What do you gain from UHP-H1 to SCD-XA5400ES - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By happy hopping
  • 1 Post By gbaby
  • 1 Post By WestCoastD
post #1 of 13 Old 02-14-2017, 08:31 PM - Thread Starter
happy hopping's Avatar
Quoted: 140 Post(s)
The UHP-H1 is $350, and the XA5400ES is $1200. The ES is obviously Evaluated Standard, but what is it inside that there is a near 4X the price? And is it worth it to buy the 55400ES
JA Fant likes this.
happy hopping is offline
post #2 of 13 Old 02-15-2017, 10:41 AM
gbaby's Avatar
Quoted: 844 Post(s)
Liked: 439
The only reason to buy the XA-5400ES is if you need a quality 2 channel D/A converter and your system can take XLR inputs. Otherwise, the less expensive UHP-H1 can play DVD-A and SACD 5.1 through HDMI so for me, it is the better unit. I own both.
JA Fant likes this.
gbaby is offline
post #3 of 13 Old 02-15-2017, 04:39 PM
JA Fant's Avatar
Quoted: 560 Post(s)
Liked: 1428
Thanks! for sharing- gbaby
JA Fant is offline
post #4 of 13 Old 02-16-2017, 11:46 PM - Thread Starter
Quoted: 140 Post(s)
what about the quality? The sony guy told me the ES is a better build.
Off hand, my first initial impression is the buttons on the Sony 5400ES, as my room is small, so I usually use the buttons on my old CD player. But I can get used to using the remote on the UHP-h1
post #5 of 13 Old 02-17-2017, 06:59 AM
RWetmore's Avatar
Quoted: 666 Post(s)
Liked: 402
Yes, of course the build of the XA5400ES is far superior, but again if you're not using the analog outs, I would say there is no reason to get the ES.
RWetmore is offline
post #6 of 13 Old 02-17-2017, 10:47 AM
commsysman's Avatar
Quoted: 1119 Post(s)
Liked: 584
If you really want the best sound quality, the new OPPO 205 is going to be out very soon. I would want to see about it first. It should run around $1200 or so.
The OPPO 203 is already out, and appears to be very good also.
commsysman is offline
post #7 of 13 Old 02-17-2017, 01:50 PM - Thread Starter
Quoted: 140 Post(s)
thanks for that oppo news. I wonder if they support DSD decoding, as their older models do not
post #8 of 13 Old 02-17-2017, 08:17 PM
RWetmore's Avatar
Quoted: 666 Post(s)
Liked: 402
I'm pretty sure it will.
RWetmore is offline
post #9 of 13 Old 02-20-2017, 07:31 PM
ematcion's Avatar
Quoted: 178 Post(s)
Liked: 282
From the 103/105? They can decode DSD directly to analog, as clearly stated in their respective owners manual.
Avatar - My guard dog, Bogi - RIP
Part of my ever-growing SACD collection
ematcion is offline
post #10 of 13 Old 02-21-2017, 06:28 PM
gbaby's Avatar
Quoted: 844 Post(s)
Liked: 439
The Oppo cannot compete with this Sony when you consider the cost/performance ratio. Put your money in a quality processor.
gbaby is offline
post #11 of 13 Old 02-25-2017, 08:16 PM - Thread Starter
Quoted: 140 Post(s)
Which Oppo, the cheap or the expensive one or both? you mean the Sony is better? I have a half decent DAC from Emotiva. That's why my next step is to get a good SACD player. The reason I like the 5400ES is that I use those buttons at the front panel all the time. It's hideous to find the remote and push those buttons on the remote instead
post #12 of 13 Old 02-26-2017, 01:29 PM
gbaby's Avatar
Quoted: 844 Post(s)
Liked: 439
You need to analyze your own needs. If you have a processor with an excellent D/A converter, the Sony UHP-H1 for the money and its features, is a no brainer.
gbaby is offline
post #13 of 13 Old 09-26-2019, 04:07 PM
WestCoastD's Avatar
Quoted: 327 Post(s)
Liked: 134
still listening to my Sony XA5400ES, love it!
Also, still use my Oppo BDP-105, mostly for DVD's, DVD-A's, Blu-Ray Movies, BluRay-Audio
System:
Marantz AV8802A
Parasound A51 amp
Monitor Audio Gold GX speakers
JL Audio F110 sub
fatuglyguy likes this.
WestCoastD is offline
Reply CD Players & Dedicated Music Transports
