AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   CD Players & Dedicated Music Transports (https://www.avsforum.com/forum/153-cd-players-dedicated-music-transports/)
-   -   Dac/streamer/app? (https://www.avsforum.com/forum/153-cd-players-dedicated-music-transports/3124360-dac-streamer-app.html)
MDJAK 02-19-2020 12:27 PM
Dac/streamer/app?
I will try to be succinct.
I have a Marantz 8802A in one room.
I have a Marantz 7703 in another. The 7703 has HEOS. I have no idea what that is.
I went in an audio-video store where I purchased a McIntosh MC462 amp. When I sat down to listen, he handed me an iPad that had seemingly limitless choices of music on it.
Is that merely an app and I am already in possession of the ability to stream high quality music with HEOS?
If not, without breaking the bank, meaning no more than 1500, what do I need to stream music through the Marantz 7703?
I have an Oppo dvd player, the original high end model (don't recall the number) and I know that has a DAC, I know the Marantz has a DAC, so I don't know if I need another DAC or something like what's used for movies called the Kaliedoscope which I know is very expensive.
I've tried doing my own research, youtube videos, etc., but can't zero in on what I need.
Thank you in advance for your help.
Mark
crn3371 02-19-2020 04:34 PM
You need a streamer and a subscription to a music service such as Tidal, or Qobuz. For someone starting out I’d recommend the Bluesound Node 2i as your streamer. The Node runs about $500 and connects to the internet via WiFi, or Ethernet. A subscription music service will run you $15-$20 monthly. The Node has an internal DAC with rca outputs, and also digital out, in case you want to use one of your DACs. Do a search for Bluesound and that will point you in the right direction for your research.
glangford 02-20-2020 01:40 AM
Was it a subscription service like Tidal or Quboz, or was it just he had a bunch of ripped music in itunes? If it was ripped music in iTunes, then all you have to do is have an airplay capable device. Select the device in iTunes, hit play and voila.
Roseval 02-20-2020 09:57 AM
Before you start spending money, read a bit about HEOS as it is a multi room audio solution including a couple of streaming audio services.
Hence you already have what you want, a streamer.
https://www.lifewire.com/heos-4155588
Once you have sorted out HEOS, have a look at the 8802A
It supports both DLNA and Airplay so you can use this for streaming audio as well.
MTVhike 03-07-2020 07:38 AM
I have a NAD amp which has BluOS built in, and I can stream from many sources, some of which are free. I thought HEOS was a similar system from Denon (and Marantz). If that's the case, you might be able to stream now using your 7703. I don't know how subscription services, but I assume that if you subscribe, you can stream to any player you own, including a phone. Am I right?
smdelaney 03-07-2020 07:59 AM
Mark
HEOS is a Wireless system available in most newer Denon and Marantz receivers. There is the Receiver component and the App component. With the App you can stream various sources to the HEOS enabled receiver but it is limited to what the App supports...if it is not supported in the app you can't stream it.
On the other side of things HEOS is designed to connect to HEOS <brand> wireless speakers...think SONOS. I'm not 100% sure but I think HEOS has evolved into "Denon Home". If you have HEOS wireless speakers and a HEOS enabled Denon/Marantz receiver any source you can stream to the Receiver you can also stream to the HEOS speakers or you can divide them up into "rooms" and stream the same (or different ) content to each.
Keeping things more general as I'm not sure about your specific receivers (I have the Denon X2400H) ...There are other streaming limits that may come into play depending on how your Receiver handles (or doesn't) passing HDMI/Digital sources to a zone 2.
In my experience HEOS is just OK...the interface leaves a lot to be desired...but it is NOT an end all be all streaming solution.
MDJAK 03-07-2020 08:42 AM
Thank you all for the replies. I wound up buying a Moon Mind Neo 2. Took a bit to finally get it working but I like it.
Trouble I’m now having is I wanted to switch from Tidal to Qobuz as I understand the quality is better.
I can log into the Quboz app so my user name and password are right, but when I select library in the Mind app and select Qobuz and log in it keeps saying wrong log in info. Frustrating. Emailed their support.
They replied to a prior question I had and also suggested using Roon. When I try that I just get Roon searching for a core.
fatuglyguy 03-16-2020 10:25 PM
For Roon, you have to have a main "Core" device running their management software which communicates with your streaming device ("endpoint"). This is usually desktop or laptop that remains on with the Roon app running, or you can purchase their dedicated Nucelus hardware. Roon acts as a single interface for your music library (stored on your PC or on an external drive), and streaming services like Tidal and Qobuz. The experience is great once set up properly but I would get a trial before dipping your toes in as it is isn't cheap.
douglasturci 03-18-2020 08:35 AM
Hi, I think there are other cheaper subscriptions on the market, other apps like soundcloud are much more comfortable. as well as spotify but
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
