TEST RESULTS ON UPSCALING: XA2 vs. SDI+Crystallio 2 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 291 Old 01-07-2007, 06:10 PM
TheLion's Avatar
Liked: 30
Thank you for all your efforts, lorelevitt!
Please tell us about the "Edge Enhancement" feature! Despite the dreadful labeling I assume it is in fact HQV's quite decent "detail enhancement" filter - therefor it's use should be without exessive and horrible ringing/halo artifacts. Would you mind taking a look?
TheLion is offline
post #32 of 291 Old 01-07-2007, 06:17 PM
TomHuffman's Avatar
Quoted: 993 Post(s)
Liked: 834
Actually, I agreed with Lore on the second jaggies test. I thought that the xa2 performed a little better--not a lot, but perceptible.
On the Detail test, I thought that the CII did look better--sharper and more clearly defined. Also, on the Film Detail test (the racetrack) the CII locked on quicker than the xa2.
The noise eduction test was one area in which I thought that the xa2 was clearly superior. This confirmed our earlier tests with various video processors. The HQV algorithms are exceptional in their ability to reduce noise without reducing detail.
With SD program material I preferred the xa2. It's hard to explain but the image was smooth yet very detailed, with exceptional color saturation and depth. The objective tests suggested that this was due the the Reon's superior noise reduction, but I suspect there was something else going on as well.
The HD DVD material was stunning, though I could not evaluate this because I was not familiar with what HD DVD looked like on Lore's display with the A1.
I hadn't planned on buying this unit, but this experience has caused me to reevaluate.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #33 of 291 Old 01-07-2007, 06:19 PM
goldielox's Avatar
The reason the Toshiba is so much more expensive is that it is a high-def DVD player, not because it was designed to upconvert SD discs better than any other DVD player.
That's exactly what everyone is raving about. It uses the same chip (Silicon Optix) for upconverting SD DVDs that many higher priced/ high performance players use.
goldielox is offline
post #34 of 291 Old 01-07-2007, 06:20 PM
boxwes's Avatar
The Oppo 970 outclassed ALL DVD players, many costing MANY hundreds of dollars more. Unless you actually have seen the image of the 980, I wouldn't just dismiss it out of hand. The reason the Toshiba is so much more expensive is that it is a high-def DVD player, not because it was designed to upconvert SD discs better than any other DVD player.
The Crystalio II Video Processor he used for upconversion is a $5k piece of equipment. The Oppo can't touch it.
boxwes is offline
post #35 of 291 Old 01-07-2007, 06:27 PM
tsd2005's Avatar
The XA2 is amazing just as I originally reported. It's easily the best player visually on the market. We compared it with Meridian units and it was superior.
That says a lot.
tsd2005 is offline
post #36 of 291 Old 01-07-2007, 06:30 PM
JMCecil's Avatar
Quoted: 318 Post(s)
Liked: 332
No one questions that this is an HD DVD player. It just turns out to be an unexpected bonus is that is a first class upscaling DVD player.
Since I was hoping for something that would do a passable job at just that task, so that I could replace my existing player instead of having to add yet another box to the rack, this is awesome news.
JMCecil is offline
post #37 of 291 Old 01-07-2007, 06:32 PM
JMCecil's Avatar
Quoted: 318 Post(s)
Liked: 332
To bad I still have to solve the upscaling problem for D* and OTA SD. I'm not real hopeful about the capability of the 70XBR2 in that area.
JMCecil is offline
post #38 of 291 Old 01-07-2007, 06:57 PM
KramerTC's Avatar
Quoted: 105 Post(s)
Liked: 73
When upscaling std DVDs... does the XA2 give the flexibility of moving the sub-titles inside the viewing area? This feature would be great for 2.35:1 screens in a constant image height set up.
KramerTC is offline
post #39 of 291 Old 01-07-2007, 06:59 PM
dschuman's Avatar
So, a $1k piece of equipment beat out a $5k piece, yet you out of hand dismiss the Oppo? Would I be correct in assuming that you have not seen the Oppo HD-980 in action as yet?
dschuman is offline
post #40 of 291 Old 01-07-2007, 07:10 PM - Thread Starter
lorelevitt's Avatar
You know there was never any reason to turn on the edge enhancement because the natural image was so sharp both for DVD's and HD-DVD's. But I'll take a look at it tomorrow evening and report back. I generally like to do these qualitative tests with a second pair of impartial eyes so that it just isn't "my" opinion alone.
lorelevitt is offline
post #41 of 291 Old 01-07-2007, 07:26 PM
HiFiGuy1's Avatar
Quoted: 104 Post(s)
Liked: 57
Lore and Tom,
Thank you for the insightful review! I am going to order an HD-XA2 tomorrow. I was already happy with my HD-XA1 but this thing sounds fantastic! I concur with your idea about someone releasing a Reon VX processor. It would be great, as noted, for DirecTV and other stuff.
Philip Springer, owner -- Apex AV Systems, Inc.
THX and ISF certified systems integration specialist
WWW:ApexAVS.com
Twitter:@ApexAVSystems
Instagram:apexavsystems
HiFiGuy1 is offline
post #42 of 291 Old 01-07-2007, 07:29 PM
Murilo's Avatar
Quoted: 272 Post(s)
Liked: 62
How much of a difference is the xa2 to the xa1, could I visibly notice a difference without running tests?
Murilo is offline
post #43 of 291 Old 01-07-2007, 07:31 PM
WirelessGuru's Avatar
Jeez...what is with all the Oppo freaks around here. It is a great upconverting DVD player for sure, but it is not in the same league as the XA2 or the Crystallio II. Why doesn't one of you 980 owners offer to lend it to the OP so he can test it? I assure you it score one point lower in almost every category.
Last Watched 3D: Oz the Great and Powerful
It should be called Violet-Ray
WirelessGuru is offline
post #44 of 291 Old 01-07-2007, 07:31 PM
John Ballentine's Avatar
Quoted: 96 Post(s)
Liked: 97
You've sold me. Looks like I'll be buying an HD-XA2 mainly for use as an upscaling SD player (I was considering the $1,500. Denon 3930) and for use secondly ...as an HD-DVD player.
John Ballentine is offline
post #45 of 291 Old 01-07-2007, 07:36 PM
azmodien's Avatar
Yes, has anyone compared the gen1 units yet? The SD playback on my A1 is bafflingly good.
I don't know how they do it.
azmodien is offline
post #46 of 291 Old 01-07-2007, 07:37 PM
HPforMe's Avatar
There would be a significant difference because the A1 doesn't have the ReonVX processor.
HPforMe is offline
post #47 of 291 Old 01-07-2007, 07:40 PM
rto
rto's Avatar
Great work, lorelevitt; and thanks! This erases any lingering misgivings I had about having returned an XA1 for a pre-order on the XA2. I hope you'll follow up with your impressions of the on-board video enhancements; particularly on less than stellar transfers.
rto is offline
post #48 of 291 Old 01-07-2007, 07:44 PM - Thread Starter
lorelevitt's Avatar
It would be useful if anyone has any suggestions of scenes from SD DVD's I should look at with the XA2. Hopefully I'll have a copy of that DVD in my collection.
post #49 of 291 Old 01-07-2007, 07:51 PM
Robert George's Avatar
Location: Trapped in time. Surrounded by evil. Low on gas.
Please tell us about the "Edge Enhancement" feature! Despite the dreadful labeling I assume it is in fact HQV's quite decent "detail enhancement" filter - therefor it's use should be without excessive and horrible ringing/halo artifacts. Would you mind taking a look?
I have been testing using various settings, including the "Edge Enhancement" feature. You are right, the name Toshiba chose for this is terrible, especially around this forum, but fortunately, what this feature does is anything but terrible. This appears to be a detail enhancement tool that actually enhances detail without inducing any visible ringing. I have my player set with this setting at "1" (selections are off, 1, 2) and block noise reduction on. SD DVD looks the best I have ever seen. Perhaps even as good as what the Anthem D-2 does with SD DVD.
Robert George is offline
post #50 of 291 Old 01-07-2007, 08:07 PM
Sean_O's Avatar
*drools*
Sean_O is offline
post #51 of 291 Old 01-07-2007, 08:07 PM
gordong11's Avatar
I do not think so....In LOTR, the subtitles are at the bottom of the viewing area, can't move them, and no zoom on SD DVD.
It's all about 1080P/24 & HD audio
Toshiba HD-XA2
Panasonic DMP-BD30K
Sony KDL-40XBR4
Elite VSX-92TXH (w/7.1)
gordong11 is offline
post #52 of 291 Old 01-07-2007, 08:12 PM
ILJG's Avatar
I'm sure when you get the firmware that enables 1080p24 on the XA2, you'll compare that to the Crystallio II taking 1080i60 (say, from an A1 or A2) and outputting it at 1080p24 as well?
Won't you?
Excellent writeup, thanks for sharing your test results.
Still looking for a movie theatre that shows movies the way they're SUPPOSED to be viewed...
...with a bitrate meter and screencaps.
ILJG is offline
post #53 of 291 Old 01-07-2007, 08:16 PM
c722's Avatar
well, I'm not that surprised. The HQV test disk is, well, designed to show off HQV algos. (ok granted most of them are quite objective). So a HQV player ought to pass all of them. Do u also have the DVDO test disc ? The HQV doesn't do too well there. The real life performance therefore will be much different. And for that, unfortunately there will never be a "benchmark" for it. (for the record I have some material the HQV performs very poorly, whereas an ordinary dvdp/PJ performs better)
..although I certainly agree the video processor nowadays is getting harder to sell once you see HQV/VXP chips going mainstream. 8 yrs ago the 1st Faroudja equipped dvdp sells for $800, today it's like $100. Will we see $200 HQV players ? When that happens VPs better sell for <1k.
c722 is offline
post #54 of 291 Old 01-07-2007, 08:21 PM
IndianaGeorge's Avatar
Quoted: 18 Post(s)
How about comparing the A2/XA2 to a MCE 2005 HTPC using NVidia Purevideo decoder?
IndianaGeorge is offline
post #55 of 291 Old 01-07-2007, 08:39 PM
Murilo's Avatar
Quoted: 272 Post(s)
Liked: 62
I dont know how significant it could possibly be to the human eye, yes as someone said running an hqv test of course the hqv equipment will yeild great results. This is like ati when using my htpc, does great on hqv tests but real time real world situations, I dont find it to be as great even though when i did the test ati beat purevideo in hqv tests, real time i didnt see it the same.
I know pictures dont tell the entire story, but if someone can post non doctored comparison shots i would like to see how dramtic of difference it is to the human eye with real material.
Murilo is offline
post #56 of 291 Old 01-07-2007, 09:22 PM
Sam S's Avatar
Quoted: 320 Post(s)
Liked: 133
Lorelevitt, thanks for posting your comparisions.
I do have one critical question: How does the XA2 handle the colorspace conversion of SD DVDs? Does it transform Rec.601 SD colorspace to HD Rec.709 spec?
Sam S is offline
post #57 of 291 Old 01-07-2007, 09:48 PM
HPforMe's Avatar
It's true eyeballing is going to have to be the final test. Comparative pics are also important. But I trust the OP's judgment here.
HPforMe is offline
post #58 of 291 Old 01-07-2007, 10:00 PM
boxwes's Avatar
I have not seen the 980, but have a 970HD that was my primary player before I bought my A1. Oppo makes a mighty fine player, especially for the price. But, I do not pretend that they compete with the ultra high end video processors, nor are they intended to.
boxwes is offline
post #59 of 291 Old 01-08-2007, 03:50 AM
TomHuffman's Avatar
Quoted: 993 Post(s)
Liked: 834
This is just silly.
First, it is misleading at best to suggest that these are two entirely different test discs. They share many of the same tests in common.
Second, the VP50 does as well or better than HQV processors on the HQV test disc on every test, except the noise reduction test. This is not surprising since the VP50 doesn't have noise reduction.
Note: The HQV discs may reveal some minor differences between DVDO processors and Realta-based processors on some of the weird cadences, which is of little consequence to the overwhelming majority of users. However, Gennum processors do just as well here.
Tom Huffman
Springfield, MO
post #60 of 291 Old 01-08-2007, 03:59 AM
madshi's Avatar
Quoted: 2339 Post(s)
Liked: 3042
Originally Posted by TomHuffman View Post
This is just silly.
I don't disagree with you. However, it should be noted that the HQV test disc surely doesn't contain any sequences which could put any HQV processor into bad light. HQV would be stupid to release such a disc. So an independent disc could possibly show some shortcomings of HQV processors which Gennum processors might not have. I'm NOT saying that this will actually be the case. I'm just saying that it's no surprise that a HQV processor never totally slips with a HQV test disc.
madshi is online now
Reply HD DVD Players
