AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   CD Players & Dedicated Music Transports (https://www.avsforum.com/forum/153-cd-players-dedicated-music-transports/)
-   -   Record Player (https://www.avsforum.com/forum/153-cd-players-dedicated-music-transports/3067198-record-player.html)
StrifeX 05-12-2019 11:41 AM
Record Player
1 Attachment(s)
High everyone. My fantastic wife got me my first record player as a gift, but I need a little help. I have a receiver that I am attempting to connect it to via rca, but when I use the phono input on the receiver it sounds awful, staticy, super loud and too much bass. If I use a different stereo input it sounds clean and normal, but there is absolutely no bass. I suspect that part of the issue is that it may have a built in preamp. Any help would be great. The receiver is a pioneer vsx-lx303. I posted this in receivers as well, because I'm not sure where the issue is. Thanks.
Class A 05-12-2019 04:37 PM
Are those two round objects on your TT built in speakers??:)
markmanner 05-12-2019 04:48 PM
What you have doesn't have a line output or output for a phono input. The outputs are for connection to a PC or to external speakers, presumably using the internal amplifier that your record player has. That is why it doesn't sound right into a line level input on your receiver. If your receiver has a Bluetooth input, then you could use that method, but I haven't checked your receiver to know.
holl_ands 05-13-2019 04:17 PM
It sounds LOUD and TOO MUCH BASS when plugged into PHONO Input because your Turntable has a CERAMIC PHONO CARTRIDGE, which provides standard "LINE LEVEL"...and doesn't NEED a Preamp or any additional RIAA Equalization....which is MOSTLY cutting the Mid and High Freqs:
http://sound.whsites.net/project06.htm
Specs confirm this....yup it's a CERAMIC PHONO CARTRIDGE with Output Voltage = 300 mV [approx. LINE LEVEL], shown in picture driving a set of POWERED Speakers (e.g. typical PC Speakers)...which is also compatible with Pioneer's 4 ea LINE LEVEL Inputs:
[PS: I think they made a typo...should read "LINE IN = 500 mV".]
http://techvibo.com/product/jopostar-bluetooth-vinyl-turntable-record-player-lp-3-speed-belt-driven-with-built-in-stereo-speakers-aux-input-rca-output-natural-wood
https://www.google.com/imgres?imgurl...act=mrc&uact=8
Since your Turntable has a LINE LEVEL Output, you should plug the Turntable's RCA Jacks directly into one of the adjacent "AUDIO IN" RCA L/R Inputs....your choice which one.
https://www.pioneerelectronics.com/e...180418_web.pdf
If you provide the mfr and model number of your Ceramic Phono Cartridge, we can direct you to specs and where you can buy a replacement STYLUS (aka Needle)....which likely needs to be changed....
Ceramic Cartridges typically track at MUCH higher weights [typ. 4-6g] than modern MM or MC Cartridges [typ. 1-2g], which is one reason they have a bad reputation of SHREDDING pricey Vinyl Records [also shape of the Diamond]....but you'll have to investigate whether your Turntable can be adjusted down to as low as 1-2g of tracking force if you decide to "upgrade" the entire Phono Cartridge. Pioneer VSX-LX303 has a "PHONO" Input which will accept low-level signals from a MM (Moving Magnet) type Cartridge. [I did not readily find Instructions for the Japostar TT.....nor did I research as to WHICH Ceramic Replacement Cartridge MIGHT be any "better".]
And as explained on pg51 in the Manual, you would need to use some sort of "Equalizer" [e.g. MC-MM Transformer] if you are using a MC (Moving Coil) type Cartridge:
https://www.reddit.com/r/vinyl/comme..._they_work_and
http://www.axetalk.com/forum/guitar-...-magnetic.html
StrifeX 05-13-2019 08:12 PM
https://www.youtube.com/watch?v=cqICKEisoBw
Thank you so much for the information! I really appreciate it, as I was having some trouble finding information. You are awesome!
StrifeX 05-13-2019 09:53 PM
These are the cartridges they offer as replacements. If I understand correctly, I would not be able to change it to a magnetic (which sounds better) cartridge, right?
holl_ands 05-14-2019 09:33 AM
You forgot to post Ceramic Cartridge model number(s).....
Alex F. 05-14-2019 05:54 PM
If it is not too late to return the turntable to the dealer, I suggest obtaining a normal hi-fi unit. That is, a turntable that utilizes a magnetic (moving-magnet, also called "MM") phono cartridge and has outputs intended to be connected to a hi-fi component, such as your receiver. You can then use your Pioneer's phono inputs. You do not need to purchase a turntable that has its own built-in phono preamp because the Pioneer already includes one, as you know.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
