Official Toshiba HD DVD Firmware ISO Downloads Here! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 238 Old 06-03-2007, 11:33 AM
angelo913's Avatar
Originally Posted by wittangamo View Post
I had the same error. The player is having a hard time reading the CD.
Got past it by trying different burning software and burning at a slower speed. Nero 7 at 8x didn't work. ISO Recorder at 2x did. Go figure.
ISO Recorder
The quality of the Burner and CD/DVDs will effect readability. I always burn 2 or 3 steps down from max rating of CD/DVD media.
...Angelo
2x HD-XA2 firmware 3.0
1x HD-A1 firmware 3.0
HD DVD movies: 141
angelo913 is offline
post #32 of 238 Old 06-03-2007, 12:12 PM
rwestley's Avatar
Quoted: 404 Post(s)
Liked: 243
It seems tht the Toshiba disk creator will only work with certain Toshiba notbooks. Use "Burn at Once" it will work every time. I like it much better than Nero for burning ISO files. It is free and you should not get any costers. Use a slow burning speed.
rwestley is offline
post #33 of 238 Old 06-03-2007, 12:24 PM
angelo913's Avatar
^^^ I double-click ISO files and Nero would start-up and burn correctly. I'm currently using Nero v7.5.9. Also have Finalize-Disk selected too.
What problems have you run into?
...Angelo
HD DVD movies: 141
post #34 of 238 Old 06-03-2007, 12:49 PM
MarcoAD's Avatar
If anyone needs an official update disk just PM me, I have no problems passing it on.
XBOX 360 Elite(GT: BigBadPolo)
40gb PS3 (PSN: BigBadPolo)
Wii
MarcoAD is offline
post #35 of 238 Old 06-03-2007, 02:12 PM
JUSTIN MELHADO's Avatar
I have made 3 copies of the ISO files on CD-r disks and still keep getting an error 2007... message. After screwing around with it for about an hour last night and never successfully updating it just had to give up before I smashed it into a million pieces with a hammer. I wish they would come out with a player that just works, all the money that I have thrown away on this toshiba garbage is making me sick. I would have gladly spent the 2000.00 that I have waisted already looking for a player that doesn't need firm ware updates for every new release that comes out on just one player that works all the time. Any way after trying over and over last night my player finally just locked up and wouldn't respond to anything and I had to pull the plug to turn it off because holding the power button down didn't work either. Then when I gave up and put a movie in the screen went black and it would not respond again. Finally after a couple more tries I got it to play a movie which was surprising because it was a Universal title and it played through ok this time? I have tried NERO and BURNATONCE and they both didnt work?
JUSTIN MELHADO is offline
post #36 of 238 Old 06-03-2007, 04:52 PM
wittangamo's Avatar
I feel your pain. It is frustrating. But, as has been said before, it's simply a matter of getting an ISO burn that's clean enough for the player to read error-free. Sometimes it's the brand or type of disc you're using. sometimes the software, sometimes the burn speed.
The lockup you report is typical following the error message. You just have to unplug the player and start over.
The official Toshiba firmware disc will work first time, every time. But if you don't feel like waiting weeks for it to arrive, you need patience.
If burning your own ISO doesn't work, maybe it would be easier to move the player to the PC and update over the net.
wittangamo is offline
post #37 of 238 Old 06-03-2007, 04:53 PM
lcubed's Avatar
Quoted: 39 Post(s)
go to the apple store w/ a cd-r, download the ISO,
then open w/ apple disk utility (in the utilities folder),
then hit 'burn'. (pop in a blank cd-r when prompted).
thank apple staff, go home, update toshiba hd-dvd player
works everytime!! 8^}
lcubed is offline
post #38 of 238 Old 06-04-2007, 01:56 PM
Kosty's Avatar
thanks.
I have a few friends without broadband connections. They are happy now.
"A lot of good arguments are spoiled by some fool who knows what he is talking about." - Miguel de Unamuno
follow me on Twitter
Kosty is offline
post #39 of 238 Old 06-04-2007, 02:02 PM
hawkeye3.1's Avatar
I hope they are not G1 owners, because those downloads seem to have been removed.
hawkeye3.1 is offline
post #40 of 238 Old 06-04-2007, 02:25 PM
dm145's Avatar
Quoted: 81 Post(s)
Liked: 44
stickey please
dm145 is offline
post #41 of 238 Old 06-04-2007, 03:05 PM
rwestley's Avatar
Quoted: 404 Post(s)
Liked: 243
The problem some may be having in Burning ISO files could be caused by any of the following:
1. An old burner without the latest firmware.
2. Poor quality disks. (I like Taiyo Yuden but other quality disks should work)
3. Too high a speed (I suggest using 8x speed)
4. Software problem or computer that is not powerful enough.
I have updated many players and have burned countless ISO files using Burn at Once with not issues. I have used NEC, BenQ, Samsung, & Lite-On burners all with not problems.
Be sure your finalize the disks and check after burning. Make sure you are also using a CD disks not a DVD disk.
rwestley is offline
post #42 of 238 Old 06-04-2007, 03:20 PM
Arpeggio's Avatar
Looks like Canadian site took down the HD-A1 ISO link...another update coming down the pike?
I am NOT fat, my aspect ratio is just set wrong....
-=[Arpeggio]=-
Arpeggio is offline
post #43 of 238 Old 06-04-2007, 03:37 PM
charlie3133's Avatar
Thats me confused then, because I tried to do the upgrade yesterday using a cd and the player told me it did not recognise the media?
Hmmmmmm
charlie3133 is offline
post #44 of 238 Old 06-04-2007, 04:11 PM - Thread Starter
MidnightWatcher's Avatar
Quoted: 160 Post(s)
Liked: 153
If anyone has the A1/XA1 2.2 ISO saved and would like to host it, please let me know and I'll update the original post with the new link. As Arpeggio noted it appears to have been removed from the site.
Photos Of My Theater | Vero 4K | Epson 5030UB + Peerless PRG-UNV | 100" EluneVision Reference 4K Screen | Onkyo TX-NR555 @ 5.2.2 | 4 x ADX Maximus w/ Dayton Audio SA230 | Polk Audio RTi A9 + CSi A6 + OWM3 + Micca M8C + SVS PC2000 | 40" HDTV w/ Z83V Mini PC + MoviePosterApp | Z83V + DietPi FTP Server + 3 x 8TB HDDs + 4 x DLink DHP-701AV
MidnightWatcher is offline
post #45 of 238 Old 06-04-2007, 04:15 PM
Darrel McBane's Avatar
I tried Nero at two different speeds and neither copy was recognized by the Toshiba. So, I tried a right click of my mouse on the 1.6 ISO file and saw an option of "send image to disk" was there. The file copied and was read by the Toshiba XA2. I'm using Windows XP Pro. Maybe it's that easy.
Now is Forever
Darrel McBane is offline
post #46 of 238 Old 06-04-2007, 08:16 PM
trackpilot's Avatar
I just bought my A20. How do you know if you need the firmware update?
trackpilot is offline
post #47 of 238 Old 06-05-2007, 03:25 AM
rwestley's Avatar
Quoted: 404 Post(s)
Liked: 243
Darrel, you probably have a disk image burning program installed. I have that option with several programs which I right click. I still like the free program Burn at Once which I sue for most of my ISO burning. I get best results with it.
rwestley is offline
post #48 of 238 Old 06-05-2007, 05:00 AM
Scarpad's Avatar
Quoted: 91 Post(s)
Liked: 48
Can someone tell me where on the A2 it displays the firmware in place. I bought mine last week and I can't find the information. Also is connecting to the Internet as easy as plugging in an ethernet cable or is there some setup involved?
Scarpad is offline
post #49 of 238 Old 06-05-2007, 06:32 AM
karlw2000's Avatar
I have a new D2 (last Saturday) and I discovered it came with version 1.2!! Amazing because I was able to play all the difficult movies like COM, Happy Feet @ 28 minutes problem area, all the Matrix movies, etc. I did have one lockup upon loading and it was a little slow to boot up (30+ seconds), so I upgraded to 1.6 last night. Just in case, I burned at 2X speed since it was such a small file. Worked like a charm.
karlw2000 is offline
post #50 of 238 Old 06-05-2007, 09:47 AM
trackpilot's Avatar
How'd you know what version it was???
post #51 of 238 Old 06-05-2007, 10:04 AM
aaroen's Avatar
I tried several times to download the ISO recorder and got cannot open cabinet file required errors every time I tried to open it. Any suggestions?
aaroen is offline
post #52 of 238 Old 06-05-2007, 10:14 AM
MORPHIII's Avatar
ISO Recorder
Finally. It worked!!
ISO RECORDER really worked. NO more error 2007.
MORPHIII is offline
post #53 of 238 Old 06-05-2007, 10:47 AM
does anyone have a link to the address you can write to, to get them to send you a firmware disc?
post #54 of 238 Old 06-05-2007, 12:55 PM
karlw2000's Avatar
I'm at work right now, but if I remember correctly, you go into the maintenance and click all the things like you are going to update the firmware. You'll see the version along with something else.
post #55 of 238 Old 06-06-2007, 06:36 AM
Zurbaran1's Avatar
I have been having the same problem with error 2007c00f so I went out and downloaded ISO Recorder. The only problem is that I can't get ISO Recorder to work. When I follow the instructions for ISO Recorder and right click on the iso file I select Copy image to CD. The ISO Recorder CD Recording Wizard pops up with my iso file in the Source box. I have my CD drive selected in the Recorder box and here's the problem. It shows D: blank Writable Nonusable and the Next button is grayed out so I can't go on. The disc in my CD drive is a brand new blank Memorex CD-R. Anybody have any ideas they would be greatly appreciated. Thanks.
Zurbaran1 is offline
post #56 of 238 Old 06-06-2007, 06:38 AM
Zurbaran1's Avatar
That's great. If you see my post above I am trying to use ISO Recorder but I can't get it to burn the CD. Could I ask what brand CD are you using. Maybe it doesn't like mine for some reason.
post #57 of 238 Old 06-06-2007, 10:19 AM
wittangamo's Avatar
Mine are Memorex 52x CD-R. Failed with Nero at 8x, worked great with ISO recorder at 2x. My burner is an NEC 3520A.
post #58 of 238 Old 06-06-2007, 10:35 AM
MORPHIII's Avatar
MORPHIII is offline
post #59 of 238 Old 06-06-2007, 12:01 PM
tubesguy's Avatar
Shoot, I grabbed the wrong pack off the shelf at Office Depot, and when I got home I saw that I'd bought store brand CD-RWs instead of CD-Rs. Too lazy to return, so I just popped the -RW in the drive, and ISO Recorder worked like a charm. I don't even know what speed I'm using to burn.
tubesguy is offline
post #60 of 238 Old 06-06-2007, 01:22 PM
Zurbaran1's Avatar
So are mine. I wonder why ISO recorder won't work with them.
Reply HD DVD Players
