bluray and dvd release comparisons - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By AB4OLED
  • 1 Post By NJPete
  • 1 Post By wuther
post #1 of 18 Old 05-02-2016, 09:37 AM - Thread Starter
gerall's Avatar
Quoted: 60 Post(s)
Is there a website which compares both the bluray (and dvd) releases of films. I am a collector of both and would like to identify which release provides the best quality of video mastering and also audio. For example, I am running a 2 channel audio system and prefer mono of 2 channel mixes of audio, most of which are available on older DVD releases (and some newer blu-rays) I believe IMDB once provided some of this information but I no longer see it on the site. thank you.
gerall is offline
post #2 of 18 Old 05-02-2016, 09:41 AM
Quoted: 74 Post(s)
Liked: 93
Try blu-ray.com
Daniel Chaves likes this.
AB4OLED is offline
post #3 of 18 Old 05-02-2016, 11:36 AM - Thread Starter
gerall's Avatar
Quoted: 60 Post(s)
thank you - is there a similar site for dvd comparisons?
gerall is offline
post #4 of 18 Old 05-02-2016, 11:53 AM
eric.exe's Avatar
Quoted: 110 Post(s)
Liked: 44
http://www.caps-a-holic.com/ - every comparison you could dream of
eric.exe is offline
post #5 of 18 Old 05-02-2016, 03:45 PM
NJPete's Avatar
Quoted: 29 Post(s)
Liked: 49
http://www.dvdcompare.net
Phantom Stranger likes this.
NJPete is offline
post #6 of 18 Old 05-02-2016, 08:00 PM
wuther's Avatar
Quoted: 674 Post(s)
Liked: 209
Dvdbeaver.com, caps-a-holic.com is the best but is missing a lot of titles and does not cover supplements.
Originally Posted by AB4OLED View Post
Try blu-ray.com
That site lists dvd releases but does not compare them.
wuther is offline
post #7 of 18 Old 05-04-2016, 02:42 PM - Thread Starter
gerall's Avatar
Quoted: 60 Post(s)
thank you all - DVD beaver wins. the problem I have is I'm using an HTPC to play blu-rays and dvds and the volume level of blu rays is about half that of dvds - I posted this elsewhere and for the life of me I can't figure out why this is so. Any comments or suggestions would be greatly appreciated
gerall is offline
post #8 of 18 Old 05-05-2016, 08:27 AM
JazzGuyy's Avatar
Quoted: 429 Post(s)
Liked: 439
From what I understand the volume difference can be primarily ascribed to the lossless formats found on BDs. They have a potentially wider dynamic range than Dolby Digital or DTS on DVDs. The overall volume is set lower on BDs to accommodate this and to prevent the default volume from possibly damaging equipment or your ears if it was too high and your equipment or you weren't ready for the volume peaks possible.
JazzGuyy is offline
post #9 of 18 Old 05-05-2016, 12:09 PM - Thread Starter
gerall's Avatar
Quoted: 60 Post(s)
thanks is there any way to compensate for this without adding more amplification? would the dolby digital plus and dts core lossy tracks provide greater volume? thanks
gerall is offline
post #10 of 18 Old 05-05-2016, 12:25 PM
JazzGuyy's Avatar
Quoted: 429 Post(s)
Liked: 439
Maybe. You never know with encoding. Your software player may have a setting within it to set dynamic compression which should reduce the overall loudness range of the material and thus you might be able to increase the average loudness and get the result you want. Obviously you lose the dynamics so there is an affect on the sound you may or may not like. It is also possible that other settings adjustments available within your player software may give you a different (and maybe more satisfactory) result. You may even want to try different playback software. The results may be different. You will have to experiment a bit, I would think. I would ask in the HTPC forum for suggestions about what things you may be able to do. I don't really have any experience with HTPCs.
JazzGuyy is offline
post #11 of 18 Old 05-05-2016, 06:56 PM
wuther's Avatar
Quoted: 674 Post(s)
Liked: 209
Are you using a AV receiver? Those usually have low audio lifting features not that I use that.
wuther is offline
post #12 of 18 Old 05-06-2016, 02:29 PM - Thread Starter
gerall's Avatar
Quoted: 60 Post(s)
no av receiver - using my 2 channel audiophile system.
gerall is offline
post #13 of 18 Old 05-06-2016, 05:06 PM
wuther's Avatar
Quoted: 674 Post(s)
Liked: 209
I assume that is something like a AV Receiver?
wuther is offline
post #14 of 18 Old 05-15-2016, 04:26 PM
Legairre's Avatar
Quoted: 1167 Post(s)
Liked: 640
If it's just a 2 channel system he's probably using separates consisting of a stereo preamp paired with external amplification.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is online now
post #15 of 18 Old 05-15-2016, 10:49 PM
wuther's Avatar
Quoted: 674 Post(s)
Liked: 209
Sounds like analog...
wuther is offline
post #16 of 18 Old 05-16-2016, 08:53 AM - Thread Starter
gerall's Avatar
Quoted: 60 Post(s)
I'm running a desktop computer direct to monoblock tube amps - no preamp - the computer serves as my preamp - I use the volume control of my software - sounds amazing but bluray volume is less than 1/2 of the dvd volume on all software. thanks.
gerall is offline
post #17 of 18 Old 05-16-2016, 07:12 PM
wuther's Avatar
Quoted: 674 Post(s)
Liked: 209
I am starting to see why you are having audio problems...
wuther is offline
post #18 of 18 Old 06-15-2016, 06:05 PM
wuther's Avatar
Quoted: 674 Post(s)
Liked: 209
Just found this. Seems to limited to new movies but might be useful to some.
http://dvdblurayfeatures.com/tag/mov...cial-features/
wuther is offline
Reply Blu-ray Software
