NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #1711 of 5106 Old 06-18-2010, 05:01 PM
DigitalfreakNYC's Avatar
Quoted: 127 Post(s)
Originally Posted by Big C View Post
I found the specs for the Australian edition, but I couldn't find the specs for the US edition at this thread or at cinemasquid.com.
There is no US version.
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #1712 of 5106 Old 06-18-2010, 09:37 PM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
I thought I saw one at Amazon. Is this a different "Scream" or something?
Update: I went to the Amazon link above, only to discover that it is an import afterall! This would explain why Netflix doesn't have it on Blu-ray. From what I understand, NTSC and Pal have been eliminated with the Blu-ray format. Being that this Australian edition is recorded for regions A, B, and C, will it play fine on US players?
Big C is offline
post #1713 of 5106 Old 06-18-2010, 11:22 PM
PeterTHX's Avatar
Quoted: 569 Post(s)
Liked: 428
If a disc has SD supplements then the old NTSC/PAL question becomes relevant again.
Apparently there are BD players that can handle both formats (Oppo I believe) but most others won't.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #1714 of 5106 Old 06-18-2010, 11:36 PM - Thread Starter
Cinema Squid's Avatar
It appears to be the case that the Australian version of Scream will play fine on US players according to Stephen's post.
It is not exactly the case the PAL has been eliminated from Blu-ray format since 1080i50 and 576i50 are both valid formats that many US players and displays will have problems with (ex. PS3) regardless of the region coding.
There are three things to be on the lookout for when importing region B or C releases to the US:
  1. Is the release Region A compatible?
  2. Does the release contain any 50Hz content for the main title, menus or any extras that you might care about?
  3. Are there any non-English forced subtitles that cannot be removed when viewing with the English audio track?
Amazon US does frequently list imports that do not match one or more of the above criteria, so it's always best to ask if there is any uncertainty. It's probably also worth noting that you can usually get a better price on imports directly from online retailers in the country of origin rather than using Amazon US.
Cinema Squid is offline
post #1715 of 5106 Old 06-19-2010, 06:37 AM
Stephen Dawson's Avatar
To be totally and painfully pedantic, PAL was actually eliminated from DVD, as was NTSC. These letters refer to colour-coding techniques, but have become shorthand for, respectively, 576i50 and 480i60. But there are other formats, such as PAL60, which suggest a little care should be taken (PAL60 exists as a broadcast standard, I understand, in some South American countries. It uses 480i60 style pictures, but the superior PAL colour encoding system).
DVDs use neither PAL nor NTSC since their video is stored in component video format (heavily compressed, of course).
It is one of those quirks of the industry that Japanese and Korean equipment purchased in Australia or Europe support all video standards, but if purchased in the US, frequently won't support the various 50 hertz standards. The Australian version of the PS3, for example, will happily play 480i60 discs, so long as there is no region code conflict.
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1716 of 5106 Old 06-19-2010, 10:41 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
When I play Pal material on my Pioneer BDP-320, I wind up with a black and white roling picture. However, I also plan on getting the "Scream" tripple pack in SD so I can obtain the sequels. So if I can't play the extras on the BD, I have nothing to worry about because if I want to badly play the extras, I can just pop in the SD DVD edition.
Big C is offline
post #1717 of 5106 Old 06-19-2010, 04:41 PM
msgohan's Avatar
As Stephen noted in his post, you don't have a choice in that matter since the disc is barebones. :P
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #1718 of 5106 Old 06-19-2010, 05:15 PM
The rolling picture suggests that your TV won't sync to 50 hertz. The lack of colour suggests that you're using an analogue video connection -- composite video? But that can't be right. So possibly the lack of sync at 50 hertz is somehow interfering with the colour. Either way, it's probably a TV problem.
Stephen Dawson
hifi-writer.com
post #1719 of 5106 Old 06-20-2010, 02:02 AM
Dark_zero's Avatar
The big Lebowski ( " Il grande Lebowski " in italian)
out in Italy from Cecchi Gori HV got ENG dts-hd MA audio track too.
Disc Title: IL GRANDE LEBOWSKI
Disc Size: 24.684.315.437 bytes
Protection: AACS
BD-Java: No
BDInfo: 0.5.4
Notes:
PLAYLIST: 00000.MPLS
<--- BEGIN FORUMS PASTE --->
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:56:55 23.861.304.576  24.684.315.437  27,21   21,98   DTS-HD Master 5.1 1726Kbps (48kHz/16-bit)
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:56:55 (h:m:s)
Total Bitrate:          27,21 Mbps
VIDEO:
VC-1 Video              21982 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         1726 kbps       5.1 / 48 kHz / 1726 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             Italian         1798 kbps       5.1 / 48 kHz / 1798 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           Italian         46,762 kbps
FILES:
00000.M2TS      0:00:00.000     1:56:55.508     23.861.304.576  27.210
CHAPTERS:
1               0:00:00.000     0:07:15.017     22.316 kbps     33.397 kbps     00:00:37.162    27.540 kbps     00:00:04.671    26.682 kbps     00:01:59.577    116.770 bytes   334.560 bytes   00:02:03.123
2               0:07:15.017     0:02:23.059     25.274 kbps     32.724 kbps     00:07:53.389    27.749 kbps     00:09:05.253    26.641 kbps     00:08:05.693    131.728 bytes   282.928 bytes   00:08:34.931
3               0:09:38.077     0:11:58.008     23.439 kbps     33.261 kbps     00:10:27.418    27.634 kbps     00:14:38.794    26.894 kbps     00:14:38.669    122.199 bytes   405.958 bytes   00:19:44.474
4               0:21:36.086     0:02:34.070     20.081 kbps     32.880 kbps     00:23:35.414    25.421 kbps     00:23:40.335    24.524 kbps     00:23:35.414    104.721 bytes   273.667 bytes   00:23:35.705
5               0:24:10.157     0:00:29.279     20.850 kbps     28.530 kbps     00:24:10.699    22.432 kbps     00:24:10.157    21.148 kbps     00:24:10.157    108.704 bytes   229.641 bytes   00:24:38.268
6               0:24:39.436     0:07:07.635     23.493 kbps     37.464 kbps     00:29:21.885    27.964 kbps     00:26:27.127    26.926 kbps     00:26:22.038    122.472 bytes   384.970 bytes   00:29:22.719
7               0:31:47.071     0:05:07.682     19.128 kbps     32.876 kbps     00:32:05.465    25.300 kbps     00:36:03.619    24.133 kbps     00:36:03.619    99.736 bytes    322.195 bytes   00:36:54.712
8               0:36:54.754     0:05:19.652     23.675 kbps     32.804 kbps     00:37:45.930    27.795 kbps     00:39:09.221    26.830 kbps     00:39:09.221    123.431 bytes   304.613 bytes   00:36:55.254
9               0:42:14.406     0:06:11.704     20.124 kbps     33.882 kbps     00:43:58.218    25.975 kbps     00:43:58.218    23.798 kbps     00:43:01.328    104.917 bytes   380.551 bytes   00:42:59.285
10              0:48:26.111     0:05:44.218     23.352 kbps     32.600 kbps     00:52:21.763    27.532 kbps     00:48:34.119    26.823 kbps     00:48:28.238    121.747 bytes   348.516 bytes   00:52:06.123
11              0:54:10.330     0:01:48.608     21.665 kbps     31.884 kbps     00:55:48.720    26.642 kbps     00:55:28.950    25.806 kbps     00:55:24.904    112.950 bytes   231.975 bytes   00:55:33.163
12              0:55:58.938     0:05:17.191     24.466 kbps     30.148 kbps     00:59:22.016    27.766 kbps     01:01:01.699    26.604 kbps     00:56:00.565    127.536 bytes   325.921 bytes   00:56:02.359
13              1:01:16.130     0:03:36.633     23.632 kbps     27.854 kbps     01:04:29.865    26.800 kbps     01:04:27.363    26.287 kbps     01:04:22.275    123.232 bytes   275.079 bytes   01:04:19.981
14              1:04:52.763     0:03:50.063     22.269 kbps     32.366 kbps     01:05:17.496    27.390 kbps     01:06:37.660    26.408 kbps     01:06:37.702    116.098 bytes   316.993 bytes   01:05:45.232
15              1:08:42.827     0:05:49.182     22.086 kbps     33.582 kbps     01:11:47.052    25.817 kbps     01:11:31.161    25.127 kbps     01:09:27.621    115.478 bytes   341.683 bytes   01:11:47.720
16              1:14:32.009     0:05:19.652     21.516 kbps     33.008 kbps     01:15:59.054    27.367 kbps     01:17:19.718    25.859 kbps     01:17:48.914    112.177 bytes   313.872 bytes   01:19:41.067
17              1:19:51.661     0:07:02.088     20.840 kbps     33.811 kbps     01:21:33.388    27.682 kbps     01:21:39.269    26.765 kbps     01:21:33.388    109.093 bytes   401.830 bytes   01:21:13.702
18              1:26:53.750     0:05:04.637     20.154 kbps     34.005 kbps     01:29:28.863    25.480 kbps     01:27:23.863    23.130 kbps     01:27:23.363    105.651 bytes   273.478 bytes   01:30:40.226
19              1:31:58.387     0:04:36.943     18.816 kbps     30.350 kbps     01:32:09.440    23.498 kbps     01:34:21.405    22.085 kbps     01:33:35.693    98.098 bytes    254.090 bytes   01:33:15.548
20              1:36:35.331     0:04:09.207     22.009 kbps     32.830 kbps     01:37:56.954    27.316 kbps     01:36:49.720    24.894 kbps     01:36:45.716    114.724 bytes   309.712 bytes   01:40:36.405
21              1:40:44.538     0:03:19.449     20.698 kbps     25.192 kbps     01:43:09.641    23.601 kbps     01:41:42.346    23.114 kbps     01:41:05.309    108.021 bytes   255.953 bytes   01:44:03.946
22              1:44:03.987     0:01:59.702     25.086 kbps     33.692 kbps     01:45:13.348    27.591 kbps     01:44:47.364    26.425 kbps     01:44:47.322    130.788 bytes   364.245 bytes   01:46:03.648
23              1:46:03.690     0:02:51.963     25.900 kbps     30.542 kbps     01:48:27.792    27.032 kbps     01:48:06.771    26.431 kbps     01:48:19.034    134.999 bytes   369.776 bytes   01:48:27.834
24              1:48:55.654     0:07:59.854     19.123 kbps     35.800 kbps     01:50:05.974    27.721 kbps     01:49:53.336    26.818 kbps     01:50:05.598    100.131 bytes   354.601 bytes   01:56:52.588
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    7015,509                21.982                  19.276.678.099  104.865.930
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       ita (Italian)           7015,509                1.798                   1.576.726.772   9.646.657
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           7015,509                1.726                   1.513.455.900   9.298.123
00000.M2TS      4608 (0x1200)   0x90            PGS             ita (Italian)           7015,509                47                      41.006.975      231.948
<---- END FORUMS PASTE ---->
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00000.MPLS
Length: 1:56:55
Video: VC-1 Video / 21982 kbps / 1080p / 23,976 fps / 16:9 / Advanced Profile 3
Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 1726 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Audio: Italian / DTS-HD Master Audio / 5.1 / 48 kHz / 1798 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Subtitle: Italian / 46,762 kbps
PLAYLIST: 00001.MPLS
Code:
        Total   Video
00001.MPLS                                                      AVC     0:07:09 325.885.824     24.684.315.437  6,08    5,38    DD AC3 2.0 320Kbps
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 0:07:09 (h:m:s)
Total Bitrate:          6,08 Mbps
VIDEO:
MPEG-4 AVC Video        5385 kbps           576i / 25 fps / 4:3 / High Profile 3.2
AUDIO:
Dolby Digital Audio             English         320 kbps        2.0 / 48 kHz / 320 kbps / DN -4dB
FILES:
00001.M2TS      0:00:00.000     0:07:09.000     325.885.824     6.077
CHAPTERS:
1               0:00:00.000     0:07:09.000     5.385 kbps      9.746 kbps      00:00:01.999    6.265 kbps      00:00:01.999    6.035 kbps      00:00:02.000    26.925 bytes    101.630 bytes   00:00:02.679
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     467,560                 5.031                   294.034.195     1.604.877
00001.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           467,560                 298                     17.416.960      108.856
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00001.MPLS
Length: 0:07:09
Video: MPEG-4 AVC Video / 5385 kbps / 576i / 25 fps / 4:3 / High Profile 3.2
Audio: English / Dolby Digital Audio / 2.0 / 48 kHz / 320 kbps / DN -4dB
PLAYLIST: 00002.MPLS
Code:
        Total   Video
00002.MPLS                                                      AVC     0:03:08 142.786.560     24.684.315.437  6,07    5,38    DD AC3 2.0 320Kbps
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 0:03:08 (h:m:s)
Total Bitrate:          6,07 Mbps
VIDEO:
MPEG-4 AVC Video        5380 kbps           576i / 25 fps / 4:3 / High Profile 3.2
AUDIO:
FILES:
00002.M2TS      0:00:00.000     0:03:08.120     142.786.560     6.072
CHAPTERS:
1               0:00:00.000     0:03:08.120     5.380 kbps      7.213 kbps      00:00:00.240    6.121 kbps      00:00:00.240    5.824 kbps      00:00:00.240    26.902 bytes    215.002 bytes   00:00:00.440
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     188,000                 5.384                   126.519.357     690.342
00002.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           188,000                 320                     7.521.280       47.008
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00002.MPLS
Length: 0:03:08
Video: MPEG-4 AVC Video / 5380 kbps / 576i / 25 fps / 4:3 / High Profile 3.2
PLAYLIST: 00003.MPLS
Code:
        Total   Video
00003.MPLS                                                      AVC     0:01:51 83.429.376      24.684.315.437  6,01    5,32    DD AC3 2.0 320Kbps
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 0:01:51 (h:m:s)
Total Bitrate:          6,01 Mbps
VIDEO:
MPEG-4 AVC Video        5321 kbps           576i / 25 fps / 4:3 / High Profile 3.2
AUDIO:
Dolby Digital Audio             Italian         320 kbps        2.0 / 48 kHz / 320 kbps / DN -4dB
FILES:
00003.M2TS      0:00:00.000     0:01:51.039     83.429.376      6.011
CHAPTERS:
1               0:00:00.000     0:01:51.039     5.321 kbps      7.607 kbps      00:00:02.679    6.398 kbps      00:00:01.240    5.746 kbps      00:00:00.879    26.606 bytes    99.020 bytes    00:00:00.399
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     110,920                 5.327                   73.859.569      403.028
00003.M2TS      4352 (0x1100)   0x81            AC3             ita (Italian)           110,920                 320                     4.439.040       27.744
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00003.MPLS
Length: 0:01:51
Video: MPEG-4 AVC Video / 5321 kbps / 576i / 25 fps / 4:3 / High Profile 3.2
Audio: Italian / Dolby Digital Audio / 2.0 / 48 kHz / 320 kbps / DN -4dB
PLAYLIST: 00005.MPLS
Code:
        Total   Video
00005.MPLS                                                      VC-1    0:00:22 17.178.624      24.684.315.437  5,99    5,41    DD AC3 5.1 448Kbps
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 0:00:22 (h:m:s)
Total Bitrate:          5,99 Mbps
VIDEO:
VC-1 Video              5412 kbps           1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             Italian         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
FILES:
00005.M2TS      0:00:00.000     0:00:10.218     6.094.848       4.772
00006.M2TS      0:00:10.218     0:00:12.721     11.083.776      6.970
CHAPTERS:
1               0:00:00.000     0:00:22.939     5.412 kbps      11.506 kbps     00:00:17.475    10.651 kbps     00:00:13.471    8.477 kbps      00:00:08.967    28.214 bytes    242.313 bytes   00:00:02.001
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0xEA            VC-1                                    10,135                  4.538                   5.749.650       31.398
00006.M2TS      4113 (0x1011)   0xEA            VC-1                                    12,638                  6.183                   9.768.060       53.283
00006.M2TS      4352 (0x1100)   0x81            AC3             ita (Italian)           12,638                  450                     711.424         3.970
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00005.MPLS
Length: 0:00:22
Video: VC-1 Video / 5412 kbps / 1080p / 23,976 fps / 16:9 / Advanced Profile 3
Audio: Italian / Dolby Digital Audio / 5.1 / 48 kHz / 448 kbps / DN -4dB[
Dark_zero is offline
post #1720 of 5106 Old 06-20-2010, 05:35 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
You guessed right. My TV won't handle 50 Hz correctly. I got into BD mainly because of 5.1 LPCM, DTS HD MA, and Dolby TrueHD. Although my CRT is almost 12 years old, and I'm expecting it to die anytime now. To get back on topic, for now, if I want to play "Scream," I can play the movie on BD and the extras with the US SDDVD release.
Big C is offline
post #1721 of 5106 Old 06-20-2010, 06:44 AM
Ah, composite video. Don't we love it so?
Anyway, the main feature in the Australian version is 24/1.001 hertz, and the copyright crap at the start is exactly 24 hertz (this may result in dropped frames on an old 60 hertz TV), but it should otherwise work okay.
Hey, Mr Squid, it occurs to me that despite my extensive record keeping, I generally don't have any information on main menu standards. My fault, of course -- I should have noted this. But is there any obvious way for BDInfo to identify the main menu background video and provide information on this? Normally it's filtered out on the 'filter out repeated bits' exclusion, but this one might be worth keeping in the BDInfo report.
Stephen Dawson
hifi-writer.com
post #1722 of 5106 Old 06-20-2010, 01:42 PM
eric.exe's Avatar
Quoted: 110 Post(s)
Liked: 44
Big C this really isn't the thread to discuss one title but there's a review of the disc in question here: http://www.landofwhimsy.com/archives...ssions-scream/
Quality is quite awful. Considering the release of Scream 4 next year, I think a remastered domestic release to tie-in is a definite possibility.
eric.exe is offline
post #1723 of 5106 Old 06-20-2010, 06:34 PM - Thread Starter
Unfortunately there's not really any practical way to do this that I know of, especially when BD-Java is involved. The main motivation for excluding these was to help float the "real" title playlist to the top, but I suppose they could both be included by default with the loopers pushed to the bottom (although with the stream diagnostics enabled as it stands, this can get pretty ugly in the report).
On a somewhat related note, I have been idly brainstorming a bit on improving BDInfo for the "examine every playlist" club (of which I am also a member). Any suggestions you have for improving that aspect are more than welcome.
P.S. I haven't forgotten about the disc unique IDs, audio VBR charts, re-openable reports, scan pausing, formatted HTML/XML output and other various eminently useful requests all of which I would also like to see myself. It's worth noting again for any coders out there, that the source code is published and open for change submissions.
post #1724 of 5106 Old 06-21-2010, 02:41 PM - Thread Starter
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
ABC [AU] 2009   After Life                                                      AVC     1080p24 2.35:1  22.99   1:42:58 21,330,149,376  22,088,730,394  27.62   TrueHD  5.1    48/16  1479
ABC [US] 1925   Battleship Potemkin: English Intertitles                        AVC     1080p24 1.33:1  27.40   1:12:12 18,006,675,456  43,375,359,836  33.25   DTS-MA  5.1    48/16  4151
                                     Russian Intertitles                        AVC     1080p24 1.33:1  27.66   1:11:48 18,054,586,368                  33.53   DTS-MA  5.1    48/16  4163
    [IT] 1998   The Big Lebowski                                                VC-1    1080p24 1.85:1  21.98   1:56:55 23,861,304,576  24,684,315,437  27.21   DTS-MA  5.1    48/16  1726
A   [US] 1956   Bigger Than Life                                                AVC     1080p24 2.55:1  35.11   1:35:21 28,228,706,304  46,163,039,730  39.47   LPCM    1.0    48/24  1152
ABC [US] 2006   Black Book                                                      AVC     1080p24 2.35:1  25.71   2:25:38 36,044,285,952  39,407,685,510  33.00   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
    [US] 2010   The Book of Eli: Rental Edition                                 VC-1    1080p24 2.40:1  16.96   1:57:41 19,723,941,888  20,147,480,531  22.35   DTS-MA  5.1    48/24  3432
ABC [AU] 2009   Bright Star                                                     AVC     1080p24 1.85:1  29.96   1:59:07 30,706,219,008  39,147,130,984  34.37   DTS-MA  5.1    48/16  1956  / AC3     5.1    48     640
ABC [JP] 2008   Burn After Reading                                              AVC     1080p24 1.85:1  24.95   1:35:55 21,326,075,904  23,007,269,556  29.65   TrueHD  5.1    48/16  1151
 B  [AU] 2009   Carriers                                                        AVC     1080p24 2.35:1  22.99   1:24:38 18,315,761,664  20,318,388,099  28.86   TrueHD  5.1    48/24  3084  / AC3     2.0    48     256
A   [US] 1985   Commando                                                        MPEG-2  1080p24 1.85:1  24.65   1:30:15 21,096,904,704  23,003,281,313  31.17   DTS-MA  5.1    48/24  3895  / AC3     2.0    48     448
ABC [NL] 1997   Cube                                                            VC-1    1080p24*1.85:1  20.91   1:30:16 16,360,359,936  16,751,435,014  24.17   DTS-MA  5.1    48/16  1917
 B  [AU] 2009   Doghouse                                                        AVC     1080p24*2.35:1  19.15   1:28:40 17,260,279,488  21,432,578,322  25.96   DTS-MA  5.1    48/24  4730  / AC3     5.1    48     640
ABC [US] 1980   Flash Gordon                                                    VC-1    1080p24 2.35:1  20.22   1:51:23 21,560,672,256  24,546,357,322  25.81   DTS-MA  5.1    48/24  4118
ABC [US] 2004   The Grudge: Extended Cut (seamless)                             AVC     1080p24 1.85:1  27.27   1:38:11 28,758,018,048  47,611,404,649  39.05   TrueHD  5.1    48/24  3024
                            Theatrical (seamless)                               AVC     1080p24 1.85:1  27.25   1:31:25 26,470,041,600                  38.61   TrueHD  5.1    48/24  3024
ABC [CA] 2001   Harry Potter and the Sorcerer's Stone                           VC-1    1080p24 2.40:1  17.55   2:32:21 33,247,444,992  38,110,528,940  29.10   LPCM    5.1    48/16  4608  / AC3     5.1-EX 48     640
 B  [AU] 2008   The Hurt Locker                                                 AVC     1080p24 1.78:1  27.98   2:10:43 32,768,252,352  38,832,727,765  33.42   DTS-MA  5.1    48/24  3710
    [US] 2009   Invictus: Rental Edition                                        VC-1    1080p24 2.40:1  24.91   2:13:38 30,957,778,944  31,606,891,702  30.89   DTS-MA  5.1    48/24  3651
ABC [US] 1984   The Karate Kid                                                  AVC     1080p24 1.85:1  26.95   2:06:54 39,689,121,792  46,615,759,769  41.70   DTS-MA  5.1    48/24  3795
 B  [AU] 2009   Law Abiding Citizen                                             AVC     1080p24 2.40:1  27.96   1:48:49 28,862,035,968  29,264,243,472  35.36   TrueHD  5.1    48/24  3214
ABC [US] 2010   Leap Year                                                       VC-1    1080p24 2.40:1  30.25   1:40:16 28,793,465,472  30,927,228,119  38.29   DTS-MA  5.1    48/24  4147
A   [US] 2009   Mary and Max                                                    AVC     1080p24 1.85:1  26.03   1:32:26 25,845,067,776  32,049,277,358  37.28   DTS-MA  5.1    48/24  3426  / LPCM    2.0    48/24  2304
A   [US] 1989   Mystery Train                                                   AVC     1080p24 1.78:1  35.51   1:50:31 32,851,359,744  44,092,091,802  39.63   LPCM    1.0    48/24  1152
ABC [JP] 2006   Perfume: The Story of a Murderer                                AVC     1080p24 2.35:1  31.97   2:27:24 46,685,485,056  48,137,951,892  42.23   LPCM    5.1    48/16  4608  / TrueHD  5.1    48/16  1548
A   [HK] 1986   Platoon                                                         MPEG-2  1080p24 1.85:1  17.82   1:59:50 19,918,743,552  21,323,647,507  22.16   DTS-MA  5.1    48/16  2024  / AC3     4.0    48     448
 B  [UK] 2008   Ponyo                                                           AVC     1080p24 1.85:1  27.50   1:42:16 34,868,889,600  48,921,059,775  45.46   DTS-MA  6.1    48/24  4558  / AC3     2.0    48     224
A   [US] 1987   Predator                                                        MPEG-2  1080p24 1.85:1  18.91   1:46:35 20,637,812,736  22,738,268,146  25.82   DTS-MA  5.1    48/24  4530  / AC3     4.0    48     448
ABC [PL] 1994   Pulp Fiction                                                    AVC     1080p24 2.35:1  32.38   2:34:24 43,995,500,544  49,954,650,092  37.99   DTS-MA  5.1    48/16  1985  / AC3     5.1    48     640
ABC [US] 2003   Seabiscuit                                                      VC-1    1080p24 2.40:1  24.33   2:20:25 33,502,322,688  44,803,959,562  31.81   DTS-MA  5.1    48/24  3778
ABC [US] 2010   Shutter Island                                                  AVC     1080p24 2.35:1  27.63   2:18:04 37,700,271,936  44,578,743,573  36.41   DTS-MA  5.1    48/24  4725
ABC [US] 1993   Tombstone                                                       AVC     1080p24 2.40:1  30.55   2:09:37 36,367,448,064  40,670,043,714  37.41   DTS-MA  5.1    48/24  4148
    [CA] 2000   Traffic                                                         AVC     1080i60 1.78:1  15.00   2:27:04 22,789,337,088  22,869,754,388  20.66   DTS-MA  5.1    48/24  3547  / AC3     5.1    48     448
 B  [FR] 1993   True Romance                                                    AVC     1080p24 2.35:1  25.97   2:00:30 30,565,638,144  45,529,392,331  33.82   DTS-MA  5.1    48/16  2030
A   [US] 2009   Youth in Revolt                                                 AVC     1080p24 1.85:1  27.84   1:29:27 22,357,284,864  29,544,813,503  33.33   DTS-MA  5.1    48/24  3428
post #1725 of 5106 Old 06-21-2010, 07:19 PM
Phantom Stranger's Avatar
Quoted: 592 Post(s)
Liked: 617
I would just like to thank Cinema Squid publicly for his excellent stewardship of the specifications. Time after time, the information that can be found in the first post is invaluable knowledge, in a handy and accessible format. A tip of my hat to you and the other contributors. If only every BD was in the database...
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #1726 of 5106 Old 06-23-2010, 05:42 AM
eric.exe's Avatar
Quoted: 110 Post(s)
Liked: 44
Protection: AACS
BD-Java: No
Length: 1:56:55
I can confirm that's the exact same video encode as the US Universal HD DVD. Funny.
eric.exe is offline
post #1727 of 5106 Old 06-23-2010, 05:53 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
Originally Posted by msgohan View Post
Predator - USA - Fox
Region A locked (did not confirm but plenty of sources say so)
Release: 2008-04-15
This one started in Jan 2007 and was completed in April of the same year.
Code:
        Total   Video
(US) Predator                                                   MPEG-2  1:46:35 20,637,812,736  22,738,268,146  25.82   18.91   DTS-HD Master 5.1 4530Kbps (48kHz/24-bit) DD AC3 4.0 448Kbps
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID
Disc Size:      22,738,268,146 bytes
Protection:     AACS
BD-Java:        No
D-BOX Motion:   Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:46:35 (h:m:s)
Total Bitrate:          25.82 Mbps
VIDEO:
MPEG-2 Video            18910 kbps          1080p / 23.976 fps / 16:9
AUDIO:
DTS-HD Master Audio             English         4530 kbps       5.1 / 48 kHz / 4530 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        4.0 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             French          224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
Dolby Digital Audio             Spanish         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         25.354 kbps
Presentation Graphics           Chinese         21.874 kbps
Presentation Graphics           French          0.026 kbps
Presentation Graphics           Korean          13.999 kbps
Presentation Graphics           Spanish         16.549 kbps
Presentation Graphics           Spanish         0.034 kbps
FILES:
00028.M2TS      0:00:00.000     1:46:35.389     20,637,812,736  25,816
CHAPTERS:
1               0:00:00.000     0:04:04.285     18,986 kbps     40,663 kbps     00:01:30.340    27,593 kbps     00:01:29.464    24,671 kbps     00:01:29.464    98,966 bytes    696,256 bytes   00:01:29.005
2               0:04:04.285     0:02:25.353     18,357 kbps     25,221 kbps     00:04:06.287    23,111 kbps     00:04:04.410    21,096 kbps     00:04:04.577    95,704 bytes    511,490 bytes   00:06:29.639
3               0:06:29.639     0:04:02.825     19,913 kbps     30,972 kbps     00:07:25.736    26,786 kbps     00:07:24.277    24,678 kbps     00:10:09.650    103,818 bytes   469,345 bytes   00:10:32.340
4               0:10:32.465     0:07:48.718     19,178 kbps     36,021 kbps     00:16:03.837    29,763 kbps     00:16:00.918    27,275 kbps     00:15:59.959    99,986 bytes    727,827 bytes   00:16:26.986
5               0:18:21.183     0:02:00.370     20,587 kbps     34,168 kbps     00:19:14.987    32,534 kbps     00:19:15.070    27,335 kbps     00:19:13.235    107,333 bytes   480,872 bytes   00:19:54.818
6               0:20:21.553     0:07:30.783     18,630 kbps     34,299 kbps     00:25:15.222    27,509 kbps     00:21:48.181    26,936 kbps     00:21:48.056    97,128 bytes    558,185 bytes   00:24:12.701
7               0:27:52.337     0:03:11.941     18,659 kbps     31,407 kbps     00:27:54.964    27,051 kbps     00:28:57.527    25,736 kbps     00:28:55.650    97,277 bytes    475,103 bytes   00:28:55.692
8               0:31:04.279     0:03:49.437     19,202 kbps     33,456 kbps     00:31:05.530    27,182 kbps     00:32:33.993    24,744 kbps     00:32:33.993    100,110 bytes   569,929 bytes   00:33:21.833
9               0:34:53.716     0:02:55.884     20,065 kbps     42,287 kbps     00:37:38.130    34,848 kbps     00:36:42.116    32,915 kbps     00:36:40.072    104,608 bytes   772,068 bytes   00:36:40.114
10              0:37:49.600     0:03:11.232     17,904 kbps     32,591 kbps     00:39:05.468    30,073 kbps     00:39:01.464    29,434 kbps     00:38:56.459    93,345 bytes    526,527 bytes   00:38:55.499
11              0:41:00.833     0:05:32.540     18,909 kbps     42,145 kbps     00:42:07.191    36,637 kbps     00:41:34.200    34,313 kbps     00:41:20.144    98,581 bytes    577,125 bytes   00:42:34.468
12              0:46:33.373     0:06:35.311     19,152 kbps     33,435 kbps     00:47:39.481    30,093 kbps     00:47:15.582    27,224 kbps     00:47:10.661    99,851 bytes    623,519 bytes   00:53:08.685
13              0:53:08.685     0:08:28.716     18,866 kbps     35,037 kbps     00:57:48.339    25,564 kbps     00:58:44.187    23,172 kbps     00:57:48.006    98,357 bytes    650,333 bytes   00:56:14.329
14              1:01:37.402     0:02:31.359     19,367 kbps     34,625 kbps     01:02:44.427    27,521 kbps     01:01:49.414    26,546 kbps     01:01:49.414    100,970 bytes   626,145 bytes   01:02:11.853
15              1:04:08.761     0:04:01.157     19,004 kbps     36,721 kbps     01:06:39.328    31,432 kbps     01:06:39.328    30,327 kbps     01:06:36.450    99,080 bytes    605,155 bytes   01:06:03.209
16              1:08:09.919     0:06:00.443     19,148 kbps     42,648 kbps     01:11:40.754    38,785 kbps     01:12:13.912    38,585 kbps     01:12:08.907    99,826 bytes    751,915 bytes   01:12:18.834
17              1:14:10.362     0:01:39.849     17,236 kbps     29,107 kbps     01:15:37.950    25,012 kbps     01:15:33.570    23,292 kbps     01:15:33.570    89,860 bytes    646,110 bytes   01:14:15.784
18              1:15:50.212     0:02:37.157     20,287 kbps     37,848 kbps     01:16:45.017    36,067 kbps     01:16:31.378    33,544 kbps     01:16:30.502    105,767 bytes   477,838 bytes   01:16:00.764
19              1:18:27.369     0:02:27.647     19,744 kbps     32,757 kbps     01:20:12.974    24,995 kbps     01:20:09.638    22,747 kbps     01:20:35.455    102,935 bytes   558,752 bytes   01:20:55.016
20              1:20:55.016     0:04:14.253     18,406 kbps     28,050 kbps     01:21:40.353    24,691 kbps     01:21:36.349    23,483 kbps     01:21:31.344    95,962 bytes    622,975 bytes   01:22:56.179
21              1:25:09.270     0:09:22.561     19,333 kbps     40,962 kbps     01:29:16.768    29,566 kbps     01:29:14.766    27,057 kbps     01:29:16.684    100,794 bytes   605,994 bytes   01:26:09.247
22              1:34:31.832     0:01:17.285     19,935 kbps     26,180 kbps     01:35:48.117    24,424 kbps     01:35:10.996    22,861 kbps     01:35:08.452    103,930 bytes   494,218 bytes   01:35:49.118
23              1:35:49.118     0:04:09.540     19,151 kbps     29,121 kbps     01:36:08.429    24,530 kbps     01:36:41.128    23,576 kbps     01:36:05.885    99,843 bytes    459,188 bytes   01:39:43.310
24              1:39:58.659     0:02:57.510     19,265 kbps     39,716 kbps     01:41:01.221    29,004 kbps     01:40:57.968    26,219 kbps     01:40:56.842    100,441 bytes   583,950 bytes   01:41:31.043
25              1:42:56.170     0:03:39.219     13,682 kbps     37,421 kbps     01:43:11.226    33,129 kbps     01:43:07.181    31,491 kbps     01:43:02.217    71,345 bytes    654,485 bytes   01:43:11.977
STREAM DIAGNOSTICS:
00028.M2TS      4113 (0x1011)   0x02            MPEG-2                                  6395.264                18,911                  15,117,289,093  82,248,550
00028.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6395.264                4,530                   3,621,422,044   20,676,706
00028.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6395.264                448                     358,141,952     1,998,560
00028.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6395.264                224                     179,070,976     999,280
00028.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            6395.264                224                     179,070,976     999,280
00028.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6395.264                25                      20,268,655      114,635
00028.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6395.264                17                      13,229,545      75,028
00028.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           6395.264                22                      17,486,923      98,575
00028.M2TS      4611 (0x1203)   0x90            PGS             kor (Korean)            6395.264                14                      11,191,367      63,441
00028.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           6395.264                0                       26,815          152
00028.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            6395.264                0                       20,647          119
dir /s:
Code:
 Volume in drive X is LOGICAL_VOLUME_ID
 Volume Serial Number is 3E11-9498
 Directory of X:\\
04/30/2007  02:23 PM
BDMV 04/30/2007 02:23 PM
AACS 04/30/2007 02:23 PM
CERTIFICATE 01/25/2007 05:08 PM 2,119,248 022324577.zip 01/25/2007 05:08 PM 2,090,742 022324578.zip 01/25/2007 04:50 PM 2,526 FilmIndex.xml 01/25/2007 05:08 PM 2,097,314 022324576.zip 4 File(s) 6,309,830 bytes Directory of X:\\BDMV 04/30/2007 02:21 PM 300 index.bdmv 04/30/2007 02:21 PM 42,962 MovieObject.bdmv 04/30/2007 02:23 PM
PLAYLIST 04/30/2007 02:23 PM
CLIPINF 04/30/2007 02:23 PM
STREAM 04/30/2007 02:23 PM
AUXDATA 04/30/2007 02:23 PM
META 04/30/2007 02:23 PM
BDJO 04/30/2007 02:23 PM
JAR 04/30/2007 02:23 PM
BACKUP 2 File(s) 43,262 bytes Directory of X:\\BDMV\\PLAYLIST 04/30/2007 02:21 PM 73,212 00000.mpls 04/30/2007 02:21 PM 234 00003.mpls 04/30/2007 02:21 PM 184 00006.mpls 04/30/2007 02:21 PM 154 00007.mpls 04/30/2007 02:21 PM 154 00008.mpls 04/30/2007 02:21 PM 154 00009.mpls 04/30/2007 02:21 PM 154 00010.mpls 04/30/2007 02:21 PM 184 00011.mpls 04/30/2007 02:21 PM 184 00013.mpls 04/30/2007 02:21 PM 184 00014.mpls 04/30/2007 02:21 PM 184 00017.mpls 04/30/2007 02:21 PM 234 00018.mpls 04/30/2007 02:21 PM 720 00019.mpls 04/30/2007 02:21 PM 184 00020.mpls 04/30/2007 02:21 PM 184 00021.mpls 04/30/2007 02:21 PM 184 00022.mpls 04/30/2007 02:21 PM 170 00023.mpls 17 File(s) 76,658 bytes Directory of X:\\BDMV\\CLIPINF 04/30/2007 02:21 PM 292 00001.clpi 04/30/2007 02:21 PM 1,016 00025.clpi 04/30/2007 02:21 PM 908 00026.clpi 04/30/2007 02:21 PM 336 00005.clpi 04/30/2007 02:21 PM 440 00011.clpi 04/30/2007 02:21 PM 324 00012.clpi 04/30/2007 02:21 PM 324 00014.clpi 04/30/2007 02:21 PM 324 00015.clpi 04/30/2007 02:21 PM 324 00016.clpi 04/30/2007 02:21 PM 1,800 00017.clpi 04/30/2007 02:21 PM 1,860 00018.clpi 04/30/2007 02:21 PM 1,996 00019.clpi 04/30/2007 02:21 PM 500 00022.clpi 04/30/2007 02:21 PM 336 00027.clpi 04/30/2007 02:21 PM 68,732 00028.clpi 04/30/2007 02:21 PM 292 00029.clpi 04/30/2007 02:21 PM 1,652 00030.clpi 04/30/2007 02:21 PM 1,944 00031.clpi 04/30/2007 02:21 PM 984 00032.clpi 04/30/2007 02:21 PM 348 00033.clpi 20 File(s) 84,732 bytes Directory of X:\\BDMV\\STREAM 04/03/2007 11:55 AM 4,853,760 00001.m2ts 03/09/2007 07:31 PM 146,313,216 00025.m2ts 03/09/2007 07:31 PM 108,601,344 00026.m2ts 02/07/2007 10:56 AM 743,424 00005.m2ts 01/18/2007 05:27 PM 16,441,344 00011.m2ts 01/18/2007 05:27 PM 374,784 00012.m2ts 01/18/2007 05:27 PM 337,920 00014.m2ts 01/18/2007 05:27 PM 448,512 00015.m2ts 01/18/2007 05:27 PM 374,784 00016.m2ts 01/29/2007 09:47 PM 358,791,168 00017.m2ts 01/18/2007 05:28 PM 299,028,480 00018.m2ts 01/18/2007 05:28 PM 276,946,944 00019.m2ts 01/30/2007 01:22 PM 40,937,472 00022.m2ts 02/07/2007 10:56 AM 743,424 00027.m2ts 04/30/2007 02:21 PM 20,637,812,736 00028.m2ts 04/03/2007 11:55 AM 13,559,808 00029.m2ts 01/18/2007 05:29 PM 363,835,392 00030.m2ts 01/18/2007 05:30 PM 332,408,832 00031.m2ts 01/18/2007 05:30 PM 120,109,056 00032.m2ts 02/12/2007 12:00 PM 368,640 00033.m2ts 20 File(s) 22,723,031,040 bytes Directory of X:\\BDMV\\AUXDATA 04/30/2007 01:51 PM 234,370 sound.bdmv 1 File(s) 234,370 bytes Directory of X:\\BDMV\\META 04/30/2007 02:23 PM
DL 04/30/2007 02:23 PM
ES 04/30/2007 02:23 PM
TN 0 File(s) 0 bytes Directory of X:\\BDMV\\BACKUP 04/30/2007 02:21 PM 300 index.bdmv 04/30/2007 02:21 PM 42,962 MovieObject.bdmv 04/30/2007 02:23 PM
BDJO 2 File(s) 43,262 bytes Directory of X:\\BDMV\\BACKUP\\PLAYLIST 04/30/2007 02:21 PM 73,212 00000.mpls 04/30/2007 02:21 PM 234 00003.mpls 04/30/2007 02:21 PM 184 00006.mpls 04/30/2007 02:21 PM 154 00007.mpls 04/30/2007 02:21 PM 154 00008.mpls 04/30/2007 02:21 PM 154 00009.mpls 04/30/2007 02:21 PM 154 00010.mpls 04/30/2007 02:21 PM 184 00011.mpls 04/30/2007 02:21 PM 184 00013.mpls 04/30/2007 02:21 PM 184 00014.mpls 04/30/2007 02:21 PM 184 00017.mpls 04/30/2007 02:21 PM 234 00018.mpls 04/30/2007 02:21 PM 720 00019.mpls 04/30/2007 02:21 PM 184 00020.mpls 04/30/2007 02:21 PM 184 00021.mpls 04/30/2007 02:21 PM 184 00022.mpls 04/30/2007 02:21 PM 170 00023.mpls 17 File(s) 76,658 bytes Directory of X:\\BDMV\\BACKUP\\CLIPINF 04/30/2007 02:21 PM 292 00001.clpi 04/30/2007 02:21 PM 1,016 00025.clpi 04/30/2007 02:21 PM 908 00026.clpi 04/30/2007 02:21 PM 336 00005.clpi 04/30/2007 02:21 PM 440 00011.clpi 04/30/2007 02:21 PM 324 00012.clpi 04/30/2007 02:21 PM 324 00014.clpi 04/30/2007 02:21 PM 324 00015.clpi 04/30/2007 02:21 PM 324 00016.clpi 04/30/2007 02:21 PM 1,800 00017.clpi 04/30/2007 02:21 PM 1,860 00018.clpi 04/30/2007 02:21 PM 1,996 00019.clpi 04/30/2007 02:21 PM 500 00022.clpi 04/30/2007 02:21 PM 336 00027.clpi 04/30/2007 02:21 PM 68,732 00028.clpi 04/30/2007 02:21 PM 292 00029.clpi 04/30/2007 02:21 PM 1,652 00030.clpi 04/30/2007 02:21 PM 1,944 00031.clpi 04/30/2007 02:21 PM 984 00032.clpi 04/30/2007 02:21 PM 348 00033.clpi 20 File(s) 84,732 bytes Directory of X:\\AACS 04/30/2007 02:21 PM 1,048,576 MKB_RO.inf 04/30/2007 02:21 PM 1,048,576 MKB_RW.inf 04/30/2007 02:21 PM 1,048,576 ContentRevocation.lst 04/30/2007 02:21 PM 65,536 Unit_Key_RO.inf 04/30/2007 02:21 PM 288 Content000.cer 04/30/2007 02:21 PM 2,048 CPSUnit00001.cci 04/30/2007 02:21 PM 3,465 mcmf.xml 04/30/2007 02:23 PM
DUPLICATE 04/30/2007 02:21 PM 924,736 ContentHash000.tbl 8 File(s) 4,141,801 bytes Directory of X:\\AACS\\DUPLICATE 04/30/2007 02:21 PM 1,048,576 MKB_RO.inf 04/30/2007 02:21 PM 1,048,576 MKB_RW.inf 04/30/2007 02:21 PM 1,048,576 ContentRevocation.lst 04/30/2007 02:21 PM 65,536 Unit_Key_RO.inf 04/30/2007 02:21 PM 288 Content000.cer 04/30/2007 02:21 PM 2,048 CPSUnit00001.cci 04/30/2007 02:21 PM 3,465 mcmf.xml 04/30/2007 02:21 PM 924,736 ContentHash000.tbl 8 File(s) 4,141,801 bytes Directory of X:\\CERTIFICATE 04/30/2007 02:23 PM
BACKUP 0 File(s) 0 bytes Total Files Listed: 119 File(s) 22,738,268,146 bytes 19 Dir(s) 0 bytes free
Now that I'm aware of it, I'll be waiting for the specs on this one.
Big C is offline
post #1728 of 5106 Old 06-23-2010, 07:19 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Carlito's Way - 1993 - US - Universal - Region ABC
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:24:09 41,733,126,144  45,595,082,177  38.60   31.76   DTS-HD Master 5.1 3994Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     CARLITOS_WAY
Disc Size:      45,595,082,177 bytes
Protection:     AACS
BD-Java:        Yes
Extras:         D-BOX Motion Code
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 2:24:09 (h:m:s)
Total Bitrate:          38.60 Mbps
VIDEO:
VC-1 Video              31763 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3994 kbps       5.1 / 48 kHz / 3994 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         38.116 kbps
Presentation Graphics           French          30.006 kbps
Presentation Graphics           French          0.238 kbps
Presentation Graphics           Spanish         31.591 kbps
FILES:
00010.M2TS      0:00:00.000     2:24:09.599     41,733,126,144  38,599
CHAPTERS:
1               0:00:00.000     0:05:03.803     28,564 kbps     48,117 kbps     00:00:02.961    35,862 kbps     00:01:55.448    34,949 kbps     00:01:55.281    148,898 bytes   378,563 bytes   00:03:10.440
2               0:05:03.803     0:12:39.842     31,658 kbps     39,454 kbps     00:15:08.282    37,160 kbps     00:15:07.031    36,731 kbps     00:15:07.072    165,050 bytes   358,312 bytes   00:10:59.116
3               0:17:43.645     0:09:58.222     31,443 kbps     45,021 kbps     00:24:06.027    37,281 kbps     00:24:18.832    35,854 kbps     00:24:18.165    163,930 bytes   411,509 bytes   00:19:30.335
4               0:27:41.868     0:04:21.135     30,450 kbps     36,465 kbps     00:30:45.510    35,457 kbps     00:30:42.048    35,012 kbps     00:30:38.878    158,753 bytes   349,053 bytes   00:27:56.883
5               0:32:03.004     0:04:33.856     32,883 kbps     45,314 kbps     00:33:12.657    38,148 kbps     00:34:01.873    36,523 kbps     00:34:01.205    171,439 bytes   346,808 bytes   00:33:12.991
6               0:36:36.861     0:08:50.029     31,255 kbps     40,434 kbps     00:39:37.583    37,131 kbps     00:37:01.719    36,209 kbps     00:39:37.291    162,952 bytes   323,718 bytes   00:38:38.065
7               0:45:26.890     0:05:12.061     31,006 kbps     52,356 kbps     00:45:29.601    34,860 kbps     00:45:39.027    34,012 kbps     00:47:24.258    161,652 bytes   454,039 bytes   00:45:29.893
8               0:50:38.952     0:08:01.898     31,480 kbps     41,280 kbps     00:57:55.555    37,346 kbps     00:51:44.017    36,222 kbps     00:52:29.729    164,124 bytes   338,976 bytes   00:51:46.645
9               0:58:40.850     0:04:53.835     33,033 kbps     38,173 kbps     01:03:15.958    37,110 kbps     01:03:15.791    36,318 kbps     01:03:15.291    172,217 bytes   376,177 bytes   00:59:07.877
10              1:03:34.685     0:08:09.906     32,666 kbps     51,810 kbps     01:09:06.600    40,034 kbps     01:09:02.763    35,950 kbps     01:09:02.304    170,307 bytes   402,143 bytes   01:05:40.853
11              1:11:44.591     0:05:43.968     32,125 kbps     41,039 kbps     01:16:26.957    37,233 kbps     01:16:23.787    36,548 kbps     01:16:18.699    167,483 bytes   439,791 bytes   01:12:28.635
12              1:17:28.560     0:07:18.813     31,640 kbps     41,726 kbps     01:17:50.749    37,353 kbps     01:19:06.992    36,026 kbps     01:18:31.331    164,959 bytes   277,793 bytes   01:19:23.759
13              1:24:47.373     0:09:01.707     32,534 kbps     48,983 kbps     01:29:52.512    37,093 kbps     01:25:16.611    36,707 kbps     01:25:16.236    169,616 bytes   367,441 bytes   01:29:53.471
14              1:33:49.081     0:11:34.527     32,079 kbps     42,497 kbps     01:37:37.726    37,596 kbps     01:35:56.000    36,210 kbps     01:37:28.801    167,244 bytes   363,717 bytes   01:42:06.370
15              1:45:23.608     0:07:08.970     30,445 kbps     38,367 kbps     01:51:21.508    36,728 kbps     01:51:19.172    35,292 kbps     01:51:17.587    158,727 bytes   419,974 bytes   01:50:58.360
16              1:52:32.579     0:05:08.391     33,055 kbps     46,319 kbps     01:57:00.430    37,176 kbps     01:54:10.176    36,343 kbps     01:56:05.917    172,335 bytes   356,982 bytes   01:57:01.347
17              1:57:40.970     0:05:50.725     32,892 kbps     41,739 kbps     02:00:11.704    36,014 kbps     01:57:52.065    35,325 kbps     01:59:04.011    171,485 bytes   430,678 bytes   02:00:12.496
18              2:03:31.695     0:10:30.004     32,814 kbps     42,053 kbps     02:05:45.120    38,492 kbps     02:11:17.744    36,740 kbps     02:11:17.077    171,077 bytes   541,050 bytes   02:04:34.425
19              2:14:01.700     0:05:05.930     32,155 kbps     46,806 kbps     02:18:42.480    37,268 kbps     02:17:32.827    36,019 kbps     02:17:33.787    167,642 bytes   372,184 bytes   02:18:43.440
20              2:19:07.630     0:05:01.968     29,739 kbps     35,477 kbps     02:19:16.765    34,012 kbps     02:22:15.193    33,539 kbps     02:20:55.780    155,067 bytes   428,702 bytes   02:24:08.222
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    8649.474                31,764                  34,342,481,449  186,768,929
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           8649.474                3,994                   4,318,565,168   24,816,509
00010.M2TS      4353 (0x1101)   0x82            DTS             fra (French)            8649.474                768                     830,361,600     4,865,400
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8649.474                38                      41,210,548      235,633
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           8649.474                32                      34,156,716      195,885
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8649.474                30                      32,441,963      186,396
00010.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            8649.474                0                       257,791         1,494
paku is offline
post #1729 of 5106 Old 06-23-2010, 12:27 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Kingdom of Heaven - 2005 - US - Fox - Region A
Code:
        Total   Video
00002.MPLS                                                      MPEG-2  3:09:33 41,907,585,024  44,360,872,536  29.48   24.04   DTS-HD Master 5.1 3825Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Size:      44,360,872,536 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 3:09:33 (h:m:s)
Total Bitrate:          29.48 Mbps
VIDEO:
MPEG-2 Video            24038 kbps          1080p / 23.976 fps / 16:9
AUDIO:
DTS-HD Master Audio             English         3825 kbps       5.1 / 48 kHz / 3825 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         29.188 kbps
Presentation Graphics           French          27.534 kbps
Presentation Graphics           Spanish         26.894 kbps
FILES:
00000.M2TS      0:00:00.000     1:30:48.609     20,162,820,096  29,604
00001.M2TS      1:30:48.609     1:38:44.752     21,744,764,928  29,361
CHAPTERS:
1               0:00:00.000     0:04:30.478     19,378 kbps     34,903 kbps     00:00:35.243    28,489 kbps     00:00:33.158    27,527 kbps     00:01:46.272    101,010 bytes   606,218 bytes   00:04:24.806
2               0:04:30.478     0:02:52.797     23,971 kbps     33,742 kbps     00:06:15.833    30,227 kbps     00:06:47.490    29,527 kbps     00:06:47.490    124,972 bytes   603,005 bytes   00:06:10.536
3               0:07:23.276     0:01:59.077     20,892 kbps     26,714 kbps     00:09:13.886    24,798 kbps     00:08:37.350    22,810 kbps     00:08:12.909    108,923 bytes   504,580 bytes   00:09:15.471
4               0:09:22.353     0:02:15.218     20,434 kbps     32,782 kbps     00:11:27.603    29,474 kbps     00:11:23.599    24,876 kbps     00:11:22.682    106,536 bytes   471,113 bytes   00:11:04.705
5               0:11:37.571     0:03:00.263     22,148 kbps     32,419 kbps     00:11:38.155    27,197 kbps     00:14:04.802    26,183 kbps     00:12:36.422    115,468 bytes   606,882 bytes   00:12:00.511
6               0:14:37.835     0:03:37.300     22,819 kbps     29,696 kbps     00:17:17.327    26,629 kbps     00:17:26.920    26,191 kbps     00:17:26.086    118,967 bytes   600,422 bytes   00:17:29.465
7               0:18:15.135     0:02:22.934     24,075 kbps     33,855 kbps     00:20:16.882    30,185 kbps     00:20:12.836    28,830 kbps     00:20:12.044    125,517 bytes   455,997 bytes   00:20:21.887
8               0:20:38.070     0:01:25.210     26,199 kbps     32,921 kbps     00:20:57.714    31,281 kbps     00:21:16.650    31,161 kbps     00:21:11.895    136,589 bytes   609,661 bytes   00:20:44.284
9               0:22:03.280     0:02:15.260     28,216 kbps     34,578 kbps     00:22:23.884    32,131 kbps     00:22:26.344    30,749 kbps     00:22:22.591    147,106 bytes   608,391 bytes   00:24:02.607
10              0:24:18.540     0:06:25.968     26,836 kbps     35,083 kbps     00:25:41.790    31,417 kbps     00:26:31.464    30,546 kbps     00:26:43.143    139,908 bytes   607,438 bytes   00:28:39.384
11              0:30:44.509     0:01:52.111     24,302 kbps     31,418 kbps     00:31:27.260    28,153 kbps     00:31:10.326    27,214 kbps     00:31:09.617    126,702 bytes   588,372 bytes   00:31:01.943
12              0:32:36.621     0:02:15.885     22,725 kbps     34,923 kbps     00:32:45.755    31,129 kbps     00:32:41.751    30,158 kbps     00:32:36.746    118,480 bytes   543,939 bytes   00:32:49.175
13              0:34:52.507     0:01:41.643     25,891 kbps     31,064 kbps     00:35:46.018    28,969 kbps     00:35:02.391    28,644 kbps     00:34:57.386    134,985 bytes   604,301 bytes   00:35:23.079
14              0:36:34.150     0:02:41.369     22,963 kbps     30,188 kbps     00:37:18.110    25,920 kbps     00:37:14.315    25,018 kbps     00:37:10.019    119,718 bytes   563,672 bytes   00:39:11.682
15              0:39:15.519     0:02:42.829     23,058 kbps     31,862 kbps     00:41:49.924    28,714 kbps     00:41:43.292    28,018 kbps     00:41:40.289    120,214 bytes   567,632 bytes   00:41:38.829
16              0:41:58.349     0:03:56.694     25,553 kbps     34,716 kbps     00:43:27.980    29,764 kbps     00:43:38.407    28,946 kbps     00:44:21.950    133,224 bytes   586,571 bytes   00:45:40.070
17              0:45:55.043     0:03:12.192     24,549 kbps     32,121 kbps     00:47:38.564    28,630 kbps     00:46:27.284    27,683 kbps     00:47:50.909    127,989 bytes   572,030 bytes   00:48:00.335
18              0:49:07.235     0:02:29.649     25,226 kbps     31,668 kbps     00:49:12.115    30,088 kbps     00:49:27.255    28,624 kbps     00:49:24.127    131,514 bytes   574,603 bytes   00:51:13.779
19              0:51:36.885     0:02:41.244     23,951 kbps     33,312 kbps     00:53:04.723    27,593 kbps     00:52:06.623    26,468 kbps     00:52:05.038    124,869 bytes   546,445 bytes   00:53:35.045
20              0:54:18.129     0:02:18.179     25,769 kbps     33,515 kbps     00:54:57.210    29,141 kbps     00:54:33.770    27,841 kbps     00:54:29.516    134,348 bytes   604,368 bytes   00:56:15.205
21              0:56:36.309     0:01:59.744     25,072 kbps     33,213 kbps     00:56:42.440    28,511 kbps     00:57:21.688    27,408 kbps     00:57:17.267    130,712 bytes   601,686 bytes   00:57:26.401
22              0:58:36.054     0:02:39.492     25,285 kbps     32,624 kbps     01:00:37.425    28,031 kbps     01:00:03.308    27,151 kbps     00:58:41.976    131,823 bytes   583,910 bytes   01:00:07.937
23              1:01:15.546     0:04:31.771     24,474 kbps     29,960 kbps     01:04:02.588    27,195 kbps     01:02:15.773    26,779 kbps     01:02:22.321    127,598 bytes   556,957 bytes   01:01:36.776
24              1:05:47.318     0:04:24.264     24,887 kbps     33,287 kbps     01:08:18.761    29,629 kbps     01:09:51.103    28,929 kbps     01:09:46.098    129,750 bytes   605,434 bytes   01:06:24.188
25              1:10:11.582     0:05:58.357     23,987 kbps     32,841 kbps     01:15:22.184    29,121 kbps     01:15:01.121    27,477 kbps     01:15:18.639    125,059 bytes   608,265 bytes   01:15:39.868
26              1:16:09.940     0:02:33.236     22,308 kbps     26,956 kbps     01:18:10.102    25,492 kbps     01:18:24.366    24,748 kbps     01:18:20.362    116,305 bytes   503,568 bytes   01:18:43.176
27              1:18:43.176     0:01:25.710     26,135 kbps     32,052 kbps     01:20:01.796    29,195 kbps     01:19:54.206    28,313 kbps     01:19:52.787    136,254 bytes   592,807 bytes   01:18:53.186
28              1:20:08.887     0:01:19.913     23,148 kbps     29,688 kbps     01:20:16.895    26,390 kbps     01:20:12.891    25,479 kbps     01:20:09.471    120,685 bytes   602,584 bytes   01:20:17.646
29              1:21:28.800     0:03:05.560     23,950 kbps     33,431 kbps     01:22:23.104    29,181 kbps     01:24:18.845    28,373 kbps     01:24:18.845    124,866 bytes   558,472 bytes   01:21:44.107
30              1:24:34.360     0:04:59.841     26,421 kbps     33,852 kbps     01:27:28.785    30,897 kbps     01:27:32.163    30,145 kbps     01:27:27.158    137,745 bytes   579,288 bytes   01:27:55.979
31              1:29:34.202     0:01:14.407     23,891 kbps     29,840 kbps     01:30:23.501    28,336 kbps     01:29:45.546    27,435 kbps     01:29:41.084    124,556 bytes   513,954 bytes   01:29:51.094
32              1:30:48.609     0:03:18.656     25,187 kbps     33,213 kbps     01:31:58.179    32,183 kbps     01:31:55.051    31,513 kbps     01:31:54.675    131,315 bytes   591,502 bytes   01:33:51.208
33              1:34:07.266     0:03:05.977     26,090 kbps     33,165 kbps     01:35:18.212    29,999 kbps     01:35:18.129    29,303 kbps     01:36:41.086    136,022 bytes   594,890 bytes   01:36:09.847
34              1:37:13.244     0:02:23.685     24,335 kbps     31,011 kbps     01:37:23.128    27,787 kbps     01:37:19.375    27,276 kbps     01:37:14.370    126,874 bytes   607,512 bytes   01:37:23.170
35              1:39:36.929     0:03:11.774     24,695 kbps     34,258 kbps     01:42:02.533    30,942 kbps     01:42:01.490    29,615 kbps     01:41:56.652    128,747 bytes   558,181 bytes   01:41:49.686
36              1:42:48.704     0:02:25.603     23,296 kbps     29,430 kbps     01:42:53.917    27,894 kbps     01:42:50.873    26,406 kbps     01:42:48.704    121,453 bytes   522,247 bytes   01:45:05.882
37              1:45:14.307     0:05:07.390     23,624 kbps     31,923 kbps     01:47:14.094    28,966 kbps     01:50:16.693    28,447 kbps     01:46:11.990    123,166 bytes   582,216 bytes   01:46:13.950
38              1:50:21.698     0:04:30.103     23,413 kbps     31,674 kbps     01:51:19.172    27,990 kbps     01:51:45.865    27,641 kbps     01:51:38.983    122,066 bytes   605,255 bytes   01:51:04.616
39              1:54:51.801     0:01:36.554     23,886 kbps     31,169 kbps     01:56:10.254    27,643 kbps     01:56:13.007    26,693 kbps     01:56:10.254    124,533 bytes   600,150 bytes   01:56:05.291
40              1:56:28.356     0:01:37.430     25,484 kbps     34,423 kbps     01:56:54.465    28,766 kbps     01:56:53.673    27,668 kbps     01:56:47.166    132,860 bytes   609,239 bytes   01:56:49.210
41              1:58:05.787     0:03:55.485     22,389 kbps     31,008 kbps     01:58:11.417    26,831 kbps     02:01:56.267    25,156 kbps     01:58:06.996    116,726 bytes   595,474 bytes   02:00:46.948
42              2:02:01.272     0:02:05.875     26,633 kbps     33,612 kbps     02:02:39.143    30,603 kbps     02:02:35.139    29,511 kbps     02:02:34.472    138,853 bytes   605,401 bytes   02:02:40.728
43              2:04:07.148     0:00:50.008     21,955 kbps     29,822 kbps     02:04:17.950    25,693 kbps     02:04:23.873    25,007 kbps     02:04:20.786    114,466 bytes   562,705 bytes   02:04:41.098
44              2:04:57.156     0:02:45.874     25,272 kbps     36,053 kbps     02:05:28.896    32,414 kbps     02:05:37.988    31,623 kbps     02:05:37.988    131,757 bytes   605,290 bytes   02:07:28.140
45              2:07:43.030     0:04:01.282     24,869 kbps     33,691 kbps     02:08:21.151    32,097 kbps     02:09:36.602    31,549 kbps     02:09:32.055    129,657 bytes   584,775 bytes   02:08:41.964
46              2:11:44.313     0:01:41.601     23,903 kbps     31,578 kbps     02:11:45.272    28,035 kbps     02:12:48.627    27,388 kbps     02:12:49.419    124,617 bytes   520,463 bytes   02:12:31.318
47              2:13:25.914     0:02:49.919     25,382 kbps     32,104 kbps     02:15:16.733    29,514 kbps     02:15:53.979    28,796 kbps     02:15:07.766    132,331 bytes   588,990 bytes   02:14:45.452
48              2:16:15.834     0:01:52.821     23,911 kbps     29,045 kbps     02:16:36.229    26,576 kbps     02:17:12.182    25,644 kbps     02:16:33.894    124,660 bytes   561,353 bytes   02:18:04.401
49              2:18:08.655     0:03:47.101     24,314 kbps     32,096 kbps     02:20:13.613    27,159 kbps     02:21:32.942    26,509 kbps     02:20:12.320    126,762 bytes   609,805 bytes   02:20:48.731
50              2:21:55.757     0:02:21.432     24,199 kbps     31,981 kbps     02:23:22.093    27,254 kbps     02:23:54.334    26,230 kbps     02:23:51.539    126,163 bytes   583,331 bytes   02:22:00.553
51              2:24:17.190     0:04:36.943     24,854 kbps     34,640 kbps     02:26:56.057    29,693 kbps     02:26:30.990    28,892 kbps     02:26:26.652    129,576 bytes   574,869 bytes   02:24:55.353
52              2:28:54.133     0:06:03.946     25,129 kbps     35,642 kbps     02:33:06.468    30,210 kbps     02:29:23.162    30,092 kbps     02:29:18.157    131,010 bytes   548,091 bytes   02:29:24.622
53              2:34:58.080     0:02:22.767     25,650 kbps     33,745 kbps     02:35:41.999    29,869 kbps     02:35:38.037    28,023 kbps     02:35:33.365    133,726 bytes   497,365 bytes   02:36:18.911
54              2:37:20.848     0:01:58.159     21,456 kbps     28,029 kbps     02:39:15.712    26,315 kbps     02:39:14.002    24,672 kbps     02:39:08.997    111,862 bytes   526,263 bytes   02:39:18.465
55              2:39:19.007     0:02:08.670     24,368 kbps     29,787 kbps     02:39:32.229    27,222 kbps     02:41:22.672    25,991 kbps     02:41:17.667    127,046 bytes   587,139 bytes   02:40:47.304
56              2:41:27.677     0:03:39.135     24,176 kbps     34,360 kbps     02:41:44.111    29,849 kbps     02:43:04.024    28,587 kbps     02:42:59.436    126,043 bytes   579,027 bytes   02:41:54.746
57              2:45:06.813     0:05:45.762     24,201 kbps     32,551 kbps     02:48:39.901    29,892 kbps     02:48:35.897    28,648 kbps     02:49:47.343    126,172 bytes   606,809 bytes   02:49:03.591
58              2:50:52.575     0:02:15.677     27,334 kbps     33,270 kbps     02:52:16.743    30,233 kbps     02:51:34.325    29,507 kbps     02:51:29.612    142,505 bytes   583,332 bytes   02:51:23.106
59              2:53:08.252     0:02:54.299     24,179 kbps     31,361 kbps     02:53:25.561    28,322 kbps     02:53:21.557    27,095 kbps     02:53:19.597    126,058 bytes   572,834 bytes   02:55:29.352
60              2:56:02.551     0:01:16.951     25,894 kbps     30,596 kbps     02:56:16.107    28,766 kbps     02:56:39.255    28,303 kbps     02:56:39.255    135,000 bytes   484,568 bytes   02:56:10.518
61              2:57:19.503     0:03:16.029     25,467 kbps     35,543 kbps     02:58:19.939    32,078 kbps     02:58:15.935    28,704 kbps     03:00:05.586    132,775 bytes   588,578 bytes   02:59:29.592
62              3:00:35.533     0:08:57.828     17,657 kbps     31,853 kbps     03:07:32.783    29,979 kbps     03:07:32.783    29,522 kbps     03:07:30.155    92,064 bytes    458,098 bytes   03:08:25.502
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x02            MPEG-2                                  5448.485                24,192                  16,476,196,261  89,620,565
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5448.485                3,775                   2,570,939,536   14,822,455
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5448.485                35                      24,109,310      136,471
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            5448.485                33                      22,792,986      128,353
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           5448.485                32                      22,044,447      124,291
00001.M2TS      4113 (0x1011)   0x02            MPEG-2                                  5924.669                23,898                  17,698,566,673  96,270,645
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5924.669                3,870                   2,866,340,976   16,502,119
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5924.669                23                      17,386,368      98,676
00001.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            5924.669                22                      16,351,802      92,478
00001.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           5924.669                22                      16,190,569      91,578
paku is offline
post #1730 of 5106 Old 06-23-2010, 01:10 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Dr. Strangelove - 1964 - UK - Sony - Region ABC
Code:
        Total   Video
00001.MPLS                                                      AVC     1:34:45 25,903,054,848  33,387,546,926  36.45   25.96   Dolby TrueHD 5.1 1299Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     DR_STRANGELOVE
Disc Size:      33,387,546,926 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:34:45 (h:m:s)
Total Bitrate:          36.45 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        25958 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
* MPEG-4 AVC Video      646 kbps            480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
Dolby TrueHD Audio              English         1299 kbps       5.1 / 48 kHz / 1299 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              Spanish         1235 kbps       5.1 / 48 kHz / 1235 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             Czech           640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Hungarian       640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Polish          640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps
* DTS Express                   English         128 kbps        2.0 / 48 kHz / 128 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         44.536 kbps
Presentation Graphics           English         33.115 kbps
* Presentation Graphics         English         14.657 kbps
Presentation Graphics           Arabic          18.404 kbps
Presentation Graphics           Bulgarian       39.875 kbps
Presentation Graphics           Czech           33.607 kbps
Presentation Graphics           Danish          32.420 kbps
Presentation Graphics           Finnish         33.397 kbps
Presentation Graphics           Greek, Ancient (to 1453)34.016 kbps
Presentation Graphics           Hebrew          32.089 kbps
Presentation Graphics           Hindi           34.417 kbps
Presentation Graphics           Hungarian       35.651 kbps
Presentation Graphics           Icelandic       42.177 kbps
Presentation Graphics           Norwegian       33.126 kbps
Presentation Graphics           Polish          33.297 kbps
Presentation Graphics           Portuguese      34.144 kbps
Presentation Graphics           Slovak          42.894 kbps
Presentation Graphics           Spanish         36.359 kbps
* Presentation Graphics         Spanish         14.445 kbps
Presentation Graphics           Swedish         33.085 kbps
Presentation Graphics           Turkish         39.397 kbps
FILES:
00011.M2TS      0:00:00.000     1:34:45.680     25,903,054,848  36,447
CHAPTERS:
1               0:00:00.000     0:05:50.683     26,033 kbps     48,327 kbps     00:00:36.578    32,164 kbps     00:02:15.135    30,347 kbps     00:02:25.854    135,709 bytes   457,555 bytes   00:00:26.735
2               0:05:50.683     0:05:49.974     25,805 kbps     39,712 kbps     00:09:07.296    31,913 kbps     00:07:42.545    30,852 kbps     00:07:40.168    134,536 bytes   375,347 bytes   00:07:25.278
3               0:11:40.658     0:04:46.619     27,285 kbps     34,827 kbps     00:15:42.358    30,950 kbps     00:15:51.742    30,299 kbps     00:15:51.700    142,252 bytes   412,054 bytes   00:15:42.399
4               0:16:27.277     0:07:46.215     25,167 kbps     33,154 kbps     00:18:29.900    28,857 kbps     00:18:30.275    28,691 kbps     00:21:07.599    131,211 bytes   375,811 bytes   00:20:08.540
5               0:24:13.493     0:07:48.259     25,826 kbps     39,734 kbps     00:30:36.876    29,271 kbps     00:30:32.872    28,009 kbps     00:29:12.167    134,644 bytes   361,615 bytes   00:30:35.667
6               0:32:01.753     0:04:26.474     26,275 kbps     33,582 kbps     00:35:46.727    31,658 kbps     00:35:38.177    30,931 kbps     00:35:37.760    136,985 bytes   334,180 bytes   00:32:10.720
7               0:36:28.227     0:03:32.128     26,368 kbps     33,366 kbps     00:39:14.268    29,303 kbps     00:39:19.648    28,792 kbps     00:39:18.773    137,470 bytes   346,736 bytes   00:38:16.335
8               0:40:00.356     0:05:33.791     25,522 kbps     31,725 kbps     00:43:19.305    28,628 kbps     00:43:19.430    28,341 kbps     00:43:19.430    133,061 bytes   366,963 bytes   00:40:24.171
9               0:45:34.148     0:08:25.004     26,034 kbps     47,784 kbps     00:48:00.502    28,771 kbps     00:47:51.535    27,585 kbps     00:47:46.488    135,727 bytes   378,401 bytes   00:48:00.961
10              0:53:59.152     0:07:23.443     25,956 kbps     34,942 kbps     00:54:34.187    29,993 kbps     00:54:34.187    29,194 kbps     00:54:31.643    135,325 bytes   364,883 bytes   00:58:18.244
11              1:01:22.595     0:04:04.953     25,855 kbps     42,315 kbps     01:04:26.445    30,751 kbps     01:03:51.619    29,993 kbps     01:03:51.869    134,799 bytes   433,666 bytes   01:04:29.991
12              1:05:27.548     0:07:49.760     26,421 kbps     38,115 kbps     01:09:20.865    31,949 kbps     01:09:20.823    30,836 kbps     01:09:20.865    137,748 bytes   378,080 bytes   01:05:59.789
13              1:13:17.309     0:04:31.521     25,248 kbps     34,796 kbps     01:15:00.621    32,874 kbps     01:14:53.280    30,981 kbps     01:14:53.280    131,631 bytes   351,841 bytes   01:16:29.585
14              1:17:48.830     0:02:48.918     25,138 kbps     34,117 kbps     01:17:50.457    32,069 kbps     01:17:50.165    29,012 kbps     01:17:48.830    131,058 bytes   340,172 bytes   01:19:15.625
15              1:20:37.749     0:07:00.545     26,856 kbps     40,969 kbps     01:26:03.032    32,928 kbps     01:23:01.476    31,498 kbps     01:22:55.762    140,012 bytes   413,518 bytes   01:26:03.575
16              1:27:38.294     0:07:07.385     25,434 kbps     41,240 kbps     01:34:32.708    31,500 kbps     01:33:01.659    30,219 kbps     01:32:59.573    132,616 bytes   416,092 bytes   01:34:33.376
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     5685.597                25,959                  18,448,712,078  100,344,879
00011.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           5685.597                1,939                   1,378,308,996   9,838,928
00011.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5685.597                192                     136,456,704     888,390
00011.M2TS      4354 (0x1102)   0x83            TrueHD          spa (Spanish)           5685.597                1,875                   1,332,694,338   9,674,029
00011.M2TS      4355 (0x1103)   0x81            AC3             ces (Czech)             5685.597                640                     454,855,680     2,665,170
00011.M2TS      4356 (0x1104)   0x81            AC3             hun (Hungarian)         5685.597                640                     454,855,680     2,665,170
00011.M2TS      4357 (0x1105)   0x81            AC3             pol (Polish)            5685.597                640                     454,855,680     2,665,170
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5685.597                45                      31,652,505      179,804
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5685.597                33                      23,534,887      135,979
00011.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           5685.597                36                      25,840,820      146,865
00011.M2TS      4611 (0x1203)   0x90            PGS             ces (Czech)             5685.597                34                      23,884,558      137,549
00011.M2TS      4612 (0x1204)   0x90            PGS             hun (Hungarian)         5685.597                36                      25,337,741      145,589
00011.M2TS      4613 (0x1205)   0x90            PGS             pol (Polish)            5685.597                33                      23,664,765      135,665
00011.M2TS      4614 (0x1206)   0x90            PGS             ara (Arabic)            5685.597                18                      13,079,771      76,618
00011.M2TS      4615 (0x1207)   0x90            PGS             bul (Bulgarian)         5685.597                40                      28,339,276      161,962
00011.M2TS      4616 (0x1208)   0x90            PGS             dan (Danish)            5685.597                32                      23,041,214      130,760
00011.M2TS      4617 (0x1209)   0x90            PGS             fin (Finnish)           5685.597                33                      23,735,812      134,600
00011.M2TS      4618 (0x120A)   0x90            PGS             grc (Greek, Ancient (to 1453))5685.597                34                      24,175,673      136,931
00011.M2TS      4619 (0x120B)   0x90            PGS             heb (Hebrew)            5685.597                32                      22,806,254      131,838
00011.M2TS      4620 (0x120C)   0x90            PGS             hin (Hindi)             5685.597                34                      24,460,569      140,809
00011.M2TS      4621 (0x120D)   0x90            PGS             isl (Icelandic)         5685.597                42                      29,975,458      170,807
00011.M2TS      4622 (0x120E)   0x90            PGS             nor (Norwegian)         5685.597                33                      23,542,802      133,527
00011.M2TS      4623 (0x120F)   0x90            PGS             por (Portuguese)        5685.597                34                      24,266,413      137,486
00011.M2TS      4624 (0x1210)   0x90            PGS             slk (Slovak)            5685.597                43                      30,485,166      173,585
00011.M2TS      4625 (0x1211)   0x90            PGS             swe (Swedish)           5685.597                33                      23,513,784      133,520
00011.M2TS      4626 (0x1212)   0x90            PGS             tur (Turkish)           5685.597                39                      27,999,595      160,051
00011.M2TS      4627 (0x1213)   0x90            PGS             eng (English)           5685.597                15                      10,416,714      58,952
00011.M2TS      4628 (0x1214)   0x90            PGS             spa (Spanish)           5685.597                14                      10,265,957      58,178
00011.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           5685.597                128                     90,883,320      533,040
00011.M2TS      6912 (0x1B00)   0x1B            AVC                                     5685.597                646                     458,831,680     2,564,887
paku is offline
post #1731 of 5106 Old 06-23-2010, 01:48 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Layer Cake - 2004 - UK - Sony - Region ABC
Code:
        Total   Video
00004.MPLS                                                      MPEG-2  1:45:34 26,881,775,616  32,765,612,346  33.95   26.58   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Size:      32,765,612,346 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:45:34 (h:m:s)
Total Bitrate:          33.95 Mbps
VIDEO:
MPEG-2 Video            26583 kbps          1080p / 23.976 fps / 16:9
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         56.037 kbps
Presentation Graphics           English         43.842 kbps
Presentation Graphics           English         100.655 kbps
Presentation Graphics           Hindi           42.338 kbps
FILES:
00000.M2TS      0:00:00.000     1:45:34.619     26,881,775,616  33,949
CHAPTERS:
1               0:00:00.000     0:15:45.986     26,469 kbps     36,458 kbps     00:07:24.444    32,217 kbps     00:01:02.937    31,612 kbps     00:00:57.932    137,990 bytes   675,725 bytes   00:07:15.852
2               0:15:45.986     0:06:47.198     26,916 kbps     34,538 kbps     00:22:30.766    30,734 kbps     00:16:34.910    30,356 kbps     00:16:28.404    140,330 bytes   675,722 bytes   00:16:46.422
3               0:22:33.185     0:07:35.496     26,843 kbps     35,710 kbps     00:25:15.013    30,897 kbps     00:25:13.512    30,288 kbps     00:28:01.680    139,949 bytes   675,726 bytes   00:28:15.860
4               0:30:08.681     0:03:18.114     26,202 kbps     34,112 kbps     00:30:25.532    30,073 kbps     00:30:46.970    29,264 kbps     00:30:25.990    136,603 bytes   675,722 bytes   00:30:45.510
5               0:33:26.796     0:04:12.502     26,227 kbps     34,650 kbps     00:35:50.148    30,234 kbps     00:35:31.796    29,262 kbps     00:35:30.461    136,738 bytes   675,725 bytes   00:34:13.468
6               0:37:39.298     0:05:08.016     27,033 kbps     36,309 kbps     00:38:39.900    32,476 kbps     00:38:44.238    31,995 kbps     00:38:44.238    140,939 bytes   675,726 bytes   00:37:55.690
7               0:42:47.314     0:03:28.833     26,626 kbps     34,045 kbps     00:44:18.113    30,998 kbps     00:44:14.276    29,912 kbps     00:45:10.999    138,817 bytes   675,725 bytes   00:45:21.510
8               0:46:16.148     0:04:12.877     25,681 kbps     32,467 kbps     00:49:56.868    28,688 kbps     00:50:11.883    28,212 kbps     00:50:06.294    133,888 bytes   675,723 bytes   00:48:09.428
9               0:50:29.026     0:08:52.532     26,705 kbps     34,949 kbps     00:55:50.013    31,463 kbps     00:55:46.009    30,673 kbps     00:58:55.198    139,230 bytes   675,726 bytes   00:50:38.452
10              0:59:21.558     0:05:44.552     26,731 kbps     34,848 kbps     01:03:04.781    31,026 kbps     01:00:48.519    30,366 kbps     01:00:48.102    139,363 bytes   675,724 bytes   01:01:43.491
11              1:05:06.110     0:07:12.098     26,205 kbps     34,745 kbps     01:12:02.901    30,870 kbps     01:11:58.897    29,789 kbps     01:06:12.635    136,619 bytes   675,724 bytes   01:08:55.005
12              1:12:18.208     0:05:10.893     27,252 kbps     34,899 kbps     01:16:22.661    31,266 kbps     01:16:18.657    30,779 kbps     01:16:17.155    142,082 bytes   675,723 bytes   01:13:31.281
13              1:17:29.102     0:04:26.265     26,506 kbps     33,311 kbps     01:17:57.631    30,554 kbps     01:17:55.629    30,524 kbps     01:17:47.871    138,193 bytes   675,723 bytes   01:21:30.510
14              1:21:55.368     0:07:02.130     27,977 kbps     35,751 kbps     01:27:47.053    31,923 kbps     01:28:35.476    31,297 kbps     01:28:27.719    145,861 bytes   675,726 bytes   01:25:27.831
15              1:28:57.498     0:02:54.048     27,065 kbps     33,812 kbps     01:29:44.712    30,287 kbps     01:29:40.917    29,973 kbps     01:30:06.734    141,104 bytes   675,722 bytes   01:31:25.813
16              1:31:51.547     0:13:43.072     25,719 kbps     34,100 kbps     01:40:52.087    31,521 kbps     01:41:15.486    31,372 kbps     01:41:14.985    134,093 bytes   675,726 bytes   01:41:36.298
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x02            MPEG-2                                  6334.495                26,584                  21,049,406,547  114,487,403
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6334.495                640                     506,769,920     2,969,355
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6334.495                4,614                   3,653,808,816   20,270,784
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6334.495                192                     152,030,976     989,785
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6334.495                56                      44,371,377      248,325
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6334.495                44                      34,715,547      197,500
00000.M2TS      4610 (0x1202)   0x90            PGS             hin (Hindi)             6334.495                42                      33,524,699      189,162
00000.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           6334.495                101                     79,701,460      444,678
paku is offline
post #1732 of 5106 Old 06-23-2010, 08:34 PM
Leon: The Professional - 1994 - UK version
Distributed by Optimum Releasing Ltd
Locked to Region B, confirmed with AnyDVD HD. No messages, but would not play in Region A or Region C.
Has both theatrical and director's (or international) cut, as separate encodes, not via branching. DC is the main one, while the theatrical is a special extra, sans subtitles. The LPCM audio on both versions is a stereo version of the main audio, not a commentary.
Director's Cut:
Code:
        Total   Video
00004.MPLS                                                      AVC     2:12:43 25,791,123,456  49,616,912,998  25.91   19.33   DTS-HD Master 5.1 3407Kbps (48kHz/24-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LEON
Disc Size:      49,616,912,998 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:12:43 (h:m:s)
Total Bitrate:          25.91 Mbps
VIDEO:
MPEG-4 AVC Video        19331 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3407 kbps       5.1 / 48 kHz / 3407 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         22.888 kbps
FILES:
00012.M2TS      0:00:00.000     2:12:43.833     25,791,123,456  25,908
CHAPTERS:
1               0:00:00.000     0:10:02.041     19,551 kbps     37,734 kbps     00:07:02.249    34,768 kbps     00:07:01.625    32,422 kbps     00:06:55.958    101,819 bytes   298,829 bytes   00:06:40.083
2               0:10:02.041     0:09:53.041     14,971 kbps     31,342 kbps     00:19:00.833    26,145 kbps     00:18:00.750    22,511 kbps     00:18:32.166    77,973 bytes    300,975 bytes   00:10:45.250
3               0:19:55.083     0:10:18.333     20,353 kbps     36,557 kbps     00:25:09.833    33,133 kbps     00:25:06.875    30,743 kbps     00:25:05.833    106,006 bytes   395,289 bytes   00:25:09.250
4               0:30:13.416     0:09:53.541     18,579 kbps     33,867 kbps     00:33:36.208    31,823 kbps     00:33:34.416    31,381 kbps     00:33:32.208    96,766 bytes    392,899 bytes   00:33:38.250
5               0:40:06.958     0:16:30.250     18,216 kbps     34,680 kbps     00:49:51.458    30,244 kbps     00:55:26.916    27,046 kbps     00:55:25.624    94,874 bytes    334,447 bytes   00:50:56.875
6               0:56:37.208     0:16:42.666     18,739 kbps     34,957 kbps     01:12:46.291    28,827 kbps     01:12:45.583    25,320 kbps     01:10:48.749    97,599 bytes    301,224 bytes   00:56:49.250
7               1:13:19.875     0:07:23.708     22,110 kbps     35,140 kbps     01:15:16.749    30,555 kbps     01:14:23.625    29,538 kbps     01:14:18.624    115,155 bytes   287,437 bytes   01:14:43.250
8               1:20:43.583     0:17:19.166     20,303 kbps     36,370 kbps     01:20:48.541    30,204 kbps     01:20:47.583    29,413 kbps     01:20:47.333    105,743 bytes   301,957 bytes   01:27:20.500
9               1:38:02.750     0:09:16.958     23,111 kbps     32,281 kbps     01:46:07.874    30,616 kbps     01:40:17.875    30,519 kbps     01:40:08.583    120,372 bytes   303,006 bytes   01:43:39.291
10              1:47:19.708     0:08:39.583     22,485 kbps     36,892 kbps     01:54:02.041    33,687 kbps     01:49:01.500    30,451 kbps     01:54:31.833    117,108 bytes   279,487 bytes   01:55:20.958
11              1:55:59.291     0:08:24.375     23,153 kbps     37,229 kbps     01:59:42.874    32,143 kbps     01:58:59.041    30,361 kbps     01:56:35.124    120,589 bytes   288,530 bytes   02:00:40.625
12              2:04:23.666     0:08:20.166     11,441 kbps     32,507 kbps     02:07:22.583    30,536 kbps     02:07:22.000    28,734 kbps     02:07:20.583    59,596 bytes    422,199 bytes   02:07:22.625
STREAM DIAGNOSTICS:
00012.M2TS      4113 (0x1011)   0x1B            AVC                                     7963.750                19,332                  19,243,958,313  104,698,468
00012.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7963.750                3,407                   3,391,827,548   19,675,823
00012.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           7963.750                1,542                   1,535,427,388   9,556,602
00012.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7963.750                23                      22,784,220      131,066
Theatrical:
Code:
        Total   Video
00001.MPLS                                                      AVC     1:50:12 21,207,767,040  49,616,912,998  25.66   18.47   DTS-HD Master 5.1 4049Kbps (48kHz/24-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LEON
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:50:12 (h:m:s)
Total Bitrate:          25.66 Mbps
VIDEO:
MPEG-4 AVC Video        18473 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4049 kbps       5.1 / 48 kHz / 4049 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
FILES:
00003.M2TS      0:00:00.000     1:50:12.583     21,207,767,040  25,657
CHAPTERS:
1               0:00:00.000     0:10:01.208     20,497 kbps     37,653 kbps     00:02:56.999    34,326 kbps     00:07:01.791    32,206 kbps     00:06:56.124    106,747 bytes   309,578 bytes   00:01:29.750
2               0:10:01.208     0:09:54.041     20,482 kbps     37,307 kbps     00:19:35.999    34,987 kbps     00:19:33.333    34,433 kbps     00:19:28.999    106,675 bytes   396,656 bytes   00:10:24.291
3               0:19:55.250     0:10:18.333     21,459 kbps     38,291 kbps     00:26:30.041    35,287 kbps     00:25:06.083    33,955 kbps     00:26:34.541    111,766 bytes   410,040 bytes   00:26:04.208
4               0:30:13.583     0:09:53.541     20,464 kbps     37,353 kbps     00:33:37.374    34,933 kbps     00:33:34.416    34,418 kbps     00:33:33.374    106,582 bytes   429,326 bytes   00:33:38.416
5               0:40:07.125     0:06:22.333     20,806 kbps     32,392 kbps     00:44:56.083    27,749 kbps     00:44:25.375    26,683 kbps     00:44:10.166    108,363 bytes   298,038 bytes   00:44:57.125
6               0:46:29.458     0:09:47.291     18,999 kbps     35,966 kbps     00:49:41.749    34,119 kbps     00:55:10.625    33,989 kbps     00:55:06.166    98,954 bytes    418,329 bytes   00:50:36.416
7               0:56:16.750     0:07:11.291     16,597 kbps     36,870 kbps     01:00:56.124    34,120 kbps     01:00:55.125    27,055 kbps     01:00:50.166    86,441 bytes    443,196 bytes   01:00:55.166
8               1:03:28.041     0:07:36.041     15,099 kbps     22,288 kbps     01:09:54.499    20,114 kbps     01:04:06.083    19,052 kbps     01:09:48.916    78,642 bytes    270,279 bytes   01:03:36.041
9               1:11:04.083     0:09:39.541     17,077 kbps     31,013 kbps     01:17:20.458    27,134 kbps     01:17:17.333    26,234 kbps     01:17:17.374    88,941 bytes    276,362 bytes   01:17:27.541
10              1:20:43.625     0:09:30.250     17,948 kbps     30,808 kbps     01:26:23.166    29,333 kbps     01:26:30.916    25,572 kbps     01:26:26.541    93,478 bytes    293,066 bytes   01:24:49.125
11              1:30:13.875     0:09:39.041     17,947 kbps     35,754 kbps     01:31:31.458    29,163 kbps     01:31:28.750    26,447 kbps     01:31:24.958    93,474 bytes    253,469 bytes   01:31:31.500
12              1:39:52.916     0:10:19.666     13,828 kbps     38,029 kbps     01:45:00.999    35,595 kbps     01:44:51.375    35,222 kbps     01:44:51.999    72,027 bytes    477,960 bytes   01:44:53.041
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     6612.417                18,473                  15,269,200,876  83,077,533
00003.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6612.417                4,049                   3,346,803,448   19,222,972
00003.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6612.417                1,542                   1,274,898,676   7,935,054
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1733 of 5106 Old 06-23-2010, 08:41 PM
Stephen Dawson's Avatar
Leon: The Professional - 1994 - Australian version
Distributed by Madman Entertainment Pty Ltd
Locked to Region B, confirmed with AnyDVD HD (has proper Region Code violation notification)
As with UK version, there are two encodes for the Theatrical and Director's Cut versions. The DC is the main title and the other version is a special extra. Indeed, these appear to be identical encodes to the UK version, and the special extras are the same as well, with the same bitrates and formats. But this is still a different disc, with Madman's logo and small differences (eg. each Title has one extra Chapter -- one right at the very end to allow a skip to the end of the Title).
Director's Cut:
Code:
        Total   Video
00004.MPLS                                                      AVC     2:12:43 25,791,123,456  49,830,111,918  25.91   19.33   DTS-HD Master 5.1 3407Kbps (48kHz/24-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LEON_THE PROFESSIONAL
Disc Size:      49,830,111,918 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
VIDEO:
AUDIO:
SUBTITLES:
FILES:
CHAPTERS:
STREAM DIAGNOSTICS:
Theatrical:
Code:
        Total   Video
00001.MPLS                                                      AVC     1:50:12 21,207,767,040  49,830,111,918  25.66   18.47   DTS-HD Master 5.1 4049Kbps (48kHz/24-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
VIDEO:
AUDIO:
FILES:
CHAPTERS:
STREAM DIAGNOSTICS:
Stephen Dawson
hifi-writer.com
post #1734 of 5106 Old 06-23-2010, 08:55 PM
Toy Story 2 - 1999 - Australian version
Distributed by Walt Disney Studios Home Entertainment
Region Free, confirmed with AnyDVD HD
As with Toy Story, which I posted some while back, this would appear to be an Eastern European/Middle Eastern version of this disc, in view of the language package (English, Czech, Slovak, Greek, Bulgarian, Arabic and Ukranian).
Also, as with the Australian version of Toy Story, the same *.m2ts file list is used for each language playlist, except for a variation in the last couple of files. The only significant difference is is a 22 to 23 second segment at the end detailing additional credits for the relevant language version (eg. voices).
I'm only showing the English language stats here for the Australian version, with the repetitive 'Stream' data stripped out.
Code:
        Total   Video
00200.MPLS                                                      AVC     1:32:25 24,995,874,816  37,181,002,538  36.06   24.48   DTS-HD Master 5.1-ES 4038Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TOY_STORY_2_LIC
Disc Size:      37,181,002,538 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:32:25 (h:m:s)
Total Bitrate:          36.06 Mbps
VIDEO:
MPEG-4 AVC Video        24483 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4038 kbps       5.1-ES / 48 kHz / 4038 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         320 kbps        2.0 / 48 kHz / 320 kbps / Dolby Surround
Dolby Digital EX Audio          Czech           640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Greek           640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Arabic          640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Slovak          640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Bulgarian       640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Ukrainian       640 kbps        5.1-EX / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         39.227 kbps
Presentation Graphics           English         49.168 kbps
Presentation Graphics           Czech           35.392 kbps
Presentation Graphics           Greek           33.897 kbps
Presentation Graphics           Arabic          22.039 kbps
Presentation Graphics           Slovak          33.962 kbps
Presentation Graphics           Bulgarian       37.255 kbps
Presentation Graphics           Ukrainian       38.471 kbps
Presentation Graphics           Latvian         27.542 kbps
Presentation Graphics           Lithuanian      36.682 kbps
Presentation Graphics           Serbian         36.666 kbps
Presentation Graphics           Estonian        28.225 kbps
Presentation Graphics           Slovenian       20.115 kbps
Presentation Graphics           Czech           58.733 kbps
Presentation Graphics           Greek           68.501 kbps
Presentation Graphics           Arabic          38.044 kbps
Presentation Graphics           Slovak          61.893 kbps
Presentation Graphics           Bulgarian       66.833 kbps
Presentation Graphics           Ukrainian       69.866 kbps
Presentation Graphics           Serbian         65.507 kbps
Presentation Graphics           Slovenian       58.588 kbps
Presentation Graphics           Czech           0.378 kbps
Presentation Graphics           Greek           0.375 kbps
Presentation Graphics           Arabic          0.201 kbps
Presentation Graphics           Slovak          0.330 kbps
Presentation Graphics           Bulgarian       0.310 kbps
Presentation Graphics           Ukrainian       0.386 kbps
FILES:
00375.M2TS      0:00:00.000     0:00:44.502     248,156,160     44,610
00376.M2TS      0:00:44.502     0:00:52.844     249,655,296     37,795
00377.M2TS      0:01:37.347     0:02:02.956     711,413,760     46,287
00378.M2TS      0:03:40.303     0:00:44.461     197,179,392     35,479
00379.M2TS      0:04:24.764     0:13:45.449     3,664,373,760   35,514
00380.M2TS      0:18:10.214     0:00:26.860     119,267,328     35,522
00381.M2TS      0:18:37.074     0:13:55.584     3,778,037,760   36,171
00491.M2TS      0:32:32.658     0:00:33.116     140,150,784     33,857
00489.M2TS      0:33:05.775     0:06:58.876     1,845,073,920   35,239
00382.M2TS      0:40:04.652     0:00:40.290     184,707,072     36,675
00383.M2TS      0:40:44.942     0:02:15.385     606,769,152     35,854
00384.M2TS      0:43:00.327     0:00:29.154     128,335,872     35,216
00385.M2TS      0:43:29.481     0:07:18.396     1,939,058,688   35,385
00387.M2TS      0:50:47.878     0:00:45.420     211,943,424     37,330
00388.M2TS      0:51:33.298     0:33:35.346     9,034,813,440   35,864
00389.M2TS      1:25:08.645     0:00:39.330     172,572,672     35,102
00390.M2TS      1:25:47.976     0:06:12.997     1,633,769,472   35,041
00577.M2TS      1:32:00.973     0:00:24.441     130,596,864     42,747
CHAPTERS:
1               0:00:00.000     0:01:23.583     31,349 kbps     37,657 kbps     00:00:54.971    34,330 kbps     00:01:12.197    34,002 kbps     00:00:13.263    163,356 bytes   637,776 bytes   00:01:17.118
2               0:01:23.583     0:03:24.704     30,033 kbps     41,457 kbps     00:02:28.439    35,228 kbps     00:02:10.088    34,539 kbps     00:02:05.083    156,579 bytes   880,371 bytes   00:02:15.093
3               0:04:48.287     0:02:47.500     23,181 kbps     35,110 kbps     00:06:58.501    30,006 kbps     00:04:48.413    28,551 kbps     00:04:48.287    120,856 bytes   621,093 bytes   00:07:09.554
4               0:07:35.788     0:03:05.143     23,860 kbps     36,986 kbps     00:07:52.430    33,685 kbps     00:08:07.445    31,773 kbps     00:08:03.274    124,394 bytes   702,127 bytes   00:09:21.936
5               0:10:40.931     0:01:13.865     24,416 kbps     36,837 kbps     00:10:45.394    33,917 kbps     00:10:41.474    33,540 kbps     00:10:41.599    127,295 bytes   680,041 bytes   00:10:46.312
6               0:11:54.797     0:00:52.302     21,483 kbps     35,073 kbps     00:12:03.055    32,239 kbps     00:12:00.010    25,853 kbps     00:11:57.341    112,003 bytes   453,001 bytes   00:12:19.780
7               0:12:47.099     0:02:42.829     23,878 kbps     38,389 kbps     00:15:26.050    33,370 kbps     00:15:22.046    31,019 kbps     00:15:19.918    124,488 bytes   892,114 bytes   00:15:28.802
8               0:15:29.928     0:02:45.915     24,576 kbps     38,988 kbps     00:17:14.324    33,871 kbps     00:17:25.169    33,453 kbps     00:17:19.580    128,129 bytes   932,921 bytes   00:15:34.725
9               0:18:15.844     0:02:01.746     24,181 kbps     34,711 kbps     00:18:22.309    30,417 kbps     00:18:19.806    27,178 kbps     00:18:19.848    126,071 bytes   636,235 bytes   00:18:49.878
10              0:20:17.591     0:03:56.444     23,701 kbps     35,987 kbps     00:24:08.238    33,635 kbps     00:24:04.234    31,605 kbps     00:24:01.481    123,567 bytes   727,195 bytes   00:23:25.320
11              0:24:14.035     0:01:40.350     24,922 kbps     35,777 kbps     00:24:28.925    33,603 kbps     00:24:28.925    33,213 kbps     00:24:27.799    129,930 bytes   685,126 bytes   00:25:25.565
12              0:25:54.386     0:04:37.735     25,227 kbps     37,154 kbps     00:28:54.899    33,521 kbps     00:25:59.224    33,031 kbps     00:25:56.721    131,520 bytes   658,736 bytes   00:30:20.360
13              0:30:32.121     0:01:16.326     25,375 kbps     38,702 kbps     00:30:53.977    34,280 kbps     00:30:50.014    33,187 kbps     00:30:50.014    132,292 bytes   923,525 bytes   00:30:54.936
14              0:31:48.448     0:01:03.021     26,869 kbps     35,857 kbps     00:32:38.206    33,516 kbps     00:32:46.464    33,330 kbps     00:32:41.459    140,083 bytes   640,990 bytes   00:32:12.388
15              0:32:51.469     0:03:53.524     20,939 kbps     38,213 kbps     00:35:06.145    34,186 kbps     00:34:16.137    31,609 kbps     00:34:13.134    109,169 bytes   640,830 bytes   00:34:21.726
16              0:36:44.994     0:02:24.143     27,752 kbps     40,101 kbps     00:37:52.770    34,259 kbps     00:37:22.114    33,706 kbps     00:37:23.074    144,684 bytes   827,288 bytes   00:37:14.190
17              0:39:09.138     0:00:43.918     21,744 kbps     39,077 kbps     00:39:51.680    31,420 kbps     00:39:47.676    24,961 kbps     00:39:42.796    113,361 bytes   555,112 bytes   00:39:17.771
18              0:39:53.057     0:01:13.281     24,287 kbps     39,025 kbps     00:39:53.432    31,922 kbps     00:40:06.946    29,507 kbps     00:40:06.237    126,619 bytes   901,905 bytes   00:39:55.351
19              0:41:06.338     0:01:19.871     25,388 kbps     35,017 kbps     00:41:14.305    33,371 kbps     00:41:19.268    33,190 kbps     00:41:14.263    132,359 bytes   592,876 bytes   00:42:00.517
20              0:42:26.210     0:02:15.134     23,878 kbps     38,387 kbps     00:44:38.842    34,355 kbps     00:42:42.476    31,731 kbps     00:42:37.513    124,491 bytes   936,193 bytes   00:42:54.655
21              0:44:41.345     0:02:17.220     25,714 kbps     38,353 kbps     00:46:57.064    33,866 kbps     00:46:52.476    32,314 kbps     00:46:28.118    134,063 bytes   908,592 bytes   00:46:57.481
22              0:46:58.565     0:06:25.384     23,624 kbps     40,260 kbps     00:49:13.784    34,535 kbps     00:49:09.780    33,823 kbps     00:51:36.760    123,167 bytes   925,911 bytes   00:51:37.302
23              0:53:23.950     0:02:55.967     24,810 kbps     37,192 kbps     00:56:05.403    33,623 kbps     00:54:15.960    31,463 kbps     00:54:13.958    129,346 bytes   650,957 bytes   00:56:16.956
24              0:56:19.918     0:04:50.123     24,134 kbps     38,135 kbps     00:57:10.134    33,905 kbps     00:56:53.910    33,485 kbps     00:59:01.913    125,825 bytes   827,031 bytes   00:59:22.934
25              1:01:10.041     0:01:04.230     24,898 kbps     34,857 kbps     01:02:12.770    32,038 kbps     01:02:08.891    30,197 kbps     01:02:04.262    129,808 bytes   557,399 bytes   01:01:14.170
26              1:02:14.272     0:02:09.629     24,937 kbps     36,304 kbps     01:03:01.110    33,334 kbps     01:02:57.106    31,248 kbps     01:03:28.846    130,010 bytes   639,869 bytes   01:03:02.111
27              1:04:23.901     0:03:36.507     21,994 kbps     32,988 kbps     01:07:22.413    28,686 kbps     01:07:18.617    26,486 kbps     01:07:13.404    114,664 bytes   864,460 bytes   01:07:24.415
28              1:08:00.409     0:01:51.778     22,812 kbps     36,387 kbps     01:09:45.973    27,397 kbps     01:09:46.223    25,463 kbps     01:08:20.429    118,931 bytes   552,455 bytes   01:09:49.768
29              1:09:52.187     0:02:35.280     26,826 kbps     36,104 kbps     01:10:38.358    33,542 kbps     01:11:10.307    32,986 kbps     01:10:53.081    139,856 bytes   625,856 bytes   01:12:10.075
30              1:12:27.467     0:02:31.025     24,361 kbps     37,203 kbps     01:14:53.363    34,478 kbps     01:14:52.821    29,211 kbps     01:14:48.483    127,005 bytes   640,025 bytes   01:12:28.468
31              1:14:58.493     0:02:29.816     27,045 kbps     37,868 kbps     01:17:08.748    33,839 kbps     01:16:43.849    33,520 kbps     01:16:46.935    140,999 bytes   554,064 bytes   01:17:08.790
32              1:17:28.310     0:02:17.971     21,841 kbps     34,346 kbps     01:18:17.901    33,057 kbps     01:18:13.688    31,678 kbps     01:18:12.812    113,869 bytes   482,982 bytes   01:17:34.608
33              1:19:46.281     0:01:49.526     25,354 kbps     38,589 kbps     01:21:26.423    33,858 kbps     01:21:22.460    33,318 kbps     01:21:04.818    132,185 bytes   470,076 bytes   01:20:20.398
34              1:21:35.807     0:04:13.169     23,237 kbps     41,351 kbps     01:21:45.275    34,258 kbps     01:25:41.803    32,579 kbps     01:25:24.494    121,148 bytes   713,298 bytes   01:25:03.514
35              1:25:48.977     0:06:36.437     24,033 kbps     38,098 kbps     01:32:07.438    34,595 kbps     01:32:02.683    34,000 kbps     01:32:01.015    125,311 bytes   566,564 bytes   01:30:16.911
Stephen Dawson
hifi-writer.com
post #1735 of 5106 Old 06-23-2010, 10:53 PM - Thread Starter
Cinema Squid's Avatar
[US] Che (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Criterion
UPC: 715515049610
Release Date: 2010-01-19
Aspect Ratio: 2.40:1 / 1.78:1
A film in two parts on two discs in one package. Apparently, the two parts have been released separately in some countries, although it is not so horrendously confusing as Red Cliff, since there is no reduced "theatrical" cut to confuse matters further.
English DD 2.0 is a commentary.
Code:
        Total   Video
[US] Che: Part 1: The Argentine                                 AVC     2:14:28 37,981,077,504  48,174,007,713  37.66   28.00   DTS-HD Master 5.1 3631Kbps (48kHz/24-bit)
          Part 2: Guerilla                                      AVC     2:15:22 35,036,418,048  49,735,733,989  34.51   28.99   DTS-HD Master 5.1 3516Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     CHE
Disc Size:      48,174,007,713 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 2:14:28 (h:m:s)
Total Bitrate:          37.66 Mbps
VIDEO:
MPEG-4 AVC Video        27997 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             Spanish         3631 kbps       5.1 / 48 kHz / 3631 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         3629 kbps       5.1 / 48 kHz / 3629 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         38.473 kbps
Presentation Graphics           English         34.833 kbps
FILES:
00262.M2TS      0:00:00.000     2:14:28.101     37,981,077,504  37,660
CHAPTERS:
1               0:00:00.000     0:03:25.288     6,042 kbps      34,567 kbps     00:00:19.477    33,934 kbps     00:00:02.419    33,877 kbps     00:00:02.335    31,492 bytes    375,336 bytes   00:02:35.155
2               0:03:25.288     0:01:56.741     26,570 kbps     35,171 kbps     00:04:21.928    33,950 kbps     00:04:45.159    33,882 kbps     00:04:45.076    138,522 bytes   255,184 bytes   00:04:30.270
3               0:05:22.030     0:04:01.658     31,125 kbps     35,052 kbps     00:06:13.998    33,998 kbps     00:06:48.866    33,909 kbps     00:06:43.861    162,271 bytes   272,458 bytes   00:07:13.808
4               0:09:23.688     0:01:18.703     32,414 kbps     38,859 kbps     00:09:34.031    34,102 kbps     00:10:37.386    33,947 kbps     00:10:32.381    168,991 bytes   363,724 bytes   00:10:42.391
5               0:10:42.391     0:03:20.575     30,994 kbps     36,411 kbps     00:13:25.930    34,253 kbps     00:13:22.092    34,047 kbps     00:13:16.837    161,590 bytes   587,602 bytes   00:14:02.967
6               0:14:02.967     0:01:54.197     32,174 kbps     36,248 kbps     00:15:32.389    34,302 kbps     00:15:28.510    33,936 kbps     00:15:31.513    167,739 bytes   568,317 bytes   00:14:03.968
7               0:15:57.164     0:00:52.135     21,998 kbps     28,292 kbps     00:15:59.875    25,660 kbps     00:15:57.164    23,139 kbps     00:15:57.164    114,687 bytes   355,681 bytes   00:15:58.165
8               0:16:49.299     0:01:58.243     32,204 kbps     37,279 kbps     00:18:17.012    34,387 kbps     00:18:14.927    34,071 kbps     00:17:47.399    167,899 bytes   578,883 bytes   00:18:17.888
9               0:18:47.543     0:03:41.804     27,367 kbps     34,922 kbps     00:19:23.537    33,879 kbps     00:19:06.395    33,850 kbps     00:19:01.473    142,679 bytes   403,743 bytes   00:21:08.600
10              0:22:29.348     0:01:23.750     29,498 kbps     35,245 kbps     00:23:18.688    33,864 kbps     00:22:53.371    33,831 kbps     00:22:54.331    153,788 bytes   368,505 bytes   00:23:19.606
11              0:23:53.098     0:04:49.831     30,871 kbps     36,737 kbps     00:23:56.017    34,225 kbps     00:24:24.421    33,946 kbps     00:26:10.485    160,948 bytes   583,186 bytes   00:24:26.465
12              0:28:42.929     0:02:40.910     33,085 kbps     35,222 kbps     00:29:07.328    34,059 kbps     00:29:47.535    33,869 kbps     00:28:54.065    172,488 bytes   235,768 bytes   00:29:03.616
13              0:31:23.840     0:05:00.633     28,207 kbps     37,379 kbps     00:33:11.280    34,567 kbps     00:33:07.318    34,193 kbps     00:33:02.313    147,060 bytes   627,294 bytes   00:33:13.282
14              0:36:24.473     0:03:42.722     30,168 kbps     35,894 kbps     00:40:05.319    34,218 kbps     00:39:29.158    34,017 kbps     00:39:24.153    157,280 bytes   528,835 bytes   00:39:59.438
15              0:40:07.196     0:03:12.066     33,650 kbps     36,409 kbps     00:41:46.086    34,421 kbps     00:41:45.920    34,076 kbps     00:41:46.003    175,437 bytes   568,920 bytes   00:41:51.884
16              0:43:19.263     0:04:44.826     31,943 kbps     37,163 kbps     00:45:16.463    34,432 kbps     00:45:12.459    34,129 kbps     00:45:07.454    166,538 bytes   922,176 bytes   00:45:22.177
17              0:48:04.089     0:02:22.976     33,183 kbps     36,498 kbps     00:49:20.499    34,313 kbps     00:49:16.411    34,039 kbps     00:49:20.374    173,001 bytes   527,485 bytes   00:49:22.376
18              0:50:27.065     0:02:19.097     28,821 kbps     37,389 kbps     00:50:56.428    34,325 kbps     00:50:55.594    33,994 kbps     00:52:19.761    150,257 bytes   672,052 bytes   00:50:58.221
19              0:52:46.162     0:01:26.753     33,348 kbps     36,355 kbps     00:54:11.915    34,109 kbps     00:54:07.911    33,982 kbps     00:54:02.906    173,863 bytes   570,943 bytes   00:54:12.916
20              0:54:12.916     0:02:43.788     31,619 kbps     35,851 kbps     00:54:27.639    34,189 kbps     00:54:23.885    34,017 kbps     00:54:18.630    164,847 bytes   566,335 bytes   00:54:13.917
21              0:56:56.704     0:01:57.325     33,727 kbps     34,433 kbps     00:58:45.730    33,954 kbps     00:58:06.191    33,886 kbps     00:58:01.186    175,836 bytes   252,125 bytes   00:58:53.321
22              0:58:54.030     0:03:10.982     30,986 kbps     35,515 kbps     01:01:26.432    34,221 kbps     01:00:09.981    33,931 kbps     01:01:55.002    161,549 bytes   527,875 bytes   01:00:13.359
23              1:02:05.012     0:01:27.462     29,695 kbps     34,796 kbps     01:03:25.885    33,792 kbps     01:03:16.542    33,730 kbps     01:03:16.876    154,818 bytes   389,793 bytes   01:03:25.927
24              1:03:32.475     0:03:06.686     30,004 kbps     36,952 kbps     01:03:41.442    34,397 kbps     01:03:38.439    34,089 kbps     01:03:42.401    156,426 bytes   568,250 bytes   01:03:42.443
25              1:06:39.161     0:01:47.315     29,691 kbps     36,940 kbps     01:06:54.510    34,458 kbps     01:07:03.102    34,102 kbps     01:07:49.315    154,796 bytes   657,652 bytes   01:08:25.684
26              1:08:26.477     0:03:06.477     33,769 kbps     34,744 kbps     01:11:14.603    33,952 kbps     01:11:20.651    33,873 kbps     01:09:50.561    176,055 bytes   267,425 bytes   01:11:32.955
27              1:11:32.955     0:03:26.706     30,611 kbps     36,246 kbps     01:12:32.556    34,285 kbps     01:12:28.635    34,047 kbps     01:13:51.135    159,591 bytes   537,930 bytes   01:13:53.178
28              1:14:59.661     0:02:21.391     28,888 kbps     36,302 kbps     01:15:54.132    34,177 kbps     01:15:50.128    33,881 kbps     01:15:45.123    150,607 bytes   543,744 bytes   01:15:49.294
29              1:17:21.053     0:03:44.849     24,547 kbps     34,833 kbps     01:18:54.104    34,127 kbps     01:19:06.074    33,928 kbps     01:18:46.096    127,976 bytes   445,533 bytes   01:17:33.940
30              1:21:05.902     0:04:16.506     31,924 kbps     36,307 kbps     01:23:06.106    34,295 kbps     01:24:04.039    34,020 kbps     01:24:03.955    166,440 bytes   506,014 bytes   01:23:47.147
31              1:25:22.408     0:05:24.157     31,127 kbps     35,334 kbps     01:28:47.989    34,079 kbps     01:30:35.304    33,940 kbps     01:26:34.189    162,281 bytes   541,303 bytes   01:26:20.091
32              1:30:46.566     0:04:39.862     29,126 kbps     35,068 kbps     01:32:30.378    34,078 kbps     01:32:26.290    33,951 kbps     01:32:21.285    151,850 bytes   386,645 bytes   01:32:31.295
33              1:35:26.429     0:04:01.908     29,906 kbps     35,926 kbps     01:36:57.895    34,240 kbps     01:36:53.891    34,029 kbps     01:36:48.886    155,916 bytes   468,812 bytes   01:36:58.854
34              1:39:28.337     0:02:37.657     26,350 kbps     36,031 kbps     01:40:16.301    33,865 kbps     01:40:38.198    33,794 kbps     01:40:33.193    137,379 bytes   560,952 bytes   01:40:57.968
35              1:42:05.994     0:01:53.238     25,918 kbps     34,759 kbps     01:42:23.762    33,924 kbps     01:43:01.884    33,676 kbps     01:42:36.608    135,127 bytes   347,136 bytes   01:43:56.939
36              1:43:59.233     0:03:10.899     26,992 kbps     36,466 kbps     01:45:16.184    34,347 kbps     01:45:12.097    34,090 kbps     01:45:11.138    140,725 bytes   570,517 bytes   01:45:18.103
37              1:47:10.132     0:04:28.559     25,342 kbps     34,983 kbps     01:48:15.238    34,110 kbps     01:49:19.594    31,982 kbps     01:47:21.935    132,120 bytes   464,755 bytes   01:47:48.211
38              1:51:38.692     0:03:35.215     24,688 kbps     34,333 kbps     01:53:43.274    33,980 kbps     01:53:42.899    32,563 kbps     01:53:42.732    128,709 bytes   376,027 bytes   01:52:37.041
39              1:55:13.907     0:02:22.725     24,353 kbps     34,114 kbps     01:55:50.401    32,834 kbps     01:55:15.867    30,127 kbps     01:57:00.304    126,964 bytes   354,237 bytes   01:56:43.204
40              1:57:36.632     0:05:26.075     29,387 kbps     34,832 kbps     01:57:46.726    34,019 kbps     02:00:26.594    33,888 kbps     02:00:23.883    153,209 bytes   401,611 bytes   01:57:39.594
41              2:03:02.708     0:03:46.059     30,235 kbps     35,042 kbps     02:03:11.133    34,042 kbps     02:03:07.129    33,881 kbps     02:03:51.465    157,633 bytes   412,122 bytes   02:06:37.381
42              2:06:48.767     0:07:39.333     10,489 kbps     34,282 kbps     02:06:57.985    32,093 kbps     02:06:55.357    31,953 kbps     02:06:50.352    54,691 bytes    352,110 bytes   02:06:49.768
STREAM DIAGNOSTICS:
00262.M2TS      4113 (0x1011)   0x1B            AVC                                     8067.935                27,998                  28,235,317,389  153,565,198
00262.M2TS      4352 (0x1100)   0x86            DTS-HD MA       spa (Spanish)           8067.935                3,631                   3,661,411,636   21,156,600
00262.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           8067.935                3,629                   3,659,775,908   21,146,672
00262.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           8067.935                192                     193,635,072     1,260,645
00262.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8067.935                38                      38,800,205      219,692
00262.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8067.935                35                      35,129,795      198,995
Che: Part 2: Guerilla
Code:
DISC INFO:
Disc Title:     CHE
Disc Size:      49,735,733,989 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 2:15:22 (h:m:s)
Total Bitrate:          34.51 Mbps
VIDEO:
MPEG-4 AVC Video        28992 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             Spanish         3516 kbps       5.1 / 48 kHz / 3516 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         30.259 kbps
FILES:
00262.M2TS      0:00:00.000     2:15:22.739     35,036,418,048  34,507
CHAPTERS:
1               0:00:00.000     0:03:28.750     7,569 kbps      37,297 kbps     00:00:02.377    36,914 kbps     00:00:02.377    36,853 kbps     00:00:02.293    39,456 bytes    855,711 bytes   00:00:57.974
2               0:03:28.750     0:02:32.360     21,150 kbps     37,866 kbps     00:05:59.442    37,080 kbps     00:05:55.313    36,907 kbps     00:05:50.475    110,268 bytes   426,272 bytes   00:05:49.557
3               0:06:01.110     0:01:59.577     31,990 kbps     39,879 kbps     00:06:20.004    37,117 kbps     00:07:34.454    36,907 kbps     00:07:29.449    166,783 bytes   543,721 bytes   00:06:20.963
4               0:08:00.688     0:04:39.654     26,675 kbps     38,571 kbps     00:09:31.654    36,369 kbps     00:11:47.039    35,832 kbps     00:11:47.039    139,073 bytes   480,705 bytes   00:10:47.313
5               0:12:40.342     0:02:59.512     29,635 kbps     40,013 kbps     00:13:17.963    37,449 kbps     00:13:13.959    37,126 kbps     00:13:08.954    154,501 bytes   605,143 bytes   00:13:18.005
6               0:15:39.855     0:04:04.327     31,068 kbps     39,912 kbps     00:18:14.259    37,402 kbps     00:18:10.255    37,088 kbps     00:18:05.334    161,976 bytes   652,960 bytes   00:16:12.680
7               0:19:44.183     0:02:29.566     31,968 kbps     39,711 kbps     00:21:04.096    37,318 kbps     00:21:03.095    36,226 kbps     00:20:28.018    166,666 bytes   559,996 bytes   00:21:07.057
8               0:22:13.749     0:02:21.683     26,769 kbps     40,839 kbps     00:22:26.470    37,453 kbps     00:22:26.553    37,120 kbps     00:22:26.428    139,560 bytes   641,168 bytes   00:22:34.436
9               0:24:35.432     0:01:58.409     27,092 kbps     37,716 kbps     00:24:37.309    35,308 kbps     00:24:47.736    35,156 kbps     00:24:42.481    141,247 bytes   427,189 bytes   00:26:33.842
10              0:26:33.842     0:02:22.767     36,510 kbps     40,585 kbps     00:27:58.218    37,559 kbps     00:27:54.214    37,183 kbps     00:27:49.209    190,349 bytes   665,549 bytes   00:27:47.248
11              0:28:56.609     0:03:28.750     30,924 kbps     40,408 kbps     00:30:37.085    37,530 kbps     00:30:33.081    37,167 kbps     00:30:28.076    161,225 bytes   696,852 bytes   00:30:23.112
12              0:32:25.360     0:02:07.544     31,967 kbps     41,214 kbps     00:33:29.382    37,794 kbps     00:33:25.420    37,298 kbps     00:33:20.415    166,663 bytes   772,640 bytes   00:33:38.391
13              0:34:32.904     0:02:37.657     33,783 kbps     39,886 kbps     00:34:42.580    37,531 kbps     00:34:33.738    37,104 kbps     00:35:45.643    176,127 bytes   655,604 bytes   00:34:33.905
14              0:37:10.561     0:05:32.707     33,922 kbps     40,777 kbps     00:37:21.948    37,416 kbps     00:38:19.046    37,104 kbps     00:38:19.046    176,855 bytes   692,170 bytes   00:37:25.952
15              0:42:43.269     0:01:32.717     31,534 kbps     39,456 kbps     00:43:35.279    37,421 kbps     00:43:31.275    37,007 kbps     00:43:31.400    164,403 bytes   597,350 bytes   00:43:59.178
16              0:44:15.986     0:02:56.301     32,978 kbps     40,551 kbps     00:44:37.132    37,635 kbps     00:46:29.953    37,214 kbps     00:44:27.998    171,934 bytes   606,488 bytes   00:46:26.867
17              0:47:12.287     0:00:53.678     33,705 kbps     38,445 kbps     00:48:04.423    37,164 kbps     00:48:00.419    35,409 kbps     00:47:55.956    175,724 bytes   629,996 bytes   00:48:02.838
18              0:48:05.966     0:02:45.748     36,695 kbps     40,468 kbps     00:48:25.110    37,600 kbps     00:48:25.110    37,116 kbps     00:48:22.065    191,312 bytes   656,769 bytes   00:48:31.074
19              0:50:51.715     0:03:37.091     29,166 kbps     39,758 kbps     00:53:14.649    37,129 kbps     00:53:07.017    36,914 kbps     00:51:37.886    152,059 bytes   655,877 bytes   00:51:06.271
20              0:54:28.807     0:03:27.373     32,622 kbps     39,651 kbps     00:57:17.559    37,338 kbps     00:57:17.559    37,093 kbps     00:57:17.559    170,079 bytes   690,900 bytes   00:54:41.820
21              0:57:56.181     0:01:33.468     25,481 kbps     35,696 kbps     00:58:24.876    34,417 kbps     00:58:24.959    33,868 kbps     00:58:24.876    132,846 bytes   534,718 bytes   00:58:34.511
22              0:59:29.649     0:03:07.186     33,444 kbps     40,054 kbps     01:01:12.877    37,479 kbps     01:01:20.385    37,147 kbps     01:01:19.133    174,363 bytes   688,946 bytes   01:01:23.388
23              1:02:36.836     0:03:45.642     31,918 kbps     39,869 kbps     01:04:36.581    37,419 kbps     01:04:32.577    37,100 kbps     01:04:32.577    166,405 bytes   580,872 bytes   01:04:30.616
24              1:06:22.478     0:01:56.699     32,692 kbps     39,211 kbps     01:06:34.532    37,150 kbps     01:06:33.781    36,971 kbps     01:06:34.490    170,441 bytes   569,033 bytes   01:07:04.353
25              1:08:19.178     0:02:15.135     33,761 kbps     40,339 kbps     01:08:55.548    37,379 kbps     01:08:55.548    37,036 kbps     01:08:37.071    176,015 bytes   601,736 bytes   01:08:59.510
26              1:10:34.313     0:03:04.851     32,688 kbps     39,824 kbps     01:10:37.942    37,401 kbps     01:13:11.678    37,050 kbps     01:10:35.272    170,421 bytes   598,739 bytes   01:10:52.831
27              1:13:39.164     0:02:07.710     33,674 kbps     40,122 kbps     01:13:40.624    37,259 kbps     01:13:44.378    37,087 kbps     01:13:43.335    175,561 bytes   614,363 bytes   01:13:53.345
28              1:15:46.875     0:02:14.926     32,836 kbps     38,976 kbps     01:17:49.831    37,126 kbps     01:17:20.135    37,059 kbps     01:17:50.082    171,191 bytes   592,336 bytes   01:17:53.752
29              1:18:01.802     0:01:52.445     25,594 kbps     39,438 kbps     01:18:41.591    37,097 kbps     01:18:41.383    36,801 kbps     01:18:28.245    133,434 bytes   620,731 bytes   01:18:18.568
30              1:19:54.247     0:01:38.306     35,876 kbps     41,498 kbps     01:20:19.147    37,415 kbps     01:19:56.124    37,017 kbps     01:20:41.294    187,043 bytes   576,324 bytes   01:19:55.248
31              1:21:32.554     0:02:35.613     29,623 kbps     39,371 kbps     01:22:06.588    37,356 kbps     01:21:37.976    37,026 kbps     01:23:41.474    154,438 bytes   575,038 bytes   01:22:38.328
32              1:24:08.168     0:02:33.278     30,604 kbps     39,312 kbps     01:24:43.578    37,188 kbps     01:24:38.782    36,987 kbps     01:24:33.777    159,558 bytes   588,540 bytes   01:24:16.926
33              1:26:41.446     0:03:24.245     26,600 kbps     38,065 kbps     01:29:13.973    36,975 kbps     01:27:08.932    36,775 kbps     01:27:03.927    138,680 bytes   482,300 bytes   01:29:14.932
34              1:30:05.691     0:02:57.760     28,747 kbps     38,566 kbps     01:33:02.451    37,094 kbps     01:32:58.447    36,879 kbps     01:32:53.442    149,875 bytes   557,495 bytes   01:30:37.598
35              1:33:03.452     0:03:16.529     34,979 kbps     40,875 kbps     01:33:31.230    37,308 kbps     01:34:52.061    37,074 kbps     01:34:46.931    182,363 bytes   576,582 bytes   01:35:56.625
36              1:36:19.982     0:02:32.026     34,847 kbps     38,978 kbps     01:38:06.547    37,258 kbps     01:37:29.343    37,016 kbps     01:37:57.538    181,678 bytes   558,289 bytes   01:37:34.348
37              1:38:52.009     0:05:14.981     25,627 kbps     40,289 kbps     01:38:54.303    37,209 kbps     01:41:32.836    36,989 kbps     01:41:34.213    133,608 bytes   612,281 bytes   01:38:56.221
38              1:44:06.990     0:06:54.205     34,557 kbps     40,418 kbps     01:45:58.852    37,373 kbps     01:49:45.412    37,016 kbps     01:47:54.509    180,166 bytes   612,146 bytes   01:45:05.382
39              1:51:01.196     0:01:57.826     32,850 kbps     39,300 kbps     01:51:23.843    37,194 kbps     01:51:08.536    36,998 kbps     01:51:16.086    171,264 bytes   526,851 bytes   01:51:14.209
40              1:52:59.022     0:02:16.678     33,134 kbps     37,436 kbps     01:54:34.075    35,959 kbps     01:54:30.947    35,585 kbps     01:54:26.067    172,747 bytes   347,989 bytes   01:53:04.027
41              1:55:15.700     0:03:17.697     25,055 kbps     33,436 kbps     01:57:01.097    32,963 kbps     01:56:58.219    32,818 kbps     01:56:53.131    130,625 bytes   440,476 bytes   01:58:14.170
42              1:58:33.397     0:04:21.761     31,178 kbps     38,566 kbps     01:59:57.231    37,028 kbps     02:01:57.018    36,830 kbps     02:00:13.623    162,548 bytes   546,407 bytes   01:59:58.024
43              2:02:55.159     0:01:53.696     28,354 kbps     37,440 kbps     02:03:58.305    37,010 kbps     02:03:54.301    34,703 kbps     02:03:40.079    147,826 bytes   446,042 bytes   02:02:57.161
44              2:04:48.856     0:10:33.883     12,762 kbps     37,682 kbps     02:05:44.161    36,968 kbps     02:05:24.475    36,551 kbps     02:05:20.596    66,538 bytes    489,078 bytes   02:05:48.123
STREAM DIAGNOSTICS:
00262.M2TS      4113 (0x1011)   0x1B            AVC                                     8122.573                28,992                  29,436,551,917  160,094,802
00262.M2TS      4352 (0x1100)   0x86            DTS-HD MA       spa (Spanish)           8122.573                3,516                   3,569,640,288   20,670,770
00262.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           8122.573                192                     194,946,048     1,269,180
00262.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8122.573                30                      30,723,305      174,457
Cinema Squid is offline
post #1736 of 5106 Old 06-23-2010, 10:59 PM - Thread Starter
[US] Darkman (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Universal
UPC: 025192049989
Release Date: 2010-06-15
Aspect Ratio: 1.85:1
Code:
        Total   Video
[US] Darkman                                                    VC-1    1:35:23 18,499,491,840  19,548,147,396  25.86   20.84   DTS-HD Master 5.1 3611Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     DARKMAN
Disc Size:      19,548,147,396 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:35:23 (h:m:s)
Total Bitrate:          25.86 Mbps
VIDEO:
VC-1 Video              20843 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3611 kbps       5.1 / 48 kHz / 3611 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         25.574 kbps
FILES:
00010.M2TS      0:00:00.000     1:35:23.342     18,499,491,840  25,858
CHAPTERS:
1               0:00:00.000     0:05:32.623     21,788 kbps     43,053 kbps     00:02:43.121    33,862 kbps     00:00:06.840    32,585 kbps     00:02:42.871    114,323 bytes   549,650 bytes   00:02:09.546
2               0:05:32.623     0:04:02.408     22,360 kbps     41,142 kbps     00:05:44.510    33,317 kbps     00:05:44.510    32,310 kbps     00:05:43.843    116,576 bytes   556,919 bytes   00:07:56.934
3               0:09:35.032     0:05:14.772     20,584 kbps     40,402 kbps     00:11:41.617    33,120 kbps     00:11:40.116    32,256 kbps     00:12:13.357    107,315 bytes   583,918 bytes   00:12:42.261
4               0:14:49.805     0:04:45.702     19,671 kbps     44,673 kbps     00:19:00.305    33,500 kbps     00:18:39.493    32,114 kbps     00:18:37.032    102,555 bytes   540,940 bytes   00:17:54.907
5               0:19:35.507     0:02:10.922     21,410 kbps     38,736 kbps     00:20:44.493    33,179 kbps     00:20:29.436    31,606 kbps     00:20:29.436    112,119 bytes   571,933 bytes   00:21:31.832
6               0:21:46.430     0:06:35.561     25,818 kbps     42,369 kbps     00:24:29.009    33,761 kbps     00:23:48.343    33,218 kbps     00:25:24.814    135,116 bytes   562,253 bytes   00:27:20.805
7               0:28:21.991     0:06:21.005     19,410 kbps     49,748 kbps     00:29:48.495    31,300 kbps     00:28:25.912    29,913 kbps     00:32:04.088    101,195 bytes   621,032 bytes   00:29:08.371
8               0:34:42.997     0:01:46.815     21,025 kbps     42,684 kbps     00:35:10.942    31,053 kbps     00:35:10.942    29,584 kbps     00:35:10.942    109,918 bytes   596,562 bytes   00:35:54.110
9               0:36:29.812     0:13:48.869     22,367 kbps     49,424 kbps     00:45:17.297    37,207 kbps     00:45:00.948    35,894 kbps     00:44:55.943    116,612 bytes   591,644 bytes   00:42:43.477
10              0:50:18.682     0:07:35.788     22,889 kbps     47,060 kbps     00:55:37.876    35,518 kbps     00:53:41.051    34,942 kbps     00:53:36.171    119,332 bytes   724,443 bytes   00:55:37.917
11              0:57:54.470     0:11:08.584     22,524 kbps     47,305 kbps     00:59:00.787    33,184 kbps     01:00:24.704    32,224 kbps     01:02:03.886    117,432 bytes   609,337 bytes   01:02:22.947
12              1:09:03.055     0:02:16.886     27,382 kbps     47,992 kbps     01:10:18.380    39,418 kbps     01:10:16.128    34,184 kbps     01:10:16.128    142,760 bytes   555,647 bytes   01:09:35.254
13              1:11:19.942     0:03:02.348     20,895 kbps     43,652 kbps     01:12:12.828    40,381 kbps     01:12:09.616    35,374 kbps     01:12:06.363    108,962 bytes   517,617 bytes   01:13:04.755
14              1:14:22.291     0:06:01.986     26,354 kbps     39,957 kbps     01:17:25.474    32,235 kbps     01:15:58.387    31,723 kbps     01:14:48.567    137,399 bytes   654,188 bytes   01:14:46.690
15              1:20:24.277     0:08:44.065     16,773 kbps     43,352 kbps     01:23:51.026    30,921 kbps     01:25:10.146    25,851 kbps     01:25:06.226    87,449 bytes    573,445 bytes   01:25:06.976
16              1:29:08.343     0:06:14.999     5,200 kbps      37,722 kbps     01:29:14.140    31,935 kbps     01:29:13.306    29,407 kbps     01:29:13.389    27,164 bytes    387,283 bytes   01:29:19.437
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    5723.218                20,844                  14,911,697,866  81,124,741
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5723.218                3,611                   2,583,087,028   14,929,020
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5723.218                26                      18,296,397      105,986
post #1737 of 5106 Old 06-23-2010, 11:02 PM - Thread Starter
[US] She's Out of My League (Additional Details)
Studio: Dreamworks / Paramount
UPC: 097360736045
Release Date: 2010-06-22
Aspect Ratio: 2.35:1
Code:
        Total   Video
[US] She's Out of My League                                     AVC     1:44:32 33,753,348,096  38,451,124,394  43.05   34.00   DTS-HD Master 5.1 4332Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     SHES_OUT_OF_MY_LEAGUE
Disc Size:      38,451,124,394 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:44:32 (h:m:s)
Total Bitrate:          43.05 Mbps
VIDEO:
MPEG-4 AVC Video        33997 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4332 kbps       5.1 / 48 kHz / 4332 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Portuguese      640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         65.245 kbps
Presentation Graphics           English         69.261 kbps
Presentation Graphics           French          58.097 kbps
Presentation Graphics           French          0.162 kbps
Presentation Graphics           Portuguese      66.277 kbps
Presentation Graphics           Spanish         56.702 kbps
Presentation Graphics           Spanish         0.203 kbps
FILES:
00055.M2TS      0:00:00.000     1:44:32.099     33,753,348,096  43,052
CHAPTERS:
1               0:00:00.000     0:03:29.834     34,408 kbps     38,567 kbps     00:00:18.518    36,052 kbps     00:02:08.419    35,911 kbps     00:02:22.100    179,350 bytes   630,659 bytes   00:00:18.101
2               0:03:29.834     0:03:21.075     35,789 kbps     37,517 kbps     00:06:48.908    36,140 kbps     00:06:28.429    35,953 kbps     00:06:24.258    186,586 bytes   405,580 bytes   00:06:49.909
3               0:06:50.910     0:05:00.842     35,722 kbps     38,946 kbps     00:07:36.456    36,016 kbps     00:07:32.452    36,010 kbps     00:07:27.405    186,237 bytes   354,984 bytes   00:06:54.914
4               0:11:51.752     0:05:02.051     34,587 kbps     37,088 kbps     00:14:08.055    36,007 kbps     00:12:07.893    35,897 kbps     00:15:34.350    180,321 bytes   338,366 bytes   00:12:12.815
5               0:16:53.804     0:05:47.805     35,418 kbps     37,836 kbps     00:21:04.471    36,210 kbps     00:21:01.051    35,931 kbps     00:21:21.989    184,652 bytes   496,147 bytes   00:21:06.056
6               0:22:41.610     0:04:56.004     35,668 kbps     37,302 kbps     00:27:16.593    36,045 kbps     00:25:29.361    35,917 kbps     00:23:21.650    185,958 bytes   349,991 bytes   00:26:57.574
7               0:27:37.614     0:08:05.234     35,160 kbps     37,491 kbps     00:31:53.912    36,189 kbps     00:28:40.510    36,010 kbps     00:28:35.505    183,310 bytes   407,861 bytes   00:28:45.473
8               0:35:42.849     0:08:24.795     35,675 kbps     39,183 kbps     00:39:53.599    36,226 kbps     00:39:07.219    36,017 kbps     00:37:40.883    185,994 bytes   468,570 bytes   00:38:43.321
9               0:44:07.645     0:07:50.595     35,365 kbps     39,109 kbps     00:47:02.236    36,118 kbps     00:46:58.190    35,934 kbps     00:45:23.554    184,377 bytes   348,400 bytes   00:46:06.054
10              0:51:58.240     0:10:14.030     35,704 kbps     38,714 kbps     00:58:29.756    36,108 kbps     01:01:54.335    35,935 kbps     01:01:47.120    186,145 bytes   359,464 bytes   01:02:00.049
11              1:02:12.270     0:05:10.351     35,334 kbps     37,945 kbps     01:03:38.022    36,246 kbps     01:05:37.600    36,007 kbps     01:05:32.595    184,216 bytes   460,996 bytes   01:05:43.481
12              1:07:22.621     0:06:55.790     35,607 kbps     37,969 kbps     01:12:24.048    36,088 kbps     01:12:17.791    35,910 kbps     01:08:26.352    185,638 bytes   341,633 bytes   01:12:22.671
13              1:14:18.412     0:08:18.998     31,608 kbps     38,741 kbps     01:22:33.448    36,091 kbps     01:15:53.465    35,948 kbps     01:15:35.280    164,792 bytes   336,554 bytes   01:14:22.291
14              1:22:37.410     0:05:22.030     35,645 kbps     38,299 kbps     01:22:48.421    36,262 kbps     01:22:44.417    36,076 kbps     01:22:39.371    185,836 bytes   336,335 bytes   01:26:15.295
15              1:27:59.440     0:06:14.624     35,671 kbps     37,603 kbps     01:31:22.018    36,135 kbps     01:31:18.097    35,945 kbps     01:30:12.448    185,974 bytes   389,343 bytes   01:30:49.110
16              1:34:14.065     0:10:18.034     23,830 kbps     37,850 kbps     01:38:28.027    36,138 kbps     01:38:24.064    35,972 kbps     01:38:19.059    124,249 bytes   629,874 bytes   01:44:30.514
STREAM DIAGNOSTICS:
00055.M2TS      4113 (0x1011)   0x1B            AVC                                     6271.932                33,998                  26,654,448,255  144,948,694
00055.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6271.932                4,333                   3,396,719,932   19,438,280
00055.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            6271.932                640                     501,770,240     2,940,060
00055.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6271.932                640                     501,770,240     2,940,060
00055.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        6271.932                640                     501,770,240     2,940,060
00055.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           6271.932                224                     175,619,584     980,020
00055.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6271.932                65                      51,153,126      289,016
00055.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6271.932                69                      54,301,686      306,799
00055.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6271.932                58                      45,548,563      257,985
00055.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6271.932                57                      44,455,262      252,480
00055.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        6271.932                66                      51,961,611      293,424
00055.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            6271.932                0                       127,234         733
00055.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           6271.932                0                       158,979         912
post #1738 of 5106 Old 06-24-2010, 04:53 AM
La Femme Nikita - 1990 - Australian version
Locked to Region B, confirmed with AnyDVD HD. The extras are all in 576i50 format.
Code:
        Total   Video
00004.MPLS                                                      AVC     1:57:03 22,930,851,840  24,836,852,568  26.12   20.23   LPCM 5.1 4608Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LE FEMME NIKITA
Disc Size:      24,836,852,568 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:57:03 (h:m:s)
Total Bitrate:          26.12 Mbps
VIDEO:
MPEG-4 AVC Video        20230 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      French          4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         14.381 kbps
FILES:
00012.M2TS      0:00:00.000     1:57:03.541     22,930,851,840  26,119
CHAPTERS:
1               0:00:00.000     0:09:12.333     21,250 kbps     37,052 kbps     00:07:39.416    34,441 kbps     00:07:38.375    30,969 kbps     00:07:37.124    110,668 bytes   401,948 bytes   00:07:40.458
2               0:09:12.333     0:10:52.833     19,955 kbps     38,050 kbps     00:18:42.958    35,556 kbps     00:13:26.166    32,965 kbps     00:11:10.291    103,930 bytes   337,361 bytes   00:13:26.208
3               0:20:05.166     0:07:50.375     22,144 kbps     37,248 kbps     00:25:36.916    35,606 kbps     00:21:05.583    32,570 kbps     00:21:04.583    115,332 bytes   346,939 bytes   00:24:52.583
4               0:27:55.541     0:13:16.291     23,644 kbps     37,873 kbps     00:36:11.374    35,899 kbps     00:35:58.916    34,521 kbps     00:36:23.333    123,147 bytes   396,593 bytes   00:36:11.416
5               0:41:11.833     0:10:30.833     22,099 kbps     36,668 kbps     00:41:13.791    34,274 kbps     00:41:12.791    30,231 kbps     00:48:28.624    115,100 bytes   395,898 bytes   00:41:12.833
6               0:51:42.666     0:05:41.750     20,215 kbps     37,659 kbps     00:52:32.666    35,210 kbps     00:52:30.666    31,361 kbps     00:52:30.666    105,288 bytes   386,391 bytes   00:52:31.708
7               0:57:24.416     0:10:12.583     20,379 kbps     38,921 kbps     00:59:25.249    35,313 kbps     01:02:25.041    31,662 kbps     01:02:24.041    106,143 bytes   409,495 bytes   01:02:24.083
8               1:07:37.000     0:08:31.333     19,692 kbps     34,965 kbps     01:12:45.291    33,579 kbps     01:12:42.291    32,866 kbps     01:12:37.249    102,565 bytes   364,721 bytes   01:12:37.333
9               1:16:08.333     0:09:35.875     15,462 kbps     29,577 kbps     01:22:37.666    26,069 kbps     01:18:40.958    24,972 kbps     01:18:36.166    80,533 bytes    332,383 bytes   01:25:18.416
10              1:25:44.208     0:12:17.875     18,304 kbps     37,088 kbps     01:34:46.874    34,636 kbps     01:33:06.333    31,045 kbps     01:27:19.291    95,336 bytes    463,986 bytes   01:26:40.708
11              1:38:02.083     0:12:13.000     24,873 kbps     40,685 kbps     01:43:41.541    35,856 kbps     01:44:10.875    34,136 kbps     01:44:10.499    129,546 bytes   359,189 bytes   01:44:12.833
12              1:50:15.083     0:06:48.458     9,878 kbps      22,132 kbps     01:50:42.874    20,033 kbps     01:50:38.958    19,773 kbps     01:50:33.916    51,452 bytes    287,753 bytes   01:53:15.708
STREAM DIAGNOSTICS:
00012.M2TS      4113 (0x1011)   0x1B            AVC                                     7023.458                20,230                  17,760,973,225  96,625,444
00012.M2TS      4352 (0x1100)   0x80            LPCM            fra (French)            7023.458                4,619                   4,054,961,680   22,496,320
00012.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7023.458                14                      12,625,804      74,243
Stephen Dawson
hifi-writer.com
post #1739 of 5106 Old 06-24-2010, 05:55 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Black Hawk Down - 2001 - UK - Sony - Region ABC
Code:
        Total   Video
00009.MPLS                                                      MPEG-2  2:24:19 38,196,025,344  46,735,003,384  35.29   25.56   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID
Disc Size:      46,735,003,384 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 2:24:19 (h:m:s)
Total Bitrate:          35.29 Mbps
VIDEO:
MPEG-2 Video            25560 kbps          1080p / 23.976 fps / 16:9
AUDIO:
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -7dB
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -3dB
SUBTITLES:
Presentation Graphics           English         33.047 kbps
Presentation Graphics           English         42.865 kbps
Presentation Graphics           English         118.528 kbps
Presentation Graphics           English         105.895 kbps
Presentation Graphics           English         110.576 kbps
Presentation Graphics           Arabic          25.051 kbps
Presentation Graphics           Czech           40.448 kbps
Presentation Graphics           Dutch           45.325 kbps
Presentation Graphics           Dutch           104.052 kbps
Presentation Graphics           Dutch           97.078 kbps
Presentation Graphics           Dutch           87.515 kbps
Presentation Graphics           French          34.681 kbps
Presentation Graphics           French          102.619 kbps
Presentation Graphics           French          91.149 kbps
Presentation Graphics           French          96.682 kbps
Presentation Graphics           Greek           44.012 kbps
Presentation Graphics           Hindi           35.932 kbps
Presentation Graphics           Hungarian       45.210 kbps
Presentation Graphics           Polish          43.784 kbps
Presentation Graphics           Turkish         43.731 kbps
Interactive Graphics            English         0.327 kbps
* Interactive Graphics          French          0.264 kbps
FILES:
00000.M2TS      0:00:00.000     0:54:39.943     14,731,229,184  35,930
00001.M2TS      0:54:39.943     1:29:39.707     23,464,796,160  34,894
CHAPTERS:
1               0:00:00.000     0:20:37.069     25,345 kbps     33,498 kbps     00:03:40.345    29,457 kbps     00:00:54.804    29,115 kbps     00:00:26.401    132,135 bytes   560,497 bytes   00:04:55.586
2               0:20:37.069     0:09:02.667     26,185 kbps     30,558 kbps     00:22:59.628    28,433 kbps     00:24:03.108    28,044 kbps     00:23:58.103    136,518 bytes   575,671 bytes   00:22:18.378
3               0:29:39.736     0:07:15.184     26,423 kbps     31,688 kbps     00:32:49.926    29,409 kbps     00:32:16.517    28,404 kbps     00:33:54.323    137,757 bytes   546,986 bytes   00:33:45.773
4               0:36:54.921     0:03:54.359     25,969 kbps     31,268 kbps     00:38:14.875    28,528 kbps     00:38:01.862    27,925 kbps     00:38:01.821    135,391 bytes   575,739 bytes   00:38:23.801
5               0:40:49.280     0:10:03.978     26,938 kbps     32,714 kbps     00:50:20.600    29,333 kbps     00:47:48.073    28,942 kbps     00:47:48.323    140,442 bytes   554,616 bytes   00:44:30.793
6               0:50:53.258     0:08:14.285     26,968 kbps     32,160 kbps     00:58:11.988    30,261 kbps     00:58:05.773    29,460 kbps     00:58:02.979    140,598 bytes   547,388 bytes   00:52:36.903
7               0:59:07.544     0:07:52.346     27,110 kbps     30,981 kbps     00:59:25.270    29,036 kbps     01:02:31.914    28,633 kbps     01:06:06.295    141,338 bytes   561,874 bytes   01:04:03.923
8               1:06:59.890     0:17:50.903     27,088 kbps     32,920 kbps     01:23:38.304    29,387 kbps     01:18:52.269    28,780 kbps     01:23:41.558    141,226 bytes   542,944 bytes   01:08:02.536
9               1:24:50.794     0:01:43.478     27,025 kbps     31,193 kbps     01:26:19.757    28,618 kbps     01:25:08.186    28,105 kbps     01:25:08.353    140,897 bytes   438,819 bytes   01:25:25.370
10              1:26:34.272     0:12:14.942     25,296 kbps     32,243 kbps     01:33:30.146    28,377 kbps     01:34:37.672    28,259 kbps     01:34:37.046    131,880 bytes   578,278 bytes   01:38:42.166
11              1:38:49.214     0:05:14.147     25,424 kbps     31,737 kbps     01:43:16.648    27,788 kbps     01:43:15.147    26,966 kbps     01:42:24.263    132,550 bytes   571,269 bytes   01:43:01.800
12              1:44:03.362     0:13:29.225     26,087 kbps     31,693 kbps     01:50:31.666    28,407 kbps     01:50:27.704    27,964 kbps     01:56:10.421    136,006 bytes   544,256 bytes   01:51:49.577
13              1:57:32.587     0:03:27.248     26,686 kbps     32,885 kbps     01:59:32.123    28,789 kbps     01:59:32.498    28,606 kbps     01:59:30.955    139,129 bytes   465,335 bytes   01:58:45.868
14              2:00:59.835     0:04:42.240     26,569 kbps     31,710 kbps     02:01:06.509    28,909 kbps     02:01:50.136    28,044 kbps     02:04:34.425    138,516 bytes   540,876 bytes   02:05:41.158
15              2:05:42.076     0:07:24.861     27,122 kbps     31,352 kbps     02:06:22.157    28,929 kbps     02:06:30.749    28,476 kbps     02:06:27.037    141,402 bytes   578,348 bytes   02:10:03.045
16              2:13:06.937     0:11:12.713     16,645 kbps     29,660 kbps     02:13:29.167    27,585 kbps     02:13:19.449    27,530 kbps     02:13:15.195    86,783 bytes    567,179 bytes   02:14:35.317
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x02            MPEG-2                                  3279.860                26,032                  10,672,813,473  58,050,275
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           3279.860                640                     262,397,440     1,537,485
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           3279.860                4,615                   1,891,872,276   10,495,824
00000.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            3279.860                640                     262,397,440     1,537,485
00000.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           3279.860                192                     78,719,232      512,495
00000.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           3279.860                192                     78,719,232      512,495
00000.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           3279.860                192                     78,719,232      512,495
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           3279.860                51                      20,777,345      116,919
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           3279.860                39                      16,082,167      91,886
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            3279.860                43                      17,616,258      99,559
00000.M2TS      4611 (0x1203)   0x90            PGS             nld (Dutch)             3279.860                55                      22,475,320      126,389
00000.M2TS      4612 (0x1204)   0x90            PGS             ara (Arabic)            3279.860                30                      12,442,597      71,842
00000.M2TS      4613 (0x1205)   0x90            PGS             ces (Czech)             3279.860                49                      20,163,644      113,765
00000.M2TS      4614 (0x1206)   0x90            PGS             ell (Greek)             3279.860                53                      21,916,239      123,311
00000.M2TS      4615 (0x1207)   0x90            PGS             hin (Hindi)             3279.860                43                      17,683,423      100,352
00000.M2TS      4616 (0x1208)   0x90            PGS             hun (Hungarian)         3279.860                55                      22,393,845      125,978
00000.M2TS      4617 (0x1209)   0x90            PGS             pol (Polish)            3279.860                54                      22,085,933      124,354
00000.M2TS      4618 (0x120A)   0x90            PGS             tur (Turkish)           3279.860                53                      21,840,375      122,964
00000.M2TS      4619 (0x120B)   0x90            PGS             eng (English)           3279.860                124                     50,643,663      282,041
00000.M2TS      4620 (0x120C)   0x90            PGS             fra (French)            3279.860                106                     43,602,275      243,169
00000.M2TS      4621 (0x120D)   0x90            PGS             nld (Dutch)             3279.860                107                     43,997,857      244,887
00000.M2TS      4622 (0x120E)   0x90            PGS             eng (English)           3279.860                114                     46,926,513      261,491
00000.M2TS      4623 (0x120F)   0x90            PGS             fra (French)            3279.860                93                      38,269,348      213,440
00000.M2TS      4624 (0x1210)   0x90            PGS             nld (Dutch)             3279.860                100                     41,096,095      228,802
00000.M2TS      4625 (0x1211)   0x90            PGS             eng (English)           3279.860                117                     47,807,787      266,526
00000.M2TS      4626 (0x1212)   0x90            PGS             fra (French)            3279.860                105                     43,152,348      240,705
00000.M2TS      4627 (0x1213)   0x90            PGS             nld (Dutch)             3279.860                97                      39,710,854      221,629
00000.M2TS      5120 (0x1400)   0x91            IGS             eng (English)           3279.860                0                       173,364         992
00000.M2TS      5121 (0x1401)   0x91            IGS             fra (French)            3279.860                0                       137,152         794
00001.M2TS      4113 (0x1011)   0x02            MPEG-2                                  5379.541                25,273                  16,994,618,273  92,437,133
00001.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5379.541                640                     430,376,960     2,521,740
00001.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           5379.541                4,615                   3,103,016,728   17,215,072
00001.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            5379.541                640                     430,376,960     2,521,740
00001.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           5379.541                192                     129,113,088     840,580
00001.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           5379.541                192                     129,113,088     840,580
00001.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           5379.541                192                     129,113,088     840,580
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5379.541                38                      25,622,147      144,397
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5379.541                29                      19,689,537      112,761
00001.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5379.541                30                      19,924,631      112,951
00001.M2TS      4611 (0x1203)   0x90            PGS             nld (Dutch)             5379.541                40                      26,586,734      149,757
00001.M2TS      4612 (0x1204)   0x90            PGS             ara (Arabic)            5379.541                22                      14,673,537      85,003
00001.M2TS      4613 (0x1205)   0x90            PGS             ces (Czech)             5379.541                35                      23,619,870      133,624
00001.M2TS      4614 (0x1206)   0x90            PGS             ell (Greek)             5379.541                38                      25,725,127      145,019
00001.M2TS      4615 (0x1207)   0x90            PGS             hin (Hindi)             5379.541                32                      21,210,972      120,554
00001.M2TS      4616 (0x1208)   0x90            PGS             hun (Hungarian)         5379.541                39                      26,544,527      149,612
00001.M2TS      4617 (0x1209)   0x90            PGS             pol (Polish)            5379.541                38                      25,308,492      142,937
00001.M2TS      4618 (0x120A)   0x90            PGS             tur (Turkish)           5379.541                38                      25,496,693      143,845
00001.M2TS      4619 (0x120B)   0x90            PGS             eng (English)           5379.541                115                     77,657,787      432,964
00001.M2TS      4620 (0x120C)   0x90            PGS             fra (French)            5379.541                100                     67,477,879      376,610
00001.M2TS      4621 (0x120D)   0x90            PGS             nld (Dutch)             5379.541                102                     68,633,946      382,376
00001.M2TS      4622 (0x120E)   0x90            PGS             eng (English)           5379.541                108                     72,766,979      405,777
00001.M2TS      4623 (0x120F)   0x90            PGS             fra (French)            5379.541                90                      60,395,765      337,300
00001.M2TS      4624 (0x1210)   0x90            PGS             nld (Dutch)             5379.541                95                      63,986,578      356,442
00001.M2TS      4625 (0x1211)   0x90            PGS             eng (English)           5379.541                99                      66,818,916      372,942
00001.M2TS      4626 (0x1212)   0x90            PGS             fra (French)            5379.541                91                      61,501,902      343,473
00001.M2TS      4627 (0x1213)   0x90            PGS             nld (Dutch)             5379.541                82                      55,020,769      307,376
00001.M2TS      5120 (0x1400)   0x91            IGS             eng (English)           5379.541                0                       180,820         1,028
00001.M2TS      5121 (0x1401)   0x91            IGS             fra (French)            5379.541                0                       148,906         855
paku is offline
post #1740 of 5106 Old 06-24-2010, 06:54 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Love Actually - 2003 - UK - Universal - Region ABC
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:14:49 40,993,763,328  44,070,931,657  40.54   29.48   DTS-HD Master 5.1 4128Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     LOVE_ACTUALLY_GLO
Disc Size:      44,070,931,657 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 2:14:49 (h:m:s)
Total Bitrate:          40.54 Mbps
VIDEO:
VC-1 Video              29484 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         4128 kbps       5.1 / 48 kHz / 4128 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       German          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Italian         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         36.122 kbps
Presentation Graphics           English         63.045 kbps
Presentation Graphics           Dutch           24.081 kbps
Presentation Graphics           French          30.268 kbps
Presentation Graphics           French          30.343 kbps
Presentation Graphics           French          54.125 kbps
Presentation Graphics           French          1.885 kbps
Presentation Graphics           German          35.218 kbps
Presentation Graphics           German          61.223 kbps
Presentation Graphics           German          1.897 kbps
Presentation Graphics           Italian         30.594 kbps
Presentation Graphics           Italian         55.992 kbps
Presentation Graphics           Italian         1.794 kbps
Presentation Graphics           Spanish         28.466 kbps
Presentation Graphics           Spanish         29.180 kbps
Presentation Graphics           Spanish         54.474 kbps
Presentation Graphics           Spanish         1.433 kbps
Presentation Graphics           Spanish         1.899 kbps
FILES:
00009.M2TS      0:00:00.000     2:14:49.081     40,993,763,328  40,542
CHAPTERS:
1               0:00:00.000     0:09:46.419     28,090 kbps     44,634 kbps     00:03:39.552    36,770 kbps     00:00:10.260    34,672 kbps     00:00:05.880    146,698 bytes   623,745 bytes   00:02:36.906
2               0:09:46.419     0:05:23.031     29,482 kbps     43,401 kbps     00:10:57.657    37,090 kbps     00:10:40.556    34,156 kbps     00:10:39.221    153,707 bytes   630,921 bytes   00:14:26.949
3               0:15:09.450     0:07:33.870     31,149 kbps     45,477 kbps     00:16:52.094    35,415 kbps     00:21:39.089    33,442 kbps     00:21:34.042    162,395 bytes   645,576 bytes   00:18:05.834
4               0:22:43.320     0:07:05.133     28,653 kbps     43,185 kbps     00:25:43.333    35,306 kbps     00:25:39.579    33,943 kbps     00:25:35.450    149,385 bytes   661,965 bytes   00:27:43.536
5               0:29:48.453     0:06:54.080     29,606 kbps     41,141 kbps     00:33:40.393    35,113 kbps     00:32:41.000    33,884 kbps     00:32:36.287    154,350 bytes   609,662 bytes   00:36:35.359
6               0:36:42.533     0:07:38.958     29,183 kbps     46,356 kbps     00:37:46.681    34,484 kbps     00:42:18.786    33,233 kbps     00:37:33.334    152,146 bytes   676,103 bytes   00:38:57.585
7               0:44:21.492     0:07:02.755     30,469 kbps     45,764 kbps     00:49:09.029    35,143 kbps     00:45:02.574    34,073 kbps     00:44:58.404    158,853 bytes   708,645 bytes   00:47:32.307
8               0:51:24.247     0:06:59.210     27,292 kbps     43,847 kbps     00:54:34.187    34,649 kbps     00:52:55.338    33,056 kbps     00:56:32.972    142,290 bytes   604,336 bytes   00:52:13.004
9               0:58:23.458     0:08:03.983     30,632 kbps     42,718 kbps     01:06:20.977    35,544 kbps     01:03:04.489    34,011 kbps     00:59:52.922    159,700 bytes   632,229 bytes   01:03:15.041
10              1:06:27.441     0:03:00.847     31,622 kbps     44,417 kbps     01:08:15.925    35,190 kbps     01:08:14.924    33,498 kbps     01:07:37.970    164,863 bytes   595,628 bytes   01:08:44.286
11              1:09:28.289     0:06:26.928     30,461 kbps     41,426 kbps     01:10:29.975    34,654 kbps     01:10:50.162    34,010 kbps     01:10:46.158    158,809 bytes   691,092 bytes   01:14:38.348
12              1:15:55.217     0:07:37.373     30,879 kbps     49,627 kbps     01:22:28.818    35,336 kbps     01:19:46.907    33,791 kbps     01:19:48.325    160,989 bytes   647,920 bytes   01:17:03.410
13              1:23:32.590     0:05:13.980     31,245 kbps     40,944 kbps     01:27:30.912    35,613 kbps     01:24:59.719    33,485 kbps     01:24:29.105    162,896 bytes   535,871 bytes   01:23:58.658
14              1:28:46.571     0:07:58.186     31,171 kbps     41,551 kbps     01:32:10.233    35,537 kbps     01:33:29.020    33,796 kbps     01:33:28.185    162,510 bytes   671,636 bytes   01:31:41.287
15              1:36:44.757     0:08:17.079     31,346 kbps     41,207 kbps     01:43:19.193    35,368 kbps     01:38:55.220    34,212 kbps     01:42:35.023    163,421 bytes   523,263 bytes   01:40:44.455
16              1:45:01.837     0:06:37.146     31,360 kbps     45,524 kbps     01:46:36.014    35,991 kbps     01:46:36.014    35,071 kbps     01:46:36.014    163,499 bytes   659,172 bytes   01:46:36.306
17              1:51:38.983     0:06:40.024     30,661 kbps     41,971 kbps     01:53:01.107    34,520 kbps     01:55:15.241    33,169 kbps     01:54:41.249    159,855 bytes   597,343 bytes   01:58:11.125
18              1:58:19.008     0:07:15.726     31,438 kbps     48,882 kbps     02:04:36.635    36,448 kbps     02:03:58.347    34,718 kbps     02:03:57.888    163,905 bytes   664,742 bytes   01:59:06.097
19              2:05:34.735     0:01:07.817     32,003 kbps     43,514 kbps     02:06:41.510    35,047 kbps     02:05:41.617    33,328 kbps     02:05:36.904    166,848 bytes   428,752 bytes   02:06:05.432
20              2:06:42.553     0:08:06.527     18,229 kbps     44,529 kbps     02:06:49.852    36,757 kbps     02:06:57.067    35,873 kbps     02:06:54.565    95,211 bytes    736,502 bytes   02:09:49.656
STREAM DIAGNOSTICS:
00009.M2TS      4113 (0x1011)   0xEA            VC-1                                    8088.998                29,484                  29,812,320,145  162,140,581
00009.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           8088.998                4,128                   4,173,667,120   23,943,694
00009.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           8088.998                768                     776,552,448     4,550,112
00009.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            8088.998                768                     776,552,448     4,550,112
00009.M2TS      4355 (0x1103)   0x82            DTS             deu (German)            8088.998                768                     776,552,448     4,550,112
00009.M2TS      4356 (0x1104)   0x82            DTS             ita (Italian)           8088.998                768                     776,552,448     4,550,112
00009.M2TS      4357 (0x1105)   0x82            DTS             spa (Spanish)           8088.998                768                     776,552,448     4,550,112
00009.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           8088.998                192                     194,138,112     1,263,920
00009.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8088.998                36                      36,524,351      211,027
00009.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           8088.998                28                      28,783,397      166,447
00009.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8088.998                30                      30,604,615      176,354
00009.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            8088.998                30                      30,680,963      176,887
00009.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            8088.998                35                      35,610,023      203,658
00009.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           8088.998                31                      30,934,278      178,209
00009.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           8088.998                29                      29,504,718      170,383
00009.M2TS      4615 (0x1207)   0x90            PGS             nld (Dutch)             8088.998                24                      24,348,652      140,862
00009.M2TS      4616 (0x1208)   0x90            PGS             eng (English)           8088.998                63                      63,747,299      361,809
00009.M2TS      4617 (0x1209)   0x90            PGS             fra (French)            8088.998                54                      54,727,948      312,515
00009.M2TS      4618 (0x120A)   0x90            PGS             deu (German)            8088.998                61                      61,905,030      351,632
00009.M2TS      4619 (0x120B)   0x90            PGS             ita (Italian)           8088.998                56                      56,615,403      322,888
00009.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           8088.998                54                      55,080,197      314,519
00009.M2TS      4621 (0x120D)   0x90            PGS             spa (Spanish)           8088.998                1                       1,448,893       8,425
00009.M2TS      4622 (0x120E)   0x90            PGS             fra (French)            8088.998                2                       1,906,381       11,068
00009.M2TS      4623 (0x120F)   0x90            PGS             deu (German)            8088.998                2                       1,918,079       11,038
00009.M2TS      4624 (0x1210)   0x90            PGS             ita (Italian)           8088.998                2                       1,814,478       10,552
00009.M2TS      4625 (0x1211)   0x90            PGS             spa (Spanish)           8088.998                2                       1,920,135       11,149
paku is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
