Toy Story 1 and Toy Story 2 comparison *PIX* - AVS Forum | Home Theater Discussions And Reviews
post #1 of 77 Old 03-22-2010, 10:04 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #2 of 77 Old 03-22-2010, 10:04 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #3 of 77 Old 03-22-2010, 10:04 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #4 of 77 Old 03-22-2010, 10:05 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #5 of 77 Old 03-22-2010, 10:05 PM - Thread Starter
Xylon's Avatar
Reference PQ and AQ. As good as every Pixar release.
Toy Story 2 is for bass lovers Rdiculous sound
$10 off each title from Disney Movie Rewards:
http://disney.go.com/disneymovierewa..._url_tsupgrade
Log in then:
Enter UPC 786936294507 for Toy Story
Enter UPC 786936294521 for Toy Story 2
buy them together you save extra $10.
Xylon is offline
post #6 of 77 Old 03-22-2010, 10:05 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #7 of 77 Old 03-22-2010, 10:05 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #8 of 77 Old 03-22-2010, 10:06 PM - Thread Starter
Xylon's Avatar
reserved9
Xylon is offline
post #9 of 77 Old 03-22-2010, 10:06 PM - Thread Starter
Xylon's Avatar
Toy Story
ABC 720p Mpeg-2 File size: 6.95 GB
Bitrate: 11.86 mbps
Code:
Sequence Frame 282539(0-I) / Time 1:18:32 :
Info: End of MPEG2 sequence:
Info: 1280 x 720, 59.94 fps, 65.00 Mbps (Header), 11.86 Mbps (Average).
Info: AC3 Audio. 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Info: Found 282539 video frames since start of sequence.
Info: 0 video frames found with errors.
Info: 7 audio frames found with errors.
Info: 0 corrupted video bytes in file.
Info: 0.000000 seconds of video timestamp gaps.
Info: 0.000000 seconds of audio timestamp gaps.
End of Log
Blu-ray File size: 18.00 GB
Bitrate: 23.57 mbps AVC
Code:
        Total   Video
00337.MPLS                                                      AVC     1:21:27 20,933,124,096  43,296,970,139  34.26   23.57   DTS-HD Master 5.1-ES 4429Kbps (48kHz/24-bit)DTS-HD Master 2.0 2116Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TOY_STORY
Disc Size:      43,296,970,139 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:21:27 (h:m:s)
Total Bitrate:          34.26 Mbps
VIDEO:
MPEG-4 AVC Video        23573 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4429 kbps       5.1-ES / 48 kHz / 4429 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital EX Audio          French          640 kbps        5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio          Spanish         640 kbps        5.1-EX / 48 kHz / 640 kbps
DTS-HD Master Audio             English         2116 kbps       2.0 / 48 kHz / 2116 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         53.065 kbps
Presentation Graphics           English         77.399 kbps
Presentation Graphics           French          30.499 kbps
Presentation Graphics           French          69.169 kbps
Presentation Graphics           Spanish         38.955 kbps
Presentation Graphics           Spanish         66.610 kbps
FILES:
00066.M2TS      0:00:00.000     0:02:02.247     600,698,880     39,310
00504.M2TS      0:02:02.247     0:02:14.259     568,295,424     33,863
00401.M2TS      0:04:16.506     0:13:11.081     3,377,940,480   34,160
00506.M2TS      0:17:27.588     0:00:20.478     87,287,808      34,099
00402.M2TS      0:17:48.066     0:08:48.569     2,261,428,224   34,227
00508.M2TS      0:26:36.636     0:00:18.852     79,976,448      33,938
00403.M2TS      0:26:55.488     0:19:38.135     5,074,003,968   34,454
00510.M2TS      0:46:33.624     0:00:50.800     197,099,520     31,039
00404.M2TS      0:47:24.424     0:29:42.405     7,604,656,128   34,132
00512.M2TS      1:17:06.830     0:03:33.004     908,537,856     34,123
00538.M2TS      1:20:39.834     0:00:23.606     124,182,528     42,083
00540.M2TS      1:21:03.441     0:00:23.982     49,016,832      16,351
CHAPTERS:
1               0:00:00.000     0:02:02.247     28,818 kbps     38,129 kbps     00:00:31.573    34,346 kbps     00:00:26.985    34,099 kbps     00:00:49.799    150,192 bytes   558,956 bytes   00:00:29.029
2               0:02:02.247     0:01:58.118     23,269 kbps     40,638 kbps     00:03:12.609    33,532 kbps     00:03:47.977    33,191 kbps     00:03:42.597    121,313 bytes   643,868 bytes   00:02:04.249
3               0:04:00.365     0:02:33.653     23,698 kbps     35,960 kbps     00:05:42.633    33,516 kbps     00:04:01.699    30,629 kbps     00:05:19.610    123,552 bytes   587,561 bytes   00:04:01.366
4               0:06:34.018     0:02:45.248     24,167 kbps     36,248 kbps     00:08:42.021    33,590 kbps     00:08:32.553    30,370 kbps     00:08:52.573    125,998 bytes   741,170 bytes   00:08:48.236
5               0:09:19.267     0:04:57.714     23,203 kbps     35,971 kbps     00:10:23.622    30,700 kbps     00:13:16.629    28,747 kbps     00:12:15.651    120,968 bytes   672,886 bytes   00:13:09.371
6               0:14:16.981     0:05:53.269     23,482 kbps     38,079 kbps     00:19:36.717    32,025 kbps     00:14:43.465    29,332 kbps     00:14:26.615    122,422 bytes   721,138 bytes   00:16:44.086
7               0:20:10.250     0:02:06.960     22,494 kbps     35,037 kbps     00:21:27.536    33,259 kbps     00:20:51.667    29,677 kbps     00:20:49.665    117,276 bytes   640,402 bytes   00:21:44.845
8               0:22:17.210     0:02:07.752     23,814 kbps     34,946 kbps     00:23:41.253    32,398 kbps     00:23:40.585    30,545 kbps     00:23:35.747    124,154 bytes   631,500 bytes   00:23:20.649
9               0:24:24.963     0:01:36.262     23,623 kbps     36,845 kbps     00:25:43.500    30,986 kbps     00:25:00.999    29,381 kbps     00:24:55.994    123,160 bytes   736,322 bytes   00:25:23.772
10              0:26:01.226     0:03:27.707     22,613 kbps     35,509 kbps     00:28:55.525    33,082 kbps     00:29:00.738    31,938 kbps     00:28:55.525    117,896 bytes   675,197 bytes   00:29:28.933
11              0:29:28.933     0:00:40.415     21,713 kbps     31,938 kbps     00:29:52.749    25,697 kbps     00:29:51.497    24,008 kbps     00:29:49.704    113,201 bytes   720,385 bytes   00:29:52.790
12              0:30:09.349     0:05:00.508     24,575 kbps     40,471 kbps     00:30:22.528    34,046 kbps     00:30:26.950    33,704 kbps     00:31:37.353    128,125 bytes   935,902 bytes   00:30:48.096
13              0:35:09.857     0:04:15.546     23,721 kbps     41,087 kbps     00:39:24.195    33,570 kbps     00:36:13.129    31,122 kbps     00:36:12.253    123,673 bytes   711,526 bytes   00:38:34.937
14              0:39:25.404     0:03:34.130     23,915 kbps     40,190 kbps     00:40:01.899    33,806 kbps     00:40:30.427    33,550 kbps     00:40:24.672    124,684 bytes   782,082 bytes   00:40:43.440
15              0:42:59.535     0:00:43.793     17,657 kbps     23,750 kbps     00:43:06.375    20,739 kbps     00:43:02.496    19,830 kbps     00:43:00.285    92,054 bytes    490,690 bytes   00:43:04.540
16              0:43:43.328     0:02:42.370     24,759 kbps     37,483 kbps     00:43:52.296    33,683 kbps     00:43:49.209    33,111 kbps     00:43:43.328    129,083 bytes   694,963 bytes   00:43:53.297
17              0:46:25.699     0:00:54.471     22,492 kbps     33,794 kbps     00:46:32.623    31,211 kbps     00:46:28.619    26,564 kbps     00:46:25.824    117,263 bytes   454,624 bytes   00:47:02.903
18              0:47:20.170     0:01:47.941     20,834 kbps     37,820 kbps     00:48:11.763    28,542 kbps     00:48:28.030    25,410 kbps     00:48:24.693    108,617 bytes   786,695 bytes   00:48:12.681
19              0:49:08.111     0:02:00.411     26,210 kbps     37,201 kbps     00:49:21.833    33,670 kbps     00:50:34.698    33,350 kbps     00:50:32.320    136,648 bytes   629,729 bytes   00:50:56.303
20              0:51:08.523     0:02:41.411     22,455 kbps     32,479 kbps     00:52:07.165    29,201 kbps     00:52:00.242    28,852 kbps     00:52:00.200    117,071 bytes   756,136 bytes   00:53:27.662
21              0:53:49.934     0:02:33.778     26,423 kbps     36,227 kbps     00:55:31.911    33,745 kbps     00:56:13.786    33,325 kbps     00:56:13.161    137,755 bytes   649,263 bytes   00:55:28.283
22              0:56:23.713     0:00:51.050     19,777 kbps     31,583 kbps     00:56:34.807    29,585 kbps     00:56:34.474    26,723 kbps     00:56:30.053    103,109 bytes   427,591 bytes   00:56:36.726
23              0:57:14.764     0:04:26.307     22,653 kbps     34,860 kbps     01:00:42.472    29,206 kbps     01:00:07.228    27,602 kbps     01:00:10.982    118,100 bytes   674,847 bytes   01:00:42.513
24              1:01:41.072     0:01:09.027     23,340 kbps     36,870 kbps     01:02:42.925    32,469 kbps     01:02:44.635    30,556 kbps     01:02:40.089    121,683 bytes   924,167 bytes   01:02:43.885
25              1:02:50.099     0:01:58.993     23,018 kbps     35,350 kbps     01:04:06.842    32,734 kbps     01:03:37.647    31,577 kbps     01:03:33.267    120,005 bytes   755,321 bytes   01:03:58.876
26              1:04:49.093     0:03:09.564     23,437 kbps     39,870 kbps     01:05:26.255    33,874 kbps     01:05:26.922    32,263 kbps     01:05:25.004    122,191 bytes   932,002 bytes   01:05:39.310
27              1:07:58.657     0:05:11.644     24,700 kbps     42,688 kbps     01:10:19.715    34,405 kbps     01:11:23.445    33,864 kbps     01:11:08.931    128,774 bytes   936,216 bytes   01:11:26.198
28              1:13:10.302     0:02:29.774     20,845 kbps     39,515 kbps     01:15:13.425    33,733 kbps     01:15:13.300    33,010 kbps     01:15:10.464    108,678 bytes   704,127 bytes   01:13:11.845
29              1:15:40.077     0:01:28.296     22,972 kbps     37,179 kbps     01:15:48.460    29,124 kbps     01:15:56.677    26,886 kbps     01:16:54.484    119,763 bytes   607,682 bytes   01:15:52.047
30              1:17:08.373     0:04:19.050     23,132 kbps     39,242 kbps     01:20:46.424    34,985 kbps     01:20:42.420    34,027 kbps     01:20:41.044    120,620 bytes   569,322 bytes   01:20:46.841
STREAM DIAGNOSTICS:
00066.M2TS      4113 (0x1011)   0x1B            AVC                                     122.080                 28,821                  439,812,033     2,391,985
00066.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           122.080                 4,198                   64,062,648      367,213
00066.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           122.080                 2,075                   31,662,736      190,984
00066.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           122.080                 192                     2,934,528       19,105
00066.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            122.080                 641                     9,781,760       57,315
00066.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           122.080                 641                     9,781,760       57,315
00066.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           122.080                 192                     2,934,528       19,105
00066.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           122.080                 31                      469,347         2,689
00066.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            122.080                 20                      303,027         1,746
00066.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           122.080                 25                      383,820         2,179
00066.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           122.080                 63                      966,800         5,453
00066.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            122.080                 58                      879,601         4,978
00066.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           122.080                 51                      777,164         4,428
00504.M2TS      4113 (0x1011)   0x1B            AVC                                     134.092                 23,173                  388,412,212     2,112,814
00504.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           134.092                 4,452                   74,621,856      426,518
00504.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           134.092                 2,126                   35,642,520      214,634
00504.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           134.092                 192                     3,222,528       20,980
00504.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            134.092                 641                     10,741,760      62,940
00504.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           134.092                 641                     10,741,760      62,940
00504.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           134.092                 192                     3,222,528       20,980
00504.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           134.092                 65                      1,089,180       6,260
00504.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            134.092                 38                      635,012         3,721
00504.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           134.092                 45                      757,306         4,400
00504.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           134.092                 83                      1,389,962       7,872
00504.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            134.092                 73                      1,216,479       6,903
00504.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           134.092                 45                      757,306         4,400
00401.M2TS      4113 (0x1011)   0x1B            AVC                                     790.915                 23,503                  2,323,623,544   12,639,456
00401.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           790.915                 4,370                   432,051,164     2,471,443
00401.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           790.915                 2,105                   208,139,000     1,253,565
00401.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           790.915                 192                     18,986,496      123,610
00401.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            790.915                 640                     63,288,320      370,830
00401.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           790.915                 640                     63,288,320      370,830
00401.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           790.915                 192                     18,986,496      123,610
00401.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           790.915                 70                      6,874,159       39,021
00401.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            790.915                 40                      3,909,049       22,503
00401.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           790.915                 54                      5,306,804       30,243
00401.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           790.915                 78                      7,728,033       43,764
00401.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            790.915                 72                      7,126,581       40,473
00401.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           790.915                 67                      6,594,762       37,590
00506.M2TS      4113 (0x1011)   0x1B            AVC                                     20.312                  23,695                  60,161,210      327,242
00506.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           20.312                  4,233                   10,748,296      61,563
00506.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           20.312                  2,095                   5,320,112       32,041
00506.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           20.312                  194                     491,520         3,200
00506.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            20.312                  645                     1,638,400       9,600
00506.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           20.312                  645                     1,638,400       9,600
00506.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           20.312                  194                     491,520         3,200
00506.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           20.312                  89                      225,908         1,274
00506.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            20.312                  80                      203,943         1,161
00506.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           20.312                  91                      231,776         1,314
00506.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           20.312                  95                      240,175         1,351
00506.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            20.312                  88                      224,643         1,267
00506.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           20.312                  78                      198,774         1,120
00402.M2TS      4113 (0x1011)   0x1B            AVC                                     528.403                 23,505                  1,552,526,002   8,445,004
00402.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           528.403                 4,430                   292,615,596     1,672,628
00402.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           528.403                 2,121                   140,112,424     842,902
00402.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           528.403                 192                     12,685,824      82,590
00402.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            528.403                 640                     42,286,080      247,770
00402.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           528.403                 640                     42,286,080      247,770
00402.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           528.403                 192                     12,685,824      82,590
00402.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           528.403                 60                      3,994,520       22,832
00402.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            528.403                 38                      2,503,403       14,448
00402.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           528.403                 45                      2,988,284       17,112
00402.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           528.403                 81                      5,331,127       30,169
00402.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            528.403                 73                      4,821,515       27,408
00402.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           528.403                 73                      4,801,887       27,320
00508.M2TS      4113 (0x1011)   0x1B            AVC                                     18.685                  23,709                  55,376,302      301,222
00508.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           18.685                  4,331                   10,116,520      57,896
00508.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           18.685                  2,087                   4,874,012       29,195
00508.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           18.685                  194                     453,120         2,950
00508.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            18.685                  647                     1,510,400       8,850
00508.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           18.685                  647                     1,510,400       8,850
00508.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           18.685                  194                     453,120         2,950
00508.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           18.685                  27                      62,393          366
00508.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            18.685                  13                      31,171          182
00508.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           18.685                  12                      27,781          164
00508.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           18.685                  90                      209,620         1,186
00508.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            18.685                  78                      182,367         1,038
00508.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           18.685                  79                      185,555         1,054
00403.M2TS      4113 (0x1011)   0x1B            AVC                                     1177.968                23,681                  3,486,940,805   18,967,268
00403.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1177.968                4,498                   662,245,468     3,782,834
00403.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1177.968                2,124                   312,814,580     1,882,264
00403.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1177.968                192                     28,275,456      184,085
00403.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            1177.968                640                     94,251,520      552,255
00403.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           1177.968                640                     94,251,520      552,255
00403.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           1177.968                192                     28,275,456      184,085
00403.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1177.968                56                      8,231,772       46,986
00403.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            1177.968                30                      4,392,165       25,411
00403.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           1177.968                40                      5,869,709       33,536
00403.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           1177.968                76                      11,248,579      63,743
00403.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            1177.968                69                      10,104,394      57,521
00403.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1177.968                66                      9,708,603       55,384
00510.M2TS      4113 (0x1011)   0x1B            AVC                                     50.676                  20,607                  130,531,732     710,118
00510.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           50.676                  4,195                   26,571,160      152,323
00510.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           50.676                  2,138                   13,544,592      81,408
00510.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           50.676                  193                     1,219,584       7,940
00510.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            50.676                  642                     4,065,280       23,820
00510.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           50.676                  642                     4,065,280       23,820
00510.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           50.676                  193                     1,219,584       7,940
00510.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           50.676                  104                     661,159         3,725
00510.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            50.676                  59                      374,698         2,142
00510.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           50.676                  87                      551,844         3,126
00510.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           50.676                  89                      564,920         3,190
00510.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            50.676                  77                      487,537         2,770
00510.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           50.676                  70                      443,607         2,530
00404.M2TS      4113 (0x1011)   0x1B            AVC                                     1782.239                23,407                  5,214,669,246   28,365,592
00404.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1782.239                4,483                   998,786,344     5,706,355
00404.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           1782.239                2,125                   473,366,048     2,844,577
00404.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1782.239                192                     42,778,368      278,505
00404.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            1782.239                640                     142,594,560     835,515
00404.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           1782.239                640                     142,594,560     835,515
00404.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           1782.239                192                     42,778,368      278,505
00404.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1782.239                46                      10,236,800      58,963
00404.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            1782.239                26                      5,890,165       34,246
00404.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           1782.239                33                      7,249,244       41,741
00404.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           1782.239                77                      17,113,958      97,069
00404.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            1782.239                68                      15,042,566      85,803
00404.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           1782.239                67                      14,969,261      85,473
00512.M2TS      4113 (0x1011)   0x1B            AVC                                     212.838                 23,440                  623,621,111     3,392,221
00512.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           212.838                 4,499                   119,681,264     683,782
00512.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           212.838                 2,110                   56,141,860      339,001
00512.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           212.838                 192                     5,112,576       33,285
00512.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            212.838                 641                     17,041,920      99,855
00512.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           212.838                 641                     17,041,920      99,855
00512.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           212.838                 192                     5,112,576       33,285
00512.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           212.838                 22                      573,795         3,291
00512.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            212.838                 15                      390,019         2,288
00512.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           212.838                 16                      431,856         2,517
00512.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           212.838                 84                      2,241,481       12,687
00512.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            212.838                 74                      1,960,985       11,150
00512.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           212.838                 77                      2,041,437       11,610
00538.M2TS      4113 (0x1011)   0x1B            AVC                                     23.482                  32,609                  95,716,015      520,514
00538.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           23.482                  3,315                   9,730,876       56,589
00538.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           23.482                  1,985                   5,826,684       35,470
00538.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           23.482                  193                     566,784         3,690
00538.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            23.482                  644                     1,889,280       11,070
00538.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           23.482                  644                     1,889,280       11,070
00538.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           23.482                  193                     566,784         3,690
00538.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           23.482                  0                       70              7
00538.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            23.482                  0                       70              7
00538.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           23.482                  0                       70              7
00538.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           23.482                  85                      250,686         1,423
00538.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            23.482                  72                      210,616         1,204
00538.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           23.482                  73                      215,293         1,229
00540.M2TS      4113 (0x1011)   0x1B            AVC                                     23.815                  10,068                  29,970,834      163,193
00540.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           23.815                  1,571                   4,677,920       29,237
00540.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           23.815                  1,728                   5,143,920       31,986
00540.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           23.815                  193                     576,000         3,750
00540.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            23.815                  645                     1,920,000       11,250
00540.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           23.815                  645                     1,920,000       11,250
00540.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           23.815                  193                     576,000         3,750
00540.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           23.815                  0                       70              7
00540.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            23.815                  0                       70              7
00540.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           23.815                  0                       70              7
00540.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           23.815                  0                       70              7
00540.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            23.815                  0                       70              7
00540.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           23.815                  0                       70              7
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Playlist: 00337.MPLS
Length: 1:21:27
Video: MPEG-4 AVC Video / 23573 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 5.1-ES / 48 kHz / 4429 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
Audio: French / Dolby Digital EX Audio / 5.1-EX / 48 kHz / 640 kbps
Audio: Spanish / Dolby Digital EX Audio / 5.1-EX / 48 kHz / 640 kbps
Audio: English / DTS-HD Master Audio / 2.0 / 48 kHz / 2116 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 1509 kbps / 24-bit)
Audio: English / Dolby Digital Audio / 2.0 / 48 kHz / 192 kbps / Dolby Surround
Subtitle: English / 53.065 kbps
Subtitle: English / 77.399 kbps
Subtitle: French / 30.499 kbps
Subtitle: French / 69.169 kbps
Subtitle: Spanish / 38.955 kbps
Subtitle: Spanish / 66.610 kbps
Toy Story 2
ABC 720p Mpeg-2 File size: 7.40 GB
Bitrate: 11.95 mbps
Code:
Sequence Frame 298938(10-B) / Time 1:23:05 :
Info: 1280 x 720, 59.94 fps, 65.00 Mbps (Header), 11.95 Mbps (Average).
Info: Found 298938 video frames since start of sequence.
Info: 0 audio frames found with errors.
End of Log
CBC 1080i Mpeg-2 File size: 11.30 GB
Bitrate: 17.56 mbps
Code:
Sequence Summary:
File Size Processed: 11.34 GB, Play Time: 01h:28m:01s
1920 x 1080, 29.97 fps (24.37 fps Telecine), 21.70 Mbps (17.56 Mbps Average).
Average Video Quality: 87.95 KB/Frame, 0.35 Bits/Pixel.
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -24.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
0 of 128692 video frames found with errors.
0 of 165049 audio frames found with errors.
End of Log
Blu-ray File size: 22.00 GB
Bitrate: 24.35 mbps
Code:
        Total   Video
00201.MPLS                                                      AVC     1:32:55 24,122,732,544  42,999,034,311  34.61   24.35   DTS-HD Master 5.1-ES 4025Kbps (48kHz/24-bit)DTS-HD Master 2.0 2078Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TOY_STORY_2_USA
Disc Size:      42,999,034,311 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:32:55 (h:m:s)
Total Bitrate:          34.61 Mbps
VIDEO:
MPEG-4 AVC Video        24352 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4025 kbps       5.1-ES / 48 kHz / 4025 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         2078 kbps       2.0 / 48 kHz / 2078 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         48.897 kbps
Presentation Graphics           English         70.633 kbps
Presentation Graphics           French          36.349 kbps
Presentation Graphics           French          70.672 kbps
Presentation Graphics           Spanish         38.304 kbps
Presentation Graphics           Spanish         67.714 kbps
FILES:
00375.M2TS      0:00:00.000     0:00:44.502     243,314,688     43,739
00496.M2TS      0:00:44.502     0:00:52.844     249,827,328     37,821
00377.M2TS      0:01:37.347     0:02:02.956     696,766,464     45,334
00521.M2TS      0:03:40.303     0:00:44.461     188,504,064     33,918
00379.M2TS      0:04:24.764     0:13:45.449     3,525,685,248   34,170
00500.M2TS      0:18:10.214     0:00:26.860     112,588,800     33,533
00381.M2TS      0:18:37.074     0:13:55.584     3,633,229,824   34,785
00502.M2TS      0:32:32.658     0:00:33.116     137,005,056     33,097
00489.M2TS      0:33:05.775     0:06:58.876     1,783,142,400   34,056
00504.M2TS      0:40:04.652     0:00:40.290     170,072,064     33,769
00383.M2TS      0:40:44.942     0:02:15.385     588,066,816     34,749
00506.M2TS      0:43:00.327     0:00:29.154     121,989,120     33,474
00385.M2TS      0:43:29.481     0:07:18.396     1,863,659,520   34,009
00508.M2TS      0:50:47.878     0:00:45.420     185,905,152     32,744
00388.M2TS      0:51:33.298     0:33:35.346     8,714,594,304   34,593
00510.M2TS      1:25:08.645     0:00:39.330     166,336,512     33,833
00390.M2TS      1:25:47.976     0:06:12.997     1,569,226,752   33,657
00542.M2TS      1:32:00.973     0:00:22.605     124,790,784     44,162
00543.M2TS      1:32:23.579     0:00:31.990     48,027,648      12,011
CHAPTERS:
1               0:00:00.000     0:01:23.583     31,629 kbps     38,086 kbps     00:01:16.242    34,750 kbps     00:01:12.322    34,002 kbps     00:00:13.263    164,814 bytes   562,645 bytes   00:00:29.029
2               0:01:23.583     0:03:24.704     30,114 kbps     41,457 kbps     00:02:28.439    35,228 kbps     00:02:10.088    34,539 kbps     00:02:05.083    156,999 bytes   880,371 bytes   00:02:15.093
3               0:04:48.287     0:02:47.500     23,181 kbps     35,110 kbps     00:06:58.501    30,006 kbps     00:04:48.413    28,551 kbps     00:04:48.287    120,856 bytes   621,093 bytes   00:07:09.554
4               0:07:35.788     0:03:05.143     23,860 kbps     36,986 kbps     00:07:52.430    33,685 kbps     00:08:07.445    31,773 kbps     00:08:03.274    124,394 bytes   702,127 bytes   00:09:21.936
5               0:10:40.931     0:01:13.865     24,416 kbps     36,837 kbps     00:10:45.394    33,917 kbps     00:10:41.474    33,540 kbps     00:10:41.599    127,295 bytes   680,041 bytes   00:10:46.312
6               0:11:54.797     0:00:52.302     21,483 kbps     35,073 kbps     00:12:03.055    32,239 kbps     00:12:00.010    25,853 kbps     00:11:57.341    112,003 bytes   453,001 bytes   00:12:19.780
7               0:12:47.099     0:02:42.829     23,878 kbps     38,389 kbps     00:15:26.050    33,370 kbps     00:15:22.046    31,019 kbps     00:15:19.918    124,488 bytes   892,114 bytes   00:15:28.802
8               0:15:29.928     0:02:45.915     24,492 kbps     38,988 kbps     00:17:14.324    33,871 kbps     00:17:25.169    33,453 kbps     00:17:19.580    127,689 bytes   932,921 bytes   00:15:34.725
9               0:18:15.844     0:02:01.746     24,168 kbps     34,538 kbps     00:18:22.434    29,989 kbps     00:18:19.806    26,931 kbps     00:18:20.265    126,003 bytes   636,235 bytes   00:18:49.878
10              0:20:17.591     0:03:56.444     23,753 kbps     35,987 kbps     00:24:08.238    33,635 kbps     00:24:04.234    31,605 kbps     00:24:01.481    123,837 bytes   639,213 bytes   00:23:28.323
11              0:24:14.035     0:01:40.350     24,922 kbps     35,777 kbps     00:24:28.925    33,603 kbps     00:24:28.925    33,213 kbps     00:24:27.799    129,930 bytes   685,126 bytes   00:25:25.565
12              0:25:54.386     0:04:37.735     25,227 kbps     37,154 kbps     00:28:54.899    33,521 kbps     00:25:59.224    33,031 kbps     00:25:56.721    131,520 bytes   658,736 bytes   00:30:20.360
13              0:30:32.121     0:01:16.326     25,375 kbps     38,702 kbps     00:30:53.977    34,280 kbps     00:30:50.014    33,187 kbps     00:30:50.014    132,292 bytes   923,525 bytes   00:30:54.936
14              0:31:48.448     0:01:03.021     26,984 kbps     36,415 kbps     00:32:39.957    34,046 kbps     00:32:43.127    33,759 kbps     00:32:38.122    140,680 bytes   640,990 bytes   00:32:12.388
15              0:32:51.469     0:03:53.524     20,943 kbps     38,213 kbps     00:35:06.145    34,186 kbps     00:34:16.137    31,609 kbps     00:34:13.134    109,190 bytes   640,830 bytes   00:34:21.726
16              0:36:44.994     0:02:24.143     27,752 kbps     40,101 kbps     00:37:52.770    34,259 kbps     00:37:22.114    33,706 kbps     00:37:23.074    144,684 bytes   827,288 bytes   00:37:14.190
17              0:39:09.138     0:00:43.918     21,744 kbps     39,077 kbps     00:39:51.680    31,420 kbps     00:39:47.676    24,961 kbps     00:39:42.796    113,361 bytes   555,112 bytes   00:39:17.771
18              0:39:53.057     0:01:13.281     23,574 kbps     39,025 kbps     00:39:53.432    32,016 kbps     00:40:06.737    29,242 kbps     00:40:06.237    122,905 bytes   901,905 bytes   00:39:55.351
19              0:41:06.338     0:01:19.871     25,388 kbps     35,017 kbps     00:41:14.305    33,371 kbps     00:41:19.268    33,190 kbps     00:41:14.263    132,359 bytes   592,876 bytes   00:42:00.517
20              0:42:26.210     0:02:15.134     23,834 kbps     38,387 kbps     00:44:38.842    34,355 kbps     00:42:42.476    31,731 kbps     00:42:37.513    124,258 bytes   936,193 bytes   00:42:54.655
21              0:44:41.345     0:02:17.220     25,714 kbps     38,353 kbps     00:46:57.064    33,866 kbps     00:46:52.476    32,314 kbps     00:46:28.118    134,063 bytes   908,592 bytes   00:46:57.481
22              0:46:58.565     0:06:25.384     23,266 kbps     40,260 kbps     00:49:13.784    34,535 kbps     00:49:09.780    33,907 kbps     00:51:27.292    121,300 bytes   925,911 bytes   00:51:37.302
23              0:53:23.950     0:02:55.967     24,810 kbps     37,192 kbps     00:56:05.403    33,623 kbps     00:54:15.960    31,463 kbps     00:54:13.958    129,346 bytes   650,957 bytes   00:56:16.956
24              0:56:19.918     0:04:50.123     24,134 kbps     38,135 kbps     00:57:10.134    33,905 kbps     00:56:53.910    33,485 kbps     00:59:01.913    125,825 bytes   827,031 bytes   00:59:22.934
25              1:01:10.041     0:01:04.230     24,898 kbps     34,857 kbps     01:02:12.770    32,038 kbps     01:02:08.891    30,197 kbps     01:02:04.262    129,808 bytes   557,399 bytes   01:01:14.170
26              1:02:14.272     0:02:09.629     24,937 kbps     36,304 kbps     01:03:01.110    33,334 kbps     01:02:57.106    31,248 kbps     01:03:28.846    130,010 bytes   639,869 bytes   01:03:02.111
27              1:04:23.901     0:03:36.507     21,994 kbps     32,988 kbps     01:07:22.413    28,686 kbps     01:07:18.617    26,486 kbps     01:07:13.404    114,664 bytes   864,460 bytes   01:07:24.415
28              1:08:00.409     0:01:51.778     22,812 kbps     36,387 kbps     01:09:45.973    27,397 kbps     01:09:46.223    25,463 kbps     01:08:20.429    118,931 bytes   552,455 bytes   01:09:49.768
29              1:09:52.187     0:02:35.280     26,826 kbps     36,104 kbps     01:10:38.358    33,542 kbps     01:11:10.307    32,986 kbps     01:10:53.081    139,856 bytes   625,856 bytes   01:12:10.075
30              1:12:27.467     0:02:31.025     24,361 kbps     37,203 kbps     01:14:53.363    34,478 kbps     01:14:52.821    29,211 kbps     01:14:48.483    127,005 bytes   640,025 bytes   01:12:28.468
31              1:14:58.493     0:02:29.816     27,045 kbps     37,868 kbps     01:17:08.748    33,839 kbps     01:16:43.849    33,520 kbps     01:16:46.935    140,999 bytes   554,064 bytes   01:17:08.790
32              1:17:28.310     0:02:17.971     21,841 kbps     34,346 kbps     01:18:17.901    33,057 kbps     01:18:13.688    31,678 kbps     01:18:12.812    113,869 bytes   482,982 bytes   01:17:34.608
33              1:19:46.281     0:01:49.526     25,354 kbps     38,589 kbps     01:21:26.423    33,858 kbps     01:21:22.460    33,318 kbps     01:21:04.818    132,185 bytes   470,076 bytes   01:20:20.398
34              1:21:35.807     0:04:13.169     23,237 kbps     41,351 kbps     01:21:45.275    34,262 kbps     01:25:41.803    32,583 kbps     01:25:24.494    121,148 bytes   713,298 bytes   01:25:03.514
35              1:25:48.977     0:07:06.592     22,714 kbps     38,341 kbps     01:32:07.438    34,632 kbps     01:32:02.683    34,020 kbps     01:32:01.015    118,432 bytes   566,564 bytes   01:30:16.911
STREAM DIAGNOSTICS:
00375.M2TS      4113 (0x1011)   0x1B            AVC                                     44.419                  33,557                  186,320,814     1,013,236
00375.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           44.419                  3,912                   21,723,648      124,986
00375.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           44.419                  2,030                   11,270,484      68,206
00375.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           44.419                  192                     1,068,288       6,955
00375.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            44.419                  641                     3,560,960       20,865
00375.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           44.419                  641                     3,560,960       20,865
00375.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           44.419                  192                     1,068,288       6,955
00375.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           44.419                  2                       11,515          69
00375.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            44.419                  0                       70              7
00375.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           44.419                  0                       70              7
00375.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           44.419                  37                      206,939         1,185
00375.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            44.419                  40                      220,769         1,266
00375.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           44.419                  35                      196,449         1,120
00496.M2TS      4113 (0x1011)   0x1B            AVC                                     52.678                  27,437                  180,662,880     982,596
00496.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           52.678                  4,205                   27,689,056      158,739
00496.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           52.678                  2,087                   13,741,188      82,459
00496.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           52.678                  193                     1,268,736       8,260
00496.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            52.678                  642                     4,229,120       24,780
00496.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           52.678                  642                     4,229,120       24,780
00496.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           52.678                  193                     1,268,736       8,260
00496.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           52.678                  2                       12,741          76
00496.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            52.678                  0                       70              7
00496.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           52.678                  0                       70              7
00496.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           52.678                  89                      583,610         3,290
00496.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            52.678                  83                      543,654         3,067
00496.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           52.678                  83                      544,222         3,080
00377.M2TS      4113 (0x1011)   0x1B            AVC                                     122.789                 34,046                  522,562,123     2,841,967
00377.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           122.789                 4,616                   70,854,480      404,142
00377.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           122.789                 2,185                   33,529,720      201,244
00377.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           122.789                 192                     2,951,424       19,215
00377.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            122.789                 641                     9,838,080       57,645
00377.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           122.789                 641                     9,838,080       57,645
00377.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           122.789                 192                     2,951,424       19,215
00377.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           122.789                 23                      348,328         2,014
00377.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            122.789                 6                       86,267          496
00377.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           122.789                 7                       111,369         632
00377.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           122.789                 81                      1,247,981       7,053
00377.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            122.789                 79                      1,209,472       6,851
00377.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           122.789                 78                      1,190,702       6,757
00521.M2TS      4113 (0x1011)   0x1B            AVC                                     44.336                  23,445                  129,934,222     706,793
00521.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           44.336                  4,395                   24,357,460      139,275
00521.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           44.336                  2,122                   11,762,224      70,884
00521.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           44.336                  193                     1,067,520       6,950
00521.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            44.336                  642                     3,558,400       20,850
00521.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           44.336                  642                     3,558,400       20,850
00521.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           44.336                  193                     1,067,520       6,950
00521.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           44.336                  11                      63,626          372
00521.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            44.336                  3                       14,795          87
00521.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           44.336                  3                       15,088          89
00521.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           44.336                  77                      428,386         2,421
00521.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            44.336                  79                      435,826         2,460
00521.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           44.336                  73                      406,829         2,304
00379.M2TS      4113 (0x1011)   0x1B            AVC                                     825.283                 23,906                  2,466,152,300   13,414,568
00379.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           825.283                 4,048                   417,580,936     2,398,202
00379.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           825.283                 2,073                   213,873,272     1,284,809
00379.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           825.283                 192                     19,811,328      128,980
00379.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            825.283                 640                     66,037,760      386,940
00379.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           825.283                 640                     66,037,760      386,940
00379.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           825.283                 192                     19,811,328      128,980
00379.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           825.283                 56                      5,809,836       33,136
00379.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            825.283                 41                      4,178,854       23,975
00379.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           825.283                 42                      4,328,975       24,846
00379.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           825.283                 72                      7,376,716       41,779
00379.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            825.283                 72                      7,395,778       41,935
00379.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           825.283                 69                      7,084,147       40,202
00500.M2TS      4113 (0x1011)   0x1B            AVC                                     26.693                  23,603                  78,755,699      428,403
00500.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           26.693                  3,950                   13,179,712      75,837
00500.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           26.693                  2,048                   6,832,480       40,927
00500.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           26.693                  193                     645,120         4,200
00500.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            26.693                  644                     2,150,400       12,600
00500.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           26.693                  644                     2,150,400       12,600
00500.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           26.693                  193                     645,120         4,200
00500.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           26.693                  28                      93,019          531
00500.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            26.693                  28                      94,715          541
00500.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           26.693                  33                      110,087         624
00500.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           26.693                  91                      305,119         1,724
00500.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            26.693                  88                      292,018         1,653
00500.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           26.693                  87                      290,376         1,645
00381.M2TS      4113 (0x1011)   0x1B            AVC                                     835.418                 24,603                  2,569,203,692   13,974,724
00381.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           835.418                 3,926                   409,955,524     2,358,024
00381.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           835.418                 2,064                   215,564,668     1,295,616
00381.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           835.418                 192                     20,054,784      130,565
00381.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            835.418                 640                     66,849,280      391,695
00381.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           835.418                 640                     66,849,280      391,695
00381.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           835.418                 192                     20,054,784      130,565
00381.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           835.418                 59                      6,112,775       34,862
00381.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            835.418                 46                      4,783,944       27,425
00381.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           835.418                 47                      4,958,677       28,374
00381.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           835.418                 75                      7,798,852       44,122
00381.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            835.418                 76                      7,955,673       45,021
00381.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           835.418                 72                      7,474,098       42,379
00502.M2TS      4113 (0x1011)   0x1B            AVC                                     32.991                  23,301                  96,091,632      522,700
00502.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           32.991                  3,832                   15,803,916      91,022
00502.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           32.991                  2,041                   8,416,760       50,558
00502.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           32.991                  193                     794,880         5,175
00502.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            32.991                  642                     2,649,600       15,525
00502.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           32.991                  642                     2,649,600       15,525
00502.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           32.991                  193                     794,880         5,175
00502.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           32.991                  34                      141,950         805
00502.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            32.991                  18                      73,825          422
00502.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           32.991                  24                      97,505          557
00502.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           32.991                  72                      296,166         1,675
00502.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            32.991                  72                      295,911         1,673
00502.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           32.991                  70                      287,824         1,629
00489.M2TS      4113 (0x1011)   0x1B            AVC                                     418.710                 23,905                  1,251,136,672   6,805,528
00489.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           418.710                 4,000                   209,335,256     1,202,862
00489.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           418.710                 2,075                   108,578,252     652,349
00489.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           418.710                 192                     10,053,120      65,450
00489.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            418.710                 640                     33,510,400      196,350
00489.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           418.710                 640                     33,510,400      196,350
00489.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           418.710                 192                     10,053,120      65,450
00489.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           418.710                 38                      1,992,100       11,472
00489.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            418.710                 25                      1,322,111       7,603
00489.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           418.710                 28                      1,451,159       8,313
00489.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           418.710                 70                      3,664,346       20,811
00489.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            418.710                 70                      3,663,303       20,838
00489.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           418.710                 66                      3,470,617       19,764
00504.M2TS      4113 (0x1011)   0x1B            AVC                                     40.123                  23,614                  118,434,594     644,233
00504.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           40.123                  4,058                   20,352,656      116,913
00504.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           40.123                  2,097                   10,515,096      63,135
00504.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           40.123                  193                     967,680         6,300
00504.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            40.123                  643                     3,225,600       18,900
00504.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           40.123                  643                     3,225,600       18,900
00504.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           40.123                  193                     967,680         6,300
00504.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           40.123                  41                      207,042         1,185
00504.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            40.123                  29                      143,889         835
00504.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           40.123                  32                      160,872         928
00504.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           40.123                  80                      401,278         2,274
00504.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            40.123                  81                      406,755         2,302
00504.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           40.123                  78                      390,992         2,223
00383.M2TS      4113 (0x1011)   0x1B            AVC                                     135.218                 24,740                  418,168,912     2,274,551
00383.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           135.218                 3,934                   66,487,804      382,512
00383.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           135.218                 2,044                   34,540,140      207,230
00383.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           135.218                 192                     3,249,408       21,155
00383.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            135.218                 641                     10,831,360      63,465
00383.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           135.218                 641                     10,831,360      63,465
00383.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           135.218                 192                     3,249,408       21,155
00383.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           135.218                 16                      266,243         1,536
00383.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            135.218                 12                      201,415         1,150
00383.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           135.218                 12                      201,769         1,152
00383.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           135.218                 74                      1,258,124       7,160
00383.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            135.218                 73                      1,225,724       6,979
00383.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           135.218                 71                      1,193,148       6,798
00506.M2TS      4113 (0x1011)   0x1B            AVC                                     28.987                  23,584                  85,455,111      464,842
00506.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           28.987                  3,863                   13,997,176      80,574
00506.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           28.987                  2,063                   7,473,884       44,796
00506.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           28.987                  193                     700,416         4,560
00506.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            28.987                  644                     2,334,720       13,680
00506.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           28.987                  644                     2,334,720       13,680
00506.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           28.987                  193                     700,416         4,560
00506.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           28.987                  45                      161,867         921
00506.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            28.987                  35                      128,267         731
00506.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           28.987                  37                      132,918         756
00506.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           28.987                  89                      321,073         1,812
00506.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            28.987                  84                      302,727         1,711
00506.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           28.987                  85                      307,147         1,736
00385.M2TS      4113 (0x1011)   0x1B            AVC                                     438.229                 23,913                  1,309,921,238   7,125,278
00385.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           438.229                 3,902                   213,761,612     1,229,736
00385.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           438.229                 2,067                   113,206,960     680,826
00385.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           438.229                 192                     10,521,600      68,500
00385.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            438.229                 640                     35,072,000      205,500
00385.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           438.229                 640                     35,072,000      205,500
00385.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           438.229                 192                     10,521,600      68,500
00385.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           438.229                 52                      2,841,185       16,226
00385.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            438.229                 43                      2,352,287       13,510
00385.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           438.229                 44                      2,424,349       13,911
00385.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           438.229                 71                      3,865,894       21,967
00385.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            438.229                 70                      3,814,835       21,700
00385.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           438.229                 66                      3,629,720       20,693
00508.M2TS      4113 (0x1011)   0x1B            AVC                                     45.254                  22,919                  129,646,205     705,222
00508.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           45.254                  3,828                   21,656,152      124,861
00508.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           45.254                  2,027                   11,468,392      68,595
00508.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           45.254                  193                     1,090,560       7,100
00508.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            45.254                  643                     3,635,200       21,300
00508.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           45.254                  643                     3,635,200       21,300
00508.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           45.254                  193                     1,090,560       7,100
00508.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           45.254                  35                      198,531         1,153
00508.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            45.254                  36                      201,999         1,173
00508.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           45.254                  28                      156,278         922
00508.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           45.254                  82                      461,330         2,620
00508.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            45.254                  89                      503,026         2,848
00508.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           45.254                  79                      447,274         2,542
00388.M2TS      4113 (0x1011)   0x1B            AVC                                     2015.180                24,232                  6,103,939,431   33,201,891
00388.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2015.180                4,113                   1,036,166,384   5,945,576
00388.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           2015.180                2,098                   528,538,792     3,177,777
00388.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2015.180                192                     48,368,640      314,900
00388.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            2015.180                640                     161,228,800     944,700
00388.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           2015.180                640                     161,228,800     944,700
00388.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           2015.180                192                     48,368,640      314,900
00388.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2015.180                51                      12,733,502      72,807
00388.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            2015.180                38                      9,484,883       54,484
00388.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2015.180                41                      10,229,756      58,601
00388.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           2015.180                69                      17,298,873      98,213
00388.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            2015.180                68                      17,233,036      97,955
00388.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           2015.180                66                      16,597,175      94,466
00510.M2TS      4113 (0x1011)   0x1B            AVC                                     39.164                  23,362                  114,370,007     622,141
00510.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           39.164                  4,232                   20,717,624      118,710
00510.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           39.164                  2,179                   10,669,268      64,048
00510.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           39.164                  193                     944,640         6,150
00510.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            39.164                  643                     3,148,800       18,450
00510.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           39.164                  643                     3,148,800       18,450
00510.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           39.164                  193                     944,640         6,150
00510.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           39.164                  44                      215,031         1,237
00510.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            39.164                  38                      185,552         1,068
00510.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           39.164                  42                      205,328         1,182
00510.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           39.164                  86                      421,318         2,383
00510.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            39.164                  93                      455,422         2,590
00510.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           39.164                  89                      433,342         2,460
00390.M2TS      4113 (0x1011)   0x1B            AVC                                     372.873                 23,493                  1,094,989,463   5,956,225
00390.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           372.873                 3,981                   185,553,696     1,066,539
00390.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           372.873                 2,053                   95,675,552      575,265
00390.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           372.873                 192                     8,952,576       58,285
00390.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            372.873                 640                     29,841,920      174,855
00390.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           372.873                 640                     29,841,920      174,855
00390.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           372.873                 192                     8,952,576       58,285
00390.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           372.873                 62                      2,868,889       16,464
00390.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            372.873                 45                      2,080,356       11,938
00390.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           372.873                 45                      2,111,135       12,114
00390.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           372.873                 71                      3,291,402       18,631
00390.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            372.873                 71                      3,300,410       18,686
00390.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           372.873                 70                      3,248,702       18,413
00542.M2TS      4113 (0x1011)   0x1B            AVC                                     22.439                  33,937                  95,190,352      517,657
00542.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           22.439                  3,534                   9,912,716       57,443
00542.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           22.439                  1,993                   5,591,160       33,993
00542.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           22.439                  194                     542,976         3,535
00542.M2TS      4355 (0x1103)   0x81            AC3-EX          fra (French)            22.439                  645                     1,809,920       10,605
00542.M2TS      4356 (0x1104)   0x81            AC3-EX          spa (Spanish)           22.439                  645                     1,809,920       10,605
00542.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           22.439                  194                     542,976         3,535
00542.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           22.439                  0                       70              7
00542.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            22.439                  0                       70              7
00542.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           22.439                  0                       70              7
00542.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           22.439                  0                       70              7
00542.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            22.439                  0                       70              7
00542.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           22.439                  0                       70              7
00543.M2TS      4113 (0x1011)   0x1B            AVC                                     31.823                  5,348                   21,274,278      116,051
00543.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           31.823                  1,569                   6,240,000       39,000
00543.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           31.823                  1,684                   6,699,992       41,749
00543.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           31.823                  193                     768,000         5,000
00543.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            31.823                  644                     2,560,000       15,000
00543.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           31.823                  644                     2,560,000       15,000
00543.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           31.823                  193                     768,000         5,000
00543.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           31.823                  0                       70              7
00543.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            31.823                  0                       70              7
00543.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           31.823                  0                       70              7
00543.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           31.823                  0                       70              7
00543.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            31.823                  0                       70              7
00543.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           31.823                  0                       70              7
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Playlist: 00201.MPLS
Length: 1:32:55
Video: MPEG-4 AVC Video / 24352 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 5.1-ES / 48 kHz / 4025 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
Audio: English / DTS-HD Master Audio / 2.0 / 48 kHz / 2078 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 1509 kbps / 24-bit)
Subtitle: English / 48.897 kbps
Subtitle: English / 70.633 kbps
Subtitle: French / 36.349 kbps
Subtitle: French / 70.672 kbps
Subtitle: Spanish / 38.304 kbps
Subtitle: Spanish / 67.714 kbps
Xylon is offline
post #10 of 77 Old 03-22-2010, 10:14 PM
ChuckZ's Avatar
Can I get a "day-ummmm?"
ChuckZ is offline
post #11 of 77 Old 03-22-2010, 10:15 PM
42041's Avatar
Liked: 55
Looking very dated these days
42041 is offline
post #12 of 77 Old 03-22-2010, 11:24 PM
geocab's Avatar
Quoted: 93 Post(s)
Liked: 110
geocab is offline
post #13 of 77 Old 03-22-2010, 11:52 PM
stevestevenson's Avatar
was this re-rendered? Anyone know?
stevestevenson is offline
post #14 of 77 Old 03-23-2010, 12:17 AM
surap's Avatar
No reason to keep the dvd....
surap is offline
post #15 of 77 Old 03-23-2010, 12:46 AM
ChuckZ's Avatar
Toy Story was at least re-rendered. I don't know about Toy Story 2.
ChuckZ is offline
post #16 of 77 Old 03-23-2010, 06:19 AM
Gertjan's Avatar
To Infinity and Beyond indeed!
"He who asks feels dumb for a few minutes, but he who does not ask remains dumb forever."
Gertjan is offline
post #17 of 77 Old 03-23-2010, 08:30 AM
gmoney80's Avatar
wow these look amazing even for pixar
Xbox One GAMERTAG:trickygmoney80
gmoney80 is offline
post #18 of 77 Old 03-23-2010, 08:49 AM
Paul Arnette's Avatar
Quoted: 66 Post(s)
Originally Posted by geocab View Post
I love blu-ray.
I love Blu-ray when done right. Fortunately, Pixar always does it right. Too bad other studios cannot say the same.
Paul Arnette is offline
post #19 of 77 Old 03-23-2010, 08:53 AM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
Toy Story 1 definitely. Like Star Wars though I can still appreciate the movie even with dated sfx/gfx.
pcweber111 is offline
post #20 of 77 Old 03-23-2010, 09:04 AM
Rathbone's Avatar
Quoted: 56 Post(s)
Liked: 25
Definitely. Afaik all Pixar movies up to Monsters Inc. have/had to be re-rendered for Blu-ray. I read it somewhere but cannot find the link anymore.
EDIT:
This link http://web.archive.org/web/199610200...ver/cover.html from 1996 mentions a resolution of 1536x922.
The 'printed' resolution for Toy Story was 800 x 1480 afaik.
Rathbone is offline
post #21 of 77 Old 03-23-2010, 09:12 AM
Rach's Avatar
Even though I have the DVDs, thanks for the coupon link and codes!
Rach is offline
post #22 of 77 Old 03-23-2010, 09:28 AM
sb1
sb1's Avatar
Quoted: 439 Post(s)
Liked: 382
Quite a nice improvement.
Stephen.
Chances are very good that I was drinking when I posted the above.
sb1 is offline
post #23 of 77 Old 03-23-2010, 09:38 AM
nick_danger's Avatar
Oh man, that's extraordinary! I'm very excited!
This reminds me of the recent release of "Perfect Dark" on Xbox Live. It's a classic Nintendo64 game that has been given new life on the Xbox 360. The original game was rendered at 320x240 resolution, the revised game is rendered at a full 1920x1080! They upgraded some of the textures to compensate, but you can tell it's just very simple by comparison to a modern 1080p videogame.
Dated, but beautiful.
nick_danger is offline
post #24 of 77 Old 03-23-2010, 09:50 AM
Toe
Toe's Avatar
Quoted: 2661 Post(s)
Liked: 3383
Wow! Looking forward to watching my copies
Toe is online now
post #25 of 77 Old 03-23-2010, 11:27 AM
christopher a's Avatar
Waiting for the "blu ray is an improvement but the dvd is pretty damn good!!" comment.....
christopher a is offline
post #26 of 77 Old 03-23-2010, 11:58 AM
ChrisPC's Avatar
Another "Pattonized" title, their faces look just like plastic! Oh, wait...
ChrisPC is offline
post #27 of 77 Old 03-23-2010, 12:25 PM
sb1
sb1's Avatar
Quoted: 439 Post(s)
Liked: 382
What's up with Mrs. Potato Head's lips? Is that some kind of funky screen cap artifact, the BD, or my monitor?
Stephen.
sb1 is offline
post #28 of 77 Old 03-23-2010, 01:32 PM
spectator's Avatar
Yeah! And when are we going to get a source-accurate version of this movie, instead of this higher-resolution-than-the-theatrical-release atrocity?
I don't feel special...
spectator is offline
post #29 of 77 Old 03-23-2010, 02:26 PM
BenUK's Avatar
I see this comes packaged as a "DVD + BD" does that mean its a flipper, or is it seperate discs?
BenUK is offline
post #30 of 77 Old 03-23-2010, 02:47 PM
MrHT's Avatar
Quoted: 104 Post(s)
Separate discs.
MrHT is offline
Reply Blu-ray Software
