Unofficial Blu-ray Audio and Video Specifications Thread - Page 58 - AVS Forum | Home Theater Discussions And Reviews
post #1711 of 1971 Old 04-20-2009, 08:27 PM
PeterTHX's Avatar
Quoted: 568 Post(s)
Liked: 427
Originally Posted by Stephen Dawson View Post
I am having a bad day today! Yes, I got confused. This is listed as 20/48. BDInfo lists it as 24/48, I understand. Would you happen to know the provenance for the 20 bit claim? I'm keen to learn more. I also note that the front page of this thread alleges that this track is upconverted from to 20 bits from 16 bits, which simply wastes disc real estate if true.
I wouldn't mind discussing another matter with you, but I'm already verging on going wildly OT, so I'll PM you.
SPE's "paidgeek" was involved with the disc's production. He provided the information.
In TFE's case it was a 16-bit master, which was upconverted to 20 bit, which lowered the noise floor.
Originally Posted by benes View Post
Sony started out doing 20bit TrueHD as they felt this was a good compromise since no equipment is going to resolve more than 18bits anyway (paidgeek's words). But after he asked on AVS not surprisingly everyone demanded 24bit and Sony was doing that for a while. Then for some reason they switched to 16.
The masters these days are usually 24/48. However Sony's been keen to add as many lossless TrueHD tracks as possible for a single master to serve as much of the worldwide market as possible. Reducing the resolution to 16-bit also reduces the amount of bandwidth so the video is less impacted.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #1712 of 1971 Old 04-20-2009, 09:19 PM
Stephen Dawson's Avatar
Here is the post for Fifth Element.
Oh, that's sad. Sounds like Sony was being eminently sensible, but then was cowed into chasing big numbers pointlessly.
My initial data gatherings suggest that 24 bit DTS-HD MA uses about twice as much data (ie. about 2Mbps) as 16 bit. For Dolby TrueHD the figure seems to be about 85% more data for the 24 bit version, or about 1.4Mbps.
Megabits per second used in sound are megabits per second denied to PIP, video encode and so on. I am quite confident that with existing movie titles there is nothing to be gained by going from 20 to 24 bits because all that is contained in those bits is noise.
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1713 of 1971 Old 04-20-2009, 09:49 PM
PeterTHX's Avatar
Quoted: 568 Post(s)
Liked: 427
Well, you could say 24-bits leaves nothing to chance, since the master is 24-bit, literally nothing is lost. No downsampling. No possible artifacts. Jitter isn't a factor in lossless compression, since it's reclocked by the decoder.
PeterTHX is offline
post #1714 of 1971 Old 04-20-2009, 11:28 PM
CRT Dude's Avatar
2 hours at 40Mbps is only 35GB. Since that is rarely done we'll use 30Mbps which is only 26GB so an extra 2Mbps for audio isn't going to affect video quality unless in extreme cases like including 2 cuts of a movie with using branching. You're not going to use up all the 8Mbps dedicated to audio unless you include lossless dubs or use PCM.
CRT Dude is offline
post #1715 of 1971 Old 04-20-2009, 11:56 PM
My suspicion, to restate, is that the only thing you would lose by going from 24 bits down to 20 bits would be noise. No useful signal at all. Not that you would hear the noise. Or any usable signal that were reproduced to such a level.
To put it in perspective, let's say you have a really good home theatre system -- tens of thousands of dollars worth, capable of delivering peak levels of 120dBSPL, and with a signal to noise ratio of 144dB, so the equipment won't cause problems. The 21st bit of a 24 bit system would be six decibels quieter than is audible by any person (ie. -6dBSPL).
Incidentally, no artefacts should be generated by reducing resolution from 24 to 20 or to 16 bits. All that you need do is lop off the least significant bits of the sampling values.
Stephen Dawson
hifi-writer.com
post #1716 of 1971 Old 04-21-2009, 12:12 AM
Is 8Mbps dedicated to audio? I understand that the video bitrate supported by Blu-ray is up to 40Mbps, and the total data bitrate is up to 48Mbps, but within those constraints pretty much anything goes. Akira, for example, has an average audio bitrate of over 18Mbps consisting of six audio streams, two of them TrueHD.
As for the general point, yes there are plenty of discs were lots of capacity has been unused, so quibbling over 24 bit vs 20 bit sound probably isn't worth it. Still, where it comes to a tight choice due to movie length or extras, I'd hate to see something else suffer just because it is the demanded by the masses that all sound must be 24 bits.
Stephen Dawson
hifi-writer.com
post #1717 of 1971 Old 04-21-2009, 07:13 AM
poiv3's Avatar
"Frost/Nixon" anybody?
poiv3 is offline
post #1718 of 1971 Old 04-21-2009, 11:15 AM - Thread Starter
benes's Avatar
Quoted: 76 Post(s)
Liked: 26
There is no limit for audio as far as I know (besides 48Mbps). The Divertimenti BD has over 40Mbps of audio.
benes is offline
post #1719 of 1971 Old 04-21-2009, 01:58 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
HD DVD Specs
Code:
Star Trek: The Original Series - Season One
        Disc 1 - 3 Episodes             AVC     2:31:21 22,829,576,192 ~23,455,246,037  20.11   16.33   Dolby TrueHD 5.1 16&24      Yes     DDPlus 2.0  192Kbps
        Disc 2 - 3 Episodes             AVC     2:31:29 21,635,176,448 ~22,238,811,967  19.04   15.97   Dolby TrueHD 5.1 16&24      No      DDPlus 2.0  192Kbps
        Disc 3 - 3 Episodes             AVC     2:31:20 21,506,676,736 ~22,124,962,512  18.94   15.97   Dolby TrueHD 5.1 16&24      No      DDPlus 2.0  192Kbps
        Disc 4 - 3 Episodes             AVC     2:30:17 22,181,736,448  22,790,045,781  19.67   14.90   Dolby TrueHD 5.1 24-bit Yes     DDPlus 2.0  192Kbps
        Disc 5 - 3 Episodes             AVC     2:31:24 22,638,647,296  23,292,120,880  19.93   15.52   Dolby TrueHD 5.1 24-bit Yes     DDPlus 2.0  192Kbps
        Disc 6 - 3 Episodes             AVC     2:31:19 24,228,921,344  24,821,142,988  21.34   16.80   Dolby TrueHD 5.1 24-bit Yes     DDPlus 2.0  192Kbps
        Disc 7 - 3 Episodes             AVC     2:31:26 22,533,455,872  23,239,374,974  19.84   16.04   Dolby TrueHD 5.1 24-bit No      DDPlus 2.0  192Kbps
        Disc 8 - 3 Episodes             AVC     2:31:21 21,717,039,104  22,287,323,290  19.13   16.07   Dolby TrueHD 5.1 16&24      Yes     DDPlus 2.0  192Kbps
        Disc 9 - 3 Episodes             AVC     2:31:22 22,570,565,632  23,142,722,773  19.88   15.45   Dolby TrueHD 5.1 24-bit Yes     DDPlus 2.0  192Kbps
        Disc 10- 2 Episodes             AVC     1:40:50 15,701,921,792  24,356,804,574  20.76   17.04   Dolby TrueHD 5.1 24-bit No      DDPlus 2.0  192Kbps
Originally Posted by Bill Hunt - Digital Bits View Post
What's more, I've done A/B comparisons of the video quality here and on the previous HD-DVD release, and the added bandwidth of BD and extra disc space (which allows for less compression to be used) makes a clear difference. Take a look at the clouds on the shots of the Enterprise arriving in a planet's orbit at the start of The Man Trap - the HD-DVD clouds exhibit noticeable artifacting that's barely visible on Blu-ray (if at all).
Originally Posted by DVD Beaver View Post
Sample Graph
I look forward to seeing the Blu-ray as comparison. Bill Hunt claims the Blu-ray is better due to less compression. That bitrate graph suggests to me that they reused the HD DVD encode. Looks superior..
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #1720 of 1971 Old 04-21-2009, 02:13 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Only Warner reuses encodes. And that review says the BDs are VC1. Screenshots also look really blocky, 24-bit 7.1 was definitely overkill IMO, if they used 16-bit 5.1 the video could have got another 4mbps.
eric.exe is offline
post #1721 of 1971 Old 04-21-2009, 03:23 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
I didn't even notice the VC-1... However if it looks better than AVC at similar bitrates OMG... The FUD to come out of this.
post #1722 of 1971 Old 04-21-2009, 03:41 PM
bplewis24's Avatar
That would be fun
By the way, that DVD beaver graph isn't showing up.
Brandon
bplewis24 is offline
post #1723 of 1971 Old 04-21-2009, 03:50 PM
Statements like 'Only X does Y' are very brave.
Universal also reuses encodes, at least out here at the other end of the world. It did so for First Blood and also for Total Recall.
I confirmed these by extracting several hundred 'I' frames the Australian HD DVD and Blu-ray versions and using the DOS 'FC /B' command to compare their respective contents. They were identical.
Stephen Dawson
hifi-writer.com
post #1724 of 1971 Old 04-21-2009, 04:07 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Its the case for the major US studios North American releases. So far Paramount, Universal, and Weinstein haven't reused one HD DVD encode. But, I forgot that in the UK and Europe Studio Canal has been reusing their HD DVD encodes for recent Blu-rays. I think those discs you mentioned may have been handled by Studio Canal, since Studio Canal releases under Universal branding in some countries.
eric.exe is offline
post #1725 of 1971 Old 04-22-2009, 05:58 PM
Patsfan123's Avatar
Quoted: 469 Post(s)
Liked: 308
Code:
        Total   Video
The Thirteenth Floor                                            AVC     1:40:30 28,718,106,624  30,333,266,239  38.10   25.77   Dolby TrueHD 5.1 1641Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     THIRTEENTH_FLOOR
Disc Size:      30,333,266,239 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:40:30 (h:m:s)
Total Bitrate:          38.10 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        25766 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1641 kbps       5.1 / 48 kHz / 1641 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              French          1526 kbps       5.1 / 48 kHz / 1526 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              Portuguese      1664 kbps       5.1 / 48 kHz / 1664 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         22.377 kbps
Presentation Graphics           English         18.939 kbps
Presentation Graphics           French          21.616 kbps
Presentation Graphics           Portuguese      21.761 kbps
Presentation Graphics           Portuguese      41.689 kbps
Presentation Graphics           Spanish         23.030 kbps
Presentation Graphics           Spanish         40.794 kbps
FILES:
00011.M2TS      0:00:00.000     1:40:30.024     28,718,106,624  38,100
CHAPTERS:
1               0:00:00.000     0:06:51.702     25,698 kbps     48,584 kbps     00:00:24.899    32,683 kbps     00:00:24.733    31,132 kbps     00:00:24.733    133,965 bytes   502,440 bytes   00:01:10.487
2               0:06:51.702     0:06:03.946     26,169 kbps     44,706 kbps     00:08:41.062    31,516 kbps     00:11:47.832    28,893 kbps     00:11:43.869    136,431 bytes   581,407 bytes   00:11:47.957
3               0:12:55.649     0:07:01.671     26,301 kbps     37,036 kbps     00:14:13.519    30,543 kbps     00:14:27.324    30,304 kbps     00:14:20.693    137,122 bytes   477,619 bytes   00:19:57.321
4               0:19:57.321     0:08:42.313     25,792 kbps     41,859 kbps     00:24:43.607    32,638 kbps     00:24:42.814    30,836 kbps     00:27:57.842    134,470 bytes   539,507 bytes   00:22:56.166
5               0:28:39.634     0:08:03.274     25,692 kbps     36,685 kbps     00:32:20.063    30,143 kbps     00:31:35.518    28,931 kbps     00:32:19.145    133,948 bytes   542,149 bytes   00:32:39.791
6               0:36:42.909     0:05:17.108     26,490 kbps     39,854 kbps     00:41:58.766    31,164 kbps     00:41:54.762    30,559 kbps     00:41:49.965    138,104 bytes   460,814 bytes   00:41:59.391
7               0:42:00.017     0:04:25.515     25,197 kbps     36,129 kbps     00:45:11.709    30,229 kbps     00:45:11.041    29,049 kbps     00:45:54.168    131,365 bytes   467,420 bytes   00:44:49.436
8               0:46:25.532     0:05:21.320     26,464 kbps     38,803 kbps     00:47:44.987    30,929 kbps     00:47:44.987    29,752 kbps     00:48:06.967    137,970 bytes   587,466 bytes   00:47:40.858
9               0:51:46.853     0:07:32.618     25,889 kbps     38,959 kbps     00:55:17.814    33,644 kbps     00:55:13.977    31,551 kbps     00:55:14.019    134,971 bytes   471,143 bytes   00:57:33.616
10              0:59:19.472     0:03:51.397     25,662 kbps     40,920 kbps     01:00:55.902    32,394 kbps     01:00:49.479    31,408 kbps     01:00:49.479    133,789 bytes   404,831 bytes   01:03:07.784
11              1:03:10.870     0:06:11.162     26,337 kbps     35,303 kbps     01:07:10.067    29,788 kbps     01:05:40.519    28,571 kbps     01:06:15.137    137,309 bytes   460,558 bytes   01:06:17.223
12              1:09:22.032     0:07:45.131     25,977 kbps     48,545 kbps     01:12:15.039    31,717 kbps     01:17:01.158    30,928 kbps     01:11:04.301    135,433 bytes   583,145 bytes   01:12:07.489
13              1:17:07.164     0:05:18.818     25,394 kbps     42,307 kbps     01:22:08.882    28,786 kbps     01:21:21.877    28,210 kbps     01:21:22.168    132,392 bytes   457,806 bytes   01:22:17.933
14              1:22:25.982     0:05:51.142     26,206 kbps     43,830 kbps     01:24:09.878    30,689 kbps     01:27:52.350    29,345 kbps     01:24:09.878    136,625 bytes   504,065 bytes   01:23:51.151
15              1:28:17.125     0:05:52.852     26,315 kbps     48,637 kbps     01:30:26.671    33,444 kbps     01:33:15.673    29,974 kbps     01:33:10.626    137,196 bytes   490,381 bytes   01:33:16.173
16              1:34:09.977     0:06:20.046     22,613 kbps     33,773 kbps     01:34:49.558    30,364 kbps     01:34:42.677    29,669 kbps     01:36:38.751    117,919 bytes   466,997 bytes   01:34:49.600
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6029.941                25,766                  19,420,917,272  105,633,487
00011.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6029.941                2,281                   1,719,576,608   13,224,670
00011.M2TS      4353 (0x1101)   0x83            TrueHD          fra (French)            6029.941                2,166                   1,632,749,784   12,158,103
00011.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6029.941                640                     482,403,840     2,826,585
00011.M2TS      4355 (0x1103)   0x83            TrueHD          por (Portuguese)        6029.941                2,304                   1,736,395,402   13,759,521
00011.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           6029.941                192                     144,721,152     942,195
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6029.941                22                      16,866,987      97,876
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6029.941                19                      14,275,564      84,795
00011.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6029.941                22                      16,293,028      94,684
00011.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6029.941                23                      17,358,606      100,830
00011.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        6029.941                22                      16,402,281      95,549
00011.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           6029.941                41                      30,748,561      174,534
00011.M2TS      4614 (0x1206)   0x90            PGS             por (Portuguese)        6029.941                42                      31,423,258      178,601
post #1726 of 1971 Old 04-22-2009, 07:43 PM
vamovie's Avatar
Does anybody got EYES WIDE SHUT specs please
thanx in advance
vamovie is offline
post #1727 of 1971 Old 04-22-2009, 08:20 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Code:
        Total   Video
X-Men 1                                                         AVC     1:44:20 29,834,698,752  39,611,978,751  38.13   30.19   DTS-HD Master 5.1 3746Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     XMEN_D1
Disc Size:      39,611,978,751 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:44:20 (h:m:s)
Total Bitrate:          38.13 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        30189 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3746 kbps       5.1 / 48 kHz / 3746 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Portuguese      448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           English         33.880 kbps
Presentation Graphics           Chinese         25.121 kbps
Presentation Graphics           Chinese         26.291 kbps
Presentation Graphics           French          0.328 kbps
Presentation Graphics           Korean          24.436 kbps
Presentation Graphics           Portuguese      28.544 kbps
Presentation Graphics           Spanish         28.279 kbps
FILES:
00074.M2TS      0:00:00.000     1:44:20.295     29,834,698,752  38,126
CHAPTERS:
1               0:00:00.000     0:01:19.287     26,291 kbps     37,589 kbps     00:01:11.404    33,520 kbps     00:01:07.108    33,204 kbps     00:00:06.589    136,999 bytes   437,022 bytes   00:01:11.905
2               0:01:19.287     0:02:58.845     30,660 kbps     37,221 kbps     00:02:14.008    33,594 kbps     00:02:37.740    33,257 kbps     00:03:13.234    159,849 bytes   414,526 bytes   00:04:18.132
3               0:04:18.132     0:01:37.889     33,112 kbps     36,065 kbps     00:04:23.763    33,824 kbps     00:04:19.926    33,414 kbps     00:04:29.519    172,632 bytes   453,070 bytes   00:04:19.968
4               0:05:56.022     0:02:00.036     32,505 kbps     37,844 kbps     00:06:28.304    33,908 kbps     00:06:24.342    33,511 kbps     00:06:19.379    169,464 bytes   281,922 bytes   00:07:56.058
5               0:07:56.058     0:01:27.629     33,073 kbps     36,776 kbps     00:08:09.447    33,484 kbps     00:09:03.834    33,375 kbps     00:08:58.704    172,426 bytes   361,826 bytes   00:08:10.114
6               0:09:23.688     0:02:14.008     31,605 kbps     36,152 kbps     00:10:57.698    33,614 kbps     00:10:53.694    33,407 kbps     00:10:48.689    164,773 bytes   395,824 bytes   00:10:39.013
7               0:11:37.697     0:03:00.805     29,399 kbps     33,820 kbps     00:11:39.740    32,505 kbps     00:12:23.993    31,952 kbps     00:12:20.906    153,273 bytes   328,150 bytes   00:14:38.502
8               0:14:38.502     0:03:23.161     31,890 kbps     35,240 kbps     00:15:42.942    33,656 kbps     00:15:38.938    33,400 kbps     00:15:37.019    166,261 bytes   385,864 bytes   00:15:47.738
9               0:18:01.663     0:02:48.001     32,448 kbps     39,491 kbps     00:20:47.579    34,755 kbps     00:20:43.575    33,824 kbps     00:20:38.570    169,171 bytes   367,593 bytes   00:20:48.205
10              0:20:49.665     0:01:19.454     28,210 kbps     33,825 kbps     00:20:57.047    31,690 kbps     00:20:55.712    30,878 kbps     00:21:25.575    147,073 bytes   286,512 bytes   00:21:15.148
11              0:22:09.119     0:01:49.526     32,950 kbps     35,020 kbps     00:22:51.745    33,509 kbps     00:22:38.690    33,307 kbps     00:22:23.008    171,787 bytes   246,111 bytes   00:22:19.338
12              0:23:58.645     0:04:47.203     31,393 kbps     35,017 kbps     00:27:27.562    33,446 kbps     00:27:45.163    33,303 kbps     00:27:47.123    163,666 bytes   387,258 bytes   00:28:26.454
13              0:28:45.849     0:01:09.319     31,762 kbps     35,647 kbps     00:28:58.945    33,381 kbps     00:29:23.636    33,283 kbps     00:29:16.463    165,590 bytes   247,921 bytes   00:29:31.394
14              0:29:55.168     0:02:11.339     32,942 kbps     35,645 kbps     00:31:25.842    33,810 kbps     00:31:22.881    33,510 kbps     00:31:17.917    171,745 bytes   262,761 bytes   00:30:30.119
15              0:32:06.507     0:01:31.174     32,927 kbps     44,233 kbps     00:32:38.539    34,750 kbps     00:32:34.535    33,982 kbps     00:32:29.530    171,668 bytes   321,735 bytes   00:32:39.415
16              0:33:37.682     0:02:59.554     29,966 kbps     35,252 kbps     00:36:15.840    33,615 kbps     00:36:17.508    33,204 kbps     00:36:12.712    156,227 bytes   269,786 bytes   00:33:44.647
17              0:36:37.236     0:01:47.941     32,616 kbps     36,045 kbps     00:38:23.843    33,468 kbps     00:38:19.839    33,275 kbps     00:36:44.327    170,045 bytes   237,309 bytes   00:38:24.510
18              0:38:25.177     0:02:46.708     29,209 kbps     37,693 kbps     00:39:10.598    33,386 kbps     00:40:23.504    33,284 kbps     00:40:23.504    152,284 bytes   303,906 bytes   00:39:16.896
19              0:41:11.886     0:03:01.973     29,944 kbps     36,424 kbps     00:43:22.516    33,532 kbps     00:43:18.512    33,390 kbps     00:43:28.147    156,114 bytes   348,767 bytes   00:44:13.859
20              0:44:13.859     0:01:36.596     33,114 kbps     34,249 kbps     00:45:19.466    33,399 kbps     00:44:25.287    33,304 kbps     00:44:33.879    172,643 bytes   342,527 bytes   00:44:15.861
21              0:45:50.456     0:02:51.087     31,454 kbps     36,548 kbps     00:46:03.093    33,845 kbps     00:45:59.089    33,525 kbps     00:45:54.084    163,984 bytes   431,106 bytes   00:47:16.917
22              0:48:41.543     0:01:40.892     31,968 kbps     35,003 kbps     00:49:54.574    33,528 kbps     00:49:47.109    33,336 kbps     00:49:42.145    166,664 bytes   332,892 bytes   00:49:52.114
23              0:50:22.436     0:01:43.394     30,229 kbps     34,448 kbps     00:52:01.785    32,640 kbps     00:52:00.826    31,863 kbps     00:51:24.790    157,602 bytes   228,223 bytes   00:51:24.831
24              0:52:05.831     0:02:52.380     30,954 kbps     38,110 kbps     00:53:43.678    33,343 kbps     00:52:40.073    33,207 kbps     00:52:32.524    161,380 bytes   307,251 bytes   00:54:15.919
25              0:54:58.211     0:03:12.942     32,122 kbps     35,084 kbps     00:57:59.684    33,482 kbps     00:55:04.300    33,231 kbps     00:55:00.005    167,472 bytes   330,036 bytes   00:58:00.185
26              0:58:11.154     0:01:08.610     30,314 kbps     34,439 kbps     00:58:15.533    33,342 kbps     00:58:15.575    33,117 kbps     00:58:11.696    158,044 bytes   250,681 bytes   00:59:18.388
27              0:59:19.764     0:02:35.196     32,477 kbps     35,333 kbps     01:00:45.224    33,589 kbps     01:00:56.569    33,335 kbps     01:00:51.689    169,319 bytes   256,107 bytes   01:00:20.742
28              1:01:54.961     0:01:22.665     32,725 kbps     35,934 kbps     01:03:04.113    33,425 kbps     01:03:08.034    33,291 kbps     01:02:45.136    170,614 bytes   229,344 bytes   01:02:44.177
29              1:03:17.627     0:02:44.747     32,381 kbps     37,781 kbps     01:04:13.432    33,548 kbps     01:05:35.640    33,377 kbps     01:05:30.635    168,819 bytes   297,465 bytes   01:04:14.141
30              1:06:02.375     0:02:37.407     28,923 kbps     38,339 kbps     01:06:18.307    33,409 kbps     01:08:30.439    32,937 kbps     01:06:57.722    150,790 bytes   384,056 bytes   01:06:19.100
31              1:08:39.782     0:03:41.596     30,211 kbps     35,626 kbps     01:11:48.721    33,386 kbps     01:09:09.228    33,263 kbps     01:09:04.265    157,507 bytes   288,799 bytes   01:09:07.351
32              1:12:21.378     0:05:42.425     32,452 kbps     42,164 kbps     01:14:33.177    35,030 kbps     01:14:29.214    34,070 kbps     01:14:24.168    169,191 bytes   355,428 bytes   01:16:07.229
33              1:18:03.804     0:02:49.419     30,332 kbps     36,723 kbps     01:18:30.914    33,470 kbps     01:20:07.177    33,257 kbps     01:20:42.212    158,137 bytes   348,518 bytes   01:20:12.098
34              1:20:53.223     0:03:34.839     30,770 kbps     36,508 kbps     01:21:57.203    33,308 kbps     01:21:35.223    33,072 kbps     01:21:31.177    160,420 bytes   265,421 bytes   01:21:52.741
35              1:24:28.063     0:02:30.358     31,647 kbps     36,364 kbps     01:26:42.322    33,889 kbps     01:26:40.069    33,450 kbps     01:26:34.397    164,994 bytes   309,360 bytes   01:26:43.907
36              1:26:58.421     0:02:10.088     26,435 kbps     35,068 kbps     01:26:58.838    32,780 kbps     01:27:01.966    32,345 kbps     01:26:58.838    137,823 bytes   277,564 bytes   01:28:06.823
37              1:29:08.509     0:02:38.700     32,981 kbps     34,216 kbps     01:31:21.434    33,434 kbps     01:30:37.515    33,327 kbps     01:30:54.282    171,950 bytes   278,491 bytes   01:31:29.609
38              1:31:47.210     0:01:25.668     33,051 kbps     35,815 kbps     01:32:01.182    33,537 kbps     01:31:57.220    33,396 kbps     01:31:52.173    172,315 bytes   338,569 bytes   01:33:12.128
39              1:33:12.878     0:01:59.244     31,740 kbps     36,481 kbps     01:35:04.949    33,802 kbps     01:35:00.903    33,521 kbps     01:34:55.940    165,478 bytes   293,320 bytes   01:34:01.594
40              1:35:12.123     0:09:08.172     19,165 kbps     33,766 kbps     01:38:10.509    33,229 kbps     01:38:09.842    32,494 kbps     01:38:08.465    99,924 bytes    391,140 bytes   01:43:25.616
STREAM DIAGNOSTICS:
00074.M2TS      4113 (0x1011)   0x1B            AVC                                     6260.212                30,190                  23,624,239,242  128,481,032
00074.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6260.212                3,746                   2,931,220,112   16,909,470
00074.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6260.212                448                     350,577,920     1,956,350
00074.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6260.212                448                     350,577,920     1,956,350
00074.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           6260.212                448                     350,577,920     1,956,350
00074.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        6260.212                448                     350,577,920     1,956,350
00074.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           6260.212                224                     175,288,960     978,175
00074.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6260.212                34                      26,511,993      149,106
00074.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6260.212                28                      22,129,577      125,099
00074.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           6260.212                25                      19,658,406      111,661
00074.M2TS      4611 (0x1203)   0x90            PGS             kor (Korean)            6260.212                24                      19,122,395      109,151
00074.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           6260.212                26                      20,573,791      116,614
00074.M2TS      4613 (0x1205)   0x90            PGS             por (Portuguese)        6260.212                29                      22,336,986      126,049
00074.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            6260.212                0                       256,830         1,442
Code:
        Total   Video
X-Men 2                                                         AVC     2:13:47 31,697,897,472  34,383,722,714  31.59   22.88   DTS-HD Master 5.1 4075Kbps (48kHz/24-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     X2
Disc Size:      34,383,722,714 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:13:47 (h:m:s)
Total Bitrate:          31.59 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        22878 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4075 kbps       5.1 / 48 kHz / 4075 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         41.161 kbps
Presentation Graphics           Chinese         32.284 kbps
Presentation Graphics           Chinese         34.528 kbps
Presentation Graphics           French          0.731 kbps
Presentation Graphics           Korean          25.920 kbps
Presentation Graphics           Portuguese      28.138 kbps
Presentation Graphics           Spanish         31.707 kbps
FILES:
00074.M2TS      0:00:00.000     2:13:47.477     31,697,897,472  31,589
CHAPTERS:
1               0:00:00.000     0:01:50.527     19,290 kbps     47,612 kbps     00:00:36.327    36,955 kbps     00:00:32.323    35,091 kbps     00:00:27.360    100,530 bytes   514,406 bytes   00:00:37.078
2               0:01:50.527     0:03:31.419     23,713 kbps     32,024 kbps     00:03:32.795    29,508 kbps     00:03:22.243    28,111 kbps     00:03:17.488    123,629 bytes   270,736 bytes   00:02:47.250
3               0:05:21.946     0:01:50.318     24,500 kbps     36,018 kbps     00:06:40.983    33,934 kbps     00:06:40.983    32,820 kbps     00:06:41.734    127,731 bytes   405,347 bytes   00:06:50.618
4               0:07:12.265     0:05:14.856     24,399 kbps     35,187 kbps     00:11:23.432    33,027 kbps     00:11:20.805    29,507 kbps     00:11:17.134    127,204 bytes   456,852 bytes   00:12:27.121
5               0:12:27.121     0:03:07.103     22,839 kbps     32,553 kbps     00:12:27.997    27,512 kbps     00:12:27.121    25,247 kbps     00:13:56.460    119,074 bytes   385,096 bytes   00:12:28.122
6               0:15:34.224     0:02:23.101     19,234 kbps     27,388 kbps     00:15:35.184    23,526 kbps     00:16:13.097    22,239 kbps     00:16:10.302    100,278 bytes   359,196 bytes   00:15:35.225
7               0:17:57.326     0:01:28.379     25,428 kbps     32,844 kbps     00:19:06.728    29,668 kbps     00:19:04.351    28,209 kbps     00:19:04.351    132,568 bytes   250,507 bytes   00:18:21.809
8               0:19:25.706     0:03:21.910     23,368 kbps     36,072 kbps     00:20:14.630    29,656 kbps     00:20:14.046    28,073 kbps     00:20:14.004    121,828 bytes   245,399 bytes   00:22:38.690
9               0:22:47.616     0:03:22.076     25,738 kbps     36,815 kbps     00:24:13.869    33,072 kbps     00:24:10.031    32,425 kbps     00:24:13.160    134,184 bytes   350,216 bytes   00:24:10.073
10              0:26:09.693     0:03:06.269     20,464 kbps     36,838 kbps     00:27:38.573    30,541 kbps     00:27:35.862    28,055 kbps     00:27:35.862    106,691 bytes   360,574 bytes   00:27:39.366
11              0:29:15.962     0:01:54.322     19,344 kbps     34,776 kbps     00:29:45.867    27,807 kbps     00:29:29.601    26,301 kbps     00:29:29.601    100,849 bytes   256,198 bytes   00:30:47.011
12              0:31:10.285     0:02:31.401     24,363 kbps     33,625 kbps     00:31:42.066    30,349 kbps     00:31:39.731    28,668 kbps     00:31:40.940    127,018 bytes   285,063 bytes   00:32:27.195
13              0:33:41.686     0:01:27.837     25,659 kbps     36,631 kbps     00:34:35.865    32,019 kbps     00:34:35.865    30,326 kbps     00:34:35.865    133,772 bytes   275,249 bytes   00:34:19.515
14              0:35:09.524     0:04:40.655     21,934 kbps     36,273 kbps     00:36:42.158    33,182 kbps     00:36:41.490    29,758 kbps     00:36:38.446    114,356 bytes   277,909 bytes   00:36:43.701
15              0:39:50.179     0:05:45.553     22,211 kbps     36,043 kbps     00:42:25.000    32,316 kbps     00:42:23.666    31,259 kbps     00:42:23.874    115,800 bytes   305,226 bytes   00:42:31.465
16              0:45:35.733     0:01:42.602     23,948 kbps     30,604 kbps     00:45:35.733    29,093 kbps     00:46:41.715    28,240 kbps     00:46:36.710    124,853 bytes   252,346 bytes   00:47:18.335
17              0:47:18.335     0:03:05.768     23,274 kbps     31,771 kbps     00:48:45.255    28,032 kbps     00:48:53.430    25,885 kbps     00:48:51.053    121,341 bytes   230,371 bytes   00:50:07.921
18              0:50:24.104     0:02:53.882     22,498 kbps     28,610 kbps     00:52:24.766    26,853 kbps     00:51:27.209    25,394 kbps     00:51:24.706    117,294 bytes   229,971 bytes   00:52:25.517
19              0:53:17.986     0:02:22.433     23,801 kbps     35,756 kbps     00:53:48.266    32,699 kbps     00:53:46.556    31,493 kbps     00:54:33.979    124,090 bytes   321,371 bytes   00:55:00.547
20              0:55:40.420     0:01:34.511     22,703 kbps     27,327 kbps     00:56:41.356    25,215 kbps     00:56:58.832    24,861 kbps     00:56:58.706    118,362 bytes   281,780 bytes   00:56:15.330
21              0:57:14.931     0:02:06.876     21,627 kbps     29,353 kbps     00:57:33.366    27,749 kbps     00:57:29.404    26,806 kbps     00:57:28.820    112,755 bytes   252,645 bytes   00:59:21.808
22              0:59:21.808     0:05:34.083     24,718 kbps     36,378 kbps     01:02:35.209    35,100 kbps     01:02:30.997    32,039 kbps     01:02:30.079    128,870 bytes   360,203 bytes   01:02:58.399
23              1:04:55.892     0:04:27.809     22,399 kbps     30,017 kbps     01:08:08.209    28,355 kbps     01:08:37.363    26,823 kbps     01:05:53.324    116,780 bytes   274,350 bytes   01:09:10.855
24              1:09:23.701     0:05:25.033     20,305 kbps     29,927 kbps     01:12:44.902    27,965 kbps     01:12:43.984    25,761 kbps     01:12:43.901    105,863 bytes   350,851 bytes   01:12:18.125
25              1:14:48.734     0:03:29.751     23,961 kbps     34,752 kbps     01:14:55.991    31,411 kbps     01:14:55.157    28,408 kbps     01:14:55.157    124,923 bytes   329,374 bytes   01:18:18.485
26              1:18:18.485     0:06:34.060     24,757 kbps     35,070 kbps     01:22:27.025    32,433 kbps     01:18:32.374    30,761 kbps     01:18:31.081    129,071 bytes   291,567 bytes   01:18:19.486
27              1:24:52.545     0:02:23.893     21,713 kbps     28,259 kbps     01:24:53.379    27,284 kbps     01:26:23.636    25,635 kbps     01:26:21.593    113,200 bytes   253,333 bytes   01:26:23.678
28              1:27:16.439     0:03:15.945     21,438 kbps     35,719 kbps     01:28:37.437    30,325 kbps     01:28:43.860    29,335 kbps     01:28:37.437    111,769 bytes   241,310 bytes   01:28:38.021
29              1:30:32.385     0:02:01.538     20,762 kbps     37,492 kbps     01:31:53.174    29,441 kbps     01:31:49.253    26,490 kbps     01:31:44.248    108,246 bytes   287,947 bytes   01:32:19.033
30              1:32:33.923     0:04:10.166     23,862 kbps     38,176 kbps     01:35:06.951    32,096 kbps     01:35:04.657    30,495 kbps     01:34:59.151    124,408 bytes   270,748 bytes   01:33:06.080
31              1:36:44.089     0:04:31.980     22,577 kbps     37,140 kbps     01:38:43.542    32,368 kbps     01:38:25.316    28,209 kbps     01:38:34.533    117,705 bytes   302,951 bytes   01:39:02.645
32              1:41:16.070     0:02:15.093     24,427 kbps     32,339 kbps     01:42:37.901    27,918 kbps     01:42:19.466    27,216 kbps     01:43:19.193    127,354 bytes   236,114 bytes   01:43:25.616
33              1:43:31.163     0:03:06.895     22,132 kbps     30,761 kbps     01:46:36.598    28,188 kbps     01:44:21.630    26,942 kbps     01:44:17.960    115,388 bytes   235,300 bytes   01:46:32.511
34              1:46:38.058     0:02:00.578     23,004 kbps     32,812 kbps     01:46:55.992    31,681 kbps     01:46:54.491    27,934 kbps     01:46:52.406    119,933 bytes   275,364 bytes   01:47:08.463
35              1:48:38.637     0:05:03.302     24,220 kbps     36,138 kbps     01:49:51.376    32,659 kbps     01:52:02.674    31,506 kbps     01:52:02.674    126,270 bytes   359,453 bytes   01:49:57.173
36              1:53:41.940     0:04:36.943     22,924 kbps     37,591 kbps     01:54:43.585    33,562 kbps     01:57:37.050    32,860 kbps     01:55:15.867    119,513 bytes   320,373 bytes   01:53:47.070
37              1:58:18.883     0:03:55.777     19,529 kbps     36,145 kbps     01:59:11.602    33,247 kbps     02:01:45.589    30,440 kbps     02:01:43.462    101,814 bytes   430,070 bytes   02:01:44.130
38              2:02:14.660     0:02:23.810     23,261 kbps     35,396 kbps     02:02:16.287    34,784 kbps     02:02:15.536    29,493 kbps     02:02:14.660    121,271 bytes   289,547 bytes   02:02:18.664
39              2:04:38.471     0:00:32.699     33,316 kbps     35,731 kbps     02:04:57.948    34,881 kbps     02:04:55.946    34,407 kbps     02:04:51.150    173,695 bytes   242,874 bytes   02:04:39.472
40              2:05:11.170     0:08:36.307     22,511 kbps     36,122 kbps     02:12:50.963    35,147 kbps     02:07:51.705    34,941 kbps     02:12:42.245    117,373 bytes   456,057 bytes   02:07:56.335
STREAM DIAGNOSTICS:
00074.M2TS      4113 (0x1011)   0x1B            AVC                                     8027.394                22,879                  22,956,891,852  124,878,999
00074.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           8027.394                4,075                   4,088,957,808   23,473,763
00074.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           8027.394                640                     642,199,040     3,762,885
00074.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            8027.394                448                     449,539,328     2,508,590
00074.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           8027.394                640                     642,199,040     3,762,885
00074.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        8027.394                448                     449,539,328     2,508,590
00074.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           8027.394                224                     224,769,664     1,254,295
00074.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           8027.394                224                     224,769,664     1,254,295
00074.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8027.394                41                      41,302,839      233,100
00074.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           8027.394                32                      31,815,563      180,213
00074.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           8027.394                32                      32,394,653      183,641
00074.M2TS      4611 (0x1203)   0x90            PGS             kor (Korean)            8027.394                26                      26,008,961      148,042
00074.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           8027.394                35                      34,646,835      195,914
00074.M2TS      4613 (0x1205)   0x90            PGS             por (Portuguese)        8027.394                28                      28,234,835      159,349
00074.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            8027.394                1                       733,462         4,140
Code:
        Total   Video
X-Men 3                                                         AVC     1:44:05 22,331,344,896  28,106,222,746  28.61   19.81   DTS-HD Master 6.1 4738Kbps (48kHz/24-bit) DD AC3 5.1-EX 448Kbps
Code:
DISC INFO:
Disc Title:     XMEN_THELASTSTAND
Disc Size:      28,106,222,746 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:44:05 (h:m:s)
Total Bitrate:          28.61 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        19809 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4738 kbps       6.1 / 48 kHz / 4738 kbps / 24-bit (DTS Core: 6.1-ES / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital EX Audio          English         448 kbps        5.1-EX / 48 kHz / 448 kbps
SUBTITLES:
Presentation Graphics           English         37.868 kbps
Presentation Graphics           Chinese         34.226 kbps
Presentation Graphics           Chinese         37.929 kbps
Presentation Graphics           French          0.854 kbps
Presentation Graphics           Korean          25.630 kbps
Presentation Graphics           Portuguese      30.612 kbps
Presentation Graphics           Spanish         35.000 kbps
FILES:
00074.M2TS      0:00:00.000     1:44:05.239     22,331,344,896  28,606
CHAPTERS:
1               0:00:00.000     0:05:15.189     27,879 kbps     49,994 kbps     00:00:27.902    44,873 kbps     00:00:27.318    41,295 kbps     00:00:25.900    145,330 bytes   627,086 bytes   00:00:30.363
2               0:05:15.189     0:04:04.118     24,782 kbps     49,212 kbps     00:07:24.569    42,511 kbps     00:07:21.232    38,175 kbps     00:05:26.909    129,203 bytes   463,737 bytes   00:07:25.111
3               0:09:19.308     0:02:58.094     20,392 kbps     33,719 kbps     00:09:28.985    32,193 kbps     00:09:26.524    30,879 kbps     00:09:23.729    106,313 bytes   384,611 bytes   00:12:17.403
4               0:12:17.403     0:05:33.666     17,078 kbps     29,479 kbps     00:13:35.064    25,755 kbps     00:13:33.729    24,969 kbps     00:17:02.688    89,036 bytes    385,202 bytes   00:12:18.320
5               0:17:51.070     0:05:16.065     20,093 kbps     38,268 kbps     00:21:34.293    37,022 kbps     00:21:33.625    34,749 kbps     00:21:32.499    104,758 bytes   410,106 bytes   00:21:34.459
6               0:23:07.135     0:07:48.759     20,082 kbps     44,298 kbps     00:24:09.406    30,858 kbps     00:24:09.406    27,250 kbps     00:29:21.593    104,699 bytes   362,456 bytes   00:24:09.448
7               0:30:55.895     0:02:59.596     24,390 kbps     42,390 kbps     00:33:33.886    40,261 kbps     00:33:33.886    34,321 kbps     00:33:29.674    127,156 bytes   405,491 bytes   00:33:33.928
8               0:33:55.491     0:04:04.869     20,523 kbps     39,286 kbps     00:36:24.515    32,439 kbps     00:36:32.231    29,059 kbps     00:36:27.226    106,997 bytes   316,002 bytes   00:36:39.906
9               0:38:00.361     0:05:45.803     18,790 kbps     38,176 kbps     00:42:03.979    31,781 kbps     00:42:24.541    24,363 kbps     00:42:20.037    97,961 bytes    285,439 bytes   00:42:04.063
10              0:43:46.165     0:06:48.574     20,942 kbps     42,964 kbps     00:47:17.668    34,723 kbps     00:47:38.605    32,417 kbps     00:47:38.897    109,183 bytes   379,346 bytes   00:44:02.222
11              0:50:34.740     0:05:00.341     16,360 kbps     46,093 kbps     00:52:01.243    42,822 kbps     00:51:59.282    39,987 kbps     00:51:57.989    85,293 bytes    518,035 bytes   00:51:21.703
12              0:55:35.081     0:02:25.770     16,276 kbps     45,813 kbps     00:55:39.669    37,059 kbps     00:55:39.669    32,288 kbps     00:55:39.669    84,857 bytes    493,056 bytes   00:55:39.711
13              0:58:00.852     0:03:11.024     19,060 kbps     37,398 kbps     01:00:38.343    33,396 kbps     01:00:38.343    31,325 kbps     01:00:35.506    99,372 bytes    440,853 bytes   00:59:54.799
14              1:01:11.876     0:02:42.871     18,792 kbps     38,137 kbps     01:02:10.935    34,151 kbps     01:03:31.224    31,105 kbps     01:03:26.177    97,972 bytes    318,970 bytes   01:03:26.219
15              1:03:54.747     0:04:20.051     19,354 kbps     42,941 kbps     01:06:24.772    32,654 kbps     01:08:05.998    28,187 kbps     01:08:04.246    100,905 bytes   357,499 bytes   01:04:02.088
16              1:08:14.799     0:02:23.768     19,497 kbps     50,850 kbps     01:09:52.438    37,685 kbps     01:09:51.562    31,809 kbps     01:09:51.061    101,649 bytes   421,473 bytes   01:09:36.964
17              1:10:38.567     0:02:40.743     17,293 kbps     28,675 kbps     01:11:00.297    27,482 kbps     01:10:57.044    25,222 kbps     01:10:55.668    90,160 bytes    436,405 bytes   01:13:19.311
18              1:13:19.311     0:05:50.224     22,065 kbps     44,524 kbps     01:14:03.272    41,210 kbps     01:13:59.601    33,885 kbps     01:13:58.976    115,038 bytes   362,109 bytes   01:15:10.506
19              1:19:09.536     0:02:58.553     22,631 kbps     41,180 kbps     01:20:04.716    33,571 kbps     01:19:39.149    28,979 kbps     01:19:39.024    117,986 bytes   369,531 bytes   01:19:50.160
20              1:22:08.089     0:02:53.756     22,279 kbps     37,939 kbps     01:22:30.028    32,852 kbps     01:23:27.544    30,160 kbps     01:23:24.958    116,154 bytes   288,985 bytes   01:22:46.252
21              1:25:01.846     0:04:37.902     21,610 kbps     46,067 kbps     01:25:38.883    33,570 kbps     01:25:34.921    31,948 kbps     01:26:06.119    112,663 bytes   330,279 bytes   01:26:19.799
22              1:29:39.749     0:04:43.950     23,602 kbps     46,105 kbps     01:32:28.417    41,169 kbps     01:32:25.373    36,285 kbps     01:32:20.409    123,048 bytes   308,062 bytes   01:32:13.694
23              1:34:23.699     0:01:36.888     19,265 kbps     31,227 kbps     01:34:31.791    27,010 kbps     01:35:42.153    26,830 kbps     01:35:42.153    100,437 bytes   315,990 bytes   01:34:48.224
24              1:36:00.588     0:08:04.650     9,296 kbps      33,971 kbps     01:36:19.315    32,409 kbps     01:43:41.506    28,971 kbps     01:36:11.390    48,470 bytes    371,142 bytes   01:42:11.834
STREAM DIAGNOSTICS:
00074.M2TS      4113 (0x1011)   0x1B            AVC                                     6245.114                19,810                  15,464,227,673  84,131,805
00074.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6245.114                4,738                   3,698,573,992   21,074,096
00074.M2TS      4353 (0x1101)   0x81            AC3-EX          eng (English)           6245.114                448                     349,733,888     1,951,640
00074.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6245.114                448                     349,733,888     1,951,640
00074.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           6245.114                448                     349,733,888     1,951,640
00074.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        6245.114                448                     349,733,888     1,951,640
00074.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           6245.114                224                     174,866,944     975,820
00074.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           6245.114                224                     174,866,944     975,820
00074.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6245.114                38                      29,561,646      166,508
00074.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6245.114                35                      27,322,554      153,774
00074.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           6245.114                34                      26,718,870      151,125
00074.M2TS      4611 (0x1203)   0x90            PGS             kor (Korean)            6245.114                26                      20,007,974      113,979
00074.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           6245.114                38                      29,609,355      166,667
00074.M2TS      4613 (0x1205)   0x90            PGS             por (Portuguese)        6245.114                31                      23,897,451      134,422
00074.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            6245.114                1                       666,831         3,762
eric.exe is offline
post #1728 of 1971 Old 04-22-2009, 10:14 PM - Thread Starter
benes's Avatar
Quoted: 76 Post(s)
Liked: 26
Some review sites were claiming X-Men3 was a new encode. Wrong again.
benes is offline
post #1729 of 1971 Old 04-23-2009, 11:23 AM
Cinema Squid's Avatar
If someone has a copy of the original release laying around, it would be nice to see a 1-sec bitrate chart to compare against the new one... but, yeah judging from the video bitrate numbers themselves it seems that it is an identical encode.
Cinema Squid is offline
post #1730 of 1971 Old 04-23-2009, 01:34 PM
Phantom Stranger's Avatar
Quoted: 591 Post(s)
Liked: 606
The video bitrate for X-Men 2, the best one in the franchise, looks disappointing considering the wasted space on the disc. I wonder if extras were planned and then got dropped? Anyone want to post the numbers for Opium And The Kung-Fu Master? It would help on a forthcoming post for the PQ tier thread.
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #1731 of 1971 Old 04-23-2009, 01:56 PM
Phloyd's Avatar
I have the original.
I will try to get to it - not much spare time right now.
Phloyd is offline
post #1732 of 1971 Old 04-23-2009, 04:44 PM
PeterTHX's Avatar
Quoted: 568 Post(s)
Liked: 427
I was puzzled that Fox used X2 as a Blu-ray interactive demo with plenty of text, character & comic bios, none of which is on the disc.
No BDLive link to Movie Cash either, just the opportunity to buy your Wolverine ticket online and unlock a scene.
PeterTHX is offline
post #1733 of 1971 Old 04-25-2009, 10:06 AM
Xylon put the two X3 bitrate charts up in his new X-Men comparison picture thread:
https://www.avsforum.com/avs-vb/showthread.php?t=1142052
So, it's like "case closed"...
post #1734 of 1971 Old 04-26-2009, 10:34 AM
Phloyd's Avatar
It is weird that the bitrates are not exactly the same though.
Perhaps they dropped a frame or two at the start or the end...
Phloyd is offline
post #1735 of 1971 Old 04-26-2009, 11:01 AM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Or maybe they encoded opening or end credits with visually nothing in the scope image at lower bit rates.
Blu-ray : 340
lgans316 is offline
post #1736 of 1971 Old 04-26-2009, 12:49 PM
Phloyd's Avatar
I am running through a few older titles that I don't think have been posted with full 0.5.x details. Sorry if there are repeats...
The Queen
UPC: 786936736298
The Queen Blu-ray Screen Caps Here
Code:
        Total   Video
The Queen                                                       VC-1    1:43:22 21,162,989,568  24,748,361,222  27.30   19.79   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     94623009_THE_QUEEN
Disc Size:      24,748,361,222 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:43:22 (h:m:s)
Total Bitrate:          27.30 Mbps
Description:
VIDEO:
VC-1 Video              19792 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         39.773 kbps
Presentation Graphics           English         60.162 kbps
Presentation Graphics           English         58.478 kbps
Presentation Graphics           Spanish         38.094 kbps
Presentation Graphics           Spanish         0.849 kbps
FILES:
00009.M2TS      0:00:00.000     1:43:22.154     21,162,989,568  27,298
CHAPTERS:
1               0:00:00.000     0:05:12.478     16,415 kbps     48,794 kbps     00:00:52.677    38,743 kbps     00:00:52.510    35,101 kbps     00:03:51.898    86,750 bytes    366,177 bytes   00:02:45.039
2               0:05:12.478     0:05:07.515     18,330 kbps     42,610 kbps     00:05:22.447    33,203 kbps     00:05:21.988    30,167 kbps     00:05:32.206    95,565 bytes    346,416 bytes   00:05:42.175
3               0:10:19.994     0:06:18.461     16,897 kbps     37,201 kbps     00:10:25.416    35,917 kbps     00:10:21.412    30,237 kbps     00:10:19.994    88,776 bytes    339,403 bytes   00:10:26.417
4               0:16:38.455     0:08:23.419     19,951 kbps     44,608 kbps     00:17:15.117    34,857 kbps     00:24:14.786    32,015 kbps     00:21:12.062    104,014 bytes   396,613 bytes   00:20:39.112
5               0:25:01.875     0:07:04.382     23,139 kbps     56,990 kbps     00:25:56.096    38,856 kbps     00:25:45.877    34,378 kbps     00:27:22.557    120,635 bytes   558,136 bytes   00:25:56.137
6               0:32:06.257     0:06:09.077     20,190 kbps     42,633 kbps     00:33:23.543    36,835 kbps     00:33:22.750    34,975 kbps     00:33:22.667    105,260 bytes   354,453 bytes   00:34:35.865
7               0:38:15.334     0:04:33.731     20,770 kbps     39,453 kbps     00:39:23.361    30,228 kbps     00:39:23.361    28,117 kbps     00:38:23.801    108,287 bytes   360,520 bytes   00:42:02.645
8               0:42:49.066     0:07:10.054     19,841 kbps     52,861 kbps     00:46:21.361    36,698 kbps     00:46:01.759    34,064 kbps     00:46:01.759    103,443 bytes   494,635 bytes   00:46:21.403
9               0:49:59.121     0:08:23.461     24,310 kbps     50,267 kbps     00:50:18.390    37,910 kbps     00:50:26.857    36,424 kbps     00:50:26.857    126,739 bytes   390,284 bytes   00:56:38.520
10              0:58:22.582     0:05:04.387     19,014 kbps     49,494 kbps     00:59:50.753    38,422 kbps     00:59:31.484    34,033 kbps     00:59:31.484    99,130 bytes    407,673 bytes   01:01:34.399
11              1:03:26.969     0:09:29.193     20,397 kbps     47,124 kbps     01:07:26.834    38,084 kbps     01:04:16.602    36,557 kbps     01:04:16.686    106,341 bytes   342,203 bytes   01:12:15.497
12              1:12:56.163     0:05:18.443     18,586 kbps     47,017 kbps     01:13:38.705    33,068 kbps     01:13:56.515    31,756 kbps     01:13:48.757    96,897 bytes    408,483 bytes   01:16:49.229
13              1:18:14.606     0:09:20.685     21,436 kbps     49,788 kbps     01:19:39.900    38,961 kbps     01:19:39.149    36,602 kbps     01:19:57.793    111,756 bytes   432,761 bytes   01:22:18.850
14              1:27:35.291     0:03:20.783     24,366 kbps     54,237 kbps     01:30:24.335    38,961 kbps     01:30:21.624    36,499 kbps     01:27:59.607    127,034 bytes   508,241 bytes   01:30:24.377
15              1:30:56.075     0:06:12.080     20,154 kbps     41,561 kbps     01:31:21.601    35,679 kbps     01:31:20.308    33,003 kbps     01:31:21.058    105,076 bytes   354,873 bytes   01:34:53.938
16              1:37:08.155     0:06:11.996     11,007 kbps     48,067 kbps     01:43:18.192    35,243 kbps     01:37:45.317    33,302 kbps     01:37:41.564    57,413 bytes    381,987 bytes   01:37:49.363
17              1:43:20.152     0:00:02.001     247 kbps        326 kbps        01:43:20.277    0 kbps          00:00:00.000    0 kbps          00:00:00.000    2,211 bytes     10,257 bytes    01:43:20.319
STREAM DIAGNOSTICS:
00009.M2TS      4113 (0x1011)   0xEA            VC-1                                    6202.029                19,793                  15,344,292,749  83,482,636
00009.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           6202.029                4,614                   3,577,403,004   19,846,896
00009.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6202.029                640                     496,174,080     2,907,270
00009.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6202.029                192                     148,852,224     969,090
00009.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6202.029                192                     148,852,224     969,090
00009.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           6202.029                192                     148,852,224     969,090
00009.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6202.029                40                      30,834,901      176,327
00009.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6202.029                38                      29,532,796      169,100
00009.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6202.029                1                       658,064         3,816
00009.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           6202.029                58                      45,336,376      258,224
00009.M2TS      4612 (0x1204)   0x90            PGS             eng (English)           6202.029                60                      46,642,120      264,553
Phloyd is offline
post #1737 of 1971 Old 04-26-2009, 05:26 PM
Phloyd's Avatar
The Fifth Element (MPEG2)
UPC: 43396150188
The Fifth Element Blu-ray Screen Caps Here
Code:
        Total   Video
Fifth Element                                                   MPEG-2  2:05:54 23,273,226,240  24,483,629,994  24.65   17.55   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     FIFTH_ELEMENT
Disc Size:      24,483,629,994 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:05:54 (h:m:s)
Total Bitrate:          24.65 Mbps
Description:
VIDEO:
MPEG-2 Video            17550 kbps          1080p / 23.976 fps / 16:9
AUDIO:
SUBTITLES:
Presentation Graphics           English         45.571 kbps
Presentation Graphics           English         58.101 kbps
Presentation Graphics           English         58.033 kbps
Presentation Graphics           Chinese         34.710 kbps
Presentation Graphics           French          35.850 kbps
Presentation Graphics           Portuguese      43.335 kbps
Presentation Graphics           Spanish         45.480 kbps
Presentation Graphics           Thai            33.843 kbps
FILES:
00001.M2TS      0:00:00.000     2:05:54.547     23,273,226,240  24,646
CHAPTERS:
1               0:00:00.000     0:02:36.698     14,528 kbps     23,904 kbps     00:00:05.839    23,063 kbps     00:00:04.295    22,087 kbps     00:00:03.878    75,724 bytes    425,397 bytes   00:02:25.687
2               0:02:36.698     0:09:37.076     17,858 kbps     32,251 kbps     00:12:10.813    29,238 kbps     00:12:06.809    27,653 kbps     00:12:03.764    93,105 bytes    499,443 bytes   00:05:19.235
3               0:12:13.774     0:12:05.766     17,342 kbps     30,620 kbps     00:18:52.923    23,831 kbps     00:12:15.192    22,191 kbps     00:12:13.899    90,411 bytes    537,222 bytes   00:12:34.420
4               0:24:19.541     0:07:55.183     18,430 kbps     31,003 kbps     00:29:42.572    25,681 kbps     00:26:02.310    24,886 kbps     00:26:01.643    96,086 bytes    501,702 bytes   00:27:08.918
5               0:32:14.724     0:07:50.469     18,206 kbps     31,146 kbps     00:38:09.161    27,467 kbps     00:38:14.166    26,486 kbps     00:38:12.039    94,917 bytes    488,806 bytes   00:36:49.749
6               0:40:05.194     0:07:18.271     17,112 kbps     30,369 kbps     00:45:47.161    22,302 kbps     00:45:44.283    21,138 kbps     00:45:19.758    89,215 bytes    514,383 bytes   00:40:52.867
7               0:47:23.465     0:05:59.942     17,261 kbps     30,195 kbps     00:52:36.945    22,523 kbps     00:52:35.152    20,314 kbps     00:49:33.512    89,989 bytes    509,814 bytes   00:48:25.068
8               0:53:23.408     0:06:54.080     17,561 kbps     25,640 kbps     00:57:15.682    21,927 kbps     00:57:13.179    21,299 kbps     00:56:43.775    91,553 bytes    513,098 bytes   01:00:13.776
9               1:00:17.488     0:06:59.710     17,045 kbps     28,445 kbps     01:05:10.281    21,056 kbps     01:05:08.905    19,654 kbps     01:05:08.905    88,864 bytes    491,187 bytes   01:00:42.680
10              1:07:17.199     0:03:59.530     18,102 kbps     25,149 kbps     01:07:38.429    22,406 kbps     01:07:19.326    21,440 kbps     01:07:17.199    94,373 bytes    482,374 bytes   01:08:07.249
11              1:11:16.730     0:10:38.512     17,664 kbps     30,341 kbps     01:16:48.979    24,651 kbps     01:16:46.059    21,901 kbps     01:16:15.988    92,094 bytes    469,464 bytes   01:18:32.374
12              1:21:55.243     0:05:30.455     18,172 kbps     27,341 kbps     01:22:04.294    24,135 kbps     01:22:00.290    22,628 kbps     01:21:55.285    94,742 bytes    513,404 bytes   01:22:59.766
13              1:27:25.698     0:11:06.082     17,676 kbps     31,847 kbps     01:38:29.737    22,541 kbps     01:31:57.178    22,356 kbps     01:31:57.011    92,155 bytes    497,266 bytes   01:27:36.834
14              1:38:31.780     0:08:03.566     17,970 kbps     31,858 kbps     01:41:03.932    23,474 kbps     01:38:44.710    23,100 kbps     01:38:43.208    93,687 bytes    458,256 bytes   01:46:07.569
15              1:46:35.347     0:05:51.100     16,716 kbps     29,374 kbps     01:50:06.516    22,665 kbps     01:48:12.277    21,971 kbps     01:48:06.938    87,148 bytes    524,832 bytes   01:46:43.480
16              1:52:26.448     0:13:28.098     17,328 kbps     30,528 kbps     01:56:12.215    24,697 kbps     02:04:20.077    24,099 kbps     02:04:16.866    90,342 bytes    464,371 bytes   01:59:38.004
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x02            MPEG-2                                  7554.464                17,550                  16,572,949,953  90,175,743
00001.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           7554.464                448                     423,055,360     2,360,800
00001.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           7554.464                4,614                   4,357,464,440   24,174,560
00001.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            7554.464                448                     423,055,360     2,360,800
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7554.464                46                      43,033,819      243,126
00001.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7554.464                36                      33,853,537      191,879
00001.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           7554.464                45                      42,947,508      243,621
00001.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        7554.464                43                      40,922,330      230,016
00001.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           7554.464                35                      32,777,344      187,094
00001.M2TS      4613 (0x1205)   0x90            PGS             tha (Thai)              7554.464                34                      31,958,782      184,308
00001.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           7554.464                58                      54,801,896      309,079
00001.M2TS      4615 (0x1207)   0x90            PGS             eng (English)           7554.464                58                      54,865,960      300,575
Phloyd is offline
post #1738 of 1971 Old 04-26-2009, 05:29 PM
Phloyd's Avatar
A Bridge Too Far
UPC: 27616077028
A Bridge Too Far Blu-ray Screen Caps Here
Code:
        Total   Video
Bridge Too Far                                                  MPEG-2  2:56:12 41,603,131,392  43,066,763,448  31.48   24.78   DTS-HD Master 5.1 3835Kbps (48kHz/24-bit) DD AC3 5.0 448Kbps
Code:
DISC INFO:
Disc Title:     BRIDGE_TOO_FAR
Disc Size:      43,066,763,448 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:56:12 (h:m:s)
Total Bitrate:          31.48 Mbps
Description:
VIDEO:
MPEG-2 Video            24784 kbps          1080p / 23.976 fps / 16:9
AUDIO:
DTS-HD Master Audio             English         3835 kbps       5.1 / 48 kHz / 3835 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.0 / 48 kHz / 448 kbps
Dolby Digital Audio             Spanish         224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           English         29.153 kbps
Presentation Graphics           English         2.850 kbps
Presentation Graphics           Chinese         20.531 kbps
Presentation Graphics           French          3.399 kbps
Presentation Graphics           Korean          17.313 kbps
Presentation Graphics           Spanish         21.081 kbps
Presentation Graphics           Spanish         0.055 kbps
FILES:
00002.M2TS      0:00:00.000     2:56:12.186     41,603,131,392  31,481
CHAPTERS:
1               0:00:00.000     0:05:47.638     23,096 kbps     38,022 kbps     00:01:23.792    33,257 kbps     00:01:19.788    32,316 kbps     00:00:30.905    120,396 bytes   703,088 bytes   00:04:57.964
2               0:05:47.638     0:05:18.067     25,357 kbps     35,416 kbps     00:10:11.235    34,602 kbps     00:10:07.481    33,804 kbps     00:10:04.353    132,201 bytes   703,081 bytes   00:05:48.014
3               0:11:05.706     0:06:52.870     23,441 kbps     31,152 kbps     00:16:33.742    27,981 kbps     00:17:15.701    27,691 kbps     00:17:15.617    122,209 bytes   703,081 bytes   00:12:43.721
4               0:17:58.577     0:10:07.898     25,457 kbps     35,578 kbps     00:23:17.938    32,350 kbps     00:18:14.593    30,940 kbps     00:23:13.558    132,721 bytes   703,081 bytes   00:19:14.236
5               0:28:06.476     0:08:56.077     23,950 kbps     35,615 kbps     00:31:56.581    28,584 kbps     00:31:54.537    26,471 kbps     00:31:54.454    124,867 bytes   703,087 bytes   00:33:36.848
6               0:37:02.553     0:06:29.972     25,122 kbps     34,537 kbps     00:41:53.761    30,773 kbps     00:37:51.686    29,708 kbps     00:37:51.602    130,976 bytes   703,083 bytes   00:42:09.527
7               0:43:32.526     0:04:01.115     26,243 kbps     37,029 kbps     00:46:29.912    35,076 kbps     00:46:34.917    34,846 kbps     00:46:29.912    136,818 bytes   703,085 bytes   00:46:43.425
8               0:47:33.642     0:06:59.919     25,098 kbps     39,351 kbps     00:53:10.020    36,345 kbps     00:53:06.725    33,321 kbps     00:53:01.595    130,852 bytes   703,081 bytes   00:53:11.521
9               0:54:33.561     0:09:04.293     24,633 kbps     39,877 kbps     00:58:01.811    35,904 kbps     00:58:06.357    35,487 kbps     00:58:06.274    128,424 bytes   703,081 bytes   00:57:27.652
10              1:03:37.855     0:04:07.455     24,975 kbps     34,393 kbps     01:06:47.086    30,853 kbps     01:06:42.415    29,553 kbps     01:07:21.579    130,206 bytes   703,081 bytes   01:03:43.277
11              1:07:45.311     0:05:01.634     25,544 kbps     36,102 kbps     01:12:45.944    35,044 kbps     01:12:36.268    34,786 kbps     01:12:32.348    133,177 bytes   703,086 bytes   01:12:41.273
12              1:12:46.945     0:07:37.457     24,211 kbps     39,215 kbps     01:19:01.862    35,655 kbps     01:19:01.862    31,981 kbps     01:19:01.903    126,226 bytes   703,088 bytes   01:19:09.161
13              1:20:24.402     0:06:02.403     25,211 kbps     38,697 kbps     01:24:03.455    31,295 kbps     01:22:26.066    28,958 kbps     01:22:25.941    131,441 bytes   703,081 bytes   01:21:16.162
14              1:26:26.806     0:06:39.148     26,058 kbps     39,222 kbps     01:32:21.536    36,587 kbps     01:30:55.199    36,268 kbps     01:30:54.448    135,853 bytes   703,085 bytes   01:31:46.542
15              1:33:05.955     0:09:49.755     24,906 kbps     40,180 kbps     01:37:29.969    35,565 kbps     01:37:34.598    33,246 kbps     01:37:29.468    129,847 bytes   703,083 bytes   01:42:55.586
16              1:42:55.711     0:05:38.254     24,846 kbps     35,136 kbps     01:47:12.467    30,935 kbps     01:48:21.411    30,194 kbps     01:48:20.785    129,537 bytes   703,081 bytes   01:42:56.378
17              1:48:33.965     0:04:22.053     24,938 kbps     38,063 kbps     01:49:59.009    30,547 kbps     01:50:48.558    28,911 kbps     01:49:52.627    130,015 bytes   688,381 bytes   01:49:00.367
18              1:52:56.019     0:04:03.826     26,122 kbps     40,223 kbps     01:53:01.024    34,803 kbps     01:52:57.020    31,226 kbps     01:52:56.311    136,190 bytes   703,081 bytes   01:53:30.094
19              1:56:59.846     0:05:45.136     24,643 kbps     34,194 kbps     02:01:12.723    28,804 kbps     02:01:17.061    28,044 kbps     02:01:12.014    128,478 bytes   703,081 bytes   01:58:07.622
20              2:02:44.982     0:04:14.671     23,606 kbps     37,726 kbps     02:06:26.912    33,039 kbps     02:06:23.951    28,107 kbps     02:06:18.946    123,069 bytes   684,356 bytes   02:05:37.571
21              2:06:59.653     0:08:58.204     25,718 kbps     41,443 kbps     02:12:14.009    38,279 kbps     02:12:11.298    35,609 kbps     02:12:09.630    134,080 bytes   703,081 bytes   02:10:59.142
22              2:15:57.858     0:03:52.065     25,506 kbps     35,624 kbps     02:18:26.256    32,246 kbps     02:16:57.959    30,583 kbps     02:16:56.333    132,976 bytes   667,916 bytes   02:18:24.587
23              2:19:49.923     0:09:26.482     24,717 kbps     40,674 kbps     02:25:15.248    36,104 kbps     02:28:20.808    35,475 kbps     02:28:14.677    128,862 bytes   703,088 bytes   02:20:54.654
24              2:29:16.405     0:04:33.064     21,762 kbps     39,927 kbps     02:32:11.831    35,699 kbps     02:32:20.631    35,413 kbps     02:32:11.831    113,457 bytes   703,082 bytes   02:31:15.566
25              2:33:49.470     0:03:53.524     27,851 kbps     39,851 kbps     02:37:12.881    35,935 kbps     02:37:08.877    35,466 kbps     02:36:29.129    145,204 bytes   703,085 bytes   02:35:20.561
26              2:37:42.995     0:02:56.843     22,800 kbps     39,275 kbps     02:40:20.569    35,900 kbps     02:40:17.608    35,313 kbps     02:40:18.734    118,870 bytes   703,081 bytes   02:38:41.011
27              2:40:39.838     0:05:42.091     24,404 kbps     32,564 kbps     02:43:46.274    29,818 kbps     02:43:23.376    29,733 kbps     02:43:18.455    127,230 bytes   680,812 bytes   02:41:31.807
28              2:46:21.930     0:09:50.256     24,158 kbps     39,938 kbps     02:56:01.384    33,530 kbps     02:50:52.242    32,530 kbps     02:50:50.615    125,960 bytes   703,082 bytes   02:56:02.885
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x02            MPEG-2                                  10572.103               24,784                  32,752,369,378  178,149,681
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           10572.103               3,835                   5,067,540,608   29,192,964
00002.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            10572.103               448                     592,042,752     3,303,810
00002.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           10572.103               224                     296,021,376     1,651,905
00002.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           10572.103               448                     592,042,752     3,303,810
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           10572.103               29                      38,526,145      221,432
00002.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           10572.103               21                      27,859,674      162,283
00002.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           10572.103               0                       72,835          416
00002.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            10572.103               3                       4,491,820       25,811
00002.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            10572.103               17                      22,880,003      136,091
00002.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           10572.103               21                      27,132,730      158,839
00002.M2TS      4614 (0x1206)   0x90            PGS             eng (English)           10572.103               3                       3,766,513       21,722
Phloyd is offline
post #1739 of 1971 Old 04-26-2009, 05:34 PM
Phloyd's Avatar
Kill Bill: Vol. 2
UPC: 786936767148
Kill Bill: Vol. 2 Blu-ray Screen Caps Here
Code:
        Total   Video
Kill Bill Vol 2                                                 AVC     2:16:57 38,506,377,216  42,944,677,214  37.49   27.26   LPCM 5.1 6912Kbps (48kHz/24-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     KILLBILL2_US
Disc Size:      42,944,677,214 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:16:57 (h:m:s)
Total Bitrate:          37.49 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        27261 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         6912 kbps       5.1 / 48 kHz / 6912 kbps / 24-bit
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         19.518 kbps
Presentation Graphics           English         1.497 kbps
Presentation Graphics           Chinese         11.185 kbps
Presentation Graphics           French          1.381 kbps
Presentation Graphics           Japanese        14.602 kbps
Presentation Graphics           Korean          12.116 kbps
Presentation Graphics           Spanish         16.812 kbps
FILES:
00001.M2TS      0:00:00.000     2:16:57.834     38,506,377,216  37,486
CHAPTERS:
1               0:00:00.000     0:02:01.121     18,698 kbps     44,520 kbps     00:00:02.669    36,585 kbps     00:01:39.682    34,800 kbps     00:01:35.303    97,450 bytes    564,156 bytes   00:00:36.036
2               0:02:01.121     0:03:27.290     30,679 kbps     41,481 kbps     00:04:58.631    37,141 kbps     00:04:18.841    35,624 kbps     00:04:39.153    159,948 bytes   623,831 bytes   00:02:13.049
3               0:05:28.411     0:09:22.478     28,822 kbps     42,852 kbps     00:14:42.882    37,302 kbps     00:11:54.422    35,677 kbps     00:12:42.052    150,266 bytes   810,567 bytes   00:14:50.890
4               0:14:50.889     0:03:17.530     24,668 kbps     38,114 kbps     00:14:58.272    36,066 kbps     00:14:56.770    34,312 kbps     00:14:52.766    128,606 bytes   770,825 bytes   00:14:54.810
5               0:18:08.420     0:04:44.492     32,467 kbps     42,198 kbps     00:20:54.544    37,730 kbps     00:22:16.418    35,734 kbps     00:20:03.535    169,270 bytes   708,127 bytes   00:21:38.797
6               0:22:52.913     0:08:02.690     26,409 kbps     46,667 kbps     00:23:22.484    37,914 kbps     00:26:00.141    35,145 kbps     00:29:08.329    137,685 bytes   642,321 bytes   00:27:20.847
7               0:30:55.603     0:08:18.581     17,594 kbps     52,836 kbps     00:35:50.022    37,933 kbps     00:35:39.637    35,465 kbps     00:35:34.257    91,726 bytes    590,505 bytes   00:33:55.366
8               0:39:14.185     0:18:19.598     32,231 kbps     44,905 kbps     00:56:33.473    37,960 kbps     00:55:50.847    35,873 kbps     00:55:20.775    168,036 bytes   645,859 bytes   00:57:33.783
9               0:57:33.783     0:05:33.124     31,031 kbps     47,355 kbps     00:59:06.668    37,891 kbps     00:59:19.264    35,611 kbps     00:59:19.264    161,780 bytes   669,328 bytes   01:02:34.792
10              1:03:06.908     0:11:35.152     30,692 kbps     55,474 kbps     01:09:38.757    37,867 kbps     01:14:18.203    35,579 kbps     01:13:39.456    160,012 bytes   808,846 bytes   01:09:38.799
11              1:14:42.060     0:06:31.891     31,562 kbps     52,600 kbps     01:17:16.465    38,057 kbps     01:19:52.454    35,562 kbps     01:20:13.558    164,552 bytes   745,327 bytes   01:21:09.155
12              1:21:13.952     0:06:34.394     32,450 kbps     44,286 kbps     01:22:53.843    38,074 kbps     01:21:55.994    35,642 kbps     01:22:49.464    169,178 bytes   777,581 bytes   01:21:39.185
13              1:27:48.346     0:04:26.808     24,444 kbps     42,941 kbps     01:28:51.117    31,323 kbps     01:30:21.082    30,221 kbps     01:31:19.432    127,440 bytes   655,365 bytes   01:28:51.159
14              1:32:15.154     0:07:52.889     25,797 kbps     40,855 kbps     01:36:25.863    36,352 kbps     01:36:21.859    35,423 kbps     01:36:19.523    134,492 bytes   542,163 bytes   01:36:35.206
15              1:40:08.043     0:09:27.942     26,519 kbps     52,626 kbps     01:42:03.534    37,561 kbps     01:42:13.794    33,524 kbps     01:41:00.429    138,257 bytes   587,185 bytes   01:41:00.471
16              1:49:35.985     0:05:36.586     23,002 kbps     41,600 kbps     01:50:59.736    34,020 kbps     01:50:58.401    30,326 kbps     01:54:38.329    119,922 bytes   504,351 bytes   01:54:45.295
17              1:55:12.572     0:06:56.332     20,950 kbps     46,276 kbps     01:58:28.684    37,128 kbps     01:58:25.848    34,320 kbps     01:58:23.805    109,221 bytes   497,975 bytes   01:55:16.409
18              2:02:08.904     0:01:54.280     27,517 kbps     38,565 kbps     02:03:48.170    36,901 kbps     02:03:46.335    35,798 kbps     02:03:42.331    143,459 bytes   549,885 bytes   02:02:25.379
19              2:04:03.185     0:12:53.647     23,128 kbps     54,954 kbps     02:05:13.714    38,010 kbps     02:05:10.002    35,712 kbps     02:05:12.796    120,581 bytes   757,945 bytes   02:06:08.352
20              2:16:56.833     0:00:01.001     107 kbps        0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    582 bytes       932 bytes       02:16:57.000
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     8217.710                27,262                  28,003,650,615  152,308,817
00001.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           8217.710                6,919                   7,106,783,708   39,445,608
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           8217.710                640                     657,428,480     3,852,120
00001.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            8217.710                640                     657,428,480     3,852,120
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8217.710                20                      20,049,925      120,496
00001.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           8217.710                17                      17,269,354      103,616
00001.M2TS      4610 (0x1202)   0x90            PGS             jpn (Japanese)          8217.710                15                      14,999,306      90,790
00001.M2TS      4611 (0x1203)   0x90            PGS             kor (Korean)            8217.710                12                      12,446,158      77,386
00001.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           8217.710                11                      11,489,715      71,896
00001.M2TS      4613 (0x1205)   0x90            PGS             eng (English)           8217.710                1                       1,537,405       9,023
00001.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            8217.710                1                       1,418,819       8,533
Phloyd is offline
post #1740 of 1971 Old 04-26-2009, 06:26 PM
Phloyd's Avatar
This one has been posted with 4.1 (most likely) - does anyone see value in reposting 5.x BDInfo when 4.x or earlier is posted?
Did 5.x add new useful data (aside from the version tag)?
Do we care at all either way?
Kill Bill: Vol. 2
UPC: 786936767148
Code:
        Total   Video
Code:
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Description:
VIDEO:
AUDIO:
SUBTITLES:
FILES:
CHAPTERS:
STREAM DIAGNOSTICS:
Phloyd is offline
Closed Thread Blu-ray Software
