Unofficial Blu-ray Audio and Video Specifications Thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
post #1441 of 1971 Old 02-23-2009, 09:13 PM
Phloyd's Avatar
Disc Title: Super Speedway
Case is incorrectly labeled as 1080p - stupid Image Entertainment!
Highish bitrate though... but these IMAX never look as good as they should IMHO...
Screen Caps Here
UPC 014381511550
Code:
        Total   Video
Super Speedway                                                  AVC     0:49:41 14,131,648,512  21,014,998,091  37.91   30.28   DTS-HD Master 5.1 4348Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Size:      21,014,998,091 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 0:49:41 (h:m:s)
Total Bitrate:          37.91 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        30278 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4348 kbps       5.1 / 48 kHz / 4348 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
FILES:
00010.M2TS      0:00:00.000     0:49:41.979     14,131,648,512  37,912
CHAPTERS:
1               0:00:00.000     0:03:36.516     29,497 kbps     52,192 kbps     00:01:41.568    34,047 kbps     00:03:06.819    33,590 kbps     00:03:01.548    123,007 bytes   559,000 bytes   00:01:42.035
2               0:03:36.516     0:05:42.442     29,712 kbps     53,921 kbps     00:09:16.822    36,587 kbps     00:09:12.752    32,991 kbps     00:09:08.147    123,924 bytes   658,045 bytes   00:09:16.956
3               0:09:18.958     0:04:56.362     30,785 kbps     41,007 kbps     00:10:45.244    37,436 kbps     00:10:44.777    35,584 kbps     00:10:43.609    128,398 bytes   464,472 bytes   00:09:58.364
4               0:14:15.321     0:01:26.419     27,504 kbps     36,269 kbps     00:14:35.841    33,957 kbps     00:14:31.837    32,671 kbps     00:14:26.799    114,713 bytes   465,667 bytes   00:15:41.707
5               0:15:41.740     0:05:52.285     32,179 kbps     41,709 kbps     00:20:18.984    36,747 kbps     00:19:34.540    35,361 kbps     00:18:41.186    134,213 bytes   588,522 bytes   00:15:51.150
6               0:21:34.026     0:03:55.635     29,388 kbps     38,741 kbps     00:24:56.228    34,480 kbps     00:24:34.372    34,051 kbps     00:24:29.968    122,574 bytes   465,966 bytes   00:21:52.611
7               0:25:29.661     0:00:48.481     30,822 kbps     37,571 kbps     00:25:40.805    32,424 kbps     00:25:44.042    31,733 kbps     00:25:40.038    128,553 bytes   440,617 bytes   00:26:09.701
8               0:26:18.143     0:00:44.310     30,220 kbps     34,880 kbps     00:26:33.758    31,209 kbps     00:26:23.081    30,859 kbps     00:26:19.844    126,041 bytes   368,151 bytes   00:26:19.878
9               0:27:02.454     0:02:43.229     31,181 kbps     38,628 kbps     00:29:04.609    34,442 kbps     00:29:10.582    33,903 kbps     00:28:55.400    130,052 bytes   371,494 bytes   00:27:18.770
10              0:29:45.683     0:06:20.279     30,183 kbps     43,733 kbps     00:35:09.474    35,116 kbps     00:35:42.140    33,885 kbps     00:35:40.505    125,889 bytes   440,424 bytes   00:33:28.106
11              0:36:05.963     0:08:34.046     30,531 kbps     42,815 kbps     00:38:06.617    36,759 kbps     00:38:02.613    34,986 kbps     00:37:57.575    127,341 bytes   459,110 bytes   00:36:22.713
12              0:44:40.010     0:05:01.968     29,375 kbps     54,485 kbps     00:48:16.927    36,971 kbps     00:47:18.368    35,449 kbps     00:47:17.901    122,533 bytes   444,828 bytes   00:46:43.734
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0x1B            AVC                                     2981.912                30,279                  11,286,085,091  61,434,555
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2981.912                4,348                   1,620,584,436   9,272,230
00010.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            2981.912                640                     238,558,720     1,397,805
00010.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           2981.912                640                     238,558,720     1,397,805
Phloyd is offline
post #1442 of 1971 Old 02-23-2009, 11:20 PM
Cinema Squid's Avatar
I've noticed as well that the IMAX encodes from Razor Digital and even The Dark Knight seem to be prone to the type of image schmutz seen in your last shot. Not sure if IMAX film stock is extra-electrostatic and more vulnerable to dust blobs, hairs, etc. making it into the scan or what.
Originally Posted by benes View Post
I assume the first playlist is the main feature? Thats the only one we need.
That should be the case. I believe the ~53 minute 00001.MPLS refers to the "American in Pyonyang" supplemental documentary.
Cinema Squid is offline
post #1443 of 1971 Old 02-24-2009, 12:12 AM
Phloyd's Avatar
Disc Title: French Connection
Epic grain - obviously no Warner effect here!
Nice bitrate - extras on a second (not region locked) disc. Feature is region A only.
Screen Caps Here
UPC 024543529897
Code:
        Total   Video
French Connection                                               AVC     1:43:42 32,157,284,352  33,025,288,601  41.34   34.60   DTS-HD Master 5.1 2199Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Size:      33,025,288,601 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:43:42 (h:m:s)
Total Bitrate:          41.34 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        34602 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2199 kbps       5.1 / 48 kHz / 2199 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         41.968 kbps
Presentation Graphics           Chinese         39.320 kbps
Presentation Graphics           Chinese         43.121 kbps
Presentation Graphics           French          0.657 kbps
Presentation Graphics           Spanish         30.866 kbps
Presentation Graphics           Spanish         4.065 kbps
FILES:
00001.M2TS      0:00:00.000     1:43:41.506     32,157,253,632  41,350
00002.M2TS      1:43:41.506     0:00:01.000     30,720          246
CHAPTERS:
1               0:00:00.000     0:00:55.680     13,942 kbps     50,804 kbps     00:00:12.012    37,398 kbps     00:00:08.133    36,804 kbps     00:00:03.128    72,633 bytes    382,791 bytes   00:00:11.928
2               0:00:55.680     0:02:37.073     34,432 kbps     45,436 kbps     00:03:16.821    39,597 kbps     00:01:06.566    37,786 kbps     00:01:53.363    179,511 bytes   520,936 bytes   00:03:12.108
3               0:03:32.754     0:03:50.939     34,909 kbps     42,742 kbps     00:05:08.057    39,996 kbps     00:05:05.430    38,334 kbps     00:05:05.430    181,998 bytes   430,010 bytes   00:05:29.912
4               0:07:23.693     0:02:19.556     35,660 kbps     41,500 kbps     00:07:26.654    38,970 kbps     00:08:59.288    37,850 kbps     00:08:56.619    185,912 bytes   479,127 bytes   00:08:11.574
5               0:09:43.249     0:04:57.714     33,144 kbps     42,127 kbps     00:12:26.954    38,570 kbps     00:11:47.623    37,693 kbps     00:09:53.968    172,799 bytes   623,300 bytes   00:12:57.151
6               0:14:40.963     0:05:56.856     33,984 kbps     49,277 kbps     00:16:09.176    39,724 kbps     00:20:06.205    38,060 kbps     00:15:33.682    177,178 bytes   521,797 bytes   00:19:56.737
7               0:20:37.819     0:02:27.689     35,496 kbps     41,579 kbps     00:20:39.655    39,037 kbps     00:21:27.285    38,221 kbps     00:21:27.286    185,057 bytes   508,558 bytes   00:21:31.248
8               0:23:05.509     0:02:47.625     35,029 kbps     42,740 kbps     00:24:16.788    39,937 kbps     00:25:20.268    37,923 kbps     00:25:16.139    182,623 bytes   464,928 bytes   00:23:06.426
9               0:25:53.134     0:03:39.344     35,059 kbps     45,497 kbps     00:29:18.047    40,447 kbps     00:26:00.642    37,821 kbps     00:26:00.517    182,780 bytes   469,467 bytes   00:29:18.089
10              0:29:32.478     0:03:22.827     34,857 kbps     41,270 kbps     00:29:48.536    38,409 kbps     00:30:47.470    38,030 kbps     00:30:43.341    181,729 bytes   501,184 bytes   00:30:49.389
11              0:32:55.306     0:01:37.972     35,508 kbps     40,446 kbps     00:33:54.741    38,245 kbps     00:34:06.878    37,531 kbps     00:33:45.732    185,121 bytes   438,548 bytes   00:34:33.279
12              0:34:33.279     0:04:52.417     35,577 kbps     43,287 kbps     00:36:08.332    39,408 kbps     00:36:28.811    38,287 kbps     00:36:24.807    185,480 bytes   444,304 bytes   00:36:32.857
13              0:39:25.696     0:01:37.722     35,463 kbps     39,559 kbps     00:39:36.582    38,319 kbps     00:40:00.147    38,076 kbps     00:39:59.397    184,890 bytes   470,407 bytes   00:39:36.624
14              0:41:03.419     0:00:58.266     35,376 kbps     44,789 kbps     00:41:11.302    40,447 kbps     00:41:08.048    37,501 kbps     00:41:29.111    184,436 bytes   513,517 bytes   00:41:11.385
15              0:42:01.685     0:03:27.498     35,175 kbps     43,586 kbps     00:44:40.177    39,056 kbps     00:42:39.723    37,807 kbps     00:44:07.436    183,386 bytes   447,707 bytes   00:44:47.518
16              0:45:29.184     0:06:30.348     34,971 kbps     52,437 kbps     00:50:57.012    40,417 kbps     00:50:57.012    38,348 kbps     00:46:52.226    182,321 bytes   540,652 bytes   00:50:57.054
17              0:51:59.533     0:03:05.143     35,554 kbps     40,822 kbps     00:52:46.496    38,640 kbps     00:53:39.758    37,561 kbps     00:53:37.505    185,361 bytes   443,850 bytes   00:53:29.831
18              0:55:04.676     0:07:12.807     34,841 kbps     42,818 kbps     00:59:33.486    39,400 kbps     00:59:29.774    37,785 kbps     00:59:09.462    181,646 bytes   477,006 bytes   00:57:58.766
19              1:02:17.483     0:02:51.504     35,466 kbps     41,323 kbps     01:03:24.926    39,096 kbps     01:03:42.693    38,329 kbps     01:03:38.856    184,904 bytes   458,617 bytes   01:03:09.869
20              1:05:08.988     0:01:15.992     35,388 kbps     43,988 kbps     01:05:49.695    38,449 kbps     01:05:30.801    37,752 kbps     01:05:29.091    184,498 bytes   466,370 bytes   01:06:24.981
21              1:06:24.980     0:03:43.264     35,597 kbps     47,952 kbps     01:08:15.674    39,714 kbps     01:08:29.688    38,184 kbps     01:08:28.145    185,589 bytes   602,931 bytes   01:08:16.258
22              1:10:08.245     0:06:39.899     35,223 kbps     48,588 kbps     01:15:38.825    40,780 kbps     01:14:02.104    38,093 kbps     01:16:18.657    183,637 bytes   493,757 bytes   01:16:24.705
23              1:16:48.145     0:00:51.676     35,280 kbps     43,621 kbps     01:17:01.575    38,873 kbps     01:17:15.088    37,658 kbps     01:16:53.191    183,935 bytes   448,588 bytes   01:17:02.534
24              1:17:39.821     0:07:14.892     35,233 kbps     51,173 kbps     01:21:06.945    40,647 kbps     01:22:03.418    38,211 kbps     01:23:22.956    183,687 bytes   556,468 bytes   01:24:48.249
25              1:24:54.714     0:03:38.134     35,640 kbps     43,516 kbps     01:26:43.197    39,780 kbps     01:26:43.198    38,097 kbps     01:26:57.211    185,813 bytes   456,328 bytes   01:25:34.712
26              1:28:32.849     0:02:27.397     35,169 kbps     41,278 kbps     01:29:50.676    39,950 kbps     01:29:50.676    37,752 kbps     01:29:50.468    183,356 bytes   482,480 bytes   01:31:00.246
27              1:31:00.246     0:01:33.718     35,489 kbps     39,345 kbps     01:31:31.903    36,721 kbps     01:31:30.860    36,535 kbps     01:31:31.903    185,025 bytes   451,701 bytes   01:31:01.164
28              1:32:33.964     0:03:54.901     34,914 kbps     45,548 kbps     01:32:42.056    40,033 kbps     01:35:15.418    37,967 kbps     01:35:34.019    182,024 bytes   479,261 bytes   01:34:46.430
29              1:36:28.866     0:03:08.479     35,544 kbps     43,832 kbps     01:39:24.249    39,939 kbps     01:39:24.124    37,856 kbps     01:38:04.295    185,310 bytes   508,187 bytes   01:37:49.405
30              1:39:37.346     0:01:52.987     35,331 kbps     46,242 kbps     01:39:58.867    39,975 kbps     01:39:55.531    37,962 kbps     01:40:57.009    184,198 bytes   540,019 bytes   01:40:42.828
31              1:41:30.334     0:00:30.155     31,556 kbps     45,110 kbps     01:41:37.424    39,361 kbps     01:41:36.173    37,146 kbps     01:41:31.168    164,521 bytes   523,724 bytes   01:41:39.009
32              1:42:00.489     0:01:41.017     20,975 kbps     42,726 kbps     01:42:21.802    39,401 kbps     01:42:17.798    37,190 kbps     01:42:14.586    109,354 bytes   525,468 bytes   01:42:35.440
33              1:43:41.506     0:00:01.001     64 kbps         0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    346 bytes       454 bytes       01:43:42.466
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     6221.340                34,608                  26,913,777,300  146,357,366
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6221.340                2,199                   1,710,307,488   10,236,078
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6221.340                224                     174,203,008     972,115
00001.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6221.340                224                     174,203,008     972,115
00001.M2TS      4355 (0x1103)   0x81            AC3             fra (French)            6221.340                448                     348,406,016     1,944,230
00001.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           6221.340                448                     348,406,016     1,944,230
00001.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           6221.340                224                     174,203,008     972,115
00001.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           6221.340                224                     174,203,008     972,115
00001.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           6221.340                448                     348,406,016     1,944,230
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6221.340                42                      32,643,343      185,158
00001.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6221.340                31                      24,007,694      136,511
00001.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           6221.340                39                      30,583,510      173,919
00001.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           6221.340                43                      33,540,357      190,036
00001.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6221.340                1                       511,144         2,901
00001.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           6221.340                4                       3,161,477       17,983
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     0.876                   86                      9,409           61
Phloyd is offline
post #1444 of 1971 Old 02-24-2009, 12:27 AM
Phloyd's Avatar
We saw Chris Nolan write that no Digital camera has as much resolution as film, then we see IMAX, which are huge sheets of film, look soft on Blu-ray.
Something doesn't ring true... there are issues somewhere getting this stuff on to our screens...!
Phloyd is offline
post #1445 of 1971 Old 02-24-2009, 10:01 AM
DigitalfreakNYC's Avatar
Quoted: 127 Post(s)
Code:
        Total   Video
The Fugitive (VC-1)                                             VC-1    2:10:14 22,769,682,432  24,820,265,778  23.31   20.96   DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     THE_FUGITIVE (VC-1)
Disc Size:      24,820,265,778 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 2:10:14 (h:m:s)
Total Bitrate:          23.31 Mbps
Description:
VIDEO:
VC-1 Video              20958 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
Dolby Digital Audio             French          192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         39.120 kbps
Presentation Graphics           English         45.150 kbps
Presentation Graphics           French          33.080 kbps
Presentation Graphics           Spanish         37.300 kbps
FILES:
00000.M2TS      0:00:00.000     2:10:14.306     22,769,682,432  23,311
CHAPTERS:
1               0:00:00.000     0:04:49.414     19,557 kbps     30,575 kbps     00:00:47.380    27,932 kbps     00:01:29.422    27,193 kbps     00:00:46.337    102,138 bytes   261,377 bytes   00:00:48.381
2               0:04:49.414     0:04:49.497     19,657 kbps     27,804 kbps     00:06:14.040    24,852 kbps     00:06:19.420    23,873 kbps     00:06:18.711    102,484 bytes   219,809 bytes   00:06:17.960
3               0:09:38.911     0:03:18.823     20,286 kbps     29,517 kbps     00:12:49.685    24,344 kbps     00:11:38.072    23,545 kbps     00:11:36.529    105,763 bytes   237,640 bytes   00:09:45.001
4               0:12:57.735     0:01:51.820     20,143 kbps     26,262 kbps     00:14:06.053    23,237 kbps     00:14:32.663    22,417 kbps     00:14:31.495    105,014 bytes   232,294 bytes   00:14:34.456
5               0:14:49.555     0:01:45.146     19,946 kbps     26,629 kbps     00:16:14.348    22,800 kbps     00:15:56.372    21,570 kbps     00:15:51.283    103,990 bytes   204,389 bytes   00:16:03.545
6               0:16:34.702     0:02:17.595     20,498 kbps     33,025 kbps     00:18:20.516    25,032 kbps     00:18:17.930    23,989 kbps     00:18:16.553    106,865 bytes   245,595 bytes   00:18:21.141
7               0:18:52.297     0:01:27.670     19,736 kbps     26,064 kbps     00:19:06.395    23,655 kbps     00:19:05.602    23,040 kbps     00:19:05.978    102,896 bytes   219,156 bytes   00:19:10.315
8               0:20:19.968     0:02:48.293     19,712 kbps     24,985 kbps     00:21:34.459    22,278 kbps     00:21:31.164    21,098 kbps     00:21:26.493    102,769 bytes   214,772 bytes   00:23:05.967
9               0:23:08.261     0:02:25.770     21,306 kbps     33,045 kbps     00:25:01.041    27,543 kbps     00:24:50.363    26,549 kbps     00:24:20.500    111,082 bytes   234,750 bytes   00:24:28.717
10              0:25:34.032     0:00:55.555     20,987 kbps     30,781 kbps     00:26:16.157    27,127 kbps     00:26:12.153    24,860 kbps     00:26:09.526    109,415 bytes   294,742 bytes   00:26:16.575
11              0:26:29.588     0:03:16.696     21,169 kbps     32,015 kbps     00:28:47.350    26,541 kbps     00:28:46.808    24,444 kbps     00:28:41.803    110,365 bytes   242,120 bytes   00:27:18.970
12              0:29:46.284     0:01:39.432     20,693 kbps     26,875 kbps     00:31:24.048    23,321 kbps     00:31:20.712    23,004 kbps     00:31:15.707    107,886 bytes   243,829 bytes   00:30:32.914
13              0:31:25.717     0:02:56.217     21,709 kbps     32,771 kbps     00:31:47.989    26,037 kbps     00:32:09.719    24,466 kbps     00:32:04.797    113,181 bytes   273,038 bytes   00:32:38.623
14              0:34:21.934     0:02:23.017     19,628 kbps     24,115 kbps     00:35:55.403    21,017 kbps     00:34:29.484    20,406 kbps     00:34:58.513    102,330 bytes   206,457 bytes   00:36:44.660
15              0:36:44.952     0:01:17.619     19,580 kbps     27,218 kbps     00:37:28.829    22,722 kbps     00:37:24.951    21,041 kbps     00:37:19.946    102,080 bytes   229,495 bytes   00:36:46.120
16              0:38:02.571     0:01:39.182     21,081 kbps     29,423 kbps     00:39:29.325    26,230 kbps     00:38:47.992    24,025 kbps     00:38:42.236    109,907 bytes   229,108 bytes   00:38:33.894
17              0:39:41.754     0:02:37.115     22,038 kbps     34,403 kbps     00:40:55.035    27,694 kbps     00:40:37.935    25,933 kbps     00:40:48.154    114,896 bytes   294,794 bytes   00:40:52.408
18              0:42:18.869     0:03:15.862     19,852 kbps     29,472 kbps     00:43:48.667    23,789 kbps     00:44:44.431    22,522 kbps     00:43:41.660    103,498 bytes   256,766 bytes   00:43:59.219
19              0:45:34.732     0:03:00.305     20,725 kbps     29,052 kbps     00:46:39.379    25,849 kbps     00:46:39.046    24,444 kbps     00:46:36.084    108,053 bytes   289,234 bytes   00:46:24.114
20              0:48:35.037     0:01:31.132     21,024 kbps     28,663 kbps     00:48:50.928    24,779 kbps     00:49:02.689    23,224 kbps     00:48:47.174    109,608 bytes   247,787 bytes   00:48:48.425
21              0:50:06.169     0:03:20.366     20,714 kbps     28,833 kbps     00:53:14.858    26,332 kbps     00:50:56.970    24,534 kbps     00:50:36.908    107,991 bytes   247,129 bytes   00:51:13.445
22              0:53:26.536     0:02:34.112     20,688 kbps     28,841 kbps     00:55:36.916    25,542 kbps     00:53:38.215    24,515 kbps     00:53:33.210    107,860 bytes   254,016 bytes   00:54:56.209
23              0:56:00.648     0:03:19.282     21,238 kbps     29,250 kbps     00:57:05.797    26,621 kbps     00:57:01.960    24,759 kbps     00:57:12.137    110,726 bytes   234,842 bytes   00:56:24.631
24              0:59:19.931     0:03:32.670     21,340 kbps     29,757 kbps     01:02:23.364    26,312 kbps     01:02:23.030    24,678 kbps     01:02:20.153    111,258 bytes   273,368 bytes   01:02:06.806
25              1:02:52.602     0:04:51.666     21,022 kbps     31,580 kbps     01:04:30.783    26,477 kbps     01:03:35.353    25,165 kbps     01:04:53.556    109,599 bytes   244,470 bytes   01:03:45.071
26              1:07:44.268     0:06:05.031     21,695 kbps     32,580 kbps     01:08:12.713    27,580 kbps     01:12:40.814    24,873 kbps     01:12:36.268    113,109 bytes   253,781 bytes   01:10:55.668
27              1:13:49.299     0:01:52.070     21,793 kbps     29,401 kbps     01:14:41.101    27,278 kbps     01:15:19.056    24,297 kbps     01:13:55.556    113,620 bytes   243,727 bytes   01:15:05.083
28              1:15:41.370     0:03:34.881     21,662 kbps     31,813 kbps     01:16:24.705    25,747 kbps     01:19:05.323    24,195 kbps     01:19:04.656    112,938 bytes   267,997 bytes   01:15:51.213
29              1:19:16.251     0:02:37.615     21,754 kbps     32,588 kbps     01:19:49.326    26,718 kbps     01:21:36.558    24,607 kbps     01:20:34.162    113,417 bytes   245,716 bytes   01:20:32.452
30              1:21:53.867     0:02:48.751     21,589 kbps     29,301 kbps     01:22:51.216    27,601 kbps     01:22:47.337    23,916 kbps     01:23:41.766    112,557 bytes   247,504 bytes   01:23:51.526
31              1:24:42.619     0:05:04.304     21,385 kbps     30,448 kbps     01:26:29.184    25,682 kbps     01:26:25.513    24,308 kbps     01:25:27.413    111,491 bytes   274,307 bytes   01:25:05.266
32              1:29:46.923     0:05:39.464     22,101 kbps     34,397 kbps     01:31:47.460    26,739 kbps     01:31:12.717    25,463 kbps     01:34:55.773    115,223 bytes   266,151 bytes   01:35:25.636
33              1:35:26.387     0:01:32.467     21,844 kbps     29,976 kbps     01:35:46.490    26,976 kbps     01:35:33.394    24,799 kbps     01:35:28.514    113,886 bytes   242,205 bytes   01:35:46.907
34              1:36:58.854     0:03:54.192     21,619 kbps     30,327 kbps     01:40:41.368    26,507 kbps     01:40:14.049    25,137 kbps     01:40:12.548    112,709 bytes   315,835 bytes   01:40:35.362
35              1:40:53.047     0:03:31.044     21,537 kbps     29,793 kbps     01:43:25.657    26,951 kbps     01:43:23.655    24,093 kbps     01:43:46.887    112,281 bytes   257,269 bytes   01:42:24.638
36              1:44:24.091     0:05:39.881     21,571 kbps     33,909 kbps     01:46:12.699    27,071 kbps     01:45:04.589    24,620 kbps     01:49:30.981    112,459 bytes   254,475 bytes   01:44:56.707
37              1:50:03.972     0:04:39.112     21,887 kbps     30,901 kbps     01:51:28.056    27,251 kbps     01:51:24.052    25,165 kbps     01:52:08.096    114,109 bytes   264,396 bytes   01:50:06.349
38              1:54:43.084     0:03:44.974     21,305 kbps     32,778 kbps     01:55:26.461    26,724 kbps     01:56:46.374    24,061 kbps     01:56:42.829    111,076 bytes   249,461 bytes   01:55:22.665
39              1:58:28.059     0:04:13.503     20,651 kbps     33,034 kbps     01:58:55.795    25,369 kbps     01:58:52.208    23,811 kbps     02:02:17.079    107,663 bytes   234,273 bytes   01:58:56.420
40              2:02:41.562     0:01:23.249     20,784 kbps     25,708 kbps     02:02:47.568    24,534 kbps     02:02:43.647    22,869 kbps     02:03:54.760    108,359 bytes   221,698 bytes   02:03:42.415
41              2:04:04.812     0:01:45.438     21,148 kbps     30,676 kbps     02:04:56.780    27,487 kbps     02:04:32.631    24,657 kbps     02:04:28.127    110,258 bytes   230,466 bytes   02:05:10.836
42              2:05:50.251     0:04:24.055     19,067 kbps     32,048 kbps     02:09:43.442    27,967 kbps     02:09:42.941    27,279 kbps     02:09:42.858    99,547 bytes    307,693 bytes   02:10:00.793
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    7814.181                20,958                  20,471,596,295  111,370,950
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           7814.181                448                     437,602,816     2,441,980
00000.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7814.181                192                     187,544,064     1,220,990
00000.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7814.181                192                     187,544,064     1,220,990
00000.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7814.181                192                     187,544,064     1,220,990
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7814.181                39                      38,211,759      215,820
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7814.181                33                      32,312,568      183,765
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           7814.181                37                      36,433,724      206,017
00000.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           7814.181                45                      44,101,883      248,781
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #1446 of 1971 Old 02-24-2009, 04:47 PM
Mirrors
UPC: 024543525431
Code:
        Total   Video
Mirrors: Unrated    (seamless branching)                        AVC     1:51:22 24,926,932,992# 36,644,862,907  29.84   21.99   DTS-HD Master 5.1 3800Kbps (48kHz/24-bit)
         Theatrical (seamless branching)                        AVC     1:51:12 24,992,587,776# 36,644,862,907  29.97   21.99   DTS-HD Master 5.1 3796Kbps (48kHz/24-bit)
Unrated Cut
Code:
DISC INFO:
Disc Title:     MIRRORS
Disc Size:      36,644,862,907 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:51:22 (h:m:s)
Total Bitrate:          29.84 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        21987 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        1116 kbps           480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3800 kbps       5.1 / 48 kHz / 3800 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Express                     English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         39.283 kbps
Presentation Graphics           English         34.058 kbps
Presentation Graphics           Chinese         26.582 kbps
Presentation Graphics           Chinese         35.349 kbps
Presentation Graphics           French          1.393 kbps
Presentation Graphics           Korean          24.419 kbps
Presentation Graphics           Spanish         32.570 kbps
FILES:
00000.M2TS      0:00:00.000     0:03:32.212     810,227,712     30,544
00890.M2TS      0:03:32.212     0:02:09.963     474,580,992     29,213
00891.M2TS      0:05:42.175     0:38:52.413     8,626,563,072   29,588
00893.M2TS      0:44:34.588     0:02:00.245     436,703,232     29,054
00894.M2TS      0:46:34.833     0:30:34.749     6,880,825,344   30,002
00896.M2TS      1:17:09.583     0:02:05.166     454,576,128     29,054
00897.M2TS      1:19:14.749     0:01:32.550     345,606,144     29,874
00899.M2TS      1:20:47.300     0:03:59.322     859,969,536     28,747
00900.M2TS      1:24:46.623     0:12:02.471     2,774,323,200   30,720
00902.M2TS      1:36:49.094     0:00:29.237     109,713,408     30,020
00903.M2TS      1:37:18.332     0:03:43.097     873,756,672     31,332
00905.M2TS      1:41:01.430     0:00:19.477     71,651,328      29,429
00906.M2TS      1:41:20.908     0:10:01.309     2,208,436,224   29,382
CHAPTERS:
1               0:00:00.000     0:03:52.565     21,946 kbps     35,173 kbps     00:01:01.686    32,143 kbps     00:01:00.685    32,016 kbps     00:01:00.685    114,396 bytes   307,496 bytes   00:02:18.138
2               0:03:52.565     0:01:49.609     22,022 kbps     34,783 kbps     00:05:34.709    32,189 kbps     00:05:34.709    31,244 kbps     00:05:32.123    114,813 bytes   338,794 bytes   00:05:11.311
3               0:05:42.175     0:01:41.142     21,367 kbps     27,763 kbps     00:06:28.054    25,562 kbps     00:06:35.561    25,079 kbps     00:06:28.054    111,396 bytes   175,280 bytes   00:06:07.200
4               0:07:23.317     0:03:54.275     19,221 kbps     26,210 kbps     00:11:05.956    25,048 kbps     00:11:03.662    23,828 kbps     00:10:58.866    100,210 bytes   316,353 bytes   00:11:17.593
5               0:11:17.593     0:04:17.757     24,694 kbps     30,544 kbps     00:13:27.681    29,034 kbps     00:14:33.998    28,066 kbps     00:13:27.640    128,742 bytes   318,631 bytes   00:11:20.596
6               0:15:35.351     0:06:06.199     21,308 kbps     35,261 kbps     00:16:47.923    32,337 kbps     00:16:43.961    31,817 kbps     00:16:40.749    111,093 bytes   446,917 bytes   00:21:23.365
7               0:21:41.550     0:01:49.984     28,687 kbps     35,605 kbps     00:22:59.169    30,941 kbps     00:22:43.820    30,621 kbps     00:22:39.566    149,562 bytes   258,725 bytes   00:22:48.408
8               0:23:31.535     0:09:57.263     20,740 kbps     33,510 kbps     00:28:02.263    28,632 kbps     00:27:58.343    27,330 kbps     00:27:45.330    108,129 bytes   259,696 bytes   00:25:49.673
9               0:33:28.798     0:02:54.549     22,300 kbps     31,971 kbps     00:34:35.156    28,652 kbps     00:34:31.152    26,692 kbps     00:34:26.147    116,261 bytes   287,633 bytes   00:34:53.466
10              0:36:23.347     0:02:58.011     22,452 kbps     33,497 kbps     00:37:13.439    31,773 kbps     00:38:05.366    29,908 kbps     00:38:01.737    117,057 bytes   267,258 bytes   00:36:24.348
11              0:39:21.358     0:05:08.308     22,566 kbps     32,095 kbps     00:39:57.436    28,863 kbps     00:39:54.642    27,832 kbps     00:39:49.845    117,647 bytes   201,726 bytes   00:42:55.114
12              0:44:29.666     0:06:27.178     23,376 kbps     33,000 kbps     00:46:35.250    29,609 kbps     00:50:49.588    28,536 kbps     00:50:46.752    121,873 bytes   267,225 bytes   00:47:17.125
13              0:50:56.845     0:02:20.431     18,193 kbps     29,457 kbps     00:51:05.020    27,123 kbps     00:51:02.476    25,379 kbps     00:50:57.471    94,852 bytes    212,089 bytes   00:51:18.533
14              0:53:17.277     0:03:11.983     21,728 kbps     33,686 kbps     00:55:53.183    30,363 kbps     00:56:19.209    29,308 kbps     00:56:17.415    113,281 bytes   380,071 bytes   00:56:03.818
15              0:56:29.260     0:05:22.196     21,997 kbps     36,115 kbps     01:01:31.979    29,870 kbps     01:01:30.853    27,318 kbps     01:01:25.723    114,680 bytes   314,770 bytes   00:56:39.062
16              1:01:51.457     0:04:08.873     22,878 kbps     30,743 kbps     01:01:58.131    28,595 kbps     01:03:00.860    28,361 kbps     01:04:33.536    119,276 bytes   216,964 bytes   01:01:58.631
17              1:06:00.331     0:02:15.385     20,014 kbps     29,061 kbps     01:06:41.414    24,574 kbps     01:08:10.711    22,599 kbps     01:06:34.782    104,342 bytes   219,636 bytes   01:06:36.367
18              1:08:15.716     0:02:12.465     22,095 kbps     30,391 kbps     01:09:14.149    29,162 kbps     01:09:57.234    26,543 kbps     01:09:05.140    115,194 bytes   299,997 bytes   01:10:28.182
19              1:10:28.182     0:03:35.632     21,945 kbps     32,743 kbps     01:10:33.145    30,973 kbps     01:10:29.141    27,834 kbps     01:12:34.725    114,411 bytes   313,091 bytes   01:10:33.812
20              1:14:03.814     0:05:21.779     22,181 kbps     37,823 kbps     01:19:03.905    31,979 kbps     01:15:00.162    31,245 kbps     01:15:00.078    115,641 bytes   384,639 bytes   01:19:15.750
21              1:19:25.594     0:05:00.717     21,889 kbps     38,557 kbps     01:22:38.078    32,151 kbps     01:22:01.333    31,664 kbps     01:22:08.173    114,120 bytes   370,919 bytes   01:22:41.915
22              1:24:26.311     0:04:52.625     21,920 kbps     32,312 kbps     01:27:23.446    29,995 kbps     01:27:20.109    27,225 kbps     01:26:34.647    114,283 bytes   272,660 bytes   01:26:38.067
23              1:29:18.936     0:02:53.464     22,929 kbps     32,987 kbps     01:32:03.267    30,249 kbps     01:29:24.567    28,850 kbps     01:29:22.231    119,539 bytes   316,287 bytes   01:32:04.143
24              1:32:12.401     0:03:45.683     22,063 kbps     35,401 kbps     01:35:54.164    31,889 kbps     01:35:52.580    30,281 kbps     01:35:24.718    115,026 bytes   219,246 bytes   01:35:54.874
25              1:35:58.085     0:02:17.929     23,208 kbps     34,806 kbps     01:36:34.914    32,213 kbps     01:38:07.881    31,331 kbps     01:38:05.963    120,998 bytes   236,331 bytes   01:36:43.881
26              1:38:16.014     0:04:26.975     21,002 kbps     33,509 kbps     01:40:52.170    28,760 kbps     01:42:30.435    27,198 kbps     01:41:42.012    109,493 bytes   302,744 bytes   01:40:49.751
27              1:42:42.990     0:04:30.061     21,714 kbps     32,810 kbps     01:45:26.903    31,401 kbps     01:44:31.515    30,744 kbps     01:44:29.554    113,207 bytes   261,401 bytes   01:47:06.503
28              1:47:13.051     0:04:09.165     22,055 kbps     32,916 kbps     01:48:44.517    31,512 kbps     01:48:43.391    30,299 kbps     01:48:41.056    115,006 bytes   708,280 bytes   01:48:42.098
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     212.087                 22,013                  583,574,743     3,174,611
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           212.087                 3,846                   101,953,820     587,075
00000.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           212.087                 448                     11,884,544      66,320
00000.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            212.087                 448                     11,884,544      66,320
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           212.087                 13                      336,488         1,937
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           212.087                 6                       148,958         870
00000.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           212.087                 7                       189,913         1,100
00000.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           212.087                 7                       186,556         1,084
00000.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            212.087                 6                       167,711         985
00000.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            212.087                 0                       8,293           51
00000.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           212.087                 0                       70              7
00000.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           212.087                 192                     5,093,376       29,844
00000.M2TS      6912 (0x1B00)   0x1B            AVC                                     212.087                 1,888                   50,053,624      274,220
00890.M2TS      4113 (0x1011)   0x1B            AVC                                     129.880                 21,930                  356,036,774     1,936,829
00890.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           129.880                 4,352                   70,661,544      404,242
00890.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           129.880                 448                     7,279,104       40,620
00890.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            129.880                 448                     7,279,104       40,620
00890.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           129.880                 6                       96,182          557
00890.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           129.880                 0                       70              7
00890.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           129.880                 1                       13,747          81
00890.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           129.880                 1                       16,880          99
00890.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            129.880                 0                       7,761           49
00890.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            129.880                 0                       70              7
00890.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           129.880                 0                       70              7
00890.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           129.880                 192                     3,121,152       18,288
00890.M2TS      6912 (0x1B00)   0x1B            AVC                                     129.880                 231                     3,745,815       20,904
00891.M2TS      4113 (0x1011)   0x1B            AVC                                     2332.288                21,996                  6,412,669,106   34,884,347
00891.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2332.288                3,579                   1,043,539,432   6,034,696
00891.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           2332.288                448                     130,615,296     728,880
00891.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            2332.288                448                     130,615,296     728,880
00891.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2332.288                45                      13,119,373      73,762
00891.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           2332.288                38                      10,956,976      61,640
00891.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           2332.288                30                      8,773,013       49,950
00891.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           2332.288                41                      11,827,999      66,654
00891.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            2332.288                27                      7,955,234       45,457
00891.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            2332.288                2                       478,443         2,663
00891.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           2332.288                35                      10,300,610      56,633
00891.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           2332.288                192                     55,977,984      327,996
00891.M2TS      6912 (0x1B00)   0x1B            AVC                                     2332.288                1,060                   308,930,497     1,698,649
00893.M2TS      4113 (0x1011)   0x1B            AVC                                     120.162                 21,997                  330,392,539     1,797,312
00893.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           120.162                 4,013                   60,281,996      346,242
00893.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           120.162                 448                     6,734,336       37,580
00893.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            120.162                 448                     6,734,336       37,580
00893.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           120.162                 10                      146,016         839
00893.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           120.162                 0                       70              7
00893.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           120.162                 0                       70              7
00893.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           120.162                 0                       70              7
00893.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            120.162                 0                       70              7
00893.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            120.162                 0                       70              7
00893.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           120.162                 120                     1,801,036       9,903
00893.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           120.162                 192                     2,887,680       16,920
00893.M2TS      6912 (0x1B00)   0x1B            AVC                                     120.162                 231                     3,465,122       19,338
00894.M2TS      4113 (0x1011)   0x1B            AVC                                     1834.666                21,994                  5,043,954,282   27,438,681
00894.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1834.666                3,848                   882,436,084     5,082,066
00894.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           1834.666                448                     102,746,112     573,360
00894.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            1834.666                448                     102,746,112     573,360
00894.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1834.666                49                      11,282,785      63,352
00894.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           1834.666                42                      9,709,183       54,583
00894.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           1834.666                34                      7,845,868       44,604
00894.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           1834.666                46                      10,640,379      59,923
00894.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            1834.666                32                      7,293,902       41,571
00894.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            1834.666                3                       575,520         3,209
00894.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           1834.666                27                      6,210,488       34,153
00894.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           1834.666                192                     44,034,048      258,012
00894.M2TS      6912 (0x1B00)   0x1B            AVC                                     1834.666                1,173                   269,102,842     1,477,171
00896.M2TS      4113 (0x1011)   0x1B            AVC                                     125.042                 21,997                  343,812,447     1,870,321
00896.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           125.042                 3,737                   58,409,984      336,878
00896.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           125.042                 449                     7,010,304       39,120
00896.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            125.042                 449                     7,010,304       39,120
00896.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           125.042                 95                      1,492,676       8,309
00896.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           125.042                 88                      1,379,824       7,719
00896.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           125.042                 67                      1,052,210       5,937
00896.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           125.042                 90                      1,410,836       7,904
00896.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            125.042                 61                      953,299         5,398
00896.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            125.042                 0                       70              7
00896.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           125.042                 0                       70              7
00896.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           125.042                 192                     3,004,416       17,604
00896.M2TS      6912 (0x1B00)   0x1B            AVC                                     125.042                 231                     3,606,908       20,129
00897.M2TS      4113 (0x1011)   0x1B            AVC                                     92.467                  22,013                  254,439,373     1,384,122
00897.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           92.467                  3,691                   42,657,076      246,132
00897.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           92.467                  449                     5,184,256       28,930
00897.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            92.467                  449                     5,184,256       28,930
00897.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           92.467                  32                      370,555         2,076
00897.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           92.467                  33                      381,747         2,141
00897.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           92.467                  27                      314,625         1,782
00897.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           92.467                  35                      402,201         2,260
00897.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            92.467                  25                      283,760         1,609
00897.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            92.467                  4                       49,787          277
00897.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           92.467                  0                       70              7
00897.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           92.467                  192                     2,222,080       13,020
00897.M2TS      6912 (0x1B00)   0x1B            AVC                                     92.467                  1,293                   14,948,545      82,002
00899.M2TS      4113 (0x1011)   0x1B            AVC                                     239.239                 22,004                  658,018,885     3,579,524
00899.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           239.239                 3,512                   105,020,840     608,359
00899.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           239.239                 448                     13,402,368      74,790
00899.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            239.239                 448                     13,402,368      74,790
00899.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           239.239                 70                      2,086,700       11,704
00899.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           239.239                 61                      1,836,708       10,339
00899.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           239.239                 57                      1,710,722       9,691
00899.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           239.239                 69                      2,069,767       11,644
00899.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            239.239                 50                      1,506,611       8,588
00899.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            239.239                 0                       70              7
00899.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           239.239                 0                       70              7
00899.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           239.239                 192                     5,744,640       33,660
00899.M2TS      6912 (0x1B00)   0x1B            AVC                                     239.239                 231                     6,897,275       38,490
00900.M2TS      4113 (0x1011)   0x1B            AVC                                     722.388                 22,002                  1,986,789,528   10,808,026
00900.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           722.388                 4,044                   365,128,584     2,096,964
00900.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           722.388                 448                     40,459,776      225,780
00900.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            722.388                 448                     40,459,776      225,780
00900.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           722.388                 36                      3,246,416       18,399
00900.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           722.388                 28                      2,491,072       14,129
00900.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           722.388                 23                      2,070,343       11,945
00900.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           722.388                 30                      2,691,936       15,408
00900.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            722.388                 22                      2,014,219       11,627
00900.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            722.388                 0                       70              7
00900.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           722.388                 29                      2,579,014       14,185
00900.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           722.388                 192                     17,340,416      101,604
00900.M2TS      6912 (0x1B00)   0x1B            AVC                                     722.388                 1,737                   156,883,533     859,654
00902.M2TS      4113 (0x1011)   0x1B            AVC                                     29.112                  22,114                  80,473,970      437,770
00902.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           29.112                  4,825                   17,556,976      99,970
00902.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           29.112                  450                     1,637,888       9,140
00902.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            29.112                  450                     1,637,888       9,140
00902.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           29.112                  8                       30,388          172
00902.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           29.112                  8                       27,574          156
00902.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           29.112                  5                       16,851          98
00902.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           29.112                  7                       25,108          150
00902.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            29.112                  6                       20,728          126
00902.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            29.112                  0                       70              7
00902.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           29.112                  187                     681,104         3,745
00902.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           29.112                  193                     702,464         4,116
00902.M2TS      6912 (0x1B00)   0x1B            AVC                                     29.112                  231                     842,064         4,700
00903.M2TS      4113 (0x1011)   0x1B            AVC                                     222.973                 21,997                  613,089,856     3,335,123
00903.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           222.973                 4,342                   121,011,672     692,418
00903.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           222.973                 448                     12,493,824      69,720
00903.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            222.973                 448                     12,493,824      69,720
00903.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           222.973                 11                      303,397         1,778
00903.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           222.973                 4                       117,376         699
00903.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           222.973                 3                       95,361          572
00903.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           222.973                 4                       118,142         696
00903.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            222.973                 4                       100,607         602
00903.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            222.973                 0                       70              7
00903.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           222.973                 167                     4,657,487       25,605
00903.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           222.973                 192                     5,355,520       31,380
00903.M2TS      6912 (0x1B00)   0x1B            AVC                                     222.973                 2,001                   55,764,386      306,231
00905.M2TS      4113 (0x1011)   0x1B            AVC                                     19.394                  21,582                  52,321,455      284,627
00905.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           19.394                  4,706                   11,409,264      65,053
00905.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           19.394                  450                     1,091,328       6,090
00905.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            19.394                  450                     1,091,328       6,090
00905.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           19.394                  6                       13,854          82
00905.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           19.394                  0                       70              7
00905.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           19.394                  0                       70              7
00905.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           19.394                  0                       70              7
00905.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            19.394                  0                       70              7
00905.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            19.394                  0                       70              7
00905.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           19.394                  293                     709,649         3,900
00905.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           19.394                  193                     468,992         2,748
00905.M2TS      6912 (0x1B00)   0x1B            AVC                                     19.394                  231                     560,966         3,131
00906.M2TS      4113 (0x1011)   0x1B            AVC                                     601.226                 21,954                  1,649,909,071   8,975,504
00906.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           601.226                 3,914                   294,154,044     1,692,711
00906.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           601.226                 448                     33,673,472      187,910
00906.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            601.226                 448                     33,673,472      187,910
00906.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           601.226                 4                       287,701         1,670
00906.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           601.226                 2                       155,684         895
00906.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           601.226                 2                       120,738         709
00906.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           601.226                 2                       136,449         798
00906.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            601.226                 1                       93,047          561
00906.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            601.226                 1                       50,818          283
00906.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           601.226                 20                      1,508,436       8,292
00906.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           601.226                 192                     14,432,256      84,564
00906.M2TS      6912 (0x1B00)   0x1B            AVC                                     601.226                 765                     57,486,660      316,682
Theatrical Cut
Code:
DISC INFO:
Disc Title:     MIRRORS
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:51:12 (h:m:s)
Total Bitrate:          29.97 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        21988 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        1236 kbps           480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3796 kbps       5.1 / 48 kHz / 3796 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         39.319 kbps
Presentation Graphics           English         34.084 kbps
Presentation Graphics           Chinese         26.622 kbps
Presentation Graphics           Chinese         35.403 kbps
Presentation Graphics           French          1.395 kbps
Presentation Graphics           Korean          24.456 kbps
Presentation Graphics           Spanish         32.620 kbps
FILES:
00889.M2TS      0:03:32.212     0:02:07.043     471,128,064     29,667
00891.M2TS      0:05:39.255     0:38:52.413     8,626,563,072   29,588
00892.M2TS      0:44:31.668     0:01:56.491     449,009,664     30,836
00894.M2TS      0:46:28.160     0:30:34.749     6,880,825,344   30,002
00895.M2TS      1:17:02.909     0:02:04.874     481,849,344     30,869
00897.M2TS      1:19:07.784     0:01:32.550     345,606,144     29,874
00898.M2TS      1:20:40.335     0:03:57.070     881,657,856     29,752
00900.M2TS      1:24:37.405     0:12:02.471     2,774,323,200   30,720
00901.M2TS      1:36:39.877     0:00:29.237     116,809,728     31,962
00903.M2TS      1:37:09.114     0:03:43.097     873,756,672     31,332
00904.M2TS      1:40:52.212     0:00:18.601     72,394,752      31,134
00906.M2TS      1:41:10.814     0:10:01.309     2,208,436,224   29,382
CHAPTERS:
1               0:00:00.000     0:03:49.646     21,943 kbps     35,173 kbps     00:01:01.686    32,143 kbps     00:01:00.685    32,016 kbps     00:01:00.685    114,381 bytes   307,496 bytes   00:02:18.138
2               0:03:49.646     0:01:49.609     22,116 kbps     33,775 kbps     00:04:47.036    31,724 kbps     00:05:30.121    30,650 kbps     00:05:29.245    115,304 bytes   327,629 bytes   00:05:07.682
3               0:05:39.255     0:01:41.142     21,367 kbps     27,763 kbps     00:06:25.134    25,562 kbps     00:06:32.642    25,079 kbps     00:06:25.134    111,396 bytes   175,280 bytes   00:06:04.280
4               0:07:20.398     0:03:54.275     19,221 kbps     26,210 kbps     00:11:03.037    25,048 kbps     00:11:00.743    23,828 kbps     00:10:55.946    100,210 bytes   316,353 bytes   00:11:14.673
5               0:11:14.673     0:04:17.757     24,694 kbps     30,544 kbps     00:13:24.762    29,034 kbps     00:14:31.078    28,066 kbps     00:13:24.720    128,742 bytes   318,631 bytes   00:11:17.676
6               0:15:32.431     0:06:06.199     21,308 kbps     35,261 kbps     00:16:45.003    32,337 kbps     00:16:41.041    31,817 kbps     00:16:37.830    111,093 bytes   446,917 bytes   00:21:20.445
7               0:21:38.630     0:01:49.984     28,687 kbps     35,605 kbps     00:22:56.249    30,941 kbps     00:22:40.901    30,621 kbps     00:22:36.646    149,562 bytes   258,725 bytes   00:22:45.489
8               0:23:28.615     0:09:57.263     20,740 kbps     33,510 kbps     00:27:59.344    28,632 kbps     00:27:55.423    27,330 kbps     00:27:42.410    108,129 bytes   259,696 bytes   00:25:46.753
9               0:33:25.878     0:02:54.549     22,300 kbps     31,971 kbps     00:34:32.236    28,652 kbps     00:34:28.232    26,692 kbps     00:34:23.227    116,261 bytes   287,633 bytes   00:34:50.546
10              0:36:20.428     0:02:58.011     22,452 kbps     33,497 kbps     00:37:10.519    31,773 kbps     00:38:02.446    29,908 kbps     00:37:58.818    117,057 bytes   267,258 bytes   00:36:21.429
11              0:39:18.439     0:05:08.349     22,566 kbps     32,095 kbps     00:39:54.517    28,863 kbps     00:39:51.722    27,832 kbps     00:39:46.926    117,650 bytes   201,726 bytes   00:42:52.194
12              0:44:26.789     0:06:23.382     23,392 kbps     33,000 kbps     00:46:28.577    29,609 kbps     00:50:42.914    28,536 kbps     00:50:40.078    121,953 bytes   267,225 bytes   00:47:10.452
13              0:50:50.172     0:02:20.431     18,193 kbps     29,457 kbps     00:50:58.346    27,123 kbps     00:50:55.802    25,379 kbps     00:50:50.797    94,852 bytes    212,089 bytes   00:51:11.860
14              0:53:10.604     0:03:11.983     21,728 kbps     33,686 kbps     00:55:46.509    30,363 kbps     00:56:12.535    29,308 kbps     00:56:10.742    113,281 bytes   380,071 bytes   00:55:57.145
15              0:56:22.587     0:05:22.196     21,997 kbps     36,115 kbps     01:01:25.306    29,870 kbps     01:01:24.180    27,318 kbps     01:01:19.050    114,680 bytes   314,770 bytes   00:56:32.388
16              1:01:44.784     0:04:08.831     22,879 kbps     30,743 kbps     01:01:51.457    28,595 kbps     01:02:54.187    28,361 kbps     01:04:26.862    119,280 bytes   216,964 bytes   01:01:51.958
17              1:05:53.616     0:02:15.426     20,013 kbps     29,061 kbps     01:06:34.740    24,574 kbps     01:08:04.038    22,599 kbps     01:06:28.109    104,341 bytes   219,636 bytes   01:06:29.694
18              1:08:09.043     0:02:12.465     22,095 kbps     30,391 kbps     01:09:07.476    29,162 kbps     01:09:50.561    26,543 kbps     01:08:58.467    115,194 bytes   299,997 bytes   01:10:21.508
19              1:10:21.508     0:03:35.632     21,945 kbps     32,743 kbps     01:10:26.472    30,973 kbps     01:10:22.468    27,834 kbps     01:12:28.052    114,411 bytes   313,091 bytes   01:10:27.139
20              1:13:57.141     0:05:21.487     22,166 kbps     34,891 kbps     01:16:56.486    31,979 kbps     01:14:53.488    31,245 kbps     01:14:53.405    115,565 bytes   384,639 bytes   01:19:08.785
21              1:19:18.628     0:04:58.464     21,878 kbps     38,791 kbps     01:22:28.860    31,963 kbps     01:22:01.624    31,616 kbps     01:21:58.955    114,064 bytes   344,797 bytes   01:22:32.822
22              1:24:17.093     0:04:52.625     21,931 kbps     32,312 kbps     01:27:14.228    29,995 kbps     01:27:10.892    27,225 kbps     01:26:25.430    114,338 bytes   272,660 bytes   01:26:28.850
23              1:29:09.719     0:02:53.464     22,929 kbps     32,987 kbps     01:31:54.050    30,249 kbps     01:29:15.349    28,850 kbps     01:29:13.014    119,539 bytes   316,287 bytes   01:31:54.925
24              1:32:03.184     0:03:45.683     22,063 kbps     35,401 kbps     01:35:44.947    31,889 kbps     01:35:43.362    30,281 kbps     01:35:15.501    115,026 bytes   219,246 bytes   01:35:45.656
25              1:35:48.868     0:02:17.929     23,206 kbps     34,806 kbps     01:36:25.696    32,213 kbps     01:37:58.664    31,331 kbps     01:37:56.745    120,987 bytes   236,331 bytes   01:36:34.663
26              1:38:06.797     0:04:26.099     21,005 kbps     33,509 kbps     01:40:42.953    28,760 kbps     01:42:20.342    27,198 kbps     01:41:31.919    109,509 bytes   302,744 bytes   01:40:40.534
27              1:42:32.896     0:04:31.020     21,641 kbps     32,810 kbps     01:45:16.810    31,401 kbps     01:44:21.421    30,744 kbps     01:44:19.461    112,824 bytes   261,401 bytes   01:46:56.409
28              1:47:03.917     0:04:08.206     22,137 kbps     32,916 kbps     01:48:34.424    31,512 kbps     01:48:33.298    30,299 kbps     01:48:30.962    115,432 bytes   708,280 bytes   01:48:32.005
STREAM DIAGNOSTICS:
00889.M2TS      4113 (0x1011)   0x1B            AVC                                     126.960                 22,006                  349,238,139     1,899,856
00889.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           126.960                 4,324                   68,618,560      392,729
00889.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           126.960                 448                     7,116,032       39,710
00889.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            126.960                 448                     7,116,032       39,710
00889.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           126.960                 6                       96,182          557
00889.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           126.960                 0                       70              7
00889.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           126.960                 1                       13,747          81
00889.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           126.960                 1                       16,880          99
00889.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            126.960                 0                       7,761           49
00889.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            126.960                 0                       70              7
00889.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           126.960                 0                       70              7
00889.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           126.960                 192                     3,049,472       17,868
00889.M2TS      6912 (0x1B00)   0x1B            AVC                                     126.960                 615                     9,754,058       53,842
00892.M2TS      4113 (0x1011)   0x1B            AVC                                     116.366                 22,011                  320,165,248     1,741,687
00892.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           116.366                 3,936                   57,245,972      329,405
00892.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           116.366                 449                     6,524,672       36,410
00892.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            116.366                 449                     6,524,672       36,410
00892.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           116.366                 10                      146,016         839
00892.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           116.366                 0                       70              7
00892.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           116.366                 0                       70              7
00892.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           116.366                 0                       70              7
00892.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            116.366                 0                       70              7
00892.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            116.366                 0                       70              7
00892.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           116.366                 124                     1,801,036       9,903
00892.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           116.366                 192                     2,797,568       16,392
00892.M2TS      6912 (0x1B00)   0x1B            AVC                                     116.366                 1,993                   28,993,680      159,016
00895.M2TS      4113 (0x1011)   0x1B            AVC                                     124.750                 21,958                  342,414,309     1,862,710
00895.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           124.750                 3,720                   58,007,196      334,601
00895.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           124.750                 449                     6,994,176       39,030
00895.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            124.750                 449                     6,994,176       39,030
00895.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           124.750                 96                      1,492,367       8,307
00895.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           124.750                 88                      1,379,824       7,719
00895.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           124.750                 67                      1,052,210       5,937
00895.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           124.750                 90                      1,410,836       7,904
00895.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            124.750                 61                      953,299         5,398
00895.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            124.750                 0                       70              7
00895.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           124.750                 0                       70              7
00895.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           124.750                 192                     2,998,272       17,568
00895.M2TS      6912 (0x1B00)   0x1B            AVC                                     124.750                 2,014                   31,398,151      172,298
00898.M2TS      4113 (0x1011)   0x1B            AVC                                     236.945                 22,008                  651,844,472     3,545,975
00898.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           236.945                 3,489                   103,339,752     598,553
00898.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           236.945                 448                     13,276,928      74,090
00898.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            236.945                 448                     13,276,928      74,090
00898.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           236.945                 70                      2,066,763       11,592
00898.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           236.945                 62                      1,836,708       10,339
00898.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           236.945                 58                      1,710,722       9,691
00898.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           236.945                 70                      2,069,767       11,644
00898.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            236.945                 51                      1,506,611       8,588
00898.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            236.945                 0                       70              7
00898.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           236.945                 0                       70              7
00898.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           236.945                 192                     5,691,392       33,348
00898.M2TS      6912 (0x1B00)   0x1B            AVC                                     236.945                 1,207                   35,744,753      196,771
00901.M2TS      4113 (0x1011)   0x1B            AVC                                     29.154                  22,073                  80,438,514      437,580
00901.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           29.154                  4,798                   17,485,620      99,585
00901.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           29.154                  449                     1,637,888       9,140
00901.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            29.154                  449                     1,637,888       9,140
00901.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           29.154                  8                       30,388          172
00901.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           29.154                  8                       27,574          156
00901.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           29.154                  5                       16,851          98
00901.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           29.154                  7                       25,108          150
00901.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            29.154                  6                       20,728          126
00901.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            29.154                  0                       70              7
00901.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           29.154                  291                     1,059,224       5,825
00901.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           29.154                  193                     702,464         4,116
00901.M2TS      6912 (0x1B00)   0x1B            AVC                                     29.154                  2,006                   7,309,347       40,139
00904.M2TS      4113 (0x1011)   0x1B            AVC                                     18.519                  21,653                  50,122,378      272,672
00904.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           18.519                  4,640                   10,741,584      61,278
00904.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           18.519                  451                     1,042,944       5,820
00904.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            18.519                  451                     1,042,944       5,820
00904.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           18.519                  6                       13,854          82
00904.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           18.519                  0                       70              7
00904.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           18.519                  0                       70              7
00904.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           18.519                  0                       70              7
00904.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            18.519                  0                       70              7
00904.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            18.519                  0                       70              7
00904.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           18.519                  134                     310,190         1,704
00904.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           18.519                  193                     446,464         2,616
00904.M2TS      6912 (0x1B00)   0x1B            AVC                                     18.519                  2,017                   4,669,880       25,651
post #1447 of 1971 Old 02-24-2009, 06:35 PM
Babaganoosh's Avatar
So Super Speedway really is 1080i, despite what the package says? Whew, I thought my copy was bad. It does still look fine, though.
"I bought a new camera. It's very advanced. You don't even need it."
- Steven Wright
Babaganoosh is offline
post #1448 of 1971 Old 02-25-2009, 12:16 PM
Phloyd's Avatar
That is correct.
You would think that they could get this kind of thing right by now.
Phloyd is offline
post #1449 of 1971 Old 02-25-2009, 04:14 PM
Igor
UPC: 883904133285
Code:
        Total   Video
Igor                                                            AVC     1:26:32 28,083,999,744  29,974,908,194  43.27   36.35   DTS-HD Master 5.1 3971Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     IGOR
Disc Size:      29,974,908,194 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:26:32 (h:m:s)
Total Bitrate:          43.27 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        36351 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3971 kbps       5.1 / 48 kHz / 3971 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         51.336 kbps
Presentation Graphics           Spanish         37.967 kbps
FILES:
00057.M2TS      0:00:00.000     1:26:32.812     28,083,999,744  43,266
CHAPTERS:
1               0:00:00.000     0:05:12.312     36,470 kbps     45,026 kbps     00:01:31.591    40,007 kbps     00:01:27.587    39,304 kbps     00:04:36.734    190,113 bytes   808,510 bytes   00:02:29.190
2               0:05:12.312     0:02:27.564     38,171 kbps     41,627 kbps     00:06:24.550    39,477 kbps     00:07:08.886    39,178 kbps     00:05:46.637    199,007 bytes   492,087 bytes   00:07:13.766
3               0:07:39.876     0:03:23.620     38,618 kbps     44,751 kbps     00:10:05.313    39,656 kbps     00:08:15.870    39,276 kbps     00:08:56.410    201,334 bytes   575,349 bytes   00:10:05.771
4               0:11:03.496     0:04:12.460     37,853 kbps     46,315 kbps     00:13:06.035    40,078 kbps     00:14:36.208    39,420 kbps     00:14:31.203    197,349 bytes   570,036 bytes   00:15:13.829
5               0:15:15.956     0:03:43.932     37,667 kbps     47,465 kbps     00:18:18.222    40,177 kbps     00:18:14.218    39,163 kbps     00:18:03.123    196,378 bytes   589,978 bytes   00:16:22.648
6               0:18:59.888     0:03:40.595     37,063 kbps     42,041 kbps     00:20:37.611    39,560 kbps     00:21:05.138    39,221 kbps     00:20:37.486    193,229 bytes   579,555 bytes   00:21:10.018
7               0:22:40.484     0:01:55.240     37,808 kbps     41,276 kbps     00:23:58.979    39,400 kbps     00:23:59.479    39,161 kbps     00:22:51.912    197,114 bytes   529,387 bytes   00:23:59.604
8               0:24:35.724     0:04:55.295     38,188 kbps     43,557 kbps     00:27:43.662    39,786 kbps     00:27:39.616    39,228 kbps     00:27:51.086    199,097 bytes   522,744 bytes   00:29:20.925
9               0:29:31.019     0:03:56.236     36,120 kbps     48,283 kbps     00:32:53.221    39,385 kbps     00:33:11.030    39,123 kbps     00:33:08.277    188,311 bytes   501,849 bytes   00:31:13.705
10              0:33:27.255     0:04:15.463     38,645 kbps     45,501 kbps     00:35:28.084    40,745 kbps     00:35:24.080    39,520 kbps     00:35:18.950    201,476 bytes   643,341 bytes   00:35:28.668
11              0:37:42.718     0:03:16.654     38,182 kbps     42,199 kbps     00:39:20.816    39,517 kbps     00:39:16.979    39,225 kbps     00:39:11.807    199,065 bytes   559,079 bytes   00:38:42.695
12              0:40:59.373     0:01:58.827     38,105 kbps     41,399 kbps     00:41:22.062    39,638 kbps     00:42:34.134    39,039 kbps     00:41:32.198    198,661 bytes   553,575 bytes   00:41:23.689
13              0:42:58.200     0:03:05.059     38,305 kbps     42,576 kbps     00:44:59.738    39,701 kbps     00:43:29.064    39,389 kbps     00:43:24.059    199,704 bytes   532,665 bytes   00:44:44.807
14              0:46:03.260     0:06:00.401     37,810 kbps     44,800 kbps     00:51:22.370    39,531 kbps     00:51:18.492    39,153 kbps     00:48:36.538    197,125 bytes   558,346 bytes   00:48:14.433
15              0:52:03.662     0:03:40.470     37,409 kbps     43,098 kbps     00:55:41.046    39,883 kbps     00:55:37.000    39,430 kbps     00:55:31.786    195,033 bytes   597,294 bytes   00:54:04.991
16              0:55:44.132     0:02:39.033     37,923 kbps     44,635 kbps     00:58:12.405    39,562 kbps     00:58:08.443    39,155 kbps     00:55:58.438    197,711 bytes   584,848 bytes   00:58:13.156
17              0:58:23.166     0:02:35.613     37,472 kbps     42,516 kbps     00:58:59.077    39,562 kbps     00:58:46.940    39,283 kbps     00:58:42.143    195,362 bytes   660,821 bytes   00:59:00.036
18              1:00:58.780     0:02:44.581     37,679 kbps     42,845 kbps     01:02:48.222    39,522 kbps     01:01:56.129    39,132 kbps     01:02:24.657    196,439 bytes   559,516 bytes   01:02:49.766
19              1:03:43.361     0:02:34.320     37,919 kbps     46,694 kbps     01:05:43.481    40,629 kbps     01:05:39.477    39,684 kbps     01:05:34.472    197,690 bytes   714,298 bytes   01:05:13.200
20              1:06:17.682     0:02:21.349     37,779 kbps     42,172 kbps     01:08:26.143    39,511 kbps     01:07:21.746    39,261 kbps     01:07:30.421    196,960 bytes   605,837 bytes   01:07:34.175
21              1:08:39.031     0:04:17.006     37,126 kbps     45,808 kbps     01:12:47.029    39,656 kbps     01:09:44.096    39,377 kbps     01:12:38.062    193,555 bytes   625,121 bytes   01:12:24.381
22              1:12:56.038     0:03:37.467     37,759 kbps     46,303 kbps     01:13:13.722    40,047 kbps     01:15:25.729    39,333 kbps     01:15:36.323    196,857 bytes   833,208 bytes   01:15:25.771
23              1:16:33.505     0:02:35.405     37,992 kbps     44,163 kbps     01:18:53.937    40,469 kbps     01:18:49.975    39,289 kbps     01:17:47.913    198,071 bytes   719,987 bytes   01:17:01.617
24              1:19:08.910     0:07:23.901     21,983 kbps     39,700 kbps     01:22:36.368    39,134 kbps     01:22:34.824    38,653 kbps     01:22:34.032    114,622 bytes   716,486 bytes   01:24:09.210
STREAM DIAGNOSTICS:
00057.M2TS      4113 (0x1011)   0x1B            AVC                                     5192.646                36,352                  23,595,275,728  128,308,068
00057.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5192.646                3,971                   2,577,294,128   14,816,761
00057.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           5192.646                448                     290,796,800     1,622,758
00057.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5192.646                224                     145,399,296     811,380
00057.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5192.646                51                      33,322,490      191,888
00057.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5192.646                38                      24,644,649      141,720
post #1450 of 1971 Old 02-25-2009, 04:16 PM
My Name Is Bruce
UPC: 014381509755
Code:
        Total   Video
My Name Is Bruce                                                AVC     1:24:06 15,296,931,840  22,417,619,416  24.25   20.00   DTS-HD Master 5.1 1930Kbps (48kHz/16-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     MY_NAME_IS_BRUCE
Disc Size:      22,417,619,416 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:24:06 (h:m:s)
Total Bitrate:          24.25 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        19999 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1930 kbps       5.1 / 48 kHz / 1930 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         46.018 kbps
Presentation Graphics           Spanish         40.174 kbps
FILES:
00027.M2TS      0:00:00.000     1:24:06.458     15,296,931,840  24,250
CHAPTERS:
1               0:00:00.000     0:01:14.282     17,284 kbps     27,776 kbps     00:00:16.891    25,167 kbps     00:00:53.303    25,077 kbps     00:00:48.298    90,060 bytes    348,405 bytes   00:00:52.343
2               0:01:14.282     0:06:58.167     19,045 kbps     32,744 kbps     00:07:10.888    25,805 kbps     00:07:53.890    23,575 kbps     00:07:52.680    99,291 bytes    357,130 bytes   00:07:11.597
3               0:08:12.450     0:04:48.079     23,758 kbps     31,738 kbps     00:09:09.757    29,554 kbps     00:09:23.354    29,204 kbps     00:09:21.018    123,865 bytes   280,911 bytes   00:09:34.240
4               0:13:00.529     0:04:53.459     18,017 kbps     26,665 kbps     00:17:39.141    23,435 kbps     00:17:35.137    22,666 kbps     00:17:35.137    93,931 bytes    340,268 bytes   00:17:32.092
5               0:17:53.989     0:06:35.478     19,386 kbps     30,113 kbps     00:20:00.741    27,099 kbps     00:19:57.362    25,481 kbps     00:19:55.444    101,071 bytes   284,439 bytes   00:20:20.344
6               0:24:29.467     0:03:39.219     17,915 kbps     26,418 kbps     00:25:03.043    22,237 kbps     00:27:54.297    21,666 kbps     00:27:35.278    93,402 bytes    293,515 bytes   00:25:00.248
7               0:28:08.686     0:05:21.654     23,823 kbps     31,490 kbps     00:28:49.018    29,673 kbps     00:28:45.014    29,553 kbps     00:28:40.009    124,204 bytes   327,189 bytes   00:31:13.872
8               0:33:30.341     0:07:03.506     18,980 kbps     25,159 kbps     00:39:45.132    23,000 kbps     00:38:36.230    21,987 kbps     00:38:31.225    98,955 bytes    260,383 bytes   00:36:25.850
9               0:40:33.848     0:08:04.275     20,621 kbps     31,154 kbps     00:46:10.726    26,205 kbps     00:46:09.266    24,753 kbps     00:46:09.266    107,509 bytes   337,020 bytes   00:44:55.192
10              0:48:38.123     0:04:55.169     20,690 kbps     25,365 kbps     00:52:27.352    24,170 kbps     00:52:26.601    23,573 kbps     00:52:22.597    107,866 bytes   234,149 bytes   00:52:22.639
11              0:53:33.293     0:07:10.012     20,370 kbps     35,763 kbps     00:55:57.604    28,567 kbps     00:55:56.227    27,073 kbps     00:55:53.058    106,199 bytes   447,736 bytes   00:55:30.327
12              1:00:43.306     0:04:53.960     21,804 kbps     30,805 kbps     01:04:23.067    29,517 kbps     01:01:00.365    29,048 kbps     01:00:56.444    113,678 bytes   381,245 bytes   01:03:49.200
13              1:05:37.266     0:03:28.499     22,398 kbps     31,106 kbps     01:08:51.085    29,859 kbps     01:06:06.545    29,584 kbps     01:06:01.415    116,771 bytes   334,701 bytes   01:06:11.050
14              1:09:05.766     0:10:44.644     20,077 kbps     34,929 kbps     01:16:46.768    27,529 kbps     01:19:42.819    25,212 kbps     01:19:38.690    104,673 bytes   441,133 bytes   01:17:10.125
15              1:19:50.410     0:01:29.714     23,148 kbps     33,378 kbps     01:20:02.923    29,702 kbps     01:20:35.997    29,509 kbps     01:20:35.997    120,683 bytes   341,388 bytes   01:20:03.799
16              1:21:20.125     0:02:45.331     7,845 kbps      17,819 kbps     01:23:48.940    16,335 kbps     01:23:46.146    15,178 kbps     01:23:45.103    40,900 bytes    190,088 bytes   01:23:35.176
17              1:24:05.457     0:00:01.001     674 kbps        0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    3,668 bytes     5,445 bytes     01:24:05.915
STREAM DIAGNOSTICS:
00027.M2TS      4113 (0x1011)   0x1B            AVC                                     5046.291                20,000                  12,615,454,603  68,632,897
00027.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5046.291                1,930                   1,217,610,136   7,402,574
00027.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5046.291                640                     403,717,120     2,365,530
00027.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5046.291                192                     121,115,136     788,510
00027.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5046.291                46                      29,028,443      167,283
00027.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5046.291                40                      25,341,795      145,631
post #1451 of 1971 Old 02-26-2009, 12:01 AM
momaw's Avatar
Monkey Magic
Code:
        Total   Video
00000.MPLS                                                      AVC     2:00:19 17,895,045,120  18,722,455,164  19.83   18.00   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     MONKEYMAGIC_SHOWBOX
Disc Size:      18,722,455,164 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 2:00:19 (h:m:s)
Total Bitrate:          19.83 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        17999 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio             Japanese        640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Japanese        224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           English         12.911 kbps
FILES:
00000.M2TS      0:00:00.000     2:00:19.670     17,895,045,120  19,829
CHAPTERS:
1               0:00:00.000     0:04:44.909     17,760 kbps     27,559 kbps     00:01:01.144    26,386 kbps     00:01:01.144    25,459 kbps     00:00:57.766    92,577 bytes    275,864 bytes   00:04:44.784
2               0:04:44.909     0:04:18.049     19,921 kbps     27,421 kbps     00:05:09.600    25,631 kbps     00:05:09.600    23,322 kbps     00:05:07.432    103,859 bytes   331,363 bytes   00:05:21.946
3               0:09:02.959     0:00:59.851     21,855 kbps     35,163 kbps     00:09:18.266    27,134 kbps     00:09:39.203    26,739 kbps     00:09:39.203    113,942 bytes   362,986 bytes   00:09:41.956
4               0:10:02.810     0:02:05.125     17,264 kbps     20,822 kbps     00:10:08.190    19,772 kbps     00:10:07.940    19,417 kbps     00:10:02.935    90,007 bytes    312,416 bytes   00:10:10.610
5               0:12:07.935     0:04:10.041     19,068 kbps     24,934 kbps     00:14:03.759    22,817 kbps     00:14:28.075    22,183 kbps     00:14:28.033    99,414 bytes    325,085 bytes   00:16:02.086
6               0:16:17.977     0:03:28.875     20,217 kbps     24,565 kbps     00:19:25.873    23,703 kbps     00:19:24.329    23,427 kbps     00:19:24.037    105,400 bytes   276,853 bytes   00:19:22.452
7               0:19:46.852     0:02:40.034     17,640 kbps     27,727 kbps     00:20:15.422    24,890 kbps     00:20:11.501    21,521 kbps     00:20:07.205    91,969 bytes    280,991 bytes   00:20:40.447
8               0:22:26.887     0:04:20.551     18,435 kbps     28,095 kbps     00:25:07.631    22,791 kbps     00:25:03.585    21,653 kbps     00:22:55.374    96,113 bytes    368,493 bytes   00:22:29.473
9               0:26:47.439     0:03:43.806     18,702 kbps     24,760 kbps     00:27:21.348    23,729 kbps     00:27:52.879    22,969 kbps     00:27:47.999    97,502 bytes    343,599 bytes   00:27:54.297
10              0:30:31.246     0:05:39.964     16,648 kbps     23,695 kbps     00:31:41.608    20,591 kbps     00:31:38.271    19,690 kbps     00:30:34.582    86,797 bytes    354,481 bytes   00:30:36.334
11              0:36:11.210     0:02:24.978     18,628 kbps     33,511 kbps     00:36:47.580    28,486 kbps     00:36:19.677    25,860 kbps     00:36:14.672    97,116 bytes    433,167 bytes   00:38:24.635
12              0:38:36.188     0:06:56.916     18,749 kbps     25,602 kbps     00:43:09.295    22,997 kbps     00:43:19.638    22,216 kbps     00:42:52.444    97,751 bytes    248,452 bytes   00:39:53.641
13              0:45:33.105     0:04:01.199     15,819 kbps     23,941 kbps     00:47:33.892    21,899 kbps     00:47:29.888    19,128 kbps     00:46:13.479    82,475 bytes    262,044 bytes   00:47:34.434
14              0:49:34.304     0:04:53.626     18,336 kbps     32,195 kbps     00:50:55.719    26,194 kbps     00:50:52.299    22,264 kbps     00:50:47.169    95,597 bytes    248,558 bytes   00:51:08.398
15              0:54:27.931     0:03:49.646     17,441 kbps     19,902 kbps     00:54:58.420    19,460 kbps     00:54:51.329    19,405 kbps     00:54:51.037    90,929 bytes    235,829 bytes   00:56:04.277
16              0:58:17.577     0:05:25.241     17,172 kbps     22,838 kbps     01:03:28.554    21,555 kbps     01:02:44.093    20,869 kbps     01:02:39.130    89,525 bytes    295,872 bytes   01:01:58.715
17              1:03:42.819     0:03:08.187     13,769 kbps     21,529 kbps     01:05:37.683    18,986 kbps     01:05:36.474    17,455 kbps     01:05:35.848    71,787 bytes    249,240 bytes   01:06:21.268
18              1:06:51.006     0:04:32.272     20,473 kbps     33,154 kbps     01:10:05.701    32,571 kbps     01:10:05.576    32,210 kbps     01:10:01.322    106,738 bytes   502,670 bytes   01:08:39.448
19              1:11:23.279     0:02:24.602     18,647 kbps     28,101 kbps     01:13:32.282    21,702 kbps     01:11:33.998    20,861 kbps     01:11:29.076    97,218 bytes    346,528 bytes   01:13:33.283
20              1:13:47.881     0:04:36.234     18,702 kbps     33,143 kbps     01:14:10.696    23,673 kbps     01:17:34.858    22,748 kbps     01:17:34.858    97,505 bytes    348,587 bytes   01:16:17.781
21              1:18:24.116     0:06:34.394     17,205 kbps     21,534 kbps     01:19:34.394    20,305 kbps     01:20:01.838    19,668 kbps     01:19:06.700    89,698 bytes    483,514 bytes   01:20:12.933
22              1:24:58.510     0:02:28.064     18,590 kbps     24,510 kbps     01:26:23.887    20,951 kbps     01:25:50.478    20,833 kbps     01:25:50.478    96,918 bytes    259,248 bytes   01:26:24.596
23              1:27:26.574     0:04:06.371     20,471 kbps     33,274 kbps     01:30:18.162    28,404 kbps     01:30:17.662    26,421 kbps     01:30:49.652    106,725 bytes   279,693 bytes   01:30:19.163
24              1:31:32.945     0:03:38.760     21,519 kbps     32,879 kbps     01:32:12.693    26,777 kbps     01:31:56.844    26,459 kbps     01:32:03.851    112,190 bytes   345,659 bytes   01:32:12.818
25              1:35:11.706     0:04:12.710     18,053 kbps     26,238 kbps     01:35:23.259    22,245 kbps     01:35:11.789    21,004 kbps     01:37:34.056    94,120 bytes    235,222 bytes   01:37:58.205
26              1:39:24.416     0:03:46.809     13,278 kbps     24,650 kbps     01:39:31.465    19,232 kbps     01:39:30.422    18,114 kbps     01:39:24.750    69,224 bytes    240,577 bytes   01:39:31.840
27              1:43:11.226     0:06:29.889     14,752 kbps     21,908 kbps     01:45:21.189    19,660 kbps     01:49:02.994    19,263 kbps     01:49:26.142    76,908 bytes    259,710 bytes   01:48:58.532
28              1:49:41.116     0:03:56.986     21,198 kbps     26,098 kbps     01:52:24.529    24,968 kbps     01:52:03.341    24,263 kbps     01:53:17.665    110,517 bytes   286,689 bytes   01:52:59.063
29              1:53:38.102     0:01:29.214     21,808 kbps     26,606 kbps     01:54:10.218    25,891 kbps     01:54:08.591    25,034 kbps     01:54:06.089    113,697 bytes   318,251 bytes   01:54:25.108
30              1:55:07.317     0:05:12.353     15,676 kbps     21,011 kbps     01:56:09.212    20,659 kbps     01:56:08.211    20,243 kbps     01:56:06.793    81,737 bytes    227,913 bytes   01:59:45.803
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     7219.587                17,999                  16,243,293,827  88,379,581
00000.M2TS      4352 (0x1100)   0x81            AC3             jpn (Japanese)          7219.587                640                     577,574,400     3,384,225
00000.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          7219.587                224                     202,151,040     1,128,075
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7219.587                13                      11,651,209      69,598
momaw is offline
post #1452 of 1971 Old 02-26-2009, 12:18 AM
Phloyd's Avatar
Disc Title: Poison Ivy 4
UPC 794043124679
Not too sharp and artifacts are evident.
Screen Caps Here
Code:
        Total   Video
Poison Ivy 4                                                    VC-1    1:35:08 15,650,138,112  15,760,012,015  21.93   20.22   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Size:      15,760,012,015 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:35:08 (h:m:s)
Total Bitrate:          21.93 Mbps
Description:
VIDEO:
VC-1 Video              20224 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
SUBTITLES:
Presentation Graphics           English         29.682 kbps
FILES:
00000.M2TS      0:00:00.000     1:35:08.911     15,650,138,112  21,931
CHAPTERS:
1               0:00:00.000     0:04:26.099     23,283 kbps     47,875 kbps     00:00:58.767    31,697 kbps     00:04:13.503    29,366 kbps     00:04:08.164    122,482 bytes   622,580 bytes   00:01:05.857
2               0:04:26.099     0:05:00.508     22,431 kbps     43,164 kbps     00:04:46.452    33,164 kbps     00:07:17.562    32,485 kbps     00:07:17.145    116,943 bytes   669,464 bytes   00:05:08.141
3               0:09:26.607     0:04:14.128     19,513 kbps     41,887 kbps     00:10:01.934    28,944 kbps     00:11:57.299    26,641 kbps     00:11:58.300    101,733 bytes   530,120 bytes   00:13:40.653
4               0:13:40.736     0:07:26.028     20,288 kbps     41,204 kbps     00:17:04.064    31,453 kbps     00:18:31.026    29,843 kbps     00:18:31.026    105,969 bytes   624,114 bytes   00:18:33.612
5               0:21:06.765     0:03:08.187     20,636 kbps     41,422 kbps     00:22:27.054    31,197 kbps     00:22:11.038    29,579 kbps     00:22:27.054    107,586 bytes   572,121 bytes   00:22:27.095
6               0:24:14.953     0:03:01.306     18,318 kbps     38,203 kbps     00:26:53.111    29,513 kbps     00:25:16.973    28,638 kbps     00:25:15.597    95,499 bytes    754,203 bytes   00:27:13.798
7               0:27:16.259     0:06:58.000     25,921 kbps     41,416 kbps     00:32:56.599    35,487 kbps     00:30:52.433    32,426 kbps     00:30:47.428    135,139 bytes   559,860 bytes   00:27:19.262
8               0:34:14.260     0:04:18.174     20,738 kbps     40,822 kbps     00:35:40.471    34,712 kbps     00:35:22.411    32,316 kbps     00:35:17.406    108,116 bytes   672,862 bytes   00:35:12.735
9               0:38:32.435     0:07:16.310     22,880 kbps     45,812 kbps     00:45:45.492    34,160 kbps     00:42:56.240    32,208 kbps     00:42:33.467    120,030 bytes   560,654 bytes   00:42:56.407
10              0:45:48.746     0:04:12.460     21,782 kbps     49,727 kbps     00:46:29.453    32,741 kbps     00:45:49.246    30,407 kbps     00:45:49.246    113,617 bytes   611,630 bytes   00:45:52.750
11              0:50:01.206     0:03:16.195     24,190 kbps     39,699 kbps     00:50:04.084    30,579 kbps     00:50:25.522    29,565 kbps     00:50:25.647    126,116 bytes   803,952 bytes   00:53:17.319
12              0:53:17.402     0:02:48.042     17,829 kbps     50,436 kbps     00:55:11.308    30,222 kbps     00:55:01.965    26,582 kbps     00:55:02.799    92,950 bytes    488,313 bytes   00:55:44.257
13              0:56:05.445     0:05:06.764     20,199 kbps     47,563 kbps     01:00:22.160    32,238 kbps     01:00:29.876    31,656 kbps     01:00:22.535    105,311 bytes   695,563 bytes   01:00:22.577
14              1:01:12.210     0:03:08.646     20,518 kbps     40,674 kbps     01:04:11.097    32,008 kbps     01:02:06.139    29,587 kbps     01:02:05.555    106,971 bytes   536,049 bytes   01:01:46.953
15              1:04:20.857     0:05:47.347     16,954 kbps     42,136 kbps     01:04:24.110    30,288 kbps     01:07:03.644    29,125 kbps     01:06:58.639    88,391 bytes    624,533 bytes   01:07:53.527
16              1:10:08.204     0:02:58.720     22,026 kbps     40,817 kbps     01:11:08.806    33,248 kbps     01:11:52.516    31,980 kbps     01:11:47.511    115,102 bytes   430,408 bytes   01:10:35.147
17              1:13:06.924     0:05:18.735     22,698 kbps     40,068 kbps     01:16:10.148    34,368 kbps     01:14:18.579    31,147 kbps     01:16:53.317    118,339 bytes   441,728 bytes   01:15:24.394
18              1:18:25.659     0:06:04.530     17,308 kbps     43,004 kbps     01:20:17.979    34,133 kbps     01:18:56.314    32,005 kbps     01:18:51.601    90,234 bytes    589,932 bytes   01:20:18.814
19              1:24:30.190     0:04:14.128     21,710 kbps     41,651 kbps     01:26:15.170    31,644 kbps     01:26:14.919    29,164 kbps     01:26:14.544    113,879 bytes   440,391 bytes   01:28:19.460
20              1:28:44.319     0:02:21.558     20,055 kbps     41,596 kbps     01:31:02.498    30,070 kbps     01:30:58.494    28,639 kbps     01:30:53.489    106,440 bytes   653,968 bytes   01:30:48.109
21              1:31:05.877     0:04:03.034     433 kbps        2,631 kbps      01:35:03.072    2,019 kbps      01:35:01.904    1,446 kbps      01:34:56.899    32,800 bytes    239,655 bytes   01:35:04.198
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    5708.828                20,225                  14,432,353,971  78,521,342
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5708.828                640                     456,714,240     2,676,060
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5708.828                30                      21,181,237      122,444
Phloyd is offline
post #1453 of 1971 Old 02-27-2009, 02:03 AM
Kannisto's Avatar
Code:
        Total   Video
Ip Man (HK)                                                     AVC     1:46:21 34,264,104,960  42,657,355,448  42.96   25.15   LPCM 7.1 6144Kbps (48kHz/16-bit)          DTS-HD Master 7.1 2681Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     IPMAN
Disc Size:      42,657,355,448 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:46:21 (h:m:s)
Total Bitrate:          42.96 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        25147 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      Chinese         6144 kbps       7.1 / 48 kHz / 6144 kbps / 16-bit
DTS-HD Master Audio             Chinese         2681 kbps       7.1 / 48 kHz / 2681 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             Chinese         2437 kbps       7.1 / 48 kHz / 2437 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby TrueHD Audio              Chinese         1766 kbps       7.1 / 48 kHz / 1766 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             Chinese         640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         25.502 kbps
Presentation Graphics           Chinese         21.209 kbps
FILES:
00000.M2TS      0:00:00.000     1:46:21.041     34,264,104,960  42,957
CHAPTERS:
1               0:00:00.000     0:07:37.375     24,203 kbps     30,347 kbps     00:03:17.583    26,978 kbps     00:02:47.375    26,112 kbps     00:03:08.541    126,045 bytes   361,981 bytes   00:04:07.750
2               0:07:37.375     0:07:04.625     25,791 kbps     28,709 kbps     00:11:28.666    26,542 kbps     00:07:40.250    26,119 kbps     00:09:18.125    134,328 bytes   323,790 bytes   00:09:28.166
3               0:14:42.000     0:06:43.750     25,699 kbps     28,791 kbps     00:19:23.583    26,370 kbps     00:20:52.958    26,070 kbps     00:20:27.458    133,848 bytes   293,918 bytes   00:15:27.250
4               0:21:25.750     0:06:42.791     25,730 kbps     29,612 kbps     00:24:16.208    26,240 kbps     00:25:13.208    26,087 kbps     00:21:47.625    134,010 bytes   308,890 bytes   00:24:17.125
5               0:28:08.541     0:06:44.375     25,655 kbps     30,300 kbps     00:30:20.375    26,598 kbps     00:30:16.333    26,121 kbps     00:33:05.250    133,619 bytes   509,840 bytes   00:29:10.583
6               0:34:52.916     0:07:32.416     25,176 kbps     28,644 kbps     00:39:55.000    26,349 kbps     00:37:39.958    26,142 kbps     00:40:49.625    131,127 bytes   336,177 bytes   00:37:42.000
7               0:42:25.333     0:05:09.666     25,167 kbps     28,672 kbps     00:46:25.916    26,205 kbps     00:42:31.541    26,031 kbps     00:44:38.666    131,080 bytes   293,225 bytes   00:42:37.250
8               0:47:35.000     0:08:32.291     25,343 kbps     28,646 kbps     00:49:51.500    26,331 kbps     00:48:07.250    26,046 kbps     00:48:02.250    131,994 bytes   368,657 bytes   00:51:21.208
9               0:56:07.291     0:07:24.125     25,499 kbps     29,437 kbps     00:59:22.625    26,211 kbps     00:57:28.125    26,039 kbps     00:56:07.333    132,809 bytes   293,072 bytes   01:00:43.541
10              1:03:31.416     0:07:31.791     25,197 kbps     28,313 kbps     01:07:20.250    26,244 kbps     01:08:25.583    26,061 kbps     01:04:28.541    131,235 bytes   308,802 bytes   01:06:46.791
11              1:11:03.208     0:07:29.291     25,609 kbps     29,088 kbps     01:14:49.083    26,469 kbps     01:14:34.125    26,151 kbps     01:15:30.916    133,379 bytes   350,297 bytes   01:15:15.750
12              1:18:32.500     0:07:21.375     25,633 kbps     31,315 kbps     01:25:52.041    27,535 kbps     01:25:48.208    26,741 kbps     01:25:43.083    133,503 bytes   348,151 bytes   01:25:52.875
13              1:25:53.875     0:08:17.541     25,728 kbps     27,849 kbps     01:30:23.541    26,313 kbps     01:34:06.291    26,059 kbps     01:27:50.291    133,998 bytes   278,165 bytes   01:29:07.375
14              1:34:11.416     0:07:11.833     25,546 kbps     30,512 kbps     01:39:17.500    26,661 kbps     01:39:13.458    26,107 kbps     01:38:25.208    133,051 bytes   371,149 bytes   01:37:55.625
15              1:41:23.250     0:04:57.791     19,492 kbps     29,352 kbps     01:42:02.208    26,645 kbps     01:41:58.250    26,151 kbps     01:41:53.083    101,533 bytes   367,962 bytes   01:44:48.791
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6380.875                25,148                  20,058,302,165  109,101,843
00000.M2TS      4352 (0x1100)   0x80            LPCM            zho (Chinese)           6380.875                6,151                   4,905,747,396   26,800,389
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       zho (Chinese)           6380.875                2,437                   1,944,045,336   11,561,348
00000.M2TS      4354 (0x1102)   0x83            TrueHD          zho (Chinese)           6380.875                2,406                   1,919,167,874   14,963,670
00000.M2TS      4355 (0x1103)   0x86            DTS-HD MA       zho (Chinese)           6380.875                2,681                   2,138,368,312   12,611,783
00000.M2TS      4356 (0x1104)   0x81            AC3             zho (Chinese)           6380.875                640                     510,484,480     2,991,120
00000.M2TS      4608 (0x1200)   0x90            PGS             zho (Chinese)           6380.875                21                      16,917,116      98,070
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6380.875                26                      20,341,385      116,875
Cantonese LPCM 7.1, DTS-HD MA 7.1 & DD TrueHD 7.1 and Mandarin DTS-HD MA 7.1 & DD 5.1.
P.S. I tried to scan the new Japanese Mamoru Oshii Anime release "The Sky Crawlers" earlier this week but BD Info 5.2 couldn't find a playlist from the disc that contains the actual movie.
HD DVD: 387 (new: Taking Lives ; list)
Blu-ray: 262 (new: North Face (UK) ; list)
HD DVD-R: 262 (new: Charlie Wilson's War ; list)
Kannisto is offline
post #1454 of 1971 Old 02-27-2009, 04:26 AM
House's Avatar
It has a "bad" playlist so you have to disable that option in bdinfo before it'll pick it up.
Code:
        Total   Video
The Sky Crawlers                                                AVC     2:02:22 36,415,920,576  37,721,214,416  39.68   32.40   DTS-HD Master 6.1 2179Kbps (48kHz/16-bit) Dolby TrueHD 6.1 1674Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     BDROM
Disc Size:      37,721,214,416 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:02:22 (h:m:s)
Total Bitrate:          39.68 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        32400 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             Japanese        2179 kbps       6.1 / 48 kHz / 2179 kbps / 16-bit (DTS Core: 6.1-ES / 48 kHz / 1509 kbps / 16-bit)
Dolby TrueHD Audio              Japanese        1674 kbps       6.1 / 48 kHz / 1674 kbps / 16-bit (AC3 Core: 5.1-EX / 48 kHz / 448 kbps)
SUBTITLES:
Presentation Graphics           Japanese        5.708 kbps
Presentation Graphics           Japanese        44.681 kbps
FILES:
00000.M2TS      0:00:00.000     2:02:08.321     36,396,980,736  39,733
00000.M2TS      2:02:08.321     0:00:14.013     18,939,840      10,812
CHAPTERS:
1               0:00:00.000     0:05:15.314     30,240 kbps     61,144 kbps     00:01:03.146    40,286 kbps     00:01:24.209    38,737 kbps     00:01:23.833    157,638 bytes   695,341 bytes   00:01:03.188
2               0:05:15.314     0:03:34.255     33,532 kbps     41,643 kbps     00:07:47.717    34,963 kbps     00:05:24.490    34,280 kbps     00:07:32.994    174,819 bytes   711,814 bytes   00:05:28.578
3               0:08:49.570     0:08:16.412     33,540 kbps     44,592 kbps     00:15:10.159    37,439 kbps     00:14:47.094    35,673 kbps     00:15:09.825    174,863 bytes   727,726 bytes   00:16:22.356
4               0:17:05.983     0:02:45.206     33,501 kbps     39,161 kbps     00:18:24.728    34,368 kbps     00:19:12.693    34,030 kbps     00:17:08.736    174,660 bytes   633,850 bytes   00:19:19.366
5               0:19:51.189     0:08:15.244     33,468 kbps     40,857 kbps     00:24:21.585    35,398 kbps     00:27:50.835    34,380 kbps     00:25:08.673    174,488 bytes   754,528 bytes   00:24:15.078
6               0:28:06.434     0:07:40.710     33,250 kbps     40,783 kbps     00:31:56.956    35,111 kbps     00:29:47.952    34,400 kbps     00:29:42.947    173,352 bytes   783,267 bytes   00:30:31.454
7               0:35:47.145     0:05:26.659     33,038 kbps     41,545 kbps     00:35:55.361    35,737 kbps     00:37:38.089    34,444 kbps     00:39:03.883    172,246 bytes   781,119 bytes   00:38:58.127
8               0:41:13.804     0:06:31.265     33,456 kbps     44,776 kbps     00:44:30.125    38,036 kbps     00:44:26.872    35,331 kbps     00:44:26.914    174,422 bytes   781,551 bytes   00:42:58.951
9               0:47:45.070     0:02:23.852     33,187 kbps     38,642 kbps     00:49:31.301    34,949 kbps     00:48:08.677    34,193 kbps     00:48:02.170    173,020 bytes   781,972 bytes   00:48:47.132
10              0:50:08.922     0:03:32.295     33,203 kbps     42,802 kbps     00:50:28.191    35,420 kbps     00:50:24.187    34,363 kbps     00:50:19.266    173,107 bytes   754,567 bytes   00:50:35.782
11              0:53:41.218     0:07:11.222     33,602 kbps     52,696 kbps     01:00:26.873    38,065 kbps     00:53:41.218    36,021 kbps     00:53:41.218    175,186 bytes   714,856 bytes   00:56:59.374
12              1:00:52.440     0:06:42.068     33,453 kbps     40,278 kbps     01:04:23.192    35,626 kbps     01:03:33.017    34,369 kbps     01:04:33.327    174,409 bytes   738,678 bytes   01:04:50.261
13              1:07:34.508     0:03:19.616     33,463 kbps     41,060 kbps     01:09:06.350    34,637 kbps     01:08:11.003    34,255 kbps     01:09:59.695    174,461 bytes   728,455 bytes   01:07:39.889
14              1:10:54.124     0:01:51.444     33,564 kbps     42,305 kbps     01:11:36.250    35,085 kbps     01:11:32.204    34,368 kbps     01:11:27.157    174,986 bytes   527,591 bytes   01:12:45.569
15              1:12:45.569     0:08:16.621     33,543 kbps     48,574 kbps     01:17:50.290    36,392 kbps     01:17:50.207    35,196 kbps     01:17:49.206    174,875 bytes   709,285 bytes   01:13:26.360
16              1:21:02.190     0:04:52.959     33,445 kbps     41,700 kbps     01:22:37.702    36,685 kbps     01:22:35.825    35,206 kbps     01:22:36.618    174,367 bytes   716,723 bytes   01:24:37.864
17              1:25:55.150     0:05:32.540     33,313 kbps     46,347 kbps     01:30:15.576    35,993 kbps     01:30:12.240    35,687 kbps     01:30:06.401    173,677 bytes   644,352 bytes   01:29:36.662
18              1:31:27.690     0:04:56.546     33,111 kbps     39,507 kbps     01:34:12.897    34,875 kbps     01:32:57.280    34,270 kbps     01:35:24.635    172,628 bytes   696,961 bytes   01:31:28.483
19              1:36:24.236     0:03:01.431     33,344 kbps     41,726 kbps     01:36:24.862    36,296 kbps     01:36:24.278    35,091 kbps     01:36:24.236    173,843 bytes   701,155 bytes   01:36:25.029
20              1:39:25.668     0:05:19.610     33,308 kbps     38,715 kbps     01:39:27.127    34,490 kbps     01:41:57.528    34,067 kbps     01:39:27.169    173,652 bytes   603,666 bytes   01:39:30.631
21              1:44:45.279     0:03:27.498     33,432 kbps     51,071 kbps     01:44:45.320    38,681 kbps     01:44:45.278    36,430 kbps     01:44:45.279    174,298 bytes   595,924 bytes   01:46:32.719
22              1:48:12.777     0:05:29.162     33,611 kbps     47,034 kbps     01:52:56.394    37,125 kbps     01:53:19.626    35,098 kbps     01:48:13.069    175,234 bytes   631,048 bytes   01:53:40.939
23              1:53:41.940     0:02:29.023     32,966 kbps     42,074 kbps     01:56:05.500    35,145 kbps     01:56:01.371    34,357 kbps     01:55:56.366    171,869 bytes   660,663 bytes   01:54:30.029
24              1:56:10.964     0:05:57.356     16,746 kbps     57,720 kbps     02:00:23.633    38,976 kbps     02:00:33.476    38,360 kbps     02:00:40.066    87,306 bytes    774,309 bytes   02:02:03.065
25              2:02:08.321     0:00:14.013     16,981,501 kbps 61,144 kbps     00:01:03.146    40,286 kbps     00:01:24.209    38,737 kbps     00:01:23.833    168,662 bytes   783,267 bytes   00:30:31.454
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     7342.252                32,401                  29,736,751,450  161,716,115
00000.M2TS      4352 (0x1100)   0x83            TrueHD          jpn (Japanese)          7342.252                2,122                   1,947,430,894   15,429,418
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       jpn (Japanese)          7342.252                2,179                   1,999,438,948   12,011,140
00000.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          7342.252                6                       5,239,146       29,593
00000.M2TS      4609 (0x1201)   0x90            PGS             jpn (Japanese)          7342.252                45                      41,007,814      233,866
House is offline
post #1455 of 1971 Old 02-27-2009, 08:09 AM
Cinema Squid's Avatar
Code:
FILES:
Yes, this seems to have the same M2TS file listed twice in the playlist, so it is filtered out of the BDInfo display by default. As House said, you just need to uncheck the "filter invalid playlist" option in the settings and rescan the disc.
The reason for doing this is that the playlist for the main menu loop usually has the same files pasted a large number of times in the playlist. It's not really "invalid" per se, but the current highly sophisticated algorithm for floating the presumed main feature to the top of the list is to sort the playlists in descending length order. The main menu loop playlist will frequently be the longest, so I just hide playlists with duplicate M2TS by default to lessen confusion. There's probably a better way...
Cinema Squid is offline
post #1456 of 1971 Old 02-27-2009, 09:36 PM
mpgxsvcd's Avatar
Quoted: 2957 Post(s)
Liked: 2617
Originally Posted by Cinema Squid View Post
There are over 20 Warner titles that have a lower video bitrate than the Japanese 192 kHz TrueHD audio track on Akira, including:
2001: A Space Odyssey, Batman Begins, Blood Diamond, Constantine, Happy Feet, Harry Potter and the Goblet of Fire, Harry Potter and the Order of the Phoenix, Justice League of America: Season One, Lady in the Water, The Matrix Reloaded, The Matrix Revolutions, One Flew Over the Cuckoo's Nest, The Reaping, Star Wars: The Clone Wars, Supernatural: The Complete Third Season, Syriana, Terminator 3: Rise of the Machines, TMNT: Teenage Mutant Ninja Turtles, Training Day, Troy, V for Vendetta and Wedding Crashers.
Just remember that Divertimenti has not 1 but 3 192 Khz 24 bit lossless 5.1 Channel Tracks! It also has 2 channel 24 Bit 192 Khz track for good measure. I just can't get the stupid program to work on my computer or I would post the results myself.
mpgxsvcd is offline
post #1457 of 1971 Old 02-27-2009, 11:35 PM
Kannisto's Avatar
Thanks to you and House for explaining about this, now I'll know how to tackle the problem if I see it again with some other disc.
Kannisto is offline
post #1458 of 1971 Old 03-01-2009, 08:01 PM
Appaloosa
UPC: 794043127823
Code:
        Total   Video
Appaloosa                                                       VC-1    1:55:25 20,055,435,264  22,537,783,644  23.17   18.56   Dolby TrueHD 5.1 1271Kbps (48kHz/16-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     APPALOOSA
Disc Size:      22,537,783,644 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:55:25 (h:m:s)
Total Bitrate:          23.17 Mbps
Description:
VIDEO:
VC-1 Video              18564 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         1271 kbps       5.1 / 48 kHz / 1271 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         27.018 kbps
Presentation Graphics           Spanish         23.636 kbps
FILES:
00000.M2TS      0:00:00.000     1:55:25.168     20,055,435,264  23,168
CHAPTERS:
1               0:00:00.000     0:02:40.076     16,565 kbps     35,410 kbps     00:01:00.810    30,868 kbps     00:00:56.973    28,826 kbps     00:00:54.387    87,022 bytes    416,979 bytes   00:00:54.429
2               0:02:40.076     0:05:38.838     17,746 kbps     40,708 kbps     00:04:17.840    32,441 kbps     00:04:17.840    29,287 kbps     00:04:16.339    92,613 bytes    463,647 bytes   00:04:12.752
3               0:08:18.915     0:01:56.908     16,191 kbps     23,234 kbps     00:09:43.666    20,520 kbps     00:09:43.457    19,158 kbps     00:09:43.666    84,410 bytes    305,876 bytes   00:10:03.602
4               0:10:15.823     0:04:31.229     16,508 kbps     35,988 kbps     00:10:28.836    31,207 kbps     00:10:28.836    25,271 kbps     00:10:28.836    86,066 bytes    388,665 bytes   00:10:28.878
5               0:14:47.052     0:04:43.116     19,597 kbps     40,822 kbps     00:15:21.879    31,186 kbps     00:16:40.416    29,155 kbps     00:16:35.703    102,168 bytes   352,875 bytes   00:15:49.823
6               0:19:30.169     0:02:36.906     16,354 kbps     23,442 kbps     00:19:42.931    20,625 kbps     00:21:50.058    19,490 kbps     00:19:40.637    85,262 bytes    350,943 bytes   00:22:07.075
7               0:22:07.075     0:06:02.195     18,083 kbps     35,148 kbps     00:24:25.922    31,747 kbps     00:24:25.922    24,693 kbps     00:23:54.808    94,278 bytes    356,731 bytes   00:22:11.747
8               0:28:09.270     0:04:35.775     17,821 kbps     38,045 kbps     00:30:32.705    33,457 kbps     00:30:30.954    29,080 kbps     00:30:30.954    92,910 bytes    436,725 bytes   00:30:30.995
9               0:32:45.046     0:02:06.960     16,558 kbps     19,879 kbps     00:33:14.492    18,966 kbps     00:33:54.574    18,440 kbps     00:34:06.294    86,328 bytes    390,390 bytes   00:34:51.923
10              0:34:52.006     0:03:38.051     20,642 kbps     42,552 kbps     00:37:15.691    34,878 kbps     00:34:52.298    31,837 kbps     00:38:05.700    107,616 bytes   447,303 bytes   00:37:08.059
11              0:38:30.057     0:02:54.799     16,956 kbps     26,762 kbps     00:38:52.079    24,156 kbps     00:38:51.787    22,873 kbps     00:38:52.038    88,403 bytes    296,287 bytes   00:38:59.003
12              0:41:24.857     0:04:30.353     14,448 kbps     22,407 kbps     00:44:34.797    19,926 kbps     00:41:35.284    19,270 kbps     00:41:34.200    75,323 bytes    283,093 bytes   00:42:58.576
13              0:45:55.210     0:03:26.581     21,343 kbps     45,719 kbps     00:47:46.363    33,306 kbps     00:48:03.422    29,270 kbps     00:47:46.113    111,270 bytes   417,510 bytes   00:47:51.201
14              0:49:21.792     0:04:23.471     18,824 kbps     36,078 kbps     00:51:15.530    34,414 kbps     00:51:11.526    31,335 kbps     00:51:06.521    98,139 bytes    351,675 bytes   00:52:19.594
15              0:53:45.263     0:03:52.649     15,452 kbps     25,898 kbps     00:55:38.752    20,510 kbps     00:55:36.249    18,649 kbps     00:55:35.540    80,561 bytes    307,605 bytes   00:56:22.754
16              0:57:37.912     0:06:48.783     21,007 kbps     42,263 kbps     01:02:22.447    32,269 kbps     00:59:46.124    31,316 kbps     00:59:43.997    109,523 bytes   500,378 bytes   01:04:26.529
17              1:04:26.696     0:04:03.076     16,982 kbps     35,750 kbps     01:06:03.250    31,967 kbps     01:05:05.860    31,351 kbps     01:05:05.943    88,537 bytes    436,691 bytes   01:05:43.606
18              1:08:29.772     0:04:41.531     22,500 kbps     40,967 kbps     01:10:20.382    32,315 kbps     01:11:23.946    30,828 kbps     01:11:21.235    117,306 bytes   473,444 bytes   01:10:42.780
19              1:13:11.303     0:04:47.912     19,473 kbps     32,907 kbps     01:15:35.739    30,626 kbps     01:15:06.835    27,970 kbps     01:15:06.251    101,524 bytes   438,846 bytes   01:15:34.029
20              1:17:59.216     0:02:56.676     15,559 kbps     25,502 kbps     01:18:37.421    23,210 kbps     01:18:43.802    21,931 kbps     01:18:39.798    81,119 bytes    672,490 bytes   01:20:55.851
21              1:20:55.892     0:06:09.160     25,153 kbps     42,317 kbps     01:21:38.768    34,300 kbps     01:26:06.578    32,421 kbps     01:21:50.322    131,137 bytes   442,326 bytes   01:20:58.812
22              1:27:05.053     0:02:22.851     19,001 kbps     34,675 kbps     01:28:22.088    31,692 kbps     01:28:49.824    29,658 kbps     01:28:46.904    99,061 bytes    473,699 bytes   01:29:23.191
23              1:29:27.904     0:05:47.597     19,219 kbps     32,128 kbps     01:29:28.446    27,927 kbps     01:32:05.728    26,220 kbps     01:31:35.823    100,196 bytes   378,292 bytes   01:32:02.350
24              1:35:15.501     0:04:49.706     20,759 kbps     32,264 kbps     01:38:47.004    31,445 kbps     01:38:55.763    31,352 kbps     01:38:54.595    108,230 bytes   346,202 bytes   01:37:34.014
25              1:40:05.207     0:04:42.657     17,212 kbps     29,913 kbps     01:43:46.845    23,567 kbps     01:44:00.275    22,011 kbps     01:43:55.270    89,737 bytes    360,172 bytes   01:41:58.821
26              1:44:47.864     0:03:24.537     19,295 kbps     37,784 kbps     01:46:56.243    32,112 kbps     01:46:28.799    27,521 kbps     01:46:36.681    100,634 bytes   415,763 bytes   01:47:19.599
27              1:48:12.402     0:07:12.765     15,252 kbps     52,705 kbps     01:48:20.619    34,501 kbps     01:48:20.619    31,658 kbps     01:48:20.619    79,679 bytes    670,962 bytes   01:50:18.737
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    6925.043                18,565                  16,070,279,215  87,437,883
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6925.043                640                     554,014,720     3,246,180
00000.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           6925.043                1,911                   1,653,857,074   12,204,463
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6925.043                192                     166,204,416     1,082,060
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6925.043                27                      23,387,937      134,588
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6925.043                24                      20,460,814      118,202
post #1459 of 1971 Old 03-01-2009, 08:04 PM
Pirates II: Stagnetti's Revenge (R-Rated)
UPC: 787633017048
Code:
        Total   Video
Pirates II: Stagnetti's Revenge  (R-Rated)                      AVC     1:32:15 16,584,394,752  21,364,545,298  23.97   22.00   DD AC3 5.1 384Kbps                        DD AC3 2.0 192Kbps
Code:
DISC INFO:
Disc Title:     PIRATES 2
Disc Size:      21,364,545,298 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:32:15 (h:m:s)
Total Bitrate:          23.97 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        21998 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio             English         384 kbps        5.1 / 48 kHz / 384 kbps
SUBTITLES:
Presentation Graphics           Spanish         24.159 kbps
FILES:
00002.M2TS      0:00:00.000     1:32:15.738     16,584,394,752  23,967
CHAPTERS:
1               0:00:00.000     0:00:42.292     13,988 kbps     26,871 kbps     00:00:10.969    18,236 kbps     00:00:06.965    16,883 kbps     00:00:09.175    72,853 bytes    238,390 bytes   00:00:11.970
2               0:00:42.292     0:01:34.427     22,085 kbps     29,101 kbps     00:02:03.498    25,116 kbps     00:00:53.344    24,520 kbps     00:02:03.540    115,143 bytes   290,959 bytes   00:00:56.931
3               0:02:16.719     0:01:30.006     23,225 kbps     30,125 kbps     00:02:24.561    25,566 kbps     00:02:58.219    24,643 kbps     00:03:16.863    121,082 bytes   392,244 bytes   00:03:26.748
4               0:03:46.726     0:02:09.754     23,502 kbps     27,662 kbps     00:04:30.353    25,559 kbps     00:04:57.380    25,166 kbps     00:04:57.422    122,531 bytes   296,199 bytes   00:03:53.149
5               0:05:56.481     0:02:14.008     23,527 kbps     34,721 kbps     00:06:54.372    28,702 kbps     00:06:50.243    25,437 kbps     00:07:52.388    122,661 bytes   319,043 bytes   00:07:59.645
6               0:08:10.490     0:00:30.530     18,669 kbps     29,655 kbps     00:08:23.169    24,821 kbps     00:08:20.625    22,164 kbps     00:08:15.620    97,332 bytes    433,796 bytes   00:08:22.210
7               0:08:41.020     0:01:14.532     24,314 kbps     27,769 kbps     00:09:54.051    26,785 kbps     00:08:54.700    26,183 kbps     00:08:49.612    126,763 bytes   319,554 bytes   00:09:55.011
8               0:09:55.553     0:01:08.067     21,464 kbps     31,427 kbps     00:10:00.516    25,976 kbps     00:10:36.761    24,419 kbps     00:10:44.560    111,902 bytes   373,538 bytes   00:09:57.722
9               0:11:03.621     0:01:32.133     20,729 kbps     26,738 kbps     00:12:28.831    25,449 kbps     00:12:24.827    23,905 kbps     00:11:16.675    108,070 bytes   284,789 bytes   00:12:35.087
10              0:12:35.755     0:01:34.803     22,701 kbps     31,345 kbps     00:12:43.429    24,979 kbps     00:12:51.854    24,027 kbps     00:13:58.504    118,351 bytes   339,275 bytes   00:12:48.225
11              0:14:10.558     0:04:54.544     21,449 kbps     30,845 kbps     00:16:08.634    25,178 kbps     00:17:57.201    24,030 kbps     00:18:43.163    111,823 bytes   388,046 bytes   00:14:55.978
12              0:19:05.102     0:02:15.802     22,389 kbps     28,140 kbps     00:19:11.900    25,427 kbps     00:20:41.990    24,464 kbps     00:20:41.281    116,727 bytes   311,490 bytes   00:20:35.734
13              0:21:20.904     0:00:56.181     22,879 kbps     27,329 kbps     00:22:09.411    24,999 kbps     00:21:24.199    24,067 kbps     00:21:21.113    119,278 bytes   266,115 bytes   00:22:07.451
14              0:22:17.085     0:01:34.302     21,610 kbps     28,724 kbps     00:23:27.781    25,482 kbps     00:22:17.085    23,260 kbps     00:22:17.961    112,665 bytes   294,691 bytes   00:23:30.992
15              0:23:51.388     0:02:34.654     22,665 kbps     27,040 kbps     00:26:16.283    25,255 kbps     00:26:14.656    24,176 kbps     00:26:12.529    118,165 bytes   278,297 bytes   00:24:35.474
16              0:26:26.042     0:00:42.542     23,324 kbps     27,046 kbps     00:27:01.119    24,923 kbps     00:27:03.496    24,396 kbps     00:26:39.848    121,602 bytes   319,981 bytes   00:27:08.460
17              0:27:08.585     0:01:03.855     22,166 kbps     29,331 kbps     00:27:46.831    26,704 kbps     00:27:49.626    26,265 kbps     00:27:44.621    115,563 bytes   353,618 bytes   00:27:31.232
18              0:28:12.440     0:05:28.494     21,724 kbps     30,108 kbps     00:30:06.429    26,213 kbps     00:28:19.322    25,446 kbps     00:28:14.275    113,257 bytes   281,981 bytes   00:29:57.879
19              0:33:40.935     0:01:32.467     24,734 kbps     26,779 kbps     00:34:35.239    25,977 kbps     00:34:32.236    25,673 kbps     00:34:44.165    128,953 bytes   308,857 bytes   00:33:59.412
20              0:35:13.402     0:02:41.828     23,056 kbps     30,943 kbps     00:35:21.452    25,552 kbps     00:37:22.365    25,271 kbps     00:35:28.126    120,206 bytes   394,456 bytes   00:35:24.622
21              0:37:55.231     0:00:50.050     24,716 kbps     27,161 kbps     00:37:56.857    26,565 kbps     00:37:55.231    25,703 kbps     00:37:55.231    128,859 bytes   294,138 bytes   00:38:44.697
22              0:38:45.281     0:00:58.057     23,998 kbps     26,495 kbps     00:39:32.411    25,153 kbps     00:39:14.018    24,568 kbps     00:39:24.820    125,114 bytes   263,162 bytes   00:39:00.421
23              0:39:43.339     0:01:53.112     23,621 kbps     29,183 kbps     00:41:29.236    26,178 kbps     00:41:27.026    24,959 kbps     00:40:41.897    123,147 bytes   278,750 bytes   00:41:34.992
24              0:41:36.452     0:01:55.615     22,307 kbps     29,992 kbps     00:43:08.377    26,411 kbps     00:43:07.751    24,754 kbps     00:43:06.709    116,301 bytes   342,657 bytes   00:41:54.929
25              0:43:32.067     0:00:32.449     21,614 kbps     26,712 kbps     00:43:36.405    24,234 kbps     00:43:32.401    22,297 kbps     00:43:32.151    112,687 bytes   339,427 bytes   00:43:39.366
26              0:44:04.516     0:01:00.810     21,224 kbps     31,021 kbps     00:44:28.332    24,354 kbps     00:44:25.829    22,824 kbps     00:44:20.824    110,652 bytes   360,281 bytes   00:45:04.785
27              0:45:05.327     0:01:09.402     22,787 kbps     30,653 kbps     00:45:31.019    25,729 kbps     00:45:36.150    25,403 kbps     00:45:31.186    118,799 bytes   401,200 bytes   00:45:43.157
28              0:46:14.730     0:01:00.059     24,022 kbps     38,779 kbps     00:46:44.134    29,980 kbps     00:47:02.569    28,138 kbps     00:47:02.569    125,242 bytes   363,194 bytes   00:46:19.067
29              0:47:14.790     0:01:08.068     23,449 kbps     35,360 kbps     00:48:13.098    28,947 kbps     00:48:10.429    26,846 kbps     00:48:05.424    122,254 bytes   348,078 bytes   00:48:01.253
30              0:48:22.858     0:02:52.839     23,466 kbps     36,734 kbps     00:50:39.077    30,005 kbps     00:50:41.038    27,795 kbps     00:49:38.433    122,339 bytes   366,723 bytes   00:49:16.536
31              0:51:15.697     0:00:23.273     20,659 kbps     28,006 kbps     00:51:25.373    25,087 kbps     00:51:22.370    24,128 kbps     00:51:17.991    107,706 bytes   353,078 bytes   00:51:25.665
32              0:51:38.970     0:01:23.124     22,008 kbps     28,594 kbps     00:52:41.825    24,841 kbps     00:52:46.663    24,456 kbps     00:52:41.700    114,741 bytes   348,489 bytes   00:53:01.094
33              0:53:02.095     0:01:11.905     23,409 kbps     27,446 kbps     00:53:30.540    26,168 kbps     00:53:43.553    25,791 kbps     00:53:41.509    122,045 bytes   350,584 bytes   00:53:04.097
34              0:54:14.000     0:01:01.936     23,730 kbps     29,470 kbps     00:54:52.455    27,089 kbps     00:54:38.942    26,319 kbps     00:54:35.146    123,719 bytes   256,260 bytes   00:54:23.385
35              0:55:15.937     0:03:49.312     23,964 kbps     30,559 kbps     00:59:03.206    27,706 kbps     00:55:31.828    27,408 kbps     00:58:11.571    124,938 bytes   307,944 bytes   00:59:05.166
36              0:59:05.250     0:03:39.802     23,630 kbps     33,281 kbps     01:00:59.906    28,424 kbps     01:00:07.520    27,476 kbps     01:00:44.641    123,194 bytes   342,381 bytes   01:02:14.063
37              1:02:45.052     0:01:02.687     25,371 kbps     27,897 kbps     01:03:05.698    26,595 kbps     01:03:36.437    26,249 kbps     01:03:31.974    132,270 bytes   262,828 bytes   01:03:26.803
38              1:03:47.740     0:01:38.473     19,739 kbps     29,528 kbps     01:04:00.586    23,447 kbps     01:04:00.628    22,196 kbps     01:05:14.201    102,909 bytes   387,330 bytes   01:05:14.952
39              1:05:26.213     0:00:19.018     23,528 kbps     29,082 kbps     01:05:33.095    27,231 kbps     01:05:29.967    25,591 kbps     01:05:29.967    122,663 bytes   284,954 bytes   01:05:41.354
40              1:05:45.232     0:00:32.282     24,398 kbps     31,205 kbps     01:06:07.129    28,466 kbps     01:05:58.120    27,618 kbps     01:05:52.907    127,199 bytes   311,515 bytes   01:06:01.874
41              1:06:17.515     0:00:54.846     23,251 kbps     30,483 kbps     01:06:24.188    27,822 kbps     01:07:05.771    27,137 kbps     01:06:18.933    121,219 bytes   286,952 bytes   01:07:08.733
42              1:07:12.361     0:01:36.554     25,385 kbps     35,612 kbps     01:08:20.429    28,788 kbps     01:08:18.135    27,683 kbps     01:07:48.355    132,347 bytes   291,828 bytes   01:08:20.805
43              1:08:48.916     0:02:02.413     22,157 kbps     31,462 kbps     01:09:25.828    26,244 kbps     01:10:33.520    25,911 kbps     01:10:32.937    115,515 bytes   296,611 bytes   01:09:34.170
44              1:10:51.330     0:02:20.807     23,778 kbps     35,199 kbps     01:12:37.144    27,692 kbps     01:11:53.684    26,057 kbps     01:12:36.352    123,970 bytes   349,496 bytes   01:11:34.915
45              1:13:12.137     0:01:03.396     25,017 kbps     31,916 kbps     01:14:04.815    26,301 kbps     01:13:18.352    26,013 kbps     01:13:18.936    130,426 bytes   276,169 bytes   01:14:14.616
46              1:14:15.534     0:00:35.910     25,305 kbps     30,515 kbps     01:14:16.952    27,910 kbps     01:14:15.576    27,285 kbps     01:14:15.784    131,930 bytes   306,181 bytes   01:14:35.637
47              1:14:51.445     0:04:12.543     23,762 kbps     31,146 kbps     01:16:38.427    27,172 kbps     01:16:38.427    26,100 kbps     01:16:38.302    123,886 bytes   322,810 bytes   01:16:48.562
48              1:19:03.989     0:00:26.735     21,517 kbps     26,081 kbps     01:19:22.841    24,531 kbps     01:19:19.755    23,552 kbps     01:19:18.462    112,182 bytes   248,339 bytes   01:19:06.908
49              1:19:30.724     0:03:55.568     22,831 kbps     27,889 kbps     01:23:24.958    26,157 kbps     01:22:48.713    25,803 kbps     01:22:48.755    119,030 bytes   353,151 bytes   01:23:25.917
50              1:23:26.292     0:00:39.748     17,993 kbps     21,794 kbps     01:23:46.312    19,292 kbps     01:23:49.024    18,951 kbps     01:23:49.232    93,807 bytes    364,728 bytes   01:23:55.030
51              1:24:06.041     0:02:53.006     23,277 kbps     28,746 kbps     01:26:58.046    26,538 kbps     01:24:30.148    25,161 kbps     01:24:39.449    121,355 bytes   330,058 bytes   01:26:05.118
52              1:26:59.047     0:01:14.532     21,966 kbps     37,202 kbps     01:27:16.564    31,610 kbps     01:27:14.604    28,280 kbps     01:27:15.229    114,518 bytes   412,946 bytes   01:27:18.441
53              1:28:13.579     0:04:02.158     4,398 kbps      7,990 kbps      01:29:43.336    7,888 kbps      01:29:39.415    7,788 kbps      01:29:35.411    22,934 bytes    164,085 bytes   01:29:36.287
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     5535.572                21,999                  15,221,881,784  82,805,589
00002.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5535.572                384                     265,717,248     1,556,937
00002.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5535.572                192                     132,804,096     864,610
00002.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5535.572                192                     132,857,856     864,960
00002.M2TS      4608 (0x1200)   0x90            PGS             spa (Spanish)           5535.572                24                      16,716,928      99,473
post #1460 of 1971 Old 03-01-2009, 09:50 PM
Kannisto's Avatar
Code:
        Total   Video
(JP) Children of the Dark (Yami no kodomotachi)                 AVC     2:17:38 47,782,522,560  48,686,679,912  46.29   39.00   Dolby TrueHD 5.1 1376Kbps (48kHz/16-bit)  LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     YAMINOKODOMOTACHI
Disc Size:      48,686,679,912 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:17:38 (h:m:s)
Total Bitrate:          46.29 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        38998 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              Japanese        1376 kbps       5.1 / 48 kHz / 1376 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
LPCM Audio                      Japanese        1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
Dolby Digital Audio             Japanese        640 kbps        2.0 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           Japanese        7.746 kbps
Presentation Graphics           Japanese        18.241 kbps
FILES:
00005.M2TS      0:00:00.000     2:17:38.250     47,782,522,560  46,288
CHAPTERS:
1               0:00:00.000     0:00:13.012     39,433 kbps     41,393 kbps     00:00:12.011    39,478 kbps     00:00:08.007    39,238 kbps     00:00:03.002    204,277 bytes   468,872 bytes   00:00:12.971
2               0:00:13.012     0:04:44.450     39,021 kbps     46,510 kbps     00:04:51.958    42,178 kbps     00:00:21.938    41,225 kbps     00:00:16.808    203,436 bytes   493,135 bytes   00:04:10.291
3               0:04:57.463     0:01:17.035     38,921 kbps     41,557 kbps     00:06:13.498    39,511 kbps     00:06:09.494    39,255 kbps     00:06:04.489    202,917 bytes   483,631 bytes   00:06:14.457
4               0:06:14.499     0:02:05.458     39,174 kbps     46,957 kbps     00:06:46.781    41,919 kbps     00:06:14.582    41,370 kbps     00:06:15.291    204,236 bytes   447,845 bytes   00:06:15.458
5               0:08:19.957     0:01:18.661     38,875 kbps     44,125 kbps     00:08:40.144    40,428 kbps     00:08:36.182    39,712 kbps     00:08:31.177    202,675 bytes   404,399 bytes   00:08:49.237
6               0:09:38.619     0:02:13.216     38,931 kbps     43,097 kbps     00:10:25.207    40,718 kbps     00:10:53.736    39,902 kbps     00:09:55.136    202,969 bytes   448,151 bytes   00:11:11.295
7               0:11:51.836     0:03:01.222     39,043 kbps     43,591 kbps     00:12:22.241    42,187 kbps     00:14:10.391    40,958 kbps     00:14:10.182    203,554 bytes   477,442 bytes   00:12:43.804
8               0:14:53.058     0:04:52.875     38,997 kbps     43,679 kbps     00:19:41.388    40,648 kbps     00:18:26.980    40,287 kbps     00:18:27.064    203,312 bytes   473,478 bytes   00:18:28.565
9               0:19:45.934     0:00:54.429     38,988 kbps     42,090 kbps     00:20:28.727    40,064 kbps     00:19:55.402    39,631 kbps     00:19:50.397    203,266 bytes   437,719 bytes   00:20:05.746
10              0:20:40.364     0:02:23.726     38,952 kbps     46,632 kbps     00:21:19.569    42,127 kbps     00:21:16.942    40,696 kbps     00:21:11.937    203,080 bytes   466,794 bytes   00:21:45.470
11              0:23:04.091     0:01:12.405     39,142 kbps     42,559 kbps     00:23:05.425    41,405 kbps     00:23:04.883    40,366 kbps     00:23:04.091    204,067 bytes   429,441 bytes   00:23:05.050
12              0:24:16.496     0:01:25.502     38,934 kbps     41,568 kbps     00:25:30.695    41,075 kbps     00:24:47.777    40,007 kbps     00:24:43.148    202,982 bytes   402,392 bytes   00:24:18.457
13              0:25:41.998     0:00:52.302     39,117 kbps     44,771 kbps     00:26:25.500    40,352 kbps     00:25:47.712    39,887 kbps     00:25:47.545    203,940 bytes   385,327 bytes   00:26:15.490
14              0:26:34.301     0:00:47.756     38,885 kbps     40,669 kbps     00:27:21.056    39,512 kbps     00:27:17.052    39,272 kbps     00:27:08.460    202,729 bytes   404,634 bytes   00:27:22.015
15              0:27:22.057     0:02:38.116     39,016 kbps     41,261 kbps     00:29:58.713    40,332 kbps     00:29:41.321    39,732 kbps     00:29:39.152    203,411 bytes   420,675 bytes   00:28:31.376
16              0:30:00.173     0:01:46.731     39,010 kbps     46,251 kbps     00:31:36.978    40,705 kbps     00:31:21.796    40,010 kbps     00:31:29.137    203,381 bytes   392,533 bytes   00:30:25.490
17              0:31:46.904     0:01:00.685     39,052 kbps     42,025 kbps     00:32:19.938    41,134 kbps     00:32:19.938    40,584 kbps     00:32:19.938    203,598 bytes   416,153 bytes   00:32:29.906
18              0:32:47.590     0:02:05.792     38,995 kbps     44,701 kbps     00:32:49.801    40,144 kbps     00:33:33.553    39,673 kbps     00:33:32.927    203,300 bytes   407,593 bytes   00:34:53.341
19              0:34:53.382     0:01:41.643     38,934 kbps     44,183 kbps     00:35:19.450    41,828 kbps     00:35:17.865    40,413 kbps     00:35:12.860    202,985 bytes   474,869 bytes   00:35:00.348
20              0:36:35.026     0:04:23.972     39,011 kbps     41,996 kbps     00:37:03.179    40,330 kbps     00:40:17.081    39,844 kbps     00:40:15.079    203,384 bytes   527,746 bytes   00:40:15.246
21              0:40:58.998     0:03:23.536     38,977 kbps     42,271 kbps     00:41:24.815    40,010 kbps     00:41:33.949    39,385 kbps     00:41:16.932    203,206 bytes   386,280 bytes   00:42:02.311
22              0:44:22.534     0:02:38.241     38,970 kbps     42,308 kbps     00:44:38.967    41,016 kbps     00:45:32.229    40,083 kbps     00:45:31.228    203,173 bytes   463,052 bytes   00:46:41.799
23              0:47:00.776     0:01:07.984     39,037 kbps     44,668 kbps     00:47:58.584    41,292 kbps     00:47:55.789    40,023 kbps     00:47:50.826    203,519 bytes   425,294 bytes   00:48:05.966
24              0:48:08.760     0:03:57.278     39,038 kbps     42,359 kbps     00:51:22.162    40,357 kbps     00:48:09.219    40,229 kbps     00:48:09.595    203,526 bytes   446,201 bytes   00:50:06.253
25              0:52:06.039     0:02:11.256     38,948 kbps     41,733 kbps     00:54:02.989    40,330 kbps     00:53:40.967    39,728 kbps     00:53:38.715    203,056 bytes   436,210 bytes   00:54:17.254
26              0:54:17.295     0:01:02.729     39,018 kbps     41,367 kbps     00:54:40.819    40,094 kbps     00:54:38.858    39,603 kbps     00:54:37.857    203,421 bytes   475,942 bytes   00:54:19.256
27              0:55:20.025     0:01:18.203     38,978 kbps     42,839 kbps     00:56:09.157    40,179 kbps     00:56:07.155    39,622 kbps     00:55:21.943    203,213 bytes   445,714 bytes   00:56:09.199
28              0:56:38.228     0:03:09.689     38,962 kbps     41,338 kbps     00:58:07.192    40,571 kbps     00:58:07.192    39,860 kbps     00:58:06.566    203,132 bytes   409,775 bytes   00:57:24.023
29              0:59:47.917     0:03:34.464     39,041 kbps     42,590 kbps     00:59:49.836    40,548 kbps     01:01:27.475    39,804 kbps     01:01:22.470    203,541 bytes   517,951 bytes   00:59:49.877
30              1:03:22.381     0:05:44.052     39,005 kbps     43,310 kbps     01:04:20.106    40,332 kbps     01:04:16.143    39,631 kbps     01:04:11.138    203,356 bytes   421,183 bytes   01:03:23.341
31              1:09:06.433     0:03:01.222     39,028 kbps     44,940 kbps     01:12:05.279    41,219 kbps     01:12:01.275    40,013 kbps     01:11:12.559    203,472 bytes   421,213 bytes   01:10:37.441
32              1:12:07.656     0:01:01.269     38,801 kbps     42,263 kbps     01:12:47.821    40,251 kbps     01:12:46.862    39,748 kbps     01:12:19.293    202,290 bytes   449,042 bytes   01:12:48.614
33              1:13:08.926     0:01:33.551     39,006 kbps     41,549 kbps     01:13:48.757    39,876 kbps     01:13:09.051    39,500 kbps     01:13:09.093    203,359 bytes   424,332 bytes   01:13:09.885
34              1:14:42.477     0:00:30.905     39,303 kbps     41,589 kbps     01:15:11.423    39,819 kbps     01:14:42.519    39,571 kbps     01:15:03.373    204,908 bytes   421,584 bytes   01:15:02.456
35              1:15:13.383     0:00:31.030     38,688 kbps     40,875 kbps     01:15:42.663    39,437 kbps     01:15:39.409    39,213 kbps     01:15:34.404    201,700 bytes   402,376 bytes   01:15:40.827
36              1:15:44.414     0:02:08.002     39,026 kbps     46,036 kbps     01:16:36.425    40,488 kbps     01:16:22.327    39,899 kbps     01:16:22.327    203,462 bytes   405,171 bytes   01:15:45.374
37              1:17:52.417     0:02:03.832     39,025 kbps     46,479 kbps     01:18:29.329    42,736 kbps     01:18:27.285    40,822 kbps     01:18:22.280    203,457 bytes   506,939 bytes   01:17:58.382
38              1:19:56.249     0:02:09.963     39,002 kbps     41,799 kbps     01:21:49.779    40,249 kbps     01:21:49.738    39,711 kbps     01:21:46.776    203,337 bytes   396,859 bytes   01:21:33.805
39              1:22:06.212     0:02:55.383     38,978 kbps     46,936 kbps     01:22:22.771    41,067 kbps     01:22:20.143    40,024 kbps     01:22:14.137    203,214 bytes   424,104 bytes   01:25:01.554
40              1:25:01.596     0:01:56.491     38,986 kbps     44,864 kbps     01:25:28.122    40,883 kbps     01:25:24.077    40,061 kbps     01:25:19.072    203,255 bytes   406,690 bytes   01:26:58.046
41              1:26:58.087     0:01:01.644     39,102 kbps     41,510 kbps     01:27:01.049    40,779 kbps     01:26:59.255    40,070 kbps     01:26:58.254    203,861 bytes   424,427 bytes   01:26:59.047
42              1:27:59.732     0:00:21.146     38,988 kbps     45,814 kbps     01:28:14.539    40,970 kbps     01:28:10.910    39,841 kbps     01:28:05.863    203,266 bytes   426,121 bytes   01:28:05.697
43              1:28:20.878     0:00:48.631     39,011 kbps     42,486 kbps     01:29:01.252    40,391 kbps     01:28:57.415    39,876 kbps     01:28:52.410    203,383 bytes   441,773 bytes   01:28:41.607
44              1:29:09.510     0:01:11.988     39,022 kbps     41,153 kbps     01:29:42.835    40,112 kbps     01:30:00.353    39,751 kbps     01:29:57.183    203,440 bytes   436,192 bytes   01:29:44.796
45              1:30:21.499     0:01:48.149     38,997 kbps     41,833 kbps     01:32:07.855    39,531 kbps     01:32:03.851    39,334 kbps     01:31:58.846    203,313 bytes   425,104 bytes   01:30:22.458
46              1:32:09.649     0:01:52.862     38,919 kbps     42,574 kbps     01:33:45.119    40,550 kbps     01:33:44.410    40,087 kbps     01:33:11.502    202,907 bytes   414,494 bytes   01:32:49.647
47              1:34:02.511     0:04:37.986     38,979 kbps     43,902 kbps     01:36:57.603    40,717 kbps     01:36:53.557    39,889 kbps     01:36:53.849    203,221 bytes   415,656 bytes   01:37:30.386
48              1:38:40.497     0:03:04.851     39,074 kbps     43,951 kbps     01:39:37.680    41,313 kbps     01:39:07.942    40,276 kbps     01:40:17.845    203,715 bytes   449,863 bytes   01:38:41.457
49              1:41:45.349     0:01:44.979     38,927 kbps     40,627 kbps     01:43:28.702    39,452 kbps     01:43:24.698    39,205 kbps     01:43:10.100    202,945 bytes   415,491 bytes   01:41:47.309
50              1:43:30.329     0:01:35.887     39,021 kbps     41,599 kbps     01:45:04.673    39,619 kbps     01:43:52.809    39,424 kbps     01:44:12.162    203,439 bytes   414,901 bytes   01:43:32.289
51              1:45:06.216     0:02:46.249     38,983 kbps     42,071 kbps     01:46:39.893    40,154 kbps     01:46:39.643    39,824 kbps     01:46:34.638    203,241 bytes   457,234 bytes   01:46:31.134
52              1:47:52.466     0:02:45.206     39,027 kbps     46,464 kbps     01:49:54.629    41,248 kbps     01:48:47.270    40,324 kbps     01:48:42.098    203,467 bytes   404,620 bytes   01:49:01.576
53              1:50:37.672     0:01:57.575     38,992 kbps     41,152 kbps     01:51:08.203    39,949 kbps     01:51:08.119    39,477 kbps     01:51:08.203    203,288 bytes   386,483 bytes   01:51:04.657
54              1:52:35.248     0:00:52.427     38,916 kbps     42,931 kbps     01:52:42.422    40,696 kbps     01:52:41.296    39,874 kbps     01:52:39.294    202,888 bytes   483,227 bytes   01:52:42.213
55              1:53:27.675     0:01:48.358     38,999 kbps     44,797 kbps     01:54:21.646    40,789 kbps     01:54:17.642    39,868 kbps     01:54:12.637    203,325 bytes   430,920 bytes   01:54:08.299
56              1:55:16.034     0:02:41.202     39,013 kbps     45,087 kbps     01:56:59.929    40,779 kbps     01:56:57.635    40,038 kbps     01:57:13.609    203,395 bytes   410,807 bytes   01:56:16.010
57              1:57:57.236     0:01:38.807     38,950 kbps     42,038 kbps     01:59:22.238    39,768 kbps     01:59:19.110    39,382 kbps     01:59:14.105    203,069 bytes   489,643 bytes   01:59:10.268
58              1:59:36.043     0:01:04.939     39,193 kbps     44,339 kbps     01:59:43.759    41,138 kbps     02:00:16.542    40,143 kbps     01:59:36.586    204,336 bytes   407,553 bytes   02:00:39.982
59              2:00:40.983     0:02:09.921     38,901 kbps     47,079 kbps     02:02:22.960    41,209 kbps     02:00:55.790    40,074 kbps     02:00:50.785    202,810 bytes   421,753 bytes   02:00:53.955
60              2:02:50.905     0:04:34.023     39,032 kbps     44,244 kbps     02:04:32.923    41,344 kbps     02:04:32.923    40,510 kbps     02:07:08.078    203,494 bytes   542,984 bytes   02:06:53.230
61              2:07:24.928     0:01:58.076     38,962 kbps     43,470 kbps     02:08:10.724    40,934 kbps     02:07:37.566    40,162 kbps     02:07:37.066    203,131 bytes   468,633 bytes   02:07:38.984
62              2:09:23.005     0:03:02.682     38,961 kbps     42,464 kbps     02:12:12.966    41,260 kbps     02:12:11.798    40,184 kbps     02:10:03.921    203,125 bytes   512,405 bytes   02:12:25.646
63              2:12:25.687     0:05:11.561     38,990 kbps     43,521 kbps     02:12:25.854    40,361 kbps     02:12:33.487    39,828 kbps     02:12:28.482    203,275 bytes   499,271 bytes   02:12:26.647
64              2:17:37.249     0:00:01.001     34,127 kbps     0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    194,096 bytes   203,324 bytes   02:17:37.415
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     8258.167                38,999                  40,257,774,743  218,913,528
00005.M2TS      4352 (0x1100)   0x80            LPCM            jpn (Japanese)          8258.167                1,542                   1,592,190,600   9,909,900
00005.M2TS      4353 (0x1101)   0x83            TrueHD          jpn (Japanese)          8258.167                2,016                   2,081,328,554   15,741,619
00005.M2TS      4354 (0x1102)   0x81            AC3             jpn (Japanese)          8258.167                640                     660,661,760     3,871,065
00005.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          8258.167                8                       7,995,870       46,733
00005.M2TS      4609 (0x1201)   0x90            PGS             jpn (Japanese)          8258.167                18                      18,830,365      108,872
EDIT:
Dolby TrueHD Audio 5.1 - Japanese => For the movie
LPCM Audio 2.0 - Japanese => For the movie
Dolby Digital Audio 2.0 - Japanese => Audio commentary
All the extras are in SD on a separately included DVD.
Kannisto is offline
post #1461 of 1971 Old 03-02-2009, 02:17 AM
Kannisto's Avatar
Code:
        Total   Video
(FR) 36 Quai des Orfèvres                                       AVC     1:51:01 17,189,240,832  22,826,501,601  20.64   14.94   DTS-HD Master 5.1 4222Kbps (48kHz/24-bit) DTS 2.0 256Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     BD_36
Disc Size:      22,826,501,601 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:51:01 (h:m:s)
Total Bitrate:          20.64 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        14936 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             French          4222 kbps       5.1 / 48 kHz / 4222 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          256 kbps        2.0 / 48 kHz / 256 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         23.060 kbps
Presentation Graphics           French          23.300 kbps
FILES:
00004.M2TS      0:00:00.000     1:51:01.404     17,189,240,832  20,643
CHAPTERS:
1               0:00:00.000     0:02:20.306     10,070 kbps     20,193 kbps     00:00:59.267    15,364 kbps     00:02:14.926    14,772 kbps     00:02:10.296    52,483 bytes    287,665 bytes   00:01:09.652
2               0:02:20.306     0:05:36.169     16,704 kbps     28,849 kbps     00:07:01.087    23,359 kbps     00:06:57.083    21,179 kbps     00:07:38.416    87,087 bytes    300,657 bytes   00:02:25.562
3               0:07:56.476     0:01:26.377     18,455 kbps     31,474 kbps     00:08:46.192    25,911 kbps     00:08:20.833    23,466 kbps     00:08:20.416    96,218 bytes    304,310 bytes   00:09:22.436
4               0:09:22.853     0:03:09.355     14,233 kbps     22,646 kbps     00:11:56.465    18,895 kbps     00:10:19.535    17,767 kbps     00:10:15.281    74,204 bytes    296,214 bytes   00:10:40.431
5               0:12:32.209     0:01:12.697     13,945 kbps     18,542 kbps     00:12:40.301    17,103 kbps     00:12:38.841    16,048 kbps     00:12:33.669    72,703 bytes    311,432 bytes   00:13:44.907
6               0:13:44.907     0:03:28.875     14,904 kbps     26,400 kbps     00:16:39.999    22,526 kbps     00:16:39.123    19,101 kbps     00:16:39.081    77,701 bytes    307,898 bytes   00:13:47.910
7               0:17:13.782     0:04:20.635     15,364 kbps     30,744 kbps     00:18:44.915    29,228 kbps     00:18:41.870    23,818 kbps     00:18:41.370    80,102 bytes    337,391 bytes   00:18:04.041
8               0:21:34.418     0:01:13.490     15,166 kbps     32,205 kbps     00:21:36.920    24,090 kbps     00:21:35.794    19,636 kbps     00:21:35.669    79,069 bytes    306,004 bytes   00:22:11.204
9               0:22:47.908     0:05:56.814     15,677 kbps     32,577 kbps     00:23:28.824    23,467 kbps     00:23:39.167    21,013 kbps     00:23:39.292    81,731 bytes    311,707 bytes   00:27:15.967
10              0:28:44.723     0:04:51.416     16,148 kbps     25,202 kbps     00:33:30.717    20,402 kbps     00:33:27.380    19,784 kbps     00:31:08.616    84,188 bytes    286,796 bytes   00:32:29.614
11              0:33:36.139     0:05:42.300     15,466 kbps     31,574 kbps     00:33:41.019    26,790 kbps     00:33:37.015    23,511 kbps     00:33:36.139    80,633 bytes    294,119 bytes   00:33:51.237
12              0:39:18.439     0:09:18.683     15,394 kbps     34,041 kbps     00:44:23.077    28,983 kbps     00:44:22.660    26,315 kbps     00:45:23.929    80,256 bytes    351,895 bytes   00:41:45.211
13              0:48:37.122     0:06:29.138     14,676 kbps     29,823 kbps     00:54:28.473    22,422 kbps     00:54:08.828    20,176 kbps     00:54:10.163    76,514 bytes    391,507 bytes   00:54:28.723
14              0:55:06.261     0:03:43.222     15,198 kbps     32,415 kbps     00:55:46.634    24,373 kbps     00:55:43.673    21,895 kbps     00:55:40.086    79,233 bytes    313,886 bytes   00:56:12.911
15              0:58:49.484     0:07:03.881     14,874 kbps     29,386 kbps     01:04:58.978    21,193 kbps     01:04:54.974    18,372 kbps     01:00:50.980    77,545 bytes    320,735 bytes   01:04:59.979
16              1:05:53.366     0:01:51.653     14,477 kbps     21,009 kbps     01:07:41.390    17,315 kbps     01:06:49.255    16,380 kbps     01:06:44.208    75,479 bytes    311,237 bytes   01:07:31.422
17              1:07:45.019     0:02:43.830     14,828 kbps     28,465 kbps     01:08:53.462    21,056 kbps     01:09:09.103    19,790 kbps     01:08:44.453    77,309 bytes    306,849 bytes   01:09:44.638
18              1:10:28.849     0:03:55.610     14,861 kbps     26,442 kbps     01:11:18.315    20,274 kbps     01:11:32.246    18,721 kbps     01:11:30.995    77,476 bytes    317,137 bytes   01:13:16.517
19              1:14:24.460     0:02:11.840     16,149 kbps     31,413 kbps     01:15:55.300    27,309 kbps     01:15:54.132    24,136 kbps     01:15:49.503    84,194 bytes    308,916 bytes   01:15:39.409
20              1:16:36.300     0:02:53.840     15,589 kbps     33,193 kbps     01:18:53.437    24,577 kbps     01:18:44.010    23,166 kbps     01:18:45.345    81,273 bytes    403,454 bytes   01:18:58.358
21              1:19:30.140     0:04:07.288     13,991 kbps     22,126 kbps     01:20:49.594    17,872 kbps     01:19:30.432    16,880 kbps     01:19:30.432    72,942 bytes    332,429 bytes   01:20:48.343
22              1:23:37.429     0:03:26.664     14,073 kbps     28,074 kbps     01:25:42.470    19,888 kbps     01:25:40.051    17,930 kbps     01:25:41.302    73,369 bytes    305,971 bytes   01:26:26.681
23              1:27:04.093     0:03:13.318     16,084 kbps     30,359 kbps     01:29:12.555    25,061 kbps     01:29:10.970    22,582 kbps     01:29:06.966    83,857 bytes    456,560 bytes   01:29:25.651
24              1:30:17.412     0:01:12.405     15,622 kbps     33,687 kbps     01:30:41.060    20,180 kbps     01:30:37.765    19,060 kbps     01:30:39.809    81,445 bytes    306,818 bytes   01:30:27.046
25              1:31:29.817     0:04:38.403     15,392 kbps     31,930 kbps     01:32:43.307    25,497 kbps     01:32:40.096    22,771 kbps     01:32:36.467    80,247 bytes    318,478 bytes   01:34:44.845
26              1:36:08.220     0:02:00.578     14,587 kbps     30,539 kbps     01:36:37.416    23,358 kbps     01:36:35.122    20,816 kbps     01:36:35.122    76,047 bytes    332,006 bytes   01:36:37.625
27              1:38:08.799     0:08:11.115     15,861 kbps     32,838 kbps     01:38:39.955    28,144 kbps     01:38:37.328    23,574 kbps     01:38:31.614    82,694 bytes    332,079 bytes   01:43:33.707
28              1:46:19.915     0:04:41.489     8,886 kbps      20,380 kbps     01:46:34.888    18,988 kbps     01:46:34.429    18,068 kbps     01:46:30.217    46,337 bytes    284,727 bytes   01:46:23.668
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     6661.321                14,936                  12,436,897,326  67,685,297
00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            6661.321                4,222                   3,515,331,424   20,145,382
00004.M2TS      4353 (0x1101)   0x82            DTS             fra (French)            6661.321                255                     212,332,380     1,249,014
00004.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            6661.321                23                      19,401,540      113,200
00004.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6661.321                23                      19,201,569      111,203
EDIT:
DTS-HD Master Audio 5.1 - French => For the movie
DTS Audio 2.0 - French => Audio commentary
Kannisto is offline
post #1462 of 1971 Old 03-02-2009, 07:52 AM
CRT Dude's Avatar
Is that the R rated Pirates 2?
CRT Dude is offline
post #1463 of 1971 Old 03-02-2009, 09:37 AM
Yes, it's the R-rated version - sorry, I should have made that clearer.
post #1464 of 1971 Old 03-02-2009, 10:59 AM - Thread Starter
benes's Avatar
Quoted: 76 Post(s)
Liked: 26
Code:
        Total   Video
Code:
        Total   Video
Can you clarify which audio tracks are for the movie? BDInfo has no way of knowing and neither do I. Thanks.
benes is offline
post #1465 of 1971 Old 03-02-2009, 08:27 PM
Kannisto's Avatar
Yeah, sorry about that. I'll edit my original posts to add that information there now. => Done
Kannisto is offline
post #1466 of 1971 Old 03-02-2009, 08:54 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
Pinocchio (1940)                                                AVC     1:27:44 23,890,409,472  30,584,132,721  36.31   28.42   DTS-HD Master 7.1 3446Kbps (48kHz/24-bit) DD AC3 1.0 192Kbps
Code:
DISC INFO:
Disc Title:     PINOCCHIO_US_D1_BDLIVE
Disc Size:      30,584,132,721 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:27:44 (h:m:s)
Total Bitrate:          36.31 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        28421 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video        1669 kbps           480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         3446 kbps       7.1 / 48 kHz / 3446 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           English         31.039 kbps
Presentation Graphics           English         65.299 kbps
Presentation Graphics           English         2.438 kbps
Presentation Graphics           English         306.552 kbps
FILES:
00001.M2TS      0:00:00.000     1:27:44.259     23,890,409,472  36,306
CHAPTERS:
1               0:00:00.000     0:02:21.516     24,425 kbps     43,287 kbps     00:01:29.089    32,135 kbps     00:02:08.628    31,359 kbps     00:02:03.748    127,303 bytes   745,427 bytes   00:01:06.816
2               0:02:21.516     0:03:55.068     27,022 kbps     52,181 kbps     00:06:01.569    34,892 kbps     00:05:38.421    32,397 kbps     00:04:03.952    140,881 bytes   814,040 bytes   00:06:04.864
3               0:06:16.584     0:05:16.899     29,075 kbps     48,588 kbps     00:11:10.336    34,876 kbps     00:09:20.309    32,483 kbps     00:07:59.187    151,582 bytes   836,295 bytes   00:10:19.076
4               0:11:33.484     0:03:43.598     27,284 kbps     45,565 kbps     00:12:27.079    34,647 kbps     00:12:58.944    32,587 kbps     00:14:56.145    142,244 bytes   772,518 bytes   00:15:11.243
5               0:15:17.082     0:03:26.623     26,643 kbps     54,855 kbps     00:17:59.870    35,006 kbps     00:16:12.888    31,980 kbps     00:18:29.233    138,906 bytes   721,409 bytes   00:16:40.416
6               0:18:43.705     0:02:50.044     27,925 kbps     46,517 kbps     00:20:21.136    35,035 kbps     00:20:17.215    32,604 kbps     00:20:20.135    145,589 bytes   715,122 bytes   00:19:57.029
7               0:21:33.750     0:05:24.615     28,538 kbps     49,290 kbps     00:23:20.440    34,927 kbps     00:22:38.774    32,681 kbps     00:25:37.661    148,785 bytes   730,926 bytes   00:24:11.491
8               0:26:58.366     0:01:49.734     29,259 kbps     47,094 kbps     00:28:03.932    34,995 kbps     00:28:00.136    31,968 kbps     00:27:29.689    152,542 bytes   774,542 bytes   00:28:38.967
9               0:28:48.101     0:01:57.367     28,619 kbps     42,153 kbps     00:29:12.459    34,572 kbps     00:28:59.487    32,201 kbps     00:28:56.484    149,208 bytes   784,065 bytes   00:30:26.741
10              0:30:45.468     0:05:46.971     29,255 kbps     49,069 kbps     00:31:01.401    35,260 kbps     00:34:23.352    32,402 kbps     00:35:38.386    152,523 bytes   816,492 bytes   00:35:28.167
11              0:36:32.440     0:04:23.888     28,787 kbps     48,841 kbps     00:37:48.265    35,190 kbps     00:38:26.554    32,639 kbps     00:37:51.560    150,083 bytes   743,126 bytes   00:39:43.297
12              0:40:56.328     0:06:46.948     28,804 kbps     53,214 kbps     00:44:10.314    35,012 kbps     00:43:15.593    32,480 kbps     00:46:22.863    150,171 bytes   769,465 bytes   00:42:54.863
13              0:47:43.276     0:02:49.377     28,141 kbps     54,104 kbps     00:49:19.581    34,642 kbps     00:49:01.897    32,711 kbps     00:48:55.515    146,712 bytes   755,899 bytes   00:49:55.659
14              0:50:32.654     0:02:34.154     29,664 kbps     50,620 kbps     00:51:24.122    34,757 kbps     00:51:23.789    32,587 kbps     00:52:04.204    154,654 bytes   769,591 bytes   00:52:25.433
15              0:53:06.808     0:03:59.447     29,456 kbps     49,206 kbps     00:55:50.305    34,567 kbps     00:55:10.348    32,429 kbps     00:56:49.364    153,570 bytes   767,258 bytes   00:54:52.539
16              0:57:06.256     0:01:41.643     28,801 kbps     52,049 kbps     00:58:22.290    34,887 kbps     00:57:36.202    32,485 kbps     00:58:35.470    150,158 bytes   785,803 bytes   00:58:23.249
17              0:58:47.899     0:05:18.985     28,340 kbps     48,746 kbps     01:01:53.167    34,677 kbps     01:02:46.971    32,294 kbps     01:03:41.484    147,752 bytes   764,944 bytes   01:02:32.957
18              1:04:06.884     0:02:25.103     28,490 kbps     50,169 kbps     01:05:33.554    35,372 kbps     01:05:01.439    32,209 kbps     01:04:56.475    148,535 bytes   696,560 bytes   01:06:09.882
19              1:06:31.987     0:02:36.906     26,839 kbps     46,002 kbps     01:07:30.963    35,299 kbps     01:08:44.912    32,452 kbps     01:08:44.036    139,926 bytes   715,876 bytes   01:08:03.079
20              1:09:08.894     0:05:43.343     29,437 kbps     48,922 kbps     01:11:38.544    35,272 kbps     01:12:16.707    32,764 kbps     01:12:28.844    153,470 bytes   731,700 bytes   01:14:14.408
21              1:14:52.237     0:02:09.045     29,471 kbps     47,497 kbps     01:14:52.362    35,126 kbps     01:16:48.645    32,486 kbps     01:15:58.428    153,648 bytes   564,381 bytes   01:17:01.283
22              1:17:01.283     0:03:07.187     28,962 kbps     52,925 kbps     01:18:29.329    34,940 kbps     01:18:58.066    32,708 kbps     01:19:51.161    150,994 bytes   732,593 bytes   01:19:39.399
23              1:20:08.470     0:04:21.177     29,322 kbps     45,499 kbps     01:21:47.861    35,336 kbps     01:20:58.353    32,318 kbps     01:21:21.960    152,871 bytes   732,536 bytes   01:23:53.778
24              1:24:29.647     0:03:13.610     27,061 kbps     52,890 kbps     01:25:49.519    34,374 kbps     01:26:05.535    32,204 kbps     01:26:37.859    141,086 bytes   753,984 bytes   01:25:53.106
25              1:27:43.257     0:00:01.001     108 kbps        0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    585 bytes       935 bytes       01:27:43.424
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     5264.134                28,421                  18,701,676,874  101,712,988
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5264.134                3,446                   2,267,425,684   13,142,631
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5264.134                192                     126,342,912     822,545
00001.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5264.134                192                     126,342,912     822,545
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5264.134                31                      20,424,345      120,989
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5264.134                65                      42,968,977      245,619
00001.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           5264.134                2                       1,604,102       9,439
00001.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           5264.134                307                     201,721,125     1,122,678
00001.M2TS      6912 (0x1B00)   0x1B            AVC                                     5264.134                1,669                   1,097,966,351   6,036,666
eric.exe is offline
post #1467 of 1971 Old 03-03-2009, 05:16 PM
RDarrylR's Avatar
Disc Title: French Connection II
Code:
        Total   Video
00001.MPLS                                                      AVC     1:59:18 29,680,730,112  36,988,065,591  33.17   23.78   DTS-HD Master 5.1 3324Kbps (48kHz/24-bit) DTS-HD Master 5.1 2829Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     FC2_CD
Disc Size:      36,988,065,591 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:59:18 (h:m:s)
Total Bitrate:          33.17 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        23779 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3324 kbps       5.1 / 48 kHz / 3324 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             English         2829 kbps       5.1 / 48 kHz / 2829 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps
Dolby Digital Audio             French          224 kbps        2.0 / 48 kHz / 224 kbps
Dolby Digital Audio             Spanish         224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           English         33.063 kbps
Presentation Graphics           Chinese         27.012 kbps
Presentation Graphics           Chinese         26.745 kbps
Presentation Graphics           French          4.062 kbps
Presentation Graphics           Spanish         22.265 kbps
Presentation Graphics           Spanish         0.046 kbps
FILES:
00001.M2TS      0:00:00.000     1:59:18.151     29,680,730,112  33,171
CHAPTERS:
1               0:00:00.000     0:01:02.562     13,020 kbps     29,269 kbps     00:00:50.884    24,727 kbps     00:00:49.507    18,774 kbps     00:00:14.889    67,833 bytes    432,074 bytes   00:00:18.935
2               0:01:02.562     0:02:32.235     26,019 kbps     36,934 kbps     00:02:25.353    32,245 kbps     00:02:23.685    31,022 kbps     00:02:33.236    135,651 bytes   399,163 bytes   00:02:27.605
3               0:03:34.797     0:04:50.873     27,650 kbps     46,671 kbps     00:06:16.000    34,025 kbps     00:04:58.631    31,350 kbps     00:07:39.625    144,157 bytes   457,968 bytes   00:06:16.584
4               0:08:25.671     0:04:27.642     26,407 kbps     35,052 kbps     00:11:54.422    32,543 kbps     00:11:02.662    31,517 kbps     00:11:49.834    137,674 bytes   386,589 bytes   00:08:39.894
5               0:12:53.314     0:01:10.111     27,780 kbps     33,353 kbps     00:13:01.572    31,479 kbps     00:12:59.695    30,506 kbps     00:12:57.568    144,831 bytes   394,069 bytes   00:13:10.456
6               0:14:03.425     0:06:00.568     23,687 kbps     38,394 kbps     00:15:19.501    32,513 kbps     00:18:28.357    30,975 kbps     00:18:23.352    123,495 bytes   412,912 bytes   00:14:07.179
7               0:20:03.994     0:02:49.711     27,000 kbps     39,620 kbps     00:20:11.335    32,568 kbps     00:21:58.942    31,453 kbps     00:22:26.053    140,767 bytes   487,882 bytes   00:21:51.184
8               0:22:53.705     0:02:22.308     23,882 kbps     36,288 kbps     00:24:49.362    30,608 kbps     00:24:49.112    27,936 kbps     00:25:06.004    124,508 bytes   362,077 bytes   00:23:08.637
9               0:25:16.014     0:05:12.311     22,078 kbps     30,468 kbps     00:25:21.561    27,489 kbps     00:27:25.060    25,176 kbps     00:29:04.325    115,103 bytes   367,474 bytes   00:26:33.466
10              0:30:28.326     0:04:18.841     26,986 kbps     38,488 kbps     00:34:29.067    32,677 kbps     00:34:12.383    30,426 kbps     00:33:20.164    140,694 bytes   438,891 bytes   00:34:23.311
11              0:34:47.168     0:03:26.956     27,615 kbps     35,953 kbps     00:37:06.682    32,545 kbps     00:34:55.301    30,692 kbps     00:34:52.673    143,969 bytes   425,874 bytes   00:37:40.258
12              0:38:14.125     0:05:10.810     20,381 kbps     35,589 kbps     00:40:20.543    27,114 kbps     00:40:27.299    26,192 kbps     00:40:27.299    106,257 bytes   374,964 bytes   00:39:45.841
13              0:43:24.935     0:02:33.611     23,120 kbps     33,565 kbps     00:45:52.374    31,552 kbps     00:44:52.272    30,565 kbps     00:45:06.870    120,537 bytes   441,068 bytes   00:44:57.194
14              0:45:58.547     0:03:17.614     19,799 kbps     31,629 kbps     00:48:34.036    28,370 kbps     00:48:33.076    27,344 kbps     00:48:33.827    103,221 bytes   318,043 bytes   00:48:34.870
15              0:49:16.161     0:04:23.763     21,831 kbps     34,177 kbps     00:52:01.201    31,561 kbps     00:51:57.197    28,868 kbps     00:51:54.319    113,817 bytes   348,022 bytes   00:49:52.739
16              0:53:39.924     0:04:24.681     22,558 kbps     32,910 kbps     00:55:59.814    28,157 kbps     00:55:07.887    25,201 kbps     00:55:05.093    117,607 bytes   349,960 bytes   00:53:55.273
17              0:58:04.606     0:05:50.808     18,813 kbps     30,565 kbps     01:02:22.155    27,593 kbps     00:59:28.648    27,200 kbps     00:59:28.648    98,082 bytes    354,986 bytes   00:58:52.237
18              1:03:55.414     0:03:12.734     22,109 kbps     34,365 kbps     01:06:13.427    31,677 kbps     01:04:45.715    30,456 kbps     01:04:45.715    115,264 bytes   430,679 bytes   01:04:45.756
19              1:07:08.148     0:07:59.520     20,837 kbps     30,005 kbps     01:14:18.162    27,718 kbps     01:14:18.287    25,896 kbps     01:14:17.035    108,635 bytes   383,676 bytes   01:08:12.254
20              1:15:07.669     0:03:06.686     25,225 kbps     35,934 kbps     01:16:32.045    31,454 kbps     01:15:55.050    30,110 kbps     01:15:34.404    131,512 bytes   412,273 bytes   01:16:39.845
21              1:18:14.356     0:02:01.329     23,238 kbps     33,709 kbps     01:19:40.817    31,631 kbps     01:19:37.397    30,411 kbps     01:19:34.352    121,151 bytes   367,685 bytes   01:18:49.641
22              1:20:15.685     0:04:25.223     23,213 kbps     43,130 kbps     01:21:53.575    33,345 kbps     01:23:15.281    30,212 kbps     01:23:28.712    121,022 bytes   415,508 bytes   01:23:29.921
23              1:24:40.908     0:08:08.362     22,855 kbps     40,097 kbps     01:26:23.386    33,015 kbps     01:30:48.568    29,353 kbps     01:30:41.602    119,153 bytes   394,334 bytes   01:29:22.398
24              1:32:49.271     0:03:07.604     27,499 kbps     36,490 kbps     01:34:08.017    33,724 kbps     01:34:07.391    31,221 kbps     01:35:02.571    143,367 bytes   461,399 bytes   01:35:54.749
25              1:35:56.875     0:02:49.419     27,575 kbps     38,139 kbps     01:38:21.020    33,547 kbps     01:38:18.350    31,185 kbps     01:38:18.225    143,761 bytes   423,480 bytes   01:37:02.525
26              1:38:46.295     0:02:56.718     23,711 kbps     36,613 kbps     01:38:50.674    31,831 kbps     01:38:48.839    29,957 kbps     01:41:07.853    123,619 bytes   386,762 bytes   01:39:22.414
27              1:41:43.013     0:02:53.548     26,456 kbps     35,238 kbps     01:43:30.662    33,511 kbps     01:43:29.369    31,233 kbps     01:43:29.369    137,928 bytes   406,575 bytes   01:44:32.099
28              1:44:36.561     0:04:17.548     26,417 kbps     40,113 kbps     01:47:16.847    33,115 kbps     01:48:27.918    30,906 kbps     01:48:27.667    137,724 bytes   515,265 bytes   01:46:12.741
29              1:48:54.110     0:02:21.057     27,188 kbps     39,262 kbps     01:50:49.684    32,032 kbps     01:49:04.496    29,991 kbps     01:49:03.620    141,745 bytes   433,252 bytes   01:50:14.774
30              1:51:15.168     0:06:22.965     27,447 kbps     40,137 kbps     01:52:34.372    33,164 kbps     01:53:49.364    31,408 kbps     01:55:29.547    143,097 bytes   406,664 bytes   01:56:35.822
31              1:57:38.134     0:00:28.528     27,715 kbps     39,777 kbps     01:58:03.868    32,604 kbps     01:58:00.406    30,256 kbps     01:57:55.401    144,491 bytes   381,671 bytes   01:57:44.849
32              1:58:06.662     0:01:10.487     6,840 kbps      11,963 kbps     01:59:03.302    11,296 kbps     01:59:00.466    10,921 kbps     01:58:56.087    35,659 bytes    263,061 bytes   01:59:04.095
33              1:59:17.149     0:00:01.001     103 kbps        0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    560 bytes       783 bytes       01:59:17.316
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     7158.026                23,779                  21,276,546,396  115,733,143
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7158.026                3,324                   2,974,156,456   17,277,247
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           7158.026                224                     200,428,928     1,118,465
00001.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            7158.026                224                     200,428,928     1,118,465
00001.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           7158.026                224                     200,428,928     1,118,465
00001.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           7158.026                224                     200,428,928     1,118,465
00001.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           7158.026                224                     200,428,928     1,118,465
00001.M2TS      4358 (0x1106)   0x86            DTS-HD MA       eng (English)           7158.026                2,829                   2,530,885,596   14,872,399
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7158.026                33                      29,583,461      168,627
00001.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           7158.026                22                      19,922,141      113,522
00001.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           7158.026                0                       41,277          241
00001.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            7158.026                4                       3,634,371       20,751
00001.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           7158.026                27                      24,169,917      137,819
00001.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           7158.026                27                      23,930,614      136,538
RDarrylR is offline
post #1468 of 1971 Old 03-03-2009, 07:09 PM
Street Fighter
UPC: 025192008887
Code:
        Total   Video
Street Fighter                                                  VC-1    1:41:39 20,709,888,000  24,056,955,830  27.16   19.08   DTS-HD Master 5.1 4669Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     STREET_FIGHTER
Disc Size:      24,056,955,830 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:41:39 (h:m:s)
Total Bitrate:          27.16 Mbps
Description:
VIDEO:
VC-1 Video              19076 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         4669 kbps       5.1 / 48 kHz / 4669 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         34.741 kbps
Presentation Graphics           French          30.484 kbps
Presentation Graphics           French          1.540 kbps
Presentation Graphics           Spanish         27.015 kbps
Presentation Graphics           Spanish         0.716 kbps
FILES:
00010.M2TS      0:00:00.000     1:41:39.426     20,709,888,000  27,163
CHAPTERS:
1               0:00:00.000     0:06:06.157     16,129 kbps     47,767 kbps     00:03:44.599    24,139 kbps     00:03:40.678    22,169 kbps     00:03:44.015    84,303 bytes    445,314 bytes   00:00:55.180
2               0:06:06.157     0:05:09.142     20,160 kbps     31,246 kbps     00:08:17.705    28,512 kbps     00:08:38.392    27,421 kbps     00:08:35.640    105,105 bytes   381,549 bytes   00:09:18.307
3               0:11:15.299     0:04:06.412     18,662 kbps     29,531 kbps     00:14:06.637    26,180 kbps     00:14:03.717    25,508 kbps     00:13:59.713    97,296 bytes    268,813 bytes   00:11:51.419
4               0:15:21.712     0:03:44.432     17,686 kbps     27,934 kbps     00:16:55.389    24,398 kbps     00:17:12.322    22,276 kbps     00:17:10.904    92,208 bytes    333,062 bytes   00:19:06.145
5               0:19:06.145     0:06:53.996     19,626 kbps     29,740 kbps     00:21:27.869    27,955 kbps     00:23:49.344    25,021 kbps     00:19:56.653    102,322 bytes   342,338 bytes   00:23:06.426
6               0:26:00.141     0:05:19.277     16,765 kbps     30,148 kbps     00:26:00.141    23,193 kbps     00:26:00.141    20,340 kbps     00:26:00.141    87,407 bytes    231,779 bytes   00:26:56.281
7               0:31:19.419     0:07:31.200     16,948 kbps     32,949 kbps     00:38:41.694    28,286 kbps     00:38:38.190    26,824 kbps     00:38:36.314    88,359 bytes    270,177 bytes   00:35:12.985
8               0:38:50.619     0:03:14.652     16,348 kbps     25,936 kbps     00:41:19.727    24,548 kbps     00:41:19.727    23,107 kbps     00:41:27.735    85,229 bytes    285,873 bytes   00:41:22.938
9               0:42:05.272     0:06:29.972     17,927 kbps     33,481 kbps     00:47:17.251    30,988 kbps     00:47:14.748    30,164 kbps     00:47:09.701    93,462 bytes    335,967 bytes   00:44:45.766
10              0:48:35.245     0:05:29.537     20,459 kbps     30,262 kbps     00:50:18.724    29,849 kbps     00:50:19.057    29,500 kbps     00:50:12.718    106,666 bytes   257,548 bytes   00:51:32.798
11              0:54:04.783     0:03:37.717     18,759 kbps     32,970 kbps     00:54:50.412    29,893 kbps     00:54:47.993    28,974 kbps     00:54:44.572    97,801 bytes    278,125 bytes   00:54:50.453
12              0:57:42.500     0:04:54.002     19,473 kbps     33,541 kbps     00:58:02.187    28,718 kbps     00:58:02.020    24,955 kbps     00:58:01.769    101,522 bytes   437,181 bytes   01:00:13.901
13              1:02:36.502     0:05:11.894     21,627 kbps     35,714 kbps     01:03:30.348    30,086 kbps     01:03:06.199    28,650 kbps     01:03:02.653    112,752 bytes   409,892 bytes   01:05:38.059
14              1:07:48.397     0:06:06.032     21,674 kbps     33,107 kbps     01:12:53.827    29,826 kbps     01:10:33.812    29,046 kbps     01:10:33.354    112,996 bytes   299,529 bytes   01:13:54.430
15              1:13:54.430     0:03:36.507     25,645 kbps     44,400 kbps     01:14:40.100    36,315 kbps     01:14:36.180    32,152 kbps     01:14:58.327    133,700 bytes   406,430 bytes   01:15:10.172
16              1:17:30.937     0:06:28.054     22,951 kbps     42,172 kbps     01:22:32.322    34,700 kbps     01:22:29.986    31,078 kbps     01:22:29.986    119,654 bytes   452,556 bytes   01:22:31.488
17              1:23:58.992     0:03:20.867     23,079 kbps     38,585 kbps     01:26:09.164    30,514 kbps     01:24:41.993    30,105 kbps     01:24:42.577    120,323 bytes   265,262 bytes   01:26:09.831
18              1:27:19.859     0:03:29.876     22,565 kbps     45,837 kbps     01:28:10.743    33,096 kbps     01:28:01.901    30,039 kbps     01:28:01.609    117,646 bytes   334,488 bytes   01:28:11.202
19              1:30:49.735     0:04:05.161     24,580 kbps     38,217 kbps     01:31:40.161    35,356 kbps     01:31:30.193    34,169 kbps     01:31:28.774    128,147 bytes   438,518 bytes   01:34:12.897
20              1:34:54.897     0:06:44.529     8,072 kbps      31,582 kbps     01:41:27.039    22,248 kbps     01:41:23.035    21,650 kbps     01:41:03.640    42,254 bytes    384,786 bytes   01:41:28.040
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    6099.260                19,077                  14,544,436,832  79,133,982
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6099.260                4,669                   3,559,624,612   20,296,669
00010.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           6099.260                768                     585,545,728     3,430,932
00010.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            6099.260                768                     585,545,728     3,430,932
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6099.260                192                     146,386,944     953,040
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6099.260                35                      26,487,193      152,403
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6099.260                27                      20,596,631      118,386
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6099.260                30                      23,241,830      133,443
00010.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6099.260                1                       545,545         3,126
00010.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6099.260                2                       1,174,396       6,714
post #1469 of 1971 Old 03-04-2009, 03:16 PM - Thread Starter
benes's Avatar
Quoted: 76 Post(s)
Liked: 26
Code:
        Total   Video
(JP) Johnny Mnemonic                                            AVC     1:36:40 27,639,257,088  37,704,007,339  38.12   33.20   Dolby TrueHD 5.1 1584Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     BDROM
Disc Size:      37,704,007,339 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:36:40 (h:m:s)
Total Bitrate:          38.12 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        33202 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1584 kbps       5.1 / 48 kHz / 1584 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
SUBTITLES:
Presentation Graphics           English         42.866 kbps
Presentation Graphics           Japanese        39.534 kbps
FILES:
00004.M2TS      0:00:00.000     1:36:40.294     27,639,257,088  38,121
CHAPTERS:
1               0:00:00.000     0:06:55.206     32,769 kbps     62,638 kbps     00:01:23.208    39,901 kbps     00:01:31.883    37,015 kbps     00:01:31.883    170,828 bytes   768,206 bytes   00:01:23.500
2               0:06:55.206     0:09:00.248     33,354 kbps     56,802 kbps     00:11:11.462    41,332 kbps     00:11:04.997    38,580 kbps     00:10:59.992    173,891 bytes   616,903 bytes   00:06:58.501
3               0:15:55.454     0:06:16.459     33,234 kbps     46,861 kbps     00:17:35.763    36,439 kbps     00:17:35.971    34,614 kbps     00:17:35.262    173,268 bytes   613,335 bytes   00:16:47.548
4               0:22:11.913     0:11:03.579     33,267 kbps     43,004 kbps     00:31:29.971    35,066 kbps     00:23:55.142    34,343 kbps     00:30:56.729    173,437 bytes   487,067 bytes   00:31:24.632
5               0:33:15.493     0:04:40.780     33,290 kbps     50,220 kbps     00:34:11.466    36,189 kbps     00:34:02.165    34,923 kbps     00:34:02.415    173,558 bytes   665,687 bytes   00:34:06.878
6               0:37:56.274     0:08:48.694     33,201 kbps     51,544 kbps     00:42:37.513    40,410 kbps     00:41:47.046    35,308 kbps     00:41:42.082    173,097 bytes   593,652 bytes   00:40:51.031
7               0:46:44.968     0:07:41.961     33,252 kbps     44,086 kbps     00:50:48.837    36,400 kbps     00:52:38.405    34,510 kbps     00:52:38.113    173,362 bytes   481,023 bytes   00:52:54.379
8               0:54:26.930     0:07:14.433     33,270 kbps     42,699 kbps     00:59:54.799    34,963 kbps     00:59:54.340    34,284 kbps     00:54:49.536    173,455 bytes   460,585 bytes   01:00:46.976
9               1:01:41.364     0:06:41.192     33,228 kbps     54,316 kbps     01:07:16.490    35,843 kbps     01:07:14.321    35,001 kbps     01:07:07.481    173,235 bytes   512,069 bytes   01:07:16.657
10              1:08:22.556     0:08:13.659     33,272 kbps     47,738 kbps     01:15:18.555    39,608 kbps     01:15:18.263    37,025 kbps     01:15:17.638    173,464 bytes   579,467 bytes   01:14:10.779
11              1:16:36.216     0:06:46.989     33,226 kbps     54,383 kbps     01:17:45.410    37,378 kbps     01:17:41.490    35,405 kbps     01:17:36.485    173,226 bytes   637,057 bytes   01:17:45.869
12              1:23:23.206     0:13:17.087     33,090 kbps     63,271 kbps     01:31:38.993    39,252 kbps     01:31:38.993    36,408 kbps     01:31:38.993    172,523 bytes   756,039 bytes   01:31:39.202
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     5800.211                33,202                  24,072,621,606  130,911,064
00004.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           5800.211                2,224                   1,612,339,946   12,507,652
00004.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          5800.211                40                      28,663,602      164,011
00004.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5800.211                43                      31,079,761      177,400
Code:
        Total   Video
Johnny Mnemonic: Japanese Cut (480i59.94)                       MPEG-2  1:43:03 7,221,245,952   37,704,007,339  9.34    8.22    DD AC3 2.0 384Kbps
Code:
DISC INFO:
Disc Title:     BDROM
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:43:03 (h:m:s)
Total Bitrate:          9.34 Mbps
Description:
VIDEO:
MPEG-2 Video            8224 kbps           480i / 29.970 fps / 16:9
AUDIO:
Dolby Digital Audio             English         384 kbps        2.0 / 48 kHz / 384 kbps / Dolby Surround
Dolby Digital Audio             Japanese        192 kbps        2.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           Japanese        12.785 kbps
Presentation Graphics           Japanese        0.517 kbps
FILES:
00005.M2TS      0:00:00.000     1:43:03.510     7,221,245,952   9,343
CHAPTERS:
1               0:00:00.000     0:06:31.224     8,416 kbps      9,686 kbps      00:04:56.696    9,049 kbps      00:06:01.511    8,961 kbps      00:04:56.696    43,790 bytes    149,669 bytes   00:03:59.555
2               0:06:31.224     0:04:13.620     8,315 kbps      9,875 kbps      00:08:55.301    9,065 kbps      00:07:02.688    8,925 kbps      00:06:32.158    43,340 bytes    150,258 bytes   00:10:14.430
3               0:10:44.844     0:06:59.318     8,576 kbps      10,065 kbps     00:17:03.172    9,108 kbps      00:17:22.691    8,978 kbps      00:16:48.273    44,707 bytes    150,952 bytes   00:15:03.719
4               0:17:44.163     0:04:40.680     8,098 kbps      9,863 kbps      00:19:12.551    9,083 kbps      00:18:49.394    8,842 kbps      00:18:46.391    42,207 bytes    150,019 bytes   00:22:11.146
5               0:22:24.843     0:07:37.190     8,293 kbps      9,938 kbps      00:26:33.742    9,078 kbps      00:22:55.140    8,980 kbps      00:22:28.613    43,223 bytes    150,705 bytes   00:28:06.000
6               0:30:02.033     0:08:06.419     8,511 kbps      10,037 kbps     00:34:40.061    9,096 kbps      00:33:33.244    8,975 kbps      00:33:55.516    44,365 bytes    150,460 bytes   00:36:24.448
7               0:38:08.452     0:04:56.229     8,045 kbps      9,987 kbps      00:38:18.779    8,991 kbps      00:38:44.555    8,577 kbps      00:41:16.657    41,933 bytes    149,654 bytes   00:40:19.683
8               0:43:04.682     0:04:30.703     8,378 kbps      10,001 kbps     00:45:57.938    9,097 kbps      00:46:55.496    8,854 kbps      00:45:50.314    43,668 bytes    150,515 bytes   00:45:18.449
9               0:47:35.385     0:09:24.330     7,884 kbps      9,837 kbps      00:52:09.159    9,082 kbps      00:47:52.402    8,882 kbps      00:47:52.402    41,094 bytes    150,480 bytes   00:49:28.165
10              0:56:59.716     0:11:09.935     8,094 kbps      10,021 kbps     01:07:58.357    9,073 kbps      01:02:26.893    8,938 kbps      01:02:23.272    42,193 bytes    149,997 bytes   00:58:44.220
11              1:08:09.652     0:08:41.754     8,035 kbps      9,737 kbps      01:16:35.474    9,050 kbps      01:14:33.051    8,934 kbps      01:14:28.096    41,879 bytes    150,219 bytes   01:14:15.617
12              1:16:51.406     0:04:31.471     8,241 kbps      10,041 kbps     01:21:09.497    9,045 kbps      01:19:43.912    8,820 kbps      01:17:28.527    42,959 bytes    150,292 bytes   01:17:11.793
13              1:21:22.878     0:03:05.919     8,439 kbps      10,103 kbps     01:23:49.407    9,071 kbps      01:23:03.361    8,965 kbps      01:22:57.605    43,983 bytes    149,086 bytes   01:22:33.114
14              1:24:28.797     0:07:09.996     8,312 kbps      10,063 kbps     01:29:58.259    9,104 kbps      01:28:45.436    8,971 kbps      01:28:40.431    43,321 bytes    150,503 bytes   01:25:38.783
15              1:31:38.793     0:08:22.201     8,194 kbps      10,112 kbps     01:35:51.862    9,109 kbps      01:35:01.312    8,950 kbps      01:35:18.829    42,706 bytes    150,242 bytes   01:33:59.784
16              1:40:00.995     0:03:02.515     7,894 kbps      9,828 kbps      01:42:15.746    8,994 kbps      01:42:15.746    8,892 kbps      01:42:15.245    41,144 bytes    145,062 bytes   01:42:16.280
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x02            MPEG-2                                  6183.411                8,224                   6,356,698,732   34,633,595
00005.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6183.411                384                     296,808,960     1,739,115
00005.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          6183.411                192                     148,404,480     966,175
00005.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          6183.411                13                      9,881,706       62,226
00005.M2TS      4609 (0x1201)   0x90            PGS             jpn (Japanese)          6183.411                1                       399,409         2,383
benes is offline
post #1470 of 1971 Old 03-04-2009, 05:42 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
benes, I have heard the Japanese cut is drastically different. They put that cut on as basically a DVD port and put the US cut on that disc as the main feature for the JP disc? I watched it on Universal HD about 6 months ago and it looked terrible!! I would be interested in giving the BD a watch.
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
Closed Thread Blu-ray Software
