Star Wars: The Force Awakens Initial Blu-ray Release - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #61 of 95 Old 04-16-2016, 03:35 PM
Gooddoc's Avatar
Quoted: 3908 Post(s)
Liked: 3589
Originally Posted by DanT9 View Post
I wached earlier this week and in the third scene wjen the pods were released from the ship, I heard a handful of POPs from a left rear speaker. I've got a Marantz 7010 with 5.1.4. Speakers are Monitor Silver 10's up front and Monit0r Silver 2's in the rear and Monitor's in the ceiling for Atmos.
I also played on another cheap 5.1 system in my house and at a friend's low end 7.1. There was no 'POP' on the other systems. This is the only time I've notices any problem with my 4 month old system. Do I have a speaker problem? Or should i just ignore it until it is replicated?
Maybe your crossovers are too low? Could be bottoming your woofers? Don't know, just giving you somewhere to start troubleshooting.
Gooddoc is offline
post #62 of 95 Old 04-16-2016, 05:03 PM
impala454's Avatar
Reply from Oppo customer service:
Chuck,
If you are using the analog outputs then this is a confirmed issue and we are looking into the possibility of this being addressable through firmware.
Best Regards,
Customer Service
OPPO Digital, Inc.
162 Constitution Dr.
Menlo Park, CA 94025
[email protected]
Tel: 650-961-1118
Fax: 650-961-1119
So at least we aren't crazy. Hopefully their customer service will come through as always.
Gooddoc likes this.
-Chuck
impala454 is offline
post #63 of 95 Old 04-16-2016, 05:29 PM
z.pelton1996's Avatar
Quoted: 38 Post(s)
Watched it earlier this week and enjoyed it more than in theaters. Of course in theaters the bass sounded like kroger bags
z.pelton1996 is offline
post #64 of 95 Old 04-16-2016, 06:29 PM
Gooddoc's Avatar
Liked: 3589
Wow. Are the outputs clipping? I remember some clipping issues with the Oppo. I thought it had to do with bass management, I wonder if this is related.
Gooddoc is offline
post #65 of 95 Old 04-16-2016, 06:40 PM
impala454's Avatar
Not clipping, just simply not playing at all (the rear channels).
Gooddoc likes this.
-Chuck
post #66 of 95 Old 04-17-2016, 05:05 AM
FishenFool's Avatar
Quoted: 35 Post(s)
Liked: 50
I've got an old Sony 5.1 that has no HDMI, uses a passive subwoofer, only digital audio inputs are coax and optical and best output it has is regular DTS. The surrounds and dialog were working properly on my Blu-ray disc that was outputting DTS-HD 7.1 even though my Home Theater receiver was only 5.1. My setup is an early and cheap Magnavox/Funai Blu-ray player, LG 55" LED Smart TV and above mentioned Sony Receiver. Blu-ray is hooked to TV with HDMI and TV passes audio out thru an optical audio out port that is connected to the optical audio in port on the receiver.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
FishenFool is offline
post #67 of 95 Old 04-18-2016, 08:44 AM
dragonbrewer's Avatar
I have the same issue with almost the same setup. I'm using an Oppo BDP83 (not SE though) configured to down mix to 5.1. I am getting no audio from either surround channel. Are you also using the Oppo's analog outputs? When I pop in my Disney WOW test disc without changing anything and play the channel finder it works fine (finds all channels). I posted the problem to the Oppo BDP83 owner's thread as well if you want to chime in there.
I also wonder if anyone else is using any bluray player with analog outputs with this disc and seeing any issues.
I figured out how to solve the issue with this particular Blu-ray. I did send an email to Oppo and they were also going to look into the problem with this disc. After I contacted them I tried a few more things at home with my setup. I do use the analog outputs on this player because my legacy receiver doesn't process the HD surround formats. Normally when you are using the analog outputs the manual for this player recommends turning the secondary audio off. I went into the set up menu and turned secondary audio to on. This solved the problem right away. For whatever reason with the Force Awakens disc if you have secondary audio turned off you don't get a surround signal. I hope this helps. I will also post this in the oppo bdp83 owner's thread in case anyone else runs into this.
Cheers
Erik
dragonbrewer is offline
post #68 of 95 Old 04-19-2016, 05:37 AM
GuybrushT2's Avatar
Quoted: 25 Post(s)
Has anyone tried to play the bonus disc on PowerDVD? It doesn't work. All you get is a BB8 gif with no menu options. Would like to get that fixed...
GuybrushT2 is offline
post #69 of 95 Old 04-19-2016, 08:54 AM
cmdrdredd's Avatar
Quoted: 4262 Post(s)
Liked: 4574
Try using kodi?
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #70 of 95 Old 04-19-2016, 10:05 AM
GuybrushT2's Avatar
Quoted: 25 Post(s)
Originally Posted by cmdrdredd View Post
Try using kodi?
I actually use Jriver as my main media player, and it will play the longest playlist on the disc which is the making of featurette. I want access to the menu and everything else on it, so I occasionally use PowerDVD. Don't know why it isn't working. I don't use Kodi at all, though.
post #71 of 95 Old 04-19-2016, 01:41 PM
cmdrdredd's Avatar
Liked: 4574
Kodi is free and should allow you to access the menu. Can't hurt to install it and give it a try.
TurboTropic likes this.
post #72 of 95 Old 04-21-2016, 09:18 PM - Thread Starter
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 554 Post(s)
Liked: 677
I've hosted various friends for three full screenings so far. I've also returned to revisit some scenes just for fun. Newly impressed each time with the photography, transfer, mix, and actors. The extras are super interesting, too.
The mix just seems right on the money. Impressive and "natural/organic" to the action, but only imposing where it should be...and as mentioned by others, there's a couple of scenes where they use the LFE to do just that. I have to chuckle when the LF pumps with Rey's and Kylo's pulsing brows in the interrogation scene.
cmdrdredd likes this.
Cam Man is offline
post #73 of 95 Old 04-22-2016, 08:54 AM
cmdrdredd's Avatar
Liked: 4574
I also thought that for a 1080p disc it looks great.
post #74 of 95 Old 08-10-2016, 02:31 PM
LexInVA's Avatar
Quoted: 797 Post(s)
Liked: 375
3D version hits 11/15, with new extras. Consider this release the "definitive version" to own as it has all the previous extras - including exclusives - and the 3D version, in addition to the 2D.
mikejedi123 likes this.
LexInVA is offline
post #75 of 95 Old 08-11-2016, 06:01 AM
nathanddrews's Avatar
Quoted: 630 Post(s)
Liked: 654
Meh. This movie needs an HDR release.
nathanddrews is offline
post #76 of 95 Old 08-11-2016, 07:04 AM
NorthJersey's Avatar
Quoted: 576 Post(s)
Liked: 246
I wouldn't hold my breath, for some reason Disney is really holding back from the UHD/4k streaming/disc movement. Maybe they are waiting for Dolby Vision-enabled UHD players to come out next year before joining (considering TFA was shown in Dolby Vision in theaters)
as far as this release, even though I saw TFA in 3D in the theater, any my LG TV does 3D, i'll wait until the prequel+TFA 3D set is released before double-dipping
NorthJersey is offline
post #77 of 95 Old 08-11-2016, 07:04 AM
tezster's Avatar
Quoted: 660 Post(s)
Liked: 554
Hopefully it also includes an Atmos mix, and variable aspect ratio
tezster is offline
post #78 of 95 Old 08-11-2016, 08:35 AM
Quoted: 630 Post(s)
Liked: 654
Maybe we just need to email them again and again asking for UHD versions.
post #79 of 95 Old 08-11-2016, 10:22 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5986 Post(s)
Liked: 5122
Woohoo! 3D version coming out.
http://www.blu-ray.com/news/?id=19607
Still not Atmos though. Meh...
Scott Simonian is offline
post #80 of 95 Old 08-12-2016, 11:36 AM
film113's Avatar
Quoted: 364 Post(s)
Liked: 238
Right now, only Warners and Lionsgate have Dolby deals. As for Disney, people have been complaining about how few 3D releases we get from them. And 3D sells better than UHD. So I wouldn't expect them to start releasing titles that will sell less than 3D. Perhaps in a year or two, if it seems like it will be profitable. But right now, they aren't going to jump into a format that is a niche within a niche within a niche. (The only reason we are getting STAR WARS 3D is because it's from Lucasfilm, not Disney.)
film113 is offline
post #81 of 95 Old 11-03-2016, 12:20 AM
SkyCyberguy's Avatar
Quoted: 129 Post(s)
Liked: 74
3D Blu-ray: White dots in upper left corner
Just got the UK Blu-ray release version of "The Force Awakens 3D" yesteday.
Looks and sounds great, but one strange thing occured during the crash-landing scene on Jaccu:
A pattern of four white dots in the upper left corner (see photo).
It only appears in the 3D version of the film.
I pushed "Enter" on the remote because I assumed some kind of easter egg behind it, but nothing happened.
It's something that doesn't belong there, so I don't really like it.
Any clues what it is?
http://www.av-insider.de - Bild und Ton mit Sachverstand (Sound And Vision Expertized)
SkyCyberguy is offline
post #82 of 95 Old 11-03-2016, 02:42 PM
Jrek's Avatar
Quoted: 22 Post(s)
Liked: 53
I have this disc also but theres no dots when viewing mine. But this is an awesome 3d disc probably one of the best I own. And watching in 3d and dts upmixing with four height speakers is fantastic,I really would love to hear the atmos mix because if it's better than this then wow we're in for a real treat. I've watched it 3 times already and like I said before the 3d is awesome definitely the way this was intended to be seen. Thanks Jim
Jrek is offline
post #83 of 95 Old 11-03-2016, 06:41 PM
Brandon B's Avatar
Quoted: 116 Post(s)
Liked: 93
Some type of anti-piracy watermarking maybe?
Brandon B is offline
post #84 of 95 Old 11-04-2016, 12:16 AM
Quoted: 129 Post(s)
Liked: 74
My first thought, too, but then again... naaaw, too obvious, too crude, too distracting, you could do that in FAR more subtle, more sophisticated ways.
post #85 of 95 Old 11-27-2016, 11:33 AM
LineWalker's Avatar
Quoted: 111 Post(s)
Liked: 91
Finally got to see this in 3D, only to have problems of my own with the disc. I lost picture and sound for a few seconds, at two points, first at 1 hr. 12 min. and again at 1hr. 35 min. And this is the first time I played the disc on brand-new equipment I got during Black Friday: I now use a Samsung BD-J6300 BD player and an Onkyo TX-NR656 receiver, and I find no fault with either of those components. I contacted Disney Home Video support about the possibility of a defective disc, but I don't think I'll be hearing from them too soon. (Oh, and no white dots I could see on my copy.)
LineWalker is offline
post #86 of 95 Old 11-28-2016, 09:48 AM
LineWalker's Avatar
Quoted: 111 Post(s)
Liked: 91
Looks like I may have spoken a little too soon about whether the disc was defective; now it looks more like a player issue with the Samsung unit. I played Captain America: Civil War in 3D on it and had another one or two blackout issues. I called Samsung, did a hard reset according to their directions, and now I have to see if it works properly from here on out. (And it's a brand-new unit, too, I shouldn't be having these problems with it yet...)
post #87 of 95 Old 11-29-2016, 08:48 AM
Quoted: 576 Post(s)
Liked: 246
I got a chance to watch SW:TFA 3D on my Samsung K8500 uhd player last night on my LG LED TV, no issues at all in watching the movie in 3D. In fact, it was like watching the movie for the 1st time since I saw it in theaters in 3D. No way I can go back to watching the movie in 2D again, or even if it's ever re-released in Dolby Vision 4k
post #88 of 95 Old 12-01-2016, 05:11 PM
R Harkness's Avatar
Quoted: 2894 Post(s)
Liked: 2864
I watched the 3D blu-ray not long ago and it blew me away. What a fantastic 3D conversion/transfer. It really added to the movie and it's now my go-to version of the film. (Viewed with a JVC RS600 projector and large screen...fwiw..)
R Harkness is offline
post #89 of 95 Old 01-05-2017, 10:34 AM
HarpuaFSB's Avatar
Quoted: 151 Post(s)
Liked: 78
Has anyone else had issues with TFA 3D on an Xbox One S?
It does not play in 3D, only loads in 2D. Yes I am sure I have the correct disc in. Plays in 3D on my PS4 and Oppo.
HarpuaFSB is offline
post #90 of 95 Old 05-04-2019, 10:54 AM
agerson's Avatar
Quoted: 150 Post(s)
Liked: 27
Regular Blu-ray vs Apple HDR 4k streaming
I have a LG C8 OLED TV that supports 4k and HDR. So I want to watch a movie (Star Wars The Force Awakens) I have on regular blu-ray (Not ultra HD HDR 4k). Will it look better on regular Blu-ray or streamed from Apple in 4K/HDR? I sit 10 feet away so I don't think the 4k matters that much, but the HDR would.
Aperion Verus Grand Bookshelf L/R
Aperion Verus Grand Center Channel
Aperion Verus Forte Satellite
SVS PB-1000
Denon X3400 / LG C8 65inch OLED / ATV4K
agerson is offline
Reply Blu-ray Software
