Need to replace a 24v fan... Use 2 12v fans? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-29-2008, 04:35 PM - Thread Starter
zero-R's Avatar
I recently purchased an SKP pro audio amp and the fan is noooooisy (shocker I know...). I gutted the fan out and its a 92mm 24v fan. Took a trip to the local Fry's and of course, no 24v fans. Went online and all the fans I saw were on the order of 30 db+ minimum for 92mm. Is 30db quiet enough? Or is that roughly what it sounds like now?
My question is, can I buy 2 12v 60mm fans and wire them up in series (so in theory they see 12V each)? I saw a few 60mm fans that were around 11 db so I figure 2 of them together would still be a vast improvement over the vacuum cleaner I have roaring now.
Got $$?
zero-R is offline
post #2 of 11 Old 03-29-2008, 04:40 PM
DonoMan's Avatar
Quoted: 254 Post(s)
Liked: 197
30dB isn't super quiet for a fan but it's not a Vantec Tornado by any means. You can wire up 12v fans in series, yes, or you can use a properly sized resistor to sink some of the extra voltage.
DonoMan is offline
post #3 of 11 Old 03-29-2008, 07:32 PM
Looneybomber's Avatar
Liked: 29
I put 2, 80mm fans in my EP2500. Each were 14db fans, which helped cut the noise drastically! Check computer stores online if they have any quiet 92mm fans, otherwise I'd go for the 80's
YID DIY
Looneybomber is offline
post #4 of 11 Old 03-30-2008, 05:45 PM
JBJR's Avatar
You need to find out how much air you need to move and then go from there. You can order 24v fans from Mouser or Digikey. Get one that moves more air than the stock fan and then put a 15v voltage regulator in line. that will lower the speed of the fan and still move enough air and be make it much more quiet.
JBJR is offline
post #5 of 11 Old 04-11-2008, 06:16 PM
Nordo's Avatar
Quoted: 64 Post(s)
Liked: 40
I assume your saying you used two 12v fans wired in series.
Where did you put them?
Did you stack them in series where the old one was, or did you put the second one somewhere else?
I'm waiting for my EP2500 to arrive, and this will be the first mod I do.
Nordo is offline
post #6 of 11 Old 04-11-2008, 06:55 PM - Thread Starter
zero-R's Avatar
I went with two 12V 80mm fans rated at 11 db (or 9 db, whatever it is, I can't hear it) and just put both on top of the heat sink, side by side (not stacked on top of each other). My amp has yet to get hot at all.
Got $$?
zero-R is offline
post #7 of 11 Old 04-11-2008, 08:12 PM
Liked: 29
I should have taken pictures. There's a guy on HTS that wants pics too.
Both fans are in series and piggybacked where the existing fan went. One fan goes outside the shrowd in the existing location, one goes inside. Doing that, you have to route 4-5 wires up over the heatsink because of a lack of clearence under the shrowd where all the wires originally ran.
YID DIY
post #8 of 11 Old 04-12-2008, 12:15 AM
Nordo's Avatar
Quoted: 64 Post(s)
Liked: 40
Thanks, I thought that would be the way to go.
I'll now go ahead and buy a 5-pack of fans, as I want to put some on top of my Onkyo 805.
What were the 14dB fans you used?
Nordo is offline
post #9 of 11 Old 04-12-2008, 07:02 AM
Liked: 29
http://www.enermaxusa.com/catalog/pr...roducts_id=102
I saw them for sale some place for like 7 bucks. I bought mine at Tiger Direct (before I saw them someplace cheaper) for around 11.00, but they no longer carry them.
YID DIY
post #10 of 11 Old 04-12-2008, 07:06 PM
Nordo's Avatar
Quoted: 64 Post(s)
Liked: 40
I got impatient, so I ordered 5 fans last night.
I hunted around a bit and ended up with Glacialtech SilentBlade GT8025EDL-A1.
They were $5.00au each.
They are rated at 26.3cfm at 18dB.
They're not as quiet as the Enermaxs, which are rated at 14dB.
I tried for the Enermaxs, but we don't have them here in Australia, and I couldn't be bothered ordering from overseas. The shipping would cost more than the fans.
As it was, I had to pay $12.40 for postage, which was the cheapest and slowest that was offered.
Thanks for all the help.
Nordo is offline
post #11 of 11 Old 04-13-2008, 08:06 AM
fperra's Avatar
Quoted: 50 Post(s)
Liked: 71
I replaced all the 24 volt fans in my 6 QSC amps with quiet 12 volt fans. I dropped the 24 volts to 12 using a 3 pin IC regulator in series with the original 24 volts.
fperra is offline
