1:35:20 30,596,438,016  45,015,922,721  42.79   34.99   DTS-HD Master 5.1 4136Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     MARINE_2
Disc Size:      45,015,922,721 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:35:20 (h:m:s)
Total Bitrate:          42.79 Mbps
VIDEO:
MPEG-4 AVC Video        34989 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4136 kbps       5.1 / 48 kHz / 4136 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Portuguese      448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         30.592 kbps
Presentation Graphics           Chinese         27.212 kbps
Presentation Graphics           Chinese         28.998 kbps
Presentation Graphics           French          0.422 kbps
Presentation Graphics           Portuguese      24.908 kbps
Presentation Graphics           Spanish         26.948 kbps
FILES:
00999.M2TS      0:00:00.000     1:35:20.214     30,596,438,016  42,791
CHAPTERS:
1               0:00:00.000     0:03:13.985     30,862 kbps     39,101 kbps     00:02:25.895    37,247 kbps     00:02:21.766    36,951 kbps     00:02:20.807    160,865 bytes   488,045 bytes   00:00:19.269
2               0:03:13.985     0:04:20.301     36,243 kbps     40,803 kbps     00:05:17.483    37,222 kbps     00:04:07.872    36,947 kbps     00:03:26.748    188,955 bytes   456,406 bytes   00:05:18.443
3               0:07:34.287     0:06:26.761     36,522 kbps     40,754 kbps     00:09:59.557    37,305 kbps     00:08:48.152    36,930 kbps     00:11:18.594    190,411 bytes   437,242 bytes   00:10:31.213
4               0:14:01.048     0:05:55.146     36,609 kbps     39,220 kbps     00:18:28.774    37,357 kbps     00:18:21.975    37,065 kbps     00:18:19.640    190,863 bytes   522,565 bytes   00:18:29.650
5               0:19:56.195     0:05:09.976     36,419 kbps     38,817 kbps     00:20:02.993    37,168 kbps     00:20:09.333    36,896 kbps     00:24:21.501    189,872 bytes   343,372 bytes   00:25:04.294
6               0:25:06.171     0:03:21.618     35,880 kbps     47,029 kbps     00:25:42.165    38,864 kbps     00:25:38.203    37,774 kbps     00:25:33.156    187,064 bytes   379,935 bytes   00:25:42.707
7               0:28:27.789     0:05:45.845     35,059 kbps     41,621 kbps     00:31:18.084    37,319 kbps     00:31:14.080    36,880 kbps     00:31:33.808    182,783 bytes   397,396 bytes   00:31:18.793
8               0:34:13.634     0:05:05.430     35,286 kbps     39,912 kbps     00:37:39.382    37,029 kbps     00:37:11.771    36,898 kbps     00:37:43.803    183,966 bytes   302,124 bytes   00:37:39.840
9               0:39:19.065     0:04:30.853     36,140 kbps     41,728 kbps     00:42:20.913    37,224 kbps     00:42:49.775    36,991 kbps     00:39:47.802    188,416 bytes   292,457 bytes   00:42:21.455
10              0:43:49.918     0:03:44.557     35,892 kbps     42,802 kbps     00:45:32.771    37,970 kbps     00:45:28.767    37,372 kbps     00:45:23.762    187,125 bytes   442,873 bytes   00:45:33.564
11              0:47:34.476     0:03:56.903     35,838 kbps     39,785 kbps     00:49:04.858    37,037 kbps     00:48:54.765    36,884 kbps     00:48:51.011    186,844 bytes   347,415 bytes   00:47:36.144
12              0:51:31.379     0:02:40.869     36,234 kbps     38,856 kbps     00:54:09.579    37,200 kbps     00:53:36.713    36,996 kbps     00:53:34.419    188,906 bytes   454,097 bytes   00:53:44.304
13              0:54:12.248     0:05:09.017     36,219 kbps     42,195 kbps     00:55:17.355    37,456 kbps     00:55:13.351    36,951 kbps     00:56:31.596    188,827 bytes   395,230 bytes   00:56:51.241
14              0:59:21.266     0:03:36.674     35,698 kbps     39,894 kbps     01:00:45.099    37,349 kbps     01:00:41.012    36,770 kbps     01:01:52.625    186,114 bytes   331,080 bytes   01:01:08.498
15              1:02:57.940     0:02:55.258     36,094 kbps     40,544 kbps     01:05:00.897    37,531 kbps     01:04:56.934    37,165 kbps     01:04:51.804    188,177 bytes   348,077 bytes   01:05:01.564
16              1:05:53.199     0:02:23.309     36,038 kbps     42,170 kbps     01:06:04.251    37,082 kbps     01:07:15.781    36,848 kbps     01:07:54.695    187,883 bytes   297,023 bytes   01:06:11.384
17              1:08:16.509     0:04:37.652     36,054 kbps     46,416 kbps     01:10:15.794    38,516 kbps     01:10:11.790    37,399 kbps     01:10:06.785    187,970 bytes   484,376 bytes   01:10:16.295
18              1:12:54.161     0:04:32.397     35,694 kbps     41,591 kbps     01:17:03.785    37,295 kbps     01:16:28.834    36,917 kbps     01:13:05.172    186,092 bytes   300,731 bytes   01:12:56.163
19              1:17:26.558     0:01:39.557     35,550 kbps     38,762 kbps     01:18:43.552    36,892 kbps     01:18:48.724    36,741 kbps     01:18:28.620    185,341 bytes   350,066 bytes   01:19:06.116
20              1:19:06.116     0:01:28.838     36,177 kbps     38,562 kbps     01:19:43.278    37,078 kbps     01:19:57.375    36,804 kbps     01:19:57.501    188,608 bytes   383,273 bytes   01:19:20.130
21              1:20:34.955     0:02:26.563     35,971 kbps     43,382 kbps     01:22:23.396    37,042 kbps     01:22:12.719    36,817 kbps     01:21:40.896    187,535 bytes   421,001 bytes   01:22:18.475
22              1:23:01.518     0:02:21.391     36,391 kbps     39,220 kbps     01:24:23.058    37,129 kbps     01:24:19.137    36,944 kbps     01:24:14.758    189,727 bytes   478,970 bytes   01:24:24.726
23              1:25:22.909     0:05:38.880     36,045 kbps     41,763 kbps     01:26:39.319    37,521 kbps     01:28:39.272    36,973 kbps     01:28:34.350    187,924 bytes   385,329 bytes   01:28:09.909
24              1:31:01.789     0:04:18.424     17,282 kbps     37,652 kbps     01:31:02.165    36,931 kbps     01:31:01.914    36,863 kbps     01:31:34.322    90,114 bytes    503,301 bytes   01:31:49.837
STREAM DIAGNOSTICS:
00999.M2TS      4113 (0x1011)   0x1B            AVC                                     5720.048                34,990                  25,017,935,449  136,046,996
00999.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5720.048                4,136                   2,957,359,084   16,964,743
00999.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           5720.048                448                     320,332,544     1,787,570
00999.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            5720.048                448                     320,332,544     1,787,570
00999.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        5720.048                448                     320,332,544     1,787,570
00999.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5720.048                31                      21,874,109      124,353
00999.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5720.048                27                      19,268,457      109,318
00999.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5720.048                0                       301,621         1,701
00999.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           5720.048                27                      19,457,588      110,855
00999.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           5720.048                29                      20,734,198      117,824
00999.M2TS      4613 (0x1205)   0x90            PGS             por (Portuguese)        5720.048                25                      17,810,090      101,427
DJ Matt is offline
post #1026 of 5106 Old 01-03-2010, 04:54 AM
Stephen Dawson's Avatar
Deep Impact - 1998 - Australian version
Distributed by Paramount Home Entertainment (Australasia) Pty Ltd
Region Free, confirmed with AnyDVD HD
Judging from the disc title, this is probably the same as the European version. Basically the same as the US version, but with a different language package and file names.
Code:
        Total   Video
00001.MPLS                                                      AVC     2:01:11 39,920,756,736  44,223,920,003  43.92   32.41   Dolby TrueHD 5.1 3962Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     DEEPIMPACT_EU
Disc Size:      44,223,920,003 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:01:11 (h:m:s)
Total Bitrate:          43.92 Mbps
VIDEO:
MPEG-4 AVC Video        32406 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3962 kbps       5.1 / 48 kHz / 3962 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Italian         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           Danish          28.053 kbps
Presentation Graphics           German          34.770 kbps
Presentation Graphics           English         37.286 kbps
Presentation Graphics           Spanish         32.159 kbps
Presentation Graphics           French          28.633 kbps
Presentation Graphics           Italian         33.841 kbps
Presentation Graphics           Dutch           24.518 kbps
Presentation Graphics           Norwegian       26.176 kbps
Presentation Graphics           Finnish         27.508 kbps
Presentation Graphics           Swedish         26.591 kbps
Presentation Graphics           English         40.590 kbps
Presentation Graphics           German          44.868 kbps
Presentation Graphics           English         49.615 kbps
Presentation Graphics           Spanish         40.044 kbps
Presentation Graphics           French          41.225 kbps
Presentation Graphics           Italian         42.262 kbps
Presentation Graphics           German          0.274 kbps
Presentation Graphics           Spanish         0.281 kbps
Presentation Graphics           French          0.219 kbps
Presentation Graphics           Italian         0.268 kbps
FILES:
00005.M2TS      0:00:00.000     2:01:11.639     39,920,756,736  43,919
CHAPTERS:
1               0:00:00.000     0:02:37.615     29,409 kbps     44,287 kbps     00:00:40.457    36,166 kbps     00:00:36.494    35,184 kbps     00:00:31.448    153,285 bytes   391,883 bytes   00:00:41.041
2               0:02:37.615     0:04:24.138     33,448 kbps     42,262 kbps     00:06:58.751    35,993 kbps     00:06:54.747    34,399 kbps     00:04:28.184    174,380 bytes   447,119 bytes   00:04:37.777
3               0:07:01.754     0:03:52.190     33,686 kbps     36,513 kbps     00:07:08.219    34,537 kbps     00:07:04.215    34,328 kbps     00:07:37.081    175,621 bytes   370,658 bytes   00:07:48.801
4               0:10:53.944     0:06:17.043     33,983 kbps     36,126 kbps     00:14:42.006    34,514 kbps     00:14:17.773    34,372 kbps     00:12:40.676    177,171 bytes   396,672 bytes   00:12:33.669
5               0:17:10.988     0:03:26.873     32,508 kbps     36,252 kbps     00:17:31.800    34,352 kbps     00:20:32.856    34,195 kbps     00:20:18.467    169,484 bytes   382,905 bytes   00:20:37.861
6               0:20:37.861     0:01:43.770     33,731 kbps     37,500 kbps     00:21:11.895    34,781 kbps     00:21:07.891    34,348 kbps     00:20:40.822    175,859 bytes   568,826 bytes   00:21:12.854
7               0:22:21.631     0:03:06.394     33,953 kbps     35,582 kbps     00:25:16.598    34,443 kbps     00:23:15.894    34,313 kbps     00:22:34.895    177,013 bytes   375,004 bytes   00:23:20.899
8               0:25:28.026     0:09:32.905     33,228 kbps     37,163 kbps     00:34:43.748    34,899 kbps     00:34:39.744    34,454 kbps     00:27:15.091    173,234 bytes   443,897 bytes   00:27:52.045
9               0:35:00.932     0:04:10.500     33,886 kbps     36,889 kbps     00:37:24.784    34,734 kbps     00:36:41.991    34,461 kbps     00:36:56.339    176,666 bytes   506,768 bytes   00:36:47.914
10              0:39:11.432     0:04:47.453     33,053 kbps     39,490 kbps     00:40:11.033    35,065 kbps     00:40:07.071    34,693 kbps     00:40:02.066    172,323 bytes   432,576 bytes   00:42:17.701
11              0:43:58.886     0:07:47.049     33,663 kbps     37,402 kbps     00:46:52.184    34,768 kbps     00:51:35.342    34,418 kbps     00:47:45.696    175,504 bytes   440,536 bytes   00:47:58.208
12              0:51:45.936     0:04:31.604     33,480 kbps     38,701 kbps     00:54:44.489    34,839 kbps     00:54:40.568    34,413 kbps     00:53:53.480    174,548 bytes   420,393 bytes   00:53:48.016
13              0:56:17.540     0:03:58.238     33,587 kbps     36,494 kbps     00:59:18.346    34,479 kbps     00:57:46.379    34,333 kbps     00:58:18.244    175,108 bytes   399,251 bytes   00:57:50.383
14              1:00:15.778     0:04:46.035     33,806 kbps     35,926 kbps     01:01:45.451    34,511 kbps     01:01:45.159    34,380 kbps     01:01:38.152    176,250 bytes   455,696 bytes   01:02:18.192
15              1:05:01.814     0:04:40.405     33,136 kbps     36,710 kbps     01:06:23.145    34,641 kbps     01:06:21.060    34,371 kbps     01:06:46.711    172,757 bytes   527,967 bytes   01:06:26.065
16              1:09:42.219     0:04:11.125     33,263 kbps     37,503 kbps     01:09:54.732    34,516 kbps     01:10:30.768    34,364 kbps     01:10:38.400    173,416 bytes   409,408 bytes   01:09:51.228
17              1:13:53.345     0:04:17.256     33,753 kbps     36,084 kbps     01:14:18.203    34,541 kbps     01:14:27.588    34,366 kbps     01:16:45.559    175,975 bytes   392,087 bytes   01:14:31.842
18              1:18:10.602     0:01:57.700     33,476 kbps     38,290 kbps     01:19:53.705    34,559 kbps     01:19:49.743    34,211 kbps     01:18:13.271    174,529 bytes   339,671 bytes   01:18:19.319
19              1:20:08.303     0:02:44.164     33,727 kbps     38,275 kbps     01:21:38.602    34,928 kbps     01:21:34.556    34,568 kbps     01:21:29.551    175,837 bytes   354,483 bytes   01:21:03.692
20              1:22:52.467     0:02:27.856     33,932 kbps     35,953 kbps     01:23:57.949    34,549 kbps     01:25:14.609    34,379 kbps     01:23:51.109    176,904 bytes   419,363 bytes   01:25:19.489
21              1:25:20.323     0:02:26.521     33,916 kbps     39,441 kbps     01:27:27.784    35,317 kbps     01:27:23.821    34,339 kbps     01:25:52.063    176,821 bytes   330,543 bytes   01:25:59.988
22              1:27:46.844     0:04:06.746     32,591 kbps     36,383 kbps     01:31:30.485    34,589 kbps     01:29:14.098    34,371 kbps     01:29:09.177    169,913 bytes   409,562 bytes   01:29:18.811
23              1:31:53.591     0:02:29.482     33,681 kbps     35,992 kbps     01:31:58.638    34,593 kbps     01:31:58.513    34,394 kbps     01:31:58.513    175,598 bytes   423,406 bytes   01:32:01.516
24              1:34:23.074     0:04:21.970     33,589 kbps     36,464 kbps     01:37:54.660    34,460 kbps     01:34:30.039    34,316 kbps     01:34:26.911    175,118 bytes   446,762 bytes   01:36:26.071
25              1:38:45.044     0:02:10.380     33,533 kbps     36,266 kbps     01:39:36.428    34,490 kbps     01:39:58.909    34,136 kbps     01:40:40.868    174,826 bytes   432,907 bytes   01:40:55.424
26              1:40:55.424     0:02:22.684     33,996 kbps     36,594 kbps     01:41:13.192    34,632 kbps     01:41:09.396    34,430 kbps     01:41:04.391    177,241 bytes   483,107 bytes   01:41:10.439
27              1:43:18.108     0:02:57.010     33,437 kbps     39,837 kbps     01:45:07.175    34,671 kbps     01:44:45.946    34,388 kbps     01:43:39.796    174,324 bytes   453,794 bytes   01:45:26.987
28              1:46:15.118     0:05:28.369     33,145 kbps     38,172 kbps     01:50:39.424    34,607 kbps     01:48:06.771    34,310 kbps     01:51:29.849    172,801 bytes   473,546 bytes   01:48:08.773
29              1:51:43.488     0:01:40.350     34,047 kbps     35,961 kbps     01:53:22.212    34,487 kbps     01:53:18.208    34,329 kbps     01:52:02.090    177,507 bytes   472,362 bytes   01:53:17.582
30              1:53:23.838     0:07:47.800     17,884 kbps     37,624 kbps     02:01:02.004    34,149 kbps     01:59:15.731    32,278 kbps     01:59:13.396    93,250 bytes    395,831 bytes   01:59:17.191
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     7271.473                32,407                  29,455,852,618  160,187,341
00005.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           7271.473                4,602                   4,183,114,710   29,744,404
00005.M2TS      4353 (0x1101)   0x81            AC3             deu (German)            7271.473                640                     581,731,840     3,408,585
00005.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7271.473                640                     581,731,840     3,408,585
00005.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            7271.473                640                     581,731,840     3,408,585
00005.M2TS      4356 (0x1104)   0x81            AC3             ita (Italian)           7271.473                640                     581,731,840     3,408,585
00005.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           7271.473                224                     203,606,144     1,136,195
00005.M2TS      4608 (0x1200)   0x90            PGS             dan (Danish)            7271.473                28                      25,499,222      146,213
00005.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            7271.473                35                      31,603,912      180,050
00005.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           7271.473                37                      33,891,387      193,276
00005.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7271.473                32                      29,231,457      167,179
00005.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            7271.473                29                      26,026,499      149,129
00005.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           7271.473                34                      30,759,700      175,472
00005.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             7271.473                25                      22,285,905      127,270
00005.M2TS      4615 (0x1207)   0x90            PGS             nor (Norwegian)         7271.473                26                      23,792,634      136,859
00005.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           7271.473                28                      25,003,495      143,804
00005.M2TS      4617 (0x1209)   0x90            PGS             swe (Swedish)           7271.473                27                      24,170,237      138,760
00005.M2TS      4618 (0x120A)   0x90            PGS             eng (English)           7271.473                41                      36,894,722      210,488
00005.M2TS      4619 (0x120B)   0x90            PGS             deu (German)            7271.473                45                      40,782,604      230,591
00005.M2TS      4620 (0x120C)   0x90            PGS             eng (English)           7271.473                50                      45,098,137      255,655
00005.M2TS      4621 (0x120D)   0x90            PGS             spa (Spanish)           7271.473                40                      36,397,809      206,760
00005.M2TS      4622 (0x120E)   0x90            PGS             fra (French)            7271.473                41                      37,471,689      212,650
00005.M2TS      4623 (0x120F)   0x90            PGS             ita (Italian)           7271.473                42                      38,414,093      217,778
00005.M2TS      4624 (0x1210)   0x90            PGS             deu (German)            7271.473                0                       249,305         1,418
00005.M2TS      4625 (0x1211)   0x90            PGS             spa (Spanish)           7271.473                0                       255,553         1,453
00005.M2TS      4626 (0x1212)   0x90            PGS             fra (French)            7271.473                0                       198,798         1,143
00005.M2TS      4627 (0x1213)   0x90            PGS             ita (Italian)           7271.473                0                       243,256         1,387
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1027 of 5106 Old 01-03-2010, 06:14 AM
Burrito's Avatar
Studio: Warner
UPC: 5051890003836
Release Date: 2009-04-24
Code:
        Total   Video
00004.MPLS                                                      VC-1    1:55:54 27.107.850.240  28.069.176.672  31,18   22,50   Dolby TrueHD 5.1 1408Kbps (48kHz/16-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     2010_THE_YEAR_WE_MAKE_CONTACT
Disc Size:      28.069.176.672 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:55:54 (h:m:s)
Total Bitrate:          31,18 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
VC-1 Video              22500 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         1408 kbps       5.1 / 48 kHz / 1408 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
* Dolby Digital Audio           Japanese        192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Portuguese      192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         35,326 kbps
Presentation Graphics           Danish          31,520 kbps
Presentation Graphics           Dutch           28,098 kbps
Presentation Graphics           Finnish         22,546 kbps
Presentation Graphics           French          27,034 kbps
Presentation Graphics           French          1,173 kbps
Presentation Graphics           German          37,943 kbps
Presentation Graphics           German          1,356 kbps
Presentation Graphics           Italian         31,223 kbps
Presentation Graphics           Italian         35,929 kbps
Presentation Graphics           Italian         1,363 kbps
* Presentation Graphics         Japanese        27,990 kbps
* Presentation Graphics         Japanese        4,199 kbps
Presentation Graphics           Norwegian       22,940 kbps
Presentation Graphics           Portuguese      33,326 kbps
Presentation Graphics           Portuguese      29,320 kbps
Presentation Graphics           Spanish         34,257 kbps
Presentation Graphics           Spanish         30,032 kbps
Presentation Graphics           Spanish         1,437 kbps
Presentation Graphics           Spanish         0,102 kbps
Presentation Graphics           Swedish         30,946 kbps
FILES:
00004.M2TS      0:00:00.000     1:55:54.989     27.107.850.240  31.181
CHAPTERS:
1               0:00:00.000     0:02:47.542     14.085 kbps     33.537 kbps     00:00:03.837    29.042 kbps     00:00:03.837    24.739 kbps     00:01:40.558    74.488 bytes    254.176 bytes   00:00:28.695
2               0:02:47.542     0:01:26.920     17.431 kbps     34.883 kbps     00:03:13.234    33.255 kbps     00:03:11.024    30.347 kbps     00:03:09.397    91.493 bytes    333.431 bytes   00:03:14.569
3               0:04:14.462     0:05:55.480     28.328 kbps     34.517 kbps     00:07:31.159    32.995 kbps     00:07:31.159    31.790 kbps     00:04:44.701    147.687 bytes   371.457 bytes   00:07:31.200
4               0:10:09.942     0:03:24.746     25.988 kbps     30.004 kbps     00:10:27.501    29.287 kbps     00:10:23.456    28.010 kbps     00:10:18.909    135.491 bytes   412.655 bytes   00:11:31.982
5               0:13:34.688     0:02:45.456     27.445 kbps     34.546 kbps     00:14:00.005    31.789 kbps     00:13:58.254    30.793 kbps     00:15:14.705    143.085 bytes   386.930 bytes   00:13:59.463
6               0:16:20.145     0:05:04.804     26.410 kbps     38.107 kbps     00:17:33.761    34.729 kbps     00:17:29.882    32.360 kbps     00:18:32.653    137.688 bytes   385.419 bytes   00:21:17.651
7               0:21:24.950     0:05:18.484     24.749 kbps     37.265 kbps     00:21:36.336    31.646 kbps     00:21:34.543    30.418 kbps     00:21:36.336    129.030 bytes   391.610 bytes   00:21:36.378
8               0:26:43.435     0:04:12.710     23.801 kbps     40.326 kbps     00:30:52.392    34.201 kbps     00:29:37.275    32.384 kbps     00:30:45.176    124.087 bytes   354.805 bytes   00:30:33.706
9               0:30:56.145     0:01:44.687     26.169 kbps     31.176 kbps     00:31:42.150    29.143 kbps     00:31:11.119    28.611 kbps     00:31:07.782    136.431 bytes   381.890 bytes   00:31:07.156
10              0:32:40.833     0:06:15.875     21.926 kbps     38.070 kbps     00:33:59.746    32.407 kbps     00:34:07.795    30.741 kbps     00:34:07.795    114.310 bytes   351.296 bytes   00:38:05.992
11              0:38:56.709     0:02:33.403     22.081 kbps     27.873 kbps     00:39:14.226    25.929 kbps     00:39:49.011    25.596 kbps     00:39:49.011    115.120 bytes   312.252 bytes   00:40:11.075
12              0:41:30.112     0:07:36.747     24.028 kbps     36.334 kbps     00:43:43.120    33.303 kbps     00:43:40.200    32.138 kbps     00:43:35.195    125.270 bytes   381.342 bytes   00:43:39.908
13              0:49:06.860     0:05:16.441     21.614 kbps     35.877 kbps     00:50:21.810    33.085 kbps     00:50:18.682    31.242 kbps     00:50:14.678    112.688 bytes   384.383 bytes   00:49:09.863
14              0:54:23.301     0:05:24.490     25.534 kbps     32.764 kbps     00:58:38.598    31.204 kbps     00:56:15.538    30.859 kbps     00:58:37.680    133.122 bytes   371.400 bytes   00:58:42.602
15              0:59:47.792     0:04:41.364     21.833 kbps     31.642 kbps     01:00:56.194    30.425 kbps     01:00:47.101    30.303 kbps     01:00:43.598    113.826 bytes   376.428 bytes   01:00:48.227
16              1:04:29.156     0:02:29.357     22.217 kbps     31.992 kbps     01:06:20.101    27.904 kbps     01:06:16.222    26.569 kbps     01:06:14.053    115.829 bytes   291.565 bytes   01:06:08.756
17              1:06:58.514     0:02:34.612     27.725 kbps     37.690 kbps     01:07:02.727    32.632 kbps     01:07:19.702    31.391 kbps     01:07:19.702    144.543 bytes   372.857 bytes   01:07:44.268
18              1:09:33.127     0:02:40.326     20.772 kbps     27.477 kbps     01:12:12.453    26.073 kbps     01:12:08.449    23.448 kbps     01:12:03.444    108.294 bytes   310.782 bytes   01:12:13.412
19              1:12:13.454     0:04:04.827     23.148 kbps     33.023 kbps     01:14:40.851    31.549 kbps     01:14:24.001    30.818 kbps     01:14:37.347    120.683 bytes   310.771 bytes   01:14:41.393
20              1:16:18.282     0:01:46.356     22.639 kbps     28.085 kbps     01:17:56.588    26.659 kbps     01:17:56.963    25.668 kbps     01:16:22.202    118.029 bytes   297.598 bytes   01:16:25.247
21              1:18:04.638     0:02:54.841     20.413 kbps     27.510 kbps     01:20:46.049    26.601 kbps     01:20:42.045    25.967 kbps     01:20:38.416    106.424 bytes   272.836 bytes   01:19:04.865
22              1:20:59.479     0:05:38.504     24.451 kbps     33.043 kbps     01:24:28.271    32.554 kbps     01:24:28.813    31.956 kbps     01:24:27.520    127.478 bytes   307.189 bytes   01:24:36.404
23              1:26:37.984     0:02:12.173     23.875 kbps     28.300 kbps     01:27:26.783    27.534 kbps     01:27:21.069    27.498 kbps     01:27:15.063    124.475 bytes   312.865 bytes   01:28:46.696
24              1:28:50.158     0:03:35.882     22.524 kbps     32.139 kbps     01:31:00.580    31.586 kbps     01:30:57.118    30.397 kbps     01:30:52.530    117.428 bytes   359.846 bytes   01:29:10.553
25              1:32:26.040     0:03:01.306     20.861 kbps     30.868 kbps     01:33:58.633    29.685 kbps     01:33:54.629    28.718 kbps     01:33:50.625    108.759 bytes   301.080 bytes   01:33:59.592
26              1:35:27.346     0:02:15.426     19.772 kbps     25.182 kbps     01:37:35.599    22.794 kbps     01:37:03.442    21.826 kbps     01:37:04.693    103.081 bytes   271.917 bytes   01:37:38.143
27              1:37:42.773     0:04:06.704     19.422 kbps     24.480 kbps     01:41:20.491    23.986 kbps     01:41:14.610    23.909 kbps     01:41:14.610    101.259 bytes   256.311 bytes   01:41:15.569
28              1:41:49.478     0:03:11.441     20.137 kbps     30.891 kbps     01:44:23.966    29.920 kbps     01:44:21.797    27.256 kbps     01:44:17.292    104.988 bytes   307.950 bytes   01:44:26.760
29              1:45:00.919     0:01:18.703     18.483 kbps     23.055 kbps     01:45:04.881    21.880 kbps     01:45:39.750    21.124 kbps     01:45:38.457    96.360 bytes    228.531 bytes   01:45:42.544
30              1:46:19.623     0:02:51.963     20.724 kbps     33.293 kbps     01:46:57.452    27.663 kbps     01:47:46.793    26.416 kbps     01:47:41.455    108.047 bytes   344.640 bytes   01:46:57.494
31              1:49:11.586     0:02:59.762     19.977 kbps     24.596 kbps     01:51:33.937    22.938 kbps     01:49:33.984    22.843 kbps     01:49:32.983    104.153 bytes   259.808 bytes   01:49:46.079
32              1:52:11.349     0:03:43.640     6.859 kbps      20.906 kbps     01:52:12.267    20.694 kbps     01:52:12.809    18.486 kbps     01:52:11.349    35.970 bytes    191.609 bytes   01:54:49.507
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0xEA            VC-1                                    6954,865                22.501                  19.561.114.085  106.411.109
00004.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6954,865                640                     556.477.440     3.260.610
00004.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           6954,865                2.048                   1.780.306.570   12.560.976
00004.M2TS      4354 (0x1102)   0x81            AC3             jpn (Japanese)          6954,865                192                     166.943.232     1.086.870
00004.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            6954,865                640                     556.477.440     3.260.610
00004.M2TS      4356 (0x1104)   0x81            AC3             deu (German)            6954,865                640                     556.477.440     3.260.610
00004.M2TS      4357 (0x1105)   0x81            AC3             ita (Italian)           6954,865                640                     556.477.440     3.260.610
00004.M2TS      4358 (0x1106)   0x81            AC3             spa (Spanish)           6954,865                640                     556.477.440     3.260.610
00004.M2TS      4359 (0x1107)   0x81            AC3             spa (Spanish)           6954,865                192                     166.942.464     1.086.865
00004.M2TS      4360 (0x1108)   0x81            AC3             por (Portuguese)        6954,865                192                     166.943.232     1.086.870
00004.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          6954,865                28                      24.333.522      141.815
00004.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6954,865                35                      30.711.546      175.657
00004.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6954,865                27                      23.503.048      136.394
00004.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            6954,865                38                      32.986.214      189.347
00004.M2TS      4612 (0x1204)   0x90            PGS             ita (Italian)           6954,865                31                      27.144.467      156.589
00004.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           6954,865                36                      31.236.103      179.881
00004.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           6954,865                34                      29.782.287      171.199
00004.M2TS      4615 (0x1207)   0x90            PGS             nld (Dutch)             6954,865                28                      24.427.661      139.408
00004.M2TS      4616 (0x1208)   0x90            PGS             spa (Spanish)           6954,865                30                      26.109.075      151.105
00004.M2TS      4617 (0x1209)   0x90            PGS             por (Portuguese)        6954,865                33                      28.973.170      166.224
00004.M2TS      4618 (0x120A)   0x90            PGS             dan (Danish)            6954,865                32                      27.402.845      158.241
00004.M2TS      4619 (0x120B)   0x90            PGS             fin (Finnish)           6954,865                23                      19.600.573      112.629
00004.M2TS      4620 (0x120C)   0x90            PGS             nor (Norwegian)         6954,865                23                      19.943.640      114.247
00004.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        6954,865                29                      25.490.046      147.345
00004.M2TS      4622 (0x120E)   0x90            PGS             swe (Swedish)           6954,865                31                      26.903.569      155.452
00004.M2TS      4623 (0x120F)   0x90            PGS             fra (French)            6954,865                1                       1.019.845       5.842
00004.M2TS      4624 (0x1210)   0x90            PGS             deu (German)            6954,865                1                       1.179.241       6.709
00004.M2TS      4625 (0x1211)   0x90            PGS             ita (Italian)           6954,865                1                       1.185.164       6.758
00004.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           6954,865                1                       1.249.387       7.085
00004.M2TS      4627 (0x1213)   0x90            PGS             spa (Spanish)           6954,865                0                       88.319          512
00004.M2TS      4628 (0x1214)   0x90            PGS             jpn (Japanese)          6954,865                4                       3.650.113       21.465
Burrito is offline
post #1028 of 5106 Old 01-03-2010, 08:37 AM
Burrito's Avatar
Studio: Concorde Home Entertainment
UPC: 4010324037152
Release Date: 2008-04-02
Aspect Ratio: 2.35:1
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:52:53 20.475.482.112  25.019.231.848  24,18   16,79   DTS-HD Master 5.1 2026Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     30 DAYS OF NIGHT
Disc Size:      25.019.231.848 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:52:53 (h:m:s)
Total Bitrate:          24,18 Mbps
VIDEO:
VC-1 Video              16791 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             German          2026 kbps       5.1 / 48 kHz / 2026 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD High-Res Audio           English         2046 kbps       5.1 / 48 kHz / 2046 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS Audio                       English         256 kbps        2.0 / 48 kHz / 256 kbps / 16-bit
SUBTITLES:
Presentation Graphics           German          217,628 kbps
Presentation Graphics           German          332,709 kbps
Presentation Graphics           German          996,097 kbps
FILES:
00000.M2TS      0:00:00.000     1:52:53.433     20.475.451.392  24.183
00020.M2TS      1:52:53.433     0:00:00.542     30.720          453
CHAPTERS:
1               0:00:00.000     0:04:56.963     13.823 kbps     48.060 kbps     00:00:58.516    26.627 kbps     00:01:57.492    25.428 kbps     00:01:37.097    72.300 bytes    709.356 bytes   00:00:58.558
2               0:04:56.963     0:07:42.462     15.879 kbps     35.323 kbps     00:07:13.808    27.605 kbps     00:07:11.556    25.787 kbps     00:05:06.556    82.784 bytes    289.671 bytes   00:06:58.668
3               0:12:39.425     0:08:16.162     18.964 kbps     32.856 kbps     00:19:46.894    28.930 kbps     00:19:44.975    27.278 kbps     00:19:45.017    98.872 bytes    316.677 bytes   00:17:05.983
4               0:20:55.587     0:07:07.260     19.234 kbps     29.370 kbps     00:24:58.997    25.923 kbps     00:23:42.087    23.941 kbps     00:23:40.085    100.278 bytes   289.468 bytes   00:21:22.364
5               0:28:02.847     0:07:40.293     17.516 kbps     26.690 kbps     00:34:46.793    24.901 kbps     00:34:32.695    21.197 kbps     00:30:10.767    91.323 bytes    252.898 bytes   00:33:03.481
6               0:35:43.141     0:07:26.988     18.606 kbps     31.600 kbps     00:39:12.433    27.615 kbps     00:39:42.421    26.126 kbps     00:39:08.095    97.039 bytes    311.011 bytes   00:41:51.091
7               0:43:10.129     0:07:06.217     16.692 kbps     29.826 kbps     00:49:35.180    24.056 kbps     00:46:44.551    23.266 kbps     00:46:40.422    87.024 bytes    303.241 bytes   00:49:35.389
8               0:50:16.346     0:11:19.845     16.915 kbps     38.122 kbps     01:01:14.587    28.188 kbps     01:01:11.417    26.048 kbps     01:01:06.371    88.186 bytes    262.780 bytes   01:01:15.463
9               1:01:36.192     0:07:17.103     17.953 kbps     33.686 kbps     01:04:35.913    27.323 kbps     01:04:32.243    25.934 kbps     01:04:30.908    93.598 bytes    290.996 bytes   01:04:36.289
10              1:08:53.295     0:06:15.208     16.740 kbps     25.952 kbps     01:14:17.327    21.374 kbps     01:11:36.458    20.425 kbps     01:12:33.432    87.275 bytes    246.617 bytes   01:14:50.986
11              1:15:08.504     0:08:01.981     18.359 kbps     37.744 kbps     01:16:36.300    27.098 kbps     01:17:32.731    24.707 kbps     01:17:51.625    95.715 bytes    294.826 bytes   01:16:36.925
12              1:23:10.485     0:07:02.255     16.297 kbps     24.219 kbps     01:26:24.721    21.997 kbps     01:26:09.664    21.396 kbps     01:26:05.702    84.967 bytes    234.226 bytes   01:26:12.709
13              1:30:12.740     0:08:53.699     17.387 kbps     35.950 kbps     01:37:12.493    27.389 kbps     01:37:03.067    24.437 kbps     01:32:15.780    90.648 bytes    325.733 bytes   01:37:07.947
14              1:39:06.440     0:07:40.293     18.890 kbps     30.878 kbps     01:41:36.590    26.988 kbps     01:41:35.839    24.592 kbps     01:41:35.839    98.876 bytes    293.380 bytes   01:41:39.802
15              1:46:46.733     0:06:07.241     5.002 kbps      20.458 kbps     01:48:27.751    16.438 kbps     01:48:25.332    14.873 kbps     01:48:25.582    26.164 bytes    242.896 bytes   01:48:40.472
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    6773,308                16.792                  14.217.287.173  77.365.877
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       deu (German)            6773,308                2.026                   1.715.097.508   10.387.245
00000.M2TS      4353 (0x1101)   0x85            DTS-HD HR       eng (English)           6773,308                2.046                   1.732.304.552   10.160.144
00000.M2TS      4354 (0x1102)   0x82            DTS             eng (English)           6773,308                255                     215.903.060     1.270.018
00000.M2TS      4608 (0x1200)   0x90            PGS             deu (German)            6773,308                218                     184.275.650     1.021.231
00000.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            6773,308                333                     281.720.563     1.558.841
00000.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            6773,308                996                     843.441.827     4.652.680
00020.M2TS      4113 (0x1011)   0xEA            VC-1                                    0,417                   357                     18.636          111
Burrito is offline
post #1029 of 5106 Old 01-03-2010, 10:24 AM
Burrito's Avatar
Studio: Warner
UPC: 7321983161032
Release Date: 2007-08-24
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:56:38 26.486.624.256  35.511.350.980  30,28   16,58   LPCM 5.1 4608Kbps (48kHz/16-bit)          Dolby TrueHD 5.1 1735Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     300____
Disc Size:      35.511.350.980 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:56:38 (h:m:s)
Total Bitrate:          30,28 Mbps
VIDEO:
VC-1 Video              16584 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         1735 kbps       5.1 / 48 kHz / 1735 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
SUBTITLES:
Presentation Graphics           English         21,603 kbps
Presentation Graphics           English         23,714 kbps
Presentation Graphics           Danish          20,348 kbps
Presentation Graphics           Dutch           20,615 kbps
Presentation Graphics           Finnish         21,109 kbps
Presentation Graphics           French          20,355 kbps
Presentation Graphics           German          25,425 kbps
Presentation Graphics           German          27,389 kbps
Presentation Graphics           Italian         22,538 kbps
Presentation Graphics           Italian         24,600 kbps
Presentation Graphics           Norwegian       20,029 kbps
Presentation Graphics           Portuguese      22,651 kbps
Presentation Graphics           Spanish         23,147 kbps
Presentation Graphics           Swedish         20,468 kbps
FILES:
00000.M2TS      0:00:00.000     1:56:38.783     26.486.624.256  30.276
CHAPTERS:
1               0:00:00.000     0:05:16.983     17.056 kbps     30.167 kbps     00:02:41.369    21.522 kbps     00:00:13.805    20.178 kbps     00:01:40.683    89.499 bytes    442.832 bytes   00:00:05.880
2               0:05:16.983     0:05:06.306     17.504 kbps     29.224 kbps     00:09:46.043    21.161 kbps     00:08:49.195    20.123 kbps     00:10:11.152    91.308 bytes    496.594 bytes   00:10:11.193
3               0:10:23.289     0:02:53.506     17.934 kbps     27.786 kbps     00:10:48.272    20.732 kbps     00:13:08.746    19.956 kbps     00:10:40.056    93.520 bytes    424.354 bytes   00:11:19.261
4               0:13:16.796     0:03:35.381     16.591 kbps     28.816 kbps     00:14:10.140    21.664 kbps     00:14:09.598    20.257 kbps     00:16:22.940    86.617 bytes    354.257 bytes   00:16:03.712
5               0:16:52.177     0:02:52.172     17.240 kbps     30.271 kbps     00:18:02.623    21.399 kbps     00:19:12.651    20.077 kbps     00:18:42.955    89.881 bytes    318.701 bytes   00:18:02.748
6               0:19:44.349     0:02:43.997     15.851 kbps     27.818 kbps     00:22:13.415    21.598 kbps     00:22:21.048    19.152 kbps     00:19:56.486    84.333 bytes    251.823 bytes   00:20:47.913
7               0:22:28.347     0:04:35.275     17.040 kbps     31.280 kbps     00:24:28.508    21.058 kbps     00:24:28.466    20.055 kbps     00:23:35.372    88.944 bytes    413.912 bytes   00:25:19.935
8               0:27:03.622     0:02:12.632     17.597 kbps     30.080 kbps     00:27:14.507    21.120 kbps     00:27:12.255    19.939 kbps     00:28:38.675    91.741 bytes    361.034 bytes   00:27:14.633
9               0:29:16.254     0:04:01.574     15.262 kbps     30.034 kbps     00:32:06.633    21.550 kbps     00:29:44.741    19.857 kbps     00:29:21.342    79.568 bytes    396.768 bytes   00:32:06.674
10              0:33:17.829     0:01:48.942     15.813 kbps     31.098 kbps     00:34:41.704    21.015 kbps     00:34:51.130    19.568 kbps     00:34:46.709    82.443 bytes    306.097 bytes   00:33:30.008
11              0:35:06.771     0:02:42.662     16.918 kbps     28.996 kbps     00:36:52.919    21.065 kbps     00:35:35.758    19.693 kbps     00:35:33.464    88.204 bytes    340.302 bytes   00:36:08.583
12              0:37:49.433     0:02:56.843     17.473 kbps     29.666 kbps     00:38:49.076    21.073 kbps     00:39:56.560    20.276 kbps     00:38:40.109    91.094 bytes    451.640 bytes   00:37:54.605
13              0:40:46.277     0:03:24.037     16.227 kbps     29.592 kbps     00:43:59.219    21.356 kbps     00:41:06.922    19.842 kbps     00:42:04.396    84.602 bytes    419.267 bytes   00:40:53.200
14              0:44:10.314     0:05:06.973     17.491 kbps     29.157 kbps     00:47:30.097    21.095 kbps     00:47:55.998    20.187 kbps     00:44:39.385    91.190 bytes    440.723 bytes   00:45:13.877
15              0:49:17.287     0:03:29.042     17.027 kbps     29.046 kbps     00:52:11.086    21.358 kbps     00:49:36.890    20.106 kbps     00:50:13.802    88.773 bytes    452.317 bytes   00:51:03.060
16              0:52:46.329     0:02:47.333     17.413 kbps     28.141 kbps     00:53:08.977    21.170 kbps     00:54:08.328    19.857 kbps     00:55:10.974    90.783 bytes    304.528 bytes   00:53:16.026
17              0:55:33.663     0:06:07.200     17.906 kbps     28.154 kbps     00:55:41.504    21.535 kbps     00:56:22.545    20.209 kbps     00:56:53.701    93.351 bytes    458.074 bytes   00:57:22.939
18              1:01:40.863     0:03:39.886     17.198 kbps     29.274 kbps     01:03:33.559    21.439 kbps     01:02:22.572    20.256 kbps     01:02:35.001    89.660 bytes    260.058 bytes   01:03:34.060
19              1:05:20.750     0:03:22.202     17.230 kbps     27.025 kbps     01:07:15.531    21.217 kbps     01:05:22.668    20.272 kbps     01:08:25.976    89.829 bytes    260.385 bytes   01:06:17.306
20              1:08:42.952     0:04:00.239     16.447 kbps     31.435 kbps     01:12:05.237    21.055 kbps     01:10:10.164    19.759 kbps     01:09:38.299    85.747 bytes    420.101 bytes   01:11:54.977
21              1:12:43.192     0:03:07.186     17.539 kbps     25.926 kbps     01:13:36.120    20.987 kbps     01:12:52.701    20.052 kbps     01:12:52.659    91.440 bytes    459.474 bytes   01:13:22.815
22              1:15:50.379     0:02:48.001     16.542 kbps     26.248 kbps     01:17:06.079    21.018 kbps     01:16:53.734    19.372 kbps     01:18:21.446    86.244 bytes    309.875 bytes   01:18:08.100
23              1:18:38.380     0:03:42.555     16.889 kbps     27.939 kbps     01:20:51.263    21.177 kbps     01:22:03.209    20.069 kbps     01:21:59.664    88.050 bytes    297.566 bytes   01:20:51.429
24              1:22:20.936     0:04:22.595     17.817 kbps     28.267 kbps     01:26:34.939    21.094 kbps     01:25:05.975    19.943 kbps     01:25:03.723    92.888 bytes    283.634 bytes   01:26:11.166
25              1:26:43.531     0:02:27.981     16.324 kbps     25.610 kbps     01:27:25.448    20.699 kbps     01:28:27.635    19.732 kbps     01:27:58.856    85.104 bytes    400.033 bytes   01:27:25.490
26              1:29:11.512     0:04:47.704     16.479 kbps     30.803 kbps     01:33:31.606    21.275 kbps     01:33:34.525    19.943 kbps     01:33:08.249    85.915 bytes    389.623 bytes   01:30:36.681
27              1:33:59.216     0:04:55.378     17.499 kbps     30.532 kbps     01:38:45.794    21.065 kbps     01:34:35.670    20.246 kbps     01:35:48.284    91.232 bytes    535.803 bytes   01:34:09.060
28              1:38:54.595     0:04:31.604     17.055 kbps     31.338 kbps     01:43:18.650    21.255 kbps     01:42:38.986    20.233 kbps     01:42:38.694    89.042 bytes    391.318 bytes   01:38:57.765
29              1:43:26.200     0:05:37.337     17.484 kbps     29.446 kbps     01:44:59.418    21.149 kbps     01:44:19.711    20.224 kbps     01:47:51.756    91.663 bytes    347.865 bytes   01:45:44.296
30              1:49:03.537     0:07:35.246     9.818 kbps      27.250 kbps     01:49:41.366    20.514 kbps     01:49:31.356    17.360 kbps     01:49:40.156    51.452 bytes    401.033 bytes   01:56:35.989
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    6998,658                16.584                  14.508.369.095  78.950.547
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6998,658                2.375                   2.077.635.800   16.128.095
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6998,658                192                     167.970.816     1.093.560
00000.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6998,658                640                     559.902.720     3.280.680
00000.M2TS      4355 (0x1103)   0x81            AC3             deu (German)            6998,658                640                     559.902.720     3.280.680
00000.M2TS      4356 (0x1104)   0x81            AC3             ita (Italian)           6998,658                640                     559.902.720     3.280.680
00000.M2TS      4357 (0x1105)   0x81            AC3             spa (Spanish)           6998,658                640                     559.902.720     3.280.680
00000.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           6998,658                192                     167.970.816     1.093.560
00000.M2TS      4359 (0x1107)   0x80            LPCM            eng (English)           6998,658                4.614                   4.036.899.188   22.396.112
00000.M2TS      4360 (0x1108)   0x81            AC3             eng (English)           6998,658                640                     559.902.720     3.280.680
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6998,658                22                      18.899.777      108.897
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6998,658                24                      20.746.418      119.600
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6998,658                20                      17.807.522      103.624
00000.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            6998,658                25                      22.243.292      127.145
00000.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            6998,658                27                      23.961.555      137.209
00000.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           6998,658                23                      19.717.615      113.326
00000.M2TS      4614 (0x1206)   0x90            PGS             ita (Italian)           6998,658                25                      21.521.413      123.811
00000.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           6998,658                23                      20.250.451      116.403
00000.M2TS      4616 (0x1208)   0x90            PGS             nld (Dutch)             6998,658                21                      18.035.319      103.855
00000.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            6998,658                20                      17.801.211      101.548
00000.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           6998,658                21                      18.467.260      105.163
00000.M2TS      4619 (0x120B)   0x90            PGS             por (Portuguese)        6998,658                23                      19.816.086      113.892
00000.M2TS      4620 (0x120C)   0x90            PGS             nor (Norwegian)         6998,658                20                      17.522.728      100.007
00000.M2TS      4621 (0x120D)   0x90            PGS             swe (Swedish)           6998,658                20                      17.906.615      102.462
Burrito is offline
post #1030 of 5106 Old 01-03-2010, 03:42 PM
Burrito's Avatar
Regions: No region code (Source: DVD Profiler database)
Studio: MagicPlay Entertainment Corp.
UPC: 4042564030129
Release Date: 2008-03-07
Aspect Ratio: 1.78:1
Code:
        Total   Video
00003.MPLS                                                      MPEG-2  0:39:09 13.423.233.024  14.390.439.044  45,71   40,00   DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     BDROM
Disc Size:      14.390.439.044 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 0:39:09 (h:m:s)
Total Bitrate:          45,71 Mbps
VIDEO:
MPEG-2 Video            40000 kbps          1080p / 24 fps / 16:9
AUDIO:
Dolby Digital Audio             Chinese         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             Czech           448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             Hungarian       448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             Korean          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         19,179 kbps
Presentation Graphics           Chinese         16,488 kbps
FILES:
00003.M2TS      0:00:00.000     0:39:09.375     13.423.233.024  45.708
CHAPTERS:
1               0:00:00.000     0:11:14.000     40.001 kbps     43.856 kbps     00:01:54.124    40.771 kbps     00:02:05.666    40.428 kbps     00:01:45.124    208.328 bytes   516.483 bytes   00:01:54.916
2               0:11:14.000     0:05:32.958     40.003 kbps     43.095 kbps     00:11:41.708    40.653 kbps     00:12:40.083    40.328 kbps     00:11:14.875    208.351 bytes   557.370 bytes   00:11:52.791
3               0:16:46.958     0:05:33.666     40.000 kbps     43.325 kbps     00:19:53.875    40.562 kbps     00:19:15.500    40.301 kbps     00:19:45.000    208.331 bytes   490.562 bytes   00:19:56.166
4               0:22:20.625     0:05:11.375     40.000 kbps     42.819 kbps     00:24:47.583    40.585 kbps     00:23:17.875    40.315 kbps     00:23:08.500    208.332 bytes   490.588 bytes   00:24:36.375
5               0:27:32.000     0:06:48.458     39.999 kbps     43.068 kbps     00:30:49.083    40.625 kbps     00:29:08.875    40.309 kbps     00:30:26.208    208.328 bytes   493.783 bytes   00:31:19.833
6               0:34:20.458     0:04:05.166     40.001 kbps     42.267 kbps     00:37:46.750    40.433 kbps     00:34:48.000    40.248 kbps     00:34:46.208    208.340 bytes   438.408 bytes   00:36:12.541
7               0:38:25.625     0:00:43.750     39.958 kbps     42.500 kbps     00:38:50.750    40.531 kbps     00:38:52.625    40.244 kbps     00:38:44.000    208.312 bytes   412.846 bytes   00:38:51.041
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x02            MPEG-2                                  2349,250                40.002                  11.746.872.228  63.874.768
00003.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           2349,250                448                     131.568.640     734.200
00003.M2TS      4353 (0x1101)   0x81            AC3             deu (German)            2349,250                448                     131.568.640     734.200
00003.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            2349,250                448                     131.568.640     734.200
00003.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           2349,250                448                     131.568.640     734.200
00003.M2TS      4356 (0x1104)   0x81            AC3             zho (Chinese)           2349,250                448                     131.568.640     734.200
00003.M2TS      4357 (0x1105)   0x81            AC3             hun (Hungarian)         2349,250                448                     131.568.640     734.200
00003.M2TS      4358 (0x1106)   0x81            AC3             kor (Korean)            2349,250                448                     131.568.640     734.200
00003.M2TS      4359 (0x1107)   0x81            AC3             ces (Czech)             2349,250                448                     131.568.640     734.200
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2349,250                19                      5.632.235       32.481
00003.M2TS      4609 (0x1201)   0x90            PGS             zho (Chinese)           2349,250                16                      4.842.080       28.082
Burrito is offline
post #1031 of 5106 Old 01-03-2010, 03:53 PM
Charlie & Boots - 2009 - Australian version
Region Free, confirmed with AnyDVD HD.
This is a recent Australian movie, details on IMDB here. Despite this, all the content is in 1080p24 format, including a segment for the Australian TV version of '60 Minutes', which must have originated at 50 hertz. Anyway, the lack of 50 hertz content means that the disc should work anywhere. The large disc size and relatively low bitrate is due to the extensive extras, including a 1080p24 'Making Of' featurette that's longer than the movie itself, and appears to have been converted -- somewhat poorly -- from 1080i material. The two DD2.0 audio tracks are English Audio Descriptive and Commentary.
Code:
        Total   Video
00000.MPLS                                                      AVC     1:41:20 18,391,633,920  43,587,749,836  24.20   18.00   Dolby TrueHD 5.1 3215Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     CHARLIE_AND_BOOTS
Disc Size:      43,587,749,836 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:41:20 (h:m:s)
Total Bitrate:          24.20 Mbps
VIDEO:
MPEG-4 AVC Video        17999 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3215 kbps       5.1 / 48 kHz / 3215 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps / DN -4dB)
SUBTITLES:
Presentation Graphics           English         33.488 kbps
FILES:
00000.M2TS      0:00:00.000     1:41:20.157     18,391,633,920  24,199
CHAPTERS:
1               0:00:00.000     0:05:07.432     17,044 kbps     28,408 kbps     00:02:47.083    26,796 kbps     00:02:04.582    25,326 kbps     00:01:59.577    88,850 bytes    308,383 bytes   00:03:58.446
2               0:05:07.432     0:05:21.696     18,826 kbps     30,424 kbps     00:05:59.359    26,059 kbps     00:05:57.565    24,639 kbps     00:05:57.565    98,148 bytes    305,751 bytes   00:09:59.473
3               0:10:29.128     0:05:37.211     20,116 kbps     33,854 kbps     00:14:27.116    29,176 kbps     00:14:26.198    25,413 kbps     00:12:49.226    104,874 bytes   304,582 bytes   00:14:33.455
4               0:16:06.340     0:03:55.401     21,090 kbps     28,105 kbps     00:16:53.929    26,409 kbps     00:16:56.056    25,948 kbps     00:16:50.968    109,951 bytes   348,293 bytes   00:17:55.908
5               0:20:01.742     0:05:24.365     17,702 kbps     37,612 kbps     00:20:40.822    31,230 kbps     00:20:38.195    27,007 kbps     00:20:36.485    92,291 bytes    355,490 bytes   00:20:48.080
6               0:25:26.107     0:06:12.288     18,472 kbps     36,028 kbps     00:27:27.854    28,228 kbps     00:27:32.275    26,879 kbps     00:27:31.983    96,304 bytes    324,548 bytes   00:27:27.937
7               0:31:38.396     0:04:39.779     20,034 kbps     28,691 kbps     00:33:20.081    26,000 kbps     00:33:16.744    24,793 kbps     00:36:04.579    104,448 bytes   258,085 bytes   00:33:04.607
8               0:36:18.176     0:04:22.220     17,245 kbps     28,949 kbps     00:38:18.379    26,407 kbps     00:40:31.429    23,408 kbps     00:38:13.374    89,907 bytes    272,321 bytes   00:40:31.762
9               0:40:40.396     0:07:21.315     16,963 kbps     30,761 kbps     00:43:35.612    25,202 kbps     00:45:17.464    23,691 kbps     00:45:12.334    88,435 bytes    288,635 bytes   00:42:02.353
10              0:48:01.712     0:05:20.153     16,868 kbps     31,323 kbps     00:50:37.826    23,765 kbps     00:48:26.903    22,120 kbps     00:53:11.104    87,945 bytes    262,147 bytes   00:49:31.551
11              0:53:21.865     0:04:23.137     17,495 kbps     31,807 kbps     00:56:56.329    26,880 kbps     00:56:53.326    23,368 kbps     00:56:53.326    91,211 bytes    317,757 bytes   00:53:39.341
12              0:57:45.003     0:04:32.605     17,823 kbps     30,698 kbps     00:59:24.644    26,689 kbps     00:59:22.642    24,094 kbps     00:59:21.975    92,920 bytes    317,563 bytes   00:59:17.887
13              1:02:17.608     0:05:45.470     15,639 kbps     31,975 kbps     01:05:41.437    29,636 kbps     01:05:37.475    23,818 kbps     01:05:37.016    81,532 bytes    305,363 bytes   01:02:52.477
14              1:08:03.079     0:03:37.050     19,031 kbps     32,391 kbps     01:09:55.524    25,114 kbps     01:09:55.441    24,730 kbps     01:09:55.107    99,218 bytes    369,775 bytes   01:08:06.999
15              1:11:40.129     0:06:06.115     21,848 kbps     35,869 kbps     01:12:10.284    29,012 kbps     01:11:41.797    26,786 kbps     01:12:06.447    113,907 bytes   315,534 bytes   01:12:32.181
16              1:17:46.244     0:06:55.039     19,181 kbps     31,780 kbps     01:20:55.767    28,856 kbps     01:21:45.650    25,628 kbps     01:20:46.842    99,998 bytes    362,540 bytes   01:22:34.950
17              1:24:41.284     0:03:49.854     16,927 kbps     26,306 kbps     01:26:36.399    23,273 kbps     01:26:32.520    21,067 kbps     01:27:11.601    88,250 bytes    282,651 bytes   01:25:29.457
18              1:28:31.139     0:05:00.133     21,171 kbps     35,597 kbps     01:30:15.076    34,147 kbps     01:30:14.325    28,999 kbps     01:30:13.825    110,376 bytes   359,758 bytes   01:32:15.446
19              1:33:31.272     0:03:00.346     16,235 kbps     26,738 kbps     01:34:10.227    26,100 kbps     01:34:15.066    25,771 kbps     01:34:09.977    84,644 bytes    277,770 bytes   01:35:21.966
20              1:36:31.619     0:04:48.538     9,125 kbps      18,829 kbps     01:40:34.278    17,334 kbps     01:40:33.110    15,123 kbps     01:40:29.982    47,579 bytes    224,017 bytes   01:40:38.032
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6080.032                17,999                  13,679,646,700  74,431,116
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6080.032                3,664                   2,784,285,338   19,107,370
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6080.032                192                     145,923,840     950,025
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6080.032                192                     145,923,840     950,025
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6080.032                33                      25,451,553      147,516
Stephen Dawson
hifi-writer.com
post #1032 of 5106 Old 01-03-2010, 04:12 PM
Burrito's Avatar
Studio: Constantin Film AG
UPC: 4011976311683
Release Date: 2008-09-04
Code:
        Total   Video
00002.MPLS                                                      AVC     1:35:36 16.416.276.480  22.724.879.440  22,90   17,17   DTS-HD Hi-Res 5.1 2046Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     AMERICAN_PIE
Disc Size:      22.724.879.440 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:35:36 (h:m:s)
Total Bitrate:          22,90 Mbps
VIDEO:
MPEG-4 AVC Video        17175 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD High-Res Audio           German          2046 kbps       5.1 / 48 kHz / 2046 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           German          48,865 kbps
FILES:
00040.M2TS      0:00:00.000     1:35:36.041     16.416.276.480  22.896
CHAPTERS:
1               0:00:00.000     0:06:33.041     18.011 kbps     36.505 kbps     00:01:54.749    30.271 kbps     00:01:53.708    27.203 kbps     00:00:16.374    93.796 bytes    544.425 bytes   00:01:57.083
2               0:06:33.041     0:05:33.916     14.487 kbps     32.933 kbps     00:07:18.666    28.167 kbps     00:07:14.666    25.839 kbps     00:07:11.291    75.452 bytes    357.347 bytes   00:08:45.083
3               0:12:06.958     0:06:16.416     16.942 kbps     31.490 kbps     00:15:34.333    28.734 kbps     00:15:34.333    27.660 kbps     00:15:34.333    88.240 bytes    553.628 bytes   00:15:34.458
4               0:18:23.375     0:08:28.791     20.228 kbps     35.480 kbps     00:18:30.833    30.989 kbps     00:18:26.875    27.458 kbps     00:18:23.375    105.352 bytes   513.375 bytes   00:18:30.875
5               0:26:52.166     0:04:51.833     17.303 kbps     34.478 kbps     00:31:01.249    24.249 kbps     00:31:01.125    22.849 kbps     00:30:57.583    90.120 bytes    479.155 bytes   00:28:04.916
6               0:31:44.000     0:06:34.333     22.484 kbps     37.812 kbps     00:33:33.166    34.069 kbps     00:33:34.666    30.862 kbps     00:33:30.749    117.102 bytes   532.889 bytes   00:35:45.541
7               0:38:18.333     0:05:42.833     18.716 kbps     32.614 kbps     00:40:56.666    28.993 kbps     00:43:12.875    25.820 kbps     00:39:09.583    97.481 bytes    523.349 bytes   00:44:01.166
8               0:44:01.166     0:09:25.666     20.300 kbps     40.250 kbps     00:47:12.208    31.954 kbps     00:44:21.458    30.230 kbps     00:47:11.666    105.731 bytes   584.477 bytes   00:47:20.000
9               0:53:26.833     0:06:53.791     15.831 kbps     29.708 kbps     00:53:34.416    22.660 kbps     00:58:13.083    21.483 kbps     00:58:09.708    82.455 bytes    411.970 bytes   00:59:38.750
10              1:00:20.625     0:07:29.875     19.374 kbps     36.933 kbps     01:04:05.291    32.927 kbps     01:04:01.333    31.822 kbps     01:04:03.500    100.906 bytes   477.003 bytes   01:06:26.291
11              1:07:50.500     0:03:20.458     17.322 kbps     29.635 kbps     01:07:53.250    23.682 kbps     01:07:51.166    21.941 kbps     01:09:29.541    90.217 bytes    516.496 bytes   01:09:35.375
12              1:11:10.958     0:05:44.708     13.839 kbps     32.881 kbps     01:12:15.125    25.955 kbps     01:12:12.250    23.678 kbps     01:12:07.166    72.076 bytes    432.863 bytes   01:15:14.666
13              1:16:55.666     0:10:25.583     10.841 kbps     31.250 kbps     01:22:11.000    26.078 kbps     01:27:05.208    25.377 kbps     01:27:06.500    56.461 bytes    398.640 bytes   01:22:10.500
14              1:27:21.250     0:02:30.166     15.780 kbps     33.016 kbps     01:29:21.166    29.294 kbps     01:29:17.916    27.967 kbps     01:29:13.416    82.187 bytes    483.480 bytes   01:29:22.166
15              1:29:51.416     0:05:44.625     15.826 kbps     26.155 kbps     01:29:51.916    23.288 kbps     01:34:21.750    23.011 kbps     01:34:18.250    82.439 bytes    455.883 bytes   01:31:13.083
STREAM DIAGNOSTICS:
00040.M2TS      4113 (0x1011)   0x1B            AVC                                     5735,875                17.175                  12.314.444.612  67.006.893
00040.M2TS      4352 (0x1100)   0x85            DTS-HD HR       deu (German)            5735,875                2.046                   1.466.987.456   8.604.032
00040.M2TS      4353 (0x1101)   0x85            DTS-HD HR       eng (English)           5735,875                2.046                   1.466.987.456   8.604.032
00040.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5735,875                224                     160.608.896     896.255
00040.M2TS      4608 (0x1200)   0x90            PGS             deu (German)            5735,875                49                      35.036.163      198.025
Burrito is offline
post #1033 of 5106 Old 01-03-2010, 04:34 PM
Burrito's Avatar
Region: B (Source: DVD Profiler database)
Studio: E-M-S
UPC: 4020974168434
Release Date: 2009-02-26
Aspect Ratio: 1.85:1
Code:
        Total   Video
00004.MPLS                                                      AVC     1:35:42 16.255.303.680  21.779.818.614  22,65   19,00   DTS-HD Master 5.1 1930Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     CHINESEGHOSTSTORY1
Disc Size:      21.779.818.614 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:35:42 (h:m:s)
Total Bitrate:          22,65 Mbps
VIDEO:
MPEG-4 AVC Video        18996 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             German          1930 kbps       5.1 / 48 kHz / 1930 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           German          15,771 kbps
FILES:
00005.M2TS      0:00:00.000     1:35:41.625     16.255.285.248  22.649
00000.M2TS      1:35:41.625     0:00:01.000     18.432          147
CHAPTERS:
1               0:00:00.000     0:06:21.833     19.485 kbps     28.155 kbps     00:02:59.916    26.286 kbps     00:02:57.666    24.968 kbps     00:02:56.416    101.471 bytes   375.423 bytes   00:00:47.333
2               0:06:21.833     0:03:47.499     18.846 kbps     28.487 kbps     00:10:07.916    25.455 kbps     00:09:58.083    24.026 kbps     00:09:55.750    98.158 bytes    274.314 bytes   00:10:09.333
3               0:10:09.333     0:05:51.625     17.129 kbps     27.886 kbps     00:10:14.166    22.583 kbps     00:11:26.625    21.796 kbps     00:11:26.541    89.215 bytes    313.879 bytes   00:11:26.666
4               0:16:00.958     0:02:58.000     17.335 kbps     34.254 kbps     00:18:56.750    31.385 kbps     00:18:53.875    27.389 kbps     00:18:48.916    90.288 bytes    251.025 bytes   00:16:53.375
5               0:18:58.958     0:04:39.125     17.783 kbps     27.896 kbps     00:20:16.375    22.877 kbps     00:20:13.416    21.641 kbps     00:20:08.916    92.617 bytes    284.289 bytes   00:19:43.958
6               0:23:38.083     0:05:47.750     17.293 kbps     30.266 kbps     00:28:15.583    24.241 kbps     00:28:14.083    22.262 kbps     00:28:12.041    90.070 bytes    284.839 bytes   00:28:18.250
7               0:29:25.833     0:05:20.500     18.303 kbps     26.176 kbps     00:34:23.041    22.016 kbps     00:34:23.041    21.219 kbps     00:34:16.208    95.326 bytes    292.688 bytes   00:30:17.875
8               0:34:46.333     0:03:51.583     19.726 kbps     34.728 kbps     00:36:46.041    26.255 kbps     00:36:44.583    25.425 kbps     00:36:25.458    102.738 bytes   291.502 bytes   00:38:29.250
9               0:38:37.916     0:08:49.500     17.653 kbps     25.592 kbps     00:45:00.833    21.996 kbps     00:39:52.166    21.290 kbps     00:39:52.500    91.944 bytes    284.570 bytes   00:39:29.875
10              0:47:27.416     0:05:57.541     20.321 kbps     31.399 kbps     00:53:14.416    26.353 kbps     00:53:11.833    24.019 kbps     00:48:47.250    105.836 bytes   340.609 bytes   00:51:58.125
11              0:53:24.958     0:02:54.458     19.301 kbps     31.296 kbps     00:55:38.750    24.578 kbps     00:55:31.041    24.170 kbps     00:55:31.666    100.525 bytes   256.781 bytes   00:55:39.333
12              0:56:19.416     0:04:54.416     18.182 kbps     28.322 kbps     01:00:03.541    25.727 kbps     01:00:05.875    23.923 kbps     01:00:02.708    94.698 bytes    285.782 bytes   00:59:09.333
13              1:01:13.833     0:02:46.250     19.599 kbps     29.278 kbps     01:02:55.666    25.451 kbps     01:02:51.958    24.531 kbps     01:02:46.916    102.078 bytes   286.906 bytes   01:03:59.083
14              1:04:00.083     0:04:36.458     17.279 kbps     25.156 kbps     01:04:12.625    21.406 kbps     01:06:37.125    19.787 kbps     01:05:04.916    89.995 bytes    286.014 bytes   01:04:01.083
15              1:08:36.541     0:08:47.500     19.679 kbps     30.760 kbps     01:13:36.500    25.801 kbps     01:11:50.583    24.148 kbps     01:11:46.291    102.497 bytes   294.398 bytes   01:11:47.708
16              1:17:24.041     0:04:52.541     19.592 kbps     28.689 kbps     01:18:26.041    25.816 kbps     01:19:01.916    24.510 kbps     01:18:58.916    102.042 bytes   255.157 bytes   01:17:27.791
17              1:22:16.583     0:03:42.125     20.401 kbps     30.029 kbps     01:25:29.125    26.507 kbps     01:25:26.916    24.538 kbps     01:25:25.708    106.257 bytes   333.389 bytes   01:23:33.625
18              1:25:58.708     0:05:37.541     23.345 kbps     33.814 kbps     01:30:00.416    29.698 kbps     01:26:51.250    28.082 kbps     01:26:51.958    121.590 bytes   299.699 bytes   01:30:49.541
19              1:31:36.250     0:02:39.375     18.198 kbps     29.500 kbps     01:32:08.375    25.732 kbps     01:33:38.166    22.207 kbps     01:31:59.416    94.779 bytes    282.323 bytes   01:33:28.250
20              1:34:15.625     0:01:27.000     23.519 kbps     33.921 kbps     01:35:16.708    28.135 kbps     01:35:13.916    27.338 kbps     01:35:16.708    122.556 bytes   293.888 bytes   01:35:29.208
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     5741,542                18.999                  13.635.794.141  74.188.446
00005.M2TS      4352 (0x1100)   0x86            DTS-HD MA       deu (German)            5741,542                1.930                   1.385.159.972   8.413.199
00005.M2TS      4353 (0x1101)   0x81            AC3             zho (Chinese)           5741,542                450                     322.785.792     1.801.260
00005.M2TS      4608 (0x1200)   0x90            PGS             deu (German)            5741,542                16                      11.320.661      66.899
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     0,875                   88                      9.613           60
Burrito is offline
post #1034 of 5106 Old 01-03-2010, 04:39 PM
Hi Burrito. Doing a great job there! Just wondering if you have the DE version of 'The Departed' to hand, and if you could post a scan of that one. It appears that at some point the disc in the Australian version has swapped from the US version (with English LPCM5.1 and English, Spanish and French DD5.1), to the German version (with English and German DD5.1 only).
Stephen Dawson
hifi-writer.com
post #1035 of 5106 Old 01-03-2010, 04:59 PM
Burrito's Avatar
Studio: E-M-S
UPC: 4020974168441
Code:
        Total   Video
00004.MPLS                                                      AVC     1:42:58 17.608.058.880  21.352.695.678  22,80   19,00   DTS-HD Master 5.1 2067Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     CHINESE_GHOST_STORY_2
Disc Size:      21.352.695.678 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:42:58 (h:m:s)
Total Bitrate:          22,80 Mbps
VIDEO:
AUDIO:
DTS-HD Master Audio             German          2067 kbps       5.1 / 48 kHz / 2067 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           German          20,273 kbps
FILES:
00004.M2TS      0:00:00.000     1:42:57.083     17.608.040.448  22.804
00000.M2TS      1:42:57.083     0:00:01.000     18.432          147
CHAPTERS:
1               0:00:00.000     0:04:20.333     19.265 kbps     33.915 kbps     00:02:20.291    29.276 kbps     00:00:40.125    28.182 kbps     00:02:18.708    100.324 bytes   351.124 bytes   00:02:21.291
2               0:04:20.333     0:03:45.666     18.273 kbps     28.055 kbps     00:04:55.249    23.823 kbps     00:04:51.500    21.569 kbps     00:04:48.249    95.172 bytes    291.591 bytes   00:04:42.541
3               0:08:06.000     0:05:08.083     18.246 kbps     37.124 kbps     00:13:04.916    27.773 kbps     00:13:04.458    25.797 kbps     00:13:00.666    95.033 bytes    319.657 bytes   00:12:16.958
4               0:13:14.083     0:05:14.166     17.695 kbps     30.033 kbps     00:13:35.708    25.039 kbps     00:13:56.541    23.068 kbps     00:13:53.000    92.162 bytes    336.180 bytes   00:13:47.791
5               0:18:28.250     0:05:17.708     19.743 kbps     32.301 kbps     00:18:58.041    28.002 kbps     00:20:10.708    26.331 kbps     00:20:10.833    102.828 bytes   316.499 bytes   00:20:02.500
6               0:23:45.958     0:04:15.208     19.404 kbps     28.807 kbps     00:26:53.708    23.429 kbps     00:27:51.208    22.707 kbps     00:27:48.499    101.060 bytes   317.132 bytes   00:27:17.541
7               0:28:01.166     0:09:26.333     19.387 kbps     33.665 kbps     00:36:48.958    27.122 kbps     00:36:48.375    25.604 kbps     00:36:48.916    100.975 bytes   343.604 bytes   00:35:35.500
8               0:37:27.500     0:04:15.666     21.123 kbps     29.651 kbps     00:38:01.291    26.062 kbps     00:38:27.625    25.096 kbps     00:37:56.041    110.014 bytes   263.378 bytes   00:41:37.041
9               0:41:43.166     0:06:35.166     18.347 kbps     28.374 kbps     00:44:18.250    25.765 kbps     00:41:59.875    24.283 kbps     00:41:53.916    95.560 bytes    258.906 bytes   00:47:11.333
10              0:48:18.333     0:06:34.083     19.380 kbps     33.063 kbps     00:52:27.500    25.249 kbps     00:52:25.500    24.329 kbps     00:52:26.583    100.940 bytes   390.557 bytes   00:51:38.416
11              0:54:52.416     0:06:49.458     20.419 kbps     36.231 kbps     01:00:48.125    30.773 kbps     01:00:48.125    27.794 kbps     01:00:48.125    106.347 bytes   341.023 bytes   01:00:31.541
12              1:01:41.875     0:09:27.125     19.739 kbps     31.211 kbps     01:08:49.708    27.169 kbps     01:01:48.333    26.313 kbps     01:01:43.291    102.806 bytes   295.620 bytes   01:08:39.083
13              1:11:09.000     0:05:42.708     15.985 kbps     33.916 kbps     01:13:49.875    28.241 kbps     01:13:35.458    26.769 kbps     01:13:31.750    83.255 bytes    335.144 bytes   01:13:45.916
14              1:16:51.708     0:03:18.083     15.334 kbps     28.399 kbps     01:18:04.083    24.219 kbps     01:18:02.416    23.063 kbps     01:17:58.375    79.863 bytes    316.609 bytes   01:18:05.083
15              1:20:09.791     0:05:46.916     18.623 kbps     31.308 kbps     01:25:12.250    24.204 kbps     01:25:15.750    23.750 kbps     01:25:12.250    96.994 bytes    344.660 bytes   01:23:53.208
16              1:25:56.708     0:03:20.791     20.157 kbps     31.762 kbps     01:26:49.000    25.161 kbps     01:27:53.291    24.110 kbps     01:26:02.458    104.987 bytes   326.150 bytes   01:27:35.625
17              1:29:17.500     0:03:54.875     21.187 kbps     32.837 kbps     01:32:28.500    28.854 kbps     01:32:27.541    26.843 kbps     01:32:22.500    110.350 bytes   305.487 bytes   01:30:50.916
18              1:33:12.375     0:04:47.708     19.122 kbps     30.186 kbps     01:34:17.750    26.117 kbps     01:35:37.166    25.364 kbps     01:35:36.625    99.591 bytes    296.265 bytes   01:35:36.708
19              1:38:00.083     0:03:29.666     19.640 kbps     27.046 kbps     01:38:02.291    24.725 kbps     01:38:02.000    23.752 kbps     01:40:59.708    102.292 bytes   282.237 bytes   01:41:03.750
20              1:41:29.750     0:01:28.333     15.561 kbps     19.883 kbps     01:42:22.708    18.096 kbps     01:42:21.000    17.694 kbps     01:42:19.708    81.085 bytes    290.045 bytes   01:42:55.750
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     6177,000                19.000                  14.670.056.112  79.815.711
00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       deu (German)            6177,000                2.068                   1.596.549.536   9.655.050
00004.M2TS      4353 (0x1101)   0x81            AC3             zho (Chinese)           6177,000                450                     347.266.304     1.937.870
00004.M2TS      4608 (0x1200)   0x90            PGS             deu (German)            6177,000                20                      15.655.670      92.135
Burrito is offline
post #1036 of 5106 Old 01-03-2010, 05:36 PM
Burrito's Avatar
Studio: Warner
UPC: 7321983000348
Release Date: 2007-06-22
Aspect Ratio: 2.40:1
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:31:19 19.589.074.944  23.378.827.468  17,26   14,87   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     VOLUME_ID
Disc Size:      23.378.827.468 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:31:19 (h:m:s)
Total Bitrate:          17,26 Mbps
VIDEO:
VC-1 Video              14869 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
SUBTITLES:
Presentation Graphics           English         63,894 kbps
Presentation Graphics           German          74,036 kbps
Presentation Graphics           German          78,104 kbps
FILES:
00000.M2TS      0:00:00.000     2:31:19.028     19.589.074.944  17.261
CHAPTERS:
1               0:00:00.000     0:05:03.636     14.814 kbps     34.133 kbps     00:04:23.513    23.621 kbps     00:04:19.509    22.702 kbps     00:04:14.504    77.737 bytes    547.444 bytes   00:04:23.554
2               0:05:03.636     0:03:48.895     17.596 kbps     32.390 kbps     00:06:05.156    24.008 kbps     00:06:01.194    22.403 kbps     00:06:00.735    91.739 bytes    536.716 bytes   00:06:51.828
3               0:08:52.532     0:06:03.529     16.529 kbps     28.834 kbps     00:12:47.600    24.262 kbps     00:12:47.600    21.283 kbps     00:12:47.433    86.177 bytes    405.150 bytes   00:12:36.380
4               0:14:56.061     0:04:15.755     15.448 kbps     28.969 kbps     00:18:48.752    24.489 kbps     00:19:01.181    22.644 kbps     00:19:01.181    80.536 bytes    411.836 bytes   00:17:09.820
5               0:19:11.817     0:04:50.456     16.351 kbps     24.348 kbps     00:22:27.637    22.872 kbps     00:22:24.801    22.278 kbps     00:22:21.256    85.244 bytes    341.275 bytes   00:19:21.660
6               0:24:02.274     0:01:59.786     15.730 kbps     26.651 kbps     00:24:05.444    22.992 kbps     00:24:02.566    19.922 kbps     00:24:02.691    82.008 bytes    344.348 bytes   00:24:06.278
7               0:26:02.060     0:04:05.912     16.870 kbps     29.583 kbps     00:28:40.635    24.291 kbps     00:29:36.357    22.780 kbps     00:29:36.357    87.951 bytes    383.250 bytes   00:29:38.902
8               0:30:07.972     0:02:14.801     9.849 kbps      18.728 kbps     00:32:17.268    16.126 kbps     00:32:13.973    14.689 kbps     00:32:12.764    51.349 bytes    238.023 bytes   00:30:43.800
9               0:32:22.774     0:04:50.623     13.244 kbps     24.561 kbps     00:36:46.954    22.665 kbps     00:32:33.451    22.214 kbps     00:32:28.446    69.046 bytes    357.308 bytes   00:36:47.788
10              0:37:13.397     0:05:33.332     13.703 kbps     27.900 kbps     00:39:21.400    24.763 kbps     00:38:54.665    19.881 kbps     00:38:34.437    71.442 bytes    591.152 bytes   00:42:05.773
11              0:42:46.730     0:04:41.447     14.809 kbps     31.411 kbps     00:43:53.297    23.647 kbps     00:43:52.004    22.466 kbps     00:43:53.172    77.209 bytes    314.213 bytes   00:47:16.875
12              0:47:28.178     0:03:55.568     12.018 kbps     26.663 kbps     00:50:11.341    20.634 kbps     00:51:18.617    18.361 kbps     00:51:13.737    62.654 bytes    307.968 bytes   00:50:12.175
13              0:51:23.747     0:03:27.206     16.907 kbps     30.800 kbps     00:54:38.984    23.977 kbps     00:54:00.487    23.013 kbps     00:54:25.804    88.144 bytes    367.819 bytes   00:52:30.147
14              0:54:50.954     0:04:53.126     15.641 kbps     29.769 kbps     00:58:26.544    20.382 kbps     00:58:07.609    18.368 kbps     00:58:02.604    81.542 bytes    357.664 bytes   00:55:56.519
15              0:59:44.080     0:03:25.705     14.691 kbps     30.597 kbps     01:02:50.808    23.320 kbps     01:02:46.554    21.883 kbps     01:02:43.217    76.593 bytes    460.817 bytes   01:02:46.596
16              1:03:09.786     0:04:36.442     13.927 kbps     28.971 kbps     01:03:30.473    19.135 kbps     01:03:27.178    17.076 kbps     01:05:03.524    72.608 bytes    387.414 bytes   01:03:30.723
17              1:07:46.228     0:05:17.984     17.693 kbps     31.594 kbps     01:12:35.392    24.059 kbps     01:12:03.402    22.421 kbps     01:10:00.404    92.242 bytes    393.956 bytes   01:07:54.153
18              1:13:04.213     0:01:53.947     15.220 kbps     27.722 kbps     01:14:01.103    19.261 kbps     01:14:37.890    17.579 kbps     01:14:34.595    79.351 bytes    379.883 bytes   01:13:12.304
19              1:14:58.160     0:04:30.436     14.414 kbps     26.693 kbps     01:18:06.431    22.452 kbps     01:18:02.552    21.118 kbps     01:17:57.839    75.148 bytes    393.305 bytes   01:18:07.391
20              1:19:28.597     0:03:16.696     13.188 kbps     22.460 kbps     01:22:08.089    18.615 kbps     01:22:03.501    16.680 kbps     01:19:40.734    68.759 bytes    285.821 bytes   01:22:45.168
21              1:22:45.293     0:04:38.444     14.548 kbps     26.812 kbps     01:24:04.914    23.572 kbps     01:24:04.873    20.377 kbps     01:24:04.873    75.845 bytes    362.495 bytes   01:26:00.238
22              1:27:23.738     0:02:55.508     17.138 kbps     31.161 kbps     01:28:24.132    24.787 kbps     01:28:24.132    22.476 kbps     01:28:24.132    89.350 bytes    299.251 bytes   01:28:49.490
23              1:30:19.247     0:06:14.040     15.405 kbps     30.574 kbps     01:33:22.346    20.860 kbps     01:30:24.377    18.161 kbps     01:33:21.846    80.314 bytes    378.939 bytes   01:30:46.190
24              1:36:33.287     0:02:58.344     15.425 kbps     26.014 kbps     01:37:42.439    20.788 kbps     01:37:42.565    19.571 kbps     01:37:08.781    80.417 bytes    308.812 bytes   01:37:09.406
25              1:39:31.632     0:04:16.756     16.655 kbps     32.072 kbps     01:41:07.061    24.231 kbps     01:39:50.109    22.510 kbps     01:42:42.781    86.834 bytes    483.526 bytes   01:39:53.028
26              1:43:48.388     0:03:57.570     17.848 kbps     29.995 kbps     01:44:14.915    24.849 kbps     01:44:41.984    23.275 kbps     01:45:54.014    93.052 bytes    439.110 bytes   01:45:55.015
27              1:47:45.959     0:04:07.080     14.643 kbps     26.348 kbps     01:48:12.110    20.883 kbps     01:48:09.191    17.897 kbps     01:48:08.607    76.342 bytes    408.201 bytes   01:47:48.920
28              1:51:53.039     0:05:01.301     15.429 kbps     27.462 kbps     01:54:16.933    21.738 kbps     01:54:13.930    20.048 kbps     01:55:24.834    80.441 bytes    312.225 bytes   01:54:17.392
29              1:56:54.340     0:03:59.072     17.162 kbps     30.416 kbps     01:57:17.905    25.188 kbps     01:57:17.864    22.772 kbps     01:57:14.027    89.475 bytes    336.166 bytes   01:57:15.862
30              2:00:53.412     0:02:13.132     17.035 kbps     31.039 kbps     02:03:04.668    24.140 kbps     02:03:00.706    22.590 kbps     02:02:56.452    88.812 bytes    270.121 bytes   02:01:02.672
31              2:03:06.545     0:02:57.010     14.988 kbps     21.847 kbps     02:04:09.859    19.266 kbps     02:04:25.249    18.189 kbps     02:04:24.331    78.143 bytes    246.831 bytes   02:05:01.494
32              2:06:03.556     0:04:49.288     16.151 kbps     31.806 kbps     02:10:39.039    23.701 kbps     02:10:38.288    21.294 kbps     02:10:34.868    84.202 bytes    425.381 bytes   02:08:49.888
33              2:10:52.845     0:04:26.265     16.607 kbps     29.211 kbps     02:13:36.800    24.640 kbps     02:12:18.555    22.267 kbps     02:12:13.258    86.579 bytes    328.675 bytes   02:15:18.443
34              2:15:19.111     0:03:36.883     16.143 kbps     24.639 kbps     02:16:57.000    21.122 kbps     02:17:39.709    19.080 kbps     02:16:50.744    84.163 bytes    380.741 bytes   02:17:58.895
35              2:18:55.994     0:04:23.096     17.039 kbps     30.607 kbps     02:22:30.750    22.740 kbps     02:21:32.901    21.893 kbps     02:21:28.229    88.835 bytes    465.071 bytes   02:21:40.575
36              2:23:19.090     0:01:26.586     14.673 kbps     22.581 kbps     02:24:02.091    17.093 kbps     02:24:05.511    16.162 kbps     02:23:53.374    76.537 bytes    360.725 bytes   02:23:49.954
37              2:24:45.677     0:06:33.351     1.126 kbps      12.049 kbps     02:31:12.313    6.418 kbps      02:31:12.021    3.711 kbps      02:31:07.058    5.951 bytes     330.550 bytes   02:31:16.233
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    9078,903                14.869                  16.874.186.852  91.837.545
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           9078,903                640                     726.323.200     4.255.800
00000.M2TS      4353 (0x1101)   0x81            AC3             deu (German)            9078,903                640                     726.323.200     4.255.800
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           9078,903                64                      72.512.320      406.494
00000.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            9078,903                74                      84.022.132      470.323
00000.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            9078,903                78                      88.638.344      496.307
Burrito is offline
post #1037 of 5106 Old 01-03-2010, 05:43 PM
Thanks Burrito, that was fast! One last question: the etched disc number near the spindle hole: would that be 'A0100819766-A511 1000'?
Stephen Dawson
hifi-writer.com
post #1038 of 5106 Old 01-03-2010, 11:10 PM
District 9 - 2009 - Australian version
Distributed by Sony Pictures Home Entertainment Australia
Code:
        Total   Video
00001.MPLS                                                      AVC     1:52:15 24,495,630,336  39,652,404,765  29.09   19.70   DTS-HD Master 5.1 3958Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     DISTRICT_9
Disc Size:      39,652,404,765 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:52:15 (h:m:s)
Total Bitrate:          29.09 Mbps
VIDEO:
MPEG-4 AVC Video        19697 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3958 kbps       5.1 / 48 kHz / 3958 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps
DTS-HD Master Audio             French          2717 kbps       5.1 / 48 kHz / 2717 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         37.325 kbps
* Presentation Graphics         English         37.341 kbps
* Presentation Graphics         English         32.123 kbps
Presentation Graphics           English         32.118 kbps
Presentation Graphics           French          34.665 kbps
Presentation Graphics           Hindi           34.217 kbps
* Presentation Graphics         Korean          0.000 kbps
* Presentation Graphics         Estonian        0.000 kbps
* Presentation Graphics         Lithuanian      0.000 kbps
* Presentation Graphics         Russian         0.000 kbps
* Presentation Graphics         Ukrainian       0.000 kbps
Presentation Graphics           English         65.776 kbps
* Presentation Graphics         Spanish         0.000 kbps
* Presentation Graphics         Portuguese      0.000 kbps
FILES:
00011.M2TS      0:00:00.000     1:52:15.729     24,495,630,336  29,093
CHAPTERS:
1               0:00:00.000     0:06:22.340     19,569 kbps     34,809 kbps     00:03:54.108    30,931 kbps     00:04:23.638    28,062 kbps     00:04:23.638    102,014 bytes   691,975 bytes   00:03:22.952
2               0:06:22.340     0:07:03.005     19,661 kbps     34,607 kbps     00:11:46.038    31,032 kbps     00:11:44.495    30,312 kbps     00:11:41.992    102,506 bytes   674,396 bytes   00:06:47.198
3               0:13:25.346     0:07:08.010     20,340 kbps     35,007 kbps     00:14:08.472    30,661 kbps     00:13:49.787    28,566 kbps     00:13:47.952    106,042 bytes   494,861 bytes   00:15:15.414
4               0:20:33.357     0:06:35.395     19,492 kbps     40,320 kbps     00:25:42.499    28,077 kbps     00:23:43.380    27,163 kbps     00:23:38.125    101,624 bytes   645,743 bytes   00:26:05.105
5               0:27:08.752     0:07:04.966     20,030 kbps     36,426 kbps     00:29:48.286    30,083 kbps     00:29:46.743    28,753 kbps     00:28:53.314    104,426 bytes   596,112 bytes   00:29:49.120
6               0:34:13.718     0:07:44.213     19,654 kbps     37,782 kbps     00:38:34.312    33,636 kbps     00:38:30.308    28,999 kbps     00:38:16.210    102,466 bytes   553,996 bytes   00:34:35.573
7               0:41:57.932     0:05:04.012     20,280 kbps     44,778 kbps     00:44:09.396    31,457 kbps     00:44:29.291    30,390 kbps     00:42:40.975    105,729 bytes   598,681 bytes   00:45:50.038
8               0:47:01.944     0:07:06.008     19,074 kbps     31,323 kbps     00:53:58.652    24,601 kbps     00:47:57.374    23,178 kbps     00:47:53.829    99,446 bytes    718,489 bytes   00:51:51.316
9               0:54:07.953     0:05:52.643     19,025 kbps     37,105 kbps     00:54:24.844    30,331 kbps     00:54:24.844    25,853 kbps     00:54:22.842    99,189 bytes    577,925 bytes   00:54:53.498
10              1:00:00.597     0:08:25.379     20,276 kbps     32,061 kbps     01:01:02.158    26,161 kbps     01:00:29.584    25,547 kbps     01:02:20.862    105,708 bytes   468,947 bytes   01:08:25.976
11              1:08:25.976     0:05:11.894     19,964 kbps     38,065 kbps     01:08:44.745    29,467 kbps     01:08:43.953    24,957 kbps     01:08:42.576    104,082 bytes   666,147 bytes   01:08:45.663
12              1:13:37.871     0:07:24.318     20,584 kbps     42,999 kbps     01:20:28.240    31,792 kbps     01:14:48.525    29,309 kbps     01:20:28.240    107,314 bytes   659,260 bytes   01:14:13.740
13              1:21:02.190     0:05:38.171     19,935 kbps     32,172 kbps     01:21:11.199    28,812 kbps     01:21:10.198    28,073 kbps     01:21:07.112    103,932 bytes   585,365 bytes   01:25:10.480
14              1:26:40.361     0:07:01.003     19,570 kbps     33,997 kbps     01:28:14.872    28,752 kbps     01:28:12.078    24,582 kbps     01:28:12.078    102,027 bytes   556,348 bytes   01:28:12.453
15              1:33:41.365     0:05:03.136     19,901 kbps     38,050 kbps     01:35:09.370    31,598 kbps     01:35:09.370    29,127 kbps     01:35:05.991    103,754 bytes   686,379 bytes   01:35:09.412
16              1:38:44.501     0:13:31.227     18,729 kbps     37,670 kbps     01:41:22.576    32,717 kbps     01:40:03.455    30,673 kbps     01:41:20.449    97,656 bytes    679,467 bytes   01:41:30.250
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6735.646                19,697                  16,584,215,434  90,226,623
00011.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6735.646                3,958                   3,332,332,316   19,160,253
00011.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6735.646                448                     377,201,664     2,104,920
00011.M2TS      4354 (0x1102)   0x86            DTS-HD MA       fra (French)            6735.646                2,717                   2,287,625,048   13,488,285
00011.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6735.646                192                     161,657,856     1,052,460
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6735.646                37                      31,426,004      180,016
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6735.646                37                      31,440,173      180,087
00011.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           6735.646                32                      27,046,185      157,592
00011.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           6735.646                32                      27,042,209      157,572
00011.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6735.646                35                      29,186,577      168,074
00011.M2TS      4613 (0x1205)   0x90            PGS             hin (Hindi)             6735.646                34                      28,809,462      166,147
00011.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            6735.646                0                       70              7
00011.M2TS      4615 (0x1207)   0x90            PGS             est (Estonian)          6735.646                0                       70              7
00011.M2TS      4616 (0x1208)   0x90            PGS             lit (Lithuanian)        6735.646                0                       70              7
00011.M2TS      4617 (0x1209)   0x90            PGS             rus (Russian)           6735.646                0                       70              7
00011.M2TS      4618 (0x120A)   0x90            PGS             ukr (Ukrainian)         6735.646                0                       70              7
00011.M2TS      4619 (0x120B)   0x90            PGS             eng (English)           6735.646                66                      55,380,979      313,645
00011.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           6735.646                0                       70              7
00011.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        6735.646                0                       70              7
Stephen Dawson
hifi-writer.com
post #1039 of 5106 Old 01-03-2010, 11:37 PM
Burrito's Avatar
Studio: Columbia Pictures
UPC: 4030521709584
Release Date: 2008-03-06
Code:
        Total   Video
00002.MPLS                                                      AVC     2:41:29 44.110.503.936  46.570.356.396  36,42   24,98   Dolby TrueHD 5.1 1654Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     ALMOST_FAMOUS
Disc Size:      46.570.356.396 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:41:29 (h:m:s)
Total Bitrate:          36,42 Mbps
VIDEO:
MPEG-4 AVC Video        24984 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1654 kbps       5.1 / 48 kHz / 1654 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby TrueHD Audio              French          1655 kbps       5.1 / 48 kHz / 1655 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby TrueHD Audio              German          1536 kbps       5.1 / 48 kHz / 1536 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
SUBTITLES:
Presentation Graphics           English         30,465 kbps
Presentation Graphics           Arabic          17,329 kbps
Presentation Graphics           Dutch           27,846 kbps
Presentation Graphics           French          27,321 kbps
Presentation Graphics           German          29,757 kbps
Presentation Graphics           Turkish         28,188 kbps
FILES:
00002.M2TS      0:00:00.000     2:41:29.721     44.110.503.936  36.418
CHAPTERS:
1               0:00:00.000     0:07:38.040     26.869 kbps     31.112 kbps     00:03:26.164    29.921 kbps     00:00:15.432    29.792 kbps     00:00:10.427    140.069 bytes   310.552 bytes   00:04:01.783
2               0:07:38.040     0:10:58.199     27.043 kbps     31.298 kbps     00:12:09.770    30.006 kbps     00:11:56.716    29.861 kbps     00:12:00.761    140.990 bytes   336.465 bytes   00:12:13.607
3               0:18:36.240     0:08:24.670     23.435 kbps     30.576 kbps     00:19:56.403    29.832 kbps     00:19:55.402    29.740 kbps     00:19:55.444    122.181 bytes   301.820 bytes   00:22:03.947
4               0:27:00.910     0:09:19.892     24.970 kbps     31.231 kbps     00:31:50.491    29.783 kbps     00:27:27.646    29.694 kbps     00:34:28.733    130.183 bytes   403.778 bytes   00:32:38.373
5               0:36:20.803     0:09:44.667     23.991 kbps     31.777 kbps     00:42:44.353    29.809 kbps     00:37:47.265    28.830 kbps     00:40:42.148    125.076 bytes   274.045 bytes   00:44:30.501
6               0:46:05.471     0:07:16.102     24.787 kbps     32.020 kbps     00:51:10.358    29.833 kbps     00:51:34.466    29.772 kbps     00:51:29.503    129.228 bytes   352.662 bytes   00:49:12.491
7               0:53:21.573     0:06:04.364     26.148 kbps     32.001 kbps     00:53:31.750    30.225 kbps     00:53:27.704    29.803 kbps     00:53:22.741    136.324 bytes   290.716 bytes   00:53:58.902
8               0:59:25.937     0:08:03.024     22.970 kbps     30.792 kbps     01:00:41.638    29.622 kbps     01:04:50.595    27.659 kbps     01:04:07.552    119.757 bytes   326.635 bytes   01:07:20.327
9               1:07:28.961     0:10:03.269     25.431 kbps     31.397 kbps     01:10:13.334    29.842 kbps     01:10:09.330    29.763 kbps     01:10:30.851    132.584 bytes   298.707 bytes   01:10:20.883
10              1:17:32.230     0:10:36.052     25.194 kbps     33.492 kbps     01:26:29.684    30.351 kbps     01:26:25.847    29.790 kbps     01:22:29.778    131.347 bytes   312.679 bytes   01:25:51.980
11              1:28:08.283     0:06:28.346     26.199 kbps     32.549 kbps     01:30:55.700    29.871 kbps     01:28:44.652    29.758 kbps     01:33:57.256    136.590 bytes   345.490 bytes   01:30:57.994
12              1:34:36.629     0:10:53.986     25.639 kbps     32.320 kbps     01:36:32.953    30.109 kbps     01:41:22.659    29.752 kbps     01:36:54.892    133.672 bytes   438.229 bytes   01:39:45.229
13              1:45:30.615     0:09:23.187     25.597 kbps     31.014 kbps     01:52:21.109    30.054 kbps     01:53:53.743    29.871 kbps     01:53:50.740    133.449 bytes   387.076 bytes   01:53:58.748
14              1:54:53.803     0:13:32.394     26.033 kbps     31.549 kbps     02:01:44.547    29.962 kbps     02:08:14.228    29.836 kbps     02:08:14.269    135.725 bytes   311.027 bytes   02:08:19.066
15              2:08:26.198     0:08:07.612     23.716 kbps     31.527 kbps     02:10:04.296    29.807 kbps     02:09:28.427    29.419 kbps     02:10:17.100    123.647 bytes   302.904 bytes   02:11:20.080
16              2:16:33.810     0:24:55.911     23.581 kbps     32.520 kbps     02:36:50.025    30.050 kbps     02:37:10.170    29.836 kbps     02:26:47.173    122.944 bytes   384.006 bytes   02:38:44.848
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     9689,555                24.984                  30.260.719.734  164.596.314
00002.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           9689,555                2.294                   2.778.359.490   21.939.781
00002.M2TS      4353 (0x1101)   0x83            TrueHD          fra (French)            9689,555                2.295                   2.780.220.784   21.608.550
00002.M2TS      4354 (0x1102)   0x83            TrueHD          deu (German)            9689,555                2.176                   2.636.110.112   20.145.833
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           9689,555                30                      36.899.836      212.252
00002.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            9689,555                27                      33.091.109      191.748
00002.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            9689,555                30                      36.041.884      207.727
00002.M2TS      4611 (0x1203)   0x90            PGS             ara (Arabic)            9689,555                17                      20.989.288      126.030
00002.M2TS      4612 (0x1204)   0x90            PGS             nld (Dutch)             9689,555                28                      33.727.231      191.929
00002.M2TS      4613 (0x1205)   0x90            PGS             tur (Turkish)           9689,555                28                      34.141.837      197.407
Burrito is offline
post #1040 of 5106 Old 01-03-2010, 11:40 PM
Burrito's Avatar
No problem, you're welcome!
Yes sir, thats the number.
Burrito is offline
post #1041 of 5106 Old 01-04-2010, 01:54 AM
Stephen Dawson's Avatar
This is Spinal Tap - 1984 - Australian version
Distributed by Universal Pictures (Australasia) Pty Ltd
Locked to Region B, confirmed with AnyDVD HD. Also has most of the extra content as 576i50.
An oddity: the sound is provided in DTS-HD MA English, and both English and French LPCM 2.0. The English LPCM gets 24 bits, while the French gets 16 bits. The Commentary is also LPCM 2.0, and also gets 24 bits!
Code:
        Total   Video
00000.MPLS                                                      AVC     1:23:06 20,784,840,960  36,848,328,352  33.35   21.00   LPCM 2.0 2304Kbps (48kHz/24-bit)          DTS-HD Master 5.1 3917Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     SPINAL TAP
Disc Size:      36,848,328,352 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:23:06 (h:m:s)
Total Bitrate:          33.35 Mbps
VIDEO:
MPEG-4 AVC Video        20999 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
DTS-HD Master Audio             English         3917 kbps       5.1 / 48 kHz / 3917 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
LPCM Audio                      French          1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           Danish          33.522 kbps
Presentation Graphics           French          42.109 kbps
Presentation Graphics           German          49.897 kbps
Presentation Graphics           Norwegian       30.644 kbps
Presentation Graphics           Finnish         33.782 kbps
Presentation Graphics           Swedish         32.629 kbps
Presentation Graphics           French          50.655 kbps
Presentation Graphics           German          60.009 kbps
Presentation Graphics           French          0.124 kbps
FILES:
00000.M2TS      0:00:00.000     1:23:06.231     20,784,840,960  33,347
CHAPTERS:
1               0:00:00.000     0:06:47.156     20,206 kbps     32,001 kbps     00:02:33.820    27,413 kbps     00:03:06.352    25,952 kbps     00:05:19.777    105,334 bytes   324,208 bytes   00:03:20.033
2               0:06:47.156     0:06:24.133     21,698 kbps     31,428 kbps     00:12:07.101    27,191 kbps     00:12:00.511    26,339 kbps     00:12:00.553    113,126 bytes   333,692 bytes   00:12:48.642
3               0:13:11.290     0:05:52.643     20,548 kbps     28,451 kbps     00:13:39.318    24,951 kbps     00:15:00.065    23,450 kbps     00:14:59.898    107,127 bytes   274,169 bytes   00:13:19.256
4               0:19:03.934     0:08:09.238     21,870 kbps     32,698 kbps     00:21:07.641    28,312 kbps     00:21:37.087    26,740 kbps     00:21:33.834    114,018 bytes   288,165 bytes   00:20:50.207
5               0:27:13.173     0:09:31.362     20,829 kbps     31,140 kbps     00:34:23.102    27,719 kbps     00:29:34.272    25,509 kbps     00:32:42.043    108,592 bytes   287,122 bytes   00:31:52.869
6               0:36:44.535     0:07:34.787     20,783 kbps     32,428 kbps     00:38:05.700    26,972 kbps     00:38:36.105    25,497 kbps     00:38:36.439    108,355 bytes   316,483 bytes   00:37:38.506
7               0:44:19.323     0:05:47.430     21,696 kbps     32,906 kbps     00:49:48.860    28,383 kbps     00:49:48.694    26,172 kbps     00:49:46.149    113,113 bytes   343,211 bytes   00:45:07.079
8               0:50:06.753     0:07:46.966     20,301 kbps     31,790 kbps     00:56:57.622    27,633 kbps     00:56:57.622    26,678 kbps     00:56:57.789    105,842 bytes   354,805 bytes   00:57:07.757
9               0:57:53.720     0:06:25.968     20,107 kbps     30,556 kbps     01:03:48.074    24,713 kbps     01:01:24.430    23,494 kbps     01:02:08.683    104,831 bytes   267,310 bytes   01:03:13.623
10              1:04:19.689     0:06:15.625     21,030 kbps     30,915 kbps     01:06:38.035    26,723 kbps     01:08:46.956    24,587 kbps     01:07:12.820    109,640 bytes   294,862 bytes   01:10:08.329
11              1:10:35.314     0:07:17.395     21,636 kbps     33,387 kbps     01:16:29.334    29,689 kbps     01:17:16.340    27,471 kbps     01:17:35.567    112,800 bytes   308,276 bytes   01:15:31.944
12              1:17:52.709     0:05:13.521     21,387 kbps     25,925 kbps     01:20:27.531    24,922 kbps     01:21:13.535    24,501 kbps     01:21:10.240    111,529 bytes   333,828 bytes   01:20:36.206
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     4986.148                21,000                  13,088,401,486  71,203,921
00000.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           4986.148                2,310                   1,440,024,668   7,977,976
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           4986.148                3,917                   2,441,618,296   13,754,943
00000.M2TS      4354 (0x1102)   0x80            LPCM            fra (French)            4986.148                1,542                   961,346,108     5,983,482
00000.M2TS      4355 (0x1103)   0x80            LPCM            eng (English)           4986.148                2,310                   1,440,024,668   7,977,976
00000.M2TS      4608 (0x1200)   0x90            PGS             dan (Danish)            4986.148                34                      20,893,828      118,522
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            4986.148                42                      26,246,152      152,019
00000.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            4986.148                50                      31,099,919      177,666
00000.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         4986.148                31                      19,100,038      108,766
00000.M2TS      4612 (0x1204)   0x90            PGS             fin (Finnish)           4986.148                34                      21,055,713      120,025
00000.M2TS      4613 (0x1205)   0x90            PGS             swe (Swedish)           4986.148                33                      20,337,127      115,478
00000.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            4986.148                51                      31,572,187      182,222
00000.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            4986.148                60                      37,402,916      213,889
00000.M2TS      4616 (0x1208)   0x90            PGS             fra (French)            4986.148                0                       77,210          442
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1042 of 5106 Old 01-04-2010, 12:22 PM
Burrito's Avatar
Regions: B (AnyDVD)
Studio: Kinowelt Home Entertainment GmbH
UPC: 4006680045368
Release Date: 2008-11-21
Code:
        Total   Video
00008.MPLS                                                      AVC     1:51:40 29.917.648.896  42.971.329.460  35,72   28,57   DTS-HD Master 7.1 2428Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     BANKJOB
Disc Size:      42.971.329.460 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:51:40 (h:m:s)
Total Bitrate:          35,72 Mbps
VIDEO:
MPEG-4 AVC Video        28572 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2428 kbps       7.1 / 48 kHz / 2428 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             German          2405 kbps       7.1 / 48 kHz / 2405 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           German          27,207 kbps
Presentation Graphics           German          38,415 kbps
FILES:
00012.M2TS      0:00:00.000     1:51:39.734     29.917.636.608  35.724
00008.M2TS      1:51:39.734     0:00:00.417     12.288          236
CHAPTERS:
1               0:00:00.000     0:07:32.827     27.548 kbps     41.693 kbps     00:00:29.362    36.568 kbps     00:00:25.608    34.480 kbps     00:00:23.314    143.609 bytes   583.357 bytes   00:01:51.820
2               0:07:32.827     0:05:54.604     30.001 kbps     34.740 kbps     00:08:06.027    31.649 kbps     00:08:02.315    31.181 kbps     00:11:08.584    156.411 bytes   519.388 bytes   00:11:12.588
3               0:13:27.431     0:07:38.708     29.728 kbps     34.103 kbps     00:15:50.824    32.030 kbps     00:19:51.523    31.454 kbps     00:19:51.899    154.989 bytes   547.541 bytes   00:20:34.900
4               0:21:06.139     0:07:01.963     29.839 kbps     34.086 kbps     00:23:35.705    31.863 kbps     00:23:34.704    31.426 kbps     00:24:27.966    155.568 bytes   497.271 bytes   00:23:34.454
5               0:28:08.103     0:08:03.316     29.575 kbps     34.844 kbps     00:35:11.526    32.032 kbps     00:31:12.328    31.338 kbps     00:29:34.481    154.190 bytes   563.397 bytes   00:30:02.759
6               0:36:11.419     0:05:24.741     29.855 kbps     34.908 kbps     00:37:23.991    31.975 kbps     00:41:29.028    31.458 kbps     00:40:00.314    155.650 bytes   560.113 bytes   00:37:24.033
7               0:41:36.160     0:05:56.814     29.994 kbps     34.815 kbps     00:45:05.411    32.008 kbps     00:43:23.392    31.591 kbps     00:43:18.178    156.374 bytes   507.444 bytes   00:45:05.661
8               0:47:32.975     0:06:40.525     29.596 kbps     34.535 kbps     00:49:34.012    32.256 kbps     00:49:32.928    31.324 kbps     00:52:44.286    154.299 bytes   575.016 bytes   00:49:34.054
9               0:54:13.500     0:06:36.604     29.358 kbps     35.420 kbps     00:58:40.642    31.692 kbps     00:59:53.965    31.110 kbps     00:59:50.295    153.060 bytes   579.032 bytes   00:58:40.683
10              1:00:50.104     0:05:04.846     30.051 kbps     33.899 kbps     01:05:52.406    31.677 kbps     01:02:14.397    31.043 kbps     01:04:02.380    156.672 bytes   544.097 bytes   01:05:54.158
11              1:05:54.951     0:07:42.670     29.935 kbps     34.773 kbps     01:07:55.321    32.121 kbps     01:08:01.202    31.278 kbps     01:09:00.052    156.065 bytes   519.175 bytes   01:09:00.928
12              1:13:37.621     0:06:16.292     29.820 kbps     34.136 kbps     01:15:15.302    31.948 kbps     01:18:57.065    31.628 kbps     01:16:14.444    155.469 bytes   482.112 bytes   01:15:12.549
13              1:19:53.914     0:07:53.598     29.796 kbps     35.799 kbps     01:24:23.683    32.024 kbps     01:24:23.683    31.510 kbps     01:27:18.650    155.342 bytes   583.411 bytes   01:24:23.725
14              1:27:47.512     0:06:47.031     29.794 kbps     33.850 kbps     01:30:44.272    31.599 kbps     01:32:24.455    31.130 kbps     01:30:07.360    155.330 bytes   568.372 bytes   01:32:12.568
15              1:34:34.543     0:08:29.300     29.465 kbps     35.168 kbps     01:42:33.313    31.894 kbps     01:42:32.938    31.355 kbps     01:42:31.436    153.617 bytes   571.402 bytes   01:42:30.811
16              1:43:03.844     0:08:36.307     16.328 kbps     34.050 kbps     01:44:47.698    31.873 kbps     01:44:04.613    31.210 kbps     01:44:39.439    85.133 bytes    404.975 bytes   01:44:46.989
STREAM DIAGNOSTICS:
00012.M2TS      4113 (0x1011)   0x1B            AVC                                     6699,568                28.574                  23.929.519.958  130.145.538
00012.M2TS      4352 (0x1100)   0x86            DTS-HD MA       deu (German)            6699,568                2.406                   2.014.535.228   11.993.230
00012.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           6699,568                2.428                   2.033.134.140   12.093.723
00012.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6699,568                192                     160.793.856     1.046.835
00012.M2TS      4608 (0x1200)   0x90            PGS             deu (German)            6699,568                27                      22.786.240      132.169
00012.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            6699,568                38                      32.173.270      185.065
00008.M2TS      4113 (0x1011)   0x1B            AVC                                     0,250                   169                     5.274           32
Burrito is offline
post #1043 of 5106 Old 01-04-2010, 12:50 PM
Burrito's Avatar
Regions: No region code (AnyDVD)
Studio: Warner Bros. Entertainment Inc.
UPC: 7321983001109
Release Date: 2007-03-23
Code:
        Total   Video
00003.MPLS                                                      VC-1    1:32:51 18.648.981.504  23.310.692.642  26,78   23,93   DD AC3 5.1 640Kbps                        DD AC3 1.0 192Kbps
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID
Disc Size:      23.310.692.642 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:32:51 (h:m:s)
Total Bitrate:          26,78 Mbps
VIDEO:
VC-1 Video              23933 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             French          192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             German          192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         51,188 kbps
Presentation Graphics           English         59,209 kbps
Presentation Graphics           French          45,057 kbps
Presentation Graphics           German          52,312 kbps
Presentation Graphics           German          60,226 kbps
FILES:
00003.M2TS      0:00:00.000     1:32:51.774     18.648.981.504  26.776
CHAPTERS:
1               0:00:00.000     0:02:16.761     23.986 kbps     33.743 kbps     00:00:21.104    28.380 kbps     00:00:20.478    27.264 kbps     00:00:20.478    125.396 bytes   263.696 bytes   00:01:20.538
2               0:02:16.761     0:03:41.679     24.478 kbps     32.989 kbps     00:04:52.292    27.570 kbps     00:04:44.784    26.640 kbps     00:03:02.140    127.616 bytes   264.227 bytes   00:04:19.884
3               0:05:58.441     0:02:50.336     25.146 kbps     32.565 kbps     00:07:22.650    27.544 kbps     00:06:17.960    26.874 kbps     00:08:02.648    131.099 bytes   326.770 bytes   00:08:36.599
4               0:08:48.778     0:04:18.508     23.677 kbps     31.515 kbps     00:12:56.066    25.879 kbps     00:12:56.066    24.861 kbps     00:09:58.681    123.444 bytes   265.997 bytes   00:12:34.670
5               0:13:07.286     0:05:15.148     23.785 kbps     32.184 kbps     00:13:59.755    27.400 kbps     00:14:22.111    26.384 kbps     00:14:22.111    124.020 bytes   264.611 bytes   00:13:26.847
6               0:18:22.434     0:03:21.534     23.715 kbps     29.904 kbps     00:21:41.466    25.517 kbps     00:21:37.671    24.876 kbps     00:21:32.624    123.639 bytes   247.624 bytes   00:20:51.291
7               0:21:43.969     0:03:29.209     23.630 kbps     31.886 kbps     00:24:51.031    26.285 kbps     00:22:29.765    25.888 kbps     00:22:29.765    123.195 bytes   243.094 bytes   00:24:09.364
8               0:25:13.178     0:05:06.848     24.532 kbps     34.131 kbps     00:27:17.636    27.324 kbps     00:28:49.436    26.541 kbps     00:28:49.436    127.897 bytes   267.431 bytes   00:27:28.563
9               0:30:20.026     0:01:38.932     24.024 kbps     29.235 kbps     00:31:50.658    26.567 kbps     00:30:45.426    26.468 kbps     00:30:45.426    125.250 bytes   251.134 bytes   00:30:21.110
10              0:31:58.958     0:08:51.530     23.902 kbps     33.908 kbps     00:39:02.506    27.851 kbps     00:39:07.511    27.210 kbps     00:39:02.506    124.612 bytes   279.304 bytes   00:33:00.186
11              0:40:50.489     0:02:11.089     23.434 kbps     28.918 kbps     00:41:00.291    26.092 kbps     00:40:57.705    25.561 kbps     00:42:23.749    122.172 bytes   259.857 bytes   00:41:00.749
12              0:43:01.578     0:05:23.364     23.597 kbps     30.139 kbps     00:46:06.597    27.140 kbps     00:44:25.913    25.996 kbps     00:44:20.908    123.025 bytes   269.069 bytes   00:45:44.324
13              0:48:24.943     0:01:36.763     23.703 kbps     27.368 kbps     00:48:59.102    26.564 kbps     00:48:56.350    26.084 kbps     00:48:55.724    123.579 bytes   233.751 bytes   00:49:05.400
14              0:50:01.707     0:02:43.163     23.467 kbps     29.452 kbps     00:50:40.704    27.777 kbps     00:50:37.659    26.167 kbps     00:50:35.198    122.346 bytes   245.978 bytes   00:52:11.837
15              0:52:44.870     0:05:35.001     23.827 kbps     30.894 kbps     00:56:02.859    26.993 kbps     00:57:43.418    26.078 kbps     00:53:25.202    124.226 bytes   251.036 bytes   00:56:40.105
16              0:58:19.871     0:03:03.141     23.044 kbps     31.294 kbps     01:00:17.905    28.036 kbps     01:00:17.780    27.242 kbps     01:00:17.655    120.142 bytes   243.594 bytes   01:00:39.927
17              1:01:23.012     0:05:47.305     24.397 kbps     31.762 kbps     01:05:33.220    27.890 kbps     01:04:25.653    26.973 kbps     01:01:28.101    127.194 bytes   268.094 bytes   01:05:25.254
18              1:07:10.317     0:04:41.990     24.269 kbps     31.425 kbps     01:09:42.469    27.319 kbps     01:09:18.362    26.333 kbps     01:11:35.874    126.527 bytes   266.392 bytes   01:10:59.129
19              1:11:52.308     0:01:35.428     24.856 kbps     31.898 kbps     01:12:18.125    27.665 kbps     01:12:23.130    27.241 kbps     01:12:18.125    129.587 bytes   270.401 bytes   01:12:28.594
20              1:13:27.736     0:03:53.608     22.986 kbps     31.233 kbps     01:16:31.962    27.986 kbps     01:15:26.063    27.134 kbps     01:15:24.895    119.836 bytes   252.178 bytes   01:17:21.303
21              1:17:21.345     0:02:06.459     24.401 kbps     32.781 kbps     01:19:17.002    26.485 kbps     01:19:01.945    25.604 kbps     01:18:19.986    127.214 bytes   274.212 bytes   01:19:12.789
22              1:19:27.804     0:01:09.903     25.225 kbps     33.278 kbps     01:20:03.840    27.900 kbps     01:20:03.840    26.825 kbps     01:20:03.840    131.513 bytes   261.425 bytes   01:20:27.280
23              1:20:37.707     0:02:47.917     24.694 kbps     34.327 kbps     01:21:42.022    27.927 kbps     01:20:59.938    26.813 kbps     01:22:30.862    128.742 bytes   273.184 bytes   01:21:39.519
24              1:23:25.625     0:04:14.963     24.337 kbps     30.418 kbps     01:25:10.230    27.781 kbps     01:25:35.588    27.061 kbps     01:26:06.619    126.883 bytes   257.450 bytes   01:27:35.291
25              1:27:40.588     0:04:34.607     23.771 kbps     29.820 kbps     01:31:34.447    27.658 kbps     01:31:14.510    26.133 kbps     01:31:28.774    123.930 bytes   265.382 bytes   01:30:18.246
26              1:32:15.196     0:00:36.578     16.269 kbps     22.272 kbps     01:32:24.455    21.133 kbps     01:32:36.759    20.202 kbps     01:32:16.113    84.916 bytes    230.175 bytes   01:32:49.397
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0xEA            VC-1                                    5571,691                23.933                  16.668.420.227  90.669.884
00003.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5571,691                640                     445.742.080     2.611.770
00003.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5571,691                192                     133.722.624     870.590
00003.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            5571,691                192                     133.722.624     870.590
00003.M2TS      4355 (0x1103)   0x81            AC3             deu (German)            5571,691                192                     133.722.624     870.590
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5571,691                51                      35.650.835      200.534
00003.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5571,691                59                      41.237.203      232.373
00003.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5571,691                45                      31.380.653      177.513
00003.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            5571,691                52                      36.433.625      204.256
00003.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            5571,691                60                      41.945.565      235.315
Burrito is offline
post #1044 of 5106 Old 01-04-2010, 01:54 PM
Burrito's Avatar
Region Code: B (Source: DVD Profiler)
Studio: Walt Disney Pictures
UPC: 8717418205881
Release Date: 2009-06-18
Code:
        Total   Video
00350.MPLS                                                      AVC     1:36:21 26.122.819.584  38.044.185.888  36,14   24,13   DTS-HD Master 5.1-ES 3874Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BOLT_DEU
Disc Size:      38.044.185.888 bytes
Protection:     AACS
BD-Java:        Yes
D-BOX Motion:   Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:36:21 (h:m:s)
Total Bitrate:          36,14 Mbps
VIDEO:
MPEG-4 AVC Video        24126 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3874 kbps       5.1-ES / 48 kHz / 3874 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
DTS-ES Audio                    Dutch           1509 kbps       5.1-ES / 48 kHz / 1509 kbps / 24-bit
DTS-ES Audio                    German          1509 kbps       5.1-ES / 48 kHz / 1509 kbps / 24-bit
Dolby Digital EX Audio          Danish          640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Dutch           640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Norwegian       640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Polish          640 kbps        5.1-EX / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         34,703 kbps
Presentation Graphics           English         40,653 kbps
Presentation Graphics           Danish          35,427 kbps
Presentation Graphics           Danish          0,224 kbps
Presentation Graphics           Dutch           25,806 kbps
Presentation Graphics           Dutch           0,044 kbps
Presentation Graphics           German          36,150 kbps
Presentation Graphics           German          0,082 kbps
Presentation Graphics           Norwegian       30,969 kbps
Presentation Graphics           Norwegian       0,225 kbps
Presentation Graphics           Polish          32,292 kbps
Presentation Graphics           Polish          0,251 kbps
FILES:
00161.M2TS      0:00:00.000     0:02:01.538     580.448.256     38.207
00003.M2TS      0:02:01.538     0:01:01.311     273.371.136     35.670
00004.M2TS      0:03:02.849     0:00:31.114     143.032.320     36.776
00172.M2TS      0:03:33.963     0:00:15.932     76.068.864      38.195
00173.M2TS      0:03:49.896     0:07:04.465     1.951.899.648   36.788
00174.M2TS      0:10:54.361     0:00:18.351     82.249.728      35.855
00175.M2TS      0:11:12.713     0:00:39.122     174.569.472     35.697
00176.M2TS      0:11:51.836     0:00:48.715     216.238.080     35.510
00177.M2TS      0:12:40.551     0:06:11.579     1.626.163.200   35.011
00178.M2TS      0:18:52.130     0:00:50.050     232.949.760     37.235
00179.M2TS      0:19:42.180     0:04:00.907     1.137.002.496   37.757
00180.M2TS      0:23:43.088     0:00:23.565     107.040.768     36.339
00181.M2TS      0:24:06.653     0:04:54.752     1.342.955.520   36.450
00182.M2TS      0:29:01.406     0:00:18.643     83.521.536      35.839
00183.M2TS      0:29:20.049     0:06:43.361     1.762.105.344   34.948
00184.M2TS      0:36:03.411     0:00:21.730     95.883.264      35.300
00185.M2TS      0:36:25.141     0:15:29.553     4.167.641.088   35.868
00186.M2TS      0:51:54.694     0:00:28.361     129.902.592     36.642
00187.M2TS      0:52:23.056     0:17:09.069     4.705.124.352   36.578
00188.M2TS      1:09:32.126     0:00:22.021     98.058.240      35.622
00189.M2TS      1:09:54.148     0:04:52.333     1.279.752.192   35.022
00190.M2TS      1:14:46.481     0:00:51.593     229.287.936     35.553
00191.M2TS      1:15:38.075     0:01:07.233     300.883.968     35.801
00192.M2TS      1:16:45.308     0:00:21.771     97.585.152      35.858
00193.M2TS      1:17:07.080     0:01:45.980     466.649.088     35.225
00194.M2TS      1:18:53.061     0:00:35.702     156.266.496     35.015
00195.M2TS      1:19:28.763     0:02:11.422     602.793.984     36.693
00196.M2TS      1:21:40.186     0:00:20.854     95.035.392      36.457
00197.M2TS      1:22:01.040     0:14:20.818     3.908.339.712   36.322
CHAPTERS:
1               0:00:00.000     0:02:31.651     27.433 kbps     42.536 kbps     00:00:46.212    34.960 kbps     00:00:42.208    34.118 kbps     00:00:37.245    142.982 bytes   572.955 bytes   00:00:46.838
2               0:02:31.651     0:08:29.008     23.921 kbps     38.638 kbps     00:10:21.579    34.217 kbps     00:10:17.533    31.863 kbps     00:07:54.807    124.715 bytes   911.930 bytes   00:10:22.538
3               0:11:00.659     0:02:46.541     22.419 kbps     28.734 kbps     00:11:06.373    26.249 kbps     00:11:59.510    25.237 kbps     00:11:13.297    116.880 bytes   655.341 bytes   00:11:01.660
4               0:13:47.201     0:05:32.749     24.242 kbps     36.175 kbps     00:14:47.678    33.277 kbps     00:19:07.145    32.995 kbps     00:19:03.016    126.384 bytes   661.754 bytes   00:14:52.099
5               0:19:19.950     0:04:58.923     24.954 kbps     38.408 kbps     00:20:58.256    33.797 kbps     00:21:01.676    33.357 kbps     00:21:01.218    130.099 bytes   688.173 bytes   00:20:12.002
6               0:24:18.873     0:02:55.508     24.846 kbps     36.027 kbps     00:25:57.097    32.830 kbps     00:24:39.644    29.180 kbps     00:26:43.893    129.537 bytes   663.623 bytes   00:26:19.452
7               0:27:14.382     0:02:34.320     24.538 kbps     34.633 kbps     00:27:33.735    31.034 kbps     00:29:36.733    28.319 kbps     00:29:33.062    127.927 bytes   895.702 bytes   00:27:25.810
8               0:29:48.703     0:05:37.128     22.769 kbps     35.873 kbps     00:33:25.837    29.790 kbps     00:32:25.526    28.395 kbps     00:32:19.020    118.708 bytes   712.323 bytes   00:34:37.283
9               0:35:25.831     0:06:43.736     23.483 kbps     40.810 kbps     00:38:21.298    34.550 kbps     00:38:17.378    33.473 kbps     00:38:12.206    122.428 bytes   936.924 bytes   00:40:09.198
10              0:42:09.568     0:09:32.405     24.023 kbps     39.246 kbps     00:48:05.799    33.313 kbps     00:48:57.309    32.014 kbps     00:48:28.363    125.244 bytes   723.343 bytes   00:51:13.153
11              0:51:41.973     0:10:16.365     25.346 kbps     39.016 kbps     01:01:28.726    33.731 kbps     01:01:42.532    33.510 kbps     00:58:41.225    132.144 bytes   547.906 bytes   00:51:50.815
12              1:01:58.339     0:06:17.668     23.388 kbps     39.434 kbps     01:07:34.508    34.205 kbps     01:07:30.588    32.919 kbps     01:07:29.086    121.937 bytes   750.686 bytes   01:06:55.344
13              1:08:16.008     0:04:46.703     23.369 kbps     38.757 kbps     01:11:10.098    33.684 kbps     01:11:03.717    31.506 kbps     01:11:01.548    121.838 bytes   927.917 bytes   01:11:08.555
14              1:13:02.711     0:05:50.349     23.837 kbps     40.678 kbps     01:18:48.098    33.082 kbps     01:18:35.210    30.399 kbps     01:18:31.873    124.274 bytes   936.803 bytes   01:13:52.260
15              1:18:53.061     0:10:43.768     24.060 kbps     39.986 kbps     01:26:51.080    33.713 kbps     01:25:46.891    32.638 kbps     01:19:14.207    125.440 bytes   723.941 bytes   01:26:51.998
16              1:29:36.829     0:06:45.029     24.312 kbps     42.139 kbps     01:29:38.831    34.786 kbps     01:36:10.973    34.288 kbps     01:36:04.717    126.764 bytes   730.697 bytes   01:30:58.327
STREAM DIAGNOSTICS:
00161.M2TS      4113 (0x1011)   0x1B            AVC                                     121,371                 26.719                  405.368.977     2.204.818
00161.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           121,371                 3.538                   53.675.988      310.459
00161.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            121,371                 1.511                   22.926.740      136.740
00161.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         121,371                 641                     9.725.440       56.985
00161.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            121,371                 641                     9.725.440       56.985
00161.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             121,371                 1.511                   22.926.740      136.740
00161.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             121,371                 641                     9.725.440       56.985
00161.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            121,371                 641                     9.725.440       56.985
00161.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           121,371                 0                       6.145           40
00161.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           121,371                 5                       78.252          481
00161.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            121,371                 0                       5.106           34
00161.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         121,371                 0                       3.239           24
00161.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            121,371                 0                       5.492           36
00161.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             121,371                 4                       60.249          349
00161.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            121,371                 1                       9.438           59
00161.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            121,371                 0                       70              7
00161.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         121,371                 0                       70              7
00161.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            121,371                 0                       70              7
00161.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             121,371                 0                       70              7
00161.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            121,371                 0                       70              7
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     61,144                  23.793                  181.851.753     989.239
00003.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           61,144                  3.833                   29.295.492      168.761
00003.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            61,144                  1.513                   11.564.976      68.976
00003.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         61,144                  642                     4.904.960       28.740
00003.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            61,144                  642                     4.904.960       28.740
00003.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             61,144                  1.513                   11.564.976      68.976
00003.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             61,144                  642                     4.904.960       28.740
00003.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            61,144                  642                     4.904.960       28.740
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           61,144                  27                      205.223         1.214
00003.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           61,144                  37                      281.794         1.653
00003.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            61,144                  34                      262.881         1.540
00003.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         61,144                  29                      218.791         1.299
00003.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            61,144                  32                      241.814         1.425
00003.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             61,144                  28                      210.318         1.233
00003.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            61,144                  27                      207.450         1.246
00003.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            61,144                  0                       70              7
00003.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         61,144                  5                       37.085          215
00003.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            61,144                  5                       35.718          209
00003.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             61,144                  0                       70              7
00003.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            61,144                  3                       20.628          119
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     30,948                  23.904                  92.471.823      503.014
00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           30,948                  4.974                   19.239.980      109.404
00004.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            30,948                  1.517                   5.869.004       35.004
00004.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         30,948                  644                     2.490.880       14.595
00004.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            30,948                  644                     2.490.880       14.595
00004.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             30,948                  1.517                   5.869.004       35.004
00004.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             30,948                  644                     2.490.880       14.595
00004.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            30,948                  644                     2.490.880       14.595
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           30,948                  15                      59.198          343
00004.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           30,948                  22                      86.719          500
00004.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            30,948                  18                      68.634          393
00004.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         30,948                  16                      60.811          352
00004.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            30,948                  16                      62.719          362
00004.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             30,948                  17                      64.056          369
00004.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            30,948                  19                      73.517          421
00004.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            30,948                  0                       70              7
00004.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         30,948                  0                       70              7
00004.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            30,948                  0                       70              7
00004.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             30,948                  0                       70              7
00004.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            30,948                  0                       70              7
00172.M2TS      4113 (0x1011)   0x1B            AVC                                     15,766                  26.117                  51.469.265      279.948
00172.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           15,766                  4.397                   8.666.044       49.573
00172.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            15,766                  1.525                   3.005.928       17.928
00172.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         15,766                  647                     1.274.880       7.470
00172.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            15,766                  647                     1.274.880       7.470
00172.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             15,766                  1.525                   3.005.928       17.928
00172.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             15,766                  647                     1.274.880       7.470
00172.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            15,766                  647                     1.274.880       7.470
00172.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           15,766                  0                       70              7
00172.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           15,766                  0                       70              7
00172.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            15,766                  10                      19.774          115
00172.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         15,766                  0                       70              7
00172.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            15,766                  0                       70              7
00172.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             15,766                  0                       70              7
00172.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            15,766                  3                       6.541           42
00172.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            15,766                  0                       70              7
00172.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         15,766                  0                       70              7
00172.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            15,766                  0                       70              7
00172.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             15,766                  0                       70              7
00172.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            15,766                  0                       70              7
00173.M2TS      4113 (0x1011)   0x1B            AVC                                     424,299                 24.330                  1.290.395.242   7.018.917
00173.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           424,299                 4.459                   236.484.804     1.351.334
00173.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            424,299                 1.510                   80.065.528      477.528
00173.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         424,299                 640                     33.958.400      198.975
00173.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            424,299                 640                     33.958.400      198.975
00173.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             424,299                 1.510                   80.065.528      477.528
00173.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             424,299                 640                     33.958.400      198.975
00173.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            424,299                 640                     33.958.400      198.975
00173.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           424,299                 12                      610.889         3.520
00173.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           424,299                 16                      867.303         5.083
00173.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            424,299                 12                      631.395         3.633
00173.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         424,299                 11                      563.530         3.264
00173.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            424,299                 12                      657.479         3.775
00173.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             424,299                 11                      598.294         3.453
00173.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            424,299                 11                      592.376         3.425
00173.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            424,299                 0                       70              7
00173.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         424,299                 0                       70              7
00173.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            424,299                 0                       70              7
00173.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             424,299                 0                       70              7
00173.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            424,299                 0                       70              7
00174.M2TS      4113 (0x1011)   0x1B            AVC                                     18,268                  23.921                  54.623.330      297.125
00174.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           18,268                  3.884                   8.869.052       51.055
00174.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            18,268                  1.516                   3.462.652       20.652
00174.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         18,268                  643                     1.469.440       8.610
00174.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            18,268                  643                     1.469.440       8.610
00174.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             18,268                  1.516                   3.462.652       20.652
00174.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             18,268                  643                     1.469.440       8.610
00174.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            18,268                  643                     1.469.440       8.610
00174.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           18,268                  45                      101.930         582
00174.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           18,268                  64                      146.720         848
00174.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            18,268                  41                      93.989          538
00174.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         18,268                  37                      83.412          482
00174.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            18,268                  36                      82.280          474
00174.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             18,268                  9                       20.645          119
00174.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            18,268                  40                      90.674          528
00174.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            18,268                  0                       70              7
00174.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         18,268                  0                       70              7
00174.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            18,268                  0                       70              7
00174.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             18,268                  0                       70              7
00174.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            18,268                  3                       6.541           42
00175.M2TS      4113 (0x1011)   0x1B            AVC                                     38,956                  23.979                  116.766.636     635.135
00175.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           38,956                  3.685                   17.942.076      103.619
00175.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            38,956                  1.516                   7.380.016       44.016
00175.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         38,956                  643                     3.130.880       18.345
00175.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            38,956                  643                     3.130.880       18.345
00175.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             38,956                  1.516                   7.380.016       44.016
00175.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             38,956                  643                     3.130.880       18.345
00175.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            38,956                  643                     3.130.880       18.345
00175.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           38,956                  35                      170.212         988
00175.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           38,956                  46                      222.212         1.298
00175.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            38,956                  43                      210.020         1.201
00175.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         38,956                  33                      159.641         932
00175.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            38,956                  38                      185.173         1.066
00175.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             38,956                  29                      140.436         813
00175.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            38,956                  35                      168.282         973
00175.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            38,956                  0                       70              7
00175.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         38,956                  0                       70              7
00175.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            38,956                  0                       70              7
00175.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             38,956                  0                       70              7
00175.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            38,956                  0                       70              7
00176.M2TS      4113 (0x1011)   0x1B            AVC                                     48,549                  23.882                  144.929.205     788.345
00176.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           48,549                  3.480                   21.116.168      122.344
00176.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            48,549                  1.514                   9.190.816       54.816
00176.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         48,549                  642                     3.898.880       22.845
00176.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            48,549                  642                     3.898.880       22.845
00176.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             48,549                  1.514                   9.190.816       54.816
00176.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             48,549                  642                     3.898.880       22.845
00176.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            48,549                  642                     3.898.880       22.845
00176.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           48,549                  54                      326.298         1.869
00176.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           48,549                  55                      331.739         1.905
00176.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            48,549                  51                      308.030         1.770
00176.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         48,549                  46                      280.323         1.619
00176.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            48,549                  53                      319.393         1.831
00176.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             48,549                  47                      285.849         1.628
00176.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            48,549                  49                      300.102         1.724
00176.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            48,549                  0                       70              7
00176.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         48,549                  0                       70              7
00176.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            48,549                  0                       70              7
00176.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             48,549                  0                       70              7
00176.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            48,549                  0                       70              7
00177.M2TS      4113 (0x1011)   0x1B            AVC                                     371,496                 23.464                  1.089.580.749   5.926.804
00177.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           371,496                 3.319                   154.110.068     895.654
00177.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            371,496                 1.509                   70.090.032      418.032
00177.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         371,496                 640                     29.726.720      174.180
00177.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            371,496                 640                     29.726.720      174.180
00177.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             371,496                 1.509                   70.090.032      418.032
00177.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             371,496                 640                     29.726.720      174.180
00177.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            371,496                 640                     29.726.720      174.180
00177.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           371,496                 55                      2.574.899       14.675
00177.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           371,496                 60                      2.794.025       15.972
00177.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            371,496                 57                      2.634.235       14.993
00177.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         371,496                 46                      2.153.520       12.380
00177.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            371,496                 58                      2.701.922       15.358
00177.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             371,496                 41                      1.917.045       10.907
00177.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            371,496                 51                      2.385.648       13.636
00177.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            371,496                 0                       70              7
00177.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         371,496                 0                       70              7
00177.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            371,496                 0                       70              7
00177.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             371,496                 0                       70              7
00177.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            371,496                 0                       70              7
00178.M2TS      4113 (0x1011)   0x1B            AVC                                     49,883                  25.567                  159.422.732     867.115
00178.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           49,883                  3.714                   23.160.108      133.687
00178.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            49,883                  1.514                   9.442.316       56.316
00178.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         49,883                  643                     4.006.400       23.475
00178.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            49,883                  643                     4.006.400       23.475
00178.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             49,883                  1.514                   9.442.316       56.316
00178.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             49,883                  643                     4.006.400       23.475
00178.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            49,883                  643                     4.006.400       23.475
00178.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           49,883                  13                      81.683          485
00178.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           49,883                  20                      123.949         739
00178.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            49,883                  14                      89.955          531
00178.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         49,883                  14                      85.380          507
00178.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            49,883                  13                      81.744          486
00178.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             49,883                  11                      70.193          422
00178.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            49,883                  14                      88.420          523
00178.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            49,883                  0                       70              7
00178.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         49,883                  0                       70              7
00178.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            49,883                  0                       70              7
00178.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             49,883                  0                       70              7
00178.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            49,883                  0                       70              7
00179.M2TS      4113 (0x1011)   0x1B            AVC                                     240,782                 25.422                  765.144.733     4.161.777
00179.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           240,782                 4.094                   123.210.488     707.219
00179.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            240,782                 1.510                   45.443.032      271.032
00179.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         240,782                 640                     19.274.240      112.935
00179.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            240,782                 640                     19.274.240      112.935
00179.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             240,782                 1.510                   45.443.032      271.032
00179.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             240,782                 640                     19.274.240      112.935
00179.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            240,782                 640                     19.274.240      112.935
00179.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           240,782                 40                      1.205.779       6.940
00179.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           240,782                 50                      1.496.583       8.664
00179.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            240,782                 40                      1.191.331       6.856
00179.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         240,782                 35                      1.058.174       6.137
00179.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            240,782                 41                      1.241.907       7.133
00179.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             240,782                 32                      976.170         5.615
00179.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            240,782                 41                      1.228.245       7.059
00179.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            240,782                 0                       70              7
00179.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         240,782                 0                       70              7
00179.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            240,782                 0                       70              7
00179.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             240,782                 0                       70              7
00179.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            240,782                 0                       70              7
00180.M2TS      4113 (0x1011)   0x1B            AVC                                     23,440                  24.171                  70.821.094      385.221
00180.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           23,440                  4.373                   12.814.004      73.329
00180.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            23,440                  1.518                   4.446.520       26.520
00180.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         23,440                  644                     1.886.720       11.055
00180.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            23,440                  644                     1.886.720       11.055
00180.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             23,440                  1.518                   4.446.520       26.520
00180.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             23,440                  644                     1.886.720       11.055
00180.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            23,440                  644                     1.886.720       11.055
00180.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           23,440                  2                       5.288           35
00180.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           23,440                  24                      69.571          407
00180.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            23,440                  2                       5.288           35
00180.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         23,440                  2                       5.288           35
00180.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            23,440                  2                       5.288           35
00180.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             23,440                  2                       4.926           33
00180.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            23,440                  2                       5.288           35
00180.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            23,440                  0                       70              7
00180.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         23,440                  0                       70              7
00180.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            23,440                  0                       70              7
00180.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             23,440                  0                       70              7
00180.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            23,440                  0                       70              7
00181.M2TS      4113 (0x1011)   0x1B            AVC                                     294,586                 24.341                  896.313.471     4.875.310
00181.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           294,586                 4.036                   148.621.972     853.706
00181.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            294,586                 1.510                   55.599.608      331.608
00181.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         294,586                 640                     23.582.720      138.180
00181.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            294,586                 640                     23.582.720      138.180
00181.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             294,586                 1.510                   55.599.608      331.608
00181.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             294,586                 640                     23.582.720      138.180
00181.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            294,586                 640                     23.582.720      138.180
00181.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           294,586                 25                      928.479         5.335
00181.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           294,586                 32                      1.194.474       6.949
00181.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            294,586                 26                      957.826         5.498
00181.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         294,586                 22                      793.379         4.604
00181.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            294,586                 25                      921.812         5.298
00181.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             294,586                 19                      709.028         4.075
00181.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            294,586                 22                      827.141         4.784
00181.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            294,586                 0                       70              7
00181.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         294,586                 0                       70              7
00181.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            294,586                 0                       70              7
00181.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             294,586                 0                       70              7
00181.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            294,586                 0                       70              7
00182.M2TS      4113 (0x1011)   0x1B            AVC                                     18,477                  24.018                  55.471.313      301.732
00182.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           18,477                  3.719                   8.588.712       49.551
00182.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            18,477                  1.523                   3.516.976       20.976
00182.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         18,477                  646                     1.492.480       8.745
00182.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            18,477                  646                     1.492.480       8.745
00182.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             18,477                  1.523                   3.516.976       20.976
00182.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             18,477                  646                     1.492.480       8.745
00182.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            18,477                  646                     1.492.480       8.745
00182.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           18,477                  62                      143.062         810
00182.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           18,477                  62                      143.062         810
00182.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            18,477                  69                      160.269         909
00182.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         18,477                  60                      139.616         798
00182.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            18,477                  65                      150.642         858
00182.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             18,477                  40                      93.521          538
00182.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            18,477                  59                      136.455         781
00182.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            18,477                  7                       17.142          100
00182.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         18,477                  8                       18.644          108
00182.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            18,477                  8                       17.605          103
00182.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             18,477                  0                       70              7
00182.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            18,477                  10                      22.009          127
00183.M2TS      4113 (0x1011)   0x1B            AVC                                     403,194                 23.030                  1.160.716.648   6.313.872
00183.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           403,194                 3.726                   187.799.080     1.083.552
00183.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            403,194                 1.510                   76.085.792      453.792
00183.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         403,194                 640                     32.271.360      189.090
00183.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            403,194                 640                     32.271.360      189.090
00183.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             403,194                 1.510                   76.085.792      453.792
00183.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             403,194                 640                     32.271.360      189.090
00183.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            403,194                 640                     32.271.360      189.090
00183.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           403,194                 50                      2.509.229       14.355
00183.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           403,194                 58                      2.912.790       16.773
00183.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            403,194                 51                      2.593.780       14.814
00183.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         403,194                 45                      2.280.076       13.113
00183.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            403,194                 50                      2.537.733       14.513
00183.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             403,194                 41                      2.049.012       11.711
00183.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            403,194                 45                      2.282.688       13.126
00183.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            403,194                 0                       70              7
00183.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         403,194                 0                       70              7
00183.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            403,194                 0                       70              7
00183.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             403,194                 0                       70              7
00183.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            403,194                 0                       70              7
00184.M2TS      4113 (0x1011)   0x1B            AVC                                     21,563                  24.099                  64.955.475      353.329
00184.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           21,563                  3.237                   8.725.892       50.827
00184.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            21,563                  1.521                   4.100.456       24.456
00184.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         21,563                  646                     1.740.800       10.200
00184.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            21,563                  646                     1.740.800       10.200
00184.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             21,563                  1.521                   4.100.456       24.456
00184.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             21,563                  646                     1.740.800       10.200
00184.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            21,563                  646                     1.740.800       10.200
00184.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           21,563                  42                      112.238         642
00184.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           21,563                  51                      136.345         787
00184.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            21,563                  42                      113.059         647
00184.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         21,563                  38                      102.379         588
00184.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            21,563                  46                      122.922         700
00184.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             21,563                  35                      93.429          529
00184.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            21,563                  40                      108.441         621
00184.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            21,563                  0                       70              7
00184.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         21,563                  0                       70              7
00184.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            21,563                  0                       70              7
00184.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             21,563                  0                       70              7
00184.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            21,563                  0                       70              7
00185.M2TS      4113 (0x1011)   0x1B            AVC                                     929,387                 23.780                  2.762.558.359   15.026.924
00185.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           929,387                 3.867                   449.236.260     2.586.316
00185.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            929,387                 1.509                   175.337.752     1.045.752
00185.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         929,387                 640                     74.365.440      435.735
00185.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            929,387                 640                     74.365.440      435.735
00185.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             929,387                 1.509                   175.337.752     1.045.752
00185.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             929,387                 640                     74.365.440      435.735
00185.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            929,387                 640                     74.365.440      435.735
00185.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           929,387                 48                      5.593.045       32.040
00185.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           929,387                 57                      6.604.121       38.077
00185.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            929,387                 49                      5.679.596       32.508
00185.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         929,387                 42                      4.874.527       28.143
00185.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            929,387                 49                      5.672.419       32.475
00185.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             929,387                 38                      4.421.232       25.221
00185.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            929,387                 44                      5.077.469       29.244
00185.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            929,387                 0                       70              7
00185.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         929,387                 0                       70              7
00185.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            929,387                 0                       70              7
00185.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             929,387                 0                       70              7
00185.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            929,387                 0                       70              7
00186.M2TS      4113 (0x1011)   0x1B            AVC                                     28,195                  24.729                  87.153.899      474.067
00186.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           28,195                  3.871                   13.644.308      78.581
00186.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            28,195                  1.518                   5.349.908       31.908
00186.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         28,195                  644                     2.270.720       13.305
00186.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            28,195                  644                     2.270.720       13.305
00186.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             28,195                  1.518                   5.349.908       31.908
00186.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             28,195                  644                     2.270.720       13.305
00186.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            28,195                  644                     2.270.720       13.305
00186.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           28,195                  19                      66.365          381
00186.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           28,195                  21                      73.377          420
00186.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            28,195                  40                      141.201         809
00186.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         28,195                  34                      121.056         700
00186.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            28,195                  38                      132.348         762
00186.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             28,195                  23                      79.311          460
00186.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            28,195                  41                      143.589         825
00186.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            28,195                  0                       70              7
00186.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         28,195                  19                      66.554          383
00186.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            28,195                  20                      70.513          405
00186.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             28,195                  0                       70              7
00186.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            28,195                  23                      81.694          468
00187.M2TS      4113 (0x1011)   0x1B            AVC                                     1028,903                24.628                  3.167.499.952   17.228.967
00187.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1028,903                3.788                   487.244.244     2.808.396
00187.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            1028,903                1.509                   194.109.712     1.157.712
00187.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         1028,903                640                     82.327.040      482.385
00187.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            1028,903                640                     82.327.040      482.385
00187.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             1028,903                1.509                   194.109.712     1.157.712
00187.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             1028,903                640                     82.327.040      482.385
00187.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            1028,903                640                     82.327.040      482.385
00187.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1028,903                36                      4.587.350       26.455
00187.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1028,903                41                      5.209.865       30.205
00187.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            1028,903                37                      4.742.105       27.300
00187.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         1028,903                32                      4.121.796       23.938
00187.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            1028,903                35                      4.517.768       26.075
00187.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             1028,903                26                      3.316.445       19.063
00187.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            1028,903                34                      4.326.205       25.034
00187.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            1028,903                0                       70              7
00187.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         1028,903                0                       70              7
00187.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            1028,903                0                       70              7
00187.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             1028,903                0                       70              7
00187.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            1028,903                0                       70              7
00188.M2TS      4113 (0x1011)   0x1B            AVC                                     21,855                  23.936                  65.390.899      355.699
00188.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           21,855                  3.584                   9.790.132       56.657
00188.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            21,855                  1.521                   4.154.780       24.780
00188.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         21,855                  646                     1.763.840       10.335
00188.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            21,855                  646                     1.763.840       10.335
00188.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             21,855                  1.521                   4.154.780       24.780
00188.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             21,855                  646                     1.763.840       10.335
00188.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            21,855                  646                     1.763.840       10.335
00188.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           21,855                  53                      144.199         834
00188.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           21,855                  53                      144.199         834
00188.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            21,855                  62                      170.546         983
00188.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         21,855                  49                      132.888         778
00188.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            21,855                  65                      178.796         1.026
00188.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             21,855                  46                      125.169         720
00188.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            21,855                  52                      142.599         831
00188.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            21,855                  7                       20.398          118
00188.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         21,855                  7                       19.638          114
00188.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            21,855                  7                       18.599          108
00188.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             21,855                  0                       70              7
00188.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            21,855                  8                       20.594          119
00189.M2TS      4113 (0x1011)   0x1B            AVC                                     292,209                 23.296                  850.919.182     4.628.611
00189.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           292,209                 3.573                   130.520.660     755.020
00189.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            292,209                 1.510                   55.142.884      328.884
00189.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         292,209                 640                     23.388.160      137.040
00189.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            292,209                 640                     23.388.160      137.040
00189.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             292,209                 1.510                   55.142.884      328.884
00189.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             292,209                 640                     23.388.160      137.040
00189.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            292,209                 640                     23.388.160      137.040
00189.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           292,209                 45                      1.658.736       9.509
00189.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           292,209                 48                      1.752.222       10.063
00189.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            292,209                 46                      1.693.750       9.707
00189.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         292,209                 40                      1.456.522       8.414
00189.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            292,209                 47                      1.724.051       9.866
00189.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             292,209                 35                      1.267.411       7.239
00189.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            292,209                 38                      1.390.207       8.055
00189.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            292,209                 0                       70              7
00189.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         292,209                 0                       70              7
00189.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            292,209                 0                       70              7
00189.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             292,209                 0                       70              7
00189.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            292,209                 0                       70              7
00190.M2TS      4113 (0x1011)   0x1B            AVC                                     51,426                  23.857                  153.357.853     834.200
00190.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           51,426                  3.663                   23.543.924      135.966
00190.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            51,426                  1.514                   9.732.044       58.044
00190.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         51,426                  642                     4.129.280       24.195
00190.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            51,426                  642                     4.129.280       24.195
00190.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             51,426                  1.514                   9.732.044       58.044
00190.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             51,426                  642                     4.129.280       24.195
00190.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            51,426                  642                     4.129.280       24.195
00190.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           51,426                  31                      198.184         1.139
00190.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           51,426                  34                      215.876         1.235
00190.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            51,426                  33                      214.109         1.231
00190.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         51,426                  30                      191.183         1.107
00190.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            51,426                  35                      227.225         1.303
00190.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             51,426                  28                      177.692         1.013
00190.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            51,426                  33                      214.452         1.236
00190.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            51,426                  3                       19.949          115
00190.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         51,426                  3                       19.121          111
00190.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            51,426                  3                       18.082          105
00190.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             51,426                  5                       29.517          167
00190.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            51,426                  3                       20.594          119
00191.M2TS      4113 (0x1011)   0x1B            AVC                                     67,067                  23.856                  199.995.135     1.087.852
00191.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           67,067                  3.781                   31.698.048      182.758
00191.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            67,067                  1.513                   12.683.648      75.648
00191.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         67,067                  642                     5.381.120       31.530
00191.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            67,067                  642                     5.381.120       31.530
00191.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             67,067                  1.513                   12.683.648      75.648
00191.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             67,067                  642                     5.381.120       31.530
00191.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            67,067                  642                     5.381.120       31.530
00191.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           67,067                  51                      429.412         2.461
00191.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           67,067                  57                      475.214         2.724
00191.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            67,067                  50                      420.383         2.411
00191.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         67,067                  43                      358.812         2.077
00191.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            67,067                  51                      429.830         2.461
00191.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             67,067                  38                      315.263         1.797
00191.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            67,067                  44                      367.806         2.125
00191.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            67,067                  0                       70              7
00191.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         67,067                  0                       70              7
00191.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            67,067                  0                       70              7
00191.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             67,067                  0                       70              7
00191.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            67,067                  0                       70              7
00192.M2TS      4113 (0x1011)   0x1B            AVC                                     21,605                  24.923                  67.307.655      366.110
00192.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           21,605                  3.237                   8.741.800       50.950
00192.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            21,605                  1.521                   4.108.504       24.504
00192.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         21,605                  646                     1.743.360       10.215
00192.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            21,605                  646                     1.743.360       10.215
00192.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             21,605                  1.521                   4.108.504       24.504
00192.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             21,605                  646                     1.743.360       10.215
00192.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            21,605                  646                     1.743.360       10.215
00192.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           21,605                  2                       4.245           30
00192.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           21,605                  8                       21.628          131
00192.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            21,605                  2                       4.245           30
00192.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         21,605                  2                       4.245           30
00192.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            21,605                  2                       4.245           30
00192.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             21,605                  2                       4.245           30
00192.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            21,605                  2                       5.601           37
00192.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            21,605                  0                       70              7
00192.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         21,605                  0                       70              7
00192.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            21,605                  0                       70              7
00192.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             21,605                  0                       70              7
00192.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            21,605                  0                       70              7
00193.M2TS      4113 (0x1011)   0x1B            AVC                                     105,814                 23.814                  314.979.491     1.713.317
00193.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           105,814                 3.501                   46.306.096      268.190
00193.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            105,814                 1.511                   19.991.232      119.232
00193.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         105,814                 641                     8.478.720       49.680
00193.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            105,814                 641                     8.478.720       49.680
00193.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             105,814                 1.511                   19.991.232      119.232
00193.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             105,814                 641                     8.478.720       49.680
00193.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            105,814                 641                     8.478.720       49.680
00193.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           105,814                 12                      153.610         906
00193.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           105,814                 16                      211.077         1.254
00193.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            105,814                 14                      186.224         1.082
00193.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         105,814                 12                      161.894         949
00193.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            105,814                 14                      184.488         1.071
00193.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             105,814                 10                      128.030         752
00193.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            105,814                 13                      176.087         1.027
00193.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            105,814                 0                       70              7
00193.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         105,814                 0                       70              7
00193.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            105,814                 0                       70              7
00193.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             105,814                 0                       70              7
00193.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            105,814                 0                       70              7
00194.M2TS      4113 (0x1011)   0x1B            AVC                                     35,619                  23.198                  103.287.896     561.853
00194.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           35,619                  3.789                   16.871.556      97.255
00194.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            35,619                  1.513                   6.736.176       40.176
00194.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         35,619                  642                     2.856.960       16.740
00194.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            35,619                  642                     2.856.960       16.740
00194.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             35,619                  1.513                   6.736.176       40.176
00194.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             35,619                  642                     2.856.960       16.740
00194.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            35,619                  642                     2.856.960       16.740
00194.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           35,619                  31                      137.405         788
00194.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           35,619                  37                      163.762         945
00194.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            35,619                  34                      150.357         860
00194.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         35,619                  29                      131.316         756
00194.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            35,619                  35                      155.585         888
00194.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             35,619                  30                      133.768         769
00194.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            35,619                  31                      137.747         793
00194.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            35,619                  0                       70              7
00194.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         35,619                  0                       70              7
00194.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            35,619                  0                       70              7
00194.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             35,619                  0                       70              7
00194.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            35,619                  2                       7.549           47
00195.M2TS      4113 (0x1011)   0x1B            AVC                                     131,256                 24.723                  405.630.156     2.206.353
00195.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           131,256                 3.847                   63.117.640      363.425
00195.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            131,256                 1.511                   24.789.852      147.852
00195.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         131,256                 641                     10.513.920      61.605
00195.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            131,256                 641                     10.513.920      61.605
00195.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             131,256                 1.511                   24.789.852      147.852
00195.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             131,256                 641                     10.513.920      61.605
00195.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            131,256                 641                     10.513.920      61.605
00195.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           131,256                 33                      537.068         3.127
00195.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           131,256                 39                      634.387         3.713
00195.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            131,256                 35                      567.407         3.291
00195.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         131,256                 31                      504.955         2.952
00195.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            131,256                 33                      533.687         3.110
00195.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             131,256                 28                      465.878         2.706
00195.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            131,256                 30                      498.567         2.918
00195.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            131,256                 0                       70              7
00195.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         131,256                 0                       70              7
00195.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            131,256                 0                       70              7
00195.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             131,256                 0                       70              7
00195.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            131,256                 0                       70              7
00196.M2TS      4113 (0x1011)   0x1B            AVC                                     20,729                  23.942                  62.037.279      337.452
00196.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           20,729                  4.507                   11.678.368      66.724
00196.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            20,729                  1.519                   3.935.472       23.472
00196.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         20,729                  644                     1.669.120       9.780
00196.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            20,729                  644                     1.669.120       9.780
00196.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             20,729                  1.519                   3.935.472       23.472
00196.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             20,729                  644                     1.669.120       9.780
00196.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            20,729                  644                     1.669.120       9.780
00196.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           20,729                  34                      88.343          529
00196.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           20,729                  43                      110.328         662
00196.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            20,729                  38                      97.811          581
00196.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         20,729                  33                      85.541          514
00196.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            20,729                  38                      97.497          580
00196.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             20,729                  28                      72.618          423
00196.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            20,729                  31                      79.432          482
00196.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            20,729                  0                       70              7
00196.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         20,729                  0                       70              7
00196.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            20,729                  0                       70              7
00196.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             20,729                  0                       70              7
00196.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            20,729                  0                       70              7
00197.M2TS      4113 (0x1011)   0x1B            AVC                                     860,651                 24.134                  2.596.379.066   14.122.931
00197.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           860,651                 4.137                   445.097.392     2.552.857
00197.M2TS      4353 (0x1101)   0x82            DTS-ES          deu (German)            860,651                 1.509                   162.372.424     968.424
00197.M2TS      4354 (0x1102)   0x81            AC3-EX          nor (Norwegian)         860,651                 640                     68.866.560      403.515
00197.M2TS      4355 (0x1103)   0x81            AC3-EX          dan (Danish)            860,651                 640                     68.866.560      403.515
00197.M2TS      4356 (0x1104)   0x82            DTS-ES          nld (Dutch)             860,651                 1.509                   162.372.424     968.424
00197.M2TS      4357 (0x1105)   0x81            AC3-EX          nld (Dutch)             860,651                 640                     68.866.560      403.515
00197.M2TS      4358 (0x1106)   0x81            AC3-EX          pol (Polish)            860,651                 640                     68.866.560      403.515
00197.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           860,651                 23                      2.442.264       14.045
00197.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           860,651                 27                      2.879.562       16.655
00197.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            860,651                 25                      2.713.762       15.515
00197.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         860,651                 21                      2.249.613       12.999
00197.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            860,651                 23                      2.427.597       13.965
00197.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             860,651                 8                       850.198         4.905
00197.M2TS      4614 (0x1206)   0x90            PGS             pol (Polish)            860,651                 21                      2.267.917       13.098
00197.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            860,651                 0                       70              7
00197.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         860,651                 0                       70              7
00197.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            860,651                 0                       70              7
00197.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             860,651                 0                       70              7
00197.M2TS      4619 (0x120B)   0x90            PGS             pol (Polish)            860,651                 0                       70              7
Burrito is offline
post #1045 of 5106 Old 01-04-2010, 04:02 PM
Stephen Dawson's Avatar
Love Actually - 2003 - Australian
Distributed by Universal Pictures (Australasia) Pty Ltd
Region Free, confirmed with AnyDVD HD
Seems to be identical to US version shown on front page, details here, except for a slight disc size variation (US: 44,070,966,924 bytes, my scan: 44,070,931,672 bytes). The Australian version opens with an FBI copyright warning, and carries the same disc title as the US version (LOVE_ACTUALLY_GLO - global?), so I reckon they're the same.
Stephen Dawson
hifi-writer.com
post #1046 of 5106 Old 01-04-2010, 04:50 PM
Burrito's Avatar
Studio: Magidson Films
UPC: 5028836040019
Release Date: 2008-11-10
Aspect Ratio: 2.21:1
Code:
        Total   Video
00002.MPLS                                                      VC-1    1:37:49 28.329.646.080  46.972.359.966  38,62   27,33   DTS-HD Master 5.1 8683Kbps (96kHz/24-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     BARAKA
Disc Size:      46.972.359.966 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:37:49 (h:m:s)
Total Bitrate:          38,62 Mbps
VIDEO:
VC-1 Video              27334 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         8683 kbps       5.1 / 96 kHz / 8683 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
FILES:
00017.M2TS      0:00:00.000     1:37:49.029     28.329.646.080  38.616
CHAPTERS:
1               0:00:00.000     0:03:33.296     26.249 kbps     38.084 kbps     00:01:57.742    36.071 kbps     00:01:57.575    34.728 kbps     00:01:54.656    140.083 bytes   590.837 bytes   00:01:50.026
2               0:03:33.296     0:02:47.542     23.554 kbps     34.774 kbps     00:04:09.165    31.849 kbps     00:04:39.070    31.435 kbps     00:04:39.070    122.800 bytes   537.543 bytes   00:04:10.083
3               0:06:20.838     0:05:37.754     28.781 kbps     40.467 kbps     00:07:58.519    36.424 kbps     00:11:23.099    34.549 kbps     00:08:09.447    150.048 bytes   756.814 bytes   00:10:57.406
4               0:11:58.592     0:03:53.524     28.687 kbps     43.643 kbps     00:15:49.156    35.407 kbps     00:12:05.599    33.410 kbps     00:12:05.057    149.560 bytes   766.397 bytes   00:12:21.615
5               0:15:52.117     0:05:56.814     27.547 kbps     39.645 kbps     00:16:49.925    36.802 kbps     00:16:49.008    34.982 kbps     00:17:54.406    143.618 bytes   674.635 bytes   00:21:46.930
6               0:21:48.932     0:02:19.597     29.558 kbps     41.760 kbps     00:22:05.657    35.697 kbps     00:23:54.641    34.871 kbps     00:23:54.641    154.099 bytes   763.619 bytes   00:22:05.949
7               0:24:08.530     0:02:47.417     31.565 kbps     41.692 kbps     00:25:57.180    36.969 kbps     00:25:54.135    35.042 kbps     00:25:50.882    164.567 bytes   725.955 bytes   00:26:48.148
8               0:26:55.947     0:03:06.185     31.628 kbps     42.395 kbps     00:27:09.586    36.406 kbps     00:28:47.809    35.723 kbps     00:28:47.934    164.892 bytes   549.738 bytes   00:27:29.648
9               0:30:02.133     0:03:33.046     27.937 kbps     42.926 kbps     00:30:14.103    36.038 kbps     00:31:17.834    34.111 kbps     00:32:59.978    145.653 bytes   756.358 bytes   00:32:56.265
10              0:33:35.179     0:04:51.666     28.721 kbps     43.107 kbps     00:37:12.605    35.865 kbps     00:34:13.468    35.669 kbps     00:34:13.468    149.736 bytes   747.080 bytes   00:37:05.640
11              0:38:26.846     0:02:29.440     30.135 kbps     41.228 kbps     00:40:31.137    35.926 kbps     00:40:06.195    34.706 kbps     00:40:30.386    157.112 bytes   478.591 bytes   00:38:43.863
12              0:40:56.287     0:06:55.748     31.125 kbps     41.715 kbps     00:43:16.135    37.009 kbps     00:45:28.475    34.853 kbps     00:45:23.846    162.272 bytes   703.837 bytes   00:41:48.088
13              0:47:52.035     0:03:44.057     31.268 kbps     40.361 kbps     00:48:38.665    35.834 kbps     00:50:24.730    35.024 kbps     00:50:19.349    163.017 bytes   671.955 bytes   00:50:47.127
14              0:51:36.093     0:04:09.499     26.918 kbps     40.707 kbps     00:53:52.896    34.493 kbps     00:52:50.166    33.342 kbps     00:52:45.161    140.337 bytes   608.822 bytes   00:53:04.973
15              0:55:45.592     0:03:06.895     28.733 kbps     40.048 kbps     00:55:45.592    35.388 kbps     00:58:16.951    34.395 kbps     00:58:13.281    149.798 bytes   588.767 bytes   00:58:52.487
16              0:58:52.487     0:03:15.028     29.352 kbps     37.930 kbps     01:00:04.934    35.305 kbps     01:00:03.516    34.874 kbps     00:59:59.429    153.025 bytes   606.626 bytes   00:58:53.488
17              1:02:07.515     0:04:40.029     23.718 kbps     37.429 kbps     01:03:42.527    34.625 kbps     01:05:23.502    33.147 kbps     01:03:33.851    123.656 bytes   548.943 bytes   01:02:34.542
18              1:06:47.545     0:06:01.736     24.634 kbps     40.254 kbps     01:11:26.865    33.935 kbps     01:07:25.583    33.807 kbps     01:07:21.746    128.429 bytes   826.905 bytes   01:11:03.509
19              1:12:49.281     0:06:50.576     29.872 kbps     43.400 kbps     01:13:28.695    36.424 kbps     01:17:30.062    34.922 kbps     01:13:36.662    155.738 bytes   729.200 bytes   01:15:58.845
20              1:19:39.858     0:05:49.724     30.986 kbps     39.355 kbps     01:24:20.430    35.762 kbps     01:20:35.080    35.188 kbps     01:20:30.158    161.549 bytes   629.490 bytes   01:24:38.782
21              1:25:29.582     0:05:21.738     31.658 kbps     41.311 kbps     01:30:41.727    35.754 kbps     01:26:57.503    34.657 kbps     01:26:55.043    166.975 bytes   506.072 bytes   01:26:56.669
22              1:30:51.320     0:06:57.708     9.341 kbps      26.505 kbps     01:35:30.599    25.460 kbps     01:35:29.140    23.949 kbps     01:35:26.762    49.164 bytes    601.789 bytes   01:35:31.600
STREAM DIAGNOSTICS:
00017.M2TS      4113 (0x1011)   0xEA            VC-1                                    5868,905                27.334                  20.052.918.664  109.068.212
00017.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5868,905                640                     469.524.480     2.751.120
00017.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           5868,905                8.683                   6.370.136.908   35.534.272
Burrito is offline
post #1047 of 5106 Old 01-04-2010, 06:39 PM
Burrito's Avatar
Region Code: none (Source: DVD Profiler)
Studio: New Line Home Entertainment
UPC: 5051890000163
Release Date: 2008-12-08
Aspect Ratio: 1.85:1
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:36:43 22.108.090.368  42.525.498.403  30,48   21,95   Dolby TrueHD 5.1 1512Kbps (48kHz/16-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     ELF
Disc Size:      42.525.498.403 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:36:43 (h:m:s)
Total Bitrate:          30,48 Mbps
VIDEO:
VC-1 Video              21951 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         1512 kbps       5.1 / 48 kHz / 1512 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         382,773 kbps
Presentation Graphics           English         128,111 kbps
Presentation Graphics           German          417,320 kbps
Presentation Graphics           German          151,713 kbps
Presentation Graphics           Spanish         353,641 kbps
Presentation Graphics           Spanish         145,234 kbps
FILES:
00000.M2TS      0:00:00.000     1:36:43.172     22.108.090.368  30.477
CHAPTERS:
1               0:00:00.000     0:03:45.683     23.096 kbps     43.924 kbps     00:00:02.502    32.620 kbps     00:01:31.925    30.147 kbps     00:01:07.025    120.657 bytes   625.381 bytes   00:01:32.425
2               0:03:45.683     0:05:13.896     23.893 kbps     39.136 kbps     00:07:21.732    32.715 kbps     00:04:08.122    30.928 kbps     00:04:03.117    124.568 bytes   522.416 bytes   00:05:35.293
3               0:08:59.580     0:05:42.759     22.769 kbps     38.325 kbps     00:09:47.795    28.619 kbps     00:13:51.288    28.028 kbps     00:13:50.204    118.709 bytes   575.738 bytes   00:13:01.655
4               0:14:42.339     0:07:01.587     23.568 kbps     46.339 kbps     00:18:43.413    34.138 kbps     00:18:41.453    32.155 kbps     00:17:45.522    122.875 bytes   667.933 bytes   00:18:21.350
5               0:21:43.927     0:03:37.050     23.565 kbps     42.632 kbps     00:22:02.404    33.762 kbps     00:21:59.484    31.736 kbps     00:21:53.228    122.858 bytes   500.027 bytes   00:22:01.528
6               0:25:20.977     0:08:10.072     23.390 kbps     48.347 kbps     00:28:54.107    35.036 kbps     00:27:07.500    31.923 kbps     00:27:05.081    121.947 bytes   732.502 bytes   00:28:54.733
7               0:33:31.050     0:04:46.953     22.221 kbps     42.374 kbps     00:38:16.919    32.262 kbps     00:33:31.134    29.861 kbps     00:36:31.647    115.852 bytes   470.082 bytes   00:36:31.105
8               0:38:18.004     0:04:30.311     21.151 kbps     36.216 kbps     00:38:49.076    27.782 kbps     00:42:20.871    27.330 kbps     00:42:20.871    110.274 bytes   500.123 bytes   00:42:16.784
9               0:42:48.315     0:08:33.221     21.950 kbps     43.172 kbps     00:48:20.939    31.724 kbps     00:45:27.141    30.751 kbps     00:45:19.842    114.437 bytes   651.463 bytes   00:51:08.565
10              0:51:21.536     0:06:38.189     23.244 kbps     39.626 kbps     00:57:57.724    31.733 kbps     00:57:53.720    30.548 kbps     00:53:48.850    121.183 bytes   757.228 bytes   00:52:47.247
11              0:57:59.726     0:07:08.928     23.430 kbps     45.153 kbps     01:01:26.557    34.815 kbps     01:01:23.429    31.733 kbps     01:00:48.603    122.152 bytes   548.184 bytes   01:01:58.840
12              1:05:08.654     0:02:06.584     24.800 kbps     42.338 kbps     01:06:04.585    33.392 kbps     01:05:32.720    31.356 kbps     01:05:27.673    129.294 bytes   637.962 bytes   01:06:32.154
13              1:07:15.239     0:04:46.202     22.833 kbps     41.650 kbps     01:08:52.211    34.279 kbps     01:07:59.575    30.967 kbps     01:07:59.492    119.038 bytes   577.712 bytes   01:08:00.159
14              1:12:01.442     0:05:46.596     21.375 kbps     35.806 kbps     01:17:16.506    32.959 kbps     01:17:12.836    32.218 kbps     01:17:10.375    111.441 bytes   521.297 bytes   01:16:47.144
15              1:17:48.038     0:07:44.005     23.670 kbps     57.213 kbps     01:22:04.878    35.285 kbps     01:22:32.572    31.013 kbps     01:23:07.065    123.403 bytes   591.920 bytes   01:22:00.749
16              1:25:32.043     0:05:39.922     24.047 kbps     49.674 kbps     01:27:11.017    34.794 kbps     01:27:57.814    31.946 kbps     01:29:32.116    125.602 bytes   722.977 bytes   01:27:57.855
17              1:31:11.966     0:05:31.205     4.372 kbps      7.241 kbps      01:35:40.776    7.112 kbps      01:35:38.774    7.006 kbps      01:35:33.602    22.817 bytes    182.648 bytes   01:35:35.438
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    5803,047                21.951                  15.922.839.351  86.621.201
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5803,047                640                     464.253.440     2.720.235
00000.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           5803,047                2.152                   1.561.365.164   11.946.925
00000.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            5803,047                640                     464.253.440     2.720.235
00000.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           5803,047                640                     464.253.440     2.720.235
00000.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           5803,047                192                     139.276.032     906.745
00000.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           5803,047                192                     139.276.032     906.745
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5803,047                383                     277.662.342     1.556.306
00000.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            5803,047                417                     302.722.455     1.691.157
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           5803,047                354                     256.530.263     1.439.376
00000.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           5803,047                128                     92.931.373      520.736
00000.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            5803,047                152                     110.051.850     613.684
00000.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           5803,047                145                     105.352.489     588.272
Burrito is offline
post #1048 of 5106 Old 01-04-2010, 09:11 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
UPC: 0 12236 10586 2 (Sticker placed over original UPC)
Disc Author Date: 10/18/09 for all files/folders
Store: Purchased from Amazon on 12/22/09
Extended:
Code:
        Total   Video
00000.MPLS                                                      AVC     2:09:36 32,760,261,120  43,711,210,365  33.70   24.01   DTS-HD Master 7.1 5173Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     STARGATE
Disc Size:      43,711,210,365 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:09:36 (h:m:s)
Total Bitrate:          33.70 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        24007 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
* MPEG-4 AVC Video      1600 kbps           480p / 23.976 fps / 4:3 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         5173 kbps       7.1 / 48 kHz / 5173 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
* Dolby Digital Audio           French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
* Dolby Digital Audio           English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
* DTS Express                   English         192 kbps        2.0 / 48 kHz / 192 kbps / 16-bit
SUBTITLES:
* Presentation Graphics         English         18.949 kbps
* Presentation Graphics         Spanish         18.099 kbps
* Presentation Graphics         English         29.087 kbps
* Presentation Graphics         French          1.810 kbps
FILES:
00347.M2TS      0:00:00.000     0:04:13.378     1,174,749,696   37,091
00313.M2TS      0:04:13.378     0:01:18.953     320,188,416     32,443
00349.M2TS      0:05:32.332     0:01:31.132     388,153,344     34,074
00315.M2TS      0:07:03.464     0:05:24.449     1,374,818,304   33,899
00351.M2TS      0:12:27.913     0:00:04.504     21,540,864      38,257
00317.M2TS      0:12:32.418     0:09:02.875     2,285,322,240   33,677
00353.M2TS      0:21:35.293     0:00:35.618     157,310,976     35,332
00319.M2TS      0:22:10.912     0:05:24.824     1,390,454,784   34,245
00355.M2TS      0:27:35.737     0:01:53.446     453,316,608     31,967
00321.M2TS      0:29:29.184     0:13:14.460     3,357,124,608   33,805
00357.M2TS      0:42:43.644     0:00:19.686     78,557,184      31,924
00323.M2TS      0:43:03.330     0:06:03.404     1,568,593,920   34,531
00359.M2TS      0:49:06.735     0:01:39.599     401,854,464     32,278
00325.M2TS      0:50:46.334     0:02:38.992     703,168,512     35,381
00361.M2TS      0:53:25.327     0:02:00.120     518,584,320     34,538
00327.M2TS      0:55:25.447     0:06:01.694     1,442,942,976   31,915
00363.M2TS      1:01:27.141     0:01:00.226     242,399,232     32,198
00329.M2TS      1:02:27.368     0:03:34.339     924,346,368     34,500
00348.M2TS      1:06:01.707     0:02:18.304     545,261,568     31,540
00331.M2TS      1:08:20.012     0:07:50.928     1,918,703,616   32,594
00350.M2TS      1:16:10.941     0:00:51.217     206,217,216     32,210
00333.M2TS      1:17:02.159     0:10:06.689     2,572,591,104   33,923
00352.M2TS      1:27:08.848     0:00:09.342     37,435,392      32,055
00335.M2TS      1:27:18.191     0:00:32.198     127,862,784     31,768
00354.M2TS      1:27:50.389     0:02:00.328     496,508,928     33,010
00337.M2TS      1:29:50.718     0:01:50.652     467,822,592     33,823
00356.M2TS      1:31:41.370     0:00:16.975     67,301,376      31,717
00339.M2TS      1:31:58.345     0:02:23.810     624,734,208     34,753
00358.M2TS      1:34:22.156     0:02:03.790     547,958,784     35,412
00341.M2TS      1:36:25.946     0:02:49.252     683,532,288     32,308
00360.M2TS      1:39:15.199     0:00:16.891     68,640,768      32,508
00343.M2TS      1:39:32.090     0:08:29.592     2,078,908,416   32,636
00362.M2TS      1:48:01.683     0:00:16.391     67,577,856      32,982
00345.M2TS      1:48:18.074     0:21:18.860     5,445,777,408   34,066
CHAPTERS:
1               0:00:00.000     0:04:00.365     24,247 kbps     34,197 kbps     00:03:26.581    32,863 kbps     00:03:03.975    32,287 kbps     00:02:58.970    126,393 bytes   310,517 bytes   00:02:19.222
2               0:04:00.365     0:02:41.703     25,011 kbps     32,721 kbps     00:05:47.180    32,319 kbps     00:05:45.053    30,639 kbps     00:05:44.052    130,396 bytes   331,246 bytes   00:06:05.573
3               0:06:42.068     0:03:42.722     23,073 kbps     30,250 kbps     00:07:28.281    29,505 kbps     00:08:01.564    28,955 kbps     00:07:15.977    120,290 bytes   339,554 bytes   00:10:24.790
4               0:10:24.790     0:01:43.812     24,572 kbps     31,429 kbps     00:12:07.601    28,086 kbps     00:12:03.597    26,460 kbps     00:10:25.541    128,107 bytes   349,897 bytes   00:10:25.791
5               0:12:08.602     0:09:26.691     24,079 kbps     32,688 kbps     00:17:28.297    27,916 kbps     00:12:09.186    27,091 kbps     00:12:49.393    125,535 bytes   353,003 bytes   00:17:28.881
6               0:21:35.293     0:07:15.059     24,299 kbps     32,675 kbps     00:24:00.647    29,668 kbps     00:25:11.843    29,384 kbps     00:25:11.801    126,684 bytes   267,193 bytes   00:27:31.983
7               0:28:50.353     0:04:33.064     26,118 kbps     34,839 kbps     00:30:56.562    32,863 kbps     00:32:33.201    32,592 kbps     00:32:30.740    136,166 bytes   278,332 bytes   00:32:51.260
8               0:33:23.418     0:02:42.662     22,732 kbps     28,833 kbps     00:33:30.633    27,573 kbps     00:34:44.832    26,151 kbps     00:35:18.324    118,516 bytes   259,258 bytes   00:35:18.783
9               0:36:06.080     0:08:34.055     23,220 kbps     32,705 kbps     00:41:10.885    29,756 kbps     00:44:00.804    28,492 kbps     00:43:57.676    121,060 bytes   347,987 bytes   00:41:06.630
10              0:44:40.135     0:06:34.852     23,872 kbps     31,157 kbps     00:46:47.554    28,941 kbps     00:46:43.926    28,671 kbps     00:50:01.748    124,455 bytes   324,215 bytes   00:46:25.407
11              0:51:14.988     0:04:21.177     23,459 kbps     33,259 kbps     00:51:41.348    31,297 kbps     00:51:37.969    29,338 kbps     00:51:32.923    122,307 bytes   314,244 bytes   00:54:26.012
12              0:55:36.166     0:05:50.975     24,210 kbps     30,755 kbps     00:57:36.578    29,679 kbps     00:57:20.937    28,738 kbps     00:57:20.019    126,219 bytes   239,646 bytes   00:59:23.142
13              1:01:27.141     0:11:28.813     23,451 kbps     31,665 kbps     01:02:27.577    29,224 kbps     01:02:56.772    28,011 kbps     01:04:06.968    122,265 bytes   221,410 bytes   01:12:41.315
14              1:12:55.954     0:03:53.232     25,297 kbps     32,054 kbps     01:14:37.848    29,813 kbps     01:14:29.923    29,038 kbps     01:14:30.382    131,889 bytes   269,779 bytes   01:15:02.497
15              1:16:49.187     0:07:10.096     24,876 kbps     33,198 kbps     01:20:24.527    31,847 kbps     01:16:55.026    31,028 kbps     01:23:24.791    129,690 bytes   254,919 bytes   01:23:28.962
16              1:23:59.284     0:03:05.476     22,320 kbps     33,773 kbps     01:24:00.618    28,224 kbps     01:25:05.266    27,295 kbps     01:25:03.806    116,365 bytes   290,002 bytes   01:24:47.624
17              1:27:04.761     0:04:46.786     24,068 kbps     29,609 kbps     01:27:08.806    28,323 kbps     01:31:44.665    28,017 kbps     01:31:39.994    125,479 bytes   233,461 bytes   01:31:12.550
18              1:31:51.547     0:11:18.511     23,672 kbps     33,699 kbps     01:34:54.772    31,322 kbps     01:34:53.312    30,423 kbps     01:34:51.352    123,413 bytes   349,274 bytes   01:32:42.056
19              1:43:10.058     0:02:31.526     24,151 kbps     34,507 kbps     01:44:46.404    32,330 kbps     01:44:30.680    30,146 kbps     01:44:28.053    125,914 bytes   268,883 bytes   01:45:35.370
20              1:45:41.585     0:03:48.519     27,377 kbps     34,267 kbps     01:47:27.315    33,029 kbps     01:49:01.951    32,933 kbps     01:48:56.946    142,733 bytes   308,896 bytes   01:48:52.609
21              1:49:30.104     0:08:47.068     30,297 kbps     34,217 kbps     01:55:55.531    33,032 kbps     01:56:52.964    32,916 kbps     01:57:00.137    157,956 bytes   297,702 bytes   01:51:34.312
22              1:58:17.173     0:03:15.320     30,434 kbps     33,812 kbps     02:00:50.451    32,991 kbps     01:58:34.815    32,772 kbps     01:58:42.323    158,671 bytes   328,546 bytes   02:00:38.647
23              2:01:32.493     0:01:52.862     28,819 kbps     35,512 kbps     02:02:53.866    33,262 kbps     02:02:49.820    32,807 kbps     02:01:46.507    150,248 bytes   276,820 bytes   02:03:05.210
24              2:03:25.356     0:06:11.579     8,524 kbps      16,260 kbps     02:09:29.928    14,640 kbps     02:09:27.050    12,263 kbps     02:09:24.548    44,446 bytes    242,149 bytes   02:09:30.721
STREAM DIAGNOSTICS:
00347.M2TS      4113 (0x1011)   0x1B            AVC                                     269.978                 23,995                  809,764,180     4,404,658
00347.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           269.978                 5,539                   186,923,972     1,057,511
00347.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            269.978                 640                     21,608,960      126,615
00347.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           269.978                 224                     7,563,136       42,205
00347.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           269.978                 0                       70              7
00347.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           269.978                 2                       77,601          442
00347.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           269.978                 6                       199,845         1,154
00347.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            269.978                 0                       70              7
00347.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           269.978                 192                     6,483,968       37,992
00347.M2TS      6912 (0x1B00)   0x1B            AVC                                     269.978                 3,580                   120,802,634     660,071
00313.M2TS      4113 (0x1011)   0x1B            AVC                                     78.787                  24,051                  236,859,380     1,288,368
00313.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           78.787                  5,250                   51,705,568      293,322
00313.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            78.787                  642                     6,318,080       37,020
00313.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           78.787                  225                     2,211,328       12,340
00313.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           78.787                  12                      119,264         697
00313.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           78.787                  15                      152,560         891
00313.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           78.787                  34                      332,793         1,910
00313.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            78.787                  7                       72,000          413
00313.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           78.787                  193                     1,896,448       11,112
00313.M2TS      6912 (0x1B00)   0x1B            AVC                                     78.787                  336                     3,311,977       18,930
00349.M2TS      4113 (0x1011)   0x1B            AVC                                     90.966                  24,033                  273,275,485     1,486,459
00349.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           90.966                  5,330                   60,609,624      343,580
00349.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            90.966                  641                     7,290,880       42,720
00349.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           90.966                  224                     2,551,808       14,240
00349.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           90.966                  11                      128,969         728
00349.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           90.966                  19                      210,443         1,205
00349.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           90.966                  29                      326,662         1,864
00349.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            90.966                  10                      117,288         671
00349.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           90.966                  192                     2,187,264       12,816
00349.M2TS      6912 (0x1B00)   0x1B            AVC                                     90.966                  1,829                   20,798,819      114,282
00315.M2TS      4113 (0x1011)   0x1B            AVC                                     324.282                 24,002                  972,934,981     5,292,224
00315.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           324.282                 4,827                   195,659,048     1,113,785
00315.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            324.282                 640                     25,958,400      152,100
00315.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           324.282                 224                     9,085,440       50,700
00315.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           324.282                 41                      1,679,199       9,523
00315.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           324.282                 41                      1,678,580       9,508
00315.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           324.282                 49                      1,991,289       11,269
00315.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            324.282                 0                       70              7
00315.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           324.282                 192                     7,788,544       45,636
00315.M2TS      6912 (0x1B00)   0x1B            AVC                                     324.282                 2,092                   84,793,462      464,878
00351.M2TS      4113 (0x1011)   0x1B            AVC                                     4.338                   24,918                  13,511,009      73,490
00351.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4.338                   5,444                   2,951,800       16,747
00351.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            4.338                   666                     360,960         2,115
00351.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           4.338                   233                     126,336         705
00351.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4.338                   0                       70              7
00351.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           4.338                   0                       70              7
00351.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           4.338                   14                      7,426           47
00351.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            4.338                   0                       70              7
00351.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           4.338                   200                     108,544         636
00351.M2TS      6912 (0x1B00)   0x1B            AVC                                     4.338                   6,175                   3,348,292       18,261
00317.M2TS      4113 (0x1011)   0x1B            AVC                                     542.751                 24,002                  1,628,420,581   8,857,697
00317.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           542.751                 4,676                   317,242,212     1,808,847
00317.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            542.751                 640                     43,430,400      254,475
00317.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           542.751                 224                     15,200,640      84,825
00317.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           542.751                 46                      3,131,369       17,781
00317.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           542.751                 39                      2,656,510       15,107
00317.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           542.751                 52                      3,531,626       20,009
00317.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            542.751                 0                       25,253          144
00317.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           542.751                 192                     13,029,376      76,344
00317.M2TS      6912 (0x1B00)   0x1B            AVC                                     542.751                 2,014                   136,625,862     749,290
00353.M2TS      4113 (0x1011)   0x1B            AVC                                     35.452                  24,101                  106,805,364     580,949
00353.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           35.452                  5,352                   23,715,524      134,470
00353.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            35.452                  644                     2,851,840       16,710
00353.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           35.452                  225                     998,144         5,570
00353.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           35.452                  26                      114,616         656
00353.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           35.452                  22                      95,636          554
00353.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           35.452                  41                      180,289         1,028
00353.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            35.452                  0                       70              7
00353.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           35.452                  193                     856,064         5,016
00353.M2TS      6912 (0x1B00)   0x1B            AVC                                     35.452                  3,018                   13,375,072      73,143
00319.M2TS      4113 (0x1011)   0x1B            AVC                                     324.699                 24,003                  974,228,515     5,299,289
00319.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           324.699                 5,334                   216,484,052     1,227,163
00319.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            324.699                 640                     25,986,560      152,265
00319.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           324.699                 224                     9,095,296       50,755
00319.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           324.699                 42                      1,698,764       9,601
00319.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           324.699                 38                      1,549,951       8,776
00319.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           324.699                 51                      2,078,730       11,766
00319.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            324.699                 0                       70              7
00319.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           324.699                 192                     7,796,736       45,684
00319.M2TS      6912 (0x1B00)   0x1B            AVC                                     324.699                 1,912                   77,590,821      425,742
00355.M2TS      4113 (0x1011)   0x1B            AVC                                     113.280                 24,024                  340,175,492     1,850,368
00355.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           113.280                 4,808                   68,075,892      387,657
00355.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            113.280                 641                     9,077,760       53,190
00355.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           113.280                 224                     3,177,216       17,730
00355.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           113.280                 19                      262,365         1,507
00355.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           113.280                 21                      295,886         1,689
00355.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           113.280                 24                      333,274         1,919
00355.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            113.280                 0                       70              7
00355.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           113.280                 192                     2,723,840       15,960
00355.M2TS      6912 (0x1B00)   0x1B            AVC                                     113.280                 336                     4,759,184       27,200
00321.M2TS      4113 (0x1011)   0x1B            AVC                                     794.335                 23,998                  2,382,840,623   12,961,293
00321.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           794.335                 5,145                   510,881,548     2,900,166
00321.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            794.335                 640                     63,557,120      372,405
00321.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           794.335                 224                     22,244,992      124,135
00321.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           794.335                 24                      2,357,869       13,393
00321.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           794.335                 21                      2,061,391       11,723
00321.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           794.335                 30                      2,959,672       16,822
00321.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            794.335                 0                       70              7
00321.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           794.335                 192                     19,068,928      111,732
00321.M2TS      6912 (0x1B00)   0x1B            AVC                                     794.335                 1,736                   172,397,609     946,733
00357.M2TS      4113 (0x1011)   0x1B            AVC                                     19.561                  24,151                  59,052,842      321,208
00357.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           19.561                  4,797                   11,728,660      66,812
00357.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            19.561                  645                     1,576,960       9,240
00357.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           19.561                  226                     551,936         3,080
00357.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           19.561                  9                       23,221          139
00357.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           19.561                  7                       17,325          101
00357.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           19.561                  29                      71,129          413
00357.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            19.561                  0                       70              7
00357.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           19.561                  193                     473,088         2,772
00357.M2TS      6912 (0x1B00)   0x1B            AVC                                     19.561                  338                     825,836         4,720
00323.M2TS      4113 (0x1011)   0x1B            AVC                                     363.238                 23,999                  1,089,679,567   5,927,249
00323.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           363.238                 4,793                   217,642,880     1,239,208
00323.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            363.238                 640                     29,073,920      170,355
00323.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           363.238                 224                     10,175,872      56,785
00323.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           363.238                 9                       408,080         2,367
00323.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           363.238                 8                       365,406         2,115
00323.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           363.238                 23                      1,038,277       5,985
00323.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            363.238                 0                       70              7
00323.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           363.238                 192                     8,722,432       51,108
00323.M2TS      6912 (0x1B00)   0x1B            AVC                                     363.238                 2,827                   128,381,879     702,396
00359.M2TS      4113 (0x1011)   0x1B            AVC                                     99.433                  24,039                  298,777,166     1,625,200
00359.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           99.433                  5,026                   62,470,624      354,920
00359.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            99.433                  641                     7,969,280       46,695
00359.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           99.433                  224                     2,789,248       15,565
00359.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           99.433                  43                      540,368         3,047
00359.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           99.433                  35                      434,370         2,464
00359.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           99.433                  55                      683,033         3,856
00359.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            99.433                  0                       70              7
00359.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           99.433                  192                     2,392,064       14,016
00359.M2TS      6912 (0x1B00)   0x1B            AVC                                     99.433                  336                     4,178,326       23,880
00325.M2TS      4113 (0x1011)   0x1B            AVC                                     158.867                 24,016                  476,915,881     2,594,175
00325.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           158.867                 5,284                   104,936,612     595,189
00325.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            158.867                 641                     12,720,640      74,535
00325.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           158.867                 224                     4,452,224       24,845
00325.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           158.867                 19                      386,834         2,192
00325.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           158.867                 17                      334,208         1,906
00325.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           158.867                 31                      619,670         3,526
00325.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            158.867                 0                       70              7
00325.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           158.867                 192                     3,817,472       22,368
00325.M2TS      6912 (0x1B00)   0x1B            AVC                                     158.867                 3,115                   61,864,534      338,259
00361.M2TS      4113 (0x1011)   0x1B            AVC                                     119.953                 24,018                  360,127,949     1,958,896
00361.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           119.953                 5,561                   83,377,568      471,897
00361.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            119.953                 641                     9,610,240       56,310
00361.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           119.953                 224                     3,363,584       18,770
00361.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           119.953                 17                      261,415         1,510
00361.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           119.953                 19                      288,631         1,655
00361.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           119.953                 29                      428,306         2,473
00361.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            119.953                 0                       70              7
00361.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           119.953                 192                     2,883,584       16,896
00361.M2TS      6912 (0x1B00)   0x1B            AVC                                     119.953                 2,049                   30,727,903      168,509
00327.M2TS      4113 (0x1011)   0x1B            AVC                                     361.528                 24,006                  1,084,842,671   5,900,938
00327.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           361.528                 4,713                   213,003,596     1,213,774
00327.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            361.528                 640                     28,935,680      169,545
00327.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           361.528                 224                     10,127,488      56,515
00327.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           361.528                 28                      1,284,255       7,347
00327.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           361.528                 24                      1,088,505       6,257
00327.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           361.528                 44                      1,971,393       11,219
00327.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            361.528                 0                       70              7
00327.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           361.528                 192                     8,681,472       50,868
00327.M2TS      6912 (0x1B00)   0x1B            AVC                                     361.528                 336                     15,172,705      86,720
00363.M2TS      4113 (0x1011)   0x1B            AVC                                     60.060                  24,060                  180,629,366     982,522
00363.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           60.060                  4,903                   36,812,976      209,498
00363.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            60.060                  642                     4,820,480       28,245
00363.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           60.060                  225                     1,687,168       9,415
00363.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           60.060                  62                      466,379         2,624
00363.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           60.060                  51                      383,277         2,172
00363.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           60.060                  73                      547,833         3,067
00363.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            60.060                  0                       70              7
00363.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           60.060                  193                     1,445,888       8,472
00363.M2TS      6912 (0x1B00)   0x1B            AVC                                     60.060                  337                     2,526,710       14,442
00329.M2TS      4113 (0x1011)   0x1B            AVC                                     214.172                 23,996                  642,409,432     3,494,351
00329.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           214.172                 5,576                   149,283,888     844,772
00329.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            214.172                 641                     17,149,440      100,485
00329.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           214.172                 224                     6,002,304       33,495
00329.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           214.172                 3                       67,934          397
00329.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           214.172                 2                       65,542          385
00329.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           214.172                 11                      300,800         1,763
00329.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            214.172                 0                       70              7
00329.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           214.172                 192                     5,144,576       30,144
00329.M2TS      6912 (0x1B00)   0x1B            AVC                                     214.172                 2,052                   54,947,974      301,324
00348.M2TS      4113 (0x1011)   0x1B            AVC                                     138.138                 24,020                  414,763,672     2,256,096
00348.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           138.138                 4,427                   76,440,016      436,500
00348.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            138.138                 641                     11,066,880      64,845
00348.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           138.138                 224                     3,873,408       21,615
00348.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           138.138                 7                       126,532         770
00348.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           138.138                 6                       109,211         653
00348.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           138.138                 21                      360,733         2,166
00348.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            138.138                 0                       70              7
00348.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           138.138                 192                     3,319,808       19,452
00348.M2TS      6912 (0x1B00)   0x1B            AVC                                     138.138                 336                     5,801,930       33,162
00331.M2TS      4113 (0x1011)   0x1B            AVC                                     470.762                 23,993                  1,411,879,598   7,679,895
00331.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           470.762                 4,721                   277,803,304     1,583,166
00331.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            470.762                 640                     37,675,520      220,755
00331.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           470.762                 224                     13,186,432      73,585
00331.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           470.762                 38                      2,246,232       12,687
00331.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           470.762                 32                      1,894,074       10,753
00331.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           470.762                 55                      3,249,837       18,466
00331.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            470.762                 0                       70              7
00331.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           470.762                 192                     11,302,912      66,228
00331.M2TS      6912 (0x1B00)   0x1B            AVC                                     470.762                 958                     56,352,582      311,923
00350.M2TS      4113 (0x1011)   0x1B            AVC                                     51.051                  24,064                  153,561,598     835,282
00350.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           51.051                  5,109                   32,603,852      185,147
00350.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            51.051                  642                     4,098,560       24,015
00350.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           51.051                  225                     1,434,496       8,005
00350.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           51.051                  2                       15,370          90
00350.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           51.051                  2                       14,801          87
00350.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           51.051                  5                       32,948          200
00350.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            51.051                  0                       70              7
00350.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           51.051                  193                     1,230,848       7,212
00350.M2TS      6912 (0x1B00)   0x1B            AVC                                     51.051                  337                     2,148,800       12,282
00333.M2TS      4113 (0x1011)   0x1B            AVC                                     606.523                 23,991                  1,818,892,588   9,893,771
00333.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           606.523                 5,399                   409,328,468     2,319,097
00333.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            606.523                 640                     48,537,600      284,400
00333.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           606.523                 224                     16,988,160      94,800
00333.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           606.523                 6                       441,899         2,547
00333.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           606.523                 7                       497,084         2,871
00333.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           606.523                 17                      1,251,940       7,264
00333.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            606.523                 2                       149,019         857
00333.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           606.523                 192                     14,561,280      85,320
00333.M2TS      6912 (0x1B00)   0x1B            AVC                                     606.523                 1,651                   125,146,781     687,642
00352.M2TS      4113 (0x1011)   0x1B            AVC                                     9.176                   24,422                  28,011,535      152,372
00352.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           9.176                   5,015                   5,752,084       32,738
00352.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            9.176                   652                     747,520         4,380
00352.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           9.176                   228                     261,632         1,460
00352.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           9.176                   0                       70              7
00352.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           9.176                   0                       70              7
00352.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           9.176                   17                      19,286          118
00352.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            9.176                   0                       70              7
00352.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           9.176                   196                     225,280         1,320
00352.M2TS      6912 (0x1B00)   0x1B            AVC                                     9.176                   342                     392,224         2,240
00335.M2TS      4113 (0x1011)   0x1B            AVC                                     32.032                  24,108                  96,527,930      525,062
00335.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           32.032                  4,692                   18,785,452      107,117
00335.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            32.032                  644                     2,577,920       15,105
00335.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           32.032                  225                     902,272         5,035
00335.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           32.032                  0                       70              7
00335.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           32.032                  0                       70              7
00335.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           32.032                  11                      45,256          273
00335.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            32.032                  0                       70              7
00335.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           32.032                  193                     774,144         4,536
00335.M2TS      6912 (0x1B00)   0x1B            AVC                                     32.032                  337                     1,350,990       7,722
00354.M2TS      4113 (0x1011)   0x1B            AVC                                     120.162                 24,026                  360,873,508     1,962,962
00354.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           120.162                 4,857                   72,957,868      415,292
00354.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            120.162                 641                     9,628,160       56,415
00354.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           120.162                 224                     3,369,856       18,805
00354.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           120.162                 0                       70              7
00354.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           120.162                 1                       14,148          84
00354.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           120.162                 2                       35,745          208
00354.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            120.162                 1                       10,406          63
00354.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           120.162                 192                     2,889,728       16,932
00354.M2TS      6912 (0x1B00)   0x1B            AVC                                     120.162                 1,344                   20,183,437      111,163
00337.M2TS      4113 (0x1011)   0x1B            AVC                                     110.527                 24,023                  331,904,478     1,805,372
00337.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           110.527                 4,853                   67,043,232      381,698
00337.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            110.527                 641                     8,852,480       51,870
00337.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           110.527                 224                     3,098,368       17,290
00337.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           110.527                 0                       70              7
00337.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           110.527                 38                      530,797         3,020
00337.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           110.527                 1                       17,637          103
00337.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            110.527                 42                      584,025         3,312
00337.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           110.527                 192                     2,656,256       15,564
00337.M2TS      6912 (0x1B00)   0x1B            AVC                                     110.527                 2,041                   28,199,654      154,634
00356.M2TS      4113 (0x1011)   0x1B            AVC                                     16.850                  24,161                  50,889,182      276,811
00356.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           16.850                  4,644                   9,781,164       55,840
00356.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            16.850                  645                     1,359,360       7,965
00356.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           16.850                  226                     475,776         2,655
00356.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           16.850                  0                       70              7
00356.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           16.850                  0                       70              7
00356.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           16.850                  0                       70              7
00356.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            16.850                  16                      33,427          186
00356.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           16.850                  193                     407,552         2,388
00356.M2TS      6912 (0x1B00)   0x1B            AVC                                     16.850                  338                     712,090         4,070
00339.M2TS      4113 (0x1011)   0x1B            AVC                                     143.644                 24,009                  431,095,814     2,344,936
00339.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           143.644                 5,372                   96,464,560      546,697
00339.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            143.644                 641                     11,507,200      67,425
00339.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           143.644                 224                     4,027,520       22,475
00339.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           143.644                 1                       20,843          120
00339.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           143.644                 12                      221,038         1,248
00339.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           143.644                 9                       168,634         1,002
00339.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            143.644                 12                      211,953         1,199
00339.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           143.644                 192                     3,452,928       20,232
00339.M2TS      6912 (0x1B00)   0x1B            AVC                                     143.644                 2,478                   44,498,468      243,661
00358.M2TS      4113 (0x1011)   0x1B            AVC                                     123.624                 24,014                  371,080,326     2,018,456
00358.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           123.624                 5,994                   92,625,508      522,777
00358.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            123.624                 641                     9,904,640       58,035
00358.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           123.624                 224                     3,466,624       19,345
00358.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           123.624                 6                       100,138         591
00358.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           123.624                 3                       50,522          302
00358.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           123.624                 23                      352,652         2,066
00358.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            123.624                 0                       70              7
00358.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           123.624                 192                     2,971,648       17,412
00358.M2TS      6912 (0x1B00)   0x1B            AVC                                     123.624                 2,492                   38,503,647      210,813
00341.M2TS      4113 (0x1011)   0x1B            AVC                                     169.086                 24,018                  507,636,580     2,761,262
00341.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           169.086                 4,692                   99,169,876      565,431
00341.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            169.086                 641                     13,542,400      79,350
00341.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           169.086                 224                     4,739,840       26,450
00341.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           169.086                 51                      1,087,238       6,123
00341.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           169.086                 42                      895,832         5,106
00341.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           169.086                 60                      1,263,646       7,117
00341.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            169.086                 4                       95,052          558
00341.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           169.086                 192                     4,063,232       23,808
00341.M2TS      6912 (0x1B00)   0x1B            AVC                                     169.086                 672                     14,199,955      79,183
00360.M2TS      4113 (0x1011)   0x1B            AVC                                     16.767                  24,169                  50,654,260      275,532
00360.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           16.767                  5,408                   11,333,456      64,203
00360.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            16.767                  645                     1,351,680       7,920
00360.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           16.767                  226                     473,088         2,640
00360.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           16.767                  0                       70              7
00360.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           16.767                  0                       70              7
00360.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           16.767                  14                      28,929          171
00360.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            16.767                  0                       70              7
00360.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           16.767                  193                     405,504         2,376
00360.M2TS      6912 (0x1B00)   0x1B            AVC                                     16.767                  338                     708,597         4,050
00343.M2TS      4113 (0x1011)   0x1B            AVC                                     509.426                 24,002                  1,528,415,464   8,313,734
00343.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           509.426                 5,067                   322,646,416     1,832,899
00343.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            509.426                 640                     40,768,000      238,875
00343.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           509.426                 224                     14,268,800      79,625
00343.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           509.426                 8                       536,860         3,070
00343.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           509.426                 12                      783,698         4,513
00343.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           509.426                 23                      1,451,203       8,369
00343.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            509.426                 6                       357,436         2,059
00343.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           509.426                 192                     12,230,656      71,664
00343.M2TS      6912 (0x1B00)   0x1B            AVC                                     509.426                 721                     45,942,464      255,755
00362.M2TS      4113 (0x1011)   0x1B            AVC                                     16.225                  24,248                  49,176,169      267,484
00362.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           16.225                  5,876                   11,916,904      67,321
00362.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            16.225                  648                     1,313,280       7,695
00362.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           16.225                  227                     459,648         2,565
00362.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           16.225                  0                       70              7
00362.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           16.225                  0                       70              7
00362.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           16.225                  7                       14,406          85
00362.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            16.225                  0                       70              7
00362.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           16.225                  195                     395,264         2,316
00362.M2TS      6912 (0x1B00)   0x1B            AVC                                     16.225                  339                     687,904         3,930
00345.M2TS      4113 (0x1011)   0x1B            AVC                                     1278.694                23,993                  3,834,901,579   20,859,814
00345.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1278.694                5,719                   914,126,908     5,167,476
00345.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1278.694                640                     102,310,400     599,475
00345.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1278.694                224                     35,808,640      199,825
00345.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1278.694                6                       913,610         5,277
00345.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           1278.694                5                       827,344         4,796
00345.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           1278.694                15                      2,380,871       13,781
00345.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            1278.694                1                       101,850         580
00345.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           1278.694                192                     30,693,376      179,844
00345.M2TS      6912 (0x1B00)   0x1B            AVC                                     1278.694                1,467                   234,416,260     1,289,716
Theatrical:
Code:
        Total   Video
00004.MPLS                                                      AVC     2:00:47 30,367,953,216  43,711,210,365  33.52   24.01   DTS-HD Master 7.1 5147Kbps (48kHz/24-bit)
Code:
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:00:47 (h:m:s)
Total Bitrate:          33.52 Mbps
VIDEO:
* MPEG-4 AVC Video      1456 kbps           480p / 23.976 fps / 4:3 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         5147 kbps       7.1 / 48 kHz / 5147 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         19.218 kbps
Presentation Graphics           Spanish         18.336 kbps
Presentation Graphics           English         29.186 kbps
Presentation Graphics           French          1.833 kbps
FILES:
00312.M2TS      0:00:00.000     0:02:58.595     733,038,912     32,836
00313.M2TS      0:02:58.595     0:01:18.953     320,188,416     32,443
00314.M2TS      0:04:17.548     0:00:54.512     220,753,920     32,397
00315.M2TS      0:05:12.061     0:05:24.449     1,374,818,304   33,899
00316.M2TS      0:10:36.510     0:00:04.546     20,287,488      35,700
00317.M2TS      0:10:41.057     0:09:02.875     2,285,322,240   33,677
00318.M2TS      0:19:43.932     0:00:35.702     145,274,880     32,552
00319.M2TS      0:20:19.635     0:05:24.824     1,390,454,784   34,245
00320.M2TS      0:25:44.459     0:00:53.178     211,488,768     31,816
00321.M2TS      0:26:37.637     0:13:14.460     3,357,124,608   33,805
00322.M2TS      0:39:52.097     0:00:19.769     79,841,280      32,308
00323.M2TS      0:40:11.867     0:06:03.404     1,568,593,920   34,531
00324.M2TS      0:46:15.272     0:01:12.489     290,770,944     32,090
00325.M2TS      0:47:27.761     0:02:38.992     703,168,512     35,381
00326.M2TS      0:50:06.753     0:00:14.764     62,717,952      33,983
00327.M2TS      0:50:21.518     0:06:01.694     1,442,942,976   31,915
00328.M2TS      0:56:23.213     0:00:30.822     124,815,360     32,396
00329.M2TS      0:56:54.035     0:03:34.339     924,346,368     34,500
00330.M2TS      1:00:28.374     0:02:18.429     541,562,880     31,297
00331.M2TS      1:02:46.804     0:07:50.928     1,918,703,616   32,594
00332.M2TS      1:10:37.733     0:00:51.259     206,966,784     32,301
00333.M2TS      1:11:28.992     0:10:06.689     2,572,591,104   33,923
00334.M2TS      1:21:35.682     0:00:09.426     39,444,480      33,477
00335.M2TS      1:21:45.108     0:00:32.198     127,862,784     31,768
00336.M2TS      1:22:17.307     0:00:27.610     111,065,088     32,180
00337.M2TS      1:22:44.918     0:01:50.652     467,822,592     33,823
00338.M2TS      1:24:35.570     0:00:17.017     68,782,080      32,336
00339.M2TS      1:24:52.587     0:02:23.810     624,734,208     34,753
00340.M2TS      1:27:16.397     0:00:32.782     137,177,088     33,475
00341.M2TS      1:27:49.180     0:02:49.252     683,532,288     32,308
00342.M2TS      1:30:38.432     0:00:03.837     17,221,632      35,905
00343.M2TS      1:30:42.269     0:08:29.592     2,078,908,416   32,636
00344.M2TS      1:39:11.862     0:00:16.599     69,851,136      33,663
00345.M2TS      1:39:28.462     0:21:18.860     5,445,777,408   34,066
CHAPTERS:
1               0:00:00.000     0:02:49.085     24,213 kbps     30,633 kbps     00:02:46.374    29,640 kbps     00:02:44.038    29,007 kbps     00:02:39.033    126,204 bytes   330,638 bytes   00:02:22.058
2               0:02:49.085     0:02:01.579     25,498 kbps     33,629 kbps     00:02:51.963    32,947 kbps     00:02:49.919    32,112 kbps     00:02:49.085    132,935 bytes   324,590 bytes   00:04:31.312
3               0:04:50.665     0:03:42.722     23,061 kbps     30,250 kbps     00:05:36.878    29,505 kbps     00:06:10.161    28,955 kbps     00:05:24.574    120,230 bytes   339,554 bytes   00:08:33.387
4               0:08:33.387     0:01:49.317     24,736 kbps     32,055 kbps     00:10:16.240    28,789 kbps     00:10:14.238    28,070 kbps     00:10:12.695    128,963 bytes   349,897 bytes   00:08:34.388
5               0:10:22.705     0:09:21.227     24,042 kbps     32,688 kbps     00:15:36.935    27,833 kbps     00:15:35.851    27,091 kbps     00:10:58.032    125,342 bytes   353,003 bytes   00:15:37.519
6               0:19:43.932     0:06:14.874     24,069 kbps     32,675 kbps     00:22:09.369    29,668 kbps     00:23:20.565    29,384 kbps     00:23:20.524    125,486 bytes   267,193 bytes   00:25:40.705
7               0:25:58.807     0:04:33.064     26,505 kbps     34,839 kbps     00:28:05.016    32,863 kbps     00:29:41.654    32,592 kbps     00:29:39.194    138,184 bytes   278,332 bytes   00:29:59.714
8               0:30:31.871     0:02:42.662     22,732 kbps     28,833 kbps     00:30:39.087    27,573 kbps     00:31:53.286    26,151 kbps     00:32:26.778    118,516 bytes   259,258 bytes   00:32:27.236
9               0:33:14.534     0:08:34.138     23,220 kbps     32,705 kbps     00:38:19.338    29,756 kbps     00:41:09.341    28,492 kbps     00:41:06.213    121,060 bytes   347,987 bytes   00:38:15.084
10              0:41:48.672     0:06:07.742     23,860 kbps     31,157 kbps     00:43:56.091    28,941 kbps     00:43:52.463    28,121 kbps     00:46:43.175    124,397 bytes   324,215 bytes   00:43:33.944
11              0:47:56.415     0:02:35.822     23,106 kbps     33,259 kbps     00:48:22.774    31,297 kbps     00:48:19.396    29,338 kbps     00:48:14.349    120,462 bytes   299,773 bytes   00:49:20.749
12              0:50:32.237     0:05:50.975     24,210 kbps     30,755 kbps     00:52:32.649    29,679 kbps     00:52:17.008    28,738 kbps     00:52:16.091    126,220 bytes   239,646 bytes   00:54:19.214
13              0:56:23.213     0:10:59.533     23,427 kbps     31,665 kbps     00:56:54.244    29,224 kbps     00:57:23.439    28,011 kbps     00:58:33.634    122,135 bytes   221,410 bytes   01:07:08.107
14              1:07:22.746     0:03:53.274     25,295 kbps     32,054 kbps     01:09:04.640    29,813 kbps     01:08:56.715    29,038 kbps     01:08:57.174    131,877 bytes   269,779 bytes   01:09:29.289
15              1:11:16.021     0:07:10.096     24,877 kbps     33,198 kbps     01:14:51.361    31,931 kbps     01:11:21.860    31,028 kbps     01:17:51.625    129,696 bytes   254,919 bytes   01:17:55.795
16              1:18:26.117     0:03:05.476     22,320 kbps     33,773 kbps     01:18:27.452    28,224 kbps     01:19:32.100    27,295 kbps     01:19:30.640    116,365 bytes   290,002 bytes   01:19:14.457
17              1:21:31.594     0:03:14.193     24,108 kbps     30,210 kbps     01:24:34.652    28,319 kbps     01:24:38.906    28,044 kbps     01:24:34.193    125,686 bytes   240,925 bytes   01:24:35.570
18              1:24:45.788     0:09:34.448     23,616 kbps     32,749 kbps     01:27:13.519    30,317 kbps     01:27:10.933    28,918 kbps     01:32:23.204    123,123 bytes   349,274 bytes   01:25:36.297
19              1:34:20.237     0:02:31.526     24,151 kbps     34,507 kbps     01:35:56.583    32,330 kbps     01:35:40.859    30,146 kbps     01:35:38.232    125,914 bytes   268,883 bytes   01:36:45.549
20              1:36:51.763     0:03:48.728     27,374 kbps     34,267 kbps     01:38:37.494    33,029 kbps     01:40:12.339    32,933 kbps     01:40:07.334    142,716 bytes   308,896 bytes   01:40:02.996
21              1:40:40.492     0:08:47.068     30,297 kbps     34,217 kbps     01:47:05.919    33,032 kbps     01:48:03.351    32,916 kbps     01:48:10.525    157,956 bytes   297,702 bytes   01:42:44.699
22              1:49:27.560     0:03:15.320     30,434 kbps     33,812 kbps     01:52:00.838    32,991 kbps     01:49:45.203    32,772 kbps     01:49:52.710    158,671 bytes   328,546 bytes   01:51:49.035
23              1:52:42.880     0:01:52.862     28,819 kbps     35,512 kbps     01:54:04.253    33,262 kbps     01:54:00.208    32,807 kbps     01:52:56.894    150,248 bytes   276,820 bytes   01:54:15.598
24              1:54:35.743     0:06:11.579     8,524 kbps      16,260 kbps     02:00:40.316    14,640 kbps     02:00:37.438    12,263 kbps     02:00:34.935    44,446 bytes    242,149 bytes   02:00:41.108
STREAM DIAGNOSTICS:
00312.M2TS      4113 (0x1011)   0x1B            AVC                                     188.522                 23,990                  565,335,700     3,075,103
00312.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           188.522                 5,169                   121,797,412     691,002
00312.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            188.522                 641                     15,096,320      88,455
00312.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           188.522                 224                     5,283,712       29,485
00312.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           188.522                 0                       70              7
00312.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           188.522                 2                       36,723          213
00312.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           188.522                 3                       65,921          379
00312.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            188.522                 0                       70              7
00312.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           188.522                 192                     4,530,176       26,544
00312.M2TS      6912 (0x1B00)   0x1B            AVC                                     188.522                 89                      2,091,488       11,405
00314.M2TS      4113 (0x1011)   0x1B            AVC                                     54.346                  24,055                  163,412,007     888,861
00314.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           54.346                  5,267                   35,780,616      202,906
00314.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            54.346                  642                     4,362,240       25,560
00314.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           54.346                  225                     1,526,784       8,520
00314.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           54.346                  17                      115,126         646
00314.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           54.346                  23                      157,075         895
00314.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           54.346                  30                      206,227         1,162
00314.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            54.346                  8                       51,593          294
00314.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           54.346                  193                     1,308,672       7,668
00314.M2TS      6912 (0x1B00)   0x1B            AVC                                     54.346                  308                     2,091,488       11,405
00316.M2TS      4113 (0x1011)   0x1B            AVC                                     4.379                   24,907                  13,634,537      74,162
00316.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4.379                   5,253                   2,875,464       16,339
00316.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            4.379                   669                     366,080         2,145
00316.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           4.379                   234                     128,128         715
00316.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4.379                   0                       70              7
00316.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           4.379                   0                       70              7
00316.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           4.379                   14                      7,426           47
00316.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            4.379                   0                       70              7
00316.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           4.379                   202                     110,592         648
00316.M2TS      6912 (0x1B00)   0x1B            AVC                                     4.379                   3,821                   2,091,488       11,405
00318.M2TS      4113 (0x1011)   0x1B            AVC                                     35.536                  24,110                  107,093,612     582,538
00318.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           35.536                  5,234                   23,247,888      131,904
00318.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            35.536                  643                     2,856,960       16,740
00318.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           35.536                  225                     999,936         5,580
00318.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           35.536                  26                      114,616         656
00318.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           35.536                  22                      95,636          554
00318.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           35.536                  41                      180,289         1,028
00318.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            35.536                  0                       70              7
00318.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           35.536                  193                     858,112         5,028
00318.M2TS      6912 (0x1B00)   0x1B            AVC                                     35.536                  471                     2,091,488       11,405
00320.M2TS      4113 (0x1011)   0x1B            AVC                                     53.011                  24,075                  159,533,506     867,761
00320.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           53.011                  4,683                   31,034,268      176,960
00320.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            53.011                  642                     4,254,720       24,930
00320.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           53.011                  225                     1,489,152       8,310
00320.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           53.011                  22                      147,138         861
00320.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           53.011                  28                      183,826         1,060
00320.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           53.011                  24                      159,652         928
00320.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            53.011                  0                       70              7
00320.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           53.011                  193                     1,277,952       7,488
00320.M2TS      6912 (0x1B00)   0x1B            AVC                                     53.011                  316                     2,091,488       11,405
00322.M2TS      4113 (0x1011)   0x1B            AVC                                     19.603                  24,199                  59,296,158      322,545
00322.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           19.603                  4,682                   11,471,504      65,400
00322.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            19.603                  646                     1,582,080       9,270
00322.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           19.603                  226                     553,728         3,090
00322.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           19.603                  9                       23,221          139
00322.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           19.603                  7                       17,325          101
00322.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           19.603                  29                      71,129          413
00322.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            19.603                  0                       70              7
00322.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           19.603                  194                     475,136         2,784
00322.M2TS      6912 (0x1B00)   0x1B            AVC                                     19.603                  854                     2,091,488       11,405
00324.M2TS      4113 (0x1011)   0x1B            AVC                                     72.322                  24,044                  217,367,778     1,182,359
00324.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           72.322                  5,023                   45,411,292      258,121
00324.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            72.322                  642                     5,800,960       33,990
00324.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           72.322                  225                     2,030,336       11,330
00324.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           72.322                  28                      256,680         1,444
00324.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           72.322                  25                      225,440         1,274
00324.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           72.322                  36                      328,521         1,869
00324.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            72.322                  0                       70              7
00324.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           72.322                  193                     1,740,800       10,200
00324.M2TS      6912 (0x1B00)   0x1B            AVC                                     72.322                  231                     2,091,488       11,405
00326.M2TS      4113 (0x1011)   0x1B            AVC                                     14.598                  24,272                  44,289,693      240,912
00326.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           14.598                  6,017                   10,980,208      61,982
00326.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            14.598                  648                     1,182,720       6,930
00326.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           14.598                  227                     413,952         2,310
00326.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           14.598                  13                      23,123          132
00326.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           14.598                  16                      29,926          169
00326.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           14.598                  21                      37,809          219
00326.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            14.598                  0                       70              7
00326.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           14.598                  195                     356,352         2,088
00326.M2TS      6912 (0x1B00)   0x1B            AVC                                     14.598                  1,146                   2,091,488       11,405
00328.M2TS      4113 (0x1011)   0x1B            AVC                                     30.656                  24,109                  92,385,566      502,526
00328.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           30.656                  5,013                   19,209,844      109,160
00328.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            30.656                  644                     2,467,840       14,460
00328.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           30.656                  225                     863,744         4,820
00328.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           30.656                  34                      130,686         737
00328.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           30.656                  23                      88,897          510
00328.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           30.656                  49                      189,085         1,062
00328.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            30.656                  0                       70              7
00328.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           30.656                  193                     741,376         4,344
00328.M2TS      6912 (0x1B00)   0x1B            AVC                                     30.656                  546                     2,091,488       11,405
00330.M2TS      4113 (0x1011)   0x1B            AVC                                     138.263                 24,020                  415,140,503     2,258,135
00330.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           138.263                 4,424                   76,457,560      436,851
00330.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            138.263                 641                     11,074,560      64,890
00330.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           138.263                 224                     3,876,096       21,630
00330.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           138.263                 7                       126,532         770
00330.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           138.263                 6                       109,211         653
00330.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           138.263                 21                      360,733         2,166
00330.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            138.263                 0                       70              7
00330.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           138.263                 192                     3,323,904       19,476
00330.M2TS      6912 (0x1B00)   0x1B            AVC                                     138.263                 121                     2,091,488       11,405
00332.M2TS      4113 (0x1011)   0x1B            AVC                                     51.093                  24,065                  153,690,247     835,995
00332.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           51.093                  5,218                   33,323,544      189,182
00332.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            51.093                  642                     4,101,120       24,030
00332.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           51.093                  225                     1,435,392       8,010
00332.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           51.093                  2                       15,370          90
00332.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           51.093                  2                       14,801          87
00332.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           51.093                  5                       32,948          200
00332.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            51.093                  0                       70              7
00332.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           51.093                  193                     1,230,848       7,212
00332.M2TS      6912 (0x1B00)   0x1B            AVC                                     51.093                  327                     2,091,488       11,405
00334.M2TS      4113 (0x1011)   0x1B            AVC                                     9.259                   24,426                  28,270,272      153,776
00334.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           9.259                   4,941                   5,718,252       32,544
00334.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            9.259                   652                     755,200         4,425
00334.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           9.259                   228                     264,320         1,475
00334.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           9.259                   0                       70              7
00334.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           9.259                   0                       70              7
00334.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           9.259                   17                      19,286          118
00334.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            9.259                   0                       70              7
00334.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           9.259                   196                     227,328         1,332
00334.M2TS      6912 (0x1B00)   0x1B            AVC                                     9.259                   1,807                   2,091,488       11,405
00336.M2TS      4113 (0x1011)   0x1B            AVC                                     27.444                  24,143                  82,821,833      450,511
00336.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           27.444                  4,818                   16,526,932      94,169
00336.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            27.444                  644                     2,209,280       12,945
00336.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           27.444                  225                     773,248         4,315
00336.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           27.444                  0                       70              7
00336.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           27.444                  4                       14,148          84
00336.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           27.444                  7                       24,741          141
00336.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            27.444                  3                       10,406          63
00336.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           27.444                  193                     663,552         3,888
00336.M2TS      6912 (0x1B00)   0x1B            AVC                                     27.444                  610                     2,091,488       11,405
00338.M2TS      4113 (0x1011)   0x1B            AVC                                     16.892                  24,173                  51,041,699      277,644
00338.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           16.892                  4,607                   9,728,576       55,523
00338.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            16.892                  645                     1,361,920       7,980
00338.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           16.892                  226                     476,672         2,660
00338.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           16.892                  0                       70              7
00338.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           16.892                  0                       70              7
00338.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           16.892                  0                       70              7
00338.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            16.892                  0                       70              7
00338.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           16.892                  194                     409,600         2,400
00338.M2TS      6912 (0x1B00)   0x1B            AVC                                     16.892                  991                     2,091,488       11,405
00340.M2TS      4113 (0x1011)   0x1B            AVC                                     32.658                  24,093                  98,353,137      534,989
00340.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           32.658                  6,109                   24,939,976      140,659
00340.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            32.658                  643                     2,624,000       15,375
00340.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           32.658                  225                     918,400         5,125
00340.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           32.658                  19                      76,397          449
00340.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           32.658                  9                       34,888          210
00340.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           32.658                  22                      88,293          514
00340.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            32.658                  0                       70              7
00340.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           32.658                  193                     788,480         4,620
00340.M2TS      6912 (0x1B00)   0x1B            AVC                                     32.658                  512                     2,091,488       11,405
00342.M2TS      4113 (0x1011)   0x1B            AVC                                     3.712                   24,810                  11,511,872      62,616
00342.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           3.712                   4,749                   2,203,724       12,570
00342.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            3.712                   662                     307,200         1,800
00342.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           3.712                   232                     107,520         600
00342.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           3.712                   0                       70              7
00342.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           3.712                   0                       70              7
00342.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           3.712                   0                       70              7
00342.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            3.712                   0                       70              7
00342.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           3.712                   199                     92,160          540
00342.M2TS      6912 (0x1B00)   0x1B            AVC                                     3.712                   4,507                   2,091,488       11,405
00344.M2TS      4113 (0x1011)   0x1B            AVC                                     16.433                  24,243                  49,798,585      270,872
00344.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           16.433                  5,871                   12,059,404      68,133
00344.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            16.433                  647                     1,328,640       7,785
00344.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           16.433                  226                     465,024         2,595
00344.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           16.433                  0                       70              7
00344.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           16.433                  0                       70              7
00344.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           16.433                  7                       14,406          85
00344.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            16.433                  0                       70              7
00344.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           16.433                  194                     399,360         2,340
00344.M2TS      6912 (0x1B00)   0x1B            AVC                                     16.433                  1,018                   2,091,488       11,405
Clearly some more analysis needs to be done on this. I was just checking out the disc when I noticed it was AVC. I haven't watched it or anything so just enjoy the stats for now!
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is online now
post #1049 of 5106 Old 01-04-2010, 09:52 PM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Lionsgate and conspiracy theories go hand in hand.
Blu-ray : 340
lgans316 is offline
post #1050 of 5106 Old 01-05-2010, 03:00 PM
Burrito's Avatar
Studio: Warner Bros. Pictures
UPC: 7321983000416
Release Date: 2007-12-07
Aspect Ratio: 2.40:1
Code:
        Total   Video
00001.MPLS                                                      VC-1    1:57:36 25.061.763.072  28.930.071.980  28,41   16,87   Dolby TrueHD 5.1 3766Kbps (48kHz/24-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     BLADERUNNER_FINAL_EU
Disc Size:      28.930.071.980 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:57:36 (h:m:s)
Total Bitrate:          28,41 Mbps
VIDEO:
VC-1 Video              16875 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         3766 kbps       5.1 / 48 kHz / 3766 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Italian         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         15,001 kbps
Presentation Graphics           English         17,149 kbps
Presentation Graphics           Danish          15,531 kbps
Presentation Graphics           Dutch           13,621 kbps
Presentation Graphics           Finnish         16,080 kbps
Presentation Graphics           French          13,858 kbps
Presentation Graphics           German          17,299 kbps
Presentation Graphics           German          19,350 kbps
Presentation Graphics           Italian         16,155 kbps
Presentation Graphics           Italian         18,521 kbps
Presentation Graphics           Norwegian       14,183 kbps
Presentation Graphics           Portuguese      15,133 kbps
Presentation Graphics           Spanish         13,824 kbps
Presentation Graphics           Swedish         14,211 kbps
FILES:
00047.M2TS      0:00:00.000     1:57:36.841     25.061.763.072  28.411
CHAPTERS:
1               0:00:00.000     0:02:58.178     4.101 kbps      17.199 kbps     00:02:18.054    16.167 kbps     00:02:16.970    15.906 kbps     00:02:17.095    24.343 bytes    217.481 bytes   00:02:38.741
2               0:02:58.178     0:01:33.802     16.771 kbps     31.446 kbps     00:03:07.103    20.440 kbps     00:03:06.728    19.720 kbps     00:03:50.563    89.261 bytes    306.321 bytes   00:04:16.589
3               0:04:31.980     0:02:54.132     17.881 kbps     23.064 kbps     00:06:19.379    20.099 kbps     00:06:17.418    19.175 kbps     00:05:33.249    93.225 bytes    206.877 bytes   00:07:25.695
4               0:07:26.112     0:03:52.148     17.337 kbps     21.512 kbps     00:10:23.497    20.429 kbps     00:08:13.367    19.091 kbps     00:08:08.571    90.389 bytes    213.218 bytes   00:07:32.702
5               0:11:18.260     0:01:40.308     17.218 kbps     20.106 kbps     00:12:16.318    19.068 kbps     00:12:14.817    18.355 kbps     00:12:09.812    89.766 bytes    206.004 bytes   00:12:13.065
6               0:12:58.569     0:03:59.614     17.432 kbps     22.841 kbps     00:15:50.866    20.289 kbps     00:15:48.656    18.912 kbps     00:15:48.280    90.882 bytes    271.078 bytes   00:16:35.244
7               0:16:58.183     0:05:40.631     17.516 kbps     25.336 kbps     00:20:22.554    20.050 kbps     00:21:03.512    19.274 kbps     00:21:03.345    91.318 bytes    229.725 bytes   00:20:22.971
8               0:22:38.815     0:02:26.062     17.861 kbps     23.037 kbps     00:23:11.473    20.029 kbps     00:23:08.345    19.037 kbps     00:23:05.717    93.117 bytes    269.767 bytes   00:24:30.802
9               0:25:04.878     0:02:53.464     17.619 kbps     23.933 kbps     00:25:18.058    21.963 kbps     00:25:14.179    20.196 kbps     00:25:11.092    91.859 bytes    226.853 bytes   00:25:09.549
10              0:27:58.343     0:02:23.143     17.429 kbps     22.256 kbps     00:29:49.537    19.289 kbps     00:28:43.722    19.004 kbps     00:28:43.847    90.866 bytes    254.362 bytes   00:29:51.498
11              0:30:21.486     0:05:57.690     17.515 kbps     25.782 kbps     00:32:15.975    20.995 kbps     00:32:11.971    20.377 kbps     00:32:06.966    91.314 bytes    379.041 bytes   00:32:16.935
12              0:36:19.176     0:05:11.144     17.627 kbps     23.604 kbps     00:40:24.255    21.530 kbps     00:40:20.501    20.101 kbps     00:40:20.251    91.900 bytes    259.641 bytes   00:41:02.668
13              0:41:30.321     0:00:53.678     17.800 kbps     21.058 kbps     00:42:04.104    19.464 kbps     00:42:17.576    18.714 kbps     00:41:57.181    92.804 bytes    217.679 bytes   00:42:04.522
14              0:42:23.999     0:03:32.337     17.569 kbps     25.297 kbps     00:42:42.977    21.916 kbps     00:45:28.684    20.303 kbps     00:45:27.683    91.598 bytes    290.152 bytes   00:42:57.241
15              0:45:56.336     0:02:48.126     17.612 kbps     23.353 kbps     00:46:18.692    19.893 kbps     00:46:17.024    19.246 kbps     00:48:13.015    91.819 bytes    227.360 bytes   00:46:19.693
16              0:48:44.463     0:06:34.435     17.574 kbps     26.494 kbps     00:48:46.965    21.577 kbps     00:48:44.463    19.788 kbps     00:48:44.463    91.621 bytes    205.082 bytes   00:52:22.180
17              0:55:18.898     0:02:08.378     17.604 kbps     25.550 kbps     00:55:47.844    20.087 kbps     00:55:44.007    18.821 kbps     00:55:43.715    91.780 bytes    244.017 bytes   00:55:30.076
18              0:57:27.277     0:02:17.720     17.554 kbps     22.230 kbps     00:58:52.820    19.062 kbps     00:58:51.402    18.469 kbps     00:57:39.789    91.518 bytes    245.362 bytes   00:58:41.809
19              0:59:44.998     0:02:04.415     17.518 kbps     22.607 kbps     01:00:04.267    19.297 kbps     01:00:35.089    18.712 kbps     01:00:31.753    91.331 bytes    193.395 bytes   00:59:57.302
20              1:01:49.414     0:01:28.588     17.579 kbps     21.537 kbps     01:02:01.592    19.198 kbps     01:02:29.287    18.387 kbps     01:01:55.086    91.650 bytes    191.261 bytes   01:02:33.291
21              1:03:18.002     0:04:26.391     17.511 kbps     24.387 kbps     01:07:25.416    20.035 kbps     01:05:10.865    19.227 kbps     01:05:06.903    91.295 bytes    297.535 bytes   01:05:30.176
22              1:07:44.393     0:04:55.128     17.571 kbps     27.436 kbps     01:12:05.070    19.834 kbps     01:12:03.068    18.782 kbps     01:08:37.655    91.605 bytes    232.495 bytes   01:12:05.362
23              1:12:39.521     0:03:34.005     17.533 kbps     23.425 kbps     01:13:26.860    20.867 kbps     01:13:25.025    19.422 kbps     01:13:23.315    91.407 bytes    226.418 bytes   01:13:26.985
24              1:16:13.527     0:03:58.947     17.507 kbps     23.439 kbps     01:17:59.299    19.656 kbps     01:17:55.337    18.853 kbps     01:18:23.865    91.273 bytes    230.757 bytes   01:20:04.299
25              1:20:12.474     0:02:22.058     17.314 kbps     22.082 kbps     01:20:45.757    19.661 kbps     01:20:44.047    18.530 kbps     01:20:44.047    90.268 bytes    290.865 bytes   01:20:40.418
26              1:22:34.532     0:04:32.981     17.290 kbps     21.417 kbps     01:25:16.986    18.840 kbps     01:26:42.447    18.368 kbps     01:26:42.405    90.142 bytes    256.685 bytes   01:22:38.328
27              1:27:07.513     0:01:37.722     17.865 kbps     21.995 kbps     01:28:22.588    19.138 kbps     01:28:18.626    18.635 kbps     01:27:49.222    93.142 bytes    261.120 bytes   01:28:24.841
28              1:28:45.236     0:05:16.983     17.451 kbps     25.088 kbps     01:31:15.928    20.666 kbps     01:31:15.761    19.507 kbps     01:31:15.761    90.983 bytes    327.768 bytes   01:30:44.188
29              1:34:02.219     0:02:52.088     17.550 kbps     24.821 kbps     01:35:59.503    19.743 kbps     01:35:31.058    18.938 kbps     01:35:29.098    91.496 bytes    314.277 bytes   01:36:04.425
30              1:36:54.308     0:04:18.007     17.328 kbps     23.014 kbps     01:37:57.830    19.722 kbps     01:39:20.287    18.627 kbps     01:37:27.258    90.338 bytes    223.535 bytes   01:39:58.909
31              1:41:12.316     0:01:24.959     17.669 kbps     22.476 kbps     01:42:02.032    19.927 kbps     01:41:31.502    19.197 kbps     01:41:26.288    92.117 bytes    278.225 bytes   01:41:41.887
32              1:42:37.276     0:01:54.531     17.684 kbps     23.868 kbps     01:42:54.001    20.175 kbps     01:42:52.833    18.984 kbps     01:42:48.287    92.195 bytes    234.770 bytes   01:43:09.641
33              1:44:31.807     0:01:24.459     17.791 kbps     22.872 kbps     01:44:34.434    19.223 kbps     01:45:05.507    18.554 kbps     01:45:02.212    92.753 bytes    280.114 bytes   01:45:51.053
34              1:45:56.266     0:03:08.229     17.613 kbps     21.319 kbps     01:46:44.689    19.366 kbps     01:47:39.411    19.135 kbps     01:47:35.574    91.828 bytes    246.612 bytes   01:47:07.462
35              1:49:04.496     0:03:17.238     17.549 kbps     21.934 kbps     01:49:23.723    19.198 kbps     01:49:42.409    18.728 kbps     01:49:41.366    91.784 bytes    298.953 bytes   01:49:42.450
36              1:52:21.735     0:05:15.106     10.557 kbps     21.234 kbps     01:57:24.454    20.192 kbps     01:54:48.214    19.745 kbps     01:54:44.752    57.117 bytes    472.165 bytes   01:57:25.955
STREAM DIAGNOSTICS:
00047.M2TS      4113 (0x1011)   0xEA            VC-1                                    7056,758                16.875                  14.885.152.997  81.002.356
00047.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           7056,758                4.406                   3.886.938.256   28.240.943
00047.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           7056,758                640                     564.549.120     3.307.905
00047.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            7056,758                640                     564.549.120     3.307.905
00047.M2TS      4355 (0x1103)   0x81            AC3             deu (German)            7056,758                640                     564.549.120     3.307.905
00047.M2TS      4356 (0x1104)   0x81            AC3             ita (Italian)           7056,758                640                     564.549.120     3.307.905
00047.M2TS      4357 (0x1105)   0x81            AC3             spa (Spanish)           7056,758                640                     564.549.120     3.307.905
00047.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           7056,758                192                     169.364.736     1.102.635
00047.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           7056,758                192                     169.364.736     1.102.635
00047.M2TS      4360 (0x1108)   0x81            AC3             eng (English)           7056,758                192                     169.364.736     1.102.635
00047.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7056,758                15                      13.232.466      77.079
00047.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7056,758                17                      15.127.155      87.989
00047.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7056,758                14                      12.224.311      71.247
00047.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            7056,758                17                      15.259.097      88.079
00047.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            7056,758                19                      17.069.155      98.545
00047.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           7056,758                16                      14.250.403      82.750
00047.M2TS      4614 (0x1206)   0x90            PGS             ita (Italian)           7056,758                19                      16.337.065      94.698
00047.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           7056,758                14                      12.194.618      71.539
00047.M2TS      4616 (0x1208)   0x90            PGS             nld (Dutch)             7056,758                14                      12.014.975      70.005
00047.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            7056,758                16                      13.699.913      79.372
00047.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           7056,758                16                      14.184.687      82.435
00047.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         7056,758                14                      12.510.710      73.181
00047.M2TS      4620 (0x120C)   0x90            PGS             por (Portuguese)        7056,758                15                      13.348.495      77.833
00047.M2TS      4621 (0x120D)   0x90            PGS             swe (Swedish)           7056,758                14                      12.535.421      73.002
Burrito is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
