New Firmware 4.0 HD-XA2/HD-XF2/HD-A20 - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #601 of 609 Old 12-14-2019, 03:38 PM
GoGadget's Avatar
Originally Posted by latreche34 View Post
Anyone still has the file to the latest firmware for HD-XA2 ?
Try this.
GoGadget is offline
post #602 of 609 Old 12-14-2019, 03:51 PM
Rambler358's Avatar
Quoted: 112 Post(s)
Liked: 38
My HD-XA2 finally died with the disc slot no longer wanting to open. Is this an issue that’s easily fixable?
Rambler358 is offline
post #603 of 609 Old 12-19-2019, 09:38 AM
latreche34's Avatar
Quoted: 151 Post(s)
Liked: 66
You need a service manual and a voltmeter to check all voltages coming out the power supply.
latreche34 is offline
post #604 of 609 Old 12-19-2019, 11:45 AM
Rambler358's Avatar
Quoted: 112 Post(s)
Liked: 38
Yeah, I didn’t think it was going to be an easy fix. Oh well, I got really good use out of it while it was working, so I guess it’s time I give it a proper burial.
Anyone interested in a bunch of HD-DVDs on the cheap?
post #605 of 609 Old 12-19-2019, 12:01 PM
snowghost's Avatar
Quoted: 27 Post(s)
My player died as well, but I have the A35 that still works. Problem is Laser Rot on most of the HDs. Really irks me.
"The best long distance runners eat raw meat, run naked and sleep in the snow."
snowghost is offline
post #606 of 609 Old 12-19-2019, 11:42 PM
Worf's Avatar
Quoted: 874 Post(s)
Liked: 601
Well, it depends. If it's a drive problem, it might be easy to fix - usually a belt may be bad that keeps the. To or from working properly.
If it's a logic board problem, which it can be since the eject function is a software controlled one, then it can be much harder to diagnose.
There's an emergency eject hole under the tray that can be used to pop the tray out so you can see if the problem is the drive or motherboard.
Worf is offline
post #607 of 609 Old 12-20-2019, 09:10 AM
Rambler358's Avatar
Quoted: 112 Post(s)
Liked: 38
Thanks guys. I opened it up and couldn’t see any reasons why the door wouldn’t open. I’m just going to trash it. It served me well for many years though.
latreche34 likes this.
post #608 of 609 Old 12-21-2019, 10:11 PM
Super Moderator
teachsac's Avatar
Quoted: 1315 Post(s)
Liked: 2147
No sales outside of the classifieds. Posts removed/edited.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #609 of 609 Old 01-02-2020, 07:26 AM
exm
exm's Avatar
Quoted: 265 Post(s)
Liked: 126
There's plenty of used HD DVD players on eBay for cheap.
exm is offline
Reply HD DVD Players
