Peter Jackson's Heavenly Creatures - Alliance Canada (PIX) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-17-2010, 01:33 PM - Thread Starter
msgohan's Avatar
Specs here. This is the "uncut" version.
Some of the shots are matched to the DVD screenshots here.
Opened up to 1.78:1 from 2.35:1. No DNR. The transfer itself looks decent though it seems to have that weird noise present in some other releases. But god damn, the compression job is pathetically unstable. From second-to-second you can see it abruptly switch from relatively transparent to horribly smoothed and (de)blocked.
Features the Miramax logo at the start so a proper stateside release may be a while. Tons of different foreign distributors though so maybe another one will get it right first.
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #2 of 7 Old 09-17-2010, 01:51 PM
Deviation's Avatar
Compression artifacts, ahoy! Seriously, what's with all of the macroblocking?
Bleah. Another poor cable master in the wrong aspect ratio from Alliance.
Deviation is offline
post #3 of 7 Old 09-17-2010, 01:55 PM
dvdmike007's Avatar
Liked: 50
I hate Peter Jackson's work post The Frighteners, and hate that anything before those rings movies gets shafted
dvdmike007 is offline
post #4 of 7 Old 09-17-2010, 02:02 PM - Thread Starter
msgohan's Avatar
Forgot to mention, I think you do get a couple extra seconds of Winslet boobies underwater as a result. Worth it?
msgohan is offline
post #5 of 7 Old 09-17-2010, 02:26 PM
eric.exe's Avatar
Quoted: 110 Post(s)
Liked: 44
Looks like theres DNR underneath all the video noise
eric.exe is offline
post #6 of 7 Old 09-17-2010, 02:41 PM
Deviation's Avatar
You know, I think you're right. Talk about a truly wretched presentation. The framing is abandoned, the detail is sucked out by DNR and what's left is obscured by a truly stupendous amount of video noise and macroblocking. The only thing this presentation seems to have escaped is edge enhancement.
post #7 of 7 Old 09-17-2010, 04:44 PM
Kram Sacul's Avatar
Wrong aspect ratio, ancient transfer, bad compression... another hit from Alliance.
Deviation, check out the 2nd bottom right capture. EE galore.
Kram Sacul is offline
Reply Blu-ray Software
