New Firmware 4.0 HD-XA2/HD-XF2/HD-A20 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #61 of 619 Old 09-24-2008, 10:44 AM
viper37's Avatar
I can download the file, but I just can't open it. I tried with Powerdesk, WinZip, 7zip and WinRAR but none can open the file. It's size is reported at 7mb, is that ok? Are there any alternative links for download?
viper37 is offline
post #62 of 619 Old 09-24-2008, 10:52 AM
allargon's Avatar
Quoted: 316 Post(s)
Liked: 267
Re-download it. My first download stopped at 7.1 MB. I knew the zip file was supposed to be 39.1MB. Your download is incomplete.
allargon is offline
post #63 of 619 Old 09-24-2008, 11:02 AM
livingproof73's Avatar
Originally Posted by Scubawoman View Post
Toshiba indicated to me when I called them about it that it was something on the motherboard that needed replacing. Some people got new motherboards (refurbished units). I got a new unit to replace the one I had that had the shutdown. I believe all the units Toshiba sent back whether refurbished or new had firmware 2.5. (at least the 2 new ones I received did). To my knowledge the shutdown bug doesn't have anything to do with firmware. You should call Toshiba to see if they have any newer information. My info. is from Jan 08.
Yeah, I called Toshiba of Canada and they had no clue to what I was talking about
livingproof73 is offline
post #64 of 619 Old 09-24-2008, 11:43 AM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 86 Post(s)
Liked: 56
The A30 update is only 7.0MB in size - that's the filesize reported by the website, and that is the size of file I get after downloading twice. The older A30 FW updates are 38MB or so.
The XA2 and A2 file sizes are 39.9 and 39.1 MB in size, respectively. Perhaps the A30 file is corrupted on the Toshiba server.
shinksma
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
post #65 of 619 Old 09-24-2008, 11:46 AM
allargon's Avatar
Quoted: 316 Post(s)
Liked: 267
shinksma
My bad... I thought you had a second gen player.
Jaggies are gone on my HD-A20. To those who actually wondered I took some (mostly bad) photos of the opening Transformers menu where the Autobot's hand is circling the around scenes from the movie. The hand has aliasing artifacts (jaggies) on the edges. I circled the still visible ones in red.
http://i101.photobucket.com/albums/m...es_1080p24.png
Anyone know what if anything this update does for an A2?
allargon is offline
post #66 of 619 Old 09-24-2008, 12:19 PM
akadennis's Avatar
Quoted: 594 Post(s)
Liked: 238
anyone try this update with the A35? and can you confirm jaggies are gone with 1080/24p with the
A35 thanks
LG OLED77C9 / LG OLED65C9 / LG UP970 / Oppo UDP-203 / Sony HT-Z9F+SA-Z9R / Apple TV 4K / Fire TV Stick 4K / TCL 55P605
akadennis is online now
post #67 of 619 Old 09-24-2008, 12:39 PM
slimm's Avatar
A35 thanks
The website download of the 4.0 firmware for the A35 is corrupt, so until Toshiba either updates the file on their website or places the file on their servers for download via the player, nobody can know. I've sent an email to Toshiba support so hopefully this will be resolved soon.
slimm is offline
post #68 of 619 Old 09-24-2008, 01:48 PM
jumpy27's Avatar
I successfully downloaded firmware 4.0, but forgot the proper procedure for burning it to a disc. Can someone give me a link to the instructions? I don't want to damage my XA2. Thanks.
jumpy27 is offline
post #69 of 619 Old 09-24-2008, 02:06 PM
sharkcohen's Avatar
Liked: 25
Originally Posted by jumpy27 View Post
I have successfully downloaded firmware 4.0, but have forgotten the proper procedure for burning it to a disc. Can someone give me a link to the instructions? I don't want to damage my XA2. Thanks.
You unzip the download to extract the iso, and burn the iso to disk as a disk image.
sharkcohen is offline
post #70 of 619 Old 09-24-2008, 02:47 PM
crussell1492's Avatar
Hi-
So I dont have jaggies on my XA2 with 1080/24 display cause I rolled back to 2.7
I guess if I go to 4.0 I wont have jaggies..goodness
but what's the benefit of 4.0 then if auto frame detect does not work? Has anyone see any tangible benefits?
thanks
crussell1492 is offline
post #71 of 619 Old 09-24-2008, 03:23 PM
jumpy27's Avatar
Do I use a CD or DVD?
jumpy27 is offline
post #72 of 619 Old 09-24-2008, 03:31 PM
ti-triodes's Avatar
Quoted: 587 Post(s)
Liked: 1401
do i use a cd or dvd?
cd
ti-triodes is offline
post #73 of 619 Old 09-24-2008, 03:53 PM
sharkcohen's Avatar
Liked: 25
Originally Posted by crussell1492 View Post
Hi-
thanks
I think there were some issues fixed in 3.0 that, if you need those fixes and you want to output 1080p24 exclusively, you would want 4.0. If you have a display that correctly deinterlaces film based content, you could just output 1080i for everything, like I do.
post #74 of 619 Old 09-24-2008, 03:59 PM
Geoff D's Avatar
Quoted: 353 Post(s)
Liked: 378
Finally, those damned AVC jaggies appear to be gone.
Geoff D is offline
post #75 of 619 Old 09-24-2008, 04:18 PM
arty100's Avatar
Is this the correct name of this ISO file?
AX4000N_S-USER-HDXA2_TN.iso
I am having trouble getting it to disc.
Can someone pls confirm?
arty100 is offline
post #76 of 619 Old 09-24-2008, 04:34 PM
sharkcohen's Avatar
Liked: 25
That is the correct file for the XA2.
post #77 of 619 Old 09-24-2008, 05:54 PM
Electone's Avatar
Oddly, when I put the update disc in my A3, it shows both "VERUP" on the front panel and asks if I want to update on the tv screen. But, when I put the disc in my SHD7000, it only shows "VERUP" on the front panel and the tv screen goes blank. I think I'll wait on this update for now...
Electone is offline
post #78 of 619 Old 09-24-2008, 07:12 PM
PRO-630HD's Avatar
Quoted: 321 Post(s)
Liked: 207
Anyone having any luck downloading this through the ethernet port?
PRO-630HD is offline
post #79 of 619 Old 09-24-2008, 08:55 PM
jamjas's Avatar
HD-A1 here. I couldn't update through the ethernet, but I had absolutely no problems burning it to a cd and updating with it.
jamjas is offline
post #80 of 619 Old 09-24-2008, 10:55 PM
Trackman's Avatar
Quoted: 116 Post(s)
Liked: 106
Originally Posted by dfchang View Post
Do you have problems with audio drop outs as well then?
I believe this is a very specific problem that has to do with Toshiba players not synching up correctly with Pioneer receivers particularly.
The only other guy I know who has these annoying dropouts is Trackman.
Once again it is pretty specific because you have to be playing a HD-DVD disc on a Toshiba player connected to a Pioneer receiver and you must be playing a Dolby Digital Plus track. Most of us go for TrueHD or some other lossless codec if there's a choice and many don't have Pioneer AVRs. Also not all HD-DVDs have the problem. For instance, 300, Bourne Ultimatum, Robin Hood, Batman Begins all output Dolby Digital Plus from my XA2 to my Pioneer fine.
So it would be pretty hard to catch . . . but it does happen.
And NO, I installed 4.0 and it does nothing. But I wouldn't expect it to since it is something to do with the receiver I think.
Dennis
When I first encountered this and posted on the Pio 01 and 1018 threads, I quickly received a response that DD+ skipping was a known Tosh issue, discussed in the A30 and 35 thread. A quick search revealed that is only on certain discs and that it also affects Onkyo AVRs.
Go Duke !
Trackman is offline
post #81 of 619 Old 09-24-2008, 11:39 PM
bsoko2's Avatar
Quoted: 80 Post(s)
Liked: 80
Firmware 4.0 certainly made the XA2 faster as far as fast forwarding through the scenes. It was quite surprising at just how much faster it is now than my Panny BD30 BluRay player. It is nice that Tosh is still supporting the HDDVD players. I think that they really got a raw deal in all of this and were light years ahead of BluRay format.
Bill
bsoko2 is offline
post #82 of 619 Old 09-25-2008, 12:31 AM
gurkey's Avatar
Quoted: 290 Post(s)
Liked: 188
There is some specific info inside the file header which might prevent an OEM update if not matched to the model.
I You got an older firmware file of Your model, try to check / compare it with a hex editor.
I did the same already for a XE1 model.
gurkey is online now
post #83 of 619 Old 09-25-2008, 12:36 AM
gurkey's Avatar
Quoted: 290 Post(s)
Liked: 188
I remember reading, that this could only be fixed by a board exchange due to some part ...
Not a firmware issue...
Originally Posted by livingproof73 View Post
Can anyone confirm if 4.0 fixed the 1080p shutdown bug??
post #84 of 619 Old 09-25-2008, 01:21 AM
Sirluckyj's Avatar
Did it successfully update?
Yes, all seems to be working OK. It shows 4.0 in Setup.
Jim
Sirluckyj is offline
post #85 of 619 Old 09-25-2008, 05:40 AM
Pitou's Avatar
Just upgraded my XA2 to 4.0, jaggies gone for me as well.
Wonderful!!
Pitou!
Pitou is offline
post #86 of 619 Old 09-25-2008, 05:56 AM
shabre's Avatar
Updated to 4.0 and the one thing I noticed is in that when skipping to next/previous chapter, there is no more audio delay. Great job Tosh.
shabre is offline
post #87 of 619 Old 09-25-2008, 06:04 AM
shabre's Avatar
Also, no more messing with the "digital direct audio mode" every time you put a disc in.
And, I also agree with the above observation in that the FF frame is much quicker.
shabre is offline
post #88 of 619 Old 09-25-2008, 06:30 AM
akadennis's Avatar
Quoted: 594 Post(s)
Liked: 238
Has this been fixed yet?
post #89 of 619 Old 09-25-2008, 06:57 AM
DCunited's Avatar
Tried burning 4.0 for my a2 but the image file is not buring, Unziped and burned and no luck.
DCunited is offline
post #90 of 619 Old 09-25-2008, 08:35 AM
nicholc2's Avatar
I still can't get update for A2 or A30 (internet or CD). Anyone know why?
nicholc2 is offline
Reply HD DVD Players
