CD player for an old Technics amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-01-2019, 11:55 AM - Thread Starter
zorro21's Avatar
I'm putting together an old-school "system". For an amp I have a Technics SU-V2 and i'm slowly adding more components to it. Since this amp is from the early 80s it does not have an optical input (analog only) as such does not have any DACs.
What would be the best way to go about getting the best sound out of a CD player from this amp?
Option 1: Buy a CD player and connect via RCA (use the CD player's DACS)
Option 2: Buy CD player/transport and DAC and connect via optical then RCA to amp
If I go option 1, what would be a good CD player that contains good DACs?
If I go option 2, what would be a good CD transport + DAC?
Truth be told, I don't want to spend a lot of money given that I haven't spend much so far to put this system together.
Currently have:
Amp: Technics SU-V2
Tuner: Technics ST-S3
Cassette deck: Technics M222
EQ/Space dimension controller: Technics SH-8040
Turntable: Fluance RT82
Speakers: PSB 40 MKII
zorro21 is offline
post #2 of 4 Old 05-02-2019, 02:33 AM
glangford's Avatar
Quoted: 708 Post(s)
Liked: 626
If you don't want to spend a lot of money then I'd recommend a cheap dvd or blu ray player using optical to a dac. You can get a fairly cheap dac that is pretty decent. I'd try Schiit dacs.
You didn't say what your budget was.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #3 of 4 Old 05-02-2019, 04:50 AM - Thread Starter
zorro21's Avatar
Thanks for the reply!
ah yes budget! I don't mind spending some $ but i just don't want to spend more than what my amp can actually take advantage of.
Also, i'll be honest, looks matter ha! All my stuff is silver machined faced so ideally a silver faced CD from late 80s/90s with good DACs or maybe a nice looking silver CD player from that era and a DAC. I don't want blu ray/DVD, striclkly a CD player.
Let's say under $200?
zorro21 is offline
post #4 of 4 Old 06-30-2019, 09:20 AM
Quoted: 538 Post(s)
Liked: 1232
Originally Posted by zorro21 View Post
Let's say under $200? Thanks!
Onkyo C-7030
Teac CD-P650
Related info:
https://www.onkyousa.com/product/hi-...layers/c-7030/
https://www.teac-usa.com/cd-p650/
Note: Some specs say the Onkyo weighs 15 lbs. That may be shipping weight. Others say 11.7 lbs for the unit. I'd go with 11.7 lbs.
The Teac weight is 8.8 lbs.
Panasonic TC65CX850U Yamaha RX-V1079 Technics SU-V650 Panasonic DMP-UB900 Sony UBP-X800 Polk Audio SDA-2B
Panson is offline
Reply CD Players & Dedicated Music Transports
