Unofficial Blu-ray Audio and Video Specifications Thread - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 1971 Old 07-01-2008, 07:53 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
More from Xylon:
Code:
        Total   Video
The Professionals                                               AVC     1:57:29 31,733,366,784  35,480,980,307  36.01   26.06   Dolby TrueHD 5.1 4232Kbps (48kHz/24-bit)
A Passage To India                                              AVC     2:43:57 36,402,094,080  47,091,721,168  29.60   22.96   Dolby TrueHD 5.1 2444Kbps (48kHz/16-bit)
The Sand Pebbles                                                MPEG-2  3:02:33 33,297,426,432  39,457,412,972  24.32   18.02   DTS-HD Master 5.1 3705Kbps (48kHz/24-bit) DD AC3 4.0 320Kbps
The Seventh Seal                                                AVC     1:36:13 16,988,663,808  22,550,087,928  23.54   21.99   DD AC3 2.0 224Kbps
The Longest Day                                                 AVC     2:58:22 39,626,440,704  40,765,784,136  29.62   23.40   DTS-HD Master 5.1 3318Kbps (48kHz/24-bit) DD AC3 4.0 448Kbps
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #392 of 1971 Old 07-02-2008, 10:55 AM
msgohan's Avatar
Originally Posted by msgohan View Post
Benes
Video Bitrate: 33.67
DGAVCIndex
Bitrate (Avg): 32.880
Bitrate (Max): 53.064
Re: Peak bitrates and whether >48Mbps video is possible, stats for Cast Away. I can't speak to how DGAVCIndex calculates this but the Doom9 forums may say.
The author, neuron2, explained this in response to someone else's query:
Every 30 coded frames this occurs:
1. Adjust number of coded frames to the number of displayed frames by adding as needed for frame or field repeats seen during that time.
2. Calculate the time for those as (displayed frames / frame rate).
3. Calculate the video data rate as:
rate = bytes_delivered * 8.0 / time / 1024000.0;
4. Print the highest rate seen since start of decoding as the max bitrate.
Maybe someone else can explain how this affects the numbers.
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #393 of 1971 Old 07-02-2008, 11:10 AM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Code:
DTS-HD Master Audio (lossless compression) 24-bit/48kHz
        Advertised
        Total   Video   Video
Title                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Bitrate Main Audio Track                                Secondary Audio Track
Point Break                                     AVC     2:02:05 33,988,184,064  41,725,606,312  37.12   29.33   28      DTS-HD Master Audio 5.1 4303Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps/DD AC3 4.0 448Kbps
Code:
PLAYLIST REPORT:
Length:         2:02:05 (h:m:s)
Total Bitrate:  37.12 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00001.M2TS      33,988,184,064  2:02:05.693     0:00:00.000     2:02:05.693
VIDEO:
Codec               Bitrate         Description
MPEG-4 AVC Video    29330 kbps      1080p / 23.976fps
AUDIO:
DTS-HD Master Audio             English         4303 kbps       5.1 / 48kHz / 24-bit / 4303kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
Dolby Digital Audio             English         448 kbps        5.1 / 48kHz / 448kbps
Dolby Digital Audio             English         448 kbps        4.0 / 48kHz / 448kbps
Dolby Digital Audio             French          224 kbps        2.0 / 48kHz / 224kbps
Dolby Digital Audio             Spanish         224 kbps        2.0 / 48kHz / 224kbps
SUBTITLES:
Presentation Graphics           English         59 kbps
Presentation Graphics           Chinese         58 kbps
Presentation Graphics           French          0 kbps
Presentation Graphics           Korean          36 kbps
Presentation Graphics           Spanish         34 kbps
Presentation Graphics           Spanish         0 kbps
Code:
Dolby TrueHD (lossless compression) 16-bit/48kHz
        Total   Video
Title                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track                                Secondary Audio Track
In the Line of Fire                             AVC     2:08:36 35,309,082,624  39,525,927,767  36.61   24.95   Dolby TrueHD 5.1 1435Kbps (48kHz/16-bit)
Code:
PLAYLIST REPORT:
Length:         2:08:36 (h:m:s)
Total Bitrate:  36.61 Mbps
Description:
FILES:
00011.M2TS      35,309,082,624  2:08:36.709     0:00:00.000     2:08:36.709
VIDEO:
MPEG-4 AVC Video    24948 kbps      1080p / 23.976fps
AUDIO:
Dolby TrueHD Audio              English         1435 kbps       5.1 / 48kHz / 16-bit / 1435kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby TrueHD Audio              French          1507 kbps       5.1 / 48kHz / 16-bit / 1507kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby TrueHD Audio              Portuguese      1415 kbps       5.1 / 48kHz / 16-bit / 1415kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         25 kbps
Presentation Graphics           Arabic          14 kbps
Presentation Graphics           Chinese         24 kbps
Presentation Graphics           Chinese         31 kbps
Presentation Graphics           Dutch           24 kbps
Presentation Graphics           Dutch           44 kbps
Presentation Graphics           French          25 kbps
Presentation Graphics           French          44 kbps
Presentation Graphics           Indonesian      27 kbps
Presentation Graphics           Korean          19 kbps
Presentation Graphics           Portuguese      24 kbps
Presentation Graphics           Portuguese      51 kbps
Presentation Graphics           Spanish         27 kbps
Presentation Graphics           Spanish         38 kbps
Cinema Squid- Point Break took 9:36 to scan, while In the Line of Fire took 30:37 from the same hard drive. The only difference I see between ITLOF and the others I have tried is the multiple TrueHD tracks. When I scanned Spiderwick again it took the 10 mins. I think multiple lossless tracks slow it down. This was with v.0.3.1 .
post #394 of 1971 Old 07-02-2008, 06:00 PM
Cinema Squid's Avatar
I've noticed this too and it does seem like discs with TrueHD tracks might be taking longer for some reason. The only thing major difference that I can think of as a culprit would be a small section of code that gets run repeatedly as the average bitrate is updated to take out the core AC3 bytes. I'd be surprised if that was the cause, but you never know because it happens a lot (at each presentation timestamp increment).
Employee of the Month - DTS-HD High Resolution Audio (lossy compression) 24-bit/48kHz
Code:
        Total   Video
Employee of the Month                                           AVC     1:48:07 19,310,014,464  24,894,603,764  23.81   18.19   DTS-HD Hi-Res 6.1 3039Kbps (48kHz/24-bit) DD AC3 5.1-EX 640Kbps
Code:
PLAYLIST REPORT:
Length:         1:48:07 (h:m:s)
Total Bitrate:  23.81 Mbps
Description:
FILES:
00001.M2TS      19,310,014,464  1:48:07.481     0:00:00.000     1:48:07.481
VIDEO:
MPEG-4 AVC Video    18187 kbps      1080p / 23.976fps
AUDIO:
DTS-HD Audio                    English         3039 kbps       6.1 / 48kHz / 24-bit / 3039kbps (DTS-ES Core: 5.1-ES / 48kHz / 24-bit / 1536kbps)
Dolby Digital EX Audio          English         640 kbps        5.1-EX / 48kHz / 640kbps
SUBTITLES:
Presentation Graphics           English         40 kbps
Cinema Squid is offline
post #395 of 1971 Old 07-02-2008, 11:41 PM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Cinema Squid,
How do you calculate the audio bit rate ? Do you scan the entire disc for every audio track or you spawn multiple threads to do the scanning concurrently ? Please educate.
Buddies with BD Drives,
Could you please scan The Descent Blu-ray and check if the Rated & Unrated Versions are really AVC encoded ?
It would be great if you can perform the scan using PowerDVD, DGAVCIndex and BDInfo.
Some interesting discussion is going on here. Check from post #15.
https://www.avsforum.com/avs-vb/showt...3#post14205123
Blu-ray : 340
lgans316 is offline
post #396 of 1971 Old 07-03-2008, 11:54 AM
sfligio's Avatar
Originally Posted by House View Post
Batman Begins BD
Same encode as the HD DVD.
Are you sure?
BluRay movie size 23,792,474,112
HdDvd movie size 19,857,584,128
sfligio is offline
post #397 of 1971 Old 07-03-2008, 12:39 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Code:
Dolby TrueHD (lossless compression) 24-bit/96kHz
        Total   Video
John Mayer: Where the Light Is                  VC-1    2:32:38 46,356,916,224  48,283,404,188  40.49   24.77   Dolby TrueHD 5.1 7490Kbps (96kHz/24-bit)        LPCM 2.0 4608Kbps (96kHz/24-bit)
Code:
PLAYLIST REPORT:
Length:         2:32:38 (h:m:s)
Total Bitrate:  40.49 Mbps
Description:
FILES:
00012.M2TS      25,366,265,856  1:23:07.816     0:00:00.000     1:23:07.816
00013.M2TS      20,990,650,368  1:09:30.749     1:23:07.816     2:32:38.566
VIDEO:
VC-1 Video          24771 kbps      1080p / 23.976fps
AUDIO:
Dolby TrueHD Audio              English         7490 kbps       5.1 / 96kHz / 24-bit / 7263kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
LPCM Audio                      English         4608 kbps       2.0 / 96kHz / 24-bit / 4608kbps
post #398 of 1971 Old 07-03-2008, 02:08 PM
Originally Posted by sfligio View Post
Are you sure?
Perhaps the BD has extra audio/subtitle tracks not present on the HD DVD to account for the size difference? Warner has been known to put on more of these for the BD port and I have vague memories of this very same discussion regarding V for Vendetta.
Here is a (hopefully not too long-winded, but reasonably thorough) overview of the current BDInfo scanning/calculation process:
There are three types of files involved in the process: the MPLS "playlist" files, the CLPI "clip info" files and the M2TS "MPEG transport streams" and it's worth talking about their structure first to make the process clearer.
Each MPLS file represents a single playable item (a movie, television episode, featurette, trailer, etc.) and serves as a table of contents for that item to the playback device. The MPLS contains a list of M2TS files arranged in playback order along with time stamps specifying the in/out times of each M2TS. There is also an ordered list of chapter markers in the MPLS and each marker is specified as an M2TS index and the time offset within it (so the overall chapter time stamp is determined by calculating the overall start time of the M2TS according the playlist order and then adding the offset of the marker). While many MPLS only reference a single M2TS file, some reference more than one if the item is broken into multiple M2TS files and a given M2TS may be referenced by multiple MPLS. This is how seamless branching and other operation such as "play all episodes" or "play all deleted scenes" are performed: i.e. different playlists specifying different orderings of M2TS files.
Each M2TS file also has a corresponding CLPI "clip info" file that serves as a simple table of contents to the streams contained within the M2TS - i.e. video, audio and graphics tracks. Each stream is given a unique four-digit "PID" (packet identifier) and a stream type identifier that indicates the codec of the stream. Depending on the stream type, there is a little bit of additional information supplied that can be used to populate the display/menus of the playback device. Video tracks also have their resolution (1080p, etc.), framerate (23.976, 29.97, etc.) and basic aspect ratio (4:3, 16:9) listed. Audio tracks have their basic channel layout (Mono, Stereo, Multi - kind of useless), sampling rate (48/96/192) and language code (English/Spanish/etc.). Presentation and interactive graphics tracks (i.e. subtitles and non-Java menus) also have a language code. All of this information is also redundantly stored in the MPLS files, but it can be a little more convenient to read it from the CLPI files.
The M2TS files themselves are the real meat and potatoes of things and contain all the video, audio and graphics data. Structurally, the M2TS is laid out as a sequence of 192 byte packets (chunks of data). Each packet has a 4-byte synchronization header (an addition over the old-style .TS file) followed by the normal 188-byte MPEG transport stream packet data (for more information, see http://en.wikipedia.org/wiki/MPEG_transport_stream). The important point is that each data packet is assigned to a specific stream through the packet identifier (PID) and there are a number of flags indicating what should be done with the data inside the packet. For BDInfo, there are a few critical pieces of information. Video and audio streams have a codec-independent generic PES (program elementary stream) header that is contained within the packet data. This header is used to increment the presentation/display time stamps for each stream (since they are all potentially running at different rates and the packets from all streams are jumbled together in an interleaved fashion) and also to indicate the number of bytes of actual stream data that is expected to follow, spread across multiple subsequent packets, when a new chunk of data "payload" begins (i.e. a single video frame or a set of audio frame samples).
With all that said, here is the sequence of events inside BDInfo:
After clicking the Browse button and selecting a disc/folder, BDInfo locates the BDMV folder and recursively calculates the total folder size of BDMV's parent (i.e. one level above BDMV) - this sum is given as the disc size. It looks for the presence of a BDSVM (or SLYVM) folder - if found, the disc is marked as BD+. It looks for the BDJO folder and if any .BDJO files are in this folder, then the disc is marked as having BD-Java. This is the highly sophisticated BD+ and BD-Java detection algorithm!
BDInfo then reads in and fully parses all of the MPLS files in the PLAYLIST folder. For each playlist, the list of referenced M2TS files are stored, the playlist M2TS time offsets are used to calculate the playlist length and the file sizes of the constituent M2TS files are added together as the playlist size - these numbers show up as the movie length and size respectively in the final report. For each referenced M2TS, the corresponding CLPI file is then read and parsed to create a master list of streams for the playlist with the PID, stream type/codec, and basic stream attributes stored.
The final (and most time-consuming) step in the Browse process is to open and read each unique M2TS referenced by all of the playlists. Packets are read from each M2TS until a codec-specific header is found for each video and audio stream in the M2TS - i.e. processing of the M2TS stops once all the streams have their extra information filled in. Separate routines for AVC, MPEG-2, VC-1, AC3, DTS, TrueHD, DTS-HD and LPCM process this header information to update the stream descriptions with additional information not found in the CLPI such as the exact channel count, bit depth, core AC3/DTS stream info for TrueHD/DTS-HD, and constant bitrate values for AC3/DTS/LPCM. Any discrepancies found for the video stream's resolution and frame rate replace the information from the CLPI.
At this point, hopefully only a few seconds have passed and BDInfo is sitting idle with the playlists, files and streams displayed. The fun begins when the scan bitrates button is clicked. A unique list of M2TS is built based on the checked items in the "Select Playlist(s)" box or, if no items are checked, all of the referenced M2TS are added to the list - in either case, each M2TS is only added to the list once so it doesn't get scanned multiple times. The bitrate scanner then opens the M2TS files one at a time and reads the entire file in 16KB chunks. After each chunk is read into memory, it is then processed to break it up into individual packets to increment the packet counts and byte counts for each stream PID.
Getting the payload byte count is essentially a process of boiling away the M2TS packet and stream header overhead to get the raw data bytes for each stream. This is done in a codec-independent manner using the PES headers. Also, increments of the presentation/display time stamps for each stream are located and the stream bitrate is recalculated at each time stamp increment (with the final bitrate for the M2TS stream coming from the last increment). For playlists with multiple M2TS, both the running and final bitrates are calculated by dividing the sum total data payload bytes for each stream across all M2TS divided by the total duration of all the M2TS (or in the case of the running bitrate the total duration of all processed M2TS + the PTS location of the M2TS currently being scanned). You can enable the stream diagnostics checkbox and click the View Report button while the scan is running to get an incremental snapshot of the scan progress for each stream.
All of this is done in a single-threaded manner one M2TS file at a time, although the file I/O is backed by a double-buffer and there is a separate user interface thread with a timer that fires once a second while scanning to update the incremental bitrate display on the screen. Putting in multiple reader threads might work well for scanning a disc layout on the hard-drive, although I suspect would be disastrous when reading from a BD-ROM drive. Also, some care would have to be taken when dividing up a single M2TS into multiple pieces to make sure the cuts are not only along packet boundaries but also at payload start boundaries.
post #399 of 1971 Old 07-03-2008, 09:12 PM
msgohan's Avatar
Interesting info there, Cinema Squid, thanks. You may like to know that BDInfo was added to videohelp.com and digital-digest.com today.
I found something today that I hadn't heard of before: BD region codes can apparently have an expiration option if the distributor chooses.
Source: http://www.freepatentsonline.com/70162711.html
If the fixed-date information exists in the recording medium 10 , the control unit decides whether the limited time corresponding to the region/county designated to the data record/reproduction apparatus 20 has expired based on the fixed-date information (S 44 ). Namely, the recording medium 10 includes a data after which reproduction is permitted regardless of the regional codes in the recording medium 10 and the record/reproduction apparatus 20 match. In this case, the control unit 202 can use a separate date/time secured clock or a Local_date field of PSR20 to decide whether the corresponding limited time included in the fixed-date information read from the recording medium 10 has expired.
In the date/time secured clock, a user or application program is unable to change a date or time. Instead, a date or time of the date/time secured clock can be set/changed based on official time information carried by a broadcast or GPS signal. In case of the Local_date field, it is updated using the official time information. Since the user or application program is unable to change a date or time of the separate secured clock, the control unit 204 can correctly decide whether the corresponding limited time has expired.
If the limited time has expired, the control unit 202 performs the playback according to the user's command even if a match between regional codes in the recording medium 10 and the record/reproduction apparatus 20 does not exist (S 43 ). If the limited time has not expired, the control unit 202 displays a warning message (S 45 ).
msgohan is offline
post #400 of 1971 Old 07-03-2008, 09:21 PM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Thanks for the detailed explanation Cinema Whale.
I will have to read your notes multiple times to get a vague understanding of the disc structure.
Can anyone scan The Descent BD to find out if it's MPEG-2 or MPEG-4 encoded ?
Blu-ray : 340
lgans316 is offline
post #401 of 1971 Old 07-03-2008, 09:46 PM
msgohan's Avatar
I hesitate to post this, but piracy can be used for the power of good sometimes. No, I didn't download it - in fact I can't - but here's an NFO file stating AVC.
The.Descent.2005.BluRay.1080p.DTS.h264.Remux-CtrlHD
General Info
IMDB Link: http://www.imdb.com/title/tt0435625/
Length: 100 minutes
This movie doesn't compress very well because of the grain. A crf18 encode would
be around 15 GB, only 1 GB smaller than the source, so I decided to remux it. The Blu-ray
is 45 GB, so I believe it is appropriate to upload a 16 GB remux.
Technical Specs
Video Encoder.....: h.264 (untouched video)
Video Aspect Ratio: 2.35:1 (1920x1080)
Audio Codec.......: DTS
Audio BitRate.....: 1536 kbit/sec
Audio Channels....: 5.1 channels
Subtitles.........: English, Dutch, Portugese, Spanish and Swedish (thank you Hristoff2)
Remuxed by........: Rabomil
Source............: Blu-ray
File Size.........: 16 GB
msgohan is offline
post #402 of 1971 Old 07-03-2008, 10:01 PM
shadowrage's Avatar
From the looks of that NFO, some converted it to h.264 from something else. Which could be anything?
Not trying to be rude, but this info doesn't look to be too helpful.
h.264 (untouched video) - I'm guessing by this he just means that the video is lossless-ish. Because this thread lists the video size as 20+ gigs.
Ridiculous codec tier sig gone. Still AVC/24bit lossless fanboy.
Studio quality tier
Most Major studios>Small Studios>dogs>cats>Warner(the guys that do new movies)
shadowrage is offline
post #403 of 1971 Old 07-03-2008, 10:13 PM
msgohan's Avatar
Well first of all I didn't even check to see if it was on the list already since lgans was asking for it. Now I'm not sure what he was wanting since it's already listed as AVC... Someone to confirm an MPEG-2 copy rather than posting more AVC scans of it?
The NFO specifically states that he didn't re-encode, but rather remuxed from M2TS to MKV. "Untouched" means just that; the video portion of the file is just copied off of the disc. The "movie size" you're looking at in the list includes the 6Mbps LPCM track, other audio, etc. If you multiply AVBR by the runtime you get 15.75GB for the Unrated cut's video track.
msgohan is offline
post #404 of 1971 Old 07-03-2008, 10:30 PM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
msgohan,
I want you or our buddies with BD Drives to scan through their BD copy of Descent in BDInfo or PowerDVD and check if the Rated and Unrated features are encoded using MPEG-4 and NOT MPEG-2. The copy which I received from amazon day before yesterday is MPEG-2 encoded. Please help.
Blu-ray : 340
lgans316 is offline
post #405 of 1971 Old 07-03-2008, 10:57 PM
msgohan's Avatar
Well benes already has it scanned as Rated AVC/Unrated AVC/PiP MPEG-2 using whatever tools he used to use. That CtrlHD pirate also confirms it as AVC. I might be able to rent it, but it seems like scanning your copy would be the best way to see whether there really is an MPEG-2 disc. I'm sure one of us would be happy to scan it if you sent us the disc. Or I can help you use the PS3 ripper OS I mentioned before.
msgohan is offline
post #406 of 1971 Old 07-03-2008, 11:01 PM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Thanks msg. Few others members have reported similar problem with their copies. Looks like I have been offered a vintage legacy copy.
Blu-ray : 340
lgans316 is offline
post #407 of 1971 Old 07-03-2008, 11:56 PM
madshi's Avatar
Quoted: 2328 Post(s)
Liked: 2993
Originally Posted by Cinema Squid View Post
So if I am unable to easily separate out the AC3 core payload bytes, it looks like I may be able to just subtract them out at the end (assuming I can get the exact same byte sizes as xport).
That should be possible. FWIW I've heard that the AC3 frames have a different DontRememberTheExactThingItWasSomeKindOfID compared to the TrueHD frames in the PES packets. So it should be really easy to separate them.
madshi is offline
post #408 of 1971 Old 07-04-2008, 12:32 AM
Phloyd's Avatar
I have The Decent and can 'take a look' at it over the weekend.
BTW there are only two encodes on the disc - the unrated is seamlessly branched into the normal version of the movie.
Phloyd is offline
post #409 of 1971 Old 07-04-2008, 05:27 AM
Kannisto's Avatar
Night Watch (Fox Japan release) scan:
Code:
        Total   Video
Night Watch (Fox Japan release)                                 AVC     1:54:21 37,754,382,336  43,949,394,764  44.02   32.95   Dolby TrueHD 5.1 3803Kbps (48kHz/24-bit)  DTS 5.1 768Kbps (48kHz/24-bit)
Code:
PLAYLIST REPORT:
Length:         1:54:21 (h:m:s)
Total Bitrate:  44.02 Mbps
Description:
FILES:
00375.M2TS      37,754,382,336  1:54:21.896     0:00:00.000     1:54:21.896
VIDEO:
MPEG-4 AVC Video    32950 kbps      1080p / 23.976fps
AUDIO:
Dolby TrueHD Audio              Russian         3803 kbps       5.1 / 48kHz / 24-bit / 3803kbps (AC3 Core: 5.1 / 48kHz / 448kbps)
DTS Audio                       Russian         768 kbps        5.1 / 48kHz / 24-bit / 768kbps
Dolby Digital Audio             French          448 kbps        5.1 / 48kHz / 448kbps
Dolby Digital Audio             German          448 kbps        5.1 / 48kHz / 448kbps
Dolby Digital Audio             Japanese        448 kbps        5.1 / 48kHz / 448kbps
Dolby Digital Audio             English         224 kbps        2.0 / 48kHz / 224kbps
SUBTITLES:
Presentation Graphics           English         24 kbps
Presentation Graphics           English         27 kbps
Presentation Graphics           English         0 kbps
Presentation Graphics           English         48 kbps
Presentation Graphics           English         37 kbps
Presentation Graphics           Danish          20 kbps
Presentation Graphics           Dutch           19 kbps
Presentation Graphics           Dutch           31 kbps
Presentation Graphics           Dutch           41 kbps
Presentation Graphics           Finnish         16 kbps
Presentation Graphics           French          18 kbps
Presentation Graphics           French          33 kbps
Presentation Graphics           French          42 kbps
Presentation Graphics           German          24 kbps
Presentation Graphics           German          0 kbps
Presentation Graphics           German          37 kbps
Presentation Graphics           German          47 kbps
Presentation Graphics           Japanese        15 kbps
Presentation Graphics           Japanese        0 kbps
Presentation Graphics           Japanese        22 kbps
Presentation Graphics           Japanese        36 kbps
Presentation Graphics           Norwegian       18 kbps
Presentation Graphics           Swedish         19 kbps
CHAPTERS:
Number          Time            Name
1               0:00:00.000     Chapter 1
2               0:04:00.073     Chapter 2
3               0:10:54.028     Chapter 3
4               0:15:49.615     Chapter 4
5               0:19:26.790     Chapter 5
6               0:24:12.868     Chapter 6
7               0:28:15.110     Chapter 7
8               0:33:08.861     Chapter 8
9               0:38:08.160     Chapter 9
10              0:40:01.065     Chapter 10
11              0:43:40.951     Chapter 11
12              0:50:44.458     Chapter 12
13              0:58:33.051     Chapter 13
14              1:04:30.491     Chapter 14
15              1:09:26.996     Chapter 15
16              1:13:34.952     Chapter 16
17              1:24:06.249     Chapter 17
18              1:33:18.259     Chapter 18
19              1:37:39.562     Chapter 19
20              1:47:40.787     Chapter 20
21              1:54:21.646     Chapter 21
STREAM DIAGNOSTICS:
File            PID             Type            Seconds         Bytes           Packets         Bitrate
00375.M2TS      4113 (0x1011)   0x1B            6861.90         28,262,159,014  153,695,821     32949.68
00375.M2TS      4352 (0x1100)   0x83            6861.90         3,646,622,502   26,108,172      4251.45
00375.M2TS      4353 (0x1101)   0x82            6861.90         658,742,272     3,859,818       768.00
00375.M2TS      4354 (0x1102)   0x81            6861.90         384,267,520     2,144,350       448.00
00375.M2TS      4355 (0x1103)   0x81            6861.90         384,267,520     2,144,350       448.00
00375.M2TS      4356 (0x1104)   0x81            6861.90         384,267,520     2,144,350       448.00
00375.M2TS      4357 (0x1105)   0x81            6861.90         384,267,520     2,144,350       448.00
00375.M2TS      4358 (0x1106)   0x81            6861.90         192,133,760     1,072,175       224.00
00375.M2TS      4608 (0x1200)   0x90            6861.90         20,375,112      117,659         23.75
00375.M2TS      4609 (0x1201)   0x90            6861.90         22,739,566      131,099         26.51
00375.M2TS      4610 (0x1202)   0x90            6861.90         36,626          218             0.04
00375.M2TS      4611 (0x1203)   0x90            6861.90         12,557,996      74,927          14.64
00375.M2TS      4612 (0x1204)   0x90            6861.90         80,439          484             0.09
00375.M2TS      4613 (0x1205)   0x90            6861.90         20,313,584      117,093         23.68
00375.M2TS      4614 (0x1206)   0x90            6861.90         112,938         663             0.13
00375.M2TS      4615 (0x1207)   0x90            6861.90         15,866,153      92,927          18.50
00375.M2TS      4616 (0x1208)   0x90            6861.90         56,951          351             0.07
00375.M2TS      4617 (0x1209)   0x90            6861.90         16,456,856      94,523          19.19
00375.M2TS      4618 (0x120A)   0x90            6861.90         13,791,287      80,711          16.08
00375.M2TS      4619 (0x120B)   0x90            6861.90         17,288,553      99,826          20.16
00375.M2TS      4620 (0x120C)   0x90            6861.90         15,981,898      92,477          18.63
00375.M2TS      4621 (0x120D)   0x90            6861.90         15,315,154      89,755          17.86
00375.M2TS      4622 (0x120E)   0x90            6861.90         31,440,656      180,064         36.66
00375.M2TS      4623 (0x120F)   0x90            6861.90         41,351,571      234,068         48.21
00375.M2TS      4624 (0x1210)   0x90            6861.90         19,273,160      110,712         22.47
00375.M2TS      4625 (0x1211)   0x90            6861.90         31,037,968      177,311         36.19
00375.M2TS      4626 (0x1212)   0x90            6861.90         32,030,687      183,069         37.34
00375.M2TS      4627 (0x1213)   0x90            6861.90         39,896,227      226,145         46.51
00375.M2TS      4628 (0x1214)   0x90            6861.90         28,039,898      161,112         32.69
00375.M2TS      4629 (0x1215)   0x90            6861.90         36,113,285      205,457         42.10
00375.M2TS      4630 (0x1216)   0x90            6861.90         26,826,530      153,432         31.28
00375.M2TS      4631 (0x1217)   0x90            6861.90         35,214,190      200,298         41.05
Full scan report including all 43 playlists attached as WinZip'd text file.
Some more info about this and Japanese Day Watch release in:
http://forums.highdefdigest.com/showthread.php?t=59843
NW_JP_scan.zip 10.6494140625k . file
HD DVD: 387 (new: Taking Lives ; list)
Blu-ray: 262 (new: North Face (UK) ; list)
HD DVD-R: 262 (new: Charlie Wilson's War ; list)
Kannisto is offline
post #410 of 1971 Old 07-04-2008, 05:29 AM
Kannisto's Avatar
Day Watch (Fox Japan release) scan:
Code:
        Total   Video
Day Watch (Fox Japan release)                                   AVC     2:25:48 44,533,014,528  46,537,441,336  40.72   29.47   Dolby TrueHD 5.1 3617Kbps (48kHz/24-bit)  DTS 5.1 768Kbps (48kHz/24-bit)
Code:
PLAYLIST REPORT:
Length:         2:25:48 (h:m:s)
Total Bitrate:  40.72 Mbps
Description:
FILES:
00012.M2TS      44,533,014,528  2:25:48.531     0:00:00.000     2:25:48.531
VIDEO:
MPEG-4 AVC Video    29470 kbps      1080p / 23.976fps
AUDIO:
Dolby TrueHD Audio              Russian         3617 kbps       5.1 / 48kHz / 24-bit / 3617kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
DTS Audio                       English         768 kbps        5.1 / 48kHz / 24-bit / 768kbps
DTS Audio                       French          768 kbps        5.1 / 48kHz / 24-bit / 768kbps
DTS Audio                       German          768 kbps        5.1 / 48kHz / 24-bit / 768kbps
SUBTITLES:
Presentation Graphics           English         22 kbps
Presentation Graphics           Dutch           20 kbps
Presentation Graphics           Finnish         22 kbps
Presentation Graphics           French          19 kbps
Presentation Graphics           German          26 kbps
Presentation Graphics           Japanese        13 kbps
Presentation Graphics           Norwegian       22 kbps
Presentation Graphics           Swedish         21 kbps
CHAPTERS:
Number          Time            Name
2               0:05:48.139     Chapter 2
3               0:08:30.218     Chapter 3
4               0:12:35.838     Chapter 4
5               0:17:00.352     Chapter 5
6               0:20:30.270     Chapter 6
7               0:23:24.319     Chapter 7
8               0:26:59.200     Chapter 8
9               0:32:45.797     Chapter 9
10              0:35:15.530     Chapter 10
11              0:38:31.976     Chapter 11
12              0:40:52.450     Chapter 12
13              0:45:38.068     Chapter 13
14              0:49:48.777     Chapter 14
15              0:54:10.622     Chapter 15
16              0:57:15.849     Chapter 16
17              1:00:01.556     Chapter 17
18              1:01:27.141     Chapter 18
19              1:05:13.576     Chapter 19
20              1:06:54.260     Chapter 20
21              1:08:56.715     Chapter 21
22              1:13:09.551     Chapter 22
23              1:16:12.025     Chapter 23
24              1:20:04.591     Chapter 24
25              1:22:50.173     Chapter 25
26              1:28:49.824     Chapter 26
27              1:30:42.770     Chapter 27
28              1:34:49.475     Chapter 28
29              1:39:45.813     Chapter 29
30              1:45:16.476     Chapter 30
31              1:46:56.326     Chapter 31
32              1:50:32.834     Chapter 32
33              1:52:12.934     Chapter 33
34              1:54:37.120     Chapter 34
35              1:57:41.804     Chapter 35
36              2:01:07.009     Chapter 36
37              2:08:46.969     Chapter 37
38              2:10:28.862     Chapter 38
39              2:13:10.065     Chapter 39
40              2:17:02.130     Chapter 40
41              2:25:48.281     Chapter 41
STREAM DIAGNOSTICS:
00012.M2TS      4113 (0x1011)   0x1B            8748.53         32,227,637,156  175,274,521     29470.21
00012.M2TS      4352 (0x1100)   0x83            8748.53         4,654,941,482   32,270,629      4256.66
00012.M2TS      4353 (0x1101)   0x82            8748.53         839,859,200     4,921,050       768.00
00012.M2TS      4354 (0x1102)   0x81            8748.53         489,918,464     2,733,920       448.00
00012.M2TS      4355 (0x1103)   0x82            8748.53         839,859,200     4,921,050       768.00
00012.M2TS      4356 (0x1104)   0x82            8748.53         839,859,200     4,921,050       768.00
00012.M2TS      4357 (0x1105)   0x82            8748.53         839,859,200     4,921,050       768.00
00012.M2TS      4608 (0x1200)   0x90            8748.53         24,136,542      139,456         22.07
00012.M2TS      4609 (0x1201)   0x90            8748.53         29,017,740      167,780         26.53
00012.M2TS      4610 (0x1202)   0x90            8748.53         376,530         2,253           0.34
00012.M2TS      4611 (0x1203)   0x90            8748.53         14,470,200      87,062          13.23
00012.M2TS      4612 (0x1204)   0x90            8748.53         398,985         2,344           0.36
00012.M2TS      4613 (0x1205)   0x90            8748.53         27,951,528      160,261         25.56
00012.M2TS      4614 (0x1206)   0x90            8748.53         389,761         2,319           0.36
00012.M2TS      4615 (0x1207)   0x90            8748.53         20,593,033      120,069         18.83
00012.M2TS      4616 (0x1208)   0x90            8748.53         386,449         2,305           0.35
00012.M2TS      4617 (0x1209)   0x90            8748.53         21,341,687      123,655         19.52
00012.M2TS      4618 (0x120A)   0x90            8748.53         21,721,588      126,211         19.86
00012.M2TS      4619 (0x120B)   0x90            8748.53         24,597,225      141,358         22.49
00012.M2TS      4620 (0x120C)   0x90            8748.53         23,573,155      136,340         21.56
00012.M2TS      4621 (0x120D)   0x90            8748.53         22,648,897      131,092         20.71
Full scan report with all 10 playlists attached as WinZip'd text file.
DW_JP_scan.zip 3.6484375k . file
Kannisto is offline
post #411 of 1971 Old 07-04-2008, 07:50 AM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Wow Kannisto, glad to see you are going to contribute to this thread. I bet you have alot of discs that we don't have since we are primarily in the USA.
Back to the topic, I wonder why Fox is switching to TrueHD?? Right after we get the update to decode it in our PS3's...
post #412 of 1971 Old 07-04-2008, 10:01 AM
August Rush - Dolby TrueHD (lossless compression) 16-bit/48kHz
Code:
        Total   Video
August Rush                                                     VC-1    1:53:37 20,365,344,768  20,891,356,894  23.90   18.16   Dolby TrueHD 5.1 1611Kbps (48kHz/16-bit)
Code:
PLAYLIST REPORT:
Length:         1:53:37 (h:m:s)
Total Bitrate:  23.90 Mbps
Description:
FILES:
00000.M2TS      20,365,344,768  1:53:37.519     0:00:00.000     1:53:37.519
VIDEO:
VC-1 Video          18155 kbps      1080p / 23.976fps
AUDIO:
Dolby TrueHD Audio              English         1611 kbps       5.1 / 48kHz / 16-bit / 1611kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             French          640 kbps        5.1 / 48kHz / 640kbps
SUBTITLES:
Presentation Graphics           English         20 kbps
Presentation Graphics           English         29 kbps
Presentation Graphics           Spanish         20 kbps
post #413 of 1971 Old 07-04-2008, 10:03 AM
Flatliners - LPCM (uncompressed) 16-bit/48kHz
Code:
        Total   Video
Flatliners                                                      MPEG-2  1:54:12 23,380,494,336  24,166,104,276  27.29   19.45   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
PLAYLIST REPORT:
Length:         1:54:12 (h:m:s)
Total Bitrate:  27.29 Mbps
Description:
FILES:
00000.M2TS      23,380,494,336  1:54:12.846     0:00:00.000     1:54:12.846
VIDEO:
MPEG-2 Video        19446 kbps      1080p / 23.976fps
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48kHz / 16-bit / 4608kbps
Dolby Digital Audio             English         640 kbps        5.1 / 48kHz / 640kbps
SUBTITLES:
Presentation Graphics           English         35 kbps
Presentation Graphics           Arabic          12 kbps
Presentation Graphics           Bulgarian       22 kbps
Presentation Graphics           Croatian        20 kbps
Presentation Graphics           Czech           19 kbps
Presentation Graphics           Dutch           21 kbps
Presentation Graphics           Finnish         21 kbps
Presentation Graphics           French          21 kbps
Presentation Graphics           Greek           21 kbps
Presentation Graphics           Hebrew          16 kbps
Presentation Graphics           Hindi           22 kbps
Presentation Graphics           Hungarian       20 kbps
Presentation Graphics           Icelandic       22 kbps
Presentation Graphics           Korean          17 kbps
Presentation Graphics           Norwegian       20 kbps
Presentation Graphics           Polish          21 kbps
Presentation Graphics           Romanian        22 kbps
Presentation Graphics           Slovenian       19 kbps
Presentation Graphics           Swedish         20 kbps
Presentation Graphics           Turkish         20 kbps
post #414 of 1971 Old 07-04-2008, 05:40 PM
Kannisto's Avatar
Thanks! lgans316 introduced me to this thread and asked if I could scan these releases and post the data here I had not been following this thread before yesterday.
I do have some Japanese, Korean and Hong Kong BD releases and some European imports and I'm always after the most interesting new ones so I can start to contribute more especially when I get something new and fresh
Yeah, I'm actually not so happy that Fox is switching to TrueHD as I enjoy the quality of the DTS core tracks on my optical output based somewhat limited audio setup.
Kannisto is offline
post #415 of 1971 Old 07-04-2008, 06:06 PM
PeterTHX's Avatar
Quoted: 568 Post(s)
Liked: 427
Sorry, but 640k DD > DTS @1536 (for those of you about to jump on this STOP COMPARING THE 448kbps DVD DD tracks! I'm talking about DD at full bitrate!)
Second: those of us in apartments appreciate TrueHD's (& DD's) dynamic range control aka night mode. Clear lossless sound without the neighbors petitioning for your eviction.
Third: TrueHD tracks have no pops from pause nor pops that can damage certain setups (despite the DSP firmware fixes, there's thousands of people unaware that there are fixes and are in danger of damage).
Fourth: No encoding screwups like on Die Hard 2 or 7.1 issues with numerous New Line discs.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #416 of 1971 Old 07-04-2008, 08:00 PM
Phloyd's Avatar
Peter,
I would like some evidence that 640kbps DD is better than DTS at over twice the bitrate, especially since DTS maintains lossless where it can at that bitrate.
I am not saying it is not true, but I find it hard to believe myself and all I ever seem to see you doing anywhere is bashing DTS... so please provide some evidence to back up your claims.
Back to purpose - The Descent is measuring as AVC for the main encode and MPEG2 for the alternate picture in picture version, just as Benes' list indicates.
I will post the full reports later.
The difference between the main and alternate looks to be minimal since it is a branch for an alternate ending so I will probably not scan that version unless there is specific interest. It is of course also AVC.
Phloyd is offline
post #417 of 1971 Old 07-04-2008, 08:10 PM
Phloyd's Avatar
The Descent - LPCM 6.1 (encoded as 7.1) 6144Kbps (48kHz/16-bit)
Code:
        Total   Video
The Descent                                                     AVC     1:39:50 23,020,302,336  48,362,529,368  30.74   21.56   LPCM 7.1 6144Kbps (48kHz/16-bit)          DD AC3 5.1-EX 640Kbps
Code:
PLAYLIST REPORT:
Length:         1:39:50 (h:m:s)
Total Bitrate:  30.74 Mbps
Description:
FILES:
00002.M2TS      21,667,233,792  1:33:55.254     0:00:00.000     1:33:55.254
00024.M2TS      1,353,068,544   0:05:55.730     1:33:55.254     1:39:50.984
VIDEO:
MPEG-4 AVC Video    21559 kbps      1080p / 23.976fps
AUDIO:
LPCM Audio                      English         6144 kbps       7.1 / 48kHz / 16-bit / 6144kbps
SUBTITLES:
Presentation Graphics           English         18 kbps
Presentation Graphics           Spanish         17 kbps
CHAPTERS:
Number          Time            Name
2               0:08:10.031     Chapter 2
3               0:14:22.111     Chapter 3
4               0:21:33.625     Chapter 4
5               0:28:50.270     Chapter 5
6               0:39:38.959     Chapter 6
7               0:45:24.012     Chapter 7
8               0:54:25.011     Chapter 8
9               0:58:23.249     Chapter 9
10              1:05:17.330     Chapter 10
11              1:10:16.086     Chapter 11
12              1:16:57.654     Chapter 12
13              1:20:17.979     Chapter 13
14              1:25:00.970     Chapter 14
15              1:29:05.465     Chapter 15
16              1:31:46.459     Chapter 16
17              1:39:50.734     Chapter 17
Phloyd is offline
post #418 of 1971 Old 07-04-2008, 08:13 PM
Phloyd's Avatar
The Descent PiP - DD AC3 2.0 224Kbps
Code:
        Total   Video
The Descent PiP                                                 MPEG-2  1:39:50 12,668,018,688  48,362,529,368  16.92   15.91   DD AC3 2.0 224Kbps
Code:
PLAYLIST REPORT:
Total Bitrate:  16.92 Mbps
Description:
FILES:
00020.M2TS      12,668,018,688  1:39:50.985     0:00:00.000     1:39:50.985
VIDEO:
MPEG-2 Video        15911 kbps      1080p / 23.976fps
AUDIO:
CHAPTERS:
Number          Time            Name
Phloyd is offline
post #419 of 1971 Old 07-04-2008, 08:16 PM
Phloyd's Avatar
The Descent Alternate - LPCM 6.1 (encoded as 7.1) 6144Kbps (48kHz/16-bit)
Code:
        Total   Video
The Descent Alternate                                           AVC     1:38:35 22,579,138,560  48,362,529,368  30.53   21.36   LPCM 7.1 6144Kbps (48kHz/16-bit)          DD AC3 5.1-EX 640Kbps
Code:
PLAYLIST REPORT:
Length:         1:38:35 (h:m:s)
Total Bitrate:  30.53 Mbps
Description:
FILES:
00025.M2TS      911,904,768     0:04:40.655     1:33:55.254     1:38:35.909
VIDEO:
MPEG-4 AVC Video    21360 kbps      1080p / 23.976fps
AUDIO:
SUBTITLES:
Presentation Graphics           Spanish         18 kbps
CHAPTERS:
Number          Time            Name
17              1:38:35.659     Chapter 17
For completeness... scanned with version 0.3.1
Phloyd is offline
post #420 of 1971 Old 07-04-2008, 08:17 PM
PeterTHX's Avatar
Quoted: 568 Post(s)
Liked: 427
Two can play this game.
Please provide evidence that it is NOT, on the exact same movies, same mixes, level matched.
To put it in video terms: MPEG4 vs MPEG2, I guess MPEG2 is better since it requires a higher bitrate?
When are you guys going to get it that DD is more efficient than DTS, there is no roll off of higher frequencies (starting @ 17kHz) for DD @448 like there is for DTS @768. If DTS was TRULY better it would sound BETTER than DD at lower bitrates!
As for "bashing": there's a "find more posts by..." option here. You will find VERY little "bashing" by me other than when DTS fanboys come out of the woodwork and spread FUD about DD or TrueHD.
PeterTHX is offline
Closed Thread Blu-ray Software
