Unofficial Blu-ray Audio and Video Specifications Thread - Page 44 - AVS Forum | Home Theater Discussions And Reviews
post #1291 of 1971 Old 01-16-2009, 09:32 AM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Shame on Fox for not using BD+ on Max Payne.
Blu-ray : 340
lgans316 is offline
post #1292 of 1971 Old 01-16-2009, 10:19 AM
House's Avatar
They did, BDInfo just doesn't detect it on the newer AnyDVD versions/folders.
House is offline
post #1293 of 1971 Old 01-16-2009, 10:57 AM
Cinema Squid's Avatar
That's correct - they used to create a folder called "SLYVM", but now it is called "ANYVM". I'll probably be pushing out a new version this weekend that has this fix among other things.
Cinema Squid is offline
post #1294 of 1971 Old 01-16-2009, 12:41 PM
Phantom Stranger's Avatar
Quoted: 591 Post(s)
Liked: 606
At this point I think it is indisputable that including multiple cuts of a movie on one BD is impacting the average video bitrates. If the studios are so enthusiastic about including multiple cuts they should offer them on separate BDs. I dread seeing a movie announced with multiple cuts for fear it might impact the quality of the video transfer. Was there some great clarion call for the original theatrical cut of Max Payne to be released? There only appears to be a difference of three minutes or so from the unrated cut.
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #1295 of 1971 Old 01-16-2009, 12:53 PM
bplewis24's Avatar
Forgive me for my ignorance here, as this is likely readily available information...but doesn't seamless branching circumvent this scenario?
If I see disc specs showing 2 different cuts of a movie, does that mean seamless branching was not used? If so, how do I spot it?
Brandon
bplewis24 is offline
post #1296 of 1971 Old 01-16-2009, 01:19 PM
You can tell whether seamless branching is employed by examining the constituent M2TS file lists and looking for what's shared or different between the two. For example, in the Max Payne listings you can see some differences early in the movie where alternate files are swapped in at the 7:34 and 11:21 marks.
In this case, seamless branching is used - for completely separate cuts there would be no M2TS files shared between the film versions (ex. I Am Legend).
Unrated:
Code:
00002.M2TS      0:00:00.000     0:07:34.912     1,820,559,360   32,016
00004.M2TS      0:07:34.912     0:00:48.548     174,575,616     28,767
00005.M2TS      0:08:23.461     0:02:58.094     784,422,912     35,236
00007.M2TS      0:11:21.555     0:02:30.900     622,141,440     32,983
Theatrical:
Code:
00003.M2TS      0:07:34.912     0:00:48.548     174,938,112     28,827
00006.M2TS      0:11:21.555     0:02:18.263     585,406,464     33,872
post #1297 of 1971 Old 01-16-2009, 04:44 PM
Phloyd's Avatar
I think that Wedding Crashers was the most recent film to just encode the movie twice.
Universal has been using seamless, so has Fox, Sony and Lionsgate.
I don't recall Disney ever using seamless... am I wrong?
Wedding Crashers was a classic Warner... two versions of the movie included with 10GB left empty as well... they could have fit it on a BD25 if they used branching no problem....
Phloyd is offline
post #1298 of 1971 Old 01-16-2009, 09:10 PM
Quoted: 591 Post(s)
Liked: 606
Originally Posted by benes View Post
Surely you know about seamless branching?
Yes I do. With seamless branching, the average video bitrates are typically much lower than single cuts from the same studios on other movies almost every single time. Can anyone find a seamlessly branched BD with an average bitrate for either cut over 30 Mbps? I have not seen one yet. I believe there are limitations in seamlessly branched cuts for the overall mux rate when you end up loading the disc with BD-Live stuff and multiple audio tracks. Overall capacity is almost never a limiting concern except for the very longest movies.
post #1299 of 1971 Old 01-16-2009, 09:49 PM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Phantom,
Max Payne is encoded at an AVBR of 22 Mbps which I think is still in the sweet spot zone and by having a glance at the BDInfo scan, it looks like FOX has indeed implemented seamless branching. However, featuring 2 separate encodes (WB/NL - are you listening?) on one disc and encoding at less than 17 Mbps by pushing the WAX controls is something that is unacceptable.
Blu-ray : 340
lgans316 is offline
post #1300 of 1971 Old 01-17-2009, 04:16 AM
patrick99's Avatar
Originally Posted by lgans316 View Post
Phantom,
Not to these eyes.
patrick99 is offline
post #1301 of 1971 Old 01-17-2009, 01:34 PM
House's Avatar
Lakeview Terrace
Code:
        Total   Video
Lakeview Terrace                                                AVC     1:50:27 30,244,847,616  36,967,464,865  36.51   23.81   Dolby TrueHD 5.1 1489Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     VOLUME_ID
Disc Size:      36,967,464,865 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 1:50:27 (h:m:s)
Total Bitrate:          36.51 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        23812 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1489 kbps       5.1 / 48 kHz / 1489 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              French          1479 kbps       5.1 / 48 kHz / 1479 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              Portuguese      1551 kbps       5.1 / 48 kHz / 1551 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Thai            640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         40.588 kbps
Presentation Graphics           English         36.296 kbps
Presentation Graphics           Chinese         30.449 kbps
Presentation Graphics           Chinese         25.162 kbps
Presentation Graphics           French          27.394 kbps
Presentation Graphics           Indonesian      41.160 kbps
Presentation Graphics           Korean          19.245 kbps
Presentation Graphics           Korean          44.027 kbps
Presentation Graphics           Portuguese      31.393 kbps
Presentation Graphics           Portuguese      64.626 kbps
Presentation Graphics           Spanish         34.550 kbps
Presentation Graphics           Spanish         74.580 kbps
Presentation Graphics           Thai            29.960 kbps
FILES:
00011.M2TS      0:00:00.000     1:50:27.621     30,244,847,616  36,508
CHAPTERS:
1               0:00:00.000     0:07:00.336     21,301 kbps     35,105 kbps     00:02:38.575    30,772 kbps     00:01:42.185    30,177 kbps     00:02:44.414    111,043 bytes   722,799 bytes   00:05:32.999
2               0:07:00.336     0:06:57.792     26,774 kbps     38,689 kbps     00:11:44.954    32,430 kbps     00:13:51.664    31,045 kbps     00:11:45.037    139,590 bytes   584,824 bytes   00:11:36.278
3               0:13:58.128     0:06:40.650     21,801 kbps     34,412 kbps     00:19:11.400    28,205 kbps     00:18:18.430    26,523 kbps     00:18:13.884    113,662 bytes   449,456 bytes   00:14:24.113
4               0:20:38.779     0:06:01.444     25,262 kbps     36,794 kbps     00:23:57.644    32,688 kbps     00:23:53.557    30,879 kbps     00:23:49.386    131,703 bytes   588,008 bytes   00:26:19.286
5               0:26:40.223     0:09:10.841     24,822 kbps     42,650 kbps     00:29:03.616    32,058 kbps     00:27:07.709    31,322 kbps     00:27:07.500    129,413 bytes   704,598 bytes   00:26:59.075
6               0:35:51.065     0:05:46.679     23,583 kbps     32,271 kbps     00:36:36.569    28,704 kbps     00:36:32.523    27,903 kbps     00:36:27.768    122,949 bytes   503,374 bytes   00:37:21.197
7               0:41:37.745     0:04:50.623     20,666 kbps     36,061 kbps     00:42:14.365    29,060 kbps     00:42:28.712    28,071 kbps     00:42:28.420    107,745 bytes   503,263 bytes   00:42:32.925
8               0:46:28.368     0:06:07.575     25,865 kbps     42,280 kbps     00:51:15.655    31,478 kbps     00:50:49.296    29,245 kbps     00:50:46.960    134,850 bytes   589,625 bytes   00:49:15.494
9               0:52:35.944     0:05:26.367     25,392 kbps     36,928 kbps     00:55:23.194    30,937 kbps     00:53:09.978    30,801 kbps     00:53:05.223    132,384 bytes   579,435 bytes   00:54:46.366
10              0:58:02.312     0:07:56.142     23,734 kbps     35,836 kbps     01:04:52.513    31,715 kbps     01:05:06.569    30,169 kbps     01:05:02.273    123,741 bytes   539,339 bytes   01:04:52.555
11              1:05:58.454     0:06:51.327     24,656 kbps     35,184 kbps     01:07:07.857    29,905 kbps     01:08:59.135    28,967 kbps     01:08:54.130    128,546 bytes   519,429 bytes   01:12:49.698
12              1:12:49.782     0:05:46.846     25,432 kbps     38,885 kbps     01:18:11.812    32,245 kbps     01:18:08.642    30,510 kbps     01:18:04.096    132,593 bytes   684,691 bytes   01:16:58.113
13              1:18:36.628     0:07:44.338     21,744 kbps     32,654 kbps     01:25:18.446    27,326 kbps     01:24:41.201    26,848 kbps     01:24:36.196    113,362 bytes   607,974 bytes   01:24:22.474
14              1:26:20.967     0:07:35.204     24,431 kbps     40,953 kbps     01:30:04.148    32,258 kbps     01:30:02.647    28,589 kbps     01:29:59.102    127,370 bytes   590,412 bytes   01:33:19.844
15              1:33:56.172     0:07:51.804     25,476 kbps     36,846 kbps     01:40:04.707    28,982 kbps     01:39:38.639    28,360 kbps     01:39:33.384    132,823 bytes   479,384 bytes   01:36:46.926
16              1:41:47.976     0:08:39.644     20,518 kbps     38,750 kbps     01:44:14.790    32,221 kbps     01:43:51.308    30,707 kbps     01:43:58.315    106,991 bytes   610,511 bytes   01:41:56.652
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6627.538                23,813                  19,727,301,244  107,306,675
00011.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6627.538                2,129                   1,764,120,804   13,121,497
00011.M2TS      4353 (0x1101)   0x83            TrueHD          fra (French)            6627.538                2,119                   1,755,168,374   13,039,643
00011.M2TS      4354 (0x1102)   0x83            TrueHD          por (Portuguese)        6627.538                2,192                   1,815,533,562   14,130,844
00011.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           6627.538                640                     530,211,840     3,106,710
00011.M2TS      4356 (0x1104)   0x81            AC3             tha (Thai)              6627.538                640                     530,211,840     3,106,710
00011.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           6627.538                192                     159,063,552     1,035,570
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6627.538                41                      33,625,575      192,534
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6627.538                36                      30,069,514      176,075
00011.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6627.538                27                      22,694,782      132,659
00011.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6627.538                35                      28,623,381      165,064
00011.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        6627.538                31                      26,007,586      150,830
00011.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           6627.538                30                      25,225,280      146,843
00011.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           6627.538                25                      20,845,512      123,293
00011.M2TS      4615 (0x1207)   0x90            PGS             ind (Indonesian)        6627.538                41                      34,099,109      195,240
00011.M2TS      4616 (0x1208)   0x90            PGS             kor (Korean)            6627.538                19                      15,943,562      95,902
00011.M2TS      4617 (0x1209)   0x90            PGS             tha (Thai)              6627.538                30                      24,820,565      145,104
00011.M2TS      4618 (0x120A)   0x90            PGS             spa (Spanish)           6627.538                75                      61,786,095      347,916
00011.M2TS      4619 (0x120B)   0x90            PGS             por (Portuguese)        6627.538                65                      53,539,837      303,141
00011.M2TS      4620 (0x120C)   0x90            PGS             kor (Korean)            6627.538                44                      36,473,993      210,432
House is offline
post #1302 of 1971 Old 01-17-2009, 04:47 PM
Afro Samurai: Season One
Code:
        Total   Video
Afro Samurai: Season One                                        AVC     2:11:22 21,888,175,296  24,961,566,071  22.21   16.99   Dolby TrueHD 5.1 1856Kbps (48kHz/16-bit)  DD AC3 2.0 640Kbps
Just to be clear, the AC3 2.0 640Kbps track is a secondary original audio track and not commentary. This disc has no subtitles.
Code:
DISC INFO:
Disc Title:     AFRO_SAMURAI
Disc Size:      24,961,566,071 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:11:22 (h:m:s)
Total Bitrate:          22.21 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        16986 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1856 kbps       5.1 / 48 kHz / 1856 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             English         640 kbps        2.0 / 48 kHz / 640 kbps
FILES:
00035.M2TS      0:00:00.000     0:26:15.657     4,400,117,760   22,340
00036.M2TS      0:26:15.657     0:26:17.534     4,352,710,656   22,073
00037.M2TS      0:52:33.191     0:26:17.534     4,401,266,688   22,320
00038.M2TS      1:18:50.725     0:26:17.450     4,406,169,600   22,346
00039.M2TS      1:45:08.176     0:26:13.446     4,327,369,920   22,002
00007.M2TS      2:11:21.623     0:00:01.001     540,672         4,321
CHAPTERS:
1               0:00:00.000     0:04:38.361     19,783 kbps     40,590 kbps     00:04:34.565    32,281 kbps     00:04:33.356    25,352 kbps     00:00:21.855    103,122 bytes   615,709 bytes   00:04:34.232
2               0:04:38.361     0:04:57.046     15,754 kbps     40,600 kbps     00:07:48.426    34,633 kbps     00:07:48.259    26,378 kbps     00:07:41.335    82,133 bytes    430,109 bytes   00:07:49.302
3               0:09:35.408     0:05:11.310     15,406 kbps     48,279 kbps     00:13:57.711    23,179 kbps     00:13:53.707    19,479 kbps     00:13:53.666    80,321 bytes    536,579 bytes   00:13:58.504
4               0:14:46.719     0:04:43.741     19,187 kbps     38,542 kbps     00:17:53.530    30,716 kbps     00:16:39.081    28,775 kbps     00:19:02.558    100,030 bytes   407,881 bytes   00:19:10.816
5               0:19:30.460     0:04:59.007     18,630 kbps     31,699 kbps     00:23:29.991    28,404 kbps     00:24:01.439    26,861 kbps     00:22:34.311    97,130 bytes    379,032 bytes   00:22:40.650
6               0:24:29.468     0:01:46.189     7,140 kbps      40,116 kbps     00:26:05.981    26,384 kbps     00:26:02.686    21,153 kbps     00:25:57.055    37,224 bytes    490,045 bytes   00:25:55.554
7               0:26:15.657     0:00:30.029     15,652 kbps     29,303 kbps     00:26:24.124    23,931 kbps     00:26:24.124    21,157 kbps     00:26:23.999    81,602 bytes    329,627 bytes   00:26:36.553
8               0:26:45.687     0:04:59.674     20,099 kbps     30,508 kbps     00:28:15.193    29,775 kbps     00:28:14.901    27,922 kbps     00:28:09.896    104,785 bytes   325,462 bytes   00:31:44.485
9               0:31:45.361     0:06:15.208     18,570 kbps     43,448 kbps     00:37:44.845    30,653 kbps     00:37:40.967    25,615 kbps     00:34:20.475    96,816 bytes    300,276 bytes   00:37:45.429
10              0:38:00.569     0:07:06.884     18,558 kbps     26,502 kbps     00:41:02.501    25,479 kbps     00:41:02.501    24,385 kbps     00:40:58.747    96,754 bytes    289,009 bytes   00:40:30.803
11              0:45:07.454     0:05:39.672     14,016 kbps     41,203 kbps     00:47:58.000    28,529 kbps     00:47:53.996    22,155 kbps     00:47:51.618    73,072 bytes    270,581 bytes   00:47:58.500
12              0:50:47.127     0:01:46.064     6,230 kbps      40,100 kbps     00:52:23.557    23,658 kbps     00:52:19.761    18,527 kbps     00:52:14.673    32,483 bytes    455,357 bytes   00:52:13.255
13              0:52:33.191     0:00:30.030     19,514 kbps     35,974 kbps     00:52:41.700    29,006 kbps     00:52:41.700    25,804 kbps     00:52:41.658    101,737 bytes   385,092 bytes   00:52:54.087
14              0:53:03.221     0:06:49.742     16,915 kbps     40,203 kbps     00:55:21.401    39,247 kbps     00:55:17.397    37,032 kbps     00:55:13.143    88,189 bytes    395,729 bytes   00:55:16.688
15              0:59:52.964     0:07:02.672     17,798 kbps     30,245 kbps     01:04:27.029    27,058 kbps     01:04:27.029    23,459 kbps     01:04:27.029    92,788 bytes    215,346 bytes   01:01:21.386
16              1:06:55.636     0:05:16.399     17,402 kbps     42,600 kbps     01:10:04.950    38,994 kbps     01:10:59.004    30,320 kbps     01:10:55.000    90,724 bytes    405,349 bytes   01:09:42.845
17              1:12:12.036     0:04:52.625     18,534 kbps     42,365 kbps     01:12:33.140    38,871 kbps     01:12:35.476    36,628 kbps     01:12:33.140    96,629 bytes    404,505 bytes   01:12:33.807
18              1:17:04.661     0:01:46.064     7,656 kbps      40,021 kbps     01:18:41.091    26,816 kbps     01:18:37.254    21,781 kbps     01:18:32.207    39,916 bytes    496,934 bytes   01:18:30.747
19              1:18:50.725     0:00:30.029     14,660 kbps     28,100 kbps     01:18:59.234    22,580 kbps     01:18:59.234    19,639 kbps     01:18:59.192    76,430 bytes    310,375 bytes   01:19:11.621
20              1:19:20.755     0:04:56.504     13,484 kbps     39,654 kbps     01:22:25.940    22,899 kbps     01:22:25.649    18,679 kbps     01:22:18.183    70,298 bytes    458,399 bytes   01:22:26.232
21              1:24:17.260     0:06:31.891     19,363 kbps     31,586 kbps     01:27:30.286    27,671 kbps     01:27:28.743    25,552 kbps     01:27:24.739    100,952 bytes   265,323 bytes   01:27:30.328
22              1:30:49.152     0:06:01.527     19,598 kbps     29,134 kbps     01:32:28.668    25,115 kbps     01:32:15.279    24,025 kbps     01:32:15.404    102,176 bytes   223,143 bytes   01:32:29.252
23              1:36:50.679     0:06:31.516     18,064 kbps     41,762 kbps     01:39:13.364    32,988 kbps     01:39:11.945    31,997 kbps     01:39:11.195    94,175 bytes    570,022 bytes   01:41:31.376
24              1:43:22.195     0:01:45.980     5,999 kbps      39,231 kbps     01:44:58.625    22,906 kbps     01:44:54.788    16,963 kbps     01:44:49.741    31,277 bytes    406,950 bytes   01:44:49.282
25              1:45:08.176     0:00:30.029     16,529 kbps     31,045 kbps     01:45:28.363    25,302 kbps     01:45:16.643    22,096 kbps     01:45:16.643    86,176 bytes    341,081 bytes   01:45:29.072
26              1:45:38.206     0:05:52.435     14,959 kbps     27,238 kbps     01:48:47.938    21,805 kbps     01:46:12.324    19,364 kbps     01:46:11.531    77,989 bytes    273,573 bytes   01:50:03.763
27              1:51:30.642     0:04:57.505     19,633 kbps     46,165 kbps     01:56:25.853    40,411 kbps     01:56:21.808    37,341 kbps     01:56:17.053    102,358 bytes   320,847 bytes   01:55:16.826
28              1:56:28.147     0:06:25.176     19,394 kbps     45,336 kbps     01:59:42.300    39,813 kbps     01:56:59.929    39,176 kbps     01:59:58.733    101,114 bytes   498,732 bytes   02:00:08.618
29              2:02:53.324     0:06:41.818     17,415 kbps     44,340 kbps     02:03:52.925    39,193 kbps     02:03:24.939    34,100 kbps     02:03:23.562    90,796 bytes    369,855 bytes   02:06:44.930
30              2:09:35.142     0:01:47.482     6,096 kbps      39,286 kbps     02:11:11.697    24,466 kbps     02:11:08.402    17,557 kbps     02:11:02.854    31,795 bytes    443,682 bytes   02:11:02.271
STREAM DIAGNOSTICS:
00035.M2TS      4113 (0x1011)   0x1B            AVC                                     1575.574                16,981                  3,344,399,252   18,198,094
00035.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1575.574                2,526                   497,542,386     4,173,952
00035.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           1575.574                448                     88,238,080      492,400
00036.M2TS      4113 (0x1011)   0x1B            AVC                                     1577.367                16,993                  3,350,536,125   18,231,586
00036.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1577.367                2,397                   472,641,432     3,892,906
00036.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           1577.367                448                     88,342,016      492,980
00037.M2TS      4113 (0x1011)   0x1B            AVC                                     1577.367                16,978                  3,347,641,160   18,215,772
00037.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1577.367                2,633                   519,241,686     4,161,614
00037.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           1577.367                448                     88,342,016      492,980
00038.M2TS      4113 (0x1011)   0x1B            AVC                                     1577.367                17,003                  3,352,487,064   18,242,299
00038.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1577.367                2,517                   496,280,888     4,160,671
00038.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           1577.367                448                     88,338,432      492,960
00039.M2TS      4113 (0x1011)   0x1B            AVC                                     1573.280                16,991                  3,341,510,781   18,182,461
00039.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1573.280                2,407                   473,447,720     3,811,327
00039.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           1573.280                448                     88,112,640      491,704
00007.M2TS      4113 (0x1011)   0x1B            AVC                                     0.834                   973                     101,406         576
00007.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           0.834                   1,665                   173,626         1,692
00007.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           0.834                   786                     81,920          480
post #1303 of 1971 Old 01-17-2009, 04:49 PM
Sting: Bring on the Night
Code:
        Total   Video
Sting: Bring on the Night                                       AVC     1:37:02 18,709,370,880  21,692,817,849  25.71   19.98   DTS-HD Master 5.1 2412Kbps (48kHz/16-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Oops - someone forgot to put on the language tags during disc authoring! Audio tracks are English with subtitles in English, French, German, Portuguese and Spanish.
Code:
DISC INFO:
Disc Title:     Sting_Bring_On_The_Night
Disc Size:      21,692,817,849 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:37:02 (h:m:s)
Total Bitrate:          25.71 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        19978 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             Undetermined    2412 kbps       5.1 / 48 kHz / 2412 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
LPCM Audio                      Undetermined    1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           Undetermined    31.215 kbps
Presentation Graphics           Undetermined    31.957 kbps
Presentation Graphics           Undetermined    34.652 kbps
Presentation Graphics           Undetermined    29.922 kbps
Presentation Graphics           Undetermined    28.811 kbps
FILES:
00002.M2TS      0:00:00.000     1:37:02.733     18,709,370,880  25,705
CHAPTERS:
1               0:00:00.000     0:03:42.639     21,296 kbps     41,000 kbps     00:00:11.511    32,245 kbps     00:01:14.282    30,683 kbps     00:01:14.074    111,007 bytes   387,743 bytes   00:01:14.324
2               0:03:42.639     0:02:08.920     24,419 kbps     32,664 kbps     00:05:36.502    29,207 kbps     00:05:46.512    28,953 kbps     00:05:41.466    127,311 bytes   265,145 bytes   00:04:24.097
3               0:05:51.559     0:02:56.718     24,946 kbps     35,099 kbps     00:07:57.602    29,431 kbps     00:07:18.855    28,926 kbps     00:08:26.130    130,055 bytes   284,409 bytes   00:07:34.245
4               0:08:48.277     0:02:06.584     25,510 kbps     34,447 kbps     00:10:11.611    30,389 kbps     00:09:19.850    29,851 kbps     00:10:11.611    132,995 bytes   307,484 bytes   00:10:11.652
5               0:10:54.862     0:04:14.045     23,409 kbps     36,215 kbps     00:14:26.699    27,535 kbps     00:13:59.213    27,362 kbps     00:13:55.167    122,044 bytes   260,179 bytes   00:12:15.443
6               0:15:08.908     0:03:45.433     21,587 kbps     27,852 kbps     00:16:42.418    25,251 kbps     00:18:19.223    24,750 kbps     00:18:20.307    112,545 bytes   243,992 bytes   00:15:37.436
7               0:18:54.341     0:04:08.331     23,784 kbps     34,406 kbps     00:20:10.417    30,256 kbps     00:21:08.225    29,920 kbps     00:21:03.220    123,998 bytes   278,941 bytes   00:22:30.932
8               0:23:02.672     0:01:30.799     26,625 kbps     32,533 kbps     00:23:56.268    29,780 kbps     00:24:20.667    29,638 kbps     00:24:21.084    138,812 bytes   325,163 bytes   00:24:33.388
9               0:24:33.472     0:03:28.208     19,723 kbps     30,712 kbps     00:24:34.139    25,025 kbps     00:24:33.472    23,839 kbps     00:24:33.472    102,826 bytes   318,765 bytes   00:24:35.015
10              0:28:01.680     0:05:37.587     19,112 kbps     39,435 kbps     00:32:01.628    28,754 kbps     00:33:06.609    28,463 kbps     00:33:01.604    99,640 bytes    279,483 bytes   00:32:02.462
11              0:33:39.267     0:04:32.230     21,644 kbps     29,662 kbps     00:35:33.631    27,636 kbps     00:33:54.615    27,327 kbps     00:33:51.571    112,840 bytes   265,437 bytes   00:35:33.673
12              0:38:11.497     0:06:31.557     21,119 kbps     38,401 kbps     00:40:50.406    30,562 kbps     00:40:49.530    28,400 kbps     00:40:42.648    110,103 bytes   377,725 bytes   00:40:43.732
13              0:44:43.055     0:04:36.693     20,925 kbps     30,854 kbps     00:48:09.386    28,499 kbps     00:48:06.174    28,207 kbps     00:48:01.128    109,094 bytes   279,217 bytes   00:45:13.794
14              0:49:19.748     0:03:39.594     17,794 kbps     23,539 kbps     00:49:31.051    20,795 kbps     00:49:58.912    19,579 kbps     00:49:53.949    92,770 bytes    239,857 bytes   00:50:01.498
15              0:52:59.342     0:03:49.812     17,850 kbps     23,653 kbps     00:56:05.278    21,054 kbps     00:55:30.660    20,778 kbps     00:55:30.660    93,064 bytes    231,770 bytes   00:56:00.940
16              0:56:49.155     0:04:50.248     19,527 kbps     30,650 kbps     01:01:27.809    28,556 kbps     01:01:33.564    28,359 kbps     01:01:27.809    101,803 bytes   245,459 bytes   01:01:27.850
17              1:01:39.404     0:04:33.273     17,336 kbps     30,337 kbps     01:06:07.588    21,824 kbps     01:05:28.049    21,026 kbps     01:05:28.007    90,382 bytes    271,397 bytes   01:05:31.260
18              1:06:12.677     0:04:51.457     17,652 kbps     29,078 kbps     01:11:00.589    21,803 kbps     01:06:43.124    20,965 kbps     01:07:14.405    92,030 bytes    248,590 bytes   01:07:05.146
19              1:11:04.134     0:03:47.060     18,301 kbps     35,267 kbps     01:12:27.593    30,943 kbps     01:12:27.593    28,863 kbps     01:12:23.380    95,413 bytes    260,617 bytes   01:12:27.634
20              1:14:51.195     0:02:39.742     17,211 kbps     20,887 kbps     01:16:08.313    19,092 kbps     01:15:54.758    18,438 kbps     01:17:20.886    89,730 bytes    200,331 bytes   01:15:05.125
21              1:17:30.937     0:04:35.191     19,705 kbps     27,514 kbps     01:18:41.091    23,822 kbps     01:20:37.582    22,836 kbps     01:20:32.702    102,733 bytes   320,545 bytes   01:19:05.157
22              1:22:06.129     0:04:25.682     17,108 kbps     33,346 kbps     01:24:34.486    21,945 kbps     01:24:33.985    19,617 kbps     01:24:28.980    89,194 bytes    259,245 bytes   01:24:34.903
23              1:26:31.811     0:01:39.849     17,736 kbps     24,229 kbps     01:28:08.574    19,559 kbps     01:28:05.905    18,764 kbps     01:28:00.942    92,466 bytes    200,467 bytes   01:27:10.183
24              1:28:11.661     0:03:46.851     18,157 kbps     23,340 kbps     01:31:13.342    21,521 kbps     01:31:10.506    20,804 kbps     01:31:05.251    94,663 bytes    204,847 bytes   01:30:37.181
25              1:31:58.513     0:05:04.220     15,874 kbps     22,999 kbps     01:32:11.359    21,025 kbps     01:32:11.359    19,716 kbps     01:32:11.359    82,781 bytes    217,266 bytes   01:35:59.587
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     5822.650                19,978                  14,540,625,547  79,107,140
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       und (Undetermined)      5822.650                2,412                   1,755,317,076   10,456,819
00002.M2TS      4353 (0x1101)   0x80            LPCM            und (Undetermined)      5822.650                1,542                   1,122,622,024   6,987,279
00002.M2TS      4608 (0x1200)   0x90            PGS             und (Undetermined)      5822.650                31                      22,719,793      126,478
00002.M2TS      4609 (0x1201)   0x90            PGS             und (Undetermined)      5822.650                32                      23,259,690      129,443
00002.M2TS      4610 (0x1202)   0x90            PGS             und (Undetermined)      5822.650                35                      25,221,025      140,072
00002.M2TS      4611 (0x1203)   0x90            PGS             und (Undetermined)      5822.650                30                      21,778,604      121,421
00002.M2TS      4612 (0x1204)   0x90            PGS             und (Undetermined)      5822.650                29                      20,969,952      117,004
post #1304 of 1971 Old 01-18-2009, 01:15 AM
PeterTHX's Avatar
Quoted: 568 Post(s)
Liked: 427
How do you know if it affects picture quality?
I'm annoyed Paramount doesn't include the ORIGINAL cuts of their films because they don't use branching.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #1305 of 1971 Old 01-18-2009, 01:35 AM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Creating 2 separate encodes for different cuts of the movie without seamless branching is fine as long as the bit rates aren't compromised. However, encoding at very low bit rates to squeeze 2 encodes onto one disc definitely affects the overall PQ.
Classic examples are
1) I am Legend
2) Dark City
3) Wedding Crashers
Blu-ray : 340
lgans316 is offline
post #1306 of 1971 Old 01-18-2009, 07:32 AM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Code:
        Total   Video
Badder Santa (Unrated)                                          VC-1    1:39:16 22,719,553,536  47,850,966,670  30.51   23.72   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Bad Santa (Director's Cut)                                      AVC     1:28:31 20,620,677,120  47,850,966,670  31.06   23.95   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Unrated
Code:
DISC INFO:
Disc Title:     BST1NND1_BADDERSANTA
Disc Size:      47,850,966,670 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 1:39:16 (h:m:s)
Total Bitrate:          30.51 Mbps
Description:
VIDEO:
VC-1 Video              23721 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         48.530 kbps
FILES:
00076.M2TS      0:00:00.000     1:39:16.408     22,719,553,536  30,514
CHAPTERS:
1               0:00:00.000     0:07:31.325     21,446 kbps     41,847 kbps     00:03:43.348    32,520 kbps     00:04:17.006    30,666 kbps     00:02:56.092    111,798 bytes   597,100 bytes   00:03:09.898
2               0:07:31.325     0:04:31.396     24,615 kbps     51,541 kbps     00:10:46.937    36,378 kbps     00:11:01.452    34,765 kbps     00:11:01.327    128,333 bytes   605,832 bytes   00:09:59.390
3               0:12:02.722     0:04:07.205     24,298 kbps     43,495 kbps     00:12:29.498    36,390 kbps     00:12:43.721    35,092 kbps     00:12:12.815    126,677 bytes   532,792 bytes   00:14:56.312
4               0:16:09.927     0:03:25.496     30,504 kbps     47,768 kbps     00:16:26.860    36,355 kbps     00:16:26.860    35,057 kbps     00:16:26.860    159,034 bytes   513,920 bytes   00:16:27.152
5               0:19:35.424     0:03:58.112     30,314 kbps     47,947 kbps     00:20:29.186    37,126 kbps     00:19:37.259    34,590 kbps     00:20:25.015    158,044 bytes   581,299 bytes   00:19:41.138
6               0:23:33.537     0:04:35.817     22,117 kbps     39,031 kbps     00:24:23.962    29,182 kbps     00:25:39.120    28,390 kbps     00:25:38.495    115,308 bytes   507,701 bytes   00:25:52.592
7               0:28:09.354     0:03:32.212     20,628 kbps     36,723 kbps     00:31:26.759    25,406 kbps     00:29:38.193    23,820 kbps     00:30:41.506    107,543 bytes   475,519 bytes   00:28:24.244
8               0:31:41.566     0:05:29.328     24,301 kbps     51,490 kbps     00:36:52.960    35,943 kbps     00:35:22.703    30,698 kbps     00:35:17.698    126,694 bytes   584,903 bytes   00:32:55.848
9               0:37:10.895     0:07:25.236     23,433 kbps     43,074 kbps     00:42:35.177    33,133 kbps     00:42:17.284    31,360 kbps     00:42:25.668    122,170 bytes   528,903 bytes   00:43:02.413
10              0:44:36.131     0:04:11.167     23,347 kbps     41,274 kbps     00:44:43.222    34,344 kbps     00:46:15.314    33,003 kbps     00:46:10.434    121,718 bytes   561,962 bytes   00:44:43.263
11              0:48:47.299     0:04:35.108     20,491 kbps     42,629 kbps     00:49:22.209    27,581 kbps     00:52:28.144    25,495 kbps     00:52:24.057    106,833 bytes   511,726 bytes   00:52:39.865
12              0:53:22.407     0:05:20.903     25,957 kbps     49,885 kbps     00:56:11.534    33,647 kbps     00:56:11.534    31,699 kbps     00:56:11.534    135,330 bytes   631,711 bytes   00:55:16.354
13              0:58:43.311     0:05:20.153     24,999 kbps     48,057 kbps     01:01:12.877    35,389 kbps     01:01:09.040    32,928 kbps     01:01:05.995    130,335 bytes   574,624 bytes   01:03:52.370
14              1:04:03.464     0:05:13.479     24,684 kbps     50,416 kbps     01:04:38.875    36,019 kbps     01:05:00.271    34,860 kbps     01:04:55.766    128,690 bytes   510,136 bytes   01:09:06.559
15              1:09:16.944     0:06:50.785     22,758 kbps     48,008 kbps     01:10:46.909    31,967 kbps     01:10:03.365    29,643 kbps     01:10:46.909    118,649 bytes   519,338 bytes   01:09:56.442
16              1:16:07.729     0:05:51.350     22,864 kbps     44,269 kbps     01:21:19.791    30,673 kbps     01:18:54.438    29,417 kbps     01:18:55.272    119,203 bytes   520,063 bytes   01:20:26.696
17              1:21:59.080     0:05:08.933     23,992 kbps     44,609 kbps     01:26:54.459    31,070 kbps     01:22:00.248    28,792 kbps     01:22:00.916    125,084 bytes   571,407 bytes   01:22:25.899
18              1:27:08.014     0:07:54.098     24,761 kbps     45,748 kbps     01:28:43.192    31,940 kbps     01:29:45.797    27,881 kbps     01:30:31.342    129,093 bytes   607,739 bytes   01:33:02.994
19              1:35:02.113     0:04:14.295     17,390 kbps     35,944 kbps     01:38:07.047    34,444 kbps     01:38:06.881    34,029 kbps     01:38:03.210    90,681 bytes    427,226 bytes   01:38:29.153
STREAM DIAGNOSTICS:
00076.M2TS      4113 (0x1011)   0xEA            VC-1                                    5956.284                23,722                  17,661,837,904  96,074,406
00076.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           5956.284                4,614                   3,435,657,288   19,060,512
00076.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5956.284                640                     476,513,280     2,792,070
00076.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5956.284                49                      36,133,296      204,458
Director's Cut
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 1:28:31 (h:m:s)
Total Bitrate:          31.06 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        23954 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
SUBTITLES:
Presentation Graphics           English         43.998 kbps
Presentation Graphics           English         60.044 kbps
FILES:
00133.M2TS      0:00:00.000     0:50:27.691     12,047,714,304  31,833
00134.M2TS      0:50:27.691     0:38:04.073     8,572,962,816   30,027
CHAPTERS:
1               0:00:00.000     0:08:19.749     26,350 kbps     34,058 kbps     00:08:17.079    32,874 kbps     00:03:58.112    32,785 kbps     00:00:46.671    137,363 bytes   454,088 bytes   00:08:17.747
2               0:08:19.749     0:01:37.347     25,470 kbps     33,522 kbps     00:09:26.148    32,838 kbps     00:09:11.467    32,771 kbps     00:09:06.462    132,790 bytes   358,218 bytes   00:09:10.841
3               0:09:57.096     0:03:42.513     28,208 kbps     33,953 kbps     00:11:06.832    32,891 kbps     00:11:03.120    32,796 kbps     00:10:58.032    147,063 bytes   371,814 bytes   00:10:48.481
4               0:13:39.610     0:05:34.208     26,626 kbps     34,127 kbps     00:16:02.503    32,952 kbps     00:16:42.334    32,546 kbps     00:13:40.444    138,815 bytes   376,599 bytes   00:13:46.617
5               0:19:13.819     0:04:18.049     22,294 kbps     33,583 kbps     00:23:08.845    29,446 kbps     00:22:46.823    26,738 kbps     00:22:44.738    116,230 bytes   337,812 bytes   00:20:00.532
6               0:23:31.868     0:03:35.506     24,739 kbps     35,270 kbps     00:26:44.477    32,724 kbps     00:25:50.924    31,170 kbps     00:26:35.719    128,976 bytes   357,531 bytes   00:26:45.395
7               0:27:07.375     0:04:31.437     25,123 kbps     33,801 kbps     00:30:05.094    32,883 kbps     00:30:00.173    32,766 kbps     00:29:56.377    130,979 bytes   367,772 bytes   00:31:36.436
8               0:31:38.813     0:04:07.121     21,287 kbps     29,367 kbps     00:35:44.934    26,178 kbps     00:33:35.847    25,148 kbps     00:34:18.973    110,981 bytes   335,930 bytes   00:35:45.434
9               0:35:45.935     0:04:34.691     27,089 kbps     33,769 kbps     00:35:46.227    32,784 kbps     00:38:58.627    32,572 kbps     00:39:00.671    141,227 bytes   366,835 bytes   00:35:46.435
10              0:40:20.626     0:04:01.532     19,259 kbps     37,234 kbps     00:44:20.032    26,618 kbps     00:44:16.111    22,403 kbps     00:44:11.106    100,405 bytes   447,349 bytes   00:44:20.783
11              0:44:22.159     0:03:30.668     24,585 kbps     33,791 kbps     00:47:28.136    32,720 kbps     00:45:10.124    32,371 kbps     00:45:08.247    128,173 bytes   351,528 bytes   00:45:09.289
12              0:47:52.828     0:05:48.181     25,250 kbps     33,626 kbps     00:52:03.829    32,847 kbps     00:52:26.393    31,719 kbps     00:50:27.649    131,644 bytes   329,121 bytes   00:51:37.302
13              0:53:41.009     0:02:53.256     26,482 kbps     33,991 kbps     00:54:16.670    32,905 kbps     00:54:16.670    32,783 kbps     00:54:10.497    138,066 bytes   344,593 bytes   00:54:18.505
14              0:56:34.265     0:05:55.104     23,975 kbps     33,973 kbps     00:58:54.697    32,894 kbps     01:01:17.924    32,767 kbps     00:59:25.228    124,995 bytes   363,854 bytes   00:59:18.680
15              1:02:29.370     0:05:02.385     23,618 kbps     44,642 kbps     01:05:41.520    32,824 kbps     01:02:46.679    30,758 kbps     01:02:45.178    123,134 bytes   545,084 bytes   01:05:42.146
16              1:07:31.756     0:04:27.767     22,258 kbps     33,756 kbps     01:11:08.639    32,851 kbps     01:10:45.032    32,439 kbps     01:10:44.198    116,041 bytes   351,671 bytes   01:10:47.451
17              1:11:59.523     0:04:53.876     22,544 kbps     29,898 kbps     01:15:48.126    28,114 kbps     01:15:54.633    27,354 kbps     01:15:48.126    117,533 bytes   302,970 bytes   01:11:59.857
18              1:16:53.400     0:07:24.819     23,301 kbps     38,311 kbps     01:21:31.177    32,953 kbps     01:21:45.233    32,834 kbps     01:21:41.187    121,479 bytes   452,708 bytes   01:21:31.761
19              1:24:18.219     0:04:13.544     15,762 kbps     25,902 kbps     01:28:28.803    21,839 kbps     01:28:25.550    18,266 kbps     01:24:49.584    82,190 bytes    224,124 bytes   01:24:59.260
STREAM DIAGNOSTICS:
00133.M2TS      4113 (0x1011)   0x1B            AVC                                     3027.566                24,690                  9,343,825,376   50,824,256
00133.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           3027.566                4,615                   1,746,374,476   9,688,624
00133.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           3027.566                640                     242,216,960     1,419,240
00133.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           3027.566                192                     72,665,088      473,080
00133.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           3027.566                48                      18,332,538      103,882
00133.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           3027.566                65                      24,639,689      137,958
00134.M2TS      4113 (0x1011)   0x1B            AVC                                     2283.907                22,982                  6,561,186,658   35,690,767
00134.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           2283.907                4,615                   1,317,454,460   7,309,040
00134.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2283.907                640                     182,727,680     1,070,670
00134.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           2283.907                192                     54,818,304      356,890
00134.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2283.907                38                      10,880,836      61,748
00134.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           2283.907                53                      15,227,782      85,193
Weird bitrate graph for the DC. I remember seeing a review praising the AVC DC encode and saying how the VC-1 encode was terrible. 1' from my monitor they look pretty much identical to me.
Edit:
Bland and noisy, The 'Badder Santa' VC-1 encode looks only slightly better than an upscaled presentation of the previously-released standard DVD. Thankfully, the AVC Director's Cut looks a lot better, boasting vibrant colors, deep blacks, and crisp details.
(Note that the conflicting quality of the two transfers on this disc should not be interpreted as a technical fault or merit of either codec. The problems with the VC-1 encoded 'Badder Santa' transfer are a result of the transfer source, not the codec used to compress that source.)
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #1307 of 1971 Old 01-18-2009, 02:08 PM
Quoted: 591 Post(s)
Liked: 606
In my experience of watching hundreds of Blu-rays for comparison, flawless compression encodes are typically seen when the newer video codecs (VC-1 and AVC) are used in the 27 to 35 Mbps range at a minimum unless you are dealing with very easy to compress material. All I want is as much transparency to the studio master that is possible within the limits of the Blu-ray specifications.
I do not like it either when studios abandon original theatrical cuts, but my solution would be to include two discs, with each cut on its own separate disc. I realize this is a business for the studios though and few of them are willing to make that a reality (though there are a few examples of it). Seamless branching is fine if the studio decides to move all extras to a second disc and eliminates any BD-Live features.
post #1308 of 1971 Old 01-18-2009, 02:43 PM
Gregor Samsa's Avatar
Disc Title: SOP_P2
Disc Size: 46,235,641,203 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.1
Notes:
BDINFO HOME AND REPORTS SUBMISSION:
Cinema Squid
http://www.cinemasquid.com/Tools.aspx
INCLUDES FORUMS REPORT FOR:
https://www.avsforum.com/avs-vb/showthread.php?t=760714
http://forum.blu-ray.com/showthread.php?t=3338
PLAYLIST: 00004.MPLS
<--- BEGIN SUMMARY PASTE --->
Code:
        Total   Video
00004.MPLS                                                      AVC     1:55:51 32,588,949,504  46,235,641,203  37.50   25.28   Dolby TrueHD 5.1 2909Kbps (48kHz/24-bit)
<---- END SUMMARY PASTE ---->
<--- BEGIN DETAILS PASTE --->
Code:
DISC INFO:
Disc Title:     SOP_P2
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 1:55:51 (h:m:s)
Total Bitrate:          37.50 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        25283 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         2909 kbps       5.1 / 48 kHz / 2909 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              French          1257 kbps       5.1 / 48 kHz / 1257 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              Portuguese      1194 kbps       5.1 / 48 kHz / 1194 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
SUBTITLES:
Presentation Graphics           English         49.213 kbps
Presentation Graphics           English         40.984 kbps
Presentation Graphics           Chinese         33.308 kbps
Presentation Graphics           French          39.798 kbps
Presentation Graphics           German          47.863 kbps
Presentation Graphics           German          52.918 kbps
Presentation Graphics           Korean          29.206 kbps
Presentation Graphics           Portuguese      45.979 kbps
Presentation Graphics           Portuguese      49.826 kbps
Presentation Graphics           Spanish         43.420 kbps
Presentation Graphics           Thai            41.925 kbps
Presentation Graphics           Turkish         45.851 kbps
FILES:
00262.M2TS      0:00:00.000     1:55:51.986     32,588,949,504  37,502
CHAPTERS:
1               0:00:00.000     0:05:25.450     24,008 kbps     32,608 kbps     00:03:44.933    30,439 kbps     00:03:40.929    30,007 kbps     00:03:35.924    125,153 bytes   640,750 bytes   00:04:10.833
2               0:05:25.450     0:07:15.476     23,950 kbps     42,133 kbps     00:06:26.511    32,021 kbps     00:06:22.507    30,699 kbps     00:08:14.619    124,865 bytes   629,951 bytes   00:07:24.444
3               0:12:40.926     0:08:35.890     23,735 kbps     41,678 kbps     00:20:34.775    32,165 kbps     00:20:30.771    30,360 kbps     00:19:59.781    123,743 bytes   563,596 bytes   00:20:14.087
4               0:21:16.817     0:05:34.167     24,565 kbps     36,186 kbps     00:24:46.443    30,468 kbps     00:22:45.280    30,116 kbps     00:22:40.359    128,069 bytes   537,322 bytes   00:25:58.098
5               0:26:50.984     0:03:38.843     28,735 kbps     31,699 kbps     00:28:17.737    30,161 kbps     00:27:19.971    29,978 kbps     00:27:14.924    149,812 bytes   250,168 bytes   00:28:59.404
6               0:30:29.828     0:06:07.366     28,161 kbps     36,530 kbps     00:36:07.582    31,073 kbps     00:36:03.578    30,342 kbps     00:32:34.202    146,818 bytes   512,769 bytes   00:31:18.376
7               0:36:37.194     0:09:57.597     25,709 kbps     43,950 kbps     00:39:44.173    32,649 kbps     00:39:40.169    31,237 kbps     00:39:35.164    134,035 bytes   575,553 bytes   00:41:56.889
8               0:46:34.792     0:06:51.160     28,187 kbps     40,559 kbps     00:52:20.345    31,449 kbps     00:47:44.611    30,422 kbps     00:47:31.598    146,953 bytes   316,982 bytes   00:49:27.005
9               0:53:25.952     0:08:55.993     27,484 kbps     40,291 kbps     00:59:57.176    31,952 kbps     00:59:53.214    30,867 kbps     00:59:48.126    143,288 bytes   574,278 bytes   00:58:04.606
10              1:02:21.946     0:08:06.360     26,164 kbps     34,981 kbps     01:04:05.132    30,465 kbps     01:03:56.332    30,109 kbps     01:03:43.319    136,409 bytes   594,461 bytes   01:02:50.641
11              1:10:28.307     0:05:18.234     17,477 kbps     32,629 kbps     01:11:44.466    30,362 kbps     01:11:40.462    29,906 kbps     01:14:37.306    91,115 bytes    487,867 bytes   01:11:49.638
12              1:15:46.542     0:06:31.516     24,200 kbps     39,811 kbps     01:17:18.425    31,997 kbps     01:17:14.421    30,825 kbps     01:17:09.416    126,169 bytes   622,305 bytes   01:21:34.764
13              1:22:18.058     0:07:43.963     21,931 kbps     43,057 kbps     01:27:24.280    32,063 kbps     01:27:20.276    30,969 kbps     01:27:15.271    114,341 bytes   600,265 bytes   01:27:05.011
14              1:30:02.021     0:09:33.155     26,999 kbps     42,643 kbps     01:33:30.438    31,505 kbps     01:34:40.675    30,671 kbps     01:34:35.670    140,762 bytes   936,548 bytes   01:33:34.025
15              1:39:35.177     0:06:46.823     26,020 kbps     30,985 kbps     01:41:00.137    30,087 kbps     01:40:56.133    29,973 kbps     01:43:24.114    135,659 bytes   603,040 bytes   01:39:57.199
16              1:46:22.000     0:09:29.986     25,889 kbps     36,729 kbps     01:47:21.184    30,045 kbps     01:47:11.425    29,904 kbps     01:47:06.420    134,983 bytes   431,008 bytes   01:55:47.982
STREAM DIAGNOSTICS:
00262.M2TS      4113 (0x1011)   0x1B            AVC                                     6951.903                25,284                  21,971,078,971  119,504,431
00262.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6951.903                3,549                   3,083,813,722   22,213,591
00262.M2TS      4353 (0x1101)   0x83            TrueHD          fra (French)            6951.903                1,897                   1,648,577,032   12,017,968
00262.M2TS      4354 (0x1102)   0x83            TrueHD          por (Portuguese)        6951.903                1,834                   1,593,958,110   12,113,603
00262.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6951.903                192                     166,848,000     1,086,250
00262.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6951.903                49                      42,765,874      240,891
00262.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6951.903                41                      35,615,052      202,863
00262.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6951.903                40                      34,584,042      197,415
00262.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            6951.903                48                      41,593,209      236,694
00262.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        6951.903                46                      39,955,282      225,965
00262.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           6951.903                43                      37,731,553      213,894
00262.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           6951.903                33                      28,944,747      166,022
00262.M2TS      4615 (0x1207)   0x90            PGS             kor (Korean)            6951.903                29                      25,379,654      146,890
00262.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              6951.903                42                      36,432,527      206,926
00262.M2TS      4617 (0x1209)   0x90            PGS             tur (Turkish)           6951.903                46                      39,844,785      225,380
00262.M2TS      4618 (0x120A)   0x90            PGS             deu (German)            6951.903                53                      45,985,595      258,472
00262.M2TS      4619 (0x120B)   0x90            PGS             por (Portuguese)        6951.903                50                      43,298,660      243,919
<---- END DETAILS PASTE ---->
Taxes are the price we pay to live in civilization. If you don't like government, move to Somalia.
Gregor Samsa is offline
post #1309 of 1971 Old 01-18-2009, 03:47 PM
Disc Title: BRANDENBURGISCHE KONZERTE
Disc Size: 22,770,908,248 bytes
Protection: AACS
BD-Java: No
BDInfo: 0.5.1
Notes:
Cinema Squid
PLAYLIST: 00000.MPLS
Code:
        Total   Video
00000.MPLS                                                      AVC     1:39:32 22,199,894,016  22,770,908,248  29.74   21.94   LPCM 5.1 4608Kbps (48kHz/16-bit)          LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 1:39:32 (h:m:s)
Total Bitrate:          29.74 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        21939 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      German          4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
LPCM Audio                      German          1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
FILES:
00000.M2TS      0:00:00.000     1:39:15.950     22,197,835,776  29,816
00015.M2TS      1:39:15.950     0:00:09.009     976,896         867
00016.M2TS      1:39:24.959     0:00:07.307     1,069,056       1,170
00002.M2TS      1:39:32.266     0:00:00.333     12,288          295
CHAPTERS:
1               0:00:00.000     0:00:47.047     19,804 kbps     26,884 kbps     00:00:09.409    25,735 kbps     00:00:05.972    25,118 kbps     00:00:02.268    82,542 bytes    276,001 bytes   00:00:04.204
2               0:00:47.047     0:03:49.362     21,034 kbps     30,317 kbps     00:03:01.714    27,487 kbps     00:01:15.108    25,378 kbps     00:01:11.004    87,729 bytes    278,504 bytes   00:02:33.419
3               0:04:36.409     0:03:05.985     20,015 kbps     27,966 kbps     00:07:21.073    25,964 kbps     00:05:03.970    24,962 kbps     00:05:03.770    83,481 bytes    272,542 bytes   00:04:47.387
4               0:07:42.395     0:03:52.699     21,206 kbps     28,836 kbps     00:11:09.402    27,022 kbps     00:11:09.402    25,699 kbps     00:11:05.398    88,445 bytes    277,552 bytes   00:11:34.060
5               0:11:35.094     0:07:14.901     20,987 kbps     32,504 kbps     00:15:56.789    29,239 kbps     00:15:56.789    26,909 kbps     00:15:56.755    87,533 bytes    277,008 bytes   00:14:16.455
6               0:18:49.995     0:05:15.948     21,958 kbps     30,434 kbps     00:22:29.014    28,300 kbps     00:22:26.678    27,370 kbps     00:22:25.610    91,583 bytes    274,516 bytes   00:19:24.796
7               0:24:05.944     0:00:25.291     18,090 kbps     20,925 kbps     00:24:29.801    19,709 kbps     00:24:25.831    19,100 kbps     00:24:21.226    75,449 bytes    246,768 bytes   00:24:23.028
8               0:24:31.236     0:04:38.277     21,571 kbps     31,297 kbps     00:27:08.059    27,884 kbps     00:27:08.026    26,647 kbps     00:25:23.421    89,970 bytes    278,029 bytes   00:28:59.637
9               0:29:09.514     0:08:51.631     21,496 kbps     30,389 kbps     00:33:00.878    26,985 kbps     00:33:00.445    25,740 kbps     00:29:37.709    89,658 bytes    278,509 bytes   00:34:34.005
10              0:38:01.145     0:05:03.036     20,720 kbps     27,881 kbps     00:42:36.987    24,552 kbps     00:42:32.983    23,719 kbps     00:40:04.835    86,418 bytes    270,730 bytes   00:40:21.719
11              0:43:04.181     0:05:08.241     22,158 kbps     30,188 kbps     00:43:58.702    25,622 kbps     00:43:54.565    24,840 kbps     00:43:55.165    92,417 bytes    277,293 bytes   00:47:21.104
12              0:48:12.422     0:05:53.019     21,690 kbps     29,414 kbps     00:51:34.891    25,961 kbps     00:48:18.328    24,355 kbps     00:48:13.323    90,464 bytes    278,025 bytes   00:51:23.013
13              0:54:05.442     0:04:50.023     20,365 kbps     26,985 kbps     00:55:00.797    23,864 kbps     00:56:46.836    23,203 kbps     00:54:58.061    84,939 bytes    275,816 bytes   00:54:09.913
14              0:58:55.465     0:05:36.135     21,334 kbps     28,646 kbps     01:02:37.520    25,367 kbps     01:04:07.510    24,810 kbps     01:03:51.761    88,980 bytes    277,706 bytes   01:03:54.363
15              1:04:31.601     0:06:55.715     24,762 kbps     34,051 kbps     01:10:01.931    30,426 kbps     01:06:10.566    28,300 kbps     01:07:22.071    103,277 bytes   278,832 bytes   01:09:48.584
16              1:11:27.316     0:03:49.562     23,317 kbps     29,523 kbps     01:15:04.600    28,867 kbps     01:15:01.663    27,713 kbps     01:14:59.061    97,252 bytes    279,780 bytes   01:11:50.239
17              1:15:16.879     0:05:08.207     23,427 kbps     31,234 kbps     01:16:22.411    27,953 kbps     01:16:22.644    26,871 kbps     01:18:11.987    97,711 bytes    278,293 bytes   01:19:12.581
18              1:20:25.086     0:04:45.485     22,656 kbps     32,944 kbps     01:24:20.855    30,197 kbps     01:24:20.655    27,625 kbps     01:21:49.604    94,493 bytes    277,376 bytes   01:24:09.177
19              1:25:10.572     0:03:48.628     21,923 kbps     33,881 kbps     01:26:46.267    30,491 kbps     01:26:44.032    28,591 kbps     01:26:40.428    91,438 bytes    277,598 bytes   01:26:59.480
20              1:28:59.200     0:04:50.289     23,625 kbps     31,382 kbps     01:33:24.398    28,748 kbps     01:32:35.816    28,081 kbps     01:32:35.816    98,538 bytes    277,178 bytes   01:29:41.275
21              1:33:49.490     0:03:02.749     22,659 kbps     32,188 kbps     01:35:15.176    28,932 kbps     01:35:14.942    27,087 kbps     01:34:18.886    94,506 bytes    278,185 bytes   01:35:57.251
22              1:36:52.239     0:02:40.360     21,695 kbps     30,117 kbps     01:37:52.633    28,915 kbps     01:37:52.199    28,419 kbps     01:37:51.665    90,503 bytes    278,029 bytes   01:37:52.900
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5955.850                21,999                  16,377,574,790  89,201,942
00000.M2TS      4352 (0x1100)   0x80            LPCM            deu (German)            5955.850                1,543                   1,148,571,296   7,148,784
00000.M2TS      4353 (0x1101)   0x80            LPCM            deu (German)            5955.850                4,616                   3,436,182,176   19,063,424
00015.M2TS      4113 (0x1011)   0x1B            AVC                                     8.909                   759                     844,728         4,762
00016.M2TS      4113 (0x1011)   0x1B            AVC                                     7.207                   1,025                   923,122         5,303
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     0.200                   244                     6,107           41
post #1310 of 1971 Old 01-18-2009, 03:58 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Thanks for the postings Gregor, I look forward to any others.
post #1311 of 1971 Old 01-18-2009, 04:17 PM
BDInfo v.0.5.2 is now posted for download (with source).
The changes:
  • Fixed bug that prevented detection of BD+ with newer revisions of AnyDVD HD.
  • Fixed bug that prevented proper stream identification for certain playlists.
  • Added setting to preserve original stream ordering.
  • Added quick playlist summary output to the text report.
  • Added "rescan" button to refresh disc contents from last folder scanned.
  • Added feature to remember the last folder scanned between BDInfo sessions.
  • Added default filename to chart image save screen.
Note that the "quick playlist summary" output is a return of the previous summary text that some found useful for easily pasting/publishing elsewhere and you'll find it tucked away at the end of each playlist in the text report. It should be enabled by default, but there is option to toggle it on/off in the settings screen.
post #1312 of 1971 Old 01-18-2009, 10:22 PM
I'm a noob at this, so I hope I didn't **** it up too bad. These were the first I'd come across that weren't already posted. If just a bit of editorializing is OK, the Brandenburg is superb. It doesn't get a lot of love on Netflix, but it's can't miss for Bach fans. Visually, not much classical music is exciting, but the venue is gorgeous, the director keeps the camera moving and the people playing it are generally attractive.
The LPCM is nicely done too.
I'll post more if I find more that aren't already here. The software appears to be flawless; not sure what the update will help, but I'll get it anyway.
Now that I have previewed this, I see I have been censored. Really, some words have multiple meanings. To the British, this isn't particularly obscene, it's just an expression. Slightly rude, but not as offensive as the nanny software here would imply.
post #1313 of 1971 Old 01-18-2009, 10:37 PM
Thanks very much for the contributions Gregor. It's always good to see the numbers and specs for titles, even if they don't mean an awful lot in the grand scheme of things. I believe that the core of the BDInfo software (i.e. bitrate collection) has been relatively stable for a little while, so newer versions are meant to address specific problematic titles or to add minor tweaks to the user interface which should not invalidate previous measurements. Of course, the latest version is recommended but in almost all cases you should see identical results if you rescan a title.
Now that makes me slightly f*ing curious.
post #1314 of 1971 Old 01-19-2009, 06:45 AM
http://www.worldwidewords.org/qa/qa-coc1.htm
post #1315 of 1971 Old 01-19-2009, 11:42 AM
Phloyd's Avatar
Just to clarify - this is the Johann Sebastian Bach: Brandenburg Concertos 1-6 [Blu-ray] (2007) directed by Andreas Morell ?
Phloyd is offline
post #1316 of 1971 Old 01-19-2009, 11:51 AM
mpgxsvcd's Avatar
Quoted: 2957 Post(s)
Liked: 2617
How do I produce the cool little chart for the disc specs? I got the Divertimenti disk and I would like to add its specs.
It appears that we will have to add three new categories for this disk. It contains 192Khz 24 Bit 5.1 Channel audio in DTS-MA, DD-TrueHD, and LPCM formats.
http://www.amazon.com/Divertimenti-H...2136955&sr=8-1
mpgxsvcd is offline
post #1317 of 1971 Old 01-19-2009, 07:14 PM
I honestly don't know what kind of nuances there might be to some of these Blu-ray audio-only titles. I assume that they are at least AACS-protected, so you will likely need to feed it through an AACS decoder such as AnyDVD HD before attempting to scan in something like BDInfo or eac3to. If there is no video track, then you will not be able to print a bitrate chart since BDInfo does not currently support printing an audio bitrate chart.
I would not be surprised if BDInfo has difficulty with these since there may be assumptions that a video track is present in several places in the code. I am very curious to know about this, however, so if you run into problems with a 2-L or Surround Records title, let me know! The eac3to program is likely much more robust to these titles, so results from that program would also be much appreciated.
post #1318 of 1971 Old 01-19-2009, 08:26 PM
mpgxsvcd's Avatar
Liked: 2617
It is weird. I get a "The volume does not contain a recognized file system" error for every disc except for Spiderman 3 with BDInfo. My drives always show up as CD drives for the ones that do not work with BDInfo. I can play those .iso files with PDVD and TMT though. I have also tried the original discs and those give the same error message.
Have you seen that error before? I couldn't figure out how to make eac3to work. I would love to post the info for a number of new discs that I have I just can not get the programs to work.
mpgxsvcd is offline
post #1319 of 1971 Old 01-20-2009, 04:45 PM
That's an odd one - I haven't seen that error before. I'm not sure what would be causing that.
post #1320 of 1971 Old 01-20-2009, 04:46 PM
The Mummy: Tomb of the Dragon Emperor
Code:
        Total   Video
The Mummy: Tomb of the Dragon Emperor                           AVC     1:51:47 29,724,383,232  45,580,396,319  35.45   24.11   DTS-HD Master 5.1 4387Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     MUMMY_3TODE
Disc Size:      45,580,396,319 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:51:47 (h:m:s)
Total Bitrate:          35.45 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        24110 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        757 kbps            480p / 23.976 fps / 16:9 / High Profile 3.2
MPEG-4 AVC Video        2008 kbps           480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         4387 kbps       5.1 / 48 kHz / 4387 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Express                     English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         26.752 kbps
Presentation Graphics           French          24.749 kbps
Presentation Graphics           French          2.910 kbps
Presentation Graphics           Spanish         19.697 kbps
Presentation Graphics           Spanish         2.536 kbps
FILES:
00220.M2TS      0:00:00.000     1:51:47.742     29,724,383,232  35,451
CHAPTERS:
1               0:00:00.000     0:05:24.073     22,889 kbps     34,553 kbps     00:02:35.446    30,151 kbps     00:02:59.095    29,172 kbps     00:02:42.537    119,317 bytes   350,324 bytes   00:04:22.011
2               0:05:24.073     0:04:28.059     25,692 kbps     35,308 kbps     00:06:32.100    33,425 kbps     00:09:39.203    32,423 kbps     00:09:41.038    133,944 bytes   388,791 bytes   00:07:02.505
3               0:09:52.133     0:04:23.346     23,962 kbps     35,643 kbps     00:10:36.761    33,402 kbps     00:10:07.690    33,261 kbps     00:10:03.561    124,927 bytes   446,912 bytes   00:10:21.579
4               0:14:15.479     0:04:57.922     24,842 kbps     33,703 kbps     00:17:11.071    33,077 kbps     00:14:15.479    30,412 kbps     00:17:09.862    129,513 bytes   344,132 bytes   00:15:40.731
5               0:19:13.402     0:05:20.278     24,035 kbps     34,598 kbps     00:24:23.712    33,410 kbps     00:24:23.587    32,720 kbps     00:24:23.128    125,305 bytes   321,708 bytes   00:24:33.680
6               0:24:33.680     0:06:23.966     23,985 kbps     34,787 kbps     00:24:36.975    33,238 kbps     00:26:34.509    33,123 kbps     00:26:29.879    125,047 bytes   377,612 bytes   00:30:57.647
7               0:30:57.647     0:04:33.314     24,724 kbps     34,231 kbps     00:32:16.392    33,113 kbps     00:32:14.140    31,678 kbps     00:32:09.260    128,899 bytes   406,346 bytes   00:31:10.660
8               0:35:30.962     0:06:45.404     23,259 kbps     36,109 kbps     00:41:29.570    32,162 kbps     00:38:56.125    29,610 kbps     00:38:50.494    121,262 bytes   294,451 bytes   00:36:56.380
9               0:42:16.367     0:06:01.319     24,580 kbps     36,156 kbps     00:44:17.821    33,312 kbps     00:48:12.681    31,640 kbps     00:44:10.898    128,148 bytes   281,129 bytes   00:48:00.294
10              0:48:17.686     0:04:09.207     23,113 kbps     33,501 kbps     00:48:21.023    32,358 kbps     00:48:17.686    29,676 kbps     00:48:17.686    120,503 bytes   335,098 bytes   00:51:58.990
11              0:52:26.893     0:05:01.634     22,756 kbps     33,592 kbps     00:52:51.918    33,024 kbps     00:52:47.914    30,902 kbps     00:54:17.295    118,638 bytes   375,811 bytes   00:54:22.926
12              0:57:28.528     0:05:12.061     25,852 kbps     36,129 kbps     00:59:05.583    33,324 kbps     00:59:22.225    32,170 kbps     00:58:02.061    134,780 bytes   361,084 bytes   00:58:05.315
13              1:02:40.590     0:07:11.639     24,258 kbps     37,202 kbps     01:04:10.680    33,180 kbps     01:07:33.924    30,559 kbps     01:04:04.799    126,471 bytes   299,800 bytes   01:07:38.054
14              1:09:52.229     0:06:01.986     24,519 kbps     35,053 kbps     01:13:07.633    33,154 kbps     01:10:43.739    32,269 kbps     01:10:39.193    127,829 bytes   425,047 bytes   01:10:56.210
15              1:15:54.216     0:05:06.764     22,305 kbps     37,018 kbps     01:18:45.554    33,518 kbps     01:19:21.131    30,567 kbps     01:19:17.419    116,286 bytes   324,468 bytes   01:18:46.388
16              1:21:00.981     0:04:32.438     24,423 kbps     34,128 kbps     01:23:46.271    32,970 kbps     01:21:42.188    28,285 kbps     01:21:39.185    127,329 bytes   320,711 bytes   01:24:16.092
17              1:25:33.419     0:08:21.542     25,237 kbps     41,361 kbps     01:27:13.561    34,078 kbps     01:28:44.527    33,379 kbps     01:28:39.522    131,574 bytes   346,012 bytes   01:28:23.965
18              1:33:54.962     0:05:58.983     23,876 kbps     36,807 kbps     01:39:05.105    31,562 kbps     01:34:04.347    30,683 kbps     01:34:04.388    124,476 bytes   546,422 bytes   01:38:12.303
19              1:39:53.946     0:01:34.552     22,848 kbps     30,386 kbps     01:41:22.868    27,405 kbps     01:41:21.283    25,322 kbps     01:40:58.177    119,120 bytes   277,290 bytes   01:39:55.864
20              1:41:28.499     0:10:19.243     23,920 kbps     41,430 kbps     01:42:41.446    34,416 kbps     01:42:22.636    33,020 kbps     01:42:23.011    124,717 bytes   884,217 bytes   01:51:45.073
STREAM DIAGNOSTICS:
00220.M2TS      4113 (0x1011)   0x1B            AVC                                     6707.659                24,111                  20,215,683,605  109,961,472
00220.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6707.659                4,387                   3,678,498,928   21,037,315
00220.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           6707.659                768                     643,943,424     3,773,106
00220.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            6707.659                768                     643,943,424     3,773,106
00220.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6707.659                192                     160,985,856     1,048,085
00220.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6707.659                27                      22,430,897      129,465
00220.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6707.659                20                      16,515,392      95,811
00220.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6707.659                25                      20,750,871      119,254
00220.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6707.659                3                       2,126,081       12,494
00220.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6707.659                3                       2,439,605       14,217
00220.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           6707.659                192                     160,987,136     943,284
00220.M2TS      6657 (0x1A01)   0xA2            DTS Express     eng (English)           6707.659                192                     160,987,136     943,284
00220.M2TS      6912 (0x1B00)   0x1B            AVC                                     6707.659                757                     634,602,528     3,497,875
00220.M2TS      6913 (0x1B01)   0x1B            AVC                                     6707.659                2,008                   1,683,877,885   9,240,997
Closed Thread Blu-ray Software
