SACD player for Yamaha RX-A1080 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-04-2019, 10:07 AM - Thread Starter
Hi,
I have just purchased a new Yamaha RX-A1080 receiver for my home theater and I need some help selecting a DVD or Blu-Ray player that will output SACD and DVD-Audio over HDMI.
I am going from an old Marantz SR5005 receiver which had a 5.1 analog input that I used from my old Pioneer Elite DV-59avi. The Yamaha doesn't have a 5.1 or 7.1 analog input so I would like to find a player that will output multichannel SACD and DVD-Audio over HDMI. I don't care if the player is new or used, just that it allows me to listen to all of my multichannel SACDs and DVD_Audio discs.
Can you provide some recommendations for a player that will meet my requirements?
Mark Foley is offline
post #2 of 10 Old 05-04-2019, 10:50 AM
MNSACD's Avatar
Originally Posted by Mark Foley View Post
Hi,
Hello,
I recently helped a friend of mine install some new home theater gear he had purchased. He bought the Sony UBP-X800 universal player. We hooked it up to his Onkyo receiver via HDMI. We listened to CD's, SACD"s, and a DVD-Audio. I thought it sounded great and the user interface was simple to use and navigate. Build quality was pretty good as well. So maybe that is one to consider.
https://www.sony.com/electronics/blu...ayers/ubp-x800
MNSACD
MNSACD is offline
post #3 of 10 Old 05-05-2019, 03:59 AM
glangford's Avatar
Quoted: 722 Post(s)
Liked: 644
Hi,
There aren't many options in the market anymore for universal players with Oppo out of the market. The sony x800 suggested is the cheapest option. It's main drawback is no front panel display. (they assume you'll use a monitor with it.) The next step up is the Sony X1000es, which has a front panel display and also an analog fr/fl RCA connection. The x1000es has a 3 year warranty instead of the 1 for the x800. The x1000es is 499, the x800 299.
You mention home theater. Will this player also spin movies? If so you might consider waiting until the second generation players (X1100es and x800m2) come out with Dolby Vision, of course there won't be a discount available when first released, which would put the x1100es at probably 699 instead of the discounted x1000es at 499. I didn't see any discounts of the x800 out there, and supplies will be dwindling down with the newer version m2 coming out soon.
The next option is the Pioneer LX-500. A universal player at 999 bucks. Built like a tank. Has analog FR/FL connections in addition to HDMI.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #4 of 10 Old 05-05-2019, 07:47 AM - Thread Starter
Thanks for the advice guys. I noticed you both mentioned the Sony UBP-X800 but didn't mention the UBP-X700. It sounds like the 700 has Dolby Vision. Will it work for both SACD and DVD-Audio over HDMI?
post #5 of 10 Old 05-05-2019, 10:48 AM
MNSACD's Avatar
I checked on Sony's site and the X700 supports SACD and DVD-A over HDMI.
MNSACD
MNSACD is offline
post #6 of 10 Old 05-06-2019, 01:56 AM
glangford's Avatar
Quoted: 722 Post(s)
Liked: 644
MNSACD
It's my understanding that the x700 does not support dvd-a.
Edit: confirmed in the X700 thread. Also from the Sony website from the x700 page. Disc Format:
BD-RE, BD-RE Dual Layer, BD-ROM, CD (CD-DA), CD-R/-RW, DVD+R, DVD+R Double Layer, DVD+RW, DVD-R, DVD-R Dual Layer, DVD-RW, DVD-Video, SA-CD (SA-CD / CD) Playback, Stereoscopic 3D (profile 5), Ultra HD Blu-ray™
there is no DVD-A in the list.
post #7 of 10 Old 05-06-2019, 02:02 AM
glangford's Avatar
Quoted: 722 Post(s)
Liked: 644
No the X700 does not do DVD-A, you have to get the x800 or newer x800m2 for that.
From Sony's website. List of disc formats for the x800m2:
Ultra HD Blu-ray, BD-ROM, Stereoscopic 3D (profile 5), SA-CD (SA-CD / CD) Playback, DVD-Video, DVD-Audio, DVD-R, DVD-RW, DVD-R Dual Layer, DVD+R, DVD+RW, DVD+R Double Layer, CD (CD-DA), CD-R / -RW
post #8 of 10 Old 05-06-2019, 06:06 AM
MNSACD's Avatar
Yes, I stand corrected. I looked again and it does not do DVD-A.
MNSACD
MNSACD is offline
post #9 of 10 Old 05-23-2019, 09:28 AM
eljaycanuck's Avatar
Quoted: 1891 Post(s)
Liked: 2651
OPPO OP-DV980H. There's one listed on eBay.com for just under $130, shipped. Does SACD and DVD-A over m-c analogue and HDMI.
eljaycanuck is offline
post #10 of 10 Old 07-08-2019, 03:30 PM
Quoted: 95 Post(s)
Liked: 122
Sony X800 is your best bet IMO.
Projector: LG PF1500W; Receiver: Sony STR-DN1080; Speakers: Monitor Audio Controlled Performance Inwalls and Inceilings; Subwoofer(s): SVS PC-2000; Bluray Player: Sony BDP-S6500; Remote: Roomie Remote; Cables: Monoprice
rnatalli is offline
Reply CD Players & Dedicated Music Transports
