Blu-ray HD movie screenshot thread... - Page 105 - AVS Forum | Home Theater Discussions And Reviews
post #3121 of 4060 Old 07-05-2011, 01:49 AM
Dark_zero's Avatar
Few from Conan The Destroyer
Dark_zero is offline
post #3122 of 4060 Old 07-05-2011, 02:48 AM
Dark_zero's Avatar
Few pics from Born on the 4th July
post #3123 of 4060 Old 07-05-2011, 01:19 PM
Giger's Avatar
12 screenshots from TrollHunter.
Giger is offline
post #3124 of 4060 Old 07-05-2011, 01:37 PM
Gamereviewgod's Avatar
Liked: 24
Gamereviewgod is offline
post #3125 of 4060 Old 07-06-2011, 07:46 AM
Liked: 24
post #3126 of 4060 Old 07-06-2011, 08:11 AM
Dark_zero's Avatar
Screenshoots from [IT] Lord of the rings Extended
The Fellowship of the ring BD1
The Fellowship of the ring BD2
post #3127 of 4060 Old 07-06-2011, 10:14 AM
Giger's Avatar
12 screenshots from Arthur 3: The War of the Two Worlds.
Originally Posted by dark_zero View Post
Not to nitpick, but the levels appear to be off on these captures. The letterbox bars are extremely bright, for one...
Giger is offline
post #3128 of 4060 Old 07-06-2011, 11:00 PM
Dark_zero's Avatar
im just using media player home cinema with nothing changed! is there something to check?
thanks indeed
i've also made some comparision with the ones posted on blubrew.com and seems pretty the same!
post #3129 of 4060 Old 07-07-2011, 07:55 AM
Liked: 24
post #3130 of 4060 Old 07-08-2011, 06:26 AM
Giger's Avatar
thanks indeed
I'm not really an expert on these things, but the letterbox bars should be RGB: 0 0 0, yours are RGB: 17 17 17.
Here's a quick image with the "correct" level as a subtitle:
Giger is offline
post #3131 of 4060 Old 07-08-2011, 07:25 AM
Dark_zero's Avatar
ehe you're talking chinese with me
do you know how can i fix that with the software? Strange to me that there isnt any software who can make raw pics without processing them...
Thanks a lot anyway
post #3132 of 4060 Old 07-08-2011, 10:22 AM
msgohan's Avatar
MPC doesn't generally process the pics; the issue is probably with a setting in your graphics card drivers or the renderer being used in MPC. Check the Output: DirectShow Video tab in MPC's options to see what renderer you're using first off.
Personally I use ffdshow + AviSynth and capture in VirtualDubMod, avoiding graphics card processing and conversions. You do have to manually specify the correct RGB conversion matrix, and make sure ffdshow's own processing is turned off.
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #3133 of 4060 Old 07-08-2011, 11:29 PM
Dark_zero's Avatar
check and here the screenshoot:
post #3134 of 4060 Old 07-08-2011, 11:53 PM
msgohan's Avatar
Trying using one of the EVR options. Mine is set to EVR Sync.
msgohan is offline
post #3135 of 4060 Old 07-09-2011, 05:21 AM
Dark_zero's Avatar
oki did as you wrote and here the result:
With new setting:
with old setting:
mmm seems pretty the same to me, or am i wrong?
post #3136 of 4060 Old 07-09-2011, 07:30 AM
Liked: 24
post #3137 of 4060 Old 07-09-2011, 02:38 PM
msgohan's Avatar
Not wrong, I also said graphics card settings. What's your graphics card and how do you have it set in the drivers?
msgohan is offline
post #3138 of 4060 Old 07-10-2011, 01:28 AM
Dark_zero's Avatar
old nvidia 8600gt with not the latest drivers...is there any specific option to check? There arent many anyway
Thanks a lot!
post #3139 of 4060 Old 07-10-2011, 06:34 AM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Thanks a lot!
Look for an option to change output levels from 16-235 to 0-255.
paku is offline
post #3140 of 4060 Old 07-10-2011, 09:45 AM
Dark_zero's Avatar
bingo!
did as you told me and here the result:
yep different from the other, is it ok now?
(of course DNR is still DNR )
thanks folks
EDIT:
thanks a lot msgohan!
post #3141 of 4060 Old 07-10-2011, 02:45 PM
msgohan's Avatar
Appears to be good. If you want to be sure the levels are correct, download AVS HD 709. If you grab the MP4 version, "2-APL Clipping.mp4" in the Basic Settings folder is a good video showing both white and black.
The "16" bar should be RGB 0 and "235" should be RGB 255 for our purposes.
msgohan is offline
post #3142 of 4060 Old 07-10-2011, 03:01 PM
Giger's Avatar
12 screenshots from Norwegian Wood.
Giger is offline
post #3143 of 4060 Old 07-10-2011, 09:17 PM
Cinema Squid's Avatar
35 screen captures from Network (1976) [Warner - US Region ABC]
Cinema Squid is offline
post #3144 of 4060 Old 07-12-2011, 03:19 PM
Liked: 24
post #3145 of 4060 Old 07-13-2011, 07:09 AM
Liked: 24
post #3146 of 4060 Old 07-15-2011, 03:44 PM
Liked: 24
Anyone try uploading the past few days? Can't get anything through. The uploads fail.
post #3147 of 4060 Old 07-16-2011, 07:04 AM
Liked: 24
post #3148 of 4060 Old 07-16-2011, 07:07 AM
Liked: 24
post #3149 of 4060 Old 07-16-2011, 08:00 PM
35 screen captures from A.I. Artificial Intelligence (2001) [Paramount / DreamWorks - US Region A]
post #3150 of 4060 Old 07-17-2011, 07:08 AM
Liked: 24
Reply Blu-ray Software
Blu Ray Movies
