HiFi Digital Audio Player (DAP) Options - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By 2WheelsWillTravel
  • 1 Post By lucser
  • 1 Post By lucser
post #1 of 16 Old 02-24-2019, 07:13 PM - Thread Starter
spec1alk's Avatar
Quoted: 42 Post(s)
I struggled with what is the appropriate forum for this post. I could see it going into the 2-Channel Audio forum because that tends to be more geared towards hi-fidelity audio, or Networking, Media Servers & Content Streaming because my topic is about DAP. I opted for here. I apologize if it is not appropriately placed.
I have a library of 16 and 24bit FLAC files. I would like to have the ability to play these with a portable device.
I have been looking at a DIY option by building something on the Raspberry Pi platform combined with HiFiBerry (or something similar). The challenge with this, is that the UI for the player would effectively be my phone, and this could be troublesome when in an area where we have a stereo but no WiFi.
I also have a couple old phones (iPhone 7 and a Samsung Galaxy S3) that I wouldn't mind using as the UI for the player, but I don't know how to set these up to be able to play the 24bit FLAC files without them being down-sampled to 16bit. Could I buy an external DAC?
I know there are also personal audio players that can do this, but most of those are $400 or more (several being over $900).
My requirements are:
  • Play 24bit FLAC files without down-sampling them to 16bit
  • Analog out via RCA (does not need to be amplified)
  • UI that does not require WiFi (Bluetooth would be acceptable)
Nice to have:
  • Nice to have SP/DIF or Optical/Toslink
  • Battery powered
I am looking for advice on what my options are and where I can get the most value. Is going the Raspberry Pi route the best value? Or can I pair a DAC with one of those phones? What is the pro/con of each of these options? Am I chasing the wrong approach and should just save up and buy one of the commercial options?
Budget of under $200, and I would like to keep it closer to $100 to try it out. If this works out well, I may end up further investing in an upgrade down the line.
spec1alk is offline
post #2 of 16 Old 02-25-2019, 01:24 PM
mlknez's Avatar
Quoted: 635 Post(s)
Liked: 214
An external DAC would be the easiest and cheapest bet. There are several <$200 models that you can buy new or even more that are available on the used market.
It depends upon the format, bit depth and sampling rate of the files that you wish to play.
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #3 of 16 Old 02-25-2019, 09:11 PM - Thread Starter
spec1alk's Avatar
Quoted: 42 Post(s)
I would like to be able to play SACD ISO's, FLAC, and possibly ALAC. Bit depth of FLAC & ALAC will be 16bit to 24bit, and 44.1khz to 192khz. I am not sure what the bit depth and sampling rate of SACD's are, they seem to report something about 5Mhz.
I will be playing very few MP3 files.
spec1alk is offline
post #4 of 16 Old 02-26-2019, 03:39 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 502 Post(s)
Liked: 16176
Phone/Tablet with SD card and external DAC. Some great examples later on in this thread. Use headphones or connect to preamp. Unfortunately, it looks like a lot of DanBa's pics are unavailable. But name model are still there. And there's probably newer things availble which you'll probably run into if you start tracking down some of the things mentioned.
If a cannibal eats a clown, will it taste funny?
PooperScooper is offline
post #5 of 16 Old 02-26-2019, 03:41 AM
Roseval's Avatar
Quoted: 87 Post(s)
Liked: 54
In the past I couldn’t get USB audio to work on Android as my DAC is 24 bit.
Using Oreo (Android 8) it worked.
Never verified what happened under the hood but at least it sends 24 bits to the DAC.
So you need something with recent Android.
They say an iPhone with a camera kit also works, don’t know what sample rate and bit depths are supported.
Bluetooth is IMHO not an option as it is lossy (say high bitrate MP3)
A PI is a cheap solution.
Either combine it with a HAT or a USB DAC
Control by phone requires WiFi
If WiFi is not an option, add a screen and mouse/keyboard
Maybe this one gets you started: http://archimago.blogspot.com/2018/
Roseval is online now
post #6 of 16 Old 02-26-2019, 03:45 AM
Moderator
Moderator
Quoted: 502 Post(s)
Liked: 16176
Android 5.0 Lollipop and above supports USB audio.
post #7 of 16 Old 02-26-2019, 09:31 AM - Thread Starter
spec1alk's Avatar
Quoted: 42 Post(s)
I think my Galaxy S3 only has Android 4.x.
Not sure it makes sense to pursue the iPhone 7 option if it doesn't support the full bit depth and sampling rate.
The main goal in using one of my older phones as the "player" was it would provide a screen/gui without the need for WiFi to control the RPi.
Thanks for the link Roseval. Will take a look.
spec1alk is offline
post #8 of 16 Old 02-26-2019, 03:14 PM
Quoted: 157 Post(s)
Liked: 213
Wherever the Pi is located you will have WiFi. The Pi can generate its own WiFi hotspot, that you can then connect directly to with your control device of choice. It's not dependent on a home network WiFi (router) to function.
2WheelsWillTravel is offline
post #9 of 16 Old 02-26-2019, 06:04 PM - Thread Starter
spec1alk's Avatar
Quoted: 42 Post(s)
This may be the best option for me then.
spec1alk is offline
post #10 of 16 Old 02-26-2019, 06:14 PM - Thread Starter
spec1alk's Avatar
Quoted: 42 Post(s)
Any thoughts on the DAC? Is the one from HiFiBerry good? Or should I look at others?
spec1alk is offline
post #11 of 16 Old 02-26-2019, 09:20 PM
Quoted: 157 Post(s)
Liked: 213
The HiFiberry DAC is fine, I've been using their DAC+ Pro (RCA) for a while now without issue. If you want digital out instead, they have the Digi+ They also sell cases to house everything. For player software I'm running Volumio, I haven't messed with any of the others. It's free to use if all you're doing is playing your own files.
lucser likes this.
post #12 of 16 Old 02-27-2019, 02:08 AM
Moderator
Moderator
Quoted: 502 Post(s)
Liked: 16176
A used S4 with Lollipop is around $75.
post #13 of 16 Old 03-03-2019, 03:02 AM
Roseval's Avatar
Quoted: 87 Post(s)
Liked: 54
Maybe:
https://www.audiosciencereview.com/f...y-pi-dac.4529/
https://www.audiosciencereview.com/f...-pi-dacs.4164/
post #14 of 16 Old 03-09-2019, 05:02 PM
lucser's Avatar
Liked: 4
Rpi or equivalent
Hi,
If something as Rpi solution is attractive there are many options. HifiBerry is one, I think the cheapeast but good enough. Depending what you want (only analog output or digital also) Allo site have several better ones as Digione, Boss DAC, Katana Dac... . Also Pi2Design has the very good 502DAC that provide both analog and digital out. The Pi2Design are built in small batches so if is out of stock just send an e-mail to check next batch availability.
natchie likes this.
lucser is offline
post #15 of 16 Old 03-09-2019, 05:08 PM
lucser's Avatar
Liked: 4
I’ve used Hifiberry and 502DAC (currently the last one) with Volumio and Moode Audio and I’m very happy with the setup. I use it mainly on AES digital out to my dac but as said it has also analog output.
Volumio offers a wifi hotspot setup so could be used as portable where no wifi available.
Also you could learn many things and you can upgrade it in future with more feaures (e.g. on diyaudio is a very nice IsolatorPi board offered on IanCanada Group buy for 49USD or FIFOPI board 99usd providing both isolation and reclocking).
Highly recommended.
natchie likes this.
lucser is offline
post #16 of 16 Old 02-10-2020, 04:00 PM
Jaywalker1's Avatar
Quoted: 103 Post(s)
Deleted
Jaywalker1 is offline
Reply CD Players & Dedicated Music Transports
