Denon DN-300DH tuner : DAB+ connectivity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-23-2020, 12:38 AM - Thread Starter
Liked: 3
Hi,
I have bought a DN-300DH tuner for my basement rack. It does AM/FM but also DAB+.
I'd like to extend the DAB+ antena with a cable but I'm having a hard time identifying what plug it is.
Here is its rear :
https://09f3b4e35b829ef5e143-525d2f2...m/1895/images/[DP32]DN-300DH_Rear_Web_RGB.jpg
Is this a BNC plug ? A "SMA" (never heard of that before) ?
https://en.wikipedia.org/wiki/BNC_connector
https://en.wikipedia.org/wiki/SMA_connector
Thanks for any advice.
aurels_ is offline
post #2 of 13 Old 04-23-2020, 10:07 AM
Roseval's Avatar
Quoted: 87 Post(s)
Liked: 54
Link doesn't work but I assume it is a F type connector
https://www.dabonwheels.co.uk/what-d...ors-look-like/
Compare with the plug of the antena
Roseval is offline
post #3 of 13 Old 04-23-2020, 11:18 AM
MTVhike's Avatar
Location: North Shore of central Long Island, NY (Stony Brook)
Quoted: 280 Post(s)
Liked: 63
Can't see the connector clearly, but it appears to me to be a BNC. Does it have little pins sticking out of the sides? An SMA connector is threaded as is an F-connector, although some of the cable-end F-connectors are push-on.
MTVhike is offline
post #4 of 13 Old 04-24-2020, 12:43 AM - Thread Starter
Liked: 3
Hi, thanks for your replies.
Sorry for the wrongly parsed link. It was the same picture I attached to the post.
I've attached pictures of the male antena plug ;-)
It does not have little pins sticking out of the sides, right ?
I have ordered a SMA cable yesterday (in my timezone), hope it will fit.
This one : https://www.amazon.fr/gp/product/B079YT7NM3
How the hell are there so many coax connector types ?
ID:	2715512   Click image for larger version
aurels_ is offline
post #5 of 13 Old 04-24-2020, 04:59 AM
MTVhike's Avatar
Quoted: 280 Post(s)
Liked: 63
With your better pictures of the coax ends, I'm pretty sure that they are F-connectors. I think SMA are rarely used in home audio and BNC have to have the little pins you say you don't have.
MTVhike is offline
post #6 of 13 Old 04-24-2020, 05:22 AM - Thread Starter
Liked: 3
OK thanks, I'll try if the SMA fits anyway since it's ordered. If it does not, I'll return it.
I'll post the final conclusion here and close the topic.
aurels_ is offline
post #7 of 13 Old 04-24-2020, 05:32 AM - Thread Starter
Liked: 3
I was able to cancel my order.
I'm now looking for a "f type" extension cord with a male plug on one end, and a female plug on the other.
aurels_ is offline
post #8 of 13 Old 04-25-2020, 05:15 AM
ClemC's Avatar
Quoted: 41 Post(s)
Usually you get a Male to Male F-cable, then an F-barrel connector to join the two together. Dont recall ever seeing a Male to female F- cable. https://images-na.ssl-images-amazon...._AC_SX679_.jpg
ClemC is offline
post #9 of 13 Old 04-26-2020, 11:39 PM - Thread Starter
Liked: 3
OK i see, I'll investigate this, thanks.
aurels_ is offline
post #10 of 13 Old 04-28-2020, 10:34 AM - Thread Starter
Liked: 3
I've ordered an assortment of "couplers", let's hope it fits.
aurels_ is offline
post #11 of 13 Old 05-13-2020, 03:42 AM - Thread Starter
Liked: 3
I now have one side of the cable that fits.
I have to find a coupler for the other side, parbably this :
https://www.amazon.fr/Hama-Coupleur-...dp/B00006J9WH/
Thanks for the suggestions @ClemC
aurels_ is offline
post #12 of 13 Old 05-13-2020, 06:22 AM
ClemC's Avatar
Quoted: 41 Post(s)
Originally Posted by aurels_ View Post
I now have one side of the cable that fits.<br />
<br />
I have to find a coupler for the other side, parbably this :<br />
<a href="https://www.amazon.fr/Hama-Coupleur-c%C3%A2ble-dantenne-femelle/dp/B00006J9WH/" target="_blank">https://www.amazon.fr/Hama-Coupleur-c%C3%A2ble-dantenne-femelle/dp/B00006J9WH/</a><br />
<br />
Thanks for the suggestions <!-- BEGIN TEMPLATE: dbtech_usertag_mention -->
@<b><a href="https://www.avsforum.com/forum/member.php?u=7633076" target="_blank">ClemC</a></b>
<!-- END TEMPLATE: dbtech_usertag_mention -->
<br />
<br />
From the picture I pulled up on the net, the DAB connection is a screw-on 75 ohm F-connector. The FM connector is ALSO a 75ohm F-connector, but is a push-on type instead of screw-on.
https://www.amazon.fr/images/I/61ilT%2BcAPvL._AC_SX425_.jpg
ClemC is offline
post #13 of 13 Old 05-28-2020, 12:20 AM - Thread Starter
Liked: 3
I finally received every small parts I needed, and it works !
Thanks to you all.
aurels_ is offline
Reply CD Players & Dedicated Music Transports
