Ribbons VS Electrostatics - HF extension - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 11-28-2008, 08:24 AM - Thread Starter
vasyachkin's Avatar
i know some ribbons have response to 100 khz
on the other hand i look at the specs of speakers like Quad and Martin Logan and they only have response to about 21 - 25 khz.
is this due to the transformer ? or is this because of the capacitance of the speaker itself ? or interaction of the two ?
are there any speakers that use Ribbon Tweeter with Electrostatic Midrange ?
is that what this speaker used:
http://www.apogeespeakers.com/the_grand.htm
vasyachkin is offline
post #2 of 26 Old 12-02-2008, 02:22 PM
Looneybomber's Avatar
Liked: 29
While some ribbons and domes can play upwards of 40khz or more, what's the point? Ask yourself if something you can't hear, feel, or perceive in anyway, is at all important.
To answer your question, why an electrostat is rated to 21-25k where-as some ribbons and domes can play much higher, I'd have to guess it has to do with the physics of how an electrostat works. But I don't know.
YID DIY
Looneybomber is offline
post #3 of 26 Old 12-03-2008, 12:21 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
B&W's theory and research as to why they went from there old to the new higher frequency Diamond tweeters in the Flagship 800 series speakers is because of the gain in "headroom" which in B&W's research showed and meant A step up in accuracy in the lower audible range of the new Diamond tweeter....
Cheers....
cinema mad is offline
post #4 of 26 Old 12-03-2008, 05:29 AM
brandonnash's Avatar
Liked: 34
Another of their theories is that if HF is extended that much then the sound "breakup" won't occur until well past the range of your hearing. Meaning a "breakup" free sound in your hearing range. Very clean. I haven't heard their diamond drivers, but it at least makes some sense (but not in the pocket though).
brandonnash is offline
post #5 of 26 Old 12-03-2008, 06:34 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Yes When you have the 800 801's or 802's Diamond series B&W speakers or go to A certified 800 series dealer you get A book and DVD that explains about what you have stated above...
B&W are Extremely advanced in the research and develepment of speakers, I guess that is why recording studios like Abbey road choose B&W 800's :quote " recording equitment must offer nothing less than absolute definition and purity. In all three main studios, its Penthouse and its mobile units, Abbey Road employs the 800 Series to monitor the output of the most demanding artists.."
I can tell you first hand that they are awsome speakers ...
Cheers....
post #6 of 26 Old 12-03-2008, 02:38 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 822
Abbey Road also uses Shakti Stones Nothing against the speakers mind you.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #7 of 26 Old 12-03-2008, 05:10 PM
b curry's Avatar
Quoted: 1067 Post(s)
Liked: 678
Apogees were a combination of planar magnetic and ribbon speakers.
Some of the Magnapans are of similar construction.
I know of no speaker combining electrostatic and ribbon drivers.
b curry is offline
post #8 of 26 Old 12-03-2008, 05:24 PM - Thread Starter
vasyachkin's Avatar
we could be the first ?
lol.
i think it would make a lot of sense. electrostatic speaker is capacitive so extremely difficult to drive at high frequencies. on the other hand ribbon speaker is not, but extremely expensive if you're trying to make it reproduce anything lower than 1 khz.
a match made in heaven ?
post #9 of 26 Old 12-03-2008, 06:38 PM
Aaron Gilbert's Avatar
lol.
Oh I don't know that an electrostatic is so hard to drive at high frequencies. I have driven several dozen different Martin Logan electrostatics from some of the oldest to the newest, at high volumes, from a mid 1990's Kenwood receiver - albeit a very beefy one which has no problem with low impedance loads.
Aaron Gilbert is offline
post #10 of 26 Old 12-03-2008, 06:41 PM - Thread Starter
vasyachkin's Avatar
i think those Martin Logans spec the impedance falling to under 1 ohm at 20 khz ?
post #11 of 26 Old 12-03-2008, 06:53 PM
I don't believe it's that low. It varies from model to model, but the latest specification I heard was only in the two ohm range, maybe just under. There might be a model or two that goes down to one ohm, but I have tested most of them and not had any problems: Monolith, SL2, SL3, Quest, ReQuest, Ascent, Cinema, Theater, Aerius, Clarity, Odyssey, Prodigy, Vista, Vantage, etc.
But on the other hand, how much power is actually needed at 20 kHz? I don't believe it's that much, even when the average level is high. I can't hear past about 17 kHz though, so couldn't tell you how loud it is at 20k.
post #12 of 26 Old 12-04-2008, 04:16 AM
b curry's Avatar
Liked: 678
I could be wrong but IIRC the original Monolith or maybe CLS gave some amplifiers a little trouble.
For sure, some of the Apogees fried a few amplifiers.
b curry is offline
post #13 of 26 Old 12-04-2008, 04:20 AM
b curry's Avatar
Liked: 678
lol.
Interesting idea...
I would be concerned about the permanent magnets for the ribbons interfering with the field for the stats. But it would be a interesting project!
b curry is offline
post #14 of 26 Old 12-04-2008, 09:27 AM - Thread Starter
vasyachkin's Avatar
Interesting idea...
thanks.
by the way i think electric field cancels outside of the capacitor because one plate is + and one is - . so the field is only between the stators. shouldn't interfere with ribbons nearby imho.
post #15 of 26 Old 12-04-2008, 02:32 PM
b curry's Avatar
Liked: 678
thanks.
Yes, I don't see interference from the electrostatic part, really just the other way around.
I am using Apogee's in my two channel rig. The permanent magnets are very strong; pretty much impossible to have them next to a CRT display with out induced distortion on the display. I see the possibility of interference with the pole pieces of the stat's from the permanent magnets field of the ribbon; the stat's being a push pull arrangement.
Like I said though, it is an interesting idea and it makes me want to play around with the concept. It seems like it might be a possible solution or help with high frequency beaming or off axis problems with high frequency common in stat's. However, it would certainly seem like someone would have done this by now though???
b curry is offline
post #16 of 26 Old 12-06-2008, 07:09 AM - Thread Starter
vasyachkin's Avatar
ok, in theory there could be some interaction. but i think it would be minor in magnitude.
rather than trying to calculate it if you're interested i think you should simply take a magnet to an electrostatic speaker while its playing and see if you hear any difference.
also a ribbon could be partially shielded.
as for your question about whether it has been tried ? - i don't know. but i can give you one reason why maybe it wasn't. because people are religious about high end audio. they believe in things like "voicing". they are probably either hung up on ribbons or on stats and quite likely will not even consider a hybrid like this.
by the way i would complete this speaker with an array of scan-speak illuminators, sealed, for bass.
post #17 of 26 Old 12-06-2008, 11:28 AM
catapult's Avatar
Old news, guys. ThomasW over at HTG has been using a setup like that for ages. It started out as 2 Acoustat panels with a line of Technics leaf tweeters in between.
Later, he added an RD75 midrange, shown here just propped in place for testing and later built in.
Dennis H
catapult is offline
post #18 of 26 Old 12-06-2008, 03:59 PM - Thread Starter
vasyachkin's Avatar
ok but i don't want to buy an electrostatic "speaker"
i would buy just a panel if that is possible. ?
also i would definitely use an array of small woofers for bass.
i don't really understand the point of a BG midrange in there ? cant the acoustat go up to about 3 khz to meet up with something like Raven or Raal ?
also i think a curved panel ( a la martin logan ) would be more appropriate here since we would be trying to emulate a line source.
post #19 of 26 Old 12-06-2008, 05:15 PM
catapult's Avatar
That would be a cheaper way to go if starting from scratch but it's not needed if you happen to have the stat panels on hand. They have enough surface area to play low enough to cross to the IB sub. You can find them used once in a while at a pretty good price.
Because it sounds better. The stats can play plenty high but their width gives you a very narrow sweet spot at high frequencies -- the old wavelength thing.
Not sure but I think Thomas's XOs are around 50, 600 and 5K.
Edit: here's a recent thread where Thomas talks about cones vs. stats, both of which he has used. Both can work well.
http://www.htguide.com/forum/showthread.php4?t=31291
Dennis H
catapult is offline
post #20 of 26 Old 12-06-2008, 05:52 PM - Thread Starter
vasyachkin's Avatar
you know that BG ribbon was never designed for hi-fi
i have real doubts about its potential
on the other hand its likely that in a certain narrow band ( say 500 hz - 5 khz ) it performs very well ... but i am still not very excited about using it
i would rather get an electrostatic panel with curvature to overcome the beaming issue ... but then that's subject to availability ... unless you build one yourself ... but then i don't really wanna do that =/
do you think this one:
http://www.radiapro.net/uploads/NEO10DataSheet.pdf
would be better than:
http://www.radiapro.net/uploads/DataBook10pLogo.pdf
how is the availability / price on those ?
post #21 of 26 Old 12-06-2008, 07:25 PM
catapult's Avatar
Well, it helps hide it but it doesn't really overcome it. Do the math -- wide sources (wider than a wavelength) aren't really all that good for high frequencies no matter how you bend and shape them .
That said, plenty of people like stats run fullrange. Whatever sounds good to them is just fine with me.
Dennis H
catapult is offline
post #22 of 26 Old 12-06-2008, 09:38 PM - Thread Starter
vasyachkin's Avatar
that is WRONG.
cylinder is same as a line source no matter the radius.
sphere is same as a point no matter the radius.
if you want i can explain a universal way of thinking about all this so you will not need to memorize anything and will be able to analyze any geometry.
post #23 of 26 Old 12-07-2008, 01:12 AM
catapult's Avatar
No, thanks.
Dennis H
catapult is offline
post #24 of 26 Old 12-07-2008, 07:52 AM - Thread Starter
vasyachkin's Avatar
No, thanks.
the problem with bent panel is that its not quite a cylinder ...
but then a regular panel is not quite a plane ...
so there will be some artifacts with both obviously.
post #25 of 26 Old 12-08-2008, 09:35 AM
JLemay's Avatar
Hey Vas,
There was one system I know of that used an electrostatic mid and ribbon tweets. It was the Mark Levinson HQD. It consisted of Hartley 24" woofers, a pair of stacked Quad 57s and a Decca ribbon tweet. It was state of the art when it was made (70's) and came very highly regarded, though I've never personally heard one.
BTW, if I understand line array theory correctly, any true line launches a cylindrical wave. It doesn't have to be a cylindrical shaped panel.
JLemay is offline
post #26 of 26 Old 12-08-2008, 11:26 PM - Thread Starter
vasyachkin's Avatar
well obviously.
you should read the "Line, Point and Plane sources - implications for audio" article on my site.
basically you want to try and move away from sources with zero dimensions because they can never be anything but a gross approximation. a cylinder can be a real cylinder. a line can't be a real line - because a real line has zero width which is impossible in reality.
