OFFICIAL Toshiba firmware update thread: 2.0 and or CD is here! - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #901 of 3262 Old 08-23-2006, 08:46 AM
William's Avatar
Quoted: 82 Post(s)
Liked: 69
Originally Posted by dvdjan View Post
YES 5.1 TrueHD
Any other features of note:
DTS-HD Master
1080p 24/48/60Hz support
Triple layer support (no way to tell I guess)
Deferent or more detailed menu tree
DVD-A and/or SA-CD (not likely)
Cure for cancer
William is offline
post #902 of 3262 Old 08-23-2006, 08:46 AM
jmpage2's Avatar
Quoted: 714 Post(s)
Liked: 511
Originally Posted by Fettastic View Post
The stupid black crush issue via DVI is STILL THERE? That was the single biggest issue with 1.4, I can't believe they haven't fixed this!
Remember that they have priorities. Apparently added features are more important than bug fixes for users that probably make up 5% of the user base. The one big bug they needed to stop was the strange buffering/synch/freezup playback problems which have caused a lot of people grief.
jmpage2 is offline
post #903 of 3262 Old 08-23-2006, 08:47 AM
Q of BanditZ's Avatar
DTS-HD Master
Cure for cancer
How about: End of glitches. End of hiccups. End of "bad layer change" like effects and varying drop outs?
Great ISF Job by Chad B.
Q of BanditZ is offline
post #904 of 3262 Old 08-23-2006, 08:49 AM
Fettastic's Avatar
Well, there's always next update. Until then no TruHD for me because I'm not going to cripple my PQ. I feel bad for all the people who "upgraded" to 1.4 without a 1.2 disc and are stuck with a screwed up picture yet again.
Fettastic is offline
post #905 of 3262 Old 08-23-2006, 08:49 AM
Symtex's Avatar
Quoted: 120 Post(s)
Liked: 91
End of bad users that refuse to return their player to Toshiba ? My player has none of thoses problems. you should send your player back to toshiba.
Symtex is offline
post #906 of 3262 Old 08-23-2006, 08:49 AM
craysv1's Avatar
does anyone know if the player will decode the TruHD5.1 to DTS over the Optical connection?
I have a Harmon Kardon AVR340.... I've never used the analog connections. If I use the multi-channel inputs, does anyone know if I can apply PL][-x or Neo-6 or Logic7 to virtualize the rear surrounds? What about using the HK auto-setup with MIC for the analog connections... does that work?
craysv1 is offline
post #907 of 3262 Old 08-23-2006, 08:49 AM
Originally Posted by Symtex View Post
End of bad players that use refuse to return to Toshiba ? My players are none of thoses symptop. you should send your player back to toshiba.
Keep telling yourself that and maybe it'll come true. Just because YOU don't have any problems doesn't mean PLENTY of other people don't have issues.
Next?
post #908 of 3262 Old 08-23-2006, 08:52 AM
cnickersonjr's Avatar
Location: Missouri City, Texas (Next door to SUGARLAND)
Originally Posted by ahro View Post
No, my receiver is more than 3 years old and doesn't have analog inputs. Any recommendationa on an inexpensive receiver? I don't want to spend more than I paid for the Tosh! I can live with DTS.
I like the Onkyo brand receivers. This one is 7.1 no HDMI though http://www.circuitcity.com/ssm/Onkyo...oductDetail.do
cnickersonjr is offline
post #909 of 3262 Old 08-23-2006, 08:53 AM
jmpage2's Avatar
Quoted: 714 Post(s)
Liked: 511
My player shipped with 1.4 so I don't have much of an option here either.
jmpage2 is offline
post #910 of 3262 Old 08-23-2006, 08:53 AM
Originally Posted by dylanneild View Post
... This is about the only thing I can check right away (obviously seeing if the ridiculous skipping issues are gone will take a few movie plays)
post #911 of 3262 Old 08-23-2006, 08:53 AM
dvdjan's Avatar
Not the best pictures, mobile phone camera
dvdjan is offline
post #912 of 3262 Old 08-23-2006, 08:53 AM
jediod's Avatar
Next?
Q-
Mine have never had those problems either...with any firmware I've flashed. I'm not saying you dont have those problems or that they dont exist. But I have personally never had a glitch ( I may have just jinxed myself). But maybe the other poster is right...you should return your player and try another. There alot of others here that dont have those problems that you have described.
Kevin
jediod is offline
post #913 of 3262 Old 08-23-2006, 08:54 AM
I really will never understand people like that... "I'm not having problems" (or more likely, "I am but don't know what I'm looking for"), so logically, "the problem is with your specific unit, send it back".
As if most of us haven't been through the gauntlet with Toshiba support over this already.
Exactly.
Some people have issues, others do not.
I'm certainly not going to exchange my player for some refurb from Toshiba if I don't absolutely have to.
In fact, I won't do that at all. It will either be a new unit or it's gone.
Being told in broken English on some forum certainly isn't going to fix the OBVIOUS issues that we see in various threads even on a very pro HD-DVD forum like this one.
So some people don't have problems. Good for them!
This firmware has to end it.
post #914 of 3262 Old 08-23-2006, 08:55 AM
Here's a cheap one also http://www.circuitcity.com/ssm/Onkyo...oductDetail.do
post #915 of 3262 Old 08-23-2006, 08:56 AM
Check Harman Kardon as well.
post #916 of 3262 Old 08-23-2006, 08:56 AM
dpippel's Avatar
Quoted: 325 Post(s)
Liked: 450
5%? I'd be willing to bet there's a larger number of early adopters than that with DVI only on their HD displays.
Flipping a couple of bits is all it would take to correct the HDMI->DVI issue. It's not like it's been there all along - Toshiba broke it in v1.4. If they're going to release firmware that's been labeled with a new whole number revision then it should be comprehensive.
That being said, I'm not gonna get all bent out of shape until the official firmware release has been confirmed and the black crush problem has also been confirmed as still being there. THEN I'll get pissed.
______________
LG OLED65E6P | Yamaha RX-A2080 | Oppo UDP-203 | Panasonic DP-UB820
My Media Collection
dpippel is offline
post #917 of 3262 Old 08-23-2006, 08:58 AM
jorgerod's Avatar
Same issue with COnstantine and Perfect Storm. I normally hear audio on my receiver at -38 and I have to bring it up to -31 for the TrueHD.
It sounds incredible even if it sounds lower.
Jorge
Audio Enthusiast, HD Videophile.
jorgerod is offline
post #918 of 3262 Old 08-23-2006, 08:59 AM
ResOGlas's Avatar
What exactly is black crush?
ResOGlas is offline
post #919 of 3262 Old 08-23-2006, 09:01 AM
dpippel's Avatar
Quoted: 325 Post(s)
Liked: 450
Incorrect black level reproduction results in the loss (or crushing) of shadow detail.
______________
My Media Collection
dpippel is offline
post #920 of 3262 Old 08-23-2006, 09:03 AM
dpippel's Avatar
Quoted: 325 Post(s)
Liked: 450
I'm assuming that SACD is a no-go as well at this point.
The HD-A1 will never be able to play SACD - it lacks the hardware to do so.
______________
My Media Collection
dpippel is offline
post #921 of 3262 Old 08-23-2006, 09:08 AM
ahro's Avatar
Quoted: 2033 Post(s)
Liked: 4130
Thanks all for the receiver suggestions!
korsjs likes this.
HENRY
78HU9000, 10 BIT, TS-01; NEW 3500 OCB, WD PASSPORT HDD
ONKYO TX-NR646 ATMOS RECEIVER
ISCAN MINI, UHD 30 PACK. SAMSUNG BJ7500 BLU RAY PLAYER
USB 3.0 4 PORT HOT SWITCHABLE HUB, ROKU 4,SAMSUNG K-8500 BRP
ahro is offline
post #922 of 3262 Old 08-23-2006, 09:08 AM
ryoohki's Avatar
crap i'am at work right now, just hope the link won't be taken out as i arrive at home crap crap..
89+ Blu-ray Disc ;)
ryoohki is offline
post #923 of 3262 Old 08-23-2006, 09:09 AM
dpippel's Avatar
Quoted: 325 Post(s)
Liked: 450
I think that's just speculation that hasn't been proven. The SHARC DSP's in the HD-A1 do seem to support DSD decoding....
I agree it's likely it'll never play SACD given that SACD is a Sony format.... but I don't think it's for lack of hardware.
Has this been documented? I don't think that it's possible. It seems to me that until someone verifies that the HD-A1 has the hardware necessary to decode DSD then its potential ability to play SACD is what would be termed "speculation". As of right now it does NOT support SACD, with absolutely 100% certainty.
______________
My Media Collection
dpippel is offline
post #924 of 3262 Old 08-23-2006, 09:09 AM
dago2727's Avatar
The sequel to Blue Crush of course
dago2727 is offline
post #925 of 3262 Old 08-23-2006, 09:12 AM
ResOGlas's Avatar
Oh nos!!!
ResOGlas is offline
post #926 of 3262 Old 08-23-2006, 09:16 AM
debyrd's Avatar
With True HD enabled do we still have control over individual speaker volume and distance?
My sub output is already cranked all the way up in the Tosh menu compared to the other speakers.
I can deal with a couple db reduced gain overall but need that ability to tweak my surrounds. Using 5.1 analog inputs on my Pioneer receiver disables everything except the volume control on that unit.
debyrd is offline
post #927 of 3262 Old 08-23-2006, 09:18 AM
ResOGlas's Avatar
Do the RCA players still have the RCA bootup logo or do they now say Toshiba?
ResOGlas is offline
post #928 of 3262 Old 08-23-2006, 09:20 AM
Symtex's Avatar
Quoted: 120 Post(s)
Liked: 91
Exactly.
I have 3 HDVD : The Rundown, Training Day and Swordfish. I have never seen a layer change, skipping, audio sync issue that I have been reported in the AVS forums. Im certain there is some issue with the Toshiba HD-A1, like any electronic device but the facts that you refuse to have you player replace is making me curious.
If it is so OBVIOUS, I would at least notice either of theses problem once. Which I didn't. I don't negate there is player that has the problem, my point of view is maybe something went wrong in 1 of your firmware upgrade or the manufacturing date of your player is different from mine.
Symtex is offline
post #929 of 3262 Old 08-23-2006, 09:21 AM
rwestley's Avatar
Quoted: 495 Post(s)
Liked: 320
Did you guys burn the image as a DVD or CD? What program did you use?
Solved problem. I am upgrading now.
rwestley is online now
post #930 of 3262 Old 08-23-2006, 09:21 AM
ryoohki's Avatar
Is it possible to burn it on a DVD-R? I got like 300+ DVD-R at home but 0 CDR LOL (last 2 were FW1.2 and FW1.3 disc...
89+ Blu-ray Disc ;)
ryoohki is offline
Reply HD DVD Players
