Transformers: Revenge of the Fallen DVD, BD & Walmart Big Screen (IMAX) Edition *PIX* - AVS Forum | Home Theater Discussions And Reviews
post #1 of 404 Old 10-20-2009, 12:18 PM - Thread Starter
Xylon's Avatar
XylonHD, YouTube Channel, @XylonHD
After The Dark Knight PQ fiasco, this one as far as PQ goes did everything right. Reference PQ all around. IMAX scenes and the non-IMAX scenes. The Walmart Big Screen Edition with the IMAX scenes is a whooping 71 seconds longer. In the forest battle scenes is where you find most of the extra footage:
Reference AQ on the regular blu-ray edition. The Walmart version however is not. As reported by some members here the audio somehow lacks "punch". So I tested the discs on two receivers (Onkyo SR706 & Denon 2809) connected via HDMI bitreaming DTS-HD MA and also via optical DTS. I did a quick A/B comparison (as quick as I can) and clearly the Walmart edition is not on par. Is it only as simple as loudness fix? I'm not sure. I don't have the tools to measure and get the numbers of the different frequency and levels.
The Walmart edition may be the most sought after but beware you may not get the same AQ.
#1 UPDATE:
IMAX Edition BDinfo: ** Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 4659 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit / DN -4dB)
Regular Edition BDinfo: Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 4658 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dialnorm at -4db applied for the IMAX edition.
#2 UPDATE:
IMAX Edition eac3to info:
Code:
M2TS, 1 video track, 4 audio tracks, 7 subtitle tracks, 2:30:25, 24p /1.001
1: Chapters, 20 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz, dialnorm: -4dB
   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz, dialnorm: -4dB)
4: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
5: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
6: AC3, English, 2.0 channels, 224kbps, 48khz, dialnorm: -27dB
7: Subtitle (PGS), English
8: Subtitle (PGS), French
9: Subtitle (PGS), Spanish
10: Subtitle (PGS), Portuguese
11: Subtitle (PGS), English
12: Subtitle (PGS), French
13: Subtitle (PGS), Spanish
[a03] Extracting audio track number 3...
[a03] Removing DTS dialog normalization...
[a03] Creating file "C:\\1_3_audio.dtshd"...
Video track 2 contains 216382 frames.
eac3to processing took 34 minutes, 58 seconds.
Done.
Regular Edition eac3to info:
Code:
M2TS, 1 video track, 4 audio tracks, 7 subtitle tracks, 2:29:53, 24p /1.001
   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz)
8: Subtitle (PGS), English
9: Subtitle (PGS), French
10: Subtitle (PGS), Spanish
11: Subtitle (PGS), Portuguese
Video track 2 contains 215617 frames.
eac3to processing took 34 minutes, 14 seconds.
Done.
Xylon is offline
post #2 of 404 Old 10-20-2009, 12:19 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #3 of 404 Old 10-20-2009, 12:19 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #4 of 404 Old 10-20-2009, 12:19 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #5 of 404 Old 10-20-2009, 12:19 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #6 of 404 Old 10-20-2009, 12:20 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #7 of 404 Old 10-20-2009, 12:20 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #8 of 404 Old 10-20-2009, 12:20 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #9 of 404 Old 10-20-2009, 12:20 PM - Thread Starter
Xylon's Avatar
reserved9
Xylon is offline
post #10 of 404 Old 10-20-2009, 12:20 PM - Thread Starter
Xylon's Avatar
reserved10
Xylon is offline
post #11 of 404 Old 10-20-2009, 12:21 PM - Thread Starter
Xylon's Avatar
Blu-ray File size: 47.70 GB
Bitrate: 31.29 mbps
Code:
        Total   Video
Title                                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main
Audio Track                          Secondary Audio Track
00003.MPLS                                                      AVC     2:29:53 44,644,798,464  45,008,217,238  39.72   31.29   DTS-
HD Master 5.1 4658Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TRANSFORMERS_2_D1_AC
Disc Size:      45,008,217,238 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:29:53 (h:m:s)
Total Bitrate:          39.72 Mbps
VIDEO:
MPEG-4 AVC Video        31290 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4658 kbps       5.1 / 48 kHz / 4658 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps
/ 24-bit)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         41.365 kbps
Presentation Graphics           English         44.305 kbps
Presentation Graphics           French          38.795 kbps
Presentation Graphics           French          0.353 kbps
Presentation Graphics           Portuguese      33.963 kbps
Presentation Graphics           Spanish         33.815 kbps
Presentation Graphics           Spanish         0.330 kbps
FILES:
00003.M2TS      0:00:00.000     2:29:53.025     44,644,798,464  39,715
CHAPTERS:
Number          Time In         Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max
10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:08:49.278     32,961 kbps     42,213 kbps     00:01:27.587    36,152 kbps     00:06:15.917
35,880 kbps     00:01:44.729    171,830 bytes   808,861 bytes   00:01:02.771
2               0:08:49.278     0:06:03.363     31,962 kbps     39,439 kbps     00:13:10.372    35,990 kbps     00:12:40.468
35,830 kbps     00:12:40.050    166,635 bytes   440,567 bytes   00:14:44.842
3               0:14:52.641     0:03:25.371     30,812 kbps     36,824 kbps     00:17:45.731    35,619 kbps     00:17:36.054
35,009 kbps     00:14:56.979    160,640 bytes   336,771 bytes   00:17:25.002
4               0:18:18.013     0:06:49.617     31,348 kbps     40,106 kbps     00:23:59.229    36,244 kbps     00:20:48.455
35,772 kbps     00:19:50.814    163,433 bytes   421,308 bytes   00:24:13.869
5               0:25:07.631     0:07:52.889     31,811 kbps     37,859 kbps     00:32:43.836    35,951 kbps     00:25:18.141
35,890 kbps     00:25:13.261    165,846 bytes   427,487 bytes   00:29:57.378
6               0:33:00.520     0:04:07.247     31,527 kbps     36,739 kbps     00:33:45.106    35,961 kbps     00:35:30.336
35,400 kbps     00:35:14.779    164,365 bytes   292,544 bytes   00:33:50.653
7               0:37:07.767     0:06:25.885     31,636 kbps     37,319 kbps     00:37:45.680    36,106 kbps     00:37:19.445
35,944 kbps     00:37:35.753    164,935 bytes   388,314 bytes   00:37:49.642
8               0:43:33.652     0:11:22.890     31,711 kbps     38,676 kbps     00:53:13.231    36,254 kbps     00:53:09.102
35,832 kbps     00:46:34.541    165,328 bytes   375,896 bytes   00:54:00.987
9               0:54:56.543     0:08:27.340     31,426 kbps     39,879 kbps     00:59:57.927    36,116 kbps     00:59:30.066
35,786 kbps     00:58:33.635    163,841 bytes   437,252 bytes   01:02:09.142
10              1:03:23.883     0:09:02.124     31,899 kbps     37,971 kbps     01:05:21.918    36,154 kbps     01:03:59.627
35,739 kbps     01:05:59.997    166,308 bytes   417,178 bytes   01:09:31.000
11              1:12:26.008     0:07:46.174     31,109 kbps     37,271 kbps     01:15:56.677    36,025 kbps     01:15:52.673
35,891 kbps     01:15:47.668    162,187 bytes   336,224 bytes   01:12:38.020
12              1:20:12.182     0:06:22.882     31,774 kbps     37,274 kbps     01:26:33.062    35,970 kbps     01:23:33.883
35,671 kbps     01:22:43.249    165,657 bytes   423,317 bytes   01:26:03.074
13              1:26:35.064     0:09:06.087     31,406 kbps     37,355 kbps     01:28:49.240    36,047 kbps     01:28:45.236
35,872 kbps     01:28:13.621    163,738 bytes   396,789 bytes   01:28:21.337
14              1:35:41.152     0:09:12.927     31,797 kbps     38,459 kbps     01:44:15.415    36,196 kbps     01:44:11.411
35,928 kbps     01:39:05.147    165,777 bytes   357,119 bytes   01:36:07.344
15              1:44:54.079     0:05:40.631     31,515 kbps     39,236 kbps     01:45:21.314    36,039 kbps     01:47:32.988
35,944 kbps     01:47:51.882    164,304 bytes   387,448 bytes   01:49:22.264
16              1:50:34.711     0:08:27.089     31,882 kbps     41,044 kbps     01:56:37.949    36,261 kbps     01:53:01.149
36,041 kbps     01:52:56.144    166,220 bytes   476,026 bytes   01:52:44.591
17              1:59:01.801     0:08:11.908     31,819 kbps     40,163 kbps     02:05:37.488    36,071 kbps     02:05:02.953
35,496 kbps     02:05:58.676    165,890 bytes   564,068 bytes   01:59:12.228
18              2:07:13.709     0:07:51.596     33,665 kbps     39,442 kbps     02:10:52.886    36,159 kbps     02:08:03.008
35,901 kbps     02:10:12.554    175,516 bytes   362,899 bytes   02:12:40.869
19              2:15:05.305     0:07:09.512     33,679 kbps     38,752 kbps     02:16:38.440    36,104 kbps     02:17:17.812
35,910 kbps     02:21:53.296    175,589 bytes   411,143 bytes   02:15:35.001
20              2:22:14.817     0:07:38.207     19,491 kbps     37,492 kbps     02:22:21.407    35,975 kbps     02:22:40.593
35,886 kbps     02:22:32.877    101,625 bytes   428,093 bytes   02:28:43.581
STREAM DIAGNOSTICS:
File            PID             Type            Codec           Language                Seconds                 Bitrate
  Bytes           Packets
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     8992.859                31,291
  35,174,145,794  191,289,943
00003.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           8992.859                4,658
  5,235,727,180   29,856,676
00003.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            8992.859                640
  719,444,480     4,215,495
00003.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           8992.859                640
00003.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           8992.859                224
  251,805,568     1,405,165
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8992.859                41
  46,499,164      264,945
00003.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8992.859                44
  49,804,964      283,782
00003.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8992.859                39
  43,611,048      249,427
00003.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           8992.859                34
  38,012,754      218,683
00003.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        8992.859                34
  38,178,693      219,683
00003.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            8992.859                0
  396,875         2,272
00003.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           8992.859                0
  371,396         2,132
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Playlist: 00003.MPLS
Length: 2:29:53
Video: MPEG-4 AVC Video / 31290 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: French / Dolby Digital Audio / 5.1 / 48 kHz / 640 kbps / DN -4dB
Audio: Spanish / Dolby Digital Audio / 5.1 / 48 kHz / 640 kbps / DN -4dB
Audio: English / Dolby Digital Audio / 2.0 / 48 kHz / 224 kbps / DN -4dB
Subtitle: English / 41.365 kbps
Subtitle: English / 44.305 kbps
Subtitle: French / 38.795 kbps
Subtitle: French / 0.353 kbps
Subtitle: Portuguese / 33.963 kbps
Subtitle: Spanish / 33.815 kbps
Subtitle: Spanish / 0.330 kbps
Blu-ray IMAX File size: 47.70 GB
Bitrate: 31.30 mbps
Code:
        Total   Video
00003.MPLS                                                      AVC     2:30:24 44,811,589,632  45,175,023,272  39.72   31.30   DTS-
HD Master 5.1 4659Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TF_2_D1_AC_BSE
Disc Size:      45,175,023,272 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:30:24 (h:m:s)
VIDEO:
MPEG-4 AVC Video        31297 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4659 kbps       5.1 / 48 kHz / 4659 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps
/ 24-bit / DN -4dB)
SUBTITLES:
Presentation Graphics           English         41.228 kbps
Presentation Graphics           English         44.318 kbps
Presentation Graphics           French          38.665 kbps
Presentation Graphics           French          0.352 kbps
Presentation Graphics           Portuguese      33.859 kbps
Presentation Graphics           Spanish         33.695 kbps
Presentation Graphics           Spanish         0.329 kbps
FILES:
00003.M2TS      0:00:00.000     2:30:24.932     44,811,589,632  39,722
CHAPTERS:
9               0:54:56.543     0:08:50.196     31,475 kbps     38,861 kbps     00:57:48.298    36,034 kbps     01:02:38.379
35,804 kbps     01:02:33.374    164,096 bytes   454,609 bytes   01:03:16.626
10              1:03:46.739     0:09:02.124     31,899 kbps     37,971 kbps     01:05:44.774    36,154 kbps     01:04:22.483
35,739 kbps     01:06:22.853    166,308 bytes   417,178 bytes   01:09:53.856
11              1:12:48.864     0:07:46.174     31,109 kbps     37,271 kbps     01:16:19.533    36,025 kbps     01:16:15.529
35,891 kbps     01:16:10.524    162,187 bytes   336,224 bytes   01:13:00.876
12              1:20:35.038     0:06:22.882     31,774 kbps     37,274 kbps     01:26:55.919    35,970 kbps     01:23:56.740
35,671 kbps     01:23:06.106    165,657 bytes   423,317 bytes   01:26:25.930
13              1:26:57.921     0:09:06.087     31,406 kbps     37,355 kbps     01:29:12.096    36,047 kbps     01:29:08.092
35,872 kbps     01:28:36.477    163,738 bytes   396,789 bytes   01:28:44.193
14              1:36:04.008     0:09:12.927     31,797 kbps     38,459 kbps     01:44:38.272    36,196 kbps     01:44:34.268
35,928 kbps     01:39:28.003    165,777 bytes   357,119 bytes   01:36:30.201
15              1:45:16.935     0:05:40.631     31,515 kbps     39,236 kbps     01:45:44.171    36,039 kbps     01:47:55.844
35,944 kbps     01:48:14.738    164,304 bytes   387,448 bytes   01:49:45.120
16              1:50:57.567     0:08:36.098     31,898 kbps     38,559 kbps     01:57:51.355    36,198 kbps     01:57:05.810
35,847 kbps     01:55:55.990    166,301 bytes   507,551 bytes   01:53:10.325
17              1:59:33.666     0:08:11.949     31,850 kbps     40,163 kbps     02:06:09.395    36,071 kbps     02:05:34.860
35,468 kbps     02:07:31.560    166,054 bytes   564,068 bytes   01:59:44.135
18              2:07:45.616     0:07:51.596     33,665 kbps     39,442 kbps     02:11:24.793    36,159 kbps     02:08:34.915
35,901 kbps     02:10:44.461    175,516 bytes   362,899 bytes   02:13:12.776
19              2:15:37.212     0:07:09.512     33,679 kbps     38,752 kbps     02:17:10.347    36,104 kbps     02:17:49.719
35,910 kbps     02:22:25.203    175,589 bytes   411,143 bytes   02:16:06.908
20              2:22:46.724     0:07:38.207     19,491 kbps     37,492 kbps     02:22:53.314    35,975 kbps     02:23:12.500
35,886 kbps     02:23:04.784    101,625 bytes   428,093 bytes   02:29:15.488
STREAM DIAGNOSTICS:
  Bytes           Packets
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     9024.766                31,297
  35,306,180,471  192,008,034
00003.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           9024.766                4,659
  5,255,709,756   29,969,999
00003.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            9024.766                640
  721,996,800     4,230,450
00003.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           9024.766                640
00003.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           9024.766                224
  252,698,880     1,410,150
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           9024.766                41
  46,509,728      265,007
00003.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            9024.766                39
  43,618,143      249,473
00003.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           9024.766                34
  38,011,405      218,676
00003.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        9024.766                34
  38,197,062      219,785
00003.M2TS      4612 (0x1204)   0x90            PGS             eng (English)           9024.766                44
  49,995,821      284,892
00003.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            9024.766                0
  396,875         2,272
00003.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           9024.766                0
  371,396         2,132
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Length: 2:30:24
Video: MPEG-4 AVC Video / 31297 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Subtitle: English / 41.228 kbps
Subtitle: English / 44.318 kbps
Subtitle: French / 38.665 kbps
Subtitle: French / 0.352 kbps
Subtitle: Portuguese / 33.859 kbps
Subtitle: Spanish / 33.695 kbps
Subtitle: Spanish / 0.329 kbps
Xylon is offline
post #12 of 404 Old 10-20-2009, 01:48 PM
Moderator
rboster's Avatar
Quoted: 1593 Post(s)
Liked: 2169
Please stay on topic concerning the PQ and comparisons. If you have questions about the movie, the different editions etc etc, please go to one of the other threads to post your questions or comments (outside of the PQ)
Like this thread
https://www.avsforum.com/avs-vb/showthread.php?t=1172468
rboster is offline
post #13 of 404 Old 10-20-2009, 01:57 PM
Spoonsey's Avatar
Quoted: 42 Post(s)
Liked: 29
Might I say a most aesthetically pleasing choice for the first pic.
Spoonsey is offline
post #14 of 404 Old 10-20-2009, 02:00 PM
Fang Zei's Avatar
So is this comparing three different editions (one dvd and two blu-rays) or am I mistaken?
Fang Zei is offline
post #15 of 404 Old 10-20-2009, 02:14 PM
Kram Sacul's Avatar
Is that Michael Bay reflected on the far left?
Kram Sacul is offline
post #16 of 404 Old 10-20-2009, 02:16 PM
kmlm13's Avatar
Sure looks like him, hahah. Good eyes.
kmlm13 is offline
post #17 of 404 Old 10-20-2009, 02:16 PM
ack_bk's Avatar
Quoted: 1334 Post(s)
Liked: 1461
Xylon, you are such a tease
ack_bk is offline
post #18 of 404 Old 10-20-2009, 02:18 PM
dvdmike007's Avatar
Liked: 50
Was waiting for this thread just watched the two disc for the second time, and if there are any picture faults I cannot see them
dvdmike007 is offline
post #19 of 404 Old 10-20-2009, 02:31 PM
42041's Avatar
Liked: 55
Originally Posted by x43x View Post
Brightness looks cranked up a few notches on the IMAX shot
No it doesn't
They're not identical frames BTW.
(wait... now they are... i must be going out of my mind)
42041 is offline
post #20 of 404 Old 10-20-2009, 02:32 PM
Dave_6's Avatar
Quoted: 39 Post(s)
Originally Posted by 42041 View Post
No it doesn't
I was thinking the same thing.
LG OLED65B6P
Oppo UDP-203
Denon AVR-X4200W
PS4 Pro
Xbox One X
Dave_6 is offline
post #21 of 404 Old 10-20-2009, 02:42 PM
42041's Avatar
Liked: 55
Really? Maybe it's my computer then or I'm crazy. IMAX looks a tad brighter, standard looks to have a tad more color saturation because of it. I'm comparing her face and the shadow in her hair. Very small difference, but I swear I can see it.
Load up the images in separate windows (or if you have some decent image editing program, different layers) and switch back and forth between them. They look absolutely identical to me. I'd go as far as to say it's the same encode with the different IMAX shots inserted into the stream.
42041 is offline
post #22 of 404 Old 10-20-2009, 02:43 PM
tokerblue's Avatar
Quoted: 226 Post(s)
Liked: 222
I'm a little confused on the versions. I know that the Wal-Mart version has the IMAX sequences, but why is the framing different on post #2? Do the other versions also have the IMAX footage, just in 2.35:1 format?
tokerblue is offline
post #23 of 404 Old 10-20-2009, 03:08 PM
mike2060's Avatar
DVD makes me think I need glasses :s
mike2060 is offline
post #24 of 404 Old 10-20-2009, 03:22 PM
Kram Sacul's Avatar
Interesting that the letterboxed version is shifted down and has more image area below than the Imax shot.
post #25 of 404 Old 10-20-2009, 03:49 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5985 Post(s)
Liked: 5114
I won't judge looking here on teh PC but the IMAX shots do indeed look a tad brighter on my screen to me. I think that is good though cause it brings out some of the detail without washing out the dark areas. Won't know for sure without seeing it on my 100" at home. I don't see any extra enhancements or filtering though between the different versions... that's good!
Scott Simonian is offline
post #26 of 404 Old 10-20-2009, 04:42 PM
opfreak's Avatar
In that airplan jumping pic, IMHO, blu-ray just looks softer. Or DVD more edge enhanced. a bit of a let down
opfreak is offline
post #27 of 404 Old 10-20-2009, 04:52 PM
42041's Avatar
Liked: 55
I have no idea where that scene is in the movie, having not watched the whole thing, but considering the extremely high level of quality of what I DID see I'd say that scene is supposed to look bad.
42041 is offline
post #28 of 404 Old 10-20-2009, 04:53 PM
raoul_duke's Avatar
Quoted: 13 Post(s)
Liked: 36
If you're calling the BD a letdown, you're mad. Regardless of whatever your thoughts on the actual movie, the BD is gorgeous, both visually and sonically.
raoul_duke is offline
post #29 of 404 Old 10-20-2009, 04:55 PM
Stryker412's Avatar
Quoted: 83 Post(s)
Liked: 36
The IMAX is def a tad brighter. Compare the two pics of Optimus covered in dirt, specifically his right shoulder. It's brighter on the IMAX version.
Stryker412 is offline
post #30 of 404 Old 10-20-2009, 04:56 PM
Dave Mack's Avatar
Quoted: 13 Post(s)
the dvd looks really bad. like much worse than it should imho....
Dave Mack is offline
Reply Blu-ray Software
