Having VERY bad luck with Warner HD-DVDs! - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #721 of 734 Old 05-22-2019, 01:41 PM
scowl's Avatar
Quoted: 160 Post(s)
Liked: 49
Originally Posted by Laserfan View Post
Gotcha. I confused myself by forgetting you were referring only to BDs with no doubt the various outrageous e.g. "Master Audio" bitrates.
There are some HD-DVD with lossless audio, usually TrueHD.
Compressing the lossless audio with E-AC3 at 1.7 Mbps reduces the size of the file by about 20% so this is beneficial. Also E-AC3 supports 24 bit audio so there's really not much difference at that bitrate.
Laserfan likes this.
scowl is offline
post #722 of 734 Old 06-18-2019, 06:30 AM
Brian81's Avatar
At this point, is there any reason to track matrix numbers and IFPI codes for defective discs, whether for here or to provide for LDDB website? i have held onto most of my rotted discs. I still have around a 50/50 chance of a disc playing all the way through, some titles both copies work and others neither copies work. Seems like early releases are more likely to work and also I have never encountered an error on an HD15 disc. I did have one that did not read at all but it may have been defective from the beginning. At this point I wish they crammed them all on HD15s.
Brian81 is offline
post #723 of 734 Old 01-03-2020, 12:01 PM
jurid001's Avatar
Quoted: 78 Post(s)
Liked: 26
60% failure rate thus far
Tested my WB HD DVDs: out of 25, 15 are rotten. I have more, but I think it will be about the same ratio. I suspect that WB did some accelerated aging testing of their HD DVDs and found out that most of them (if not all) would have failed in a few years, and decided to jump HD DVD bandwagon entirely and contribute to the format's death. Fearing that if the format survives , that would be a PR disaster for WB, with lawsuits and customers potentially requesting all their discs replaced.
A2, A35, 150, 62fd, s790, s6500, x800, 83, 103D, HTPC w/ HD-DVD/BD
jurid001 is offline
post #724 of 734 Old 01-03-2020, 12:18 PM
scowl's Avatar
Quoted: 160 Post(s)
Liked: 49
If the HD-DVD format had been a success, then the defective Warner discs would have been just a momentary setback in the history of the format, something that we old timers would be talking about as we play the replacement discs that Warner sent us for free. Remember that an HD-DVD didn't cost much more to produce than a DVD so sending replacement discs wouldn't have been a huge expense in a billion dollar format.
I have a couple of Universal Blu-rays that stopped playing after a few years. Universal refused to replace them.
scowl is offline
post #725 of 734 Old 01-03-2020, 12:24 PM
snowghost's Avatar
Quoted: 27 Post(s)
I was remiss in not trying to replace the bad ones immediately. I still have a bunch of unopened ones that should probably be tested.
Thing is they need be watched all the way through as not all defective ones are non loading.
"The best long distance runners eat raw meat, run naked and sleep in the snow."
snowghost is offline
post #726 of 734 Old 01-03-2020, 01:39 PM
TMOSteel's Avatar
Funny thing is its only Warner HD-DVD's that I've ever had problems with. I managed to get a mailer from them last year as a "courtesy" on their part (ha!) to replace A Christmas Story but in the end couldn't be bothered with the exchange to Blu-ray.
TMOSteel is offline
post #727 of 734 Old 01-03-2020, 02:19 PM
scowl's Avatar
Quoted: 160 Post(s)
Liked: 49
I bought one unopened HD-DVD and, yep, it was dead right out of the package.
Yes, I've tried to rip them with mkmkv and it can take a while to hit a bad spot, but once you do it's over. There doesn't seem to be any way to convince mkmkv to skip over the errors and keep reading.
scowl is offline
post #728 of 734 Old 01-03-2020, 05:31 PM
jurid001's Avatar
Quoted: 78 Post(s)
Liked: 26
Replacing close to 100% could've been a different matter, not a momentary setback.
jurid001 is offline
post #729 of 734 Old 01-03-2020, 05:41 PM
scowl's Avatar
Quoted: 160 Post(s)
Liked: 49
No. There really weren't a lot of HD-DVD discs sold and Warner would have passed most of the costs onto the manufacturer who was responsible for making the defective discs.
scowl is offline
post #730 of 734 Old 01-09-2020, 06:41 PM
sivartk's Avatar
Quoted: 14 Post(s)
I have ripped all but 2 of my ~30 HD DVDs to my Plex server. There was one that I thought had no chance at ripping (you could see "wave pattern" discoloration on the disc data side), but it did rip. I contacted the studio and they replaced it with the Blu-ray for no cost. This was about 2 years ago. For the one that didn't play, I just rented it (Blu-ray) and ripped it to my Plex server. The other one was planet earth that had 2 bad discs, but I ended up getting the full Blu-ray for $5.
Haven't tested any of them in the past 2 years so not sure how many of mine have died since then.
At no point in your rambling, incoherent post were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having read it.
My Little Theater
sivartk is offline
post #731 of 734 Old 02-24-2020, 04:13 PM
scowl's Avatar
Quoted: 160 Post(s)
Liked: 49
I've ripped all of my HD-DVD and Blu-ray discs to hard disk and I've recompressed about half of them with the H265 and E-AC3 codecs which reduced them to one half to one third their original size.
scowl is offline
post #732 of 734 Old 02-25-2020, 07:19 AM
Laserfan's Avatar
Quoted: 21 Post(s)
Liked: 169
Nice job. I used MakeMKV to convert the movies "as-is" (no further compression or re-encoding) but I have a large capacity NAS so don't care about size, at least for now.
I was disappointed though to find that about 8 out of my collection of ~104 of my discs failed to read/copy, but iirc they will still play in my HD-DVD player. I have my eye on iTunes for these titles and might just buy them when they go on sale...
Laserfan is offline
post #733 of 734 Old 02-25-2020, 10:23 AM
scowl's Avatar
Quoted: 160 Post(s)
Liked: 49
Compression is free and I have a lot of titles.
Also, I now have four Blu-ray discs that are defective. This is a much smaller fraction than my HD-DVD discs but I don't like my media decaying while it's on the shelf.
scowl is offline
post #734 of 734 Old 02-26-2020, 06:38 PM
tomtastic's Avatar
Quoted: 1312 Post(s)
Liked: 576
I went to play Batman Returns and one of my discs gave me an error. I have 2 copies the 2nd disc played fine.
This line intentionally left blank.
tomtastic is offline
Reply HD DVD Software
