Streaming music from computer to iPod/iPhone - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-09-2010, 02:21 PM - Thread Starter
Sumthn's Avatar
I'm not sure if this is right place to put this but I wanted to know if it is possible to use my iPhone as a media player. I don't have much memory on my iPhone but I have a lot of music on my computer. I don't always like sitting at my comp and sometimes I like to just sit on the couch with my earplugs but I don't know how to stream music from my computer on to my iPhone. Does anyone know how I can do this if possible?
Sumthn is offline
post #2 of 7 Old 08-09-2010, 03:29 PM
mcnarus's Avatar
Quoted: 154 Post(s)
Liked: 381
There are apps for that. The one I'd heard recommended was Simplify Music, but it's been discontinued. Others that seem to do the same thing are Subsonic and ootunes. A search on "simplify music alternatives" might yield some other candidates.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 7 Old 08-09-2010, 03:40 PM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
you can use airfoil with the airfoil speakers app to do what you want...
clicky
- chris
https://www.avsforum.com/t/1332917/ccotenj-finally-gets-a-projector
ccotenj is offline
post #4 of 7 Old 08-09-2010, 04:14 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
I don't know much in this area, but you could research PlugPlayer. Among other uses, you can apparently use PlugPlayer to stream from a foobar2000 media library using this download.
MSmith83 is offline
post #5 of 7 Old 02-05-2011, 01:18 AM
Vivianne Turner's Avatar
WiFi2HiFi streams audio from PC or Mac to stereo system or sound-dock in crystal-clear stereo quality, with an iOS device acting as a wireless receiver.
Vivianne Turner is offline
post #6 of 7 Old 02-15-2011, 05:01 AM
Koolarrow's Avatar
thanks V Turner for the info. Would there be an advantage to getting a Network A/V receiver like the Yamaha RX A1000, or would it be just as good to get Western Digital Live Hub Media Center?
Koolarrow is offline
post #7 of 7 Old 06-22-2011, 06:40 AM
tmaschm's Avatar
If your computer is always on then do this:
1.). Buy an apple tv/airport express/squeezebox etc
2.). Download remote app or equivalent
3.) turn sharing on iTunes to on (or eq)
4.) listen to music from couch.
tmaschm is offline
Reply CD Players & Dedicated Music Transports
