UHD Blu-Rays - Report Your FIRST IMPRESSIONS Here! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 164Likes
post #91 of 345 Old 02-17-2016, 06:42 AM
mpgxsvcd's Avatar
Quoted: 2958 Post(s)
Liked: 2617
Red face
Originally Posted by rcheng View Post
FWIW, here is another comparison. To my eyes, UHD has better detail, contrast and color. But I am really impressed how great this player up converts BD. Very happy with my purchase so far~!
Top: BD
Bottom: UHD HDR
The only difference I can see between these two images is a MASSIVE green push for the 1080p Blu ray. Otherwise the pictures are identical. What TV were you using?
mpgxsvcd is offline
post #92 of 345 Old 02-17-2016, 07:27 AM
rcheng's Avatar
Quoted: 17 Post(s)
65" Samsung JS9000
Viewing the screen at my sitting distance, I can definitely see a difference in regards to better contrast, detail, and color. The UHD HDR image just has more pop. But I have to say this player does a heck of a job with BD also.
rcheng is offline
post #93 of 345 Old 02-17-2016, 07:45 AM
cdnscg's Avatar
Quoted: 602 Post(s)
Liked: 123
65" Samsung JS9000
Are you using a BD disc for both images, or a BD and 4K disc?
cdnscg is offline
post #94 of 345 Old 02-17-2016, 07:56 AM
rcheng's Avatar
Quoted: 17 Post(s)
top: BD bottom: 4k UHD
rcheng is offline
post #95 of 345 Old 02-17-2016, 10:28 AM - Thread Starter
R Harkness's Avatar
Quoted: 2805 Post(s)
Liked: 2726
Originally Posted by ray0414 View Post
You see, you are going off "theory" and opinion.
Your responses suggest you aren't approaching this with a very "scientific" mindset, which means that perhaps this is a fruitless conversation. But one more go....
No, I'm not simply going of "theory" and "opinion." I'm going off the basis of how display technology actually works, facts you can look up yourself, and which you can test yourself, and which are routinely tested by professionals.
You are aware of the importance of black levels always being touted by AV professionals and reviewers, and educated AVSmembers, right? This is why the contrast ratio and black level measurements - the deepest black a display is capable of, so often features in the tests of displays going back decades. Now...before UHD came along, what would be the point of measuring the very deepest black a display is capable of...if it wasn't relevant to the black levels the display could produce with existing DVD/Blu-Rays? Of course it's relevant. Reviewers don't like seeing high black level measurements on displays because it tells you about the black levels you will see with actual content! It tells you what black level you will get when some portion of the image on DVD or Blu-Ray is putting out 0 IRE, or "no" light.
That's why you can use EXISTING Blu-Ray test discs to MEASURE the black levels of your display! Blu-Ray can already produce the "blackest blacks" your display is capable of.
If Blu-Ray can already reach the limits of black level that a display is even capable of...how is it you suggest that UHD can produce "even darker" black levels?
If your idea made sense, all the technical calibrating done to displays, based on how the technology is understood to work, has never made sense. You are operating under a different paradigm than the actual people who build our displays, and who calibrate displays.
Can you not see the problem there?
Im going off real world testimony, and other DOZENS of people who have this real world testimony that agree that the black levels are better with HDR.
And have any of these been supported by measurements of the black level, showing it has actually deepened?
Do you not understand how easily our eyes are tricked in regards to contrast and light levels? Ever see any of the many
contrast effects on our vision?
The classic, wouldn't your eyes "tell you" that the A square is darker than the B square (even though it's not)?
Don't your eyes tell you that the right square is darker than the left square?:
But they are not. We know very well from empirical experience as above, not simply on some "funky theory," that how we perceive tonal shades is very influenced by a variety of factors. If we shift the contrast relationship around an area of the same brightness, it's brightness will appear to change to our eyes. Brightening bright areas will do this in an image, as will shifting gamma, which will shift the brightness of areas bordering on the dark areas. As I said, when I go to a higher gamma, I often perceive my black levels going lower, though I know they remain at the same actual measured levels.
the question is whether its from the higher bitrate/encoding or HDR itself. I think it may actually be a combination.
See...you seem actually interested in the answer, so it doesn't help to start off on the wrong foot towards getting it. You are starting with a conclusion "UHD sources produces lower black levels than Blu-Ray" that has been arrived at via faulty methods of inference and dubious assumptions.
UHD can't make the *same display* produce lower black levels than it could with Blu-Ray. Good calibration already sets the back level of a display as low as it will go (some caveats in there for different display technologies). In other words, the usual rec709 calibration tends to use the lowest black level your display can manage as a base from which it builds toward the brightest areas. What UHD does is allow for encoding of more information, so you can get better shadow detail (though not lower black levels) but also encode picture information that allows for much brighter highlights to maintain detail. So now you can calibrate the brighter end of the display to extend brighter - much brighter displays up until now could do - without losing detail in the source.
So think of UHD as allowing higher brightness, not lower darkness. That's why the emphasis is always on "specular highlights" such as the glint of sun off metal, for a more realistic image.
(And, having seen UHD on some LCDs, as to be expected it was certainly clear UHD didn't help the LCDs magically achieve lower black levels - the brightness of highlights was certainly increased, but any low APL dark scenes still showed less than stellar black levels...because those are set by the display, not the source).
seanbryan, krichter1, muzz and 7 others like this.
R Harkness is online now
post #96 of 345 Old 02-17-2016, 10:33 AM
bruceames's Avatar
Quoted: 538 Post(s)
Liked: 371
So Rich, do you think the increased shadow detail is due solely to the higher bit rate? If so, would that be seen equally as well playing a UHD on a 1080p display?
bruceames is offline
post #97 of 345 Old 02-17-2016, 11:44 AM
mpgxsvcd's Avatar
Liked: 2617
Wink
The increased shadow detail is due to a different edit of the original footage. They can pull the shadows in post processing to extract extra detail from dark regions. This extra shadow detail will also have additional noise. This is why HDR often shows extra details but often tends to be noisier as well. Sometimes the noise can be cleaned up with additional processing though.
bruceames likes this.
mpgxsvcd is offline
post #98 of 345 Old 02-17-2016, 04:03 PM
rcheng's Avatar
Quoted: 17 Post(s)
Comparing to MGO HDR on Samsung 65" JS9000.
Still images are pretty close. I can see more shadow detail in UHD disc. When watching live, the UHD disc looks more vibrant to my eyes.
Top: UHD HDR Disc (Standard picture mode)
Bottom: MGO HDR
Here is a closeup. Can you see a difference? They are pretty darn close.
ID:	1260889   Click image for larger version
ID:	1260897   Click image for larger version
Name:	Lightroom Exports9.jpg
mpgxsvcd likes this.
rcheng is offline
post #99 of 345 Old 02-17-2016, 04:39 PM
JeffR1's Avatar
Quoted: 1072 Post(s)
Liked: 531
Interesting, I took a piece of paper and covered everything leaving only the two squares _ they are the same shade.
JeffR1 is offline
post #100 of 345 Old 02-17-2016, 04:57 PM - Thread Starter
R Harkness's Avatar
Liked: 2726
Yep. That's what we learn when we take the precaution of double-checking and testing our assumptions, rather than simply "testifying" how it looks to our eyes.
post #101 of 345 Old 02-18-2016, 03:23 AM
Liked: 3
If possible for anyone to take some comparison shots of the BD and UHD with HDR on a setup like this:
  • 10-Bit DCI-P3 monitor at normal 100-120nits
  • 10-Bit DCI-P3 monitor at max brightness (probably ~350nits)
(e.g. LG 31MU97-B, Eizo ColorEdge CG318-4K, ...)
I would really like to know if the HDR impacts positively or negatively on a P3 monitor with such low brightness (a TV is out of my budget right now).
twgz is offline
post #102 of 345 Old 02-18-2016, 03:36 AM
James Freeman's Avatar
Quoted: 517 Post(s)
Liked: 348
The color difference between BD and UHD-BD in the rec.709 gamut range has to do with the color grading and TV setting, and can't be properly compared with screenshots.
In other words, 99% of the color content of UHD can be easily mapped to rec.709 gamut rang, any difference you see between the versions with: skin tones, rooms, clothing has nothing to do with wider gamut of rec.2020 or DCI-P3 but with color grading and TV setting.
The use of wider gamut shines in nature (flowers, plants, birds, insects, animals, etc..) and special effects (lasers, Avatar, extra vivid colors) where the captured/created colors actually wider than rec.709 and should be clearly visible alongside NORMAL mellow skin tones.
As for resolution;
You can clearly see that if the camera captured 4K and the studios downscaled it to 1080p (2K) the difference should look similar to what you see below.
To my eyes what we got now on the UHD disc is an upscaled 2K DCI version, as I see from the comparison images in this thread.
The new format will shine with HDR, HFR, lots of real vivid (outside rec.709) colors and real 4k content (camera with proper lenses etc.).
For now, what I see is HDR mastered and upscaled DCI 2K movies, not bad considering the difference is only 10 vs 12bit and 420 vs 444.
But the format is in its infancy and the potential is HUGE.
Unfortunately there is also a lot of trickery potential from the studios so that new customers will clearly see the difference between the HD and UHD version;
They may make the colors more vivid inside rec.709 (completely unnecessary) and sharpen the hell out of an upscaled 2k master, even without using HDR, so it looks "nicer" to the untrained eye in a side by side comparison.
Personally, I am waiting for a movie that was captured in 4K (or higher), HFR, with lots of nice colors.
The Hobbit comes to mind.
One last note,
The studios will definitely NOT redo the FX in 4K if the master is already in 2K.
So basically what we will get for the first couple of years is upscaled 2K DCI masters with HDR.
James Freeman is offline
post #103 of 345 Old 02-18-2016, 06:17 AM
mpgxsvcd's Avatar
Liked: 2617
Wink
The use of wider gamut shines in nature (flowers, plants, birds, insects, animals, etc..) and special effects (lasers, Avatar, extra vivid colors) where the captured/created colors actually wider than rec.709 and should be clearly visible.
As for resolution;
One last note,
Most of what you said was correct. However, there is no 12 bit or 4:4:4 content at the moment unless you count the few Dolby Vision movies the Vizio R-series is supposed to play.
mpgxsvcd is offline
post #104 of 345 Old 02-18-2016, 06:36 AM
Quoted: 517 Post(s)
Liked: 348
I meant that DCI 2K is 12bit, 4:4:4, P3 Gamut,
vs UHD which is upscaled 2K 10bit 4:2:0, P3 Gamut (in a rec.2020 container).
Also the bitrate of UHD now allows for 128MBit/s while DCI allows 250MBit/s.
Anything above 50MBit/s is practically invisible, so not even DCI compressed (not compressed I should say) to 250MBit/s.
If they upscale the 2K 4:4:4 12bit to 4K 4:4:4 12bit before compressing with HEVC to 4:2:0 10bit, we might not even lose any color at all.
Most probably than not, as it's much more lengthy process to first convert to 4:2:0 10bit and only then upscale, and then compress.
It's a lot faster to just upscale the 2K 4:4:4 12bit master to 4K (can be easily done in real time on your desktop PC) and let HEVC compress it to 4:2:0 10bit.
Not bad for a home format.
With UHD-BR you basically buy the DCI Master, what more do we want?
EDIT:
I know what we want.
4K 12bit, 4:4:4 HFR, HDR, Rec.2020 in 128MBit/s or they're not getting my 30$.
reanimator likes this.
post #105 of 345 Old 02-18-2016, 07:45 AM
metalsaber's Avatar
Quoted: 1048 Post(s)
Liked: 858
Originally Posted by wuther View Post
Like sharpening artifacts?
it was actual macroblock like compression. not sharpening.
metalsaber is offline
post #106 of 345 Old 02-18-2016, 08:05 AM
MisterXDTV's Avatar
Quoted: 49 Post(s)
Liked: 26
Wrong, you get the DCI Master (reduced to 4:2:0, 10bit) re-graded in HDR for no reason and upscaled most of the time
MisterXDTV is offline
post #107 of 345 Old 02-18-2016, 06:48 PM
rcheng's Avatar
Quoted: 17 Post(s)
For those that are still on the fence, judge the difference for yourselves. Try to stand back at normal tv viewing distance and see if you see the improvements.
Closeup comparison BD vs UHD on Samsung JS9000. Photos taken with 50MP Canon 5DSR on tripod.
rcheng is offline
post #108 of 345 Old 02-19-2016, 12:29 PM
Quoted: 38 Post(s)
I wish stores would hurry up and start displaying UHD discs. That's the only way I'll be able to see for myself for the time being.
JRobinson84 is offline
post #109 of 345 Old 02-19-2016, 12:51 PM
darinp2's Avatar
Quoted: 1135 Post(s)
Liked: 1767
Would you expect pixels encoded at say 90% of REC.709 on BD to be encoded at the same x,y coordinates in UHD Blu-Ray just because those pixels are inside REC.709? I expect sone degree of roll off and not just clipping, so expect that some things inside REC.709 would be encoded differently between a REC.709 encode and a P3 or REC.2020 encode.
--Darin
darinp2 is offline
post #110 of 345 Old 02-19-2016, 01:09 PM
Quoted: 38 Post(s)
For anyone in the West LA area, I just found out that the Magnolia at the Best Buy on Pico/Sawtelle just set up their UHD disc display last night. The guy said they're currently playing The Martian and that it looks fantastic. I'll be heading over there to check it out. If I'm impressed, I'm gonna be in financial trouble!
aaronwt and reanimator like this.
post #111 of 345 Old 02-19-2016, 04:33 PM
DavidHir's Avatar
Quoted: 2576 Post(s)
Liked: 2258
As for resolution;
One last note,
The Hobbit was actually finished in 2K.
There are a lot of catalog titles that have been remastered or restored in 4K, however, I get the sense the studios will be focused on newer releases for the next couple of years but it would be nice if they released a few.
DavidHir is online now
post #112 of 345 Old 02-21-2016, 11:40 AM
kristoffer77's Avatar
Quoted: 84 Post(s)
Liked: 57
For people with the Samsung. How much noise does it make and how fast is it?
kristoffer77 is offline
post #113 of 345 Old 02-21-2016, 10:57 PM
carr857's Avatar
Quoted: 59 Post(s)
Liked: 37
Its super fast actually. One of the fastest blu ray players I have ever used. As far as noise, pretty quiet as far as I can tell. It does get hot, and has a small fan in the back.
carr857 is offline
post #114 of 345 Old 02-22-2016, 04:27 AM
metalsaber's Avatar
Liked: 858
Agreed. Super fast and quiet. Pretty much what you want.
post #115 of 345 Old 02-22-2016, 05:41 AM
Quoted: 743 Post(s)
Liked: 123
As for resolution;
One last note,
Hi James
Could you explain what is rec 709 , rec 2020? I am new to 4K . Thanks a lot
Roudan is offline
post #116 of 345 Old 02-22-2016, 08:24 PM
Quoted: 517 Post(s)
Liked: 348
Wrong, wrong.
First upscaling to 4K then truncating to 4:2:0 retains 100% of the original 2K 4:4:4 chroma.
Understand why?
--Darin
Of course there will be difference.
The 2K DCI master is projected with 2.6 gamma to begin with and has to be regraded.
It is obvious that the colorist will create completely new result with UHD Blu-ray without taking reference of the rec.709 Blu-ray version.
What I want to say is, if you have all the colors in the world it does not mean you have to use them.
What I "fear" the most is the studios will oversharpen the upscaled 2K video and unnecessarily make the video more colorful.
Everything has its proper place in the Chromaticity diagram, from pale skin tones to super vivid red neon lights (which can't be displayed on 709 BTW).
Our eye can see much more color than what a TV can display.
rec.709 color space is what TVs display for almost 50 years now (CRT or LCD).
rec.2020 is the new standard which can display much more vivid colors.
DCI-P3 is the colors that a Xeonon lamp cinema projector can display.
Google "color space".
Roudan likes this.
post #117 of 345 Old 02-25-2016, 01:57 PM
frenchie903's Avatar
Quoted: 38 Post(s)
This post sums up how I feel about it at the moment. Maybe if they ever produce a "Real" 4K disc I will feel differently then. However, for now it just seems like a scam.
https://www.avsforum.com/forum/150-bl...l#post41512417
Yes I was taken back when I learned alot of the early releases were not shot in true 4k. At the time I purchased Martian 4k I did not realize that. When I first put it in and from beginning to end I said WOW! There is definitely a improved sharpness and color factor to it. Then I played the standard bluray disc. Amazing. The standard one looked dull compared to the "fake" 4k one. All I can say is that these are the best knockoffs I've ever seen:-).
aaronwt likes this.
frenchie903 is online now
post #118 of 345 Old 02-25-2016, 02:18 PM
UHD Addict
aaronwt's Avatar
Quoted: 9327 Post(s)
Liked: 6008
Yes. i figured if these UHD BD titles, with supposedly 2K Masters, can look so much better than a BD. Then I can't wait for the UHD BD titles from actual 4K masters. Hopefully my first UHD BDs, from 4K masters, show up next week.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #119 of 345 Old 02-25-2016, 03:54 PM
Quoted: 38 Post(s)
I read here that the "Real" 4k releases are Hancock Salt Spiderman 2 Sicario and Expendables 3. My 4k receiver will arrive tomorrow so I'll have it hooked up for next week. I think I'll have a "Real" 4k release party:-).
post #120 of 345 Old 02-25-2016, 04:52 PM
ray0414's Avatar
Quoted: 12691 Post(s)
Liked: 11949
Thats because the uhd version of the martian IS part native 4k. It has 5k elements spliced in. Everyone is ignoring this. It's like a hybrid.
aaronwt likes this.
ray0414 is online now
Reply Blu-ray Software
artifacts
