TheEAR made me feel inferior with my 500W sub amp, so... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-18-2008, 11:14 AM - Thread Starter
DonoMan's Avatar
Quoted: 238 Post(s)
Liked: 191
For now, I've ordered an AMP8 kit from http://www.41hz.com/. It should do about 1350W into 4 ohms at low distortion. I have one of these chassis already that I hope it'll fit in: http://www.atiresearch-anodized.com/ATI-661U.html
I've got a couple of 500VA 25-0-25 trafos which give me 70V if I leave the CTs out. I'm thinking I might unwind the secondaries to make them 20-0-20. I also play to run this on 220V eventually, so I think I should be able to just switch to using the center taps at that time instead. What do you guys think? I can't seem to find a cheap and good SMPS at this voltage. Coldamp makes one but they've got a bad rep. over at DIYAudio.
Edit: and of course, I will have to make a softstart module, but that's not too hard.
DonoMan is offline
post #2 of 9 Old 04-18-2008, 12:18 PM
TheEAR's Avatar
Inferior why? 15W(from a Tenor OTL) may be gold in some applications ...
It is not simply huge wattage...but quality watts.
Ask yourself mortal , do you have as much displacement as me ? The answer is no unless you have a Windmere fan sub.
TheEAR is offline
post #3 of 9 Old 04-18-2008, 12:45 PM - Thread Starter
DonoMan's Avatar
Quoted: 238 Post(s)
Liked: 191
ha, really though, I just need more power. Like Tim Taylor minus the stuff blowing up.
DonoMan is offline
post #4 of 9 Old 04-18-2008, 12:59 PM
thylantyr's Avatar
*See is the +/- 60v design is sensitive to a higher voltage.
*Softstart not mandatory for dual 500VA's.
*220VAC supply is nice, but not critical to have.
*Quality watts? lol
*"I just need more power" proamps ?
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
post #5 of 9 Old 04-18-2008, 01:05 PM - Thread Starter
DonoMan's Avatar
Quoted: 238 Post(s)
Liked: 191
+/- 65v is absolute max for that chip. My trafos will do 70v as-is. And soft-start is getting put in anyway because I already have the parts for it.
DonoMan is offline
post #6 of 9 Old 04-18-2008, 01:31 PM
thylantyr's Avatar
I would use +/- 60v to be safe. Tweak the transformer as needed.
post #7 of 9 Old 04-18-2008, 03:48 PM
TheEAR's Avatar
Thylantyr,
Yes sir quality wattage...for the PLACEBO masters, Poupon fanatics in the 50K plus section of AVS ! They are insulted at anything below...in your face 500lbs amp.
TheEAR is offline
post #8 of 9 Old 04-20-2008, 09:32 PM
Vinculum's Avatar
Quoted: 13 Post(s)
Originally Posted by TheEAR View Post
Thylantyr,
Maybe some ERS paper will help.
https://www.avsforum.com/avs-vb/showthread.php?t=741626
I must personally thank Thylantyr for that link, via Undergroupd Audio. I'm only up to the part about disposable projectors - the real money is spent on the power cord! What a GREAT read to cramp the laugh muscles!
Vinculum is offline
post #9 of 9 Old 04-21-2008, 01:31 AM
armystud0911's Avatar
The DIY area has been growing here lately, with that, there has been an influx of folks getting into audio voodoo, we need to stomp this out before it takes hold.
armystud0911 is offline
