Connect Blu ray Player's SACD player to AV receiver by hdmi or analog out? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-18-2019, 10:18 PM - Thread Starter
Rysa_105's Avatar
Quoted: 105 Post(s)
How do i know which will sound better with SACD playback, or will it be dependent on the DAC quality? My AV receiver (onkyo rz3100) says a AKM 32bit/384kHz DAC, i dont know what DAC the blu ray player (sony) has but it supports SACD playback and has both hdmi and analog outputs. So how should i connect it to the AV receiver for best sacd sound quality?
Rysa_105 is offline
post #2 of 6 Old 10-18-2019, 10:21 PM - Thread Starter
Rysa_105's Avatar
Quoted: 105 Post(s)
I mostly use stereo playback, because i prefer 2 channel sacd to 5.1, with multichannel sacd's i also set the player to read and output the stereo portion.
Rysa_105 is offline
post #3 of 6 Old 10-19-2019, 03:12 AM
glangford's Avatar
Quoted: 739 Post(s)
Liked: 655
You didn't specify which Sony blu ray player, but I suspect it's an older one as most now don't have analog outputs except the X1000es or 1100es. They were never known for outstanding DACs so I'd use hdmi and use the onkyo DAC, it's capable of DSD over HDMI.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #4 of 6 Old 10-19-2019, 07:28 AM - Thread Starter
Rysa_105's Avatar
Quoted: 105 Post(s)
bdp -s780
how's the dac in the new x1100es?
Rysa_105 is offline
post #5 of 6 Old 10-20-2019, 04:55 AM
glangford's Avatar
Quoted: 739 Post(s)
Liked: 655
Originally Posted by Rysa_105 View Post
bdp -s780
No one knows. I've asked and didn't get a response in that thread. If sony isn't saying, it's not a flagship dac by any stretch. Your Onkyo is a pretty high end unit for them and would surely blow away the s780 DAC. Use HDMI. If you want another SACD/bluray player, consider the Pioneer UDP-LX500. It has two channel analog outs and uses a AKM 4490 dac. It's pricey though.
I'd still use HDMI to an AVR regardless of the player. Many AVRs will do a A to D conversion regardless then run it through it's dac. Even pure direct doesn't guarantee a pure analog signal is maintained, as it may just cut off unneeded circuitry. Rule of thumb with an AVR is leave everything in the digital domain as long as possible. I have two Oppo players hooked up to my anthem AVR. I use HDMI, even though the 95 I have on paper beats the Anthem DAC. It sounds fine through the receiver this way. I use the analog outs to a headphone amp.
post #6 of 6 Old 10-25-2019, 02:30 PM
SeeMoreDigital's Avatar
Quoted: 1040 Post(s)
Liked: 833
Most Onkyo AVR's offer pretty decent on-board DSD bit-stream decoding (via HDMI). So when playing SACD's there's nothing stopping you from setting your Sony to output either DSD or PCM audio to see which 'you' personally prefer...
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
Reply CD Players & Dedicated Music Transports
