Onkyo dx 7555 cd player Help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-02-2020, 12:30 PM - Thread Starter
Liked: 0
I really need some help and advice please.
My CD player is an Onkyo DX 7555.
I had it connected to my Marantz sr5013 via rca cables for the past year or so.
I wanted to try swapping my rca with a digital output cable to see if I would get better sound quality using the DAC of my Marantz rather than Onkyo.
The issue is I cant seem to switch the digi out settings on my Onkyo cd player. It's on page 20 of my owners manual but I just dont know what to do or how to change the current setting from analogue output to digital output.
Currently digital out out is switched off, there is no digital signal.
How can I activate this. Can some one please advise asap. Thanks a ton
Nev1 is offline
post #2 of 3 Old 04-02-2020, 02:30 PM
bobknavs's Avatar
Quoted: 2848 Post(s)
Liked: 2059
My old C-7030 lacks that function.
However, to get into my player's setup, I use the SETUP button the remote. I navigate with the right and left arrow keys that are on either side of the ENTER button. I presume that when you get to Audio, press the ENTER button. Then use the arrow keys to select the desired setting. Press ENTER again, and the display will return COMPLETE.
I use optical, but it's always on. There's no setting to keep digital noise out of the analog output.
The moderators may move these posts, as they're in the wrong forum.
HTH.
bobknavs is offline
post #3 of 3 Old 04-02-2020, 02:49 PM
Transistorious's Avatar
Quoted: 244 Post(s)
Liked: 107
Once you remove the RCA cables and then you connect the digital cable, optical or coaxial to your Marantz AVR you have to go into the Marantz setup menu. Look for digital inputs. Let's say you use a coaxial cable and you connect it to coaxial input #1 . You have to activate coaxial input #1 . I prefer the coaxial cable. Keep in mind that on AVR remote select CD for CD player. Give it a try.
Good luck
"Feels great, baby." SF 49ers QB Jimmy G.
Transistorious is offline
Reply CD Players & Dedicated Music Transports
