NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 97 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #2881 of 5106 Old 04-04-2011, 12:11 AM
Stephen Dawson's Avatar
Monsters - 2010 - Australian version
Distributed by Madman Entertainment Pty Ltd
Locked to Region B, confirmed with AnyDVD HD
Code:
        Total   Video
00008.MPLS                                                      AVC     1:33:44 27,586,830,336  43,160,537,035  39.24   32.78   LPCM 5.1 4608Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     MONSTERS
Disc Size:      43,160,537,035 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:33:44 (h:m:s)
Total Bitrate:          39.24 Mbps
VIDEO:
MPEG-4 AVC Video        32778 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         40.566 kbps
FILES:
00016.M2TS      0:00:00.000     1:33:44.750     27,586,830,336  39,236
CHAPTERS:
1               0:00:00.000     0:09:39.333     28,954 kbps     46,731 kbps     00:03:09.249    40,088 kbps     00:03:09.125    37,960 kbps     00:01:41.249    150,792 bytes   658,184 bytes   00:03:10.291
2               0:09:39.333     0:08:44.208     35,322 kbps     46,496 kbps     00:13:43.291    41,002 kbps     00:13:40.791    39,059 kbps     00:11:16.958    183,967 bytes   716,818 bytes   00:13:42.791
3               0:18:23.541     0:12:51.333     35,596 kbps     42,435 kbps     00:28:01.999    39,567 kbps     00:27:59.291    38,920 kbps     00:27:57.999    185,394 bytes   546,861 bytes   00:28:02.041
4               0:31:14.875     0:06:05.416     35,798 kbps     40,811 kbps     00:34:58.958    38,316 kbps     00:34:56.958    37,328 kbps     00:35:32.666    186,447 bytes   471,011 bytes   00:35:00.000
5               0:37:20.291     0:08:37.958     36,024 kbps     38,961 kbps     00:43:34.916    37,387 kbps     00:40:11.416    37,062 kbps     00:40:42.583    187,623 bytes   336,804 bytes   00:42:25.375
6               0:45:58.250     0:13:09.666     31,828 kbps     43,186 kbps     00:57:27.666    40,238 kbps     00:48:50.125    39,430 kbps     00:49:33.166    165,772 bytes   639,167 bytes   00:51:35.708
7               0:59:07.916     0:07:49.708     32,223 kbps     47,101 kbps     01:02:55.833    41,121 kbps     01:06:41.083    40,124 kbps     01:06:39.125    167,826 bytes   678,962 bytes   01:00:20.916
8               1:06:57.625     0:06:12.625     33,891 kbps     45,058 kbps     01:11:38.458    41,526 kbps     01:11:37.541    40,297 kbps     01:11:35.625    176,514 bytes   795,694 bytes   01:11:37.583
9               1:13:10.250     0:05:19.416     33,537 kbps     42,335 kbps     01:16:01.291    39,427 kbps     01:15:59.541    38,665 kbps     01:16:54.208    174,673 bytes   649,281 bytes   01:16:55.291
10              1:18:29.666     0:05:25.375     35,563 kbps     45,001 kbps     01:19:17.500    41,486 kbps     01:19:16.625    40,412 kbps     01:19:15.708    185,226 bytes   745,307 bytes   01:19:17.750
11              1:23:55.041     0:06:40.666     35,045 kbps     44,753 kbps     01:28:50.833    40,086 kbps     01:28:47.375    39,101 kbps     01:28:46.833    182,526 bytes   730,356 bytes   01:28:50.875
12              1:30:35.708     0:03:09.041     3,483 kbps      9,561 kbps      01:33:02.666    7,526 kbps      01:33:00.416    7,127 kbps      01:32:57.666    18,144 bytes    299,904 bytes   01:33:02.708
STREAM DIAGNOSTICS:
00016.M2TS      4113 (0x1011)   0x1B            AVC                                     5624.667                32,778                  23,045,860,254  125,327,801
00016.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           5624.667                4,615                   3,244,860,500   18,002,000
00016.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5624.667                41                      28,522,038      163,141
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #2882 of 5106 Old 04-04-2011, 04:08 AM
DigitalfreakNYC's Avatar
Quoted: 127 Post(s)
Originally Posted by Cinema Squid View Post
I dunno, but the first page is a little heavyweight with all the lists. What browser version are you using? Do you have the same problem in another browser? I recommend trying Google Chrome, since it's awesomely fast. Do you have any problems pulling up the PQ Tier Listings thread, since that's rather large as well? Here is the link: https://www.avsforum.com/avs-vb/showthread.php?t=1168342
Also, as a complete shot in the dark (trying to imagine what forum scripts might be running), you could try turning off the auto word links - "Turn OFF in post auto word links?" in the User CP Edit Options screen of AVS.
I'm using IE.
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #2883 of 5106 Old 04-05-2011, 12:39 AM
Laputa: Castle in the Sky - 1986 - Australian version
Main title has a section near the start, plus the credits at the end, that are English or Japanese text, depending on the selected credits, implemented as angles. There are also BonusView PIP storyboards throughout.
I'm not quite sure what's going on with the weird bitrate measurements shown.
Code:
        Total   Video
00002.MPLS                                                      AVC     2:04:31 33,978,771,456  45,822,156,065  36.38   26.26   LPCM 5.1 4608Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LAPUTA
Disc Size:      45,822,156,065 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 2:04:31 (h:m:s)
Total Bitrate:          36.38 Mbps
Angle 1 Length:         0:04:42 (h:m:s) / 2:04:31 (h:m:s)
Angle 1 Size:           1,316,173,824 bytes / 33,964,161,024 bytes
Angle 1 Total Bitrate:  37.27 Mbps / 36.37 Mbps
All Angles Length:      2:09:13 (h:m:s)
All Angles Size:        35,294,945,280 bytes
All Angles Bitrate:     36.42 Mbps
VIDEO:
MPEG-4 AVC Video        26258 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video (1)    1028 (27179) kbps   1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        2021 kbps           480p / 23.976 fps / 16:9 / High Profile 3.2
MPEG-4 AVC Video (1)    73 (1920) kbps      480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
LPCM Audio                      Japanese        1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         22.147 kbps
FILES:
00008.M2TS      0:00:00.000     0:03:51.856     1,043,269,632   35,997
00009.M2TS      0:03:51.856     0:01:39.140     485,431,296     39,171
00010.M2TS (1)  0:03:51.856     0:01:39.140     474,759,168     38,310
00011.M2TS      0:05:30.997     1:55:56.824     31,604,717,568  36,344
00012.M2TS      2:01:27.822     0:03:03.391     845,352,960     36,876
00013.M2TS (1)  2:01:27.822     0:03:03.391     841,414,656     36,705
CHAPTERS:
1               0:00:00.000     0:10:44.977     25,423 kbps     37,368 kbps     00:03:53.650    31,573 kbps     00:03:53.483    30,087 kbps     00:03:53.691    132,537 bytes   947,276 bytes   00:03:55.610
2               0:10:44.977     0:07:14.308     26,886 kbps     37,008 kbps     00:13:03.240    30,890 kbps     00:11:32.024    29,643 kbps     00:11:27.228    140,170 bytes   857,790 bytes   00:11:17.843
3               0:17:59.286     0:10:07.857     27,035 kbps     32,671 kbps     00:27:43.953    28,937 kbps     00:24:24.129    28,684 kbps     00:24:20.959    140,948 bytes   813,806 bytes   00:27:43.995
4               0:28:07.143     0:08:10.907     24,992 kbps     37,453 kbps     00:35:46.143    30,951 kbps     00:33:51.362    29,745 kbps     00:33:46.399    130,296 bytes   952,527 bytes   00:35:46.602
5               0:36:18.050     0:07:24.694     24,994 kbps     36,449 kbps     00:41:19.602    31,831 kbps     00:38:59.170    29,785 kbps     00:36:18.801    130,308 bytes   965,927 bytes   00:36:20.052
6               0:43:42.745     0:07:38.124     25,729 kbps     37,292 kbps     00:49:59.037    31,476 kbps     00:45:17.714    30,087 kbps     00:45:17.798    134,138 bytes   874,997 bytes   00:45:17.840
7               0:51:20.869     0:11:51.961     26,172 kbps     38,524 kbps     00:52:58.842    30,796 kbps     00:52:58.300    28,910 kbps     00:52:58.300    136,447 bytes   828,216 bytes   00:53:51.102
8               1:03:12.830     0:13:37.566     26,283 kbps     35,347 kbps     01:11:59.606    29,871 kbps     01:11:59.606    29,151 kbps     01:12:44.109    137,029 bytes   824,018 bytes   01:03:20.338
9               1:16:50.397     0:08:59.664     26,914 kbps     37,845 kbps     01:19:28.805    30,657 kbps     01:16:54.192    29,403 kbps     01:20:15.143    140,318 bytes   828,990 bytes   01:16:56.403
10              1:25:50.061     0:08:41.103     27,633 kbps     31,558 kbps     01:29:24.484    29,344 kbps     01:29:24.484    28,908 kbps     01:29:19.437    144,065 bytes   524,809 bytes   01:26:42.113
11              1:34:31.165     0:17:43.270     26,544 kbps     34,869 kbps     01:47:03.708    30,203 kbps     01:42:18.715    29,046 kbps     01:46:45.482    138,389 bytes   912,490 bytes   01:42:38.902
12              1:52:14.436     0:09:13.386     25,622 kbps     35,486 kbps     01:53:15.497    31,083 kbps     01:57:24.412    29,977 kbps     01:57:23.411    133,583 bytes   811,076 bytes   01:54:55.179
13              2:01:27.822     0:03:03.391     27,535 kbps     37,922 kbps     02:01:28.364    31,442 kbps     02:01:27.947    29,857 kbps     02:01:27.947    143,589 bytes   877,634 bytes   02:01:28.447
STREAM DIAGNOSTICS:
00008.M2TS      4113 (0x1011)   0x1B            AVC                                     231.773                 25,861                  749,229,976     4,075,195
00008.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           231.773                 4,616                   133,736,848     741,952
00008.M2TS      4353 (0x1101)   0x80            LPCM            jpn (Japanese)          231.773                 1,543                   44,702,608      278,232
00008.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           231.773                 8                       228,427         1,335
00008.M2TS      6912 (0x1B00)   0x1B            AVC                                     231.773                 2,070                   59,969,551      329,186
00009.M2TS      4113 (0x1011)   0x1B            AVC                                     99.057                  27,606                  341,816,465     1,859,070
00009.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           99.057                  4,618                   57,186,836      317,264
00009.M2TS      4353 (0x1101)   0x80            LPCM            jpn (Japanese)          99.057                  1,544                   19,115,156      118,974
00009.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           99.057                  12                      148,885         853
00009.M2TS      6912 (0x1B00)   0x1B            AVC                                     99.057                  3,341                   41,374,637      226,169
00010.M2TS (1)  4113 (0x1011)   0x1B            AVC                                     99.057                  26,781                  331,609,266     1,803,616
00010.M2TS (1)  4352 (0x1100)   0x80            LPCM            eng (English)           99.057                  4,618                   57,186,836      317,264
00010.M2TS (1)  4353 (0x1101)   0x80            LPCM            jpn (Japanese)          99.057                  1,544                   19,115,156      118,974
00010.M2TS (1)  4608 (0x1200)   0x90            PGS             eng (English)           99.057                  12                      148,885         853
00010.M2TS (1)  6912 (0x1B00)   0x1B            AVC                                     99.057                  3,341                   41,374,637      226,169
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6956.700                26,218                  22,798,980,193  124,005,132
00011.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           6956.700                4,614                   4,012,696,660   22,261,840
00011.M2TS      4353 (0x1101)   0x80            LPCM            jpn (Japanese)          6956.700                1,542                   1,341,275,860   8,348,190
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6956.700                23                      20,071,364      116,210
00011.M2TS      6912 (0x1B00)   0x1B            AVC                                     6956.700                2,024                   1,759,753,035   9,643,458
00012.M2TS      4113 (0x1011)   0x1B            AVC                                     183.225                 27,594                  631,984,953     3,437,258
00012.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           183.225                 4,619                   105,782,236     586,864
00012.M2TS      4353 (0x1101)   0x80            LPCM            jpn (Japanese)          183.225                 1,544                   35,358,556      220,074
00012.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           183.225                 10                      234,899         1,327
00012.M2TS      6912 (0x1B00)   0x1B            AVC                                     183.225                 1,154                   26,437,120      146,383
00013.M2TS (1)  4113 (0x1011)   0x1B            AVC                                     183.225                 27,431                  628,255,872     3,416,942
00013.M2TS (1)  4352 (0x1100)   0x80            LPCM            eng (English)           183.225                 4,619                   105,782,236     586,864
00013.M2TS (1)  4353 (0x1101)   0x80            LPCM            jpn (Japanese)          183.225                 1,544                   35,358,556      220,074
00013.M2TS (1)  4608 (0x1200)   0x90            PGS             eng (English)           183.225                 10                      234,899         1,327
00013.M2TS (1)  6912 (0x1B00)   0x1B            AVC                                     183.225                 1,154                   26,437,120      146,383
Stephen Dawson
hifi-writer.com
post #2884 of 5106 Old 04-05-2011, 04:47 AM
Dark_zero's Avatar
The last emperor -ITA-
("L'Ultimo imperatore" in italian)
Released in Italy by Eagle Pictures with ENG and ITA in dts-hd HR 5.1 and dts-hd MA 2.0
Code:
        Total   Video
00010.MPLS                                                      VC-1    2:42:42 47.425.603.584  48.684.861.336  38,86   27,00   DTS-HD Hi-Res 5.1 3840Kbps (48kHz/16-bit) DTS-HD Master 2.0 911Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:
Disc Size:      48.684.861.336 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:42:42 (h:m:s)
Total Bitrate:          38,86 Mbps
VIDEO:
VC-1 Video              27001 kbps          1080p / 24 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD High-Res Audio           English         3840 kbps       5.1 / 48 kHz / 3840 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD High-Res Audio           Italian         3840 kbps       5.1 / 48 kHz / 3840 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             English         911 kbps        2.0 / 48 kHz / 911 kbps / 16-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 16-bit)
DTS-HD Master Audio             Italian         904 kbps        2.0 / 48 kHz / 904 kbps / 16-bit (DTS Core: 2.0 / 48 kHz / 768 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           Italian         18,720 kbps
Presentation Graphics           Italian         19,441 kbps
Presentation Graphics           Italian         16,677 kbps
FILES:
00017.M2TS      0:00:00.000     2:42:42.791     47.425.603.584  38.862
CHAPTERS:
1               0:00:00.000     0:08:52.208     19.928 kbps     42.934 kbps     00:07:11.708    38.406 kbps     00:08:26.750    34.377 kbps     00:08:21.750    103.781 bytes   358.809 bytes   00:07:12.750
2               0:08:52.208     0:12:11.250     29.519 kbps     53.832 kbps     00:15:31.500    40.370 kbps     00:14:08.041    37.697 kbps     00:16:23.125    153.744 bytes   640.226 bytes   00:14:50.041
3               0:21:03.458     0:09:07.708     29.847 kbps     50.897 kbps     00:25:32.958    40.490 kbps     00:27:54.666    37.670 kbps     00:27:54.833    155.455 bytes   712.198 bytes   00:27:40.166
4               0:30:11.166     0:09:34.250     29.387 kbps     52.975 kbps     00:39:43.875    40.066 kbps     00:33:13.041    37.765 kbps     00:37:14.791    153.057 bytes   688.034 bytes   00:33:03.416
5               0:39:45.416     0:17:09.500     29.320 kbps     50.955 kbps     00:45:39.125    40.496 kbps     00:45:55.791    37.799 kbps     00:55:09.583    152.709 bytes   693.587 bytes   00:51:53.083
6               0:56:54.916     0:06:03.875     27.239 kbps     52.372 kbps     01:00:49.708    40.546 kbps     01:02:14.958    37.644 kbps     01:00:43.291    141.872 bytes   642.159 bytes   01:00:54.291
7               1:02:58.791     0:10:15.875     26.418 kbps     48.274 kbps     01:06:32.583    40.136 kbps     01:03:39.541    37.732 kbps     01:03:33.916    137.594 bytes   552.364 bytes   01:03:15.958
8               1:13:14.666     0:09:23.250     25.073 kbps     53.149 kbps     01:20:28.708    39.909 kbps     01:18:31.458    37.717 kbps     01:18:45.625    130.587 bytes   540.591 bytes   01:20:19.958
9               1:22:37.916     0:12:02.375     26.695 kbps     54.854 kbps     01:22:39.041    39.094 kbps     01:24:45.666    37.687 kbps     01:22:38.791    139.034 bytes   655.427 bytes   01:23:04.041
10              1:34:40.291     0:08:00.916     21.737 kbps     39.466 kbps     01:37:06.250    35.416 kbps     01:37:06.250    34.159 kbps     01:37:05.750    113.215 bytes   359.942 bytes   01:34:46.083
11              1:42:41.208     0:07:29.166     28.487 kbps     49.319 kbps     01:50:08.541    40.542 kbps     01:46:04.791    37.456 kbps     01:49:46.833    148.370 bytes   487.500 bytes   01:50:08.041
12              1:50:10.375     0:11:48.916     26.212 kbps     46.713 kbps     01:52:54.583    40.289 kbps     01:50:33.458    37.746 kbps     01:50:30.416    136.521 bytes   662.589 bytes   01:52:52.208
13              2:01:59.291     0:07:26.333     26.836 kbps     45.285 kbps     02:08:19.833    39.215 kbps     02:08:12.041    37.654 kbps     02:08:07.833    139.771 bytes   542.178 bytes   02:08:23.875
14              2:09:25.625     0:11:03.833     23.265 kbps     45.428 kbps     02:16:33.208    40.667 kbps     02:16:27.208    37.531 kbps     02:12:58.416    121.173 bytes   512.071 bytes   02:13:08.458
15              2:20:29.458     0:07:58.458     27.994 kbps     48.823 kbps     02:24:46.375    39.618 kbps     02:27:37.666    37.573 kbps     02:22:23.583    145.800 bytes   576.546 bytes   02:25:49.375
16              2:28:27.916     0:14:14.875     30.143 kbps     49.222 kbps     02:37:15.708    40.148 kbps     02:35:17.541    37.803 kbps     02:28:44.083    157.009 bytes   653.238 bytes   02:37:08.958
STREAM DIAGNOSTICS:
00017.M2TS      4113 (0x1011)   0xEA            VC-1                                    9762,708                27.001                  32.950.311.910  179.218.440
00017.M2TS      4352 (0x1100)   0x86            DTS-HD MA       ita (Italian)           9762,708                904                     1.103.386.700   6.964.551
00017.M2TS      4353 (0x1101)   0x85            DTS-HD HR       ita (Italian)           9762,708                3.840                   4.686.141.440   26.542.598
00017.M2TS      4354 (0x1102)   0x86            DTS-HD MA       eng (English)           9762,708                911                     1.112.064.888   7.027.251
00017.M2TS      4355 (0x1103)   0x85            DTS-HD HR       eng (English)           9762,708                3.840                   4.686.141.440   26.542.598
00017.M2TS      4608 (0x1200)   0x90            PGS             ita (Italian)           9762,708                19                      22.844.585      131.421
00017.M2TS      4609 (0x1201)   0x90            PGS             ita (Italian)           9762,708                19                      23.725.159      136.556
00017.M2TS      4610 (0x1202)   0x90            PGS             ita (Italian)           9762,708                17                      20.351.569      117.838
Dont know why, but im not been able to make screenshoots via Kmplayer nor via Media Player Classic Home Cinema
Dark_zero is offline
post #2885 of 5106 Old 04-05-2011, 10:47 AM
hlwl's Avatar
^Whats the aspect ratio on the Italian release?
hlwl is offline
post #2886 of 5106 Old 04-05-2011, 01:32 PM
squallmx's Avatar
[MX] The Karate Kid (2010)
Released By: Sony Pictures Home Entertainment Mexico
Region: A, B, C
Aspect Ratio: 2.39
Format: 1 BD50 + 1 DVD9
Code:
        Total   Video
00001.MPLS                                                      AVC     2:20:01 32,637,708,288  45,905,645,960  31.08   22.95   DTS-HD Master 5.1 2211Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     THE_KARATE_KID
Disc Size:      45,905,645,960 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:20:01 (h:m:s)
Total Bitrate:          31.08 Mbps
VIDEO:
MPEG-4 AVC Video        22951 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2211 kbps       5.1 / 48 kHz / 2211 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
DTS-HD Master Audio             Portuguese      2601 kbps       5.1 / 48 kHz / 2601 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Thai            640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         17.711 kbps
Presentation Graphics           Spanish         16.625 kbps
Presentation Graphics           Portuguese      15.171 kbps
Presentation Graphics           Chinese         13.984 kbps
Presentation Graphics           Indonesian      20.292 kbps
Presentation Graphics           Korean          9.792 kbps
Presentation Graphics           Thai            13.437 kbps
FILES:
00011.M2TS      0:00:00.000     2:20:01.393     32,637,708,288  31,078
CHAPTERS:
1               0:00:00.000     0:10:26.250     22,384 kbps     38,136 kbps     00:00:36.953    30,249 kbps     00:06:50.952    28,372 kbps     00:05:47.972    116,691 bytes   612,242 bytes   00:10:03.644
2               0:10:26.250     0:04:40.071     23,147 kbps     34,757 kbps     00:13:31.560    28,895 kbps     00:13:27.556    27,559 kbps     00:13:27.181    120,679 bytes   634,826 bytes   00:14:04.385
3               0:15:06.322     0:09:20.893     23,557 kbps     34,191 kbps     00:19:19.992    28,299 kbps     00:19:03.892    27,757 kbps     00:18:56.844    122,816 bytes   582,313 bytes   00:20:49.498
4               0:24:27.215     0:15:22.087     22,715 kbps     32,565 kbps     00:37:04.597    28,164 kbps     00:37:01.052    26,401 kbps     00:34:53.049    118,424 bytes   654,755 bytes   00:27:55.965
5               0:39:49.303     0:10:03.102     23,668 kbps     36,815 kbps     00:46:00.382    28,849 kbps     00:41:38.454    27,834 kbps     00:41:04.920    123,394 bytes   523,176 bytes   00:39:51.764
6               0:49:52.406     0:05:02.593     22,009 kbps     32,770 kbps     00:54:35.814    29,187 kbps     00:54:47.617    26,081 kbps     00:54:42.696    114,744 bytes   472,165 bytes   00:54:00.904
7               0:54:55.000     0:09:42.623     22,559 kbps     37,123 kbps     01:00:14.360    31,382 kbps     01:00:19.032    31,172 kbps     01:00:14.027    117,611 bytes   590,137 bytes   00:57:01.835
8               1:04:37.623     0:05:09.434     24,293 kbps     35,536 kbps     01:04:58.477    29,878 kbps     01:04:54.849    29,361 kbps     01:04:51.095    126,653 bytes   556,394 bytes   01:05:19.373
9               1:09:47.057     0:10:37.511     23,363 kbps     35,564 kbps     01:17:26.224    29,275 kbps     01:17:39.154    28,694 kbps     01:15:25.729    121,802 bytes   657,124 bytes   01:14:23.542
10              1:20:24.569     0:10:18.909     22,916 kbps     35,210 kbps     01:28:52.368    33,676 kbps     01:28:52.368    30,551 kbps     01:28:47.989    119,475 bytes   613,180 bytes   01:28:29.554
11              1:30:43.479     0:11:00.618     22,413 kbps     35,184 kbps     01:31:54.717    28,865 kbps     01:37:03.734    27,167 kbps     01:37:10.366    116,851 bytes   524,027 bytes   01:31:16.512
12              1:41:44.098     0:05:13.563     23,106 kbps     34,721 kbps     01:46:29.674    27,422 kbps     01:45:24.401    26,564 kbps     01:45:24.776    120,466 bytes   594,143 bytes   01:45:49.760
13              1:46:57.661     0:03:26.915     22,088 kbps     33,999 kbps     01:47:26.231    28,663 kbps     01:47:26.189    26,982 kbps     01:47:23.728    115,158 bytes   540,665 bytes   01:49:14.047
14              1:50:24.576     0:08:35.097     25,179 kbps     41,047 kbps     01:55:19.621    30,329 kbps     01:52:43.923    28,034 kbps     01:52:42.464    131,269 bytes   543,244 bytes   01:56:45.748
15              1:58:59.674     0:04:57.505     24,645 kbps     37,701 kbps     02:00:41.067    29,358 kbps     02:00:40.358    28,022 kbps     02:00:21.130    128,486 bytes   488,413 bytes   02:01:54.181
16              2:03:57.179     0:16:04.213     21,330 kbps     43,109 kbps     02:14:06.079    28,482 kbps     02:14:06.079    27,064 kbps     02:06:51.937    111,207 bytes   552,726 bytes   02:16:30.640
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     8401.268                22,951                  24,102,469,137  131,110,387
00011.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           8401.268                2,211                   2,321,929,932   13,969,846
00011.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           8401.268                640                     672,112,640     3,938,160
00011.M2TS      4354 (0x1102)   0x86            DTS-HD MA       por (Portuguese)        8401.268                2,601                   2,731,381,584   16,090,824
00011.M2TS      4355 (0x1103)   0x81            AC3             tha (Thai)              8401.268                640                     672,112,640     3,938,160
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8401.268                18                      18,599,943      108,211
00011.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           8401.268                17                      17,459,046      101,815
00011.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        8401.268                15                      15,932,172      93,582
00011.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           8401.268                14                      14,685,934      87,044
00011.M2TS      4612 (0x1204)   0x90            PGS             ind (Indonesian)        8401.268                20                      21,310,179      121,459
00011.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            8401.268                10                      10,282,851      63,279
00011.M2TS      4614 (0x1206)   0x90            PGS             tha (Thai)              8401.268                13                      14,111,586      83,804
Portuguese track is actually 16 bit padded to 24.
squallmx is offline
post #2887 of 5106 Old 04-05-2011, 01:38 PM
squallmx's Avatar
[MX] TRON: Legacy
Released By: Disney Latino
Region: A, B, C
Format: 1 BD50 + DVD9
Code:
        Total   Video
00532.MPLS                                                      AVC     2:05:08 31,818,756,096  43,406,524,068  33.90   24.28   DTS-HD Master 7.1 5731Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TRON LEGACY
Disc Size:      43,406,524,068 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:05:08 (h:m:s)
Total Bitrate:          33.90 Mbps
VIDEO:
MPEG-4 AVC Video        24283 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         5731 kbps       7.1 / 48 kHz / 5731 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         320 kbps        2.0 / 48 kHz / 320 kbps / Dolby Surround
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         24.244 kbps
Presentation Graphics           French          22.288 kbps
Presentation Graphics           Spanish         20.166 kbps
Presentation Graphics           French          0.114 kbps
Presentation Graphics           Spanish         0.056 kbps
FILES:
00005.M2TS      0:00:00.000     2:05:08.672     31,818,756,096  33,901
CHAPTERS:
1               0:00:00.000     0:04:07.163     27,449 kbps     32,347 kbps     00:00:56.681    30,951 kbps     00:01:50.110    30,672 kbps     00:01:47.732    143,081 bytes   233,088 bytes   00:00:57.265
2               0:04:07.163     0:10:36.970     24,987 kbps     31,780 kbps     00:05:17.734    31,102 kbps     00:05:10.810    30,963 kbps     00:05:05.972    130,271 bytes   252,552 bytes   00:05:08.099
3               0:14:44.133     0:08:31.469     24,093 kbps     32,730 kbps     00:23:00.921    29,762 kbps     00:22:59.044    28,345 kbps     00:18:45.666    125,610 bytes   523,989 bytes   00:23:14.559
4               0:23:15.602     0:03:37.091     23,995 kbps     31,108 kbps     00:26:03.979    30,866 kbps     00:26:00.141    28,755 kbps     00:25:20.810    125,101 bytes   201,088 bytes   00:26:01.393
5               0:26:52.694     0:09:19.516     23,930 kbps     33,047 kbps     00:34:43.498    30,977 kbps     00:36:01.576    29,917 kbps     00:35:58.531    124,762 bytes   264,714 bytes   00:31:04.779
6               0:36:12.210     0:02:23.769     24,046 kbps     30,015 kbps     00:37:26.619    29,204 kbps     00:37:23.115    28,068 kbps     00:37:23.115    125,363 bytes   215,630 bytes   00:36:26.183
7               0:38:35.980     0:08:16.746     24,027 kbps     31,168 kbps     00:43:12.172    29,636 kbps     00:43:08.919    27,706 kbps     00:43:09.670    125,265 bytes   245,859 bytes   00:46:31.747
8               0:46:52.726     0:06:11.036     23,981 kbps     33,420 kbps     00:47:57.749    29,942 kbps     00:47:53.745    28,944 kbps     00:49:03.398    125,024 bytes   207,771 bytes   00:51:58.490
9               0:53:03.763     0:11:50.417     23,805 kbps     31,195 kbps     01:04:16.811    30,932 kbps     01:04:13.891    30,905 kbps     01:04:10.805    124,107 bytes   294,090 bytes   00:57:34.409
10              1:04:54.180     0:08:53.240     24,084 kbps     32,662 kbps     01:04:57.393    29,545 kbps     01:05:50.863    29,240 kbps     01:05:49.236    125,565 bytes   388,581 bytes   01:05:00.104
11              1:13:47.421     0:05:13.522     24,257 kbps     31,965 kbps     01:16:18.073    29,840 kbps     01:17:35.817    29,166 kbps     01:17:37.152    126,463 bytes   207,927 bytes   01:16:18.699
12              1:19:00.944     0:03:39.510     23,994 kbps     30,961 kbps     01:20:39.334    29,685 kbps     01:21:29.259    28,283 kbps     01:21:25.005    125,092 bytes   278,819 bytes   01:21:34.180
13              1:22:40.455     0:03:10.440     23,994 kbps     31,142 kbps     01:23:46.146    30,373 kbps     01:23:43.351    29,273 kbps     01:25:08.895    125,092 bytes   210,894 bytes   01:23:46.396
14              1:25:50.895     0:02:20.933     24,079 kbps     31,007 kbps     01:26:06.369    30,663 kbps     01:26:02.907    28,516 kbps     01:26:01.489    125,536 bytes   218,586 bytes   01:27:17.607
15              1:28:11.828     0:03:30.584     24,181 kbps     30,680 kbps     01:31:36.365    29,736 kbps     01:31:33.404    27,640 kbps     01:29:35.703    126,067 bytes   222,269 bytes   01:31:33.487
16              1:31:42.412     0:11:30.648     24,068 kbps     31,971 kbps     01:40:26.979    30,986 kbps     01:32:13.486    30,643 kbps     01:32:09.106    125,478 bytes   329,940 bytes   01:40:30.691
17              1:43:13.061     0:05:04.972     24,326 kbps     29,957 kbps     01:46:39.100    29,016 kbps     01:45:59.644    27,653 kbps     01:45:57.309    126,823 bytes   254,304 bytes   01:47:53.884
18              1:48:18.033     0:06:30.347     24,314 kbps     32,742 kbps     01:54:42.250    31,154 kbps     01:54:38.246    30,039 kbps     01:54:36.869    126,761 bytes   437,012 bytes   01:53:49.155
19              1:54:48.381     0:03:15.277     24,619 kbps     32,321 kbps     01:57:10.940    30,979 kbps     01:56:29.232    30,735 kbps     01:54:49.882    128,354 bytes   235,866 bytes   01:56:33.861
20              1:58:03.659     0:07:05.012     24,478 kbps     32,048 kbps     01:59:39.046    30,415 kbps     01:59:35.042    29,113 kbps     02:00:32.767    127,630 bytes   386,798 bytes   02:03:21.727
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     7508.584                24,284                  22,791,944,036  123,977,218
00005.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7508.584                5,731                   5,379,353,520   30,404,518
00005.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           7508.584                320                     300,346,880     1,877,168
00005.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           7508.584                320                     300,346,880     1,877,168
00005.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            7508.584                640                     600,693,760     3,519,690
00005.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           7508.584                640                     600,693,760     3,519,690
00005.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7508.584                24                      22,754,722      131,831
00005.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7508.584                22                      20,918,977      120,829
00005.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           7508.584                20                      18,927,417      109,317
00005.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            7508.584                0                       106,795         607
00005.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           7508.584                0                       53,003          321
Most likely identical to the US edition (minus digital copy).
squallmx is offline
post #2888 of 5106 Old 04-05-2011, 07:53 PM
McCrutchy's Avatar
Batman Beyond: Return of the Joker (2000) (Additional Details)
Studio: Warner Bros.
Release Date: 2011-04-05
UPC: 883929159543
Region ABC (Confirmed by my own standalone Panasionic DMP-BD35 Multiregion and Region A BD-RE drive with AnyDVD HD).
The DVD is marked Region 1, but is actually coded for DVD regions 1, 2, 3 and 4 (NTSC).
Both the Blu-ray and the DVD are the uncut US PG-13-rated version. The BD is presented in 1080p 4:3 open-matte, while the included DVD is the same as the original 2002 DVD (2002 .VOB files), presented in non-anamorphic widescreen matted from the 4:3 master. All subtitles are in white font.
English DD 2.0 is an audio commentary with producer Bruce Timm, screenwriter Paul Dini, art director Glen Murakami and director Curt Geda.
Extra features and audio commentary are duplicated from the DVD in 480i AVC/VC-1 with the addition of some new HD trailers; not all extras are subtitled.
Code:
        Total   Video
00100.MPLS                                                      AVC     1:16:45 14,823,886,848  16,900,802,527  25.75   19.56   DTS-HD Master 5.1 3521Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BATMAN_BEYOND_RETURN_OF_JOKER
Disc Size:      16,900,802,527 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 1:16:45 (h:m:s)
Total Bitrate:          25.75 Mbps
VIDEO:
MPEG-4 AVC Video        19557 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3521 kbps       5.1 / 48 kHz / 3521 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
Dolby Digital Audio             French          192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
Dolby Digital Audio             German          192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Swedish         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         27.777 kbps
Presentation Graphics           French          23.134 kbps
Presentation Graphics           German          32.513 kbps
Presentation Graphics           German          0.800 kbps
Presentation Graphics           Spanish         26.317 kbps
Presentation Graphics           Swedish         27.296 kbps
Presentation Graphics           Swedish         0.696 kbps
FILES:
00042.M2TS      0:00:00.000     1:16:45.934     14,823,886,848  25,747
CHAPTERS:
1               0:00:00.000     0:08:09.488     17,046 kbps     45,890 kbps     00:06:38.147    25,048 kbps     00:01:47.565    23,307 kbps     00:01:47.649    88,862 bytes    501,063 bytes   00:01:12.864
2               0:08:09.488     0:02:21.641     20,085 kbps     30,594 kbps     00:08:33.012    24,574 kbps     00:08:29.717    23,221 kbps     00:08:24.712    104,715 bytes   419,783 bytes   00:09:03.960
3               0:10:31.130     0:01:12.572     20,847 kbps     27,794 kbps     00:10:54.904    22,545 kbps     00:10:53.569    21,629 kbps     00:11:08.751    108,685 bytes   588,069 bytes   00:11:43.703
4               0:11:43.703     0:02:52.589     20,265 kbps     34,976 kbps     00:11:44.954    23,452 kbps     00:11:44.453    21,756 kbps     00:11:44.954    105,654 bytes   588,074 bytes   00:11:44.495
5               0:14:36.292     0:05:17.900     20,048 kbps     30,355 kbps     00:19:28.542    22,636 kbps     00:18:10.923    21,661 kbps     00:18:08.086    104,523 bytes   510,982 bytes   00:15:58.207
6               0:19:54.193     0:01:19.204     19,755 kbps     24,180 kbps     00:21:09.309    21,088 kbps     00:20:40.656    20,295 kbps     00:20:55.128    102,993 bytes   302,713 bytes   00:21:13.397
7               0:21:13.397     0:02:58.219     19,849 kbps     27,155 kbps     00:21:21.029    21,289 kbps     00:23:07.677    20,578 kbps     00:23:07.761    103,482 bytes   426,406 bytes   00:23:22.150
8               0:24:11.616     0:00:54.846     19,999 kbps     34,944 kbps     00:24:12.159    22,710 kbps     00:24:12.200    21,228 kbps     00:24:12.117    104,264 bytes   394,480 bytes   00:24:13.910
9               0:25:06.463     0:05:28.369     20,338 kbps     35,851 kbps     00:29:15.754    24,724 kbps     00:29:15.545    22,972 kbps     00:25:48.505    106,033 bytes   666,373 bytes   00:27:28.563
10              0:30:34.832     0:03:36.674     20,263 kbps     28,001 kbps     00:31:53.870    26,629 kbps     00:32:41.042    26,541 kbps     00:32:40.166    105,642 bytes   556,544 bytes   00:30:35.625
11              0:34:11.507     0:10:51.233     20,251 kbps     32,413 kbps     00:35:23.121    25,336 kbps     00:35:23.162    23,039 kbps     00:35:23.079    105,577 bytes   499,066 bytes   00:34:59.222
12              0:45:02.741     0:01:08.818     19,790 kbps     26,388 kbps     00:45:07.204    22,559 kbps     00:46:01.759    20,979 kbps     00:45:59.673    103,179 bytes   362,580 bytes   00:46:10.851
13              0:46:11.560     0:01:41.267     20,000 kbps     38,124 kbps     00:46:26.450    24,330 kbps     00:46:26.450    22,058 kbps     00:46:26.742    104,273 bytes   504,897 bytes   00:47:38.313
14              0:47:52.828     0:03:34.005     20,123 kbps     32,616 kbps     00:50:15.804    22,825 kbps     00:50:30.736    21,437 kbps     00:50:15.762    104,912 bytes   414,723 bytes   00:51:16.782
15              0:51:26.833     0:02:18.596     19,665 kbps     29,243 kbps     00:51:34.216    22,115 kbps     00:53:40.425    20,798 kbps     00:52:23.014    102,526 bytes   509,122 bytes   00:53:04.514
16              0:53:45.430     0:05:55.855     20,212 kbps     36,371 kbps     00:55:54.142    24,816 kbps     00:55:54.142    22,135 kbps     00:58:09.527    105,375 bytes   489,158 bytes   00:53:47.057
17              0:59:41.286     0:11:54.422     19,980 kbps     41,653 kbps     01:05:41.479    26,271 kbps     01:11:04.843    24,776 kbps     01:11:04.843    104,165 bytes   510,526 bytes   01:05:35.806
18              1:11:35.708     0:05:10.226     16,644 kbps     35,832 kbps     01:16:41.013    27,751 kbps     01:13:49.091    25,164 kbps     01:13:47.840    86,797 bytes    717,631 bytes   01:16:43.640
STREAM DIAGNOSTICS:
00042.M2TS      4113 (0x1011)   0x1B            AVC                                     4605.851                19,557                  11,259,661,787  61,258,293
00042.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4605.851                3,521                   2,027,334,156   11,736,136
00042.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            4605.851                192                     110,565,888     719,830
00042.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            4605.851                192                     110,565,888     719,830
00042.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           4605.851                192                     110,565,888     719,830
00042.M2TS      4356 (0x1104)   0x81            AC3             swe (Swedish)           4605.851                192                     110,565,888     719,830
00042.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           4605.851                192                     110,565,888     719,830
00042.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4605.851                28                      15,992,366      92,570
00042.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            4605.851                23                      13,319,079      77,132
00042.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            4605.851                33                      18,719,187      107,402
00042.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           4605.851                26                      15,151,891      87,331
00042.M2TS      4612 (0x1204)   0x90            PGS             swe (Swedish)           4605.851                27                      15,715,201      90,331
00042.M2TS      4613 (0x1205)   0x90            PGS             deu (German)            4605.851                1                       460,589         2,678
00042.M2TS      4614 (0x1206)   0x90            PGS             swe (Swedish)           4605.851                1                       400,915         2,354
Video Bitrate: 5-Second Window
Video Bitrate: 10-Second Window
Video Frame Size (Min / Max)
Video Frame Type Counts
Video Frame Type Sizes
McCrutchy is offline
post #2889 of 5106 Old 04-05-2011, 09:24 PM
msgohan's Avatar
Not to worry; no need to import as it's also cropped.
Above, nice to see good old Warner never changes even when they do an AVC with a beefy soundtrack. Disc over 1/4 empty.
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #2890 of 5106 Old 04-06-2011, 03:41 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Black Swan - 2010 - US - Fox - Region AB
Code:
        Total   Video
00800.MPLS                                                      AVC     1:48:07 28,305,788,928  42,590,822,636  34.90   28.50   DTS-HD Master 5.1 3622Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BLACK_SWAN
Disc Size:      42,590,822,636 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 1:48:07 (h:m:s)
Total Bitrate:          34.90 Mbps
VIDEO:
MPEG-4 AVC Video        28504 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3622 kbps       5.1 / 48 kHz / 3622 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps
SUBTITLES:
Presentation Graphics           English         26.166 kbps
Presentation Graphics           French          0.146 kbps
Presentation Graphics           Spanish         18.323 kbps
FILES:
00800.M2TS      0:00:00.000     1:48:07.522     28,305,788,928  34,905
CHAPTERS:
1               0:00:00.000     0:06:18.044     26,382 kbps     39,752 kbps     00:02:32.694    35,487 kbps     00:03:32.754    35,397 kbps     00:03:27.874    137,529 bytes   376,110 bytes   00:00:41.666
2               0:06:18.044     0:06:36.687     30,134 kbps     37,005 kbps     00:07:20.148    35,474 kbps     00:06:50.785    35,385 kbps     00:06:24.467    157,102 bytes   268,848 bytes   00:10:01.684
3               0:12:54.732     0:03:40.345     29,822 kbps     35,659 kbps     00:14:07.930    34,466 kbps     00:12:59.278    33,721 kbps     00:12:54.815    155,479 bytes   233,242 bytes   00:13:59.088
4               0:16:35.077     0:02:31.609     28,423 kbps     37,679 kbps     00:19:02.391    31,390 kbps     00:17:32.092    30,948 kbps     00:17:29.548    148,185 bytes   432,010 bytes   00:19:03.100
5               0:19:06.687     0:02:46.332     26,853 kbps     30,238 kbps     00:19:13.443    29,937 kbps     00:19:13.527    29,633 kbps     00:19:08.647    140,001 bytes   227,449 bytes   00:20:35.901
6               0:21:53.020     0:04:40.571     28,920 kbps     34,709 kbps     00:25:02.000    32,671 kbps     00:25:28.401    32,385 kbps     00:25:23.313    150,775 bytes   230,725 bytes   00:24:49.488
7               0:26:33.592     0:03:10.273     28,827 kbps     33,129 kbps     00:27:32.233    32,627 kbps     00:27:05.540    32,584 kbps     00:27:00.827    150,291 bytes   232,043 bytes   00:27:34.653
8               0:29:43.865     0:02:34.946     28,708 kbps     31,664 kbps     00:30:46.761    31,151 kbps     00:30:46.010    30,863 kbps     00:31:47.238    149,669 bytes   241,783 bytes   00:30:27.283
9               0:32:18.811     0:03:47.060     29,507 kbps     34,373 kbps     00:33:41.769    32,129 kbps     00:32:33.493    31,461 kbps     00:34:49.212    153,834 bytes   241,383 bytes   00:33:45.273
10              0:36:05.872     0:04:36.734     27,712 kbps     32,947 kbps     00:40:18.582    32,454 kbps     00:40:14.578    32,265 kbps     00:40:09.573    144,478 bytes   234,149 bytes   00:40:18.791
11              0:40:42.606     0:03:09.522     28,015 kbps     36,006 kbps     00:42:23.082    32,096 kbps     00:42:31.674    31,216 kbps     00:42:29.213    146,059 bytes   259,621 bytes   00:41:24.982
12              0:43:52.129     0:02:47.709     26,886 kbps     31,609 kbps     00:44:02.681    29,683 kbps     00:45:36.650    29,292 kbps     00:45:31.812    140,171 bytes   220,247 bytes   00:44:03.265
13              0:46:39.838     0:02:53.840     30,343 kbps     34,572 kbps     00:48:13.682    33,948 kbps     00:48:13.015    33,869 kbps     00:48:05.716    158,197 bytes   238,501 bytes   00:48:21.899
14              0:49:33.679     0:03:04.809     29,142 kbps     35,656 kbps     00:51:41.306    35,333 kbps     00:51:46.520    35,118 kbps     00:51:41.306    151,934 bytes   251,849 bytes   00:51:38.929
15              0:52:38.488     0:03:09.397     27,287 kbps     34,071 kbps     00:55:27.323    33,577 kbps     00:55:21.693    32,731 kbps     00:55:21.568    142,260 bytes   235,700 bytes   00:55:47.886
16              0:55:47.886     0:02:35.989     29,048 kbps     32,264 kbps     00:57:09.134    31,571 kbps     00:56:00.815    31,549 kbps     00:55:55.810    151,441 bytes   243,141 bytes   00:55:59.898
17              0:58:23.875     0:08:32.220     27,747 kbps     34,286 kbps     01:01:08.539    31,934 kbps     01:01:05.995    31,442 kbps     01:01:00.823    144,658 bytes   362,059 bytes   01:05:11.157
18              1:06:56.095     0:03:19.699     30,202 kbps     36,335 kbps     01:10:12.917    33,926 kbps     01:08:13.631    33,191 kbps     01:08:11.003    157,459 bytes   247,436 bytes   01:08:15.007
19              1:10:15.794     0:03:10.690     28,309 kbps     32,489 kbps     01:10:57.920    31,644 kbps     01:10:15.794    30,933 kbps     01:10:15.794    147,589 bytes   242,540 bytes   01:10:56.460
20              1:13:26.485     0:05:01.884     28,802 kbps     34,363 kbps     01:13:46.922    32,114 kbps     01:15:39.326    31,700 kbps     01:15:39.368    150,158 bytes   267,665 bytes   01:13:27.486
21              1:18:28.370     0:04:21.427     28,695 kbps     33,547 kbps     01:18:33.583    33,049 kbps     01:19:14.249    32,814 kbps     01:19:11.413    149,602 bytes   242,785 bytes   01:19:12.914
22              1:22:49.798     0:02:41.995     27,022 kbps     37,347 kbps     01:25:27.205    31,106 kbps     01:24:41.910    30,547 kbps     01:24:36.946    140,879 bytes   399,196 bytes   01:25:27.705
23              1:25:31.793     0:03:08.771     29,906 kbps     33,455 kbps     01:26:37.775    32,411 kbps     01:28:01.734    32,251 kbps     01:27:56.521    155,915 bytes   235,391 bytes   01:27:03.551
24              1:28:40.565     0:04:12.669     26,309 kbps     35,681 kbps     01:30:02.105    34,775 kbps     01:29:59.268    33,661 kbps     01:29:56.516    137,163 bytes   244,815 bytes   01:29:56.974
25              1:32:53.234     0:01:41.810     30,865 kbps     34,422 kbps     01:33:36.027    32,671 kbps     01:34:20.780    32,567 kbps     01:34:20.863    160,915 bytes   237,664 bytes   01:34:35.044
26              1:34:35.044     0:03:12.400     28,682 kbps     35,798 kbps     01:36:26.113    35,263 kbps     01:36:22.860    34,273 kbps     01:36:18.022    149,535 bytes   278,476 bytes   01:36:16.729
27              1:37:47.444     0:05:10.351     29,242 kbps     35,764 kbps     01:42:00.572    35,390 kbps     01:41:56.568    34,500 kbps     01:41:56.235    152,455 bytes   487,530 bytes   01:42:54.626
28              1:42:57.796     0:05:09.726     28,432 kbps     39,223 kbps     01:44:11.286    36,101 kbps     01:44:07.282    35,551 kbps     01:44:18.919    148,250 bytes   640,765 bytes   01:44:04.696
STREAM DIAGNOSTICS:
00800.M2TS      4113 (0x1011)   0x1B            AVC                                     6487.439                28,504                  23,114,917,156  125,715,824
00800.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6487.439                3,622                   2,936,825,536   16,971,917
00800.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           6487.439                448                     363,302,912     2,027,360
00800.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6487.439                448                     363,302,912     2,027,360
00800.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6487.439                26                      21,219,054      123,704
00800.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6487.439                18                      14,858,580      86,743
00800.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6487.439                0                       118,738         685
paku is offline
post #2891 of 5106 Old 04-06-2011, 04:51 AM
Dark_zero's Avatar
its still the one approved by Storaro
post #2892 of 5106 Old 04-06-2011, 07:19 PM
McCrutchy's Avatar
Rush: Moving Pictures (1981) (Blu-ray Album) (Additional Details)
Studio: Mercury/UMG
UPC: 602527636986
Blu-ray of the Moving Pictures (1981) album. Contains the original seven album tracks, three music videos ("Tom Sawyer", "Limelight" and "Vital Signs") and a photo gallery. All three audio options are available on all the tracks and the three videos.
The music videos have been upscaled to a 1080i 29.970fps image. The static menus are 1080p.
The presentation graphics are optional English lyrics for the audio tracks.
Also contains a CD of the remastered album tracks.
Code:
        Total   Video
00003.MPLS                                                      AVC     0:40:09 13,573,103,616  19,033,156,812  45.06   15.00   LPCM 5.1 13824Kbps (96kHz/24-bit)         DTS-HD Master 5.1 9019Kbps (96kHz/24-bit)
Code:
DISC INFO:
Disc Title:     Rush - Moving Pictures
Disc Size:      19,033,156,812 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 0:40:09 (h:m:s)
Total Bitrate:          45.06 Mbps
VIDEO:
MPEG-4 AVC Video        15001 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         13824 kbps      5.1 / 96 kHz / 13824 kbps / 24-bit
DTS-HD Master Audio             English         9019 kbps       5.1 / 96 kHz / 9019 kbps / 24-bit (DTS Core: 6.1 / 48 kHz / 1509 kbps / 24-bit)
LPCM Audio                      English         4608 kbps       2.0 / 96 kHz / 4608 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         5.704 kbps
FILES:
00003.M2TS      0:00:00.000     0:40:09.990     13,573,103,616  45,056
CHAPTERS:
1               0:00:00.000     0:04:38.653     15,003 kbps     15,340 kbps     00:00:02.669    15,069 kbps     00:00:00.500    15,001 kbps     00:00:05.630    78,208 bytes    120,648 bytes   00:00:03.670
2               0:04:38.653     0:06:10.370     15,001 kbps     15,248 kbps     00:04:45.201    15,050 kbps     00:04:41.197    15,001 kbps     00:06:07.158    78,208 bytes    109,137 bytes   00:04:46.202
3               0:10:49.023     0:04:25.932     15,001 kbps     15,146 kbps     00:10:52.026    15,030 kbps     00:10:49.815    15,001 kbps     00:12:19.864    78,208 bytes    96,312 bytes    00:10:53.027
4               0:15:14.955     0:04:24.013     15,001 kbps     15,198 kbps     00:15:16.290    15,040 kbps     00:15:15.915    15,001 kbps     00:15:20.961    78,208 bytes    102,859 bytes   00:15:17.291
5               0:19:38.969     0:10:56.530     15,001 kbps     15,261 kbps     00:19:40.470    15,053 kbps     00:19:40.095    15,001 kbps     00:24:46.276    78,208 bytes    110,723 bytes   00:19:41.471
6               0:30:35.500     0:04:48.454     15,001 kbps     15,001 kbps     00:30:36.292    15,001 kbps     00:30:36.292    15,001 kbps     00:30:36.292    78,208 bytes    78,208 bytes    00:30:35.542
7               0:35:23.955     0:04:44.033     15,001 kbps     15,001 kbps     00:35:24.413    15,001 kbps     00:35:24.413    15,001 kbps     00:35:24.413    78,208 bytes    78,208 bytes    00:35:23.996
8               0:40:07.988     0:00:02.002     14,688 kbps     15,001 kbps     00:40:08.823    0 kbps          00:00:00.000    0 kbps          00:00:00.000    78,208 bytes    78,208 bytes    00:40:08.072
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     2409.908                15,001                  4,519,004,261   24,615,121
00003.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2409.908                9,019                   2,716,900,540   15,140,997
00003.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           2409.908                4,610                   1,388,828,656   7,705,014
00003.M2TS      4354 (0x1102)   0x80            LPCM            eng (English)           2409.908                13,818                  4,162,633,456   23,115,040
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2409.908                6                       1,718,379       9,752
post #2893 of 5106 Old 04-06-2011, 07:40 PM - Thread Starter
Cinema Squid's Avatar
[US] Network (Additional Details)
Region Free (ABC) (Confirmed w/ PowerDVD set to all three regions)
Studio: Warner
UPC: 883929160730
Release Date: 2011-02-15
Aspect Ratio: 1.78:1
English DD 1.0 is a commentary.
Code:
        Total   Video
[US] Network                                                    AVC     2:01:20 19,120,478,208  25,341,980,580  21.01   17.97   DTS-HD Master 1.0 1108Kbps (48kHz/24-bit) DD AC3 1.0 192Kbps
Code:
DISC INFO:
Disc Title:     NETWORK
Disc Size:      25,341,980,580 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 2:01:20 (h:m:s)
Total Bitrate:          21.01 Mbps
VIDEO:
MPEG-4 AVC Video        17966 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1108 kbps       1.0 / 48 kHz / 1108 kbps / 24-bit (DTS Core: 1.0 / 48 kHz / 768 kbps / 24-bit)
Dolby Digital Audio             French          192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Spanish         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         56.396 kbps
Presentation Graphics           French          50.095 kbps
Presentation Graphics           Spanish         51.606 kbps
FILES:
00020.M2TS      0:00:00.000     2:01:20.314     19,120,478,208  21,011
CHAPTERS:
1               0:00:00.000     0:02:21.891     18,107 kbps     27,188 kbps     00:00:03.336    23,093 kbps     00:01:31.591    22,692 kbps     00:01:24.876    94,373 bytes    278,433 bytes   00:02:18.513
2               0:02:21.891     0:01:20.830     17,013 kbps     24,796 kbps     00:03:32.587    20,796 kbps     00:03:32.587    19,662 kbps     00:03:32.587    88,699 bytes    335,944 bytes   00:03:35.089
3               0:03:42.722     0:02:30.275     17,814 kbps     24,191 kbps     00:04:26.683    21,250 kbps     00:03:45.058    20,283 kbps     00:03:45.141    92,874 bytes    272,073 bytes   00:04:45.910
4               0:06:12.997     0:06:53.538     17,204 kbps     26,816 kbps     00:09:51.882    24,728 kbps     00:09:47.878    23,385 kbps     00:09:42.873    89,693 bytes    331,082 bytes   00:09:52.216
5               0:13:06.535     0:03:12.066     21,680 kbps     28,530 kbps     00:14:15.104    24,288 kbps     00:16:11.261    23,982 kbps     00:16:08.550    113,032 bytes   368,414 bytes   00:14:15.312
6               0:16:18.602     0:01:43.812     17,829 kbps     24,048 kbps     00:16:46.964    19,719 kbps     00:16:46.046    19,009 kbps     00:16:45.879    92,951 bytes    292,917 bytes   00:16:30.197
7               0:18:02.414     0:04:31.980     17,371 kbps     21,446 kbps     00:20:36.735    19,666 kbps     00:20:18.800    18,981 kbps     00:20:16.215    90,565 bytes    263,146 bytes   00:18:36.240
8               0:22:34.394     0:02:27.522     18,682 kbps     23,792 kbps     00:24:50.197    22,387 kbps     00:24:49.404    21,472 kbps     00:24:46.985    97,399 bytes    304,405 bytes   00:23:02.339
9               0:25:01.917     0:05:07.640     18,651 kbps     24,616 kbps     00:28:40.593    21,557 kbps     00:28:18.696    20,095 kbps     00:26:27.252    97,237 bytes    287,137 bytes   00:29:19.007
10              0:30:09.557     0:03:53.942     18,334 kbps     25,269 kbps     00:33:35.221    21,802 kbps     00:33:22.709    21,565 kbps     00:33:17.578    95,586 bytes    289,281 bytes   00:33:35.430
11              0:34:03.499     0:05:24.032     17,353 kbps     21,915 kbps     00:36:07.206    19,978 kbps     00:38:23.968    19,295 kbps     00:38:19.130    90,471 bytes    263,028 bytes   00:35:57.446
12              0:39:27.531     0:02:13.258     17,269 kbps     19,359 kbps     00:40:11.367    18,044 kbps     00:39:59.563    17,686 kbps     00:39:58.187    90,033 bytes    228,036 bytes   00:39:47.885
13              0:41:40.789     0:07:16.727     18,438 kbps     26,559 kbps     00:46:12.060    23,627 kbps     00:46:11.769    22,703 kbps     00:46:11.852    96,125 bytes    310,334 bytes   00:42:26.627
14              0:48:57.517     0:04:29.352     18,917 kbps     26,377 kbps     00:50:33.613    23,548 kbps     00:50:12.676    22,527 kbps     00:51:46.019    98,627 bytes    312,112 bytes   00:51:53.568
15              0:53:26.870     0:04:13.127     17,894 kbps     26,742 kbps     00:57:02.168    22,613 kbps     00:57:06.840    20,594 kbps     00:57:01.793    93,289 bytes    352,022 bytes   00:56:46.778
16              0:57:39.998     0:04:48.454     19,128 kbps     27,504 kbps     00:57:53.178    25,984 kbps     00:57:52.093    24,505 kbps     00:57:47.881    99,726 bytes    322,752 bytes   01:00:11.357
17              1:02:28.453     0:04:43.574     16,594 kbps     24,377 kbps     01:02:31.706    20,104 kbps     01:02:31.706    18,824 kbps     01:07:01.976    86,512 bytes    311,351 bytes   01:02:32.623
18              1:07:12.028     0:01:16.117     16,751 kbps     28,099 kbps     01:08:22.306    23,543 kbps     01:08:19.261    20,814 kbps     01:08:18.094    87,331 bytes    426,262 bytes   01:08:22.556
19              1:08:28.145     0:03:09.606     18,273 kbps     26,203 kbps     01:08:55.589    20,804 kbps     01:08:55.506    19,685 kbps     01:09:03.305    95,267 bytes    288,978 bytes   01:08:43.536
20              1:11:37.751     0:03:16.279     16,301 kbps     22,885 kbps     01:11:57.813    19,519 kbps     01:11:57.813    18,782 kbps     01:11:54.685    84,986 bytes    293,973 bytes   01:11:57.855
21              1:14:54.031     0:04:46.953     18,482 kbps     23,985 kbps     01:17:46.912    22,204 kbps     01:17:18.967    20,979 kbps     01:17:14.755    96,358 bytes    283,822 bytes   01:16:32.504
22              1:19:40.984     0:01:53.321     16,514 kbps     21,380 kbps     01:21:00.355    17,748 kbps     01:20:15.101    17,464 kbps     01:20:10.514    86,094 bytes    269,422 bytes   01:21:13.743
23              1:21:34.306     0:02:13.424     17,234 kbps     22,744 kbps     01:23:11.653    19,938 kbps     01:22:48.964    19,025 kbps     01:22:47.253    89,851 bytes    279,177 bytes   01:22:18.808
24              1:23:47.731     0:07:46.716     17,252 kbps     24,726 kbps     01:26:14.002    21,548 kbps     01:26:13.251    19,836 kbps     01:26:08.288    89,946 bytes    272,805 bytes   01:25:54.899
25              1:31:34.447     0:06:14.707     16,850 kbps     26,907 kbps     01:35:06.075    21,312 kbps     01:33:45.077    19,815 kbps     01:37:19.875    87,847 bytes    295,945 bytes   01:33:04.787
26              1:37:49.154     0:03:23.494     17,373 kbps     23,941 kbps     01:40:44.663    22,306 kbps     01:40:40.993    20,233 kbps     01:40:40.826    90,573 bytes    289,480 bytes   01:40:44.872
27              1:41:12.649     0:03:40.094     22,081 kbps     28,369 kbps     01:41:58.946    24,670 kbps     01:41:59.113    24,207 kbps     01:41:57.528    115,122 bytes   294,133 bytes   01:44:26.551
28              1:44:52.744     0:02:05.875     18,916 kbps     25,960 kbps     01:45:49.968    22,967 kbps     01:45:50.052    22,527 kbps     01:46:05.692    98,617 bytes    287,543 bytes   01:45:50.093
29              1:46:58.620     0:05:32.165     18,432 kbps     27,131 kbps     01:49:22.222    23,285 kbps     01:49:18.385    22,976 kbps     01:49:13.380    96,094 bytes    277,247 bytes   01:49:55.463
30              1:52:30.785     0:04:55.920     18,599 kbps     24,319 kbps     01:54:26.317    21,943 kbps     01:53:40.980    21,469 kbps     01:53:09.032    96,968 bytes    287,841 bytes   01:54:26.401
31              1:57:26.706     0:01:52.946     17,526 kbps     26,805 kbps     01:58:07.371    21,340 kbps     01:57:57.570    19,232 kbps     01:57:53.232    91,373 bytes    312,579 bytes   01:57:30.960
32              1:59:19.652     0:02:00.662     12,888 kbps     19,735 kbps     02:00:44.362    17,995 kbps     02:00:21.380    17,593 kbps     02:00:21.380    67,237 bytes    306,587 bytes   02:00:45.196
STREAM DIAGNOSTICS:
00020.M2TS      4113 (0x1011)   0x1B            AVC                                     7280.231                17,966                  16,349,871,584  88,960,568
00020.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7280.231                1,108                   1,007,988,372   6,150,788
00020.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7280.231                192                     174,727,680     1,137,550
00020.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7280.231                192                     174,727,680     1,137,550
00020.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7280.231                192                     174,727,680     1,137,550
00020.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7280.231                56                      51,322,556      290,988
00020.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7280.231                50                      45,588,609      259,700
00020.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           7280.231                52                      46,963,711      267,216
Cinema Squid is offline
post #2894 of 5106 Old 04-06-2011, 07:46 PM - Thread Starter
[US] Tron: Legacy: 2D (Additional Details)
Studio: Disney
UPC: 786936808568
Aspect Ratio: 1.78:1 / 2.35:1
Curiously, this is not quite identical to the Mexican release just posted by squallmx even though the languages seem to be the same. On this disc, one of the English DD 2.0 is descriptive audio and the other is a stereo mix on the main audio.
Code:
        Total   Video
[US] Tron: Legacy: 2D                                           AVC     2:05:08 31,521,619,968  43,069,078,019  33.58   23.97   DTS-HD Master 7.1 5731Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TRON_LEGACY
Disc Size:      43,069,078,019 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.7
PLAYLIST REPORT:
Total Bitrate:          33.58 Mbps
VIDEO:
MPEG-4 AVC Video        23967 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
SUBTITLES:
Presentation Graphics           Spanish         20.176 kbps
FILES:
00005.M2TS      0:00:00.000     2:05:08.667     31,521,619,968  33,584
CHAPTERS:
1               0:00:00.000     0:04:07.163     24,078 kbps     35,093 kbps     00:01:49.192    29,991 kbps     00:01:45.730    29,133 kbps     00:00:13.388    125,510 bytes   328,035 bytes   00:04:04.577
2               0:04:07.163     0:10:37.011     24,622 kbps     36,051 kbps     00:05:12.145    35,636 kbps     00:05:10.810    35,158 kbps     00:05:09.851    128,368 bytes   280,434 bytes   00:05:10.852
3               0:14:44.174     0:08:31.427     23,376 kbps     34,595 kbps     00:20:53.293    33,625 kbps     00:20:53.460    33,093 kbps     00:20:51.959    121,872 bytes   338,555 bytes   00:23:01.880
4               0:23:15.602     0:03:37.091     25,827 kbps     34,665 kbps     00:26:03.979    34,431 kbps     00:25:59.975    31,594 kbps     00:25:55.428    134,648 bytes   229,595 bytes   00:25:59.391
5               0:26:52.694     0:09:19.517     24,781 kbps     37,619 kbps     00:31:04.028    34,298 kbps     00:31:58.374    31,769 kbps     00:30:55.645    129,195 bytes   291,570 bytes   00:31:04.779
6               0:36:12.211     0:02:23.768     19,202 kbps     23,873 kbps     00:37:23.282    23,097 kbps     00:37:23.157    22,224 kbps     00:37:23.157    100,112 bytes   193,190 bytes   00:36:25.266
7               0:38:35.980     0:08:16.746     25,893 kbps     36,622 kbps     00:46:17.900    34,373 kbps     00:43:08.919    31,846 kbps     00:43:09.628    134,994 bytes   240,644 bytes   00:46:30.662
8               0:46:52.726     0:06:11.037     20,966 kbps     30,784 kbps     00:47:57.374    28,903 kbps     00:52:09.084    28,797 kbps     00:52:10.043    109,310 bytes   211,192 bytes   00:51:57.489
9               0:53:03.763     0:11:50.418     23,665 kbps     33,584 kbps     00:56:34.974    32,895 kbps     00:56:31.137    30,850 kbps     01:02:22.196    123,378 bytes   315,598 bytes   00:57:34.409
10              1:04:54.181     0:08:53.241     23,102 kbps     36,479 kbps     01:04:55.266    31,775 kbps     01:04:54.515    27,720 kbps     01:09:38.883    120,442 bytes   326,265 bytes   01:05:00.104
11              1:13:47.423     0:05:13.521     24,414 kbps     35,003 kbps     01:17:35.233    31,691 kbps     01:17:35.233    30,803 kbps     01:17:34.066    127,282 bytes   230,530 bytes   01:18:16.400
12              1:19:00.944     0:03:39.510     25,545 kbps     33,428 kbps     01:20:39.376    31,481 kbps     01:20:37.541    29,990 kbps     01:20:37.457    133,180 bytes   294,807 bytes   01:21:34.180
13              1:22:40.455     0:03:10.440     23,537 kbps     30,586 kbps     01:23:46.229    29,825 kbps     01:23:43.351    28,826 kbps     01:25:08.895    122,710 bytes   212,766 bytes   01:23:44.394
14              1:25:50.895     0:02:20.932     21,826 kbps     28,595 kbps     01:28:02.860    27,779 kbps     01:26:02.991    25,906 kbps     01:27:54.602    113,792 bytes   217,532 bytes   01:27:17.607
15              1:28:11.828     0:03:30.585     23,425 kbps     30,010 kbps     01:30:19.831    27,832 kbps     01:30:20.206    27,321 kbps     01:29:11.512    122,125 bytes   233,380 bytes   01:30:21.916
16              1:31:42.413     0:11:30.648     23,080 kbps     36,467 kbps     01:36:49.970    35,757 kbps     01:39:10.527    34,898 kbps     01:36:31.243    120,327 bytes   363,242 bytes   01:36:44.048
17              1:43:13.061     0:05:04.971     26,335 kbps     35,438 kbps     01:45:34.703    31,786 kbps     01:45:32.743    30,708 kbps     01:44:08.075    137,301 bytes   224,031 bytes   01:47:28.567
18              1:48:18.033     0:06:30.348     25,321 kbps     37,351 kbps     01:54:42.292    35,199 kbps     01:54:38.371    33,119 kbps     01:54:36.786    132,010 bytes   624,570 bytes   01:53:49.155
19              1:54:48.381     0:03:15.278     23,849 kbps     35,081 kbps     01:57:12.483    33,956 kbps     01:56:29.232    32,475 kbps     01:56:29.232    124,338 bytes   293,856 bytes   01:58:03.659
20              1:58:03.659     0:07:05.007     23,763 kbps     34,281 kbps     01:59:34.542    30,276 kbps     01:59:33.124    27,575 kbps     01:59:32.373    123,904 bytes   412,749 bytes   02:03:27.066
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     7508.584                23,967                  22,495,113,515  122,364,293
00005.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7508.584                5,731                   5,379,361,632   30,402,546
00005.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           7508.584                20                      18,937,246      109,377
post #2895 of 5106 Old 04-06-2011, 07:55 PM - Thread Starter
[US] Dogtooth (Additional Details)
Studio: Kino International
UPC: 738329075828
Release Date: 2011-03-29
Aspect Ratio: 2.35:1
Original Greek audio w/ English subs. This movie is... strange...
Code:
        Total   Video
[US] Dogtooth                                                   AVC     1:37:06 26,587,084,800  33,037,161,664  36.50   32.93   DTS-HD Master 5.1 1715Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     DOGTOOTH
Disc Size:      33,037,161,664 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:37:06 (h:m:s)
Total Bitrate:          36.50 Mbps
VIDEO:
MPEG-4 AVC Video        32934 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             Greek           1715 kbps       5.1 / 48 kHz / 1715 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         23.724 kbps
FILES:
00001.M2TS      0:00:00.000     0:00:12.011     4,503,552       2,999
00000.M2TS      0:00:12.011     1:36:54.850     26,582,581,248  36,572
CHAPTERS:
1               0:00:00.000     0:03:32.795     23,594 kbps     42,969 kbps     00:00:56.139    39,555 kbps     00:00:52.260    39,156 kbps     00:00:47.130    122,984 bytes   666,514 bytes   00:00:31.614
2               0:03:32.795     0:07:58.269     32,065 kbps     40,140 kbps     00:11:05.956    38,820 kbps     00:11:04.121    38,024 kbps     00:10:59.825    167,170 bytes   544,952 bytes   00:11:05.164
3               0:11:31.065     0:12:34.545     33,813 kbps     49,705 kbps     00:16:31.365    41,935 kbps     00:16:29.613    39,916 kbps     00:20:05.913    176,284 bytes   663,952 bytes   00:20:08.206
4               0:24:05.610     0:09:22.645     35,379 kbps     44,663 kbps     00:31:13.746    40,551 kbps     00:27:13.465    39,508 kbps     00:27:08.585    184,449 bytes   588,940 bytes   00:27:16.176
5               0:33:28.256     0:09:05.378     33,306 kbps     44,834 kbps     00:41:21.854    40,846 kbps     00:39:30.785    40,241 kbps     00:39:26.280    173,644 bytes   594,357 bytes   00:41:16.265
6               0:42:33.634     0:06:11.037     36,306 kbps     41,630 kbps     00:45:34.481    39,653 kbps     00:45:34.481    38,631 kbps     00:45:32.479    189,284 bytes   670,384 bytes   00:45:35.441
7               0:48:44.671     0:08:38.100     36,016 kbps     39,738 kbps     00:54:13.667    37,888 kbps     00:55:26.948    37,489 kbps     00:51:41.097    187,773 bytes   417,059 bytes   00:54:12.415
8               0:57:22.772     0:03:21.576     35,940 kbps     38,324 kbps     00:58:26.836    37,757 kbps     00:58:22.832    37,375 kbps     00:58:17.827    187,373 bytes   490,337 bytes   00:58:26.711
9               1:00:44.349     0:11:49.250     32,935 kbps     42,717 kbps     01:09:18.696    40,269 kbps     01:04:53.556    39,782 kbps     01:04:48.467    171,708 bytes   653,700 bytes   01:07:20.786
10              1:12:33.599     0:08:51.614     34,842 kbps     47,240 kbps     01:16:43.724    41,014 kbps     01:16:43.682    39,290 kbps     01:16:38.719    181,648 bytes   537,375 bytes   01:16:47.102
11              1:21:25.213     0:04:01.532     33,516 kbps     39,528 kbps     01:21:31.720    39,017 kbps     01:21:30.093    38,809 kbps     01:21:27.757    174,739 bytes   439,700 bytes   01:21:35.223
12              1:25:26.746     0:11:40.116     26,582 kbps     43,766 kbps     01:26:44.657    41,783 kbps     01:26:44.657    40,075 kbps     01:26:40.653    138,596 bytes   502,733 bytes   01:29:36.746
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     11.887                  1,018                   1,512,831       8,355
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       ell (Greek)             11.887                  1,578                   2,344,160       14,651
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           11.887                  1                       1,366           15
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5814.726                33,001                  23,986,340,637  130,442,448
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       ell (Greek)             5814.726                1,715                   1,246,561,516   7,715,185
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5814.726                24                      17,278,176      98,504
post #2896 of 5106 Old 04-06-2011, 07:58 PM - Thread Starter
[US] I Love You Phillip Morris (Additional Details)
Region Locked (A) (Confirmed w/ PowerDVD set to all three regions)
Studio: Lionsgate
UPC: 031398134008
English DD 2.0 is a commentary.
Code:
        Total   Video
[US] I Love You Phillip Morris                                  AVC     1:37:47 17,314,074,624  21,857,692,569  23.61   20.00   DTS-HD Master 5.1 1941Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     I_LOVE_YOU_PHILLIP_MORRIS_BD
Disc Size:      21,857,692,569 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:37:47 (h:m:s)
Total Bitrate:          23.61 Mbps
VIDEO:
MPEG-4 AVC Video        19997 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1941 kbps       5.1 / 48 kHz / 1941 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         44.392 kbps
Presentation Graphics           Spanish         48.433 kbps
Presentation Graphics           English         55.259 kbps
FILES:
00000.M2TS      0:00:00.000     1:37:46.819     17,314,050,048  23,609
00013.M2TS      1:37:46.819     0:00:01.000     24,576          196
CHAPTERS:
1               0:00:00.000     0:07:13.599     19,758 kbps     38,408 kbps     00:03:36.174    32,290 kbps     00:03:39.719    32,035 kbps     00:03:36.090    103,000 bytes   613,498 bytes   00:07:10.138
2               0:07:13.599     0:05:29.370     22,804 kbps     44,303 kbps     00:10:46.729    38,358 kbps     00:07:21.774    35,298 kbps     00:07:20.148    118,888 bytes   627,195 bytes   00:10:47.521
3               0:12:42.970     0:06:37.855     23,729 kbps     42,113 kbps     00:18:57.761    35,983 kbps     00:18:48.710    33,316 kbps     00:18:48.794    123,713 bytes   606,036 bytes   00:12:57.943
4               0:19:20.826     0:06:55.873     18,942 kbps     36,940 kbps     00:22:03.530    33,276 kbps     00:22:02.863    31,057 kbps     00:22:00.485    98,756 bytes    438,965 bytes   00:21:40.132
5               0:26:16.700     0:05:59.776     17,790 kbps     32,304 kbps     00:29:02.699    27,744 kbps     00:30:36.793    26,444 kbps     00:28:30.333    92,747 bytes    384,012 bytes   00:28:23.535
6               0:32:16.476     0:06:11.996     17,291 kbps     46,092 kbps     00:38:20.506    37,930 kbps     00:38:02.530    32,372 kbps     00:38:18.462    90,146 bytes    589,623 bytes   00:38:28.264
7               0:38:28.472     0:08:52.281     18,910 kbps     43,455 kbps     00:46:58.607    38,060 kbps     00:38:56.792    36,438 kbps     00:38:56.500    98,588 bytes    617,572 bytes   00:38:32.935
8               0:47:20.754     0:08:51.280     19,486 kbps     36,331 kbps     00:52:07.958    30,964 kbps     00:52:05.539    28,131 kbps     00:52:00.325    101,591 bytes   490,741 bytes   00:52:43.451
9               0:56:12.035     0:06:22.715     23,418 kbps     42,462 kbps     01:01:04.410    34,380 kbps     01:02:24.490    32,746 kbps     01:01:02.367    122,092 bytes   563,607 bytes   00:57:00.959
10              1:02:34.751     0:03:36.299     25,919 kbps     36,355 kbps     01:03:45.446    32,678 kbps     01:05:05.902    32,147 kbps     01:05:01.814    135,127 bytes   476,149 bytes   01:03:07.033
11              1:06:11.050     0:06:38.773     21,773 kbps     40,036 kbps     01:12:00.065    35,103 kbps     01:11:59.857    32,999 kbps     01:11:43.298    113,515 bytes   489,777 bytes   01:12:46.403
12              1:12:49.823     0:03:32.128     21,130 kbps     39,082 kbps     01:14:42.728    32,845 kbps     01:14:42.436    27,105 kbps     01:14:38.474    110,163 bytes   506,597 bytes   01:14:48.484
13              1:16:21.952     0:03:49.103     20,316 kbps     32,285 kbps     01:19:28.638    27,732 kbps     01:18:37.921    27,225 kbps     01:18:37.379    105,921 bytes   378,673 bytes   01:17:22.721
14              1:20:11.056     0:04:18.049     18,732 kbps     31,929 kbps     01:20:11.598    28,613 kbps     01:20:11.056    26,982 kbps     01:23:12.987    97,662 bytes    409,553 bytes   01:22:59.099
15              1:24:29.105     0:08:07.153     21,401 kbps     46,009 kbps     01:25:00.220    37,284 kbps     01:25:00.220    31,541 kbps     01:25:00.220    111,574 bytes   621,893 bytes   01:26:49.162
16              1:32:36.259     0:05:10.560     9,795 kbps      44,106 kbps     01:32:49.730    40,193 kbps     01:32:48.187    37,413 kbps     01:32:46.644    51,069 bytes    422,576 bytes   01:33:31.814
17              1:37:46.819     0:00:01.001     75 kbps         0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    407 bytes       2,428 bytes     01:37:47.570
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5866.694                20,000                  14,667,027,133  79,794,204
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5866.694                1,941                   1,423,472,412   8,648,919
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5866.694                192                     140,802,816     916,685
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5866.694                44                      32,560,832      186,190
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5866.694                48                      35,524,180      202,473
00000.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           5866.694                55                      40,531,350      232,299
00013.M2TS      4113 (0x1011)   0x1B            AVC                                     0.876                   108                     11,791          72
post #2897 of 5106 Old 04-07-2011, 04:31 AM
Jojos's Avatar
[FR] Enter the Void
Region Locked (B)
Studio: Wild Side
EAN: 3700301019066
Release Date: 2010-12-01
Forced French subtitles.
Code:
        Total   Video
[FR] Enter the Void: Theatrical Cut (seamless)                  AVC     2:41:16 30.059.433.984  41.413.243.629  24,85   19,96   DTS-HD Master 5.1 1647Kbps (48kHz/16-bit)
                     Alternate Cut (seamless)                   AVC     2:23:16 26.723.629.056  41.413.243.629  24,87   19,97   DTS-HD Master 5.1 1650Kbps (48kHz/16-bit)
Theatrical Cut
Code:
DISC INFO:
Disc Title:     ENTER_THE_VOID
Disc Size:      41.413.243.629 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:41:16 (h:m:s)
Total Bitrate:          24,85 Mbps
VIDEO:
MPEG-4 AVC Video        19960 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1647 kbps       5.1 / 48 kHz / 1647 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             French          1659 kbps       5.1 / 48 kHz / 1659 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           French          14,722 kbps
FILES:
00087.M2TS      0:00:00.000     1:51:50.787     20.913.364.992  24.931
00088.M2TS      1:51:50.787     0:17:59.328     3.335.804.928   24.725
00089.M2TS      2:09:50.115     0:31:26.009     5.810.264.064   24.646
CHAPTERS:
1               0:00:00.000     0:02:17.762     19.690 kbps     41.445 kbps     00:02:10.672    28.215 kbps     00:01:54.906    27.095 kbps     00:01:57.200    102.626 bytes   626.179 bytes   00:01:36.554
2               0:02:17.762     0:09:14.554     20.164 kbps     37.796 kbps     00:02:21.599    33.250 kbps     00:02:21.641    32.111 kbps     00:02:21.599    105.126 bytes   492.992 bytes   00:02:18.263
3               0:11:32.316     0:15:30.888     20.006 kbps     33.744 kbps     00:17:27.129    31.494 kbps     00:17:25.461    30.197 kbps     00:17:20.581    104.303 bytes   444.574 bytes   00:11:52.837
4               0:27:03.204     0:19:03.809     19.642 kbps     33.013 kbps     00:29:52.665    31.525 kbps     00:29:52.624    30.163 kbps     00:29:47.827    102.402 bytes   338.858 bytes   00:36:19.010
5               0:46:07.014     0:17:46.690     20.610 kbps     32.071 kbps     00:47:15.290    30.592 kbps     00:56:27.759    29.920 kbps     00:56:25.632    107.450 bytes   491.743 bytes   00:46:53.435
6               1:03:53.704     0:10:03.644     19.215 kbps     31.217 kbps     01:09:28.497    26.689 kbps     01:09:28.497    25.912 kbps     01:09:28.497    100.178 bytes   406.285 bytes   01:09:28.539
7               1:13:57.349     0:15:08.282     20.131 kbps     30.111 kbps     01:24:32.984    27.959 kbps     01:27:18.358    26.865 kbps     01:27:17.899    104.956 bytes   338.976 bytes   01:27:06.471
8               1:29:05.631     0:22:45.155     20.131 kbps     40.051 kbps     01:36:22.318    33.451 kbps     01:37:17.623    31.656 kbps     01:37:16.747    104.955 bytes   482.135 bytes   01:40:15.426
9               1:51:50.787     0:17:59.495     19.900 kbps     38.340 kbps     02:03:32.488    33.458 kbps     02:03:32.488    32.094 kbps     02:03:32.488    103.751 bytes   445.130 bytes   02:05:00.034
10              2:09:50.282     0:14:46.051     19.968 kbps     41.584 kbps     02:10:11.303    33.446 kbps     02:09:57.915    32.003 kbps     02:09:57.998    104.103 bytes   317.685 bytes   02:10:10.552
11              2:24:36.334     0:05:51.851     19.431 kbps     30.348 kbps     02:24:36.334    28.270 kbps     02:24:36.334    27.736 kbps     02:24:36.709    101.305 bytes   330.113 bytes   02:29:55.695
12              2:30:28.185     0:10:47.938     19.746 kbps     37.488 kbps     02:30:28.269    30.993 kbps     02:30:28.269    29.320 kbps     02:30:28.269    102.959 bytes   331.161 bytes   02:30:28.310
STREAM DIAGNOSTICS:
00087.M2TS      4113 (0x1011)   0x1B            AVC                                     6710,704                20.018                  16.791.585.571  91.353.514
00087.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            6710,704                1.667                   1.398.340.796   8.659.402
00087.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           6710,704                1.654                   1.387.432.108   8.597.283
00087.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            6710,704                18                      15.242.176      88.728
00088.M2TS      4113 (0x1011)   0x1B            AVC                                     1079,245                19.905                  2.685.340.263   14.609.221
00088.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            1079,245                1.631                   219.980.132     1.363.141
00088.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1079,245                1.624                   219.151.936     1.358.222
00088.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            1079,245                9                       1.244.950       7.241
00089.M2TS      4113 (0x1011)   0x1B            AVC                                     1885,801                19.792                  4.665.433.019   25.382.240
00089.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            1885,801                1.645                   387.856.036     2.408.807
00089.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1885,801                1.634                   385.286.436     2.399.743
00089.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            1885,801                6                       1.319.025       7.820
Alternate Cut
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:23:16 (h:m:s)
Total Bitrate:          24,87 Mbps
VIDEO:
MPEG-4 AVC Video        19967 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1650 kbps       5.1 / 48 kHz / 1650 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             French          1662 kbps       5.1 / 48 kHz / 1662 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           French          15,412 kbps
FILES:
00089.M2TS      1:51:50.787     0:31:26.009     5.810.264.064   24.646
CHAPTERS:
8               1:29:05.631     0:22:45.113     20.130 kbps     40.051 kbps     01:36:22.318    33.451 kbps     01:37:17.623    31.656 kbps     01:37:16.747    104.950 bytes   482.135 bytes   01:40:15.426
9               1:51:50.745     0:00:00.041     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
10              1:51:50.787     0:14:46.051     19.963 kbps     41.584 kbps     01:52:11.975    33.446 kbps     01:51:58.586    32.003 kbps     01:51:58.670    104.077 bytes   317.685 bytes   01:52:11.224
11              2:06:36.839     0:05:51.851     19.443 kbps     30.348 kbps     02:06:37.006    28.395 kbps     02:06:36.839    27.736 kbps     02:06:37.381    101.369 bytes   330.113 bytes   02:11:56.366
12              2:12:28.690     0:10:48.105     19.741 kbps     37.488 kbps     02:12:28.940    30.993 kbps     02:12:28.940    29.320 kbps     02:12:28.940    102.933 bytes   331.161 bytes   02:12:28.982
STREAM DIAGNOSTICS:
Jojos is offline
post #2898 of 5106 Old 04-07-2011, 04:52 AM
Jojos's Avatar
[FR] Wild at Heart
aka "Sailor & Lula"
Region Locked (B)
Studio: Universal
EAN: 5050582785159
Release Date: 2010-10-19
Code:
        Total   Video
00002.MPLS                                                      AVC     2:05:11 35.956.236.288  43.638.781.434  38,29   32,01   DTS-HD Master 5.1 2170Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     SAILOR_ET_LULA
Disc Size:      43.638.781.434 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:05:11 (h:m:s)
Total Bitrate:          38,29 Mbps
VIDEO:
MPEG-4 AVC Video        32005 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2170 kbps       5.1 / 48 kHz / 2170 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             French          1970 kbps       5.1 / 48 kHz / 1970 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           French          23,508 kbps
Presentation Graphics           French          0,600 kbps
FILES:
00006.M2TS      0:00:00.000     0:59:30.567     17.130.270.720  38.381
00001.M2TS      0:59:30.567     1:05:40.978     18.825.965.568  38.216
CHAPTERS:
1               0:00:00.000     0:11:15.508     32.022 kbps     37.516 kbps     00:01:53.071    35.282 kbps     00:01:03.938    34.171 kbps     00:01:01.102    166.939 bytes   402.388 bytes   00:10:03.769
2               0:11:15.508     0:12:03.222     31.996 kbps     37.682 kbps     00:18:29.942    35.239 kbps     00:18:27.523    33.601 kbps     00:18:24.228    166.814 bytes   377.914 bytes   00:19:43.432
3               0:23:18.730     0:08:55.660     32.006 kbps     40.802 kbps     00:31:01.401    36.497 kbps     00:23:39.000    34.216 kbps     00:23:34.996    166.865 bytes   468.036 bytes   00:23:40.043
4               0:32:14.390     0:11:55.548     32.001 kbps     40.238 kbps     00:34:20.641    33.974 kbps     00:34:18.222    33.071 kbps     00:39:30.826    166.837 bytes   481.242 bytes   00:43:13.716
5               0:44:09.938     0:10:50.941     31.997 kbps     35.905 kbps     00:49:47.025    33.810 kbps     00:45:29.393    33.208 kbps     00:45:25.889    166.816 bytes   458.530 bytes   00:52:01.868
6               0:55:00.880     0:09:04.961     32.042 kbps     39.607 kbps     01:00:44.349    35.254 kbps     00:57:07.757    33.822 kbps     00:57:02.752    167.053 bytes   488.131 bytes   00:55:01.756
7               1:04:05.842     0:09:36.492     31.985 kbps     35.289 kbps     01:11:42.298    33.505 kbps     01:07:43.142    33.370 kbps     01:07:45.603    166.754 bytes   432.567 bytes   01:07:43.726
8               1:13:42.334     0:11:19.970     32.009 kbps     37.428 kbps     01:21:11.533    33.898 kbps     01:21:09.656    32.918 kbps     01:21:32.929    166.878 bytes   463.233 bytes   01:24:38.323
9               1:25:02.305     0:10:52.276     32.013 kbps     36.032 kbps     01:35:51.412    33.840 kbps     01:31:22.894    33.510 kbps     01:25:02.347    166.903 bytes   499.779 bytes   01:31:23.519
10              1:35:54.582     0:11:30.022     32.007 kbps     39.414 kbps     01:43:53.185    33.925 kbps     01:46:13.116    33.480 kbps     01:43:35.042    166.869 bytes   439.477 bytes   01:37:38.561
11              1:47:24.604     0:08:55.534     32.003 kbps     36.998 kbps     01:52:14.894    33.605 kbps     01:48:03.018    33.276 kbps     01:48:03.894    166.848 bytes   462.750 bytes   01:48:00.056
12              1:56:20.139     0:08:51.405     31.979 kbps     37.589 kbps     01:56:29.983    34.339 kbps     01:57:24.454    33.318 kbps     01:57:19.449    166.736 bytes   456.621 bytes   01:59:18.568
STREAM DIAGNOSTICS:
00006.M2TS      4113 (0x1011)   0x1B            AVC                                     3570,484                32.007                  14.285.243.295  77.687.193
00006.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            3570,484                2.001                   893.068.260     5.409.202
00006.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           3570,484                2.217                   989.388.128     5.932.833
00006.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            3570,484                27                      12.076.326      69.170
00006.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            3570,484                1                       357.753         2.115
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     3940,895                32.004                  15.765.641.467  85.737.780
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            3940,895                1.941                   956.266.300     5.817.786
00001.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           3940,895                2.127                   1.047.932.288   6.305.048
00001.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            3940,895                20                      9.996.102       58.051
00001.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            3940,895                0                       205.434         1.200
Jojos is offline
post #2899 of 5106 Old 04-07-2011, 05:37 AM
Jojos's Avatar
[BE] Boarding Gate
Region Free*
Studio: Melimedias
EAN: 5410865422032
Release Date: 2009-05-14
*But all content other than the main feature is in 1080i/50Hz or 576i/50Hz.
Code:
        Total   Video
00001.MPLS                                                      AVC     1:46:10 28.840.253.952  34.037.306.747  36,22   24,00   LPCM 5.1 6912Kbps (48kHz/24-bit)          LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     BOARDING GATE
Disc Size:      34.037.306.747 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 1:46:10 (h:m:s)
Total Bitrate:          36,22 Mbps
VIDEO:
MPEG-4 AVC Video        23998 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         6912 kbps       5.1 / 48 kHz / 6912 kbps / 24-bit
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
LPCM Audio                      French          1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           Dutch           21,135 kbps
Presentation Graphics           French          18,044 kbps
Presentation Graphics           French          1,201 kbps
FILES:
00000.M2TS      0:00:00.000     1:46:10.208     28.840.253.952  36.219
CHAPTERS:
1               0:00:00.000     0:13:43.791     19.231 kbps     44.463 kbps     00:00:00.916    35.180 kbps     00:00:00.041    29.065 kbps     00:09:07.958    100.154 bytes   400.972 bytes   00:00:03.291
2               0:13:43.791     0:08:24.666     25.427 kbps     40.881 kbps     00:21:23.375    36.120 kbps     00:21:42.083    33.806 kbps     00:21:39.416    132.431 bytes   355.777 bytes   00:13:49.083
3               0:22:08.458     0:04:14.375     24.239 kbps     32.933 kbps     00:25:12.499    27.445 kbps     00:22:24.208    27.222 kbps     00:22:18.916    126.243 bytes   293.088 bytes   00:24:58.250
4               0:26:22.833     0:12:40.916     24.346 kbps     39.622 kbps     00:36:39.083    37.346 kbps     00:36:41.541    35.974 kbps     00:36:36.833    126.801 bytes   316.194 bytes   00:33:53.125
5               0:39:03.750     0:13:06.458     27.711 kbps     39.394 kbps     00:43:57.291    37.074 kbps     00:50:57.291    34.259 kbps     00:43:49.791    144.328 bytes   292.254 bytes   00:49:19.875
6               0:52:10.208     0:10:10.416     27.568 kbps     40.709 kbps     01:02:12.583    37.316 kbps     01:01:51.916    35.215 kbps     00:59:08.500    143.582 bytes   318.649 bytes   01:02:13.083
7               1:02:20.625     0:15:21.791     25.493 kbps     40.203 kbps     01:13:30.416    37.683 kbps     01:16:56.500    36.691 kbps     01:16:53.958    132.774 bytes   388.274 bytes   01:13:47.041
8               1:17:42.416     0:06:15.041     21.394 kbps     37.007 kbps     01:22:21.916    28.917 kbps     01:18:44.166    25.636 kbps     01:20:11.500    111.426 bytes   313.077 bytes   01:22:21.958
9               1:23:57.458     0:08:00.458     26.009 kbps     36.983 kbps     01:28:24.833    34.132 kbps     01:28:35.250    32.153 kbps     01:28:30.208    135.463 bytes   264.908 bytes   01:26:00.625
10              1:31:57.916     0:14:12.291     19.792 kbps     39.688 kbps     01:38:45.416    37.494 kbps     01:38:43.666    34.836 kbps     01:40:46.375    103.094 bytes   414.794 bytes   01:38:38.875
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6370,125                23.999                  19.109.437.512  103.946.709
00000.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           6370,125                6.918                   5.508.957.608   30.577.008
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6370,125                1.542                   1.228.176.488   7.644.252
00000.M2TS      4354 (0x1102)   0x80            LPCM            fra (French)            6370,125                1.542                   1.228.176.488   7.644.252
00000.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            6370,125                18                      14.367.920      83.590
00000.M2TS      4609 (0x1201)   0x90            PGS             nld (Dutch)             6370,125                21                      16.829.757      96.076
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6370,125                1                       956.573         5.605
Jojos is offline
post #2900 of 5106 Old 04-07-2011, 07:35 PM
Stephen Dawson's Avatar
2010 AFL Grand Final Draw 3D - 2011 - Australian version
Distributed by Visual Entertainment Group Pty Ltd
Region Free, confirmed with AnyDVD HD, but all content in 1080i50 format.
This is essential a replay of the 2010 Australian Football Grand Final, which ended in a draw. (A rematch was held the following week.)
This disc claims to be Blu-ray 3D, but is in fact side-by-side 3D. The three audio tracks are three for three different live audio broadcasts conducted during the game.
Details on the 3D presentation here.
Code:
        Total   Video
01002.MPLS                                                      AVC     2:39:03 40,797,659,520  40,888,114,285  34.20   31.99   DD AC3 2.0 192Kbps
Code:
DISC INFO:
Disc Title:     AFL Grand Final Draw 3D
Disc Size:      40,888,114,285 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 2:39:03 (h:m:s)
Total Bitrate:          34.20 Mbps
VIDEO:
MPEG-4 AVC Video        31995 kbps          1080i / 25 fps / 16:9 / High Profile 4.1
AUDIO:
FILES:
00004.M2TS      0:00:00.000     2:38:50.000     40,740,962,304  34,200
00005.M2TS      2:38:50.000     0:00:13.960     56,697,216      32,398
CHAPTERS:
1               0:00:00.000     0:13:10.840     29,353 kbps     46,230 kbps     00:10:23.400    38,739 kbps     00:10:19.400    37,688 kbps     00:10:14.400    146,758 bytes   639,739 bytes   00:00:22.920
2               0:13:10.840     0:33:26.440     32,488 kbps     44,867 kbps     00:45:19.680    38,248 kbps     00:45:15.680    37,577 kbps     00:45:10.720    162,442 bytes   638,459 bytes   00:42:18.880
3               0:46:37.280     0:34:44.600     31,543 kbps     42,307 kbps     01:06:04.520    38,055 kbps     01:13:12.880    37,129 kbps     01:18:41.040    157,715 bytes   639,004 bytes   01:11:49.360
4               1:21:21.880     0:33:49.600     32,670 kbps     43,254 kbps     01:42:11.680    38,170 kbps     01:24:42.760    37,162 kbps     01:53:59.080    163,348 bytes   636,638 bytes   01:32:02.920
5               1:55:11.480     0:31:46.999     32,475 kbps     44,324 kbps     02:03:40.640    37,819 kbps     02:23:44.720    37,163 kbps     02:19:45.240    162,377 bytes   628,007 bytes   01:58:46.120
6               2:26:58.480     0:11:50.520     31,739 kbps     46,874 kbps     02:33:00.480    38,816 kbps     02:32:56.519    37,424 kbps     02:29:00.000    158,703 bytes   640,264 bytes   02:32:03.199
7               2:38:49.000     0:00:01.000     2,593 kbps      2,593 kbps      02:38:49.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    12,967 bytes    137,480 bytes   02:38:49.959
8               2:38:50.000     0:00:13.959     29,695 kbps     43,157 kbps     02:38:59.040    38,742 kbps     02:38:57.480    33,124 kbps     02:38:52.440    149,330 bytes   602,152 bytes   02:39:02.920
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     9529.840                31,999                  38,118,065,955  207,302,323
00004.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           9529.840                192                     228,695,808     1,488,909
00004.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           9529.840                192                     228,696,576     1,488,910
00004.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           9529.840                192                     228,696,576     1,488,910
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     13.880                  30,166                  52,338,835      284,653
00005.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           13.880                  434                     752,640         4,200
00005.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           13.880                  434                     752,640         4,200
00005.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           13.880                  434                     752,640         4,200
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #2901 of 5106 Old 04-07-2011, 10:16 PM - Thread Starter
[US] Howl (Additional Details)
Studio: Oscilloscope Laboratories
UPC: 896602002951
Release Date: 2011-01-04
Aspect Ratio: 1.85:1
One of the English LPCM 2.0 is a stereo mix and the other is a commentary.
Code:
        Total   Video
[US] Howl                                                       AVC     1:24:28 19,770,846,912  38,460,238,435  31.20   22.00   DTS-HD Master 5.1 2793Kbps (48kHz/24-bit) LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     HOWL
Disc Size:      38,460,238,435 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:24:28 (h:m:s)
Total Bitrate:          31.20 Mbps
VIDEO:
MPEG-4 AVC Video        21999 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2793 kbps       5.1 / 48 kHz / 2793 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         46.994 kbps
Presentation Graphics           French          48.763 kbps
FILES:
00015.M2TS      0:00:00.000     1:24:28.813     19,770,846,912  31,204
CHAPTERS:
1               0:00:00.000     0:04:00.073     14,804 kbps     39,037 kbps     00:00:11.010    35,490 kbps     00:00:08.299    28,967 kbps     00:00:03.628    77,166 bytes    578,685 bytes   00:00:12.971
2               0:04:00.073     0:06:50.451     22,691 kbps     36,427 kbps     00:07:29.866    30,860 kbps     00:07:25.862    28,086 kbps     00:04:40.613    118,301 bytes   431,737 bytes   00:06:46.280
3               0:10:50.524     0:05:46.596     23,244 kbps     38,287 kbps     00:14:01.632    36,025 kbps     00:13:57.878    31,089 kbps     00:13:57.878    121,186 bytes   418,480 bytes   00:12:29.957
4               0:16:37.121     0:06:36.270     22,615 kbps     42,468 kbps     00:23:12.307    29,089 kbps     00:18:08.962    28,406 kbps     00:18:03.957    117,905 bytes   422,055 bytes   00:21:59.443
5               0:23:13.391     0:05:01.634     26,707 kbps     43,941 kbps     00:23:18.897    37,755 kbps     00:23:18.605    35,490 kbps     00:23:14.726    139,237 bytes   418,881 bytes   00:24:25.338
6               0:28:15.026     0:04:48.288     26,553 kbps     35,746 kbps     00:32:44.671    31,617 kbps     00:32:23.608    29,273 kbps     00:32:36.412    138,433 bytes   409,405 bytes   00:31:56.539
7               0:33:03.314     0:06:20.505     22,617 kbps     39,455 kbps     00:34:29.942    35,070 kbps     00:34:25.980    28,086 kbps     00:34:20.975    117,915 bytes   411,925 bytes   00:38:41.736
8               0:39:23.819     0:05:43.593     19,732 kbps     42,582 kbps     00:42:42.977    36,265 kbps     00:42:48.816    28,850 kbps     00:42:46.397    102,873 bytes   410,258 bytes   00:42:56.407
9               0:45:07.413     0:03:09.731     23,860 kbps     32,807 kbps     00:46:16.106    29,917 kbps     00:46:43.008    27,505 kbps     00:46:38.045    124,398 bytes   384,392 bytes   00:47:13.080
10              0:48:17.144     0:04:41.823     22,140 kbps     45,321 kbps     00:51:19.659    40,113 kbps     00:51:19.326    30,913 kbps     00:51:19.326    115,425 bytes   439,187 bytes   00:51:15.655
11              0:52:58.967     0:08:32.386     23,499 kbps     32,740 kbps     00:56:13.411    29,010 kbps     01:00:59.739    28,355 kbps     01:01:13.211    122,514 bytes   424,621 bytes   00:57:53.344
12              1:01:31.354     0:07:14.100     26,704 kbps     32,432 kbps     01:06:52.842    29,841 kbps     01:06:48.838    29,448 kbps     01:06:33.531    139,221 bytes   419,495 bytes   01:08:18.177
13              1:08:45.454     0:05:22.030     25,118 kbps     31,500 kbps     01:10:28.682    28,913 kbps     01:11:14.561    28,556 kbps     01:11:16.647    130,952 bytes   422,269 bytes   01:10:02.990
14              1:14:07.484     0:02:57.176     25,019 kbps     32,016 kbps     01:15:29.024    29,050 kbps     01:15:27.022    27,946 kbps     01:15:24.061    130,439 bytes   360,477 bytes   01:17:00.616
15              1:17:04.661     0:02:09.379     14,139 kbps     31,927 kbps     01:17:38.904    26,210 kbps     01:17:30.729    25,134 kbps     01:17:30.228    73,716 bytes    457,049 bytes   01:18:11.728
16              1:19:14.040     0:05:14.772     5,647 kbps      11,560 kbps     01:20:31.576    10,460 kbps     01:20:29.074    9,822 kbps      01:20:25.612    29,450 bytes    179,388 bytes   01:20:32.077
STREAM DIAGNOSTICS:
00015.M2TS      4113 (0x1011)   0x1B            AVC                                     5068.730                22,000                  13,938,700,726  75,826,012
00015.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5068.730                2,793                   1,769,366,772   10,394,190
00015.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           5068.730                2,312                   1,465,174,816   8,117,312
00015.M2TS      4354 (0x1102)   0x80            LPCM            eng (English)           5068.730                2,312                   1,465,174,816   8,117,312
00015.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5068.730                47                      29,775,522      171,458
00015.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            5068.730                49                      30,896,734      176,895
post #2902 of 5106 Old 04-07-2011, 10:19 PM - Thread Starter
[US] Soylent Green (Additional Details)
Studio: Warner
UPC: 883929174126
Aspect Ratio: 2.40:1
Code:
        Total   Video
[US] Soylent Green                                              AVC     1:36:48 16,136,042,496  17,325,486,897  22.22   18.95   DTS-HD Master 1.0 1064Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     SOYLENT_GREEN_BD01
Disc Size:      17,325,486,897 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:36:48 (h:m:s)
Total Bitrate:          22.22 Mbps
VIDEO:
MPEG-4 AVC Video        18947 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1064 kbps       1.0 / 48 kHz / 1064 kbps / 24-bit (DTS Core: 1.0 / 48 kHz / 768 kbps / 24-bit)
Dolby Digital Audio             German          192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         23.935 kbps
Presentation Graphics           French          17.343 kbps
Presentation Graphics           German          24.754 kbps
Presentation Graphics           Spanish         20.592 kbps
Presentation Graphics           Spanish         23.723 kbps
FILES:
00020.M2TS      0:00:00.000     1:36:48.928     16,136,042,496  22,222
CHAPTERS:
1               0:00:00.000     0:02:26.938     18,399 kbps     29,629 kbps     00:01:05.607    24,039 kbps     00:01:21.748    22,061 kbps     00:01:34.260    95,897 bytes    278,058 bytes   00:00:12.512
2               0:02:26.938     0:04:38.778     17,414 kbps     22,076 kbps     00:06:27.428    20,334 kbps     00:03:31.544    19,924 kbps     00:02:53.506    90,788 bytes    203,432 bytes   00:02:30.108
3               0:07:05.716     0:02:45.957     18,861 kbps     27,622 kbps     00:08:44.023    22,739 kbps     00:07:27.321    21,435 kbps     00:07:23.985    98,333 bytes    222,213 bytes   00:08:40.520
4               0:09:51.674     0:02:50.962     17,988 kbps     30,730 kbps     00:11:27.228    24,481 kbps     00:11:26.602    22,719 kbps     00:11:20.805    93,780 bytes    249,744 bytes   00:11:34.860
5               0:12:42.636     0:04:41.155     21,195 kbps     26,480 kbps     00:16:00.960    25,903 kbps     00:15:56.914    25,658 kbps     00:15:52.952    110,501 bytes   213,826 bytes   00:14:30.202
6               0:17:23.792     0:03:50.396     20,936 kbps     26,248 kbps     00:18:51.255    25,069 kbps     00:18:15.511    24,907 kbps     00:18:15.344    109,152 bytes   204,960 bytes   00:19:28.375
7               0:21:14.189     0:03:32.712     16,955 kbps     22,497 kbps     00:21:14.856    19,729 kbps     00:23:08.303    19,356 kbps     00:23:08.303    88,394 bytes    195,811 bytes   00:23:44.464
8               0:24:46.902     0:03:27.206     19,837 kbps     28,425 kbps     00:27:18.595    25,294 kbps     00:26:35.969    23,377 kbps     00:27:18.595    103,423 bytes   211,815 bytes   00:27:18.637
9               0:28:14.109     0:05:00.508     20,449 kbps     31,468 kbps     00:29:17.547    26,589 kbps     00:29:17.547    26,130 kbps     00:29:17.547    106,609 bytes   233,202 bytes   00:29:17.589
10              0:33:14.617     0:02:43.413     16,633 kbps     22,921 kbps     00:34:23.060    19,173 kbps     00:34:04.709    18,573 kbps     00:33:59.704    86,718 bytes    202,894 bytes   00:33:47.942
11              0:35:58.030     0:02:34.737     16,304 kbps     21,007 kbps     00:38:31.767    18,447 kbps     00:37:17.652    18,043 kbps     00:37:12.980    85,004 bytes    194,041 bytes   00:36:13.171
12              0:38:32.768     0:03:56.986     18,737 kbps     26,438 kbps     00:41:24.940    25,461 kbps     00:41:40.080    25,184 kbps     00:41:35.784    97,684 bytes    237,678 bytes   00:42:07.608
13              0:42:29.755     0:05:03.219     21,179 kbps     29,640 kbps     00:43:27.563    26,794 kbps     00:43:41.035    26,530 kbps     00:43:35.237    110,420 bytes   229,230 bytes   00:45:53.417
14              0:47:32.975     0:03:06.269     19,685 kbps     29,164 kbps     00:50:04.668    24,394 kbps     00:48:59.186    23,744 kbps     00:48:45.881    102,628 bytes   244,076 bytes   00:48:53.555
15              0:50:39.244     0:03:20.241     18,383 kbps     29,628 kbps     00:51:45.560    24,184 kbps     00:52:38.822    23,955 kbps     00:52:33.817    95,843 bytes    199,705 bytes   00:51:45.769
16              0:53:59.486     0:03:08.354     17,799 kbps     30,796 kbps     00:55:01.965    25,969 kbps     00:55:24.362    22,441 kbps     00:55:24.362    92,794 bytes    216,632 bytes   00:55:32.454
17              0:57:07.841     0:02:54.966     24,897 kbps     32,176 kbps     00:58:23.416    30,023 kbps     00:58:19.370    29,175 kbps     00:58:14.407    129,802 bytes   227,779 bytes   00:58:24.042
18              1:00:02.807     0:02:01.746     24,564 kbps     31,037 kbps     01:00:25.663    28,479 kbps     01:00:22.452    26,798 kbps     01:00:49.228    128,063 bytes   203,441 bytes   01:00:26.331
19              1:02:04.554     0:02:12.507     17,834 kbps     23,811 kbps     01:03:56.874    21,282 kbps     01:03:54.330    20,666 kbps     01:03:50.201    92,978 bytes    195,734 bytes   01:03:51.035
20              1:04:17.061     0:02:56.759     18,511 kbps     27,047 kbps     01:06:34.949    24,280 kbps     01:06:32.863    23,866 kbps     01:06:27.858    96,508 bytes    236,613 bytes   01:05:12.700
21              1:07:13.821     0:01:23.458     14,930 kbps     18,600 kbps     01:07:16.198    16,440 kbps     01:07:14.613    16,038 kbps     01:07:53.069    77,836 bytes    162,785 bytes   01:07:30.921
22              1:08:37.279     0:01:08.735     21,942 kbps     29,295 kbps     01:08:51.293    27,470 kbps     01:08:51.127    26,852 kbps     01:08:51.001    114,395 bytes   202,585 bytes   01:08:56.423
23              1:09:46.015     0:03:56.235     20,573 kbps     29,521 kbps     01:12:17.333    25,961 kbps     01:11:44.675    25,273 kbps     01:11:44.758    107,259 bytes   223,551 bytes   01:10:18.172
24              1:13:42.251     0:05:19.444     19,584 kbps     31,202 kbps     01:17:52.709    26,774 kbps     01:18:19.444    25,941 kbps     01:18:14.523    102,104 bytes   265,099 bytes   01:15:21.308
25              1:19:01.695     0:03:37.717     17,575 kbps     32,626 kbps     01:21:02.274    21,647 kbps     01:20:40.335    20,892 kbps     01:20:38.041    91,626 bytes    264,461 bytes   01:21:02.816
26              1:22:39.412     0:04:13.378     17,678 kbps     23,353 kbps     01:26:29.851    21,551 kbps     01:26:29.851    20,270 kbps     01:26:26.681    92,165 bytes    221,695 bytes   01:25:21.616
27              1:26:52.790     0:03:16.237     14,347 kbps     19,595 kbps     01:29:30.907    17,556 kbps     01:28:16.165    16,868 kbps     01:28:14.539    74,798 bytes    215,930 bytes   01:30:09.028
28              1:30:09.028     0:03:51.731     15,314 kbps     25,748 kbps     01:30:09.028    18,213 kbps     01:30:09.028    17,505 kbps     01:32:15.488    79,841 bytes    180,299 bytes   01:30:09.070
29              1:34:00.760     0:02:48.167     19,783 kbps     37,053 kbps     01:34:42.468    26,219 kbps     01:34:42.301    24,276 kbps     01:34:42.301    103,188 bytes   289,567 bytes   01:35:17.503
STREAM DIAGNOSTICS:
00020.M2TS      4113 (0x1011)   0x1B            AVC                                     5808.845                18,947                  13,757,559,056  74,851,192
00020.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5808.845                1,064                   772,371,892     4,902,112
00020.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            5808.845                192                     139,415,040     907,650
00020.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            5808.845                192                     139,415,040     907,650
00020.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           5808.845                192                     139,415,040     907,650
00020.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           5808.845                192                     139,415,040     907,650
00020.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5808.845                24                      17,379,870      100,548
00020.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            5808.845                17                      12,592,983      72,828
00020.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            5808.845                25                      17,974,327      103,811
00020.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           5808.845                21                      14,952,233      86,927
00020.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           5808.845                24                      17,225,425      99,233
post #2903 of 5106 Old 04-08-2011, 04:18 PM - Thread Starter
[DE] Event Horizon (Additional Details)
Studio: Paramount
EAN: 4010884260120
Release Date: 2010-08-19
Taken from the German steelbook edition. Same encode and special features as the U.S. release, just with a different language package. It's region free, with no 50Hz content and a language selection menu on startup that includes English, so it's very import-friendly. Should be the same disc in the UK, Australia and Netherlands since it has those cert. logos in addition to the German FSK.
English DD 2.0 is a commentary (w/ English, French, German, Italian and Spanish commentary subs).
Code:
        Total   Video
[DE] Event Horizon                                              AVC     1:35:57 33,788,860,416  41,756,274,709  46.95   36.31   Dolby TrueHD 5.1 3452Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     EVENT_HORIZON_EU
Disc Size:      41,756,274,709 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:35:57 (h:m:s)
Total Bitrate:          46.95 Mbps
VIDEO:
MPEG-4 AVC Video        36313 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3452 kbps       5.1 / 48 kHz / 3452 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Italian         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           Danish          29.544 kbps
Presentation Graphics           German          31.337 kbps
Presentation Graphics           English         30.855 kbps
Presentation Graphics           Spanish         29.857 kbps
Presentation Graphics           French          26.696 kbps
Presentation Graphics           Italian         28.059 kbps
Presentation Graphics           Dutch           25.206 kbps
Presentation Graphics           Norwegian       26.000 kbps
Presentation Graphics           Finnish         25.674 kbps
Presentation Graphics           Swedish         26.687 kbps
Presentation Graphics           English         32.166 kbps
Presentation Graphics           German          49.202 kbps
Presentation Graphics           English         49.772 kbps
Presentation Graphics           Spanish         46.061 kbps
Presentation Graphics           French          41.835 kbps
Presentation Graphics           Italian         45.720 kbps
Presentation Graphics           German          0.567 kbps
Presentation Graphics           Spanish         0.541 kbps
Presentation Graphics           French          0.599 kbps
Presentation Graphics           Italian         0.531 kbps
FILES:
00000.M2TS      0:00:00.000     1:35:57.042     33,788,860,416  46,953
CHAPTERS:
1               0:00:00.000     0:05:41.007     33,806 kbps     42,541 kbps     00:03:45.725    39,418 kbps     00:03:41.721    38,480 kbps     00:03:36.716    176,227 bytes   389,782 bytes   00:03:46.184
2               0:05:41.007     0:02:45.957     36,341 kbps     39,215 kbps     00:06:14.624    37,887 kbps     00:06:10.620    37,612 kbps     00:06:47.949    189,463 bytes   319,035 bytes   00:06:43.903
3               0:08:26.964     0:03:45.016     36,700 kbps     39,527 kbps     00:08:56.744    37,907 kbps     00:08:52.740    37,728 kbps     00:08:47.735    191,337 bytes   315,737 bytes   00:09:07.213
4               0:12:11.981     0:06:26.969     37,288 kbps     40,426 kbps     00:12:19.447    37,841 kbps     00:12:41.761    37,709 kbps     00:12:36.756    194,404 bytes   298,359 bytes   00:15:19.501
5               0:18:38.951     0:04:40.780     35,849 kbps     44,837 kbps     00:20:33.941    38,784 kbps     00:20:29.937    37,663 kbps     00:20:48.080    186,902 bytes   427,065 bytes   00:19:53.650
6               0:23:19.731     0:05:46.054     36,100 kbps     44,145 kbps     00:28:14.275    38,472 kbps     00:24:01.314    37,996 kbps     00:23:56.309    188,211 bytes   389,792 bytes   00:27:34.235
7               0:29:05.785     0:04:55.295     36,570 kbps     45,670 kbps     00:30:40.922    38,923 kbps     00:30:36.918    38,218 kbps     00:30:31.913    190,658 bytes   346,324 bytes   00:33:42.603
8               0:34:01.080     0:05:22.238     36,680 kbps     41,135 kbps     00:39:20.649    38,191 kbps     00:39:16.645    37,730 kbps     00:36:41.532    191,233 bytes   364,831 bytes   00:38:55.416
9               0:39:23.319     0:05:45.303     36,029 kbps     50,162 kbps     00:44:52.648    38,568 kbps     00:44:19.657    38,018 kbps     00:44:14.735    187,838 bytes   490,865 bytes   00:44:53.315
10              0:45:08.622     0:06:00.985     36,873 kbps     39,860 kbps     00:49:58.203    37,817 kbps     00:50:20.100    37,674 kbps     00:50:15.178    192,239 bytes   387,123 bytes   00:50:25.105
11              0:51:09.608     0:07:08.094     36,105 kbps     44,123 kbps     00:52:51.042    38,213 kbps     00:54:05.992    37,715 kbps     00:55:41.129    188,234 bytes   447,631 bytes   00:54:42.779
12              0:58:17.702     0:06:20.254     36,691 kbps     41,590 kbps     01:02:11.519    37,737 kbps     01:01:29.185    37,660 kbps     01:01:36.943    191,289 bytes   321,232 bytes   01:02:12.186
13              1:04:37.957     0:04:52.000     36,722 kbps     48,422 kbps     01:06:50.047    38,075 kbps     01:08:36.112    37,770 kbps     01:08:21.180    191,454 bytes   438,750 bytes   01:06:50.715
14              1:09:29.957     0:05:35.209     36,691 kbps     41,496 kbps     01:13:08.342    37,834 kbps     01:11:04.635    37,635 kbps     01:12:35.893    191,289 bytes   351,389 bytes   01:14:45.772
15              1:15:05.167     0:07:15.393     36,590 kbps     41,824 kbps     01:20:38.834    38,099 kbps     01:18:34.584    37,606 kbps     01:18:15.607    190,765 bytes   364,941 bytes   01:16:59.239
16              1:22:20.560     0:07:14.392     36,648 kbps     42,522 kbps     01:25:26.162    38,548 kbps     01:25:22.158    37,871 kbps     01:29:21.481    191,066 bytes   346,132 bytes   01:23:51.985
17              1:29:34.952     0:06:22.090     35,586 kbps     52,054 kbps     01:31:08.254    40,400 kbps     01:31:04.250    38,935 kbps     01:30:59.245    185,550 bytes   468,723 bytes   01:35:53.205
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5756.960                36,313                  26,131,673,911  142,100,659
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           5756.960                4,092                   2,944,918,412   19,673,465
00000.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            5756.960                640                     460,564,480     2,698,620
00000.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           5756.960                640                     460,564,480     2,698,620
00000.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           5756.960                224                     161,197,568     899,540
00000.M2TS      4356 (0x1104)   0x81            AC3             deu (German)            5756.960                640                     460,564,480     2,698,620
00000.M2TS      4357 (0x1105)   0x81            AC3             ita (Italian)           5756.960                640                     460,564,480     2,698,620
00000.M2TS      4608 (0x1200)   0x90            PGS             dan (Danish)            5756.960                30                      21,260,823      122,832
00000.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            5756.960                31                      22,551,377      129,851
00000.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           5756.960                31                      22,204,211      127,800
00000.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           5756.960                30                      21,486,157      124,071
00000.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            5756.960                27                      19,210,945      111,706
00000.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           5756.960                28                      20,192,186      117,037
00000.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             5756.960                25                      18,138,661      105,871
00000.M2TS      4615 (0x1207)   0x90            PGS             nor (Norwegian)         5756.960                26                      18,710,149      108,973
00000.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           5756.960                26                      18,475,644      107,705
00000.M2TS      4617 (0x1209)   0x90            PGS             swe (Swedish)           5756.960                27                      19,205,022      111,674
00000.M2TS      4618 (0x120A)   0x90            PGS             eng (English)           5756.960                32                      23,147,646      133,272
00000.M2TS      4619 (0x120B)   0x90            PGS             deu (German)            5756.960                49                      35,406,984      200,811
00000.M2TS      4620 (0x120C)   0x90            PGS             eng (English)           5756.960                50                      35,817,734      202,989
00000.M2TS      4621 (0x120D)   0x90            PGS             spa (Spanish)           5756.960                46                      33,147,076      188,495
00000.M2TS      4622 (0x120E)   0x90            PGS             fra (French)            5756.960                42                      30,106,039      171,974
00000.M2TS      4623 (0x120F)   0x90            PGS             ita (Italian)           5756.960                46                      32,901,145      187,142
00000.M2TS      4624 (0x1210)   0x90            PGS             deu (German)            5756.960                1                       407,940         2,317
00000.M2TS      4625 (0x1211)   0x90            PGS             spa (Spanish)           5756.960                1                       389,564         2,222
00000.M2TS      4626 (0x1212)   0x90            PGS             fra (French)            5756.960                1                       431,235         2,449
00000.M2TS      4627 (0x1213)   0x90            PGS             ita (Italian)           5756.960                1                       382,418         2,178
post #2904 of 5106 Old 04-08-2011, 04:24 PM - Thread Starter
[DE] Cloverfield (Additional Details)
Studio: Paramount
EAN: 4010884260076
Code:
        Total   Video
[DE] Cloverfield                                                VC-1    1:24:40 26,226,253,824  44,184,736,580  41.30   30.43   Dolby TrueHD 5.1 3463Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     CLOVERFIELD_EU
Disc Size:      44,184,736,580 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:24:40 (h:m:s)
Total Bitrate:          41.30 Mbps
VIDEO:
VC-1 Video              30426 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         3463 kbps       5.1 / 48 kHz / 3463 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           Danish          27.568 kbps
Presentation Graphics           German          43.633 kbps
Presentation Graphics           Greek           24.835 kbps
Presentation Graphics           English         45.070 kbps
Presentation Graphics           English         51.760 kbps
Presentation Graphics           Spanish         27.831 kbps
Presentation Graphics           Finnish         24.943 kbps
Presentation Graphics           French          21.905 kbps
Presentation Graphics           Hungarian       27.578 kbps
Presentation Graphics           Italian         36.221 kbps
Presentation Graphics           Dutch           21.290 kbps
Presentation Graphics           Norwegian       23.821 kbps
Presentation Graphics           Polish          27.028 kbps
Presentation Graphics           Portuguese      27.315 kbps
Presentation Graphics           Swedish         27.966 kbps
Presentation Graphics           Turkish         28.007 kbps
Presentation Graphics           German          74.953 kbps
Presentation Graphics           English         78.539 kbps
Presentation Graphics           Spanish         63.940 kbps
Presentation Graphics           French          67.204 kbps
Presentation Graphics           Italian         62.337 kbps
Presentation Graphics           German          0.280 kbps
Presentation Graphics           Spanish         0.318 kbps
Presentation Graphics           French          0.166 kbps
Presentation Graphics           Italian         0.296 kbps
FILES:
00000.M2TS      0:00:00.000     1:24:40.533     26,226,253,824  41,297
CHAPTERS:
1               0:00:00.000     0:05:03.469     27,910 kbps     44,885 kbps     00:01:28.129    38,266 kbps     00:01:27.879    36,873 kbps     00:01:27.879    149,769 bytes   516,439 bytes   00:00:12.178
2               0:05:03.469     0:04:37.902     34,713 kbps     43,671 kbps     00:07:46.632    38,630 kbps     00:07:46.632    37,501 kbps     00:07:45.131    180,979 bytes   481,394 bytes   00:06:12.705
3               0:09:41.372     0:05:20.987     34,888 kbps     43,169 kbps     00:11:34.652    37,660 kbps     00:09:49.922    37,133 kbps     00:10:12.445    181,892 bytes   527,374 bytes   00:14:41.547
4               0:15:02.359     0:04:23.471     33,992 kbps     55,373 kbps     00:18:29.316    38,799 kbps     00:16:19.436    37,286 kbps     00:16:14.431    177,220 bytes   626,376 bytes   00:18:35.489
5               0:19:25.831     0:04:56.004     32,801 kbps     57,292 kbps     00:20:20.427    38,803 kbps     00:22:43.695    37,825 kbps     00:20:20.427    171,322 bytes   855,822 bytes   00:20:20.552
6               0:24:21.835     0:05:00.883     34,508 kbps     53,536 kbps     00:26:35.510    39,710 kbps     00:26:35.510    37,879 kbps     00:28:01.846    179,907 bytes   617,475 bytes   00:24:29.092
7               0:29:22.719     0:04:12.752     34,375 kbps     47,400 kbps     00:30:59.732    38,271 kbps     00:33:29.007    36,782 kbps     00:30:58.606    179,213 bytes   530,998 bytes   00:31:25.008
8               0:33:35.471     0:02:47.167     33,498 kbps     45,842 kbps     00:36:04.954    38,699 kbps     00:35:50.148    37,543 kbps     00:35:48.896    174,644 bytes   684,305 bytes   00:35:38.302
9               0:36:22.638     0:05:02.635     34,681 kbps     52,898 kbps     00:41:00.040    39,950 kbps     00:36:25.391    37,531 kbps     00:36:23.055    181,087 bytes   495,283 bytes   00:36:23.097
10              0:41:25.274     0:04:03.159     29,424 kbps     61,111 kbps     00:43:50.961    38,876 kbps     00:42:31.799    37,031 kbps     00:42:32.925    153,403 bytes   705,131 bytes   00:44:45.349
11              0:45:28.434     0:03:47.560     35,427 kbps     49,568 kbps     00:45:47.786    38,449 kbps     00:46:17.399    37,161 kbps     00:46:12.519    184,701 bytes   747,706 bytes   00:45:28.559
12              0:49:15.994     0:04:18.549     34,831 kbps     51,682 kbps     00:53:00.385    38,614 kbps     00:51:26.082    37,351 kbps     00:50:04.126    181,595 bytes   554,735 bytes   00:50:37.200
13              0:53:34.544     0:05:33.624     31,959 kbps     46,499 kbps     00:55:18.732    40,059 kbps     00:55:14.728    38,060 kbps     00:55:09.806    166,620 bytes   646,848 bytes   00:55:19.607
14              0:59:08.169     0:07:47.383     32,372 kbps     57,422 kbps     01:03:49.242    39,115 kbps     01:03:49.325    37,453 kbps     00:59:08.169    168,775 bytes   644,590 bytes   01:03:49.951
15              1:06:55.553     0:06:48.491     31,136 kbps     58,327 kbps     01:10:42.613    38,904 kbps     01:08:47.832    37,800 kbps     01:08:47.832    163,529 bytes   660,012 bytes   01:09:14.400
16              1:13:44.044     0:10:56.489     13,255 kbps     43,421 kbps     01:13:58.142    38,579 kbps     01:13:55.472    36,783 kbps     01:13:54.388    69,377 bytes    595,945 bytes   01:24:33.860
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    5080.409                30,427                  19,322,801,535  105,088,919
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           5080.409                4,103                   2,605,543,006   17,911,947
00000.M2TS      4353 (0x1101)   0x81            AC3             deu (German)            5080.409                640                     406,443,520     2,381,505
00000.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           5080.409                640                     406,443,520     2,381,505
00000.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            5080.409                640                     406,443,520     2,381,505
00000.M2TS      4356 (0x1104)   0x81            AC3             ita (Italian)           5080.409                640                     406,443,520     2,381,505
00000.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           5080.409                192                     121,933,056     793,835
00000.M2TS      4608 (0x1200)   0x90            PGS             dan (Danish)            5080.409                28                      17,507,823      102,200
00000.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            5080.409                44                      27,710,071      158,955
00000.M2TS      4610 (0x1202)   0x90            PGS             ell (Greek)             5080.409                25                      15,771,570      91,613
00000.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           5080.409                45                      28,622,436      163,764
00000.M2TS      4612 (0x1204)   0x90            PGS             eng (English)           5080.409                52                      32,871,131      187,963
00000.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           5080.409                28                      17,674,343      103,000
00000.M2TS      4614 (0x1206)   0x90            PGS             fin (Finnish)           5080.409                25                      15,840,215      92,795
00000.M2TS      4615 (0x1207)   0x90            PGS             fra (French)            5080.409                22                      13,911,240      81,795
00000.M2TS      4616 (0x1208)   0x90            PGS             hun (Hungarian)         5080.409                28                      17,513,859      102,534
00000.M2TS      4617 (0x1209)   0x90            PGS             ita (Italian)           5080.409                36                      23,002,595      133,375
00000.M2TS      4618 (0x120A)   0x90            PGS             nld (Dutch)             5080.409                21                      13,520,646      79,586
00000.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         5080.409                24                      15,127,778      89,100
00000.M2TS      4620 (0x120C)   0x90            PGS             pol (Polish)            5080.409                27                      17,164,648      100,331
00000.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        5080.409                27                      17,346,836      100,974
00000.M2TS      4622 (0x120E)   0x90            PGS             swe (Swedish)           5080.409                28                      17,760,331      103,529
00000.M2TS      4623 (0x120F)   0x90            PGS             tur (Turkish)           5080.409                28                      17,786,380      103,874
00000.M2TS      4624 (0x1210)   0x90            PGS             deu (German)            5080.409                75                      47,600,367      269,377
00000.M2TS      4625 (0x1211)   0x90            PGS             eng (English)           5080.409                79                      49,877,215      281,692
00000.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           5080.409                64                      40,606,157      231,358
00000.M2TS      4627 (0x1213)   0x90            PGS             fra (French)            5080.409                67                      42,679,274      242,621
00000.M2TS      4628 (0x1214)   0x90            PGS             ita (Italian)           5080.409                62                      39,588,466      225,839
00000.M2TS      4629 (0x1215)   0x90            PGS             deu (German)            5080.409                0                       177,560         1,000
00000.M2TS      4630 (0x1216)   0x90            PGS             spa (Spanish)           5080.409                0                       201,796         1,139
00000.M2TS      4631 (0x1217)   0x90            PGS             fra (French)            5080.409                0                       105,536         603
00000.M2TS      4632 (0x1218)   0x90            PGS             ita (Italian)           5080.409                0                       187,897         1,056
post #2905 of 5106 Old 04-08-2011, 04:27 PM - Thread Starter
[US] Galaxy of Terror (Additional Details)
Studio: Shout! Factory
UPC: 826663121964
Release Date: 2010-07-20
One of the DTS-HD Master 2.0 tracks is the main stereo mix and the other is a commentary. There aren't actually any subtitles - the English graphics track is a trivia track.
Code:
        Total   Video
[US] Galaxy of Terror                                           AVC     1:21:32 19,941,046,272  37,194,877,645  32.60   26.92   DTS-HD Master 2.0 1878Kbps (48kHz/24-bit) DTS-HD Master 2.0 1857Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     Galaxy of Terror
Disc Size:      37,194,877,645 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:21:32 (h:m:s)
Total Bitrate:          32.60 Mbps
VIDEO:
MPEG-4 AVC Video        26921 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1878 kbps       2.0 / 48 kHz / 1878 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         1857 kbps       2.0 / 48 kHz / 1857 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         27.578 kbps
FILES:
00004.M2TS      0:00:00.000     1:21:32.888     19,941,046,272  32,604
CHAPTERS:
1               0:00:00.000     0:05:15.481     22,976 kbps     37,581 kbps     00:02:01.204    29,131 kbps     00:04:10.500    28,701 kbps     00:04:10.375    119,768 bytes   331,981 bytes   00:04:11.584
2               0:05:15.481     0:08:13.326     27,840 kbps     38,808 kbps     00:08:47.026    33,709 kbps     00:08:11.949    32,860 kbps     00:07:32.577    145,147 bytes   381,167 bytes   00:08:46.359
3               0:13:28.808     0:07:01.003     27,753 kbps     36,627 kbps     00:15:45.527    33,913 kbps     00:16:44.128    33,152 kbps     00:16:39.373    144,692 bytes   363,389 bytes   00:16:42.876
4               0:20:29.811     0:07:18.271     27,603 kbps     42,206 kbps     00:23:22.401    40,237 kbps     00:23:18.647    35,725 kbps     00:23:15.685    143,911 bytes   408,605 bytes   00:23:23.235
5               0:27:48.083     0:05:41.716     25,860 kbps     33,135 kbps     00:30:42.590    31,146 kbps     00:29:10.790    30,137 kbps     00:29:05.994    134,823 bytes   427,602 bytes   00:29:14.961
6               0:33:29.799     0:03:46.142     23,506 kbps     35,489 kbps     00:36:30.646    28,552 kbps     00:33:49.068    27,157 kbps     00:33:49.569    122,549 bytes   319,877 bytes   00:34:08.296
7               0:37:15.942     0:03:47.685     25,872 kbps     47,199 kbps     00:40:32.388    35,793 kbps     00:40:30.428    31,363 kbps     00:40:25.506    134,885 bytes   388,436 bytes   00:40:33.305
8               0:41:03.627     0:07:29.490     28,664 kbps     38,453 kbps     00:46:44.384    33,188 kbps     00:45:48.454    32,678 kbps     00:45:43.407    149,443 bytes   382,389 bytes   00:46:25.991
9               0:48:33.118     0:13:01.030     27,702 kbps     38,487 kbps     00:55:06.636    35,944 kbps     00:55:02.632    34,336 kbps     00:54:57.627    144,425 bytes   408,407 bytes   00:55:42.297
10              1:01:34.148     0:04:33.606     27,528 kbps     33,774 kbps     01:04:12.223    31,514 kbps     01:05:21.876    30,891 kbps     01:05:16.871    143,516 bytes   343,162 bytes   01:05:25.338
11              1:06:07.755     0:04:13.544     24,394 kbps     39,723 kbps     01:07:14.196    35,413 kbps     01:06:07.880    31,519 kbps     01:06:07.755    127,177 bytes   362,996 bytes   01:06:10.257
12              1:10:21.300     0:09:12.009     28,308 kbps     52,405 kbps     01:13:22.898    39,762 kbps     01:19:23.592    37,727 kbps     01:14:46.940    147,583 bytes   448,918 bytes   01:13:27.277
13              1:19:33.310     0:01:59.577     25,515 kbps     44,061 kbps     01:21:26.756    39,850 kbps     01:21:26.131    30,863 kbps     01:21:21.376    133,070 bytes   499,120 bytes   01:21:31.136
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     4892.763                26,922                  16,465,246,335  89,553,783
00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4892.763                1,878                   1,148,765,392   7,009,209
00004.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           4892.763                1,857                   1,136,008,656   6,982,459
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4892.763                28                      16,867,230      96,492
post #2906 of 5106 Old 04-08-2011, 04:33 PM - Thread Starter
Cinema Squid's Avatar
[UK] Les Vacances de Monsieur Hulot (Additional Details)
Region Locked (B) (Confirmed w/ PowerDVD set to all three regions)
Studio: BFI
EAN: 5035673010501
Release Date: 2010-11-29
Aspect Ratio: 1.33:1
For the primary version (shorter cut), audio is original French and the international "English". The two sub tracks correspond to each of these respectively.
Code:
        Total   Video
Les Vacances de Monsieur Hulot                                  AVC     1:28:10 22,860,638,208  44,356,774,643  34.57   30.00   LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     LES_VACANCES
Disc Size:      44,356,774,643 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:28:10 (h:m:s)
Total Bitrate:          34.57 Mbps
VIDEO:
MPEG-4 AVC Video        29999 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      French          2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
Dolby Digital Audio             English         640 kbps        2.0 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         8.751 kbps
Presentation Graphics           English         3.575 kbps
FILES:
00004.M2TS      0:00:00.000     1:28:10.708     22,860,638,208  34,567
CHAPTERS:
1               0:00:00.000     0:02:02.458     14,877 kbps     35,592 kbps     00:01:46.958    34,170 kbps     00:01:40.625    33,746 kbps     00:01:39.958    77,460 bytes    318,898 bytes   00:01:45.000
2               0:02:02.458     0:08:56.750     27,785 kbps     38,210 kbps     00:10:42.750    35,315 kbps     00:07:09.125    34,170 kbps     00:07:09.041    144,712 bytes   368,430 bytes   00:05:46.166
3               0:10:59.208     0:03:30.958     31,783 kbps     38,817 kbps     00:13:34.166    36,890 kbps     00:13:33.333    35,980 kbps     00:12:04.000    165,534 bytes   350,737 bytes   00:14:16.166
4               0:14:30.166     0:01:45.583     31,162 kbps     37,240 kbps     00:14:36.125    34,797 kbps     00:15:21.208    33,312 kbps     00:15:16.208    162,304 bytes   347,603 bytes   00:14:47.916
5               0:16:15.750     0:05:26.458     31,142 kbps     38,063 kbps     00:20:53.375    36,192 kbps     00:20:53.041    35,232 kbps     00:20:51.208    162,200 bytes   341,778 bytes   00:17:13.375
6               0:21:42.208     0:03:00.708     31,994 kbps     37,229 kbps     00:24:13.166    35,413 kbps     00:23:59.208    35,104 kbps     00:23:53.375    166,633 bytes   354,757 bytes   00:22:02.125
7               0:24:42.916     0:09:10.250     30,223 kbps     39,809 kbps     00:26:50.333    36,724 kbps     00:25:42.166    35,538 kbps     00:29:52.666    157,411 bytes   373,746 bytes   00:26:28.625
8               0:33:53.166     0:05:27.625     31,160 kbps     39,465 kbps     00:38:12.000    36,468 kbps     00:38:42.875    35,814 kbps     00:38:42.625    162,291 bytes   342,134 bytes   00:34:41.375
9               0:39:20.791     0:04:11.750     31,957 kbps     39,893 kbps     00:43:23.666    36,836 kbps     00:40:54.416    36,273 kbps     00:40:51.666    166,444 bytes   373,756 bytes   00:43:27.291
10              0:43:32.541     0:04:00.958     29,514 kbps     38,438 kbps     00:47:27.250    35,905 kbps     00:47:24.958    35,272 kbps     00:47:23.458    153,717 bytes   392,935 bytes   00:44:21.375
11              0:47:33.500     0:06:25.833     29,839 kbps     42,250 kbps     00:52:39.541    38,569 kbps     00:53:21.041    35,593 kbps     00:49:20.250    155,413 bytes   378,336 bytes   00:49:56.750
12              0:53:59.333     0:03:31.750     32,464 kbps     38,737 kbps     00:54:36.666    36,853 kbps     00:54:35.666    36,285 kbps     00:54:34.666    169,086 bytes   353,145 bytes   00:56:27.000
13              0:57:31.083     0:09:02.958     31,868 kbps     38,635 kbps     00:58:44.083    36,316 kbps     00:58:43.333    36,274 kbps     00:58:43.083    165,978 bytes   357,391 bytes   01:00:48.958
14              1:06:34.041     0:03:48.000     33,494 kbps     38,795 kbps     01:06:41.000    37,287 kbps     01:06:39.291    36,193 kbps     01:06:39.000    174,449 bytes   334,217 bytes   01:07:29.333
15              1:10:22.041     0:07:45.583     28,486 kbps     39,505 kbps     01:15:28.291    36,585 kbps     01:17:45.708    33,599 kbps     01:13:37.833    148,364 bytes   399,676 bytes   01:17:55.541
16              1:18:07.625     0:02:04.833     32,373 kbps     38,173 kbps     01:19:27.541    37,016 kbps     01:19:24.916    35,970 kbps     01:19:19.458    168,608 bytes   333,447 bytes   01:19:22.583
17              1:20:12.458     0:04:22.916     31,518 kbps     45,008 kbps     01:22:42.083    36,979 kbps     01:20:56.458    35,570 kbps     01:20:53.083    164,155 bytes   342,692 bytes   01:21:59.750
18              1:24:35.375     0:03:35.333     23,794 kbps     37,920 kbps     01:25:40.916    36,328 kbps     01:25:37.916    34,754 kbps     01:25:37.916    123,949 bytes   348,333 bytes   01:27:38.791
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     5290.542                30,000                  19,839,384,056  107,896,557
00004.M2TS      4352 (0x1100)   0x80            LPCM            fra (French)            5290.542                2,310                   1,527,957,048   8,465,136
00004.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5290.542                640                     423,257,600     2,480,025
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5290.542                9                       5,787,409       33,161
00004.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5290.542                4                       2,364,506       13,662
Original Release Version
Code:
        Total   Video
Les Vacances de Monsieur Hulot: Original Release Version        AVC     1:38:47 21,212,547,072  44,356,774,643  28.63   25.00   LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:38:47 (h:m:s)
Total Bitrate:          28.63 Mbps
VIDEO:
MPEG-4 AVC Video        24999 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
SUBTITLES:
Presentation Graphics           English         11.336 kbps
FILES:
00005.M2TS      0:00:00.000     1:38:47.541     21,212,547,072  28,629
CHAPTERS:
1               0:00:00.000     0:01:34.250     21,338 kbps     34,210 kbps     00:01:33.208    31,465 kbps     00:01:17.125    29,527 kbps     00:01:16.958    111,088 bytes   286,608 bytes   00:01:20.000
2               0:01:34.250     0:09:44.416     25,520 kbps     39,000 kbps     00:04:48.375    36,240 kbps     00:07:12.250    33,734 kbps     00:07:12.583    132,916 bytes   303,655 bytes   00:05:27.500
3               0:11:18.666     0:04:09.500     26,279 kbps     42,358 kbps     00:13:58.000    34,167 kbps     00:13:54.916    30,851 kbps     00:13:54.000    136,867 bytes   289,876 bytes   00:14:32.166
4               0:15:28.166     0:01:55.208     24,830 kbps     37,146 kbps     00:16:21.250    29,412 kbps     00:16:19.500    27,218 kbps     00:16:14.500    129,322 bytes   284,682 bytes   00:17:07.291
5               0:17:23.375     0:06:19.583     25,352 kbps     36,724 kbps     00:20:38.041    29,495 kbps     00:22:54.375    28,613 kbps     00:22:52.916    132,044 bytes   292,152 bytes   00:19:22.750
6               0:23:42.958     0:03:00.708     25,073 kbps     30,772 kbps     00:24:11.125    28,924 kbps     00:24:08.125    28,625 kbps     00:24:08.125    130,589 bytes   289,899 bytes   00:25:08.750
7               0:26:43.666     0:11:41.416     24,861 kbps     42,441 kbps     00:28:52.000    37,822 kbps     00:31:19.333    31,708 kbps     00:31:15.458    129,484 bytes   303,193 bytes   00:31:33.958
8               0:38:25.083     0:05:39.916     25,626 kbps     39,485 kbps     00:43:23.458    31,254 kbps     00:39:22.416    29,969 kbps     00:43:38.416    133,468 bytes   286,945 bytes   00:40:02.875
9               0:44:05.000     0:04:23.125     25,362 kbps     41,990 kbps     00:48:20.583    35,417 kbps     00:46:41.833    31,584 kbps     00:45:37.000    132,091 bytes   291,890 bytes   00:47:59.541
10              0:48:28.125     0:03:36.625     22,879 kbps     31,215 kbps     00:50:34.916    27,632 kbps     00:51:49.708    26,879 kbps     00:51:44.666    119,160 bytes   299,975 bytes   00:50:10.750
11              0:52:04.750     0:08:06.541     24,395 kbps     40,858 kbps     00:59:35.541    38,258 kbps     00:59:00.958    34,523 kbps     00:58:58.125    127,057 bytes   293,207 bytes   00:58:23.750
12              1:00:11.291     0:04:10.041     24,903 kbps     38,198 kbps     01:02:47.333    32,261 kbps     01:00:50.916    30,193 kbps     01:00:48.250    129,701 bytes   284,263 bytes   01:03:40.458
13              1:04:21.333     0:10:01.666     24,803 kbps     35,819 kbps     01:08:48.083    29,404 kbps     01:08:44.125    29,346 kbps     01:08:45.583    129,180 bytes   292,196 bytes   01:04:44.458
14              1:14:23.000     0:03:49.041     25,770 kbps     36,467 kbps     01:16:52.791    30,599 kbps     01:18:05.083    28,833 kbps     01:16:46.208    134,217 bytes   284,149 bytes   01:15:05.708
15              1:18:12.041     0:09:25.375     24,053 kbps     39,283 kbps     01:24:02.750    34,073 kbps     01:26:50.500    28,572 kbps     01:26:49.500    125,274 bytes   304,945 bytes   01:27:08.583
16              1:27:37.416     0:02:39.083     24,245 kbps     33,549 kbps     01:29:28.958    29,666 kbps     01:29:28.916    27,987 kbps     01:29:29.000    126,274 bytes   285,478 bytes   01:30:00.041
17              1:30:16.500     0:04:57.000     27,937 kbps     41,373 kbps     01:33:11.875    35,089 kbps     01:31:13.250    33,383 kbps     01:31:10.000    145,505 bytes   286,754 bytes   01:33:04.750
18              1:35:13.500     0:03:34.041     24,459 kbps     36,155 kbps     01:38:06.000    33,969 kbps     01:38:01.916    33,544 kbps     01:37:57.000    127,416 bytes   293,652 bytes   01:36:05.083
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     5927.417                25,000                  18,522,976,562  100,751,388
00005.M2TS      4352 (0x1100)   0x80            LPCM            fra (French)            5927.417                2,310                   1,711,874,996   9,484,072
00005.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5927.417                11                      8,399,649       47,957
Cinema Squid is offline
post #2907 of 5106 Old 04-08-2011, 04:36 PM - Thread Starter
[UK] Peeping Tom (Additional Details)
Studio: Optimum
EAN: 5055201811035
Release Date: 2010-11-22
Aspect Ratio: 1.66:1
Code:
        Total   Video
[UK] Peeping Tom                                                AVC     1:41:39 27,537,199,104  34,186,821,778  36.12   31.92   LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     PEEPING_TOM
Disc Size:      34,186,821,778 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.7
PLAYLIST REPORT:
Length:                 1:41:39 (h:m:s)
Total Bitrate:          36.12 Mbps
VIDEO:
MPEG-4 AVC Video        31924 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
SUBTITLES:
Presentation Graphics           English         31.603 kbps
FILES:
00007.M2TS      0:00:00.000     1:41:39.500     27,537,199,104  36,117
CHAPTERS:
1               0:00:00.000     0:09:11.500     30,043 kbps     48,987 kbps     00:05:33.666    42,760 kbps     00:05:33.625    39,537 kbps     00:05:49.833    156,461 bytes   630,692 bytes   00:05:35.708
2               0:09:11.500     0:07:11.541     33,989 kbps     44,421 kbps     00:10:48.791    39,847 kbps     00:12:44.541    39,135 kbps     00:11:31.208    177,028 bytes   707,032 bytes   00:11:17.958
3               0:16:23.041     0:11:30.958     27,955 kbps     46,862 kbps     00:24:04.541    39,276 kbps     00:24:01.833    36,778 kbps     00:24:20.583    145,601 bytes   572,494 bytes   00:17:11.833
4               0:27:54.000     0:07:54.875     35,815 kbps     50,023 kbps     00:28:25.458    44,205 kbps     00:28:23.250    40,414 kbps     00:28:23.250    186,535 bytes   657,285 bytes   00:33:49.250
5               0:35:48.875     0:12:13.291     32,089 kbps     48,131 kbps     00:47:39.500    42,203 kbps     00:47:38.458    41,534 kbps     00:47:33.583    167,132 bytes   686,495 bytes   00:47:37.541
6               0:48:02.166     0:08:14.291     31,495 kbps     48,158 kbps     00:53:20.333    42,705 kbps     00:53:17.208    40,892 kbps     00:53:17.500    164,034 bytes   660,745 bytes   00:53:27.375
7               0:56:16.458     0:10:36.083     32,942 kbps     47,403 kbps     01:00:43.833    40,329 kbps     01:04:47.208    39,200 kbps     01:04:08.041    171,573 bytes   597,948 bytes   01:04:49.916
8               1:06:52.541     0:14:00.875     33,849 kbps     49,504 kbps     01:15:16.458    43,754 kbps     01:11:35.000    41,144 kbps     01:11:29.916    176,297 bytes   689,172 bytes   01:15:38.250
9               1:20:53.416     0:06:03.583     32,551 kbps     45,929 kbps     01:21:01.500    41,061 kbps     01:21:00.375    39,552 kbps     01:21:27.041    169,535 bytes   707,566 bytes   01:21:02.541
10              1:26:57.000     0:07:53.708     33,738 kbps     49,229 kbps     01:26:59.458    43,127 kbps     01:26:57.125    41,201 kbps     01:26:57.875    175,719 bytes   699,376 bytes   01:26:59.541
11              1:34:50.708     0:03:35.333     27,952 kbps     40,264 kbps     01:37:33.500    34,863 kbps     01:37:47.250    34,319 kbps     01:37:47.291    145,583 bytes   566,564 bytes   01:38:26.041
12              1:38:26.041     0:03:13.458     24,854 kbps     49,659 kbps     01:38:30.000    43,684 kbps     01:38:27.250    40,231 kbps     01:38:26.041    129,476 bytes   549,507 bytes   01:38:28.041
STREAM DIAGNOSTICS:
00007.M2TS      4113 (0x1011)   0x1B            AVC                                     6099.375                31,924                  24,339,886,406  132,367,483
00007.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           6099.375                2,310                   1,761,535,600   9,759,200
00007.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6099.375                192                     146,388,480     953,050
00007.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6099.375                32                      24,095,652      138,831
post #2908 of 5106 Old 04-09-2011, 08:37 AM
Jojos's Avatar
[NL] Species
Region Locked (B)
Studio: MGM
EAN: 8712626031970
Release Date: 2007-11-28
Aspect Ratio: 2.35:1
Code:
        Total   Video
00000.MPLS                                                      AVC     1:48:25 20.708.161.536  22.182.678.008  25,47   20,30   DTS-HD Master 5.1 2247Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     SPECIES
Disc Size:      22.182.678.008 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 1:48:25 (h:m:s)
Total Bitrate:          25,47 Mbps
VIDEO:
MPEG-4 AVC Video        20296 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2247 kbps       5.1 / 48 kHz / 2247 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         23,833 kbps
Presentation Graphics           Dutch           19,902 kbps
Presentation Graphics           Dutch           47,933 kbps
Presentation Graphics           Dutch           54,057 kbps
Presentation Graphics           French          20,726 kbps
Presentation Graphics           French          0,207 kbps
Presentation Graphics           French          38,281 kbps
Presentation Graphics           French          50,594 kbps
FILES:
00000.M2TS      0:00:00.000     1:48:25.457     20.708.161.536  25.466
CHAPTERS:
1               0:00:00.000     0:06:13.748     19.723 kbps     36.190 kbps     00:05:17.567    31.233 kbps     00:05:39.839    28.427 kbps     00:05:36.419    102.817 bytes   449.515 bytes   00:05:24.741
2               0:06:13.748     0:07:21.649     21.300 kbps     36.419 kbps     00:06:55.790    27.925 kbps     00:06:44.070    26.465 kbps     00:08:44.649    111.051 bytes   450.035 bytes   00:08:54.242
3               0:13:35.397     0:05:04.137     19.774 kbps     35.143 kbps     00:13:55.793    30.780 kbps     00:13:51.789    29.851 kbps     00:13:46.784    103.095 bytes   492.875 bytes   00:13:56.335
4               0:18:39.535     0:08:33.471     19.991 kbps     35.614 kbps     00:21:45.053    25.304 kbps     00:20:41.198    23.918 kbps     00:20:38.445    104.222 bytes   464.738 bytes   00:20:18.175
5               0:27:13.006     0:03:49.729     21.400 kbps     31.775 kbps     00:28:02.889    27.423 kbps     00:28:01.262    24.370 kbps     00:27:58.510    111.572 bytes   451.028 bytes   00:28:04.599
6               0:31:02.735     0:10:38.304     20.513 kbps     37.539 kbps     00:40:27.800    33.237 kbps     00:31:17.959    31.547 kbps     00:31:17.625    106.944 bytes   476.464 bytes   00:40:52.116
7               0:41:41.040     0:06:28.638     18.700 kbps     41.690 kbps     00:45:08.706    33.775 kbps     00:45:08.706    27.157 kbps     00:45:08.706    97.491 bytes    420.121 bytes   00:45:08.747
8               0:48:09.678     0:04:15.546     21.566 kbps     29.860 kbps     00:49:18.455    26.287 kbps     00:48:45.213    25.570 kbps     00:48:43.837    112.433 bytes   435.439 bytes   00:49:42.604
9               0:52:25.225     0:07:22.817     20.101 kbps     41.761 kbps     00:57:40.331    32.090 kbps     00:57:40.331    28.946 kbps     00:57:40.331    104.796 bytes   472.486 bytes   00:58:10.570
10              0:59:48.042     0:06:06.574     19.395 kbps     30.597 kbps     01:05:47.318    25.543 kbps     01:05:45.483    24.037 kbps     01:05:40.645    101.116 bytes   551.721 bytes   01:05:47.360
11              1:05:54.617     0:07:03.089     21.273 kbps     31.645 kbps     01:09:42.887    26.716 kbps     01:11:44.466    24.308 kbps     01:06:37.326    110.910 bytes   500.691 bytes   01:06:37.368
12              1:12:57.706     0:06:01.486     19.424 kbps     27.005 kbps     01:16:10.983    22.360 kbps     01:16:47.394    22.116 kbps     01:16:46.768    101.269 bytes   396.731 bytes   01:18:59.192
13              1:18:59.192     0:07:45.047     20.561 kbps     36.990 kbps     01:21:17.414    33.564 kbps     01:21:05.944    32.336 kbps     01:21:09.114    107.195 bytes   426.264 bytes   01:26:26.639
14              1:26:44.240     0:05:27.160     20.264 kbps     30.812 kbps     01:26:53.583    24.934 kbps     01:26:52.916    23.642 kbps     01:26:49.662    105.646 bytes   383.709 bytes   01:29:59.310
15              1:32:11.400     0:06:40.441     21.115 kbps     42.141 kbps     01:36:41.212    34.014 kbps     01:36:59.271    31.920 kbps     01:36:59.271    110.083 bytes   459.766 bytes   01:37:03.067
16              1:38:51.842     0:09:33.614     20.064 kbps     42.224 kbps     01:41:16.070    30.935 kbps     01:40:32.943    29.688 kbps     01:42:07.871    104.619 bytes   437.770 bytes   01:46:03.815
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6505,374                20.296                  16.504.235.556  89.788.525
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6505,374                2.247                   1.827.035.896   10.961.548
00000.M2TS      4353 (0x1101)   0x82            DTS             fra (French)            6505,374                768                     624.524.288     3.659.322
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6505,374                224                     182.153.216     1.016.480
00000.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6505,374                224                     182.153.216     1.016.480
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6505,374                24                      19.380.246      112.284
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            6505,374                21                      16.854.360      97.462
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6505,374                0                       168.244         972
00000.M2TS      4611 (0x1203)   0x90            PGS             nld (Dutch)             6505,374                20                      16.184.331      93.841
00000.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6505,374                38                      31.129.571      179.204
00000.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            6505,374                51                      41.142.012      235.417
00000.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             6505,374                48                      38.978.370      224.902
00000.M2TS      4615 (0x1207)   0x90            PGS             nld (Dutch)             6505,374                54                      43.957.827      250.593
Jojos is offline
post #2909 of 5106 Old 04-09-2011, 08:40 AM
Jojos's Avatar
[FR] Lord of War
Region Free
Studio: M6 Vidéo
EAN: 3475001012722
Release Date: 2008-06-04
English 2.0 = commentary.
Code:
        Total   Video
00000.MPLS                                                      AVC     2:01:54 38.433.871.872  44.273.557.196  42,03   35,00   DTS-HD Master 6.1 2307Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LORD_OF_WAR
Disc Size:      44.273.557.196 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:01:54 (h:m:s)
Total Bitrate:          42,03 Mbps
VIDEO:
MPEG-4 AVC Video        35000 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2307 kbps       6.1 / 48 kHz / 2307 kbps / 16-bit (DTS Core: 6.1-ES / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             French          2141 kbps       5.1 / 48 kHz / 2141 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           French          20,568 kbps
Presentation Graphics           French          28,882 kbps
Presentation Graphics           French          20,661 kbps
FILES:
00000.M2TS      0:00:00.000     2:01:54.666     38.433.871.872  42.035
CHAPTERS:
1               0:00:00.000     0:10:46.333     35.004 kbps     39.040 kbps     00:03:13.958    35.904 kbps     00:04:24.750    35.463 kbps     00:00:05.833    182.298 bytes   377.668 bytes   00:07:19.583
2               0:10:46.333     0:09:13.208     35.000 kbps     37.969 kbps     00:11:44.375    35.633 kbps     00:17:43.708    35.479 kbps     00:18:11.333    182.293 bytes   389.015 bytes   00:18:21.041
3               0:19:59.541     0:12:54.291     34.996 kbps     38.087 kbps     00:20:28.416    35.718 kbps     00:21:10.083    35.406 kbps     00:21:05.041    182.273 bytes   466.873 bytes   00:21:34.000
4               0:32:53.833     0:09:21.624     35.004 kbps     37.646 kbps     00:38:10.166    35.684 kbps     00:39:52.250    35.290 kbps     00:37:45.166    182.314 bytes   366.966 bytes   00:35:01.083
5               0:42:15.458     0:09:58.000     34.999 kbps     38.029 kbps     00:50:59.416    35.631 kbps     00:50:55.458    35.342 kbps     00:51:00.166    182.284 bytes   375.121 bytes   00:49:26.125
6               0:52:13.458     0:09:49.750     35.001 kbps     37.911 kbps     01:00:40.083    35.553 kbps     00:58:14.000    35.322 kbps     00:53:30.833    182.295 bytes   400.828 bytes   00:52:14.208
7               1:02:03.208     0:10:17.583     34.997 kbps     39.058 kbps     01:05:01.625    35.819 kbps     01:04:57.791    35.357 kbps     01:04:57.416    182.278 bytes   382.409 bytes   01:08:24.208
8               1:12:20.791     0:09:05.208     35.003 kbps     38.657 kbps     01:13:09.375    35.656 kbps     01:12:26.583    35.416 kbps     01:12:55.458    182.309 bytes   367.271 bytes   01:12:48.208
9               1:21:26.000     0:12:15.791     34.999 kbps     38.201 kbps     01:23:16.750    35.693 kbps     01:30:11.125    35.371 kbps     01:30:06.041    182.285 bytes   463.840 bytes   01:30:15.791
10              1:33:41.791     0:10:08.833     35.001 kbps     37.717 kbps     01:35:42.458    35.676 kbps     01:40:47.541    35.257 kbps     01:41:57.125    182.295 bytes   471.920 bytes   01:43:39.166
11              1:43:50.625     0:12:10.375     34.997 kbps     37.946 kbps     01:54:01.791    35.856 kbps     01:55:53.791    35.365 kbps     01:44:57.916    182.274 bytes   475.809 bytes   01:45:07.791
12              1:56:01.000     0:05:53.666     35.000 kbps     37.598 kbps     01:59:51.666    35.625 kbps     02:00:38.750    35.289 kbps     01:59:48.750    182.312 bytes   405.379 bytes   01:59:12.458
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     7314,500                35.001                  32.001.491.357  174.026.915
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            7314,500                2.141                   1.957.823.484   11.769.736
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           7314,500                2.307                   2.109.720.732   12.612.531
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           7314,500                224                     204.811.264     1.142.920
00000.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            7314,500                21                      18.805.628      111.563
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7314,500                29                      26.407.637      155.399
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7314,500                21                      18.890.641      112.292
Jojos is offline
post #2910 of 5106 Old 04-09-2011, 08:47 AM
Jojos's Avatar
[FR] Caramel
aka "Sukkar banat‎" (Original Arabic title)
Region Free
Studio: Bac Video
EAN: 3700447502224
Release Date: 2008-08-13
Code:
        Total   Video
00004.MPLS                                                      AVC     1:35:38 27.277.332.480  28.713.548.040  38,02   34,97   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     CARAMEL_BAC_13594
Disc Size:      28.713.548.040 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 1:35:38 (h:m:s)
Total Bitrate:          38,02 Mbps
VIDEO:
MPEG-4 AVC Video        34970 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio             Arabic          640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           French          18,167 kbps
FILES:
00007.M2TS      0:00:00.000     1:35:38.833     27.277.332.480  38.025
CHAPTERS:
1               0:00:00.000     0:09:15.916     35.532 kbps     38.480 kbps     00:07:14.208    36.986 kbps     00:02:10.500    36.831 kbps     00:07:06.208    185.049 bytes   427.035 bytes   00:07:22.250
2               0:09:15.916     0:08:22.333     35.790 kbps     37.960 kbps     00:10:16.333    36.866 kbps     00:10:58.583    36.764 kbps     00:10:20.875    186.405 bytes   361.845 bytes   00:09:55.250
3               0:17:38.250     0:13:03.166     36.155 kbps     37.961 kbps     00:18:33.916    36.892 kbps     00:24:18.708    36.764 kbps     00:25:40.125    188.307 bytes   361.064 bytes   00:28:05.250
4               0:30:41.416     0:15:48.791     35.536 kbps     38.177 kbps     00:45:34.208    36.875 kbps     00:35:21.875    36.762 kbps     00:35:21.875    185.086 bytes   357.457 bytes   00:38:03.541
5               0:46:30.208     0:04:46.833     35.788 kbps     38.179 kbps     00:49:53.125    36.862 kbps     00:48:20.791    36.733 kbps     00:48:57.125    186.398 bytes   344.424 bytes   00:47:50.833
6               0:51:17.041     0:06:18.833     36.164 kbps     38.010 kbps     00:57:21.791    36.886 kbps     00:56:08.875    36.753 kbps     00:56:45.791    188.355 bytes   369.695 bytes   00:57:31.000
7               0:57:35.875     0:09:00.541     36.064 kbps     38.507 kbps     01:01:31.666    36.944 kbps     01:04:13.875    36.757 kbps     01:02:52.833    187.835 bytes   387.851 bytes   01:00:53.458
8               1:06:36.416     0:03:54.291     36.195 kbps     38.097 kbps     01:07:33.541    36.837 kbps     01:09:55.083    36.735 kbps     01:09:50.208    188.515 bytes   379.269 bytes   01:07:34.583
9               1:10:30.708     0:07:36.291     35.391 kbps     38.623 kbps     01:17:08.041    36.878 kbps     01:17:03.833    36.733 kbps     01:15:49.583    184.331 bytes   392.168 bytes   01:11:28.750
10              1:18:07.000     0:03:35.333     35.824 kbps     37.756 kbps     01:21:31.541    36.842 kbps     01:19:40.416    36.729 kbps     01:19:35.583    186.581 bytes   329.533 bytes   01:21:18.916
11              1:21:42.333     0:06:48.583     35.597 kbps     39.753 kbps     01:26:41.875    37.187 kbps     01:26:41.041    36.948 kbps     01:26:31.916    185.401 bytes   582.024 bytes   01:26:41.916
12              1:28:30.916     0:07:07.916     24.721 kbps     38.443 kbps     01:28:41.625    37.025 kbps     01:28:36.875    36.782 kbps     01:28:32.750    128.770 bytes   428.570 bytes   01:28:41.875
STREAM DIAGNOSTICS:
00007.M2TS      4113 (0x1011)   0x1B            AVC                                     5738,667                34.971                  25.086.136.266  136.418.297
00007.M2TS      4352 (0x1100)   0x81            AC3             ara (Arabic)            5738,667                640                     459.107.840     2.690.085
00007.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            5738,667                640                     459.107.840     2.690.085
00007.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            5738,667                18                      13.031.963      76.184
00007.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            5738,667                1                       430.691         2.494
Jojos is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
