Demonstration Blu-Ray Discs (Independently Authored) - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 83Likes
post #331 of 363 Old 11-09-2017, 06:34 AM
Eric The Red's Avatar
Quoted: 21 Post(s)
Liked: 1
Hi again I have managed to stream the files but when I tried to burn them to disc I do not have enough space so it looks like I will have to get 8mg discs But I am having trouble I watched some file which where very good but when going to watch a other file I get this see photo and then my computer frezzes and I have to turn off my Pc and turn it on again this happens all the time what is going on
Eric The Red is offline
post #332 of 363 Old 11-10-2017, 04:33 AM
Quoted: 21 Post(s)
Liked: 1
Manged to get rid POWER DVD 17 and the probs it was causing Now I have the demo disc but streamed to Power DVD16 now how do I get from Stream to disc Thanks and can I use normal record-able DVD 8Gb
post #333 of 363 Old 11-10-2017, 07:22 AM - Thread Starter
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
To play the folder as a disc the easiest way is just to drag and drop the BDMV folder in to the Power DVD icon.
The Power DVD program should launch and "load" the disc.
Once is loaded you should be able to see the disc menus. Use your arrow keys to navigate and enter to select.
That should do it. Enjoy!
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #334 of 363 Old 11-10-2017, 08:55 AM
LastButNotLeast's Avatar
Quoted: 2348 Post(s)
Liked: 1978
Yes. Sadly, AFAIK, there are no re-writable 8GB discs available.
Make sure you write the whole folder (with the BDMV and CERTIFICATE folders inside).
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #335 of 363 Old 11-10-2017, 09:27 AM
Quoted: 21 Post(s)
Liked: 1
Hi Michael and Leo Here is as far as i have got. I some how managed to stream the demos which not only look good but sound good also. But the thing is I do not want to show them on the PC I want demonstrate the on my Home Theatre that has the picture and sound system to show it of to full as this demo disc deserves to be show and also show off to my mates as well I took Michael advice with help from him of course and got it on Utorrent then opened the folder in the torrent and transferred it to powerdrive 16 nothing happen then I transfer it to my hard drive and tried to burn it to my DVD disc but it sad I did not have enough space as they only 4.7Gb so I then tried one of my USB sticks which I knew had plenty of room on it transferred OK but when I tried it on the TV nothing so that was a dead in the water. I then tried what Leo said to do but again nothing if I copyed and pasted the folder to power DVD all I got was a blank screen if I tried the other folder which I think said Movie object I get the message no disc in drive I am at a Lose what to do now Please see pictures Is this a lost cause for me I know I am in Dunce section when it comes to this sort of thing. Maybe it is because I am a stupid 68 year old Fart
ID:	2313178   Click image for larger version
ID:	2313180   Click image for larger version
ID:	2313182   Click image for larger version
post #336 of 363 Old 11-10-2017, 09:30 AM
Quoted: 21 Post(s)
Liked: 1
Michael Saw these would these be OK https://www.reichelt.com/gb/en/?LANG...11QAsMEAQYBSAB
post #337 of 363 Old 11-10-2017, 10:02 AM - Thread Starter
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
Hey Eric, by all means do not give up.
In some respect age is just a number... as long as extraneous physical activity is not part of it , ask me how I know. I'm your junior by a few years but I'm right behind you and Michael.
If I'm reading your post correctly, you are saying that you "cut paste" the folder - you should "drag and drop" the folder directly into the Poser DVD icon. Then the program should start the disc.
I understand that what you want is being able to play the disc anywhere. The best way is to burn it to a disc. As Michael mentioned there are no reusable DVD but might as well buy yourself a BD-RE disc. And of course you would need a BD RE computer player.
superleo is offline
post #338 of 363 Old 11-10-2017, 10:10 AM
Quoted: 21 Post(s)
Liked: 1
Hi leo I can not seem to see this dvd copoer on PowerDVD Where about isit mate
post #339 of 363 Old 11-10-2017, 10:24 AM
Quoted: 21 Post(s)
Liked: 1
Its OK I found it but once I have dragged the folder to the Power DVD all i get is I get is a picture of the cover of the said disc which is of a load of loudspeaker cons and a gold cup. Over here they do 8Gb DVDs https://www.reichelt.com/gb/en/?LANG...11QAsMEAQYBSAB
post #340 of 363 Old 11-10-2017, 10:25 AM - Thread Starter
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
I'm attaching a picture of the folder with the BDMV forlder and right next to it my PowerDVD icon.
left click the mouse button and hold it down. While holding it down drag the folder to the PowerDVD icon, once on top of the icon release the mouse button. That should start the program.
superleo is offline
post #341 of 363 Old 11-10-2017, 10:30 AM - Thread Starter
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
Eric send you a PM (private message).
You should have a notification towards the top of your browser. Click on the notification and it will take you to the message.
Let me know.
superleo is offline
post #342 of 363 Old 11-10-2017, 11:52 AM
Liked: 1978
And a BD BURNER, which is probably what you meant.
post #343 of 363 Old 11-10-2017, 12:10 PM - Thread Starter
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
That is exactly what I meant ... Thanks for the clarification Michael.
superleo is offline
post #344 of 363 Old 11-10-2017, 02:16 PM
Liked: 1978
Those are fine.
They'd be fine over here, too.
post #345 of 363 Old 11-10-2017, 11:47 PM
Quoted: 21 Post(s)
Liked: 1
Hello Again I just want to say Thank you to everybody on here especially Leo and Micheal who have been very patient with me indeed ( They must of been banging there heads on there computer desks trying for me to get it right you all have bent over backwards to help me big time. I am going to be honest with you. Before I came on this AVS site I did not like Americans 1 thought they where brash could be very rude shoot you as soon as look at you. You won and done everything Home Theatres the size of commercial ones over here and of course statistics. BUT HOW WRONG I WAS! As far as I am concerned you have been very helpful and very kind and Patient with a old fart like me and I am very grateful to you all. I mean you play a good game of football sorry soccer and holy of holys you have taking up the classic English Game of CRICKET What ever next I would like to wish you all a Great Thanksgiving Day as i know it is important to you. But I will leave one American out if you do not mind D.T Once again thank you all you are not a bad lot after all I admit I got it wrong
post #346 of 363 Old 11-13-2017, 07:27 AM - Thread Starter
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
Hello Again I just want to say Thank you to everybody on here especially Leo and Micheal who have been very patient with me indeed...
Glad I could help.
superleo is offline
post #347 of 363 Old 11-13-2017, 08:30 AM
Quoted: 21 Post(s)
Liked: 1
Glad I could help.
Thank you Leo
post #348 of 363 Old 11-20-2017, 04:54 PM
NINaudio's Avatar
Quoted: 35 Post(s)
I have a question about these, does anyone know if I can just play them from my Shield TV (streamed through Plex on my home network or I can put them on the Shield's internal storage)or do I have to burn them to a blu-ray?
| Samsung UN55H7150 | NVIDIA Shield TV Pro | Denon AVR-X4000 | Boston Acoustics Lynnfield VR 950 mains, VR 10 center, NHT Superzero 2.1 surrounds | Ultimax 18" powered by a Crown XLS 1502 |
NINaudio is offline
post #349 of 363 Old 12-04-2017, 11:33 AM - Thread Starter
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
As far as I know, as long as the clips are in a format that the Shield can play, pretty much any format, then the shield will be able to play them. You would need to have the codecs loaded if you will be using the shield with no other audio processing these, otherwise you can just bitstream the audio and the receiver/processor should handle the audio correctly.
If you "true" stream these, then the throughput of your network, wireless or wired, is a determining factor.
I don't think there is a front end for the Shield that would play the BD structure files with menus, so you would be needing to play the individual clips from the stream folder(s).
If you want the full Blu-ray experience with any of these discs - easiness of navigation, pop up menus, menus etc, the best way is to just burn them to media.
superleo is offline
post #350 of 363 Old 12-04-2017, 01:32 PM
Ph8te's Avatar
Quoted: 6255 Post(s)
Liked: 5881
Oled does not support ISO, so you’d need to either browse the folders or break them out another way.
Ph8te is offline
post #351 of 363 Old 03-12-2018, 09:41 PM
rjeeves33's Avatar
Liked: 0
G'day guys. Long time lurker, first post. Sorry it's a leech request. Just trying to grab 'Home Theater Demonstration v2.0'. Got to 83.3% and stalled. Any chance someone seeding for a while. Shouldn't need long on 50Mbps connection
rjeeves33 is offline
post #352 of 363 Old 03-25-2018, 08:02 AM
Frank D's Avatar
Quoted: 417 Post(s)
Liked: 101
Is there a good Atmos demo disc or download? If yes link please.
Frank D is offline
post #353 of 363 Old 03-25-2018, 08:56 AM
Super Moderator
teachsac's Avatar
Quoted: 1233 Post(s)
Liked: 2021
Audio section
https://www.avsforum.com/forum/89-spe...-download.html
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #354 of 363 Old 05-20-2018, 07:08 AM
JayNYC's Avatar
Quoted: 31 Post(s)
Hi - are there any 'scope' only demo discs? (ie: content that is 2.35 or 2.39 aspect ratio only)
JayNYC is offline
post #355 of 363 Old 05-20-2018, 08:18 AM
Super Moderator
teachsac's Avatar
Liked: 2021
He found the thread in the HT section.
teachsac is offline
post #356 of 363 Old 07-29-2018, 07:15 PM - Thread Starter
superleo's Avatar
Quoted: 91 Post(s)
Liked: 331
Yes ...
Here is the link. https://www.avsforum.com/forum/19-de...l#post35921610
superleo is offline
post #357 of 363 Old 03-27-2019, 08:32 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 566 Post(s)
Liked: 406
I know this is an old thread, but it makes the most sense to place the question here.
For Dolby Atmos, we have the demonstration trailers created by Dolby, but I was wondering if there is any interest in creating one of these independently authored discs for Atmos demo material, now that we have a good deal of movies released in the format?
Mark
Archaea and biliam1982 like this.
giomania is offline
post #358 of 363 Old 03-28-2019, 08:34 AM
Liked: 1978
There is a lot of interest; unfortunately, remastering these new formats to a disc requires software that is not freely available.
The latest collection of files is here:
https://www.avsforum.com/forum/19-de...dtsx-more.html
Michael
giomania likes this.
post #359 of 363 Old 03-28-2019, 10:40 AM
deano86's Avatar
Quoted: 613 Post(s)
Liked: 303
Ya, I think it would be sweet to create nothing but the best Atmos demo scenes and provide as a downloadable torrent..... In addition, creating separate torrents with one being only the 4K atmos files and the other being only 1080p files would be super handy!
deano86 is offline
post #360 of 363 Old 03-28-2019, 10:49 AM
Liked: 1978
Apparently, there's a way to select which files you want from the torrent.
I've never done it that way, so I'm afraid I can't advise.
Michael
Reply Blu-ray Software
