Unofficial Blu-ray Audio and Video Specifications Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 1971 Old 08-18-2008, 05:05 PM
Cinema Squid's Avatar
Originally Posted by msgohan View Post
Cinema Squid, see what I mean about I-frames not always being the largest?
Yeah, it seems when I try to make a definitive statement about Blu-ray video and audio tech, I usually get something wrong!
At first, it seemed very counterintuitive to me that the largest frame would be a predictive frame implying that it is larger than the key frame of its sequence. However, I could see how this would happen if the motion prediction is not yielding much benefit (ex. the I -> P sequence crosses a video cut) and the predictive frame's spatial complexity is higher than the key frame.
Looking at those video frame graphs, I think I need to work on their layout a bit (BI frames are a disaster with overlapping text). I'll try moving that info to a legend in the bar charts instead to see if that helps. I can also try alternating the pie chart so it goes I -> P -> BI -> B to avoid the label overlap by alternating big/small slices.
I had also planned on changing the timescale unit of the bitrate graphs from seconds to minutes which I think will make them more readable.
Cinema Squid is offline
post #632 of 1971 Old 08-18-2008, 07:23 PM
msgohan's Avatar
"Optimum" should be listed under "DTS-HD Master Audio (lossless compression) 16-bit/48kHz" by the way, benes. And the Traffic BD with DTS-HD HR is "Splendid Film". And I spotted the UK Seventh Seal under "Dolby Digital AC3 (lossy compression)", that's Tartan Video.
Region AB, same menu layout.
Code:
        Total   Video
(UK) Rambo: First Blood Part II                                 VC-1    1:35:55 20,505,513,984  23,373,405,514  28.50   17.01   DTS-HD Master 5.1 2111Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     RAMBO2
Disc Size:      23,373,405,514 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:35:55 (h:m:s)
Total Bitrate:  28.50 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00104.M2TS      20,505,513,984  1:35:55.708     0:00:00.000     1:35:55.708
VIDEO:
Codec               Bitrate         Description
VC-1 Video          17014 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         2111 kbps       5.1 / 48kHz / 16-bit / 2111kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
DTS-HD Audio                    French          2046 kbps       5.1 / 48kHz / 16-bit / 2046kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
DTS-HD Audio                    German          2046 kbps       5.1 / 48kHz / 16-bit / 2046kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
DTS Audio                       Portuguese      1536 kbps       2.0 / 48kHz / 16-bit / 1536kbps
DTS Audio                       Spanish         1536 kbps       2.0 / 48kHz / 16-bit / 1536kbps
SUBTITLES:
Presentation Graphics           English         13.318 kbps
Presentation Graphics           Danish          12.378 kbps
Presentation Graphics           Dutch           11.828 kbps
Presentation Graphics           Finnish         13.495 kbps
Presentation Graphics           French          11.823 kbps
Presentation Graphics           German          14.990 kbps
Presentation Graphics           Norwegian       12.149 kbps
Presentation Graphics           Portuguese      17.392 kbps
Presentation Graphics           Spanish         15.625 kbps
Presentation Graphics           Spanish         16.741 kbps
Presentation Graphics           Swedish         12.390 kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:05:36.545     16,045 kbps     32,817 kbps     00:03:52.983    24,931 kbps     00:04:02.576    21,303 kbps     00:04:01.074    83,652 bytes    683,110 bytes   00:00:20.062
2               0:05:36.545     0:08:23.294     16,082 kbps     30,424 kbps     00:09:28.860    23,593 kbps     00:09:25.231    21,004 kbps     00:09:20.226    83,843 bytes    350,362 bytes   00:11:11.671
3               0:13:59.839     0:08:02.482     15,077 kbps     30,819 kbps     00:18:05.042    19,941 kbps     00:20:38.904    17,930 kbps     00:20:34.525    78,603 bytes    672,738 bytes   00:16:04.714
4               0:22:02.321     0:07:12.057     16,320 kbps     26,911 kbps     00:23:18.606    21,973 kbps     00:23:16.270    20,838 kbps     00:23:11.015    85,082 bytes    310,318 bytes   00:29:00.989
5               0:29:14.378     0:06:08.576     15,854 kbps     26,878 kbps     00:29:33.647    24,608 kbps     00:30:25.574    22,475 kbps     00:30:23.238    82,653 bytes    318,763 bytes   00:33:30.175
6               0:35:22.954     0:09:58.181     18,361 kbps     34,750 kbps     00:39:23.278    24,912 kbps     00:39:30.535    23,523 kbps     00:39:27.657    95,728 bytes    493,409 bytes   00:42:44.187
7               0:45:21.135     0:07:25.862     17,273 kbps     33,727 kbps     00:45:42.865    22,812 kbps     00:48:50.386    20,986 kbps     00:48:50.386    90,053 bytes    441,439 bytes   00:45:42.990
8               0:52:46.997     0:10:26.209     15,710 kbps     30,909 kbps     00:54:55.250    22,308 kbps     01:02:11.186    19,573 kbps     01:02:05.180    81,903 bytes    309,615 bytes   01:03:13.164
9               1:03:13.206     0:08:46.318     17,603 kbps     31,221 kbps     01:11:42.757    23,248 kbps     01:10:25.513    21,172 kbps     01:11:22.403    91,772 bytes    388,201 bytes   01:11:42.965
10              1:11:59.524     0:06:36.604     19,834 kbps     34,929 kbps     01:16:45.142    24,843 kbps     01:13:27.028    23,421 kbps     01:12:09.325    103,407 bytes   436,884 bytes   01:12:35.101
11              1:18:36.128     0:07:52.889     19,508 kbps     33,728 kbps     01:19:06.283    24,210 kbps     01:22:35.701    23,218 kbps     01:19:46.490    101,708 bytes   431,294 bytes   01:18:46.513
12              1:26:29.017     0:09:26.691     16,566 kbps     33,019 kbps     01:28:00.233    24,762 kbps     01:28:16.166    23,179 kbps     01:28:00.400    86,368 bytes    422,851 bytes   01:33:05.830
STREAM DIAGNOSTICS:
File            PID             Type            Codec           Lang. Code      Lang. Name      Seconds         Bytes           Packets         Bitrate
00104.M2TS      4113 (0x1011)   0xEA            VC-1                                            5755.71         12,241,002,004  66,610,500      17,014
00104.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         5755.71         1,519,109,308   9,151,805       2,111
00104.M2TS      4353 (0x1101)   0x82            DTS             por             Portuguese      5755.71         1,085,671,176   6,475,176       1,509
00104.M2TS      4354 (0x1102)   0x85            DTS-HD HR       deu             German          5755.71         1,472,023,344   8,633,568       2,046
00104.M2TS      4355 (0x1103)   0x82            DTS             spa             Spanish         5755.71         1,085,671,176   6,475,176       1,509
00104.M2TS      4356 (0x1104)   0x85            DTS-HD HR       fra             French          5755.71         1,472,023,344   8,633,568       2,046
00104.M2TS      4608 (0x1200)   0x90            PGS             eng             English         5755.71         9,582,169       54,869          13
00104.M2TS      4609 (0x1201)   0x90            PGS             por             Portuguese      5755.71         12,512,643      71,784          17
00104.M2TS      4610 (0x1202)   0x90            PGS             dan             Danish          5755.71         8,905,289       50,750          12
00104.M2TS      4611 (0x1203)   0x90            PGS             deu             German          5755.71         10,784,454      61,480          15
00104.M2TS      4612 (0x1204)   0x90            PGS             spa             Spanish         5755.71         11,241,821      64,391          16
00104.M2TS      4613 (0x1205)   0x90            PGS             fra             French          5755.71         8,505,908       49,196          12
00104.M2TS      4614 (0x1206)   0x90            PGS             spa             Spanish         5755.71         12,044,631      69,377          17
00104.M2TS      4615 (0x1207)   0x90            PGS             nld             Dutch           5755.71         8,509,597       49,095          12
00104.M2TS      4616 (0x1208)   0x90            PGS             nor             Norwegian       5755.71         8,740,784       49,867          12
00104.M2TS      4617 (0x1209)   0x90            PGS             fin             Finnish         5755.71         9,708,840       55,258          13
00104.M2TS      4618 (0x120A)   0x90            PGS             swe             Swedish         5755.71         8,914,103       50,837          12
Full specs for USA Lionsgate Blu-ray:
Code:
        Total   Video
Rambo: First Blood Part II                                      VC-1    1:35:58 21,325,658,112  24,359,135,536  29.63   21.97   DTS-HD Master 5.1 4233Kbps (48kHz/24-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     RAMBO_II
Disc Size:      24,359,135,536 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:35:58 (h:m:s)
Total Bitrate:  29.63 Mbps
Description:
FILES:
00002.M2TS      21,325,658,112  1:35:58.794     0:00:00.000     1:35:58.794
VIDEO:
VC-1 Video          21974 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         4233 kbps       5.1 / 48kHz / 24-bit / 4233kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
Dolby Digital Audio             English         640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Audio             French          640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         16.159 kbps
Presentation Graphics           English         236.400 kbps
Presentation Graphics           Spanish         16.580 kbps
CHAPTERS:
1               0:00:00.000     0:05:39.047     20,362 kbps     56,100 kbps     00:00:02.544    33,375 kbps     00:01:18.787    32,752 kbps     00:01:12.573    106,156 bytes   517,317 bytes   00:00:03.545
2               0:05:39.047     0:05:20.654     18,538 kbps     33,238 kbps     00:09:31.279    30,827 kbps     00:09:27.275    28,239 kbps     00:09:25.440    96,651 bytes    329,308 bytes   00:09:31.738
3               0:10:59.701     0:06:40.608     20,504 kbps     34,233 kbps     00:13:16.295    25,660 kbps     00:16:34.410    24,543 kbps     00:16:29.447    106,899 bytes   494,367 bytes   00:15:37.728
4               0:17:40.309     0:04:23.931     18,455 kbps     33,924 kbps     00:18:50.963    25,364 kbps     00:20:42.533    22,859 kbps     00:19:15.738    96,214 bytes    372,524 bytes   00:20:45.661
5               0:22:04.240     0:04:46.411     17,090 kbps     38,823 kbps     00:23:22.276    30,061 kbps     00:22:08.327    25,663 kbps     00:22:04.323    89,099 bytes    352,581 bytes   00:22:11.288
6               0:26:50.651     0:08:34.180     18,453 kbps     30,738 kbps     00:33:23.043    25,171 kbps     00:29:37.109    23,623 kbps     00:29:32.187    96,203 bytes    466,037 bytes   00:30:45.302
7               0:35:24.831     0:06:18.962     23,523 kbps     43,262 kbps     00:39:25.321    35,136 kbps     00:40:32.430    31,659 kbps     00:39:25.154    122,641 bytes   479,385 bytes   00:41:15.306
8               0:41:43.793     0:06:13.832     24,617 kbps     50,170 kbps     00:42:41.559    37,162 kbps     00:43:13.132    33,529 kbps     00:43:22.892    128,343 bytes   538,622 bytes   00:45:44.992
9               0:47:57.625     0:04:51.624     21,074 kbps     37,950 kbps     00:48:14.850    34,089 kbps     00:48:13.641    33,087 kbps     00:48:54.348    109,869 bytes   463,062 bytes   00:48:15.184
10              0:52:49.249     0:06:33.101     18,451 kbps     33,736 kbps     00:53:30.499    26,026 kbps     00:54:50.537    25,189 kbps     00:54:50.287    96,193 bytes    533,660 bytes   00:54:57.419
11              0:59:22.350     0:07:32.119     20,878 kbps     35,249 kbps     01:03:10.328    26,668 kbps     01:01:01.449    25,199 kbps     01:02:00.508    108,848 bytes   343,666 bytes   01:05:25.880
12              1:06:54.469     0:08:56.577     25,092 kbps     44,621 kbps     01:13:46.172    37,162 kbps     01:14:35.554    34,515 kbps     01:12:59.333    130,820 bytes   506,220 bytes   01:12:35.226
13              1:15:51.046     0:04:45.744     26,520 kbps     50,004 kbps     01:16:37.885    36,659 kbps     01:19:52.413    35,521 kbps     01:19:48.492    138,266 bytes   587,586 bytes   01:19:53.247
14              1:20:36.790     0:05:30.831     29,940 kbps     44,761 kbps     01:23:23.749    36,639 kbps     01:21:25.214    35,199 kbps     01:23:55.989    156,096 bytes   505,179 bytes   01:23:56.448
15              1:26:07.621     0:06:29.430     27,130 kbps     42,977 kbps     01:27:50.182    37,701 kbps     01:27:50.098    35,670 kbps     01:28:19.920    141,441 bytes   425,644 bytes   01:30:35.972
16              1:32:37.051     0:03:21.744     18,643 kbps     27,050 kbps     01:33:08.792    23,604 kbps     01:34:49.017    23,203 kbps     01:34:48.016    97,197 bytes    322,484 bytes   01:34:49.225
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0xEA            VC-1                                            5758.79         15,817,921,370  86,050,286      21,974
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         5758.79         3,046,813,064   17,456,532      4,233
00002.M2TS      4353 (0x1101)   0x81            AC3             fra             French          5758.79         460,705,280     2,699,445       640
00002.M2TS      4354 (0x1102)   0x81            AC3             eng             English         5758.79         460,705,280     2,699,445       640
00002.M2TS      4608 (0x1200)   0x90            PGS             eng             English         5758.79         11,631,789      66,858          16
00002.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         5758.79         11,935,198      68,679          17
00002.M2TS      4610 (0x1202)   0x90            PGS             eng             English         5758.79         170,172,207     937,114         236
00002.M2TS      4355 (0x1103)   0x81            AC3             eng             English         5758.79         138,211,584     899,815         192
The bitrate graphs are actually very similar, and they appear to be peaking around the same frames judging from the chapter timecodes. I'm going to update the First Blood post above with the graphs in half an hour too.
StudioCanal HD DVD:
Code:
(EU) Rambo: First Blood Part II         VC-1    1:35:50 16,294,049,792*~17,071,625,621  22.66   17.03   DTS-HD Master Audio 5.1 No
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #633 of 1971 Old 08-18-2008, 08:02 PM
Code:
        Total   Video
Top Gun                                                         AVC     1:49:35 36,207,679,488  48,576,730,665  44.05   29.93   DTS-HD Master 6.1 4930Kbps (48kHz/24-bit) Dolby TrueHD 5.1 3596Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TOP_GUN
Disc Size:      48,576,730,665 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         1:49:35 (h:m:s)
Total Bitrate:  44.05 Mbps
Description:
FILES:
00001.M2TS      36,207,679,488  1:49:35.569     0:00:00.000     1:49:35.569
VIDEO:
MPEG-4 AVC Video    29934 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4930 kbps       6.1 / 48kHz / 24-bit / 4930kbps (DTS-ES Core: 5.1-ES / 48kHz / 24-bit / 1536kbps)
Dolby TrueHD Audio              English         3596 kbps       5.1 / 48kHz / 24-bit / 3596kbps (AC3-EX Core: 5.1-EX / 48kHz / 640kbps)
Dolby Digital EX Audio          French          640 kbps        5.1-EX / 48kHz / 640kbps
Dolby Digital EX Audio          Spanish         640 kbps        5.1-EX / 48kHz / 640kbps
SUBTITLES:
Presentation Graphics           English         35.455 kbps
Presentation Graphics           English         38.084 kbps
Presentation Graphics           French          27.162 kbps
Presentation Graphics           Portuguese      26.663 kbps
Presentation Graphics           Spanish         32.947 kbps
CHAPTERS:
1               0:00:00.000     0:02:40.369     28,625 kbps     45,100 kbps     00:00:16.350    31,892 kbps     00:00:57.975    30,170 kbps     00:00:57.975    149,239 bytes   672,385 bytes   00:00:03.378
2               0:02:40.369     0:10:05.062     30,314 kbps     41,331 kbps     00:05:56.982    33,613 kbps     00:08:12.283    32,741 kbps     00:07:44.089    158,045 bytes   538,655 bytes   00:07:16.853
3               0:12:45.431     0:06:18.337     30,016 kbps     38,262 kbps     00:15:33.933    32,559 kbps     00:18:45.583    32,119 kbps     00:18:45.291    156,491 bytes   516,103 bytes   00:13:57.628
4               0:19:03.768     0:06:36.729     29,998 kbps     36,644 kbps     00:22:33.477    32,951 kbps     00:22:45.239    32,040 kbps     00:22:52.454    156,396 bytes   520,722 bytes   00:25:40.539
5               0:25:40.497     0:03:46.018     29,602 kbps     35,966 kbps     00:26:00.225    31,936 kbps     00:25:56.513    30,806 kbps     00:25:41.290    154,332 bytes   554,467 bytes   00:25:45.544
6               0:29:26.515     0:09:40.955     30,041 kbps     43,190 kbps     00:32:25.485    34,920 kbps     00:31:57.749    33,004 kbps     00:30:35.625    156,622 bytes   555,711 bytes   00:36:54.671
7               0:39:07.470     0:08:52.073     29,927 kbps     38,455 kbps     00:41:54.929    31,509 kbps     00:43:07.001    30,770 kbps     00:41:54.929    156,025 bytes   644,791 bytes   00:47:50.159
8               0:47:59.543     0:07:23.568     29,937 kbps     40,321 kbps     00:52:59.468    34,228 kbps     00:52:58.926    32,701 kbps     00:52:58.592    156,078 bytes   616,711 bytes   00:51:12.861
9               0:55:23.111     0:06:04.740     30,165 kbps     41,335 kbps     00:58:51.486    33,828 kbps     00:56:32.180    32,277 kbps     00:56:47.487    157,267 bytes   512,255 bytes   01:00:50.438
10              1:01:27.851     0:02:31.735     29,752 kbps     35,638 kbps     01:02:15.023    31,080 kbps     01:01:37.736    30,532 kbps     01:02:30.205    155,113 bytes   514,098 bytes   01:01:55.253
11              1:03:59.586     0:09:38.453     29,898 kbps     44,361 kbps     01:08:28.771    35,171 kbps     01:07:05.271    32,561 kbps     01:07:05.605    155,874 bytes   570,876 bytes   01:11:23.654
12              1:13:38.039     0:07:31.868     29,706 kbps     44,503 kbps     01:15:12.550    32,284 kbps     01:15:12.550    31,460 kbps     01:15:12.550    154,872 bytes   526,918 bytes   01:16:27.583
13              1:21:09.907     0:05:55.063     29,873 kbps     36,220 kbps     01:25:22.284    32,046 kbps     01:25:40.218    31,354 kbps     01:26:29.017    155,745 bytes   602,456 bytes   01:24:44.830
14              1:27:04.970     0:07:14.100     29,999 kbps     44,068 kbps     01:28:40.148    33,358 kbps     01:28:33.517    32,155 kbps     01:31:14.260    156,402 bytes   553,565 bytes   01:30:54.407
15              1:34:19.070     0:07:39.793     29,924 kbps     43,129 kbps     01:34:59.485    34,832 kbps     01:39:06.315    32,367 kbps     01:36:57.812    156,010 bytes   553,424 bytes   01:39:07.984
16              1:41:58.863     0:07:36.706     29,942 kbps     43,084 kbps     01:49:19.011    33,037 kbps     01:44:38.981    32,080 kbps     01:46:40.686    156,105 bytes   735,737 bytes   01:49:22.389
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                             6575.57         24,604,018,680  133,810,380     29,934
00001.M2TS      4352 (0x1100)   0x83            TrueHD          eng             English         6575.57         3,481,951,626   23,551,649      4,236
00001.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng             English         6575.57         4,051,887,760   23,047,308      4,930
00001.M2TS      4354 (0x1102)   0x81            AC3-EX          fra             French          6575.57         526,046,720     3,082,305       640
00001.M2TS      4355 (0x1103)   0x81            AC3-EX          spa             Spanish         6575.57         526,046,720     3,082,305       640
00001.M2TS      4356 (0x1104)   0x81            AC3             eng             English         6575.57         157,814,016     1,027,435       192
00001.M2TS      4608 (0x1200)   0x90            PGS             eng             English         6575.57         29,141,950      167,472         35
00001.M2TS      4609 (0x1201)   0x90            PGS             eng             English         6575.57         31,302,699      179,911         38
00001.M2TS      4610 (0x1202)   0x90            PGS             fra             French          6575.57         22,326,066      129,367         27
00001.M2TS      4611 (0x1203)   0x90            PGS             spa             Spanish         6575.57         27,080,409      156,083         33
00001.M2TS      4612 (0x1204)   0x90            PGS             por             Portuguese      6575.57         21,915,941      127,146         27
Just to be thorough for the TrueHD:
Code:
[a03] This audio track has a constant bit depth of 24 bits.
post #634 of 1971 Old 08-18-2008, 09:17 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Spider-man
Code:
[a03] Creating file "spider-man.flac"...
[a03] Bitdepth analyzation: max 24 bits, average 16 bits, most common 16 bits.
Resident Evil
Code:
[a03] Creating file "residentevil.flac"...
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #635 of 1971 Old 08-19-2008, 04:17 AM
House's Avatar
Transformers...
Code:
        Total   Video
Transformers                                                    AVC     2:23:27 44,482,652,160  45,753,719,301  41.34   31.43   Dolby TrueHD 5.1 3659Kbps (48kHz/24-bit)  DD AC3+ 2.0 192Kbps
Code:
DISC INFO:
Disc Title:     TRANSFORMERS_D1
Disc Size:      45,753,719,301 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         2:23:27 (h:m:s)
Total Bitrate:  41.34 Mbps
Description:
FILES:
00010.M2TS      44,482,652,160  2:23:27.307     0:00:00.000     2:23:27.307
VIDEO:
MPEG-4 AVC Video    31427 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video    690 kbps        480p / 23.976fps / 16:9 / High Profile 3.2
AUDIO:
Dolby TrueHD Audio              English         3659 kbps       5.1 / 48kHz / 24-bit / 3659kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Plus Audio        English         192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         41.731 kbps
Presentation Graphics           English         45.510 kbps
Presentation Graphics           English         20.771 kbps
Presentation Graphics           French          38.568 kbps
Presentation Graphics           French          0.382 kbps
Presentation Graphics           Portuguese      31.887 kbps
Presentation Graphics           Spanish         32.083 kbps
Presentation Graphics           Spanish         0.399 kbps
CHAPTERS:
1               0:00:00.000     0:02:04.708     26,779 kbps     38,469 kbps     00:00:33.450    35,378 kbps     00:01:12.739    35,164 kbps     00:01:07.693    139,614 bytes   561,785 bytes   00:00:40.082
2               0:02:04.708     0:06:49.826     33,156 kbps     45,809 kbps     00:07:54.140    35,705 kbps     00:06:02.112    35,130 kbps     00:05:57.274    172,863 bytes   551,935 bytes   00:07:55.100
3               0:08:54.534     0:06:39.107     31,597 kbps     37,980 kbps     00:13:15.920    35,281 kbps     00:11:46.706    35,041 kbps     00:13:15.503    164,733 bytes   603,282 bytes   00:13:38.443
4               0:15:33.641     0:06:47.741     31,817 kbps     38,168 kbps     00:19:00.222    35,287 kbps     00:20:29.603    35,044 kbps     00:15:59.292    165,880 bytes   631,204 bytes   00:18:20.182
5               0:22:21.382     0:05:21.279     31,387 kbps     37,643 kbps     00:24:42.606    35,222 kbps     00:22:55.291    35,018 kbps     00:22:51.829    163,637 bytes   562,753 bytes   00:22:23.801
6               0:27:42.661     0:05:42.717     32,050 kbps     38,719 kbps     00:31:52.035    35,254 kbps     00:30:49.806    35,085 kbps     00:29:47.661    167,095 bytes   534,701 bytes   00:27:44.705
7               0:33:25.378     0:05:32.624     31,036 kbps     37,856 kbps     00:36:03.244    35,203 kbps     00:35:05.395    34,935 kbps     00:35:12.110    161,806 bytes   528,644 bytes   00:37:00.176
8               0:38:58.002     0:06:15.918     31,973 kbps     39,935 kbps     00:42:59.827    35,480 kbps     00:44:44.724    35,069 kbps     00:41:47.422    166,694 bytes   572,494 bytes   00:44:49.687
9               0:45:13.920     0:06:32.517     31,650 kbps     38,272 kbps     00:50:44.792    35,485 kbps     00:50:40.704    34,950 kbps     00:46:43.050    165,010 bytes   570,222 bytes   00:48:16.227
10              0:51:46.437     0:06:58.251     31,727 kbps     40,555 kbps     00:52:10.044    35,480 kbps     00:53:57.109    35,051 kbps     00:54:41.778    165,409 bytes   460,339 bytes   00:54:49.036
11              0:58:44.688     0:08:03.733     31,890 kbps     39,128 kbps     00:58:51.153    35,309 kbps     01:00:31.962    35,039 kbps     01:00:15.612    166,258 bytes   508,239 bytes   01:03:02.612
12              1:06:48.421     0:05:05.138     31,213 kbps     37,428 kbps     01:06:50.381    35,309 kbps     01:06:48.421    34,999 kbps     01:11:24.071    162,731 bytes   533,981 bytes   01:10:59.672
13              1:11:53.559     0:05:02.886     31,439 kbps     38,244 kbps     01:14:00.311    35,299 kbps     01:13:40.291    35,027 kbps     01:14:56.367    163,908 bytes   491,228 bytes   01:12:47.863
14              1:16:56.445     0:06:40.901     31,644 kbps     37,999 kbps     01:19:46.824    35,255 kbps     01:17:53.335    35,056 kbps     01:16:58.948    164,976 bytes   444,264 bytes   01:19:36.563
15              1:23:37.346     0:05:26.826     31,943 kbps     39,873 kbps     01:27:52.642    35,289 kbps     01:28:17.125    34,903 kbps     01:25:56.485    166,534 bytes   439,780 bytes   01:24:32.776
16              1:29:04.172     0:07:24.569     31,420 kbps     37,995 kbps     01:30:36.264    35,280 kbps     01:30:32.010    35,105 kbps     01:30:27.339    163,807 bytes   582,369 bytes   01:35:04.407
17              1:36:28.741     0:07:29.366     31,722 kbps     39,477 kbps     01:42:49.121    35,428 kbps     01:38:32.323    35,021 kbps     01:38:27.401    165,382 bytes   569,775 bytes   01:36:29.784
18              1:43:58.107     0:05:47.639     31,533 kbps     38,120 kbps     01:44:39.356    35,388 kbps     01:46:07.403    34,692 kbps     01:46:37.933    164,398 bytes   564,541 bytes   01:48:26.208
19              1:49:45.746     0:07:08.261     31,697 kbps     41,719 kbps     01:49:57.382    35,626 kbps     01:54:55.680    35,121 kbps     01:54:50.717    165,253 bytes   509,978 bytes   01:53:13.412
20              1:56:54.007     0:06:15.875     31,637 kbps     39,547 kbps     01:57:33.338    35,734 kbps     01:57:29.251    34,864 kbps     02:02:34.389    164,942 bytes   521,315 bytes   02:02:34.472
21              2:03:09.882     0:07:34.037     31,695 kbps     40,129 kbps     02:10:20.813    35,453 kbps     02:09:30.012    35,181 kbps     02:09:25.091    165,244 bytes   503,544 bytes   02:07:27.139
22              2:10:43.919     0:04:18.384     32,101 kbps     38,702 kbps     02:11:16.285    35,335 kbps     02:14:14.672    35,015 kbps     02:14:14.797    167,361 bytes   549,624 bytes   02:14:20.636
23              2:15:02.303     0:08:25.004     27,622 kbps     38,918 kbps     02:16:42.069    35,325 kbps     02:15:20.612    35,107 kbps     02:15:18.819    144,010 bytes   737,573 bytes   02:21:10.921
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0x1B            AVC                                             8607.31         33,812,353,897  183,884,300     31,427
00010.M2TS      4352 (0x1100)   0x83            TrueHD          eng             English         8607.31         4,625,014,216   31,293,394      4,299
00010.M2TS      4353 (0x1101)   0x81            AC3             fra             French          8607.31         688,586,240     4,034,685       640
00010.M2TS      4354 (0x1102)   0x81            AC3             spa             Spanish         8607.31         688,586,240     4,034,685       640
00010.M2TS      4355 (0x1103)   0x81            AC3             eng             English         8607.31         206,575,872     1,344,895       192
00010.M2TS      4608 (0x1200)   0x90            PGS             eng             English         8607.31         44,899,250      256,864         42
00010.M2TS      4609 (0x1201)   0x90            PGS             eng             English         8607.31         48,965,078      280,333         46
00010.M2TS      4610 (0x1202)   0x90            PGS             fra             French          8607.31         41,495,863      238,512         39
00010.M2TS      4611 (0x1203)   0x90            PGS             spa             Spanish         8607.31         34,518,910      199,322         32
00010.M2TS      4612 (0x1204)   0x90            PGS             por             Portuguese      8607.31         34,307,182      198,267         32
00010.M2TS      4613 (0x1205)   0x90            PGS             fra             French          8607.31         411,223         2,355           0
00010.M2TS      4614 (0x1206)   0x90            PGS             spa             Spanish         8607.31         428,816         2,458           0
00010.M2TS      4615 (0x1207)   0x90            PGS             eng             English         8607.31         22,347,372      133,766         21
00010.M2TS      6912 (0x1B00)   0x1B            AVC                                             8607.31         742,898,047     4,143,364       690
00010.M2TS      6656 (0x1A00)   0xA1            AC3+            eng             English         8607.31         206,575,872     1,344,895       192
House is offline
post #636 of 1971 Old 08-19-2008, 04:35 AM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Was expecting you to post the BD Info of Transformers and you did it. Thanks a lot House.
Blu-ray : 340
lgans316 is offline
post #637 of 1971 Old 08-19-2008, 09:50 AM
msgohan's Avatar
So on Top Gun you get matrixed 6.1 using the 5.1-EX that you lose by going to TrueHD?
Very nice bitrate on Transformers. Paramount doing things right. I didn't know Blu-ray supports DD+?
The partial Stargate UK stats got lost in the crash... Good old Google cache.
"From HolgerS at forum.cinefacts.de:
Code:
Disc Title: STARGATE
Disc Size: 29.692.475.862 bytes
Protection: AACS
BD-Java: No
VIDEO:
MPEG-4 AVC Video 19749 kbps 1080p / 24fps
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 2035 kbps 5.1 / 48kHz / 16-bit / 2035kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
SUBTITLES:
Presentation Graphics English 3 kbps
Still fits HD DVD size, I wonder if the peaks fit too. Too bad Stargate and Cliffhanger are apparently DNR'd. Add to that the upconverted Escape from New York and Optimum/StudioCanal is really starting to suck..."
msgohan is offline
post #638 of 1971 Old 08-19-2008, 09:53 AM
Phloyd's Avatar
Just for reference, iirc the bitrate on Transformers HD DVD was right around 20.5.
Phloyd is offline
post #639 of 1971 Old 08-19-2008, 10:13 AM
msgohan's Avatar
Here's T2, it's on the list but I love me some graphs and then there's this:
T2 starts with a similar country selection screen but much shorter, the only options being: Australia, Espana, France, Nederland, and United Kingdom. I wonder if that means Germany will get a different release, even though SC now owns Kinowelt? The language and subtitle tracks will certainly be different. Hmm...
Region AB locked yet again.
Code:
        Total   Video
(UK) Terminator 2: Judgment Day - Special Edition               VC-1    2:33:25 28,298,729,472  28,863,536,716  24.59   18.90   DTS-HD Master 5.1 2125Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     TERMINATOR_2_V_DIRECTOR
Disc Size:      28,863,536,716 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         2:33:25 (h:m:s)
Total Bitrate:  24.59 Mbps
Description:
FILES:
00129.M2TS      28,298,729,472  2:33:25.237     0:00:00.000     2:33:25.237
VIDEO:
VC-1 Video          18901 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         2125 kbps       5.1 / 48kHz / 16-bit / 2125kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
DTS-HD Audio                    Spanish         2046 kbps       5.1 / 48kHz / 16-bit / 2046kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
SUBTITLES:
Presentation Graphics           Dutch           16.710 kbps
Presentation Graphics           French          16.148 kbps
CHAPTERS:
1               0:00:00.000     0:05:35.210     18,564 kbps     32,997 kbps     00:04:54.085    24,627 kbps     00:00:35.285    23,987 kbps     00:00:33.325    96,783 bytes    383,463 bytes   00:00:26.360
2               0:05:35.210     0:10:56.197     19,024 kbps     33,736 kbps     00:12:30.416    26,476 kbps     00:06:02.529    23,343 kbps     00:12:23.117    99,182 bytes    430,529 bytes   00:12:30.541
3               0:16:31.407     0:14:48.471     19,118 kbps     34,364 kbps     00:22:16.877    23,248 kbps     00:22:16.961    21,191 kbps     00:28:55.317    99,674 bytes    385,178 bytes   00:19:06.145
4               0:31:19.878     0:07:32.786     19,120 kbps     29,061 kbps     00:34:30.527    23,523 kbps     00:34:45.041    21,169 kbps     00:31:25.425    99,683 bytes    281,859 bytes   00:34:30.735
5               0:38:52.664     0:10:55.446     18,993 kbps     30,021 kbps     00:42:31.090    22,585 kbps     00:42:54.530    21,037 kbps     00:42:08.401    99,022 bytes    354,858 bytes   00:48:09.220
6               0:49:48.110     0:16:36.204     19,039 kbps     33,122 kbps     01:01:54.961    22,965 kbps     00:58:18.412    21,020 kbps     01:03:47.323    99,262 bytes    512,988 bytes   01:01:55.086
7               1:06:24.314     0:22:35.437     18,960 kbps     30,944 kbps     01:11:09.640    23,143 kbps     01:11:09.640    20,992 kbps     01:22:28.152    98,848 bytes    379,428 bytes   01:26:53.917
8               1:28:59.751     0:06:17.002     19,230 kbps     32,436 kbps     01:31:44.416    24,517 kbps     01:31:37.325    23,089 kbps     01:31:35.657    100,258 bytes   554,585 bytes   01:30:44.439
9               1:35:16.753     0:09:07.046     19,131 kbps     30,000 kbps     01:43:29.787    22,621 kbps     01:40:53.714    20,939 kbps     01:42:29.727    99,741 bytes    279,478 bytes   01:36:05.385
10              1:44:23.799     0:15:19.794     19,145 kbps     31,982 kbps     01:57:59.656    22,708 kbps     01:57:45.183    21,322 kbps     01:46:53.574    99,813 bytes    334,699 bytes   01:57:59.739
11              1:59:43.593     0:09:00.123     19,115 kbps     31,984 kbps     02:06:13.816    22,383 kbps     02:06:03.347    21,177 kbps     02:00:28.304    99,658 bytes    311,054 bytes   02:00:28.430
12              2:08:43.716     0:24:41.522     18,143 kbps     33,437 kbps     02:27:52.655    26,683 kbps     02:30:07.165    25,462 kbps     02:30:05.663    94,591 bytes    361,935 bytes   02:31:57.859
STREAM DIAGNOSTICS:
00129.M2TS      4113 (0x1011)   0xEA            VC-1                                            9205.24         21,749,088,566  118,334,688     18,901
00129.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         9205.24         2,445,039,556   14,720,014      2,125
00129.M2TS      4353 (0x1101)   0x85            DTS-HD HR       spa             Spanish         9205.24         2,354,242,176   13,807,872      2,046
00129.M2TS      4608 (0x1200)   0x90            PGS             fra             French          9205.24         18,581,035      107,323         16
00129.M2TS      4609 (0x1201)   0x90            PGS             nld             Dutch           9205.24         19,227,743      110,909         17
Code:
        Total   Video
Terminator 2: Judgment Day                                      MPEG-2  2:16:35 23,357,331,456  24,466,699,874  22.80   18.93   DTS 5.1-ES 1536Kbps (48kHz/24-bit)        DD AC3 5.1-EX 640Kbps
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID
Disc Size:      24,466,699,874 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         2:16:35 (h:m:s)
Total Bitrate:  22.80 Mbps
Description:
FILES:
00008.M2TS      23,357,331,456  2:16:35.687     0:00:00.000     2:16:35.687
VIDEO:
MPEG-2 Video        18927 kbps      1080p / 23.976fps / 16:9
AUDIO:
DTS-ES Audio                    English         1536 kbps       5.1-ES / 48kHz / 24-bit / 1536kbps
Dolby Digital EX Audio          English         640 kbps        5.1-EX / 48kHz / 640kbps
SUBTITLES:
Presentation Graphics           English         19.246 kbps
Presentation Graphics           English         6.479 kbps
Presentation Graphics           Spanish         18.786 kbps
CHAPTERS:
1               0:00:00.000     0:03:36.383     19,006 kbps     35,060 kbps     00:02:01.163    27,842 kbps     00:02:00.787    26,537 kbps     00:02:00.787    99,090 bytes    436,517 bytes   00:03:36.174
2               0:03:36.383     0:01:58.535     22,933 kbps     33,555 kbps     00:05:30.247    32,304 kbps     00:05:18.777    32,092 kbps     00:05:13.814    119,563 bytes   426,721 bytes   00:04:56.505
3               0:05:34.918     0:04:56.713     18,301 kbps     33,416 kbps     00:06:10.453    29,985 kbps     00:06:09.911    28,228 kbps     00:06:05.156    95,415 bytes    441,118 bytes   00:08:18.331
4               0:10:31.631     0:01:57.951     18,816 kbps     28,291 kbps     00:10:37.512    22,367 kbps     00:10:36.302    21,311 kbps     00:10:53.945    98,098 bytes    482,085 bytes   00:11:28.146
5               0:12:29.582     0:03:00.222     18,797 kbps     31,502 kbps     00:12:29.582    28,198 kbps     00:12:29.582    23,658 kbps     00:12:29.582    97,999 bytes    474,258 bytes   00:12:29.624
6               0:15:29.804     0:02:36.323     18,245 kbps     29,151 kbps     00:16:39.207    23,316 kbps     00:16:39.165    21,265 kbps     00:16:37.205    95,119 bytes    495,379 bytes   00:16:41.709
7               0:18:06.127     0:06:23.967     18,126 kbps     28,183 kbps     00:21:33.000    25,731 kbps     00:24:23.754    24,233 kbps     00:24:20.000    94,500 bytes    500,052 bytes   00:20:56.964
8               0:24:30.094     0:06:17.043     19,959 kbps     37,490 kbps     00:25:59.850    28,323 kbps     00:25:57.181    23,971 kbps     00:25:52.134    104,058 bytes   528,600 bytes   00:25:23.480
9               0:30:47.137     0:03:40.095     21,091 kbps     32,590 kbps     00:32:20.230    25,327 kbps     00:34:15.136    25,057 kbps     00:30:57.397    109,961 bytes   475,914 bytes   00:31:19.336
10              0:34:27.232     0:05:05.513     17,708 kbps     24,008 kbps     00:34:39.995    21,323 kbps     00:36:55.797    20,898 kbps     00:36:54.254    92,323 bytes    439,049 bytes   00:38:01.863
11              0:39:32.745     0:05:01.927     16,855 kbps     25,883 kbps     00:39:34.664    20,850 kbps     00:43:29.816    19,806 kbps     00:43:24.811    87,874 bytes    481,792 bytes   00:39:34.706
12              0:44:34.672     0:04:56.046     16,941 kbps     24,934 kbps     00:44:55.860    21,057 kbps     00:44:51.856    19,969 kbps     00:44:47.602    88,323 bytes    439,407 bytes   00:44:56.652
13              0:49:30.718     0:03:29.959     18,171 kbps     24,799 kbps     00:50:00.289    22,133 kbps     00:49:57.995    21,112 kbps     00:51:16.740    94,735 bytes    479,710 bytes   00:51:16.782
14              0:53:00.677     0:03:37.426     19,077 kbps     28,493 kbps     00:54:18.964    23,980 kbps     00:54:52.080    22,888 kbps     00:54:49.203    99,457 bytes    442,576 bytes   00:56:08.448
15              0:56:38.103     0:04:33.231     21,148 kbps     34,628 kbps     00:58:39.433    30,844 kbps     00:58:41.518    28,726 kbps     00:58:38.348    110,256 bytes   546,900 bytes   00:56:55.871
16              1:01:11.334     0:03:45.434     18,156 kbps     24,940 kbps     01:01:11.793    22,029 kbps     01:01:11.376    20,959 kbps     01:01:39.029    94,656 bytes    435,596 bytes   01:03:02.112
17              1:04:56.768     0:04:00.532     17,688 kbps     26,153 kbps     01:04:56.976    19,966 kbps     01:07:36.594    19,173 kbps     01:04:57.060    92,217 bytes    405,518 bytes   01:06:16.931
18              1:08:57.300     0:03:46.184     18,260 kbps     25,862 kbps     01:11:26.574    20,703 kbps     01:11:25.865    20,557 kbps     01:11:24.739    95,200 bytes    522,487 bytes   01:10:34.063
19              1:12:43.484     0:04:20.260     16,717 kbps     26,322 kbps     01:13:20.479    22,818 kbps     01:13:17.059    19,744 kbps     01:13:13.055    87,157 bytes    447,566 bytes   01:14:43.437
20              1:17:03.744     0:04:13.712     19,484 kbps     31,414 kbps     01:18:15.941    27,039 kbps     01:18:14.231    25,042 kbps     01:18:38.380    101,582 bytes   494,950 bytes   01:17:35.860
21              1:21:17.456     0:05:38.964     18,629 kbps     29,790 kbps     01:22:23.230    23,022 kbps     01:22:19.434    22,248 kbps     01:22:27.151    97,124 bytes    506,164 bytes   01:24:42.786
22              1:26:56.420     0:02:49.043     17,191 kbps     23,834 kbps     01:26:56.420    19,508 kbps     01:26:56.420    18,777 kbps     01:26:56.420    89,626 bytes    501,872 bytes   01:29:03.922
23              1:29:45.463     0:04:41.281     18,707 kbps     33,731 kbps     01:33:47.956    24,154 kbps     01:33:44.536    22,283 kbps     01:30:05.817    97,528 bytes    522,867 bytes   01:30:48.276
24              1:34:26.744     0:02:06.210     19,677 kbps     34,472 kbps     01:34:38.339    26,576 kbps     01:34:36.129    24,337 kbps     01:34:31.833    102,589 bytes   443,298 bytes   01:36:32.745
25              1:36:32.954     0:02:21.766     20,724 kbps     32,692 kbps     01:37:07.363    26,934 kbps     01:37:06.988    24,488 kbps     01:37:06.779    108,044 bytes   463,206 bytes   01:36:55.518
26              1:38:54.720     0:03:52.149     20,250 kbps     32,997 kbps     01:42:19.133    27,810 kbps     01:40:38.324    25,712 kbps     01:42:12.418    105,572 bytes   477,432 bytes   01:40:14.091
27              1:42:46.869     0:03:51.606     19,416 kbps     30,789 kbps     01:45:25.528    25,406 kbps     01:45:10.429    23,076 kbps     01:46:00.813    101,225 bytes   481,118 bytes   01:43:49.932
28              1:46:38.475     0:02:38.993     21,460 kbps     34,521 kbps     01:47:32.488    26,552 kbps     01:47:31.362    25,113 kbps     01:48:31.797    111,883 bytes   440,269 bytes   01:48:27.835
29              1:49:17.468     0:04:04.786     20,132 kbps     32,471 kbps     01:52:24.363    25,079 kbps     01:52:24.071    23,736 kbps     01:52:24.279    104,957 bytes   435,847 bytes   01:49:37.279
30              1:53:22.254     0:03:31.962     19,875 kbps     29,530 kbps     01:55:54.114    24,745 kbps     01:55:51.319    23,095 kbps     01:55:47.732    103,620 bytes   478,188 bytes   01:55:55.031
31              1:56:54.216     0:01:46.397     21,812 kbps     34,557 kbps     01:57:51.147    28,368 kbps     01:57:59.489    27,580 kbps     01:57:58.280    113,719 bytes   448,779 bytes   01:57:26.122
32              1:58:40.613     0:02:31.569     22,195 kbps     34,513 kbps     02:00:37.814    29,409 kbps     02:00:33.893    28,416 kbps     02:00:28.805    115,713 bytes   451,903 bytes   01:59:03.720
33              2:01:12.182     0:04:35.567     21,113 kbps     34,977 kbps     02:03:52.425    30,596 kbps     02:02:55.910    27,314 kbps     02:02:50.905    110,074 bytes   466,619 bytes   02:02:15.787
34              2:05:47.749     0:02:13.216     21,530 kbps     32,276 kbps     02:06:24.744    29,306 kbps     02:06:24.744    26,493 kbps     02:06:21.449    112,245 bytes   480,112 bytes   02:07:37.483
35              2:08:00.965     0:04:33.648     17,719 kbps     40,224 kbps     02:11:46.065    24,928 kbps     02:11:43.062    22,238 kbps     02:11:37.556    92,380 bytes    480,981 bytes   02:10:51.052
36              2:12:34.613     0:04:01.074     13,971 kbps     20,826 kbps     02:14:47.579    20,186 kbps     02:14:47.371    19,957 kbps     02:14:44.910    72,839 bytes    372,320 bytes   02:14:47.788
STREAM DIAGNOSTICS:
00008.M2TS      4113 (0x1011)   0x02            MPEG-2                                          8195.69         19,389,654,768  105,492,807     18,927
00008.M2TS      4352 (0x1100)   0x81            AC3-EX          eng             English         8195.69         655,656,960     3,841,740       640
00008.M2TS      4353 (0x1101)   0x82            DTS-ES          eng             English         8195.69         1,545,912,152   9,220,152       1,509
00008.M2TS      4354 (0x1102)   0x81            AC3             eng             English         8195.69         196,697,088     1,280,580       192
00008.M2TS      4355 (0x1103)   0x81            AC3             eng             English         8195.69         196,697,088     1,280,580       192
00008.M2TS      4608 (0x1200)   0x90            PGS             eng             English         8195.69         19,717,137      113,678         19
00008.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         8195.69         19,245,051      110,689         19
00008.M2TS      4610 (0x1202)   0x90            PGS             eng             English         8195.69         6,637,982       37,949          6
StudioCanal HD DVD:
Code:
(EU)Terminator 2: Judgment Day-SE(Disc2)VC-1    2:33:15 24,567,705,600*                 21.37  ~19.37   DTS-HD Master Audio 5.1 No
Let's just say all of these have the same video encode as the HD DVDs.
msgohan is offline
post #640 of 1971 Old 08-20-2008, 08:32 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Code:
Prom Night                                                      AVC     1:29:11 25,472,163,840  33,458,128,714  38.08   27.31   Dolby TrueHD 5.1 1321Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     PROMNIGHT
Disc Size:      33,458,128,714 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         1:29:11 (h:m:s)
Total Bitrate:  38.08 Mbps
Description:
FILES:
00262.M2TS      25,472,163,840  1:29:11.387     0:00:00.000     1:29:11.387
VIDEO:
MPEG-4 AVC Video    27306 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video    1601 kbps       480p / 23.976fps / 16:9 / High Profile 3.2
AUDIO:
Dolby TrueHD Audio              English         1321 kbps       5.1 / 48kHz / 16-bit / 1321kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby TrueHD Audio              Portuguese      1357 kbps       5.1 / 48kHz / 16-bit / 1357kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             Thai            640 kbps        5.1 / 48kHz / 640kbps
SUBTITLES:
Presentation Graphics           English         30.866 kbps
Presentation Graphics           English         30.920 kbps
Presentation Graphics           Chinese         24.685 kbps
Presentation Graphics           Indonesian      32.719 kbps
Presentation Graphics           Korean          20.288 kbps
Presentation Graphics           Portuguese      28.101 kbps
Presentation Graphics           Spanish         25.928 kbps
Presentation Graphics           Thai            23.128 kbps
CHAPTERS:
1               0:00:00.000     0:06:12.831     24,463 kbps     31,157 kbps     00:05:31.790    28,827 kbps     00:05:27.744    28,523 kbps     00:05:22.822    127,537 bytes   266,786 bytes   00:02:24.436
2               0:06:12.831     0:05:02.802     28,320 kbps     30,732 kbps     00:11:14.007    28,851 kbps     00:11:10.044    28,574 kbps     00:10:23.790    147,646 bytes   392,997 bytes   00:11:15.675
3               0:11:15.633     0:02:51.547     28,246 kbps     31,127 kbps     00:13:36.024    28,988 kbps     00:13:32.061    28,514 kbps     00:13:27.015    147,263 bytes   517,460 bytes   00:13:37.025
4               0:14:07.180     0:07:16.769     28,045 kbps     39,767 kbps     00:14:52.183    30,588 kbps     00:14:48.179    29,447 kbps     00:14:43.174    146,211 bytes   674,012 bytes   00:16:37.121
5               0:21:23.949     0:03:21.410     28,113 kbps     33,231 kbps     00:21:36.545    29,130 kbps     00:21:44.261    28,624 kbps     00:24:05.194    146,568 bytes   362,778 bytes   00:21:35.169
6               0:24:45.359     0:07:13.683     27,995 kbps     33,768 kbps     00:28:27.706    29,366 kbps     00:28:23.702    28,866 kbps     00:28:18.697    145,953 bytes   363,616 bytes   00:28:28.248
7               0:31:59.042     0:06:27.637     28,231 kbps     32,265 kbps     00:35:09.024    29,115 kbps     00:35:34.049    28,648 kbps     00:32:28.530    147,185 bytes   386,624 bytes   00:35:38.595
8               0:38:26.679     0:08:17.289     28,198 kbps     32,115 kbps     00:42:09.902    29,052 kbps     00:42:15.199    28,642 kbps     00:42:10.194    147,009 bytes   334,109 bytes   00:42:10.319
9               0:46:43.968     0:06:06.157     28,048 kbps     33,428 kbps     00:49:02.940    29,270 kbps     00:48:58.936    28,869 kbps     00:48:53.931    146,230 bytes   339,074 bytes   00:49:03.482
10              0:52:50.125     0:03:56.111     28,092 kbps     35,560 kbps     00:53:56.775    29,317 kbps     00:53:52.688    28,939 kbps     00:53:47.766    146,457 bytes   408,647 bytes   00:54:34.396
11              0:56:46.236     0:02:50.796     27,863 kbps     32,632 kbps     00:57:45.253    29,368 kbps     00:58:28.630    28,822 kbps     00:58:23.667    145,263 bytes   357,058 bytes   00:57:37.120
12              0:59:37.032     0:04:36.151     27,521 kbps     33,729 kbps     01:02:55.480    29,073 kbps     01:01:43.617    28,696 kbps     01:01:38.570    143,484 bytes   634,978 bytes   01:03:23.008
13              1:04:13.183     0:06:18.878     27,868 kbps     35,436 kbps     01:08:17.677    29,943 kbps     01:08:13.631    29,036 kbps     01:08:08.710    145,293 bytes   457,145 bytes   01:09:47.225
14              1:10:32.061     0:04:01.158     27,750 kbps     36,403 kbps     01:11:28.826    30,126 kbps     01:11:24.864    28,946 kbps     01:11:19.859    144,678 bytes   423,492 bytes   01:11:29.452
15              1:14:33.219     0:07:15.351     27,974 kbps     34,449 kbps     01:21:34.389    29,413 kbps     01:21:14.078    28,873 kbps     01:21:09.073    145,843 bytes   454,720 bytes   01:16:18.157
16              1:21:48.570     0:07:22.818     22,296 kbps     34,751 kbps     01:23:55.113    29,337 kbps     01:26:34.398    28,662 kbps     01:24:33.819    116,242 bytes   392,190 bytes   01:26:38.902
STREAM DIAGNOSTICS:
00262.M2TS      4113 (0x1011)   0x1B            AVC                                             5351.39         18,265,359,581  99,343,067      27,306
00262.M2TS      4352 (0x1100)   0x83            TrueHD          eng             English         5351.39         1,311,562,282   10,069,588      1,961
00262.M2TS      4608 (0x1200)   0x90            PGS             eng             English         5351.39         20,646,669      117,995         31
00262.M2TS      4353 (0x1101)   0x81            AC3             spa             Spanish         5351.39         428,111,360     2,508,465       640
00262.M2TS      4354 (0x1102)   0x81            AC3             tha             Thai            5351.39         428,111,360     2,508,465       640
00262.M2TS      4355 (0x1103)   0x83            TrueHD          por             Portuguese      5351.39         1,335,534,058   10,404,895      1,997
00262.M2TS      4356 (0x1104)   0x81            AC3             eng             English         5351.39         128,433,408     836,155         192
00262.M2TS      4609 (0x1201)   0x90            PGS             eng             English         5351.39         20,683,144      120,843         31
00262.M2TS      4610 (0x1202)   0x90            PGS             tha             Thai            5351.39         15,470,916      90,001          23
00262.M2TS      4611 (0x1203)   0x90            PGS             zho             Chinese         5351.39         16,512,136      95,433          25
00262.M2TS      4612 (0x1204)   0x90            PGS             ind             Indonesian      5351.39         21,886,616      124,902         33
00262.M2TS      4613 (0x1205)   0x90            PGS             kor             Korean          5351.39         13,571,285      79,505          20
00262.M2TS      4614 (0x1206)   0x90            PGS             por             Portuguese      5351.39         18,797,661      107,993         28
00262.M2TS      4615 (0x1207)   0x90            PGS             spa             Spanish         5351.39         17,343,651      99,907          26
00262.M2TS      6912 (0x1B00)   0x1B            AVC                                             5351.39         1,071,187,645   5,924,048       1,601
Code:
[a04] Creating file "promnight.flac"...
[a04] This audio track has a constant bit depth of 16 bits.
post #641 of 1971 Old 08-20-2008, 09:17 PM
There is a separate playlist and M2TS for each of the four episodes of this series which I've included below along with the summary per disc. It's unfortunate that this was not placed on a single BD-50 - would be much more convenient than being spread across two BD-25.
Code:
        Total   Video
Human Body: Disc 1, Episodes 1-2 (1080i)                        AVC     1:22:16 15,286,824,960  15,860,837,336  24.77   22.96   DD AC3 5.1 384Kbps                        DD AC3 2.0 192Kbps
            Disc 2, Episodes 3-4 (1080i)                        AVC     1:22:57 15,418,472,448  15,992,553,888  24.78   22.97   DD AC3 5.1 384Kbps                        DD AC3 2.0 192Kbps
Code:
        Total   Video
Episode 1: Strength                                             AVC     0:40:38 7,551,547,392   15,860,837,336  24.77   22.96   DD AC3 5.1 384Kbps                        DD AC3 2.0 192Kbps
DISC INFO:
Disc Title:     BDROM
Disc Size:      15,860,837,336 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:40:38 (h:m:s)
Total Bitrate:  24.77 Mbps
Description:
FILES:
00004.M2TS      7,551,547,392   0:40:38.869     0:00:00.000     0:40:38.869
VIDEO:
MPEG-4 AVC Video    22963 kbps      1080i / 29.970fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio             English         384 kbps        5.1 / 48kHz / 384kbps
SUBTITLES:
Presentation Graphics           English         53.442 kbps
CHAPTERS:
1               0:00:00.000     0:01:11.538     22,087 kbps     37,543 kbps     00:00:06.807    29,315 kbps     00:00:01.068    25,805 kbps     00:00:26.960    92,122 bytes    417,951 bytes   00:00:49.683
2               0:01:11.538     0:06:43.770     23,125 kbps     38,124 kbps     00:02:29.349    30,926 kbps     00:01:19.780    30,269 kbps     00:01:15.776    96,451 bytes    429,143 bytes   00:05:45.045
3               0:07:55.308     0:08:55.702     23,001 kbps     37,504 kbps     00:15:34.801    28,624 kbps     00:15:16.449    26,739 kbps     00:08:16.196    95,933 bytes    424,355 bytes   00:16:01.861
4               0:16:51.010     0:06:16.876     23,003 kbps     38,004 kbps     00:20:38.070    31,656 kbps     00:21:55.214    30,717 kbps     00:21:50.109    95,943 bytes    420,893 bytes   00:20:25.558
5               0:23:07.886     0:06:11.939     23,028 kbps     36,481 kbps     00:25:33.032    29,399 kbps     00:23:07.887    25,719 kbps     00:23:23.535    96,046 bytes    413,671 bytes   00:27:19.404
6               0:29:19.825     0:04:16.956     22,964 kbps     36,708 kbps     00:31:42.033    32,246 kbps     00:31:07.466    30,318 kbps     00:31:02.461    95,777 bytes    428,064 bytes   00:32:48.800
7               0:33:36.781     0:06:32.192     23,011 kbps     37,968 kbps     00:39:17.021    31,707 kbps     00:39:17.021    28,046 kbps     00:39:17.021    95,976 bytes    427,802 bytes   00:38:54.732
8               0:40:08.973     0:00:29.897     20,261 kbps     38,573 kbps     00:40:10.475    28,189 kbps     00:40:08.973    24,685 kbps     00:40:08.973    84,505 bytes    417,608 bytes   00:40:10.508
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                             2438.87         7,000,484,367   38,089,119      22,963
00004.M2TS      4352 (0x1100)   0x81            AC3             eng             English         2438.87         117,064,704     685,926         384
00004.M2TS      4353 (0x1101)   0x81            AC3             eng             English         2438.87         58,532,352      381,070         192
00004.M2TS      4608 (0x1200)   0x90            PGS             eng             English         2438.87         16,292,369      93,123          53
Code:
        Total   Video
Episode 2: Sight                                                AVC     0:41:37 7,735,277,568   15,860,837,336  24.78   22.96   DD AC3 5.1 384Kbps
DISC INFO:
Disc Title:     BDROM
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:41:37 (h:m:s)
Total Bitrate:  24.78 Mbps
Description:
FILES:
00008.M2TS      7,735,277,568   0:41:37.695     0:00:00.000     0:41:37.695
VIDEO:
MPEG-4 AVC Video    22962 kbps      1080i / 29.970fps / 16:9 / High Profile 4.1
AUDIO:
SUBTITLES:
Presentation Graphics           English         59.060 kbps
CHAPTERS:
1               0:00:00.000     0:01:12.139     22,141 kbps     37,385 kbps     00:00:54.788    28,867 kbps     00:00:01.101    25,360 kbps     00:00:01.201    92,344 bytes    412,850 bytes   00:00:06.907
2               0:01:12.139     0:06:19.746     23,096 kbps     39,941 kbps     00:05:11.411    33,003 kbps     00:01:12.372    30,238 kbps     00:01:12.139    96,331 bytes    424,796 bytes   00:06:17.911
3               0:07:31.885     0:05:17.183     23,081 kbps     38,500 kbps     00:09:54.160    29,079 kbps     00:07:31.885    27,294 kbps     00:07:31.885    96,268 bytes    422,944 bytes   00:09:52.025
4               0:12:49.068     0:06:05.766     22,945 kbps     35,923 kbps     00:18:45.157    29,997 kbps     00:17:38.391    29,446 kbps     00:17:36.322    95,700 bytes    428,287 bytes   00:17:36.355
5               0:18:54.834     0:05:42.509     23,030 kbps     38,425 kbps     00:23:25.604    33,680 kbps     00:23:25.437    30,126 kbps     00:23:23.435    96,054 bytes    426,407 bytes   00:19:48.087
6               0:24:37.343     0:09:31.437     22,982 kbps     39,403 kbps     00:32:06.191    30,810 kbps     00:32:04.956    28,384 kbps     00:31:05.697    95,852 bytes    428,664 bytes   00:27:34.987
7               0:34:08.780     0:06:55.615     23,047 kbps     37,877 kbps     00:40:21.352    32,097 kbps     00:39:17.388    29,731 kbps     00:39:43.314    96,126 bytes    427,986 bytes   00:40:44.976
8               0:41:04.395     0:00:33.300     20,190 kbps     33,377 kbps     00:41:26.017    25,836 kbps     00:41:17.475    24,809 kbps     00:41:10.234    84,209 bytes    423,487 bytes   00:41:10.301
STREAM DIAGNOSTICS:
00008.M2TS      4113 (0x1011)   0x1B            AVC                                             2497.70         7,169,043,544   39,006,119      22,962
00008.M2TS      4352 (0x1100)   0x81            AC3             eng             English         2497.70         119,887,872     702,468         384
00008.M2TS      4353 (0x1101)   0x81            AC3             eng             English         2497.70         59,943,936      390,260         192
00008.M2TS      4608 (0x1200)   0x90            PGS             eng             English         2497.70         18,439,373      105,366         59
Code:
        Total   Video
Epsisode 3: Sensation                                           AVC     0:41:45 7,762,655,232   15,992,553,888  24.79   22.97   DD AC3 5.1 384Kbps
DISC INFO:
Disc Title:     BDROM
Disc Size:      15,992,553,888 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:41:45 (h:m:s)
Total Bitrate:  24.79 Mbps
Description:
FILES:
00003.M2TS      7,762,655,232   0:41:45.536     0:00:00.000     0:41:45.536
VIDEO:
MPEG-4 AVC Video    22972 kbps      1080i / 29.970fps / 16:9 / High Profile 4.1
AUDIO:
SUBTITLES:
Presentation Graphics           English         58.752 kbps
CHAPTERS:
1               0:00:00.000     0:01:11.605     22,052 kbps     37,639 kbps     00:00:06.940    29,641 kbps     00:00:01.134    25,543 kbps     00:00:01.134    91,976 bytes    412,686 bytes   00:00:01.235
2               0:01:11.605     0:06:14.641     23,064 kbps     38,733 kbps     00:01:14.741    30,418 kbps     00:01:14.741    29,996 kbps     00:01:14.708    96,196 bytes    429,104 bytes   00:04:58.999
3               0:07:26.246     0:06:12.939     23,081 kbps     37,791 kbps     00:10:08.374    32,088 kbps     00:07:27.947    28,559 kbps     00:07:26.680    96,269 bytes    424,407 bytes   00:13:14.627
4               0:13:39.185     0:08:14.327     23,035 kbps     36,984 kbps     00:15:48.247    31,511 kbps     00:20:05.271    30,391 kbps     00:20:00.499    96,074 bytes    429,129 bytes   00:17:11.631
5               0:21:53.512     0:05:35.402     22,956 kbps     37,065 kbps     00:26:02.361    28,145 kbps     00:26:01.760    25,101 kbps     00:23:02.181    95,747 bytes    400,296 bytes   00:22:40.392
6               0:27:28.914     0:07:38.291     23,011 kbps     38,644 kbps     00:32:32.150    28,441 kbps     00:32:31.783    26,995 kbps     00:27:39.758    95,975 bytes    420,256 bytes   00:31:28.487
7               0:35:07.205     0:06:06.333     23,021 kbps     37,253 kbps     00:39:59.664    29,679 kbps     00:40:46.477    29,040 kbps     00:40:34.032    96,015 bytes    428,860 bytes   00:41:06.164
8               0:41:13.538     0:00:31.998     20,770 kbps     34,930 kbps     00:41:34.258    28,127 kbps     00:41:33.591    25,421 kbps     00:41:30.021    86,630 bytes    413,118 bytes   00:41:33.725
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x1B            AVC                                             2505.54         7,194,606,088   39,145,177      22,972
00003.M2TS      4352 (0x1100)   0x81            AC3             eng             English         2505.54         120,265,728     704,682         384
00003.M2TS      4353 (0x1101)   0x81            AC3             eng             English         2505.54         60,132,864      391,490         192
00003.M2TS      4608 (0x1200)   0x90            PGS             eng             English         2505.54         18,400,622      105,192         59
Code:
        Total   Video
Episode 4: Brain Power                                          AVC     0:41:11 7,655,817,216   15,992,553,888  24.78   22.96   DD AC3 5.1 384Kbps
DISC INFO:
Disc Title:     BDROM
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:41:11 (h:m:s)
Description:
FILES:
00004.M2TS      7,655,817,216   0:41:11.836     0:00:00.000     0:41:11.836
VIDEO:
AUDIO:
SUBTITLES:
Presentation Graphics           English         60.794 kbps
CHAPTERS:
1               0:00:00.000     0:01:11.638     21,924 kbps     36,809 kbps     00:00:06.940    29,198 kbps     00:00:01.134    25,485 kbps     00:00:01.268    91,441 bytes    420,981 bytes   00:00:06.974
2               0:01:11.638     0:06:53.613     23,192 kbps     37,764 kbps     00:05:32.232    31,139 kbps     00:01:18.078    29,929 kbps     00:05:23.190    96,730 bytes    428,793 bytes   00:01:16.576
3               0:08:05.251     0:07:05.425     22,982 kbps     37,044 kbps     00:08:45.558    29,881 kbps     00:14:16.122    27,165 kbps     00:14:11.718    95,856 bytes    426,462 bytes   00:14:51.457
4               0:15:10.676     0:06:49.009     22,996 kbps     37,833 kbps     00:18:52.098    29,918 kbps     00:18:54.834    28,200 kbps     00:18:50.196    95,913 bytes    419,285 bytes   00:19:13.953
5               0:21:59.685     0:05:48.915     23,160 kbps     38,918 kbps     00:23:06.051    31,780 kbps     00:27:43.028    26,449 kbps     00:27:29.181    96,598 bytes    423,047 bytes   00:22:39.792
6               0:27:48.600     0:06:27.854     22,841 kbps     36,735 kbps     00:33:55.333    28,906 kbps     00:27:59.244    27,272 kbps     00:27:59.912    95,267 bytes    426,968 bytes   00:29:22.628
7               0:34:16.454     0:06:23.750     23,030 kbps     36,841 kbps     00:36:48.006    29,272 kbps     00:36:44.569    26,690 kbps     00:36:39.564    96,055 bytes    425,033 bytes   00:36:09.300
8               0:40:40.204     0:00:31.632     20,096 kbps     33,034 kbps     00:40:54.419    28,591 kbps     00:40:53.518    25,762 kbps     00:40:48.579    83,815 bytes    335,213 bytes   00:40:54.752
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                             2471.84         7,094,866,652   38,602,529      22,962
00004.M2TS      4352 (0x1100)   0x81            AC3             eng             English         2471.84         118,646,784     695,196         384
00004.M2TS      4353 (0x1101)   0x81            AC3             eng             English         2471.84         59,323,392      386,220         192
00004.M2TS      4608 (0x1200)   0x90            PGS             eng             English         2471.84         18,784,227      107,277         61
post #642 of 1971 Old 08-23-2008, 05:33 AM
sehgal.v7's Avatar
Can anybody post BDINfo report of Blue Planet, Casino Royale, Rambo 4, Transformers, The Bourne Ultimatum with Stream Diagnostics?
Sehgal
sehgal.v7 is offline
post #643 of 1971 Old 08-23-2008, 07:57 AM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
No Country For Old Men
Code:
[a03] Creating file "nocountry.flac"...
[a03] This audio track has a constant bit depth of 16 bits.
BTW I have noticed that Sony is Dialnorming some of their TrueHD tracks now.. As we know, -31dB is 0 dialnorm. -27dB is what Warner/Paramount uses.
Across the Universe:TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
Broken Trail: TrueHD/AC3, English, 5.1 channels, 48khz
John Mayer: TrueHD/AC3, English, 5.1 channels, 96khz
Prom Night: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -26dB
Resident Evil: TrueHD/AC3, English, 5.1 channels, 48khz
Spider-man: TrueHD/AC3, English, 5.1 channels, 48khz
Spider-man 2: TrueHD/AC3, English, 5.1 channels, 48khz
Spider-man 3: TrueHD/AC3, English, 5.1 channels, 48khz
Surf's Up: TrueHD/AC3, English, 5.1 channels, 48khz
Untraceable: TrueHD/AC3, English, 5.1 channels, 48khz
Walk Hard: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
I am guessing for those tracks with no info, dialnorm is -31dB since its not being reported. madshi can you advise?
post #644 of 1971 Old 08-23-2008, 08:00 AM
madshi's Avatar
Quoted: 2330 Post(s)
Liked: 2997
Originally Posted by Patsfan123 View Post
I am guessing for those tracks dialnorm is -31dB since its not being reported.
Correct. For tracks where dialnorm is not listed, it's turned off.
madshi is offline
post #645 of 1971 Old 08-24-2008, 10:59 AM
Phloyd's Avatar
The Bourne Ultimatum has not been released on BD, so that will be tricky.
Once my rig is back working again, I can probably do Casino Royale...
Phloyd is offline
post #646 of 1971 Old 08-24-2008, 01:08 PM
msgohan's Avatar
I can do Casino Royale and Rambo, not sure why you want the Stream Diagnostics specifically though?
msgohan is offline
post #647 of 1971 Old 08-24-2008, 02:37 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
I am bored..
Code:
        Total   Video
Casino Royale                                                   AVC     2:24:12 35,118,618,624  47,296,347,838  32.47   24.52   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     60815090_CASINO_ROYALE
Disc Size:      47,296,347,838 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         2:24:12 (h:m:s)
Total Bitrate:  32.47 Mbps
Description:
FILES:
00000.M2TS      35,118,618,624  2:24:12.644     0:00:00.000     2:24:12.644
VIDEO:
MPEG-4 AVC Video    24517 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48kHz / 16-bit / 4608kbps
Dolby Digital Audio             English         448 kbps        5.1 / 48kHz / 448kbps
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48kHz / 448kbps
SUBTITLES:
Presentation Graphics           English         31.014 kbps
Presentation Graphics           English         23.894 kbps
Presentation Graphics           Chinese         23.863 kbps
Presentation Graphics           French          24.581 kbps
Presentation Graphics           Korean          17.293 kbps
Presentation Graphics           Portuguese      26.151 kbps
Presentation Graphics           Spanish         29.078 kbps
Presentation Graphics           Thai            24.316 kbps
CHAPTERS:
1               0:00:00.000     0:09:33.406     23,815 kbps     42,873 kbps     00:05:54.771    34,014 kbps     00:05:38.046    32,480 kbps     00:05:38.046    124,163 bytes   778,718 bytes   00:04:11.501
2               0:09:33.406     0:09:53.051     26,506 kbps     43,001 kbps     00:10:19.702    33,647 kbps     00:18:02.623    32,023 kbps     00:18:00.830    138,190 bytes   753,091 bytes   00:13:10.957
3               0:19:26.457     0:06:04.823     22,157 kbps     40,906 kbps     00:19:34.298    31,952 kbps     00:19:33.798    30,748 kbps     00:19:32.421    115,518 bytes   698,963 bytes   00:22:24.176
4               0:25:31.280     0:09:42.915     24,639 kbps     39,587 kbps     00:33:00.353    31,239 kbps     00:25:31.280    28,918 kbps     00:30:06.972    128,458 bytes   741,506 bytes   00:31:50.575
5               0:35:14.195     0:04:40.614     24,062 kbps     38,275 kbps     00:37:30.331    35,484 kbps     00:37:29.456    33,736 kbps     00:37:27.912    125,446 bytes   621,586 bytes   00:35:14.237
6               0:39:54.809     0:05:22.906     25,232 kbps     39,788 kbps     00:42:19.245    31,262 kbps     00:43:44.413    30,881 kbps     00:43:33.027    131,551 bytes   624,763 bytes   00:42:19.579
7               0:45:17.715     0:12:28.623     24,075 kbps     43,485 kbps     00:53:19.071    34,754 kbps     00:46:58.357    34,451 kbps     00:46:56.272    125,517 bytes   688,955 bytes   00:54:25.512
8               0:57:46.338     0:09:31.237     24,074 kbps     40,636 kbps     00:57:51.218    34,138 kbps     00:57:48.590    32,300 kbps     00:57:46.338    125,513 bytes   757,213 bytes   01:05:36.558
9               1:07:17.575     0:09:49.756     24,107 kbps     39,789 kbps     01:09:14.400    34,089 kbps     01:09:13.649    31,954 kbps     01:09:08.728    125,682 bytes   639,353 bytes   01:12:07.323
10              1:17:07.331     0:12:37.006     24,463 kbps     44,923 kbps     01:25:00.053    34,335 kbps     01:25:00.012    33,376 kbps     01:26:11.333    127,539 bytes   772,678 bytes   01:25:11.356
11              1:29:44.337     0:08:35.098     23,281 kbps     39,948 kbps     01:32:34.090    33,556 kbps     01:32:38.136    32,586 kbps     01:32:34.090    121,376 bytes   642,768 bytes   01:32:34.132
12              1:38:19.435     0:04:48.455     25,041 kbps     38,743 kbps     01:42:24.680    35,163 kbps     01:42:23.220    31,369 kbps     01:42:19.467    130,551 bytes   704,087 bytes   01:41:18.572
13              1:43:07.890     0:10:32.924     24,345 kbps     37,205 kbps     01:43:28.744    32,456 kbps     01:43:25.324    31,814 kbps     01:43:32.832    126,924 bytes   726,732 bytes   01:46:57.536
14              1:53:40.814     0:11:42.827     25,668 kbps     43,448 kbps     01:53:42.733    32,834 kbps     01:59:52.769    32,670 kbps     01:59:52.769    133,821 bytes   779,971 bytes   01:57:25.914
15              2:05:23.641     0:07:34.329     26,339 kbps     45,602 kbps     02:11:37.098    35,364 kbps     02:09:50.616    33,068 kbps     02:09:50.616    137,319 bytes   753,153 bytes   02:05:26.144
16              2:12:57.970     0:11:14.674     24,120 kbps     39,828 kbps     02:13:35.883    33,224 kbps     02:14:09.667    32,394 kbps     02:13:26.916    125,751 bytes   782,357 bytes   02:19:41.206
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                             8652.64         26,516,928,068  144,235,599     24,517
00000.M2TS      4352 (0x1100)   0x81            AC3             eng             English         8652.64         484,549,632     2,703,960       448
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng             English         8652.64         4,983,923,520   27,688,464      4,608
00000.M2TS      4354 (0x1102)   0x81            AC3             fra             French          8652.64         692,213,760     4,055,940       640
00000.M2TS      4355 (0x1103)   0x81            AC3             spa             Spanish         8652.64         484,549,632     2,703,960       448
00000.M2TS      4608 (0x1200)   0x90            PGS             eng             English         8652.64         33,544,211      189,283         31
00000.M2TS      4609 (0x1201)   0x90            PGS             eng             English         8652.64         25,843,490      148,807         24
00000.M2TS      4610 (0x1202)   0x90            PGS             fra             French          8652.64         26,586,256      150,540         25
00000.M2TS      4611 (0x1203)   0x90            PGS             spa             Spanish         8652.64         31,449,669      177,937         29
00000.M2TS      4612 (0x1204)   0x90            PGS             zho             Chinese         8652.64         25,810,135      146,964         24
00000.M2TS      4613 (0x1205)   0x90            PGS             kor             Korean          8652.64         18,703,819      107,954         17
00000.M2TS      4614 (0x1206)   0x90            PGS             por             Portuguese      8652.64         28,284,553      160,137         26
00000.M2TS      4615 (0x1207)   0x90            PGS             tha             Thai            8652.64         26,299,920      150,024         24
post #648 of 1971 Old 08-24-2008, 07:26 PM
msgohan's Avatar
Code:
        Total   Video
Rambo                                                           AVC     1:31:31 26,384,185,344  46,855,015,149  38.44   26.82   DTS-HD Master 7.1 5516Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     RAMBO
Disc Size:      46,855,015,149 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         1:31:31 (h:m:s)
Total Bitrate:  38.44 Mbps
Description:
FILES:
00112.M2TS      2,427,942,912   0:08:16.746     0:00:00.000     0:08:16.746
00114.M2TS      37,730,304      0:00:08.591     0:08:16.746     0:08:25.338
00115.M2TS      6,595,203,072   0:22:32.351     0:08:25.338     0:30:57.689
00116.M2TS      492,232,704     0:01:50.568     0:30:57.689     0:32:48.257
00117.M2TS      1,007,271,936   0:03:47.060     0:32:48.257     0:36:35.318
00118.M2TS      294,795,264     0:01:06.816     0:36:35.318     0:37:42.134
00119.M2TS      1,886,957,568   0:06:26.469     0:37:42.134     0:44:08.604
00120.M2TS      225,196,032     0:00:50.884     0:44:08.604     0:44:59.488
00121.M2TS      1,728,841,728   0:05:58.441     0:44:59.488     0:50:57.929
00122.M2TS      134,639,616     0:00:29.738     0:50:57.929     0:51:27.667
00123.M2TS      3,972,612,096   0:13:37.608     0:51:27.667     1:05:05.276
00124.M2TS      312,422,400     0:01:10.320     1:05:05.276     1:06:15.596
00125.M2TS      7,268,339,712   0:25:15.931     1:06:15.596     1:31:31.527
VIDEO:
MPEG-4 AVC Video    26820 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video    3205 kbps       480p / 23.976fps / 16:9 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         5516 kbps       7.1 / 48kHz / 24-bit / 5217kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
SUBTITLES:
Presentation Graphics           English         25.721 kbps
Presentation Graphics           Spanish         25.993 kbps
CHAPTERS:
1               0:00:00.000     0:06:51.369     26,173 kbps     38,949 kbps     00:04:46.453    34,601 kbps     00:05:07.557    34,379 kbps     00:06:05.657    136,455 bytes   430,455 bytes   00:05:02.093
2               0:06:51.369     0:03:42.181     26,687 kbps     36,080 kbps     00:07:31.201    34,350 kbps     00:07:51.388    34,162 kbps     00:06:51.870    139,135 bytes   337,886 bytes   00:07:35.997
3               0:10:33.550     0:05:54.103     26,078 kbps     36,180 kbps     00:12:16.778    34,151 kbps     00:12:13.650    33,184 kbps     00:12:13.650    135,957 bytes   318,454 bytes   00:10:34.467
4               0:16:27.653     0:05:57.691     23,297 kbps     36,254 kbps     00:20:03.702    34,146 kbps     00:18:39.035    32,611 kbps     00:18:33.487    121,457 bytes   345,316 bytes   00:20:16.048
5               0:22:25.344     0:03:51.314     30,077 kbps     37,171 kbps     00:24:07.196    34,540 kbps     00:24:06.153    34,365 kbps     00:22:28.305    156,806 bytes   384,857 bytes   00:25:29.528
6               0:26:16.658     0:07:37.624     29,504 kbps     38,970 kbps     00:27:54.089    34,803 kbps     00:27:58.635    34,355 kbps     00:32:26.736    153,823 bytes   411,387 bytes   00:29:09.665
7               0:33:54.282     0:06:35.937     26,235 kbps     37,964 kbps     00:37:50.143    34,431 kbps     00:37:17.986    34,173 kbps     00:37:17.861    136,777 bytes   437,216 bytes   00:37:52.896
8               0:40:30.219     0:05:41.175     26,572 kbps     37,927 kbps     00:41:30.279    35,003 kbps     00:41:26.275    33,556 kbps     00:41:24.482    138,532 bytes   441,439 bytes   00:41:31.030
9               0:46:11.394     0:06:54.580     26,555 kbps     36,539 kbps     00:47:48.449    34,524 kbps     00:47:29.472    34,200 kbps     00:47:27.344    138,447 bytes   412,641 bytes   00:46:59.316
10              0:53:05.974     0:04:17.174     30,866 kbps     38,185 kbps     00:53:59.361    34,704 kbps     00:54:04.491    34,154 kbps     00:53:59.486    160,923 bytes   317,764 bytes   00:54:00.028
11              0:57:23.148     0:04:00.991     25,450 kbps     37,939 kbps     00:58:10.487    32,417 kbps     00:59:45.624    30,510 kbps     00:59:05.667    132,684 bytes   276,678 bytes   01:01:16.464
12              1:01:24.139     0:04:47.704     25,008 kbps     36,417 kbps     01:03:44.070    34,261 kbps     01:03:52.412    32,825 kbps     01:03:23.758    130,383 bytes   444,368 bytes   01:04:47.967
13              1:06:11.843     0:05:15.857     30,892 kbps     39,030 kbps     01:09:33.378    34,728 kbps     01:06:29.736    34,247 kbps     01:07:00.266    161,055 bytes   500,116 bytes   01:09:33.920
14              1:11:27.700     0:05:36.544     32,804 kbps     40,564 kbps     01:11:54.685    35,082 kbps     01:14:03.064    34,500 kbps     01:14:45.398    171,025 bytes   538,544 bytes   01:14:22.917
15              1:17:04.244     0:02:27.523     32,543 kbps     36,198 kbps     01:19:10.746    34,520 kbps     01:17:20.386    34,246 kbps     01:17:45.536    169,665 bytes   407,507 bytes   01:17:04.787
16              1:19:31.767     0:11:59.761     21,166 kbps     35,354 kbps     01:25:40.260    34,305 kbps     01:25:36.173    34,139 kbps     01:25:31.168    110,347 bytes   398,456 bytes   01:25:40.677
STREAM DIAGNOSTICS:
00112.M2TS      4113 (0x1011)   0x1B            AVC                                             496.75          1,672,895,417   9,098,902       26,942
00112.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         496.75          323,960,012     1,838,080       5,217
00112.M2TS      4353 (0x1101)   0x81            AC3             fra             French          496.75          39,741,440      232,860         640
00112.M2TS      4354 (0x1102)   0x81            AC3             eng             English         496.75          11,922,432      77,620          192
00112.M2TS      4608 (0x1200)   0x90            PGS             eng             English         496.75          1,935,054       10,921          31
00112.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         496.75          2,148,184       12,095          35
00112.M2TS      6912 (0x1B00)   0x1B            AVC                                             496.75          248,674,364     1,358,385       4,005
00114.M2TS      4113 (0x1011)   0x1B            AVC                                             8.59            29,016,340      157,815         27,017
00114.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         8.59            5,034,584       28,740          4,688
00114.M2TS      4353 (0x1101)   0x81            AC3             fra             French          8.59            688,640         4,035           641
00114.M2TS      4354 (0x1102)   0x81            AC3             eng             English         8.59            206,592         1,345           192
00114.M2TS      4608 (0x1200)   0x90            PGS             eng             English         8.59            140,795         795             131
00114.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         8.59            131,933         746             123
00114.M2TS      6912 (0x1B00)   0x1B            AVC                                             8.59            488,287         2,751           455
00115.M2TS      4113 (0x1011)   0x1B            AVC                                             1352.35         4,550,836,086   24,751,685      26,921
00115.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         1352.35         920,631,724     5,213,958       5,446
00115.M2TS      4353 (0x1101)   0x81            AC3             fra             French          1352.35         108,188,160     633,915         640
00115.M2TS      4354 (0x1102)   0x81            AC3             eng             English         1352.35         32,456,448      211,305         192
00115.M2TS      4608 (0x1200)   0x90            PGS             eng             English         1352.35         5,040,253       28,696          30
00115.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         1352.35         5,583,039       31,783          33
00115.M2TS      6912 (0x1B00)   0x1B            AVC                                             1352.35         628,428,719     3,433,371       3,718
00116.M2TS      4113 (0x1011)   0x1B            AVC                                             110.57          371,115,173     2,018,479       26,851
00116.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         110.57          75,283,768      426,623         5,447
00116.M2TS      4353 (0x1101)   0x81            AC3             fra             French          110.57          8,847,360       51,840          640
00116.M2TS      4354 (0x1102)   0x81            AC3             eng             English         110.57          2,654,208       17,280          192
00116.M2TS      4608 (0x1200)   0x90            PGS             eng             English         110.57          944,450         5,345           68
00116.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         110.57          879,808         4,969           64
00116.M2TS      6912 (0x1B00)   0x1B            AVC                                             110.57          6,292,674       35,451          455
00117.M2TS      4113 (0x1011)   0x1B            AVC                                             227.06          719,095,521     3,911,315       25,336
00117.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         227.06          149,751,908     848,934         5,276
00117.M2TS      4353 (0x1101)   0x81            AC3             fra             French          227.06          18,165,760      106,440         640
00117.M2TS      4354 (0x1102)   0x81            AC3             eng             English         227.06          5,449,728       35,480          192
00117.M2TS      4608 (0x1200)   0x90            PGS             eng             English         227.06          2,667,062       15,057          94
00117.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         227.06          2,455,766       13,862          87
00117.M2TS      6912 (0x1B00)   0x1B            AVC                                             227.06          56,069,921      307,505         1,976
00118.M2TS      4113 (0x1011)   0x1B            AVC                                             66.82           225,379,396     1,225,813       26,985
00118.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         66.82           42,623,460      242,041         5,103
00118.M2TS      4353 (0x1101)   0x81            AC3             fra             French          66.82           5,347,840       31,335          640
00118.M2TS      4354 (0x1102)   0x81            AC3             eng             English         66.82           1,604,352       10,445          192
00118.M2TS      4608 (0x1200)   0x90            PGS             eng             English         66.82           152,514         866             18
00118.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         66.82           213,853         1,209           26
00118.M2TS      6912 (0x1B00)   0x1B            AVC                                             66.82           3,802,813       21,423          455
00119.M2TS      4113 (0x1011)   0x1B            AVC                                             386.47          1,303,613,209   7,090,265       26,985
00119.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         386.47          246,377,608     1,399,345       5,100
00119.M2TS      4353 (0x1101)   0x81            AC3             fra             French          386.47          30,919,680      181,170         640
00119.M2TS      4354 (0x1102)   0x81            AC3             eng             English         386.47          9,275,904       60,390          192
00119.M2TS      4608 (0x1200)   0x90            PGS             eng             English         386.47          2,705,375       15,292          56
00119.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         386.47          2,575,376       14,564          53
00119.M2TS      6912 (0x1B00)   0x1B            AVC                                             386.47          192,931,382     1,053,929       3,994
00120.M2TS      4113 (0x1011)   0x1B            AVC                                             50.88           171,660,627     933,667         26,988
00120.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         50.88           33,122,096      188,030         5,207
00120.M2TS      4353 (0x1101)   0x81            AC3             fra             French          50.88           4,072,960       23,865          640
00120.M2TS      4354 (0x1102)   0x81            AC3             eng             English         50.88           1,221,888       7,955           192
00120.M2TS      4608 (0x1200)   0x90            PGS             eng             English         50.88           128,597         737             20
00120.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         50.88           106,359         615             17
00120.M2TS      6912 (0x1B00)   0x1B            AVC                                             50.88           2,896,081       16,315          455
00121.M2TS      4113 (0x1011)   0x1B            AVC                                             358.44          1,179,265,880   6,414,018       26,320
00121.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         358.44          246,127,440     1,393,689       5,493
00121.M2TS      4353 (0x1101)   0x81            AC3             fra             French          358.44          28,677,120      168,030         640
00121.M2TS      4354 (0x1102)   0x81            AC3             eng             English         358.44          8,603,136       56,010          192
00121.M2TS      4608 (0x1200)   0x90            PGS             eng             English         358.44          1,515,872       8,638           34
00121.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         358.44          1,558,867       8,867           35
00121.M2TS      6912 (0x1B00)   0x1B            AVC                                             358.44          172,648,302     943,120         3,853
00122.M2TS      4113 (0x1011)   0x1B            AVC                                             29.74           100,057,824     544,200         26,917
00122.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         29.74           22,681,436      127,894         6,102
00122.M2TS      4353 (0x1101)   0x81            AC3             fra             French          29.74           2,380,800       13,950          640
00122.M2TS      4354 (0x1102)   0x81            AC3             eng             English         29.74           714,240         4,650           192
00122.M2TS      4608 (0x1200)   0x90            PGS             eng             English         29.74           181             7               0
00122.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         29.74           181             7               0
00122.M2TS      6912 (0x1B00)   0x1B            AVC                                             29.74           1,692,174       9,533           455
00123.M2TS      4113 (0x1011)   0x1B            AVC                                             817.61          2,759,283,583   15,007,530      26,999
00123.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         817.61          602,115,384     3,399,885       5,891
00123.M2TS      4353 (0x1101)   0x81            AC3             fra             French          817.61          65,410,560      383,265         640
00123.M2TS      4354 (0x1102)   0x81            AC3             eng             English         817.61          19,623,168      127,755         192
00123.M2TS      4608 (0x1200)   0x90            PGS             eng             English         817.61          1,251,604       7,179           12
00123.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         817.61          1,213,984       6,963           12
00123.M2TS      6912 (0x1B00)   0x1B            AVC                                             817.61          316,132,876     1,730,695       3,093
00124.M2TS      4113 (0x1011)   0x1B            AVC                                             70.32           237,084,725     1,289,473       26,972
00124.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         70.32           46,482,764      263,715         5,288
00124.M2TS      4353 (0x1101)   0x81            AC3             fra             French          70.32           5,626,880       32,970          640
00124.M2TS      4354 (0x1102)   0x81            AC3             eng             English         70.32           1,688,064       10,990          192
00124.M2TS      4608 (0x1200)   0x90            PGS             eng             English         70.32           454,973         2,605           52
00124.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         70.32           440,981         2,523           50
00124.M2TS      6912 (0x1B00)   0x1B            AVC                                             70.32           4,001,291       22,543          455
00125.M2TS      4113 (0x1011)   0x1B            AVC                                             1515.93         5,090,989,619   27,689,663      26,867
00125.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng             English         1515.93         1,072,011,708   6,062,165       5,657
00125.M2TS      4353 (0x1101)   0x81            AC3             fra             French          1515.93         121,274,880     710,595         640
00125.M2TS      4354 (0x1102)   0x81            AC3             eng             English         1515.93         36,382,464      236,865         192
00125.M2TS      4608 (0x1200)   0x90            PGS             eng             English         1515.93         719,384         4,185           4
00125.M2TS      4609 (0x1201)   0x90            PGS             spa             Spanish         1515.93         534,448         3,108           3
00125.M2TS      6912 (0x1B00)   0x1B            AVC                                             1515.93         565,834,889     3,098,550       2,986
And Warner's German disc to compare graphs:
Code:
        Total   Video
(DE) Rambo                                                      VC-1    1:31:13 18,359,592,960  ~20,119,118,800 26.84   17.97   DTS-HD Master 5.1 2653Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     JOHN_RAMBO
Disc Size:      ~20,119,118,800 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:31:13 (h:m:s)
Total Bitrate:  26.84 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00005.M2TS      18,359,592,960  1:31:13.092     0:00:00.000     1:31:13.092
VIDEO:
Codec               Bitrate         Description
VC-1 Video          17971 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         2653 kbps       5.1 / 48kHz / 16-bit / 2653kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
DTS-HD Master Audio             German          4432 kbps       5.1 / 48kHz / 24-bit / 4432kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
SUBTITLES:
Presentation Graphics           English         3.439 kbps
Presentation Graphics           German          49.983 kbps
Presentation Graphics           German          70.637 kbps
Presentation Graphics           German          3.938 kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:07:15.644     14,571 kbps     31,824 kbps     00:00:03.045    29,481 kbps     00:06:34.477    27,783 kbps     00:06:29.180    75,967 bytes    445,306 bytes   00:04:17.716
2               0:07:15.644     0:05:06.431     15,758 kbps     24,369 kbps     00:11:52.420    21,611 kbps     00:11:51.920    21,229 kbps     00:11:52.253    82,154 bytes    327,706 bytes   00:10:12.862
3               0:12:22.075     0:04:05.328     16,905 kbps     26,676 kbps     00:14:30.578    21,505 kbps     00:14:27.492    20,563 kbps     00:14:23.571    88,135 bytes    291,857 bytes   00:14:33.372
4               0:16:27.403     0:07:05.508     17,676 kbps     33,309 kbps     00:18:11.549    30,227 kbps     00:18:08.587    25,805 kbps     00:18:08.587    92,153 bytes    415,186 bytes   00:22:51.495
5               0:23:32.911     0:08:13.118     17,982 kbps     42,018 kbps     00:27:58.343    29,875 kbps     00:27:55.257    27,321 kbps     00:31:27.469    93,749 bytes    463,244 bytes   00:31:31.306
6               0:31:46.029     0:09:17.432     16,473 kbps     37,220 kbps     00:33:00.395    26,832 kbps     00:36:38.238    23,837 kbps     00:33:47.901    85,883 bytes    438,673 bytes   00:36:38.363
7               0:41:03.461     0:08:12.200     17,517 kbps     42,102 kbps     00:48:01.420    30,766 kbps     00:45:58.673    29,159 kbps     00:44:55.276    91,326 bytes    532,160 bytes   00:45:01.616
8               0:49:15.661     0:11:45.997     23,166 kbps     46,268 kbps     00:56:57.873    31,152 kbps     00:51:38.721    28,973 kbps     00:53:37.673    120,779 bytes   424,450 bytes   00:56:58.415
9               1:01:01.658     0:07:28.365     19,787 kbps     38,754 kbps     01:05:49.612    31,697 kbps     01:03:20.463    28,943 kbps     01:06:20.768    103,160 bytes   506,393 bytes   01:04:30.158
10              1:08:30.023     0:08:21.375     21,891 kbps     41,216 kbps     01:13:06.674    30,585 kbps     01:14:01.103    28,768 kbps     01:14:35.805    114,130 bytes   529,188 bytes   01:14:47.483
11              1:16:51.398     0:03:02.016     17,027 kbps     33,501 kbps     01:18:51.560    29,082 kbps     01:17:10.793    23,699 kbps     01:17:05.830    88,770 bytes    496,831 bytes   01:18:50.935
12              1:19:53.414     0:11:19.679     14,033 kbps     24,566 kbps     01:23:07.983    23,372 kbps     01:23:07.065    23,093 kbps     01:23:06.815    73,164 bytes    413,159 bytes   01:21:45.609
STREAM DIAGNOSTICS:
File            PID             Type            Codec           Lang. Code      Lang. Name      Seconds         Bytes           Packets         Bitrate
00005.M2TS      4113 (0x1011)   0xEA            VC-1                                            5473.09         12,294,530,766  66,897,343      17,971
00005.M2TS      4352 (0x1100)   0x86            DTS-HD MA       deu             German          5473.09         3,032,100,904   17,332,409      4,432
00005.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng             English         5473.09         1,815,281,012   10,717,380      2,653
00005.M2TS      4608 (0x1200)   0x90            PGS             deu             German          5473.09         34,195,185      191,914         50
00005.M2TS      4609 (0x1201)   0x90            PGS             deu             German          5473.09         48,325,017      271,808         71
00005.M2TS      4610 (0x1202)   0x90            PGS             deu             German          5473.09         2,693,813       15,171          4
00005.M2TS      4611 (0x1203)   0x90            PGS             eng             English         5473.09         2,353,078       13,306          3
Warner's blurry encode actually has higher peaks and more I-frames.
msgohan is offline
post #649 of 1971 Old 08-24-2008, 10:02 PM
b_scott's Avatar
Quoted: 417 Post(s)
Liked: 128
on Pirates #1 Blu-ray, can someone tell me the best audio stream to send my Onkyo 705? my Pio 51 auto-sends feed #2, which is DD 5.1. but I noticed there is a PCM MultiCh feed as well as feed #1. is that a "better" sound? thanks!
b_scott is offline
post #650 of 1971 Old 08-24-2008, 11:39 PM
sehgal.v7's Avatar
@msgohan & Patsfan123
Thank you very much brothers, i needed them with Stream Diag coz i had done some experimenting with them earlier & i returned original BD to friend.
So i wanted to see if i still got Same exact demuxed files.
@Cinema Squid
Are you looking forward to add an option to Diag Particular TS or M2TS file instead whole Blu Ray Directory?
Regards & Thanks
post #651 of 1971 Old 08-25-2008, 04:35 PM
Phantom Stranger's Avatar
Quoted: 591 Post(s)
Liked: 606
For your receiver PCM will always be better sounding than the Dolby Digital one. The Dolby Digital is a lossy derivative of the PCM soundtrack.
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #652 of 1971 Old 08-25-2008, 08:03 PM
b_scott's Avatar
Quoted: 417 Post(s)
Liked: 128
thanks Phantom. I wish my BD51 would automatically choose the highest audio.
b_scott is offline
post #653 of 1971 Old 08-26-2008, 07:14 AM
House's Avatar
Gundam 00 Vol. 1...
Code:
        Total   Video
Gundam 00 Vol. 1                                                AVC     0:47:53 16,398,944,256  17,216,715,230  45.66   38.39   LPCM 2.0 1536Kbps (48kHz/16-bit)          LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     GUNDAM00_01
Disc Size:      17,216,715,230 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:47:53 (h:m:s)
Total Bitrate:  45.66 Mbps
Description:
FILES:
00002.M2TS      8,186,222,592   0:23:49.010     0:00:00.000     0:23:49.010
00003.M2TS      8,181,571,584   0:23:50.011     0:23:49.010     0:47:39.022
00004.M2TS      31,150,080      0:00:14.014     0:47:39.022     0:47:53.036
VIDEO:
MPEG-4 AVC Video    38391 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      Japanese        1536 kbps       2.0 / 48kHz / 16-bit / 1536kbps
CHAPTERS:
1               0:00:00.000     0:02:01.997     38,690 kbps     47,931 kbps     00:02:00.537    40,687 kbps     00:01:56.533    39,749 kbps     00:01:51.528    201,714 bytes   610,613 bytes   00:01:31.133
2               0:02:01.997     0:01:34.010     38,188 kbps     47,397 kbps     00:02:02.664    39,825 kbps     00:02:08.712    39,273 kbps     00:03:13.110    199,094 bytes   696,535 bytes   00:03:33.213
3               0:03:36.007     0:07:57.019     38,677 kbps     45,359 kbps     00:07:23.777    40,106 kbps     00:08:56.703    39,460 kbps     00:09:31.738    201,644 bytes   605,573 bytes   00:03:39.970
4               0:11:33.026     0:10:29.962     38,681 kbps     49,393 kbps     00:16:44.045    40,636 kbps     00:12:45.139    39,651 kbps     00:13:41.195    201,664 bytes   666,216 bytes   00:18:06.294
5               0:22:02.988     0:01:30.007     38,462 kbps     44,635 kbps     00:23:17.730    40,016 kbps     00:22:16.877    39,341 kbps     00:22:44.488    200,522 bytes   444,452 bytes   00:23:11.682
6               0:23:32.995     0:00:17.017     29,884 kbps     40,939 kbps     00:23:37.958    39,383 kbps     00:23:33.996    38,803 kbps     00:23:32.995    155,800 bytes   467,750 bytes   00:23:33.037
7               0:23:50.012     0:01:49.025     38,490 kbps     45,059 kbps     00:25:16.473    40,201 kbps     00:25:12.469    39,526 kbps     00:25:28.694    200,671 bytes   498,749 bytes   00:25:17.307
8               0:25:39.037     0:01:33.969     38,206 kbps     46,994 kbps     00:25:39.663    39,855 kbps     00:25:45.711    39,281 kbps     00:26:50.108    199,188 bytes   696,822 bytes   00:27:10.212
9               0:27:13.006     0:09:08.006     38,568 kbps     49,679 kbps     00:31:52.911    41,369 kbps     00:31:48.907    40,256 kbps     00:31:43.902    201,075 bytes   859,240 bytes   00:28:19.865
10              0:36:21.012     0:09:31.988     38,721 kbps     50,135 kbps     00:36:29.562    40,610 kbps     00:36:25.600    39,455 kbps     00:42:43.686    201,875 bytes   596,843 bytes   00:44:33.170
11              0:45:53.000     0:01:30.007     38,551 kbps     44,556 kbps     00:47:07.658    39,969 kbps     00:46:06.806    39,322 kbps     00:46:34.417    200,986 bytes   449,189 bytes   00:47:01.610
12              0:47:23.007     0:00:16.016     31,008 kbps     41,831 kbps     00:47:30.598    39,077 kbps     00:47:23.632    38,706 kbps     00:47:24.258    161,663 bytes   398,018 bytes   00:47:24.925
13              0:47:39.023     0:00:14.014     11,648 kbps     20,216 kbps     00:47:40.024    12,905 kbps     00:47:40.024    11,991 kbps     00:47:40.024    60,726 bytes    346,926 bytes   00:47:41.025
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                             1429.01         6,886,046,142   37,444,227      38,550
00002.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        1429.01         274,370,880     1,714,818       1,536
00002.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        1429.01         274,370,880     1,714,818       1,536
00002.M2TS      4354 (0x1102)   0x80            LPCM            jpn             Japanese        1429.01         274,370,880     1,714,818       1,536
00003.M2TS      4113 (0x1011)   0x1B            AVC                                             1430.01         6,880,943,931   37,416,409      38,494
00003.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        1430.01         274,561,920     1,716,012       1,536
00003.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        1430.01         274,561,920     1,716,012       1,536
00003.M2TS      4354 (0x1102)   0x80            LPCM            jpn             Japanese        1430.01         274,561,920     1,716,012       1,536
00004.M2TS      4113 (0x1011)   0x1B            AVC                                             14.01           20,450,783      111,292         11,674
00004.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        14.01           2,690,880       16,818          1,536
00004.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        14.01           2,690,880       16,818          1,536
00004.M2TS      4354 (0x1102)   0x80            LPCM            jpn             Japanese        14.01           2,690,880       16,818          1,536
House is offline
post #654 of 1971 Old 08-26-2008, 08:26 AM
House's Avatar
Vol. 2
Code:
        Total   Video
Gundam 00 Vol. 2                                                AVC     1:35:33 31,374,747,648  32,521,200,402  43.78   38.35   LPCM 2.0 1536Kbps (48kHz/16-bit)          LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     GUNDAM00_02
Disc Size:      32,521,200,402 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:35:33 (h:m:s)
Total Bitrate:  43.78 Mbps
Description:
FILES:
00002.M2TS      7,841,955,840   0:23:49.010     0:00:00.000     0:23:49.010
00003.M2TS      7,829,790,720   0:23:50.011     0:23:49.010     0:47:39.022
00004.M2TS      7,832,875,008   0:23:50.095     0:47:39.022     1:11:29.118
00005.M2TS      7,842,207,744   0:23:50.137     1:11:29.118     1:35:19.255
00006.M2TS      27,918,336      0:00:14.014     1:35:19.255     1:35:33.269
VIDEO:
MPEG-4 AVC Video    38352 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
CHAPTERS:
1               0:00:00.000     0:01:02.980     38,432 kbps     46,711 kbps     00:00:41.208    40,402 kbps     00:00:31.406    39,380 kbps     00:00:26.276    200,369 bytes   438,936 bytes   00:00:41.875
2               0:01:02.980     0:01:34.052     38,156 kbps     46,346 kbps     00:01:03.647    39,953 kbps     00:01:09.695    39,259 kbps     00:02:20.015    198,927 bytes   699,207 bytes   00:02:34.196
3               0:02:37.032     0:09:03.001     38,829 kbps     45,956 kbps     00:03:01.807    39,951 kbps     00:02:57.803    39,425 kbps     00:05:12.020    202,439 bytes   607,627 bytes   00:09:19.100
4               0:11:40.033     0:10:22.955     38,710 kbps     51,493 kbps     00:18:52.423    40,839 kbps     00:13:55.960    39,916 kbps     00:13:51.039    201,815 bytes   861,169 bytes   00:18:54.050
5               0:22:02.988     0:01:30.007     36,334 kbps     44,742 kbps     00:22:38.440    40,407 kbps     00:22:34.436    39,191 kbps     00:23:17.896    189,430 bytes   604,357 bytes   00:23:08.178
6               0:23:32.995     0:00:17.017     29,583 kbps     45,666 kbps     00:23:40.544    39,776 kbps     00:23:36.582    38,208 kbps     00:23:33.912    154,232 bytes   431,259 bytes   00:23:36.749
7               0:23:50.012     0:01:11.988     38,071 kbps     42,286 kbps     00:24:56.787    39,599 kbps     00:24:52.700    39,375 kbps     00:24:47.736    198,483 bytes   678,781 bytes   00:24:09.448
8               0:25:02.000     0:01:34.053     38,144 kbps     46,888 kbps     00:25:02.626    40,024 kbps     00:25:08.674    39,287 kbps     00:26:13.071    198,863 bytes   686,437 bytes   00:26:35.135
9               0:26:36.053     0:10:03.978     38,668 kbps     45,017 kbps     00:33:35.680    40,222 kbps     00:33:31.676    39,724 kbps     00:33:26.588    201,598 bytes   911,711 bytes   00:36:04.287
10              0:36:40.031     0:09:18.266     38,741 kbps     47,674 kbps     00:40:27.467    41,102 kbps     00:40:23.588    39,731 kbps     00:38:10.914    201,978 bytes   826,217 bytes   00:41:28.778
11              0:45:58.297     0:01:24.710     36,080 kbps     51,666 kbps     00:46:14.605    40,250 kbps     00:46:26.951    39,205 kbps     00:47:10.411    188,103 bytes   593,652 bytes   00:47:01.694
12              0:47:23.007     0:00:17.017     30,230 kbps     42,098 kbps     00:47:28.262    39,582 kbps     00:47:24.258    39,100 kbps     00:47:24.258    157,603 bytes   701,032 bytes   00:47:39.982
13              0:47:40.024     0:01:05.982     38,752 kbps     42,756 kbps     00:47:57.833    39,719 kbps     00:47:50.242    39,294 kbps     00:48:14.391    202,033 bytes   801,406 bytes   00:47:40.691
14              0:48:46.006     0:01:34.053     38,170 kbps     46,324 kbps     00:48:46.590    39,981 kbps     00:48:52.638    39,254 kbps     00:49:57.036    198,999 bytes   698,254 bytes   00:49:23.085
15              0:50:20.059     0:09:51.048     38,589 kbps     47,306 kbps     00:58:35.470    40,522 kbps     00:58:31.508    39,782 kbps     00:58:26.503    201,185 bytes   688,427 bytes   00:57:34.785
16              1:00:11.107     0:09:31.989     38,808 kbps     52,119 kbps     01:01:20.886    41,024 kbps     01:01:16.798    39,578 kbps     01:03:06.074    202,326 bytes   684,838 bytes   01:08:15.133
17              1:09:43.096     0:01:30.006     35,965 kbps     44,786 kbps     01:10:57.753    40,091 kbps     01:10:17.004    39,109 kbps     01:11:00.423    187,507 bytes   620,515 bytes   01:10:50.705
18              1:11:13.102     0:00:17.017     29,857 kbps     41,555 kbps     01:11:19.192    39,165 kbps     01:11:18.608    38,818 kbps     01:11:13.478    155,660 bytes   424,533 bytes   01:11:20.067
19              1:11:30.119     0:02:18.013     38,724 kbps     41,384 kbps     01:13:08.759    39,600 kbps     01:13:04.797    39,319 kbps     01:13:06.757    201,890 bytes   505,597 bytes   01:13:15.766
20              1:13:48.132     0:01:34.011     38,182 kbps     46,265 kbps     01:13:48.674    39,992 kbps     01:13:54.722    39,260 kbps     01:14:59.120    199,062 bytes   688,700 bytes   01:15:19.223
21              1:15:22.143     0:09:08.089     38,815 kbps     47,187 kbps     01:19:57.418    40,305 kbps     01:23:17.034    39,815 kbps     01:19:48.409    202,363 bytes   936,733 bytes   01:19:51.453
22              1:24:30.232     0:09:03.001     38,729 kbps     52,567 kbps     01:32:36.342    41,592 kbps     01:32:32.338    39,666 kbps     01:29:30.699    201,918 bytes   891,585 bytes   01:29:42.627
23              1:33:33.233     0:01:30.006     35,901 kbps     44,788 kbps     01:34:47.849    39,913 kbps     01:34:07.058    39,130 kbps     01:34:53.229    187,171 bytes   614,980 bytes   01:34:41.801
24              1:35:03.239     0:00:16.016     30,443 kbps     41,425 kbps     01:35:06.743    39,021 kbps     01:35:09.537    38,259 kbps     01:35:03.948    158,718 bytes   405,163 bytes   01:35:13.416
25              1:35:19.255     0:00:14.014     11,672 kbps     20,216 kbps     01:35:20.173    12,905 kbps     01:35:20.173    11,991 kbps     01:35:20.173    60,851 bytes    346,926 bytes   01:35:21.174
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                             1429.01         6,871,675,676   37,365,998      38,470
00003.M2TS      4113 (0x1011)   0x1B            AVC                                             1430.01         6,859,575,492   37,300,215      38,375
00003.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        1430.01         274,562,880     1,716,018       1,536
00003.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        1430.01         274,562,880     1,716,018       1,536
00004.M2TS      4113 (0x1011)   0x1B            AVC                                             1430.10         6,862,478,285   37,316,089      38,389
00004.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        1430.10         274,579,200     1,716,120       1,536
00004.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        1430.10         274,579,200     1,716,120       1,536
00005.M2TS      4113 (0x1011)   0x1B            AVC                                             1430.14         6,871,415,123   37,364,611      38,438
00005.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        1430.14         274,585,920     1,716,162       1,536
00005.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        1430.14         274,585,920     1,716,162       1,536
00006.M2TS      4113 (0x1011)   0x1B            AVC                                             14.01           20,450,783      111,292         11,674
00006.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        14.01           2,690,880       16,818          1,536
00006.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        14.01           2,690,880       16,818          1,536
House is offline
post #655 of 1971 Old 08-26-2008, 09:16 AM
PeterTHX's Avatar
Quoted: 568 Post(s)
Liked: 427
Unless he's using the HDMI or 6-ch analog out the 5.1 DD track is probably better than a 2-ch PCM one thru SPDIF
My opinions do not reflect the policies of my company
PeterTHX is offline
post #656 of 1971 Old 08-26-2008, 10:31 AM
House's Avatar
Code Geass Vol. 1
Code:
        Total   Video
Code Geass Vol. 1                                               AVC     0:24:08 7,474,636,800   16,411,516,108  41.28   35.96   LPCM 2.0 1536Kbps (48kHz/16-bit)          LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     CODE_GEASS_01
Disc Size:      16,411,516,108 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:24:08 (h:m:s)
Total Bitrate:  41.28 Mbps
Description:
FILES:
00002.M2TS      7,474,636,800   0:24:08.447     0:00:00.000     0:24:08.447
VIDEO:
MPEG-4 AVC Video    35961 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
CHAPTERS:
1               0:00:00.000     0:01:42.102     34,022 kbps     48,632 kbps     00:00:34.159    40,483 kbps     00:00:30.113    39,312 kbps     00:01:29.214    177,375 bytes   936,604 bytes   00:00:15.891
2               0:01:42.102     0:01:30.090     37,128 kbps     49,966 kbps     00:01:45.480    40,024 kbps     00:02:52.506    39,420 kbps     00:02:47.501    193,568 bytes   833,947 bytes   00:03:01.264
3               0:03:12.192     0:09:59.599     35,717 kbps     50,265 kbps     00:04:25.766    40,964 kbps     00:06:17.877    40,036 kbps     00:12:32.877    186,212 bytes   933,634 bytes   00:05:16.858
4               0:13:11.791     0:09:25.565     36,245 kbps     53,152 kbps     00:20:34.024    41,222 kbps     00:20:29.979    39,832 kbps     00:15:38.271    188,963 bytes   935,667 bytes   00:18:44.373
5               0:22:37.356     0:01:30.090     37,120 kbps     44,097 kbps     00:24:05.527    39,806 kbps     00:24:01.482    39,250 kbps     00:23:56.477    193,527 bytes   636,905 bytes   00:23:27.448
6               0:24:07.446     0:00:01.001     7,820 kbps      0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    40,768 bytes    40,768 bytes    00:24:07.571
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                             1448.45         6,510,893,632   35,405,578      35,961
00002.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        1448.45         278,101,440     1,738,134       1,536
00002.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        1448.45         278,101,440     1,738,134       1,536
House is offline
post #657 of 1971 Old 08-26-2008, 10:54 AM
b_scott's Avatar
Quoted: 417 Post(s)
Liked: 128
Originally Posted by PeterTHX View Post
Unless he's using the 6-ch analog out the 5.1 DD track is probably better than a 2-ch PCM one thru SPDIF
i'm running HDMI > Onkyo 705. which would be better?
b_scott is offline
post #658 of 1971 Old 08-26-2008, 11:02 AM
PeterTHX's Avatar
Quoted: 568 Post(s)
Liked: 427
PCM 5.1 then
Most discs default to DD because more receivers at this time support it, just like a lot of early DVDs defaulted to DD 2.0 and you had to manually select the 5.1 track.
Since both your receiver and player support HDMI 1.3 you can bitstream everything to the receiver, such as Dolby TrueHD and DTS-HD MA, PCM of course and apply THX Cinema (select) to them.
PeterTHX is offline
post #659 of 1971 Old 08-26-2008, 11:05 AM
b_scott's Avatar
Quoted: 417 Post(s)
Liked: 128
cool, thanks. PCM it is!
b_scott is offline
post #660 of 1971 Old 08-26-2008, 11:29 AM
House's Avatar
Code Geass R2 Vol. 1
Code:
        Total   Video
Code Geass R2 Vol. 1                                            AVC     0:24:07 7,691,206,656   27,497,822,328  42.51   37.14   LPCM 2.0 1536Kbps (48kHz/16-bit)          LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     CODE_GEASS_R2_01
Disc Size:      27,497,822,328 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:24:07 (h:m:s)
Total Bitrate:  42.51 Mbps
Description:
FILES:
00002.M2TS      7,691,206,656   0:24:07.446     0:00:00.000     0:24:07.446
VIDEO:
MPEG-4 AVC Video    37135 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
CHAPTERS:
1               0:00:00.000     0:02:16.136     36,127 kbps     47,158 kbps     00:00:51.093    40,718 kbps     00:00:47.089    39,376 kbps     00:01:21.498    188,352 bytes   871,163 bytes   00:01:52.654
2               0:02:16.136     0:01:30.090     36,330 kbps     49,987 kbps     00:02:39.576    39,950 kbps     00:02:35.489    39,290 kbps     00:03:14.403    189,410 bytes   750,130 bytes   00:03:05.644
3               0:03:46.226     0:07:47.467     35,800 kbps     54,641 kbps     00:06:01.236    41,639 kbps     00:05:57.232    39,619 kbps     00:05:52.269    186,643 bytes   933,751 bytes   00:08:22.210
4               0:11:33.693     0:10:29.629     38,538 kbps     52,959 kbps     00:16:45.254    41,688 kbps     00:16:41.209    40,374 kbps     00:16:36.204    200,919 bytes   934,256 bytes   00:15:14.622
5               0:22:03.322     0:01:33.093     37,498 kbps     43,108 kbps     00:23:13.851    39,647 kbps     00:22:51.537    39,352 kbps     00:22:51.537    195,497 bytes   774,325 bytes   00:22:54.415
6               0:23:36.415     0:00:30.030     35,284 kbps     45,589 kbps     00:23:59.480    40,680 kbps     00:23:55.309    38,895 kbps     00:23:38.626    183,952 bytes   888,015 bytes   00:24:00.981
7               0:24:06.445     0:00:01.001     7,820 kbps      0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    40,768 bytes    40,768 bytes    00:24:06.570
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                             1447.45         6,718,904,753   36,535,994      37,135
00002.M2TS      4352 (0x1100)   0x80            LPCM            jpn             Japanese        1447.45         277,909,440     1,736,934       1,536
00002.M2TS      4353 (0x1101)   0x80            LPCM            jpn             Japanese        1447.45         277,909,440     1,736,934       1,536
House is offline
Closed Thread Blu-ray Software
