AC Power Cable Cord for Toshiba HD-A3KU - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-07-2019, 05:43 PM - Thread Starter
Liked: 0
Question AC Power Cable Cord for Toshiba HD-A3KU
I have this DVD player without the power cord but I have one that will fit in back of this player. This power cord is label KS-15w 7A 125v will this cable work? If not which one will work for this model? I have more cord with different amps and Volts. Thanks!
SamPuzo is offline
post #2 of 5 Old 12-08-2019, 02:12 AM
Worf's Avatar
Quoted: 872 Post(s)
Liked: 600
Should work just fine as long as the voltage is what your local voltage is (I.e, North America with 120V system). It's wrong if you're in Asia or Europe (except say Japan or Taiwan).
Power cables are basically interchangeable as long as they're suitable for the local power system.
Worf is offline
post #3 of 5 Old 12-08-2019, 06:21 AM
markmon1's Avatar
Quoted: 5687 Post(s)
Liked: 3745
That unit looks like it is just raw AC in and has the power supply in the unit, not an external power supply. So any cable that will fit it will work.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #4 of 5 Old 12-08-2019, 07:20 PM - Thread Starter
Liked: 0
Yes I'm in the USA thanks!
SamPuzo is offline
post #5 of 5 Old 12-08-2019, 07:21 PM - Thread Starter
Liked: 0
Ok Thanks!
SamPuzo is offline
Reply HD DVD Players
toshiba hd-a3ku
