Fixing a NAD 524 CD player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-23-2012, 03:48 AM - Thread Starter
MrSkyline's Avatar
I'm going to get a broken NAD 524 CD player and i want to try fixing it.
The problem is that the tray won't open, i haven't had my hands on it yet, so i can't say if its the button, or the motor that could be the problem.
I know these NAD cd players have a bad reputation, i read about allot about problems with playback, but none about the tray.
I'm not an elektricien, but i know how to handle a soldering iron, and i'm not a complete ******, so i thought, maybe i can fix it.
Does anyone know of a similar problem, and how to fix it?
I get de player next sunday, so by then i know more.
MrSkyline is offline
post #2 of 4 Old 01-23-2012, 05:06 AM
brubacca's Avatar
Could be very simple. According to this thread the belt can stretch out and would be an easy fix (like a vacuum cleaner).
http://forum.audiogon.com/cgi-bin/fr...ray-Won-t-Open
brubacca is offline
post #3 of 4 Old 02-04-2012, 12:50 PM
commsysman's Avatar
Quoted: 1118 Post(s)
Liked: 584
Most of the time it is a bad control chip. It could be a bad operating belt or gear though. Open it up and study the mechanism, and if there is no obvious physical problem, see if you can download a service manual or buy one from NAD.
commsysman is offline
post #4 of 4 Old 04-05-2019, 12:27 AM
44ct357's Avatar
Quoted: 22 Post(s)
I'm going to get a broken NAD 524 CD player and i want to try fixing it.<br>
The problem is that the tray won't open, i haven't had my hands on it yet, so i can't say if its the button, or the motor that could be the problem.<br><br>
I know these NAD cd players have a bad reputation, i read about allot about problems with playback, but none about the tray.<br><br>
I'm not an elektricien, but i know how to handle a soldering iron, and i'm not a complete ******, so i thought, maybe i can fix it.<br><br>
Does anyone know of a similar problem, and how to fix it?<br>
I HAVE JUST REWORKED ONE ONLY TO FIND THE TRAY IS DAMAGED. Anyone have one from a blown unit????
The loader is reading and all working.
Its a good build, large logic pcb and a toroidal!
The sound is excellent, cant see why some say the audio is not tops!
Colin Cape Town SA.
0722024190
44ct357 is offline
Reply CD Players & Dedicated Music Transports
