AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   CD Players & Dedicated Music Transports (https://www.avsforum.com/forum/153-cd-players-dedicated-music-transports/)
-   -   Internal DAC vs. Amp DAC? (https://www.avsforum.com/forum/153-cd-players-dedicated-music-transports/3118240-internal-dac-vs-amp-dac.html)
svenfran 01-23-2020 08:29 AM
Just purchased an Integra CDC-3.4 CD changer to replace my old Sony that died. The manual says, "The digital outputs offer the best audio quality, so if your digital recorder or amp has a digital input you should use it." My amp is a Yamaha RX-V1300 that's quite old, but still works well, and it DOES have digital inputs. QUESTION: Should I use the analog output from the Integra (it uses a Wolfson 192kHz/24-Bit DAC) with my Monster cables, or should I use the Integra's optical output or coax digital output? Or does it really matter? Thanks for any advice.
mlknez 01-23-2020 10:18 AM
Only the cost of a cable to try both
svenfran 01-24-2020 10:16 AM
Good point, can easily try that and will do. Just curious if there's any technical explanation for why Integra (Onkyo) thinks the DAC built into an external amp may be better than the one built into the player.
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
