Deadlands rot?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-15-2019, 07:01 PM - Thread Starter
Liked: 0
Deadlands rot??
I just received this today and I have a problem. The disc that is on the right side in picture 4 & 5 comes up with errors in all 4 of my players. The other disc works fine. I was told that if the discs say "3rd generation support" it wont work on earlier machines or out of date firmwares. Both of the discs say 3rd generation support on them but only 1 disc doesnt work. Any help would be greatly appreciated.
ID:	2628238   Click image for larger version
ID:	2628240   Click image for larger version
ID:	2628242   Click image for larger version
ID:	2628244   Click image for larger version
majik732007 is offline
post #2 of 3 Old 11-04-2019, 09:48 AM
Actionable Mango's Avatar
Quoted: 333 Post(s)
Liked: 278
These are HD-DVD-R discs (burned, not pressed). It wouldn't surprise me if the occasional coaster was made, if there was bad recordable media in the first place, or if there was disc rot over time.
Actionable Mango is offline
post #3 of 3 Old 04-06-2020, 02:33 PM
tomtastic's Avatar
Quoted: 1334 Post(s)
Liked: 590
My copy didn't work either when I bought it. I should have returned it to seller but I didn't test it right away, my mistake.
I don't think it has anything to do with software version. I've burned some HD-DVD-R's and they played find on my XA2 and it's the final updated version. I think I used the same software to burn as Deadlands. It's probably a bad disc just like mine. And I know my disc is bad because I should be able to rip it but I can't do that either. It's just dead.
This line intentionally left blank.
tomtastic is offline
Reply HD DVD Software
