A2 / XA2 1.2 , 1.3, and 1.5 ISO available for download - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 312 Old 02-02-2007, 08:45 PM
WestCDA's Avatar
Quoted: 68 Post(s)
Liked: 79
Thanks for posting the ISO. I upgraded to 1.2 tonight using Nero Express to burn to a TDK CD-R at 8X - which AFAIR cost about 20 cents way back when I bought them. Tried Sonic first, and it made a coaster about half way through the burn (with both discs, it's still below postage costs for the stamp on the upgrade card!).
A2 recognized the Nero disc immediately, and it took less than 10 minutes to completion and disc eject (I confess I was pouring another glass of wine at the time it finished).
I just checked and Toshiba Canada is still only showing an A1 upgrade available on http://www.toshibahddvd.ca/. Ironic, as the hosted ISO is from Toshiba Canada.
Good group of people here. I had no pressing need for the update, but do like to keep my equipment up to date.
Cheers!
WestCDA is offline
post #32 of 312 Old 02-02-2007, 08:49 PM
dlhoppe's Avatar
Worked like a charm! Thanks guys!
dlhoppe is offline
post #33 of 312 Old 02-02-2007, 08:58 PM
sharkshark's Avatar
Quoted: 23 Post(s)
I forgot to mention, just for fun the first thing I did post-upate was to connect the unit to the server, for the first time seeing the now accurate "there are no futher updates available" message... catharsis, to be sure...
let's hope that the XA2 forthcoming upgrade goes significantly better than this one....
sharkshark is offline
post #34 of 312 Old 02-02-2007, 09:11 PM
WadeSc's Avatar
Thanks a lot for making this available. I upgraded tonight without problem. I have a DVI HDTV, so I verified that I now get 1080i to my TV. Black levels are still not where they should be when up-converting SD DVDs. I still cannot see the drop shadow behind the THX logo. Not sure how to test this for HD DVDs though.
WadeSc is offline
post #35 of 312 Old 02-02-2007, 10:13 PM
Bill Broderick's Avatar
Quoted: 18 Post(s)
Thank you to everyone who had a hand in making the firmware available to us. It worked perfectly my machine and now I can go back to using the HDMI -> DVI connection again.
Bill Broderick is offline
post #36 of 312 Old 02-02-2007, 11:09 PM
333
333's Avatar
Thanks AESO and squidboy, worked for me! I used Nero and Verbatim CD-Rs.
333 is offline
post #37 of 312 Old 02-03-2007, 12:42 AM
mattalgrand's Avatar
Worked without a hitch. Kinda surprising. Thanks!
More content (COUGH) does not equal better content.
Better movies (COUGH) equal better content.
Awesome PQ/AQ are just bonuses.
mattalgrand is offline
post #38 of 312 Old 02-03-2007, 07:07 AM
f300v10's Avatar
Have any Linux users been able to burn this ISO? K3b says the iso is not valid, and wont burn it.
f300v10 is offline
post #39 of 312 Old 02-03-2007, 07:59 AM - Thread Starter
squidboy's Avatar
I know my way around Linux, but I've never actually burned an ISO using it. Maybe this can help?
http://www.yolinux.com/TUTORIALS/Lin...ialCDBurn.html
Specifically:
Burn ISO image onto CD:
* Linux 2.6 kernel: cdrecord -v -eject speed=16 dev=ATA:1,0,0 RedHat-7.0-i386-powertools.iso
* Linux 2.4 kernel: cdrecord -v speed=2 dev=0,4,0 RedHat-7.0-i386-powertools.iso
squidboy is offline
post #40 of 312 Old 02-03-2007, 08:07 AM
f300v10's Avatar
Thanks squidboy. I actually used cdrecord on the command line to burn the image just 20 minutes ago. I have yet to try it in the player, but will report back when I do.
For the record, here was the command that worked on my system:
cdrecord -v -pad speed=4 dev=/dev/hdc A2_1.2_unofficial.iso
f300v10 is offline
post #41 of 312 Old 02-03-2007, 08:37 AM
slimm's Avatar
Originally Posted by jellow View Post
Burned the ISO with Mac OS X, updated A2 with no problems. The A2 is now at 1.2/T19M.
Thank you to squidboy for hosting the file and the helpful instructions.
I was able to update my HD-A2 via the internet connection. After update, my firmware is listed as 1.2/T17M. Is the difference due to this being a Canadian release? I thought the Canadian and US versions of the HD-A2 were the same.
slimm is offline
post #42 of 312 Old 02-03-2007, 09:28 AM
pchin2's Avatar
Great work squidboy & AESO! Also ADBNZ for his summary instruction. Thanks so much guys! Now I'm one of the happy bunnies.
Enjoying High Definition Movies in Lossless Audio! Awesome Xperience!
pchin2 is offline
post #43 of 312 Old 02-03-2007, 10:30 AM
MN-Rabbit's Avatar
Quoted: 17 Post(s)
Liked: 29
Bunnies, Rabbits.... we are all happy! Thanks a lot guys! Really appreciate your hosting it and the great directions. I burned it at 40x with no problems.
MN-Rabbit is offline
post #44 of 312 Old 02-03-2007, 10:31 AM
Mjara's Avatar
That worked. Thanks for hosting the ISO.
Mjara is offline
post #45 of 312 Old 02-03-2007, 11:35 AM
GmanAVS's Avatar
shouldn't this thread be sticky for a while (or merged into the main fw upgrade one)?
GmanAVS is offline
post #46 of 312 Old 02-03-2007, 11:55 AM
f300v10's Avatar
I am happy to report that my HD-A2 had no problems with the upgrade as well. Much thanks to squidboy and the folks hosting the files. Now I don't need to cut a 60 ft. run of cat 5. :-)
f300v10 is offline
post #47 of 312 Old 02-03-2007, 01:29 PM
rack04's Avatar
Quoted: 13 Post(s)
So has anyone noticed any differences with this Canada FW version vs the US release?
rack04 is offline
post #48 of 312 Old 02-03-2007, 02:20 PM
APaulDev's Avatar
Thanks for all the work. I had the message "already upgraded" when I tried to upgrade from the Net. Followed the instructions to burn the disk, using XP to burn the image file. Worked just fine. This site has been great for information on the A2. Keep it coming!!
APaulDev is offline
post #49 of 312 Old 02-03-2007, 02:22 PM
APaulDev's Avatar
Thanks for all the work. I had the message "already upgraded" when I tried to upgrade from the Net. Followed the instructions to burn the disk, using XP to burn the image file. Loaded and worked just fine.
APaulDev is offline
post #50 of 312 Old 02-03-2007, 06:01 PM
Scottwdw's Avatar
Ditto for me! Thanks for hosting!
Scottwdw is offline
post #51 of 312 Old 02-03-2007, 06:08 PM
ADBNZ's Avatar
I've made a page with instructions and firmware downloads for the A1 and A2 here. As new firmware comes out (XA2 etc.) I will add those too.
Adam
ADBNZ is offline
post #52 of 312 Old 02-03-2007, 07:14 PM
clifburns's Avatar
Thanks, ADBNZ and squidboy. It worked without a hitch.
clifburns is offline
post #53 of 312 Old 02-03-2007, 07:34 PM
Deja-vue's Avatar
Quoted: 51 Post(s)
Liked: 33
Does anyone know what kind of improvement or fixes this update contains?
Deja-vue is offline
post #54 of 312 Old 02-04-2007, 01:42 AM
GVLBob's Avatar
ADBNZ did a nice job of summarizing the improvements. The link to that document is in his post #51.
GVLBob is offline
post #55 of 312 Old 02-04-2007, 10:15 AM
k.berger's Avatar
Hi guys,
Updated Firmware for Toshiba's HD-A2/HD-XA2 is now available for download form www.1080x1920.net (free registration required).
They have also quite few other interesting things there, like Manuals, HD Test Files, FREE CD Disk Image Burning Utilities and such!
Kris
k.berger is offline
post #56 of 312 Old 02-04-2007, 10:19 AM
dlhoppe's Avatar
Originally Posted by k.berger View Post
Hi guys,
Kris
I was curious about the Xa2 update. I didn't think it was released yet. I looked on the web site mentioned and didn't see either the HD-A2 or the HD-XA2.
dlhoppe is offline
post #57 of 312 Old 02-04-2007, 10:20 AM
dlhoppe's Avatar
Oh, I see they labled it incorrectly. It's labeled as HD-A1/HD-XA1. In fact it's only for the HD-A2.
Edited: Also for the Walmart and RCA variants of the A2.
dlhoppe is offline
post #58 of 312 Old 02-04-2007, 01:54 PM
jacksonian's Avatar
Will this work with a DVD+R? I'm out of CD-R's.
jacksonian is offline
post #59 of 312 Old 02-04-2007, 04:40 PM
k.berger's Avatar
I should work with any recordable CD, theoretically even with rewritable (CD+/-RW). Rewritables aren't recommended though, what with their lower compatibility level (comparing to write-once media), and higher write/read error rate.
Kris
k.berger is offline
post #60 of 312 Old 02-04-2007, 05:27 PM - Thread Starter
squidboy's Avatar
Probably won't work with any type of DVD recordable. It's a CD image. I believe someone also tried it and it didn't work with their system.
squidboy is offline
Reply HD DVD Players
