what is a good DSD and SACD player for less than $1500? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #31 of 62 Old 04-11-2016, 10:11 AM
2channel8's Avatar
Quoted: 60 Post(s)
Liked: 27
On a similar note, I snagged an Oppo DV-980-H on Ebay last year for $65 plus shipping. I love it. I use it for audio onlt in my 2 channel set up. I got it to get into SACDs and as a bonus found out that some of my old CDs also have HDCD layers. I think I may like the HDCD even better than SACD. I also like the USB port for playing files from my PC.
I wanted to snag another one; but apparently the word is out that tis is a great little bit of gear and the bidding on Ebay is getting too high since I only paid $85 total for mine. Haven't found a Sony or other quality model with a USB port and analog audio out.
Anyone have any suggestions for a bargain hunter? $900 for the Sony XA5400ES is too rich for where I am going to use it and I don't see a USB port in the features.
2channel8 is offline
post #32 of 62 Old 04-11-2016, 12:56 PM
LexInVA's Avatar
Quoted: 797 Post(s)
Liked: 374
Thrift stores/pawn shops in your area might have something. I've gotten lucky with electronics by going through those before.
LexInVA is offline
post #33 of 62 Old 05-19-2016, 08:40 PM - Thread Starter
happy hopping's Avatar
Quoted: 141 Post(s)
http://www.stereophile.com/content/p...cd-oppo-970h-1
well, good thing I did NOT listen any of the above people who ask me to buy this piece of junk called Oppo.
I have the same problem as those people in stereophile, the only difference is, I didn't pay for the Oppo player, I borrow it.
Just like those people, no matter what you do, Oppo doesn't play SACD. There is no sound. After wasting hours on different setting, it just won't play SACD.
This brand Oppo is a joke.
happy hopping is online now
post #34 of 62 Old 05-20-2016, 11:55 AM
ematcion's Avatar
Quoted: 178 Post(s)
Liked: 282
Did you call customer service at Oppo? Usually, they customer care is top-notch.
Avatar - My guard dog, Bogi - RIP
Part of my ever-growing SACD collection
ematcion is offline
post #35 of 62 Old 05-21-2016, 12:31 PM
thebard's Avatar
Quoted: 88 Post(s)
Liked: 51
Are you using hdmi or optical/coax for digital audio out?
From page 34 in the manual:
Symptom:
No sound
Possible Cause:
DVD-Audio or SACD is played
and the audio connection is
coaxial or optical digital audio
Solution
This is not supported due to copyright restrictions of
DVD-Audio and SACD. Please use the analogue 5.1-
channel audio output.
Due to copyright restrictions, no consumer player will output the multichannel layer except over hdmi or analog.
thebard is offline
post #36 of 62 Old 05-21-2016, 07:09 PM - Thread Starter
Quoted: 141 Post(s)
I am using Co-ax. I mean, if that's the case, then I should buy a SACD player that c/w Co-ax and that would solve all the problem
post #37 of 62 Old 05-23-2016, 11:01 AM
thebard's Avatar
Quoted: 88 Post(s)
Liked: 51
Sorry, I don't know what you mean by "c/w" ("comes with?).
You will not get the SACD layer to play digitally over optical or coax on any player that I know of. Your options are analog (stereo or multi-channel) or hdmi (or DenonLink).
I've heard some players will play the SACD layer over coax if you set the player output to PCM, but I can't vouch for the accuracy of this.
You've been given a lot of good options on this thread, from the Oppo & Sony models to others. My recommendation would be to get the one with the connections / features / bit-rate / support you prefer, but don't expect any of them to play non-standard SACD discs (DSD rips), or SACD layers over anything other than analog or hdmi, and you won't be disappointed.
CruelInventions likes this.
thebard is offline
post #38 of 62 Old 05-23-2016, 07:59 PM - Thread Starter
Quoted: 141 Post(s)
I have a channel setup w/ a DAC that has no HDMI. So what I don't understand is, what happens to people who have a 2 channel setup? How do they get their SACD to play? It sounds like there is no solution to digital out.
The Oppo clearly doesn't work, as it doesn't play SACD signal thru Co-ax
the Sony also doesn't work, I just view their manual:
http://pdf.crse.com/manuals/4000691131.pdf
Only the audio signals of conventional CDs can be
output from the DIGITAL OUT (CD) COAXIAL jack.
Those of Super Audio CDs cannot be output through the jack
post #39 of 62 Old 05-23-2016, 08:26 PM
grasshoppers's Avatar
Quoted: 966 Post(s)
Liked: 704
To play a SACD/DSD disc you only have 2 choices.
HDMI or analog out (using the players DAC)
In my two channel analog rig I use the analog out
On my Sony SACD player. (Using the player's DAC)
In my other room (Oppo)
I have a Marantz AVR and I use HDMI using the AVR DAC.
In my main system I use a Sony blu-ray player to play
SACD discs via HDMI.
As noted, co-ax or optical won't do DSD due to copyright
Protection.
3 different players. If you wish to use your external DAC
You are probably SOL.
(Main)-Marantz 6012*Outlaw Audio M2200*Rythmik F12 subs*Paradigm Signature S6,C1,S1
******Harman Kardon DMC1000 (music)-Assassin HTPC (movies).
(Bedroom)-Marantz SR5003*Paradigm Studio 40,SE Center,SE One*SVS SB-2000 subs*Sony S6200
(Music room)-Outlaw Audio RR2150*Sierra Two ribbon speakers*Rythmik L12 sub*Yamaha CDR-HD1500
grasshoppers is offline
post #40 of 62 Old 05-23-2016, 10:27 PM - Thread Starter
Quoted: 141 Post(s)
Grasshoppers, so you're in the same boat as me. As such, have you seen this gadget that converts HDMI to Coax?
http://www.monoprice.com/product?p_id=5557
post #41 of 62 Old 05-23-2016, 11:15 PM
Quoted: 966 Post(s)
Liked: 704
Never seen it before??? Wonder if it would work?
I guess, for $45 it might be worth a shot!
post #42 of 62 Old 05-23-2016, 11:17 PM - Thread Starter
Quoted: 141 Post(s)
I buy from Monoprice a no. of times, their product quality is very good, shipping is very cheap. My last order is the XLR cable, outstanding quality. You can email them and ask what kind of guarantee do they have.
I like that switch to swap from 5.1 to 2 chnl. of this 5557, if you buy this before me, let me know and post it here
post #43 of 62 Old 05-24-2016, 07:29 AM
Quoted: 966 Post(s)
Liked: 704
Actually, I'm good, as I don't feel the need for an external
DAC. I'm happy with the internal DAC on my Sony player.
When you get the mono price switcher post back if it
Works to your expectations.
post #44 of 62 Old 09-17-2016, 02:16 AM - Thread Starter
Quoted: 141 Post(s)
it works very nicely. Go buy it
post #45 of 62 Old 09-17-2016, 08:09 AM
Quoted: 966 Post(s)
Liked: 704
I'm glad you're happy with it! However, I have no
Need for it. All 3 of my systems can play and decode
SACD discs. (Post #39) And I don't have any 'DSD' discs.
post #46 of 62 Old 09-27-2016, 07:55 PM
Liked: 0
Originally Posted by dbphd View Post
My Ayre C-5xeMP plays DSD, and it sounds superb. I don't know if they have any current players that do, though.
Ayre C-5xeMP play DSD files burned on DVD-R? or only original SACD?
KnyazHM is offline
post #47 of 62 Old 09-28-2016, 10:00 AM
Liked: 0
I burned two DVD-R with DSF and DFF files. Ayre C-5xeMP does not read. Its play only the original SACD.
Maybe try TEAC PD-501HR? May be other options?
KnyazHM is offline
post #48 of 62 Old 10-01-2016, 08:53 AM
JA Fant's Avatar
Quoted: 560 Post(s)
Liked: 1428
Marantz
Sony ES
JA Fant is offline
post #49 of 62 Old 10-05-2016, 11:17 AM
2channel8's Avatar
Quoted: 60 Post(s)
Liked: 27
Cambridge Audio CXU?
post #50 of 62 Old 10-05-2016, 05:10 PM
IMWhizzle's Avatar
Quoted: 1003 Post(s)
Liked: 329
Guys, will my Marantz 6010 support native dsd over hdmi? I am aiming for 5.1 surround SACD's. I also have a external hdd with 5.1 dsd dff files. Will those play natively on my avr without downconverting or whatsoever?
Klipsch Reference Premiere: 4 x RP-280's, 1 x RP 450C and dual R-115W's
Marantz 7011 AVR
LG OLED B6
Apple TV 4K
PlayStation Pro
IMWhizzle is offline
post #51 of 62 Old 10-12-2016, 06:17 AM
JA Fant's Avatar
Quoted: 560 Post(s)
Liked: 1428
How about the new Sony universal player?
JA Fant is offline
post #52 of 62 Old 10-12-2016, 06:24 AM
Liked: 0
What Sony player?
KnyazHM is offline
post #53 of 62 Old 10-12-2016, 02:38 PM
ematcion's Avatar
Quoted: 178 Post(s)
Liked: 282
Originally Posted by KnyazHM View Post
What Sony player?
Sony UDP-X1000ES??
https://www.cnet.com/products/sony-ubp-x1000es/preview/
ematcion is offline
post #54 of 62 Old 10-21-2016, 07:55 AM
rbrb's Avatar
Quoted: 34 Post(s)
Liked: 27
I'm trying to get this straight, I'm somewhat confused by this conversation. We have SA-CD that never really lit the world on fire. It's still possible to buy Blu-Ray players that support SA-CD, (I'm on my 4th SA-CD player) but it will never be a mass market format. Then someone gets the idea that PCM should be remastered using DSD technology and put on disc but not play on SA-CD players. The player would require separate file support for DSD discs.
Does this sound about right?
Calling Oppo a joke because it doesn't support these obscure discs?
rbrb is offline
post #55 of 62 Old 11-12-2016, 06:10 PM
smitty8451's Avatar
Quoted: 73 Post(s)
Liked: 101
I have the teac pd-501, and I record my vinyl masters to a tascam da-3000 SS recorder in DSD format, clean up the recordings and burn the files to a dvd-r disc and play them back. Works great. Also tascam has FREE conversion software to convert those did files to WAV in any flavor you like. I run my teac analog RCA outputs straight into a rogue audio Pharaoh tube integrated amp. Pure bliss IMO.
I've had the teac PDF-501 for over a year, a very rock solid unit
Yamaha CX-A5200, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers, Antimode Dual Core 2, Oppo UDP-205, MMF-7.1, Tavish Adagio phono pre w/tube power supply, XBox 360, XBox One, Oppo HA-1, and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio RP-7 preamp, Atlas Magnum II Amp, Sony HAPZ1-ES
smitty8451 is offline
post #56 of 62 Old 11-17-2016, 12:39 AM
justthinking's Avatar
Quoted: 389 Post(s)
Liked: 226
I want a new SACD player with following requirements for a 2 channel setup that will not have any display devices available...
1. Excellent 2 channel analog output quality
2. Support SACD and DSD (at least both DSD 2.8 mhz and DSD 5.6 mhz)
3. Can play DSD and other files (FLAC/ALAC/MP3/AAC/ETC) directly from USB storage device, if can play these files from a NAS would be even better
4. Has a good app for both iOS and android since no display devices will be available, need to have good funcitonal app to browse file collections for playbac
Looks like Oppo 105D is the only player that meet most if not all requirements, is there a pure SACD player that can meet my requirements??
5.2.4 HT - Sony XBR75X850C, Denon X4400H, Monitor Audio GS60, GSLCR, GSFX, C380LCR x4 and Martin Logan Descent I x2
2 Channel - Ascend Sierra Tower w/ RAAL, Sony HAP-Z1ES, Marantz SA-KI-Pearl, Primaluna Dialogue Three, Parasound Halo A21, JL Audio CR1, JL Audio E112 and ATS Acoustics room treatments
justthinking is offline
post #57 of 62 Old 11-17-2016, 04:44 PM
2channel8's Avatar
Quoted: 60 Post(s)
Liked: 27
I think the Marantz SA8005 does most of that. Not sure about #4.
post #58 of 62 Old 05-30-2017, 01:51 AM
Methodical_1's Avatar
Quoted: 467 Post(s)
Liked: 303
I wanted to snag another one; but apparently the word is out that tis is a great little bit of gear and the bidding on Ebay is getting too high since I only paid $85 total for mine...
hummmm, interesting. I still have mine in storage.
HT Configuration: 7.3.4 l Panasonic Plasma (65") l Denon X4300H l Polk LSiM 707s, 706c, FXi-30 l Infinity ERS-610 l SVS PB-2000 Subs (2x) l Monolith 7 l Behringer A500 (2x) l Oppo UDP-203 l MH mmf-9.3 l Cassette Deck.
"Never be afraid to try something new, remember amateurs built the Ark, professionals built the Titanic"
Methodical_1 is offline
post #59 of 62 Old 05-30-2017, 09:44 AM
2channel8's Avatar
Quoted: 60 Post(s)
Liked: 27
That was written just over a year ago. Since then I have added a BDP-95 and moved the DV-980 to my B system. Also the UDP models have been introduced; yet the DVs seem to be holding their prices. I always keep an eye out for a good deal on a DV-983.
post #60 of 62 Old 09-26-2019, 04:02 PM
WestCoastD's Avatar
Quoted: 327 Post(s)
Liked: 134
still listening to my Sony XA5400ES, love it!
Also, still use my Oppo BDP-105, mostly for DVD's, DVD-A's, Blu-Ray Movies, BluRay-Audio
System:
Marantz AV8802A
Parasound A51 amp
Monitor Audio Gold GX speakers
JL Audio F110 sub
WestCoastD is offline
Reply CD Players & Dedicated Music Transports
