Playing CD's again.loving it.. - AVS Forum | Home Theater Discussions And Reviews
 70Likes
  • 4 Post By MRAYB
  • 1 Post By zeuspaul
  • 3 Post By MRAYB
  • 4 Post By Bill-99
  • 3 Post By glangford
  • 1 Post By Bill-99
  • 5 Post By DonoMan
  • 1 Post By glangford
  • 5 Post By MRAYB
  • 8 Post By MRAYB
  • 2 Post By thetman
  • 3 Post By Graustark
  • 5 Post By Graustark
  • 1 Post By JA Fant
  • 5 Post By MRAYB
  • 4 Post By Graustark
  • 2 Post By Panson
  • 2 Post By MRAYB
  • 2 Post By Panson
  • 3 Post By MRAYB
  • 3 Post By yanks1
  • 1 Post By Milliron
  • 1 Post By Graustark
  • 1 Post By blu ray boy
post #1 of 24 Old 02-04-2019, 02:53 PM - Thread Starter
MRAYB's Avatar
Quoted: 372 Post(s)
Liked: 883
Have not had a dedicated cd player for about 7? years. Everything on sticks, hard drives, streaming, or pc. My library is about 1000 cd's. Running a used Denon 4311CI and an Onkyo 2ch amp for fronts in a 9.4 format sounding great for music mostly, not so much a movie goer( but they sound great also). Just seemed to miss discs. Am I that old? 48btw.
Got burnt on Fleabay TWICE for an old multi-disc player. One didn't even read discs. Got a refund. Seller said just throw it away. Other one was not even the model in the listing. Shipped back and got the refund.
Going by many recommendations that I have seen on here, I looked at Accessories4less. Got this Yamaha player the other day and couldn't be happier. "Factory refurbished" with a one year warranty. Was actually $20 cheaper two days ago??. Anyway, sounds GREAT!. The old Denon 4311CI with the player sounds awesome. Just wanted to give a heads up to those looking. I am not a dumpster diver, but most on fleabay are, I guess.
https://www.accessories4less.com/mak...xchange/1.html
My first test cd. Love it.
MRAYB is offline
post #2 of 24 Old 02-04-2019, 07:35 PM
zeuspaul's Avatar
Quoted: 252 Post(s)
Liked: 368
Is the sound quality of a CD played directly better than the sound quality of a CD ripped to a lossless file such as wav or flac? Does it depend on the DAC of the CD player and the DAC of the media player in the case of files?
JA Fant likes this.
Spoiler!
zeuspaul is offline
post #3 of 24 Old 02-05-2019, 12:34 AM - Thread Starter
MRAYB's Avatar
Quoted: 372 Post(s)
Liked: 883
I really can't answer these. I am sure there are numerous threads regarding the comparisons. When I ripped all my cd's years ago, I used Handbrake. I don't have any intention of doing that again. They are now mp3, so a cd does sound much better. As far as the DAC, I am running the Yamaha into the Denon 4311CI via component cables. From what I have read and researched, the 4311 has an excellent DAC.
As you can tell, no audiophile here. Just know it sounds great with the 9.4 setup. The post was mainly to recommend Accessories4less to anyone looking for used/refurbished gear.
glangford, JA Fant and zeuspaul like this.
MRAYB is offline
post #4 of 24 Old 02-05-2019, 02:06 PM
Bill-99's Avatar
Quoted: 989 Post(s)
Liked: 644
This is something I've been investigating of late. While this is not definitive, it may be of interest.
My sources are an Oppo 203 blu ray player and a home theater PC containing lossless rips in WMA format. The HTPC uses JRiver Media Center to play music. Both sources are configured to send BitStream to an Anthem AVM 60 processor. Source connections to the processor are both HDMI.
In comparing a CD played on the Oppo to the lossless rip played on the HTPC, I can't hear any difference. The Oppo supports playing music from a memory stick in a USB port on the back of the unit, so I thought perhaps hi-rez files might sound different. After loading some hi-rez files from HD Tracks onto a memory stick, I plugged that into the Oppo. Playing hi-rez from the Oppo or from the HTPC sounded the same.
I have not explored the analog outs from the Oppo and it's possible that this could impact sound quality.
5.1.0 System: Anthem AVM 60 | Anthem Statement A5 | Revel F208s, C208, M106s | Velodyne FSR-12 | Samsung UN65KS800DF | Oppo UDP-203 | Roku Premiere+ | DIY HTPC | Logitech Harmony Companion | Amazon Echo Dot
Bill-99 is offline
post #5 of 24 Old 02-06-2019, 03:08 AM
glangford's Avatar
Quoted: 790 Post(s)
Liked: 696
I too use an Oppo 203 as my CD source. I have all my HD tracks purchased high rez music and CD rips on 256 gb ssd based USB stick that I plug into the front usb port. I navigate the stick via the iOS media control app. Great solution. I use HDMI to my Anthem MRX-520 which is only used for two channel with my supercharged song towers. I use the analog to my burson audio headphone amp. I also have an Oppo 95 hooked up the same way, but navigating the 95 via an android app on a kindle fire (no iOS app for the 95). I have just finished re ripping all my CDs to ALAC (apple lossless). I usually then us XLD to convert to flac because the 95 will not read ALAC.
The analog of the 203 sounds really good through my burson audio headphone amp and my Sennheiser 800S headphones. It is almost indistinguishable to listening to my 95 the same way via it's two channel analog. To maximize the quality of the analog outs on the 203 there is a setting for sdif that needs to be set to maximum bit rate. I don't know why but Oppo claims this will provide the best analog out capability of the unit.
I haven't tested back to back usb vs disc spinning, but they should be indistinguishable. You are getting bit for bit the same thing either way. Disc spinning may be a bit more error prone to a 'error correction applied' rip, but I doubt it's noticeable. Plus Oppo is out of business and I won't be able to get another one, so I'm inclined to save wear and tear on the loader by doing music playback via usb and saving the mechanical disc spinning for movies. Hopefully this will help make my player last as long as possible. The only music disc I spin are SACDs.
MRAYB, Bill-99 and JA Fant like this.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #6 of 24 Old 02-06-2019, 07:06 AM
Bill-99's Avatar
Quoted: 989 Post(s)
Liked: 644
^Well, this may be your laugh for the day. I didn't realize until reading your post that there's a USB port on the front panel of the Oppo. Time to review the Oppo doc a little more closely!
I don't know which DAC Anthem uses in the MRX 520 but Anthem confirmed that the AVM 60 uses the AKM AK4458NV. That's the same DAC used in the Oppo 203. Short of implementation differences, the analog outs from the Oppo could sound pretty similar to those of the AVM 60 but that's just a guess. I need to find time to try the Oppo analog outs for a comparison.
According to the Burson web site, at least some of their products use Sabre DACs, which seem to routinely get accolades for high end quality. Which Burson product are you using? Have you compared Oppo-to-Burson sound to Oppo-to-MRX 520 sound? If so, how did they stack up?
JA Fant likes this.
Bill-99 is offline
post #7 of 24 Old 02-06-2019, 07:37 AM
DonoMan's Avatar
Quoted: 290 Post(s)
Liked: 215
It's not even slightly better. But what is better is the experience of just putting a disc in the player, pressing play, and relaxing - and not being tempted to keep changing the song. A better listening experience can make things sound better to you. That subjective experience affects how we humans perceive the audio even though scientific tests would show FLAC to be exactly the same quality. (And any modern DAC is fine.)
DonoMan is offline
post #8 of 24 Old 02-06-2019, 12:35 PM
glangford's Avatar
Quoted: 790 Post(s)
Liked: 696
My understanding is the MRX 520 uses the 4458VN DAC as well. I've never hooked the Oppo up to the Anthem via analog, just hdmi so I can't really compare. The dAC is the 203 sounds very good via the analog to my headphone rig and the combination of the 203 to 520 via hdmi is also very good. Audioholics found the 203 to sound almost as good as the 205 via analog, which is a plus given the 205 has the ESS 9038 PRO dac. The Burson I"m using doesn't have a DAC its just a pure class A headphone amp. It's the Soloist MKII. So when listening to headphones I'm using the Oppo AKM 4458VN DAC. My Oppo 95 has a ESS 9018 and it's hard to tell a difference with the AKM 4458VN in my 203 via headphones. It might be a tad smoother, but that is not a blind test. Suffice it to say the analog implementation in the Oppo 203 is quite good.
JA Fant likes this.
post #9 of 24 Old 02-06-2019, 01:15 PM - Thread Starter
MRAYB's Avatar
Quoted: 372 Post(s)
Liked: 883
Exactly, DonoMan. The usb with all the cd's going through the Denon is great, don't get me wrong. Like I said , had been years since I went through the "process" with a cd. Put in 5, hit random, go about your life around the house. What also makes it "sound" better, I believe, is that you think you got a good deal on the piece. Part of the fun is getting people to pick out a few cd's to play. They look through the collection, tell stories about certain discs and "wow you got that", if they are actually looking at something. Way better than just streaming, or me hitting enter for a track or disc on usb.
MRAYB is offline
post #10 of 24 Old 02-06-2019, 01:25 PM - Thread Starter
MRAYB's Avatar
Quoted: 372 Post(s)
Liked: 883
I believe it's called human interaction. Me and girl went out for pizza at Godfathers(awesome) the other night. Maybe ten couples there on a date night younger than us(almost 50yrs old). We were the ONLY ones who did not have a phone plastered to their face. Really sad. Nobody talking, just pointing and clicking...
MRAYB is offline
post #11 of 24 Old 02-10-2019, 11:32 AM
thetman's Avatar
Quoted: 534 Post(s)
Liked: 291
I've been on a tear lately with cds mostly ( some sacds and multichannel too). Not into vinyl ( maybe someday- who knows). Also have a large digital collection. Using an oppo 103 and Emotiva ERC-3.
ID:	2523506   Click image for larger version
ID:	2523508   Click image for larger version
ID:	2523510   Click image for larger version
JA Fant and MRAYB like this.
thetman is offline
post #12 of 24 Old 02-10-2019, 02:59 PM
Quoted: 56 Post(s)
Liked: 115
Not even slightly worse, either.
Panson, JA Fant and MRAYB like this.
Graustark is offline
post #13 of 24 Old 02-10-2019, 03:03 PM
Quoted: 56 Post(s)
Liked: 115
This Modern Age.
I used to be able to go to someone's house and, by looking at their music collections, wall art, and bookshelves, be able to get an idea of the person.
Between streaming, Kindles and tablets, it's impossible to tell anything now. And people don't look at wall art anymore. They just look at their phones.
post #14 of 24 Old 02-10-2019, 03:19 PM
JA Fant's Avatar
Quoted: 562 Post(s)
Liked: 1442
Thanks! for sharing and welcome back to CDs. Those cd players made in Japan still hold up well.
Unfortunately, eBay will allow anyone to sell anything...
Panson likes this.
JA Fant is offline
post #15 of 24 Old 02-11-2019, 01:31 AM - Thread Starter
MRAYB's Avatar
Quoted: 372 Post(s)
Liked: 883
Originally Posted by Graustark View Post
This Modern Age.
Yes Graustark. I am almost 50(???) now. Have a younger coworker(late 20's) that will NOT stop bugging me about getting a 10inch tablet. Like my life is incomplete without one. "But you can watch movies on it", he says. "What the hell do you think that big ass Samsung in my living room is for". I say. "But you can watch them at lunch in your car". "Lunch is for a couple smokes, eating and relaxing" is my reply. I just don't get it.
Walk into my house and the first things you will see are a few of my prized collection..
Would this give you a little hint as to the type of person I am....lol
(BEFORE he added "RAY")
MRAYB is offline
post #16 of 24 Old 02-12-2019, 12:20 AM
Quoted: 56 Post(s)
Liked: 115
True, that.
Everywhere I see people standing around in public, they're all glued to a screen. They don't interact at all.
Depressing, actually.
yanks1, MRAYB, Panson and 1 others like this.
post #17 of 24 Old 02-12-2019, 09:48 AM
Quoted: 1031 Post(s)
Liked: 2593
Thank you OP for this thread. More will be discovering and rediscovering CD advantage. Including discs that've been gloriously remastered. That's a big deal because Masters may not be available some day.
I won't disparage youth and their listening, reading, talking, loving habits. The important thing is sustaining the Arts. Remember, too, many from this demographic have discovered vinyl. Next step could be CD.
Graustark and JA Fant like this.
Panasonic TC65CX850U Yamaha RX-V1079 Technics SU-V650 Panasonic DMP-UB900 Sony UBP-X800 Polk Audio SDA-2B
"I watch a lot of movies, I know what I'm doing." - Daniel Lugo
Panson is offline
post #18 of 24 Old 02-12-2019, 11:27 AM - Thread Starter
MRAYB's Avatar
Quoted: 372 Post(s)
Liked: 883
Panson friend, I would LOVE to get back into vinyl. Just can't pull the trigger right now. Was brought up on it. I was kinda in between. I owned a few records when younger. First one was "Rock 80", wore it out! Never owned an 8 track. Had a few cassettes, mostly made my own "mix tapes". Then was there at the start of cd's. Used to belong to a couple of the clubs where you could get a box full for 1cent..lol. Nowadays it is just kinda BLAHH. When I retire in about ten years, I am going back to step 1-vinyl.
Panson and JA Fant like this.
MRAYB is offline
post #19 of 24 Old 02-12-2019, 01:05 PM
Liked: 2593
I wish you well. I love retirement, and I loved vinyl for many years. Sound, feel, smell, everything. Eventually, I found storage, cleaning, and what would be serious equipment upgrade to the next level, all counterproductive. Leaving it behind became easier as life downsized and CD remastering improved.
When you re-pull the vinyl trigger, you'll probably find it easier, as in discrete collecting and listening. Enjoy.
MRAYB and JA Fant like this.
Panson is offline
post #20 of 24 Old 02-13-2019, 12:43 PM - Thread Starter
MRAYB's Avatar
Quoted: 372 Post(s)
Liked: 883
Thank you for the warm wishes. I was the "DJ" back in the 70's when mom and dad wanted a record loaded for the house parties. Elvis, Supremes, Tom Jones, The Carpenters....loved those days. EVERYBODY drinking and smoking, playing cards, having a good time talking and laughing. No cellphones. Maybe that is why I long for them again now that I am their age NOW. Take care, bringing back some great memories.
Panson, JA Fant and Graustark like this.
MRAYB is offline
post #21 of 24 Old 02-16-2019, 11:14 AM
Quoted: 1066 Post(s)
Liked: 871
I’m doing both; playing some of my 400+ CDs more often lately. And also back into Vinyl, just purchased my 2nd Turntable this week ; First one was last January
Panson, MRAYB and JA Fant like this.
Primary set-up 5.2.4; Yamaha A2050, Paired w/Parasound P5 & ATI 522NC 2 channel amp
Revel F206 fronts & Revel M16 rears; 2 Outlaw X12 Subs & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #22 of 24 Old 03-03-2019, 12:18 PM
Quoted: 20 Post(s)
Liked: 9
Drop a high speed DAC into the equation and use your old CD’s digital out and rediscover CD’s all over again. Unless you’re rocking an Esoteric or a dCS, those legacy DACs don’t age well.
JA Fant likes this.
Milliron is offline
post #23 of 24 Old 03-03-2019, 01:11 PM
Quoted: 56 Post(s)
Liked: 115
What amazes me about legacy DACs (and I'd like to have one or two of my old faves, though that's probably more nostalgia and curiosity than anything else) is the prices people are asking. On eBay, I see old Wadias and Thetas going for thousands, when a Topping D30 goes for pennies and will outperform any of the legacies.
Certainly, those old high-enders were built like tanks and were aesthetically stunning. A Theta DS Pro Gen Va makes for a more impressive visual presentation than the Topping, which looks like the box you keep your extra car keys in. But I notice a lot of these eBay offerings also get relisted a lot when no one wants to meet the asking price. Or the second asking price. Or the third...
JA Fant likes this.
post #24 of 24 Old 03-03-2019, 01:55 PM
blu ray boy's Avatar
Quoted: 39 Post(s)
Liked: 27
For some reason I thought this thread would be about switching from records to cd's. Interesting though. I have a large collection of cd's and records too. If anything ever happened to them I would be lost. I have ripped all the cd's to lossless flac and am in the process of uploading all my music to the cloud. At least I will have that if anything bad happened to my collection, such as a catastrophic fire or something. Anyways I listen to mostly cds these days (I am 48) although I dabbled in records for a while (too much work keeping them clean). I grew up spinning records and never remember having to clean them like I do now-a-days.
I listen to my digital collection on a NUC PC and a Yggydrasil dac to my amp and speakers. Sounds great to me. I rip all my cds with eac to flac and I doubt there is a sound quality difference between that and playing them back from a spinning disc, all things being equal like the dac, etc. I find the convenience of being able to access my library from my couch without changing discs to be worth the effort to rip them. So that's my two cents.
JA Fant likes this.
blu ray boy is offline
Reply CD Players & Dedicated Music Transports
