hd ep10 issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-23-2020, 07:18 PM - Thread Starter
Liked: 0
hd ep10 issues
So set up my Toshiba hdep10 after a couple of years of being packed away(moved house etc.) and I have come across two issues.
1- First movie I popped in was "shooter" and the black bars top and bottom are shaking. its the weirdest thing ive seen. I popped in king kong and its perfect no black bar issues what so ever. Any ideas?
2- I hooked up the 'ep10 through my Yamaha rxv1085 avr via hdmi which then outputs to my tv but Im not getting any audio? I tried direct to my tv from ep10 with hdmi and same issue. So I range optical from 'ep10 to amp and voila it works. any ideas there folks?
thanks for any help or info provided
Marcus ling is offline
post #2 of 2 Old 04-08-2020, 08:30 PM
kcgr's Avatar
Quoted: 94 Post(s)
Liked: 93
not sure about #1 , but on #2 , I didn't get video thru a Denon.
Though you have audio issues, here is what addressed the video issue: Set the Deep Color setting on the TV to OFF .... or .... If the Yanny has a second HDMI monitor output, connect a second HDMI cable to another input on the TV and set Deep Color on that input to OFF while using the primary input for all other video sources.
That may or may not help .... That's all I got.
kcgr is offline
Reply HD DVD Players
