Digital source recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-18-2020, 09:00 AM - Thread Starter
mybuddy's Avatar
Hello-I'm looking for recommendation on a new digital source. My current setup is a Denon 2900 CD/SACD, Samsung Blu-ray/DVD player (<$100), Integra DHC 9.9 AVR, Anthem 5ch amplifier & PSB speakers. The Denon 2900 is connected via RCA with the AVR setup to play in Pure Direct mode. The Samsung player is connected via digital coax. with the AVR setup to play movies. I have had this setup for many years & very happy with the results; only forced to make this move because the Denon 2900 has developed a problem (it skips). The 2900 is quite old, and not worth the repair in my mind. My priority is high quality stereo playback of rebook CDs (I have few SACDs). I play BD/DVDs but not so much anymore; for movies I stream via the TV. I don't stream music now, but I would consider it a bonus if the new source is able . I am open to all recommendations, i.e. CD transport, CD player to a universal player, & anything in between. My budget is $500. Thanks in advance.
mybuddy is offline
post #2 of 7 Old 03-19-2020, 11:53 AM
Alex F.'s Avatar
Quoted: 1031 Post(s)
Liked: 618
For CD playback there are many units available within your price range. Take a look at the Tascam CD-200BT ($300), which replaced the excellent CD-200 that I tested at home. Links below to my test (Post 15) and Amazon:
https://www.avsforum.com/forum/173-2...l#post55187756
https://www.amazon.com/Tascam-CD-200...s%2C232&sr=8-1
I have not heard it, but based on my positive experience with the Yamaha CD-N500, consider the Yamaha CD-S300 ($300) as well, available from Crutchfield and elsewhere.
Here is a selection of CD players from the good folks at Crutchfield:
https://www.crutchfield.com/g_53100/...ers.html?&pg=2
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000 II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is offline
post #3 of 7 Old 03-21-2020, 03:18 AM
glangford's Avatar
Quoted: 844 Post(s)
Liked: 740
On the universal playback front there are some options from Sony in your budget. Sony ES UBP-X1100. Plays pretty much every disc video and audio including SACD and DVD-A. It has RCA connection if you prefer that type of connection as well as HDMI. It has the AKM 4452VN dac. My Oppo-203 has the 4458 which I find quite pleasing and the 4452 is the two channel sibling to the 4458 8 channel dac. It's 498 at Crutchfield.
There is it's little sibling, the Sony UBP-X800M2 which plays pretty much all the same things, but sans the RCA connection and front panel display. It's 248 bucks. The 1100 has a 3 year warranty the x800 only 1 year. Both play ripped music from USB.
The only other truly universal player is the Pioneer UBP-LX500, that is 999 bucks and has been out of stock for a while now with on retailer telling me it may be April/May before any inventory shows up.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #4 of 7 Old 03-23-2020, 06:14 AM - Thread Starter
mybuddy's Avatar
glangford I appreciate the feedback. Sony X800M2 & X1100ES have peeked my interest. I like the single box solution to play my legacy CD, SACD, DVD-A, DVD-V and Blu Ray. As far as I can tell, the X1100 has a DAC and the X800 does not. Otherwise both have same features. I plan to connect X800 to Integra AVR via HDMI, and use the Integra's DAC. I'll do more research & confirm this will work.
mybuddy is offline
post #5 of 7 Old 03-24-2020, 02:13 AM
glangford's Avatar
Quoted: 844 Post(s)
Liked: 740
It should, there is not reason it shouldn't. Make sure you get the x800 M2 version if you do. It has Dobly Vision, the older x800 does not.
post #6 of 7 Old 03-31-2020, 11:58 AM
MTVhike's Avatar
Location: North Shore of central Long Island, NY (Stony Brook)
Quoted: 280 Post(s)
Liked: 63
I have the non-M2 version; does it make any difference for audio only? I use it for SACDs.
MTVhike is offline
post #7 of 7 Old 04-01-2020, 02:30 AM
glangford's Avatar
Quoted: 844 Post(s)
Liked: 740
No, for audio, there is no difference. I only mentioned dolby vision as mbuddy expressed the desire for playing video discs as well.
Reply CD Players & Dedicated Music Transports
