Media player - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By glangford
post #1 of 4 Old 06-14-2020, 03:18 PM - Thread Starter
Enilder's Avatar
Quoted: 14 Post(s)
Media player
I have Onkyo TX8270, and I am looking to purchase a media player. I was primarily looking for a CD player, and got me wondering about what features I should look out for. In the past, I was using another audio system that had everything integrated into the system whereas I am slowly building a system to accommodate music (CD) and blu-ray for movies. Is there a generic all-in-1 media player that people are happy with? Thanks.
Enilder is offline
post #2 of 4 Old 06-15-2020, 01:44 AM
glangford's Avatar
Quoted: 874 Post(s)
Liked: 777
Since you have a receiver with HDMI, you might consider a blu ray player. Sony UDP-X800M2. It is basically a universal player. Plays, CD, SACD, DVD video, DVD-A, and blu ray (both 4k and regular). It's 249 bucks. If you don't care for 4k blu ray and just want standard blu ray you can try the Sony BDP-S6700 for 99 bucks. Doesn't play DVD-A but does, SACD, CD, DVD video and Blu ray.
Want something more upscale, the Sony UPD-X1100es, at 599, plays everything the x800M2 plays and has analog audio out connections.
For CD players, I'd probably look at Marantz.
Enilder likes this.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #3 of 4 Old 06-15-2020, 05:19 AM - Thread Starter
Enilder's Avatar
Quoted: 14 Post(s)
Perfect! BDP-S6700 is what I am going to go with. Thank you!
Enilder is offline
post #4 of 4 Old 06-18-2020, 06:34 AM
Rgb
Rgb's Avatar
Quoted: 824 Post(s)
Liked: 1110
Use it as the disc transport and add an audiophile grade used DAC for low cost/high quality analog output.
See Topping, FX Audio, Cambridge, Meridian, Music Hall DAC models a generation or two behind current for audiophile sound on a budget.
Rgb is offline
Reply CD Players & Dedicated Music Transports
