NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #1801 of 5106 Old 07-10-2010, 01:46 PM - Thread Starter
Cinema Squid's Avatar
Originally Posted by Phloyd View Post
I wonder if this is the source of some of the small number of bytes difference between some BDInfos and others from the same disc...?
Yes, I think this is one of the reasons. For example, moving to HDD with the "Keep Protection" option unchecked in AnyDVD will typically reduce the disc size by ~10MB (i.e. roughly the size of the AACS folder) - probably a bit more on a BD+ title. Presumably some of the other options like removing the region coding change the size slightly as well.
All in all, not really a big deal to me although it does sometimes make it difficult to say if discs are 100% identical without using something like the suggested approach for a checksum-based disc id.
Cinema Squid is offline
post #1802 of 5106 Old 07-13-2010, 08:23 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
I've seen the specs for the 2006 Blu-ray release. MGM re-released this title in 2010 with an SD DVD. Are the specs for the 2010 Blu-ray disc any different? Also, I believe "End of Days" has been released on Blu-ray twice. Which specs are listed, the first release, or the latest release? Thanks.
Big C is offline
post #1803 of 5106 Old 07-13-2010, 08:44 AM - Thread Starter
The current listings for both are the original releases. However, it's probably the case that The Terminator, End of Days and other titles reissued as Blu-ray + DVD combo packs are identical to the originals save for the package change and inclusion of the DVD. If it turns out that some are not, I can update the listing to reflect this on a case-by-case basis.
post #1804 of 5106 Old 07-13-2010, 11:03 AM
Phloyd's Avatar
I have started tracking the CRC32 checksum of MovieObject.bdmv, though I have not proven any uniqueness as of yet. I also keep the creation date of the BDMV folder.
The combination of these two should be so close to unique that we have a better chance of winning the lottery than finding two different discs with the same checksum and authoring Y/M/D H:M.
The only note is that removing BD+ does affect the MovieObject.bdmv file so you need to do it before that or use the 'backup' version of the file for this purpose (which is not changed).
Also, I use an SFV utility to calculate the CRC32.
Phloyd is offline
post #1805 of 5106 Old 07-13-2010, 02:14 PM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
I buy my movies at Amazon. Sometimes, results for two editions of the same title come up. If the releases have the same specs, then there is no need adding the later edition to the list. However, the reason I call the newer editions to your attention is so you could check them and if the specs are different on the later edition, you could add the specs to the later edition to the list. By the way, I don't think the 2010 edition of "End of Days" is a BD/DVD combo pack. So you might want to check it out. If the "Terminator" combo pack's BD specs are no different than the 2006 release, you don't need to add the specs to the list. You only need to add the specs if the BD disc in the combo pack is different. Same with the 2008 and 2010 releases of "End of Days." If the specs are the same, you don't need to add anything. You only need to add the 2010 specs if they are different from the 2008 edition.
Big C is offline
post #1806 of 5106 Old 07-13-2010, 10:04 PM - Thread Starter
[US] Eyeborgs (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Image
UPC: 014381656756
Release Date: 2010-07-06
Aspect Ratio: 2.35:1
Code:
        Total   Video
[US] Eyeborgs                                                   AVC     1:42:28 15,286,665,216  22,846,308,460  19.89   16.09   DTS-HD Master 5.1 2578Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     EYEBORGS
Disc Size:      22,846,308,460 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:42:28 (h:m:s)
Total Bitrate:          19.89 Mbps
VIDEO:
MPEG-4 AVC Video        16093 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2578 kbps       5.1 / 48 kHz / 2578 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         48.585 kbps
Presentation Graphics           Spanish         38.981 kbps
FILES:
00005.M2TS      0:00:00.000     1:42:28.142     15,286,665,216  19,891
CHAPTERS:
1               0:00:00.000     0:01:27.921     10,311 kbps     15,078 kbps     00:00:22.647    13,573 kbps     00:00:22.564    11,987 kbps     00:00:18.018    53,733 bytes    258,037 bytes   00:00:08.800
2               0:01:27.921     0:14:02.132     14,782 kbps     36,466 kbps     00:03:57.946    22,505 kbps     00:06:10.995    21,299 kbps     00:06:06.032    77,068 bytes    299,594 bytes   00:03:58.488
3               0:15:30.054     0:06:12.705     14,921 kbps     32,140 kbps     00:15:55.913    20,280 kbps     00:20:40.447    19,987 kbps     00:20:53.961    77,790 bytes    288,606 bytes   00:15:31.680
4               0:21:42.759     0:10:45.144     17,111 kbps     25,311 kbps     00:26:59.784    21,247 kbps     00:26:56.531    20,076 kbps     00:24:24.713    89,211 bytes    260,888 bytes   00:24:51.781
5               0:32:27.904     0:10:48.898     17,127 kbps     32,819 kbps     00:40:56.287    30,735 kbps     00:41:06.005    27,917 kbps     00:40:49.447    89,290 bytes    300,382 bytes   00:35:38.761
6               0:43:16.802     0:05:28.619     15,812 kbps     25,539 kbps     00:43:52.254    24,764 kbps     00:44:52.856    22,947 kbps     00:44:51.480    82,435 bytes    209,190 bytes   00:46:26.700
7               0:48:45.422     0:16:38.372     17,113 kbps     27,159 kbps     01:04:32.535    24,048 kbps     01:04:28.656    22,071 kbps     01:04:25.570    89,220 bytes    249,918 bytes   00:58:14.491
8               1:05:23.794     0:10:57.990     15,969 kbps     32,741 kbps     01:09:18.696    26,169 kbps     01:09:22.241    24,722 kbps     01:09:18.445    83,253 bytes    282,941 bytes   01:10:57.544
9               1:16:21.785     0:06:48.574     16,582 kbps     28,327 kbps     01:16:26.957    24,786 kbps     01:16:26.415    23,829 kbps     01:16:21.785    86,452 bytes    273,602 bytes   01:16:30.419
10              1:23:10.360     0:05:26.200     16,177 kbps     30,770 kbps     01:28:35.268    23,924 kbps     01:28:31.347    19,848 kbps     01:28:26.551    84,340 bytes    221,530 bytes   01:28:35.518
11              1:28:36.561     0:10:17.658     17,600 kbps     36,346 kbps     01:34:28.621    31,344 kbps     01:35:57.084    28,039 kbps     01:35:53.706    91,761 bytes    298,279 bytes   01:35:55.750
12              1:38:54.219     0:03:33.922     10,107 kbps     18,083 kbps     01:42:22.761    14,953 kbps     01:42:19.258    12,513 kbps     01:42:17.381    52,705 bytes    243,277 bytes   01:39:07.232
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     6147.975                16,094                  12,367,855,823  67,302,812
00005.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6147.975                2,578                   1,981,107,700   11,724,102
00005.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6147.975                49                      37,338,589      213,850
00005.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6147.975                39                      29,957,501      171,298
post #1807 of 5106 Old 07-13-2010, 10:07 PM - Thread Starter
[US] Lola Montès (Additional Details)
Studio: Criterion
UPC: 715515052719
Release Date: 2010-02-16
Aspect Ratio: 2.55:1
English DD 2.0 is a commentary.
Code:
        Total   Video
[US] Lola Montès                                                AVC     1:55:33 31,462,582,272  47,129,440,648  36.30   32.00   DTS-HD Master 3.0 2220Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     LOLA_MONTES
Disc Size:      47,129,440,648 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:55:33 (h:m:s)
Total Bitrate:          36.30 Mbps
VIDEO:
MPEG-4 AVC Video        32000 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             French          2220 kbps       3.0 / 48 kHz / 2220 kbps / 24-bit (DTS Core: 3.0 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           English         41.544 kbps
FILES:
00262.M2TS      0:00:00.000     1:55:33.259     31,462,582,272  36,303
CHAPTERS:
1               0:00:00.000     0:06:13.331     27,107 kbps     37,918 kbps     00:01:33.802    36,991 kbps     00:05:54.437    36,875 kbps     00:05:45.345    141,306 bytes   328,150 bytes   00:02:21.057
2               0:06:13.331     0:04:37.568     26,167 kbps     37,720 kbps     00:07:10.638    36,966 kbps     00:07:16.269    36,891 kbps     00:07:57.435    136,422 bytes   311,008 bytes   00:08:08.821
3               0:10:50.900     0:05:22.196     31,891 kbps     38,181 kbps     00:15:36.143    37,066 kbps     00:15:12.745    36,935 kbps     00:15:07.740    166,267 bytes   385,412 bytes   00:15:37.895
4               0:16:13.097     0:06:10.787     33,224 kbps     37,830 kbps     00:16:25.818    37,031 kbps     00:21:48.849    36,905 kbps     00:21:18.819    173,217 bytes   389,917 bytes   00:21:42.342
5               0:22:23.884     0:06:14.540     30,209 kbps     37,639 kbps     00:27:12.922    36,964 kbps     00:26:25.709    36,866 kbps     00:28:01.179    157,496 bytes   300,745 bytes   00:23:02.506
6               0:28:38.425     0:03:50.647     27,356 kbps     37,619 kbps     00:29:27.223    36,933 kbps     00:29:41.780    36,877 kbps     00:29:36.399    142,623 bytes   294,078 bytes   00:28:43.430
7               0:32:29.072     0:05:41.215     33,272 kbps     38,268 kbps     00:33:32.510    36,955 kbps     00:33:20.123    36,860 kbps     00:36:46.037    173,463 bytes   335,200 bytes   00:34:13.926
8               0:38:10.287     0:03:22.911     32,993 kbps     37,988 kbps     00:40:49.738    36,999 kbps     00:39:07.970    36,902 kbps     00:39:02.965    172,010 bytes   344,330 bytes   00:38:53.998
9               0:41:33.199     0:04:22.053     33,731 kbps     37,717 kbps     00:43:47.499    36,997 kbps     00:44:02.514    36,909 kbps     00:44:13.067    175,860 bytes   342,363 bytes   00:43:01.704
10              0:45:55.252     0:04:14.587     33,824 kbps     38,259 kbps     00:48:43.128    36,954 kbps     00:49:56.410    36,899 kbps     00:47:53.495    176,342 bytes   325,814 bytes   00:48:16.852
11              0:50:09.840     0:03:08.354     32,547 kbps     38,091 kbps     00:51:07.272    37,050 kbps     00:51:23.872    36,927 kbps     00:51:18.867    169,687 bytes   375,850 bytes   00:51:36.635
12              0:53:18.194     0:04:58.756     35,719 kbps     37,956 kbps     00:56:17.999    37,069 kbps     00:54:10.247    36,920 kbps     00:54:10.247    186,222 bytes   345,486 bytes   00:55:03.675
13              0:58:16.951     0:02:58.469     32,674 kbps     38,453 kbps     01:00:10.064    37,139 kbps     01:00:06.060    36,890 kbps     00:59:45.873    170,346 bytes   348,188 bytes   01:00:12.525
14              1:01:15.421     0:05:15.481     33,983 kbps     38,252 kbps     01:01:30.895    37,096 kbps     01:01:31.104    36,948 kbps     01:01:25.139    177,170 bytes   401,172 bytes   01:01:38.861
15              1:06:30.903     0:07:25.987     35,396 kbps     38,411 kbps     01:08:33.275    37,110 kbps     01:11:59.481    36,960 kbps     01:08:15.966    184,536 bytes   431,654 bytes   01:08:34.026
16              1:13:56.890     0:07:18.020     34,326 kbps     37,955 kbps     01:18:32.999    37,084 kbps     01:15:09.046    36,932 kbps     01:15:04.041    178,958 bytes   366,261 bytes   01:15:13.967
17              1:21:14.911     0:03:04.642     36,666 kbps     37,975 kbps     01:22:48.630    36,991 kbps     01:22:48.630    36,891 kbps     01:22:42.582    191,157 bytes   331,979 bytes   01:23:12.404
18              1:24:19.554     0:03:51.898     36,192 kbps     38,158 kbps     01:26:04.242    37,074 kbps     01:26:00.238    36,951 kbps     01:25:55.483    188,687 bytes   325,107 bytes   01:24:51.002
19              1:28:11.452     0:06:31.641     36,136 kbps     38,038 kbps     01:31:20.183    37,000 kbps     01:31:16.095    36,894 kbps     01:29:10.011    188,395 bytes   325,893 bytes   01:29:02.503
20              1:34:43.094     0:06:18.878     29,264 kbps     37,589 kbps     01:35:44.780    36,969 kbps     01:36:17.938    36,876 kbps     01:36:29.825    152,570 bytes   353,887 bytes   01:41:00.971
21              1:41:01.972     0:04:21.886     29,496 kbps     36,986 kbps     01:45:21.690    36,466 kbps     01:45:17.686    35,763 kbps     01:45:12.848    153,778 bytes   356,383 bytes   01:41:02.973
22              1:45:23.859     0:10:09.400     27,019 kbps     37,745 kbps     01:54:00.500    36,957 kbps     01:54:10.510    36,887 kbps     01:54:13.096    140,872 bytes   368,323 bytes   01:54:25.900
STREAM DIAGNOSTICS:
00262.M2TS      4113 (0x1011)   0x1B            AVC                                     6933.093                32,001                  27,733,383,034  150,821,743
00262.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            6933.093                2,220                   1,923,573,360   11,526,115
00262.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6933.093                192                     166,398,720     1,083,325
00262.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6933.093                42                      36,004,432      204,148
post #1808 of 5106 Old 07-13-2010, 10:12 PM
Renner's Avatar
Training Day (2001)
German Blu-ray:
Code:
PLAYLIST REPORT:
Length:                 2:02:02 (h:m:s)
Total Bitrate:          19.88 Mbps
VIDEO:
VC-1 Video              16424 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         46.894 kbps
Presentation Graphics           English         49.447 kbps
Presentation Graphics           French          41.658 kbps
Presentation Graphics           German          55.826 kbps
Presentation Graphics           German          58.248 kbps
Euro Blu-ray:
Code:
PLAYLIST REPORT:
Total Bitrate:          20.05 Mbps
VIDEO:
AUDIO:
Dolby Digital Audio             Italian         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         46.879 kbps
Presentation Graphics           Danish          44.665 kbps
Presentation Graphics           Dutch           38.886 kbps
Presentation Graphics           Finnish         39.437 kbps
Presentation Graphics           Italian         46.089 kbps
Presentation Graphics           Italian         0.033 kbps
Presentation Graphics           Italian         48.730 kbps
Presentation Graphics           Norwegian       50.768 kbps
Presentation Graphics           Spanish         49.241 kbps
Presentation Graphics           Swedish         41.647 kbps
Renner is offline
post #1809 of 5106 Old 07-13-2010, 10:15 PM - Thread Starter
[US] In Bruges (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Universal
UPC: 025192046896
Release Date: 2010-07-13
Code:
        Total   Video
[US] In Bruges                                                  VC-1    1:46:56 29,421,293,568  31,612,812,000  36.68   30.01   DTS-HD Master 5.1 3918Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     IN_BRUGES
Disc Size:      31,612,812,000 bytes
Protection:     AACS
BD-Java:        Yes
Extras:         D-BOX Motion Code
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:46:56 (h:m:s)
Total Bitrate:          36.68 Mbps
VIDEO:
VC-1 Video              30005 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3918 kbps       5.1 / 48 kHz / 3918 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         36.467 kbps
Presentation Graphics           French          30.373 kbps
Presentation Graphics           French          0.271 kbps
Presentation Graphics           Spanish         29.775 kbps
FILES:
00010.M2TS      0:00:00.000     1:46:56.618     29,421,293,568  36,681
CHAPTERS:
1               0:00:00.000     0:04:41.572     26,447 kbps     50,146 kbps     00:00:03.003    38,308 kbps     00:01:55.740    36,264 kbps     00:01:52.987    140,524 bytes   514,688 bytes   00:03:36.925
2               0:04:41.572     0:05:21.487     32,155 kbps     41,915 kbps     00:04:42.490    37,132 kbps     00:06:53.621    36,103 kbps     00:09:50.298    167,641 bytes   555,532 bytes   00:06:36.938
3               0:10:03.060     0:05:20.069     31,951 kbps     39,588 kbps     00:14:58.355    35,844 kbps     00:10:04.353    35,406 kbps     00:10:03.060    166,580 bytes   454,689 bytes   00:11:25.226
4               0:15:23.130     0:04:59.507     32,275 kbps     43,202 kbps     00:18:23.560    38,671 kbps     00:18:21.016    36,745 kbps     00:18:16.053    168,266 bytes   652,572 bytes   00:15:44.860
5               0:20:22.638     0:04:59.340     31,491 kbps     44,912 kbps     00:24:06.611    38,441 kbps     00:24:05.694    35,836 kbps     00:24:00.689    164,182 bytes   635,873 bytes   00:25:08.173
6               0:25:21.978     0:05:13.980     31,746 kbps     41,873 kbps     00:28:01.971    35,850 kbps     00:27:57.967    34,941 kbps     00:27:57.676    165,511 bytes   605,906 bytes   00:28:07.602
7               0:30:35.959     0:06:14.457     31,222 kbps     44,683 kbps     00:35:32.421    36,074 kbps     00:35:32.171    34,358 kbps     00:35:30.419    162,777 bytes   425,792 bytes   00:30:49.138
8               0:36:50.416     0:06:32.934     31,337 kbps     47,833 kbps     00:40:01.857    35,885 kbps     00:40:01.690    34,083 kbps     00:40:01.440    163,377 bytes   519,344 bytes   00:40:02.650
9               0:43:23.350     0:03:31.836     32,366 kbps     44,073 kbps     00:43:57.384    35,257 kbps     00:43:54.381    34,160 kbps     00:44:47.226    168,740 bytes   397,311 bytes   00:43:57.426
10              0:46:55.187     0:03:43.473     31,845 kbps     41,052 kbps     00:48:56.600    37,093 kbps     00:48:53.013    35,880 kbps     00:48:49.760    166,026 bytes   390,896 bytes   00:48:24.234
11              0:50:38.660     0:03:47.018     32,244 kbps     41,597 kbps     00:53:56.233    36,201 kbps     00:53:53.563    35,121 kbps     00:52:06.123    168,107 bytes   424,035 bytes   00:53:56.274
12              0:54:25.679     0:05:57.940     32,082 kbps     42,706 kbps     00:59:28.439    36,551 kbps     00:56:13.370    34,965 kbps     00:59:52.130    167,260 bytes   520,084 bytes   01:00:23.536
13              1:00:23.620     0:06:54.497     32,265 kbps     41,156 kbps     01:04:52.805    37,068 kbps     01:05:35.264    35,843 kbps     01:02:36.127    168,215 bytes   541,904 bytes   01:05:21.709
14              1:07:18.117     0:05:10.893     31,869 kbps     42,046 kbps     01:10:20.674    34,722 kbps     01:10:16.670    34,079 kbps     01:11:32.871    166,152 bytes   567,961 bytes   01:12:28.927
15              1:12:29.011     0:05:17.150     31,835 kbps     40,075 kbps     01:15:17.888    36,813 kbps     01:13:22.231    34,551 kbps     01:13:22.648    165,974 bytes   519,727 bytes   01:13:23.357
16              1:17:46.161     0:06:07.825     31,413 kbps     41,671 kbps     01:18:04.054    36,668 kbps     01:20:23.109    36,249 kbps     01:20:19.523    163,773 bytes   478,544 bytes   01:18:04.846
17              1:23:53.987     0:05:23.614     31,764 kbps     42,526 kbps     01:29:04.797    35,108 kbps     01:29:03.963    33,643 kbps     01:26:03.158    165,605 bytes   468,493 bytes   01:29:05.006
18              1:29:17.602     0:07:25.820     31,467 kbps     46,199 kbps     01:36:26.155    35,404 kbps     01:30:19.831    34,404 kbps     01:30:19.747    164,055 bytes   514,506 bytes   01:32:06.062
19              1:36:43.422     0:04:32.271     31,620 kbps     43,791 kbps     01:37:00.814    35,886 kbps     01:38:19.685    35,244 kbps     01:38:18.142    165,791 bytes   509,220 bytes   01:39:07.149
20              1:41:15.694     0:05:40.923     2,429 kbps      4,839 kbps      01:46:00.771    4,709 kbps      01:46:00.270    4,544 kbps      01:45:57.017    13,809 bytes    169,324 bytes   01:46:00.979
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    6416.493                30,006                  24,066,362,101  130,888,322
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6416.493                3,918                   3,142,689,496   18,078,401
00010.M2TS      4353 (0x1101)   0x82            DTS             fra (French)            6416.493                768                     615,995,392     3,609,348
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6416.493                36                      29,249,037      167,110
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6416.493                30                      23,881,467      136,928
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6416.493                30                      24,361,863      139,553
00010.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            6416.493                0                       217,162         1,241
post #1810 of 5106 Old 07-13-2010, 10:27 PM
Stephen Dawson's Avatar
Brothers - 2009 - Australian version
Distributed by Roadshow Entertainment
Region Free, confirmed with AnyDVD HD. No 50 hertz content.
Presented with a 1.78:1 aspect ratio. Original aspect ratio: 2.35:1. Unclear whether this has been 'pan and scanned', or just opened up.
One of the stereo audio tracks is English Audio Descriptive and the other is a commentary.
Code:
        Total   Video
00000.MPLS                                                      AVC     1:44:37 24,461,137,920  30,825,610,236  31.17   25.99   Dolby TrueHD 5.1 1223Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     BROTHERS
Disc Size:      30,825,610,236 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:44:37 (h:m:s)
Total Bitrate:          31.17 Mbps
VIDEO:
MPEG-4 AVC Video        25991 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1223 kbps       5.1 / 48 kHz / 1223 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps)
Dolby Digital Audio             English         640 kbps        2.0 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         37.473 kbps
FILES:
00000.M2TS      0:00:00.000     1:44:37.145     24,461,137,920  31,175
CHAPTERS:
1               0:00:00.000     0:07:21.149     27,130 kbps     35,423 kbps     00:00:33.658    33,105 kbps     00:04:16.673    32,374 kbps     00:03:17.655    141,427 bytes   401,883 bytes   00:04:41.531
2               0:07:21.149     0:05:09.100     25,310 kbps     29,807 kbps     00:10:05.396    28,537 kbps     00:11:08.542    28,114 kbps     00:11:08.542    131,957 bytes   315,959 bytes   00:08:37.683
3               0:12:30.249     0:06:53.496     24,604 kbps     33,746 kbps     00:14:41.589    33,011 kbps     00:14:37.585    32,922 kbps     00:14:32.580    128,274 bytes   332,560 bytes   00:15:59.875
4               0:19:23.745     0:06:22.298     25,703 kbps     34,436 kbps     00:23:36.623    32,956 kbps     00:24:42.063    32,699 kbps     00:24:42.063    134,004 bytes   459,325 bytes   00:23:37.624
5               0:25:46.044     0:06:55.915     26,228 kbps     33,768 kbps     00:28:06.309    31,536 kbps     00:28:03.807    30,640 kbps     00:28:47.308    136,741 bytes   337,617 bytes   00:28:33.878
6               0:32:41.960     0:06:53.121     26,719 kbps     34,672 kbps     00:33:29.841    33,190 kbps     00:36:52.960    32,984 kbps     00:36:52.460    139,302 bytes   403,456 bytes   00:39:26.113
7               0:39:35.081     0:05:28.036     29,143 kbps     33,937 kbps     00:44:01.889    33,024 kbps     00:43:57.217    32,879 kbps     00:43:31.066    151,937 bytes   334,650 bytes   00:41:21.854
8               0:45:03.117     0:09:43.040     25,997 kbps     34,799 kbps     00:47:21.380    33,210 kbps     00:46:59.900    32,998 kbps     00:47:19.336    135,536 bytes   480,688 bytes   00:46:47.262
9               0:54:46.157     0:04:48.037     30,923 kbps     34,641 kbps     00:55:29.659    33,159 kbps     00:55:26.740    32,988 kbps     00:55:21.609    161,220 bytes   377,533 bytes   00:55:04.592
10              0:59:34.195     0:06:58.251     29,629 kbps     34,621 kbps     00:59:55.133    33,030 kbps     01:02:49.891    32,932 kbps     01:02:44.886    154,473 bytes   366,012 bytes   01:02:14.439
11              1:06:32.446     0:07:37.498     28,647 kbps     34,115 kbps     01:08:34.777    33,165 kbps     01:10:07.745    32,977 kbps     01:10:15.961    149,354 bytes   347,497 bytes   01:06:40.329
12              1:14:09.945     0:04:24.555     26,828 kbps     33,630 kbps     01:14:21.665    31,574 kbps     01:14:19.830    30,751 kbps     01:14:17.411    139,869 bytes   374,992 bytes   01:14:20.956
13              1:18:34.501     0:08:44.649     26,056 kbps     34,394 kbps     01:19:07.617    33,049 kbps     01:19:04.239    32,563 kbps     01:18:58.608    135,844 bytes   488,763 bytes   01:19:08.577
14              1:27:19.150     0:07:59.729     23,935 kbps     33,293 kbps     01:32:17.740    31,453 kbps     01:32:16.739    29,536 kbps     01:31:32.236    124,786 bytes   299,093 bytes   01:31:13.301
15              1:35:18.879     0:05:05.054     25,473 kbps     34,613 kbps     01:37:52.199    32,794 kbps     01:37:50.197    32,303 kbps     01:37:50.197    132,803 bytes   424,427 bytes   01:37:53.075
16              1:40:23.934     0:04:13.211     8,964 kbps      33,939 kbps     01:40:30.190    31,823 kbps     01:40:26.186    25,997 kbps     01:40:23.934    46,740 bytes    390,079 bytes   01:40:27.354
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6276.979                25,992                  20,393,945,044  110,924,172
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6276.979                1,671                   1,311,465,664   10,214,049
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6276.979                640                     502,172,160     2,942,415
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6276.979                640                     502,172,160     2,942,415
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6276.979                37                      29,402,702      168,406
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1811 of 5106 Old 07-13-2010, 10:32 PM - Thread Starter
[US] Insomnia (Additional Details)
Studio: Warner
UPC: 883929108985
Aspect Ratio: 2.40:1
This one took a little figuring to determine the actual structure. There are five separate scene-specific commentaries represented by the four hidden English DD 2.0 tracks (presumably a pair of them doesn't overlap, so thus can share a track). Individual playlists are provided for each of these, along with a 42-minute "combined" commentary - all refer to offsets in the main title M2TS and activate the appropriate audio commentary track.
There is also a (nearly) full-length feature commentary by Christopher Nolan which is provided as a completely separate encode with scene number notes embedded in the video. I've included this playlist at the bottom (a single selectable English DD 2.0 and no subtitles, regardless of what Warner's messy spaghetti authoring might imply).
Code:
        Total   Video
[US] Insomnia                                                   VC-1    1:58:13 28,313,296,896  43,962,613,143  31.93   23.75   DTS-HD Master 5.1 3851Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     INSOMNIA
Disc Size:      43,962,613,143 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:58:13 (h:m:s)
Total Bitrate:          31.93 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
VC-1 Video              23751 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3851 kbps       5.1 / 48 kHz / 3851 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         30.536 kbps
* Presentation Graphics         English         0.000 kbps
Presentation Graphics           French          22.882 kbps
* Presentation Graphics         French          0.000 kbps
Presentation Graphics           German          36.827 kbps
* Presentation Graphics         German          0.000 kbps
Presentation Graphics           Portuguese      29.974 kbps
* Presentation Graphics         Portuguese      0.000 kbps
Presentation Graphics           Spanish         25.796 kbps
* Presentation Graphics         Spanish         0.000 kbps
FILES:
00020.M2TS      0:00:00.000     1:58:13.544     28,313,296,896  31,931
CHAPTERS:
1               0:00:00.000     0:02:56.050     12,829 kbps     40,583 kbps     00:00:04.546    32,543 kbps     00:02:46.374    32,170 kbps     00:02:46.040    67,640 bytes    374,910 bytes   00:01:04.397
2               0:02:56.050     0:03:25.747     27,853 kbps     41,456 kbps     00:05:47.764    34,152 kbps     00:05:58.983    32,753 kbps     00:05:54.937    145,214 bytes   371,495 bytes   00:03:43.598
3               0:06:21.798     0:03:51.147     27,819 kbps     43,117 kbps     00:08:32.887    34,765 kbps     00:08:56.661    32,559 kbps     00:08:18.915    145,035 bytes   353,490 bytes   00:06:26.803
4               0:10:12.945     0:02:30.483     27,627 kbps     33,501 kbps     00:11:01.285    31,698 kbps     00:11:04.288    30,745 kbps     00:11:00.701    144,032 bytes   335,591 bytes   00:11:02.244
5               0:12:43.429     0:03:46.809     29,041 kbps     34,305 kbps     00:14:44.717    33,662 kbps     00:14:43.215    31,726 kbps     00:14:43.215    151,407 bytes   295,145 bytes   00:14:05.761
6               0:16:30.239     0:05:15.315     27,429 kbps     41,767 kbps     00:17:45.439    34,245 kbps     00:16:48.716    31,715 kbps     00:16:47.548    143,001 bytes   332,505 bytes   00:19:41.889
7               0:21:45.554     0:02:05.250     24,358 kbps     31,238 kbps     00:22:07.409    28,531 kbps     00:21:48.849    27,953 kbps     00:21:45.762    126,993 bytes   276,970 bytes   00:22:31.892
8               0:23:50.804     0:03:15.862     26,763 kbps     43,071 kbps     00:27:04.956    34,198 kbps     00:25:10.258    32,284 kbps     00:25:10.258    139,531 bytes   396,575 bytes   00:24:01.022
9               0:27:06.666     0:04:33.272     25,096 kbps     44,282 kbps     00:27:19.012    35,276 kbps     00:30:03.301    32,523 kbps     00:28:28.498    130,840 bytes   321,009 bytes   00:27:19.512
10              0:31:39.939     0:03:20.116     20,359 kbps     28,210 kbps     00:34:18.139    24,096 kbps     00:31:45.737    23,179 kbps     00:31:45.236    106,141 bytes   271,889 bytes   00:35:00.014
11              0:35:00.056     0:02:46.624     23,698 kbps     31,772 kbps     00:37:01.802    29,409 kbps     00:36:59.842    28,154 kbps     00:36:23.806    123,549 bytes   280,417 bytes   00:37:40.174
12              0:37:46.681     0:03:34.964     20,463 kbps     35,495 kbps     00:39:31.285    33,986 kbps     00:39:31.285    29,547 kbps     00:39:26.030    106,687 bytes   403,018 bytes   00:39:52.181
13              0:41:21.645     0:04:44.659     22,138 kbps     35,925 kbps     00:43:05.874    33,306 kbps     00:43:02.037    31,425 kbps     00:42:57.700    115,415 bytes   372,294 bytes   00:43:05.749
14              0:46:06.305     0:02:45.081     21,311 kbps     33,411 kbps     00:48:34.661    28,233 kbps     00:48:34.119    27,420 kbps     00:48:27.654    111,106 bytes   279,823 bytes   00:47:08.867
15              0:48:51.386     0:02:29.149     25,489 kbps     33,478 kbps     00:51:13.195    30,247 kbps     00:51:11.318    28,739 kbps     00:51:06.521    132,889 bytes   258,553 bytes   00:50:52.174
16              0:51:20.535     0:05:31.748     26,212 kbps     35,905 kbps     00:55:36.958    32,165 kbps     00:54:24.803    30,287 kbps     00:55:47.302    136,656 bytes   345,683 bytes   00:55:29.576
17              0:56:52.283     0:04:26.391     22,180 kbps     32,310 kbps     01:00:54.525    30,600 kbps     01:00:08.980    29,416 kbps     01:00:07.895    115,635 bytes   303,215 bytes   00:56:59.290
18              1:01:18.675     0:02:55.049     27,790 kbps     40,368 kbps     01:02:18.276    32,644 kbps     01:02:35.126    31,571 kbps     01:02:31.622    144,884 bytes   478,540 bytes   01:02:38.921
19              1:04:13.724     0:02:29.107     25,706 kbps     34,402 kbps     01:06:32.279    31,643 kbps     01:06:29.360    30,667 kbps     01:06:24.397    134,020 bytes   285,508 bytes   01:06:11.008
20              1:06:42.832     0:05:08.725     24,570 kbps     41,994 kbps     01:08:57.216    33,635 kbps     01:07:46.645    32,104 kbps     01:07:42.808    128,099 bytes   319,452 bytes   01:07:39.180
21              1:11:51.557     0:03:07.520     22,260 kbps     39,263 kbps     01:11:51.890    33,217 kbps     01:12:56.121    30,469 kbps     01:11:51.557    116,053 bytes   326,656 bytes   01:13:00.084
22              1:14:59.077     0:04:46.202     23,529 kbps     31,454 kbps     01:15:53.215    28,597 kbps     01:15:49.253    27,215 kbps     01:15:44.164    122,669 bytes   284,965 bytes   01:17:56.296
23              1:19:45.280     0:05:58.274     20,105 kbps     29,693 kbps     01:25:19.989    26,387 kbps     01:20:07.719    25,840 kbps     01:20:03.673    104,821 bytes   328,875 bytes   01:19:47.824
24              1:25:43.555     0:03:39.219     26,249 kbps     34,664 kbps     01:27:36.501    32,828 kbps     01:27:32.497    30,983 kbps     01:27:29.661    136,848 bytes   317,375 bytes   01:27:37.502
25              1:29:22.774     0:04:47.620     23,375 kbps     43,814 kbps     01:30:06.442    33,068 kbps     01:30:03.439    28,806 kbps     01:30:03.439    121,867 bytes   446,926 bytes   01:30:03.481
26              1:34:10.394     0:02:46.249     24,882 kbps     32,006 kbps     01:34:16.275    30,702 kbps     01:34:14.065    28,816 kbps     01:34:13.105    129,725 bytes   320,012 bytes   01:36:45.716
27              1:36:56.644     0:05:51.225     24,213 kbps     34,548 kbps     01:37:00.272    30,281 kbps     01:38:09.341    29,457 kbps     01:38:05.629    126,233 bytes   412,274 bytes   01:37:08.572
28              1:42:47.870     0:03:25.455     26,931 kbps     42,935 kbps     01:44:56.581    33,553 kbps     01:45:33.410    30,553 kbps     01:45:19.813    140,406 bytes   452,268 bytes   01:45:37.497
29              1:46:13.325     0:02:49.502     26,712 kbps     33,578 kbps     01:46:21.458    31,509 kbps     01:47:44.124    30,369 kbps     01:47:42.581    139,266 bytes   403,757 bytes   01:48:27.626
30              1:49:02.827     0:05:02.010     24,505 kbps     41,006 kbps     01:50:54.773    31,894 kbps     01:49:37.279    30,887 kbps     01:49:51.793    129,312 bytes   467,603 bytes   01:49:41.658
31              1:54:04.838     0:04:08.706     7,611 kbps      17,333 kbps     01:58:06.788    12,266 kbps     01:58:06.746    10,731 kbps     01:54:57.932    40,031 bytes    550,219 bytes   01:58:09.082
STREAM DIAGNOSTICS:
00020.M2TS      4113 (0x1011)   0xEA            VC-1                                    7093.420                23,751                  21,059,755,318  114,557,674
00020.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7093.420                3,851                   3,414,258,340   19,661,278
00020.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7093.420                640                     567,485,440     3,325,110
00020.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            7093.420                640                     567,485,440     3,325,110
00020.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           7093.420                192                     170,245,632     1,108,370
00020.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           7093.420                192                     170,245,632     1,108,370
00020.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           7093.420                192                     170,245,632     1,108,370
00020.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           7093.420                192                     170,245,632     1,108,370
00020.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           7093.420                192                     170,245,632     1,108,370
00020.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7093.420                31                      27,076,418      155,002
00020.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7093.420                23                      20,289,470      117,086
00020.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            7093.420                37                      32,654,545      185,670
00020.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7093.420                26                      22,872,837      131,509
00020.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        7093.420                30                      26,577,717      151,641
00020.M2TS      4613 (0x1205)   0x90            PGS             eng (English)           7093.420                0                       70              7
00020.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            7093.420                0                       70              7
00020.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            7093.420                0                       70              7
00020.M2TS      4616 (0x1208)   0x90            PGS             spa (Spanish)           7093.420                0                       70              7
00020.M2TS      4617 (0x1209)   0x90            PGS             por (Portuguese)        7093.420                0                       70              7
Christopher Nolan Commentary Version
Code:
        Total   Video
00207.MPLS                                                      VC-1    1:46:27 13,366,972,416  43,962,613,143  16.74   15.05   DD AC3 2.0 192Kbps
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:46:27 (h:m:s)
Total Bitrate:          16.74 Mbps
VIDEO:
VC-1 Video              15053 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
SUBTITLES:
FILES:
00089.M2TS      0:00:00.000     1:46:27.506     13,366,972,416  16,741
CHAPTERS:
1               0:00:00.000     0:00:16.766     13,263 kbps     19,186 kbps     00:00:02.085    15,700 kbps     00:00:05.672    15,523 kbps     00:00:04.879    73,150 bytes    174,379 bytes   00:00:03.003
2               0:00:16.766     0:00:28.361     16,027 kbps     19,511 kbps     00:00:20.145    18,165 kbps     00:00:18.810    17,467 kbps     00:00:19.477    83,556 bytes    148,386 bytes   00:00:39.414
3               0:00:45.128     0:00:38.872     12,615 kbps     21,610 kbps     00:01:21.372    16,529 kbps     00:00:53.928    15,443 kbps     00:00:49.049    65,768 bytes    141,393 bytes   00:01:22.081
4               0:01:24.000     0:02:55.967     17,330 kbps     21,736 kbps     00:02:48.960    20,640 kbps     00:02:46.875    19,426 kbps     00:02:42.203    90,353 bytes    245,204 bytes   00:02:49.878
5               0:04:19.968     0:03:46.434     13,486 kbps     16,749 kbps     00:05:44.218    15,363 kbps     00:06:00.485    15,001 kbps     00:07:55.308    70,311 bytes    230,188 bytes   00:08:06.360
6               0:08:06.402     0:02:30.400     13,542 kbps     18,178 kbps     00:08:57.620    17,697 kbps     00:08:57.620    16,361 kbps     00:08:56.911    70,603 bytes    238,999 bytes   00:08:09.405
7               0:10:36.802     0:02:12.257     15,623 kbps     21,632 kbps     00:11:11.253    17,784 kbps     00:11:08.959    17,312 kbps     00:11:02.328    81,453 bytes    181,207 bytes   00:10:39.555
8               0:12:49.059     0:00:56.306     16,106 kbps     18,976 kbps     00:13:23.427    17,153 kbps     00:13:21.091    16,907 kbps     00:12:57.526    83,969 bytes    170,277 bytes   00:13:45.324
9               0:13:45.366     0:01:00.518     12,338 kbps     16,572 kbps     00:14:24.905    15,098 kbps     00:14:24.864    14,025 kbps     00:14:24.864    64,327 bytes    182,123 bytes   00:14:45.885
10              0:14:45.885     0:01:38.848     12,783 kbps     17,432 kbps     00:15:54.036    17,027 kbps     00:14:46.844    15,748 kbps     00:14:45.926    66,647 bytes    189,303 bytes   00:14:47.887
11              0:16:24.733     0:02:05.166     12,685 kbps     16,970 kbps     00:16:31.949    15,602 kbps     00:16:31.657    15,266 kbps     00:16:27.987    66,133 bytes    170,169 bytes   00:17:11.030
12              0:18:29.900     0:00:37.078     13,046 kbps     16,035 kbps     00:18:40.828    14,654 kbps     00:18:32.653    14,535 kbps     00:18:32.736    68,014 bytes    177,164 bytes   00:18:41.703
13              0:19:06.979     0:04:06.287     13,484 kbps     17,269 kbps     00:19:28.500    15,429 kbps     00:19:31.128    14,859 kbps     00:19:28.208    70,300 bytes    147,248 bytes   00:21:27.452
14              0:23:13.266     0:01:38.014     12,518 kbps     18,320 kbps     00:23:58.979    14,816 kbps     00:23:13.266    14,107 kbps     00:24:06.778    65,264 bytes    190,557 bytes   00:23:59.563
15              0:24:51.281     0:01:59.452     12,936 kbps     18,794 kbps     00:24:52.407    17,589 kbps     00:24:51.823    16,264 kbps     00:24:51.281    67,443 bytes    194,349 bytes   00:26:07.732
16              0:26:50.734     0:00:50.049     16,173 kbps     25,964 kbps     00:27:06.833    22,010 kbps     00:27:05.248    19,335 kbps     00:27:06.833    84,320 bytes    201,920 bytes   00:27:06.875
17              0:27:40.784     0:00:56.806     14,306 kbps     21,129 kbps     00:28:03.640    16,402 kbps     00:28:00.095    15,386 kbps     00:27:58.093    74,586 bytes    222,217 bytes   00:28:37.549
18              0:28:37.590     0:01:13.156     17,151 kbps     24,723 kbps     00:29:15.670    22,353 kbps     00:29:12.041    20,242 kbps     00:29:09.831    89,415 bytes    222,248 bytes   00:29:44.032
19              0:29:50.747     0:00:44.294     11,760 kbps     19,908 kbps     00:29:52.665    15,964 kbps     00:29:50.747    14,893 kbps     00:29:50.747    61,311 bytes    163,648 bytes   00:30:16.064
20              0:30:35.041     0:01:40.809     12,736 kbps     16,036 kbps     00:32:11.179    15,241 kbps     00:31:04.279    14,322 kbps     00:31:45.695    66,402 bytes    209,948 bytes   00:30:44.175
21              0:32:15.850     0:01:16.409     17,020 kbps     20,070 kbps     00:33:10.738    19,145 kbps     00:33:09.612    18,556 kbps     00:33:06.025    88,736 bytes    245,377 bytes   00:33:11.698
22              0:33:32.260     0:02:21.683     16,954 kbps     22,933 kbps     00:34:38.576    20,817 kbps     00:34:36.073    19,742 kbps     00:34:48.920    88,389 bytes    267,785 bytes   00:34:31.277
23              0:35:53.943     0:00:27.193     14,014 kbps     16,293 kbps     00:36:15.673    15,267 kbps     00:36:14.714    14,518 kbps     00:36:08.708    73,063 bytes    269,457 bytes   00:36:21.095
24              0:36:21.137     0:00:48.757     13,865 kbps     18,739 kbps     00:36:22.054    15,383 kbps     00:36:31.647    15,176 kbps     00:36:26.017    72,283 bytes    264,918 bytes   00:36:22.138
25              0:37:09.894     0:01:31.132     18,061 kbps     27,413 kbps     00:38:09.412    20,953 kbps     00:38:26.762    20,021 kbps     00:38:22.925    94,163 bytes    285,688 bytes   00:38:09.453
26              0:38:41.027     0:00:41.624     17,318 kbps     25,446 kbps     00:38:47.658    21,351 kbps     00:38:45.865    20,321 kbps     00:38:41.027    90,289 bytes    209,438 bytes   00:38:50.661
27              0:39:22.651     0:05:10.059     13,146 kbps     18,865 kbps     00:43:41.827    16,867 kbps     00:43:40.075    15,866 kbps     00:43:36.655    68,537 bytes    193,285 bytes   00:39:29.867
28              0:44:32.711     0:01:38.515     15,593 kbps     20,398 kbps     00:45:19.925    19,779 kbps     00:45:16.004    19,558 kbps     00:45:10.958    81,297 bytes    295,948 bytes   00:45:20.175
29              0:46:11.226     0:01:16.076     14,717 kbps     20,940 kbps     00:46:15.272    17,205 kbps     00:46:11.351    16,558 kbps     00:46:28.076    76,730 bytes    247,568 bytes   00:46:13.729
30              0:47:27.302     0:00:13.847     14,603 kbps     17,620 kbps     00:47:39.690    16,394 kbps     00:47:35.686    15,476 kbps     00:47:30.681    76,132 bytes    145,132 bytes   00:47:36.854
31              0:47:41.149     0:00:44.002     15,607 kbps     18,392 kbps     00:48:13.181    16,720 kbps     00:47:51.451    16,443 kbps     00:47:48.699    81,369 bytes    151,664 bytes   00:47:47.739
32              0:48:25.152     0:00:22.188     14,300 kbps     19,443 kbps     00:48:35.037    15,838 kbps     00:48:31.116    15,565 kbps     00:48:26.069    74,556 bytes    160,683 bytes   00:48:27.863
33              0:48:47.341     0:01:33.968     15,445 kbps     19,179 kbps     00:48:47.424    18,283 kbps     00:48:47.591    17,097 kbps     00:48:47.633    80,526 bytes    164,552 bytes   00:49:25.879
34              0:50:21.309     0:01:46.105     15,948 kbps     20,163 kbps     00:51:01.725    18,088 kbps     00:50:58.722    17,437 kbps     00:50:53.341    83,147 bytes    178,625 bytes   00:51:38.637
35              0:52:07.415     0:02:22.892     15,979 kbps     19,492 kbps     00:54:20.465    18,805 kbps     00:54:16.544    18,435 kbps     00:54:11.873    83,305 bytes    183,386 bytes   00:53:59.569
36              0:54:30.308     0:01:53.446     17,716 kbps     22,967 kbps     00:56:20.502    20,901 kbps     00:56:18.124    19,334 kbps     00:56:13.119    92,361 bytes    209,477 bytes   00:56:20.877
37              0:56:23.755     0:03:58.988     15,624 kbps     20,077 kbps     00:58:23.458    18,088 kbps     00:58:22.165    17,471 kbps     00:58:21.748    81,459 bytes    269,965 bytes   00:57:05.964
38              1:00:22.744     0:01:45.772     13,264 kbps     21,230 kbps     01:00:26.122    17,922 kbps     01:00:22.744    16,041 kbps     01:00:22.869    69,153 bytes    210,099 bytes   01:01:00.281
39              1:02:08.516     0:03:52.565     17,345 kbps     21,000 kbps     01:02:14.313    19,658 kbps     01:02:20.653    19,235 kbps     01:02:14.313    90,429 bytes    286,553 bytes   01:06:01.040
40              1:06:01.082     0:00:35.034     17,566 kbps     24,643 kbps     01:06:09.632    23,748 kbps     01:06:07.755    20,861 kbps     01:06:02.750    91,583 bytes    329,613 bytes   01:06:28.818
41              1:06:36.117     0:07:27.738     15,086 kbps     28,830 kbps     01:12:00.858    24,403 kbps     01:12:00.858    19,685 kbps     01:12:00.566    78,650 bytes    223,627 bytes   01:12:00.899
42              1:14:03.856     0:03:46.726     13,713 kbps     17,568 kbps     01:17:39.738    16,322 kbps     01:17:39.905    15,348 kbps     01:17:34.900    71,495 bytes    191,413 bytes   01:14:04.857
43              1:17:50.582     0:01:24.626     12,701 kbps     15,042 kbps     01:18:00.300    14,182 kbps     01:17:58.131    13,536 kbps     01:17:54.711    66,216 bytes    150,025 bytes   01:18:00.342
44              1:19:15.208     0:00:39.122     14,461 kbps     16,170 kbps     01:19:22.299    15,365 kbps     01:19:18.378    15,056 kbps     01:19:15.292    75,394 bytes    157,915 bytes   01:19:16.209
45              1:19:54.331     0:00:41.958     20,400 kbps     23,950 kbps     01:20:10.388    22,213 kbps     01:20:10.388    21,377 kbps     01:20:08.470    106,358 bytes   160,717 bytes   01:19:56.833
46              1:20:36.289     0:00:12.011     15,435 kbps     18,362 kbps     01:20:39.251    16,898 kbps     01:20:37.207    16,049 kbps     01:20:36.456    80,470 bytes    197,348 bytes   01:20:46.299
47              1:20:48.301     0:02:55.466     14,978 kbps     20,809 kbps     01:21:12.033    17,057 kbps     01:21:03.400    16,782 kbps     01:21:03.525    78,091 bytes    191,425 bytes   01:21:04.693
48              1:23:43.768     0:02:04.332     14,651 kbps     19,503 kbps     01:25:42.554    18,114 kbps     01:25:38.591    16,998 kbps     01:24:14.591    76,386 bytes    212,045 bytes   01:25:41.678
49              1:25:48.101     0:03:54.067     14,931 kbps     17,873 kbps     01:28:11.536    17,033 kbps     01:26:41.112    16,283 kbps     01:26:41.196    77,845 bytes    152,346 bytes   01:26:43.573
50              1:29:42.168     0:05:37.003     15,483 kbps     21,146 kbps     01:31:29.192    19,372 kbps     01:30:53.448    18,933 kbps     01:30:50.486    80,724 bytes    235,569 bytes   01:29:53.971
51              1:35:19.171     0:01:30.924     16,834 kbps     22,450 kbps     01:36:30.284    18,925 kbps     01:36:34.288    18,775 kbps     01:36:04.091    87,762 bytes    213,648 bytes   01:36:30.826
52              1:36:50.095     0:01:22.665     18,589 kbps     32,253 kbps     01:38:08.090    23,575 kbps     01:38:04.169    20,920 kbps     01:37:46.443    96,915 bytes    357,468 bytes   01:38:08.549
53              1:38:12.761     0:00:20.270     16,896 kbps     20,722 kbps     01:38:20.728    19,732 kbps     01:38:16.807    19,110 kbps     01:38:15.723    88,087 bytes    304,259 bytes   01:38:18.767
54              1:38:33.032     0:02:17.178     13,926 kbps     17,932 kbps     01:39:07.441    16,642 kbps     01:39:03.729    16,116 kbps     01:40:24.977    72,603 bytes    202,496 bytes   01:38:45.502
55              1:40:50.210     0:00:42.709     16,710 kbps     20,678 kbps     01:41:18.155    18,380 kbps     01:41:18.155    17,717 kbps     01:41:18.155    87,117 bytes    187,715 bytes   01:40:52.212
56              1:41:32.920     0:03:26.956     17,418 kbps     23,495 kbps     01:44:46.613    19,953 kbps     01:42:31.103    19,174 kbps     01:42:30.352    90,808 bytes    253,157 bytes   01:44:37.479
57              1:44:59.876     0:01:27.629     15,760 kbps     30,997 kbps     01:45:42.919    21,530 kbps     01:45:38.957    18,597 kbps     01:45:40.292    83,237 bytes    196,426 bytes   01:45:43.879
STREAM DIAGNOSTICS:
00089.M2TS      4113 (0x1011)   0xEA            VC-1                                    6387.423                15,053                  12,019,078,098  65,413,410
00089.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6387.423                192                     153,300,480     998,050
00089.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6387.423                192                     153,300,480     998,050
00089.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6387.423                192                     153,300,480     998,050
00089.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6387.423                192                     153,300,480     998,050
00089.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6387.423                0                       70              7
00089.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            6387.423                0                       70              7
00089.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            6387.423                0                       70              7
00089.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6387.423                0                       70              7
00089.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        6387.423                0                       70              7
post #1812 of 5106 Old 07-14-2010, 04:16 AM
Youth in Revolt - 2009 - Australian version
Very different encode to the US version.
Code:
        Total   Video
00021.MPLS                                                      AVC     1:29:23 22,518,030,336  28,014,233,939  33.59   27.99   Dolby TrueHD 5.1 1313Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     YOUTHINREVOLT
Disc Size:      28,014,233,939 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:29:23 (h:m:s)
Total Bitrate:          33.59 Mbps
VIDEO:
MPEG-4 AVC Video        27994 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1313 kbps       5.1 / 48 kHz / 1313 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
SUBTITLES:
Presentation Graphics           English         60.137 kbps
FILES:
00056.M2TS      0:00:00.000     1:29:23.816     22,518,030,336  33,585
CHAPTERS:
1               0:00:00.000     0:07:21.232     26,386 kbps     34,940 kbps     00:01:39.390    33,260 kbps     00:01:35.386    32,388 kbps     00:01:32.383    137,552 bytes   474,181 bytes   00:01:40.141
2               0:07:21.232     0:05:54.687     29,473 kbps     34,562 kbps     00:08:46.442    33,123 kbps     00:10:12.361    32,979 kbps     00:10:07.356    153,657 bytes   430,653 bytes   00:10:32.340
3               0:13:15.920     0:05:01.259     29,743 kbps     35,066 kbps     00:16:21.480    33,218 kbps     00:16:21.480    33,002 kbps     00:16:21.480    155,065 bytes   423,052 bytes   00:16:27.361
4               0:18:17.179     0:05:24.907     30,703 kbps     34,958 kbps     00:19:10.149    33,274 kbps     00:19:06.145    33,050 kbps     00:19:01.140    160,070 bytes   478,045 bytes   00:21:34.418
5               0:23:42.087     0:06:07.700     28,289 kbps     34,617 kbps     00:26:25.875    33,135 kbps     00:26:32.590    33,057 kbps     00:26:26.251    147,484 bytes   496,230 bytes   00:26:36.803
6               0:29:49.788     0:05:44.260     28,534 kbps     34,493 kbps     00:32:25.109    33,166 kbps     00:32:21.064    32,696 kbps     00:32:20.563    148,765 bytes   449,699 bytes   00:33:53.239
7               0:35:34.048     0:05:43.217     27,693 kbps     34,851 kbps     00:38:34.854    33,105 kbps     00:38:45.156    32,646 kbps     00:38:41.402    144,381 bytes   421,096 bytes   00:36:45.286
8               0:41:17.266     0:06:51.285     28,189 kbps     34,877 kbps     00:46:16.857    33,150 kbps     00:42:35.344    32,987 kbps     00:42:30.339    146,967 bytes   488,482 bytes   00:42:28.462
9               0:48:08.552     0:07:10.805     29,614 kbps     34,177 kbps     00:48:19.187    32,944 kbps     00:54:38.108    32,801 kbps     00:54:33.645    154,396 bytes   364,677 bytes   00:48:20.147
10              0:55:19.357     0:04:09.290     29,604 kbps     35,098 kbps     00:58:43.937    33,297 kbps     00:58:39.933    32,936 kbps     00:58:36.679    154,340 bytes   478,122 bytes   00:58:42.977
11              0:59:28.648     0:06:41.567     27,241 kbps     33,327 kbps     01:01:01.866    32,874 kbps     01:00:39.677    32,651 kbps     01:00:39.218    142,022 bytes   425,807 bytes   00:59:56.175
12              1:06:10.216     0:06:25.343     27,038 kbps     36,432 kbps     01:11:47.469    33,226 kbps     01:11:47.928    33,044 kbps     01:06:12.051    140,962 bytes   432,274 bytes   01:12:13.120
13              1:12:35.559     0:05:17.317     27,804 kbps     34,611 kbps     01:17:49.790    33,207 kbps     01:16:10.691    32,965 kbps     01:16:05.769    144,958 bytes   488,025 bytes   01:16:08.939
14              1:17:52.876     0:07:13.599     28,449 kbps     34,930 kbps     01:18:09.935    33,148 kbps     01:18:16.566    33,013 kbps     01:18:11.728    148,320 bytes   416,345 bytes   01:18:21.488
15              1:25:06.476     0:04:17.340     19,997 kbps     27,536 kbps     01:29:20.772    20,533 kbps     01:25:19.030    20,338 kbps     01:25:18.947    104,272 bytes   404,888 bytes   01:26:11.166
STREAM DIAGNOSTICS:
00056.M2TS      4113 (0x1011)   0x1B            AVC                                     5363.650                27,995                  18,769,464,861  102,082,842
00056.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           5363.650                1,953                   1,309,651,442   9,761,569
00056.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5363.650                640                     429,107,200     2,514,300
00056.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5363.650                640                     429,107,200     2,514,300
00056.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5363.650                60                      40,320,402      228,667
Stephen Dawson
hifi-writer.com
post #1813 of 5106 Old 07-14-2010, 06:05 AM
Dear John - 2010 - Australian version
The stereo audio track is English Audio Descriptive.
Code:
        Total   Video
00020.MPLS                                                      AVC     1:47:39 23,643,420,672  38,112,690,303  29.28   25.00   Dolby TrueHD 5.1 1327Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     DEARJOHN
Disc Size:      38,112,690,303 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:47:39 (h:m:s)
Total Bitrate:          29.28 Mbps
VIDEO:
MPEG-4 AVC Video        24997 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1327 kbps       5.1 / 48 kHz / 1327 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             English         256 kbps        2.0 / 48 kHz / 256 kbps
SUBTITLES:
Presentation Graphics           English         49.098 kbps
FILES:
00038.M2TS      0:00:00.000     1:47:39.494     23,643,420,672  29,282
CHAPTERS:
1               0:00:00.000     0:05:15.023     25,610 kbps     33,903 kbps     00:03:34.839    32,934 kbps     00:01:43.394    31,798 kbps     00:01:38.681    133,502 bytes   479,076 bytes   00:05:15.023
2               0:05:15.023     0:07:14.851     22,866 kbps     35,028 kbps     00:05:16.816    32,133 kbps     00:05:15.732    29,202 kbps     00:05:15.023    119,214 bytes   501,705 bytes   00:05:16.024
3               0:12:29.874     0:05:24.449     24,698 kbps     32,814 kbps     00:13:03.657    30,513 kbps     00:13:00.196    28,369 kbps     00:13:31.894    128,764 bytes   403,042 bytes   00:13:03.824
4               0:17:54.323     0:06:57.959     25,993 kbps     34,412 kbps     00:18:08.003    33,129 kbps     00:23:24.236    32,866 kbps     00:22:16.209    135,517 bytes   491,969 bytes   00:22:33.018
5               0:24:52.282     0:04:51.124     24,562 kbps     34,037 kbps     00:28:51.646    31,752 kbps     00:24:52.282    30,378 kbps     00:29:30.351    128,053 bytes   350,861 bytes   00:25:26.608
6               0:29:43.406     0:05:56.022     24,534 kbps     34,061 kbps     00:34:23.311    31,248 kbps     00:30:01.382    30,373 kbps     00:34:16.929    127,907 bytes   443,115 bytes   00:34:45.416
7               0:35:39.428     0:05:15.398     26,001 kbps     35,082 kbps     00:38:46.699    33,272 kbps     00:36:45.077    33,041 kbps     00:36:45.077    135,557 bytes   450,419 bytes   00:36:50.082
8               0:40:54.827     0:05:04.637     24,620 kbps     34,388 kbps     00:45:57.463    33,015 kbps     00:45:53.459    32,852 kbps     00:45:36.358    128,358 bytes   441,573 bytes   00:42:28.879
9               0:45:59.465     0:05:35.585     26,168 kbps     34,290 kbps     00:48:45.297    33,141 kbps     00:48:41.293    32,855 kbps     00:48:36.288    136,429 bytes   455,388 bytes   00:49:39.559
10              0:51:35.050     0:05:16.065     23,988 kbps     34,424 kbps     00:51:44.851    30,361 kbps     00:51:41.848    28,695 kbps     00:51:36.927    125,062 bytes   480,590 bytes   00:51:36.051
11              0:56:51.116     0:03:46.893     23,302 kbps     32,405 kbps     01:00:36.633    31,922 kbps     01:00:26.789    31,775 kbps     01:00:27.498    121,484 bytes   449,662 bytes   01:00:35.798
12              1:00:38.009     0:05:34.792     26,131 kbps     34,719 kbps     01:04:46.632    33,082 kbps     01:06:06.212    32,748 kbps     01:04:46.424    136,236 bytes   438,605 bytes   01:04:47.633
13              1:06:12.802     0:09:00.248     29,462 kbps     35,828 kbps     01:15:10.380    33,141 kbps     01:07:25.249    32,990 kbps     01:07:20.244    153,603 bytes   354,208 bytes   01:07:29.295
14              1:15:13.050     0:06:33.518     25,299 kbps     31,949 kbps     01:15:13.425    29,964 kbps     01:15:54.591    29,524 kbps     01:15:49.670    131,896 bytes   288,224 bytes   01:20:27.364
15              1:21:46.568     0:06:17.668     25,107 kbps     34,036 kbps     01:21:58.413    32,942 kbps     01:22:13.428    32,824 kbps     01:22:10.675    130,895 bytes   403,152 bytes   01:23:26.376
16              1:28:04.237     0:10:23.456     24,781 kbps     34,012 kbps     01:28:19.168    33,097 kbps     01:28:15.081    32,957 kbps     01:28:10.076    129,197 bytes   429,974 bytes   01:30:48.985
17              1:38:27.693     0:03:31.878     25,953 kbps     34,554 kbps     01:39:42.559    33,108 kbps     01:39:55.197    32,980 kbps     01:39:50.067    135,306 bytes   410,909 bytes   01:39:42.601
18              1:41:59.571     0:05:39.922     18,514 kbps     23,474 kbps     01:43:04.011    21,300 kbps     01:43:02.843    20,712 kbps     01:43:02.843    96,534 bytes    358,156 bytes   01:46:26.546
STREAM DIAGNOSTICS:
00038.M2TS      4113 (0x1011)   0x1B            AVC                                     6459.328                24,998                  20,183,726,627  109,784,637
00038.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6459.328                1,967                   1,588,144,968   11,705,231
00038.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6459.328                256                     206,704,640     1,211,160
00038.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6459.328                49                      39,643,812      225,374
Stephen Dawson
hifi-writer.com
post #1814 of 5106 Old 07-14-2010, 05:47 PM
The New Daughter - 2009 - Australian version
Code:
        Total   Video
00021.MPLS                                                      AVC     1:47:47 21,528,324,096  22,274,077,228  26.63   21.99   Dolby TrueHD 5.1 1388Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     NEWDAUGHTER
Disc Size:      22,274,077,228 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:47:47 (h:m:s)
Total Bitrate:          26.63 Mbps
VIDEO:
MPEG-4 AVC Video        21992 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1388 kbps       5.1 / 48 kHz / 1388 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps)
SUBTITLES:
Presentation Graphics           English         31.175 kbps
FILES:
00047.M2TS      0:00:00.000     1:47:47.919     21,528,324,096  26,628
CHAPTERS:
1               0:00:00.000     0:05:44.886     23,544 kbps     34,699 kbps     00:01:10.153    33,165 kbps     00:01:09.319    32,991 kbps     00:01:06.608    122,732 bytes   471,324 bytes   00:01:24.959
2               0:05:44.886     0:06:12.163     21,146 kbps     27,674 kbps     00:09:57.179    26,140 kbps     00:07:43.838    25,427 kbps     00:07:43.838    110,245 bytes   256,848 bytes   00:07:57.852
3               0:11:57.049     0:06:31.474     25,684 kbps     34,591 kbps     00:17:25.085    33,041 kbps     00:18:18.138    32,945 kbps     00:17:13.699    133,904 bytes   529,134 bytes   00:15:05.863
4               0:18:28.524     0:04:34.190     21,314 kbps     33,177 kbps     00:20:59.383    31,825 kbps     00:20:55.379    30,068 kbps     00:20:55.379    111,121 bytes   400,069 bytes   00:21:00.259
5               0:23:02.714     0:08:04.859     24,816 kbps     33,091 kbps     00:25:45.168    29,808 kbps     00:24:47.027    29,594 kbps     00:24:48.487    129,382 bytes   428,422 bytes   00:26:00.475
6               0:31:07.574     0:04:50.248     20,668 kbps     30,802 kbps     00:34:01.330    28,292 kbps     00:33:57.702    25,115 kbps     00:33:52.613    107,752 bytes   405,833 bytes   00:34:01.456
7               0:35:57.822     0:05:39.714     23,958 kbps     31,919 kbps     00:37:37.421    30,219 kbps     00:37:33.417    29,325 kbps     00:37:29.121    124,905 bytes   468,103 bytes   00:37:36.462
8               0:41:37.536     0:05:23.698     20,427 kbps     26,349 kbps     00:42:31.215    24,721 kbps     00:42:00.309    24,392 kbps     00:42:22.748    106,495 bytes   319,533 bytes   00:45:55.711
9               0:47:01.235     0:06:39.232     21,759 kbps     33,626 kbps     00:49:48.318    32,770 kbps     00:49:45.691    27,886 kbps     00:49:45.691    113,444 bytes   332,552 bytes   00:53:26.703
10              0:53:40.467     0:05:48.681     24,212 kbps     30,485 kbps     00:58:38.890    29,951 kbps     00:58:34.886    29,506 kbps     00:58:33.301    126,228 bytes   371,390 bytes   00:53:45.013
11              0:59:29.148     0:06:28.930     18,246 kbps     24,503 kbps     01:01:45.284    22,151 kbps     01:02:41.424    21,439 kbps     01:02:37.420    95,124 bytes    263,208 bytes   00:59:33.152
12              1:05:58.079     0:06:38.773     18,904 kbps     27,786 kbps     01:06:48.462    25,643 kbps     01:06:45.835    22,886 kbps     01:06:59.223    98,558 bytes    367,519 bytes   01:10:34.355
13              1:12:36.852     0:05:13.021     22,077 kbps     37,152 kbps     01:15:41.870    33,383 kbps     01:15:51.213    32,987 kbps     01:15:46.208    115,100 bytes   437,456 bytes   01:16:33.880
14              1:17:49.873     0:05:55.605     23,294 kbps     33,754 kbps     01:20:18.688    31,497 kbps     01:20:45.882    29,533 kbps     01:19:59.836    121,444 bytes   392,779 bytes   01:21:12.868
15              1:23:45.478     0:06:25.176     23,844 kbps     31,373 kbps     01:27:42.840    30,778 kbps     01:27:39.003    29,589 kbps     01:27:34.707    124,313 bytes   267,918 bytes   01:23:56.281
16              1:30:10.655     0:05:04.512     23,169 kbps     34,066 kbps     01:34:44.804    29,899 kbps     01:34:44.470    28,015 kbps     01:34:40.174    120,791 bytes   255,779 bytes   01:34:41.133
17              1:35:15.167     0:07:05.383     21,035 kbps     30,091 kbps     01:41:08.312    27,461 kbps     01:40:17.594    26,947 kbps     01:36:06.927    109,664 bytes   248,893 bytes   01:40:09.378
18              1:42:20.551     0:05:27.368     16,574 kbps     20,842 kbps     01:47:36.616    18,158 kbps     01:46:18.497    17,664 kbps     01:47:11.550    86,420 bytes    338,529 bytes   01:46:53.907
STREAM DIAGNOSTICS:
00047.M2TS      4113 (0x1011)   0x1B            AVC                                     6467.753                21,992                  17,780,178,053  96,721,615
00047.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6467.753                2,028                   1,639,889,584   12,011,473
00047.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6467.753                640                     517,434,880     3,031,845
00047.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6467.753                31                      25,204,829      145,037
Stephen Dawson
hifi-writer.com
post #1815 of 5106 Old 07-14-2010, 07:05 PM
Double Identity (known in IMDB as Fake Identity) - 2010 - Australian version
Code:
        Total   Video
00020.MPLS                                                      AVC     1:32:53 20,245,653,504  20,668,600,781  29.06   24.99   Dolby TrueHD 5.1 1372Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     DOUBLEIDENTITY
Disc Size:      20,668,600,781 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:32:53 (h:m:s)
Total Bitrate:          29.06 Mbps
VIDEO:
MPEG-4 AVC Video        24991 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1372 kbps       5.1 / 48 kHz / 1372 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps)
Dolby Digital Audio             English         256 kbps        2.0 / 48 kHz / 256 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         28.368 kbps
FILES:
00034.M2TS      0:00:00.000     1:32:53.943     20,245,653,504  29,058
CHAPTERS:
1               0:00:00.000     0:05:26.159     21,778 kbps     33,522 kbps     00:03:23.203    32,584 kbps     00:03:20.533    30,711 kbps     00:01:29.631    113,525 bytes   281,429 bytes   00:01:03.772
2               0:05:26.159     0:06:08.326     26,455 kbps     33,517 kbps     00:08:36.766    32,088 kbps     00:08:32.762    30,349 kbps     00:08:42.563    137,923 bytes   318,124 bytes   00:08:51.280
3               0:11:34.485     0:03:31.377     23,018 kbps     31,859 kbps     00:14:15.980    30,691 kbps     00:14:01.757    28,095 kbps     00:14:00.214    120,003 bytes   231,856 bytes   00:13:53.165
4               0:15:05.863     0:05:50.016     24,890 kbps     33,960 kbps     00:19:36.300    31,808 kbps     00:19:19.199    31,210 kbps     00:19:53.734    129,765 bytes   287,070 bytes   00:17:13.532
5               0:20:55.879     0:05:50.933     27,308 kbps     33,703 kbps     00:22:45.405    32,910 kbps     00:24:14.035    32,784 kbps     00:24:10.365    142,371 bytes   387,965 bytes   00:26:46.771
6               0:26:46.813     0:06:30.556     28,774 kbps     34,239 kbps     00:27:12.797    32,928 kbps     00:31:46.696    32,781 kbps     00:31:46.195    150,014 bytes   373,706 bytes   00:27:12.839
7               0:33:17.370     0:05:28.870     27,214 kbps     33,979 kbps     00:38:45.239    32,928 kbps     00:37:59.151    32,474 kbps     00:37:54.480    141,883 bytes   323,041 bytes   00:37:12.188
8               0:38:46.240     0:05:36.336     24,364 kbps     33,661 kbps     00:38:54.248    32,963 kbps     00:38:50.327    31,965 kbps     00:38:46.240    127,020 bytes   332,582 bytes   00:43:49.960
9               0:44:22.576     0:07:01.212     24,458 kbps     34,983 kbps     00:46:09.183    32,901 kbps     00:44:25.704    31,165 kbps     00:48:42.544    127,514 bytes   320,811 bytes   00:47:13.080
10              0:51:23.789     0:04:04.661     23,194 kbps     31,554 kbps     00:54:40.902    28,707 kbps     00:51:49.606    27,682 kbps     00:51:49.606    120,923 bytes   229,960 bytes   00:54:26.596
11              0:55:28.450     0:06:10.953     24,471 kbps     30,830 kbps     00:58:01.227    29,545 kbps     00:57:51.551    28,807 kbps     00:57:52.427    127,580 bytes   282,004 bytes   01:01:26.182
12              1:01:39.404     0:06:06.616     25,692 kbps     33,487 kbps     01:07:22.997    31,895 kbps     01:07:32.715    30,393 kbps     01:07:28.878    133,947 bytes   512,269 bytes   01:07:45.603
13              1:07:46.020     0:05:45.178     26,549 kbps     33,512 kbps     01:12:38.437    32,596 kbps     01:11:05.094    32,183 kbps     01:13:16.141    138,415 bytes   348,647 bytes   01:12:55.954
14              1:13:31.198     0:07:30.575     25,046 kbps     33,923 kbps     01:13:34.493    32,217 kbps     01:18:24.324    32,078 kbps     01:18:21.321    130,579 bytes   331,501 bytes   01:16:29.835
15              1:21:01.773     0:06:07.283     27,592 kbps     33,607 kbps     01:21:03.900    32,941 kbps     01:21:55.827    32,862 kbps     01:23:37.345    143,854 bytes   334,888 bytes   01:22:31.279
16              1:27:09.057     0:05:44.886     16,963 kbps     26,115 kbps     01:32:40.930    24,354 kbps     01:27:09.057    21,315 kbps     01:27:09.057    88,446 bytes    362,433 bytes   01:28:46.279
STREAM DIAGNOSTICS:
00034.M2TS      4113 (0x1011)   0x1B            AVC                                     5573.777                24,991                  17,412,126,751  94,709,125
00034.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           5573.777                1,820                   1,267,764,478   9,392,737
00034.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5573.777                256                     178,366,464     1,045,116
00034.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5573.777                28                      19,765,053      112,379
Stephen Dawson
hifi-writer.com
post #1816 of 5106 Old 07-16-2010, 04:45 PM - Thread Starter
[US] Le Mépris (Contempt) (Additional Details)
Region Locked (AB) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Lionsgate
UPC: 012236107811
Code:
        Total   Video
[US] Le Mépris (Contempt)                                       AVC     1:43:15 29,169,106,944  47,153,693,752  37.67   31.59   DTS-HD Master 2.0 933Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LE_MEPRIS
Disc Size:      47,153,693,752 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:43:15 (h:m:s)
Total Bitrate:          37.67 Mbps
VIDEO:
MPEG-4 AVC Video        31589 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             French          933 kbps        2.0 / 48 kHz / 933 kbps / 16-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 16-bit)
DTS-HD Master Audio             English         857 kbps        2.0 / 48 kHz / 857 kbps / 16-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 16-bit)
DTS-HD Master Audio             German          844 kbps        2.0 / 48 kHz / 844 kbps / 16-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 16-bit)
DTS-HD Master Audio             Spanish         1015 kbps       2.0 / 48 kHz / 1015 kbps / 16-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         18.631 kbps
Presentation Graphics           English         0.362 kbps
Presentation Graphics           Danish          23.506 kbps
Presentation Graphics           Dutch           20.445 kbps
Presentation Graphics           Finnish         21.082 kbps
Presentation Graphics           German          24.610 kbps
Presentation Graphics           German          2.839 kbps
Presentation Graphics           Japanese        15.630 kbps
Presentation Graphics           Norwegian       20.063 kbps
Presentation Graphics           Spanish         20.352 kbps
Presentation Graphics           Spanish         22.561 kbps
Presentation Graphics           Swedish         19.768 kbps
FILES:
00000.M2TS      0:00:00.000     1:43:15.416     29,169,106,944  37,665
CHAPTERS:
1               0:00:00.000     0:09:57.458     31,303 kbps     40,004 kbps     00:05:14.125    35,101 kbps     00:05:44.875    34,478 kbps     00:07:39.583    163,024 bytes   531,696 bytes   00:09:57.458
2               0:09:57.458     0:11:18.500     33,512 kbps     44,547 kbps     00:14:35.250    40,048 kbps     00:16:10.916    39,537 kbps     00:16:05.833    174,540 bytes   591,847 bytes   00:09:59.083
3               0:21:15.958     0:07:19.875     32,815 kbps     40,293 kbps     00:24:10.583    35,993 kbps     00:25:17.250    35,294 kbps     00:25:17.250    170,911 bytes   537,935 bytes   00:25:48.750
4               0:28:35.833     0:09:01.583     32,142 kbps     44,603 kbps     00:35:07.833    38,316 kbps     00:35:07.083    36,206 kbps     00:35:07.000    167,404 bytes   592,424 bytes   00:33:05.291
5               0:37:37.416     0:07:42.916     29,475 kbps     37,331 kbps     00:45:14.208    33,051 kbps     00:38:22.625    32,702 kbps     00:37:47.375    153,518 bytes   384,244 bytes   00:40:12.291
6               0:45:20.333     0:07:08.500     29,616 kbps     37,355 kbps     00:51:50.791    32,141 kbps     00:47:18.291    31,937 kbps     00:47:38.708    154,250 bytes   396,198 bytes   00:50:40.500
7               0:52:28.833     0:08:21.458     31,900 kbps     38,295 kbps     00:57:46.791    34,338 kbps     00:57:46.791    33,461 kbps     00:57:46.791    166,144 bytes   453,514 bytes   00:56:49.875
8               1:00:50.291     0:08:26.916     29,444 kbps     44,457 kbps     01:08:03.041    34,121 kbps     01:08:25.541    33,702 kbps     01:08:20.750    153,353 bytes   421,656 bytes   01:08:03.083
9               1:09:17.208     0:09:54.458     32,834 kbps     39,604 kbps     01:12:30.625    35,576 kbps     01:14:14.041    35,057 kbps     01:14:11.458    171,009 bytes   519,768 bytes   01:19:11.666
10              1:19:11.666     0:10:56.916     31,533 kbps     37,401 kbps     01:22:43.833    35,645 kbps     01:19:34.958    34,753 kbps     01:19:34.500    164,237 bytes   605,318 bytes   01:21:15.666
11              1:30:08.583     0:06:49.208     32,227 kbps     39,018 kbps     01:33:51.833    35,345 kbps     01:30:41.791    34,922 kbps     01:30:40.166    167,848 bytes   501,091 bytes   01:34:59.666
12              1:36:57.791     0:06:17.625     31,115 kbps     42,117 kbps     01:39:02.458    35,443 kbps     01:39:02.458    34,171 kbps     01:38:47.208    162,093 bytes   436,039 bytes   01:38:34.750
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6195.333                31,590                  24,463,640,314  133,041,899
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6195.333                857                     663,838,160     4,161,407
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       fra (French)            6195.333                933                     722,240,076     4,623,822
00000.M2TS      4354 (0x1102)   0x86            DTS-HD MA       deu (German)            6195.333                844                     653,363,776     4,162,314
00000.M2TS      4355 (0x1103)   0x86            DTS-HD MA       spa (Spanish)           6195.333                1,015                   786,325,944     4,781,191
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6195.333                19                      14,428,653      83,649
00000.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            6195.333                25                      19,058,489      110,031
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6195.333                20                      15,760,754      91,172
00000.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6195.333                23                      17,471,658      101,349
00000.M2TS      4612 (0x1204)   0x90            PGS             nld (Dutch)             6195.333                20                      15,833,369      91,536
00000.M2TS      4613 (0x1205)   0x90            PGS             dan (Danish)            6195.333                24                      18,203,568      106,657
00000.M2TS      4614 (0x1206)   0x90            PGS             nor (Norwegian)         6195.333                20                      15,537,636      90,327
00000.M2TS      4615 (0x1207)   0x90            PGS             fin (Finnish)           6195.333                21                      16,326,804      94,536
00000.M2TS      4616 (0x1208)   0x90            PGS             swe (Swedish)           6195.333                20                      15,308,544      88,440
00000.M2TS      4617 (0x1209)   0x90            PGS             jpn (Japanese)          6195.333                16                      12,104,135      72,211
00000.M2TS      4618 (0x120A)   0x90            PGS             eng (English)           6195.333                0                       280,028         1,645
00000.M2TS      4619 (0x120B)   0x90            PGS             deu (German)            6195.333                3                       2,198,876       12,659
post #1817 of 5106 Old 07-16-2010, 04:49 PM - Thread Starter
[US] Pirate Radio (Additional Details)
a.k.a. The Boat That Rocked / Radio Rock Revolution / Good Morning England
Studio: Universal
UPC: 025195052351
Release Date: 2010-04-13
Code:
        Total   Video
[US] Pirate Radio                                               VC-1    1:56:38 32,914,452,480  46,230,822,226  37.63   30.15   DTS-HD Master 5.1 3601Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     PIRATE_RADIO
Disc Size:      46,230,822,226 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:56:38 (h:m:s)
Total Bitrate:          37.63 Mbps
VIDEO:
VC-1 Video              30149 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3601 kbps       5.1 / 48 kHz / 3601 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         43.999 kbps
Presentation Graphics           French          36.917 kbps
Presentation Graphics           French          0.879 kbps
Presentation Graphics           Spanish         32.550 kbps
Presentation Graphics           Spanish         0.450 kbps
FILES:
00010.M2TS      0:00:00.000     1:56:38.199     32,914,452,480  37,626
CHAPTERS:
1               0:00:00.000     0:06:58.209     29,663 kbps     52,441 kbps     00:00:31.031    36,827 kbps     00:03:40.094    35,503 kbps     00:03:39.761    155,082 bytes   670,774 bytes   00:04:38.444
2               0:06:58.209     0:06:10.286     31,349 kbps     42,468 kbps     00:07:36.622    35,932 kbps     00:07:04.966    34,417 kbps     00:07:00.169    163,437 bytes   662,579 bytes   00:08:26.839
3               0:13:08.496     0:04:40.530     31,432 kbps     45,102 kbps     00:13:38.442    37,852 kbps     00:15:39.146    34,950 kbps     00:16:25.943    163,870 bytes   607,123 bytes   00:17:17.953
4               0:17:49.026     0:06:11.537     31,483 kbps     42,215 kbps     00:18:06.960    36,512 kbps     00:23:48.552    34,792 kbps     00:21:10.769    164,135 bytes   527,917 bytes   00:22:53.038
5               0:24:00.564     0:05:11.185     31,899 kbps     47,739 kbps     00:24:00.981    36,344 kbps     00:27:13.673    35,230 kbps     00:24:18.165    166,307 bytes   717,728 bytes   00:25:12.761
6               0:29:11.750     0:08:46.943     31,226 kbps     45,695 kbps     00:31:30.221    37,142 kbps     00:36:53.794    36,229 kbps     00:33:41.352    162,800 bytes   625,820 bytes   00:32:26.694
7               0:37:58.693     0:04:21.886     30,888 kbps     46,438 kbps     00:41:58.098    37,482 kbps     00:40:02.900    36,195 kbps     00:40:02.983    161,034 bytes   531,099 bytes   00:39:07.011
8               0:42:20.579     0:04:26.140     31,392 kbps     42,409 kbps     00:44:03.515    36,207 kbps     00:44:27.623    35,274 kbps     00:44:27.623    163,664 bytes   675,611 bytes   00:43:34.486
9               0:46:46.720     0:03:19.782     31,962 kbps     46,038 kbps     00:47:27.052    37,452 kbps     00:47:23.131    35,746 kbps     00:47:36.311    166,635 bytes   801,721 bytes   00:48:25.652
10              0:50:06.503     0:04:24.055     32,050 kbps     42,289 kbps     00:52:15.715    37,969 kbps     00:52:15.298    36,148 kbps     00:50:51.673    167,095 bytes   491,260 bytes   00:54:19.547
11              0:54:30.558     0:06:10.661     31,118 kbps     46,996 kbps     00:59:22.684    35,326 kbps     00:56:20.043    33,582 kbps     00:56:20.877    162,237 bytes   815,700 bytes   00:56:52.826
12              1:00:41.220     0:04:56.129     31,473 kbps     49,872 kbps     01:01:21.552    36,226 kbps     01:03:46.656    34,976 kbps     01:01:27.975    164,084 bytes   625,559 bytes   01:00:46.267
13              1:05:37.350     0:04:26.641     31,991 kbps     46,414 kbps     01:09:59.737    36,129 kbps     01:07:48.355    35,941 kbps     01:07:42.475    166,784 bytes   660,068 bytes   01:09:52.563
14              1:10:03.991     0:07:58.728     31,215 kbps     42,337 kbps     01:10:48.035    35,822 kbps     01:16:07.771    34,333 kbps     01:16:00.138    162,739 bytes   717,530 bytes   01:15:20.182
15              1:18:02.719     0:05:35.877     32,167 kbps     45,402 kbps     01:21:04.192    37,164 kbps     01:19:44.488    35,360 kbps     01:19:42.903    167,704 bytes   606,923 bytes   01:21:04.276
16              1:23:38.596     0:06:09.911     31,053 kbps     47,836 kbps     01:24:36.112    37,442 kbps     01:24:41.326    36,493 kbps     01:24:36.196    161,896 bytes   660,547 bytes   01:27:31.996
17              1:29:48.508     0:07:17.937     31,684 kbps     47,425 kbps     01:33:40.781    36,478 kbps     01:32:46.894    35,465 kbps     01:32:46.894    165,184 bytes   725,739 bytes   01:33:54.462
18              1:37:06.445     0:05:11.394     31,003 kbps     44,938 kbps     01:40:03.914    35,301 kbps     01:39:09.193    33,427 kbps     01:40:03.914    161,635 bytes   724,893 bytes   01:37:12.451
19              1:42:17.840     0:06:35.061     32,162 kbps     49,643 kbps     01:43:38.962    37,759 kbps     01:48:40.013    35,091 kbps     01:48:34.925    167,677 bytes   658,323 bytes   01:47:52.215
20              1:48:52.901     0:07:45.298     12,757 kbps     49,155 kbps     01:50:20.905    36,931 kbps     01:50:31.416    36,161 kbps     01:49:24.182    67,154 bytes    837,107 bytes   01:50:44.638
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    6998.074                30,150                  26,373,892,165  143,437,864
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6998.074                3,601                   3,149,689,968   18,210,988
00010.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           6998.074                768                     671,827,968     3,936,492
00010.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            6998.074                768                     671,827,968     3,936,492
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6998.074                192                     167,956,992     1,093,470
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6998.074                44                      38,489,418      221,449
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6998.074                33                      28,473,579      165,390
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6998.074                37                      32,293,798      186,185
00010.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6998.074                0                       393,690         2,247
00010.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6998.074                1                       768,664         4,379
Cinema Squid is offline
post #1818 of 5106 Old 07-16-2010, 04:53 PM - Thread Starter
Cinema Squid's Avatar
[US] The New Daughter (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Anchor Bay / Starz
UPC: 013132165998
Release Date: 2010-05-18
Aspect Ratio: 2.35:1
Clearly different in several respects from the Australian version recently posted by Stephen.
Both the LPCM and DD 5.1 are main audio, while the DD 2.0 is a commentary.
Code:
        Total   Video
[US] The New Daughter                                           VC-1    1:47:59 21,547,905,024  24,066,877,882  26.60   19.97   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     THE_NEW_DAUGHTER
Disc Size:      24,066,877,882 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:47:59 (h:m:s)
Total Bitrate:          26.60 Mbps
VIDEO:
VC-1 Video              19966 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         29.441 kbps
Presentation Graphics           Spanish         26.226 kbps
FILES:
00015.M2TS      0:00:00.000     1:47:59.556     21,547,905,024  26,604
CHAPTERS:
1               0:00:00.000     0:04:16.005     23,061 kbps     46,375 kbps     00:01:37.764    38,250 kbps     00:01:02.604    37,225 kbps     00:01:01.436    120,210 bytes   786,375 bytes   00:01:55.573
2               0:04:16.005     0:09:49.171     18,036 kbps     36,470 kbps     00:09:35.491    30,342 kbps     00:13:22.551    29,703 kbps     00:13:20.424    94,031 bytes    662,583 bytes   00:13:50.454
3               0:14:05.177     0:06:33.768     22,574 kbps     49,351 kbps     00:17:49.818    39,418 kbps     00:14:24.071    38,235 kbps     00:18:29.233    117,693 bytes   826,665 bytes   00:14:40.963
4               0:20:38.946     0:06:46.697     22,945 kbps     41,319 kbps     00:25:56.263    38,086 kbps     00:21:07.307    36,505 kbps     00:21:06.390    119,627 bytes   745,299 bytes   00:21:06.431
5               0:27:25.644     0:06:43.820     21,966 kbps     38,564 kbps     00:30:36.584    36,220 kbps     00:29:49.287    35,242 kbps     00:29:48.286    114,523 bytes   739,585 bytes   00:27:57.842
6               0:34:09.464     0:11:12.505     17,438 kbps     39,709 kbps     00:34:10.673    36,951 kbps     00:37:42.843    33,783 kbps     00:37:40.007    90,912 bytes    644,742 bytes   00:39:10.806
7               0:45:21.969     0:13:23.177     18,390 kbps     40,418 kbps     00:57:21.604    36,626 kbps     00:57:21.563    34,641 kbps     00:57:21.521    95,875 bytes    655,388 bytes   00:49:49.486
8               0:58:45.146     0:07:23.943     19,492 kbps     42,640 kbps     01:01:56.379    31,373 kbps     01:05:53.699    30,367 kbps     01:05:50.363    101,622 bytes   555,794 bytes   01:03:01.903
9               1:06:09.090     0:17:47.399     19,034 kbps     47,766 kbps     01:16:28.166    39,833 kbps     01:20:56.893    37,608 kbps     01:16:45.517    99,233 bytes    905,747 bytes   01:15:51.338
10              1:23:56.489     0:08:56.285     21,813 kbps     41,422 kbps     01:27:40.546    32,788 kbps     01:27:03.885    31,853 kbps     01:27:00.423    113,723 bytes   717,128 bytes   01:25:46.724
11              1:32:52.775     0:09:36.492     25,904 kbps     49,540 kbps     01:37:10.449    38,330 kbps     01:37:35.933    37,885 kbps     01:37:30.845    135,051 bytes   830,548 bytes   01:39:41.058
12              1:42:29.268     0:05:30.288     11,052 kbps     16,042 kbps     01:47:37.617    15,217 kbps     01:47:35.115    13,901 kbps     01:47:31.445    57,627 bytes    398,319 bytes   01:43:13.312
STREAM DIAGNOSTICS:
00015.M2TS      4113 (0x1011)   0xEA            VC-1                                    6479.431                19,966                  16,171,250,897  87,980,879
00015.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6479.431                448                     362,856,704     2,024,870
00015.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6479.431                4,614                   3,737,410,208   20,734,592
00015.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6479.431                192                     155,510,016     1,012,435
00015.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6479.431                29                      23,845,185      136,910
00015.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6479.431                26                      21,241,421      121,903
post #1819 of 5106 Old 07-16-2010, 05:01 PM - Thread Starter
[US] The White Ribbon (Das weisse Band) (Additional Details)
Studio: Sony
UPC: 043396352162
Release Date: 2010-06-29
Aspect Ratio: 1.85:1
The English audio track is apparently not a full dub, but rather English narration with German dialog (haven't listened to it yet). Surprisingly for Sony, there is no BD-Java or BD-Live stuff on the disc. They did still manage to include 8 previews for other titles, however.
Code:
        Total   Video
[US] The White Ribbon                                           AVC     2:23:55 36,468,346,752  48,420,890,507  33.78   26.90   DTS-HD Master 5.1 2783Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     WHITE_RIBBON
Disc Size:      48,420,890,507 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 2:23:55 (h:m:s)
Total Bitrate:          33.78 Mbps
VIDEO:
MPEG-4 AVC Video        26898 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             German          2783 kbps       5.1 / 48 kHz / 2783 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         2077 kbps       5.1 / 48 kHz / 2077 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         18.207 kbps
Presentation Graphics           English         13.196 kbps
Presentation Graphics           English         13.905 kbps
FILES:
00011.M2TS      0:00:00.000     2:23:55.627     36,468,346,752  33,784
CHAPTERS:
1               0:00:00.000     0:18:17.679     26,883 kbps     42,773 kbps     00:00:02.001    31,191 kbps     00:02:37.824    30,550 kbps     00:02:32.819    140,149 bytes   752,202 bytes   00:15:43.776
2               0:18:17.679     0:12:03.097     27,068 kbps     36,995 kbps     00:18:25.979    30,336 kbps     00:18:22.559    28,978 kbps     00:18:18.388    141,122 bytes   722,272 bytes   00:21:23.657
3               0:30:20.777     0:07:26.654     28,056 kbps     37,486 kbps     00:37:41.133    32,611 kbps     00:34:53.925    30,168 kbps     00:34:48.920    146,269 bytes   760,799 bytes   00:37:07.183
4               0:37:47.431     0:15:35.768     26,454 kbps     44,371 kbps     00:43:04.039    29,484 kbps     00:52:36.153    28,845 kbps     00:43:12.548    137,920 bytes   750,784 bytes   00:43:04.248
5               0:53:23.200     0:14:56.228     27,060 kbps     39,977 kbps     01:03:15.082    30,020 kbps     01:03:15.166    29,106 kbps     00:53:26.453    141,078 bytes   717,645 bytes   01:08:19.428
6               1:08:19.428     0:19:02.015     26,470 kbps     34,156 kbps     01:16:29.793    29,963 kbps     01:17:44.785    28,855 kbps     01:17:43.200    138,000 bytes   758,433 bytes   01:26:10.373
7               1:27:21.444     0:14:09.181     26,786 kbps     35,497 kbps     01:35:00.528    29,886 kbps     01:27:48.221    28,807 kbps     01:27:50.890    139,650 bytes   631,560 bytes   01:27:58.231
8               1:41:30.626     0:23:25.487     27,239 kbps     41,228 kbps     01:52:33.621    31,030 kbps     01:52:31.077    30,253 kbps     01:46:46.733    142,014 bytes   768,240 bytes   01:41:41.428
9               2:04:56.113     0:18:59.513     26,682 kbps     38,106 kbps     02:23:45.533    30,602 kbps     02:05:00.201    29,575 kbps     02:07:02.156    139,117 bytes   623,287 bytes   02:22:52.188
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     8635.544                26,899                  29,035,454,686  157,923,184
00011.M2TS      4352 (0x1100)   0x86            DTS-HD MA       deu (German)            8635.544                2,783                   3,004,566,680   17,675,171
00011.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           8635.544                2,077                   2,242,438,472   13,756,627
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8635.544                18                      19,653,405      116,335
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8635.544                13                      14,244,338      88,920
00011.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           8635.544                14                      15,010,109      89,603
post #1820 of 5106 Old 07-17-2010, 04:44 PM
svenge's Avatar
Disc is Region-A locked. No extras were included on disc.
DISC INFO:
Disc Title: EVANGELION 222
Disc Size: 24,463,907,378 bytes
Protection: AACS
BD-Java: No
BDInfo: 0.5.1
PLAYLIST REPORT:
Length: 1:52:09 (h:m:s)
Total Bitrate: 28.65 Mbps
Description:
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 19998 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio Japanese 2668 kbps 6.1 / 48 kHz / 2668 kbps / 16-bit (DTS Core: 6.1-ES / 48 kHz / 1509 kbps / 16-bit)
Dolby TrueHD Audio Japanese 2121 kbps 6.1 / 48 kHz / 2121 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio Chinese 192 kbps 2.0 / 48 kHz / 192 kbps
Dolby Digital Audio Japanese 192 kbps 2.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics English 40.889 kbps
Presentation Graphics Chinese 42.718 kbps
svenge is offline
post #1821 of 5106 Old 07-17-2010, 09:04 PM
ktm911's Avatar
List of USA titles that have TrueHD included. Ordered by TrueHD titles and audio quality. MA and LPCM titles that also include TrueHD tracks are dropped on bottom.
Open archive with winrar or winzip to extract or use 'right click'/'open with' from within archive to open csv file with Scalc (Open Office) or other spreadsheet program.
Blueray-TrueHD US.zip 38.8193359375k . file
ktm911 is offline
post #1822 of 5106 Old 07-18-2010, 01:51 AM
ktm911's Avatar
https://www.avsforum.com/avs-vb/showp...&postcount=166
I didn't notice this US version of Watchman Directors cut listed in main txt download. Anyone got a reason why this title shows up as DTS-HD on my players menu when it lists as DTS-MA on above link? DTS-HD aka DTS-HR would be a whole other track rather than dts-ma and it's core wouldn't it or is what I seeing really just how the player lists it after a core extraction? Player is the funky dmp-bd10a which only decodes trueHD and but doesn't send either MA or TrueHD undecoded via bitstream.
ktm911 is offline
post #1823 of 5106 Old 07-18-2010, 12:51 PM
svenge's Avatar
House of Flying Daggers (TW)
Region-ABC Coded
DISC INFO:
Disc Title: HOUSE OF FLYING DAGGERS
Disc Size: 22,545,924,804 bytes
Protection: AACS
BD-Java: No
BDInfo: 0.5.1
PLAYLIST REPORT:
Length: 1:59:17 (h:m:s)
Total Bitrate: 23.78 Mbps
Description:
VIDEO:
MPEG-4 AVC Video 20000 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio Chinese 2047 kbps 5.1 / 48 kHz / 2047 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio Chinese 384 kbps 2.0 / 48 kHz / 384 kbps
SUBTITLES:
Presentation Graphics English 15.550 kbps
Presentation Graphics Chinese 13.980 kbps
svenge is offline
post #1824 of 5106 Old 07-20-2010, 06:25 PM - Thread Starter
[US] The Illusionist (Additional Details)
Studio: Fox
UPC: 024543686873
Release Date: 2010-06-08
Aspect Ratio: 1.78:1
The English DD 5.1 is an alternate main audio track. Presumably identical to the Alliance Canada version.
Code:
        Total   Video
[US] The Illusionist                                            AVC     1:48:56 21,208,160,256  21,442,525,640  25.96   19.96   DTS-HD Master 5.1 3698Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     THE_ILLUSIONIST
Disc Size:      21,442,525,640 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:48:56 (h:m:s)
Total Bitrate:          25.96 Mbps
VIDEO:
MPEG-4 AVC Video        19958 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3698 kbps       5.1 / 48 kHz / 3698 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
FILES:
00889.M2TS      0:00:00.000     1:48:56.613     21,208,160,256  25,956
CHAPTERS:
1               0:00:00.000     0:06:18.169     13,318 kbps     41,998 kbps     00:06:11.579    35,796 kbps     00:06:09.577    31,958 kbps     00:06:04.614    69,425 bytes    329,448 bytes   00:06:10.453
2               0:06:18.169     0:06:46.989     20,097 kbps     42,147 kbps     00:09:11.676    32,565 kbps     00:09:08.089    30,131 kbps     00:09:04.043    104,775 bytes   368,953 bytes   00:07:13.599
3               0:13:05.159     0:06:02.487     22,553 kbps     37,717 kbps     00:13:55.793    30,911 kbps     00:17:50.778    26,909 kbps     00:17:43.729    117,581 bytes   370,162 bytes   00:15:45.361
4               0:19:07.646     0:05:54.479     20,487 kbps     33,872 kbps     00:21:55.147    26,646 kbps     00:23:25.695    25,064 kbps     00:22:40.442    106,812 bytes   360,744 bytes   00:19:13.652
5               0:25:02.125     0:03:52.982     21,398 kbps     35,149 kbps     00:26:43.310    29,111 kbps     00:26:39.681    25,069 kbps     00:26:38.972    111,559 bytes   364,130 bytes   00:25:25.815
6               0:28:55.108     0:03:56.736     19,803 kbps     36,987 kbps     00:30:20.527    33,329 kbps     00:30:18.358    30,655 kbps     00:30:14.562    103,244 bytes   329,442 bytes   00:30:53.518
7               0:32:51.844     0:04:48.037     20,570 kbps     32,543 kbps     00:33:27.547    26,457 kbps     00:34:24.937    23,970 kbps     00:34:19.974    107,245 bytes   346,345 bytes   00:34:27.064
8               0:37:39.882     0:07:11.347     21,774 kbps     38,574 kbps     00:43:02.162    30,082 kbps     00:42:45.479    28,034 kbps     00:42:45.980    113,520 bytes   367,231 bytes   00:39:07.678
9               0:44:51.230     0:06:19.462     20,306 kbps     35,930 kbps     00:48:56.558    32,694 kbps     00:48:56.475    30,362 kbps     00:48:54.473    105,867 bytes   317,795 bytes   00:50:44.750
10              0:51:10.692     0:06:26.135     20,277 kbps     38,501 kbps     00:51:20.452    27,220 kbps     00:51:48.688    26,319 kbps     00:51:42.390    105,713 bytes   344,023 bytes   00:53:31.583
11              0:57:36.828     0:06:05.073     23,774 kbps     44,396 kbps     00:59:17.220    40,155 kbps     01:02:14.814    36,234 kbps     00:58:03.021    123,947 bytes   355,180 bytes   01:03:17.210
12              1:03:41.901     0:05:52.352     20,890 kbps     39,154 kbps     01:05:44.607    36,022 kbps     01:05:40.645    27,809 kbps     01:05:41.020    108,913 bytes   389,558 bytes   01:04:29.365
13              1:09:34.253     0:06:38.106     18,439 kbps     37,470 kbps     01:09:36.338    27,647 kbps     01:14:04.481    23,543 kbps     01:15:41.119    96,132 bytes    350,241 bytes   01:14:47.149
14              1:16:12.359     0:06:20.213     19,333 kbps     36,270 kbps     01:22:13.511    31,825 kbps     01:22:09.507    28,341 kbps     01:22:09.090    100,795 bytes   349,552 bytes   01:17:44.326
15              1:22:32.572     0:03:16.195     19,291 kbps     25,687 kbps     01:25:46.808    23,241 kbps     01:23:34.801    22,657 kbps     01:23:31.715    100,573 bytes   340,264 bytes   01:25:47.767
16              1:25:48.768     0:03:18.698     20,702 kbps     35,156 kbps     01:26:53.791    29,284 kbps     01:26:50.413    28,028 kbps     01:26:45.909    107,930 bytes   324,222 bytes   01:25:49.769
17              1:29:07.467     0:03:51.814     20,798 kbps     36,469 kbps     01:29:12.555    30,858 kbps     01:29:40.166    28,137 kbps     01:29:40.166    108,431 bytes   380,463 bytes   01:32:00.723
18              1:32:59.282     0:03:49.229     18,840 kbps     27,303 kbps     01:35:39.984    24,149 kbps     01:33:51.626    23,414 kbps     01:33:51.459    98,223 bytes    329,803 bytes   01:34:15.441
19              1:36:48.511     0:03:28.666     24,016 kbps     38,703 kbps     01:40:07.167    37,026 kbps     01:40:06.917    35,288 kbps     01:40:06.917    125,211 bytes   345,329 bytes   01:38:38.746
20              1:40:17.177     0:04:05.787     23,141 kbps     41,485 kbps     01:43:17.941    36,290 kbps     01:40:19.513    34,531 kbps     01:40:19.304    120,646 bytes   350,510 bytes   01:42:05.619
21              1:44:22.965     0:04:33.648     10,260 kbps     15,409 kbps     01:44:39.898    14,885 kbps     01:44:38.522    14,526 kbps     01:44:37.938    53,501 bytes    192,886 bytes   01:46:17.079
STREAM DIAGNOSTICS:
00889.M2TS      4113 (0x1011)   0x1B            AVC                                     6536.488                19,958                  16,306,896,722  88,715,853
00889.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6536.488                3,698                   3,021,228,328   17,438,901
00889.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6536.488                448                     366,051,840     2,042,700
00889.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6536.488                448                     366,051,840     2,042,700
post #1825 of 5106 Old 07-20-2010, 06:28 PM - Thread Starter
[US] Red Desert (Il Deserto rosso) (Additional Details)
Studio: Criterion
UPC: 715515058216
Release Date: 2010-06-22
English DD 1.0 is a commentary.
Code:
        Total   Video
[US] Red Desert                                                 AVC     1:57:19 34,787,149,824  48,100,320,581  39.54   35.21   LPCM 1.0 1152Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     RED_DESERT
Disc Size:      48,100,320,581 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:57:19 (h:m:s)
Total Bitrate:          39.54 Mbps
VIDEO:
MPEG-4 AVC Video        35213 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      Italian         1152 kbps       1.0 / 48 kHz / 1152 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           English         19.732 kbps
FILES:
00274.M2TS      0:00:00.000     1:57:19.073     34,787,149,824  39,536
CHAPTERS:
1               0:00:00.000     0:08:45.691     34,260 kbps     38,691 kbps     00:02:46.332    37,156 kbps     00:03:52.106    36,991 kbps     00:03:47.101    178,601 bytes   310,317 bytes   00:06:51.786
2               0:08:45.691     0:06:43.778     32,868 kbps     37,587 kbps     00:14:19.483    36,972 kbps     00:14:37.251    36,885 kbps     00:14:32.246    171,357 bytes   329,082 bytes   00:09:40.413
3               0:15:29.470     0:04:19.217     30,501 kbps     37,101 kbps     00:19:03.600    36,411 kbps     00:19:02.266    36,217 kbps     00:18:58.804    159,018 bytes   280,321 bytes   00:19:48.687
4               0:19:48.687     0:07:50.720     35,669 kbps     38,135 kbps     00:26:35.302    37,052 kbps     00:26:34.134    36,928 kbps     00:26:29.087    185,963 bytes   323,984 bytes   00:20:31.188
5               0:27:39.407     0:07:02.296     35,952 kbps     37,831 kbps     00:31:18.334    36,988 kbps     00:30:53.518    36,895 kbps     00:30:23.279    187,435 bytes   288,877 bytes   00:28:32.043
6               0:34:41.704     0:03:03.349     36,763 kbps     38,273 kbps     00:36:11.002    37,062 kbps     00:36:39.864    36,926 kbps     00:36:34.859    191,664 bytes   358,881 bytes   00:35:44.600
7               0:37:45.054     0:05:15.857     36,718 kbps     38,163 kbps     00:39:46.842    37,034 kbps     00:42:31.799    36,942 kbps     00:42:26.794    191,429 bytes   323,405 bytes   00:42:59.076
8               0:43:00.911     0:10:12.612     35,608 kbps     37,959 kbps     00:44:21.033    37,035 kbps     00:44:17.029    36,918 kbps     00:50:30.152    185,646 bytes   311,192 bytes   00:50:41.121
9               0:53:13.523     0:11:29.480     34,565 kbps     37,866 kbps     01:04:01.587    37,035 kbps     00:55:34.831    36,885 kbps     01:03:57.542    180,208 bytes   316,555 bytes   01:00:02.265
10              1:04:43.004     0:04:00.698     36,703 kbps     39,797 kbps     01:06:34.573    37,400 kbps     01:06:30.569    37,116 kbps     01:06:25.564    191,354 bytes   278,754 bytes   01:06:35.241
11              1:08:43.702     0:02:57.719     35,969 kbps     37,964 kbps     01:08:45.204    36,968 kbps     01:08:53.921    36,877 kbps     01:11:13.269    187,524 bytes   302,504 bytes   01:09:01.720
12              1:11:41.422     0:08:20.291     36,694 kbps     38,207 kbps     01:18:11.269    37,114 kbps     01:17:51.416    36,959 kbps     01:17:46.411    191,305 bytes   346,079 bytes   01:17:58.382
13              1:20:01.713     0:04:23.263     35,910 kbps     38,146 kbps     01:22:58.473    37,040 kbps     01:21:48.111    36,906 kbps     01:21:43.231    187,217 bytes   336,165 bytes   01:22:45.543
14              1:24:24.976     0:08:30.843     36,649 kbps     39,328 kbps     01:26:14.669    37,238 kbps     01:26:10.665    36,952 kbps     01:28:48.531    191,073 bytes   378,672 bytes   01:28:58.541
15              1:32:55.820     0:13:39.818     36,273 kbps     38,267 kbps     01:45:55.682    37,124 kbps     01:45:51.720    36,905 kbps     01:41:27.831    189,110 bytes   294,120 bytes   01:41:28.874
16              1:46:35.639     0:03:01.389     35,986 kbps     37,640 kbps     01:49:08.667    37,006 kbps     01:47:31.403    36,905 kbps     01:47:26.398    187,616 bytes   292,272 bytes   01:49:27.936
17              1:49:37.028     0:05:38.379     30,581 kbps     37,450 kbps     01:54:06.339    36,933 kbps     01:54:02.335    36,869 kbps     01:53:57.330    159,436 bytes   303,120 bytes   01:50:58.068
18              1:55:15.408     0:02:03.665     35,158 kbps     37,584 kbps     01:56:08.336    36,991 kbps     01:55:17.076    36,892 kbps     01:55:20.371    183,360 bytes   302,997 bytes   01:55:30.381
STREAM DIAGNOSTICS:
00274.M2TS      4113 (0x1011)   0x1B            AVC                                     7038.907                35,214                  30,983,146,153  168,484,846
00274.M2TS      4352 (0x1100)   0x80            LPCM            ita (Italian)           7038.907                2,310                   2,032,884,860   11,262,520
00274.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           7038.907                192                     168,938,496     1,099,860
00274.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7038.907                20                      17,362,238      100,007
post #1826 of 5106 Old 07-20-2010, 09:56 PM - Thread Starter
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
ABC [AU] 2009   Brothers                                                        AVC     1080p24 1.78:1  25.99   1:44:37 24,461,137,920  30,825,610,236  31.18   TrueHD  5.1    48/16  1223
A   [US] 1990   Close-Up                                                        AVC     1080p24 1.33:1  26.00   1:37:58 22,009,344,000  48,013,376,179  29.95   LPCM    1.0    48/24  1152
    [AU] 2009   Coraline: Blu-ray 3D                                            AVC     1080p24 1.85:1  29.51   1:40:34 28,419,545,088  44,792,652,615  37.68   DTS-MA  5.1    48/24  3449
    [IT] 1977   Crime Busters (I due superpiedi quasi piatti)                   AVC     1080p24*1.85:1  23.00   1:54:12 22,000,256,256  22,406,658,316  25.69   AC3     5.1           640   / AC3     2.0    48     384
ABC [AU] 2010   Dear John                                                       AVC     1080p24 1.78:1  25.00   1:47:39 23,643,420,672  38,112,690,303  29.28   TrueHD  5.1    48/16  1327
ABC [AU] 2010   Double Identity                                                 AVC     1080p24 1.78:1  24.99   1:32:53 20,245,653,504  20,668,600,781  29.06   TrueHD  5.1    48/16  1372
A   [HK] 2009   Evangelion 2.22: You Can (Not) Advance                          AVC     1080p24 1.78:1  20.00   1:52:09 24,104,017,920  24,463,907,378  28.66   DTS-MA  6.1    48/16  2668  / TrueHD  6.1    48/16  2121  / AC3     2.0    48     192
A   [US] 2008   Everlasting Moments                                             AVC     1080p24 1.78:1  26.94   2:11:24 31,671,957,504  46,860,863,678  32.14   DTS-MA  5.1    48/24  3532
A   [US] 2009   Eyeborgs                                                        AVC     1080p24 2.35:1  16.09   1:42:28 15,286,665,216  22,846,308,460  19.89   DTS-MA  5.1    48/24  2578
ABC [TW] 2004   House of Flying Daggers                                         AVC     1080p24 2.35:1  20.00   1:59:17 21,279,657,984  22,545,924,804  23.79   DTS-MA  5.1    48/16  2047  / AC3     2.0    48     384
    [AU] 2009   Ice Age: Dawn of the Dinosaurs: Blu-ray 3D                      AVC     1080p24 1.85:1  28.05   1:34:01 26,379,614,208  38,565,034,984  37.41   DTS-MA  7.1    48/16  2576
A   [US] 2006   The Illusionist                                                 AVC     1080p24 1.78:1  19.96   1:48:56 21,208,160,256  21,442,525,640  25.96   DTS-MA  5.1    48/24  3698  / AC3     5.1    48     448
ABC [US] 2008   In Bruges                                                       VC-1    1080p24 2.35:1  30.05   1:46:56 29,421,293,568  31,612,812,000  36.68   DTS-MA  5.1    48/24  3918
ABC [US] 2002   Insomnia                                                        VC-1    1080p24 2.40:1  23.75   1:58:13 28,313,296,896  43,962,613,143  31.93   DTS-MA  5.1    48/24  3851
A   [US] 1955   Lola Montès                                                     AVC     1080p24 2.55:1  32.00   1:55:33 31,462,582,272  47,129,440,648  36.30   DTS-MA  3.0    48/24  2220
AB  [US] 1963   Le Mépris (Contempt)                                            AVC     1080p24*2.35:1  31.59   1:43:15 29,169,106,944  47,153,693,752  37.67   DTS-MA  2.0    48/16  933
    [IT] 1984   The Neverending Story                                           AVC     1080p24 2.40:1  28.98   1:33:57 23,858,368,512  23,858,448,376  33.86   AC3     2.0           224
A   [US] 2009   The New Daughter                                                VC-1    1080p24 2.35:1  19.97   1:47:59 21,547,905,024  24,066,877,882  26.61   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
ABC [AU] 2009   The New Daughter                                                AVC     1080p24 2.35:1  21.99   1:47:47 21,528,324,096  22,274,077,228  26.63   TrueHD  5.1    48/16  1388
ABC [US] 2009   Pirate Radio                                                    VC-1    1080p24 2.35:1  30.15   1:56:38 32,914,452,480  46,220,582,228  37.63   DTS-MA  5.1    48/24  3601
A   [US] 1964   Red Desert (Il Deserto rosso)                                   AVC     1080p24 1.85:1  35.21   1:57:19 34,787,149,824  48,100,320,581  39.54   LPCM    1.0    48/24  1152
A   [US] 1976   Rocky                                                           MPEG-2  1080p24 1.85:1  18.33   1:59:35 21,625,233,408  23,144,062,834  24.11   DTS-MA  5.1    48/24  3468  / AC3     2.0    48     224
ABC [UK] 1998   Saving Private Ryan (Fixed Sync)                                AVC     1080p24 1.85:1  27.55   2:49:28 46,634,840,064  47,422,094,900  36.69   DTS-MA  5.1    48/24  4198
ABC [UK] 1998   Saving Private Ryan (Original)                                  AVC     1080p24 1.85:1  27.53   2:49:28 46,602,369,024  47,389,661,090  36.67   DTS-MA  5.1    48/24  4198
ABC [DE] 2001   Training Day                                                    VC-1    1080p24 2.40:1  16.42   2:02:02 18,201,120,768                  19.89   AC3     5.1    48     640
A   [US] 2005   Walk the Line: Theatrical                                       AVC     1080p24 2.40:1  22.88   2:15:52 30,028,603,392  40,311,554,314  29.47   DTS-MA  5.1    48/24  3416
A   [US] 2009   The White Ribbon                                                AVC     1080p24 1.85:1  26.89   2:23:55 36,468,387,840  48,420,890,507  33.79   DTS-MA  5.1    48/24  2783
 B  [UK] 2009   The White Ribbon                                               AVC     1080p24 1.85:1  27.92   2:23:33 33,604,454,400  43,927,489,402  31.21   DTS-MA  5.1    48/16  1657
ABC [AU] 2009   Youth in Revolt                                                 AVC     1080p24 1.85:1  27.99   1:29:23 22,518,030,336  28,014,233,939  33.59   TrueHD  5.1    48/16  1313
post #1827 of 5106 Old 07-21-2010, 02:26 AM
Dark_zero's Avatar
Caruso Pascoski di padre polacco - ITA (only) - from Cecchi Gori HV
Code:
        Total   Video
00003.MPLS                                                      VC-1    1:43:06 22.492.778.496  29.581.852.607  29,09   26,00   LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     CARUSO_PASCOSKI
Disc Size:      29.581.852.607 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:43:06 (h:m:s)
Total Bitrate:          29,09 Mbps
VIDEO:
VC-1 Video              25999 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
LPCM Audio                      Italian         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           Italian         38,359 kbps
FILES:
00005.M2TS      0:00:00.000     1:43:06.180     22.492.778.496  29.088
CHAPTERS:
1               0:00:00.000     0:04:47.954     29.363 kbps     44.848 kbps     00:00:56.931    38.024 kbps     00:02:03.331    34.902 kbps     00:02:29.941    153.064 bytes   480.214 bytes   00:01:38.348
2               0:04:47.954     0:02:54.841     29.499 kbps     42.189 kbps     00:07:10.471    37.073 kbps     00:06:23.508    36.262 kbps     00:07:01.462    153.795 bytes   546.667 bytes   00:07:23.317
3               0:07:42.795     0:04:59.590     23.356 kbps     40.278 kbps     00:10:06.897    34.508 kbps     00:11:52.044    33.415 kbps     00:11:47.957    121.769 bytes   434.296 bytes   00:07:44.755
4               0:12:42.386     0:04:16.172     23.737 kbps     52.616 kbps     00:12:42.470    37.372 kbps     00:14:31.036    34.864 kbps     00:14:26.031    123.753 bytes   420.688 bytes   00:12:42.928
5               0:16:58.559     0:09:19.684     21.278 kbps     40.496 kbps     00:22:06.283    37.435 kbps     00:22:05.115    33.849 kbps     00:22:04.197    110.935 bytes   580.428 bytes   00:22:06.325
6               0:26:18.243     0:03:40.929     28.728 kbps     53.153 kbps     00:27:18.595    37.746 kbps     00:27:58.218    35.373 kbps     00:27:58.093    149.775 bytes   569.946 bytes   00:28:31.042
7               0:29:59.172     0:04:08.915     29.000 kbps     43.095 kbps     00:31:23.089    36.555 kbps     00:31:33.057    35.220 kbps     00:31:57.040    151.191 bytes   596.104 bytes   00:31:45.695
8               0:34:08.087     0:05:03.511     28.250 kbps     36.545 kbps     00:38:34.186    34.466 kbps     00:35:57.655    33.409 kbps     00:35:52.650    147.281 bytes   446.488 bytes   00:39:09.555
9               0:39:11.599     0:07:40.418     22.741 kbps     34.826 kbps     00:46:48.263    31.528 kbps     00:44:27.122    31.037 kbps     00:44:22.284    118.562 bytes   446.609 bytes   00:40:28.676
10              0:46:52.017     0:03:47.810     29.607 kbps     40.355 kbps     00:49:39.935    37.086 kbps     00:49:36.014    35.889 kbps     00:50:08.338    154.357 bytes   444.229 bytes   00:48:31.950
11              0:50:39.828     0:03:32.629     27.924 kbps     44.800 kbps     00:52:14.422    38.939 kbps     00:52:10.418    37.049 kbps     00:52:05.539    145.581 bytes   434.567 bytes   00:54:03.990
12              0:54:12.457     0:05:51.768     32.091 kbps     39.571 kbps     00:54:55.166    36.429 kbps     00:56:35.475    35.698 kbps     00:56:34.307    167.307 bytes   510.688 bytes   01:00:02.473
13              1:00:04.225     0:05:45.970     27.679 kbps     38.302 kbps     01:01:03.451    35.531 kbps     01:01:08.456    34.701 kbps     01:01:08.456    144.303 bytes   447.861 bytes   01:00:35.214
14              1:05:50.196     0:02:08.086     21.049 kbps     37.751 kbps     01:07:50.983    30.490 kbps     01:07:48.606    29.594 kbps     01:07:47.813    109.739 bytes   462.382 bytes   01:06:28.192
15              1:07:58.282     0:07:16.853     22.160 kbps     43.379 kbps     01:09:50.269    32.937 kbps     01:09:17.528    30.452 kbps     01:14:32.801    115.533 bytes   432.056 bytes   01:09:50.644
16              1:15:15.135     0:04:44.117     27.329 kbps     49.580 kbps     01:19:31.349    37.418 kbps     01:19:06.158    35.351 kbps     01:18:45.679    142.480 bytes   477.326 bytes   01:18:50.851
17              1:19:59.252     0:06:57.917     27.101 kbps     37.956 kbps     01:20:03.298    34.197 kbps     01:20:12.098    33.269 kbps     01:20:07.427    141.291 bytes   474.919 bytes   01:20:41.419
18              1:26:57.170     0:08:01.856     25.440 kbps     41.293 kbps     01:27:10.642    38.250 kbps     01:27:19.859    36.218 kbps     01:27:17.941    132.634 bytes   499.666 bytes   01:34:57.983
19              1:34:59.026     0:03:23.578     23.087 kbps     46.953 kbps     01:35:18.838    34.742 kbps     01:35:14.959    33.044 kbps     01:35:09.954    120.367 bytes   479.210 bytes   01:38:19.310
20              1:38:22.605     0:04:43.574     26.984 kbps     45.909 kbps     01:40:25.978    36.522 kbps     01:39:10.945    34.593 kbps     01:40:52.796    140.705 bytes   507.178 bytes   01:40:26.186
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0xEA            VC-1                                    6186,055                26.000                  20.104.336.191  109.352.386
00005.M2TS      4352 (0x1100)   0x80            LPCM            ita (Italian)           6186,055                1.542                   1.192.711.892   7.423.518
00005.M2TS      4608 (0x1200)   0x90            PGS             ita (Italian)           6186,055                38                      29.662.132      166.723
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Playlist: 00003.MPLS
Length: 1:43:06
Video: VC-1 Video / 25999 kbps / 1080p / 23,976 fps / 16:9 / Advanced Profile 3
Audio: Italian / LPCM Audio / 2.0 / 48 kHz / 1536 kbps / 16-bit
Subtitle: Italian / 38,359 kbps
Dark_zero is offline
post #1828 of 5106 Old 07-21-2010, 06:30 AM
Dark_zero's Avatar
Johnny Stecchino (Roberto Benigni) - ITA only - Cecchi Gori HV
Code:
        Total   Video
00003.MPLS                                                      VC-1    2:00:50 27.982.516.224  28.303.171.310  30,87   27,72   LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     JOHNNY_STECCHINO
Disc Size:      28.303.171.310 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 2:00:50 (h:m:s)
Total Bitrate:          30,87 Mbps
VIDEO:
VC-1 Video              27721 kbps          1080p / 23,976 fps / 16:9 / Advanced Profile 3
AUDIO:
SUBTITLES:
Presentation Graphics           Italian         28,967 kbps
FILES:
00006.M2TS      0:00:00.000     2:00:50.576     27.982.516.224  30.875
CHAPTERS:
1               0:00:00.000     0:04:01.115     29.071 kbps     42.126 kbps     00:04:00.114    37.198 kbps     00:01:15.617    36.949 kbps     00:01:14.699    151.534 bytes   569.743 bytes   00:01:24.083
2               0:04:01.115     0:05:22.947     25.172 kbps     42.216 kbps     00:07:07.927    38.911 kbps     00:07:43.337    33.794 kbps     00:07:43.337    131.238 bytes   477.291 bytes   00:06:58.334
3               0:09:24.063     0:01:35.095     29.288 kbps     40.262 kbps     00:10:22.330    36.814 kbps     00:10:54.153    34.960 kbps     00:10:18.784    152.693 bytes   591.287 bytes   00:09:46.752
4               0:10:59.158     0:06:42.527     28.046 kbps     40.885 kbps     00:15:19.460    37.791 kbps     00:15:12.244    36.497 kbps     00:16:09.426    146.217 bytes   624.251 bytes   00:12:08.602
5               0:17:41.685     0:04:03.034     30.263 kbps     39.140 kbps     00:20:27.017    36.872 kbps     00:20:24.598    34.602 kbps     00:19:54.818    157.778 bytes   477.610 bytes   00:18:08.712
6               0:21:44.720     0:04:32.939     25.099 kbps     42.511 kbps     00:24:49.070    36.327 kbps     00:24:47.986    34.351 kbps     00:22:57.834    130.856 bytes   572.719 bytes   00:24:50.530
7               0:26:17.659     0:16:07.841     26.109 kbps     47.551 kbps     00:41:37.870    38.739 kbps     00:28:50.603    36.360 kbps     00:32:36.704    136.118 bytes   645.811 bytes   00:41:38.412
8               0:42:25.501     0:02:28.648     19.607 kbps     39.408 kbps     00:42:50.317    30.622 kbps     00:42:35.636    28.904 kbps     00:42:30.631    102.224 bytes   549.217 bytes   00:42:50.609
9               0:44:54.149     0:05:15.398     27.906 kbps     40.793 kbps     00:48:21.273    37.303 kbps     00:48:17.227    36.567 kbps     00:48:12.222    145.487 bytes   505.081 bytes   00:47:58.876
10              0:50:09.548     0:09:15.471     26.026 kbps     41.235 kbps     00:52:04.788    36.159 kbps     00:51:45.852    34.481 kbps     00:51:43.100    135.689 bytes   552.115 bytes   00:54:25.345
11              0:59:25.019     0:00:41.458     25.370 kbps     33.897 kbps     01:00:04.475    32.238 kbps     01:00:01.222    28.086 kbps     00:59:56.426    132.269 bytes   502.955 bytes   00:59:48.668
12              1:00:06.477     0:03:26.164     22.730 kbps     32.177 kbps     01:01:32.980    28.358 kbps     01:01:29.143    27.722 kbps     01:01:27.141    118.505 bytes   611.833 bytes   01:00:39.427
13              1:03:32.642     0:08:45.441     25.874 kbps     38.899 kbps     01:09:48.559    35.839 kbps     01:11:56.228    35.145 kbps     01:11:56.186    134.897 bytes   477.437 bytes   01:07:39.930
14              1:12:18.083     0:10:54.612     31.468 kbps     40.983 kbps     01:23:06.564    34.640 kbps     01:15:46.833    33.386 kbps     01:12:25.424    164.062 bytes   620.854 bytes   01:22:09.507
15              1:23:12.696     0:04:01.282     31.138 kbps     37.597 kbps     01:23:58.700    33.894 kbps     01:23:54.696    33.128 kbps     01:23:39.055    162.340 bytes   639.443 bytes   01:23:55.071
16              1:27:13.978     0:04:16.047     31.823 kbps     42.561 kbps     01:30:37.432    36.239 kbps     01:31:23.686    35.769 kbps     01:31:20.016    165.911 bytes   505.607 bytes   01:31:15.636
17              1:31:30.026     0:05:23.531     31.365 kbps     43.603 kbps     01:34:16.984    37.713 kbps     01:34:16.275    35.961 kbps     01:34:16.776    163.522 bytes   523.543 bytes   01:36:07.386
18              1:36:53.557     0:04:05.787     31.216 kbps     40.644 kbps     01:36:53.557    37.125 kbps     01:37:12.243    36.019 kbps     01:37:12.660    162.748 bytes   641.592 bytes   01:40:05.791
19              1:40:59.344     0:03:02.307     28.214 kbps     39.783 kbps     01:42:54.543    35.261 kbps     01:42:51.081    33.494 kbps     01:42:46.243    147.097 bytes   513.488 bytes   01:42:49.580
20              1:44:01.652     0:05:07.557     25.720 kbps     40.688 kbps     01:48:56.821    36.805 kbps     01:48:31.838    36.042 kbps     01:48:31.838    134.092 bytes   559.285 bytes   01:45:50.135
21              1:49:09.209     0:03:40.511     25.249 kbps     39.679 kbps     01:51:36.773    34.430 kbps     01:51:33.645    32.995 kbps     01:52:38.626    131.639 bytes   540.781 bytes   01:52:41.838
22              1:52:49.721     0:02:01.287     29.437 kbps     40.776 kbps     01:53:57.288    35.211 kbps     01:53:53.159    33.448 kbps     01:53:53.159    153.471 bytes   484.205 bytes   01:53:17.665
23              1:54:51.009     0:02:07.544     25.129 kbps     37.266 kbps     01:56:48.251    34.984 kbps     01:56:47.250    34.461 kbps     01:56:47.250    131.012 bytes   570.801 bytes   01:56:31.234
24              1:56:58.553     0:03:52.023     31.541 kbps     40.591 kbps     01:59:11.227    37.500 kbps     01:59:09.767    36.080 kbps     01:59:04.762    164.472 bytes   855.951 bytes   02:00:35.686
STREAM DIAGNOSTICS:
00006.M2TS      4113 (0x1011)   0xEA            VC-1                                    7250,452                27.721                  25.123.802.800  136.647.257
00006.M2TS      4352 (0x1100)   0x80            LPCM            ita (Italian)           7250,452                1.542                   1.397.917.608   8.700.732
00006.M2TS      4608 (0x1200)   0x90            PGS             ita (Italian)           7250,452                29                      26.253.192      151.367
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Length: 2:00:50
Video: VC-1 Video / 27721 kbps / 1080p / 23,976 fps / 16:9 / Advanced Profile 3
Subtitle: Italian / 28,967 kbps
post #1829 of 5106 Old 07-21-2010, 07:43 AM
Stephen Dawson's Avatar
Cloudy with a Chance of Meatballs - Blu-ray 3D - 2009 - Australian version
Distributed by Sony Pictures Home Entertainment Australia
Region Free, confirmed with AnyDVD HD
Obviously the BDInfo scan data which I will show at the end of this post refers only to the 2D version of the movie. But first some discussion, and some other information.
First, this movie lacks the multiple angles CinemaSquid has referred to at the start of the UK and US 2D versions. Second, it has lots of languages. The English DD is English Audio Descriptive.
Third, the actual size of the disc (calculated by doing DIR /S on the whole disc, thereby yielding the same result as BDInfo, and then subtracting the subtotal for the SSIF folder) is 43,132,943,414 bytes.
Fourth, unlike Universal (judging from Coraline), but like Fox (judging from Ice Age 3), this Sony disc has 2D menus. On selecting 'Play' you get an option to play the 2D or 3D versions. If you choose the latter in a 2D player, it tells you that you can't do that.
Fifth, there are three separate 3D elements to the disc. There is the movie itself, which is divided into two 2D files for some reason (four files to support 3D). These files are 00151/00152 and then 00177/00178.
There is an 89 second 'Sneak Peek' of the 2006 movie Open Season on Blu-ray 3D. Interestingly, this is available only in 3D. If you try to play it on a 2D player, you are told that you can't. But this is just a matter of disc organisation: if you drag the file containing it (either 154 or 156) into a player on a computer, the 2D version plays fine. You can also switch off 3D at the TV at any time, so if you have a 3D system you can see this item in either 3D or 2D, but if you have a 2D system, tough. The companion 3D elements to those two files are 00155 and 00157 respectively.
And, yes, this 'Sneak Peek' appears to be duplicated. I played both of the left eye files and they appeared identical. I tried doing a DOS file compare on these two files. It was taking so long to finish that I ended up aborting it (after pulling a Sony 3D TV from its box, and a Sony Blu-ray 3D player, and assembling them and plugging them into the audio system and getting a station scan started on the former), without any differences having been disclosed by FC /B. So why there are two copies is rather a mystery.
The final 3D element is a 19 second clip for Blu-ray 3D and Sony 3D logos played at the start of the 3D version of the movie. This clip shows that the files containing the left and right eye elements do not need to be sequentially numbered, for they are 00179 and 00184.
So here are the contents of the SSIF folder:
Code:
18,286,030,848 00151.ssif
   446,355,456 00154.ssif
   446,355,456 00156.ssif
17,294,223,360 00177.ssif
    99,514,368 00179.ssif
And here is the usual BDInfo scan:
Code:
        Total   Video
00001.MPLS                                                      AVC     1:29:53 24,077,303,808  79,705,422,902  35.71   24.55   DTS-HD Master 5.1 2300Kbps (48kHz/16-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     CLOUDY_3D_P2
Disc Size:      79,705,422,902 bytes
Protection:     AACS
BD-Java:        Yes
Extras:         Blu-ray 3D
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:29:53 (h:m:s)
Total Bitrate:          35.71 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        24548 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2300 kbps       5.1 / 48 kHz / 2300 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             Japanese        2293 kbps       5.1 / 48 kHz / 2293 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             Chinese         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Danish          448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Finnish         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Korean          448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Norwegian       448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Swedish         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Thai            448 kbps        5.1 / 48 kHz / 448 kbps
SUBTITLES:
Presentation Graphics           English         29.868 kbps
* Presentation Graphics         English         29.884 kbps
* Presentation Graphics         English         37.224 kbps
Presentation Graphics           Japanese        20.079 kbps
Presentation Graphics           Chinese         25.857 kbps
Presentation Graphics           Danish          28.254 kbps
Presentation Graphics           Finnish         27.373 kbps
Presentation Graphics           Hindi           29.242 kbps
Presentation Graphics           Indonesian      28.362 kbps
Presentation Graphics           Korean          22.372 kbps
Presentation Graphics           Norwegian       29.155 kbps
Presentation Graphics           Swedish         27.347 kbps
Presentation Graphics           Thai            27.064 kbps
Presentation Graphics           Japanese        0.248 kbps
FILES:
00151.M2TS      0:00:00.000     0:45:44.032     12,282,974,208  35,810
00177.M2TS      0:45:44.032     0:44:09.355     11,794,329,600  35,614
CHAPTERS:
1               0:00:00.000     0:04:47.620     24,799 kbps     40,724 kbps     00:03:53.066    31,645 kbps     00:00:59.642    30,740 kbps     00:00:54.637    129,274 bytes   725,957 bytes   00:02:18.179
2               0:04:47.620     0:04:08.957     24,371 kbps     45,806 kbps     00:06:53.121    28,855 kbps     00:05:59.317    26,917 kbps     00:06:44.404    127,060 bytes   664,524 bytes   00:05:29.495
3               0:08:56.577     0:05:36.586     24,363 kbps     44,094 kbps     00:13:03.866    33,641 kbps     00:13:02.698    27,956 kbps     00:12:58.277    127,017 bytes   736,628 bytes   00:13:07.661
4               0:14:33.163     0:05:57.065     25,241 kbps     39,422 kbps     00:15:09.700    34,276 kbps     00:20:04.203    30,157 kbps     00:15:00.691    131,595 bytes   621,041 bytes   00:16:47.047
5               0:20:30.229     0:03:55.360     24,317 kbps     41,187 kbps     00:20:54.544    32,608 kbps     00:20:53.043    28,763 kbps     00:20:53.877    126,777 bytes   655,023 bytes   00:24:01.815
6               0:24:25.589     0:06:17.585     24,675 kbps     46,895 kbps     00:24:54.826    31,776 kbps     00:24:51.615    29,401 kbps     00:28:16.986    128,646 bytes   712,892 bytes   00:26:30.589
7               0:30:43.174     0:05:46.429     24,923 kbps     39,373 kbps     00:35:52.358    29,107 kbps     00:35:18.616    28,364 kbps     00:31:07.532    129,938 bytes   642,708 bytes   00:34:34.739
8               0:36:29.604     0:06:20.505     24,693 kbps     37,321 kbps     00:40:09.073    29,652 kbps     00:37:23.908    27,207 kbps     00:37:20.905    128,738 bytes   650,838 bytes   00:42:36.345
9               0:42:50.109     0:03:46.684     24,403 kbps     46,142 kbps     00:43:58.177    30,066 kbps     00:43:54.631    28,307 kbps     00:43:49.585    127,225 bytes   601,707 bytes   00:45:52.541
10              0:46:36.793     0:06:07.033     25,349 kbps     41,451 kbps     00:50:34.906    32,074 kbps     00:50:51.298    30,913 kbps     00:50:09.506    132,156 bytes   629,682 bytes   00:47:11.662
11              0:52:43.827     0:02:23.601     22,817 kbps     40,312 kbps     00:54:19.756    32,495 kbps     00:54:19.506    31,363 kbps     00:54:13.875    118,959 bytes   637,346 bytes   00:54:52.706
12              0:55:07.429     0:05:35.335     24,449 kbps     40,487 kbps     00:58:33.509    29,594 kbps     00:57:51.176    28,781 kbps     00:57:51.176    127,464 bytes   702,674 bytes   00:58:13.990
13              1:00:42.764     0:05:00.633     25,143 kbps     38,466 kbps     01:02:10.059    32,661 kbps     01:03:48.115    30,660 kbps     01:03:46.072    131,085 bytes   728,372 bytes   01:04:38.791
14              1:05:43.397     0:07:20.356     24,505 kbps     40,461 kbps     01:07:02.768    32,887 kbps     01:07:01.934    30,879 kbps     01:06:56.762    127,756 bytes   677,235 bytes   01:06:41.247
15              1:13:03.754     0:04:41.614     25,485 kbps     41,694 kbps     01:17:20.635    32,952 kbps     01:17:18.300    30,058 kbps     01:17:15.255    132,866 bytes   574,143 bytes   01:13:05.172
16              1:17:45.369     0:12:08.018     23,457 kbps     50,306 kbps     01:21:20.083    32,277 kbps     01:21:43.398    29,833 kbps     01:23:32.590    122,301 bytes   759,510 bytes   01:23:17.409
STREAM DIAGNOSTICS:
00151.M2TS      4113 (0x1011)   0x1B            AVC                                     2743.908                24,704                  8,473,199,200   46,088,472
00151.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2743.908                2,215                   759,680,408     4,577,664
00151.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2743.908                448                     153,667,584     857,520
00151.M2TS      4354 (0x1102)   0x86            DTS-HD MA       jpn (Japanese)          2743.908                2,211                   758,447,856     4,563,124
00151.M2TS      4355 (0x1103)   0x81            AC3             zho (Chinese)           2743.908                448                     153,667,584     857,520
00151.M2TS      4356 (0x1104)   0x81            AC3             zho (Chinese)           2743.908                448                     153,667,584     857,520
00151.M2TS      4357 (0x1105)   0x81            AC3             dan (Danish)            2743.908                448                     153,667,584     857,520
00151.M2TS      4358 (0x1106)   0x81            AC3             fin (Finnish)           2743.908                448                     153,667,584     857,520
00151.M2TS      4359 (0x1107)   0x81            AC3             kor (Korean)            2743.908                448                     153,667,584     857,520
00151.M2TS      4360 (0x1108)   0x81            AC3             nor (Norwegian)         2743.908                448                     153,667,584     857,520
00151.M2TS      4361 (0x1109)   0x81            AC3             swe (Swedish)           2743.908                448                     153,667,584     857,520
00151.M2TS      4362 (0x110A)   0x81            AC3             tha (Thai)              2743.908                448                     153,667,584     857,520
00151.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2743.908                38                      12,889,178      74,519
00151.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2743.908                38                      12,896,093      74,556
00151.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           2743.908                45                      15,588,841      90,380
00151.M2TS      4611 (0x1203)   0x90            PGS             jpn (Japanese)          2743.908                25                      8,572,847       51,609
00151.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           2743.908                33                      11,151,934      65,358
00151.M2TS      4613 (0x1205)   0x90            PGS             dan (Danish)            2743.908                36                      12,180,033      70,058
00151.M2TS      4614 (0x1206)   0x90            PGS             fin (Finnish)           2743.908                34                      11,821,954      68,190
00151.M2TS      4615 (0x1207)   0x90            PGS             hin (Hindi)             2743.908                37                      12,524,138      72,759
00151.M2TS      4616 (0x1208)   0x90            PGS             ind (Indonesian)        2743.908                36                      12,326,893      70,680
00151.M2TS      4617 (0x1209)   0x90            PGS             kor (Korean)            2743.908                28                      9,539,852       56,333
00151.M2TS      4618 (0x120A)   0x90            PGS             nor (Norwegian)         2743.908                37                      12,552,210      72,936
00151.M2TS      4619 (0x120B)   0x90            PGS             swe (Swedish)           2743.908                34                      11,777,743      68,629
00151.M2TS      4620 (0x120C)   0x90            PGS             tha (Thai)              2743.908                35                      11,841,955      69,236
00151.M2TS      4621 (0x120D)   0x90            PGS             jpn (Japanese)          2743.908                0                       84,214          524
00177.M2TS      4113 (0x1011)   0x1B            AVC                                     2649.272                24,389                  8,076,494,474   43,931,295
00177.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2649.272                2,388                   790,801,948     4,715,282
00177.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2649.272                448                     148,365,056     827,930
00177.M2TS      4354 (0x1102)   0x86            DTS-HD MA       jpn (Japanese)          2649.272                2,377                   787,175,504     4,695,282
00177.M2TS      4355 (0x1103)   0x81            AC3             zho (Chinese)           2649.272                448                     148,365,056     827,930
00177.M2TS      4356 (0x1104)   0x81            AC3             zho (Chinese)           2649.272                448                     148,365,056     827,930
00177.M2TS      4357 (0x1105)   0x81            AC3             dan (Danish)            2649.272                448                     148,365,056     827,930
00177.M2TS      4358 (0x1106)   0x81            AC3             fin (Finnish)           2649.272                448                     148,365,056     827,930
00177.M2TS      4359 (0x1107)   0x81            AC3             kor (Korean)            2649.272                448                     148,365,056     827,930
00177.M2TS      4360 (0x1108)   0x81            AC3             nor (Norwegian)         2649.272                448                     148,365,056     827,930
00177.M2TS      4361 (0x1109)   0x81            AC3             swe (Swedish)           2649.272                448                     148,365,056     827,930
00177.M2TS      4362 (0x110A)   0x81            AC3             tha (Thai)              2649.272                448                     148,365,056     827,930
00177.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2649.272                22                      7,246,870       42,201
00177.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2649.272                22                      7,250,634       42,222
00177.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           2649.272                29                      9,506,618       55,419
00177.M2TS      4611 (0x1203)   0x90            PGS             jpn (Japanese)          2649.272                15                      4,963,699       30,127
00177.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           2649.272                19                      6,280,061       37,081
00177.M2TS      4613 (0x1205)   0x90            PGS             dan (Danish)            2649.272                21                      6,868,300       39,832
00177.M2TS      4614 (0x1206)   0x90            PGS             fin (Finnish)           2649.272                20                      6,632,062       38,600
00177.M2TS      4615 (0x1207)   0x90            PGS             hin (Hindi)             2649.272                22                      7,190,017       42,030
00177.M2TS      4616 (0x1208)   0x90            PGS             ind (Indonesian)        2649.272                21                      6,793,841       39,255
00177.M2TS      4617 (0x1209)   0x90            PGS             kor (Korean)            2649.272                17                      5,542,515       32,938
00177.M2TS      4618 (0x120A)   0x90            PGS             nor (Norwegian)         2649.272                21                      7,103,498       41,534
00177.M2TS      4619 (0x120B)   0x90            PGS             swe (Swedish)           2649.272                20                      6,658,942       39,098
00177.M2TS      4620 (0x120C)   0x90            PGS             tha (Thai)              2649.272                19                      6,403,819       37,842
00177.M2TS      4621 (0x120D)   0x90            PGS             jpn (Japanese)          2649.272                0                       83,313          507
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1830 of 5106 Old 07-22-2010, 10:26 AM
Snowknight26's Avatar
Quoted: 31 Post(s)
The Brothers Grimm
US Release
Code:
        Total   Video
00002.MPLS                                                      AVC     1:58:28 20,649,080,832  24,594,018,186  23.24   15.98   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     32126158_GRM1NNE1
Disc Size:      24,594,018,186 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 1:58:28 (h:m:s)
Total Bitrate:          23.24 Mbps
VIDEO:
MPEG-4 AVC Video        15980 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps / DN -6dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           English         27.424 kbps
Presentation Graphics           English         0.214 kbps
Presentation Graphics           English         52.760 kbps
Presentation Graphics           French          22.361 kbps
Presentation Graphics           Spanish         22.099 kbps
FILES:
00005.M2TS      0:00:00.000     1:58:28.101     20,649,080,832  23,240
CHAPTERS:
1               0:00:00.000     0:11:21.806     15,823 kbps     45,710 kbps     00:07:40.960    34,374 kbps     00:00:54.304    27,583 kbps     00:00:50.175    82,488 bytes    502,864 bytes   00:00:54.387
2               0:11:21.806     0:01:56.366     16,536 kbps     42,205 kbps     00:12:47.892    28,837 kbps     00:13:08.954    25,216 kbps     00:13:08.162    86,212 bytes    474,304 bytes   00:13:11.165
3               0:13:18.172     0:04:34.399     15,856 kbps     24,992 kbps     00:17:26.211    20,261 kbps     00:16:09.969    19,533 kbps     00:16:08.217    82,665 bytes    400,173 bytes   00:17:27.212
4               0:17:52.571     0:03:13.568     19,135 kbps     35,933 kbps     00:20:25.515    27,054 kbps     00:20:17.174    24,026 kbps     00:20:12.169    99,760 bytes    436,877 bytes   00:19:18.782
5               0:21:06.139     0:02:03.248     15,483 kbps     28,469 kbps     00:22:03.030    23,618 kbps     00:21:59.026    22,112 kbps     00:21:56.231    80,724 bytes    439,489 bytes   00:22:07.075
6               0:23:09.388     0:05:10.643     14,374 kbps     32,495 kbps     00:23:10.180    20,783 kbps     00:24:23.545    19,337 kbps     00:24:20.584    74,937 bytes    450,752 bytes   00:24:24.004
7               0:28:20.031     0:02:52.463     15,636 kbps     27,891 kbps     00:30:38.044    20,884 kbps     00:30:53.643    19,787 kbps     00:30:48.638    81,519 bytes    385,828 bytes   00:28:51.855
8               0:31:12.495     0:05:38.963     17,128 kbps     33,412 kbps     00:36:48.748    25,681 kbps     00:35:42.890    21,850 kbps     00:33:17.245    89,300 bytes    528,475 bytes   00:36:48.831
9               0:36:51.459     0:03:58.112     19,683 kbps     38,751 kbps     00:40:01.941    31,426 kbps     00:40:00.523    29,151 kbps     00:39:57.520    102,621 bytes   537,392 bytes   00:38:51.537
10              0:40:49.572     0:05:28.828     16,913 kbps     35,733 kbps     00:45:14.128    27,926 kbps     00:45:11.458    25,992 kbps     00:40:55.327    88,179 bytes    433,840 bytes   00:41:46.754
11              0:46:18.400     0:05:47.180     11,680 kbps     24,047 kbps     00:51:18.909    21,084 kbps     00:51:14.696    19,284 kbps     00:51:14.696    60,892 bytes    391,673 bytes   00:51:44.351
12              0:52:05.580     0:05:34.792     14,981 kbps     29,663 kbps     00:55:07.929    23,468 kbps     00:52:38.780    19,782 kbps     00:52:38.780    78,106 bytes    470,437 bytes   00:52:41.616
13              0:57:40.373     0:08:47.818     16,274 kbps     31,819 kbps     01:02:54.395    28,518 kbps     01:02:54.061    27,160 kbps     01:02:53.519    84,847 bytes    500,032 bytes   01:02:54.437
14              1:06:28.192     0:02:59.220     17,083 kbps     36,003 kbps     01:07:36.635    29,826 kbps     01:07:36.385    23,366 kbps     01:07:28.461    89,060 bytes    448,302 bytes   01:07:41.057
15              1:09:27.413     0:09:22.520     15,087 kbps     34,258 kbps     01:18:45.429    24,981 kbps     01:10:04.366    22,239 kbps     01:09:59.069    78,657 bytes    521,422 bytes   01:11:09.265
16              1:18:49.933     0:02:49.544     16,923 kbps     41,732 kbps     01:20:18.021    30,888 kbps     01:20:17.729    26,973 kbps     01:20:17.729    88,229 bytes    510,519 bytes   01:20:18.063
17              1:21:39.477     0:04:57.797     17,187 kbps     36,622 kbps     01:21:51.823    28,448 kbps     01:22:52.300    26,799 kbps     01:21:48.320    89,605 bytes    459,115 bytes   01:22:16.723
18              1:26:37.275     0:04:34.732     13,676 kbps     27,686 kbps     01:27:28.326    24,936 kbps     01:27:28.660    20,956 kbps     01:27:25.698    71,301 bytes    443,872 bytes   01:27:43.174
19              1:31:12.008     0:11:34.860     16,916 kbps     36,097 kbps     01:31:43.080    27,306 kbps     01:36:20.983    26,479 kbps     01:36:16.103    88,193 bytes    508,845 bytes   01:31:43.122
20              1:42:46.869     0:05:39.964     20,520 kbps     37,391 kbps     01:45:07.634    33,996 kbps     01:45:07.634    30,970 kbps     01:45:07.634    106,979 bytes   493,212 bytes   01:45:07.676
21              1:48:26.833     0:02:18.930     23,163 kbps     34,585 kbps     01:48:32.214    28,995 kbps     01:50:05.223    28,113 kbps     01:49:31.398    120,760 bytes   454,432 bytes   01:49:24.808
22              1:50:45.764     0:07:42.336     10,365 kbps     26,782 kbps     01:57:47.935    25,022 kbps     01:57:45.308    24,828 kbps     01:57:40.803    54,044 bytes    330,484 bytes   01:57:36.632
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     7107.934                15,980                  14,198,201,260  77,263,902
00005.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           7107.934                640                     568,650,240     3,331,935
00005.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           7107.934                4,615                   4,099,954,964   22,745,936
00005.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            7107.934                448                     398,055,168     2,221,290
00005.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7107.934                192                     170,595,072     1,110,645
00005.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7107.934                27                      24,366,264      141,820
00005.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7107.934                22                      19,867,967      114,899
00005.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           7107.934                22                      19,635,041      113,007
00005.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           7107.934                53                      46,877,863      264,614
00005.M2TS      4612 (0x1204)   0x90            PGS             eng (English)           7107.934                0                       190,401         1,098
Snowknight26 is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
