Dedicated CD Player Recommendations? - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By smdelaney
  • 1 Post By Muphasta
  • 2 Post By glangford
post #1 of 20 Old 09-03-2019, 12:32 PM - Thread Starter
smdelaney's Avatar
Quoted: 178 Post(s)
Liked: 92
I have several hundred CDs I want to continue to be able to to play but my current CD changer is no longer reliable (Onkyo DX-C390). I want to replace it with a single disc player...what are folks recommending that's on the market these days (2019)?
I DON'T need a universal player.
I DON'T need network or USB playback
I DO need analog out and prefer both Optical and Coaxial Digital out (but can live with just one or the other).
Analog out is needed due to a limitation with my AVR that only permits analog content to pass to zone 2 and/or my HEOS speakers, otherwise I'd rely 100% on my BD player. Basically I want a simple, reliable player for when I just want to throw on an album and listen to it from start to finish. The ability to program a selection of tracks would be a plus.
The Yamaha CD-S300 looks pretty good to me and runs about as much as I'd like to spend. What are other folks using and what recommendations do you have?
"You keep using that word...I do not think it means what you think it means."
-Steve-
TCL 55R617, Denon AVR-X2400H, Philips BDP-7502, Onkyo DX-C390, (2) HEOS 3HS2's,
Cambridge Soundworks Ensemble (FR/FL), MC150 (C), S100 (SR/SL), KLH E-12DB (SW)
smdelaney is online now
post #2 of 20 Old 09-03-2019, 12:36 PM
lizrussspike's Avatar
Quoted: 1240 Post(s)
Liked: 1843
What is your budget @smdelaney
lizrussspike is offline
post #3 of 20 Old 09-04-2019, 01:49 PM
Quoted: 1034 Post(s)
Liked: 820
I was in same position earlier this year, many stated the Onkyo C-7030 was solid good value choice with a good Processing chip. I purchased it & been very pleased
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 522NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #4 of 20 Old 09-05-2019, 02:09 AM
glangford's Avatar
Quoted: 728 Post(s)
Liked: 646
Look up Crutchfield's site. Several options for 499 or less that can do what you want. I'd be partial to Marantz.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #5 of 20 Old 09-05-2019, 05:37 AM - Thread Starter
smdelaney's Avatar
Quoted: 178 Post(s)
Liked: 92
Thank you for all of the feedback....
@lizrussspike ... my budget is +/- $300
@yanks1 ... I saw reviews for the Onkyo and it is definitely a contender but for the multiple stories of it [email protected] out 1-2 months past the end of the warranty. That and I've had a less than stellar experience with Onkyo in general (my last AVR was an Onkyo and only lasted 6 years and the CD changer died shortly after that).
@glangford ...Crutchfield is my go-to site for feature comparisons and reviews, then I usually hit Amazon for additional <verified> user reviews. Plus I look at the total # of reviews (and within each rating level) to weight the reliability of the overall rating.
I DO like the Marantz CD5005 and it would integrate nicely with my Denon AVR but it costs more than I would like to spend.
The NAD C538 is a possibility...simple interface (can easily operat without the remote), but again, a little more than I would like to spend.
I am leaning towards the Yamaha CD-S300 as a reliable brand at a reasonable price. I simply can't justify paying much more than what this costs for something that is only going to see limited use.
yanks1 likes this.
-Steve-
post #6 of 20 Old 09-05-2019, 07:56 AM
Liked: 1843
Roger that @smdelaney, sounds like you have what you want/need in the Yamaha CD-S300. I was going to suggest one of the OPPO's but they are a few $$$.
post #7 of 20 Old 09-05-2019, 08:20 AM
Jawaburger's Avatar
Quoted: 206 Post(s)
Liked: 202
Cambridge Audio and NAD both make CD players in the price range, I believe.
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | Phase Tech PC 9.1 (FL/FR) | Phase Tech PC 3.1 (C/SL/SR) | Dual PSA S1811 Subs
Jawaburger is offline
post #8 of 20 Old 09-05-2019, 11:20 AM - Thread Starter
smdelaney's Avatar
Quoted: 178 Post(s)
Liked: 92
I was actually saving up to splurge on the Oppo 203 and then they bailed on the market. Even with the feature overkill I could have justified the expense given that I wouldn't need to spend $$ on separate CD/4K UHD BD players. In the end I upgraded the TV (TCL) and BD (Philips) a few months earlier than I would have if the Oppo had still been in production.
So now I'm leaning towards the Yamaha. As @Jawaburger noted NAD and Cambridge Audio are contenders albeit a little more expensive.
-Steve-
post #9 of 20 Old 09-05-2019, 11:26 AM
Pete7874's Avatar
Quoted: 300 Post(s)
Liked: 183
I have an old Yamaha CDC-905 5-disc carousel. If it dies and I still need to play CDs, I'd be looking at that CD-S300 as well - $300 new or $220 refurb on A4L. Historically, Yamaha's lasers have been top notch - they would read all kinds of scratched CDs while other players (looking at you, Sony!) would get stuck. Hopefully this CD-S300 is no different in that respect.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is online now
post #10 of 20 Old 09-05-2019, 11:45 AM
Muphasta's Avatar
Quoted: 253 Post(s)
Liked: 214
I hit up Goodwill about once a month and pick up most CD players I find there. The majority are Sony 5 disc changers, which you stated that you don't need, but for $10, they are hard to beat. The majority do have analog and both optical and coax digital output. Only negative is lack of a remote, which you can find on-line easily enough.
I know that isn't a specific recommendation, but all of the units I've picked up work well and sound great. I've put them in both of my sons' rooms, and I have about 8 connected in my garage. I found a very nice Yamaha 5 disc changer at a swap meet for $10 and that is what I currently use in my main TV room.
hard to beat the $10 options (when found) at Goodwill.
Have I mentioned that I'm a cheap ass?
cardoski likes this.
Vinyl, tape, digital... I don't care as long as I can listen to my music...
Muphasta is offline
post #11 of 20 Old 09-05-2019, 12:51 PM
Liked: 1843
smdelaney I want that TV and is on my radar. What about a OPPO 103, I know I could play my SACD's on it, and you could probably find one for less than $300.
post #12 of 20 Old 09-05-2019, 04:53 PM
Liked: 0
Yamaha CD-S300 and a couple up level Marantz/Denon are at Accessories4less. Usually factory refurbs; the Marantz/Denon(s) often have 3 year warrantys. And yeah good deals to be had. Your 5005 is your price there. I'll probably buy the CD-s300 from them myself. Heard it at a friends and it matches up with my Yamaha receiver for days I just wanna play CDs.
Just realized A4L is already quoted above. Sorry to duplicate!
caz33 is offline
post #13 of 20 Old 09-06-2019, 03:21 AM
glangford's Avatar
Quoted: 728 Post(s)
Liked: 646
The Marantz CD5005 is 299 at accessories4less.com and comes with a three year warranty,
lizrussspike and cardoski like this.
post #14 of 20 Old 09-06-2019, 04:03 AM
Liked: 1843
Sounds like a winner that @glangford found.
post #15 of 20 Old 09-17-2019, 11:50 PM
Ryan Statz's Avatar
Quoted: 473 Post(s)
Liked: 257
Cambridge Audio CXC or AXC35
https://www.cambridgeaudio.com/en/products/cx/cxc
https://www.cambridgeaudio.com/en/products/ax/axc35
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is online now
post #16 of 20 Old 09-21-2019, 11:26 AM
Alex F.'s Avatar
Quoted: 902 Post(s)
Liked: 516
Originally Posted by Ryan Statz View Post
The Cambridge CXC is a transport only, thus it has digital outputs only but not an analog output as required by the OP.
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is offline
post #17 of 20 Old 09-21-2019, 11:42 AM
Ryan Statz's Avatar
Quoted: 473 Post(s)
Liked: 257
And it's why I also cited the AXC35, which has digital coax/S/PDIF and regular RCA outputs.
post #18 of 20 Old 09-21-2019, 12:05 PM
Alex F.'s Avatar
Quoted: 902 Post(s)
Liked: 516
My concern was that the OP might purchase the CXC without realizing it was not suitable for his needs.
Also, I noticed a minute ago that the AXC35 is not ideal for him either as he prefers to have both coaxial and optical outputs. Unfortunately, the AXC35 does not have an optical output.
Alex F. is offline
post #19 of 20 Old 09-21-2019, 12:14 PM
Ryan Statz's Avatar
Quoted: 473 Post(s)
Liked: 257
I would think that the OP has the wherewithal to take the time to look at the links/specs before buying anything.
He did say he could live with either digital coax OR optical if both weren't available. It has digital coax, which is perfectly fine. And it has the analog out.
post #20 of 20 Old 09-21-2019, 03:19 PM
Alex F.'s Avatar
Quoted: 902 Post(s)
Liked: 516
We obviously have different ways of suggesting products.
I try to find ones that satisfy all stated requirements, if possible. If my suggestions do not do so, I will mention how they fall short. In this thread, for example, I would not suggest a CD transport to someone who obviously needs a CD player and then hope he finds out prior to making a purchase that it is not a player. I would feel horrible if I caused him to buy the wrong product.
Alex F. is offline
Reply CD Players & Dedicated Music Transports
